13-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS12500G-AF SeriesConfigure & DeployConfiguration GuidesH3C S12500G-AF Switch Series Configuration Guides-Release7634Pxx-6W10113-Network Management and Monitoring Configuration Guide
11-Sampler configuration
11-Sampler configuration 59.68 KB
Configuring samplers
About sampler
A sampler selects a packet from sequential packets and sends the packet to other service modules for processing. Sampling is useful when you want to limit the volume of traffic to be analyzed. The sampled data is statistically accurate and sampling decreases the impact on the forwarding capacity of the device.
The device supports random sampling mode.
In random sampling mode, any packet might be selected from sequential packets in each sampling.
Creating a sampler
2.     Create a sampler.
sampler sampler-name mode random packet-interval n-power rate
By default, no samplers exist.
Display and maintenance commands for a sampler
Display configuration information about the sampler.
In standalone mode:
display sampler [ sampler-name ] [ slot slot-number ]
In IRF mode:
display sampler [ sampler-name ] [ chassis chassis-number slot slot-number ]
Samplers and IPv4 NetStream configuration examples
Example: Configuring samplers and IPv4 NetStream
As shown in Figure 1, configure samplers and NetStream as follows:
·     Configure IPv4 NetStream on the device to collect statistics on outgoing traffic.
·     Send the NetStream data to port 5000 on the NetStream server.
·     Configure random sampling in the outbound direction to select one packet randomly from 256 packets on HundredGigE 3/0/2.
Figure 1 Network diagram
Configuration procedure
# Create sampler 256 in random sampling mode, and set the sampling rate to 8. One packet from 256 packets is selected.
[Device] sampler 256 mode random packet-interval n-power 8
# Enable IPv4 NetStream to use sampler 256 to collect statistics about outgoing traffic on HundredGigE 3/0/2.
[Device] interface hundredgige 3/0/2
[Device-HundredGigE3/0/2] ip netstream outbound
[Device-HundredGigE3/0/2] ip netstream outbound sampler 256
[Device-HundredGigE3/0/2] quit
# Configure the address and port number of the NetStream server as the destination for the NetStream data export. Use the default source interface for the NetStream data export.
[Device] ip netstream export host 12.110.2.2 5000
# Display configuration information for sampler 256.
[Device] display sampler 256
 Sampler name: 256
  Mode: Random;  Packet-interval: 8; IsNpower: Y
