- 12-Security Configuration Guide
- 01-DAE proxy configuration
- 02-Password control configuration
- 03-Keychain configuration
- 04-Public key management
- 05-PKI configuration
- 06-IPsec configuration
- 07-SSH configuration
- 08-SSL configuration
- 09-Session management
- 10-Object group configuration
- 11-Attack detection and prevention configuration
- 12-IP-based attack prevention configuration
- 13-IP source guard configuration
- 14-ARP attack protection configuration
- 15-ND attack defense configuration
- 16-uRPF configuration
- 17-SAVA configuration
- 18-Crypto engine configuration
- 19-SMA configuration
- 20-SAVNET configuration
| 09-Session management | 141.85 KB |
Restrictions and guidelines: Session management configuration
Setting the session aging time for different protocol states
Setting the session aging time for different application layer protocols
Specifying persistent sessions
Enabling session synchronization
Enabling session statistics collection
Configuring SNMP notifications for session entry resources
Configuring session entry resource logging
Enabling destination address matching for SIP relation entries
Display and maintenance commands for session management
Managing sessions
About session management
Session management is a common module, providing basic services for attack detection and protection to implement their session-based services.
Session management defines packet exchanges at transport layer as sessions. It updates session states and ages out sessions according to data flows from the initiators or responders. Session management allows multiple features to process the same service packet.
Session management operation
Session management tracks the session status by inspecting the transport layer protocol information. It performs unified status maintenance and management of all connections based on session tables and relation tables.
When a connection request passes through the device from a client to a server, the device creates a session entry. The entry can contain the request and response information, such as:
· Source IP address and port number.
· Destination IP address and port number.
· Transport layer protocol.
· Application layer protocol.
· Protocol state of the session.
A multichannel protocol requires that the client and the server negotiate a new connection based on an existing connection to implement an application. Session management enables the device to create a relation entry for each connection during the negotiation phase. The entry is used to associate the connection with the application. Relation entries will be removed after the associated connections are established.
If the destination IP address of a packet is a multicast IP address, the packet will be forwarded out of multiple ports. When a multicast connection request is received on an inbound interface, the device performs the following operations:
· Creates a multicast session entry on the inbound interface.
· Creates a corresponding multicast session entry for each outbound interface.
Unless otherwise stated, "session entry" in this chapter refers to both unicast and multicast session entries.
Session management only tracks connection status. It does not block potential attack packets.
Session management functions
Session management enables the device to provide the following functions:
· Creates sessions for protocol packets, updates session states, and sets aging time for sessions in different protocol states.
· Sets aging time for sessions based on application layer protocols.
· Supports ICMP/ICMPv6 error packet mapping, enabling the device to search for original sessions according to the payloads in the ICMP/ICMPv6 error packets.
Because error packets are generated due to host errors, the mapping can help speed up the aging of the original sessions.
· Supports persistent sessions, which are kept alive for a long period of time.
· Supports session management for the control channels and dynamic data channels of application layer protocols, for example, FTP.
· Supports real-time synchronization for sessions and for dynamic entries of session-based services, .
For a TCP session in ESTABLISHED state, the priority order of the associated aging time is as follows:
· Aging time for persistent sessions.
· Aging time for sessions of application layer protocols.
· Aging time for sessions in different protocol states.
If the device has excessive sessions, do not set the aging time shorter than the default for a certain protocol state or an application layer protocol. Short aging time settings can make the device slow in response.
If a session in a certain protocol state has no packet hit before the aging time expires, the device automatically removes the session.
1. Enter system view.
2. Set the session aging time for different protocol states.
session aging-time state { fin | icmp-reply | icmp-request | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | syn | tcp-est | udp-open | udp-ready } time-value
The default aging time for sessions in different protocol states is as follows:
¡ FIN_WAIT: 30 seconds.
¡ ICMP-REPLY: 30 seconds.
¡ ICMP-REQUEST: 60 seconds.
¡ ICMPv6-REPLY: 30 seconds.
¡ ICMPv6-REQUEST: 60 seconds.
¡ RAWIP-OPEN: 30 seconds.
¡ RAWIP-READY: 60 seconds.
¡ TCP SYN-SENT and SYN-RCV: 30 seconds.
¡ TCP ESTABLISHED: 240 seconds.
¡ UDP-OPEN: 30 seconds.
¡ UDP-READY: 240 seconds.
The aging time for sessions of different application layer protocols are valid for TCP sessions in ESTABLISHED state or UDP sessions in READY state. For sessions used by other application layer protocols, the aging time for sessions in different protocol states applies.
2. Set the session aging time for different application layer protocols.
session aging-time application { dns | ftp | gtp | h225 | h245 | ils | mgcp | nbt | pptp | ras | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp } time-value
By default, the session aging time is as follows:
¡ DNS: 1 second.
¡ FTP: 240 seconds.
¡ GTP: 60 seconds.
¡ H.225: 3600 seconds.
¡ H.245: 3600 seconds.
¡ ILS: 3600 seconds.
¡ MGCP: 60 seconds.
¡ NBT: 3600 seconds.
¡ PPTP: 3600 seconds.
¡ RAS: 300 seconds.
¡ RSH: 60 seconds.
¡ RTSP: 3600 seconds.
¡ SCCP: 3600 seconds.
¡ SIP: 300 seconds.
¡ SQLNET: 600 seconds.
¡ TFTP: 60 seconds.
¡ XDMCP: 3600 seconds.
This task is only for TCP sessions in ESTABLISHED state. You can specify TCP sessions that match the permit statements in the specified ACL as persistent sessions, and set longer lifetime or never-age-out persistent sessions.
A persistent session is not removed until one of the following events occurs:
· The session entry ages out.
· The device receives a connection close request from the initiator or responder.
· You manually clear the session entries.
2. Specify persistent sessions.
session persistent acl [ ipv6 ] acl-number [ aging-time time-value ]
This feature enables devices to synchronize sessions and dynamic entries of session-based services, . Typically, these devices back up each other and use a virtual IP address to communicate with a peer device. When the primary device fails, a backup device takes over to process and forward service traffic. The failover process is transparent to the peer device, and does not interrupt ongoing services.
This feature also provides automatic backup service for the device. The system automatically backs up session tables and relation tables that are generated by applications that use ALG. These applications include H.323, SIP, and ILS.
Enable session synchronization for DNS and HTTP in the following situations:
· Users are aware that the current HTTP or DNS sessions will last for a long time.
· HTTP or DNS session backup is required.
On an IRF fabric, the NAT configuration is dependent of session synchronization. If session synchronization is enabled, make sure NAT is configured on global interfaces such as aggregate interfaces and Reth interfaces. If you configure NAT on physical ports, disable session synchronization as a best practice.
2. Enable session synchronization.
session synchronization enable
By default, session synchronization is disabled.
After session synchronization is enabled, session synchronization is enabled for all application layer protocols except DNS and HTTP by default.
3. (Optional.) Enable session synchronization for DNS, HTTP, or both.
session synchronization { dns | http } *
By default, session synchronization is disabled for DNS and HTTP.
4. (Optional.) Set the session synchronization delay time.
session synchronization delay seconds
The default setting is 5 seconds.
5. Enter interface view.
6. (Optional.) Specify the port identity number for session synchronization.
identity-number number
By default, no identity number is specified for a port.
For a successful session synchronization from one system to another, make sure the service ports on the two systems are configured with the same identity number.
This feature enables the device to collect session-based outbound and inbound packets and bytes. You can display session statistics based on different criteria.
· To display statistics per unicast session, use the display session table command.
· To display statistics per unicast packet type, use the display session statistics command.
· To display statistics per multicast session, use the display session table multicast command.
· To display statistics per multicast packet type, use the display session statistics multicast command.
2. Enable session statistics collection.
session statistics enable
By default, session statistics collection is disabled.
After you enable SNMP notifications for session entry resources, the device generates a notification when hardware session entry resources are exhausted or when the device recovers from the resource exhaustion condition.
For SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
2. Enable SNMP notifications for session entry resources.
snmp-agent trap enable session resources
By default, SNMP notifications are enabled for session entry resources.
Session entry resource logging enables the device to generate logs when hardware session entry resources are exhausted and when the device recovers from the resource exhaustion condition.
2. Enable session entry resource logging.
undo session resources log disable
By default, session entry resource logging is enabled.
In an SIP network, data traffic does not match destination addresses when matching the relation table entries. In this case, if a client is to access multiple servers through multiple outbound interfaces, incorrect match of the relation entries might cause the traffic to be forwarded incorrectly.
This feature requires the data traffic to match the destination addresses when matching the relation entries, which helps to forward traffic correctly.
2. Enable destination address matching for SIP relation entries.
session relation-table match destination-ip sip enable
By default, destination address matching is disabled for SIP relation entries.
Task |
Command |
Display the aging time for sessions of different application layer protocols. |
display session aging-time application |
Display the aging time for sessions in different protocol states. |
display session aging-time state |
Display IPv4 unicast session table entries. |
In standalone mode: display session table ipv4 [ slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] [ verbose ] In IRF mode: display session table ipv4 [ chassis chassis-number slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] [ verbose ] |
Display IPv6 unicast session table entries. |
In standalone mode: display session table ipv6 [ slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] [ verbose ] In IRF mode: display session table ipv6 [ chassis chassis-number slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] [ verbose ] |
Display unicast session statistics. |
In standalone mode: display session statistics [ summary ] [ slot slot-number ] In IRF mode: display session statistics [ summary ] [ chassis chassis-number slot slot-number ] |
Display IPv4 unicast session statistics. |
In standalone mode: display session statistics ipv4 { source-ip source-ip | destination-ip destination-ip | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-port source-port | destination-port destination-port } * [ slot slot-number ] In IRF mode: display session statistics ipv4 { source-ip source-ip | destination-ip destination-ip | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-port source-port | destination-port destination-port } * [ chassis chassis-number slot slot-number ] |
Display IPv6 unicast session statistics. |
In standalone mode: display session statistics ipv6 { source-ip source-ip | destination-ip destination-ip | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-port source-port | destination-port destination-port } * [ slot slot-number ] In IRF mode: display session statistics ipv6 { source-ip source-ip | destination-ip destination-ip | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-port source-port | destination-port destination-port } * [ chassis chassis-number slot slot-number ] |
Display IPv4 multicast session table entries. |
In standalone mode: display session table multicast ipv4 [ slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ verbose ] In IRF mode: display session table multicast ipv4 [ chassis chassis-number slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ verbose ] |
Display IPv6 multicast session table entries. |
In standalone mode: display session table multicast ipv6 [ slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ verbose ] In IRF mode: display session table multicast ipv6 [ chassis chassis-number slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ verbose ] |
Display multicast session statistics. |
In standalone mode: display session statistics multicast [ slot slot-number ] In IRF mode: display session statistics multicast [ chassis chassis-number slot slot-number ] |
Display relation table entries. |
In standalone mode: display session relation-table { ipv4 | ipv6 } [ slot slot-number ] In IRF mode: display session relation-table { ipv4 | ipv6 } [ chassis chassis-number slot slot-number ] |
Display batch hot-backup state information. |
In standalone mode: display session batch-hot-backup statedisplay session relation-table { ipv4 | ipv6 } [ slot slot-number] In IRF mode: display session batch-hot-backup state [ chassis chassis-number slot slot-number ] |
Clear IPv4 unicast session table entries. |
In standalone mode: reset session table ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] In IRF mode: reset session table ipv4 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] |
Clear IPv6 unicast session table entries. |
In standalone mode: reset session table ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] In IRF mode: reset session table ipv6 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] |
Clear IPv4 and IPv6 unicast session table entries. |
In standalone mode: reset session table [ slot slot-number ] In IRF mode: reset session table [ chassis chassis-number slot slot-number ] |
Clear unicast session statistics. |
In standalone mode: reset session statistics [ slot slot-number ] In IRF mode: reset session statistics [ chassis chassis-number slot slot-number ] |
Clear IPv4 multicast session table entries. |
In standalone mode: reset session table multicast ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] In IRF mode: reset session table multicast ipv4 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] |
Clear IPv6 multicast session table entries. |
In standalone mode: reset session table multicast ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] In IRF mode: reset session table multicast ipv6 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] |
Clear IPv4 and IPv6 multicast session table entries. |
In standalone mode: reset session table multicast [ slot slot-number ] In IRF mode: reset session table multicast [ chassis chassis-number slot slot-number ] |
Clear multicast session statistics. |
In standalone mode: reset session statistics multicast [ slot slot-number ] In IRF mode: reset session statistics multicast [ chassis chassis-number slot slot-number ] |
Clear relation table entries. |
In standalone mode: reset session relation-table [ ipv4 | ipv6 ] [ slot slot-number ] In IRF mode: reset session relation-table [ ipv4 | ipv6 ] [ chassis chassis-number slot slot-number ] |
