07-IP Multicast Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6526XE-HI[EI] Switch Series Command References-R8340Pxx-6W10007-IP Multicast Command Reference
12-IPv6 multicast routing and forwarding commands
acl (IPv6 multicast flow policy view)
Use acl to configure the multicast group range in which an IPv6 multicast flow policy takes effect.
Use undo acl to restore the default.
acl { ipv6-acl-number | name ipv6-acl-name }
undo acl
An IPv6 multicast flow policy does not take effect on any multicast groups.
ipv6-acl-number: Specifies an IPv6 basic or advanced ACL by its number, in the range of 2000 to 3999. If the ACL does not exist or does not have contain rules, the IPv6 multicast flow policy does not take effect on any multicast groups.
name ipv6-acl-name: Specifies an IPv6 basic or advanced ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters and must begin with an English letter. To avoid confusion, make sure the argument is not all. If the ACL does not exist or does not have contain rules, the IPv6 multicast flow policy does not take effect on any multicast groups.
This command is not supported by the default IPv6 multicast flow policy.
If a multicast group matches the ACL specified in an IPv6 multicast flow policy, the estimated bandwidth configured in the policy is used for the multicast flows of the multicast group.
In a basic ACL rule, the source parameter specifies a multicast group range. Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
In an advanced ACL rule, the source parameter specifies a multicast source range, and the destination parameter specifies a multicast group range. Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
An ACL rule containing the vpn-instance vpn-instance option does not take effect.
Example
# Configure an IPv6 multicast flow policy to take effect on the multicast group range FF03::101/128.
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source ff03::101 128
[Sysname] ipv6 multicast routing
[Sysname-mrib6] flow-policy name abc
[Sysname-mrib6-flow-policy-abc] acl 2000
flow-policy (IPv6 MRIB view)
bandwidth (IPv6 multicast flow policy view)
Use bandwidth to set the estimated bandwidth for IPv6 multicast flows.
bandwidth bandwidth { gbps | kbps | mbps }
undo bandwidth
The estimated bandwidth for IPv6 multicast flows is 0.
bandwidth: Specifies the estimated bandwidth in the range of 1 to 10000.
gbps: Specifies Gbps as the bandwidth unit.
kbps: Specifies kbps as the bandwidth unit.
Mbps: Specifies Mbps as the bandwidth unit.
The estimated bandwidth is selected for IPv6 multicast flows as follows:
1.     If the multicast group of an IPv6 multicast flow matches the ACL specified in a custom IPv6 multicast flow policy, the estimated bandwidth configured in the policy is selected for the multicast flow.
2.     If the multicast group of an IPv6 multicast flow does not match an ACL in any custom IPv6 multicast flow policy, the estimated bandwidth configured in the default policy is selected for the multicast flow.
3.     If the default policy is not created or the estimated bandwidth is not configured in the default policy, the estimated bandwidth for the multicast flow is 0.
Example
# Set the estimated bandwidth to 200 Mbps for IPv6 multicast flow policy abc.
[Sysname-mrib6-flow-policy-abc] bandwidth 200 mbps
delete ipv6 rpf-route-static
Use delete ipv6 rpf-route-static to delete all static IPv6 multicast routes.
delete ipv6 rpf-route-static [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command deletes all static IPv6 multicast routes on the public network.
This command deletes all static IPv6 multicast routes. To delete a single static IPv6 multicast route, use the undo ipv6 rpf-route-static command.
# Delete all static IPv6 multicast routes on the public network.
[Sysname] delete ipv6 rpf-route-static
This will erase all ipv6 multicast static routes and their configurations, you must reconfigure all ipv6 static routes.
Are you sure?[Y/N]:y
display ipv6 mrib interface
Use display ipv6 mrib interface to display information about interfaces maintained by the IPv6 MRIB.
display ipv6 mrib [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about interfaces maintained by the IPv6 MRIB on the public network.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about all interfaces maintained by the IPv6 MRIB.
# Display information about interfaces maintained by the IPv6 MRIB on the public network.
<Sysname> display ipv6 mrib interface
 Interface: Vlan-interface1
     Index: 0x00004444
     Current state: up
     MTU: 1500
     Type: BROADCAST
     Protocol: PIM-DM
     PIM protocol state: Enabled
     Address list:
          1. Local address : FE80:7:11::1/10
             Remote address: ::
             Reference     : 1
             State         : NORMAL
             Flags         : 0x0
Interface name.
Index
Index number of the interface.
Current state
Current status of the interface: up or down.
MTU
MTU value.
Interface type:
·     BROADCAST—Broadcast link interface.
·     LOOP—Loopback interface.
·     REGISTER—Register interface.
·     MTUNNEL—Multicast tunnel interface.
This field is empty if the interface is Null 0.
Protocol
Protocol running on the interface: PIM-DM, PIM-SM, MLD, or PROXY.
PIM protocol state
Whether IPv6 PIM is enabled: Enabled or Disabled.
Address list
Interface address list.
Local address
Local IP address.
Remote address
Remote end IP address. This field is displayed only when the interface is vlink type.
Reference
Number of times that the address has been used.
Status of the interface address: NORMAL or DEL.
Flags
Interface attribute:
·     0x0—The interface is in normal status.
·     0x1—The interface address is being deleted.
display ipv6 multicast boundary
Use display ipv6 multicast boundary to display IPv6 multicast boundary information.
display ipv6 multicast [ vpn-instance vpn-instance-name ] boundary { group [ ipv6-group-address [ prefix-length ] ] | scope [ scope-id ] } [ interface interface-type interface-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 multicast boundary information on the public network.
group: Displays the IPv6 multicast boundary information for the specified groups.
ipv6-group-address: Specifies an IPv6 multicast group address in the range of FFxy::/16, where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not specify an IPv6 multicast group, this command displays IPv6 multicast boundary information for all IPv6 multicast groups.
prefix-length: Specifies an address prefix length in the range of 8 to 128. The default is 128.
scope: Displays the IPv6 multicast group boundary information in the admin-scoped zone.
scope-id: Specifies an admin-scope zone by its ID in the range of 3 to 15, which is identified by the scope field in the IPv6 multicast group address. If you do not specify an admin-scoped zone, this command displays IPv6 multicast boundary information for all IPv6 admin-scoped zones.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IPv6 multicast boundary information for all interfaces.
# Display IPv6 multicast boundary information of all IPv6 multicast groups for all interfaces on the public network.
<Sysname> display ipv6 multicast boundary group
 Boundary                                                 Interface
 FF1E::/64                                                Vlan1
# Display IPv6 multicast boundary information in all IPv6 admin-scope zones for all interfaces on the public network.
<Sysname> display ipv6 multicast boundary scope
 Boundary            Interface
        3            Vlan-interface1
Boundary
IPv6 multicast group or IPv6 admin-scoped zone associated with the IPv6 multicast boundary.
Boundary interface associated with the IPv6 multicast boundary.
display ipv6 multicast fast-forwarding cache
Use display ipv6 multicast fast-forwarding cache to display IPv6 multicast fast forwarding entries.
display ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache [ ipv6-source-address | ipv6-group-address ] * [ slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 multicast fast forwarding entries on the public network.
ipv6-source-address: Specifies an IPv6 multicast source address.
ipv6-group-address: Specifies an IPv6 multicast group address. The value range for this argument is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 multicast fast forwarding entries for the master device.
# Display IPv6 multicast fast forwarding entries on the public network.
<Sysname> display ipv6 multicast fast-forwarding cache
Total 1 entries, 1 matched
(FE1F:60::200, FF0E::1)
Status     : Enabled
Source port: 2001                   Destination port: 2002
Protocol   : 2                      Flag            : 0x2
Incoming interface: Vlan-interface1
List of 1 outgoing interfaces:
Vlan-interface2
Status: Enabled               Flag: 0x14
Total number of (S, G) entries, and the total number of matching (S, G) entries.
(S, G) entry.
Protocol
Protocol number.
Flag
Flag for the (S, G) entry or the outgoing interface of the entry.
This field displays one flag or the sum of multiple flags. In this example, the value 0x2 means that the entry has only one flag 0x2. The value 0x14 means that the outgoing interface has flags 0x10 and 0x4.
The following flags are available for an entry:
·     0x1—The entry is created because of packets passed through between cards.
·     0x2—The entry is added by IPv6 multicast forwarding.
The following flags are available for an outgoing interface:
·     0x1—The interface is added to the entry because of packets passed through between cards.
·     0x2—The interface is added to an existing entry.
·     0x4—The MAC address of the interface is needed for fast forwarding.
·     0x8—The interface is an outgoing interface associated with the incoming VLAN or super VLAN interface.
·     0x10—The interface is associated with the entry.
·     0x20—The interface is to be deleted.
Status
Status of the (S, G) entry or the outgoing interface:
·     Enabled—Available.
·     Disabled—Unavailable.
Incoming interface
Incoming interface of the (S, G) entry.
Outgoing interface list of the (S, G) entry.
reset ipv6 multicast fast-forwarding cache all
display ipv6 multicast flow-policy info
Use display ipv6 multicast flow-policy info to display link selection information for IPv6 multicast flow policies.
display ipv6 multicast [ vpn-instance vpn-instance-name ] flow-policy info [ interface interface-type interface-number | source source-address | group group-address | policy { default | name policy-name } ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays link selection information for IPv6 multicast flow policies on the public network.
interface interface-type interface-number: Displays link selection information for IPv6 multicast flow policies on an interface.
source source-address: Displays link selection information for IPv6 multicast flow policies for a multicast source.
group group-address: Displays link selection information for IPv6 multicast flow policies for a multicast group. The value range for the group-address argument is FFxy::/16, where "x" and "y" represent any hexadecimal numbers in the range of 0 to F.
policy default: Specifies the default IPv6 multicast flow policy.
policy name policy-name: Specifies a custom IPv6 multicast flow policy by its name, a case-insensitive string of 1 to 63 characters.
If you do not specify the source, group, or policy parameter, this command displays link selection information for all IPv6 multicast flow policies.
# Display link selection information for all IPv6 multicast flow policies on the public network.
<Sysname> display ipv6 multicast flow-policy info
Total 2 interfaces, 2 matched
  Vlan-interface100:
    Available bandwidth: 100M
    Used bandwidth: 30M (30%)
    Total 4 entries, 4 matched
    Flow bandwidth: 5M
      Total 2 entries, 2 matched
        (100::1, ff03::101)
        Flow policy: video1
        (100::1, ff03::102)
        Flow policy: audio2
    Flow bandwidth: 10M
       (100::1, ff03::111)
         Flow policy: audio1
       (100::1, ff03::112)
         Default flow policy
  Vlan-interface200:
    Used bandwidth: 10M (10%)
    Flow bandwidth: 10M
      (100::1, ff03::103)
        Flow policy: video3
Total number of interfaces enabled with IPv6 PIM and number of matching interfaces.
Available bandwidth
Total available multicast bandwidth on the interface.
Used bandwidth
Used multicast bandwidth in percentage on the interface.
Total number of (S, G) entries that have selected the interface as an upstream interface and number of matching  (S, G) entries.
Flow bandwidth
Estimated bandwidth configured in an IPv6 multicast flow policy.
Total number of (S, G) entries for the IPv6 multicast flow policy and number of matching (S, G) entries.
(100::1, ff03::101)
(S, G) entry for the IPv6 multicast flow.
Flow policy
Name of the custom IPv6 multicast flow policy.
Default flow policy
Name of the default IPv6 multicast flow policy.
ipv6 flow-ucmp unicast reserved-bandwidth
display ipv6 multicast forwarding df-info
Use display ipv6 multicast forwarding df-info to display DF information.
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding df-info [ ipv6-rp-address ] [ verbose ] [ slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about DFs on the public network.
ipv6-rp-address: Specifies an IPv6 BIDIR-PIM RP by its IPv6 address.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information about DFs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays DF information for the master device.
In an IPv6 BIDIR-PIM domain, only the DF on each subnet can forward IPv6 multicast data destined for an IPv6 multicast group toward the RP of the group. For more information about DFs, PIM configuration in see IP Multicast Configuration Guide.
# Display brief information about DFs on the public network.
<Sysname> display ipv6 multicast forwarding df-info
Total 1 RPs, 1 matched
00001. RP address: 7:11::1
     Flags: 0x0
     Uptime: 01:46:40
     RPF interface: Vlan-interface1
     List of 1 DF interfaces:
       1: Vlan-interface2
# Display detailed information about DFs on the public network.
<Sysname> display ipv6 multicast forwarding df-info verbose
     MID: 2, Flags: 0x0
     Uptime: 00:03:53
       Product information: 0x7a2f762f, 0x718fee9f, 0x4b82f137, 0x71c32184
       Product information: 0xa567d6fc, 0xadeb03e3
       Tunnel  information: 0xdfb107d4, 0x7aa5d510
       1: Vlan-interface2
          Product information: 0xa986152b, 0xb74a9a2f
          Tunnel  information: 0x297ca208, 0x76985b89
Table 5 Command output
Total number of RPs, and the total number of matching RPs.
00001
Sequence number of the entry to which the RP is designated.
RP address
IPv6 address of the RP.
MID
ID of the entry to which the RP is designated. Each entry to which the RP is designated has a unique MID.
Flags
Entry flag.
This field displays one flag or the sum of multiple flags. In this example, the value 0x0 means that the entry has only one flag 0x0.
·     0x0—The entry is in correct state.
·     0x4—The entry fails to update.
·     0x8—DF interface information fails to update for the entry.
·     0x40—The entry is to be deleted.
·     0x100—The entry is being deleted.
·     0x200—The entry is in GR state.
Uptime
Length of time for which the entry has been up.
RPF interface
RPF interface to the RP.
DF interface list.
display ipv6 multicast forwarding event
Use display ipv6 multicast forwarding event to display statistics of IPv6 multicast forwarding events.
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding event [ slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays statistics of IPv6 multicast forwarding events on the public network.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays statistics of IPv6 multicast forwarding events for the master device.
# Display statistics of IPv6 multicast forwarding events on the public network.
<Sysname> display ipv6 multicast forwarding event
Total active events sent: 0
Total inactive events sent: 0
Total NoCache events sent: 2
Total NoCache events dropped: 0
Total WrongIF events sent: 0
Total WrongIF events dropped: 0
Total SPT switch events sent: 0
NoCache rate limit: 1024 packets/s
WrongIF rate limit: 1 packets/10s
Total timer of register suppress timeout: 0
Table 6 Command output
Number of times that entry-active events have been sent.
Number of times that entry-inactive events have been sent.
Number of times that NoCache events have been sent.
Number of times that NoCache events have been dropped.
Number of times that WrongIF events have been sent.
Number of times that WrongIF events have been dropped.
Number of times that SPT-switch events have been sent.
NoCache rate limit
Rate limit for sending NoCache events, in pps.
WrongIF rate limit
Rate limit for sending WrongIF events, in packets per 10 seconds.
Number of times that the registration suppression has timed out in total.
reset ipv6 multicast forwarding event
display ipv6 multicast forwarding-table
Use display ipv6 multicast forwarding-table to display IPv6 multicast forwarding entries.
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | slot slot-number | statistics ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 multicast forwarding entries on the public network.
prefix-length: Specifies an address prefix length. The default value is 128. For an IPv6 multicast group address, the value range for this argument is 8 to 128. For an IPv6 multicast source address, the value range for this argument is 0 to 128.
incoming-interface: Specifies the IPv6 forwarding entries that contain the specified incoming interface.
outgoing-interface: Specifies the IPv6 forwarding entries that contain the specified outgoing interface.
exclude: Specifies the IPv6 forwarding entries that do not contain the specified interface in the outgoing interface list.
include: Specifies the IPv6 forwarding entries that contain the specified interface in the outgoing interface list.
match: Specifies the IPv6 forwarding entries that contain only the specified interface in the outgoing interface list.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 multicast forwarding entries for the master device.
statistics: Displays statistics for the IPv6 multicast forwarding table.
# Display IPv6 multicast forwarding entries on the public network.
<Sysname> display ipv6 multicast forwarding-table
00001. (1::1, ff0e::1)
     Flags: 0x0
     Incoming interface: Vlan-interface10
          Incoming sub-VLAN: VLAN 11
          Outgoing sub-VLAN: VLAN 12
                             VLAN 13
     Backup incoming interface: Vlan-interface11
     List of 1 outgoing interface:
       1: Vlan-interface20
          Sub-VLAN: VLAN 21
                    VLAN 22
     Matched 19648 packets(20512512 bytes), Wrong If 0 packet
Table 7 Command output
00001
Sequence number of the (S, G) entry.
(1::1, ff0e::1)
(S, G) entry.
Flags
Entry flag.
·     0x1—The entry is in inactive state.
·     0x2—The entry is null.
·     0x8—The outgoing interface information fails to update for the entry.
·     0x20—A register outgoing interface is available.
·     0x80—The entry is in registration suppression state.
·     0x400—The entry has the VLAN interface of the super VLAN.
·     0x800—The entry has the associated ND entry for the IPv6 multicast source address.
·     0x4000000—The entry is created by the MLD proxy.
·     0x20000000—The entry is an IPv6 BIDIR-PIM forwarding entry.
Uptime
Length of time for which the (S, G) entry has been up.
Timeout in
Length of time in which the (S, G) entry will time out.
Incoming interface
Incoming sub-VLAN
Incoming sub-VLAN of the super VLAN when the incoming interface of the (S, G) entry is the VLAN interface of this super VLAN.
Backup incoming interface of the (S, G) entry. If the primary incoming interface of the (S, G) entry fails, IPv6 multicast data arrived at the backup incoming interface will be forwarded to receivers.
Outgoing sub-VLAN
Outgoing sub-VLAN of the super VLAN when the incoming interface of the (S, G) entry is the VLAN interface of this super VLAN.
Outgoing interface list of the (S, G) entry. An outgoing interface marked with (inactive) indicates that the interface does not participate in multicast forwarding.
Sub-VLAN
Outgoing sub-VLAN of the super VLAN when the outgoing interface of the (S, G) entry is the VLAN interface of this super VLAN.
Matched 19648 packets (20512512 bytes), Wrong If 0 packet
Number of packets (bytes) that match the (S, G) entry, and number of packets with incoming interface errors.
The numbers are displayed as 0 if an outgoing interface of the (S, G) entry is on the specified slot.
Forwarded 19648 packets (20512512 bytes)
Number of packets (bytes) that have been forwarded.
reset ipv6 multicast forwarding-table
display ipv6 multicast forwarding-table df-list
Use display ipv6 multicast forwarding-table df-list to display information about the DF list in IPv6 multicast forwarding entries.
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table df-list [ ipv6-group-address ] [ verbose ] [ slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about the DF list in IPv6 multicast forwarding entries on the public network.
ipv6-group-address: Specifies an IPv6 multicast address. The value range for this argument is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about the DF list in IPv6 multicast forwarding entries for the master device.
# Display brief information about the DF list in IPv6 multicast forwarding entries on the public network.
<Sysname> display ipv6 multicast forwarding-table df-list
00001. (::, FF1E::1)
       1: Vlan-interface1
# Display detailed information about the DF list in IPv6 multicast forwarding entries on the public network.
<Sysname> display ipv6 multicast forwarding-table df-list verbose
         1: Vlan-interface1
            Product information: 0x347849f6, 0x14bd6837
            Tunnel  information: 0xc4857986, 0x128a9c8f
Table 8 Command output
Total number of entries, and the total number of matching entries.
00001
Sequence number of the entry.
(::, FF1E::1)
(*, G) entry.
DF interface list.
display ipv6 multicast routing-table
Use display ipv6 multicast routing-table to display IPv6 multicast routing entries.
display ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 multicast routing entries on the public network.
prefix-length: Specifies an address prefix length. The default is 128. For an IPv6 multicast group address, the value range for this argument is 8 to 128. For an IPv6 multicast source address, the value range for this argument is 0 to 128.
incoming-interface: Displays the IPv6 routing entries that contain the specified incoming interface.
outgoing-interface: Displays the IPv6 routing entries that contain the specified outgoing interface.
exclude: Displays the IPv6 routing entries that do not contain the specified interface in the outgoing interface list.
include: Displays the IPv6 routing entries that contain the specified interface in the outgoing interface list.
match: Displays the IPv6 routing entries that contain only the specified interface in the outgoing interface list.
IPv6 multicast routing entries are the basis of IPv6 multicast forwarding. You can use this command to view the establishment state of (S, G) entries.
# Display IPv6 multicast routing entries on the public network.
<Sysname> display ipv6 multicast routing-table
 Total 1 entries
 00001. (2001::2, FFE3::101)
       Uptime: 00:00:14
       Upstream Interface: Vlan-interface1
       Backup Upstream Interface: Vlan-interface4
       List of 2 downstream interfaces
           1:  Vlan-interface2
           2:  Vlan-interface3
Table 9 Command output
Total 1 entries
Total number of (S, G) entries.
00001
(S, G) entry.
Uptime
Upstream Interface
Upstream interface at which the (S, G) packets should arrive.
Backup upstream interface of the (S, G) entry. If the primary upstream interface of the (S, G) entry fails, multicast data arrived at the backup upstream interface will be forwarded to receivers.
List of downstream interfaces that forward (S, G) packets. A downstream interface marked with (inactive) indicates that the interface does not participate in multicast forwarding.
reset ipv6 multicast routing-table
display ipv6 multicast routing-table static
Use display ipv6 multicast routing-table static to display static IPv6 multicast routing entries.
display ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table static [ ipv6-source-address [ prefix-length ] ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays static IPv6 multicast routing entries on the public network.
prefix-length: Specifies the address prefix length in the range of 0 to 128. The default is 128.
This command displays only valid static IPv6 multicast routing entries.
# Display static IPv6 multicast routing entries on the public network.
<Sysname> display ipv6 multicast routing-table static
Destinations: 2        Routes: 4
Destination/Prefix: 2::100/128
  Pre: 10
  RPF neighbor                             Interface
  100::2                                   Vlan11
  125:0:3::3                               Vlan12
 Destination/Prefix: 3::100/128
  Pre: 20
  100::3                                   Vlan13
  125:0:3::4                               Vlan14
Table 10 Command output
Destinations
Number of IPv6 multicast destination addresses.
Routes
Number of routes.
Destination/Mask
Destination address and its prefix length.
Pre
Route preference.
RPF neighbor
IPv6 address of the RPF neighbor to the reachable destination.
Outgoing interface to the reachable destination.
display ipv6 multicast rpf-info
Use display ipv6 multicast rpf-info to display RPF information for an IPv6 multicast source.
display ipv6 multicast [ vpn-instance vpn-instance-name ] rpf-info ipv6-source-address [ ipv6-group-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays RPF information for an IPv6 multicast source on the public network.
ipv6-group-address: Specifies an IPv6 multicast group address in the range of FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F.
# Display RPF information for IPv6 multicast source 2001::101 on the public network.
<Sysname> display ipv6 multicast rpf-info 2001::101
 RPF information about source 2001::101:
     RPF interface: Vlan-interface1, RPF neighbor: FE80::A01:101:1
     Backup RPF interface: Vlan-interface2, backup RPF neighbor: FE80::A01:101:2
     Referenced prefix/prefix length: 2001::/64
     Referenced route type: igp
     Load splitting rule: disable
     Source AS: 0
     C-multicast route target: 0x0000000000000000
Table 11 Command output
RPF information of the IPv6 multicast source 2001::101.
RPF interface
Type and number of the RPF interface.
RPF neighbor
IPv6 address (link-local address) of the RPF neighbor.
Referenced route and its prefix length.
Type of the referenced route:
·     igp—IPv6 IGP unicast route.
·     egp—IPv6 EGP unicast route.
·     unicast (direct) —IPv6 directly connected unicast route.
·     unicast—Other IPv6 unicast route, such as IPv6 unicast static route.
·     mbgp—IPv6 MBGP route.
RPF route selection rule:
·     Route preference.
·     Longest prefix match.
Load splitting rule
Whether load splitting is enabled.
Source AS
AS number of the source-side PE.
Route target attribute value of the C-multicast route.
Use flow-policy to create an IPv6 multicast flow policy and enter its view, or enter the view of an existing IPv6 multicast flow policy.
Use undo flow-policy to delete IPv6 multicast flow policies.
flow-policy { default | name policy-name }
undo flow-policy { all | default | name policy-name }
No IPv6 multicast flow policies exist.
IPv6 MRIB view
all: Deletes all IPv6 multicast flow policies.
Operating mechanism
The device selects the link with the smallest bandwidth usage as the optimal link if the following conditions exist:
·     ECMP routes between the device and an upstream device.
·     The multicast load-splitting mode is flow-ucmp.
If two links have the same bandwidth usage, the link with the higher next-hop IPv6 address is selected.
The bandwidth usage is calculated according to the following formula: Bandwidth usage = (Used bandwidth+Estimated bandwidth)/(Total interface bandwidth x (1–Unicast reserved bandwidth)).
·     The estimated bandwidth is configured by the bandwidth command in IPv6 multicast flow policy view.
·     The total interface bandwidth is configured by the bandwidth command in interface view.
·     The unicast reserved bandwidth is configured by the flow-ucmp unicast reserve-bandwidth or ipv6 multicast flow-ucmp unicast reserve-bandwidth command.
For this command to take effect, you must configure the multicast load-splitting mode as flow-ucmp.
Adding, deleting, or modifying an IPv6 multicast flow policy does not affect the link selection results of existing multicast flows and affects link selection for only new multicast flows. Before configuring the multicast load-splitting mode as flow-ucmp, you must plan the configuration of an IPv6 multicast flow policy and the unicast reserved bandwidth configuration.
The change of link bandwidth and the change in the number of ECMP routes do not affect the route selection of existing multicast flows.
This feature does not affect multicast source-side link selection, link selection in IPv6 PIM-DM, RPT link selection in IPv6 PIM-SM, or local RP link selection.
If both IPv4 and IPv6 multicast flows exist in the network, increase the unicast reserved bandwidth as needed to avoid congestion.
# Create an IPv6 multicast flow policy named abc and enter its view.
# Create the default IPv6 multicast flow policy and enter its view.
[Sysname-mrib6] flow-policy default
acl (IPv6 multicast flow policy)
bandwidth
flow-ucmp unicast reserve-bandwidth (IPv6 MRIB view)
Use flow-ucmp unicast reserve-bandwidth to set the global IPv6 unicast reserved bandwidth percentage.
Use undo flow-ucmp unicast reserve-bandwidth to restore the default.
flow-ucmp unicast reserve-bandwidth percentage
The global IPv6 unicast reserved bandwidth percentage is not set.
IPv6 MRIB view
percentage: Specifies the global IPv6 unicast reserved bandwidth percentage in the range of 1 to 100.
Execute this command when IPv6 unicast traffic and IPv6 multicast traffic coexist in the network. The available bandwidth for multicast traffic is calculated based on the total interface bandwidth and the configured IPv6 unicast reserved bandwidth percentage. For example, if the total interface bandwidth is 100 kbps and the IPv6 unicast reserved bandwidth percentage is 20% (20 kbps), the available bandwidth for multicast traffic is 80 kbps.
The flow-ucmp unicast reserve-bandwidth command takes effect on all interfaces, and the ipv6 multicast flow-ucmp unicast reserve-bandwidth command takes effect only on the current interface. If you execute both commands, the latter has higher priority.
Example
# Set the global IPv6 unicast reserved bandwidth percentage to 50%.
[Sysname-mrib6] flow-ucmp unicast reserve-bandwidth 50
Use ipv6 multicast boundary to configure an IPv6 multicast forwarding boundary.
Use undo ipv6 multicast boundary to delete an IPv6 multicast forwarding boundary.
ipv6 multicast boundary { ipv6-group-address prefix-length | scope { scope-id | admin-local | global | organization-local | site-local } }
undo ipv6 multicast boundary { ipv6-group-address prefix-length| all | scope { scope-id | admin-local | global | organization-local | site-local } }
An interface is not an IPv6 multicast forwarding boundary.
Interface view
prefix-length: Specifies the address prefix length in the range of 8 to 128.
all: Specifies all IPv6 multicast boundaries configured on the interface.
scope-id: Specifies the ID of an admin-scoped zone, in the range of 3 to 15, which is identified by the scope field in the IPv6 multicast group address.
admin-local: Specifies the scoped zone as admin-local, which has a scope ID of 4.
global: Specifies the scoped zone as global, which has a scope ID of 14.
organization-local: Specifies the scoped zone as organization-local, which has a scope ID of 8.
site-local: Specifies the scoped zone as site-local, which has a scope ID of 5.
A multicast forwarding boundary sets the boundary condition for the IPv6 multicast groups in the specified address range. If the destination address of an IPv6 multicast packet matches the set boundary condition, the packet is not forwarded.
An interface can act as a forwarding boundary for multiple IPv6 multicast groups in different address ranges. You can implement this by using this command on the interface for each multicast address range. These multicast groups must be in the same scope. The latest configuration of a scope overwrites the previous one.
You do not need to enable IPv6 multicast routing before you execute this command.
Assume that Set A and Set B are both IPv6 multicast forwarding boundary sets with different address ranges, and that B is a subset of A. A takes effect on the interface no matter whether A is configured earlier or later than B.
# Configure VLAN-interface 100 as the forwarding boundary of IPv6 multicast groups in the range of FF03::/16.
[Sysname-Vlan-interface100] ipv6 multicast boundary ff03:: 16
# Configure VLAN-interface 100 as the forwarding boundary of IPv6 multicast groups in the admin-local scope.
[Sysname-Vlan-interface100] ipv6 multicast boundary scope 4
ipv6 multicast cpu-forwarding max-copy-count
Use ipv6 multicast cpu-forwarding max-copy-count to set the maximum number of copied IPv6 multicast packets during software forwarding.
Use undo ipv6 multicast cpu-forwarding max-copy-count to restore the default.
ipv6 multicast cpu-forwarding max-copy-count count
The maximum number of copied IPv6 multicast packets during software forwarding is 16.
count: Specifies the maximum number of copied IPv6 multicast packets during software forwarding. The value range for this argument is 1 to 32.
Setting a greater limit will cause high CPU usage and degrade forwarding performance. Setting a small limit will cause IPv6 multicast packets to be dropped.
CAUTION
CAUTION:
Perform this task under the guidance of H3C Support.
# Set the maximum number to 3 for copied IPv6 multicast packets during software forwarding.
[Sysname] ipv6 multicast cpu-forwarding max-copy-count 3
Use ipv6 multicast flow-ucmp unicast reserve-bandwidth to set the IPv6 unicast reserved bandwidth percentage on an interface.
Use undo ipv6 multicast flow-ucmp unicast reserve-bandwidth to restore the default.
ipv6 multicast flow-ucmp unicast reserve-bandwidth percentage
The IPv6 unicast reserved bandwidth percentage is not set on an interface.
Interface view
percentage: Specifies the IPv6 unicast reserved bandwidth percentage in the range of 1 to 100.
For this command to take effect, you must use the load-splitting command to configure the multicast load-splitting mode.
Example
# Set the IPv6 unicast reserved bandwidth percentage to 50% on VLAN interface 100.
[Sysname-Vlan-interface100] ipv6 multicast flow-ucmp unicast reserve-bandwidth 50
ipv6 flow-ucmp unicast reserve-bandwidth
ipv6 multicast forwarding supervlan community
Use ipv6 multicast forwarding supervlan community to enable IPv6 multicast forwarding between sub-VLANs that are associated with a super VLAN.
Use undo ipv6 multicast forwarding supervlan community to disable IPv6 multicast forwarding between sub-VLANs that are associated with a super VLAN.
IPv6 multicast forwarding between sub-VLANs that are associated with a super VLAN is disabled.
VLAN interface view
For this command to take effect, you must clear all IPv6 multicast forwarding entries with the super VLAN interface as the incoming interface after executing this command. To clear IPv6 multicast forwarding entries, use the reset ipv6 multicast forwarding-table command.
# Enable IPv6 multicast forwarding between sub-VLANs that are associated with the super VLAN 2.
[Sysname-Vlan-interface2] ipv6 multicast forwarding supervlan community
ipv6 multicast forwarding-table cache-unknown per-entry
Use ipv6 multicast forwarding-table cache-unknown per-entry to set the maximum number of unknown IPv6 multicast packets that can be cached for an (S, G) entry.
Use undo ipv6 multicast forwarding-table cache-unknown per-entry to restore the default.
ipv6 multicast forwarding-table cache-unknown per-entry per-entry-limit
The device can cache only one unknown IPv6 multicast packet for an (S, G) entry.
per-entry-limit: Specifies the maximum number of unknown IPv6 multicast packets that can be cached for an (S, G) entry. The value range for this argument is 0 to 256. If you set the value to 0, the device cannot cache unknown IPv6 multicast packets.
# Set the maximum number to 20 for unknown IPv6 multicast packets that can be cached for an (S, G) entry.
[Sysname] ipv6 multicast forwarding-table cache-unknown per-entry 20
ipv6 multicast forwarding-table cache-unknown total
Use ipv6 multicast forwarding-table cache-unknown total to set the maximum number of all unknown IPv6 multicast packets that can be cached.
Use undo multicast forwarding-table cache-unknown total to restore the default.
ipv6 multicast forwarding-table cache-unknown total total-limit
undo ipv6 multicast forwarding-table cache-unknown total
The device can cache 1024 unknown IPv6 multicast packets in total.
total-limit: Specifies the maximum number of all unknown IPv6 multicast packets that can be cached. The value range for this argument is 0 to 65535. If you set the value to 0, the device cannot cache unknown IPv6 multicast packets.
As a best practice, set the value in this command to be far greater than the value set in the ipv6 multicast forwarding-table cache-unknown per-entry command.
# Set the maximum number to 10000 for all unknown IPv6 multicast packets that can be cached.
[Sysname] ipv6 multicast forwarding-table cache-unknown total 10000
Use ipv6 multicast routing to enable IPv6 multicast routing and enter IPv6 MRIB view.
Use undo ipv6 multicast routing to disable IPv6 multicast routing.
ipv6 multicast routing [ vpn-instance vpn-instance-name ]
undo ipv6 multicast routing [ vpn-instance vpn-instance-name ]
IPv6 multicast routing is disabled.
parameters
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command enables IPv6 multicast routing on the public network.
Other Layer 3 IPv6 multicast commands take effect only when IPv6 multicast routing is enabled on the public network or for the VPN instance to which the device belongs.
The device does not forward any IPv6 multicast packets before IPv6 multicast routing is enabled.
# Enable IPv6 multicast routing on the public network, and enter IPv6 MRIB view.
[Sysname-mrib6]
# Enable IPv6 multicast routing for VPN instance mvpn, and enter IPv6 MRIB view.
[Sysname] ipv6 multicast routing vpn-instance mvpn
[Sysname-mrib6-mvpn]
Use ipv6 rpf-route-static to configure a static IPv6 multicast route.
Use undo ipv6 rpf-route-static to delete a static IPv6 multicast route.
ipv6 rpf-route-static [ vpn-instance vpn-instance-name ] ipv6-source-address prefix-length { ipv6-rpf-nbr-address | interface-type interface-number } [ preference preference ]
undo ipv6 rpf-route-static [ vpn-instance vpn-instance-name ] ipv6-source-address prefix-length { ipv6-rpf-nbr-address | interface-type interface-number }
No static IPv6 multicast routes exist.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command configures a static IPv6 multicast route on the public network.
ipv6-rpf-nbr-address: Specifies an RPF neighbor by its IPv6 address.
interface-type interface-number: Specifies an interface by its type and number. The interface connects the RPF neighbor.
preference: Sets a route preference in the range of 1 to 255. The default is 1.
If the interface connected to an RPF neighbor is a point-to-point interface, you must specify the interface by its type and number.
If the interface connected to an RPF neighbor is not a point-to-point interface, you must specify the interface by its IP address. This type of interfaces includes Layer 3 Ethernet, Layer 3 aggregate, loopback, and VLAN interfaces.
The configured static IPv6 multicast route might not take effect when one of the following conditions exists:
·     The outgoing interface iteration fails.
·     The specified interface is not in the public network or the same VPN instance as the current interface.
·     The specified interface is not a point-to-point interface.
·     The specified interface is down.
If multiple static IPv6 multicast routes within the same IPv6 multicast source address range are available, only the one with the highest route preference can become active. You can use the display ipv6 multicast routing-table static command to verify that the configured static IPv6 multicast route has taken effect.
The undo ipv6 rpf-route-static command deletes the specified static IPv6 multicast route. To delete all static IPv6 multicast routes, use the delete ipv6 rpf-route-static command.
# Configure a static IPv6 multicast route to IPv6 multicast source 101::0/64 and specify the interface with IP address 106::7 as the RPF neighbor on the public network.
[Sysname] ipv6 rpf-route-static 101::0 64 106::7
load-splitting (IPv6 MRIB view)
Use load-splitting to enable IPv6 multicast load splitting.
Use undo load-splitting to restore the default.
load-splitting { balance-ecmp | balance-ucmp | ecmp | flow-ucmp |source | source-group | ucmp }
undo load-splitting
IPv6 multicast load splitting is disabled.
IPv6 MRIB view
balance-ecmp: Enables IPv6 multicast load balancing based on ECMP paths. Multicast traffic is evenly distributed among ECMP paths.
balance-ucmp: Enables IPv6 multicast load balancing based on links. Multicast traffic is evenly distributed among links.
ecmp: Enables IPv6 multicast load splitting based on ECMP paths.
flow-ucmp: Enables IPv6 multicast load splitting based on the bandwidth usage of multicast flows.
source: Enables IPv6 multicast load splitting based on IPv6 multicast source.
source-group: Enables IPv6 multicast load splitting based on IPv6 multicast source and group.
ucmp: Enables IPv6 multicast load splitting based on links.
This command does not take effect on IPv6 BIDIR-PIM.
To use the flow-ucmp multicast load-splitting mode, you must first configure an IPv6 multicast flow policy and the IPv6 unicast reserved bandwidth percentage. Adding, deleting, or modifying an IPv6 multicast flow policy does not affect the link selection results of existing IPv6 multicast flows and affects link selection for only new IPv6 multicast flows.
On a network with ECMP routes, specify the balance-ecmp, ecmp, flow-ucmp, source, or source-group keyword. On a network with UCMP routes, specify the balance-ucmp or ucmp keyword.
·     If you specify the ecmp keyword, adding or deleting ECMP routes severely affects IPv6 multicast forwarding.
·     If you specify the source or source-group keyword, adding or deleting ECMP routes slightly affects IPv6 multicast forwarding. Specify either of the keywords on a network with unstable equal cost links.
·     If you specify the balance-ecmp or balance-ucmp keyword, the device uses a polling mechanism for IPv6 multicast load balancing. ECMP or UCMP-based IPv6 multicast load balancing provides better stability and balance than ECMP or UCMP-based IPv6 multicast load sharing.
·     If you specify the flow-ucmp keyword, adding or deleting ECMP routes slightly affects IPv6 multicast forwarding. Specify this keyword on a network with unstable equal-cost links. It provides better stability and balance than the ucmp multicast load-sharing mode.
# Enable IPv6 multicast load splitting based on IPv6 multicast source on the public network.
[Sysname-mrib6] load-splitting source
longest-match (IPv6 MRIB view)
Use longest-match to specify the longest prefix match principle for RPF route selection.
Use undo longest-match to restore the default.
longest-match
undo longest-match
Route preference is used for RPF route selection. The route with the highest route preference is used as the RPF route.
IPv6 MRIB view
This command enables the device to use the matching route with the longest prefix as the RPF route.
# Specify the longest prefix match principle for RPF route selection on the public network.
[Sysname-mrib6] longest-match
Use reset ipv6 multicast fast-forwarding cache to clear IPv6 multicast fast forwarding entries.
reset ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache { { ipv6-source-address | ipv6-group-address } * | all } [ slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears IPv6 multicast fast forwarding entries on the public network.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears IPv6 multicast fast forwarding entries for the master device.
all: Specifies all IPv6 multicast fast forwarding entries.
# Clear all IPv6 multicast fast forwarding entries on the public network.
<Sysname> reset ipv6 multicast fast-forwarding cache all
# Clear the IPv6 multicast fast forwarding entry for IPv6 multicast source and group (FE1F:20::2, FF0E::1) on the public network.
<Sysname> reset ipv6 multicast fast-forwarding cache fe1f:20::2 ff0e::1
Use reset ipv6 multicast forwarding event to clear statistics for IPv6 multicast forwarding events.
reset ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding event
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears statistics for the IPv6 multicast forwarding events on the public network.
# Clear statistics for the IPv6 multicast forwarding events on the public network.
<Sysname> reset ipv6 multicast forwarding event
Use reset ipv6 multicast forwarding-table to clear IPv6 multicast forwarding entries.
reset ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface { interface-type interface-number } } * | all }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears IPv6 multicast forwarding entries on the public network.
prefix-length: Specifies the address prefix length. The default value is 128. For an IPv6 multicast group address, the value range for this argument is 8 to 128. For an IPv6 multicast source address, the value range for this argument is 0 to 128.
incoming-interface: Specifies the IPv6 multicast forwarding entries that contain the specified incoming interface.
all: Specifies all IPv6 multicast forwarding entries.
When you clear an IPv6 multicast forwarding entry, the associated IPv6 multicast routing entry is also cleared.
# Clear IPv6 multicast forwarding entries for IPv6 multicast group FF0E::1 on the public network.
<Sysname> reset ipv6 multicast forwarding-table ff0e::1
Use reset ipv6 multicast routing-table to clear IPv6 multicast routing entries.
reset ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number } * | all }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears IPv6 multicast routing entries on the public network.
incoming-interface: Specifies the IPv6 multicast routing entries that contain the specified incoming interface.
all: Specifies all IPv6 multicast routing entries.
When you clear an IPv6 multicast routing entry, the associated IPv6 multicast forwarding entry is also cleared.
# Clear IPv6 multicast routing entries for IPv6 multicast group FF03::101 on the public network.
<Sysname> reset ipv6 multicast routing-table ff03::101
