06-Layer 3—IP Services Command Reference
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesCommand ReferencesH3C SR8800-F Routers Command Reference-R8530Pxx-6W10106-Layer 3—IP Services Command Reference
01-ARP commands
01-ARP commands 307.74 KB
ARP commands
arp check enable
Use arp check enable to enable dynamic ARP entry check.
Use undo arp check enable to disable dynamic ARP entry check.
arp check enable
Dynamic ARP entry check is enabled.
Dynamic ARP entry check disables a device from supporting dynamic ARP entries with multicast MAC addresses. The device cannot learn dynamic ARP entries containing multicast MAC addresses. You cannot manually add static ARP entries that contain multicast MAC addresses.
When dynamic ARP entry check is disabled, ARP entries containing multicast MAC addresses are supported. The device can learn dynamic ARP entries containing multicast MAC addresses obtained from the ARP packets sourced from a unicast MAC address. You can also manually add static ARP entries containing multicast MAC addresses.
# Enable dynamic ARP entry check.
[Sysname] arp check enable
arp check log enable
Use arp check log enable to enable the ARP logging feature.
Use undo arp check log enable to disable the ARP logging feature.
ARP logging is disabled.
This feature enables a device to log ARP events when ARP cannot resolve IP addresses correctly. The device can log the following ARP events:
·     On a proxy ARP-disabled interface, the target IP address of a received ARP packet is not one of the following IP addresses:
¡     The IP address of the receiving interface.
¡     The virtual IP address of the VRRP group.
¡     The public IP address after NAT.
·     The sender IP address of a received ARP reply conflicts with one of the following IP addresses:
The device sends ARP log messages to the information center. You can use the info-center source command to specify the log output rules for the information center. For more information about information center, see Network Management and Monitoring Configuration Guide.
The device can generate a large number of ARP logs. To conserve system resources, enable ARP logging only when you are auditing or troubleshooting ARP events.
# Enable ARP logging.
[Sysname] arp check log enable
arp ip-unnumbered learning enable
Use arp ip-unnumbered learning enable to enable an IP unnumbered interface to learn ARP entries for different subnets.
Use undo arp ip-unnumbered learning enable to disable an IP unnumbered interface from learning ARP entries for different subnets.
An IP unnumbered interface cannot learn ARP entries for different subnets.
Interface view
Application scenarios
An IP unnumbered interface cannot learn the ARP entry of the peer device if the unnumbered interface and the peer device are on different subnets.
Operating mechanism
After you enable this feature on an IP unnumbered interface, it can learn the corresponding ARP entry when it receives an ARP packet from a different subnet, which ensures communication.
If an IP unnumbered interface is disabled from learning ARP entries for different subnets, existing ARP entries learned for different subnets are deleted after they age out.
This feature takes effect only on an interface configured with the ip address unnumbered command. This interface is an unnumbered interface and borrows the IP address from another interface.
To avoid ARP learning anomalies, do not execute the arp ip-unnumbered learning enable command on a non-IP-unnumbered interface.
# Configure Ten-GigabitEthernet 3/1/1 to borrow the IP address of Ten-GigabitEthernet 3/1/2, and enable Ten-GigabitEthernet 3/1/1 to learn ARP entries for different subnets.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] ip address unnumbered interface Ten-GigabitEthernet 3/1/2
[Sysname-Ten-GigabitEthernet3/1/1] arp ip-unnumbered learning enable
arp local-conflict record enable
Use arp local-conflict record enable to enable recording conflicts between an endpoint and the local device.
Use undo arp local-conflict record enable to disable recording conflicts between the endpoints and local device.
Recording conflicts between the endpoints and local device is disabled.
This feature enables the device to detect and record conflicts between the endpoints and local device. The device determines that a conflict occurs if an incoming non-gratuitous ARP packet has the same sender IP address or sender MAC address as that of the device. The device generates an endpoint and local device conflict entry, logs the conflict, and sends the log to the information center. For information about the log destination and output rule configuration, see information center configuration in Network Management and Monitoring Configuration Guide.
If no new endpoint and local device conflict occurs within three minutes after the entry is generated, the system deletes the conflict entry.
An interface sends only one endpoint and local device conflict log to the information center per minute. The device supports a maximum of 128 interfaces sending conflict logs simultaneously. When the number of interfaces that send conflict logs reaches 128, the device stops another interface from sending conflict logs until an existing conflict is resolved.
# Enable recording conflicts between the endpoints and local device.
[Sysname] arp local-conflict record enable
arp max-learning-num
Use arp max-learning-num to set the dynamic ARP learning limit on an interface.
Use undo arp max-learning-num to restore the default.
arp max-learning-num max-number
An interface can learn a maximum of 589824 dynamic ARP entries.
VXLAN VSI interface view
VLAN interface view
max-number: Specifies the maximum number of dynamic ARP entries that can be learned on an interface. The value range is 0 to 589824.
An interface can dynamically learn ARP entries. To prevent an interface from holding too many ARP entries, you can set the maximum number of dynamic ARP entries that the interface can learn. When the limit is reached, the interface stops learning ARP entries.
When the learning limit is set to 0, the interface is disabled from learning dynamic ARP entries.
# Specify VLAN-interface 40 to learn a maximum of 10 dynamic ARP entries.
[Sysname] interface vlan-interface 40
[Sysname-Vlan-interface40] arp max-learning-num 10
# Specify Ten-GigabitEthernet 3/1/1 to learn a maximum of 10 dynamic ARP entries.
[Sysname-Ten-GigabitEthernet3/1/1] arp max-learning-num 10
# Specify Layer 2 aggregate interface Bridge-Aggregation 1 to learn a maximum of 10 dynamic ARP entries.
[Sysname-Bridge-Aggregation1] arp max-learning-num 10
# Specify Layer 3 aggregate interface Route-Aggregation 1 to learn a maximum of 10 dynamic ARP entries.
[Sysname-Route-Aggregation1] arp max-learning-num 10
arp max-learning-number
Use arp max-learning-number to set the dynamic ARP learning limit on a device.
Use undo arp max-learning-number to restore the default.
In standalone mode:
arp max-learning-number max-number slot slot-number
undo arp max-learning-number slot slot-number
In IRF mode:
arp max-learning-number max-number chassis chassis-number slot slot-number
undo arp max-learning-number chassis chassis-number slot slot-number
The device can learn a maximum of 589824 dynamic ARP entries.
max-number: Specifies the maximum number of dynamic ARP entries that can be learned on a device. The value range is 0 to 589824.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
A device can dynamically learn ARP entries. To prevent a device from holding too many ARP entries, you can set the maximum number of dynamic ARP entries that the device can learn. When the limit is reached, the device stops learning ARP entries.
When the learning limit is set to 0, the device is disabled from learning dynamic ARP entries.
# Set the ARP learning limit to 64 for slot 1.
[Sysname] arp max-learning-number 64 slot 1
arp safe-guard enable
This command is available only for the following cards:
Card category
Cards
CSPEX
CSPEX-1304S, CSPEX-1404S, CSPEX-1504S
Use arp safe-guard enable to enable the ARP safe-guard feature.
Use undo safe-guard enable to disable the ARP safe-guard feature.
undo arp safe-guard enable
The ARP safe-guard feature is disabled.
VLAN interface view
You can use this command to prevent traffic-intensive ARP packet attacks on a device. After you enable this feature, the device operates as follows:
·     The device sends replies to all incoming ARP requests but do not generate corresponding ARP entries, which prevents gateway spoofing attacks.
·     The device generates ARP entries for incoming ARP replies that the device requests.
·     The device drops incoming ARP replies that are not requested by the device, which ensures that the device can learn correct ARP entries.
# Enable the ARP safe-guard feature on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] arp safe-guard enable
arp smooth
Use arp smooth to synchronize ARP entries from the active MPU to all other cards.
arp smooth
This command triggers a one-time operation to ensure that all cards on the device have the same ARP entries.
To synchronize ARP entries across all cards in a timely manner, you can schedule the device to automatically execute the arp smooth command. For information about scheduling a task, see Fundamentals Configuration Guide.
# Synchronize ARP entries from the active MPU to all other cards.
<Sysname> arp smooth
arp static
Use arp static to configure a static ARP entry.
Use undo arp to delete an ARP entry.
arp static ip-address mac-address [ vlan-id interface-type interface-number | interface-type interface-number interface-type interface-number | vsi-interface vsi-interface-id tunnel number vsi vsi-name | vsi-interface vsi-interface-id interface-type interface-number service-instance instance-id vsi vsi-name ] [ vpn-instance vpn-instance-name ] [ description text ]
undo arp ip-address [ vpn-instance-name ]
No static ARP entries exist.
ip-address: Specifies an IP address for the static ARP entry.
mac-address: Specifies a MAC address for the static ARP entry, in the format of H-H-H.
vlan-id: Specifies the ID of a VLAN to which the static ARP entry belongs. The value range is 1 to 4094.
vsi-interface vsi-interface-id: Specifies a VSI interface by its number. The value range for the vsi-interface-id argument is 1 to 31.
tunnel number: Specifies a tunnel interface by its number.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. This option is a must if you specify a Layer 2 Ethernet interface for the preceding interface-type interface-number arguments. Do not specify this option if you specify an interface of other types for the preceding interface-type interface-number argument.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the static ARP entry belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the static ARP entry belongs to the public network, do not specify this option.
description text: Specifies the description for the static ARP entry, a case-sensitive string of 1 to 255 characters.
A static ARP entry is manually configured and maintained. It does not age out and cannot be overwritten by any dynamic ARP entry.
Static ARP entries can be short or long.
A resolved short static ARP entry becomes unresolved upon certain events, for example, when the resolved output interface goes down, or the corresponding VLAN or VLAN interface is deleted.
Long static ARP entries are effective or ineffective. Ineffective long static ARP entries cannot be used for packet forwarding. A long static ARP entry is ineffective when any of the following conditions exists:
·     The IP address in the entry conflicts with a local IP address.
·     No local interface has an IP address in the same subnet as the IP address in the ARP entry.
If you specify the vlan-id interface-type interface-number argument, follow these restrictions and guidelines:
·     The interface can be an Ethernet interface or an aggregate interface.
·     The VLAN and VLAN interface must already exist. The specified Ethernet interface must belong to the specified VLAN.
·     The IP address of the VLAN interface and the IP address specified by the ip-address argument must be on the same network.
·     A long static ARP entry for a VLAN is deleted if the VLAN or VLAN interface is deleted.
On a PE-agg device that provides L2VPN access to the L3VPN network, an L3VE interface (input interface) might be connected to multiple L2VE subinterfaces (output interfaces). In this case, to configure a long static ARP entry, you must specify the interface-type interface-number interface-type interface-number argument to identify the mapping between input and output interfaces. For more information about L2VE interfaces and L3VE interfaces, see MPLS Configuration Guide.
On a VXLAN IP gateway that forwards traffic among VXLANs through VXLAN tunnels, a VSI interface can act as the gateway for multiple VXLANs. The VSI interface (input interface) might be connected to multiple VXLAN tunnel interfaces (output interfaces). In this case, you must specify the vsi-interface vsi-interface-id tunnel number vsi vsi-name parameters to identify a VSI interface-VSI-VXLAN tunnel interface binding. For more information about VSI interfaces, VSI, and VXLAN tunnel interfaces, see VXLAN Configuration Guide.
On a VXLAN IP gateway that forwards traffic from multiple local sites to remote sites, a VSI interface can act as the gateway for multiple local sites. The VSI interface (input interface) might be associated with multiple Ethernet services (output interfaces) on Layer 2 Ethernet interfaces through which the VSI interface connects to the local sites. In this case, you must specify the vsi-interface vsi-interface-id interface-type interface-number service-instance instance-id vsi vsi-name parameters to identify a VSI interface-Layer 2 Ethernet interface-Ethernet service instance-VSI binding. For more information about VSI interfaces, VSI, and Ethernet service instances, see VXLAN Configuration Guide.
For easy identification of ARP entries, you can configure a description for each static ARP entry.
# Configure a long static ARP entry that contains IP address 202.38.10.2, output interface Ten-GigabitEthernet 3/1/1 in VLAN 10, and MAC address 00e0-fc01-0000.
[Sysname] arp static 202.38.10.2 00e0-fc01-0000 10 ten-gigabitethernet 3/1/1
# Configure a long static ARP entry that contains IP address 1.1.1.1, MAC address 00e0-fc01-0000, input interface VE-L3VPN 1, and output interface VE-L2VPN 1.1.
[Sysname] arp static 1.1.1.1 00e0-fc01-0000 ve-l3vpn 1 ve-l2vpn 1.1
# Configure a long static ARP entry that contains IP address 1.1.1.1, MAC address 00e0-fc01-0000, input interface VSI-interface 1, output interface Tunnel 1, and VSI a.
[Sysname] arp static 1.1.1.1 00e0-fc01-0000 vsi-interface 1 tunnel 1 vsi a
# Configure a long static ARP entry that contains IP address 1.1.1.1, MAC address 00e0-fc01-0000, input interface VSI-interface 1, output interface Ethernet instance 1 on Ten-GigabitEthernet 3/1/1, and VSI a.
[Sysname] arp static 1.1.1.1 00e0-fc01-0000 vsi-interface 1 ten-gigabitethernet 3/1/1 service-instance 1 vsi a
display arp
reset arp
arp timer aging
Use arp timer aging to set the aging timer for dynamic ARP entries.
Use undo arp timer aging to restore the default.
System view:
arp timer aging aging-time
Interface view:
arp timer aging { aging-minutes | second aging-seconds }
In system view, the aging timer for dynamic ARP entries is 20 minutes.
In interface view, the aging timer for dynamic ARP entries is the aging timer set in system view.
VLAN interface view
aging-time: Specifies the aging timer for dynamic ARP entries, in the range of 1 to 1440 minutes.
second aging-seconds: Specifies the aging timer in seconds. The value range for the aging-seconds argument is 5 to 86400.
Each dynamic ARP entry in the ARP table has a limited lifetime, called an aging timer. The aging timer of a dynamic ARP entry is reset each time the dynamic ARP entry is updated. Dynamic ARP entries that are not updated before their aging timers expire are deleted from the ARP table.
You can set the aging timer for dynamic ARP entries to make sure dynamic ARP entries are updated in a timely manner.
You can set the aging timer for dynamic ARP entries in system view or in interface view. The aging timer set in interface view takes precedence over the aging timer set in system view.
Set the aging timer for dynamic ARP entries as needed. For example, when you configure proxy ARP, set a short aging time so that invalid dynamic ARP entries can be deleted in a timely manner.
# Set the aging timer for dynamic ARP entries to 10 minutes.
[Sysname] arp timer aging 10
# Set the aging timer for dynamic ARP entries to 200 seconds on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] arp timer aging second 200
display arp timer aging
arp user-ip-conflict record enable
Use arp user-ip-conflict record enable to enable recording user IP address conflicts.
Use undo arp user-ip-conflict record enable to disable recording user IP address conflicts.
Recording user IP address conflicts is disabled.
This feature enables the device to detect and record user IP address conflicts. The device determines that a conflict occurs if an incoming ARP packet has the same sender IP address as an existing ARP entry but a different sender MAC address. The device generates a user IP address conflict record, logs the conflict, and sends the log to the information center. For information about the log destination and output rule configuration, see the information center in Network Management and Monitoring Configuration Guide.
A card can generate a maximum of 10 user IP address conflict records or logs per second and save a maximum of 200 user IP address conflict records or logs.
If the maximum number of saved user IP address conflict records or logs is reached, a new record or log will override the earliest record or log.
To display user IP address conflict records, use the display arp user-ip-conflict record command.
# Enable recording user IP address conflicts.
[Sysname] arp user-ip-conflict record enable
arp user-move record enable
Use user-move record enable to enable recording user port migrations.
Use undo arp user-move record enable to disable recording user port migrations.
Recording user port migrations is disabled.
Each card can generate a maximum of 10 user port migration logs per second.
To display user port migration records, use the display arp user-move record command.
# Enable recording user port migration.
[Sysname] arp user-move record enable
display arp
Use display arp to display ARP entries.
In standalone mode:
display arp [ [ all | dynamic | static ] [ slot slot-number ] | vlan vlan-id | interface interface-type interface-number ] [ count | verbose ]
In IRF mode:
display arp [ [ all | dynamic | static ] [ chassis chassis-number slot slot-number ] | vlan vlan-id | interface interface-type interface-number ] [ count | verbose ]
all: Displays all ARP entries.
dynamic: Displays dynamic ARP entries.
static: Displays static ARP entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ARP entries on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays ARP entries on the global active MPU. (In IRF mode.)
vlan vlan-id: Specifies a VLAN by its VLAN ID. The VLAN ID is in the range of 1 to 4094.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays ARP entries for all interfaces.
count: Displays the number of ARP entries.
verbose: Displays detailed information about ARP entries.
This command displays information about static and dynamic ARP entries, including the IP address, MAC address, VLAN ID, output interface, entry type, and aging timer.
# Display all ARP entries.
<Sysname> display arp all
  Type: S-Static   D-Dynamic   O-Openflow   R-Rule   M-Multiport  I-Invalid
IP address      MAC address    VLAN/VSI name Interface                Aging Type
1.1.1.1         02e0-f102-0023 1             XGE3/1/1                 --    S
1.1.1.2         00e0-fc00-0001 12            XGE3/1/2                 1182  D
1.1.1.3         00e0-fe50-6503 vsi1          Tunnel1                  1200  D
1.1.1.4         000d-88f7-9f7d vsi1          XGE3/1/3                 685   D
1.1.1.5         000c-77f7-8e1c --            L3VE1000-L2VE1000.1      124   D
# Display detailed information about all ARP entries.
<Sysname> display arp all verbose
IP address          : 1.1.1.1             MAC address    : 02e0-f102-0023
Type                : Static              Aging          : --
Interface           : XGE3/1/1
SVLAN/CVLAN         : 1000/1001
VPN instance        : --
Link ID             : --
VXLAN ID            : --
VSI name            : --
VSI interface       : --
Nickname            : 0x0000
Description         : User1
IP address          : 1.1.1.2             MAC address    : 0015-e944-adc5
Type                : Dynamic             Aging          : 1179 sec
Interface           : XGE3/1/2
SVLAN/CVLAN         : --/--
VPN instance        : --
Link ID             : --
VXLAN ID            : --
VSI name            : --
VSI interface       : --
Nickname            : 0x0000
Description         : --
IP address          : 1.1.1.5             MAC address    : 0015-e944-adc5
Type                : Dynamic             Aging          : 180 sec
Interface           : L3VE1000-L2VE1000.1
SVLAN/CVLAN         : --/--
VPN instance        : --
Link ID             : --
VXLAN ID            : --
VSI name            : --
VSI interface       : --
Nickname            : 0x0000
Description         : --
# Display the number of all ARP entries.
<Sysname> display arp all count
 Total number of entries : 4
IP address
IP address in an ARP entry.
MAC address
MAC address in an ARP entry.
VLAN/VSI name
ID of the VLAN or name of the VSI to which an ARP entry belongs. This field displays hyphens (--) in either of the following situations:
·     The ARP entry is an unresolved short static ARP entry.
·     The output interface of the ARP entry does not belong to any VLAN or VSI.
Output interface in an ARP entry. This field displays hyphens (--) in either of the following situations:
·     The ARP entry is a multiport ARP entry and has no output interface information.
To obtain the output interface information of the multiport ARP entry, look up the MAC address table according to the MAC address in the ARP entry.
Aging
Aging time for an ARP entry, in seconds.
For a static ARP entry, this field always displays hyphens (--). The static ARP entry never ages out unless you delete it manually.
For a dynamic ARP entry, this field displays hyphens (--) if the aging time is unknown.
ARP entry type:
·     D—Dynamic.
·     S—Static.
·     O—OpenFlow.
·     R—Rule.
·     M—Multiport.
·     I—Invalid.
SVLAN/CVLAN
ID of the SVLAN or CVLAN to which the ARP entry belongs. This field displays hyphens (--) in either of the following situations:
·     The output interface of the ARP entry does not belong to any SVLAN or CVLAN.
VPN instance
Name of VPN instance. This field displays hyphens (--) if no VPN instance is configured for the ARP entry.
Link ID
Link ID in an ARP entry. This field displays hyphens (--) if the ARP entry does not belong to any VSI.
VXLAN ID
VXLAN ID (also called VNI). This field displays hyphens (--) if the ARP entry does not belong to any VXLAN.
VSI name
Name of the VSI to which the ARP entry belongs. This field displays hyphens (--) if the ARP entry does not belong to a specific VSI.
VSI interface
VSI interface specified for the VSI. This field displays hyphens (--) if no VSI interface is specified for the VSI.
Nickname
Nickname of the ARP entry. The nickname is a string of four hexadecimal numbers, for example, 012a.
Description of the ARP entry. If no description is configured for the ARP entry, this field displays hyphens (--).
Number of ARP entries.
arp static
reset arp
display arp entry-limit
Use display arp entry-limit to display the maximum number of ARP entries that a device supports.
# Display the maximum number of ARP entries that the device supports.
<Sysname> display arp entry-limit
ARP entries: 2048
display arp ip-address
Use display arp ip-address to display the ARP entry for an IP address.
In standalone mode:
display arp ip-address [ slot slot-number ] [ verbose ]
In IRF mode:
display arp ip-address [ chassis chassis-number slot slot-number ] [ verbose ]
ip-address: Specifies an IP address.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the ARP entry on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays the ARP entry on the global active MPU. (In IRF mode.)
verbose: Displays the detailed information about the specified ARP entry.
The ARP entry information includes the IP address, MAC address, VLAN ID, output interface, entry type, and aging timer.
# Display the ARP entry for the IP address 20.1.1.1.
<Sysname> display arp 20.1.1.1
20.1.1.1        00e0-fc00-0001 --            --                       --    S
arp static
reset arp
display arp log
Use display arp log to display brief ARP log information.
In standalone mode:
display arp log [ interface interface-type interface-number | ip ip-address ] [ slot slot-number ]
In IRF mode:
display arp log [ interface interface-type interface-number | ip ip-address ] [ chassis chassis-number slot slot-number ]
interface: Displays the ARP log information for the specified interface.
ip: Displays the ARP log information for the specified IP address.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ARP logs for the active MPU. (Distributed devices in standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays ARP logs for the global active MPU. (Distributed devices in IRF mode.) (IRF 3 incapable.)
# Display brief information about all ARP log entries.
<Sysname> display arp log
Operate  : ADD               Reason   : ADDBYMSG
Mac      : 0000-0000-0000    Interface: GE2/0/1
SVLAN    : 65535             IP       : 1.1.1.2
CVLAN    : 65535             Time     : Oct 28 22:22:02 2022
SVLAN    : 65535             IP       : 1.1.1.1
Operate
ARP entry operation type:
·     ADD—Add an entry to the table.
·     MOD—Modify an existing entry in the table.
·     DEL—Delete an entry from the table.
Reason
Source of the ARP log entry:
·     DRNIMSG—Added in response to an ARP entry update message from the M-LAG module.
·     STATICFIX—Added in response to conversion of a dynamic ARP entry to a static one.
·     PKTLEARN—Added by learning from an ARP packet.
·     STATICMSG—Added through static configuration.
·     ADDBYRULE—Added by the IPoE or portal feature.
·     ADDBYOP—Added by the OpenFlow feature.
·     ADDBYMSG—Added through ARP entry synchronization.
·     ADDWADJ—Added in response to an IPv4 adjacency entry refresh message sent by the WAN link adjacency table module.
·     ADDWADJSYN—Added in response to an inter-card IPv4 adjacency entry synchronization message sent by the WAN link adjacency table module.
·     DRVRELOAD—Added in response to the ARP update operation done in the driver.
·     STATICEVENT—Added through ARP entry update in response to a long static entry event.
·     SYNCWITHDRV—Added in synchronization with the driver.
·     RELOADBYPW—Added in response to the PW reload operation.
·     RELOADBYMMAC— Added through ARP entry refresh triggered by the MultiMac module.
·     RELOADBYRB—Added through ARP entry refresh triggered by the RB module.
·     DELBYCFG—Manually deleted.
·     DELBYIPVRF—Deleted in bulk.
·     DELBYVSRP—Deleted by VSRP.
·     DELBYNODUMMY—Deleted due to lack of a DUMMY entry.
·     DELBYSMOOTH—Deleted upon ARP entry smoothing.
·     DELBYSMOOTHFILTER—Deleted through filtering in an ARP entry smooth operation.
·     DELCONFIGIPIF—Deleted upon an IPv6 address or interface conflict.
·     DELARPSYN—Deleted upon an inter-card ARP entry synchronization.
·     DELWADJMSG—Deleted upon deletion of the corresponding IPv4 adjacency entry from the WAN link adjacency table.
·     DELWADJIFMSG—Deleted by interface upon deletion of the corresponding IPv4 adjacency entry from the WAN link adjacency table.
·     DELWADJBI—Deleted upon reception of the entry deletion message sent from the WAN link adjacency table module to the link layer in the kernel.
·     DELWADJDUMMY—Deleted upon deletion of the corresponding DUMMY entry by the WAN link adjacency table module.
·     DELWADJIFEVENT—Deleted upon deletion of the corresponding IPv4 adjacency entry done by the WAN link adjacency table module in response to an interface event.
·     DELWADJALL—Deleted upon deletion of all IPv6 adjacency entries from the WAN link adjacency table.
·     DELWADJ—Deleted upon deletion of the corresponding IPv6 adjacency entry from the WAN link adjacency table.
·     DELWADJSAGE—Deleted upon deletion of the corresponding IPv6 adjacency entry that had aged out from the WAN link adjacency table.
·     DELWADJIFSYN—Deleted upon deletion of the corresponding IPv4 adjacency entry from the WAN link adjacency table in response to interface entry synchronization.
·     DELWADJSYNMSG—Deleted upon deletion of the corresponding IPv4 adjacency entry from the WAN link adjacency table in response to inter-card entry synchronization.
·     DELWADJSMOOTH—Deleted upon deletion of the corresponding IPv4 adjacency entry because of entry smoothing done by the WAN link adjacency table module.
·     DELWADJPULLFINISH—Deleted upon deletion of the corresponding IPv4 adjacency entry after the WAN link adjacency table module successfully obtained entries in bulk.
·     DELPORTLVLAN—Deleted upon removal of the port from the VLAN.
·     DELVLANMODCHG—Deleted upon VLAN mode change.
·     DELLIMIT—Deleted because the number of ARP entries has reached the limit.
·     DELARPBYOPIF—Deleted upon deletion of the interface.
·     DELARPVLANEVENT—Deleted upon a VLAN event.
·     DELARPSTATUS—Deleted upon ARP entry status change.
·     DELARPBYIPIF—Deleted by specify the IPv4 address or interface.
·     DELARPBYIFMAP—Deleted upon an interface mapping operation.
·     DELARPBYIFDOWN— Deleted because the interface went down.
·     DELARPBYIFAGG—Deleted because the interface was added to a link aggregation group.
·     DELARPBYNODE—Deleted upon deletion of ARP entries by slot.
·     DELARPBYALL—Deleted upon deletion of all ARP entries.
·     DELARPBYALLEM—Deleted upon deletion of all ARP entries from non-management interfaces.
·     DELARPBYPWDeleted upon deletion of ARP entries from a PW.
·     DELARPBYPWVSI—Deleted upon deletion of ARP. entries done by PWVSI.
·     DELARPBYMACNOTIFY—Deleted upon reception of ARP entries from MAC.
·     DELARPBYRB—Deleted upon a RB action.
·     DELARPBYTCPKEEP—Deleted because of the topology change notification (TCN) flag.
·     DELARPBYSTATICFIX—Deleted upon conversion of a dynamic entry to a static entry.
·     DELBYPULLFINISH—Deleted upon a successful batch data pull.
·     DELSTATICCONFLICT—Deleted upon a static configuration conflict.
IP
Mac
Name of the outgoing interface in the ARP entry.
SVLAN
Service provider VLAN.
CVLAN
Customer VLAN.
Time
Timestamp of log creation.
display arp safe-guard statistics
Card category
Cards
CSPEX
Use display arp safe-guard statistics to display ARP safe-guard statistics.
In standalone mode:
display arp safe-guard statistics slot slot-number
In IRF mode:
display arp safe-guard statistics chassis chassis-number slot slot-number
# (In standalone mode.) Display ARP safe-guard statistics.
<Sysname> display arp safe-guard statistics slot 1
ARP replies sent by the driver: 1234
ARP replies dropped by the driver: 100
# (In IRF mode.) Display ARP safe-guard statistics.
<Sysname> display arp safe-guard statistics chassis 1 slot 1
Number of ARP replies that the driver sent to the device.
Number of illegal ARP replies that the driver dropped.
reset arp safe-guard statistics
Use display arp timer aging to display the aging timer of dynamic ARP entries.
# Display the aging timer of dynamic ARP entries.
<Sysname> display arp timer aging
Current ARP aging time is 20 minute(s)(default)
arp timer aging
Use display arp user-ip-conflict record to display user IP address conflict records.
In standalone mode:
display arp user-ip-conflict record [ slot slot-number ]
In IRF mode:
display arp user-ip-conflict record [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays user IP address conflict records on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays user IP address conflict records on all cards. (In IRF mode.)
# Display all user IP address conflict records.
<Sysname> display arp user-ip-conflict record
IP address: 10.1.1.1
System time: 2018-02-02 11:22:29
Conflict count: 1
Log suppress count: 0
Old interface: Ten-GigabitEthernet3/1/1
New interface: Ten-GigabitEthernet3/1/2
Old SVLAN/CVLAN: 100/2
New SVLAN/CVLAN: 100/2
Old MAC: 00e0-ca63-8141
New MAC: 00e0-ca63-8142
IP address: 10.1.1.2
System time: 2018-02-02 10:20:30
Conflict count: 1
Old SVLAN/CVLAN: 100/--
New SVLAN/CVLAN: 100/--
IP address
IP address of a  user.
System time
Time when the user IP address conflict occurred.
Conflict count
Number of times that conflicts for the IP address.
Log suppress count
Number of times that user IP address conflict logs are suppressed.
Old interface
Output interface in the old ARP entry.
New interface
Output interface in the new ARP entry.
Old SVLAN/CVLAN
ID of the outer VLAN or inner VLAN in the old ARP entry. This field displays hyphens (--) if the ARP entry does not belong to any outer VLAN or inner VLAN.
New SVLAN/CVLAN
ID of the outer VLAN or inner VLAN in the new ARP entry. This field displays hyphens (--) if the ARP entry does not belong to any outer VLAN or inner VLAN.
Old MAC
MAC address in the old ARP entry.
New MAC
MAC address in the new ARP entry.
Use display arp user-move record to display user port migration records.
In standalone mode:
display arp user-move record [ slot slot-number ]
In IRF mode:
display arp user-move record [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays user port migration records on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays user port migration records on all cards. (In IRF mode.)
Each card can save a maximum of 200 user port migration records.
When the number of user port migration records reaches the upper limit, new records will overwrite the earliest ones.
# Display all user port migration records.
<Sysname> display arp user-move record
MAC address: 0001-0201-0e81
Move count: 1
Before:
  SVLAN/CVLAN: 100/2
After:
  SVLAN/CVLAN: 100/2
MAC address: 0001-0201-0e82
Move count: 1
Before:
  SVLAN/CVLAN: 100/--
After:
  SVLAN/CVLAN: 100/--
Table 5 Command output
IP address
IP address of the user.
MAC address
MAC address of the user.
System time
Time when the user port migration occurred.
Move count
Number of times that user port migrated.
Log suppress count
Number of times that the generation of user port migration logs is suppressed.
Output interface in the ARP entry.
SVLAN/CVLAN
ID of the outer VLAN or inner VLAN in the ARP entry. This field displays hyphens (--) if the ARP entry does not belong to any outer VLAN or inner VLAN.
display arp vpn-instance
Use display arp vpn-instance to display the ARP entries for a VPN instance.
display arp vpn-instance vpn-instance-name [ count ]
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
This command displays information about ARP entries for a VPN instance, including the IP address, MAC address, VLAN ID, output interface, entry type, and aging timer.
# Display ARP entries for VPN instance test.
<Sysname> display arp vpn-instance test
arp static
reset arp
reset arp
Use reset arp to clear ARP entries from the ARP table.
In standalone mode:
reset arp { all | dynamic | interface interface-type interface-number | slot slot-number | static }
In IRF mode:
reset arp { all | chassis chassis-number slot slot-number | dynamic | interface interface-type interface-number | static }
all: Clears all ARP entries.
dynamic: Clears all dynamic ARP entries.
static: Clears all static ARP entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears ARP entries on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears ARP entries on the global active MPU. (In IRF mode.)
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears ARP entries on all interfaces.
CAUTION
CAUTION:
The reset arp command clears existing ARP entries on the device. It might cause external traffic unable to quickly reach the LAN users.
# Clear all static ARP entries.
<Sysname> reset arp static
This will delete all static entries. Continue? [Y/N]:
arp static
display arp
Card category
Cards
CSPEX
Use reset arp safe-guard statistics to clear ARP safe-guard statistics.
In standalone mode:
reset arp safe-guard statistics { all | slot slot-number }
In IRF mode:
reset arp safe-guard statistics { all | chassis chassis-number slot slot-number }
all: Specifies all ARP safe-guard statistics.
# Clear ARP safe-guard statistics.
<Sysname> reset arp safe-guard statistics all
Gratuitous ARP commands
arp ip-conflict log prompt
Use arp ip-conflict log prompt to enable IP conflict notification.
Use undo arp ip-conflict log prompt to restore the default.
IP conflict notification is disabled.
By default, the device performs the following operations if it is using the sender IP address of a received ARP packet:
·     Sends a gratuitous ARP request.
·     Displays an error message after the device receives an ARP reply about the conflict.
You can use this command to enable the device to display error messages before sending a gratuitous ARP reply or request for conflict confirmation.
# Enable IP conflict notification on the device.
[Sysname] arp ip-conflict log prompt
arp send-gratuitous-arp
Use arp send-gratuitous-arp to enable periodic sending of gratuitous ARP packets on an interface.
Use undo arp send-gratuitous-arp to disable the interface from periodically sending gratuitous ARP packets.
arp send-gratuitous-arp [ interval interval ]
Periodic sending of gratuitous ARP packets is disabled.
VSI interface view
VLAN interface view
interval interval: Specifies the sending interval in the range of 200 to 200000 milliseconds. The default value is 2000 milliseconds.
This feature takes effect on an interface only when the interface has an IP address and the data link layer state of the interface is up.
This feature can send gratuitous ARP requests only for a VRRP virtual IP address, or the sending interface's primary IP address or manually configured secondary IP address. The primary IP address can be configured manually or automatically, whereas the secondary IP address must be configured manually.
If you change the sending interval for gratuitous ARP packets, the configuration takes effect at the next sending interval.
The sending interval for gratuitous ARP packets might be much longer than the set interval when any of the following conditions exist:
·     This feature is enabled on multiple interfaces.
·     Each interface is configured with multiple secondary IP addresses.
·     A small sending interval is configured in the preceding cases.
# Enable Ten-GigabitEthernet 3/1/1 to send gratuitous ARP packets every 300 milliseconds.
[Sysname-Ten-GigabitEthernet3/1/1] arp send-gratuitous-arp interval 300
gratuitous-arp-learning enable
Use gratuitous-arp-learning enable to enable learning of gratuitous ARP packets.
Use undo gratuitous-arp-learning enable to disable learning of gratuitous ARP packets.
Learning of gratuitous ARP packets is enabled.
The learning of gratuitous ARP packets feature allows a device to maintain its ARP table by creating or updating ARP entries based on received gratuitous ARP packets.
When this feature is disabled, the device uses received gratuitous ARP packets to update existing ARP entries only. ARP entries are not created based on the received gratuitous ARP packets, which saves ARP table space.
# Enable learning of gratuitous ARP packets.
[Sysname] gratuitous-arp-learning enable
gratuitous-arp-sending enable
Use gratuitous-arp-sending enable to enable sending gratuitous ARP packets upon receiving ARP requests whose sender IP address is on a different subnet.
Use undo gratuitous-arp-sending enable to disable sending gratuitous ARP packets upon receiving ARP requests whose sender IP address is on a different subnet.
A device does not send gratuitous ARP packets when it receives ARP requests whose sender IP address is on a different subnet.
# Disable a device from sending gratuitous ARP packets upon receiving ARP requests whose sender IP address is on a different subnet.
[Sysname] undo gratuitous-arp-sending enable
gratuitous-arp mac-change retransmit
Use gratuitous-arp mac-change retransmit to set the times and the interval for retransmitting a gratuitous ARP packet for the device MAC address change.
Use undo gratuitous-arp mac-change retransmit to restore the default.
gratuitous-arp mac-change retransmit times interval seconds
The device sends a gratuitous packet for its MAC address change once only.
times: Specifies the times of retransmitting a gratuitous packet, in the range of 1 to 10.
interval seconds: Specifies the interval for retransmitting a gratuitous packet, in the range of 1 to 10 seconds.
The device sends a gratuitous ARP packet to inform other devices of its MAC address change. However, the other devices might fail to receive the packet because the device sends the gratuitous ARP packet once only by default. Use this command to configure gratuitous ARP retransmission parameters to ensure that the other devices can receive the packet.
After you execute this command, the device will retransmit a gratuitous ARP packet for its MAC address change at the specified interval for the specified times.
# Set the times to 3 and the interval to 5 for retransmitting a gratuitous ARP packet for the device MAC address change.
[Sysname] gratuitous-arp mac-change retransmit 3 interval 5
Proxy ARP commands
In a BRAS scenario, to enable proxy ARP features (including common proxy ARP, local proxy ARP, and inter-VLAN proxy ARP), you must execute the local-proxy-arp enable command. Executing this command enables all proxy ARP features.
display local-proxy-arp
Use display local-proxy-arp to display the local proxy ARP status.
display local-proxy-arp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the local proxy ARP status for all interfaces.
You can use this command to check whether local proxy ARP is enabled or disabled.
# Display the local proxy ARP status for Ten-GigabitEthernet 3/1/1.
<Sysname> display local-proxy-arp interface ten-gigabitethernet 3/1/1
Interface Ten-GigabitEthernet3/1/1
 Local Proxy ARP status: enabled
display proxy-arp
Use display proxy-arp to display the proxy ARP status.
display proxy-arp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the proxy ARP status for all interfaces.
You can use this command to check whether proxy ARP is enabled or disabled.
# Display the proxy ARP status on Ten-GigabitEthernet 3/1/1.
<Sysname> display proxy-arp interface ten-gigabitethernet 3/1/1
 Proxy ARP status: disabled
proxy-arp enable
Use local-proxy-arp enable to enable local proxy ARP.
Use undo local-proxy-arp enable to disable local proxy ARP.
local-proxy-arp enable [ ip-range start-ip-address to end-ip-address ]
Local proxy ARP is disabled.
VSI interface view
VLAN interface view
L3VE interface/subinterface view
ip-range start-ip-address to end-ip-address: Specifies the IP address range for which local proxy ARP is enabled. The start IP address must be lower than or equal to the end IP address.
Proxy ARP enables a device on a network to answer ARP requests for an IP address not on that network.
With proxy ARP, hosts in different broadcast domains can communicate with each other as they do on the same network. To allow communication between hosts that connect to the same Layer 3 interface and reside in different broadcast domains, enable local proxy ARP.
# Enable local proxy ARP on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] local-proxy-arp enable
# Enable local proxy ARP on Ten-GigabitEthernet 3/1/1 for an IP address range.
[Sysname-Ten-GigabitEthernet3/1/1] local-proxy-arp enable ip-range 1.1.1.1 to 1.1.1.20
proxy-arp enable
Use proxy-arp enable to enable common proxy ARP.
Use undo proxy-arp enable to disable common proxy ARP.
proxy-arp enable
Common proxy ARP is disabled.
VSI interface view
VLAN interface view
With proxy ARP, hosts in different broadcast domains can communicate with each other as they do on the same network. To allow communication between hosts that connect to different Layer 3 interfaces or Layer 3 subinterfaces and reside in different broadcast domains, enable common proxy ARP.
# Enable common proxy ARP on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] proxy-arp enable
display proxy-arp
proxy-arp inter-vlan enable
Use proxy-arp inter-vlan enable to enable inter-VLAN proxy ARP.
Use undo proxy-arp inter-vlan enable to disable inter-VLAN proxy ARP.
Inter-VLAN proxy ARP is disabled.
L3VE subinterface view
With proxy ARP, hosts in different broadcast domains can communicate with each other as they do on the same network. To allow communication between hosts that connect to the same Layer 3 subinterface but reside in different VLANs, enable inter-VLAN proxy ARP.
# Enable inter-VLAN proxy ARP on Layer 3 Ethernet subinterface Ten-GigabitEthernet 3/1/1.1.
[Sysname] interface ten-gigabitethernet 3/1/1.1
[Sysname-Ten-GigabitEthernet3/1/1.1] proxy-arp inter-vlan enable
ARP snooping commands
arp snooping enable
Use arp snooping enable to enable ARP snooping.
Use undo arp snooping enable to disable ARP snooping.
arp snooping enable
ARP snooping is disabled.
VLAN view
# Enable ARP snooping for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] arp snooping enable
display arp snooping
Use display arp snooping to display ARP snooping entries.
In standalone mode:
display arp snooping [ vlan vlan-id ] [ slot slot-number ] [ count ]
display arp snooping ip ip-address [ slot slot-number ]
In IRF mode:
display arp snooping [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ count ]
display arp snooping ip ip-address [ chassis chassis-number slot slot-number ]
vlan vlan-id: Displays ARP snooping entries for a VLAN. The vlan-id argument is in the range of 1 to 4094.
count: Displays the number of the ARP snooping entries.
ip ip-address: Displays the ARP snooping entry for the specified IP address.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ARP snooping entries on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays ARP snooping entries on the global active MPU. (In IRF mode.)
# Display ARP snooping entries for VLAN 2.
<Sysname> display arp snooping vlan 2
IP Address   MAC Address    VLAN ID Interface  Aging       Status
3.3.3.3      0003-0003-0003 2       XGE3/1/1   20          Valid
3.3.3.4      0004-0004-0004 2       XGE3/1/2   5           Invalid
# Display the number of the ARP snooping entries.
<Sysname> display arp snooping count
Total entries: 2
Table 6 Command output
IP Address
IP address in an ARP snooping entry.
MAC Address
MAC address in an ARP snooping entry.
VLAN ID
ID of the VLAN to which the ARP snooping entry belongs.
Input interface in an ARP snooping entry.
Aging
Aging time for an ARP snooping entry in minutes.
If the card learns an ARP snooping entry from another card, the card cannot learn the aging time of the entry, and this field displays hyphens (--).
Status
Status of an ARP snooping entry: Valid, Invalid, Collision.
Total entries
Number of ARP snooping entries.
reset arp snooping
reset arp snooping
Use reset arp snooping to delete ARP snooping entries.
reset arp snooping [ ip ip-address | vlan vlan-id ]
ip ip-address: Deletes the ARP snooping entry for the specified IP address.
vlan vlan-id: Deletes ARP snooping entries for the specified VLAN. The value range for the vlan-id argument is 1 to 4094.
If you do not specify any option, the command deletes all ARP snooping entries.
# Delete ARP snooping entries for VLAN 2.
<Sysname> reset arp snooping vlan 2
ARP suppression commands
In standard system operating mode, ARP suppression is not supported.
In SDN-WAN system operating mode, ARP suppression is available only for the following cards:
Card category
Cards
CSPEX
arp suppression enable
Use arp suppression enable to enable ARP suppression.
Use undo arp suppression enable to disable ARP suppression.
ARP suppression is disabled.
Cross-connect view
You must enable L2VPN before you enter cross-connect view.
# Enable ARP suppression for cross-connect 2 in cross-connect group 1.
[Sysname] xconnect-group 1
[Sysname-xcg-1] connection 2
[Sysname-xcg-1-2] arp suppression enable
arp suppression push interval
Use arp suppression push interval to enable the ARP suppression push feature and set a push interval.
Use undo arp suppression push interval to disable the ARP suppression push feature.
arp suppression push interval interval
The ARP suppression push feature is disabled.
interval: Specifies a push interval for ARP suppression, in the range of 1 to 1440 minutes.
The ARP suppression push feature regularly pushes ARP suppression entries by broadcasting gratuitous ARP packets.
# Configure the device to push ARP suppression entries every 2 minutes.
[Sysname] arp suppression push interval 2
display arp suppression xconnect-group
Use display arp suppression xconnect-group to display ARP suppression entries.
In standalone mode:
display arp suppression xconnect-group [ name group-name ] [ slot slot-number ] [ count ]
In IRF mode:
display arp suppression xconnect-group [ name group-name ] [ chassis chassis-number slot slot-number ] [ count ]
name group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters excluding hyphens (-). If you do not specify a cross-connect group, this command display ARP suppression entries for all cross-connect groups.
count: Displays the total number of ARP suppression entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ARP suppression entries on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays ARP suppression entries on the global active MPU. (In IRF mode.)
# Display ARP suppression entries for all cross-connect groups.
<Sysname> display arp suppression xconnect-group
IP address      MAC address     Xconnect-group       Connection           Aging
100.1.1.1       000c-29fe-5a8f  vpna                 svc                  12
100.1.1.2       000c-29fe-5aa3  vpna                 svc                  25
# Display the total number of ARP suppression entries.
<Sysname> display arp suppression xconnect-group count
Total entries: 2
Table 7 Command output
IP address
IP address in the ARP suppression entry.
MAC address
MAC address in the ARP suppression entry.
Xconnect-group
Name of the cross-connect group to which the ARP suppression entry belongs.
Connection
Name of the cross-connect to which the ARP suppression entry belongs.
Aging
Aging time of the ARP suppression entry, in minutes.
reset arp suppression xconnect-group
Use reset arp suppression xconnect-group to clear ARP suppression entries.
reset arp suppression xconnect-group [ name group-name ]
name group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters excluding hyphens (-). If you do not specify a cross-connect group, this command clears ARP suppression entries for all cross-connect groups.
# Clear ARP suppression entries for all cross-connect groups.
<Sysname> reset arp suppression xconnect-group
ARP direct route advertisement commands
arp route-direct advertise
Use arp route-direct advertise to enable ARP direct route advertisement.
Use undo arp route-direct advertise to disable ARP direct route advertisement.
ARP direct route advertisement is disabled.
L3VE interface view
VPN instance view
FlexE logical interface view
You can enable ARP direct route advertisement in different views.
·     In system view, the feature takes effect on all interfaces on the public network.
·     In interface view, the feature takes effect on the specified interface.
·     In VPN instance view, the feature takes effect on all interfaces that belong to the VPN instance.
To disable ARP direct route advertisement on an interface, you must also disable ARP direct route advertisement in the VPN instance or the public network to which the interface belongs.
# Enable ARP direct route advertisement in system view.
[Sysname] arp route-direct advertise
# Enable ARP direct route advertisement on Ten-GigabitEthernet 3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] arp route-direct advertise
# Enable ARP direct route advertisement on L3VE interface VE-L3VPN 1.
[Sysname] interface ve-l3vpn 1
[Sysname-VE-L3VPN1] arp route-direct advertise
# Enable ARP direct route advertisement in VPN instance vpna.
[Sysname-vpn-instance-vpna] arp route-direct advertise
