07-VLAN termination commands | 139.70 KB |
user-vlan dot1q vid second-dot1q
vlan-termination broadcast enable
vlan-type dot1q vid second-dot1q
display subinterface
Use display subinterface to display information about VLAN termination-enabled subinterfaces.
display subinterface interface-type interface-number dot1q vid vlan-id [ second-dot1q vlan-id ]
interface-type interface-number: Specifies a main interface by its type and number.
dot1q vid vlan-id: Specifies the outermost VLAN ID in VLAN-tagged packets that are terminated by subinterfaces. The value range for the vlan-id argument is 1 to 4094.
second-dot1q vlan-id: Specifies the outermost Layer 2 VLAN ID in VLAN-tagged packets that are terminated by subinterfaces. The value range for the vlan-id argument is 1 to 4094.
This command displays VLAN termination configurations on subinterfaces of a specifed main interface.
This command is available only for VLAN Dot1q termination and VLAN QinQ termination:
· This command displays information about Dot1q termination-enabled subinterfaces when the dot1q vid vlan-id parameter is specified.
· This command displays information about QinQ termination-enabled subinterfaces when both the dot1q vid vlan-id and second-dot1q vlan-id parameters are specified.
# Display VLAN termination information on subinterfaces of Layer 3 aggregate interface Route-Aggregation 1. The outermost VLAN ID for the subinterfaces is 5.
<Sysname> display subinterface route-aggregation 1 dot1q vid 5
Subinterface Route-Aggregation1.1:
Current state: DOWN
Service VLAN: 5
# Display VLAN termination information on subinterfaces of Layer 3 aggregate interface Route-Aggregation 1. The outermost Layer 1 and Layer 2 VLAN IDs for the subinterfaces are 2 and 3, respectively.
<Sysname> display subinterface route-aggregation 1 dot1q vid 2 second-dot1q 3
Current state: DOWN
Service VLAN: 2
Customer VLAN: 3
No subinterface has the VLAN termination configuration. |
No subinterface has the VLAN termination configuration in the main interface. |
Subinterface |
VLAN termination configuration on a subinterface. |
Current state |
Link state of the subinterface: · UP—The interface is both administratively and physically up. · DOWN—The interface is administratively and physically down (possibly because the subinterface has been shut down by using the shutdown command or the physical link of the main interface has failed). |
Service VLAN |
This field indicates the outermost layer VLAN for VLAN Dot1q termination. |
Customer VLAN |
This field indicates Layer 2 VLAN for VLAN QinQ termination. This field displays only when the second-dot1q argument is specified. |
display user-vlan
Use display user-vlan to display user VLAN information.
display user-vlan interface interface-type interface-number.subnumber [ slot slot-number ]
interface-number.subnumber: Specifies a subinterface by its number. The interface-number argument specifies the main interface number, and the subnumber argument specifies a subinterface number.
slot slot-number: Specifies a card by its slot number.
This command displays user VLAN information on a subinterface only if the following conditions exist:
· The user-vlan dot1q vid or user-vlan dot1q vid second-dot1q command has been configured on the subinterface.
· Online users are present on the subinterface.
When you specify the slot slot-number option, following these restrictions and guidelines:
· If member ports of an aggregation group belong to different slots, use this option to specify a slot. If you do not specify this option, the command displays user VLAN information on the slot that hosts the aggregation member port with the smallest port number. The Port Number field of the display link-aggregation member-port command output displays the port number of an aggregation member port.
· To display user VLAN information on other types of subinterfaces, do not specify this option.
# Display user VLAN information on Layer 3 Ethernet subinterface Ten-GigabitEthernet3/0/1.1.
<Sysname> display user-vlan interface ten-gigabitethernet 3/0/1.1
Service VLAN Customer VLAN Number of online users
20 100 1
20 101 10
Number of user VLANs: 2
Service VLAN |
Service provider network VLAN: · This field indicates the outermost layer VLAN (customer network VLAN) for user VLAN Dot1q termination. · This field indicates Layer 1 VLAN for user VLAN QinQ termination. |
Customer VLAN |
Customer network VLAN: · This field displays N/A for user VLAN Dot1q termination. · This field indicates Layer 2 VLAN for user VLAN QinQ termination. |
Number of online users |
Number of online users in the VLAN. |
Number of user VLANs |
Number of VLANs that have online users. |
user-vlan dot1q vid
dot1q ethernet-type
Use dot1q ethernet-type to set the TPID value in the outermost VLAN tag of packets received and sent by an interface.
Use undo dot1q ethernet-type to restore the default.
dot1q ethernet-type hex-value
The TPID value for the outermost VLAN tag of a VLAN-tagged packet received and sent by the interface is 0x8100.
Layer 3 aggregate/Ethernet interface view
hex-value: Sets a hexadecimal TPID value in the range of 1 to ffff, excluding the common protocol type values listed in Table 3.
Table 3 Common protocol type values
Protocol |
Value |
ARP |
0x0806 |
PUP |
0x0200 |
RARP |
0x8035 |
IP |
0x0800 |
IPv6 |
0x86DD |
PPPoE |
0x8863/0x8864 |
MPLS |
0x8847/0x8848 |
IPX/SPX |
0x8137 |
IS-IS |
0x8000 |
LACP |
0x8809 |
LLDP |
0x88CC |
802.1X |
0x888E |
802.1ag |
0x8902 |
Cluster |
0x88A7 |
Reserved on the device |
0xFFFD/0xFFFE/0xFFFF |
After you execute this command, only packets whose TPID in the outermost VLAN tag is 0x8100 or the configured value are processed as VLAN-tagged packets.
When sending a packet, the interface sets the TPID value in the outermost VLAN tag to the configured value. If the packet includes two or more layers of VLAN tags, the interface sets the TPID values in the other VLAN tags to 0x8100.
Configurations made on a Layer 3 Ethernet interface or Layer 3 aggregate interface take effect on all subinterfaces of the interface.
# Set the TPID value to 0x9100 in the outermost VLAN tag of VLAN-tagged packets received and sent by the subinterfaces of Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] dot1q ethernet-type 9100
second-dot1q
Use second-dot1q to enable QinQ termination on an interface, and specify the Layer 2 VLAN IDs of the VLAN-tagged packets that can be terminated by the interface.
Use undo second-dot1q to disable QinQ termination on an interface.
second-dot1q { vlan-id-list | any }
undo second-dot1q { vlan-id-list | any }
QinQ termination is disabled on an interface.
VLAN interface view
vlan-id-list: Specifies a space-separated list of up to 10 Layer 2 VLAN ID items. Each item specifies a Layer 2 VLAN ID or a range of Layer 2 VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
any: Specifies all values between 1 and 4094.
When you execute this command, the Layer 1 VLAN ID of VLAN-tagged packets that can be terminated by the interface is the interface number. This Layer 1 VLAN ID is not configurable.
# Configure VLAN-interface 10 to terminate VLAN-tagged packets with Layer 2 VLAN IDs in the range of 10 to 20.
[Sysname-Vlan-interface10] second-dot1q 10 to 20
[Sysname-Vlan-interface10] quit
# Configure VLAN-interface 12 to terminate VLAN-tagged packets with Layer 2 VLAN ID 100.
[Sysname] interface vlan-interface 12
[Sysname-Vlan-interface12] second-dot1q 100
[Sysname-Vlan-interface12] quit
# Configure VLAN-interface 100 to terminate VLAN-tagged packets with any Layer 2 VLAN IDs.
[Sysname-Vlan-interface100] second-dot1q any
The following table describes the configuration results:
VLAN interface |
Layer 1 VLAN ID of VLAN-tagged packets that the VLAN interface can terminate |
Layer 2 VLAN IDs of VLAN-tagged packets that the VLAN interface can terminate |
VLAN-interface 10 |
10 |
10–20 |
VLAN-interface 12 |
12 |
100 |
VLAN-interface 100 |
100 |
1–4094 |
user-vlan dot1q default
Use user-vlan dot1q default to enable user VLAN default termination on a subinterface.
Use undo user-vlan dot1q default to disable user VLAN default termination on a subinterface.
User VLAN default termination is disabled on a subinterface.
This command enables the subinterface to process packets that cannot be terminated by other subinterfaces on the same main interface.
# Enable user VLAN default termination on Ten-GigabitEthernet 3/0/1.1.
[Sysname] interface ten-gigabitethernet 3/0/1.1
[Sysname-Ten-GigabitEthernet3/0/1.1] user-vlan dot1q default
[Sysname-Ten-GigabitEthernet3/0/1.1] quit
user-vlan dot1q vid
Use user-vlan dot1q vid to enable user VLAN Dot1q termination on a subinterface, and specify the outermost VLAN IDs in the VLAN-tagged packets that can be terminated by the subinterface.
Use undo user-vlan dot1q vid to disable user VLAN Dot1q termination on a subinterface.
user-vlan dot1q vid vlan-id-list
undo user-vlan dot1q vid vlan-id-list
User VLAN Dot1q termination is disabled on a subinterface.
vlan-id-list: Specifies a space-separated list of up to 10 outermost VLAN ID items. Each item specifies an outermost VLAN ID or a range of outermost VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
The outermost VLAN ID ranges specified by the vlan-id-list argument for different subinterfaces of a main interface cannot overlap.
This command and the vlan-type dot1q vid command are mutually exclusive on the same subinterface.
# Enable user VLAN Dot1q termination on Ten-GigabitEthernet 3/0/1.1, and configure the interface to terminate VLAN-tagged packets with outermost VLAN IDs in the range of 2 to 100.
[Sysname-Ten-GigabitEthernet3/0/1.1] user-vlan dot1q vid 2 to 100
Use user-vlan dot1q vid second-dot1q to enable user VLAN QinQ termination on a subinterface, and specify the outermost two layers of VLAN IDs in VLAN-tagged packets that are terminated by the subinterface.
Use undo user-vlan dot1q vid second-dot1q to disable user VLAN QinQ termination on a subinterface.
user-vlan dot1q vid vlan-id-list second-dot1q { vlan-id-list | any }
undo user-vlan dot1q vid vlan-id-list second-dot1q { vlan-id-list | any }
User VLAN QinQ termination is disabled on a subinterface.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN ID items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
Two subinterfaces of the same Ethernet interface cannot terminate packets that include the same two layers of VLAN IDs. If you configure the subinterfaces to terminate the same Layer 1 VLAN ID, make sure their Layer 2 VLAN ID ranges do not overlap. If you specify both any and vlan-id-list as the respective Layer 2 VLAN ID ranges of the subinterfaces, the any keyword does not include the VLAN IDs specified by vlan-id-list.
This command and the vlan-type dot1q vid second-dot1q command are mutually exclusive on the same subinterface.
# Enable user VLAN QinQ termination on Ten-GigabitEthernet3/0/1.1. Configure the interface to terminate VLAN-tagged packets with Layer 1 VLAN IDs in the range of 1 to 100 and Layer 2 VLAN IDs in the range of 500 to 600.
[Sysname-Ten-GigabitEthernet3/0/1.1] user-vlan dot1q vid 1 to 100 second-dot1q 500 to 600
Use vlan-termination broadcast enable to enable an interface to transmit broadcasts and multicasts.
Use undo vlan-termination broadcast enable to disable an interface from transmitting broadcasts and multicasts.
Broadcast and multicast packets are dropped on an interface configured with Dot1q/QinQ termination to terminate packets of multiple VLANs.
Layer 3 aggregate/Ethernet subinterface view
L3VE subinterface view
FlexE logical subinterface view
IMPORTANT: This command affects system performance. If system performance is seriously affected by this command, execute the undo form of this command to remove the command configuration. |
To transmit a broadcast or multicast packet, the interface starts a traversal over all the VLAN IDs specified for Dot1q/QinQ termination. It copies the packet and tags each copy with VLAN IDs, until all combinations of VLAN IDs are traversed.
· Configure Ten-GigabitEthernet 3/0/1.10 to tag a multicast or broadcast packet with each VLAN tag in the range of 10 to 20.
# Enable Dot1q termination on Ten-GigabitEthernet 3/0/1.10 to terminate VLAN-tagged packets with outermost VLAN IDs in the range of 10 to 20.
[Sysname] interface ten-gigabitethernet 3/0/1.10
[Sysname-Ten-GigabitEthernet3/0/1.10] vlan-type dot1q vid 10 to 20
# Enable Ten-GigabitEthernet 3/0/1.10 to transmit broadcast and multicast packets.
[Sysname-Ten-GigabitEthernet3/0/1.10] vlan-termination broadcast enable
· Configure Ten-GigabitEthernet 3/0/1.10 to tag a multicast or broadcast packet with each Layer 1 VLAN ID and each Layer 2 VLAN ID. The Layer 1 and Layer 2 VLAN IDs are in the range of 300 to 400 and 500 to 600, respectively.
# Configure Ten-GigabitEthernet 3/0/1.10 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 VLAN IDs are in the range of 300 to 400 and 500 to 600, respectively.
[Sysname-Ten-GigabitEthernet3/0/1.10] vlan-type dot1q vid 300 to 400 second-dot1q 500 to 600
vlan-termination broadcast ra
Use vlan-termination broadcast ra to enable an interface to transmit router advertisement (RA) multicast packets.
Use undo vlan-termination broadcast ra to disable an interface from transmitting RA multicast packets.
VLAN interface view
To transmit an RA multicast packet, the interface starts a traversal over all the VLAN IDs specified for Dot1q/QinQ termination. It copies the packet and tags each copy with VLAN IDs, until all combinations of VLAN IDs are traversed.
You must use this command to enable an ambiguous Dot1q or QinQ termination-enabled interface to transmit RA multicast packets on an IPv6 network. This command prohibits transmission of broadcast packets and other types of multicast packets, and consumes less CPU resources than the vlan-termination broadcast enable command.
· Configure Ten-GigabitEthernet 3/0/1.10 to tag RA multicast packets with each VLAN tag in the range of 10 to 20.
# Enable Ten-GigabitEthernet 3/0/1.10 to transmit RA multicast packets.
[Sysname-Ten-GigabitEthernet3/0/1.10] vlan-termination broadcast ra
· Configure Ten-GigabitEthernet 3/0/1.10 to tag RA multicast packets with each Layer 1 VLAN ID and each Layer 2 VLAN ID. The Layer 1 and Layer 2 VLAN IDs are in the range of 300 to 400 and 500 to 600, respectively.
vlan-termination user-mode
Use vlan-termination user-mode to enable user mode of VLAN termination.
Use undo vlan-termination user-mode to disable user mode of VLAN termination.
User mode of VLAN termination is disabled.
After you modify VLAN termination on a subinterface, the subinterface automatically restarts. In some networks (for example, networks using IPoE or PPPoE connections), the subinterface restart logs off online users. To prevent the subinterface restart and protect the online user state, enable user mode of VLAN termination before you modify VLAN termination on the subinterface.
After you enable user mode of VLAN termination and modify VLAN termination on a subinterface, clear entries of VLANs that are no longer terminated by the subinterface. If you do not clear these entries, running services might be affected.
For example, after you modify VLAN termination on a subinterface, perform the following tasks for the subinterface:
· Use the reset arp interface command in user view to clear all ARP entries.
· Use the reset ipv6 neighbors interface command in user view to clear all dynamic neighbors.
For more information about the reset arp and reset ipv6 neighbors commands, see ARP and IPv6 basics commands in Layer 3—IP Services Command Reference.
# Enable user mode of VLAN termination on Ten-GigabitEthernet 3/0/1.1.
[Sysname-Ten-GigabitEthernet3/0/1.1] vlan-termination user-mode
vlan-type dot1q untagged
Use vlan-type dot1q untagged to enable untagged termination on a subinterface.
Use undo vlan-type dot1q untagged to disable untagged termination on a subinterface.
Untagged termination is disabled on a subinterface.
This command enables the subinterface to process untagged packets.
On a main interface, you can execute this command on only one subinterface.
# Enable untagged termination on Ten-GigabitEthernet 3/0/1.1.
[Sysname-Ten-GigabitEthernet3/0/1.1] vlan-type dot1q untagged
vlan-type dot1q vid
Use vlan-type dot1q vid to enable Dot1q termination on a subinterface, and specify the outermost VLAN IDs in the VLAN-tagged packets that can be terminated by the subinterface.
Use undo vlan-type dot1q vid to disable Dot1q termination on a subinterface.
vlan-type dot1q vid vlan-id-list
undo vlan-type dot1q vid vlan-id-list
L2VE subinterface view
This command and the user-vlan dot1q vid command are mutually exclusive on the same subinterface.
# Configure Ten-GigabitEthernet 3/0/1.1 to terminate VLAN-tagged packets with outermost VLAN IDs in the range of 2 to 100.
[Sysname-Ten-GigabitEthernet3/0/1.1] vlan-type dot1q vid 2 to 100
Use vlan-type dot1q vid second-dot1q to enable QinQ termination on a subinterface, and specify the outermost two layers of VLAN IDs of VLAN-tagged packets that can be terminated by the subinterface.
Use undo vlan-type dot1q vid second-dot1q to disable QinQ termination on a subinterface.
vlan-type dot1q vid vlan-id-list second-dot1q { vlan-id-list | any }
undo vlan-type dot1q vid vlan-id-list second-dot1q { vlan-id-list | any }
Layer 3 aggregate/Ethernet/VE subinterface view
Two subinterfaces of the same main interface cannot terminate packets that include the same two layers of VLAN IDs. If you configure the subinterfaces to terminate the same Layer 1 VLAN ID, make sure their Layer 2 VLAN ID ranges do not overlap. If you specify both any and vlan-id-list as the respective Layer 2 VLAN ID ranges of the subinterfaces, the any keyword does not include the VLAN IDs specified by vlan-id-list.
This command and the user-vlan dot1q vid second-dot1q command are mutually exclusive on the same subinterface.
# Enable QinQ termination on the Layer 3 Ethernet subinterfaces, and configure each subinterface to terminate VLAN-tagged packets with the specified Layer 1 and Layer 2 VLAN IDs.
· Configure Ten-GigabitEthernet 3/0/1.1 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 VLAN IDs are both 100.
[Sysname-Ten-GigabitEthernet3/0/1.1] vlan-type dot1q vid 100 second-dot1q 100
· Configure Ten-GigabitEthernet 3/0/1.2 to terminate VLAN-tagged packets with Layer 1 VLAN ID 100 and Layer 2 VLAN IDs in the range of 200 to 300.
[Sysname] interface ten-gigabitethernet 3/0/1.2
[Sysname-Ten-GigabitEthernet3/0/1.2] vlan-type dot1q vid 100 second-dot1q 200 to 300
[Sysname-Ten-GigabitEthernet3/0/1.2] quit
· Configure Ten-GigabitEthernet 3/0/1.3 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 100 and Layer 2 VLAN ID is any value between 1 and 4094.
[Sysname] interface ten-gigabitethernet 3/0/1.3
[Sysname-Ten-GigabitEthernet3/0/1.3] vlan-type dot1q vid 100 second-dot1q any
[Sysname-Ten-GigabitEthernet3/0/1.3] quit
· Configure Ten-GigabitEthernet 3/0/1.4 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 100 and Layer 2 VLAN ID is in the range of 500 to 600.
[Sysname] interface ten-gigabitethernet 3/0/1.4
[Sysname-Ten-GigabitEthernet3/0/1.4] vlan-type dot1q vid 100 second-dot1q 500 to 600
[Sysname-Ten-GigabitEthernet3/0/1.4] quit
· Configure Ten-GigabitEthernet 3/0/1.5 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 200 and Layer 2 VLAN ID is in the range of 500 to 600.
[Sysname] interface ten-gigabitethernet 3/0/1.5
[Sysname-Ten-GigabitEthernet3/0/1.5] vlan-type dot1q vid 200 second-dot1q 500 to 600
[Sysname-Ten-GigabitEthernet3/0/1.5] quit
· Configure Ten-GigabitEthernet 3/0/1.6 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is in the range of 300 to 400 and Layer 2 VLAN ID is 100.
[Sysname] interface ten-gigabitethernet 3/0/1.6
[Sysname-Ten-GigabitEthernet3/0/1.6] vlan-type dot1q vid 300 to 400 second-dot1q 100
[Sysname-Ten-GigabitEthernet3/0/1.6] quit
· Configure Ten-GigabitEthernet 3/0/1.7 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 IDs are in the range of 300 to 400 and 500 to 600, respectively.
[Sysname] interface ten-gigabitethernet 3/0/1.7
[Sysname-Ten-GigabitEthernet3/0/1.7] vlan-type dot1q vid 300 to 400 second-dot1q 500 to 600
[Sysname-Ten-GigabitEthernet3/0/1.7] quit
· Configure Ten-GigabitEthernet 3/0/1.8 to terminate VLAN-tagged packets with a Layer 1 VLAN ID in the range of 300 to 400 and any Layer 2 VLAN ID.
[Sysname] interface ten-gigabitethernet 3/0/1.8
[Sysname-Ten-GigabitEthernet3/0/1.8] vlan-type dot1q vid 300 to 400 second-dot1q any
Layer 3 Ethernet subinterface |
Layer 1 VLAN IDs of VLAN-tagged packets that the subinterface can terminate |
Layer 2 VLAN IDs of VLAN-tagged packets that the subinterface can terminate |
Ten-GigabitEthernet 3/0/1.1 |
100 |
100 |
Ten-GigabitEthernet 3/0/1.2 |
100 |
200–300 |
Ten-GigabitEthernet 3/0/1.3 |
100 |
1–99, 101–199, 301–499, and 601–4094 |
Ten-GigabitEthernet 3/0/1.4 |
100 |
500–600 |
Ten-GigabitEthernet 3/0/1.5 |
200 |
500–600 |
Ten-GigabitEthernet 3/0/1.6 |
300–400 |
100 |
Ten-GigabitEthernet 3/0/1.7 |
300–400 |
500–600 |
Ten-GigabitEthernet 3/0/1.8 |
300–400 |
1–99, 101–499, and 601–4094 |
