02-QoS configuration | 1.25 MB |
QoS processing flow in a device
Restrictions and guidelines for applying a QoS policy
Applying the QoS policy to an interface
Applying the QoS policy to VLANs
Applying the QoS policy globally
Applying the QoS policy to a control plane
Applying the QoS policy to a user profile
Enabling SNMP notifications for QoS
Display and maintenance commands for QoS policies
Setting the exclusive bandwidth on an interface
About setting the exclusive bandwidth
Display and maintenance commands for exclusive bandwidth
Configuring interface channelization
About interface channelization
Restrictions and guidelines: Interface channelization configuration
Configuring the channelized bandwidth for a subinterface
Display and maintenance commands for interface channelization
Priority mapping configuration methods
Restrictions and guidelines: Priority mapping configuration
Priority mapping tasks at a glance
Configuring an uncolored priority map
Configuring a colored priority map
Configuring a flexible priority map
Configuring a port to trust packet priority for priority mapping
Changing the port priority of an interface
Restrictions and guidelines for configuring primap
Display and maintenance commands for priority mapping
Priority mapping configuration examples
Example: Configuring a priority trust mode
Example: Configuring priority mapping tables and priority marking
Configuring traffic policing, GTS, and rate limit
About traffic policing, GTS, and rate limit
Traffic evaluation and token buckets
Traffic policing configuration approaches
Configuring traffic policing by using the MQC approach
Configuring traffic policing for all traffic
Configuring traffic policing for a user profile
Configuring traffic policing for a control plane
Configuring traffic policing for a PW
Configuring traffic policing for attack protocol packets
Including the physical layer header in calculating the packet length for traffic policing
Configuring GTS for a user group profile
Configuring GTS for a session group profile
Configuring the rate limit for an interface
Limiting the traffic rates on Layer 3 aggregation member ports based on their physical bandwidth
Configuring traffic permission by using the MQC approach
Display and maintenance commands for traffic policing, GTS, and rate limit
Traffic policing, GTS, and rate limit configuration examples
Example: Configuring traffic policing
Configuring hardware congestion management
About hardware congestion management
Cause, negative results, and countermeasure of congestion
Restrictions and guidelines for CBQ configuration
Configure AF and the minimum guaranteed bandwidth
Configuring EF and the maximum bandwidth
Setting the maximum reserved bandwidth as a percentage of available bandwidth for an interface
Configuring a queue scheduling profile
About queue scheduling profiles
Restrictions and guidelines for queue scheduling profile configuration
Applying a queue scheduling profile
Example: Configuring a queue scheduling profile
Display and maintenance commands for hardware congestion management
Configuring congestion avoidance
Relationship between WRED and queuing mechanisms
Configuring and applying a queue-based WRED table
Example: Configuring and applying a queue-based WRED table
Configuring an applying a WRED profile
Example: Configuring and applying a WRED profile
Display and maintenance commands for WRED
Restrictions and guidelines: Traffic filtering configuration
Traffic filtering configuration examples
Example: Configuring traffic filtering
Configuring priority marking by using the MQC approach
Priority marking configuration examples
Example: Configuring priority marking
Configuring traffic redirecting
Restrictions and guidelines: Traffic redirecting configuration
Defining and applying a QoS policy
Traffic redirecting configuration examples
Example: Configuring traffic redirecting
Configuring aggregate CAR by using the MQC approach
Display and maintenance commands for global CAR
Global CAR configuration examples
Example: Configuring aggregate CAR
Configuring class-based accounting
Restrictions and guidelines: Class-based accounting configuration
Class-based accounting configuration examples
Example: Configuring class-based accounting
Configuring queue-based accounting
Configuring interface queue-based accounting
About interface queue-based accounting
Display and maintenance commands for queue-based accounting
Configuring user queue-based accounting
Configuring basic BGP functions
Configuring the route receiver
Enabling QPPB on the route receiving interface
Example: Configuring QPPB in an IPv4 network
Example: Configuring QPPB in an MPLS L3VPN
Example: Configuring QPPB in an IPv6 network
Configuring packet-drop logging for control plane traffic
About packet-drop logging for control plane traffic
Display and maintenance commands for packet-drop logging for control plane traffic
Appendix B Default priority maps
Appendix C Introduction to packet precedence
QoS overview
In data communications, Quality of Service (QoS) provides differentiated service guarantees for diversified traffic in terms of bandwidth, delay, jitter, and drop rate, all of which can affect QoS.
QoS manages network resources and prioritizes traffic to balance system resources.
The following section describes typical QoS service models and widely used QoS techniques.
QoS service models
This section describes several typical QoS service models.
Best-effort service model
The best-effort model is a single-service model. The best-effort model is not as reliable as other models and does not guarantee delay-free delivery.
The best-effort service model is the default model for the Internet and applies to most network applications. It uses the First In First Out (FIFO) queuing mechanism.
IntServ model
The integrated service (IntServ) model is a multiple-service model that can accommodate diverse QoS requirements. This service model provides the most granularly differentiated QoS by identifying and guaranteeing definite QoS for each data flow.
In the IntServ model, an application must request service from the network before it sends data. IntServ signals the service request with the RSVP. All nodes receiving the request reserve resources as requested and maintain state information for the application flow. For more information about RSVP, see MPLS Configuration Guide.
The IntServ model demands high storage and processing capabilities because it requires all nodes along the transmission path to maintain resource state information for each flow. This model is suitable for small-sized or edge networks. However, it is not suitable for large-sized networks, for example, the core layer of the Internet, where billions of flows are present.
DiffServ model
The differentiated service (DiffServ) model is a multiple-service model that can meet diverse QoS requirements. It is easy to implement and extend. DiffServ does not signal the network to reserve resources before sending data, as IntServ does.
QoS techniques in a network
The QoS techniques include the following features:
· Traffic classification.
· Traffic policing.
· Traffic shaping.
· Rate limit.
· Congestion management.
· Congestion avoidance.
The following section briefly introduces these QoS techniques.
All QoS techniques in this document are based on the DiffServ model.
Figure 1 Position of the QoS techniques in a network
As shown in Figure 1, traffic classification, traffic shaping, traffic policing, congestion management, and congestion avoidance mainly implement the following functions:
· Traffic classification—Uses match criteria to assign packets with the same characteristics to a traffic class. Based on traffic classes, you can provide differentiated services.
· Traffic policing—Polices flows and imposes penalties to prevent aggressive use of network resources. You can apply traffic policing to both incoming and outgoing traffic of a port.
· Traffic shaping—Adapts the output rate of traffic to the network resources available on the downstream device to eliminate packet drops. Traffic shaping usually applies to the outgoing traffic of a port.
· Congestion management—Provides a resource scheduling policy to determine the packet forwarding sequence when congestion occurs. Congestion management usually applies to the outgoing traffic of a port.
· Congestion avoidance—Monitors the network resource usage. It is usually applied to the outgoing traffic of a port. When congestion worsens, congestion avoidance reduces the queue length by dropping packets.
Figure 2 briefly describes how the QoS module processes traffic.
1. Traffic classifier identifies and classifies traffic for subsequent QoS actions.
2. The QoS module takes various QoS actions on classified traffic as configured, depending on the traffic processing phase and network status. For example, you can configure the QoS module to perform the following operations:
¡ Traffic policing for incoming traffic.
¡ Traffic shaping for outgoing traffic.
¡ Congestion avoidance before congestion occurs.
¡ Congestion management when congestion occurs.
QoS configuration approaches
You can configure QoS by using the MQC approach or non-MQC approach.
In the modular QoS configuration (MQC) approach, you configure QoS service parameters by using QoS policies. A QoS policy defines QoS actions to take on different classes of traffic and can be applied to an object (such as an interface) to control traffic.
In the non-MQC approach, you configure QoS service parameters without using a QoS policy. For example, you can use the rate limit feature to set a rate limit on an interface without using a QoS policy.
Some features support both approaches, but some support only one.
Configuring a QoS policy
About QoS policies
A QoS policy has the following components:
· Traffic class—Defines criteria to match packets.
· Traffic behavior—Defines QoS actions to take on matching packets.
By associating a traffic class with a traffic behavior, a QoS policy can perform the QoS actions on matching packets.
A QoS policy can have multiple class-behavior associations.
QoS policy tasks at a glance
To configure a QoS policy, perform the following tasks:
2. Defining a traffic behavior
¡ Applying the QoS policy to an interface
¡ Applying the QoS policy to VLANs
¡ Applying the QoS policy globally
¡ Applying the QoS policy to a control plane
¡ Applying the QoS policy to a user profile
5. (Optional.) Enabling SNMP notifications for QoS
Defining a traffic class
1. Enter system view.
2. Create a traffic class and enter traffic class view.
3. (Optional.) Configure a description for the traffic class.
By default, no description is configured.
4. Configure a match criterion.
if-match match-criteria
By default, no match criterion is configured.
For more information, see the if-match command in ACL and QoS Command Reference.
2. Create a traffic behavior and enter traffic behavior view.
3. Configure an action in the traffic behavior.
By default, no action is configured for a traffic behavior.
You can configure multiple actions in a traffic behavior.
For more information about configuring an action, see the subsequent chapters for traffic policing, traffic filtering, priority marking, class-based accounting, and so on.
Defining a QoS policy
2. Create a QoS policy and enter QoS policy view.
qos policy policy-name
3. Associate a traffic class with a traffic behavior to create a class-behavior association in the QoS policy.
classifier classifier-name behavior behavior-name [ mode qppb-manipulation | insert-before before-classifier-name ]
By default, a traffic class is not associated with a traffic behavior.
Repeat this step to create more class-behavior associations.
Parameter |
qppb-manipulation |
Specifies that a class-behavior association applies only to matching the apply qos-local-id command configuration in a BGP routing policy. For more information, see Layer 3—IP Routing Configuration Guide. On the following cards, this keyword does not support matching the IP precedence in a BGP routing policy: · CEPC: CEPC-CQ8L, CEPC-CQ16L1, CEPC-DQ2L1-G · CSPEX: CSPEX-1802XB, CSPEX-1802X, CSPEX-1812X-E, CSPEX-2304X-G, CSPEX-2304X-LG, CSPEX-2612X-E · SPE: RX-SPE200-E |
NOTE: If you use an ACL in a traffic class, the deny keyword in an ACL rule indicates that the action in the associated traffic behavior is not taken on matching packets. The permit keyword in an ACL rule indicates that the action in the associated traffic behavior will be taken on matching packets. |
Application destinations
You can apply a QoS policy to the following destinations:
· Interface—The QoS policy can be applied to the traffic sent or received on the interface.
· VLAN—The QoS policy can be applied to the traffic sent or received on all ports in the VLAN.
· Globally—The QoS policy can be applied to the traffic sent or received on all ports.
· Control plane—The QoS policy can be applied to the traffic received on the control plane.
· User profile—The QoS policy can be applied to the traffic sent or received by the online users of the user profile.
If a packet matches both a PBR policy and a QoS policy applied to an interface or globally, the packet is forwarded according to the PBR policy.
You can modify traffic classes, traffic behaviors, and class-behavior associations in a QoS policy even after it is applied (except that it is applied to a user profile). If a traffic class uses an ACL for traffic classification, you can delete or modify the ACL.
If an action in a traffic behavior cannot take effect, all other actions in the traffic behavior do not take effect.
A QoS policy can be applied to multiple interfaces.
A maximum of two QoS policies with different priorities and different policy names can be applied to the inbound direction of an interface.
Only one QoS policy can be applied to the outbound direction of an interface.
The QoS policy applied to the outgoing traffic on an interface does not regulate local packets. Local packets refer to critical protocol packets sent by the local system for operation maintenance. The most common local packets include link maintenance, routing, LDP, RSVP, and SSH packets.
You can configure the sharing mode for QoS and ACL resources only if you apply a QoS policy to an interface.
This feature is available only for the following cards:
Card category |
Cards |
CEPC |
CEPC-CQ8L, CEPC-CQ16L1, CEPC-DQ2L1-G |
CSPEX |
CSPEX-1802XB, CSPEX-1802X, CSPEX-1812X-E, CSPEX-2304X-G, CSPEX-2304X-LG, CSPEX-2612X-E |
SPE |
RX-SPE200-E |
If you apply QoS policies separately to an aggregate interface and a member port of the aggregate interface, the QoS policy applied to the aggregate interface takes effect. The QoS policy applied to the member port takes effect after it leaves the aggregation group.
You can specify the preorder preorder-value option only when you apply a QoS policy to the inbound direction of an interface.
A QoS policy applied with the preorder preorder-value option specified has higher priority than that applied without the preorder preorder-value option.
2. Enter interface view.
3. Apply the QoS policy to the interface.
qos apply policy policy-name { inbound | outbound } [ preorder preorder-value ] [ share-mode | share-mode-both ]
By default, no QoS policy is applied to an interface.
You can apply a QoS policy to VLANs to regulate the traffic on all ports of the VLANs.
QoS policies cannot be applied to dynamic VLANs, including VLANs created by GVRP.
When you apply a QoS policy to VLANs, the QoS policy is applied to the specified VLANs on all interface cards. If the hardware resources of an interface card are insufficient, applying a QoS policy to VLANs might fail on the interface card. The system does not automatically roll back the QoS policy configuration already applied to other interface cards. To ensure consistency, use the undo qos vlan-policy command to manually remove the QoS policy configuration applied to them.
2. Apply the QoS policy to VLANs.
By default, no QoS policy is applied to a VLAN.
You can apply a QoS policy globally to the inbound or outbound direction of all ports.
· If the hardware resources of an interface card are insufficient, applying a QoS policy globally might fail on the interface card. The system does not automatically roll back the QoS policy configuration already applied to other interface cards. To ensure consistency, you must use the undo qos apply policy global command to manually remove the QoS policy configuration applied to them.
2. Apply the QoS policy globally.
qos apply policy policy-name global { inbound | outbound } [ preorder preorder-value ]
By default, no QoS policy is applied globally.
A device provides the user plane and the control plane.
· User plane—The units at the user plane are responsible for receiving, transmitting, and switching (forwarding) packets, such as various dedicated forwarding chips. They deliver super processing speeds and throughput.
· Control plane—The units at the control plane are processing units running most routing and switching protocols. They are responsible for protocol packet resolution and calculation, such as CPUs. Compared with user plane units, the control plane units allow for great packet processing flexibility but have lower throughput.
When the user plane receives packets that it cannot recognize or process, it transmits them to the control plane. If the transmission rate exceeds the processing capability of the control plane, the control plane will be busy handling undesired packets. As a result, the control plane will fail to handle legitimate packets correctly or timely. As a result, protocol performance is affected.
To address this problem, apply a QoS policy to the control plane to take QoS actions, such as traffic filtering or traffic policing, on inbound traffic. This ensures that the control plane can correctly receive, transmit, and process packets.
A predefined control plane QoS policy uses the protocol type or protocol group type to identify the type of packets sent to the control plane. You can use protocol types or protocol group types in if-match commands in traffic class view for traffic classification. Then you can reconfigure traffic behaviors for these traffic classes as required. You can use the display qos policy control-plane pre-defined command to display predefined control plane QoS policies.
2. Enter control plane view.
In standalone mode:
control-plane slot slot-number [ cpu cpu-number ]
In IRF mode:
control-plane chassis chassis-number slot slot-number [ cpu cpu-number ]
3. Apply the QoS policy to the control plane.
By default, no QoS policy is applied to a control plane.
After a user passes authentication, the authentication server sends the name of the user profile associated with the user to the device. The QoS policy configured in user profile view manages traffic of the user profile's online users.
For more information about user profiles, see BRAS Services Configuration Guide.
In one direction of each user profile, only one policy can be applied. To modify a QoS policy already applied to a direction, first remove the applied QoS policy. You can apply a QoS policy to multiple user profiles.
When a user profile with a QoS policy applied is directly applied to an interface, it does not take effect.
This feature is supported only on the following cards in standard system operating mode:
Card category |
Cards |
CSPEX |
CSPEX-1802XB, CSPEX-1802X, CSPEX-1812X-E, CSPEX-2304X-G, CSPEX-2304X-LG |
SPE |
RX-SPE200-E |
2. Enter user profile view.
user-profile profile-name
3. Apply the QoS policy to the user profile.
By default, no QoS policy is applied to a user profile.
Parameter |
inbound |
Applies a QoS policy to the incoming traffic (traffic received by the device from online users). |
outbound |
Applies a QoS policy to the outgoing traffic (traffic sent by the device to online users). |
Perform this task to report critical QoS events by sending SNMP notifications.
For QoS notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
2. Enable SNMP notifications for QoS.
snmp-agent trap enable qos
By default, SNMP notifications are disabled for QoS.
Task |
Command |
Display traffic class configuration. |
In standalone mode: display traffic classifier user-defined [ classifier-name ] [ slot slot-number [ cpu cpu-number ] ] In IRF mode: display traffic classifieruser-defined [ classifier-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display traffic behavior configuration. |
In standalone mode: display traffic behavioruser-defined [ behavior-name ] [ slot slot-number [ cpu cpu-number ] ] In IRF mode: display traffic behavioruser-defined [ behavior-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display QoS and ACL resource usage. |
In standalone mode: display qos-acl resource [ slot slot-number ] In IRF mode: display qos-acl resource [ chassis chassis-number slot slot-number ] |
Display QoS policy configuration. |
In standalone mode: display qos policy user-defined [ policy-name [ classifier classifier-name ] ] [ slot slot-number [ cpu cpu-number ] ] In IRF mode: display qos policyuser-defined [ policy-name [ classifier classifier-name ] ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display information about QoS policies applied to interfaces. |
In standalone mode: display qos policy interface [ interface-type interface-number ] [ slot slot-number [ cpu cpu-number ] | all ] [ inbound | outbound ] In IRF mode: display qos policy interface [ interface-type interface-number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] | all ] [ inbound | outbound ] |
Display information about QoS policies applied to user profiles. |
In standalone mode: display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ] In IRF mode: display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ] |
Display information about QoS policies applied to VLANs. |
In standalone mode: display qos vlan-policy { name policy-name | vlan vlan-id } [ slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ] In IRF mode: display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ] |
Display information about QoS policies applied globally. |
In standalone mode: display qos policy global [ slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ] In IRF mode: display qos policy global [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ] |
Display information about QoS policies applied to a control plane. |
In standalone mode: display qos policy control-plane slot slot-number [ cpu cpu-number ] In IRF mode: display qos policy control-plane chassis chassis-number slot slot-number [ cpu cpu-number ] |
Display information about the predefined QoS policy applied to the control plane. |
In standalone mode: display qos policy control-plane pre-defined [ slot slot-number [ cpu cpu-number ] ] In IRF mode: display qos policy control-plane pre-defined [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Clear the statistics of the QoS policy applied in a certain direction of a VLAN. |
reset qos vlan-policy [ vlan vlan-id ] [ inbound | outbound ] |
Clear the statistics for a QoS policy applied globally. |
reset qos policy global [ inbound | outbound ] |
Clear the statistics for the QoS policy applied to a control plane. |
In standalone mode: reset qos policy control-plane slot slot-number [ cpu cpu-number ] In IRF mode: reset qos policy control-plane chassis chassis-number slot slot-number [ cpu cpu-number ] |
The exclusive bandwidth on an interface is reserved for specific features and cannot be shared with other features. The amount of exclusive bandwidth is deducted from the interface bandwidth.
The exclusive bandwidth feature is mutually exclusive with the HQoS feature. If one feature has been configured on an interface, the other feature cannot be configured successfully.
Card category |
Cards |
CEPC |
CEPC-XP4LX, CEPC-XP24LX, CEPC-XP48RX, CEPC-CP4RX, CEPC-CP4RX-L, CEPC-CQ8L, CEPC-CQ16L1, CEPC-DQ2L1-G |
CSPEX |
CSPEX-1304X, CSPEX-1304S, CSPEX-1404X, CSPEX-1404S, CSPEX-1502X, CSPEX-1504X, CSPEX-1504S, CSPEX-1602X, CSPEX-1804X, CSPEX-1512X, CSPEX-1612X, CSPEX-1812X, CSPEX-1802XB, CSPEX-1802X, CSPEX-1812X-E, CSPEX-2304X-G, CSPEX-2304X-LG, CSPEX-2612X-E |
SPE |
RX-SPE200, RX-SPE200-E |
3. Set the exclusive bandwidth on the interface.
qos exclusive-bandwidth bandwidth-value
By default, no exclusive bandwidth is set on an interface.
Task |
Command |
Display exclusive bandwidth settings for interfaces. |
In standalone mode: display qos exclusive-bandwidth interface [ interface-type interface-number ] outbound [ slot slot-number [ cpu cpu-number ] ] In IRF mode: display qos exclusive-bandwidth interface [ interface-type interface-number ] outbound [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
By default, all subinterfaces of a main interface share and contend for the bandwidth of the main interface. Subinterfaces that carry key services cannot be guaranteed enough bandwidth. This feature allows subinterfaces of a physical interface or aggregate interface to exclusively use the specified amount of bandwidth.
The total channelized bandwidth of subinterfaces cannot exceed the actual bandwidth of the main interface plus 1 Mbps. The channelized bandwidth takes effect only in the outbound direction.
This feature is mutually exclusive with the exclusive bandwidth setting.
This feature is mutually exclusive with configuring the maximum reservable bandwidth for MPLS TE. For more information about configuring the maximum reservable bandwidth for MPLS TE, see MPLS TE configuration in MPLS Configuration Guide.
This feature is mutually exclusive with HQoS. For more information about HQoS, see ACL and QoS Configuration Guide.
2. Enter subinterface view.
interface interface-type interface-number.subnumber
3. Set the channelized bandwidth for the subinterface.
mode channel-bandwidth bandwidth-value
By default, the channelized bandwidth is not set for a subinterface.
Task |
Command |
Display interface channelization configuration. |
In standalone mode: display mode channel-bandwidth interface [ interface-type { interface-number | interface-number.subnumber } ] [ slot slot-number [ cpu cpu-number ] ] In IRF mode: display mode channel-bandwidth interface [ interface-type { interface-number | interface-number.subnumber } ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
About priority mapping
When a packet arrives, a device assigns a set of QoS priority parameters to the packet based on either of the following:
· A priority field carried in the packet.
· The port priority of the incoming port.
This process is called priority mapping. During this process, the device can modify the priority of the packet according to the priority mapping rules. The set of QoS priority parameters decides the scheduling priority and forwarding priority of the packet.
Priority mapping is implemented with priority maps and involves the following priorities:
· 802.11e priority.
· 802.1p priority.
· DSCP.
· EXP.
· IP precedence.
· Local precedence.
· Drop priority.
About priorities
Priorities include the following types: priorities carried in packets, and priorities locally assigned for scheduling only.
Packet-carried priorities include 802.1p priority, DSCP precedence, IP precedence, and EXP. These priorities have global significance and affect the forwarding priority of packets across the network. For more information about these priorities, see "Appendixes."
Locally assigned priorities only have local significance. They are assigned by the device only for scheduling. These priorities include the local precedence, drop priority, and user priority, as follows:
· Local precedence—Used for queuing. A local precedence value corresponds to an output queue. A packet with higher local precedence is assigned to a higher priority output queue to be preferentially scheduled.
· Drop priority—Used for making packet drop decisions. Packets with the highest drop priority are dropped preferentially.
· User priority—Precedence that the device automatically extracts from a priority field of the packet according to its forwarding path. It is a parameter for determining the scheduling priority and forwarding priority of the packet. The user priority represents the following items:
¡ The 802.1p priority for Layer 2 packets.
¡ The IP precedence for Layer 3 packets.
¡ The EXP for MPLS packets.
Priority maps
The device provides various types of priority maps. By looking through a priority map, the device decides which priority value to assign to a packet for subsequent packet processing.
The default priority maps (as shown in Appendix B Default priority maps) are available for priority mapping. They are adequate in most cases. If a default priority map cannot meet your requirements, you can modify the priority map as required.
You can configure priority mapping by using any of the following methods.
Configuring priority trust mode
In this method, you can configure a port to look up a trusted priority type (802.1p, for example) in incoming packets in the priority maps. Then, the system maps the trusted priority to the target priority types and values.
Changing port priority
If no packet priority is trusted, the port priority of the incoming port is used. By changing the port priority of a port, you change the priority of the incoming packets on the port.
Configuring a QoS policy containing the priority mapping (called primap) action with the primap command.
Priority mapping process
On receiving an Ethernet packet on a port, the switch marks the scheduling priorities (local precedence and drop precedence) for the Ethernet packet. This procedure is done according to the priority trust mode of the receiving port and the 802.1Q tagging status of the packet, as shown in Figure 3.
Figure 3 Priority mapping process for an Ethernet packet
The switch marks a received MPLS packet with a scheduling priority based on the priority trust mode and the packet EXP value, as shown in Figure 4.
Figure 4 Priority mapping process for an MPLS packet
For information about priority marking, see "Configuring priority marking."
You can configure a flexible priority map, the auto priority trust mode, and the port priority for a Layer 3 aggregate interface or subinterface if all member ports of the Layer 3 aggregate interface are on the following cards:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
The flexible priority map, the auto priority trust mode, and the port priority settings for the Layer 3 aggregate interface or subinterface takes priority over these settings on its member ports.
To configure priority mapping, perform the following tasks:
1. (Optional.) Configuring a priority map
¡ Configuring an uncolored priority map
¡ Configuring a colored priority map
¡ Configuring a flexible priority map
2. Configure a priority mapping method:
¡ Configuring a port to trust packet priority for priority mapping
¡ Changing the port priority of an interface
¡ Configuring primap
About priority maps
Table 1 shows the priority maps provided by the device. These priority maps can be colored or uncolored.
You can use colored priority maps if the packets are colored by traffic policing. You can use uncolored priority maps if the packets are not colored by traffic policing. For how traffic policing processes and colors packets, see "About traffic policing, GTS, and rate limit."
Priority map |
dot1p-dot1p |
802.1p-802.1p priority map. |
dot1p-dp |
802.1p-drop priority map. |
dot1p-dscp |
802.1p-DSCP priority map. |
dot1p-exp |
802.1p-EXP priority map. |
dot1p-lp |
802.1p-local priority map. |
dscp-dot1p |
DSCP-802.1p priority map. |
dscp-dp |
DSCP-drop priority map. |
dscp-dscp |
DSCP-DSCP priority map. |
dscp-exp |
DSCP-EXP priority map. |
dscp-lp |
DSCP-local priority map. |
exp-dot1p |
EXP-802.1p priority map. |
exp-dp |
EXP-drop priority map. |
exp-dscp |
EXP-DSCP priority map. |
exp-exp |
EXP-EXP priority map. |
exp-lp |
EXP-local priority map. |
lp-dot1p |
Local-802.1p priority map. |
lp-dp |
Local-drop priority map. |
lp-dscp |
Local-DSCP priority map. |
lp-exp |
Local-EXP priority map. |
lp-phb |
Local-PHB priority map. |
2. Enter priority map view.
qos map-table inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp }
3. Configure mappings for the priority map.
By default, the default priority maps are used. For more information, see "Uncolored priority maps."
2. Enter colored priority map view.
qos map-table color { green | yellow | red } { inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp } | outbound { dot1p-dot1p | dot1p-dscp | dot1p-exp | dscp-dot1p | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp | exp-exp } }
3. Configure mappings for the colored priority map.
By default, the default colored priority maps are used. For more information, see "Colored priority maps."
An uncolored or colored priority map takes effect on the device globally. A flexible priority map can be applied on a per-interface basis for controlling packet scheduling and forwarding more accurately. If you have configured a priority map and applied the flexible priority map to an interface, the flexible priority map takes priority on the interface.
2. Create a flexible priority map and enter its view.
qos map-table name map-table-name
3. Configure mappings for the flexible priority map.
{ dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp } import import-value-list export export-value color { green | red | yellow }
{ lp-dot1p | lp-dp | lp-dscp | lp-exp | lp-phb } import import-value-list color { green | red | yellow } export export-value
By default, no mapping is configured in a flexible priority map.
If you execute this command multiple times and enter the same input values for one priority map, the most recent configuration takes effect.
4. Return to system view.
5. Enter interface view.
6. Apply the flexible priority map to the interface.
qos apply map-table name map-table-name { inbound | outbound }
Only one priority map can be applied to one direction of an interface.
Only the following priority maps can be applied to the inbound direction of an interface:
¡ dot1p-dot1p
¡ dot1p-dp
¡ dot1p-dscp
¡ dot1p-exp
¡ dot1p-lp
¡ dscp-dot1p
¡ dscp-dp
¡ dscp-dscp
¡ dscp-exp
¡ dscp-lp
¡ exp-dot1p
¡ exp-dp
¡ exp-dscp
¡ exp-exp
¡ exp-lp
Only the following priority maps can be applied to the outbound direction of an interface:
¡ lp-dot1p
¡ lp-dp
¡ lp-dscp
¡ lp-exp
¡ lp-php
You can configure the device to trust a particular priority field carried in packets for priority mapping on ports or globally.
When you configure the trusted packet priority type on an interface, use the following available keywords:
· auto—Automatically selects the priority of each received packet according to packet type for mapping.
¡ For Layer 2 packets, 802.1p priority is used.
¡ For Layer 3 packets, IP or DSCP precedence is used.
¡ For MPLS packets, EXP is used.
· dot1p—Uses the 802.1p priority of received packets for mapping.
· dscp—Uses the DSCP precedence of received IP packets for mapping.
· exp—Uses the EXP value of received MPLS packets for mapping.
· inner-dot1p—Uses the 802.1p priority in the inner header of received QinQ packets for mapping.
Only the following cards support the dot1p, dscp, and inner-dot1p keywords:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
If you do not specify the override keyword, the device obtains the EXP value through priority mapping when an IP packet enters an MPLS network.
For Layer 3 packets, the outer 802.1p priority value is overwritten according to the priority trust mode, regardless of whether the override keyword is specified.
The qos trust dot1p or qos trust dscp command does not take effect on MPLS packets from the public network. The device uses the EXP value in the MPLS packets for priority mapping.
Only L2VE interfaces and L3VE interfaces on the following cards support the exp keyword:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
For information about L2VE interfaces and L3VE interfaces, see L2VPN access to L3VPN or IP backbone configuration in MPLS Configuration Guide.
3. Configure the trusted packet priority type.
qos trust { auto | dot1p | dscp | exp | inner-dot1p } [ override ]
By default, an interface trusts the port priority.
If the override keyword is configured, the priority derived through priority mapping overwrites the original priority carried in the packet.
If an interface does not trust any packet priority, the device uses its port priority to look for priority parameters for the incoming packets. By changing port priority, you can prioritize traffic received on different interfaces.
3. Set the port priority of the interface.
qos priority { dot1p | dscp | exp } priority-value
The default setting is 0.
Configuring primap
About primap
To reassign priority parameters for a traffic class according to a priority mapping table, configure a primap traffic behavior and associate it with the traffic class.
A primap action takes effect only when a QoS policy is applied to the following application destinations:
· Interface.
· VLANs.
· Globally.
· Control plane.
· User profile.
Configuring colored primap
2. Define a traffic class.
a. Create a traffic class and enter traffic class view.
b. Configure a match criterion.
c. Return to system view.
3. Define a traffic behavior.
a. Create a traffic behavior and enter traffic behavior view.
b. Configure a CAR action.
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
By default, no CAR action is configured.
c. Configure the action of assigning priority values to packets using a specified colored priority mapping table.
primap pre-defined color { dot11e-lp | dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dot1p-rpr | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | dscp-rpr | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp | exp-rpr | ippre-rpr | lp-dot11e | lp-dot1p | lp-dp | lp-dscp | lp-exp | lp-lp | lp-phb | up-dot1p | up-dp | up-dscp | up-exp | up-fc | up-lp | up-rpr | up-up }
By default, no priority mapping action is configured.
d. (Optional.) Configure the action of assigning drop priority to packets according to packet color.
primap color-map-dp
The packet color-to-drop priority mappings are fixed to red to 2, yellow to 1, and green to 0.
This action can be used only in the outbound direction.
e. Return to system view.
4. Define a QoS policy.
a. Create a QoS policy and enter QoS policy view.
b. Associate the traffic behavior with the traffic class.
5. Apply the QoS policy.
For more information, see "Applying the QoS policy."
By default, no QoS policy is applied.
Task |
Command |
Display priority map configuration. |
display qos map-table inbound [ dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp ]] |
Display colored priority map configuration. |
display qos map-table color [ green | yellow | red ]{ inbound [ dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp ] | outbound [ dot1p-dot1p | dot1p-dscp | dot1p-exp | dscp-dot1p | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp | exp-exp ] } |
Display flexible priority map configuration. |
display qos map-table name [ map-table-name ] |
Display flexible priority maps applied to interfaces. |
In standalone mode: display qos map-table interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ] |
Display the trusted packet priority type on a port. |
display qos trust interface [ interface-type interface-number ] |
As shown in Figure 5:
· The 802.1p priority of traffic from Device A to Device C is 3.
· The 802.1p priority of traffic from Device B to Device C is 1.
Configure Device C to preferentially process packets from Device A to the server when Ten-GigabitEthernet 3/1/3 of Device C is congested.
# Assign port priority to Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2. Make sure the following requirements are met:
· The priority of Ten-GigabitEthernet 3/1/1 is higher than that of Ten-GigabitEthernet 3/1/2.
· No trusted packet priority type is configured on Ten-GigabitEthernet 3/1/1 or Ten-GigabitEthernet 3/1/2.
<DeviceC> system-view
[DeviceC] interface ten-gigabitethernet 3/1/1
[DeviceC-Ten-GigabitEthernet3/1/1] qos priority 3
[DeviceC-Ten-GigabitEthernet3/1/1] quit
[DeviceC] interface ten-gigabitethernet 3/1/2
[DeviceC-Ten-GigabitEthernet3/1/2] qos priority 1
[DeviceC-Ten-GigabitEthernet3/1/2] quit
As shown in Figure 6:
· The Marketing department connects to Ten-GigabitEthernet 3/1/1 of Device, which sets the 802.1p priority of traffic from the Marketing department to 3.
· The R&D department connects to Ten-GigabitEthernet 3/1/2 of Device, which sets the 802.1p priority of traffic from the R&D department to 4.
· The Management department connects to Ten-GigabitEthernet 3/1/3 of Device, which sets the 802.1p priority of traffic from the Management department to 5.
Configure port priority, 802.1p-to-local mapping table, and priority marking to implement the plan as described in Table 2.
Traffic destination |
Traffic priority order |
Queuing plan |
Traffic source |
Output queue |
Queue priority |
Public servers |
R&D department > Management department > Marketing department |
R&D department |
6 |
High |
Management department |
4 |
Medium |
2 |
Low |
Internet |
Management department > Marketing department > R&D department |
R&D department |
2 |
Low |
6 |
High |
3 |
Medium |
1. Configure trusting port priority:
# Set the port priority of Ten-GigabitEthernet 3/1/1 to 3.
[Device] interface ten-gigabitethernet 3/1/1
[Device-Ten-GigabitEthernet3/1/1] qos priority 3
[Device-Ten-GigabitEthernet3/1/1] quit
# Set the port priority of Ten-GigabitEthernet 3/1/2 to 4.
[Device] interface ten-gigabitethernet 3/1/2
[Device-Ten-GigabitEthernet3/1/2] qos priority 4
[Device-Ten-GigabitEthernet3/1/2] quit
# Set the port priority of Ten-GigabitEthernet 3/1/3 to 5.
[Device] interface ten-gigabitethernet 3/1/3
[Device-Ten-GigabitEthernet3/1/3] qos priority 5
[Device-Ten-GigabitEthernet3/1/3] quit
2. Configure the 802.1p-to-local mapping table to map 802.1p priority values 3, 4, and 5 to local precedence values 2, 6, and 4.
This guarantees the R&D department, Management department, and Marketing department decreased priorities to access the public servers.
[Device-maptbl-dot1p-lp] quit
3. Map the local precedence values 6 and 2 to local precedence values 2 and 3 and keep local precedence value 4 unchanged.
This guarantees the Management department, Marketing department, and R&D department decreased priorities to access the Internet.
[Device] traffic classifier rd
[Device-classifier-rd] if-match local-precedence 6
[Device-classifier-rd] quit
[Device] traffic classifier market
[Device-classifier-market] if-match local-precedence 2
[Device-classifier-market] quit
[Device] traffic behavior rd
[Device-behavior-rd] remark local-precedence 2
[Device-behavior-rd] quit
[Device-behavior-market] remark local-precedence 3
[Device-behavior-market] quit
[Device] qos policy policy1
[Device-qospolicy-policy1] classifier rd behavior rd
[Device-qospolicy-policy1] classifier market behavior market
[Device-qospolicy-policy1] quit
[Device] interface ten-gigabitethernet 3/1/5
[Device-Ten-GigabitEthernet3/1/5] qos apply policy policy1 outbound
Traffic limit helps assign network resources (including bandwidth) and increase network performance. For example, you can configure a flow to use only the resources committed to it in a certain time range. This avoids network congestion caused by burst traffic.
Traffic policing, Generic Traffic Shaping (GTS), and rate limit control the traffic rate and resource usage according to traffic specifications. You can use token buckets for evaluating traffic specifications.
Token bucket features
A token bucket is analogous to a container that holds a certain number of tokens. Each token represents a certain forwarding capacity. The system puts tokens into the bucket at a constant rate. When the token bucket is full, the extra tokens cause the token bucket to overflow.
Evaluating traffic with the token bucket
A token bucket mechanism evaluates traffic by looking at the number of tokens in the bucket. If the number of tokens in the bucket is enough for forwarding the packets:
· The traffic conforms to the specification (called conforming traffic).
· The corresponding tokens are taken away from the bucket.
Otherwise, the traffic does not conform to the specification (called excess traffic).
A token bucket has the following configurable parameters:
· Mean rate at which tokens are put into the bucket, which is the permitted average rate of traffic. It is usually set to the committed information rate (CIR).
· Burst size or the capacity of the token bucket. It is the maximum traffic size permitted in each burst. It is usually set to the committed burst size (CBS). The set burst size must be greater than the maximum packet size.
Each arriving packet is evaluated.
Complicated evaluation
You can set two token buckets, bucket C and bucket E, to evaluate traffic in a more complicated environment and achieve more policing flexibility. The following are main mechanisms used for complicated evaluation:
· Single rate two color—Uses one token bucket and the following parameters:
¡ CIR—Rate at which tokens are put into bucket C. It sets the average packet transmission or forwarding rate allowed by bucket C.
¡ CBS—Size of bucket C, which specifies the transient burst of traffic that bucket C can forward.
When a packet arrives, the following rules apply:
¡ If bucket C has enough tokens to forward the packet, the packet is colored green.
¡ Otherwise, the packet is colored red.
· Single rate three color—Uses two token buckets and the following parameters:
¡ EBS—Size of bucket E minus size of bucket C, which specifies the transient burst of traffic that bucket E can forward. The EBS cannot be 0. The size of E bucket is the sum of the CBS and EBS.
¡ If bucket C has enough tokens, the packet is colored green.
¡ If bucket C does not have enough tokens but bucket E has enough tokens, the packet is colored yellow.
¡ If neither bucket C nor bucket E has sufficient tokens, the packet is colored red.
· Two rate three color—Uses two token buckets and the following parameters:
¡ PIR—Rate at which tokens are put into bucket E, which specifies the average packet transmission or forwarding rate allowed by bucket E.
¡ EBS—Size of bucket E, which specifies the transient burst of traffic that bucket E can forward.
Traffic policing
A typical application of traffic policing is to supervise the specification of traffic entering a network and limit it within a reasonable range. Another application is to "discipline" the extra traffic to prevent aggressive use of network resources by an application. For example, you can limit bandwidth for HTTP packets to less than 50% of the total. If the traffic of a session exceeds the limit, traffic policing can drop the packets or re-set the priority of the packets. Figure 7 shows an example of policing outbound traffic on an interface.
Traffic policing can classify the policed traffic and take predefined policing actions on each packet depending on the evaluation result:
· Forwarding the packet.
· Dropping the packet.
· Forwarding the packet with its precedence re-marked.
· Delivering the packet to next-level traffic policing with its precedence re-marked.
GTS
GTS limits the traffic rate by buffering exceeding traffic. You can use GTS to adapt the traffic output rate on a device to the input traffic rate of its connected device to avoid packet loss.
The differences between traffic policing and GTS are as follows:
· Packets to be dropped with traffic policing are retained in a buffer or queue with GTS, as shown in Figure 8. When enough tokens are in the token bucket, the buffered packets are sent at an even rate.
· GTS can result in additional delay and traffic policing does not.
For example, in Figure 9, Device B performs traffic policing on packets from Device A and drops packets exceeding the limit. To avoid packet loss, you can perform GTS on the outgoing interface of Device A so that packets exceeding the limit are cached in Device A. Once resources are released, GTS takes out the cached packets and sends them out.
Rate limit
The rate limit of an interface specifies the maximum rate for forwarding packets (excluding critical packets).
Rate limit also uses token buckets for traffic control. When rate limit is configured on an interface, a token bucket handles all packets to be sent through the interface for rate limiting. If enough tokens are in the token bucket, packets can be forwarded. Otherwise, packets are put into QoS queues for congestion management. In this way, the traffic passing the interface is controlled.
Figure 10 Rate limit implementation
The token bucket mechanism limits traffic rate when accommodating bursts. It allows bursty traffic to be transmitted if enough tokens are available. If tokens are scarce, packets cannot be transmitted until efficient tokens are generated in the token bucket. It restricts the traffic rate to the rate for generating tokens.
Rate limit controls the total rate of all packets on an interface or PW. It is easier to use than traffic policing and GTS in controlling the total traffic rate.
You can configure traffic policing by using the MQC approach or the non-MQC approach.
You can configure the following types of traffic policing by using the non-MQC approach:
· Traffic policing for all traffic.
· Traffic policing for a user profile.
· Traffic policing for a control plane.
· Traffic policing for a PW.
If traffic policing is configured by using both the MQC approach and non-MQC approach, the configuration in MQC approach takes effect.
A traffic policing action takes effect only when a QoS policy is applied to the following application destinations:
· Interface.
· VLANs.
· Globally.
· Control plane.
· User profile.
Only the default action is supported for green packets and yellow packets. Only the discard and pass actions are supported for red packets.
For a QoS policy applied to a control plane, the supported value range for the CIR is 8 to 10000 kbps.
For more information about the if-match command, see ACL and QoS Command Reference.
b. Configure a traffic policing action.
¡ In absolute value:
By default, no traffic policing action is configured.
b. Associate the traffic class with the traffic behavior in the QoS policy.
This feature is mutually exclusive with any of the following configurations on a Layer 3 aggregate interface:
· Bind the interface to a VSI by using the xconnect vsi command.
· Bind the interface to a cross-connect by using the ac interface command.
· Traffic policing in a user profile applied to an interface.
This feature is mutually exclusive with any of the following configurations on a Layer 3 Ethernet interface:
· Enable packet statistics for a Layer 3 interface that acts as an AC by using the ac statistics enable command.
In standard system operating mode, this feature is mutually exclusive with the ip subscriber enable command (used to enable IPoE on the interface and configure an IPoE access mode for users. For more information about system operating modes, see device management in Fundamentals Configuration Guide.
Only Layer 3 aggregate interfaces and Layer 3 Ethernet interfaces on the following cards support this feature:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
Before configuring a percentage-based CAR policy, use the bandwidth command to configure the expected bandwidth of the interface. For more information about the bandwidth command, see Ethernet interface commands in Interface Command Reference.
A CAR policy does not take effect on data packets (for example, ICMP probe packets of NQA) of the VLAN interfaces, Layer 3 aggregate interfaces, Layer 3 aggregate subinterfaces, Layer 3 Ethernet interfaces, and Layer 3 Ethernet subinterfaces on the following cards:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
3. Configure a CAR policy for all traffic on the interface.
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
¡ In percentage:
qos car { inbound | outbound } any percent cir cir-percent [ cbs cbs-time [ ebs ebs-time ] ]
qos car { inbound | outbound } any percent cir cir-percent [ cbs cbs-time ] pir pir-percent [ ebs ebs-time ]
By default, no CAR policy is configured on an interface.
A user profile can take effect in either of the following methods:
· Applying a user profile directly to an interface at the CLI. The CAR policy configured in user profile view policies traffic on the interface.
· After a user passes authentication, the authentication server sends the name of the user profile associated with the user to the device. The CAR policy configured in user profile view policies traffic of the user profile's online users. When any user of the user profile logs in, the authentication server automatically applies the CAR policy configured for the user profile to the user. When the user logs off, the system automatically removes the CAR policy without manual intervention.
3. Configure a CAR policy for the user profile.
By default, no CAR policy is configured for a user profile.
You can configure the following types of traffic policing for a control plane:
· Traffic policing for all traffic—Polices all control plane traffic.
· Online user-based traffic policing—Polices the control plane traffic from all online users.
· ACL whitelist-based traffic policing—Polices the control plane traffic that matches the ACL whitelist by using the system-defined traffic policing parameters.
If multiple types of traffic policing for a control plane are configured, they take effect at the same time. When the control plane is congested, the traffic that matches the ACL whitelist is preferentially sent to the control plane.
For more information about control planes, see "Applying the QoS policy to a control plane." For more information about ACL whitelists, see "Configuring ACLs."
Only the incoming traffic of the control plane (traffic received by the control plane) can be policed.
Only the following cards support this feature:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
In standalone mode:
In IRF mode:
3. (Optional.) Enable ACL whitelist-based traffic policing.
qos car whitelist [ ipv6 ] enable [ enhancement ]
qos car whitelist mac enable
By default, ACL whitelist-based traffic policing is enabled, and the device uses the system-defined rate limit values to police matching traffic.
4. Configure a CAR policy for the control plane.
¡ Configure a CAR policy for all traffic.
qos car any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
By default, no CAR policy is configured for all traffic.
¡ Configure an online user-based CAR policy.
qos car user cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car user cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
By default, no online user-based CAR policy is configured.
2. Enter PW view.
¡ Execute the following commands in sequence to enter cross-connect PW view:
xconnect-group group-name
connection connection-name
peer ip-address pw-id pw-id [ ignore-standby-state | in-label label-value out-label label-value ] [ admin | pw-class class-name | tunnel-policy tunnel-policy-name ] *
¡ Execute the following commands in sequence to enter VSI LDP PW view:
vsi vsi-name [ hub-spoke ]
pwsignaling ldp
peer ip-address [ pw-id pw-id ] [ hub | no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] *
¡ Execute the following commands in sequence to enter VSI static PW view:
pwsignaling static
peer ip-address [ pw-id pw-id ] [ in-label label-value out-label label-value [ hub | no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] * ]
3. Configure a policy for the PW.
qos car outbound any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
qos car outbound any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
By default, no CAR policy is configured for a PW.
After attack prevention is enabled for a protocol, the device places attack protocol packets in an anti-attack queue and uses a fixed rate limit value to limit the packets of that protocol sent from a card to the CPU. This task allows you to configure a rate limit value for each protocol in control plane view.
You can also configure a rate limit value for an interface to limit the packets of all protocols to the CPU.
For this feature to take effect, first enable attack prevention for the specified protocol. You can use the following commands to enable attack prevention for different protocols:
· tcp anti-syn-flood interface-based enable
· udp anti-flood interface-based enable
· dhcp interface-rate-suppression enable
· ipv6 dhcp interface-rate-suppression enable
· arp attack-suppression enable per-interface
· ipv6 nd attack-suppression enable per-interface
· igmp attack-suppression per-interface enable
· mld attack-suppression per-interface enable
· pppoe-server connection chasten per-interface
In standalone mode:
In IRF mode:
3. Configure a rate limit value for a protocol.
qos car anti-attack protocol cir committed-information-rate
By default, the device uses a fixed rate limit value to limit the packets of a protocol.
5. (Optional.) Enter interface view.
6. (Optional.) Configure a rate limit value for an interface to limit the packets of all protocols to the CPU.
qos car inbound host rate-limit packet-per-second
By default, the device does not include the interframe gap when calculating the packet length for traffic policing. This feature allows the device to include a 20-byte interframe gap in calculating the packet length.
To ensure accuracy for traffic policing, enable this feature if the size of the transmitted packets is small.
As a best practice to save computing resources, disable this feature if the size of the transmitted packets is large.
This feature takes effect only on Layer 3 Ethernet interfaces and Layer 3 aggregate interfaces.
This feature does not take effect on mirrored packets for port mirroring.
2. Include the physical layer header in calculating the packet length for traffic policing.
qos overhead layer physical
By default, the device calculates the packet length for traffic policing based on the data link layer frame (including the CRC).
Configuring GTS
Configuring queue-based GTS
Queue-based GTS takes effect only on outbound traffic.
SPEX-1204 cards do not support queue-based GTS.
You can configure queue-based GTS for a Layer 3 aggregate interface or subinterface if all member ports of the Layer 3 aggregate interface are on the following cards:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
An interface on the following cards cannot be configured with both a queue scheduling profile with WRR queuing and a queue-based GTS configuration:
Card category |
Cards |
CSPC |
CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E |
CSPEX |
CSPEX-1104-E |
SPEX |
SPEX-1204 |
3. Configure GTS for a queue.
¡ qos gts queue queue-id cir committed-information-rate [ cbs committed-burst-size ]
By default, GTS is not configured on an interface.
When a user group profile is configured, you can perform GTS based on home users. After a user passes authentication, the authentication server sends the name of the user group profile associated with the user to the device. When any home user of the user group profile logs in, the authentication server automatically applies the GTS parameters configured for the user group profile to the user. When the user logs off, the system automatically removes the GTS configuration without manual intervention.
If you have configured rate limiting by using the qos user-queue command for a user profile and associated the user profile with a user group profile, the queue-length queue-length option in GTS cannot take effect for the user group profile. For more information about the qos user-queue command, see user profile commands in BRAS Services Command Reference.
Card category |
Cards |
CEPC |
CSPEX |
SPE |
2. Enter user group profile view.
user-group-profile profile-name
3. Configure GTS for the user group profile.
qos gts [ inbound ] any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ]
qos gts [ inbound ] anycir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ queue-length queue-length ]
By default, GTS is not configured for a user group profile.
The configuration in user group profile view takes effect when the home users come online.
If you do not specify the inbound keyword, this command shapes outgoing packets (packets received by online users).
Configuring GTS for a session group profile
When a session group profile is configured, you can perform GTS based on home users. After a user passes authentication, the authentication server sends the name of the session group profile associated with the user to the device. When any home user of the session group profile logs in, the authentication server automatically applies the GTS parameters configured for the session group profile to the user. When the user logs off, the system automatically removes the GTS configuration without manual intervention.
Card category |
Cards |
CEPC |
CSPEX |
SPE |
The GTS configuration in a session group profile takes effect only on outgoing packets.
2. Enter session group profile view.
user-profile profile-name type session-group
3. Configure GTS for the session group profile.
qos gts { any | queue queue-id } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ]
qos gts { any | queue queue-id } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ queue-length queue-length ]
By default, GTS is not configured for a session group profile.
The configuration in session group profile view takes effect when the home users come online.
Configuring the rate limit
Configuring the rate limit for an interface
Before configuring percentage-based rate limit, use the bandwidth command to configure the expected bandwidth of the interface. The actual rate limit is the value of the cir cir-percent option multiplied by the expected bandwidth of the interface.
Only the following cards support inbound rate limiting:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
You can configure the rate limit on a Layer 3 aggregate interface or subinterface.
Prodecure
3. Configure the rate limit for the interface.
¡ In percentage:
qos lr { inbound | outbound } percent cir cir-percent [ cbs cbs-time ]
By default, no rate limit is configured on an interface.
Limiting the traffic rates on Layer 3 aggregation member ports based on their physical bandwidth
If you apply a user profile containing traffic policing settings to a Layer 3 aggregate interface, the member ports of the aggregate interface are rate limited by default as follows:
· If all member ports belong to one chip, the total traffic rate on them cannot exceed the rate limit configured for the aggregate interface.
· If the member ports belong to different chips, member ports on one chip cannot exceed the rate limit configured for the aggregate interface. In this case, the total traffic rate on all member ports can exceed the rate limit configured for the aggregate interface.
This feature limits the traffic rates on the member ports based on their physical bandwidth when all member ports belong to different chips, making sure the total traffic rate on them cannot exceed the rate limit configured for the aggregate interface.
Suppose you apply a user profile with a rate limit of 100 Mbps to a Layer 3 aggregate interface, and the aggregate interface contains four member ports (ports A, B, C, and D) that have 1 Gbps bandwidth. If member ports A and B belong to chip 1, member port C belongs to chip 2, and member port D belongs to chip 3:
· The total traffic rate on member ports A and B can reach 50 Mbps.
· The traffic rate on member port C can reach 25 Mbps.
· The traffic rate on member port D can reach 25 Mbps.
You can view the rate limit value for each member port by using the display qos user-profile-car member-link-scheduler distribute command.
This feature takes effect on both the inbound and outbound directions of Layer 3 aggregate interfaces.
2. Enter Layer 3 aggregate interface view.
3. Limit the traffic rates on the member ports based on their physical bandwidth.
By default, the member ports of a Layer 3 aggregate interface are not rate limited based on their physical bandwidth.
Configuring traffic permission by using the MQC approach
About traffic permission
Traffic permission allows matching traffic to pass through without performing rate limiting and accounting on the traffic.
The device supports the following application destinations for traffic permission:
· Interface.
· VLANs.
· Globally.
· Control plane.
· User profile.
2. Enter traffic behavior view.
3. Configure the traffic permission action.
free account
By default, no traffic permission action is configured.
Display and maintenance commands for traffic policing, GTS, and rate limit
Task |
Command |
Display ACL rules in the ACL whitelist. |
In standalone mode: display acl whitelist [ ipv6 ] slot slot-number [ cpu cpu-number ] In IRF mode: display acl whitelist [ ipv6 ] chassis chassis-number slot slot-number [ cpu cpu-number ] |
Display ACL whitelist-based control plane CAR configuration and statistics. |
In standalone mode: display qos car control-plane whitelist [ ipv6 | mac ] slot slot-number [ cpu cpu-number ] In IRF mode: display qos car control-plane whitelist [ ipv6 | mac ] chassis chassis-number slot slot-number [ cpu cpu-number ] |
Display CAR configuration and statistics on an interface. |
In standalone mode: display qos car interface [ interface-type interface-number [ slot slot-number ] ] In IRF mode: display qos car interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ] |
Display CAR configuration and statistics on a PW. |
display qos car l2vpn-pw [ peer ip-address pw-id pw-id ] |
Display CAR configuration and statistics for attack protocol packets. |
In standalone mode: display qos control-plane anti-attack slot slot-num [ cpu cpu-number ] In IRF mode: display qos control-plane anti-attack chassis chassis-number slot slot-number [ cpu cpu-number ] |
In standalone mode: display qos-acl resource [ slot slot-number [ cpu cpu-number ] ] In IRF mode: display qos-acl resource [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
display traffic behavior user-defined [ behavior-name ] |
Display GTS configuration and statistics for interfaces. |
In standalone mode: display qos gts interface [ interface-type interface-number [ slot slot-number ] ] In IRF mode: display qos gts interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ] |
Display rate limit configuration and statistics for interfaces or PWs. |
In standalone mode: display qos lr interface [ interface-type interface-number [ slot slot-number ] ] In IRF mode: display qos lr interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ] |
Display the rate limit value for each member port on a Layer 3 aggregate interface applied with a user profile or CAR policy. |
display qos user-profile-car member-link-scheduler distribute interface [ route-aggregation interface-number ] |
ClearACL whitelist-based control plane CAR statistics. |
In standalone mode: reset qos car control-plane whitelist [ ipv6 | mac ] slot slot-number [ cpu cpu-number ] In IRF mode: reset qos car control-plane whitelist [ ipv6 | mac ] chassis chassis-number slot slot-number [ cpu cpu-number ] |
Clear QoS statistics for PWs. |
reset qos statistics l2vpn-pw [ peer ip-address pw-id pw-id ] |
Clear traffic statistics for attack protocol packets. |
In standalone mode: reset qos control-plane anti-attack [ protocol ] slot slot-number [ cpu cpu-number ] In IRF mode: reset qos control-plane anti-attack [ protocol ] chassis chassis-number slot slot-number [ cpu cpu-number ] |
Traffic policing, GTS, and rate limit configuration examples
Example: Configuring traffic policing
As shown in Figure 11:
· The server, Host A, and Host B can access the Internet through Device A and Device B.
· The server, Host A, and Ten-GigabitEthernet 3/1/1 of Device A are in the same network segment.
· Host B and Ten-GigabitEthernet 3/1/2 of Device A are in the same network segment.
Perform traffic control for the packets that Ten-GigabitEthernet 3/1/1 of Device A receives from the server and Host A using the following guidelines:
· Limit the rate of packets from the server to 102400 kbps. When the traffic rate is below 54 kbps, the traffic is forwarded. When the traffic rate exceeds 102400 kbps, the excess packets are marked with IP precedence 0 and then forwarded.
· Limit the rate of packets from Host A to 25600 kbps. When the traffic rate is below 25600 kbps, the traffic is forwarded. When the traffic rate exceeds 8 kbps, the excess packets are dropped.
Perform traffic control on Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 of Device B using the following guidelines:
· Limit the incoming traffic rate on Ten-GigabitEthernet 3/1/1 to 204800 kbps, and the excess packets are dropped.
· Limit the outgoing traffic rate on Ten-GigabitEthernet 3/1/2 to 102400 kbps, and the excess packets are dropped.
4. Configure Router A:
# Configure ACLs to permit the packets from the server and Host A.
[RouterA] acl basic 2001
[RouterA-acl-ipv4-basic-2001] rule permit source 1.1.1.1 0
[RouterA-acl-ipv4-basic-2001] quit
[RouterA] acl basic 2002
[RouterA-acl-ipv4-basic-2002] rule permit source 1.1.1.2 0
[RouterA-acl-ipv4-basic-2002] quit
# Create a traffic class named server, and use ACL 2001 as the match criterion.
[RouterA] traffic classifier server
[RouterA-classifier-server] if-match acl 2001
[RouterA-classifier-server] quit
# Create a traffic class named host, and use ACL 2002 as the match criterion.
[RouterA] traffic classifier host
[RouterA-classifier-host] if-match acl 2002
[RouterA-classifier-host] quit
# Create a traffic behavior named server, and configure a traffic policing action (CIR 102400 kbps).
[RouterA] traffic behavior server
[RouterA-behavior-server] car cir 102400
[RouterA-behavior-server] quit
# Create a traffic behavior named host, and configure a traffic policing action (CIR 25600 kbps).
[RouterA] traffic behavior host
[RouterA-behavior-host] car cir 25600
[RouterA-behavior-host] quit
# Create a QoS policy named car, and associate traffic classes server and host with traffic behaviors server and host in the QoS policy, respectively.
[RouterA] qos policy car
[RouterA-qospolicy-car] classifier server behavior server
[RouterA-qospolicy-car] classifier host behavior host
[RouterA-qospolicy-car] quit
# Apply QoS policy car to the inbound direction of GigabitEthernet 1/0/1.
[RouterA-GigabitEthernet1/0/1] qos apply policy car inbound
5. Configure Router B:
# Create ACL 3001, and configure a rule to match HTTP packets.
<RouterB> system-view
[RouterB] acl advanced 3001
[RouterB-acl-ipv4-adv-3001] rule permit tcp destination-port eq 80
[RouterB-acl-ipv4-adv-3001] quit
# Create a traffic class named http, and use ACL 3001 as a match criterion.
[RouterB] traffic classifier http
[RouterB-classifier-http] if-match acl 3001
[RouterB-classifier-http] quit
# Create a traffic class named class, and configure the traffic class to match all packets.
[RouterB] traffic classifier class
[RouterB-classifier-class] if-match any
[RouterB-classifier-class] quit
# Create a traffic behavior named car_inbound, and configure a traffic policing action (CIR 204800 kbps).
[RouterB] traffic behavior car_inbound
[RouterB-behavior-car_inbound] car cir 204800
[RouterB-behavior-car_inbound] quit
# Create a traffic behavior named car_outbound, and configure a traffic policing action (CIR 102400 kbps).
[RouterB] traffic behavior car_outbound
[RouterB-behavior-car_outbound] car cir 102400
[RouterB-behavior-car_outbound] quit
# Create a QoS policy named car_inbound, and associate traffic class class with traffic behavior car_inbound in the QoS policy.
[RouterB] qos policy car_inbound
[RouterB-qospolicy-car_inbound] classifier class behavior car_inbound
[RouterB-qospolicy-car_inbound] quit
# Create a QoS policy named car_outbound, and associate traffic class http with traffic behavior car_outbound in the QoS policy.
[RouterB] qos policy car_outbound
[RouterB-qospolicy-car_outbound] classifier http behavior car_outbound
[RouterB-qospolicy-car_outbound] quit
# Apply QoS policy car_inbound to the inbound direction of Ten-GigabitEthernet 3/1/1.
[RouterB] interface ten-gigabitethernet 3/1/1
[RouterB-Ten-GigabitEthernet3/1/1] qos apply policy car_inbound inbound
# Apply QoS policy car_outbound to the outbound direction of Ten-GigabitEthernet 3/1/2.
[RouterB] interface ten-gigabitethernet 3/1/2
[RouterB-Ten-GigabitEthernet3/1/2] qos apply policy car_outbound outbound
Configuring hardware congestion management
About hardware congestion management
Cause, negative results, and countermeasure of congestion
Congestion occurs on a link or node when traffic size exceeds the processing capability of the link or node. It is typical of a statistical multiplexing network and can be caused by link failures, insufficient resources, and various other causes.
Figure 12 shows two typical congestion scenarios.
Figure 12 Traffic congestion scenarios
Congestion produces the following negative results:
· Increased delay and jitter during packet transmission.
· Decreased network throughput and resource use efficiency.
· Network resource (memory, in particular) exhaustion and even system breakdown.
Congestion is unavoidable in switched networks and multiuser application environments. To improve the service performance of your network, take measures to manage and control it.
The key to congestion management is defining a resource dispatching policy to prioritize packets for forwarding when congestion occurs.
Congestion management methods
Congestion management uses queuing and scheduling algorithms to classify and sort traffic leaving a port.
The device supports the following queuing mechanisms:
· SP.
· WRR.
· WFQ.
· CBQ.
SP queuing
SP queuing is designed for mission-critical applications that require preferential service to reduce the response delay when congestion occurs.
In Figure 13, SP queuing classifies eight queues on a port into eight classes, numbered 7 to 0 in descending priority order.
SP queuing schedules the eight queues in the descending order of priority. SP queuing sends packets in the queue with the highest priority first. When the queue with the highest priority is empty, it sends packets in the queue with the second highest priority, and so on. You can assign mission-critical packets to a high priority queue to make sure they are always served first. Common service packets can be assigned to low priority queues to be transmitted when high priority queues are empty.
The disadvantage of SP queuing is that packets in the lower priority queues cannot be transmitted if packets exist in the higher priority queues. In the worst case, lower priority traffic might never get serviced.
WRR queuing
WRR queuing schedules all the queues in turn to ensure that every queue is served for a certain time, as shown in Figure 14.
Assume a port provides eight output queues. WRR assigns each queue a weight value (represented by w7, w6, w5, w4, w3, w2, w1, or w0). The weight value of a queue decides the proportion of resources assigned to the queue. On a 100 Mbps port, you can set the weight values to 50, 30, 10, 10, 50, 30, 10, and 10 for w7 through w0. In this way, the queue with the lowest priority can get a minimum of 5 Mbps of bandwidth. WRR solves the problem that SP queuing might fail to serve packets in low-priority queues for a long time.
Another advantage of WRR queuing is that when the queues are scheduled in turn, the service time for each queue is not fixed. If a queue is empty, the next queue will be scheduled immediately. This improves bandwidth resource use efficiency.
WRR queuing includes the following types:
· Basic WRR queuing—Contains multiple queues. You can set the weight for each queue, and WRR schedules these queues based on the user-defined parameters in a round robin manner.
· Group-based WRR queuing—All the queues are scheduled by WRR. You can divide output queues to WRR priority queue group 1 and WRR priority queue group 2. Round robin queue scheduling is performed for group 1 first. If group 1 is empty, round robin queue scheduling is performed for group 2.
Only WRR group 1 is supported in the current software version.
On an interface enabled with group-based WRR queuing, you can assign queues to the SP group. Queues in the SP group are scheduled with SP. The SP group has higher scheduling priority than the WRR groups.
WFQ queuing
Figure 15 WFQ queuing
WFQ is similar to WRR. WFQ queuing includes basic WFQ queuing and group-based WFQ queuing.
On an interface with group-based WFQ queuing enabled, you can also assign queues to the SP group. Queues in the SP group are scheduled with SP. The difference is that WFQ enables you to set guaranteed bandwidth that a WFQ queue can get during congestion.
CBQ queuing
Figure 16 CBQ
Class-based queuing (CBQ) extends WFQ by supporting user-defined classes and assign a FIFO queue to each class. When network congestion occurs, CBQ uses user-defined traffic match criteria to enqueue packets. Before packets are enqueued, congestion avoidance actions, such as tail drop or WRED and bandwidth restriction check, are performed. When being dequeued, packets are scheduled by WFQ.
CBQ provides the following queues:
· Low Latency Queuing (LLQ)—An EF queue that preferentially transmits delay-sensitive flows like voice packets. To reduce the delay of the other queues except the priority queue, LLQ assigns the maximum available bandwidth to each priority class. The bandwidth value polices traffic during congestion. When no congestion is present, a priority class can use more than the bandwidth assigned to it. During congestion, the packets of each priority class exceeding the assigned bandwidth are discarded.
· Bandwidth queuing (BQ)—An AF queue. The BQ provides guaranteed bandwidth for AF traffic, and schedules the AF classes proportionally.
· WFQ queue—The queue transmits the BE traffic by using the remaining interface bandwidth.
The system matches packets with classification rules in the following order:
· Match packets with classes in the configuration order.
· Match packets with classification rules in a class in the configuration order.
Configuring CBQ
Restrictions and guidelines for CBQ configuration
In a traffic behavior, only one of the following queuing actions can be configured: AF, EF, SP, and WFQ.
You can configure CBQ on a Layer 3 aggregate interface or subinterface if all member ports of the Layer 3 aggregate interface are on the following cards:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
Configure AF and the minimum guaranteed bandwidth
· You can apply this traffic behavior only to the outgoing traffic of an interface.
· You cannot configure the queue af command together with the queue ef or queue wfq command in the same traffic behavior.
· If the total bandwidth for EF, AF and BE traffic exceeds the interface bandwidth, CBQ cannot work as configured.
· The display qos queue-statistics interface command cannot display queue-based traffic statistics for a QoS policy that contains a CBQ action.
1. Enter system view.
if-match match-criteria
By default, no match criterion is configured.
For more information about configuring match criteria, see ACL and QoS Command Reference.
b. Configure AF and the minimum guaranteed bandwidth.
queue af bandwidth { bandwidth [ pir peak-information-rate ] | pct percentage }
By default, AF is not configured.
Traffic between the minimum guaranteed bandwidth and PIR is scheduled by using WFQ.
c. (Optional.) Set the weight of the AF queue.
weight weight-value
d. Return to system view.
qos policy policy-name
b. Associate a traffic behavior with a class in the policy.
classifier classifier-name behavior behavior-name
By default, a class is not associated with a behavior.
Apply the QoS policy to an interface.
5. (Optional.) Display AF configuration.
display traffic classifier user-defined
display qos policy user-defined
display qos policy interface
Configuring EF and the maximum bandwidth
· You cannot configure the queue ef command together with the queue af or queue wfq command in one traffic behavior.
b. Configure EF and the maximum bandwidth.
queue ef bandwidth { bandwidth [ cbs burst ] [ pir peak-information-rate ] | pct percentage [ cbs-ratio ratio ] }
By default, EF is not configured.
Traffic between the maximum bandwidth and PIR is scheduled by using WFQ.
c. (Optional.) Set the weight of the EF queue.
weight weight-value
5. Apply the QoS policy to an interface.
6. (Optional.) Display EF configuration.
Configuring WFQ
· You cannot configure the queue wfq command together with the queue af or queue ef command in one traffic behavior.
b. Configure WFQ.
queue wfq
By default, WFQ is not configured.
c. (Optional.) Set the weight of the WFQ queue.
weight weight-value
6. (Optional.) Display WFQ configuration.
Setting the maximum reserved bandwidth as a percentage of available bandwidth for an interface
2. Enter interface view.
3. Set the maximum reserved bandwidth as a percentage of available bandwidth.
qos reserved-bandwidth pct percent
The default setting is 80.
Typically, the maximum reserved bandwidth should not be greater than 80% of available bandwidth. As a best practice, use the default setting.
Example: Configuring CBQ
As shown in Figure 17, configure a QoS policy on Device A to meet the following requirements:
· Traffic from Device C is classified into three classes based on DSCP values. Perform AF for traffic with DSCP values of AF11 and AF21, and set the minimum guaranteed bandwidth to 500 kbps for the traffic.
· Perform EF for traffic with a DSCP value of EF and set the maximum bandwidth to 2000 kbps for the traffic.
Before configuring the QoS policy, make sure the following requirements are met:
· The route from Device C to Device D through Device A and Device B is reachable.
· The DSCP fields have been set for the traffic before the traffic enters Device A.
# Define three classes to match the IP packets with the DSCP values AF11, AF21, and EF, respectively.
[DeviceA] traffic classifier af11_class
[DeviceA-classifier-af11_class] if-match dscp af11
[DeviceA-classifier-af11_class] quit
[DeviceA]traffic classifier af21_class
[DeviceA-classifier-af21_class] if-match dscp af21
[DeviceA-classifier-af21_class] quit
[DeviceA] traffic classifier ef_class
[DeviceA-classifier-ef_class] if-match dscp ef
[DeviceA-classifier-ef_class] quit
# Define two traffic behaviors, and enable AF and set the minimum guaranteed bandwidth to 500 kbps in each traffic behavior.
[DeviceA] traffic behavior af11_behav
[DeviceA-behavior-af11_behav] queue af bandwidth 500
[DeviceA-behavior-af11_behav] quit
[DeviceA] traffic behavior af21_behav
[DeviceA-behavior-af21_behav] queue af bandwidth 500
[DeviceA-behavior-af21_behav] quit
# Define a traffic behavior, and enable EF and set the maximum bandwidth to 2000 kbps in the traffic behavior. Both bandwidth and delay are guaranteed for EF traffic.
[DeviceA] traffic behavior ef_behav
[DeviceA-behavior-ef_behav] queue ef bandwidth 2000
[DeviceA-behavior-ef_behav] quit
# Define a QoS policy and associate the configured traffic behaviors with classes in the QoS policy.
[DeviceA] qos policy dscp
[DeviceA-qospolicy-dscp] classifier af11_class behavior af11_behav
[DeviceA-qospolicy-dscp] classifier af21_class behavior af21_behav
[DeviceA-qospolicy-dscp] classifier ef_class behavior ef_behav
[DeviceA-qospolicy-dscp] quit
# Apply the QoS policy to the outgoing traffic of Ten-GigabitEthernet 3/1/1.
[DeviceA] interface ten-gigabitethernet 3/1/1
[DeviceA-Ten-GigabitEthernet3/1/1] ip address 1.1.1.1 255.255.255.0
[DeviceA-Ten-GigabitEthernet3/1/1] qos apply policy dscp outbound
The configuration enables EF traffic to be forwarded preferentially when congestion occurs.
Configuring a queue scheduling profile
About queue scheduling profiles
In a queue scheduling profile, you can configure scheduling parameters for each queue. By applying the queue scheduling profile to an interface or session group profile, you can implement congestion management on the interface or session group profile.
Queue scheduling profiles support three queue scheduling algorithms: SP, WRR, and WFQ. In a queue scheduling profile, you can configure SP+WRR or SP+WFQ. For information about each scheduling algorithm, see "About hardware congestion management." When SP and WRR groups are configured in a queue scheduling profile, Figure 18 shows the scheduling order.
Figure 18 Queue scheduling profile configured with both SP and WRR
· Queue 7 has the highest priority in the SP group. Its packets are sent preferentially.
· Queue 6 has the second highest priority in the SP group. Packets in queue 6 are sent when queue 7 is empty.
· Queue 3, queue 4, and queue 5 are scheduled according to their weights. When queue 7 and queue 6 are empty, WRR group 1 is scheduled.
· Queue 1 and queue 2 are scheduled according to their weights. WRR group 2 is scheduled when queue 7 through queue 3 are empty.
· Queue 0 has the lowest priority, and it is scheduled when all other queues are empty.
Queue scheduling profiles include the following types:
· Basic—You can set the queuing scheduling algorithm and scheduling weight.
· Advanced—You can set additional parameters such as minimum guaranteed bandwidth and service type.
Restrictions and guidelines for queue scheduling profile configuration
When you configure a queue scheduling profile, follow these restrictions and guidelines:
· You can modify the scheduling parameters in a queue scheduling profile already applied to an interface.
· You can apply a queue scheduling profile to a Layer 3 aggregate interface or subinterface if all member ports of the Layer 3 aggregate interface are on the following cards:
Card category |
Cards |
CEPC |
CEPC-XP4LX, CEPC-XP24LX, CEPC-XP48RX, CEPC-CP4RX, CEPC-CP4RX-L, CEPC-CQ8L, CEPC-CQ16L1, CEPC-DQ2L1-G |
CSPEX |
CSPEX-1304X, CSPEX-1304S, CSPEX-1404X, CSPEX-1404S, CSPEX-1502X, CSPEX-1504X, CSPEX-1504S, CSPEX-1602X, CSPEX-1804X, CSPEX-1512X, CSPEX-1612X, CSPEX-1812X, CSPEX-1802XB, CSPEX-1802X, CSPEX-1812X-E, CSPEX-2304X-G, CSPEX-2304X-LG, CSPEX-2612X-E |
SPE |
RX-SPE200, RX-SPE200-E |
· A queue scheduling profile configured with a percentage-based minimum bandwidth cannot be applied to a user profile, user group profile, or session group profile.
· A queue with a weight of 0 cannot be configured with a minimum bandwidth and has the lowest priority. Queues with a weight of 0 are scheduled in a round-robin manner.
· Queue 0 and queue 7 cannot be both configured with a minimum bandwidth.
2. Create a queue scheduling profile and enter queue scheduling profile view.
qos qmprofile profile-name [ basic ]
3. (Optional.) Configure queue scheduling parameters.
¡ Configure a queue to use SP.
queue queue-id sp [ max-bandwidth { bandwidth-value | percent percent } | wred-profile profile-name ]*
¡ Configure a queue to use WRR.
queue queue-id wrr group group-id weight schedule-value [ max-bandwidth { bandwidth-value | percent percent } | wred-profile profile-name ]*
¡ Configure a queue to use WFQ.
queue queue-id wfq group group-id weight schedule-value
By default, all queues in a queue scheduling profile are SP queues.
In a queue scheduling profile, you can configure different queue scheduling algorithms for different queues.
Only the following cards support the max-bandwidth parameter:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
4. (Optional.) Set the minimum guaranteed bandwidth for a queue.
bandwidth queue queue-id min { bandwidth-value | percent percent }
By default, the minimum guaranteed bandwidth is not set.
On the following cards, the minimum guaranteed bandwidth in a queue scheduling profile takes effect only on SP queues:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
The following cards do not support this command:
Card category |
Cards |
CSPC |
CSPEX |
CSPEX-1104-E |
SPEX |
SPEX-1204 |
5. (Optional.) Set the maximum bandwidth allowed for a group.
group group-id max-bandwidth { bandwidth-value | percent percent }
By default, the maximum bandwidth is not set for a group.
Applying a queue scheduling profile
2. Apply the queue scheduling profile.
¡ Apply the queue scheduling profile to the switching fabric module.
In standalone mode:
qos apply qmprofile profile-name fabric [ slot slot-number ]
In IRF mode:
qos apply qmprofile profile-name fabric [ chassis chassis-number slot slot-number ]
By default, no queue scheduling profile is applied to the switching fabric module.
¡ Execute the following commands in sequence to apply the queue scheduling profile to an interface.
qos apply qmprofile profile-name [ inbound ]
By default, an interface uses SP queuing.
On an SPEX-1204 card, you cannot configure both queue-based GTS and a queue scheduling profile with WRR queuing for the same interface.
¡ Execute the following commands in sequence to apply the queue scheduling profile to a user group profile.
By default, no queue scheduling profile is applied to a user group profile.
The configuration in user group profile view takes effect when the users come online.
Only one queue scheduling profile can be applied to one direction of a user group profile.
¡ Execute the following commands in sequence to apply the queue scheduling profile to a session group profile.
By default, no queue scheduling profile is applied to a session group profile.
The configuration in session group profile view takes effect when the users come online.
Only the following cards support this command:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
Only one queue scheduling profile can be applied to one direction of a session group profile.
Example: Configuring a queue scheduling profile
Configure a queue scheduling profile to meet the following requirements on Ten-GigabitEthernet 3/1/1:
· Queue 7 has the highest priority, and its packets are sent preferentially.
· Queue 4, queue 5, and queue 6 are in WRR group 1 and scheduled according to their weights, which are 1, 5, and 10, respectively. When queue 7 is empty, WRR group 1 is scheduled.
· Queue 1, queue 2, and queue 3 are in WRR group 2 and scheduled according to their weights, which are 1, 10, and 20, respectively. When queue 4, queue 5, queue 6, and queue 7 are all empty, WRR group 2 is scheduled.
· Queue 0 has the lowest priority. Queue 0 is scheduled when all the other queues are empty.
# Enter system view.
# Create a queue scheduling profile named qm1.
[Sysname] qos qmprofile qm1
[Sysname-qmprofile-qm1]
# Configure queue 7 to use SP queuing.
[Sysname-qmprofile-qm1] queue 7 sp
# Assign queue 4, queue 5, and queue 6 to WRR group 1, with the weight of 1, 5, and 10, respectively.
[Sysname-qmprofile-qm1] queue 4 wrr group 1 weight 1
[Sysname-qmprofile-qm1] queue 5 wrr group 1 weight 5
[Sysname-qmprofile-qm1] queue 6 wrr group 1 weight 10
# Assign queue 1, queue 2, and queue 3 to WRR group 2, with the weight of 1, 10, and 20, respectively.
[Sysname-qmprofile-qm1] queue 1 wrr group 2 weight 1
[Sysname-qmprofile-qm1] queue 2 wrr group 2 weight 10
[Sysname-qmprofile-qm1] queue 3 wrr group 2 weight 20
# Configure queue 0 to use SP queuing.
[Sysname-qmprofile-qm1] queue 0 sp
[Sysname-qmprofile-qm1] quit
# Apply queue scheduling profile qm1 to Ten-GigabitEthernet 3/1/1.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] qos apply qmprofile qm1
After the configuration is completed, Ten-GigabitEthernet 3/1/1 performs queue scheduling as specified in queue scheduling profile qm1.
Display and maintenance commands for hardware congestion management
Task |
Command |
Display queuing configuration. |
display qos queue interface [ interface-type interface-number ] |
Display the configuration of queue scheduling profiles. |
In standalone mode: display qos qmprofile configuration [ profile-name ] [ slot slot-number ] In IRF mode: display qos qmprofile configuration [ profile-name ] [ chassis chassis-number slot slot-number ] |
Display QoS and ACL resource usage. |
In standalone mode: display qos-queue resource slot slot-number { inbound | outbound } In IRF mode: display qos-queue resource chassis chassis-number slot slot-number { inbound | outbound } |
Display queue resource usage. |
In standalone mode: display qos-queue buffer-usage slot slot-number In IRF mode: display qos-queue buffer-usage chassis chassis-number slot slot-number |
Display the queue scheduling profiles applied to interfaces. |
In standalone mode: display qos qmprofile interface [ interface-type interface-number [ slot slot-number ] ] [ inbound ] In IRF mode: display qos qmprofile interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ] [ inbound ] |
Display weight values for subinterfaces. |
In standalone mode: display qos weight interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ outbound ] |
Configuring congestion avoidance
About congestion avoidance
Avoiding congestion before it occurs is a proactive approach to improving network performance. As a flow control mechanism, congestion avoidance:
· Actively monitors network resources (such as queues and memory buffers).
· Drops packets when congestion is expected to occur or deteriorate.
When dropping packets from a source end, congestion avoidance cooperates with the flow control mechanism at the source end to regulate the network traffic size. The combination of the local packet drop policy and the source-end flow control mechanism implements the following functions:
· Maximizes throughput and network use efficiency.
· Minimizes packet loss and delay.
Tail drop
Congestion management techniques drop all packets that are arriving at a full queue. This tail drop mechanism results in global TCP synchronization. If packets from multiple TCP connections are dropped, these TCP connections go into the state of congestion avoidance and slow start to reduce traffic. However, traffic peak occurs later. Consequently, the network traffic jitters all the time.
RED and WRED
You can use Random Early Detection (RED) or Weighted Random Early Detection (WRED) to avoid global TCP synchronization.
Both RED and WRED avoid global TCP synchronization by randomly dropping packets. When the sending rates of some TCP sessions slow down after their packets are dropped, other TCP sessions remain at high sending rates. Link bandwidth is efficiently used, because TCP sessions at high sending rates always exist.
The RED or WRED algorithm sets an upper threshold and lower threshold for each queue, and processes the packets in a queue as follows:
· When the queue size is shorter than the lower threshold, no packet is dropped.
· When the queue size reaches the upper threshold, all subsequent packets are dropped.
· When the queue size is between the lower threshold and the upper threshold, the received packets are dropped at random. The drop probability in a queue increases along with the queue size under the maximum drop probability.
If the current queue size is compared with the upper threshold and lower threshold to determine the drop policy, burst traffic is not fairly treated. To solve this problem, WRED compares the average queue size with the upper threshold and lower threshold to determine the drop probability.
The average queue size reflects the queue size change trend but is not sensitive to burst queue size changes, and burst traffic can be fairly treated.
When WFQ queuing is used, you can set the following parameters for packets with different precedence values to provide differentiated drop policies:
· Exponent for average queue size calculation.
· Upper threshold.
· Lower threshold.
· Drop probability.
Relationship between WRED and queuing mechanisms
Figure 19 Relationship between WRED and queuing mechanisms
· A flow with a smaller queue size has a lower packet drop probability.
· A flow with a larger queue size has a higher packet drop probability.
In this way, the benefits of the flow with a smaller queue size are protected.
WRED parameters
Determine the following parameters before configuring WRED:
· Upper threshold and lower threshold—When the average queue size is smaller than the lower threshold, packets are not dropped. When the average queue size is between the lower threshold and the upper threshold, the packets are dropped at random. The longer the queue, the higher the drop probability. When the average queue size exceeds the upper threshold, subsequent packets are dropped.
· Drop precedence—A parameter used for packet drop. The value 0 corresponds to green packets, the value 1 corresponds to yellow packets, and the value 2 corresponds to red packets. Red packets are dropped preferentially.
· Exponent for average queue size calculation—The greater the exponent, the less sensitive the average queue size is to real-time queue size changes. The formula for calculating the average queue size is:
Average queue size = ( previous average queue size x (1 – 2–n) ) + (current queue size x 2–n), where n is the exponent.
Configuring and applying a queue-based WRED table
One WRED table can be applied to multiple interfaces. You can modify the parameters of a WRED table applied to an interface, but you cannot delete the WRED table.
You can apply a queue-based WRED table to a Layer 3 aggregate interface or subinterface if all member ports of the Layer 3 aggregate interface are on the following cards:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
2. Create a WRED table and enter its view.
3. (Optional.) Configure the other WRED parameters.
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
By default, the lower limit is 100, the higher limit is 1000, and the drop probability value is 10.
SPEX-1204 cards do not support the discard-probability discard-prob option.
4. Return to system view.
5. Enter interface view.
6. Apply the WRED table to the interface.
qos wred apply [ table-name ]
By default, no WRED table is applied to an interface, and tail drop is used on an interface.
Example: Configuring and applying a queue-based WRED table
Apply a WRED table to Ten-GigabitEthernet 3/1/2, so that the packets are dropped as follows when congestion occurs:
· For the interface to preferentially forward higher-priority traffic, set a lower drop probability for a queue with a greater queue number. Set different drop parameters for queue 0, queue 3, and queue 7.
· Drop packets according to their colors.
¡ In queue 0, set the drop probability to 25%, 50%, and 75% for green, yellow, and red packets, respectively.
¡ In queue 3, set the drop probability to 5%, 10%, and 25% for green, yellow, and red packets, respectively.
¡ In queue 7, set the drop probability to 1%, 5%, and 10% for green, yellow, and red packets, respectively.
# Configure a queue-based WRED table, and set different drop parameters for packets with different drop levels in different queues.
[Sysname-wred-table-queue-table1] queue 0 drop-level 0 low-limit 128 high-limit 512 discard-probability 25
[Sysname-wred-table-queue-table1] queue 0 drop-level 1 low-limit 128 high-limit 512 discard-probability 50
[Sysname-wred-table-queue-table1] queue 0 drop-level 2 low-limit 128 high-limit 512 discard-probability 75
[Sysname-wred-table-queue-table1] queue 3 drop-level 0 low-limit 256 high-limit 640 discard-probability 5
[Sysname-wred-table-queue-table1] queue 3 drop-level 1 low-limit 256 high-limit 640 discard-probability 10
[Sysname-wred-table-queue-table1] queue 3 drop-level 2 low-limit 256 high-limit 640 discard-probability 25
[Sysname-wred-table-queue-table1] queue 7 drop-level 0 low-limit 512 high-limit 1024 discard-probability 1
[Sysname-wred-table-queue-table1] queue 7 drop-level 1 low-limit 512 high-limit 1024 discard-probability 5
[Sysname-wred-table-queue-table1] queue 7 drop-level 2 low-limit 512 high-limit 1024 discard-probability 10
[Sysname-wred-table-queue-table1] quit
# Apply the queue-based WRED table to Ten-GigabitEthernet 3/1/2.
[Sysname] interface ten-gigabitethernet 3/1/2
[Sysname-Ten-GigabitEthernet3/1/2] qos wred apply queue-table1
[Sysname-Ten-GigabitEthernet3/1/2] quit
Configuring an applying a WRED profile
When both this feature and a queue scheduling profile are configured on an interface, this feature takes priority.
2. Create a WRED profile and enter its view.
qos wred-profile profile-name
3. Configure WRED parameters.
queue [ drop-level drop-level ] [ limit-percent ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
queue low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
queue limit-percent low-limit low-limit high-limit high-limit [ discard-probability discard-prob ] [ queue-length length ]
By default, no WRED parameters are configured.
4. (Optional.) Specify the queue length.
queue length length
By default, the queue length is not configured.
5. Return to system view.
6. Enter interface view.
7. Apply the WRED profile to a queue on the interface.
qos apply wred-profile profile-name queue queue-id
By default, no WRED profile is applied to a queue.
Example: Configuring and applying a WRED profile
Apply a WRED profile to Ten-GigabitEthernet 3/1/2, so that the outgoing packets are dropped as follows when congestion occurs:
# Configure WRED profiles, and set different drop parameters for packets with different drop levels in each WRED profile.
[Sysname] qos wred-profile q0-profile
[Sysname-wred-profile-q0-profile] queue drop-level 0 low-limit 128 high-limit 512 discard-probability 25
[Sysname-wred-profile-q0-profile] queue drop-level 1 low-limit 128 high-limit 512 discard-probability 50
[Sysname-wred-profile-q0-profile] queue drop-level 2 low-limit 128 high-limit 512 discard-probability 75
[Sysname-wred-profile-q0-profile] quit
[Sysname] qos wred-profile q3-profile
[Sysname-wred-profile-q3-profile] queue drop-level 0 low-limit 256 high-limit 640 discard-probability 5
[Sysname-wred-profile-q3-profile] queue drop-level 1 low-limit 256 high-limit 640 discard-probability 10
[Sysname-wred-profile-q3-profile] queue drop-level 2 low-limit 256 high-limit 640 discard-probability 25
[Sysname-wred-profile-q3-profile] quit
[Sysname] qos wred-profile q7-profile
[Sysname-wred-profile-q7-profile] queue drop-level 0 low-limit 512 high-limit 1024 discard-probability 1
[Sysname-wred-profile-q7-profile] queue drop-level 1 low-limit 512 high-limit 1024 discard-probability 5
[Sysname-wred-profile-q7-profile] queue drop-level 2 low-limit 512 high-limit 1024 discard-probability 10
[Sysname-wred-profile-q7-profile] quit
# Apply the WRED profiles to Ten-GigabitEthernet 3/1/2.
[Sysname-Ten-GigabitEthernet3/1/2] qos apply wred-profile q0-profile queue 0
[Sysname-Ten-GigabitEthernet3/1/2] qos apply wred-profile q3-profile queue 3
[Sysname-Ten-GigabitEthernet3/1/2] qos apply wred-profile q7-profile queue 7
Display and maintenance commands for WRED
Task |
Command |
Display WRED configuration and statistics for an interface or PVC. |
In standalone mode: display qos wred interface [ interface-type interface-number | [ slot slot-number ] ] In IRF mode: display qos wred interface [ interface-type interface-number | [ chassis chassis-number slot slot-number ] ] |
Display the configuration of a WRED table or all WRED tables. |
In standalone mode: display qos wred table [ name table-name ] [ slot slot-number ] In IRF mode: display qos wred table [ name table-name ] [ chassis chassis-number slot slot-number ] |
Configuring traffic filtering
About traffic filtering
You can filter in or filter out traffic of a class by associating the class with a traffic filtering action. For example, you can filter packets sourced from an IP address according to network status.
Restrictions and guidelines: Traffic filtering configuration
A traffic filtering action takes effect only when a QoS policy is applied to the following application destinations:
· Interface.
· VLANs.
· Globally.
· Control plane.
· User profile.
2. Define a traffic class.
a. Create a traffic class and enter traffic class view.
b. Configure a match criterion.
c. Return to system view.
3. Define a traffic behavior.
a. Create a traffic behavior and enter traffic behavior view.
b. Configure the traffic filtering action.
filter { deny | permit }
By default, no traffic filtering action is configured.
4. Define a QoS policy.
a. Create a QoS policy and enter QoS policy view.
By default, a traffic class is not associated with a traffic behavior.
5. Apply the QoS policy.
For more information, see "Applying the QoS policy."
By default, no QoS policy is applied.
6. (Optional.) Display the traffic filtering configuration.
This command is available in any view.
Traffic filtering configuration examples
Example: Configuring traffic filtering
As shown in Figure 20, configure traffic filtering on Ten-GigabitEthernet 3/1/1 to deny the incoming packets with destination port number 21.
# Create advanced ACL 3000, and configure a rule to match packets with destination port number 21.
[Device] acl advanced 3000
[Device-acl-ipv4-adv-3000] rule 0 permit tcp destination-port eq 21
# Create a traffic class named classifier_1, and use ACL 3000 as the match criterion in the traffic class.
# Create a traffic behavior named behavior_1, and configure the traffic filtering action to drop packets.
# Create a QoS policy named policy, and associate traffic class classifier_1 with traffic behavior behavior_1 in the QoS policy.
[Device] qos policy policy
[Device-qospolicy-policy] classifier classifier_1 behavior behavior_1
[Device-qospolicy-policy] quit
# Apply QoS policy policy to the incoming traffic of Ten-GigabitEthernet 3/1/1.
[Device] interface ten-gigabitethernet 3/1/1
[Device-Ten-GigabitEthernet3/1/1] qos apply policy policy inbound
Configuring priority marking
About priority marking
Priority marking sets the priority fields or flag bits of packets to modify the priority of packets. For example, you can use priority marking to set IP precedence or DSCP for a class of IP packets to control the forwarding of these packets.
1. Configure a traffic behavior with a priority marking action.
2. Associate the traffic class with the traffic behavior.
Priority marking can be used together with priority mapping. For more information, see "Configuring priority mapping." You can configure priority marking by using the MQC approach.
Configuring priority marking by using the MQC approach
· A priority marking action takes effect only when a QoS policy is applied to the following application destinations:
¡ Interface.
¡ VLANs.
¡ Globally.
¡ Control plane.
¡ User profile.
· The remark tunnel-dscp command is mutually exclusive with the remark dscp or remark ip-precedence command in one traffic behavior.
· The remark qos-local-id command is mutually exclusive with the remark apn-id command in one traffic behavior.
b. Configure a priority marking action.
For configurable priority marking actions, see the remark commands in ACL and QoS Command Reference.
6. (Optional.) Display the priority marking configuration.
Priority marking configuration examples
Example: Configuring priority marking
As shown in Figure 21, configure priority marking on the device to meet the following requirements:
Traffic source |
Destination |
Processing priority |
Host A, B |
Data server |
High |
Host A, B |
Mail server |
Medium |
Host A, B |
File server |
Low |
# Create advanced ACL 3000, and configure a rule to match packets with destination IP address 192.168.0.1.
[Device-acl-ipv4-adv-3000] rule permit ip destination 192.168.0.1 0
# Create advanced ACL 3001, and configure a rule to match packets with destination IP address 192.168.0.2.
[Device] acl advanced 3001
[Device-acl-ipv4-adv-3001] rule permit ip destination 192.168.0.2 0
# Create advanced ACL 3002, and configure a rule to match packets with destination IP address 192.168.0.3.
[Device] acl advanced 3002
[Device-acl-ipv4-adv-3002] rule permit ip destination 192.168.0.3 0
[Device-acl-ipv4-adv-3002] quit
# Create a traffic class named classifier_dbserver, and use ACL 3000 as the match criterion in the traffic class.
[Device] traffic classifier classifier_dbserver
[Device-classifier-classifier_dbserver] if-match acl 3000
[Device-classifier-classifier_dbserver] quit
# Create a traffic class named classifier_mserver, and use ACL 3001 as the match criterion in the traffic class.
[Device] traffic classifier classifier_mserver
[Device-classifier-classifier_mserver] if-match acl 3001
[Device-classifier-classifier_mserver] quit
# Create a traffic class named classifier_fserver, and use ACL 3002 as the match criterion in the traffic class.
[Device] traffic classifier classifier_fserver
[Device-classifier-classifier_fserver] if-match acl 3002
[Device-classifier-classifier_fserver] quit
# Create a traffic behavior named behavior_dbserver, and configure the action of setting the local precedence value to 4.
[Device] traffic behavior behavior_dbserver
[Device-behavior-behavior_dbserver] remark local-precedence 4
[Device-behavior-behavior_dbserver] quit
# Create a traffic behavior named behavior_mserver, and configure the action of setting the local precedence value to 3.
[Device] traffic behavior behavior_mserver
[Device-behavior-behavior_mserver] remark local-precedence 3
[Device-behavior-behavior_mserver] quit
# Create a traffic behavior named behavior_fserver, and configure the action of setting the local precedence value to 2.
[Device] traffic behavior behavior_fserver
[Device-behavior-behavior_fserver] remark local-precedence 2
[Device-behavior-behavior_fserver] quit
# Create a QoS policy named policy_server, and associate traffic classes with traffic behaviors in the QoS policy.
[Device] qos policy policy_server
[Device-qospolicy-policy_server] classifier classifier_dbserver behavior behavior_dbserver
[Device-qospolicy-policy_server] classifier classifier_mserver behavior behavior_mserver
[Device-qospolicy-policy_server] classifier classifier_fserver behavior behavior_fserver
[Device-qospolicy-policy_server] quit
# Apply QoS policy policy_server to the incoming traffic of Ten-GigabitEthernet 3/1/1.
[Device-Ten-GigabitEthernet3/1/1] qos apply policy policy_server inbound
[Device-Ten-GigabitEthernet3/1/1] quit
Configuring traffic redirecting
About traffic redirecting
Traffic redirecting redirects packets matching the specified match criteria to a location for processing.
You can redirect packets to the following destinations:
· VPN instance.
· CPU. In UCM, packets need to be redirected to the CPU when a management user comes online or troubleshooting is performed.
· Interface.
· Card.
· Failover group.
For more information about failover groups, see High Availability Configuration Guide.
· NAT instance.
You can redirecting traffic to a NAT instance by binding the NAT instance. For more information about NAT, see NAT Configuration Guide.
· SR-MPLS TE policy or SRv6 TE policy.
The redirected packets will be forwarded through the SR-MPLS TE policy or SRv6 TE policy. For more information about SR-MPLS TE policies and SRv6 TE policies, see Segment Routing Configuration Guide.
Restrictions and guidelines: Traffic redirecting configuration
· A traffic redirecting action takes effect only when a QoS policy is applied to the following application destinations:
¡ Interface.
¡ VLANs.
¡ Globally.
¡ Control plane.
¡ User profile.
· If you execute the redirect command multiple times in the same traffic behavior, all configured actions take effect at the same time. The following exceptions exist:
¡ Any two of the redirect cpu, redirect dhcp-to-cpu, redirect http-to-cpu, and redirect https-to-cpu commands are mutually exclusive.
¡ The redirect failover-group and bind nat-instance commands are mutually exclusive.
· If both the redirect and remark apn-id commands are executed in one traffic behavior, the remark apn-id command might not take effect.
· For IPoE Web authentication, you must configure the redirect http-to-cpu or redirect https-to-cpu command. If a user performs IPoE Web authentication through the Web browser but the HTTP request is not destined for the portal Web server, the access device redirects the request to the CPU. The CPU pushes the Web authentication page to the user.
· To prevent the CPU from receiving a large number of HTTP requests during IPoE Web authentication, use the ip subscriber http-fast-reply enable command to enable the HTTP request fast reply function. This function reduces the CPU load by identifying HTTP requests in hardware and automatically replying with HTTP responses. For more information about the ip subscriber http-fast-reply enable command, see IPoE commands in see BRAS Services Command Reference.
The following cards support traffic redirecting to Layer 3 Ethernet interfaces and loopback interfaces instead of Layer 3 aggregate interfaces:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
Defining a traffic class
2. Create a traffic class and enter traffic class view.
3. Configure a match criterion.
For more information, see the if-match command in ACL and QoS Command Reference.
Defining a traffic behavior
1. Create a traffic behavior and enter traffic behavior view.
2. Configure a traffic redirecting action. Choose one option as needed:
¡ Redirect traffic on a CGN service to a VPN instance.
redirect access-cgn-vpn vpn-instance vpn-instance-name
¡ Redirect traffic to a VPN instance.
redirect access-vpn vpn-instance-name1 [ track track-entry-number ] [ vpn-instance-name2 [ track track-entry-number ] ]
¡ Redirect traffic to the CPU.
redirect cpu
¡ Redirect DHCP packets to the CPU.
¡ Redirect HTTP requests to the CPU.
¡ Redirect HTTPS requests to the CPU.
¡ Redirect traffic to an interface.
redirect interface interface-type interface-number
¡ Redirect traffic to a card.
In standalone mode:
redirect slot slot-number
In IRF mode:
redirect chassis chassis-number slot slot-number
¡ Redirect NAT traffic to a failover group.
redirect failover-group group-name
¡ Redirect AFT traffic to a failover group.
redirect aft-failover-group group-name
¡ Redirect traffic to a next hop.
redirect next-hop [ vpn-instance vpn-instance-name ] { ipv4-add1 [ track track-entry-number ] [ ipv4-add2 [ track track-entry-number ] ] | ipv6-add1 [ track track-entry-number ] [ ipv6-add2 [ track track-entry-number ] ] }
¡ Redirect traffic to a NAT instance.
bind nat-instance instance-name
¡ Redirect traffic to an SR-MPLS TE policy.
redirect sr-policy endpoint color
¡ Redirect traffic to an SRv6 TE policy.
redirect srv6-policy endpoint color [ { sid | vpnsid } sid ]
By default, no traffic redirecting action is configured for a traffic behavior.
Defining and applying a QoS policy
1. Create a QoS policy and enter QoS policy view.
2. Associate the traffic class with the traffic behavior in the QoS policy.
3. Return to system view.
4. Apply the QoS policy.
5. (Optional.) Display traffic redirecting configuration.
Traffic redirecting configuration examples
Example: Configuring traffic redirecting
As shown in Figure 22:
· Device A is connected to Device B through two links. Device A and Device B are each connected to other devices.
· Ten-GigabitEthernet 3/1/2 of Device A is a trunk port and belongs to VLAN 200 and VLAN 201.
· Ten-GigabitEthernet 3/1/2 of Device A and Ten-GigabitEthernet 3/1/2 of Device B belong to VLAN 200.
· Ten-GigabitEthernet 3/1/3 of Device A and Ten-GigabitEthernet 3/1/3 of Device B belong to VLAN 201.
· On Device A, the IP address of VLAN-interface 200 is 200.1.1.1/24, and that of VLAN-interface 201 is 201.1.1.1/24.
· On Device B, the IP address of VLAN-interface 200 is 200.1.1.2/24, and that of VLAN-interface 201 is 201.1.1.2/24.
Configure the actions of redirecting traffic to an interface to meet the following requirements:
· Packets with source IP address 2.1.1.1 received on Ten-GigabitEthernet 3/1/1 of Device A are forwarded to Ten-GigabitEthernet 3/1/2.
· Packets with source IP address 2.1.1.2 received on Ten-GigabitEthernet 3/1/1 of Device A are forwarded to Ten-GigabitEthernet 3/1/3.
· Other packets received on Ten-GigabitEthernet 3/1/1 of Device A are forwarded according to the routing table.
# Create basic ACL 2000, and configure a rule to match packets with source IP address 2.1.1.1.
[DeviceA] acl basic 2000
[DeviceA-acl-ipv4-basic-2000] rule permit source 2.1.1.1 0
# Create basic ACL 2001, and configure a rule to match packets with source IP address 2.1.1.2.
[DeviceA] acl basic 2001
[DeviceA-acl-ipv4-basic-2001] rule permit source 2.1.1.2 0
# Create a traffic class named classifier_1, and use ACL 2000 as the match criterion in the traffic class.
[DeviceA] traffic classifier classifier_1
[DeviceA-classifier-classifier_1] if-match acl 2000
[DeviceA-classifier-classifier_1] quit
# Create a traffic class named classifier_2, and use ACL 2001 as the match criterion in the traffic class.
[DeviceA] traffic classifier classifier_2
[DeviceA-classifier-classifier_2] if-match acl 2001
[DeviceA-classifier-classifier_2] quit
# Create a traffic behavior named behavior_1, and configure the action of redirecting traffic to Ten-GigabitEthernet 3/1/2.
[DeviceA] traffic behavior behavior_1
[DeviceA-behavior-behavior_1] redirect interface ten-gigabitethernet 3/1/2
[DeviceA-behavior-behavior_1] quit
# Create a traffic behavior named behavior_2, and configure the action of redirecting traffic to Ten-GigabitEthernet 3/1/3.
[DeviceA] traffic behavior behavior_2
[DeviceA-behavior-behavior_2] redirect interface ten-gigabitethernet 3/1/3
[DeviceA-behavior-behavior_2] quit
# Create a QoS policy named policy.
[DeviceA] qos policy policy
# Associate traffic class classifier_1 with traffic behavior behavior_1 in the QoS policy.
[DeviceA-qospolicy-policy] classifier classifier_1 behavior behavior_1
# Associate traffic class classifier_2 with traffic behavior behavior_2 in the QoS policy.
[DeviceA-qospolicy-policy] classifier classifier_2 behavior behavior_2
[DeviceA-qospolicy-policy] quit
[DeviceA-Ten-GigabitEthernet3/1/1] qos apply policy policy inbound
Configuring global CAR
About global CAR
Global committed access rate (CAR) is an approach to policing traffic flows globally. It adds flexibility to common CAR where traffic policing is performed only on a per-traffic class or per-interface basis. In this approach, CAR actions are created in system view and each can be used to police multiple traffic flows as a whole.
Global CAR provides the following CAR actions: aggregate CAR, hierarchical CAR, and multi-level CAR. Only aggregate CAR is supported in the current software version.
Aggregate CAR
An aggregate CAR action is created globally. It can be directly applied to interfaces or used in the traffic behaviors associated with different traffic classes to police multiple traffic flows as a whole. The total rate of the traffic flows must conform to the traffic policing specifications set in the aggregate CAR action.
Configuring aggregate CAR by using the MQC approach
For configurable match criteria, see the if-match command in ACL and QoS Command Reference.
3. Configure an aggregate CAR action.
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
By default, no aggregate CAR action is configured.
4. Define a traffic behavior.
a. Enter traffic behavior view.
b. Use the aggregate CAR in the traffic behavior.
car name car-name
By default, no aggregate CAR action is used in a traffic behavior.
5. Define a QoS policy.
b. Associate the traffic class with the traffic behavior in the QoS policy.
6. Apply the QoS policy.
Display and maintenance commands for global CAR
Task |
Command |
Display statistics for global CAR actions. |
display qos car name [ car-name ] |
Clear statistics for global CAR actions. |
reset qos car name [ car-name ] |
Global CAR configuration examples
Example: Configuring aggregate CAR
As shown in Figure 23, configure aggregate CAR to rate-limit the traffic of VLAN 10 and VLAN 100 received on Ten-GigabitEthernet 3/1/1 by using these parameters: CIR 2560 kbps and CBS 20000 bytes.
# Configure an aggregate CAR action named aggcar-1 according to the rate limit requirements.
[Device] qos car aggcar-1 aggregative cir 2560 cbs 20000
# Create class 1 to match traffic of VLAN 10. Create behavior 1 and use aggregate CAR action aggcar-1 in the behavior.
[Device] traffic classifier 1
[Device-classifier-1] if-match service-vlan-id 10
[Device-classifier-1] quit
[Device] traffic behavior 1
[Device-behavior-1] car name aggcar-1
[Device-behavior-1] quit
# Create class 2 to match traffic of VLAN 100. Create behavior 2 and use aggregate CAR action aggcar-1 in the behavior.
[Device] traffic classifier 2
[Device-classifier-2] if-match service-vlan-id 100
[Device-classifier-2] quit
[Device] traffic behavior 2
[Device-behavior-2] car name aggcar-1
[Device-behavior-2] quit
# Create a QoS policy named car, associate class 1 with behavior 1, and associate class 2 with behavior 2.
[Device] qos policy car
[Device-qospolicy-car] classifier 1 behavior 1
[Device-qospolicy-car] classifier 2 behavior 2
[Device-qospolicy-car] quit
# Apply QoS policy car to the incoming traffic of Ten-GigabitEthernet 3/1/1.
[Device-Ten-GigabitEthernet3/1/1] qos apply policy car inbound
Configuring class-based accounting
About class-based accounting
Class-based accounting collects statistics (in packets or bytes) on a per-traffic class basis. For example, you can define the action to collect statistics for traffic sourced from a certain IP address. By analyzing the statistics, you can determine whether anomalies have occurred and what action to take.
Restrictions and guidelines: Class-based accounting configuration
A class-based accounting action takes effect only when a QoS policy is applied to the following application destinations:
· Interface.
· VLANs.
· Globally.
· Control plane.
· User profile.
For more information about the if-match command, see ACL and QoS Command Reference.
b. Configure an accounting action.
accounting [ byte | packet ]
By default, no traffic accounting action is configured.
6. (Optional.) Display the class-based accounting configuration.
Class-based accounting configuration examples
Example: Configuring class-based accounting
As shown in Figure 24, configure class-based accounting on Ten-GigabitEthernet 3/1/1 to collect statistics for incoming traffic from 1.1.1.1/24.
# Create basic ACL 2000, and configure a rule to match packets with source IP address 1.1.1.1.
[Device] acl basic 2000
[Device-acl-ipv4-basic-2000] rule permit source 1.1.1.1 0
[Device-classifier-classifier_1] if-match acl 2000
# Create a traffic behavior named behavior_1, and configure the class-based accounting action.
[Device-behavior-behavior_1] accounting
# Display traffic statistics to verify the configuration.
[Device] display qos policy interface ten-gigabitethernet 3/1/1
Interface: Ten-GigabitEthernet3/1/1
Direction: Inbound
Policy: policy
Classifier: classifier_1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: behavior_1
Accounting enable:
28529 (Packets)
Configuring queue-based accounting
Configuring interface queue-based accounting
About interface queue-based accounting
Queue-based accounting collects queue-based traffic statistics for interfaces, such as:
· The total length of a queue.
· The current queue length.
· The total number of packets forwarded.
· The number of per-color packets forwarded.
2. Enable queue-based accounting.
qos queue-statistics { inbound | outbound }
By default, queue-based accounting is enabled.
Display and maintenance commands for queue-based accounting
Task |
Command |
Display queue-based traffic statistics for interfaces. |
In standalone mode: display qos queue-statistics interface [ interface-type interface-number [ slot slot-number ] ] { inbound | outbound } In IRF mode: display qos queue-statistics interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ] { inbound | outbound } |
Display queue-based traffic statistics for a VPN instance, VSI, or cross-connect. |
display qos queue-statistics { vpn-instance vpn-instance-name | vsi vsi-name | xconnect-group group-name connection connect-name } { inbound | outbound } |
Clear queue-based traffic statistics for interfaces (see Interface Command Reference). |
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ] |
Configuring user queue-based accounting
Task |
Command |
Display queue-based traffic statistics for a user. |
In standalone mode: display qos queue-statistics user-id user-id [ slot slot-number [ cpu cpu-number ] ] outbound In IRF mode: display qos queue-statistics user-id user-id [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] outbound |
Clear queue-based traffic statistics for a user. |
In standalone mode: reset qos queue-statistics user-id user-id [ slot slot-number [ cpu cpu-number ] ] outbound In IRF mode: reset qos queue-statistics user-id user-id [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]outbound |
Configuring QPPB
About QPPB
The QoS Policy Propagation Through the Border Gateway Protocol (QPPB) feature enables you to classify IP packets based on the following attributes:
· BGP community lists.
· Prefix lists.
· BGP AS paths.
Application scenarios
QPPB minimizes the QoS policy configuration and management efforts on the BGP route receiver when the network topology changes. It is suitable for a large-scaled complex network.
The QPPB feature is implemented as follows:
· The BGP route sender preclassifies routes before advertising them.
· The BGP route receiver performs the following operations:
¡ Sets the IP precedence and local QoS ID for the routes.
¡ Takes appropriate QoS actions on the packets that match the routes.
QPPB is used in the following scenarios:
· Traffic classification based on source or destination IP addresses.
· Traffic classification based on IBGP and EBGP within an autonomous system or across multiple autonomous systems.
QPPB fundamentals
QPPB works on the BGP receiver by applying a QoS policy to BGP routes with the same IP precedence or local QoS ID. It depends on the BGP route sender to preclassify routes.
The BGP route sender uses a routing policy to set route attributes for BGP routes before advertising them.
The BGP sender performs the following operations:
· Uses a routing policy to match routes based on these route attributes.
· Sets IP precedence and local QoS ID for the matching routes.
The BGP receiver performs the following operations:
1. Compares the routes with the incoming route policy based on their BGP AS path, prefix, or community attributes.
2. Applies the IP precedence and local QoS ID to the matching routes.
3. Adds the BGP routes and their associated IP precedence and local QoS ID to the routing table.
4. Applies the IP precedence and local QoS ID to the packets sourced from or destined to the IP address in the route.
5. Takes QoS actions on the packets according to the QoS priority settings.
The BGP receiver cannot classify packets and take action on matching packets according to the IP precedence set in a routing policy. The BGP receiver can execute a QoS policy according to the ToS field in original packets. Typically, the IP precedence set in a routing policy can be used for scheduling outgoing packets or processing packets on the next hop.
QPPB tasks at a glance
To configure QPPB, perform the following tasks:
1. Configuring the route sender
a. Configuring basic BGP functions
b. (Optional.) Creating a routing policy
2. Configuring the route receiver
b. Configuring a routing policy
c. Enabling QPPB on the route receiving interface
Configure the BGP route sender to set route attributes for routes before advertising them.
For more information, see Layer 3—IP Routing Configuration Guide.
Configure a routing policy to perform the following operations:
· Match the route attributes set by the route sender.
· Set the IP precedence, local QoS ID, or both for the matching routes.
For QPPB to work correctly, you must configure the QoS policy as follows:
· Use the IP precedence or local QoS ID set in the routing policy to match packets.
· Specify the mode qppb-manipulation keyword when associating a traffic behavior with a traffic class.
For more information about QoS policies, see "Configuring a QoS policy."
Only interfaces on the following cards support this feature:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
If the traffic behavior in a QoS policy contains traffic redirecting, traffic filtering, flow mirroring, or priority mapping settings, only the following cards support QPPB:
Card category |
Cards |
CEPC |
CSPEX |
SPE |
RX-SPE200-E |
if-match { ip-precedence ip-precedence-value | qos-local-id local-id-value }
The IP precedence or local QoS ID must be same as that set in "Configuring a routing policy".
b. Configure an action.
By default, no action is configured.
For configuration commands, see traffic behavior commands in ACL and QoS Command Reference.
classifier classifier-name behavior behavior-name mode qppb-manipulation
6. Enable QPPB on the interface.
bgp-policy { destination | source } ip-prec-map ip-qos-map
By default, QPPB is disabled.
For the following cards, this command applies only to the incoming traffic:
Card category |
Cards |
CEPC |
CEPC-XP4LX, CEPC-XP24LX, CEPC-XP48RX, CEPC-CP4RX, CEPC-CP4RX-L |
CSPEX |
CSPEX-1304X, CSPEX-1304S, CSPEX-1404X, CSPEX-1404S, CSPEX-1502X, CSPEX-1504X, CSPEX-1504S, CSPEX-1602X, CSPEX-1804X, CSPEX-1512X, CSPEX-1612X, CSPEX-1812X |
SPE |
RX-SPE200 |
7. Apply a QoS policy to the interface.
By default, no QoS policy is applied to an interface.
QPPB configuration examples
Example: Configuring QPPB in an IPv4 network
As shown in Figure 25, all devices run BGP.
Configure QPPB so that Device B can perform the following operations:
· Receive routes.
· Set IP precedence values and local QoS IDs according to the routing policy.
· Use the QoS policy to limit the traffic rate to 512000 kbps.
1. Configure IP addresses for each interface. (Details not shown.)
2. Configure a BGP connection to Device B, and add the network 1.1.1.0/8 to the BGP routing table on Device A.
[DeviceA] bgp 1000
[DeviceA-bgp] peer 168.1.1.2 as-number 2000
[DeviceA-bgp] peer 168.1.1.2 connect-interface ten-gigabitethernet 3/1/2
[DeviceA-bgp] address-family ipv4
[DeviceA-bgp-ipv4] import-route direct
[DeviceA-bgp-ipv4] peer 168.1.1.2 enable
[DeviceA-bgp-ipv4] quit
[DeviceA-bgp] quit
3. Configure Device B:
# Configure a BGP connection to Device A.
[DeviceB] bgp 2000
[DeviceB-bgp] peer 168.1.1.1 as-number 1000
[DeviceB-bgp] peer 168.1.1.1 connect-interface ten-gigabitethernet 3/1/2
[DeviceB-bgp] address-family ipv4
[DeviceB-bgp-ipv4] peer 168.1.1.1 enable
[DeviceB-bgp-ipv4] peer 168.1.1.1 route-policy qppb import
[DeviceB-bgp-ipv4] quit
[DeviceB-bgp] quit
# Configure the routing policy qppb.
[DeviceB] route-policy qppb permit node 0
[DeviceB-route-policy-qppb-0] apply ip-precedence 1
[DeviceB-route-policy-qppb-0] apply qos-local-id 3
[DeviceB-route-policy-qppb-0] quit
# Enable QPPB on Ten-GigabitEthernet 3/1/2.
[DeviceB] interface ten-gigabitethernet 3/1/2
[DeviceB-Ten-GigabitEthernet3/1/2] bgp-policy source ip-prec-map ip-qos-map
[DeviceB-Ten-GigabitEthernet3/1/2] quit
# Configure a QoS policy.
[DeviceB] traffic classifier qppb
[DeviceB-classifier-qppb] if-match ip-precedence 1
[DeviceB-classifier-qppb] if-match qos-local-id 3
[DeviceB-classifier-qppb] quit
[DeviceB] traffic behavior qppb
[DeviceB-behavior-qppb] car cir 512000 green pass red discard
[DeviceB-behavior-qppb] quit
[DeviceB] qos policy qppb
[DeviceB-qospolicy-qppb] classifier qppb behavior qppb mode qppb-manipulation
[DeviceB-qospolicy-qppb] quit
# Apply the QoS policy to incoming traffic on Ten-GigabitEthernet 3/1/2.
[DeviceB-Ten-GigabitEthernet3/1/2] qos apply policy qppb inbound
# Verify that the related route on Device B takes effect.
[DeviceB] display bgp routing-table ipv4 1.1.1.0
BGP local router ID: 168.1.1.2
Local AS number: 2000
Paths: 1 available, 1 best
BGP routing table information of 168.1.1.0/24:
Rely nexthop : 168.1.1.1
Original nexthop: 168.1.1.1
Out interface : Ten-GigabitEthernet3/1/2
Route age : 00h30m12s
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : 1000
Origin : incomplete
State : valid, external, best
IP precedence : 1
QoS local ID : 3
Traffic index : N/A
Tunnel policy : NULL
Rely tunnel IDs : N/A
# Display the QoS policy configuration on Ten-GigabitEthernet 3/1/2 of Device B.
[DeviceB] display qos policy interface ten-gigabitethernet 3/1/2
Interface: Ten-GigabitEthernet3/1/2
Direction: Inbound
Policy: qppb
Classifier: default-class
Mode: qppb-manipulation
Matched : 51 (Packets) 4022 (Bytes)
5-minute statistics:
Forwarded: 0/28 (pps/bps)
Dropped : 0/0 (pps/bps)
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
Classifier: qppb
Matched : 0 (Packets) 0 (Bytes)
Forwarded: 0/0 (pps/bps)
Operator: AND
Rule(s) :
If-match ip-precedence 1
If-match qos-local-id 3
Behavior: qppb
Committed Access Rate:
CIR 512000 (kbps), CBS 32000000 (Bytes), EBS 0 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Yellow packets: 0 (Packets) 0 (Bytes)
Red packets : 0 (Packets) 0 (Bytes)
Example: Configuring QPPB in an MPLS L3VPN
As shown in Figure 26, all devices run BGP.
Configure QPPB so that Device C can perform the following operations:
· Receive routes.
· Set the QPPB local QoS IDs.
· Use the QoS policy to limit the traffic rate to 200000 kbps in each direction.
Table 3 Interfaces and IP address assignment
Device |
IP address |
Device |
IP address |
Device A |
XGE3/1/1 |
192.168.1.2/24 |
Device B |
XGE3/1/1 |
167.1.1.2/24 |
XGE3/1/2 |
167.1.1.1/24 |
XGE3/1/2 |
168.1.1.2/24 |
Device C |
XGE3/1/1 |
169.1.1.2/24 |
Device D |
XGE3/1/2 |
169.1.1.1/24 |
XGE3/1/2 |
168.1.1.1/24 |
XGE3/1/1 |
192.168.3.2/24 |
2. Configure a BGP connection on Device A.
[DeviceA] bgp 100
[DeviceA-bgp] peer 167.1.1.2 as-number 200
[DeviceA-bgp] peer 167.1.1.2 connect-interface ten-gigabitethernet 3/1/2
[DeviceA-bgp-ipv4] peer 167.1.1.2 enable
[DeviceA-bgp] quit
# Configure a VPN instance.
[DeviceB] ip vpn-instance vpn1
[DeviceB-vpn-instance-vpn1] route-distinguisher 200:1
[DeviceB-vpn-instance-vpn1] vpn-target 200:1 export-extcommunity
[DeviceB-vpn-instance-vpn1] vpn-target 200:1 import-extcommunity
[DeviceB-vpn-instance-vpn1] quit
# Configure a BGP connection.
[DeviceB] router id 1.1.1.1
[DeviceB] bgp 200
[DeviceB-bgp] peer 2.2.2.2 as-number 200
[DeviceB-bgp] peer 2.2.2.2 connect-interface loopback 0
[DeviceB-bgp] ip vpn-instance vpn1
[DeviceB-bgp-vpn1] peer 167.1.1.1 as-number 100
[DeviceB-bgp-vpn1] address-family ipv4
[DeviceB-bgp-ipv4-vpn1] peer 167.1.1.1 enable
[DeviceB-bgp-ipv4-vpn1] quit
[DeviceB-bgp] address-family vpnv4
[DeviceB-bgp-vpnv4] peer 2.2.2.2 enable
[DeviceB-bgp-vpnv4] quit
[DeviceB-bgp] quit
# Configure MPLS.
[DeviceB] mpls lsr-id 1.1.1.1
[DeviceB] mpls ldp
[DeviceB-mpls-ldp] quit
# Configure OSPF.
[DeviceB] ospf
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[DeviceB-ospf-1-area-0.0.0.0] network 168.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
# Bind Ten-GigabitEthernet 3/1/1 to VPN instance vpn1.
[DeviceB] interface ten-gigabitethernet 3/1/1
[DeviceB-Ten-GigabitEthernet3/1/1] ip binding vpn-instance vpn1
[DeviceB-Ten-GigabitEthernet3/1/1] ip address 167.1.1.2 24
[DeviceB-Ten-GigabitEthernet3/1/1] quit
# Enable MPLS on Ten-GigabitEthernet 3/1/2.
[DeviceB-Ten-GigabitEthernet3/1/2] mpls enable
[DeviceB-Ten-GigabitEthernet3/1/2] mpls ldp enable
4. Configure Device C:
<DeviceC> system-view
[DeviceC] ip vpn-instance vpn1
[DeviceC-vpn-instance-vpn1] route-distinguisher 200:1
[DeviceC-vpn-instance-vpn1] vpn-target 200:1 export-extcommunity
[DeviceC-vpn-instance-vpn1] vpn-target 200:1 import-extcommunity
[DeviceC-vpn-instance-vpn1] quit
[DeviceC] router id 2.2.2.2
[DeviceC] bgp 200
[DeviceC-bgp] peer 1.1.1.1 as-number 200
[DeviceC-bgp] peer 1.1.1.1 connect-interface loopback 0
[DeviceC-bgp] ip vpn-instance vpn1
[DeviceC-bgp-vpn1] peer 169.1.1.1 as-number 300
[DeviceC-bgp-vpn1] address-family ipv4
[DeviceC-bgp-ipv4-vpn1] peer 169.1.1.1 enable
[DeviceC-bgp-ipv4-vpn1] peer 169.1.1.1 route-policy qppb import
[DeviceC-bgp-ipv4-vpn1] quit
[DeviceC-bgp-vpn1] quit
[DeviceC-bgp] address-family vpnv4
[DeviceC-bgp-vpnv4] peer 1.1.1.1 enable
[DeviceC-bgp-vpnv4] peer 1.1.1.1 route-policy qppb import
[DeviceC-bgp-vpnv4] quit
[DeviceC-bgp] quit
# Configure a routing policy.
[DeviceC] route-policy qppb permit node 0
[DeviceC-route-policy-qppb-0] apply qos-local-id 3
[DeviceC-route-policy-qppb-0] quit
# Configure MPLS.
[DeviceC] mpls lsr-id 2.2.2.2
[DeviceC] mpls ldp
[DeviceC-mpls-ldp] quit
# Configure OSPF.
[DeviceC] ospf
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[DeviceC-ospf-1-area-0.0.0.0] network 168.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
[DeviceC] traffic classifier qppb
[DeviceC-classifier-qppb] if-match qos-local-id 3
[DeviceC-classifier-qppb] quit
[DeviceC] traffic behavior qppb
[DeviceC-behavior-qppb] car cir 200000 green pass red discard
[DeviceC-behavior-qppb] quit
[DeviceC] qos policy qppb
[DeviceC-qospolicy-qppb] classifier qppb behavior qppb mode qppb-manipulation
[DeviceC-qospolicy-qppb] quit
[DeviceC] interface ten-gigabitethernet 3/1/2
[DeviceC-Ten-GigabitEthernet3/1/2] mpls enable
[DeviceC-Ten-GigabitEthernet3/1/2] mpls ldp enable
# Enable QPPB on Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2.
[DeviceC-Ten-GigabitEthernet3/1/2] bgp-policy source ip-qos-map
[DeviceC-Ten-GigabitEthernet3/1/2] quit
[DeviceC] interface ten-gigabitethernet 3/1/1
[DeviceC-Ten-GigabitEthernet3/1/1] bgp-policy source ip-qos-map
[DeviceC-Ten-GigabitEthernet3/1/1] quit
[DeviceC-Ten-GigabitEthernet3/1/1] ip binding vpn-instance vpn1
[DeviceC-Ten-GigabitEthernet3/1/1] ip address 169.1.1.2 24
# Apply QoS policy qppb to the incoming traffic of Ten-GigabitEthernet 3/1/1.
[DeviceC-Ten-GigabitEthernet3/1/1] qos apply policy qppb inbound
# Apply QoS policy qppb to the incoming traffic of Ten-GigabitEthernet 3/1/2.
[DeviceC-Ten-GigabitEthernet3/1/2] qos apply policy qppb inbound
5. Configure a BGP connection on Device D.
<DeviceD> system-view
[DeviceD] bgp 300
[DeviceD-bgp] peer 169.1.1.2 as-number 200
[DeviceD-bgp] peer 169.1.1.2 connect-interface ten-gigabitethernet 3/1/2
[DeviceD-bgp] address-family ipv4
[DeviceD-bgp-ipv4] peer 169.1.1.2 enable
[DeviceD-bgp-ipv4] import-route direct
[DeviceD-bgp-ipv4] quit
# Verify that the related routes on Device A take effect.
[DeviceA] display ip routing-table
Destinations : 16 Routes : 16
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
167.1.1.0/24 Direct 0 0 167.1.1.1 XGE3/1/2
167.1.1.0/32 Direct 0 0 167.1.1.1 XGE3/1/2
167.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
167.1.1.255/32 Direct 0 0 167.1.1.1 XGE3/1/2
169.1.1.0/24 BGP 255 0 167.1.1.2 XGE3/1/2
192.168.1.0/24 Direct 0 0 192.168.1.2 XGE3/1/1
192.168.1.0/32 Direct 0 0 192.168.1.2 XGE3/1/1
192.168.1.2/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.255/32 Direct 0 0 192.168.1.2 XGE3/1/1
192.168.3.0/24 BGP 255 0 167.1.1.2 XGE3/1/2
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# Verify that the related routes on Device B take effect.
[DeviceB] display ip routing-table
Destinations : 12 Routes : 12
1.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
2.2.2.2/32 OSPF 10 1 168.1.1.1 XGE3/1/2
168.1.1.0/24 Direct 0 0 168.1.1.2 XGE3/1/2
168.1.1.0/32 Direct 0 0 168.1.1.2 XGE3/1/2
168.1.1.2/32 Direct 0 0 127.0.0.1 InLoop0
168.1.1.255/32 Direct 0 0 168.1.1.2 XGE3/1/2
[DeviceB] display ip routing-table vpn-instance vpn1
Destinations : 14 Routes : 14
167.1.1.0/24 Direct 0 0 167.1.1.2 XGE3/1/1
167.1.1.0/32 Direct 0 0 167.1.1.2 XGE3/1/1
167.1.1.2/32 Direct 0 0 127.0.0.1 InLoop0
167.1.1.255/32 Direct 0 0 167.1.1.2 XGE3/1/1
169.1.1.0/24 BGP 255 0 2.2.2.2 XGE3/1/2
192.168.1.0/24 BGP 255 0 167.1.1.1 XGE3/1/1
192.168.2.0/24 BGP 255 0 167.1.1.1 XGE3/1/1
192.168.3.0/24 BGP 255 0 2.2.2.2 XGE3/1/2
# Verify that the related routes on Device C take effect.
[DeviceC] display ip routing-table
1.1.1.1/32 OSPF 10 1 168.1.1.2 XGE3/1/2
2.2.2.2/32 Direct 0 0 127.0.0.1 InLoop0
168.1.1.0/24 Direct 0 0 168.1.1.1 XGE3/1/2
168.1.1.0/32 Direct 0 0 168.1.1.1 XGE3/1/2
168.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
168.1.1.255/32 Direct 0 0 168.1.1.1 XGE3/1/2
[DeviceC] display ip routing-table vpn-instance vpn1
167.1.1.0/24 BGP 255 0 1.1.1.1 XGE3/1/2
169.1.1.0/24 Direct 0 0 169.1.1.2 XGE3/1/1
169.1.1.0/32 Direct 0 0 169.1.1.2 XGE3/1/1
169.1.1.2/32 Direct 0 0 127.0.0.1 InLoop0
169.1.1.255/32 Direct 0 0 169.1.1.2 XGE3/1/1
192.168.1.0/24 BGP 255 0 1.1.1.1 XGE3/1/2
192.168.2.0/24 BGP 255 0 169.1.1.1 XGE3/1/1
192.168.3.0/24 BGP 255 0 169.1.1.1 XGE3/1/1
# Verify that the related routes on Device D take effect.
[DeviceD] display ip routing-table
167.1.1.0/24 BGP 255 0 169.1.1.2 XGE3/1/2
169.1.1.0/24 Direct 0 0 169.1.1.1 XGE3/1/2
169.1.1.0/32 Direct 0 0 169.1.1.1 XGE3/1/2
169.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
169.1.1.255/32 Direct 0 0 169.1.1.1 XGE3/1/2
192.168.1.0/24 BGP 255 0 169.1.1.2 XGE3/1/2
192.168.3.0/24 Direct 0 0 192.168.3.2 XGE3/1/1
192.168.3.0/32 Direct 0 0 192.168.3.2 XGE3/1/1
192.168.3.2/32 Direct 0 0 127.0.0.1 InLoop0
192.168.3.255/32 Direct 0 0 192.168.3.2 XGE3/1/1
# Display the QoS policy configuration in the inbound direction on Device C.
[DeviceC] display qos policy interface inbound
Direction: Inbound
Policy: qppb
Matched : 312 (Packets) 18916 (Bytes)
Forwarded: 0/24 (pps/bps)
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
Classifier: qppb
Operator: AND
Rule(s) :
Behavior: qppb
CIR 200000 (kbps), CBS 1250000 (Bytes), EBS 0 (Bytes)
Green action : pass
Direction: Inbound
Policy: qppb
Matched : 311 (Packets) 23243 (Bytes)
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
Classifier: qppb
Operator: AND
Rule(s) :
Behavior: qppb
CIR 200000 (kbps), CBS 12500480 (Bytes), EBS 0 (Bytes)
Green action : pass
Example: Configuring QPPB in an IPv6 network
As shown in Figure 27, all devices run BGP.
· Receive routes.
· Set the QPPB IP precedence value and local QoS ID.
· Use the QoS policy to limit the rate of traffic with the IP precedence value and local QoS ID to 512000 kbps.
1. Configure IPv6 addresses for each interface. (Details not shown.)
2. Configure BGP on Device A.
[DeviceA] bgp 1000
[DeviceA] peer 168::2 as-number 2000
[DeviceA] peer 168::2 connect-interface ten-gigabitethernet 3/1/2
[DeviceA-bgp] address-family ipv6
[DeviceA-bgp-ipv6] peer 168::2 enable
[DeviceA-bgp-ipv6] import-route direct
[DeviceA-bgp-ipv6] quit
[DeviceA-bgp] quit
# Configure BGP.
[DeviceB] bgp 2000
[DeviceB] peer 168::1 as-number 1000
[DeviceB] peer 168::1 connect-interface ten-gigabitethernet 3/1/2
[DeviceB-bgp] address-family ipv6
[DeviceB-bgp-ipv6] peer 168::1 enable
[DeviceB-bgp-ipv6] peer 168::1 route-policy qppb import
[DeviceB-bgp-ipv6] quit
[DeviceB-bgp] quit
[DeviceB-route-policy-qppb-0] apply ip-precedence 4
[DeviceB-classifier-qppb] if-match ip-precedence 4
[DeviceB-behavior-qppb] car cir 512000 red discard
# Apply the QoS policy to the incoming traffic of Ten-GigabitEthernet 3/1/2.
[DeviceA] display bgp routing-table ipv6 2:: 64
BGP local router ID: 0.0.0.0
Local AS number: 1000
BGP routing table information of 168::/64:
Imported route.
Original nexthop: ::
Route age : 00h17m18s
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : (null)
Origin : incomplete
Attribute value : MED 0, pref-val 32768
State : valid, local, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
[DeviceB] display bgp routing-table ipv6 1:: 64
Imported route.
Route age : 00h05m17s
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : (null)
Origin : incomplete
IP precedence : 4
QoS local ID : 3
Traffic index : N/A
# Display the configuration and statistics for the QoS policy applied to Ten-GigabitEthernet 3/1/2 on Device B.
Direction: Inbound
Policy: qppb
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
Classifier: qppb
Operator: AND
Rule(s) :
If-match ip-precedence 4
Behavior: qppb
Green action : pass
Configuring packet-drop logging for control plane traffic
About packet-drop logging for control plane traffic
A device provides the user plane and the control plane.
· User plane—The units at the user plane are responsible for receiving, transmitting, and switching (forwarding) packets, such as various dedicated forwarding chips. They deliver super processing speeds and throughput.
· Control plane—The units at the control plane are processing units running most routing and switching protocols. They are responsible for protocol packet resolution and calculation, such as CPUs. Compared with user plane units, the control plane units allow for great packet processing flexibility but have lower throughput.
If protocol packets sent to the control plane are dropped, the protocol operation will be affected. You can configure packet-drop logging for control plane traffic. The device regularly counts the number of packets dropped by the control plane. When the number of packets reaches the threshold, the device generates and sends logs to the information center. For information about configuring the information center, see Network Management and Monitoring Configuration Guide.
1. Enter system view.
2. Enter control plane view.
In standalone mode:
control-plane slot slot-number [ cpu cpu-number ]
In IRF mode:
control-plane chassis chassis-number slot slot-number [ cpu cpu-number ]
3. Enable packet-drop logging for control plane traffic.
logging packet-drop { user-defined-flow | whitelist } enable
By default, packet-drop logging is enabled for control plane traffic.
4. (Optional.) Set the packet thresholds for sending packet-drop logs.
logging packet-drop { user-defined-flow | whitelist } { count-threshold count-threshold-value | rate-threshold rate-threshold-value } *
By default, the packet count threshold and packet rate threshold for sending packet-drop logs are 30000 packets and 50 packets per minute, respectively.
5. (Optional.) Set the interval for sending packet-drop logs.
logging packet-drop { user-defined-flow | whitelist } interval interval-value
The default setting is 600 seconds.
Display and maintenance commands for packet-drop logging for control plane traffic
Task |
Command |
Display the packet-drop logging configuration for control plane traffic. |
In standalone mode: display qos control-plane logging [ slot slot-number [ cpu cpu-number ] ] In IRF mode: display qos control-plane logging [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Appendixes
Appendix A Acronyms
Table 4 Appendix A Acronyms
Acronym |
Full spelling |
AF |
Assured Forwarding |
BE |
Best Effort |
BQ |
Bandwidth Queuing |
CAR |
Committed Access Rate |
CBS |
Committed Burst Size |
CBQ |
Class Based Queuing |
CE |
Congestion Experienced |
CIR |
Committed Information Rate |
CQ |
Custom Queuing |
DCBX |
Data Center Bridging Exchange Protocol |
DiffServ |
Differentiated Service |
DSCP |
Differentiated Services Code Point |
EBS |
Excess Burst Size |
ECN |
Explicit Congestion Notification |
EF |
Expedited Forwarding |
FIFO |
First in First out |
FQ |
Fair Queuing |
GMB |
Guaranteed Minimum Bandwidth |
GTS |
Generic Traffic Shaping |
IntServ |
Integrated Service |
ISP |
Internet Service Provider |
LLQ |
Low Latency Queuing |
LSP |
Label Switched Path |
MPLS |
Multiprotocol Label Switching |
PE |
Provider Edge |
PHB |
Per Hop Behavior |
PIR |
Peak Information Rate |
PQ |
Priority Queuing |
PW |
Pseudowire |
QoS |
Quality of Service |
QPPB |
QoS Policy Propagation Through the Border Gateway Protocol |
RED |
Random Early Detection |
RSVP |
Resource Reservation Protocol |
RTP |
Real-Time Transport Protocol |
SP |
Strict Priority |
ToS |
Type of Service |
VoIP |
Voice over IP |
VPN |
Virtual Private Network |
WFQ |
Weighted Fair Queuing |
WRED |
Weighted Random Early Detection |
WRR |
Weighted Round Robin |
Appendix B Default priority maps
Uncolored priority maps
For the default dot1p-dot1p, dot1p-exp, dscp-dscp, exp-lp, exp-dot1p, and exp-exp priority maps, an input value yields a target value equal to it.
Table 5 Default dot1p-lp, dot1p-dp, and dot1p-dscp priority maps
Input priority value |
dot1p-lp map |
dot1p-dp map |
dot1p-dscp map |
dot1p |
lp |
dp |
dscp |
0 |
2 |
0 |
0 |
1 |
0 |
0 |
8 |
2 |
1 |
0 |
16 |
3 |
3 |
0 |
24 |
4 |
4 |
0 |
32 |
5 |
5 |
0 |
40 |
6 |
6 |
0 |
48 |
7 |
7 |
0 |
56 |
Table 6 Default dscp-lp, dscp-dp, dscp-dot1p, and dscp-exp priority maps
dscp-lp map |
dscp-dp map |
dscp-dot1p map |
dscp-exp map |
dscp |
lp |
dp |
dot1p |
exp |
0 to 7 |
0 |
0 |
0 |
0 |
8 to 15 |
1 |
0 |
1 |
1 |
16 to 23 |
2 |
0 |
2 |
2 |
24 to 31 |
3 |
0 |
3 |
3 |
32 to 39 |
4 |
0 |
4 |
4 |
40 to 47 |
5 |
0 |
5 |
5 |
48 to 55 |
6 |
0 |
6 |
6 |
56 to 63 |
7 |
0 |
7 |
7 |
Table 7 Default exp-dscp and exp-dp priority maps
exp-dscp map |
exp-dp map |
EXP value |
dscp |
dp |
0 |
0 |
0 |
1 |
8 |
0 |
2 |
16 |
0 |
3 |
24 |
0 |
4 |
32 |
0 |
5 |
40 |
0 |
6 |
48 |
0 |
7 |
56 |
0 |
Colored priority maps
An input value yields a target value equal to it for the following default colored priority maps for green/yellow/red packets:
· dot1p-dot1p.
· dot1p-exp.
· dscp-dscp.
· exp-lp.
· exp-dot1p.
· exp-exp.
· lp-lp.
· lp-exp.
Table 8 Default dscp-dot1p, dscp-dp, dscp-exp, and dscp-lp priority maps for green packets
dscp-dot1p map |
dscp-dp map |
dscp-exp map |
dscp-lp map |
DSCP of green packets |
dot1p |
dp |
exp |
lp |
0 to 7 |
0 |
0 |
0 |
0 |
8 to 15 |
1 |
0 |
1 |
1 |
16 to 23 |
2 |
0 |
2 |
2 |
24 to 31 |
3 |
0 |
3 |
3 |
32 to 39 |
4 |
0 |
4 |
4 |
40 to 47 |
5 |
0 |
5 |
5 |
48 to 55 |
6 |
0 |
6 |
6 |
56 to 63 |
7 |
0 |
7 |
7 |
Table 9 Default dscp-dot1p, dscp-dp, dscp-exp, and dscp-lp priority maps for yellow packets
dscp-dot1p map |
dscp-dp map |
dscp-exp map |
dscp-lp map |
DSCP of yellow packets |
dot1p |
dp |
exp |
lp |
0 to 7 |
0 |
1 |
0 |
0 |
8 to 15 |
1 |
1 |
1 |
1 |
16 to 23 |
2 |
1 |
2 |
2 |
24 to 31 |
3 |
1 |
3 |
3 |
32 to 39 |
4 |
1 |
4 |
4 |
40 to 47 |
5 |
1 |
5 |
5 |
48 to 55 |
6 |
1 |
6 |
6 |
56 to 63 |
7 |
1 |
7 |
7 |
Table 10 Default dscp-dot1p, dscp-dp, dscp-exp, and dscp-lp priority maps for red packets
dscp-dot1p map |
dscp-dp map |
dscp-exp map |
dscp-lp map |
DSCP of red packets |
dot1p |
dp |
exp |
lp |
0 to 7 |
0 |
2 |
0 |
0 |
8 to 15 |
1 |
2 |
1 |
1 |
16 to 23 |
2 |
2 |
2 |
2 |
24 to 31 |
3 |
2 |
3 |
3 |
32 to 39 |
4 |
2 |
4 |
4 |
40 to 47 |
5 |
2 |
5 |
5 |
48 to 55 |
6 |
2 |
6 |
6 |
56 to 63 |
7 |
2 |
7 |
7 |
Table 11 Default exp-dp and exp-dscp priority maps for green packets
exp-dp map |
exp-dscp map |
EXP of green packets |
dp |
dscp |
0 |
0 |
0 |
1 |
0 |
8 |
2 |
0 |
16 |
3 |
0 |
24 |
4 |
0 |
32 |
5 |
0 |
40 |
6 |
0 |
48 |
7 |
0 |
56 |
Table 12 Default exp-dp and exp-dscp priority maps for yellow packets
exp-dp map |
exp-dscp map |
EXP of yellow packets |
dp |
dscp |
0 |
1 |
0 |
1 |
1 |
8 |
2 |
1 |
16 |
3 |
1 |
24 |
4 |
1 |
32 |
5 |
1 |
40 |
6 |
1 |
48 |
7 |
1 |
56 |
Table 13 Default exp-dp and exp-dscp priority maps for red packets
exp-dp map |
exp-dscp map |
EXP of red packets |
dp |
dscp |
0 |
2 |
0 |
1 |
2 |
8 |
2 |
2 |
16 |
3 |
2 |
24 |
4 |
2 |
32 |
5 |
2 |
40 |
6 |
2 |
48 |
7 |
2 |
56 |
Appendix C Introduction to packet precedence
IP precedence and DSCP values
As shown in Figure 28, the ToS field in the IP header contains 8 bits. The first 3 bits (0 to 2) represent IP precedence from 0 to 7. According to RFC 2474, the ToS field is redefined as the differentiated services (DS) field. A DSCP value is represented by the first 6 bits (0 to 5) of the DS field and is in the range 0 to 63. The remaining 2 bits (6 and 7) are reserved.
Table 14 IP precedence
IP precedence (decimal) |
IP precedence (binary) |
0 |
000 |
Routine |
1 |
001 |
priority |
2 |
010 |
immediate |
3 |
011 |
flash |
4 |
100 |
flash-override |
5 |
101 |
critical |
6 |
110 |
internet |
7 |
111 |
network |
Table 15 DSCP values
DSCP value (decimal) |
DSCP value (binary) |
46 |
101110 |
ef |
10 |
001010 |
af11 |
12 |
001100 |
af12 |
14 |
001110 |
af13 |
18 |
010010 |
af21 |
20 |
010100 |
af22 |
22 |
010110 |
af23 |
26 |
011010 |
af31 |
28 |
011100 |
af32 |
30 |
011110 |
af33 |
34 |
100010 |
af41 |
36 |
100100 |
af42 |
38 |
100110 |
af43 |
8 |
001000 |
cs1 |
16 |
010000 |
cs2 |
24 |
011000 |
cs3 |
32 |
100000 |
cs4 |
40 |
101000 |
cs5 |
48 |
110000 |
cs6 |
56 |
111000 |
cs7 |
0 |
000000 |
be (default) |
802.1p priority
802.1p priority lies in the Layer 2 header. It applies to occasions where Layer 3 header analysis is not needed and QoS must be assured at Layer 2.
Figure 29 An Ethernet frame with an 802.1Q tag header
As shown in Figure 29, the 4-byte 802.1Q tag header contains the 2-byte tag protocol identifier (TPID) and the 2-byte tag control information (TCI). The value of the TPID is 0x8100. Figure 30 shows the format of the 802.1Q tag header. The Priority field in the 802.1Q tag header is called 802.1p priority, because its use is defined in IEEE 802.1p. Table 16 shows the values for 802.1p priority.
Table 16 Description on 802.1p priority
802.1p priority (decimal) |
802.1p priority (binary) |
0 |
000 |
best-effort |
1 |
001 |
background |
2 |
010 |
spare |
3 |
011 |
excellent-effort |
4 |
100 |
controlled-load |
5 |
101 |
video |
6 |
110 |
voice |
7 |
111 |
network-management |
EXP values
The EXP field is in MPLS labels for MPLS QoS purposes. As shown in Figure 31, the EXP field is 3-bit long and is in the range of 0 to 7.
Figure 31 MPLS label structure
