| 03-Port isolation commands | 49.08 KB |
display port-isolate group
Use display port-isolate group to display port isolation group information.
display port-isolate group [ group-id ]
group-id: Specifies an isolation group by its ID. The value range is 1 to 128.
# Display all isolation groups.
<Sysname> display port-isolate group
Port isolation group information:
Group ID: 2
Group members:
Ten-GigabitEthernet3/1/1
Group ID: 5
Group members:
Ten-GigabitEthernet3/1/2 Ten-GigabitEthernet3/1/4
Group ID |
ID of the isolation group. |
Group members |
Isolated ports in the isolation group. No ports indicates that the isolation group contains no isolated ports. |
port-isolate enable
port-isolate enable
Use port-isolate enable to assign a port to an isolation group.
Use undo port-isolate enable to remove a port from an isolation group.
port-isolate enable group group-id
The port is not assigned to any isolation group.
FlexE logical interface view
group group-id: Specifies an isolation group by its ID.The value range is 1 to 128.
To assign ports to an isolation group, make sure the isolation group already exists.
One port can be assigned to only one isolation group.
The configuration in Layer 2 Ethernet interface view applies only to the interface.
The configuration in Layer 2 aggregate interface view applies to the Layer 2 aggregate interface and its aggregation member ports. If the device fails to apply the configuration to the aggregate interface, it does not assign any aggregation member port to the isolation group. If the failure occurs on an aggregation member port, the device skips the port and continues to assign other aggregation member ports to the isolation group.
# Assign Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 to isolation group 2.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] port-isolate enable group 2
[Sysname-Ten-GigabitEthernet3/1/1] quit
[Sysname] interface ten-gigabitethernet 3/1/2
[Sysname-Ten-GigabitEthernet3/1/2] port-isolate enable group 2
port-isolate group
Use port-isolate group to create an isolation group.
Use undo port-isolate group to delete isolation groups.
port-isolate group group-id
undo port-isolate group { group-id | all }
No isolation groups exist.
all: Deletes all isolation groups.
This command is available on devices that support multiple isolation groups.
# Create isolation group 2.
[Sysname] port-isolate group 2
