10-High Availability Configuration Guide
HomeSupportSwitchesS5136 SeriesS5136S-EI SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C S5136S-EI Switch Series Configuration Guides-6W10010-High Availability Configuration Guide
09-BFD configuration
09-BFD configuration 353.58 KB
Configuring BFD
About BFD
Bidirectional forwarding detection (BFD) provides a general-purpose, standard, medium- and protocol-independent fast failure detection mechanism. It can detect and monitor the connectivity of forwarding paths to detect communication failures quickly so that measures can be taken to ensure service continuity and enhance network availability.
BFD can uniformly and quickly detect the failures of the bidirectional forwarding paths between two devices for upper-layer protocols such as routing protocols. The hello mechanism used by upper-layer protocols needs seconds to detect a link failure, while BFD can provide detection measured in milliseconds.
Mechanism
BFD establishes a session between two network devices to detect failures on the bidirectional forwarding paths between the devices and provide services for upper-layer protocols. BFD provides no neighbor discovery mechanism. Protocols that BFD services notify BFD of devices to which it needs to establish sessions. After a session is established, if no BFD control packet is received from the peer within the negotiated BFD interval, BFD notifies a failure to the protocol, which then takes appropriate measures.
Figure 1 describes the operation of BFD for OSPF.
1.     OSPF discovers neighbors by sending Hello packets and establishes neighbor relationships.
2.     After establishing neighbor relationships, OSPF notifies BFD of the neighbor information, including destination and source addresses.
3.     BFD uses the information to establish BFD sessions.
4.     After session establishment, BFD starts periodic link detection.
Figure 1 BFD session establishment
Figure 2 describes the BFD fault detection process.
1.     The detected link fails.
2.     BFD detects the link failure and tears down the session.
3.     BFD notifies the neighbor unreachability to OSPF.
4.     OSPF terminates the neighbor relationship on the link.
Figure 2 BFD fault detection
BFD establishes sessions in echo packet mode or control packet mode depending on the BFD packets used.
Single-hop detection and multihop detection
BFD can be used for single-hop and multihop detections.
·     Single-hop detection—Detects the IP connectivity between two directly connected systems, for example, Device A and Device B as shown in Figure 3.
Figure 3 Single-hop detection
·     Multihop detection—Detects any of the paths between two systems, for example, Device A and Device B as shown in Figure 4. These paths have multiple hops, and might overlap.
Figure 4 Multihop detection
BFD session states
A BFD session can be in DOWN, ADMIN DOWN, INIT or UP state. The meanings of the states are as follows:
·     DOWN—The local BFD session has been shut down or is newly created. This state indicates that the forwarding path is unavailable and that the upper-layer application must take an appropriate action, such as primary/backup path switchover.
·     ADMIN DOWN—The BFD session of the local system is administratively shut down. This state does not indicate that the forwarding path is unavailable. The upper-layer application is not required to take an action.
·     INIT—The local end can communicate with the remote end and requires the BFD session to transition to UP state.
·     UP—The BFD session has been established on the local end. This state indicates that the forwarding path is available.
BFD session modes
BFD sessions use echo packets and control packets.
Echo packet mode
Echo packets are encapsulated into UDP packets. The packet contains destination port 3785, a destination IP address (transmitting interface's IP address), and a source IP address (transmitting interface's IP address).
The local end of the link sends echo packets to establish BFD sessions and monitor link status. The peer end does not establish BFD sessions and only forwards the packets back to the originating end. If the local end does not receive echo packets from the peer end within the detection time, it considers the session down.
BFD sessions in echo packet mode do not require both ends to support BFD. Upon receiving BFD echo packets, the peer end loops back the packets for detection purposes.
Control packet mode
Control packets are encapsulated into UDP packets with port number 3784 for single-hop detection or port number 4784 for multihop detection.
The two ends of the link negotiate the establishment of BFD sessions by using the session parameters carried in control packets. Session parameters include session discriminators, desired minimum packet sending and receiving intervals, and local BFD session state.
State machine transition mechanism for a BFD session in control packet mode
Figure 5 shows the state machine transition mechanism for a BFD session in control packet mode. The ADMIN DOWN state in the state machine is also the DOWN state.
Figure 5 State machine transition mechanism for a BFD session
BFD control packet format
Figure 6 shows the format of a BFD control packet. The BFD control packet contains the required portion and optional authentication portion.
Figure 6 BFD control packet format
Table 1 shows the description of the fields in a BFD control packet.
Table 1 BFD control packet field description
Length
Vers (Version)
3 bits
BFD version number. The current version number is 1.
Diag (Diagnostic)
5 bits
Diagnostic code, which indicates the reason for the most recent session down of the sender. Options include:
·     0—No diagnostic information.
·     1—A control-mode BFD session goes down because local detection times out.
·     2—An echo-mode BFD session goes down, because local detection times out or the source IP address of echo packets is deleted.
·     3—The remote end notifies the local end of BFD session down upon detection timeout.
·     7—The local system prevents a BFD session from being established.
·     31—A packet in AdminDown state is received from the remote end.
Sta (State)
2 bits
BFD session state of the sender:
·     0—AdminDown.
·     1—Down.
·     2—Init.
·     3—Up.
P (Poll)
1 bit
Upon session parameter changes, the sender sends a BFD packet with the P bit set. The receiver must immediately respond this packet.
·     0—The sender does not request verification.
·     1—The sender requests verification of the connectivity or parameter changes.
F (Final)
1 bit
The F bit determines whether BFD sends a response packet upon receiving a packet with the P bit set.
·     0—The sending system does not respond to packets with the P bit set.
·     1—The sending system responds to received packets with the P bit set.
C (Control Plane Independent)
1 bit
Forwarding- and control-plane separation bit. If this bit is set, the BFD implementation is independent of its control plane. That is, changes in the control plane do not affect BFD detection. For example, when IS-IS on the control plane performs GR, BFD can continue to detect link state.
·     1—The BFD implementation on the sending system is independent of the control plane. That is, BFD packets are transmitted on the forwarding plane. BFD can still perform link detection even if the control plane becomes invalid.
·     0—Indicates that BFD packets are transmitted on the control plane.
A (Authentication Present)
1 bit
If this bit is set, the control packet contains the authentication field and the session requires authentication.
D (Demand)
1 bit
If this bit is set, the sender wants to operate in Demand mode. If this bit is not set, the sender does not want to operate in Demand mode or does not support the Demand mode.
M (Multipoint)
1 bit
Reserved bit. It is set to 0 during transmission and ignored during reception.
Detect Mult
8 bits
Detect time multiplier used by the detecting party to calculate the detection interval.
Length
8 bits
BFD control packet length, in bytes.
My Discriminator
32 bits
Local discriminator of the BFD session. It is a unique, non-zero value generated by the sender to identify a BFD session.
Your Discriminator
32 bits
Remote discriminator of the BFD session. If a BFD control packet is received from the session-associated neighbor, the value is My Discriminator in the received packet. If no BFD control packet is received from the neighbor, this value is 0.
Desired Min TX Interval
32 bits
Minimum interval for sending BFD control packets desired by the local system, in microseconds.
Required Min RX Interval
32 bits
Minimum interval for receiving BFD control packets supported by the local system, in milliseconds.
Required Min Echo RX Interval
32 bits
Minimum interval for receiving BFD echo packets supported by the local system, in milliseconds. Value 0 indicates that the echo function is not supported.
Auth Type
8 bits
Authentication type.
Auth Len
8 bits
Authentication field length in bytes, including Auth Type field and Auth Len fields.
Authentication Data
Variable
Authentication data field.
Establishing a BFD session in control packet mode
BFD can use the following operating modes to establish a session:
·     Active mode—BFD actively sends BFD control packets regardless of whether any BFD control packet is received from the peer.
·     Passive mode—BFD does not send control packets until a BFD control packet is received from the peer.
At least one end must operate in active mode for a BFD session to be established.
BFD uses a three-way handshake mechanism to establish sessions. The sender fills the Sta field with the current session state in the transmitted BFD control packets. The receiver transits the state machine states based on the Sta field value in the received BFD control packets and local session status to establish a session.
Figure 7 BFD session establishment process
Detection mechanism of the BFD session in control packet mode
After a BFD session in control packet mode is established, the two ends can operate in the following modes:
·     Asynchronous mode—The device periodically sends BFD control packets. The device considers that the session is down if it does not receive any BFD control packets within the detection interval. By default, a BFD session is in Asynchronous mode.
·     Demand mode—If a large number of BFD sessions exist in the system, you can specify the Demand mode to prevent periodic sending of BFD control packets from affecting system operations. As a best practice, enable the BFD echo function when the detection mode is Demand mode.
¡     If the local end operates in Demand mode, the local device periodically sends BFD control packets with the D bit set to 1. Upon receiving such packets, if the peer end operates in Asynchronous mode (default setting), it stops sending BFD control packets.
¡     If the peer end is operating in Demand mode, both ends stop sending BFD control packets. When the connectivity to another system needs to be verified explicitly, a system sends several BFD control packets with the P bit set at the negotiated transmit interval. If no packets with the F bit set to 1 are received from the peer end within the detection interval, the session is considered down. If a packet with the F bit set to 1 is received from the peer end, the connectivity is found to be up, and no more BFD control packets are sent until the next command is issued.
Echo function of a BFD session in control packet mode
When you use Asynchronous mode BFD to detect the connectivity between directly connected devices, you can enable the echo function. This function enables the local system to periodically send echo packets to the remote system and reduces the control packet receiving rate to save bandwidth usage. The remote system loops back the echo packets to the local system without processing them. If the local system does not receive echo packets looped back from the remote system in a consecutive number of times, the local system declares the BFD session down.
The echo function is supported only for single-hop detection.
BFD session creation methods
BFD sessions in control packet mode can be created statically or established dynamically.
BFD sessions are distinguished by the local discriminator and remote discriminator in control packets. The main difference between a statically created session and a dynamically established session is that they obtain the local discriminator and remote discriminator in different ways.
·     The local discriminator and remote discriminator of a static BFD session are manually configured.
·     The local discriminator of a dynamic BFD session is automatically assigned by the device, and the remote discriminator is obtained during BFD session negotiation.
BFD session flapping suppression
When BFD detects a link failure, it tears down the BFD session and notifies the upper-layer protocol of the failure. When the upper-layer protocol re-establishes a neighbor relationship, the BFD session comes up again. BFD session flaps occur when a link fails and recovers repeatedly, which consumes significant system resources and causes network instability. You can use BFD session flapping suppression to solve the previous problems.
This feature allows you to suppress BFD session flapping by setting different suppression intervals based on the BFD session down times. Within the suppression intervals, BFD sessions cannot be re-established. The more the BFD session down times, the longer the suppression time to avoid BFD flapping.
Hardware BFD
Software BFD uses the CPU to receive and send BFD packets and to maintain the BFD state machine. Software BFD greatly consumes CPU resources and cannot support a large number of BFD sessions.
Hardware BFD uses hardware chips to process CPU-intensive tasks, such as receiving and sending BFD packets and fault detection. Hardware BFD improves CPU utilization and can support a large number of BFD sessions.
The Hardware mode field in the output from the display bfd session verbose command indicates whether BFD packets are processed in hardware:
·     Enabled—BFD packets are processed in hardware.
·     Disabled—BFD packets are processed in software.
You can take the following actions to disable hardware BFD:
·     Execute commands that are not supported by hardware BFD.
·     Remove cards that support hardware BFD.
When you disable hardware BFD, the BFD session might flap. Before performing this operation, make sure you understand its potential impact on the network.
Supported features
Table 2 shows the features supported by BFD.
Table 2 Features supported by BFD
Feature
Reference
Link aggregation
Ethernet link aggregation in Layer 2—LAN Switching Configuration Guide
IPv4 static routing
Static routing in Layer 3IP Routing Configuration Guide
IPv6 static routing
IPv6 static routing in Layer 3IP Routing Configuration Guide
RIP
RIP in Layer 3IP Routing Configuration Guide
OSPF
OSPF in Layer 3IP Routing Configuration Guide
OSPFv3
OSPFv3 in Layer 3IP Routing Configuration Guide
IS-IS
IS-IS in Layer 3IP Routing Configuration Guide
BGP
BGP in Layer 3IP Routing Configuration Guide
PIM
PIM in IP Multicast Configuration Guide
IPv6 PIM
IPv6 PIM in IP Multicast Configuration Guide
Track
"Configuring Track"
Link types supported by BFD
BFD can detect connectivity for various types of links, as shown in Table 3.
Table 3 Link types supported by BFD
Link category
Link types
Ethernet aggregate link
·     Layer 2 Ethernet aggregate link
·     Member links of the Layer 2 Ethernet aggregate link
·     Layer 3 Ethernet aggregate link
·     Member links of the Layer 3 Ethernet aggregate link
You can establish BFD sessions separately for trunk member ports and the trunk port. As a best practice, do not perform that operation.
Technical benefits of BFD
BFD has the following technical benefits:
·     BFD can detect the failures of the bidirectional forwarding paths of any type (including logical links, such as tunnels) between two network devices.
·     BFD can provide services for upper-layer protocols and unified detection mechanisms.
·     BFD provides millisecond-level detection speed to accelerate network convergence, reduce application interruption time, and enhance network reliability.
Protocols and standards
·     RFC 5880, Bidirectional Forwarding Detection (BFD)
·     RFC 5881, Bidirectional Forwarding Detection (BFD) for IPv4 and IPv6 (Single Hop)
·     RFC 5882, Generic Application of Bidirectional Forwarding Detection (BFD)
·     RFC 5883, Bidirectional Forwarding Detection (BFD) for Multihop Paths
·     RFC 5885, Bidirectional Forwarding Detection (BFD) for the Pseudowire Virtual Circuit Connectivity Verification (VCCV)
·     RFC 7130, Bidirectional Forwarding Detection (BFD) on Link Aggregation Group (LAG) Interfaces
Restrictions and guidelines: BFD configuration
·     By default, the device runs BFD version 1 and is compatible with BFD version 0. You cannot change the BFD version to 0 through commands. When the peer device runs BFD version 0, the local device automatically switches to BFD version 0.
·     After a BFD session is established, the two ends negotiate BFD parameters, including minimum sending interval, minimum receiving interval, initialization mode, and packet authentication, by exchanging negotiation packets. They use the negotiated parameters without affecting the session status.
·     BFD session flapping might occur on an aggregate interface with member ports on different IRF member devices. When the master device, which receives and sends BFD packets, is removed or restarted, a subordinate device might not immediately take over. For example, a subordinate device will not take over when the subordinate device has a short detection time or a large number of BFD sessions.
BFD tasks at a glance
All the BFD tasks are optional.
1.     Configuring BFD sessions in echo packet mode
¡     Creating a static BFD session
¡     Configuring detection time settings
2.     Configuring BFD sessions in control packet mode
¡     Configuring the session establishment mode
¡     Configuring the detection mode
¡     Configuring the authentication mode
¡     Configuring the destination port number for multihop BFD control packets
¡     Configuring the notification delay timer for session establishment failures
¡     Associating the interface state with BFD
¡     Configuring the TTL value for BFD packets
3.     Configuring BFD session flapping suppression
4.     Configuring a BFD template
5.     Configuring event logging and SNMP notifications for BFD
¡     Enabling BFD event logging
¡     Enabling SNMP notifications for BFD
About BFD session creation methods
A BFD session can be created manually by using the bfd static command or created dynamically through collaboration between an application module and BFD.
To avoid echo packet loss, do not configure the echo packet mode on a device with uRPF enabled. For more information about uRPF, see Security Configuration Guide.
A static BFD session in echo packet mode can be used to perform single-hop detection or multihop detection.
You need to create a static BFD session in echo packet mode on only the local device to perform detection.
When creating a static BFD session, you must specify a peer IPv4 or IPv6 address. The system checks only the format of the IP address but not its correctness. If the peer IPv4 or IPv6 address is incorrect, the static BFD session cannot be established.
Different static BFD sessions cannot have the same local discriminator.
As a best practice, specify the source IP address for echo packets when creating a static BFD session. If you do not specify the source IP address, the device uses the IP address specified in the bfd echo-source-ip or bfd echo-source-ipv6 command as the source IP address of echo packets.
Creating a static BFD session for single-hop detection
2.     Configure the source IP address of echo packets.
¡     Configure the source IP address of echo packets.
bfd echo-source-ip ip-address
By default, no source IPv4 address is configured for echo packets.
As a best practice, do not configure the source IPv4 address to be on the same network segment as any local interfaces. This can avoid network congestion caused a large number of ICMP redirect packets sent from the peer.
¡     Configure the source IPv6 address of echo packets.
By default, no source IPv6 address is configured for echo packets.
The source IPv6 address of echo packets can only be a global unicast address.
3.     Create a static BFD session and enter static BFD session view.
IPv4:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
IPv6:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
4.     (Optional.) Specify a local discriminator for the static BFD session.
discriminator local local-value
By default, no local discriminator is specified.
You can use this command only if you do not specify a local discriminator when creating a static BFD session.
Creating a static BFD session for multihop detection
2.     (Optional.) Configure the source IP address of echo packets.
¡     Configure the source IPv4 address of echo packets.
As a best practice, do not configure the source IPv4 address to be on the same network segment as any local interfaces. If you configure such a source IPv4 address, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
IPv4:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo[ discriminator { auto | local local-value } ] ]
IPv6:
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
When creating a BFD session in echo packet mode, you can configure the minimum interval for receiving BFD echo packets and the detection time multiplier for the device.
When the same BFD session (with the same source IP address, destination IP address, interface, VPN, and destination port number) is associated with multiple upper layer applications, BFD selects the detection time settings for the BFD session as follows:
1.     Minimum values of the following settings:
¡     Settings configured in static BFD session view.
¡     Settings configured in the BFD template specified by the upper layer application.
¡     Settings configured by the upper layer application.
2.     Settings configured in interface view or system view.
3.     Default settings.
When a BFD session is associated with only one upper layer application, BFD selects the detection time settings for the BFD session as follows:
1.     BFD selects the detection time settings for the BFD session based on whether the upper layer application supports using a BFD template and configuring detection time settings:
¡     If a BFD template is specified and detection time settings are also configured for the upper layer application, BFD selects the settings configured in the specified BFD template.
¡     If a BFD template is specified for the upper layer application that does not support configuring detection time settings, BFD selects the settings configured in the specified BFD template.
¡     If detection time settings are configured for the upper layer application that does not support using a BFD template, BFD selects the configured settings.
Configure detection time settings for single-hop BFD detection
2.     Enter interface view or static BFD session view.
¡     Enter interface view.
¡     Enter static BFD session view.
The static BFD session must already exist.
To configure parameters for a static BFD session, you must enter its view.
3.     Set the minimum interval for receiving BFD echo packets.
The default setting is 400 milliseconds.
4.     Set the detection time multiplier.
bfd detect-multiplier value
The default setting is 5.
Configure detection time settings for multihop BFD detection
2.     (Optional.) Enter static BFD session view.
bfd multi-hop min-echo-receive-interval interval
·     The local discriminator and remote discriminator of a static BFD session are specified manually in the bfd static command or in the commands that associate specific applications with BFD.
·     The local discriminator of a dynamic BFD session is assigned by the device, and the remote discriminator is obtained during BFD session negotiation. The device can automatically assign the local discriminator to the BFD session in the following conditions:
¡     The auto keyword is specified for the bfd static command.
¡     The local and remote discriminators are not specified for the BFD session associated with a specific application.
After an upper-layer protocol is configured to support BFD, the device automatically creates BFD sessions in control packet mode. You do not need to perform this task.
BFD version 0 does not support the following commands:
·     bfd session init-mode.
·     bfd authentication-mode.
·     bfd demand enable.
·     bfd echo enable.
2.     Configure the BFD session establishment mode.
By default, BFD uses the active mode to establish a session.
After a BFD session is established, the two ends can operate in the following modes:
·     Demand mode—The Demand mode can be used to reduce the overhead when a large number of BFD sessions exist.
¡     If the peer end is operating in Asynchronous mode (default), the peer end stops sending BFD control packets after receiving control packets with the D bit set. In this scenario, BFD detects only the link between the local end and the peer end. The device considers that the session is down if it does not receive any BFD control packets within the detection interval.
¡     If the peer end is operating in Demand mode, both ends stop sending BFD control packets. In this scenario, the system uses features other than BFD, such as Hello packets and hardware CC, to verify the connectivity to another system.
The bfd demand enable command cannot take effect when any of the following conditions exist:
·     Echo-packet-mode BFD sessions exist on the device.
·     SBFD sessions exist on the device.
·     BFD sessions for detecting aggregate links exist on the device.
·     After the bfd detect-interface source-ip command is configured, the bfd detect-interface first-fail-timer and bfd detect-interface special-processing commands are configured.
2.     Enter interface view.
3.     Specify the Demand mode for the BFD session.
bfd demand enable
A static BFD session can be used for single-hop detection and multihop detection. By working with Track, a static BFD session can provide fast failure detection. For more information about Track association with BFD, see "Configuring Track."
Restrictions and guidelines for static BFD session configuration
If a static BFD session is created on the remote end, the static BFD session must be created on the local end.
2.     Create a static BFD session and enter static BFD session view.
IPv4:
bfd static session-name peer-ip ipv4-address interface interface-type interface-number source-ip ipv4-address [ discriminator { auto | local local-value remote remote-value } ]
For a static BFD session to be established, specify the IPv4 address of the peer interface where the static BFD session resides for the peer-ip ipv4-address option. Specify the IPv4 address of the local interface where the static BFD session resides for the source-ip ipv4-address option.
IPv6:
bfd static session-name peer-ipv6 ipv6-address interface interface-type interface-number source-ipv6 ipv6-address [ discriminator { auto | local local-value remote remote-value } ]
For a static BFD session to be established, specify the IPv6 address of the peer interface where the static BFD session resides for the peer-ipv6 ipv6-address option. Specify the IPv6 address of the local interface where the static BFD session resides for the source-ipv6 ipv6-address option.
3.     (Optional.) Specify the local and remote discriminators for the static BFD session.
discriminator { local local-value | remote remote-value }
By default, no local discriminator or remote discriminator is specified for a static BFD session.
Use this command only if you do not specify the local or remote discriminator when creating a static BFD session.
Create a static BFD session for multihop detection
IPv4:
bfd static session-name peer-ip ipv4-address [ vpn-instance vpn-instance-name ] source-ip ipv4-address [ discriminator { auto |local local-value remote remote-value } ] [ track-interface interface-type interface-number ]
IPv6:
bfd static session-name peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] source-ipv6 ipv6-address [ discriminator { auto | local local-value remote remote-value } ] [ track-interface interface-type interface-number ]
When creating a BFD session in control packet mode, you can configure the minimum interval for receiving and transmitting BFD control packets and the detection time multiplier for the device.
You can use the bfd min-receive-interval and bfd min-control-interval commands to adjust the minimum interval for receiving single-hop BFD control packets. Follow these guidelines when you configure the commands:
·     If you configure both the bfd min-receive-interval and bfd min-control-interval commands, the time interval configured by the bfd min-receive-interval command takes precedence.
·     If you do not configure the bfd min-receive-interval or bfd min-control-interval command, the device uses the default value for the bfd min-receive-interval command as the minimum interval for receiving single-hop BFD control packets.
·     If you configure either the bfd min-receive-interval or bfd min-control-interval command, the device uses the value configured for that command as the minimum interval for receiving single-hop BFD control packets.
You can use the bfd min-transmit-interval and bfd min-control-interval commands to adjust the minimum interval for transmitting single-hop BFD control packets. Follow these guidelines when you configure the commands:
·     If you configure both the bfd min-transmit-interval and bfd min-control-interval commands, the time interval configured by the bfd min-transmit-interval command takes precedence.
·     If you do not configure the bfd min-transmit-interval or bfd min-control-interval command, the device uses the default value for the bfd min-transmit-interval command as the minimum interval for transmitting single-hop BFD control packets.
·     If you configure either the bfd min-transmit-interval or bfd min-control-interval command, the device uses the value configured for that command as the minimum interval for transmitting single-hop BFD control packets.
You can use the bfd multi-hop min-receive-interval and bfd multi-hop min-control-interval commands to adjust the minimum interval for receiving multihop BFD control packets. Follow these guidelines when you configure the commands:
·     If you configure both the bfd multi-hop min-receive-interval and bfd multi-hop min-control-interval commands, the time interval configured by the bfd multi-hop min-receive-interval command takes precedence.
·     If you do not configure the bfd multi-hop min-receive-interval or bfd multi-hop min-control-interval command, the device uses the default value for the bfd multi-hop min-receive-interval command as the minimum interval for receiving multihop BFD control packets.
·     If you configure either the bfd multi-hop min-receive-interval or bfd multi-hop min-control-interval command, the device uses the value configured for that command as the minimum interval for receiving multihop BFD control packets.
You can use the bfd multi-hop min-transmit-interval and bfd multi-hop min-control-interval commands to adjust the minimum interval for transmitting multihop BFD control packets. Follow these guidelines when you configure the commands:
·     If you configure both the bfd multi-hop min-transmit-interval and bfd multi-hop min-control-interval commands, the time interval configured by the bfd multi-hop min-transmit-interval command takes precedence.
·     If you do not configure the bfd multi-hop min-transmit-interval or bfd multi-hop min-control-interval command, the device uses the default value for the bfd multi-hop min-transmit-interval command as the minimum interval for transmitting multihop BFD control packets.
4.     If you configure either the bfd multi-hop min-transmit-interval or bfd multi-hop min-control-interval command, the device uses the value configured for that command as the minimum interval for transmitting multihop BFD control packets.
3.     Set the minimum interval for receiving echo packets.
4.     Set the minimum interval for transmitting and receiving single-hop BFD control packets.
¡     Set the minimum interval for transmitting single-hop BFD control packets.
¡     Set the minimum interval for receiving single-hop BFD control packets.
5.     Set the minimum interval for transmitting and receiving single-hop BFD control packets. (For some devices only.)
bfd min-control-interval interval
The default value varies by device model.
6.     Set the single-hop detection time multiplier.
3.     Set the multihop detection time multiplier.
4.     Set the minimum interval for transmitting and receiving multihop BFD control packets. (For some devices only.)
¡     Set the minimum interval for transmitting multihop BFD control packets.
¡     Set the minimum interval for receiving multihop BFD control packets.
5.     Set the minimum interval for transmitting and receiving multihop BFD control packets. (For some devices only.)
bfd multi-hop min-control-interval interval
You can configure authentication settings, including algorithm and key, to enhance BFD session security.
Configure the authentication mode for a single-hop BFD session
3.     Configure the authentication mode for single-hop control packets.
bfd authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher cipher-string | plain plain-string }
By default, no authentication mode is configured for single-hop control packets.
Configure the authentication mode for a multihop BFD session
3.     Configure the authentication mode for multihop BFD control packets.
bfd multi-hop authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher cipher-string | plain plain-string }
By default, no authentication mode is configured for multihop BFD control packets.
IANA assigned port number 4784 to BFD for multihop BFD detection in control packet mode. By default, H3C devices use 4784 as the destination port number for multihop BFD control packets, while devices from other vendors might use 3784. To avoid BFD session establishment failures, make sure the devices on both ends of the BFD session use the same destination port number for multihop BFD control packets.
This command applies to only new multihop BFD sessions in control packet mode.
2.     Configure the destination port number for multihop BFD control packets.
The default setting is 4784.
By default, BFD does not notify upper-layer protocols of session establishment failures. The notification is required in some scenarios. For example, upon a session establishment failure in an aggregate link, the aggregate link can place the associated member port in Unselected state based on the failure notification. You can configure the delay timer for BFD to notify upper-layer protocols of session establishment failures.
This feature does not apply to BFD sessions in echo packet mode.
2.     Set the delay timer for BFD to notify upper-layer protocols of session establishment failures.
bfd init-fail-timer seconds
CAUTION
CAUTION:
For session establishment failures caused by configuration mismatches at the two ends, this command can cause the upper-layer protocol to act incorrectly. Therefore, use this command with caution. BFD status mismatch and BFD authentication configuration mismatch are examples of configuration mismatches.
By creating a BFD session for single-hop detection through exchange of BFD control packets, this feature implements fast link detection. When BFD detects a link fault, it sets the link layer protocol state to DOWN(BFD). This behavior helps applications relying on the link layer protocol state achieve fast convergence. The source IP address of control packets is specified manually, and the destination IP address is fixed at 224.0.0.184. As a best practice, specify the IP address of the interface as the source IP address. If the interface does not have an IP address, specify a unicast IP address other than 0.0.0.0 as the source IP address.
You can associate the state of the following interfaces with BFD:
·     Layer 2 Ethernet interfaces.
·     Member ports in a Layer 2 aggregation group.
·     VLAN interfaces.
·     Layer 2 aggregate interfaces.
The echo function does not take effect on BFD sessions associated with interface states.
3.     Associate the interface state with BFD.
bfd detect-interface source-ip ip-address [ discriminator local local-value remote remote-value ] [ template template-name ]
If the peer device does not support obtaining BFD session discriminators through autonegotiation, you must specify the discriminators on both the local and peer devices. Without the discriminators, the BFD session cannot come up.
4.     (Optional.) Configure the timer that delays reporting the first BFD session establishment failure to the data link layer.
bfd detect-interface first-fail-timer seconds
By default, the first BFD session establishment failure is not reported to the data link layer.
5.     (Optional.) Enable special processing for BFD sessions.
bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
By default, all types of special processing are disabled for BFD sessions.
When you connect an H3C device to a third-party device, for successful BFD session negotiation, make sure the TTL value settings for BFD packets on both ends of the BFD session are the same. When the device receives a BFD packet in DOWN or INIT state from its peer, it verifies the TTL value of the packet and performs one of the following actions:
·     For a single-hop BFD session, if the device receives a packet that carries a TTL value that is different from the TTL value specified with the bfd ttl command, the device drops the packet.
·     For a multihop BFD session, if the device receives a packet that carries a TTL value that is greater than the TTL value specified with the bfd ttl command, the device drops the packet.
·     If the BFD session is already up, the device sets the BFD session state to AdminDown, which triggers a BFD session renegotiation.
·     The bfd ttl command does not take effect on BFD sessions in echo packet mode.
·     The bfd ttl command does not take effect on SBFD packets,and the device does not verify the TTL value in SBFD packets.
·     For an IPv4 or IPv6 address with different mask lengths or prefix lengths, the device uses the TTL value specified with the longest mask or prefix length.
·     For an IPv4 or IPv6 subnet, the TTL value of single-hop BFD packets must be greater than the TTL value of multihop BFD packets.
2.     Specify the TTL value for BFD packets.
bfd { peer-ip ipv4-address mask-length | peer-ipv6 ipv6-address prefix-length } ttl { single-hop | multi-hop } ttl-value
By default, the TTL value of single-hop BFD packets is 255 and the TTL value of multihop BFD packets is 64.
This feature allows you to suppress BFD session flapping by using the initial-interval, secondary-interval, and maximum-interval arguments.
·     A BFD session is suppressed within the specified interval. The suppression time does not exceed the maximum-interval.
·     After a BFD session goes down for the second time, it cannot be re-established within the initial-interval.
·     After a BFD session goes down for the third time, it cannot be re-established within the secondary-interval.
·     After a BFD session goes down for the fourth time and at any later time, the following rules apply:
¡     If secondary-interval × 2n-3 is smaller than or equal to the maximum-interval, the BFD session cannot be re-established within the secondary-interval × 2n-3.
¡     If secondary-interval × 2n-3 is greater than the maximum-interval, the BFD session cannot be re-established within the maximum-interval.
The letter n, starting from 4, is the number of times the BFD session flaps.
2.     Configure BFD session flapping suppression.
bfd dampening [ maximum maximum-interval initial initial-interval secondary secondary-interval ]
By default, BFD sessions are not suppressed.
The values for the initial-interval and secondary-interval arguments cannot be greater than or equal to the value for the maximum-interval argument.
Perform this task to specify BFD parameters in a template for sessions without next hops. You can configure BFD parameters for LSPs and PWs through a BFD template.
This task can also be used to specify BFD parameters for BFD sessions that detect interface states.
2.     Create a BFD template and enter BFD template view.
bfd template template-name
3.     (Optional.) Configure the authentication mode for BFD control packets.
By default, no authentication is performed.
5.     Set the minimum interval for transmitting and receiving BFD control packets. (For some devices only.)
¡     Set the minimum interval for transmitting BFD control packets.
¡     Set the minimum interval for receiving BFD control packets.
Use this feature to enable the device to record the following types of BFD event logs to help you locate the reason for BFD session state anomalies:
·     BFD session down events.
·     Driver packet-sending events.
2.     Enable BFD event logging.
bfd event-log enable { down [ log-size ] | driver-packet [ detection-abnormal-autostop ] }
By default, BFD event logging is disabled.
You can repeat this command to modify the maximum number of logs allowed for BFD session down events. After modification, the device clears recorded logs.
The device can record a maximum number of 8192 logs for driver packet-sending events.
To report critical BFD events to an NMS, enable SNMP notifications for BFD. For BFD event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for BFD.
snmp-agent trap enable bfd
By default, SNMP notifications are enabled for BFD.
Display and maintenance commands for BFD
Execute the display command in any view and the reset command in user view.
Display BFD session information.
display bfd session [ discriminator local local-value | static session-name | verbose ]
display bfd session [ [ dynamic ] [ control | echo ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ lsp | te | pw ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ verbose ] ]
display bfd session [ [ static ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
display bfd session [ [ static ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
Display information about static BFD sessions created to detect the aggregate links and member links of Layer 3 aggregate interfaces.
display bfd session route-aggregation [ interface interface-type interface-number ]
Display the TTL values for BFD packets.
display bfd ttl
Clear BFD session statistics.
reset bfd session statistics
