06-Layer 3—IP Services Configuration Guide
HomeSupportRoutersH3C SR8800-F Router SeriesConfigure & DeployConfiguration GuidesH3C SR8800-F Routers Configuration Guides-R8530Pxx-6W10106-Layer 3—IP Services Configuration Guide
09-UDP helper
09-UDP helper 97.50 KB
Configuring UDP helper
About UDP helper
UDP helper can provide the following packet conversion services for packets with specific UDP destination port numbers:
·     Convert broadcast to unicast, and forward the unicast packets to specific destinations.
·     Convert broadcast to multicast, and forward the multicast packets.
Configuring UDP helper to convert broadcast to unicast
You can configure UDP helper to convert broadcast packets with specific UDP port numbers to unicast packets.
Upon receiving a UDP broadcast packet, UDP helper uses the configured UDP ports to match the UDP destination port number of the packet.
·     If a match is found, UDP helper duplicates the packet and modifies the destination IP address of the copy to the configured unicast address. Then UDP helper forwards the unicast packet to the unicast address.
·     If no match is found, UDP helper does not process the packet.
2.     Enable UDP helper.
udp-helper enable
By default, UDP helper is disabled.
3.     Specify a UDP port number for UDP helper.
By default, no UDP port numbers are specified for UDP helper.
Do not set UDP ports 67 and 68 for UDP helper, because UDP helper cannot forward DHCP broadcast packets.
You can specify a maximum of 256 UDP ports for UDP helper.
4.     Enter interface view.
5.     Specify a destination server for UDP helper to convert broadcast to unicast.
udp-helper server ip-address [ global | vpn-instance vpn-instance-name ]
By default, no destination servers are specified.
Use this command on the interface that receives broadcast packets.
You can specify a maximum of 20 unicast and multicast addresses for UDP helper to convert broadcast packets on an interface.
Configuring UDP helper to convert broadcast to multicast
You can configure UDP helper to convert broadcast packets with specific UDP port numbers to multicast packets.
·     If a match is found, UDP helper duplicates the packet and modifies the destination IP address of the copy to the configured multicast address. Then UDP helper forwards the packet to the multicast group.
udp-helper enable
5.     Specify a destination multicast address for UDP helper to convert broadcast to multicast.
udp-helper broadcast-map multicast-address [ acl acl-number ]
By default, no destination multicast addresses are specified for UDP helper.
Display and maintenance commands for UDP helper
Execute display command in any view and reset commands in user view.
Display information about broadcast to unicast conversion by UDP helper on an interface.
display udp-helper interface interface-type interface-number
Clear packet statistics for UDP helper.
reset udp-helper statistics
UDP helper configuration examples
Example: Configuring UDP helper to convert broadcast to unicast
As shown in Figure 1, configure UDP helper to convert broadcast to unicast on Ten-GigabitEthernet 3/1/1 of Router A. This feature enables Router A to forward broadcast packets with UDP destination port 55 to the destination server 10.2.1.1/16.
Figure 1 Network diagram
Make sure Router A can reach the subnet 10.2.0.0/16.
# Enable UDP helper.
[RouterA] udp-helper enable
# Specify the UDP port 55 for UDP helper.
[RouterA] udp-helper port 55
# Specify the destination server 10.2.1.1 for UDP helper to convert broadcast to unicast on Ten-GigabitEthernet 3/1/1.
[RouterA] interface ten-gigabitethernet 3/1/1
[RouterA-Ten-GigabitEthernet3/1/1] ip address 10.110.1.1 16
[RouterA-Ten-GigabitEthernet3/1/1] udp-helper server 10.2.1.1
# Display information about broadcast to unicast conversion by UDP helper on Ten-GigabitEthernet 3/1/1.
[RouterA-Ten-GigabitEthernet3/1/1] display udp-helper interface ten-gigabitethernet 3/1/1
Interface                Server VPN instance            Server address   Packets sent
Ten-GigabitEthernet3/1/1     N/A                            10.2.1.1         5
Example: Configuring UDP helper to convert broadcast to multicast
As shown in Figure 2, Router B can receive multicast packets destined for 225.1.1.1.
Configure UDP helper to convert broadcast to multicast on Ten-GigabitEthernet 3/1/1 of Router A. This feature enables Router A to forward broadcast packets with UDP destination port number 55 to the multicast group 225.1.1.1.
Figure 2 Network diagram
1.     Configure Router A:
# Enable the UDP port 55 for UDP helper.
# Configure UDP helper to convert broadcast packets to multicast packets destined for 225.1.1.1 on Ten-GigabitEthernet 3/1/1.
[RouterA-Ten-GigabitEthernet3/1/1] udp-helper broadcast-map 225.1.1.1
[RouterA-Ten-GigabitEthernet3/1/1] quit
# Enable IP multicast routing globally.
[RouterA] multicast routing
[RouterA-mrib] quit
# Enable PIM-DM on Ten-GigabitEthernet 3/1/1.
[RouterA-Ten-GigabitEthernet3/1/1] pim dm
# Enable PIM-DM and IGMP on Ten-GigabitEthernet 3/1/2.
[RouterA] interface ten-gigabitethernet 3/1/2
[RouterA-Ten-GigabitEthernet3/1/2] pim dm
[RouterA-Ten-GigabitEthernet3/1/2] igmp enable
# Configure Ten-GigabitEthernet 3/1/2 as a static member of multicast group 225.1.1.1.
[RouterA-Ten-GigabitEthernet3/1/2] igmp static-group 225.1.1.1
2.     Configure Router B:
<RouterB> system-view
[RouterB] multicast routing
[RouterB-mrib] quit
# Enable PIM-DM and IGMP on Ten-GigabitEthernet 3/1/1.
[RouterB] interface ten-gigabitethernet 3/1/1
[RouterB-Ten-GigabitEthernet3/1/1] pim dm
[RouterB-Ten-GigabitEthernet3/1/1] igmp enable
# Configure Ten-GigabitEthernet 3/1/1 as a static member of multicast group 225.1.1.1.
[RouterB-Ten-GigabitEthernet3/1/1] igmp static-group 225.1.1.1
Verify that you can capture multicast packets from Router A on Router B.
