03-Layer 2—LAN Switching Command Reference
HomeSupportSwitchesS5136 SeriesS5136S-EI SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C S5136S-EI Switch Series Command References-6W10003-Layer 2—LAN Switching Command Reference
13-PPPoE commands
13-PPPoE commands 96.20 KB
PPPoE relay commands
display pppoe-relay client-information
Use display pppoe-relay client-information to display the vendor-specific tag processing configuration for client-side packets on the PPPoE relay.
display pppoe-relay client-information { format | strategy }
format: Displays the format configuration for the vendor-specific tag processing for client-side packets on the PPPoE relay.
strategy: Displays the policy configuration for the vendor-specific tag processing for client-side packets on the PPPoE relay.
# Display the format configuration for the vendor-specific tag processing for client-side packets on the PPPoE relay.
<Sysname> display pppoe-relay client-information format
The current client-information format:
Circuit ID: ASCII
Remote ID: ASCII
# Display the policy configuration for the vendor-specific tag processing for client-side packets on the PPPoE relay.
<Sysname> display pppoe-relay client-information strategy
The current global client-information strategy: Replace
The current interface client-information strategy:
  Interface                     Strategy
  GigabitEthernet1/0/1            Keep
  GigabitEthernet1/0/2            Drop
Circuit ID and remote ID padding formats in the vendor-specific tag:
·     ASCII—ASCII string padding format.
·     Hex—Hexadecimal padding format.
·     User-defined—User-defined padding format.
Global vendor-specific tag processing policy for the client-side PADI and PADR packets on the PPPoE relay:
·     Drop—Strips the vendor-specific tag from the PADI or PADR packets.
·     Keep—Keeps the vendor-specific tag unchanged.
·     Replace—Pads the vendor-specific tag in the configured padding format.
Interface-level vendor-specific tag processing policy for the client-side PADI and PADR packets on the PPPoE relay.
Interface name. This field displays only the interfaces whose processing policies are different from the global processing policy.
Strategy
Vendor-specific tag processing policy for the client-side PADI and PADR packets of the interface on the PPPoE relay:
display pppoe-relay statistics
Use display pppoe-relay statistics to display packets statistics for the PPPoE relay.
display pppoe-relay statistics [ interface interface-type interface-number ]
When this command is executed, this command displays statistics only for packets with non-zero packet counts.
# Display packet statistics on GigabitEthernet 1/0/1.
<Sysname> display pppoe-relay statistics interface GigabitEthernet 1/0/1
  Packets received:
    ALL = 5 PADI = 5 PADO = 0 PADR = 0 PADS = 0 PADT = 0
  Packets sent:
    ALL = 5 PADI = 0 PADO = 5 PADR = 0 PADS = 0 PADT = 0
  Packets dropped:
    Server responses from untrusted ports = 0
    Client requests towards untrusted ports = 0
    Malformed PPPoE Discovery packets = 0
Statistics on an interface.
Packets received
Incoming packet statistics of the interface:
·     ALL—Number of all PAD packets.
·     PADI—Number of PADI packets.
·     PADO—Number of PADO packets.
·     PADR—Number of PADR packets.
·     PADS—Number of PADS packets.
·     PADT—Number of PADT packets.
Packets sent
Outgoing packet statistics of the interface:
Packets dropped
Dropped packets statistics of the interface.
Number of PADO and PADS packets dropped on untrusted ports.
Number of PADR packets dropped by untrusted ports.
reset pppoe-relay statistics
Use pppoe-relay client-information format to configure the circuit ID and remote ID padding formats for the client-side PPPoE packets on the PPPoE relay.
Use undo pppoe-relay client-information format to restore the default.
pppoe-relay client-information format { circuit-id | remote-id } { ascii | hex | user-defined text }
undo pppoe-relay client-information format { circuit-id | remote-id }
Both the circuit ID padding format and the remote ID padding format for the client-side PPPoE packets are the ASCII string on the PPPoE relay.
circuit-id: Specifies the circuit ID padding format.
remote-id: Specifies the remote ID padding format.
ascii: Specifies the ASCII string format. When this format is configured, "%portname:%svlan.%cvlan %sysname" is extracted and used as the circuit ID content, and "%mac" is used as the remote ID content. The circuit ID and remote ID are padded with the corresponding contents in the ASCII string format.
hex: Specifies the hexadecimal format. When this format is configured, "%length%port%svlan%cvlan" is extracted and used as the circuit ID content, and "%length%mac" is used as the remote ID content. The circuit ID and remote ID are padded with the corresponding contents in the hexadecimal format.
user-defined text: Specifies the user-defined format. The text argument is a case-sensitive string of 1 to 127 characters. When this format is configured, the corresponding information is extracted from the configured text and padded in the circuit ID and remote ID.
When the PPPoE relay receives PPPoE packets from the PPPoE client, the PPPoE relay pads the circuit ID and remote ID with the contents in the format configured by using this command.
Both the circuit ID and remote ID are of up to 63 characters. When the content to be padded exceeds 63 characters, the first 63 characters are padded.
When the user-defined format is used, the system automatically recognizes the escape keyword input by the user and translates it to the actual information. For more information about the supported escape keywords, see Table 3. For example, suppose the interface that receives packet on the PPPoE relay is Ethernet 0/0/0. In this case, you can input the escape keyword %portname. Then, the system automatically recognizes the escape keyword and translates the escape keyword into the actual port information Ethernet 0/0/0. For the system to correctly recognize the escape keywords, you must add the dollar sign (%) before each keyword. Otherwise, the system directly uses the input keyword and does not translate it. Non-escape keywords are directly used.
An integer can be added between the dollar sign (%) and the escape keyword. The integer specifies the width of the translated characters. When the translated characters do not reach the width specified by the integer, spaces are padded on the left to fill the width.
Table 3 Description of escape keywords supported by the user-defined format
Keyword
sysname
System name of the PPPoE relay.
portname
Port name.
porttype
Port type.
slot
Slot number of the port.
subslot
Subslot number of the port.
port
Port number.
svlan
Outer VLAN ID.
cvlan
Inner VLAN ID.
mac
MAC address of the PPPoE relay.
Length
Length of the subsequent string. The padded content is of double digits. When the length is a single digit, one digit of 0 is padded on the left.
When you use different padding formats, the packet contents are different. For example, the contents of the circuit ID are as follows: the user access interface is Ethernet 0/0/0, the outer VLAN ID is 200, the inner VLAN ID is 100, and the system name of the PPPoE relay is Sysname. The contents of the remote ID are as follows: the MAC address of the PPPoE relay is 04f9-38a9-44b0.
When you use the ASCII string format, the contents are as follows:
  Circuit ID: Ethernet0/0/0:200.100 Sysname
  Remote ID: 04f9-38a9-44b0
When you use the hexadecimal format, the contents are as follows:
  Circuit ID: 00 05 00 00 c8 00 64
  Remote ID: 00 06 04 f9 38 a9 44 b0
When you use the user-defined format, the contents are as follows:
# Configure the user-defined format "%portname:%svlan.%cvlan %sysname" for the circuit ID.
[Sysname] pppoe-relay client-information format circuit-id user-defined "%portname:%svlan.%cvlan %sysname"
# Configure the user-defined format %mac for the remote ID.
[Sysname] pppoe-relay client-information format remote-id user-defined "%mac"
# Configure the circuit ID padding format as the ASCII string format for the client-side PPPoE packets on the PPPoE relay.
[Sysname] pppoe-relay client-information format circuit-id ascii
Use pppoe-relay client-information strategy to configure the vendor-specific tag processing policy for the client-side PADI and PADR packets on the PPPoE relay.
Use undo pppoe-relay client-information strategy to restore the default.
pppoe-relay client-information strategy { drop | keep | replace }
The global vendor-specific tag processing policy for the client-side PADI and PADR packets on the PPPoE relay is replace.
No interface-level vendor-specific tag processing policy for the client-side PADI and PADR packets on the PPPoE relay is configured.
drop: Strips the vendor-specific tag from the PADI or PADR packets.
keep: Keeps the vendor-specific tag unchanged.
replace: Pads the vendor-specific tag in the configured format.
This feature can be configured both in system view and in interface view. The configuration in system view takes effect on all interfaces. The configuration in interface view takes effect only on the current interface. The configuration in interface view takes precedence over the configuration in system view.
The processing policy takes effect only on incoming packets of interfaces.
This command is not supported on Layer 2 aggregation group member ports. If a Layer 2 Ethernet interface is configured with this command before joining a Layer 2 aggregation group, the command is cleared on the member port after the member ports joins the aggregation group.
# Configure the global processing policy for the client-side PADI and PADR packets as drop on the PPPoE relay.
[Sysname] pppoe-relay client-information strategy drop
pppoe-relay enable
Use pppoe-relay enable to enable the PPPoE relay function.
Use undo pppoe-relay enable to disable the PPPoE relay function.
pppoe-relay enable
The PPPoE relay function is disabled.
# Enable the PPPoE relay function.
[Sysname] pppoe-relay enable
pppoe-relay server-information vendor-specific strip
Use pppoe-relay server-information vendor-specific strip to enable an interface to strip the vendor-specific tags of the PPPoE server-side packets.
Use undo pppoe-relay server-information vendor-specific strip to disable an interface from stripping the vendor-specific tags of the PPPoE server-side packets.
The function of stripping vendor-specific tags of the PPPoE server-side packets is disabled on an interface.
When the PPPoE relay receives PADO and PADS packets from the PPPoE server on a PPPoE relay trusted port with this feature enabled, the PPPoE relay strips the vendor-specific tags of the packets before forwarding the packets.
This command takes effect only on packets received on PPPoE relay trusted ports.
# Enable GigabitEthernet 1/0/1 to strip the vendor-specific tags of the PPPoE server-side packets..
[Sysname-GigabitEthernet1/0/1] pppoe-relay trust
[Sysname-GigabitEthernet1/0/1] pppoe-relay server-information vendor-specific strip
pppoe-relay trust
pppoe-relay trust
Use pppoe-relay trust to configure an interface as PPPoE relay trusted port.
Use undo pppoe-relay trust to restore the default.
pppoe-relay trust
An interface is a PPPoE relay untrusted port.
A PPPoE relay-enabled device processes PPPoE protocol packets as follows:
·     When receiving PADI, PADR, and PADT on untrusted ports, the device can forward the packets out of only the trusted ports.
·     When receiving PADO and PADS packets on untrusted ports, the device directly drops the packets.
·     When receiving PADO, PADS, and PADT packets on trusted ports, the device can forward the packets out of any port.
·     When receiving PADI and PADR packets on trusted ports, the device can forward the packets out of only the trusted ports.
For a PPPoE relay to correctly forward and process PPPoE protocol packets, you must configure the PPPoE server-facing interfaces on the PPPoE relay as trusted ports, and configure the PPPoE client-facing interfaces on the PPPoE relay as untrusted ports.
# Configure GigabitEthernet 1/0/1 as a PPPoE relay trusted port.
Use reset pppoe-relay statistics to clear packets statistics for the PPPoE relay.
# Clear packet statistics for the PPPoE relay.
<Sysname> reset pppoe-relay statistics
