- 20-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-SNMP configuration
- 04-RMON configuration
- 05-NETCONF configuration
- 06-EAA configuration
- 07-Process monitoring and maintenance configuration
- 08-Flow log configuration
- 09-Fast log output configuration
- 10-Packet capture configuration
- 11-Mirroring configuration
- 12-UCC configuration
- 13-SQA configuration
- 14-SmartMC configuration
13-SQA configuration | 120.80 KB |
Restrictions and guidelines: SQA configuration
Enabling SQA for an application
Configuring SQA for audio and video traffic
Configuring statistics collection for endpoint application traffic
Example: Configuring SQA for Tencent Meeting
Configuring SQA
About SQA
Service quality analysis (SQA) enables the device to identify SIP- or H.323-based multimedia traffic and preferentially forward this traffic to ensure multimedia service quality. Use this feature to decrease multimedia stuttering and improve user experience.
SQA does not support analysis of encrypted SIP or H.323 protocol packets.
After SQA is enabled, the service template bound to the SQA profile will preferentially forward the application traffic of wireless endpoints. The device will also analyze the application traffic, collect and save traffic information and session information. The device can report the analysis data to a control terminal.
APR signature libraries of different versions support different applications. You can use the application name ? command to obtain the list of applications supported by an APR signature library.
You can execute the application name app-name enable command multiple times to enable SQA for multiple applications.
This feature is supported only in wireless local forwarding scenarios.
1. Enter system view.
2. Create an SQA profile and enter its view.
sqa profile profile-name
3. Enable SQA for an application.
By default, SQA is disabled for an application.
After SQA is enabled, the service template bound to the SQA profile will analyze the audio and video traffic of wireless endpoints. The service template also collects and saves basic information ( such as source and destination IP addresses) and quality information (such as delay and jitter) about the audio and video streams. The device can report the analysis data to a control terminal through NETCONF. For information about NETCONF, see Network Management and Monitoring Configuration Guide.
3. Enable SQA for an audio or video application.
application app-name enable
By default, SQA is disabled for all audio and video applications.
4. (Optional.) Specify the interval at which analysis data for audio and video applications is collected and sent.
application interval interval
The default setting is 300 seconds.
5. Return to system view.
6. Enter service template view.
wlan service-template service-template
7. Bind an SQA profile to the service template.
sqa-profile profile-name
By default, no SQA profile is bound to a service template.
After this feature is enabled, the service template bound to the SQA profile will collect traffic statistics on identifiable applications for wireless endpoints. The device can report the statistics to a control terminal through NETCONF. For information about NETCONF, see Network Management and Monitoring Configuration Guide.
3. Enable statistics collection for endpoint application traffic.
application statistics enable
By default, statistics collection for endpoint application traffic is disabled
4. (Optional.) Specify the interval at which traffic statistics are collected and sent.
application statistics interval interval
The default setting is 5 minutes.
SQA configuration examples
As shown in Figure 1, the wireless network uses the local forwarding mode. Client 1 and client 2 access the corporate network through service templates.
Configure SQA to analyze the audio and video traffic of endpoints.
Assign IP addresses to interfaces, and make sure the devices can reach each other.
Make sure the AP can work correctly on the AC and clients can obtain IP addresses.
# Create an SQA profile, and enable SQA for Tencent Meeting.
<AC> system-view
[AC] sqa profile 1
[AC-sqa-profile-1] application tencentmeeting enable
[AC-sqa-profile-1] quit
# Bind an SQA profile to service template service1.
[AC] wlan service-template service1
[AC-wlan-st-service1] sqa-profile 1
# Configure APs to forward client data traffic from all VLANs.
[AC-wlan-st-service1] client forwarding-location ap
[AC-wlan-st-service1] quit
# Bind the SQA profile to service template service2.
[AC] wlan service-template service2
[AC-wlan-st-service2] sqa-profile 1
[AC-wlan-st-service2] client forwarding-location ap
[AC-wlan-st-service2] quit
# Log in to the cloud platform, and view the quality information of audio and video traffic.
