16-Security Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C WX2800X&WSG1800X Configuration Guides(R5605P11)-6W10016-Security Configuration Guide
18-Crypto engine configuration
18-Crypto engine configuration 44.18 KB
Configuring crypto engines
About crypto engines
Crypto engines provide encryption/decryption services for service modules, for example, the IPsec module. When a service module requires data encryption/decryption, it sends the desired data to a crypto engine. After the crypto engine completes data encryption/decryption, it sends the data back to the service module.
Enabling the GM-capable hardware crypto engine for GM algorithms
By default, the device uses software crypto engines for data encryption/decryption by GM algorithms, including SM2, SM3, and SM4 algorithms. That is, the system uses its own software algorithms for data encryption/decryption. This consumes system resources and is less efficient. When the device is installed with the GM-capable hardware crypto engine, you can configure this feature to enable the hardware crypto engine for a specific GM algorithm. Then, data encryption/decryption by that GM algorithm will not consume system resources, which improves device processing efficiency.
2.     Enable the GM-capable hardware crypto engine for GM algorithms.
crypto-engine accelerator enable gm-algorithm { sm2 | sm3 | sm4 }*
By default, the GM-capable hardware crypto engine is disabled for GM algorithms.
Display and maintenance commands for crypto engines
Display crypto engine information.
display crypto-engine
Display the enabling status of the GM-capable hardware crypto engine for GM algorithms.
display crypto-engine accelerator gm-algorithm status
Display crypto engine statistics.
display crypto-engine statistics [ engine-id engine-id ]
Clear crypto engine statistics.
reset crypto-engine statistics [ engine-id engine-id ]
