- 08-IP Multicast Configuration Guide
- 01-Multicast overview
- 02-IGMP snooping configuration
- 03-PIM snooping configuration
- 04-Multicast VLAN configuration
- 05-Multicast routing and forwarding configuration
- 06-IGMP configuration
- 07-PIM configuration
- 08-MSDP configuration
- 09-Multicast VPN configuration
- 10-MLD snooping configuration
- 11-IPv6 PIM snooping configuration
- 12-IPv6 multicast VLAN configuration
- 13-IPv6 multicast routing and forwarding configuration
- 14-MLD configuration
- 15-IPv6 PIM configuration
| 04-Multicast VLAN configuration | 137.28 KB |
Restrictions and guidelines: Multicast VLAN configuration
Configuring a sub-VLAN-based multicast VLAN
Setting the maximum number of multicast VLAN forwarding entries
Display and maintenance commands for multicast VLAN
Multicast VLAN configuration examples
Example: Configuring sub-VLAN-based multicast VLAN
Configuring multicast VLANs
Multicast VLAN function
As shown in Figure 1, Host A, Host B, and Host C are in three different VLANs and the same multicast group. When Device A (Layer 3 device) receives multicast data for that group, it sends three copies of the multicast data to Device B (Layer 2 device). This occupies a large amount of bandwidth and increases the burden on the Layer 3 device.
Figure 1 Multicast transmission without the multicast VLAN feature
After a multicast VLAN is configured on Device B, Device A sends only one copy of the multicast data to the multicast VLAN on Switch B. This method saves network bandwidth and lessens the burden on the Layer 3 device.
Multicast VLAN methods
Multicast VLANs include sub-VLAN-based multicast VLANs and port-based multicast VLANs. Port-based multicast VLANs are not supported in the current software version.
Sub-VLAN-based multicast VLAN
As shown in Figure 2:
· Host A, Host B, and Host C are in VLAN 2 through VLAN 4, respectively.
· On Device B, VLAN 10 is a multicast VLAN. VLAN 2 through VLAN 4 are sub-VLANs of VLAN 10.
· IGMP snooping is enabled for the multicast VLAN and its sub-VLANs.
Figure 2 Sub-VLAN-based multicast VLAN
IGMP snooping manages router ports in the multicast VLAN and member ports in each sub-VLAN. When Switch A receives multicast data from the multicast source, it sends only one copy of the multicast data to the multicast VLAN on Device B. Then, Device B sends a separate copy to each sub-VLAN in the multicast VLAN.
As shown in Figure 3:
· On Device B, VLAN 10 is a multicast VLAN. All the user ports are hybrid ports and are assigned to VLAN 10.
· IGMP snooping is enabled for the multicast VLAN and VLAN 2 through VLAN 4.
Figure 3 Port-based multicast VLAN
IGMP snooping manages the router ports and member ports in the multicast VLAN. When Device A receives multicast data from the multicast source, it sends only one copy of the multicast data to the multicast VLAN on Device B. Device B sends a separate copy to each user port in the multicast VLAN.
This feature is available only for the following cards:
Card category |
Cards |
CEPC |
NP5 cards-CEPC |
CSPC |
FPGA cards-CSPC |
CSPEX |
NP5 cards-CSPEX, FPGA cards-CSPEX |
SPEX |
FPGA cards-SPEX |
SPE |
NP5 cards-SPE |
The VLAN to be configured as a multicast VLAN must exist, and only one multicast VLAN is configured.
As a best practice to avoid multicast forwarding exceptions, do not configure both multicast VLAN and IP multicast routing on a device.
As a best practice, do not configure a VLAN as a multicast VLAN or a multicast sub-VLAN if the VLAN interface is enabled with PIM or IGMP. Additionally, do not enable PIM or IGMP on a VLAN interface if the VLAN interface belongs to a multicast VLAN or a multicast sub-VLAN. A violation might cause multicast forwarding exceptions.
The VLANs to be configured as sub-VLANs of a multicast VLAN must exist and cannot be multicast VLANs or sub-VLANs of any other multicast VLAN.
Before you configure a sub-VLAN-based multicast VLAN, you must complete the following tasks:
· Create VLANs as required.
· Enable IGMP snooping for the VLAN to be configured as the multicast VLAN and for the VLANs to be configured as sub-VLANs.
1. Enter system view.
2. Configure a VLAN as a multicast VLAN and enter multicast VLAN view.
multicast-vlan vlan-id
By default, a VLAN is not a multicast VLAN.
3. Assign VLANs to the multicast VLAN as sub-VLANs.
subvlan vlan-list
You can set the maximum number of multicast VLAN forwarding entries on the device. When the upper limit is reached, the device does not create multicast VLAN forwarding entries until some entries age out or are manually removed.
2. Set the maximum number of multicast VLAN forwarding entries.
multicast-vlan entry-limit limit
The default setting is 1024.
Task |
Command |
Display information about multicast VLANs. |
display multicast-vlan [ vlan-id ] |
Display information about multicast groups in multicast VLANs. |
In standalone mode: display multicast-vlan group [ source-address | group-address | slot slot-number [ cpu cpu-number ] | verbose | vlan vlan-id ] * In IRF mode: display multicast-vlan group [ source-address | group-address | chassis chassis-number slot slot-number [ cpu cpu-number ] | verbose | vlan vlan-id ] * |
Display information about multicast VLAN forwarding entries. |
In standalone mode: display multicast-vlan forwarding-table [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | slot slot-number [ cpu cpu-number ] | subvlan vlan-id | vlan vlan-id ] * In IRF mode: display multicast-vlan forwarding-table [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] chassis chassis-number slot slot-number [ cpu cpu-number ] | subvlan vlan-id | vlan vlan-id ] * |
Clear multicast groups in multicast VLANs. |
reset multicast-vlan group [ source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] | vlan vlan-id ] * |
As shown in Figure 4:
· Layer 3 device Device A runs IGMPv2 and acts as the IGMP querier. Layer 2 device Device B runs IGMPv2 snooping.
· The multicast source sends multicast data to multicast group 224.1.1.1. Receivers Host A, Host B, and Host C belong to VLAN 2, VLAN 3, and VLAN 4, respectively.
Configure a sub-VLAN-based multicast VLAN on Device B to meet the following requirements:
· Device A sends the multicast data to Device B through the multicast VLAN.
· Device B forwards the multicast data to the receivers in different user VLANs.
1. Configure Device A:
# Enable IP multicast routing.
[DeviceA] multicast routing
[DeviceA-mrib] quit
# Create VLAN 20, and assign Ten-GigabitEthernet 3/1/2 to the VLAN.
[DeviceA] vlan 20
[DeviceA-vlan20] port ten-gigabitethernet 3/1/2
[DeviceA-vlan20] quit
# Assign an IP address to VLAN-interface 20, and enable PIM-DM on the interface.
[DeviceA] interface vlan-interface 20
[DeviceA-Vlan-interface20] ip address 1.1.1.2 24
[DeviceA-Vlan-interface20] pim dm
[DeviceA-Vlan-interface20] quit
# Create VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] quit
# Configure Ten-GigabitEthernet 3/1/1 as a hybrid port, and assign the port to VLAN 10 as a tagged VLAN member.
[DeviceA] interface ten-gigabitethernet 3/1/1
[DeviceA-Ten-GigabitEthernet3/1/1] port link-type hybrid
[DeviceA-Ten-GigabitEthernet3/1/1] port hybrid vlan 10 tagged
[DeviceA-Ten-GigabitEthernet3/1/1] quit
# Assign an IP address to VLAN-interface 10, and enable IGMP on the interface.
[DeviceA-Vlan-interface10] ip address 10.110.1.1 24
[DeviceA-Vlan-interface10] igmp enable
2. Configure Device B:
# Enable IGMP snooping globally.
[DeviceB] igmp-snooping
[DeviceB-igmp-snooping] quit
# Create VLAN 2, assign Ten-GigabitEthernet 3/1/2 to the VLAN, and enable IGMP snooping for the VLAN.
[DeviceB] vlan 2
[DeviceB-vlan2] port ten-gigabitethernet 3/1/2
[DeviceB-vlan2] igmp-snooping enable
[DeviceB-vlan2] quit
# Create VLAN 3, assign Ten-GigabitEthernet 3/1/3 to the VLAN, and enable IGMP snooping in the VLAN.
[DeviceB] vlan 3
[DeviceB-vlan3] port ten-gigabitethernet 3/1/3
[DeviceB-vlan3] igmp-snooping enable
[DeviceB-vlan3] quit
# Create VLAN 4, assign GigabitEthernet 1/0/4 to the VLAN, and enable IGMP snooping in the VLAN.
[DeviceB] vlan 4
[DeviceB-vlan4] port ten-gigabitethernet 3/1/4
[DeviceB-vlan4] igmp-snooping enable
[DeviceB-vlan4] quit
# Create VLAN 10, and enable IGMP snooping for the VLAN.
[DeviceB] vlan 10
[DeviceB-vlan10] igmp-snooping enable
[DeviceB-vlan10] quit
[DeviceB] interface ten-gigabitethernet 3/1/1
[DeviceB-Ten-GigabitEthernet3/1/1] port link-type hybrid
[DeviceB-Ten-GigabitEthernet3/1/1] port hybrid vlan 10 tagged
[DeviceB-Ten-GigabitEthernet3/1/1] quit
# Configure VLAN 10 as a multicast VLAN, and assign VLAN 2 through VLAN 4 as sub-VLANs to multicast VLAN 10.
[DeviceB] multicast-vlan 10
[DeviceB-mvlan-10] subvlan 2 to 4
[DeviceB-mvlan-10] quit
# Display information about all multicast VLANs on Device B.
[DeviceB] display multicast-vlan
Total 1 multicast VLANs.
Multicast VLAN 10:
Sub-VLAN list(3 in total):
2-4
# Display information about multicast groups in multicast VLANs on Device B.
[DeviceB] display multicast-vlan group
Total 1 entries.
Multicast VLAN 10: Total 1 entries.
(0.0.0.0, 224.1.1.1)
Sub-VLANs (3 in total):
VLAN 2
VLAN 3
VLAN 4
The output shows that multicast group 224.1.1.1 belongs to multicast VLAN 10. Multicast VLAN 10 contains sub-VLANs VLAN 2 through VLAN 4. Device B will replicate the multicast data of VLAN 10 to VLAN 2 through VLAN 4.
