11-Security Configuration Guide
HomeSupportSwitchesS12500G-AF SeriesConfigure & DeployConfiguration GuidesH3C S12500G-AF Switch Series Configuration Guides-Release7634Pxx-6W10111-Security Configuration Guide
23-Object group configuration
23-Object group configuration 45.12 KB
Configuring object groups
About object groups
An object group is a group of objects that can be used by an ACL to identify packets. Only IPv4 address object groups are available. An IPv4 address object group is a group of IPv4 address objects used to match the IPv4 address in a packet or match the user from whom a packet comes.
Configuring an IPv4 address object group
2.     Configure an IPv4 address object group and enter its view.
object-group ip address object-group-name
The system has one default IPv4 address object group named any.
3.     (Optional.) Configure a description for the IPv4 address object group.
By default, an object group does not have a description.
4.     Configure an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ip-address { mask-length | mask } }
Display and maintenance commands for object groups
Display information about object groups.
display object-group [ ip address[ default ] [ name object-group-name ] | name object-group-name ]
