14-High Availability Configuration Guide
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration GuidesH3C CR16000-F Routers Configuration Guides-R838x-6W10114-High Availability Configuration Guide
10-Service instance group configuration
10-Service instance group configuration 51.61 KB
Configuring service instance groups
About service instance groups
Associated with a failover group, a service instance group helps back up service data for specific service modules (such as NAT), and guarantee correct operation of specific services.
For inter-system service backup, you can associate a service instance group with only one failover group. The nodes in the failover group must belong to different systems.
For intra-system service backup, you can associate a service instance group with one or multiple failover groups. The nodes in the failover groups must belong to the same system.
·     If you associate a service instance group with one failover group, the nodes in the failover group perform NAT service backup globally.
·     If you associate a service instance group with multiple failover groups, NAT service backup loads are distributed among the failover groups. Each failover group also backs up services between its nodes. You can associate a service instance group with a maximum of four failover groups.
For more information about failover groups, see "Configuring failover groups."
Restrictions and guidelines: Service instance group configuration
You cannot use a service instance group for both inter-system and intra-system service backup.
You cannot associate a service instance group with multiple failover groups if the service instance group has been associated with a NAT instance that has one of the following settings:
·     Static port block mappings.
·     Address ranges configured by using the address command for a NAT address group that provides the outbound dynamic NAT service.
·     NO-PAT.
·     Static NAT.
·     Global NAT address group that has multiple NAT instance associations.
·     NAT server mapping that maps one public IP address to multiple private IP addresses.
If the NAT instance with a service instance group specified has NAT entries, you are not allowed to perform the following operations:
·     Delete the service instance group.
·     Cancel the association between the service instance group and failover group.
Configuring a service instance group
2.     Create a service instance group and enter its view.
service-instance-group service-instance-group-name
3.     Associate a failover group with the service instance group.
failover-group failover-group-name
By default, a service instance group is not associated with any failover groups.
Display and maintenance commands for service instance groups
Display service instance group information.
display service-instance-group [ service-instance-group-name ]
