- 05-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-Policy-based routing commands
- 06-IPv6 static routing commands
- 07-RIPng commands
- 08-OSPFv3 commands
- 09-IPv6 policy-based routing commands
- 10-Routing policy commands
- 11-DCN commands
11-DCN commands | 56.27 KB |
DCN commands
auto-report
Use auto-report to enable the automatic report feature on the GNE.
Use undo auto-report to disable the automatic report feature on the GNE.
auto-report
undo auto-report
The automatic report feature is disabled.
DCN view
# Enable the automatic report feature on the GNE.
[Sysname] dcn
[Sysname-dcn] auto-report
dcn
Use dcn to enable DCN and enter DCN view.
Use undo dcn to disable DCN.
dcn
undo dcn
DCN is disabled.
After DCN is enabled, each NE encapsulates its NE information in a Type-10 Opaque LSA and floods the LSA into the local area for routing information synchronization and intercommunication. The NE stops generating Type 10 Opaque LSA after DCN is disabled.
# Enable DCN and enter DCN view.
[Sysname] dcn
[Sysname-dcn]
display dcn
Use display dcn to display the brief DCN information.
display dcn
# Display the brief DCN information.
<Sysname> display dcn
DCN Brief Information
NE ID : 0x112233
NE IP : 129.0.88.1
Mask : 255.255.255.255
DCN interface: LoopBack1023
Auto report : Enabled
display dcn ne-info
Use display dcn ne-info to display information about all online NEs on the DCN network.
display dcn ne-info
# Display information about all online NEs on the DCN network.
<Sysname> display dcn ne-info
DCN Network Elements Information
NE ID NE IP Metric Device Type
0x10001 3.3.3.3 0 H3C S5136S-8FP4XS-EI-Q
Total number: 1
Metric |
Cost from the local NE to the destination NE. |
Total number |
Total number of online NEs on the DCN network. |
ne-id
Use ne-id to configure an NE ID for an NE.
Use undo ne-id to restore the default.
ne-id id-number
undo ne-id
The NE ID is automatically generated by using the 24 low-order bits of the bridge MAC address.
DCN view
id-number: Specifies the 24-bit NE ID in hexadecimal format, in the range of 010001 to FEFFFE. The eight high-order bits of the NE ID represent the subnet number. The remaining 16 bits represent the basic ID.
An NE ID uniquely identifies an NE on the DCN network and is used for generating the default NE IP.
# Configure the NE ID as 112233.
[Sysname] dcn
[Sysname-dcn] ne-id 112233
ne-ip
ne-ip
Use ne-ip to configure the NE IP for an NE.
Use undo ne-ip to restore the default.
ne-ip ip-address { mask-length | mask }
undo ne-ip
The NE IP is automatically generated according to the NE ID and changes with the NE ID. The IP address takes 129 as the eight high-order bits and the NE ID as the remaining 24 bits. The mask length is 32.
DCN view
ip-address: Specifies an IPv4 address.
mask-length: Specifies the mask length in the range of 1 to 32.
mask: Specifies the mask length in dotted decimal format.
After DCN is enabled, the system assigns an NE IP to the loopback interface with the largest interface number, and specifies the NE IP as the LLDP management address.
A manually configured NE IP overwrites the default NE IP and breaks the mapping with the NE ID.
# Configure the NE IP as 100.1.1.1/24.
[Sysname] dcn
[Sysname-dcn] ne-ip 100.1.1.1 24
ne-id
