- 17-BRAS Services Command Reference
- 01-AAA commands
- 02-ANCP commands
- 03-PPP commands
- 04-Value-added services commands
- 05-DHCP commands
- 06-DHCPv6 commands
- 07-User profile commands
- 08-Connection limit commands
- 09-L2TP commands
- 10-PPPoE commands
- 11-IPoE commands
- 12-802.1X commands
- 13-UCM commands
00-Preface | 109.77 KB |
Preface
This command reference describes the commands of BRAS features.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
