- 12-High Availability Configuration Guide
- 01-Ethernet OAM configuration
- 02-CFD configuration
- 03-DLDP configuration
- 04-RRPP configuration
- 05-ERPS configuration
- 06-Smart Link configuration
- 07-Monitor Link configuration
- 08-VRRP configuration
- 09-BFD configuration
- 10-Track configuration
- 11-Process placement configuration
00-Preface | 109.93 KB |
Preface
This configuration guide describes the high availability fundamentals and configuration procedures. The high availability technologies include fault detection and fault failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S5570S-EI and S5500V3-SI switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
