07-Layer 3—IP Routing Configuration Guide
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration GuidesH3C CR16000-F Routers Configuration Guides-R8530Pxx-6W10107-Layer 3—IP Routing Configuration Guide
10-RIPng configuration
10-RIPng configuration 326.06 KB
Configuring RIPng
About RIPng
RIP next generation (RIPng), as an extension of RIP-2 for support of IPv6, is a distance vector routing protocol. It employs UDP to exchange route information through port 521. Most RIP concepts are applicable to RIPng.
RIPng routing metrics
RIPng uses a hop count to measure the distance to a destination. The hop count is the metric or cost. The hop count from a router to a directly connected network is 0. The hop count between two directly connected routers is 1. When the hop count is greater than or equal to 16, the destination network or host is unreachable.
RIPng route entries
RIPng stores route entries in a database. Each route entry contains the following elements:
·     Destination address—IPv6 address of a destination host or a network.
·     Next hop address—IPv6 address of the next hop.
·     Egress interface—Egress interface of the route.
·     Metric—Cost from the local router to the destination.
·     Route time—Time elapsed since the most recent update. The time is reset to 0 every time the route entry is updated.
·     Route tag—Used for route control. For more information, see "Configuring routing policies."
RIPng packets and advertisement
RIPng multicasts request and response packets to exchange routing information. It uses FF02::9 as the destination address and link-local address FE80::/10 as the source address. RIPng exchanges routing information as follows:
1.     When RIPng starts or needs to update some route entries, it sends a multicast request packet to neighbors.
2.     When a RIPng neighbor receives the request packet, it sends back a response packet that contains the local routing table. RIPng can also advertise route updates in response packets periodically or advertise a triggered update caused by a route change.
3.     After RIPng receives the response, it checks the validity of the response before adding routes to its routing table, including the following details:
¡     Whether the source IPv6 address is the link-local address.
¡     Whether the port number is correct.
4.     A response packet that fails the check is discarded.
Protocols and standards
·     RFC 2080, RIPng for IPv6
·     RFC 2081, RIPng Protocol Applicability Statement
RIPng tasks at a glance
To configure RIPng, perform the following tasks:
1.     Configuring basic RIPng
2.     (Optional.) Configuring RIPng route control
¡     Configuring an additional routing metric
¡     Configuring RIPng route summarization
¡     Advertising a default route
¡     Configuring received/redistributed route filtering
¡     Setting a preference for RIPng
¡     Configuring RIPng route redistribution
3.     (Optional.) Tuning and optimizing the RIPng network
¡     Setting RIPng timers
¡     Configuring split horizon and poison reverse
¡     Setting the maximum number of ECMP routes
¡     Configuring the RIPng packet sending rate
¡     Setting the interval for sending triggered updates
4.     (Optional.) Enhancing RIPng availability
¡     Configuring RIPng GR
¡     Configuring RIPng FRR
5.     (Optional.) Enhancing RIPng security
¡     Configuring zero field check for RIPng packets
¡     Applying an IPsec profile
2.     Enable RIPng and enter its view.
ripng [ process-id ] [ vpn-instance vpn-instance-name ]
By default, RIPng is disabled.
3.     Return to system view.
4.     Enter interface view.
5.     Enable RIPng on the interface.
ripng process-id enable
By default, RIPng is disabled on the interface.
If RIPng is not enabled on an interface, the interface does not send or receive any RIPng route.
An additional routing metric (hop count) can be added to the metric of an inbound or outbound RIPng route.
·     An outbound additional metric is added to the metric of a sent route, and it does not change the route's metric in the routing table.
·     An inbound additional metric is added to the metric of a received route before the route is added into the routing table, and the route's metric is changed.
2.     Enter interface view.
3.     Specify an inbound additional routing metric.
ripng metricin value
The default additional metric of an inbound route is 0.
4.     Specify an outbound additional routing metric.
ripng metricout value
The default additional metric of an outbound route is 1.
RIPng route summarization is interface-based. RIPng advertises a summary route based on the longest match.
RIPng route summarization improves network scalability, reduces routing table size, and increases routing table lookup efficiency.
RIPng advertises a summary route with the smallest metric of all the specific routes.
For example, RIPng has two specific routes to be advertised through an interface: 1:11:11::24 with a metric of a 2 and 1:11:12::34 with a metric of 3. Configure route summarization on the interface, so RIPng advertises a single route 11::0/16 with a metric of 2.
3.     Advertise a summary IPv6 prefix.
ripng summary-address ipv6-address prefix-length
By default, no summary IPv6 prefix is configured on the interface.
You can configure RIPng to advertise a default route with the specified cost to its neighbors.
3.     Configure RIPng to advertise a default route.
ripng default-route { only | originate } [ cost cost-value | route-policy route-policy-name ] *
By default, RIPng does not advertise a default route.
This command advertises a default route on the current interface regardless of whether the default route exists in the local IPv6 routing table.
Perform this task to filter received or redistributed routes by using an IPv6 ACL or IPv6 prefix list. You can also configure RIPng to filter routes redistributed from other routing protocols and routes from a specified neighbor.
2.     Enter RIPng view.
3.     Configure a filter policy to filter received routes.
filter-policy { ipv6-acl-number | prefix-list prefix-list-name } import
By default, RIPng does not filter received routes.
4.     Configure a filter policy to filter redistributed routes.
filter-policy { ipv6-acl-number | prefix-list prefix-list-name } export [ bgp4+ | direct | { isisv6 | ospfv3 | ripng } [ process-id ] | static | unr ]
By default, RIPng does not filter redistributed routes.
Routing protocols each have a preference. When they find routes to the same destination, the route found by the routing protocol with the highest preference is selected as the optimal route. You can manually set a preference for RIPng. The smaller the value, the higher the preference.
3.     Set a preference for RIPng.
By default, the preference of RIPng is 100.
3.     Configure route redistribution.
import-route bgp4+ [ as-number ] [ allow-ibgp ] [ cost cost-value | route-policy route-policy-name ] *
import-route { direct | static | unr } [ cost cost-value | route-policy route-policy-name ] *
import-route { isisv6 | ospfv3 | ripng } [ process-id ] [ allow-direct | cost cost-value | route-policy route-policy-name ] *
By default, RIPng does not redistribute routes.
4.     (Optional.) Set a default routing metric for redistributed routes.
default cost cost-value
The default metric of redistributed routes is 0.
You can adjust RIPng timers to optimize the performance of the RIPng network.
When you adjust RIPng timers, consider the network performance, and perform unified configurations on routers running RIPng to avoid unnecessary network traffic or route oscillation.
3.     Set RIPng timers.
The default settings are as follows:
¡     The update timer is 30 seconds.
¡     The timeout timer is 180 seconds.
¡     The suppress timer is 120 seconds.
¡     The garbage-collect timer is 120 seconds.
Restrictions and guidelines for split horizon and poison reverse
When you configure split horizon and poison reverse, following these restrictions and guidelines:
·     If both split horizon and poison reverse are configured, only the poison reverse feature takes effect.
·     Split horizon disables RIPng from sending routes through the interface where the routes were learned to prevent routing loops between neighbors. As a best practice, enable split horizon to prevent routing loops in normal cases.
·     Poison reverse enables a route learned from an interface to be advertised through the interface. However, the metric of the route is set to 16, which means the route is unreachable.
3.     Enable split horizon.
ripng split-horizon
By default, split horizon is enabled.
Configuring poison reverse
3.     Enable poison reverse.
ripng poison-reverse
By default, poison reverse is disabled.
3.     Set the maximum number of ECMP routes.
maximum load-balancing number
By default, the maximum number of RIPng ECMP routes is 128.
Perform this task to specify the interval for sending RIPng packets and the maximum number of RIPng packets that can be sent at each interval. This feature can avoid excessive RIPng packets from affecting system performance and consuming too much bandwidth.
3.     Configuring the RIPng packet sending rate.
¡     Execute the following commands in sequence to configure the RIPng packet sending rate in RIPng view:
output-delay time count count
By default, an interface that runs the RIPng process sends a maximum of three RIPng packets every 20 milliseconds.
¡     Execute the following commands in sequence to configure the RIPng packet sending rate in interface view:
ripng output-delay time count count
By default, an interface uses the RIPng packet sending rate of the RIPng process that it runs.
Perform this task to avoid network overhead and reduce system resource consumption caused by frequent RIPng triggered updates.
You can use the timer triggered command to set the maximum interval, minimum interval, and incremental interval for sending RIPng triggered updates.
For a stable network, the minimum interval is used. If network changes become frequent, the triggered update sending interval is incremented by the incremental interval × 2n-2 for each triggered update until the maximum interval is reached. The value n is the number of triggered update times.
3.     Set the interval for sending triggered updates.
The default maximum interval is 5 seconds, the default minimum interval is 50 milliseconds, and the default incremental interval is 200 milliseconds.
GR ensures forwarding continuity when a routing protocol restarts or an active/standby switchover occurs.
Two routers are required to complete a GR process. The following are router roles in a GR process:
·     GR restarter—Graceful restarting router. It must have GR capability.
·     GR helper—A neighbor of the GR restarter. It helps the GR restarter to complete the GR process.
After RIPng restarts on a router, the router must learn RIPng routes again and updates its FIB table, which causes network disconnections and route reconvergence.
With the GR feature, the restarting router (known as the GR restarter) can notify the event to its GR capable neighbors. GR capable neighbors (known as GR helpers) maintain their adjacencies with the router within a configurable GR interval. During this process, the FIB table of the router does not change. After the restart, the router contacts its neighbors to retrieve its FIB.
By default, a RIPng-enabled device acts as the GR helper. Perform this task on the GR restarter.
2.     Enable RIPng and enter RIPng view.
3.     Enable the GR capability for RIPng.
graceful-restart
By default, RIPng GR is disabled.
4.     (Optional.) Set the GR interval.
The default GR interval is 60 seconds.
About RIPng FRR
A link or router failure on a path can cause packet loss and even routing loop until RIPng completes routing convergence based on the new network topology. FRR enables fast rerouting to minimize the impact of link or node failures.
Figure 1 Network diagram for RIPng FRR
As shown in Figure 1, configure FRR on Router B by using a routing policy to specify a backup next hop. When the primary link fails, RIPng directs packets to the backup next hop. At the same time, RIPng calculates the shortest path based on the new network topology. Then, the device forwards packets over that path after network convergence.
Restrictions and guidelines for RIPng FRR
RIPng FRR is available only when the state of the primary link (with Layer 3 interfaces staying up) changes from bidirectional to unidirectional or down.
RIPng FRR is only effective for RIPng routes that are learned from directly connected neighbors.
Equal-cost routes do not support RIPng FRR.
Enabling RIPng FRR
2.     Configure a routing policy.
You must specify a next hop by using the apply ipv6 fast-reroute backup-interface command in a routing policy and specify the routing policy for FRR.
For more information about routing policy configuration, see "Configuring routing policies."
3.     Enter RIPng view.
4.     Enable RIPng FRR.
By default, RIPng FRR is disabled.
Enabling BFD for RIPng FRR
By default, RIPng FRR does not use BFD to detect primary link failures. For quicker RIPng FRR, use BFD single-hop echo detection on the primary link of redundant links to detect link failure.
2.     (Optional.) Configure the source IP address of BFD echo packets.
By default, the source IP address of BFD echo packets is not configured.
As a best practice, configure this command and do not specify a source IPv6 address on the same network segment as any local interfaces. This can avoid network congestion caused by a large number of ICMPv6 redirect packets sent from the peer.
For more information about this command, see High Availability Command Reference.
3.     Enter interface view.
4.     Enable BFD single-hop echo detection for RIPng FRR.
ripng primary-path-detect bfd echo
By default, BFD single-hop echo detection is disabled for RIPng FRR.
Some fields in the RIPng packet header must be zero. These fields are called zero fields. You can enable zero field check for incoming RIPng packets. If a zero field of a packet contains a non-zero value, RIPng does not process the packets. If you are certain that all packets are trustworthy, disable the zero field check to save CPU resources.
3.     Enable the zero field check for incoming RIPng packets.
checkzero
By default, zero field check for incoming RIPng packets is enabled.
To protect routing information and prevent attacks, you can configure RIPng to authenticate protocol packets by using an IPsec profile.
An IPsec profile contains inbound and outbound security parameter indexes (SPIs). RIPng compares the inbound SPI defined in the IPsec profile with the outbound SPI in the received packets. Two RIPng devices accept the packets from each other and establish a neighbor relationship only if the SPIs are the same and the relevant IPsec profiles match.
For more information about IPsec profiles, see Security Configuration Guide.
You can apply an IPsec profile to a RIPng process or to an interface. If an interface and its process each have an IPsec profile, the IPsec profile applied to the interface takes effect.
Applying an IPsec profile to a process
3.     Apply an IPsec profile to the process.
enable ipsec-profile profile-name
By default, no IPsec profile is applied.
Applying an IPsec profile to an interface
3.     Apply an IPsec profile to the interface.
ripng ipsec-profile profile-name
Display and maintenance commands for RIPng
Display configuration information for a RIPng process.
display ripng [ process-id ]
Display routes in the RIPng database.
display ripng process-id database [ ipv6-address prefix-length ]
Display RIPng GR information.
display ripng [ process-id ] graceful-restart
Display interface information for a RIPng process.
display ripng process-id interface [ interface-type interface-number ]
Display neighbor information for a RIPng process.
display ripng process-id neighbor [ interface-type interface-number ]
Display RIPng NSR information.
display ripng [ process-id ] non-stop-routing
Display the routing information for a RIPng process.
display ripng process-id route [ ipv6-address prefix-length [ verbose ] | peer ipv6-address | statistics ]
Restart a RIPng process.
reset ripng process-id process
Clear statistics for a RIPng process.
reset ripng process-id statistics
RIPng configuration examples
Example: Configuring basic RIPng
As shown in Figure 2, Router A, Router B, and Router C learn IPv6 routing information through RIPng. Configure route filtering on Router B to accept all received routes except the route 2::/64 and to advertise only the route 4::/64.
Figure 2 Network diagram
1.     Configure IPv6 addresses for the interfaces. (Details not shown.)
2.     Configure basic RIPng settings:
# Configure Router A.
[RouterA] ripng 1
[RouterA-ripng-1] quit
[RouterA] interface ten-gigabitethernet 3/1/1
[RouterA-Ten-GigabitEthernet3/1/1] ripng 1 enable
[RouterA-Ten-GigabitEthernet3/1/1] quit
[RouterA] interface ten-gigabitethernet 3/1/2
[RouterA-Ten-GigabitEthernet3/1/2] ripng 1 enable
[RouterA-Ten-GigabitEthernet3/1/2] quit
# Configure Router B.
<RouterB> system-view
[RouterB] ripng 1
[RouterB-ripng-1] quit
[RouterB] interface ten-gigabitethernet 3/1/1
[RouterB-Ten-GigabitEthernet3/1/1] ripng 1 enable
[RouterB-Ten-GigabitEthernet3/1/1] quit
[RouterB] interface ten-gigabitethernet 3/1/2
[RouterB-Ten-GigabitEthernet3/1/2] ripng 1 enable
[RouterB-Ten-GigabitEthernet3/1/2] quit
# Configure Router C.
<RouterC> system-view
[RouterC] ripng 1
[RouterC-ripng-1] quit
[RouterC] interface ten-gigabitethernet 3/1/1
[RouterC-Ten-GigabitEthernet3/1/1] ripng 1 enable
[RouterC-Ten-GigabitEthernet3/1/1] quit
[RouterC] interface ten-gigabitethernet 3/1/2
[RouterC-Ten-GigabitEthernet3/1/2] ripng 1 enable
[RouterC-Ten-GigabitEthernet3/1/2] quit
[RouterC] interface ten-gigabitethernet 3/1/3
[RouterC-Ten-GigabitEthernet3/1/3] ripng 1 enable
[RouterC-Ten-GigabitEthernet3/1/3] quit
# Display the RIPng routing table on Router B.
[RouterB] display ripng 1 route
   Route Flags: A - Aging, S - Suppressed, G - Garbage-collect, D – Direct
                O - Optimal, F - Flush to RIB
 Peer FE80::20F:E2FF:FE23:82F5 on Ten-GigabitEthernet3/1/1
 Destination 2::/64,
     via FE80::20F:E2FF:FE23:82F5, cost 1, tag 0, AOF, 6 secs
 Peer FE80::20F:E2FF:FE00:100  on Ten-GigabitEthernet3/1/2
 Destination 4::/64,
     via FE80::20F:E2FF:FE00:100, cost 1, tag 0, AOF, 11 secs
 Destination 5::/64,
 Local route
 Destination 1::/64,
     via ::, cost 0, tag 0, DOF
 Destination 3::/64,
# Display the RIPng routing table on Router A.
[RouterA] display ripng 1 route
 Peer FE80::200:2FF:FE64:8904 on Ten-GigabitEthernet3/1/1
 Destination 3::/64,
     via FE80::200:2FF:FE64:8904, cost 1, tag 0, AOF, 31 secs
 Destination 4::/64,
     via FE80::200:2FF:FE64:8904, cost 2, tag 0, AOF, 31 secs
 Destination 5::/64,
 Local route
 Destination 2::/64,
 Destination 1::/64,
3.     Configure route filtering:
# Use IPv6 prefix lists on Router B to filter received and redistributed routes.
[RouterB] ipv6 prefix-list aaa permit 4:: 64
[RouterB] ipv6 prefix-list bbb deny 2:: 64
[RouterB] ipv6 prefix-list bbb permit :: 0 less-equal 128
[RouterB] ripng 1
[RouterB-ripng-1] filter-policy prefix-list aaa export
[RouterB-ripng-1] filter-policy prefix-list bbb import
# Display the RIPng routing tables on Router B and Router A.
 Peer FE80::1:1 on Ten-GigabitEthernet3/1/1
 Peer FE80::3:1 on Ten-GigabitEthernet3/1/2
 Destination 4::/64,
     via FE80::2:2, cost 1, tag 0, AOF, 11 secs
 Destination 5::/64,
 Local route
 Destination 1::/64,
 Destination 3::/64,
 Peer FE80::2:1 on Ten-GigabitEthernet3/1/1
 Destination 4::/64,
     via FE80::1:1, cost 2, tag 0, AOF, 2 secs
 Local route
 Destination 1::/64,
 Destination 2::/64,
Example: Configuring RIPng route redistribution
As shown in Figure 3, Router B communicates with Router A through RIPng 100 and with Router C through RIPng 200.
Configure route redistribution on Router B, so the two RIPng processes can redistribute routes from each other.
Figure 3 Network diagram
# Enable RIPng 100 on Router A.
[RouterA] ripng 100
[RouterA-ripng-100] quit
[RouterA-Ten-GigabitEthernet3/1/1] ripng 100 enable
[RouterA-Ten-GigabitEthernet3/1/2] ripng 100 enable
# Enable RIPng 100 and RIPng 200 on Router B.
[RouterB] ripng 100
[RouterB-ripng-100] quit
[RouterB-Ten-GigabitEthernet3/1/2] ripng 100 enable
[RouterB] ripng 200
[RouterB-ripng-200] quit
[RouterB-Ten-GigabitEthernet3/1/1] ripng 200 enable
#  Enable RIPng 200 on Router C.
[RouterC] ripng 200
[RouterC-Ten-GigabitEthernet3/1/1] ripng 200 enable
[RouterC-Ten-GigabitEthernet3/1/2] ripng 200 enable
# Display the routing table on Router A.
[RouterA] display ipv6 routing-table
Destinations : 6 Routes : 6
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: 1::/64                                      Protocol  : Direct
NextHop    : ::                                          Preference: 0
Interface  : XGE3/1/2                                    Cost      : 0
Destination: 1::1/128                                    Protocol  : Direct
Destination: 2::/64                                      Protocol  : Direct
Interface  : XGE3/1/1                                    Cost      : 0
Destination: 2::1/128                                    Protocol  : Direct
Destination: FE80::/10                                   Protocol  : Direct
Interface  : NULL0                                       Cost      : 0
3.     Configure RIPng route redistribution:
# Configure route redistribution between the two RIPng processes on Router B.
[RouterB] ripng 100
[RouterB-ripng-100] import-route ripng 200
[RouterB] ripng 200
[RouterB-ripng-200] import-route ripng 100
Destinations : 7 Routes : 7
Destination: 4::/64                                      Protocol  : RIPng
NextHop    : FE80::200:BFF:FE01:1C02                     Preference: 100
Interface  : XGE3/1/2                                    Cost      : 1
Example: Configuring RIPng GR
As shown in Figure 4, Router A, Router B, and Router C learn IPv6 routing information through RIPng.
Configure Router A as the GR restarter. Configure Router B and Router C as the GR helpers to synchronize their routing tables with Router A by using GR.
Figure 4 Network diagram
2.     Configure RIPng on the routers to ensure the following: (Details not shown.)
¡     Router A, Router B, and Router C can communicate with each other at Layer 3.
¡     Dynamic route update can be implemented among them with RIPng.
3.     Enable RIPng GR on Router A.
[RouterA] ripng 1
[RouterA-ripng-1] graceful-restart
# Restart RIPng or trigger an active/standby process switchover, and then display GR status on Router A.
[RouterA] display ripng 1 graceful-restart
RIPng process: 1
 Graceful Restart capability    : Enabled
 Current GR state               : Normal
 Graceful Restart period        : 60  seconds
 Graceful Restart remaining time: 0   seconds
Example: Configuring RIPng FRR
As shown in Figure 5, Router A, Router B, and Router C run RIPng. Configure RIPng FRR so that when Link A becomes unidirectional, traffic can be switched to Link B immediately.
Figure 5 Network diagram
Device
IP address
Router A
Ten-GigabitEthernet 3/1/1
1::1/64
Router A
Ten-GigabitEthernet 3/1/2
2::1/64
Router A
Loopback 0
10::1/128
Router B
3::1/64
Router B
2::2/64
Router B
Loopback 0
20::1/128
Router C
1::2/64
Router C
3::2/64
1.     Configure IPv6 addresses for the interfaces on the routers. (Details not shown.)
2.     Configure RIPng on the routers to make sure Router A, Router B, and Router C can communicate with each other at the network layer. (Details not shown.)
3.     Configure RIPng FRR:
[RouterA] ipv6 prefix-list abc index 10 permit 20::1 128
[RouterA] route-policy frr permit node 10
[RouterA-route-policy-frr-10] if-match ipv6 address prefix-list abc
[RouterA-route-policy-frr-10] apply ipv6 fast-reroute backup-interface ten-gigabitethernet 3/1/1 backup-nexthop 1::2
[RouterA-route-policy-frr-10] quit
[RouterA] ripng 1
[RouterA-ripng-1] fast-reroute route-policy frr
[RouterB] ipv6 prefix-list abc index 10 permit 10::1 128
[RouterB] route-policy frr permit node 10
[RouterB-route-policy-frr-10] if-match ipv6 address prefix-list abc
[RouterB-route-policy-frr-10] apply ipv6 fast-reroute backup-interface ten-gigabitethernet 3/1/1 backup-nexthop 3::2
[RouterB-route-policy-frr-10] quit
[RouterB] ripng 1
[RouterB-ripng-1] fast-reroute route-policy frr
# Display the route 20::1/128 on Router A to view the backup next hop information.
[RouterA] display ipv6 routing-table 20::1 128 verbose
Summary count : 1
 Destination: 20::1/128
    Protocol: RIPng
  Process ID: 1
   SubProtID: 0x0                       Age: 00h17m42s
  FlushedAge: 15h28m49s
        Cost: 1                  Preference: 100
       IpPre: N/A                QosLocalID: N/A
         Tag: 0                       State: Inactive Adv
   OrigTblID: 0x0                   OrigVrf: default-vrf
     TableID: 0xa                    OrigAs: 0
       NibID: 0x22000003             LastAs: 0
      AttrID: 0xffffffff
    BkAttrID: 0xffffffff           Neighbor: FE80::34CD:9FF:FE2F:D02
       Flags: 0x41              OrigNextHop: FE80::34CD:9FF:FE2F:D02
       Label: NULL              RealNextHop: FE80::34CD:9FF:FE2F:D02
    BkLabel: NULL                 BkNextHop: FE80::7685:45FF:FEAD:102
     SRLabel: NULL                Interface: Ten-GigabitEthernet3/1/2
   BkSRLabel: NULL              BkInterface: N/A
   Tunnel ID: Invalid           IPInterface: Ten-GigabitEthernet3/1/2
 BkTunnel ID: Invalid         BkIPInterface: Ten-GigabitEthernet3/1/1
     InLabel: NULL           ColorInterface: N/A
    SIDIndex: NULL         BkColorInterface: N/A
    FtnIndex: 0x0           TunnelInterface: N/A
TrafficIndex: N/A         BkTunnelInterface: N/A
   Connector: N/A                    PathID: 0x0
      UserID: 0x0                SRTunnelID: Invalid
    SID Type: N/A                       NID: Invalid
    FlushNID: Invalid                 BkNID: Invalid
  BkFlushNID: Invalid             StatFlags: 0x0
         SID: N/A
       BkSID: N/A
CommBlockLen: 0                    Priority: Critical
  MemberPort: N/A                  ExtFlags: 0x0
    UCMIndex: 0x0                  UserVLAN: 65535
      UCMMTU: 0                    BrasHash: 0
   SessionID: 0                 UserGroupID: 0
# Display the route 10::1/128 on Router B to view the backup next hop information.
[RouterB] display ipv6 routing-table 10::1 128 verbose
Summary count : 1
 Destination: 10::1/128
    Protocol: RIPng
  Process ID: 1
   SubProtID: 0x0                       Age: 00h22m34s
       NibID: 0x22000001             LastAs: 0
      AttrID: 0xffffffff
    BkAttrID: 0xffffffff           Neighbor: FE80::34CC:E8FF:FE5B:C02
       Flags: 0x41              OrigNextHop: FE80::34CC:E8FF:FE5B:C02
       Label: NULL              RealNextHop: FE80::34CC:E8FF:FE5B:C02
         SID: N/A
       BkSID: N/A
Example: Using an IPsec profile to protect RIPng
As shown in Figure 6, configure RIPng on the routers, and configure IPsec profiles on the routers to authenticate and encrypt protocol packets.
Figure 6 Network diagram
[RouterA] ripng 1
[RouterB] ripng 1
[RouterC] ripng 1
3.     Configure RIPng IPsec profiles:
¡     On Router A:
# Create an IPsec transform set named protrf1.
[RouterA] ipsec transform-set protrf1
# Specify the ESP encryption and authentication algorithms.
[RouterA-ipsec-transform-set-protrf1] esp encryption-algorithm 3des-cbc
[RouterA-ipsec-transform-set-protrf1] esp authentication-algorithm md5
# Specify transport mode for encapsulation.
[RouterA-ipsec-transform-set-protrf1] encapsulation-mode transport
[RouterA-ipsec-transform-set-protrf1] quit
# Create a manual IPsec profile named profile001.
[RouterA] ipsec profile profile001 manual
# Reference IPsec transform set protrf1.
[RouterA-ipsec-profile-profile001-manual] transform-set protrf1
# Configure the inbound and outbound SPIs for ESP.
[RouterA-ipsec-profile-profile001-manual] sa spi inbound esp 256
[RouterA-ipsec-profile-profile001-manual] sa spi outbound esp 256
# Configure the inbound and outbound SA keys for ESP.
[RouterA-ipsec-profile-profile001-manual] sa string-key inbound esp simple abc
[RouterA-ipsec-profile-profile001-manual] sa string-key outbound esp simple abc
[RouterA-ipsec-profile-profile001-manual] quit
¡     On Router B:
[RouterB] ipsec transform-set protrf1
[RouterB-ipsec-transform-set-protrf1] esp encryption-algorithm 3des-cbc
[RouterB-ipsec-transform-set-protrf1] esp authentication-algorithm md5
[RouterB-ipsec-transform-set-protrf1] encapsulation-mode transport
[RouterB-ipsec-transform-set-protrf1] quit
[RouterB] ipsec profile profile001 manual
[RouterB-ipsec-profile-profile001-manual] transform-set protrf1
[RouterB-ipsec-profile-profile001-manual] sa spi inbound esp 256
[RouterB-ipsec-profile-profile001-manual] sa spi outbound esp 256
[RouterB-ipsec-profile-profile001-manual] sa string-key inbound esp simple abc
[RouterB-ipsec-profile-profile001-manual] sa string-key outbound esp simple abc
[RouterB-ipsec-profile-profile001-manual] quit
¡     On Router C:
[RouterC] ipsec transform-set protrf1
[RouterC-ipsec-transform-set-protrf1] esp encryption-algorithm 3des-cbc
[RouterC-ipsec-transform-set-protrf1] esp authentication-algorithm md5
[RouterC-ipsec-transform-set-protrf1] encapsulation-mode transport
[RouterC-ipsec-transform-set-protrf1] quit
[RouterC] ipsec profile profile001 manual
[RouterC-ipsec-profile-profile001-manual] transform-set protrf1
[RouterC-ipsec-profile-profile001-manual] sa spi inbound esp 256
[RouterC-ipsec-profile-profile001-manual] sa spi outbound esp 256
[RouterC-ipsec-profile-profile001-manual] sa string-key inbound esp simple abc
[RouterC-ipsec-profile-profile001-manual] sa string-key outbound esp simple abc
[RouterC-ipsec-profile-profile001-manual] quit
4.     Apply the IPsec profiles to the RIPng process on each device:
¡     On Router A:
[RouterA] ripng 1
[RouterA-ripng-1] enable ipsec-profile profile001
¡     On Router B:
[RouterB] ripng 1
[RouterB-ripng-1] enable ipsec-profile profile001
¡     On Router C:
[RouterC] ripng 1
[RouterC-ripng-1] enable ipsec-profile profile001
# Verify that the RIPng packets between Routers A, B, and C are protected by IPsec. (Details not shown.)
