03-Interface Command Reference
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesCommand ReferencesH3C SR8800-X Routers Command Reference-R8530Pxx-6W10103-Interface Command Reference
03-WAN interface commands
03-WAN interface commands 175.68 KB
Common WAN interface commands
default
Use default to restore the default settings for an interface.
default
Serial interface view
CE1 interface view
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. You can use the display this command in interface view to check for these commands, and use their undo forms or follow the command reference to restore their respective default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings of Serial 3/1/1:0.
[Sysname] interface serial 3/1/1:0
[Sysname-Serial3/1/1:0] default
description
The interface description uses the interface name Interface format, for example, Serial3/1/1:0 Interface.
CE1 interface view
text: Specifies the description, a case-sensitive string of 1 to 255 characters.
# Configure the description of Serial 3/1/1:0 as router-interface.
[Sysname-Serial3/1/1:0] description router-interface
shutdown
Use shutdown to shut down an interface.
Use undo shutdown to restore the default.
shutdown
A WAN interface is up.
CE1 interface view
# Shut down Serial 3/1/1:0.
[Sysname-Serial3/1/1:0] shutdown
Serial interface commands
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
# Set the expected bandwidth of Serial 3/1/1:0 to 50 kbps.
[Sysname-Serial3/1/1:0] bandwidth 50
crc
Use crc to set the CRC mode for a synchronous serial interface.
Use undo crc to restore the default.
crc { 16 | 32 | none }
undo crc
16-bit CRC is used.
Synchronous serial interface view
16: Specifies 16-bit CRC.
32: Specifies 32-bit CRC.
none: Disables CRC.
# Configure Serial 3/1/1:0 to use 32-bit CRC.
[Sysname-Serial3/1/1:0] crc 32
display interface serial
Use display interface serial to display information about serial interfaces.
display interface [ serial [ interface-number ] ] [ brief [ description | down ] ]
serial [ interface-number ]: Specifies a serial interface by its number. If you do not specify the serial keyword, this command displays information about all interfaces. If you specify the serial keyword without specifying an interface, this command displays information about all serial interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays physically down interfaces and their down causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about Serial 2/1/1.
<Sysname> display interface serial 2/1/1
Serial2/1/1
Interface index: 141445
Current state: DOWN
Line protocol state: DOWN
Description: Serial2/1/1 Interface
Bandwidth: 1000 kbps
Hold timer: 10 seconds, retry times: 5
Derived from E1 3/1/1, Timeslot(s) Used: 1, Baudrate is 64000 bps
Link layer protocol: PPP
LCP: initial
Port priority: 0
Traffic statistic: Not include Inter-frame Gaps and Preambles
CRC type is 16-bit
Last 300 seconds input:  0 packets/sec,  0 bytes/sec
Last 300 seconds output:  0 packets/sec,  0 bytes/sec
Input(total):  0 packets,  0 bytes
Input(Bad):  0 Abort,  0 FCS-Error,  0 FIFO-Abort,  0 Giant,  0 Runt
Output(total):  0 packets,  0 bytes
Output(Bad):  0 Abort
Peak value of input: 0 bytes/sec, at 2022-09-19 06:16:40
Peak value of output: 0 bytes/sec, at 2022-09-19 06:16:40
# Display brief information about Serial 2/1/1.
<Sysname> display interface serial 2/1/1 brief
Brief information on interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP         Description
Ser3/1/1: 0           UP   UP(s)    --
# Display brief information about all serial interfaces in down state and the causes.
<Sysname> display interface serial brief down
Ser3/1/1: 0           ADM  Administratively
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
Description of the interface.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
Hold timer
Interval at which the interface sends keepalive packets.
retry times
Keepalive retry limit.
The interface determines that the remote end is down if it does not receive a keepalive response after the keepalive retry limit has been made.
The interface is not assigned an IP address and cannot process IP packets.
Internet Address
IP address of the interface. The primary attribute indicates that the address is the primary IP address.
Link layer protocol
Link layer protocol of the interface.
LCP
LCP status.
The most recent time that the reset counters interface serial command was executed. This field displays Never if this command has not been executed since the device startup.
Traffic statistic
Whether calculation of average interface speed includes inter-frame gaps and preambles:
·     Include Inter-frame Gaps and Preambles.
·     Not include Inter-frame Gaps and Preambles.
Average input rates (in Bps, bps, and pps) for the last 300 seconds.
Average output rates (in Bps, bps, and pps) for the last 300 seconds.
Total number and size (in bytes) of correct packets received by the interface.
Incoming error traffic statistics for the interface:
·     Abort—Number of anomalous errors.
·     FCS-Error—Number of incoming normal-size packets with CRC or FCS errors.
·     FIFO-Abort—Number of incoming FIFO overflow errors.
·     Giant—Number of incoming oversized packets.
·     Runt—Number of incoming undersized packets.
Outgoing traffic statistics for the interface.
Total number of packets that fail to be forwarded for any reasons (for example, packet collisions were detected during transmission).
Peak value of input
·     Peak rate (in bytes/sec) for incoming traffic on the interface.
Time when the peak rate occurred.
·     Peak rate (in bytes/sec) for outgoing traffic on the interface.
Brief information about Layer 3 interfaces.
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
interface serial
Use interface serial to enter serial interface view.
interface serial interface-number
interface-number: Specifies a serial interface by its number.
# Enter the view of Serial 2/1/1.
link-protocol
link-protocol
Use link-protocol to configure the data link layer protocol for an interface.
link-protocol{ hdlc | ppp }
A synchronous serial interface uses PPP as the data link layer protocol.
hdlc: Specifies the HDLC data link layer protocol.
ppp: Specifies the PPP data link layer protocol.
# Specify HDLC as the data link layer protocol of Serial 3/1/1:0.
[Sysname-Serial3/1/1:0] link-protocol hdlc
mtu
Use mtu to set the MTU size for an interface.
mtu size
undo mtu
The MTU is 1500 bytes.
size: Sets the maximum transmission unit (MTU). The value range varies by card model.
The MTU setting affects the assembly and fragmentation of IP packets.
After configuring the MTU for an interface, you must use the shutdown command and then the undo shutdown command on the interface for the modification to take effect.
# Set the MTU to 1430 bytes for Serial3/1/1:0.
[Sysname-Serial3/1/1:0] mtu 1430
reset counters interface async
Use reset counters interface async to clear asynchronous serial interface statistics.
reset counters interface [ async [ interface-number ] ]
async [ interface-number ]: Specifies an asynchronous serial interface by its number. If you do not specify the async keyword, this command clears statistics for all interfaces except VA interfaces. If you specify the async keyword without specifying an interface, this command clears statistics for all asynchronous serial interfaces.
Use this command to clear history statistics before you collect traffic statistics for a time period.
# Clear statistics for Async 2/4/0.
<Sysname> reset counters interface async 2/4/0
display interface async
timer-hold
Use timer-hold to set the keepalive interval.
Use undo timer-hold to restore the default.
timer-hold seconds
undo timer-hold
The keepalive interval is 10 seconds.
seconds: Specifies the interval at which the interface sends keepalive packets. The value range for this argument is 0 to 32767 seconds.
On an interface encapsulated with PPP or HDLC, the data link layer sends keepalive packets at keepalive intervals to detect the availability of the remote end. The data link layer determines that the peer end is down if it does not receive a response after the keepalive retry limit has been made. The data link layer then reports the link down event to the upper-layer protocols.
To set the keepalive retry limit, use the timer-hold retry command.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive interval to 15 seconds for Serial 2/1/1.
[Sysname] interface serial 2/1/1
[Sysname-Serial2/1/1] timer-hold 15
timer-hold retry
timer-hold retry
Use timer-hold retry to set the keepalive retry limit.
Use undo timer-hold retry to restore the default.
timer-hold retry retries
The keepalive retry limit is 5.
retries: Specifies the keepalive retry limit, in the range of 1 to 255.
This command applies to interfaces encapsulated with PPP or HDLC. To set the keepalive interval, use the timer-hold command.
On a slow link, increase the keepalive retry limit to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive retry limit to 10 for Serial 2/1/1.
[Sysname-Serial2/1/1] timer-hold retry 10
timer-hold
Basic CE1 interface commands
cable (CE1 interface)
Use cable to set the cable type for a CE1 interface.
Use undo cable to restore the default.
cable { long | short }
undo cable
The long keyword applies.
CE1 interface view
long: Specifies the attenuation of the receiver as –43 dB.
short: Specifies the attenuation of the receiver as –10 dB.
# Set the cable type on E1 3/1/1 to short.
[Sysname] controller e1 3/1/1
[Sysname-E1 3/1/1] cable short
channel-set (CE1 interface)
Use channel-set to bundle timeslots on a CE1 interface into a channel set.
Use undo channel-set to cancel the bundling.
channel-set set-number timeslot-list list
undo channel-set [ set-number ]
No channel sets exist on a CE1 interface.
CE1 interface view
set-number: Specifies the number of the channel set for the timeslot bundle. The value range is 0 to 30.
timeslot-list list: Specifies a comma-separated list of timeslot items. An item can be an individual timeslot or a timeslot range. Use a hyphen (-) to separate the start and end timeslot numbers of a range. The value range for the timeslot number is 1 to 31.
A CE1 interface in CE1 or PRI mode is physically divided into 32 timeslots numbered 0 through 31. All the timeslots except timeslot 0 can be bundled into multiple channel sets. For each channel set, the system automatically creates a serial interface that has the same logical features as a standard synchronous serial interface.
The serial interface name uses the serial interface-number:set-number format. The interface-number argument specifies the CE1 interface number. The set-number argument specifies the channel set number.
# Bundle timeslots 1, 2, 5, 10 through 15, and 18 into channel set 0 on E1 3/1/1.
[Sysname-E1 3/1/1] channel-set 0 timeslot-list 1,2,5,10-15,18
clock (CE1 interface)
Use clock to set the clock mode of a CE1 interface.
Use undo clock to restore the default.
clock { master | slave }
undo clock
The clock mode of a CE1 interface is slave.
CE1 interface view
master: Sets the clock mode to master.
slave: Sets the clock mode to slave.
When the clock mode of an interface is master, it uses the internal clock source. When the clock mode of an interface is slave, it uses the line clock source.
# Set the clock mode to master for CE1 interface E1 3/1/1.
[Sysname-E1 3/1/1] clock master
clock-change auto
Use clock-change auto to enable automatic clock mode switchover on an interface.
Use undo clock-change auto to disable automatic clock mode switchover.
clock-change auto
Automatic clock mode switchover is disabled on an interface.
CE1 interface view
When automatic clock mode switchover is enabled, the interface automatically switches to the master clock mode when both of the following conditions exist:
·     The interface uses the slave clock mode.
·     The interface receives an alarm indication signal (AIS), loss of signal (LOS), or loss of frame (LOF) alarm.
After the alarm is cleared, the interface automatically switches back to the slave mode.
When automatic clock mode switchover is disabled, the interface uses the user-configured clock mode.
# Enable automatic clock mode switchover for E1 3/1/1.
[Sysname-E1 3/1/1] clock-change auto
clock
controller e1
Use controller e1 to enter CE1 interface view.
controller e1 interface-number
interface-number: Specifies a CE1 interface by its number.
# Enter E1 3/1/1 interface view.
[Sysname-E1 3/1/1]
display controller e1
Use display controller e1 to display information about CE1 interfaces.
display controller [ e1 [ interface-number ] ]
e1 [ interface-number ]: Specifies a CE1 interface by its number. If you do not specify the e1 keyword, the command displays information about all CE1 interfaces, and CPOS interfaces. If you specify the e1 keyword without specifying an interface, the command displays information about all CE1 interfaces.
# Display information about E1 3/1/1.
<Sysname> display controller e1 3/1/1
E1 3/1/1
Interface index: 13825
Current state: DOWN
Description: E1 3/1/1 Interface
Current system time:2013-02-23 09:44:34
Last time when physical state changed to up:-
Last time when physical state changed to down:2013-02-20 15:58:54
Basic Configuration:
  Work mode is E1 framed, frame-format is no-crc4.
  Cable type is no connector.
  Line code is hdb3, source clock is master.
  Itf type is 7e, itf number is 4.
  Cable loss type is long, auto clock change is enabled.
  Loopback is not set.
Alarm State:
  LFA LOS
Error Statistic:
  Line Code Error: 0, Path Code Error: 0.
Current state
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Current system time
Current system time in the YYYY-MM-DD HH:MM:SS format. If the time zone is configured, this field is in the YYYY-MM-DD HH:MM:SS UTC±HH:MM:SS format.
Last time when physical state of the interface changed to up.
A hyphen (-) indicates that the physical state of the interface has not changed to up.
Last time when physical state of the interface changed to down.
A hyphen (-) indicates that the physical state of the interface has not changed to down.
Work mode
Operating mode of the interface: E1 or CE1.
Cable type
Cable type of the interface.
source clock
Clock source used by the interface: master or slave.
Line code
Line code: AMI or HDB3. AMI is not supported in the current software version.
Itf type
Interframe filling tag: 7e or ff. This field is not supported in the current software version.
itf number
Number of interframe filling tags between two successive frames. This field is not supported in the current software version.
Cable loss type
auto clock change
Auto clock change state on the interface.
Loopback
Loopback state.
Line Code Error
Error statistics for line code (AMI or HDB3).
The AMI line code is not supported in the current software version.
Path Code Error
Bit error statistics for frame alignment.
reset counters controller e1
display controller phy-option
Use display controller phy-option to display the physical attributes of a controller interface.
display controller [ interface-type [ interface-number ] ] phy-option
In the current software version, this command supports WAN interface types CPOS and E1.
If you do not specify a controller interface type, this command displays information about all controller interfaces.
If you specify a controller interface type but do not specify a controller interface number, this command displays information about all controller interfaces of the specified type.
# Display the physical attributes of CE1 interface E1 3/1/1.
<Sysname> display controller E1 3/1/1 phy-option
E1 3/1/1
Current state: DOWN
  Work mode is E1 unframed.
  Resistance type is 75 Ohm unbalanced.
  Cable type is 75 Ohm SMB E1 cable.
  Line code is hdb3, source clock is slave.
  Cable loss type is long, auto clock change is disabled.
Current state
Basic Configuration
Work mode
Resistance type
Impedance type of the cable.
Cable type
source clock
Line code
Itf type
Idle code: 7e or ff. This field is not supported in the current software version.
itf number
auto clock change
Automatic clock change enabling status.
Loopback
Loopback setting state.
display controller
display this controller
Use display this controller to display the operating status and information of a controller interface.
Interface view
In controller interface view, to quickly view the operating status or packet statistics of the interface, execute this command.
For a controller interface, the output from the display this interface command in controller interface view is the same as the output from the display controller interface-type interface-number command in any view.
display controller
frame-format (CE1 interface)
Use frame-format to set the framing format for a CE1 interface.
Use undo frame-format to restore the default.
frame-format { crc4 | no-crc4 }
undo frame-format
The framing format on a CE1 interface is no-CRC4.
CE1 interface view
crc4: Sets the framing format to CRC4.
no-crc4: Sets the framing format to no-CRC4.
A CE1 interface in CE1 mode supports both CRC4 and no-CRC4 framing formats. Only CRC4 supports four-bit CRC on physical frames.
# Set the framing format to CRC4 on E1 3/1/1.
[Sysname-E1 3/1/1] frame-format crc4
loopback (CE1 interface)
Use loopback to enable loopback and set the loopback mode on a CE1 interface.
Use undo loopback to disable loopback on a CE1 interface.
loopback { local | payload | remote }
undo loopback
Loopback is disabled on a CE1 interface.
CE1 interface view
local: Sets the interface to operate in local loopback mode.
payload: Sets the interface to operate in external payload loopback mode.
remote: Sets the interface to operate in external loopback mode.
Loopback is intended for testing only. Disable the feature when the interface is operating correctly.
You can bundle timeslots on the CE1 interface to form a serial interface and encapsulate it with PPP or HDLC. After you enable loopback on this serial interface, it is normal that the state of the link layer protocol is reported as down.
# Set E1 3/1/1 to operate in internal loopback mode.
[Sysname-E1 3/1/1] loopback local
Use reset counters controller e1 to clear CE1 interface statistics.
reset counters controller e1 [ interface-number ]
interface-number: Specifies a CE1 interface by its number. If you do not specify this argument, the command clears statistics for all CE1 interfaces.
The reset counters interface command clears statistics for all interfaces.
To display CE1 interface statistics, use the display controller e1 command.
# Clear statistics for CE1 interface E1 3/1/1.
<Sysname> reset counters controller e1 3/1/1
using (CE1 interface)
Use using to set the operating mode of a CE1 interface.
Use undo using to restore the default.
using { ce1 | e1 }
undo using
A CE1 interface operates in channelized mode.
CE1 interface view
ce1: Sets the interface to operate in channelized mode.
e1: Sets the interface to operate in E1 mode.
A CE1 interface can operate in channelized or unchannelized mode. Unchannelized mode is also called E1 mode. The channelized mode is also called the CE1 mode.
·     In channelized mode, the CE1 interface is physically divided into 32 timeslots numbered 0 through 31. Timeslot 0 is used for FSC.
¡     For an interface in E1 mode, the system automatically creates a 2.048 Mbps serial interface. The interface name uses the serial interface-number:0 format. The interface-number argument specifies the CE1 interface number. This interface has the same logical features as a standard synchronous serial interface.
# Set E1 3/1/1 to operate in E1 mode.
[Sysname-E1 3/1/1] using e1
