15-High Availability Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX2800X&WSG1800X Command References(R5605P11)-6W10015-High Availability Command Reference
04-Server load balancing commands
04-Server load balancing commands 1.97 MB
Server load balancing commands· 1
abnormal-url threshold· 1
activate· 1
all-service-down action forward· 2
application-mode enable· 3
argument 3
arp-nd interface (SNAT address pool view) 4
arp-nd interface (virtual server view) 5
auto-shutdown recovery-time· 6
busy-action· 6
capability-exchange timeout 7
case-insensitive· 8
check all-packet 8
check-url 9
class· 10
compression level 11
concurrent-streams-per-connection· 12
connection close· 13
connection idle-timeout 14
connection-limit max (real server view) 14
connection-limit max (server farm member view) 15
connection-limit max (virtual server view) 16
content (HTTP content sticky group view) 16
content (HTTP passive sticky group view) 17
content length-threshold· 19
content maxparse-length· 19
content request-max-length· 20
content rewrite· 21
cookie (protection rule view) 21
cookie (sticky group view) 22
cookie secondary name· 24
customlog content 25
default server-farm·· 27
default-class action· 28
description· 29
destination-ip object-group· 30
diameter-attribute code· 31
display loadbalance action· 32
display loadbalance alg· 38
display loadbalance class· 38
display loadbalance connections· 41
display loadbalance diameter connections· 44
display loadbalance dns-query· 46
display loadbalance external-monitor log· 47
display loadbalance limit-policy· 47
display loadbalance policy· 48
display loadbalance probe failed-record· 49
display loadbalance probe-template· 51
display loadbalance process-limit 55
display loadbalance protection-policy· 55
display loadbalance snat-address statistics· 57
display loadbalance snat-global-policy· 58
display loadbalance snat-pool 59
display loadbalance snat-pool statistics· 60
display loadbalance total-count 62
display loadbalance snat-pool reference· 62
display loadbalance virtual-server overall-total-statistics· 64
display loadbalance virtual-server total-statistics· 65
display parameter-profile· 66
display real-server 71
display real-server statistics· 77
display real-server overall-statistics· 81
display server-farm·· 83
display sticky statistics· 88
display sticky virtual-server 91
display sticky-group· 94
display temporary-real-server 100
display virtual-server 105
display virtual-server overall-statistics· 113
display virtual-server statistics· 114
domain-name· 116
dpi-app-profile· 117
encrypt-cookie· 118
env-variables· 119
exceed-mss· 120
external-link inject-domain-suffix· 120
external-link inject-uri 121
external-link proxy enable (LB action view) 122
external-link proxy enable (virtual server view) 123
external-link snat-pool 124
external-link whitelist domain· 125
external-script 125
fail-action· 126
fallback-action close· 127
fallback-action continue· 127
fallback-action response raw-file· 128
fin-wait1 timeout 129
fin-wait2 timeout 130
forward all 130
frame size· 131
frequency· 132
header (HTTP header sticky group view) 132
header (HTTP passive sticky group view) 133
header call-id· 135
header delete· 136
header delete request accept-encoding· 136
header exceed-length· 137
header insert 138
header insert response vary· 140
header maxparse-length· 140
header modify per-request 141
header rewrite· 141
header rewrite request url 143
header-table size· 145
host ip address· 146
idle-time· 146
insert-header-field· 147
insert-xff enable· 148
ip· 148
ip address· 149
ip range· 150
ip source mask· 150
ipv6· 151
ipv6 address· 152
ipv6 range· 153
ipv6 source prefix· 153
keepalive idle-timeout 154
keepalive retransmission interval 155
lb-limit-policy· 155
lb-policy· 156
limit 157
loadbalance action· 158
loadbalance alg· 159
loadbalance alg all-enable· 160
loadbalance class· 160
loadbalance limit-policy· 161
loadbalance log enable base· 162
loadbalance log enable nat 163
loadbalance policy· 164
loadbalance probe failed-record enable· 164
loadbalance probe failed-record max-number 165
loadbalance probe-template· 166
loadbalance process-limit 167
loadbalance protection-policy· 167
loadbalance reload external-link file· 168
loadbalance schedule-test ip· 169
loadbalance schedule-test ipv6· 171
loadbalance snat-global-policy· 173
loadbalance snat-pool 173
loadbalance ssl performance-optimize cache-value· 174
loadbalance tcp-timestamp-mode· 174
loadbalance test pcre· 176
loadbalance test rewrite· 176
location rewrite· 178
manual-recover enable (server farm view) 179
match acl 179
match application-id· 180
match class· 181
match content 182
match cookie· 183
match destination-realm·· 184
match header 184
match interface· 185
match method· 186
match payload· 187
match radius-attribute· 188
match source· 189
match sql 190
match url 190
match user 191
match user-group· 192
match version· 193
match-across-service enable· 193
match-across-virtual-server enable· 194
match-buffer-end· 195
match-buffer-size· 196
match-buffer-time· 196
max-reuse (parameter profile view) 197
memory-size· 198
monitor-interval 198
node· 199
origin-host 200
origin-realm·· 201
override-limit enable· 202
parameter (LB action view) 202
parameter (virtual server view) 203
parameter-profile· 204
payload (HTTP/UDP payload sticky group view) 205
payload (UDP passive sticky group view) 206
payload (TCP payload sticky group view) 207
payload rewrite· 208
pool-size· 209
port (real server view) 210
port (virtual server view) 210
predictor 211
prefer-method· 213
priority (real server view) 214
priority (server farm member view) 215
priority (SNAT global policy view) 216
probe (real server view) 216
probe (server farm member view) 217
probe (server farm view) 218
probe log enable (real server view) 219
probe log enable (server farm member view) 220
probe-template (real server view) 220
probe-template (server farm member view) 221
probe-template (server farm view) 222
product-name· 223
protect-action· 224
protected-url 225
protection-action· 226
protection-period· 226
protection-policy· 227
proximity enable· 228
proxy-protocol enable· 228
radius-attribute· 229
rate-limit bandwidth (real server view) 230
rate-limit bandwidth (virtual server view) 231
rate-limit connection (real server view) 232
rate-limit connection (server farm member view) 232
rate-limit connection (virtual server view) 233
rate-limit http-request (real server view) 233
rate-limit http-request (server farm member view) 234
readwrite-separation· 235
real-server (server farm view) 236
real-server (system view) 236
rebalance per-request 237
recover-to-active (real server view) 237
recover-to-active (server farm member view) 238
recv-window size· 238
redirect relocation (LB action view) 239
redirect relocation (virtual server view) 240
redirect return-code (LB action view) 241
redirect return-code (virtual server view) 241
reload http-response· 242
request-version all 243
reset loadbalance connections· 243
reset loadbalance probe failed-record· 244
reset loadbalance snat-pool statistics· 244
reset real-server statistics· 245
reset sticky virtual-server 245
reset virtual-server statistics· 246
response· 247
retransmission enable· 248
retransmission timeout 249
route-advertisement enable· 250
rst threshold· 250
rule (parameter profile view) 251
rule (protection policy view) 252
secondary-cookie delimiters· 252
secondary-cookie start 253
selected-server 254
server-connection reuse· 254
server-farm (LB action view) 255
server-farm (real server view) 256
server-farm (system view) 257
service-down-action reset 258
service enable· 258
service object-group· 259
set ip tos (LB action view) 259
set ip tos (parameter profile view) 260
shutdown (real server view) 261
shutdown (server farm member view) 261
slow-attack client-read timeout 262
slow-attack min-transmit-rate· 263
slow-attack protection enable· 264
slow-attack request-body timeout 265
slow-attack request-header timeout 266
slow-offline enable (real server view) 267
slow-offline enable (server farm member view) 268
slow-online· 269
slow-shutdown enable (real server view) 269
slow-shutdown enable (server farm member view) 270
snat enable· 271
snat-mode· 272
snat-pool 272
snmp-agent trap enable loadbalance· 273
source-ip· 274
source-ip object-group (parameter profile view) 275
source-ip object-group (SNAT global policy view) 276
src-addr-option· 276
ssl session-id· 277
ssl url rewrite· 278
ssl-client-policy (LB action view) 278
ssl-client-policy (virtual server view) 279
ssl-server-policy· 280
statistics-match url 281
status-code· 281
sticky· 282
sticky-group· 283
sticky-over-busy enable· 284
success-criteria (real server view) 284
success-criteria (server farm member view) 285
success-criteria (server farm view) 286
syn retransmission-timeout 286
syn-cookie threshold· 287
tcp checksum-force-verify enable· 288
tcp connection idle-timeout 288
tcp mss· 289
tcp option preserve· 290
tcp option insert 291
tcp option remove· 292
tcp option rewrite· 293
tcp window-size· 294
tcp-close· 294
timeout (LB probe template view) 295
timeout (sticky group view) 296
time-wait timeout 297
traffic-group (virtual server view) 297
traffic-group (snat pool view) 298
translation-mode· 299
transparent enable· 300
udp per-packet 300
username (virtual server view) 301
variable· 302
vendor-id· 303
version· 303
virtual ip address· 304
virtual ipv6 address· 305
virtual-server (system view) 306
vrrp vrid (SNAT address pool view) 307
weight (real server view) 307
weight (server farm member view) 308
window-size· 309
zero-window threshold· 309
Use abnormal-url threshold to set the upper limit of URL error times.
Use undo abnormal-url threshold to restore the default.
abnormal-url threshold number
The upper limit of URL error times is 10000.
HTTP passive LB probe template view
number: Specifies the upper limit of URL error times, in the range of 1 to 4294967295.
The device monitors the responses of HTTP requests with URLs specified in the check-url command. If the response time for an HTTP request exceeds the specified timeout time or the status code in the HTTP response is the same as the specified response status code, a URL error is recorded. If the number of URL errors exceeds the upper limit of URL error times, the real server is automatically shut down.
# Set the upper limit of URL error times to 20 for HTTP passive LB probe template tplt.
[Sysname] loadbalance probe-template http-passive tplt
[Sysname-lbpt-http-passive-tplt] abnormal-url threshold 20
check-url
status-code
timeout
activate
Use activate to set the criteria to determine whether a server farm is available.
Use undo activate to restore the default.
activate lower lower-percentage upper upper-percentage
undo activate
A server farm is available when a minimum of one real server is available.
Server farm view
lower lower-percentage: Specifies the lower percentage value in the range of 1 to 99. When the percentage of available real servers in the primary server farm is lower than the lower percentage value, the primary server farm becomes unavailable. Then the backup server farm takes over.
upper upper-percentage: Specifies the upper percentage value in the range of 1 to 99. The upper percentage value must be higher than or equal to the lower percentage value. When the percentage of available real servers in the primary server farm is higher than the upper percentage value, the primary server farm becomes available again to process services.
If no backup server farm is configured on the virtual server, this configuration does not take effect.
# Set the lower percentage value to 20 and upper percentage value to 80 for the server farm sf.
[Sysname] server-farm sf
[Sysname-sfarm-sf] activate lower 20 upper 80
default server-farm
Use all-service-down action forward to enable the device to forward packets to the last selected server farm member when all server farm members are unavailable.
Use undo all-service-down action forward to restore the default.
The device drops packets when all server farm members are unavailable.
Server farm view
Operating mechanism
With this feature disabled, the device drops packets when all server farm members are unavailable. With this feature enabled, the device forwards packets to the last selected server farm member when all server farm members are unavailable.
This command takes effect only when the server farm is referenced by a TCP virtual server operating in Layer 7.
# Enable the device to forward packets to the last selected server farm member when all server farm members are unavailable.
[Sysname-sfarm-sf] all-service-down action forward
Use application-mode enable to configure a TCP virtual server to operate at Layer 7.
Use undo application-mode enable to restore the default.
A TCP virtual server operates at Layer 4.
TCP virtual server view
For a TCP virtual server to operate at Layer 7, you must specify a non-zero port number for the virtual server.
# Configure TCP virtual server vs to operate at Layer 7.
[Sysname] virtual-server vs type tcp
[Sysname-vs-tcp-vs] application-mode enable
argument
Use argument to configure user-defined information for a custom-monitoring LB probe template.
Use undo argument to restore the default.
argument text
undo argument
No user-defined information is configured for a custom-monitoring LB probe template.
Custom-monitoring LB probe template view
text: Specifies an information text, a case-sensitive string of 1 to 255 characters. The string can contain spaces and cannot contain quotation marks (").
When executing the script file used for custom monitoring, the device transfers the information text to the script file as a parameter.
You can configure multiple arguments separated by spaces as the user-defined information.
# In custom-monitoring LB probe template test_external, configure user-defined information as abc 123 456.
[Sysname] loadbalance probe-template external-monitor test_external
[Sysname-lbpt-external-monitor-test_external] argument abc 123 456
Use arp-nd interface to specify an interface for sending gratuitous ARP packets and ND packets.
Use undo arp-nd interface to disable an interface from sending gratuitous ARP packets and ND packets.
arp-nd interface interface-type interface-number
undo arp-nd interface interface-type interface-number
No interface is specified for sending gratuitous ARP packets and ND packets. No interface can send gratuitous ARP packets or ND packets.
You can execute this command multiple times to specify multiple interfaces for one SNAT address pool.
If an IP address in a SNAT address pool is in the same network segment as the IP address of an interface connected to a server, you must perform the following tasks:
·     Set the IPv4 subnet mask length to 32 or IPv6 prefix length to 128 for the virtual server IP address.
·     Execute this command.
·     Enable IP address advertisement for the virtual server.
# For SNAT address pool lbsp, specify GigabitEthernet 1/0/1 as the interface for sending gratuitous ARP packets and ND packets.
[Sysname] loadbalance snat-pool lbsp
[Sysname-lbsnat-pool-lbsp] arp-nd interface gigabitethernet 1/0/1
Virtual server view
You can execute this command multiple times to specify multiple interfaces for one virtual server.
If the virtual server IP address is in the same network segment as the IP address of an interface connected to a client, you must perform the following tasks:
If the virtual server IP address and interface IP address are in different network segments, you do not need to execute this command.
# For virtual server vs3, specify GigabitEthernet 1/0/1 as the interface for sending gratuitous ARP packets and ND packets.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] arp-nd interface gigabitethernet 1/0/1
Use auto-shutdown recovery-time to set the automatic recovery time for intelligent monitoring.
Use undo auto-shutdown recovery-time to restore the default.
auto-shutdown recovery-time recovery-time
The automatic recovery time is 0 minutes.
Server farm view
recovery-time: Specifies the automatic recovery time in the range of 0 to 15300 minutes. The value of 0 means that a server farm member placed in Auto shutdown state does not automatically recover.
Application scenarios
Use this command to enable automatic recovery for a real server that is shut down by intelligent monitoring.
Operating mechanism
If health monitoring is not configured, a recovered real server is set to Unknown state.
If health monitoring is configured and succeeds, a recovered real server is set to Active state. If health monitoring fails, a recovered real server is set to Probe-failed state.
# Set the automatic recovery time to 5 minutes for server farm sf.
[Sysname-sfarm-sf] auto-shutdown recovery-time 5
busy-action
Use busy-action to configure the action to take when a server farm is busy.
Use undo busy-action to restore the default.
busy-action { drop | enqueue length length timeout timeout-value | force }
undo busy-action
The default action is drop.
Server farm view
drop: Stops assigning client requests to the server farm.
enqueue: Assigns new client requests to a wait queue.
length length: Specifies the maximum number of client requests allowed in the wait queue, in the range of 1 to 100000. When the queue is full, new client requests are dropped.
timeout timeout-value: Specifies the aging time for the wait queue, in the range of 1 to 60 seconds.
force: Forcibly assigns client requests to all real servers in the server farm.
For the drop action, if the LB policy for the server farm contains the action of matching the next rule, the device compares client requests with the next rule. Otherwise, the device drops the client requests.
# Configure the action to take when a server farm is busy as force.
[Sysname-sfarm-sf] busy-action force
Use capability-exchange timeout to set the timeout timer for Diameter capability exchange.
Use undo capability-exchange timeout to restore the default.
capability-exchange timeout timeout-value
The timeout timer for Diameter capability exchange is 10 seconds.
Diameter session parameter profile view
timeout-value: Specifies the timeout timer for Diameter capability exchange, in the range of 1 to 4294967295 seconds. The default setting is 10 seconds.
After the device establishes a TCP connection with a client or server, they exchange information through Capabilities-Exchange-Request (CER) and Capabilities-Exchange-Answer (CEA) messages. If no CER or CEA messages are exchanged between the device and the peer within the specified timeout timer, the device considers the TCP connection invalid and disconnects it. This feature avoids continuous occupation of system resources by invalid connections.
# Set the timeout timer for Diameter capability exchange to 15 seconds for Diameter session parameter profile dia.
[Sysname] parameter-profile dia type diameter-session
[Sysname-para-diameter-session-dia] capability-exchange timeout 15
parameter-profile
case-insensitive
Use case-insensitive to disable case sensitivity for matching character strings.
Use undo case-insensitive to restore the default.
case-insensitive
Case sensitivity is enabled for matching character strings.
HTTP parameter profile view
This command affects the following content:
·     HTTP header value, HTTP cookie name and value, and URL for matching classes.
·     Header value, URL, and key value used for generating sticky entries for the HTTP header sticky method.
·     Cookie name and value and key value used for generating sticky entries for the cookie get sticky method.
# Disable case sensitivity for the HTTP-type parameter profile pp1.
[Sysname] parameter-profile pp1 type http
[Sysname-para-http-pp1] case-insensitive
check all-packet
Use check all-packet to enable checking for all packets.
Use undo check all-packet to restore the default.
check all-packet
Checking for all packets is disabled.
HTTP cookie sticky group view
If the sticky method is cookie get, use this command to get cookies from all HTTP response packets. If this command is not executed, the device gets only the Set-Cookie from the first response packet of a connection.
If the sticky method is cookie rewrite, use this command to rewrite cookies in all HTTP response packets. If this command is not executed, the device rewrites only the Set-Cookie in the first response packet of a connection.
If the sticky method is cookie insert, use this command to insert cookies to all HTTP response packets. If this command is not executed, the device inserts only the Set-Cookie to the first response packet of a connection.
If the sticky method is HTTP passive, use this command to generate sticky entries from all HTTP response packets. If this command is not executed, the device generates sticky entries only from the first response packet of a connection.
# Enable checking for all packets in the HTTP cookie sticky group sg3.
[Sysname] sticky-group sg3 type http-cookie
[Sysname-sticky-http-cookie-sg3] check all-packet
check-url
Use check-url to configure a URL regular expression to match URLs for an HTTP passive LB probe template.
Use undo check-url to remove the URL regular expression configuration.
check-url url
undo check-url url
No URL regular expression is configured.
url: Specifies a URL regular expression, a case-insensitive string of 1 to 255 characters. The string cannot contain question marks (?).
Operating mechanism
If an HTTP request carries one of the specified URLs, the device examines whether a URL error occurs in the HTTP response.
You can configure a maximum of 10 URL regular expressions for one HTTP passive LB probe template.
# Configure www.example.com as a matching URL for HTTP passive LB probe template tplt.
[Sysname-lbpt-http-passive-tplt] check-url www.example.com
class
Use class to specify an LB action for the specified LB class.
Use undo class to delete an LB class.
class class-name [ insert-before before-class-name | insert-after [ after-class-name ] ] action action-name
undo class class-name
No LB action is specified for the LB class.
LB policy view
class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 255 characters.
insert-before: Inserts the target class before an LB class (which must already be referenced by the current LB policy).
before-class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 255 characters.
insert-after: Inserts the target class after an LB class (which must already be referenced by the current LB policy).
after-class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this argument, the command inserts the target LB class after all LB classes.
action-name: Specifies an LB action by its name, a case-insensitive string of 1 to 255 characters.
Operating mechanism
This command sets an LB action for packets matching the specified LB class.
If you do not specify the insert-before and insert-after keywords, the command inserts the target LB class after all LB classes.
You can specify an LB action for different LB classes.
You can specify multiple LB classes for an LB policy. Packets match the classes in the order the classes are configured. If a class is matched, the specified action is taken and packets stop matching the subsequent classes. As a best practice for finer matching when a class rule is included in the rule of another class, configure the class with more detailed rule first. If no class is matched, the default action is taken.
A DNS LB policy can reference DNS LB actions only; a generic LB policy can reference generic LB classes and generic LB actions only. This rule does not apply to HTTP LB policies.
# In server load balancing, specify the LB action lba1 for the LB class lbc1 in the generic LB policy lbp1, and insert lbc1 before the LB class lbc0.
[Sysname] loadbalance policy lbp1 type generic
[Sysname-lbp-generic-lbp1] class lbc1 insert-before lbc0 action lba1
# In outbound link load balancing, specify the LB action lba2 for the LB class lbc2 in the link-generic LB policy lbp2, and insert lbc1 before the LB class lbc0.
[Sysname] loadbalance policy lbp2 type link-generic
[Sysname-lbp-link-generic-lbp2] class lbc2 insert-before lbc0 action lba2
# In transparent DNS proxy, specify the LB action lba3 for the LB class lbc3 in the DNS LB policy lbp3, and insert lbc1 before the LB class lbc0.
[Sysname] loadbalance policy lbp3 type dns
[Sysname-lbp-dns-lbp3] class lbc3 insert-before lbc0 action lba3
compression level
Use compression level to set the compression level for response packets.
Use undo compression level to restore the default.
compression level level
The compression level for response packets is 1.
HTTP-compression parameter profile view
level: Specifies the compression level in the range of 1 to 9. A larger value indicates a lower compression speed and a higher compression ratio.
# Create the HTTP-compression parameter profile pa1, and set the compression level to 6.
[Sysname] parameter-profile pa1 type http-compress
[Sysname-para-http-compress-pa1] compression level 6
Use concurrent-streams-per-connection to configure the maximum number of concurrent requests supported by a TCP connection.
Use undo concurrent-streams-per-connection to restore the default.
concurrent-streams-per-connection connection-number
A TCP connection supports a maximum of 10 concurrent requests.
HTTP2.0 parameter profile view
connection-number: Specifies the maximum number of concurrent requests supported by a TCP connection. The value range for this argument is 1 to 256.
Operating mechanism
The HTTP2.0 protocol supports concurrent processing and responding of multiple HTTP2.0 requests over a single TCP connection. You can execute this command to configure the maximum number of concurrent requests supported by a TCP connection. When the number of requests reaches the limit, the device will terminate the HTTP2.0 TCP connection. Configure an appropriate value for the maximum number of concurrent requests supported by a TCP connection based on the actual network conditions. A large value might cause the generation of a large number of HTTP2.0 packet header entries on the client or server, occupying a lot of memory and reducing the concurrent processing capability. A small value might cause multiple TCP connection establishments during packet transmission, reducing packet transmission efficiency.
This command takes effect only on HTTP 2.0 request packets.
# Create HTTP2.0 parameter profile p1, and set the maximum number of concurrent requests supported by a TCP connection to 128.
[Sysname] parameter-profile p1 type http2
[Sysname-para-http2-p1] concurrent-streams-per-connection 128
header-table size
connection close
Use connection close to configure the device to proactively close TCP connections to real servers.
Use undo connection close to restore the default.
connection close { fin | rst }
The device does not proactively close the TCP connection to a real server.
vsys-admin
fin: Closes connections by sending FIN packets.
rst: Closes connections by sending RST packets.
When the device receives multiple concurrent HTTP2.0 requests from a client, the device needs to establish separate TCP connections to multiple real servers to forward the requests, because both the device and servers support only the HTTP1.1 protocol. After processing and responding to the requests, a real server does not close the TCP connections to the device until the client receives responses to all requests. If the client accesses the server again, it continues to use the same connection. In this scenario, a large number of servers might be occupied for a time period, delaying the processing of other clients' requests.
To resolve this issue, you can execute this command to configure the real servers to disconnect from the device in the specified manner after processing a request.
This command takes effect only when a client sends an HTTP2.0 request, but the device and real servers support only HTTP1.1.
# Create HTTP2.0 parameter profile p1, and configure the device to close TCP connections to real servers by sending FIN packets.
[Sysname-para-http2-p1] connection close fin
Use connection idle-timeout to configure the idle timeout timer for TCP connections.
Use undo connection idle-timeout to restore the default.
connection idle-timeout timeout-value
The idle timeout timer for TCP connections is 300 seconds.
timeout-value: Specifies the idle timeout timer for TCP connections, in the range of 0 to 4294967295 seconds.
Operating mechanism
You can execute this command to configure the idle timeout period for TCP connections between the device and clients/servers. If no application data is transmitted over a TCP connection within the idle timeout period, the device will close the TCP connection.
# Create HTTP2.0 parameter profile p1, and set the idle timeout timer for TCP connections to 60 seconds.
[Sysname-para-http2-p1] connection idle-timeout 60
Use connection-limit max to set the maximum number of connections of a real server.
Use undo connection-limit max to restore the default.
connection-limit max max-number
The maximum number of connections of a real server is 0, which means the number is not limited.
Real server view
max-number: Specifies the maximum number of connections, in the range of 0 to 4294967295. If the value of this argument takes 0, the number is not limited.
This command takes effect only on new sessions and does not take effect on existing sessions.
# Set the maximum number of connections of the real server rs to 10000.
[Sysname] real-server rs
[Sysname-rserver-rs] connection-limit max 10000
Use connection-limit max to set the maximum number of connections of a server farm member.
The maximum number of connections of a link is 0, which means the number is not limited.
Server farm member view
# Set the maximum number of connections of the server farm member rs1 to 10000.
[Sysname-sfarm-sf] real-server rs1 port 80
[Sysname -sfarm-sf-#member#-rs1-port-80] connection-limit max 10000
Use connection-limit max to set the maximum number of connections of a virtual server.
The maximum number of connections of a virtual server is 0, which means the number is not limited.
Virtual server view
# Set the maximum number of connections for the IP-type virtual server vs3 to 10000.
[Sysname-vs-ip-vs3] connection-limit max 10000
# In outbound link load balancing, set the maximum number of connections for the link IP-type virtual server vs2 to 10000.
[Sysname] virtual-server vs2 type link-ip
[Sysname-vs-link-ip-vs2] connection-limit max 10000
Use content to configure the HTTP entity sticky method.
Use undo content to delete the HTTP entity sticky method.
content [ offset offset ] [ start start-string ] [ end end-string | length length ]
undo content
No sticky methods exist.
HTTP entity sticky group view
offset offset: Specifies the offset value of the entity based on the start of the HTTP packet, in the range of 0 to 1000 bytes. The default is 0.
start start-string: Specifies the regular expression that marks the start of the entity, a case-sensitive string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the entity, a case-sensitive string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the entity, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
Operating mechanism
Use this command to obtain the HTTP entity information used to generate sticky entries based on the offset, start-string, end-string, and length values. The start-string and end-string values are not included in the sticky entry information.
The HTTP entity sticky method applies only to contents within the entity. The HTTP entity sticky method does not apply to chunk and multipart entity content.
The HTTP entity sticky method is not supported by the virtual servers of the fast HTTP type.
# Configure the HTTP entity sticky method for the HTTP entity sticky group sg2: Starting from the 30th byte of start of the HTTP packet, use the 20-byte HTTP entity with abc as the start string to generate sticky entries.
[Sysname] sticky-group sg2 type http-content
[Sysname-sticky-http-content-sg2] content offset 30 start abc length 20
Use content to configure the HTTP passive entity sticky method.
Use undo content to delete the HTTP passive entity sticky method.
content { get | match } id start start-string { end end-string | length length }
undo content { get | match } id
get: Obtains the specified string in the HTTP response entity, which is used to generate a sticky entry.
match: Obtains the specified string in the HTTP request entity, which is used to match a sticky entry.
id: Specifies the string ID in the range of 1 to 4.
start start-string: Specifies the regular expression that marks the start of the entity, a case-sensitive string of 1 to 127 characters. The string cannot contain question marks (?).
Both the content get and content match commands are required for an HTTP passive sticky method.
The device obtains the content information of an incoming HTTP request based on the content match command and obtains the content information of an incoming HTTP response based on the content get command. If the content information of the HTTP request matches the content information of the HTTP response, the device generates a sticky entry based on the content information of the HTTP response. Subsequent HTTP requests that match the sticky entry are forwarded according to the sticky entry.
The following rules apply to use of the content match and content get commands:
·     You can execute a maximum of four content get commands and four content match commands for one HTTP passive sticky method.
·     A number of n strings that are obtained based on n content get commands generates 2n-1 strings in ascending order of string IDs. If the string obtained based on the content match command matches any one of these generated strings, the match is successful.
·     A number of n strings that are obtained based on n content match commands combine as one string in ascending order of string IDs.
For example, three content get commands are executed with string IDs 1, 2, and 3. The device obtains three strings a, b, and c in the HTTP response header, generates seven strings a, b, c, ab, ac, bc, and abc, and generates seven sticky entries. Then, three content match commands are executed with string IDs 2, 3, and 4. The device obtains three strings a, b, and c in the HTTP request header and generates one string abc. If the string matches one of the seven strings, the device generates a sticky entry based on the string abc. Subsequent HTTP requests that match the sticky entry are forwarded according to the sticky entry.
# Configure the HTTP passive sticky method for the HTTP passive sticky group sg2: Obtain the 20-byte HTTP entity string starting with abc in the HTTP response. If the string matches the 20-byte HTTP entity string starting with xxx in the HTTP request, the device generates a sticky entry based on the string obtained from the HTTP response.
[Sysname] sticky-group sg2 type http-passive
[Sysname-sticky-http-passive-sg2] content get 1 start abc length 20
[Sysname-sticky-http-passive-sg2] content match 1 start xxx length 20
Use content length-threshold to set the minimum length of HTTP response content for compression.
Use undo content length-threshold to restore the default.
content length-threshold length
The minimum length of HTTP response content for compression is 1024 bytes.
length: Specifies the minimum length of HTTP response content for compression, in the range of 0 to 4294967295 bytes.
If an HTTP response packet contains the Content-Length header, the packet content is compressed only when its length reaches the minimum length of HTTP response content for compression. If the HTTP response packet does not contain the Content-Length header, the configuration does not take effect. The packet content is compressed regardless of its length.
# Create the HTTP-compression parameter profile http1, and set the minimum length of HTTP response content for compression to 2000 bytes.
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] content length-threshold 2000
Use content maxparse-length to set the maximum length of HTTP entities that can be parsed.
Use undo content maxparse-length to restore the default.
content maxparse-length length
The maximum length of HTTP entities that can be parsed is 4096.
length: Specifies the maximum length of HTTP entities that can be parsed, in the range of 1 to 65535 bytes.
This command is not supported by the virtual servers of the fast HTTP type.
# Set the maximum length of HTTP entities that can be parsed to 8192 for the HTTP parameter profile pp1.
[Sysname-para-http-pp1] content maxparse-length 8192
Use content request-max-length to set the maximum size of the HTTP content.
Use undo content request-max-length to restore the default.
content request-max-length length
The size of the HTTP content is not limited.
length: Specifies the maximum size of the HTTP content, in the range of 1 to 4294967295 bytes.
If the size of the HTTP content in an HTTP request exceeds the specified maximum size, the device discards the HTTP request.
# Set the maximum size of the HTTP content to 1000 for the HTTP parameter profile h1.
[Sysname] parameter h1 type http
[Sysname-para-http-h1] content request-max-length 1000
content rewrite
Use content rewrite to rewrite the content of HTTP responses.
Use undo content rewrite to restore the default.
content rewrite value value replace replace-string
The content of HTTP responses is not rewritten.
HTTP LB action view
value value: Specifies the HTTP packet content to be rewritten, a case-sensitive string of 1 to 127 characters. The string cannot contain question marks (?).
replace replace-string: Specifies the content after rewrite, a case-sensitive string of 1 to 127 characters.
This command applies only to the HTTP response packets in the format of text/*.
The rewrite operation is not performed in either of the following situations:
·     A regular expression is used to match the content before rewrite, and the content before rewrite exceeds 4096 bytes in size.
·     The content after rewrite exceeds 4096 bytes in size.
If you specify the replace-string argument as %[1-9], the matching packet content value will be replaced by the content in the corresponding pair of brackets. For example, if you execute the content rewrite value (Wel)(co)(me) replace %2 command, the content Welcome will be replaced by the content co in the second pair of brackets.
If you execute the content rewrite command multiple times, the most recent configuration takes effect.
# Create the HTTP LB action named replace, and replace the content 2000::1 in HTTP response packets with 2.3.4.5.
[Sysname] loadbalance action replace type http
[Sysname-lba-http-replace] content rewrite value 2000::1 replace 2.3.4.5
Use cookie to configure a cookie-based protection threshold.
Use undo cookie to restore the default.
cookie cookie-name request-threshold threshold
undo cookie
No cookie-based protection threshold is configured.
Protection rule view
cookie-name: Specifies an HTTP cookie by its name, a case-sensitive string of 1 to 63 characters. The cookie name cannot contain brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). Additionally, the cookie name cannot contain ASCII codes that are less than or equal to 31 and greater than or equal to 127.
request-threshold threshold: Specifies a request threshold in the range of 1 to 4294967295.
If the number of times that a user accesses a protected URL exceeds the request threshold during the protection period, the protection action is taken. The device determines whether requests belong to the same user based on the following elements:
·     Cookie—Requests with the same cookie value for the cookie specified in this command belong to the same user.
·     Source IP address—Requests with the same source IP address belong to the same user.
If you configure both a cookie-based request threshold and a source-IP-based request threshold, the protection action is taken when either threshold is exceeded.
# In protection rule 5, configure the cookie name as jsessionid and the request threshold as 2.
[Sysname] loadbalance protection-policy p1
[Sysname-lbpp-http-p1] rule 5
[Sysname-lbpp-http-p1-rule-5] cookie jsessionid request-threshold 2
protected-url
protection-action
protection-period
source-ip
Use cookie to configure the HTTP cookie sticky method.
cookie { get name cookie-name [ offset offset ] [ start start-string] [ end end-string | length length ] | { insert [ name cookie-name ] [ domain domain-name ] [ path path ] [ httponly ] [ secure ] | rewrite [ name cookie-name ] [ httponly ] [ secure ] }
undo cookie { get | insert | rewrite }
No HTTP cookie sticky methods exist.
get: Specifies the cookie get sticky method that gets the Set-Cookie field in the HTTP response packets sent by the server.
offset offset: Specifies the offset value based on the start of the cookie value, in the range of 0 to 1000 bytes. The default is 0.
start start-string: Specifies the regular expression that marks the start of the cookie, a case-sensitive string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the cookie, a case-sensitive string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the cookie, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
insert: Specifies the cookie insert sticky method that inserts the Set-Cookie field to the HTTP response packets sent by the server.
rewrite: Specifies the cookie rewrite sticky method that rewrites the Set-Cookie field in the HTTP response packets sent by the server.
name cookie-name: Specifies an HTTP cookie by its name, a case-sensitive string of 1 to 63 characters. The default name is X-LB.
domain domain-name: Specifies a domain name indicating the hosts to which the cookie will be sent, a case-sensitive string of 1 to 255 characters. If you do not specify this option, the cookie will be sent to only the host where it is created.
path path: Specifies a path indicating the paths to which the cookie will be sent, a case-sensitive string of 1 to 255 characters. If you do not specify this option, the cookie will be sent to every path (the root directory / applies).
httponly: Specifies that the cookie cannot be accessed by scripts. If you do not specify this keyword, the cookie can be accessed by scripts.
secure: Specifies that the cookie can be transmitted over only HTTPS connections. If you do not specify this keyword, the cookie can be transmitted over any connections.
Use the cookie get command to obtain the HTTP cookie information used to generate sticky entries based on the offset, start-string, end-string, and length values. The start-string and end-string values are not included in the sticky entry information.
If the sticky method is cookie rewrite, the Set-Cookie field of the specified cookie must be available in the HTTP response packets sent by the server. The system modifies only the cookie name and value in the Set-Cookie field without modifying other attributes such as Expires.
If the sticky method is cookie insert or cookie rewrite and the timeout timer for sticky entries is 0, the system adds the Expires field after the inserted or rewritten value. If the HTTP response packets sent by the server carry this attribute, the load balancing module does not modify the attribute. Instead, it adds the user-configured Expires information after the value. As a best practice, do not carry any timeout attribute in the Set-Cookie header on the server when you configure the cookie rewrite sticky method.
The domain domain-name option specifies the hosts to which the cookie will be sent. Suppose a client can visit hosts example.com, www.example.com, and www.corp.example.com. If you specify example.com for the domain domain-name option, the client includes the cookie when sending HTTP requests to any one of the three hosts. If you specify www.corp.example.com for the domain domain-name option, the client includes the cookie only when sending HTTP requests to www.corp.example.com.
The path path option limits the scope of the cookie to a set of paths. Suppose a client can visit folders www.example.com/a and www.example.com/b. If you specify www.example.com for the domain domain-name option and /a for the path path option, the client includes the cookie only when sending HTTP requests to www.example.com/a.
The httponly option prevents attackers from obtaining cookie information by using scripts.
The secure option makes sure the cookie is transmitted over an HTTPS connection. For an HTTP connection, the cookie is not transmitted.
# Configure the cookie get sticky method for the HTTP cookie sticky group sg3: Starting from the 10th byte of start of the HTTP packet, use the 32-byte HTTP cookie named user to generate sticky entries.
[Sysname-sticky-http-cookie-sg3] cookie get name user offset 10 length 32
# Configure the cookie insert sticky method for the HTTP cookie sticky group sg3.
[Sysname-sticky-http-cookie-sg3] cookie insert
Use cookie secondary name to specify the name of the secondary cookie to be searched in the URI.
Use undo cookie secondary name to restore the default.
cookie secondary name value
The name of the secondary cookie to be searched in the URI is not specified.
value: Specifies the name of the secondary cookie, a case-sensitive token string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127.
This command applies only to the cookie get sticky method. Executing this command enables the system to locate the secondary cookie in the URI when it fails to locate the specified cookie in the HTTP request packet header.
# Specify the name of the secondary cookie to be searched in the URI as sid for the HTTP cookie sticky group sg3.
[Sysname-sticky-http-cookie-sg3] cookie secondary name sid
customlog content
Use customlog content to configure the content to be output by using the fast log output feature.
Use undo customlog content to restore the default.
customlog content content-value
No content is output by using the fast log output feature.
HTTP virtual server view
content-value: Specifies the log content to be output, a case-sensitive string of 1 to 255 characters. To enter multiple variables, separate them by semicolons. The device supports the following variables:
·     %{is}—Source IP address in HTTP requests.
·     %{ps}—Source port number in HTTP requests.
·     %{id}—Destination IP address in HTTP requests.
·     %{pd}—Destination port number in HTTP requests.
·     %{sis}—Source IP address in HTTP responses.
·     %{sps}—Source port number in HTTP responses.
·     %{sid}—Destination IP address in HTTP responses.
·     %{spd}—Destination port number in HTTP responses.
·     %{vsn}—Virtual server name.
·     %{sfn}—Server farm name.
·     %{reqtmstamp}—HTTP request timestamp, in GMT.
·     %{reqtime}—HTTP request timestamp, in CST.
·     %{uri}—HTTP URI.
·     %{ver}—HTTP version number.
·     %{args}—HTTP access parameters.
·     %{method}—HTTP request method.
·     %{xff}—IP address of XFF (X-Forwarded-For).
·     %{ctype}—Content-Type field in HTTP requests.
·     %{clen}—Content-Length field in HTTP requests.
·     %{ref}—Referer header field in HTTP requests.
·     %{ua}—User-Agent header field in HTTP requests.
·     %{host}—Host header field in HTTP requests.
·     %{path}—Path in HTTP requests.
·     %{reqsz}—HTTP request size in bytes.
·     %{reqtm}—HTTP request duration in milliseconds. The duration is from time when the device receives an HTTP request to the time when the device receives the HTTP response.
·     %{rspclen}—Content-Length field in HTTP responses.
·     %{reqsz}—HTTP response size in bytes.
·     %{rsptm}—HTTP response duration in milliseconds. The duration is from the time when the device receives an HTTP response to the time when the device finishes sending out the HTTP response.
·     %{stscode}—HTTP response status code.
·     %{reqbsz}—Body size of HTTP requests, in bytes.
·     %{rspbsz}—Body size of HTTP responses received by the device from the server, in bytes.
·     %{rspsntbsz}—Body size of HTTP responses sent from the device to the client, in bytes.
·     %{cookie_cookie-name—HTTP cookie. The cookie name cannot contain brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). Additionally, the cookie name cannot contain ASCII codes that are less than or equal to 31 and greater than or equal to 127. You can specify multiple cookies.
Operating mechanism
After you execute this command, the device sends the specified content to the log host by using the fast log output feature.
Before executing this command, you must enable fast log output for load balancing and configure fast log output parameters.
# For HTTP virtual server vs, output the source IP address and source port number in HTTP requests by using the fast log output feature.
[Sysname] virtual-server vs type http
[Sysname-vs-http-vs] customlog content %{is};%{ps}
customlog format (Network Management and Monitoring Command Reference)
customlog host (Network Management and Monitoring Command Reference)
default server-farm
Use default server-farm to specify the default (primary) server farm.
Use undo default server-farm to restore the default.
default server-farm server-farm-name [ backup backup-server-farm-name ] [ sticky sticky-name [ backup backup-sticky-name ] ]
No default server farm is specified.
Fast HTTP virtual server view
IP virtual server view
UDP virtual server view
server-farm-name: Specifies a primary server farm by its name, a case-insensitive string of 1 to 255 characters.
backup backup-server-farm-name: Specifies a backup server farm by its name, a case-insensitive string of 1 to 255 characters.
sticky sticky-name: Specifies a primary sticky group by its name, a case-insensitive string of 1 to 255 characters.
backup backup-sticky-name: Specifies a backup sticky group by its name, a case-insensitive string of 1 to 255 characters. This option is supported only by HTTP virtual servers and RADIUS virtual servers.
Operating mechanism
When the primary server farm is available (contains real servers), the virtual server forwards packets through the primary server farm. When the primary server farm is not available, the virtual server forwards packets through the backup server farm.
If you specify both a primary sticky group and a backup sticky group, the device generates both primary sticky entries and backup sticky entries. If packets do not match primary sticky entries, backup sticky entries will apply.
The device generates backup sticky entries for only the following sticky group combinations:
·     RADIUS-type primary sticky group and port-address-type backup sticky group.
·     HTTP cookie-type primary sticky group and port-address-type backup sticky group.
·     HTTP cookie-type primary sticky group and HTTP passive-type backup sticky group.
# Specify the primary server farm sf, the backup server farm sfb, and the sticky group sg1 for the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] default server-farm sf backup sfb sticky sg1
Use default-class action to specify the default LB action.
Use undo default-class to restore the default.
default-class action action-name
undo default-class
No default LB action is specified.
LB policy view
action-name: Specifies an LB action by its name, a case-insensitive string of 1 to 63 characters.
Operating mechanism
This command sets the default LB action for packets that fail to match any LB class.
A DNS LB policy can reference DNS LB actions only; a generic LB policy can reference generic LB actions only. This rule does not apply to HTTP LB policies.
# In server load balancing, specify the default LB action lba1 for the generic LB policy lbp1.
[Sysname-lbp-generic-lbp1] default-class action lba1
# In outbound link load balancing, specify the default LB action lba2 for the link-generic LB policy lbp2.
[Sysname-lbp-link-generic-lbp2] default-class action lba2
# In transparent DNS proxy, specify the default LB action lba3 for the DNS LB policy lbp3.
[Sysname-lbp-dns-lbp3] default-class action lba3
description
Use description to configure a description.
No description is configured.
ISP view
LB action view
LB class view
LB policy view
LB connection limit policy view
Parameter profile view
Protection policy view
Real server view
Server farm view
Sticky group view
Virtual server view
Link group view
Link group member view
Link view
DNS server pool view
DNS server pool member view
DNS server view
Statistics node view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description LB action LBA1 for the generic LB action lba1.
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] description LB action LBA1
Use destination-ip object-group to specify a destination IP address object group for address translation.
Use undo destination-ip object-group to restore the default.
destination-ip object-group object-group-name
All packets are translated.
object-group-name: Specifies a destination IP address object group by its name, a case-insensitive string of 1 to 63 characters.
If you specify a destination IP address object group, the device performs SNAT on only packets with a matching destination IP address. For information about configuring an IP address object group, see object group configuration in Security Configuration Guide.
# Specify destination IP address object group obj1 for SNAT global policy sn1.
[Sysname] loadbalance snat-global-policy sn1
[Sysname-lb-snat-gp-sn1] destination-ip object-group obj1
object-group (Security Command Reference)
Use diameter-attribute code to configure a Diameter attribute sticky method.
Use undo diameter-attribute to delete a Diameter attribute sticky method.
diameter-attribute { code attribute-code [ index index-value ] } &<1-4>
No Diameter attribute sticky methods exist.
Diameter sticky group view
code attribute-code: Specifies a Diameter attribute by its AVP code in the range of 0 to 4294967295.
index index-value: Specifies a Diameter attribute by its index value in an AVP sequence. The value range for the index-value argument is 0 to 32. When the type of the AVP specified by the attribute-code argument is Grouped, which indicates that the attribute is an AVP sequence, you must also specify the index value of the attribute in the AVP sequence. If you do not specify the index-value argument, the index value takes 0, which indicates that the index value of the Diameter attribute in the AVP sequence is not restricted.
&<1-4>: Indicates that the arguments before it can be entered up to four times.
Operating mechanism
Use this command to configure the device to generate a sticky entry based on the specified Diameter attribute in a Diameter request. Subsequent requests that match the sticky entry are forwarded according to the sticky entry. You can configure only one Diameter attribute sticky method for a Diameter sticky group. If you execute this command multiple times, the most recent configuration takes effect.
Common Diameter attribute codes include:
·     258—Auth-Application-Id.
·     259—Acct-Application-Id.
·     263—Session-Id.
·     264—Origin-Host.
·     283—Destination-Realm.
·     293—Destination-Host.
·     296—Origin-Realm.
·     443—Subscription-Id.
·     444—Subscription-Id-Data.
The Diameter attribute sticky methods apply only to Diameter messages.
# In sticky group s1, configure a sticky method based on Diameter attribute Session-Id.
[Sysname] sticky-group s1 type diameter
[Sysname-sticky-diameter-s1] diameter-attribute code 263
sticky-group
Use display loadbalance action to display LB action information.
display loadbalance action [ name action-name ]
name action-name: Specifies an LB action by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays information about all LB actions.
# Display information about all LB actions.
<Sysname> display loadbalance action
LB action: lba1
  Description:
  Type: Generic
  State: Inactive
  Forward type: Drop
  IP ToS:
  Fallback-action: Disabled
  Busy-action: Force
  TCP payload rewrite:
    Value: QMGR.S01
    Replacement: QMGR.S01%[variable]
    Direction: Request
    Value: QMGR.S01_1
    Replacement: QMGR.S01_2
    Direction: Response
    Value: QMGR.S02_2
    Direction: Response
  Reference count: 1
LB action: lba2
  Description:
  Type: HTTP
  State: Active
  Forward type: Server farm
  Server farm: sf (in use)
  Backup server farm: sfb
  Sticky: sg3
  Backup sticky: sg4
  IP ToS: 20
  SSL client policy:
  Content rewrite:
    Value:
    Replacement:
  Redirect relocation:
  Redirect return-code: 302
  Header delete:
    Direction: Request
  Header insert:
    Value: 1234567890123456789012345678901234567890123456789012345678901234567890
    Direction: Both
  Header insert:
    Value: dd
    Direction: Request
  Header rewrite:
    Value: dd
    Replacement: ff
    Direction: Response
  SSL URL rewrite:
    Value: 12
    Clear port: 12
    SSL port: 123
  Location header rewrite:
    Target string: (http://www.example.com): 9080
    Replacement string: %1:80
  Reference count: 1
LB action: lba3
  Description: sina
  Type: Link-generic
  State: Active
  Forward type: link group
  Link group: lg1 (in use)
  Backup link group: lg2
  Sticky:
  IP ToS:
  Fallback-action: None
  Reference count: 1
LB action: lba4
  Description: xx
  Type: DNS
  State: Active
  Forward type: DNS server pool
  DNS server pool: dsp1
  Sticky: st
  IP ToS:
  Busy-action: Force
  Reference count: 1
LB action: lba5
  Description:
  Type: HTTP
  State: Active
  Forward type: Redirect
  IP ToS:
  Fallback-action: Continue
  SSL client policy:
  Content rewrite:
    Value:
    Replacement:
  Redirect relocation: www.example.com
  Reference count: 1
LB action: lba6
  Description:
  Type: HTTP
  State: Active
  Forward type: Response
  IP ToS:
  Fallback-action: Response
    Raw file name: 301.raw
  SSL client policy:
  Content rewrite:
    Value:
    Replacement:
  Response file:
    File: index.html
    URL: /index/css
  Response file:
    File name: subsys_intf.js
    URL: /index/subsys
  Response file:
    File name: subsys.js
    URL: /subsys.js
  Response zip file:
    Zip file name: subsys.zip
    Working path: /
  Reference count: 1
LB action: lba7
  Description:
  Type: Diameter
  State: Active
  Backup server farm:
  Sticky: sg3
  SSL client policy:
  TCP parameter profile (client-side): tcp
  Diameter-session parameter profile: dia1
  Reference count: 1
LB action
LB action name.
Description for the LB action.
LB action type:
·     DNS.
·     Generic.
·     HTTP.
·     Link-generic.
·     RADIUS.
·     Diameter.
LB action state:
·     Active.
·     Inactive.
Forward type
Packet forwarding mode of the LB action:
·     Drop—Discards packets.
·     Drop(FIN-close)—Closes TCP connections by sending FIN packets (applicable to generic, HTTP, and Diameter LB actions).
·     Drop(RST-close)—Closes TCP connections by sending RST packets (applicable to generic, HTTP, and Diameter LB actions).
·     Forward—Forwards packets.
·     Server farm—Forwards packets through the server farm (applicable to generic, HTTP, RADIUS, and Diameter LB actions).
·     Link group—Forwards packets through the link group (applicable to link-generic LB actions).
·     DNS server pool—Forwards packets through the DNS server pool (applicable to DNS LB actions).
·     Skip current DNS proxy (applicable to DNS LB actions).
·     Redirect—Redirects packets.
·     Response—Responds to client requests by using a file.
Server farm
Primary server farm name. (in use) indicates the server farm is in use. This field is displayed only when the packet forwarding mode is server farm.
Backup server farm
Backup server farm name. (in use) indicates the server farm is in use. This field is displayed only when the packet forwarding mode is server farm.
Link group
Default link group name. (in use) indicates the link group is in use.
Backup link group
Backup link group name. (in use) indicates the link group is in use.
Sticky
Primary sticky group name. This field is displayed only when the packet forwarding mode is server farm or DNS server pool.
Backup sticky
Backup sticky group name. This field is displayed only when the packet forwarding mode is server farm and the LB action type is HTTP or RADIUS.
IP ToS
ToS field value of IP packets.
Fallback-action
Action taken upon load balancing failure:
·     None—Does not take any action.
·     Continue—Matches the next rule.
·     Response—Responds to client requests by using a file (applicable to DNS, generic, HTTP, link-generic, and RADIUS LB actions).
·     Drop(FIN-close)—Closes TCP connections by sending FIN packets (applicable to generic and HTTP LB actions).
·     Drop(RST-close)—Closes TCP connections by sending RST packets (applicable to generic and HTTP LB actions).
Busy-action
Action taken upon busyness:
·     Force—Assigns packets to links or DNS servers regardless of whether they are busy.
SSL client policy
SSL client policy name. This field is displayed only for HTTP and Diameter LB actions.
Content rewrite
HTTP content rewrite configuration:
·     Value—Specifies the HTTP packet content to be rewritten.
·     Replacement—Specifies the content after rewrite.
This field is displayed only for an HTTP-type LB action.
Redirect relocation
Redirection URL. This field is displayed only for HTTP-type LB actions.
Status code in the redirection packets. This field is displayed only for HTTP-type LB actions.
Header delete
Deletes the HTTP header.
·     Name—Name of the HTTP packet header.
·     Direction—Specifies HTTP requests, HTTP responses, or both.
This field is displayed only when the header delete command is configured.
Header insert
Inserts the HTTP header.
·     Value—Content of the HTTP packet header.
This field is displayed only when the header insert command is configured.
Header rewrite
Rewrites the HTTP header.
·     Value—Content of the HTTP packet header to be rewritten.
·     Replacement—Content after rewrite.
This field is displayed only when the header rewrite command is configured.
SSL URL rewrite
Rewrites the URL in the Location header of HTTP response packets sent by the server.
·     Value—Regular expression for the location header URL.
·     Clear port—HTTP port number to be rewritten.
·     SSL port—SSL port number after rewrite.
This field is displayed only when the ssl url rewrite command is configured.
Rewrite the Location header content of an HTTP response sent by the server.
·     Target string—Regular expression for the Location header to be rewritten.
·     Replacement string—Location header after rewriting.
This field is displayed only when the location rewrite replace command is executed.
DNS server pool
DNS server pool name. This field is displayed only when the packet forwarding mode is DNS server pool.
Response file
Responds to client requests by using an uncompressed file.
File name
Name of the uncompressed file.
URL
URL path used to match client requests.
Response zip file
Responds to client requests by using a compressed file.
Zip file name
Name of the compressed file.
Working path
Working path used to match client requests.
Raw file name
Response file used upon load balancing failure.
TCP payload rewrite
Rewrite the TCP payload:
·     Value—Content of the TCP packet header to be rewritten.
·     Direction—Specifies TCP requests, TCP responses, or both.
This field is displayed only when the payload rewrite command is configured.
Client-side TCP parameter profile specified for the Diameter LB action. This field is displayed only when a client-side TCP parameter profile is specified.
Diameter session parameter profile specified for the Diameter LB action. This field is displayed only when a Diameter session parameter profile is specified.
Reference count
Number of times that the resource is being referenced.
display loadbalance alg
Use display loadbalance alg to display the ALG status for all protocols.
# Display the ALG status for all protocols.
<Sysname> display loadbalance alg
LB ALG:
  DNS         : Enable
  FTP         : Enable
  H323        : Disabled
  ICMP-ERROR  : Enable
  ILS         : Disabled
  MGCP        : Disabled
  NBT         : Disabled
  PPTP        : Enable
  RSH         : Disabled
  RTSP        : Enable
  SCCP        : Disabled
  SIP         : Disabled
  SQLNET      : Disabled
  TFTP        : Disabled
  XDMCP       : Disabled
display loadbalance class
Use display loadbalance class to display LB class information.
display loadbalance class [ name class-name ]
name class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays information about all LB classes.
# Display information about all LB classes.
<Sysname> display loadbalance class
LB class: lbc1
  Description:
  Type: HTTP
  Match type: Match-all
  Match rule:
    match 1 source ip address 1.2.3.0 24
    match 2 source ipv6 address 1::2
    match 3 cookie abc value 123
    match 4 header def value 12
    match 5 method ext xde
    match 6 method rfc CONNECT
    match 7 class cla2
    match 8 url 2q3
    match 9 acl ipv4 number 2000
    match 10 acl ipv6 number 2001
    match 11 acl ipv4 name aaa
    match 12 acl ipv6 name bbb
    match 13 isp name isp1
  Reference count: 1
LB class: lbc2
  Description:
  Type: Generic
  Match type: Match-any
  Match rule:
    match 1 class cla2
    match 2 source ip address 1.2.23.0 24
    match 3 source ipv6 address 1::12
    match 4 acl ipv4 number 3000
    match 5 acl ipv6 number 3001
    match 6 acl ipv4 name ccc
    match 7 acl ipv6 name ddd
    match 8 isp name isp2
    match 9 payload orcl
  Reference count: 1
LB class: lbc3
  Description:
  Type: Link-generic
  Match rule:
    match 1 class cla3
    match 2 source ip address 1.2.3.0 24
    match 4 acl ipv4 number 3002
    match 5 acl ipv6 number 3003
    match 9 user u1
    match 10 user-group lb-group
    match 11 interface GE1/0/1
  Reference count: 1
LB class: lbc4
  Description:
  Type: DNS
  Match rule:
    match 1 class cla2
    match 8 destination ip address 1.2.3.0 24
    match 9 destination ipv6 address 1::12
    match 10 domain-name www.example.com
  Reference count: 1
LB class: lbc5
  Description:
  Type: MySQL
  Match rule:
    match 1 class cla2
    match 8 sql select
  Reference count: 1
LB class: lbc6
  Description:
  Type: Diameter
  Match rule:
    match 1 class cla2
    match 2 application-id 5
    match 3 destinaton-realm a.example.com
  Reference count: 1
LB class
LB class name.
Description for the LB class.
LB class type:
·     DNS.
·     Generic.
·     HTTP.
·     Link-generic.
·     MySQL.
·     RADIUS.
·     Diameter.
Match type
Match type for the LB class:
·     Match-all—Requires matching all rules of the LB class.
·     Match-any—Requires matching any rule of the LB class.
Match rule
Match rules for the LB class.
Reference count
display loadbalance connections
Use display loadbalance connections to display information about Layer 7 LB TCP connections.
display loadbalance connections [ client-side{ ipv4 | ipv6 } [ cs-client-ip ip-address [ cs-client-port port-number ] ] [ cs-server-ip ip-address [ cs-server-port port-number ] ] [ state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait } ] ] [ server-side { ipv4 | ipv6 } [ ss-client-ip ip-address [ ss-client-port port-number ] ] [ ss-server-ip ip-address [ ss-server-port port-number ] ] [ state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait } ] ] [ verbose ]
client-side: Displays client-side connections.
server-side: Displays server-side connections.
ipv4: Specifies IPv4 connections.
ipv6: Specifies IPv6 connections.
cs-client-ip ip-address: Specifies a client by its IP address on the client side.
cs-client-port port-number: Specifies the port number of the client on the client side, in the range of 0 to 65535. 0 means any port number.
ss-client-ip ip-address: Specifies a client by its IP address on the server side.
ss-client-port port-number: Specifies the port number of the client on the server side, in the range of 0 to 65535. 0 means any port number.
cs-server-ip ip-address: Specifies a server by its IP address on the client side.
cs-server-port port-number: Specifies the port number of the server on the client side, in the range of 0 to 65535. 0 means any port number.
ss-server-ip ip-address: Specifies a server by its IP address on the server side.
ss-server-port port-number: Specifies the port number of the server on the server side, in the range of 0 to 65535. 0 means any port number.
state { closed | close_wait | closing | established | fin_wait_1 | fin_wait_2 | last_ack | listening | syn_received | syn_sent | time_wait }: Specifies TCP connections by connection state. If you do not specify this parameter, the command displays information about TCP connections in each state.
verbose: Displays detailed information about TCP connections. If you do not specify this keyword, the command displays brief information.
If you do not specify any parameters, this command displays information about all Layer 7 LB TCP connections.
# Display brief information about all Layer 7 LB TCP connections.
<Sysname> display loadbalance connections
Client side:                       State        Server side:                     State  Cookie
192.168.56.1    <--> 8.8.8.8/80    ESTAB        192.168.56.1   <--> 2.2.2.2/80   ESTB   X-LB=2.3.ab37423e.50
/50168                                          /1026
Any             <-->Any            CLOSED       192.168.56.1   <--> 2.2.2.2/80   TIMEWT   X-LB=2.3.ab37423e.50
                                                /1027
Total sessions: 3
# Display detailed information about all Layer 7 LB TCP connections.
<Sysname> display loadbalance connections verbose
Slot 1:
                Client side                     Server side
Client address  12.12.12.12/3032                12.12.12.12/54649
Server address  4.4.44.4/80                     5.5.5.5/80
State           ESTABLISHED                     ESTABLISHED
VPN name        --                              --
Cookie          X-LB=2.3.ab37423e.50
Idle time       0 sec
Idle timeout    20 sec
Start time      2018-05-30 16:54:13
Client address  12.12.12.12/2996                Any
Server address  4.4.44.4/80                     Any
State           TIME_WAIT                       N/A
VPN name        --                              --
Idle time       1 sec
Idle timeout    20 sec
Start time      2018-05-30 16:54:12
Client address  12.12.12.12/3251                12.12.12.12/54341
VPN name        --                              --
Idle time       0 sec
Idle timeout    20 sec
Start time      2018-05-30 16:54:14
Total sessions: 3
TCP connection state:
·     LISTEN.
·     SYNSNT—SYN_SENT.
·     SYNRCV—SYN_RECEIVED.
·     ESTB—ESTABLISHED.
·     FINWT1—FIN_WAIT_1.
·     FINWT2—FIN_WAIT_2.
·     CLOWAT—CLOSE_WAIT.
·     CLOSING.
·     LASACK—LAST_ACK.
·     TIMEWT—TIME_WAIT.
·     CLOSED.
For more information about these states, see RFC 793.
VPN name
VPN instance name.
Cookie
Cookie name and value.
Start time
Time when the TCP connection was established.
display loadbalance diameter connections
Use display loadbalance diameter connections to display Layer 7 LB Diameter connection information.
display loadbalance diameter connections [ verbose ]
verbose: Displays detailed LB Diameter connection information. If you do not specify this keyword, the command displays brief LB Diameter connection information.
# Display brief Layer 7 LB Diameter connection information.
<Sysname> display loadbalance diameter connections
1.1.1.1/50159    <--> 2.2.2.1/3868   ESTAB  12.12.12.1/1028 <--> 13.13.13.2/3868 ESTB
                                            12.12.12.1/1029 <--> 13.13.13.3/3868 ESTB
                                            12.12.12.1/1030 <--> 13.13.13.4/3868 ESTB
11.11.11.11/5009 <--> 22.2.22.1/3868 ESTAB  14.14.14.1/1028 <--> 15.15.15.2/3868 ESTB
                                            14.14.14.1/1029 <--> 15.15.15.3/3868 ESTB
# Display detailed Layer 7 LB Diameter connection information.
<Sysname> display loadbalance diameter connections verbose
Slot 1:
                Client side
Role            Address            Origin-Host       Origin-Realm
Client          1.1.1.1/50169      dcca.example.com  example.com
Server          2.2.2.1/3868       host.h3c.com      h3c.com
State           ESTABLISHED
VPN name        --
Idle time       0 sec
Idle timeout    20 sec
Start time      2023-05-30 16:54:13
                Server side
Client          12.12.12.1/1028      host1.h3c.com    h3c.com
Server          13.13.13.2/3868      ide.example.com  example.com
State           ESTABLISHED
VPN name        --                              .
Idle time       0 sec
Idle timeout    20 sec
Start time      2023-05-30 16:54:14
Client          12.12.12.1/1029      host1.h3c.com   h3c.com
Server          13.13.13.3/3868      ide.example.com example.lb.com
State           ESTABLISHED
VPN name        --
Idle time       0 sec
Idle timeout    20 sec
Client          12.1.12.12/1030      host1.h3c.com   h3c.com
Server          13.13.13.4/3868      ide.example.com example.com
State           ESTABLISHED
VPN name        --
Idle time       0 sec
Idle timeout    20 sec
Start time      2023-05-30 16:54:15
                Client side
Client          1.1.1.2/50169        dc1.example.com example1.com
Server          2.2.2.2/3868         host2.h3c.com   h3c2.com
State           ESTABLISHED
VPN name        --
Idle time       0 sec
Idle timeout    20 sec
                Server side
Client          12.12.12.2/1028      host2.h3c.com    h3c2.com
Server          13.13.13.3/3868      ide2.example.com example3.com
State           ESTABLISHED
VPN name        --                              .
Idle time       0 sec
Idle timeout    20 sec
Client side
Connection information on the client side.
Server side
Connection information on the server side.
Origin-Host
Source host name.
Origin-Realm
Source domain name.
TCP connection state. Options include the following:
·     CLOSED.
·     LISTEN, LISTENING.
·     SYNSNT, SYN_SENT.
·     SYNRCV, SYN_RECEIVED.
·     ESTAB, ESTABLISHED.
·     CLOWAT, CLOSE_WAIT.
·     FINWT1, FIN_WAIT_1.
·     CLOSING.
·     LASACK, LAST_ACK.
·     FINWT2, FIN_WAIT_2.
·     TIMEWT, TIME_WAIT.
For more information about Diameter connection states, see RFC793.
VPN name
VPN instance name.
Idle time
Idle time period of the TCP connection, in seconds.
Idle timeout
Idle timeout timer for TCP connections, in seconds.
Start time
Time when the connection establishment started.
display loadbalance dns-query
Use display loadbalance dns-query to display information about the domain names queried by external link proxy.
# Display information about the domain names queried by external link proxy.
<Sysname> display loadbalance dns-query
Slot 1:
VPN instance:
  Domain name      DNS server
  www.a.example.com        1.2.3.4
  www.b.example.com        2.2.3.4
Slot 2:
VPN instance:
  www.c.example.com        3.2.3.4
  www.d.example.com        4.2.3.4
Table 5 Command output
Domain name
Domain name being queried.
DNS server
IP address of the DNS server.
VPN instance
VPN instance.
display loadbalance external-monitor log
Use display loadbalance external-monitor log to display the log information for custom monitoring.
# Display the log information for custom monitoring.
<Sysname> display loadbalance external-monitor log
The external monitor probe state of (server farm sf, real server rs, port: 3306) template mysql-template changed to successful.
The external monitor probe state of (server farm sf2, real server rs2, port: 3306) template mysql-template changed to failed.
display loadbalance limit-policy
Use display loadbalance limit-policy to display LB connection limit policy information.
display loadbalance limit-policy [ name policy-name ]
policy-name: Specifies an LB connection limit policy by its name, a case-insensitive string of 1 to 255 characters.
# Display information about the LB connection limit policy lptest.
<Sysname> display loadbalance limit-policy name lptest
Limit-policy: lptest
  Description:
  Limit rule:
limit lptest acl 3000 amount 10 10
Reference count: 1
display loadbalance policy
Use display loadbalance policy to display LB policy information.
display loadbalance policy [ name policy-name ]
name policy-name: Specifies an LB policy by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays information about all LB policies.
# Display information about all LB policies.
<Sysname> display loadbalance policy
LB policy: lbp1
  Description:
  Type: Generic
  Class: lbc1
   Action: lba1
  Default action: lba0
  Reference count: 1
LB policy: lbp2
  Description:
  Type: HTTP
  Default action:
  Reference count: 1
LB policy: lbp3
  Description:
  Type: Link-generic
  Class: lbc3
  Action: lba3
  Default action: lba3
  Reference count: 1
LB policy: lbp4
  Description:
  Type: DNS
  Class: lbc4
  Action: lba4
  Default action: lba4
LB policy: lbp5
  Description:
  Type: MySQL
  Class: lbc5
  Action: lba5
  Default action: lba5
  Reference count: 1
LB policy: lbp6
  Description:
  Type: Diameter
  Class: lbc6
   Action: lba6
  Default class action: lbc1
  Reference count: 1
Table 6 Command output
LB policy
LB policy name.
Description for the LB policy.
LB policy type:
·     DNS.
·     Generic.
·     HTTP.
·     Link-generic.
·     MySQL.
·     RADIUS.
·     Diameter
Class
LB class for the LB policy.
Action
LB action for the LB class.
Default LB action.
Reference count
display loadbalance probe failed-record
Use display loadbalance probe failed-record to display the records of health monitoring failures.
display loadbalance probe failed-record { real-server | link } [ name name ]
real-server: Specifies a real server or all real servers.
link: Specifies a link or all links.
name name: Specifies a real server or a link by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this parameter, this command displays the recorded health monitoring failures for all real servers or all links.
Before display the records of health monitoring failures, use the loadbalance probe failed-record enable command to enable recording health monitoring failures.
# Display the recorded health monitoring failures for all real servers.
<Sysname> display loadbalance probe failed-record real-server
Template               Server farm    Real server          Address family   Port   Template type   Reason        Failure time
t1                     sf2            rs                   IPv4              30     arp            TimeOut       2023-06-25 17:14:39
t1                     sf1            rs                   IPv6              20     arp           TimeOut        2023-06-25 17:14:39
t1                     -              rs                   IPv4              -      arp            TimeOut       2023-06-25 17:14:38
t1                     -              rs                   IPv6              10     arp            TimeOut       2023-06-25 17:14:37
# Display the recorded health monitoring failures for all links.
<Sysname> display loadbalance probe failed-record link
Template               Link group    Link                 Address family    Template type     Reason         Failure time
t1                     lg            lk                   IPv4              arp               TimeOut        2023-06-25 17:14:39
t1                     lg            lk                   IPv6              arp               TimeOut        2023-06-25 17:14:39
t1                     -             lk                   IPv4              arp               TimeOut        2023-06-25 17:14:38
t1                     -             lk                   IPv6              arp               TimeOut        2023-06-25 17:14:37
Table 7 Command output
Template
Name of the template for health monitoring.
Server farm
Name of the server farm that failed health monitoring. This field displays a hyphen (-) if the real server is not in any server farm.
Real server
Name of the real server or server farm member.
Link group
Name of the link group that failed health monitoring. This field displays a hyphen (-) if the link is not in any link group.
Link
Name of the link or link group member.
Address family
Address family type for the real server or link. Options include IPv4 and IPv6. This field displays a hyphen (-) for a custom-monitoring LB probe template.
Port
Port number of the real server. This field displays a hyphen (-) if the NQA port number is used.
Template type
Type of the template for health monitoring.
Reason
Reason for the health monitoring failure:
·     Timeout.
·     No Route—Health monitoring failed due to routing inaccessibility.
·     Internal error.
·     Verify error—Health monitoring failed due to a verification error.
·     Disconnect—Health monitoring failed because the remote end forcibly terminated the connection.
·     No connection—Failed to establish a connection with the remote end.
·     Expect Status error.
·     Other errors.
Failure time
Time when health monitoring failed, from the most recent to the earliest.
loadbalance probe failed-record max-number
reset loadbalance probe failed-record
display loadbalance probe-template
Use display loadbalance probe-template to display LB probe template information.
display loadbalance probe-template [ name template-name ]
name template-name: Specifies an LB probe template by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays information about all LB probe templates.
# Display information about all LB probe templates.
<Sysname> display loadbalance probe-template
Load balancing probe template: rst1
  Description:
  Type: tcp-rst
  Monitoring interval: 20 sec
  RST threshold: 10
  Protection action: auto-shutdown
  Reference count: 1
Load balancing probe template: zero2
  Description:
  Type: tcp-zero-window
  Monitoring interval: 30 sec
  Zero-window threshold: 20
  Protection action: busy
    Probe interval: 30 sec
    Probe times: 3
  Reference count: 1
Load balancing probe template: icmp1
  Description:
  Type: icmp
  Timeout: 3 sec
  Frequency: 300
  Reference count: 1
  Load balancing probe template: http1
  Description:
  Type: http-passive
  Monitoring interval: 1 sec
  Abnormal-url threshold: 10000
  Timeout: 30 sec
  URL list:
    aaa
  Status code list:
    404
  Reference count: 1
Load balancing probe template: test_external
  Description:
  Type: external-monitor
  External script: http.sh
  Monitoring interval: 5 sec
  Timeout: 6 sec
  Argument: 192.168.1.123
  Environment variable list:
    Name               Value
    Test3              /opt/lib
    Test4              /usr/bin
  Reference count: 1
Load balancing probe template: mysql
  Description:
  Type: database (MySQL)
  Destination ip/ipv6: 187.61.0.45
  Destination port: 0
  Timeout: 31 sec
  Database:  sid
  Username:  admin
  Sent statement:
  Expected data:  STANDBY
  Expected column:  1
  Expected row:  2
  Max reuse times: 0
  Reference count: 2
Load balancing probe template: oracle
  Description:
  Type: database (Oracle)
  Destination ip/ipv6: 187.61.0.44
  Destination port: 0
  Monitoring interval: 15 sec
  Timeout: 10 sec
  Database connection-string: %{ip}:%{port}/sid
  Username:  admin
  Sent statement: select database role from v$database
  Expected column: 0
  Expected row: 0
  Max reuse times: 0
  Reference count: 2
Table 8 Command output
LB probe template name.
Description for the LB probe template.
LB probe template type:
·     external-monitor—Custom monitoring.
·     http-passive.
·     icmp.
·     tcp-rst.
·     tcp-zero-window.
·     database (AntDB): AntDB database LB probe template. This field is not supported in the current software version.
·     database (MySQL): MySQL database LB probe template. This field is not supported in the current software version.
·     database (Oracle): Oracle database LB probe template. This field is not supported in the current software version.
Monitoring interval
Monitoring time. During the monitoring time, the system counts the number of RST packets or zero-window packets sent by each server farm member in a server farm.
This field is not displayed for an ICMP LB probe template.
RST threshold
Maximum number of RST packets a real server can send.
This field is displayed only for a TCP-RST LB probe template.
Maximum percentage of zero-window packets a real server can send.
This field is displayed only for a TCP zero-window LB probe template.
Protection action
Action to take when the RST or zero-window packet threshold is reached: Auto-shutdown or Busy.
This field is displayed only for a TCP-RST or TCP zero-window LB probe template.
Probe interval
Interval to probe the real server in busy state.
Probe times
Maximum number of times for probing the real server in busy state. If the number of probe times is reached, the real server is automatically shut down.
Timeout
Timeout time for probe responses, HTTP responses, or custom monitoring probe packet responses.
This field is not displayed for a TCP RST or TCP zero-window LB probe template.
Frequency
Probe interval for an LB probe template.
This field is displayed only for an ICMP LB probe template or HTTP passive LB probe template.
Upper limit of URL error times.
This field is displayed only for an HTTP passive LB probe template.
URL list
List of URLs to check for an HTTP passive LB probe template
Status code list
List of response status codes to check for an HTTP passive LB probe template
External script
Script file used by a custom-monitoring LB probe template.
This field is displayed only for a custom-monitoring LB probe template.
Argument
User-defined information for a custom-monitoring LB probe template.
Environment variables list
Environment variable list for a custom-monitoring LB probe template.
Name
Environment variable name.
Value
Environment variable value.
Sent statement
Query statement to be executed after login.
This field is displayed only for database LB probe templates.
Reference count
reset real-server statistics
display loadbalance process-limit
Use display loadbalance process-limit to display the maximum number of processes allowed to be started for custom monitoring.
# Display the maximum number processes allowed to be started for custom monitoring.
<Sysname> display loadbalance process-limit
Loadbalance process-limit: 2
display loadbalance protection-policy
Use display loadbalance protection-policy to display the configuration of protection policies.
display loadbalance protection-policy [ name policy-name ]
name policy-name: Specifies a protection policy by its name, a case-insensitive string of 1 to 255 characters. If you do not specify a protection policy, this command displays the configuration of all protection policies.
# Display the configuration of all protection policies.
<Sysname> display loadbalance protection-policy
Policy name: p1
  Description:
  Type: HTTP
  Protection action: warning
  Rule ID: 3
    URL: /index.php
    Protection period: 2
    Method                     Threshold
    Cookie (Jsessionid)        20
    Source IP                  10
  Rule ID: 5
    URL: /test.php
    Protection period: 20
    Method                     Threshold
    Cookie (A1B2C3D4)          20
  Reference count: 1
  Slow-attack protection state: Enabled
  Slow-attack request-header timeout: 10 seconds
  Slow-attack request-body timeout: 20 seconds
  Slow-attack client-read timeout: 30 seconds
  Slow-attack min-transmit-rate: 100 B/s
  Slow-attack min-transmit-rate duration: 60 seconds
Table 9 Command output
Protection action
Protection action:
·     warning—Generates a log message.
·     drop—Drops requests.
·     verify (insert header)—Performs client verification by inserting an HTTP header.
·     verify (js)—Performs cookie verification by inserting a JS script.
URL
Protected URL.
Method
Threshold type:
·     Cookie (xxx)—Cookie-based threshold (cookie name).
·     Source IP—- Source-IP-based threshold.
Reference count
HTTP slow attack protection status:
·     Enabled.
·     Disabled.
Timeout timer for detecting slow headers attacks.
Timeout timer for detecting slow body attacks.
Timeout timer for detecting slow read attacks.
Minimum transmission rate for detecting HTTP slow attacks.
Minimum transmission rate duration for detecting HTTP slow attacks.
display loadbalance snat-address statistics
Use display loadbalance snat-address statistics to display SNAT IP address statistics.
display loadbalance snat-address statistics { ip ip-address | ipv6 ipv6-address }
ip ip-address: Specifies an IPv4 address.
ipv6 ipv6-address: Specifies an IPv6 address.
# Display SNAT address statistics.
<Sysname> display loadbalance snat-address statistics ip 10.10.10.79
SNAT address: 10.10.10.79
  Inbound throughput            772.2Kbps
  Outbound throughput           376.7Kbps
  Received packets              2300
  Sent packets                  1100
  Current connections           0
  Peak connections              1
  Total connections             1
Table 10 Command output
SNAT address
IP address in the SNAT address pool.
Inbound throughput
Packet inbound throughput.
Outbound throughput
Packet outbound throughput.
Received packets
Number of received packets.
Sent packets
Number of sent packets.
Current connections
Number of concurrent connections.
Peak connections
Number of history maximum concurrent connections.
Total connections
Total number of history connections.
display loadbalance snat-global-policy
Use display loadbalance snat-global-policy to display SNAT global policy information.
display loadbalance snat-global-policy [ name policy-name ]
name policy-name: Specifies a SNAT global policy by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays information about all SNAT global policies.
# Display information about all SNAT global policies.
<Sysname> display loadbalance snat-global-policy
Policy name: lbsnat1
  Description:
  State: Active
  Priority: 0
  VPN instance:
  Source IP object group: src-obj
  Destination IP object group: dst-obj
  Service object group: proto-obj
  Translation mode: snat-pool sp
Policy name: lbsnat2
  Description:
  State: Inactive(disable)
  Priority: 0
  VPN instance:
  Translation mode: auto-map
Table 11 Command output
State of the SNAT global policy:
·     Active—The SNAT global policy is enabled and available.
·     Inactive—The SNAT global policy is enabled but unavailable.
·     Inactive (disabled)—The SNAT global policy is disabled and unavailable.
VPN instance
VPN instance to which the SNAT global policy belongs.
display loadbalance snat-pool
Use display loadbalance snat-pool to display SNAT address pool information.
display loadbalance snat-pool [ name pool-name ]
name pool-name: Specifies a SNAT address pool by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays information about all SNAT address pools.
# Display information about all SNAT address pools.
<Sysname> display loadbalance snat-pool
SNAT pool: lbsp1
  Description:
  VPN instance:
  Traffic group: 1
  VRRP IPv4 info:
    VRRP IPv4 VRID: 1
  VRRP IPv6 info:
    VRRP IPv6 VRID: 3
  IPv4 range:
    Start address                       End address
    202.110.10.5                        202.110.10.10
    202.110.20.10                       202.110.20.15
  IPv6 range:
    2002::2                             2002::100
    2002::200                           2002::300
  ARP/ND interfaces:
    GigabitEthernet1/0/3
  Reference count: 1
SNAT pool: lbsp2
  Description:
  VPN instance:
  Traffic group: 1
  VRRP IPv4 info:
    VRRP IPv4 VRID: 1
  VRRP IPv6 info:
    VRRP IPv6 VRID: 3
  IPv4 range:
    203.110.10.10                       203.110.10.15
  IPv6 range:
    2003::2                             2003::100
  ARP/ND interfaces:
    GigabitEthernet1/0/2
  Reference count: 1
Table 12 Command output
SNAT pool
SNAT address pool name.
Description for the SNAT address pool.
VPN instance
VPN instance to which the SNAT address pool belongs.
Traffic group
Number of the cluster traffic group bound to the SNAT address pool.
IPv4 range
IPv4 address range.
IPv6 range
IPv6 address range.
ARP/ND interfaces
Interfaces from which gratuitous ARP packets and ND packets are sent out.
VRRP IPv4 VRID
ID of the IPv4 VRRP group bound to the SNAT address pool.
VRRP group interface bound to the SNAT address pool.
VRRP IPv6 VRID
ID of the IPv6 VRRP group bound to the SNAT address pool.
Reference count
display loadbalance snat-pool statistics
Use display loadbalance snat-pool statistics to display SNAT address pool statistics.
display loadbalance snat-pool statistics [ name pool-name ]
name pool-name: Displays statistics of the specified SNAT address pool. The pool-name argument specifies the SNAT address pool name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics of all SNAT address pools.
# Display statistics of SNAT address pool spool.
<Sysname> display loadbalance snat-pool statistics name spool
SNAT pool: spool
    Sent packets                                1100
    Current connections                         1
    Peak connections                            1
Total connections                           1
  SNAT address: 10.10.10.80
    Inbound throughput                          854.6Kbps
    Outbound throughput                         417.0Kbps
    Received packets                            2600
    Sent packets                                1300
    Peak connections                            1
Total connections                           1
  Total:
    Inbound throughput                          1.6Mbps
    Outbound throughput                         793.7Kbps
    Received packets                            4900
    Sent packets                                2400
    Current connections                         2
    Peak connections                            2
    Total connections                           2
Table 13 Command output
SNAT pool
SNAT address
IP address member in the SNAT address pool.
Inbound throughput
Outbound throughput
Received packets
Sent packets
Current connections
Peak connections
Total connections
display loadbalance total-count
Use display loadbalance total-count to display the total numbers of LB resources.
# Display the total numbers of LB resources.
<Sysname> display loadbalance total-count
Total number of virtual-server:0
Total number of real-server:0
Total number of server-farm:0
Total number of server-farm member:0
Table 14 Command output
Total number of virtual servers.
Total number of real servers.
Total number of server farms.
Total number of server farm members.
display loadbalance snat-pool reference
Use display loadbalance snat-pool reference to display information about SNAT address pools being referenced.
display loadbalance snat-pool reference [ brief | name pool-name ]
brief: Displays brief reference information. If you do not specify this keyword, the command displays detailed reference information.
name pool-name: Specifies an SNAT address pool by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays information about all SNAT address pools.
# Display brief information about all SNAT address pools being referenced.
<Sysname> display loadbalance snat-pool reference brief
SNAT pool    Type                        Server farms         SNAT global policies
lbsp1        Address-based split         3                    2
lbsp2        Port-based split            0                    1
lbsp3        Failover-group-based split  2                    2
# Display detailed reference information about SNAT address pool lbsp1.
<Sysname> display loadbalance snat-pool reference name lbsp1
SNAT pool: lbsp1
  Type: Port-based split
  Server farms: sf1
                sf3
                sf4
  SNAT global policies: lbsnat1
                        lbsnat3
# Display detailed information about all SNAT address pools being referenced.
SNAT pool: lbsp1
  Server farms: sf1
                sf3
                sf4
                        lbsnat3
SNAT pool: lbsp2
  Type: Address split
  Server farms: sf2
                sf5
  SNAT global policies: lbsnat2
                        Lbsnat4
Table 15 Command output
SNAT pool
SNAT address pool type. Options include the following:
·     Address-based split.
·     Failover-group-based spit.
·     Port-based split.
Server farms
Server farms that use this SNAT address pool.
SNAT global policies that use the SNAT address pool.
snat-pool (server farm view)
translation-mode
display loadbalance virtual-server overall-total-statistics
Use display loadbalance virtual-server overall-total-statistics to display statistics information about all virtual servers on the device.
Execute this command display statistics information about all virtual server connections on the device and SSL offloading capability statistics.
# Display statistics information about all virtual servers on the device.
<Sysname> display loadbalance virtual-server overall-total-statistics
  Total connections: 1048341
  Active connections: 0
  Connections per second: 0
  Active SSL connections: 1
  SSL connections per second: 300
  SSL inbound bandwidth: 208800 bps
  SSL outbound bandwidth: 1704864 bps
Table 16 Command output
Total connections
Total number of virtual server connections.
Active connections
Total number of active connections on all virtual servers.
Connections per second for all virtual servers.
Number of SSL offloading connections.
SSL offloading connections per second.
Inbound bandwidth for SSL offloading.
Outbound bandwidth for SSL offloading.
display loadbalance virtual-server total-statistics
Use display loadbalance virtual-server total-statistics to display cumulative statistics for all virtual servers.
Operating mechanism
This command displays the cumulative connection statistics for all virtual servers. If you execute the reset virtual-server command for a virtual server, the statistical values are affected.
# Display cumulative statistics for all virtual servers.
<Sysname> display loadbalance virtual-server total-statistics
Slot 1:
  Total connections: 0
  Active SSL connections: 0
  SSL connections per second: 0
Slot 2:
Table 17 Command output
Total connections
Total number of connections.
Active connections
Number of active connections.
Number of connections per second.
Number of active SSL connections.
SSL connections per second.
display parameter-profile
Use display parameter-profile to display parameter profile information.
display parameter-profile [ name parameter-name ]
name parameter-name: Specifies a parameter profile by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays information about all parameter profiles.
# Display information about all parameter profiles.
<Sysname> display parameter-profile
Parameter profile: pp1
  Description:
  Type: IP
  IP ToS: 20
  Reference count: 0
Parameter profile: pp2
  Description:
  Type: TCP
  Exceed MSS: Allow
  TCP window size: 65535
  TCP connection idle-timeout: 10
  Time-wait timeout: 5
  Keepalive idle-timeout: 300
  Keepalive retransmission interval: 3
  Keepalive retransmission count: 5
  Syn retransmission-timeout: 5
  Syn cookie threshold:  10
  Fin-wait1 timeout: 6
  Fin-wait2 timeout: 10
  Src-addr-option:
    Option kind number: 29 (TCP-AO)
    Encoding: string
  TCP option remove:
    Option kind number: 3 (WSopt)
  TCP option remove:
    Option kind number: 5 (SACK)
  TCP option insert-mode: data-packet
  TCP option insert:
    Option kind number: 28 (UTO)
    Value: src-ip
    Encoding: string
  TCP option preserve:
    Option kind number: 8 (TSopt)
  TCP Timestamps option: Preserve
  Reference count: 1
Parameter profile: pp3
  Description:
  Type: HTTP
  Rebalance per request: Enabled
  Server connection reuse: Enabled
  Case insensitive: Enabled
  Header modify per request: Enabled
  Content maximum parse length: 8192
  Header maximum parse length: 8192
  Secondary cookie delimiters: !@#$
  Secondary cookie start: ?
  Encrypted cookie name: cookie1
  Header exceed length: Drop
  Reference count: 1
Parameter profile: compress
  Description:
  Type: HTTP compression
  Compression level: 1
  Prefer method: Gzip
  Content length threshold: 1024
  Memory size: 8KB
  Window size: 16KB
  Header Insert: Enabled
  Header Delete: Enabled
  Request version all: Disabled
  Rule 1: Permit url abc
  Reference count: 1
Parameter profile: urlstat
  Description:
  Type: HTTP-statistics
  Node: bank1
    Description:
    rule 1 url url1
    rule 2 url url2
  Node: bank2
    Description:
    rule 1 url url3
    rule 2 url url4
  Object group name:
    ObjGrp1
    ObjGrp2
  Reference count: 1
Parameter profile: pp4
  Description:
  Type: OneConnect
  Max reuse times: 1000
  Idle time: 10000
  IPv4 source mask length: 24
  IPv6 source prefix length: 120
  Reference count: 1
Parameter profile: pp5
  Description:
  Type: TCP-application
  Match-buffer-time: 5
  Match-buffer-size: 4096
  Match-buffer-end: YY
  Reference count: 1
Parameter profile: pp6
  Description:
  Type: MySQL
  Pool size: 2000
  Idle time: 10000 sec
  Reference count: 1
  Description:
  Type: HTTP2
  Concurrent-streams-per-connection: 123
  Recv-window size: 32
  Connection idle-timeout: 300
  Frame size: 1531
  Header-table size: 53241
  Insert-header-field: hx
  Connection close fin
  Reference count: 1
Parameter profile: pp7
  Description:
  Type: Diameter-session
  Origin host: host.example.com
  Origin realm: example.com
  Vendor Id: 25506
  Product name: L5080
  Host ip: 20.0.0.2
  Retransmission: Enabled
  Retransmission timeout: 5
  CE timeout: 20
  Reference count: 1
Table 18 Command output
Parameter profile
Parameter profile name.
Description for the parameter profile.
Parameter profile type:
·     IP.
·     HTTP.
·     HTTP-compression.
·     HTTP statistics.
·     MySQL.
·     OneConnect.
·     TCP.
·     TCP-application.
·     HTTP2.
·     Diameter session.
IP ToS
ToS field of the IP packets sent to the server.
Reference count
Exceed MSS
Action to take on the segments that exceed the MSS in the HTTP requests sent by the client:
·     Allow—Allows the segments to exceed the MSS.
·     Drop—Discards the segments that exceed the MSS.
Whether or not to enable load balancing for each HTTP request.
Pool size
Size of the MySQL connection pool.
Whether or not to reuse the connection between the LB device and the server.
Whether or not to perform the insert, delete, or modify operation for the header of each HTTP request or response packet.
Case insensitive
Whether or not to enable case sensitivity for matching character strings.
Maximum length of the HTTP entities that can be parsed.
Maximum length of the HTTP headers that can be parsed.
Delimiters that can separate secondary cookies in URLs.
Start delimiter for secondary cookies in URLs.
Cookie enabled with encryption.
Action to take on the HTTP requests or responses when their packet headers exceed the maximum length:
·     Continue—Continues to perform load balancing.
·     Drop—Stops performing load balancing, discards the packet, and terminates the connection.
TCP window size
Maximum local window size for TCP connections.
Idle timeout time for TCP connections, in seconds.
Time-wait timeout
TIME_WAIT state timeout time for TCP connections, in seconds.
Idle timeout time for sending TCP keepalive packets.
Retransmission interval for TCP keepalive packets.
Retransmission times for TCP keepalive packets.
Retransmission timeout time for TCP SYN packets
Threshold for triggering SYN Cookie protection. The value of 0 indicates that SYN Cookie protection will never be triggered.
Fin-wait1 timeout
FIN-WAIT-1 state timeout time for TCP connections.
Fin-wait2 timeout
FIN-WAIT-2 state timeout time for TCP connections.
Node
Statistics node name and all URL match rules configured for the statistics node.
Object group name
IP address object groups used by the HTTP statistics parameter profile.
Max reuse times
Maximum number of times a TCP connection can be reused.
Idle time
Mask length for connection reuse.
Prefix length for connection reuse.
Match-buffer-time
Buffering period for TCP payload matching, in seconds.
Match-buffer-size
Maximum buffering size for TCP payload matching.
Match-buffer-end
Buffering end string for TCP payload matching.
Src-addr-option
TCP option for SNAT address translation.
Option kind number
TCP option number
Encoding
Encoding mode for the TCP option:
·     binary.
·     string.
TCP option insert mode. Options include the following:
·     per-packet—Insert into data packets and handshake packets.
·     data-packet—Insert into data packets only.
TCP option insert
Inserts contents into a TCP option.
Value
Contents to insert into the TCP option
TCP option remove
Removes a TCP option.
Maximum number of concurrent requests supported by a TCP connection.
Recv-window size
Tx window sized for HTTP2.0 packets.
Idle timeout period of TCP connections for HTTP2.0 requests.
Frame size
HTTP2.0 frame size.
Header-table size
HTTP2.0 packet header table size.
Insert-header-field
Header field inserted in to HTTP2.0 requests.
Connection close fin/Connection close rst
Method for closing TCP connections between the device and real servers. Options include the following:
·     fin—Close TCP connections by sending FIN packets.
·     rst—Close TCP connections by sending RST packets.
TCP option preserve
Preserves a TCP option.
TCP option rewrite
Rewrites a TCP option.
Action on the TCP Timestamps option:
·     Preserve.
·     Rewrite.
·     Remove.
An asterisk (*) after the action indicates that it is the action globally specified. If no asterisk is displayed, it is the action specified for the parameter profile.
Origin host
Origin-Host AVP to be sent in Diameter messages.
Origin realm
Origin-Realm AVP to be sent in Diameter messages.
Vendor Id
Vendor-Id AVP to be sent in Diameter messages.
Product name
Product-Name AVP to be sent in Diameter messages.
Host ip/Host ipv6
Host IPv4 or IPv6 address.
Retransmission
Enabling status of Diameter message retransmission. Options include:
·     Disabled.
·     Enabled.
Timeout timer for Diameter message retransmission.
CE timeout
Timeout timer for Diameter capability exchange.
display real-server
Use display real-server to display real server information or server farm member information.
display real-server [ brief | name real-server-name ]
display real-server server-farm server-farm-name [ name real-server-name port port-number ]
brief: Displays brief real server information. If you do not specify this keyword, the command displays detailed real server information.
name real-server-name: Displays information about the specified real server. The real-server-name argument specifies a real server name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays information about all real servers.
server-farm server-farm-name: Displays information about members of a server farm. The server-farm-name argument specifies a server farm by its name, a case-insensitive string of 1 to 255 characters.
name real-server-name port port-number: Displays information about a server farm member. The real-server-name argument specifies a server farm member by its name, a case-insensitive string of 1 to 255 characters. The port-number argument specifies the port number of the server farm member, in the range of 0 to 65535. If you do not specify this option, the command displays information about all members of a server farm.
# Display brief information about all real servers.
<Sysname> display real-server brief
Real server      Address/domain              Port  State     VPN instance     Server farm
rs1              192.168.1.1                 0     Active                    sf
rs2              192.168.1.2                 0     Busy                      sf
rs3              192.168.1.3                 0     Active                    sf
rs4              www.example.com             0     Active                    sf
# Display detailed information about the real server rs.
<Sysname> display real-server name rs
Real server: rs
  Description: Real server RS
  State: Active
  Domain name:
  VPN instance:
  Inherit VPN: Disabled
  IPv4 address: 1.1.1.1
  IPv6 address: 1001::1
  Port: 0 (port number in original packet)
  Server farm: sf
  Weight: 150
  Priority: 3
  Cost: 100
  Slow shutdown: Enabled
  Slow offline: Disabled
  Connection limit: 10000
  Rate limit:
    Connections: 10000
    Bandwidth: 10000 kbps
    Inbound bandwidth: 5000 kbps
    Outbound bandwidth: 5000 kbps
  Bandwidth busy:
    Max bandwidth: 10000 kbps
    Max inbound bandwidth: 5000 kbps
    Max outbound bandwidth: 5000 kbps
    Busy rate: 80
    Inbound busy rate: 70
    Outbound busy rate: 60
    Busy recovery rate: 60
    Inbound busy recovery rate: 60
    Outbound busy recovery rate: 60
  Probe log: Enabled
  Probe information:
    Dynamic weight: 1
    SNMPDCA busy state: Normal
    Probe success criteria: All
    Probe method                    State
    t4                              Succeeded
    External-monitor method         State
    test_external                   Succeeded
    test_external2                  Succeeded
    Database Probe method              State
    ora1(database)                     Succeeded
  Reference count: 1
# Display information about all members of server farm sf.
<Sysname> display real-server server-farm sf
Server farm: sf
  Real server: rs1
    Description: real server 1
    Parent state: Inactive
    State: Inactive
    Port: 2
    Weight: 2
    Priority: 2
    Slow shutdown: Disabled
    Manual recover: Disabled
    Connection limit: --
    Connection rate limit: --
    Probe log: Enabled
    Probe information:
      Dynamic weight: --
      SNMPDCA busy state: --
      Probe method                       State
      icmp                               Failed
      ora1                               Invalid
    Probe template information:
      TCP RST probe template: rst
        Probe result: Normal
      TCP zero-window probe template:
      HTTP passive probe template:
  Real server: rs2
    Description: real server 2
    State: Inactive
    Port: 80
    Weight: 100
    Priority: 4
    Probe log: Enabled
    Probe information:
      Dynamic weight: 1
      Probe method                       State
      tcp                                Failed
      TCP zero-window probe template: zero
    Variable information:
      Variable name: variable
      Variable value: 2
Table 19 Command output
Real server
Real server name.
Address/domain
IPv4 address of the real server. IPv6 address or domain name.
Port
Port number of the real server. 0 means the port number in the packet is used.
Domain name
Domain name of the real server.
Parent state/State
Real server state/Server farm member state:
·     Active—The real server is available.
·     Busy—The real server is busy. When the real server is in Active or Ramp state and enabled with bandwidth statistics collection and link protection, this field displays Busy if the maximum expected bandwidth is reached.
·     Inactive—The real server is unavailable, because the configuration is not complete, the server is not referenced, or the virtual server is not enabled.
·     Probe-failed—Health monitoring has failed.
·     Ramp—Ramp-up phase of slow online.
·     Shutdown—The real server is shut down.
·     Standby—Standby phase of slow online.
·     Unknown—Health monitoring is not configured.
·     Auto shutdown—The real server is automatically shut down when the RST or zero-window packet threshold is reached or the number of probe times is reached.
·     Slowoffline—The slow offline feature is enabled for the real server or server farm member, and no health monitoring method is specified for the real server, server farm, or server farm member.
·     Shutdown (Probe-success)—The slow offline feature is enabled for the real server or server farm member, no active connections exist, and health monitoring succeeds.
·     Shutdown (Probe-failed)—The slow offline feature is enabled for the real server or server farm member, no active connections exist, and health monitoring fails.
·     Slowoffline (Probe-success)—The slow offline feature is enabled for the real server or server farm member, new connections are established, and health monitoring succeeds.
·     Slowoffline (Probe-failed)—The slow offline feature is enabled for the real server or server farm member, new connections are established, and health monitoring fails.
VPN instance
VPN instance to which the real server belongs.
Inherit VPN
VPN instance inheritance: Enabled or Disabled.
Server farm
Server farm of the real server.
Description for the real server.
IPv4 address
IPv6 address
IPv6 address of the real server.
Weight
Weight of the real server.
Priority
Priority of the real server.
Cost
Cost for proximity calculation.
Slow shutdown
Slow shutdown state of the real server:
·     Disabled.
·     Enabled.
Connection limit
Maximum number of connections for the real server.
Maximum number of connections per second for the real server.
Rate limit
Rate limit of the real server.
Connections
Bandwidth
Maximum bandwidth for the real server in kbps.
Inbound bandwidth
Maximum uplink bandwidth for the real server in kbps.
Outbound bandwidth
Maximum downlink bandwidth for the real server in kbps.
Max bandwidth
Maximum expected bandwidth for the real server in kbps.
Maximum uplink expected bandwidth for the real server in kbps.
Maximum downlink expected bandwidth for the real server in kbps.
Busy rate
Bandwidth ratio for the real server.
Inbound busy rate
Inbound bandwidth ratio for the real server.
Outbound busy rate
Outbound bandwidth ratio for the real server.
Busy recovery rate
Bandwidth recovery ratio for the real server.
Inbound bandwidth recovery ratio for the real server.
Outbound bandwidth recovery ratio for the real server.
Dynamic weight
Dynamic weight calculated by using the dynamic round robin algorithm. This field displays a weight value only if the dynamic round robin algorithm is used. If any other algorithm is used, this field displays two hyphens (--).
SNMPDCA busy state
Busy state obtained by using the dynamic round robin algorithm: Normal or Busy. If the dynamic round robin algorithm is not used, this field displays two hyphens (--).
Probe log
Health monitoring logging state of the real server:
·     Disabled.
·     Enabled.
Health monitoring success criteria for the real server:
·     All—Health monitoring succeeds only when all the specified health monitoring methods succeed.
·     At least X—Health monitoring succeeds when a minimum of X health monitoring methods succeed.
Probe method
Name of the NQA template used by the health monitoring method.
State of the health monitoring method (custom monitoring or NQA):
·     Failed—Health monitoring has failed.
·     In progress—Health monitoring is in progress.
·     Invalid—Health monitoring is unavailable (because the configuration of the NQA template is not complete), or the real server is unavailable.
·     Succeeded—Health monitoring has succeeded.
Custom monitoring method.
Database LB probe template.
Name of the TCP RST LB probe template.
Name of the TCP zero-window LB probe template.
Name of the HTTP passive LB probe template.
Probe result
Probe result of the TCP RST, TCP zero-window, or HTTP passive LB probe template:
·     Normal—The server farm member is running correctly.
·     Busy—The server farm member is busy.
·     Slowdown—The server farm member is in slowdown state.
Manual recover
State of the health monitoring manual recovery feature:
·     Disabled.
·     Enabled.
Reference count
display real-server statistics
Use display real-server statistics to display real server statistics or server farm member statistics.
display real-server statistics [ name real-server-name ]
display real-server statistics server-farm server-farm-name [ name real-server-name port port-number ]
name real-server-name: Specifies a real server by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays statistics for all real servers.
server-farm server-farm-name: Displays statistics for members of a server farm. The server-farm-name argument specifies a server farm by its name, a case-insensitive string of 1 to 255 characters.
name real-server-name port port-number: Displays statistics for a server farm member. The real-server-name argument specifies a server farm member by its name, a case-insensitive string of 1 to 255 characters. The port-number argument specifies the port number of the server farm member, in the range of 0 to 65535. If you do not specify this option, the command displays statistics for all members of a server farm.
# Display statistics for the real server rs.
<Sysname> display real-server statistics name rs
Real server: rs
  Total connections: 1798
  Active connections: 788
  Max connections: 803
    recorded at 11:02:49 on Tue May 21 2019
  Connections per second: 157
  Max connections per second: 163
  Server input: 333332 bytes
  Server output: 472054 bytes
  Throughput: 4396 bps
  Inbound throughput: 1214 bps
  Outbound throughput: 3128 bps
  Max throughput: 4564 bps
  Max inbound throughput: 1214 bps
  Max outbound throughput: 3320 bps
  Received packets: 1798
  Sent packets: 0
  Dropped packets: 0
  Received packets per second: 0
  Sent packets per second: 0
  Received requests: 0
  Dropped requests: 0
  Sent responses: 0
  Dropped responses: 0
  Connection failures: 1
  Busy state: Busy
# Display statistics for all members of server farm sf.
<Sysname> display real-server statistics server-farm sf
Server farm: sf
  Real server: rs1
    Max connections: 0
    Max connections per second: 0
    Server input: 0 bytes
    Server output: 0 bytes
    Throughput: 0 bps
    Inbound throughput: 0 bps
    Outbound throughput: 0 bps
    Max throughput: 0 bps
    Max inbound throughput: 0 bps
    Max outbound throughput: 0 bps
    Received packets: 0
    Sent packets: 0
    Dropped packets: 0
    Dropped requests: 0
    Sent responses: 0
    Connection failures: 0
    RST packets: 50
    Max RST packets: 5000
    RST probe protection times: 3
    Max RST probe protection times: 9
    Zero-window packet percentage: 10
    Max zero-window packet percentage: 50
    Zero-window probe protection times: 2
    Max zero-window probe protection times: 8
    Abnormal url times: 10
    Max abnormal url times: 20
  Real server: rs2
    Max connections: 0
    Throughput: 0 bps
    Received packets: 0
    Sent packets: 0
    Dropped packets: 0
    Dropped requests: 0
    Sent responses: 0
    RST packets: 50
Table 20 Command output
Real server
Real server name.
Total connections
Active connections
Max connections
Maximum number of connections.
Maximum number of connections per second.
Server input
Traffic (in bytes) received by the server.
Server output
Traffic (in bytes) sent by the server.
Throughput
Total packet throughput in bps.
Inbound throughput
Inbound packet throughput in bps.
Outbound throughput
Outbound packet throughput in bps.
Max throughput
Maximum packet throughput in bps.
Maximum inbound packet throughput in bps.
Maximum outbound packet throughput in bps.
Received packets
Sent packets
Dropped packets
Number of dropped packets.
Received requests
Number of received HTTP request packets. This field is displayed only for Layer 7 real servers.
Dropped requests
Number of dropped HTTP request packets. This field is displayed only for Layer 7 real servers.
Sent responses
Number of sent HTTP response packets. This field is displayed only for Layer 7 real servers.
Dropped responses
Number of dropped HTTP response packets. This field is displayed only for Layer 7 real servers.
Connection failures
Number of connection establishment failures.
Busy state
Real server state:
·     --—Unavailable.
·     Normal.
·     Busy.
RST packets
Number of RST packets sent by the real server during the monitoring time.
Max RST packets
Maximum number of RST packets sent by the real server during the monitoring time.
Number of probe times for the RST LB probe template.
Maximum number of probe times for the RST LB probe template.
Zero-window packet percentageZero-window packet rate
Percentage of zero-window packets sent by the real server during the monitoring time.
Max zero-window packet percentageMax zero-window packet rate
Maximum percentage of zero-window packets sent by the real server during the monitoring time.
Number of probe times for the zero-window LB probe template.
Maximum number of probe times for the zero-window LB probe template.
Abnormal url times
Number of URL error times during the current monitoring time during the monitoring time.
Maximum number of URL error times during the monitoring time.
display real-server overall-statistics
Use display real-server overall-statistics to display statistics information about all real servers or server farm members on the device.
display real-server overall-statistics [ name real-server-name ]
display real-server overall-statistics server-farm server-farm-name [ name real-server-name port port-number ]
display real-server overall-statistics server-farm server-farm-name [ name real-server-name port port-number ] [ slot slot-number [ cpu cpu-number ] ]
name real-server-name: Specifies a real server by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays information of all real servers.
name real-server-name port port-number: Displays statistics for a server farm member. The real-server-name argument specifies a server farm member by its name, a case-insensitive string of 1 to 255 characters. The port-number argument specifies the port number of the server farm member, in the range of 0 to 65535. If you do not specify this option, the command displays information of all members of a server farm.
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
# Display statistics information about real server rs.
<Sysname> display real-server overall-statistics name rs
Real server: rs
  Total connections: 356578
  Max connections: 37,
    recorded at: 08:46:22 on Wed Apr 13 2022
  Max connections per second: 6759,
    recorded at: 08:46:04 on Wed Apr 13 2022
  Server input: 88075301 bytes
  Server output: 115531472 bytes
  Throughput: 0 bps
  Max throughput: 28337024 bps,
    recorded at: 08:46:19 on Wed Apr 13 2022
  Max inbound throughput: 13176880 bps,
    recorded at: 08:46:05 on Wed Apr 13 2022
  Max outbound throughput: 17375712 bps,
  Received packets: 1426317
  Sent packets: 713161
  Dropped packets: 0
  Received requests: 356578
  Dropped requests: 0
  Sent responses: 356578
  Busy state: --
# Display statistics information about all members in server farm sf.
<Sysname> display real-server overall-statistics server-farm sf
Server farm: sf
  Real server (port: 443): rs
    Max connections: 0
    Throughput: 0 bps
    Received packets: 0
    Sent packets: 0
    Dropped packets: 0
    Dropped requests: 0
    Sent responses: 0
    RST packets: 50
For description of the command outputs, see Table 20.
display server-farm
Use display server-farm to display server farm information.
display server-farm [ brief | name server-farm-name ]
brief: Displays brief server farm information. If you do not specify this keyword, the command displays detailed server farm information.
name server-farm-name: Displays information about the specified server farm. The server-farm-name argument specifies a server farm name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays information about all server farms.
# Display brief information about all server farms.
<Sysname> display server-farm brief
Predictor: RR - Round robin, RD - Random, LC - Least connection,
           BW – Bandwidth, MBW – Max bandwidth,
           IBW – Inbound bandwidth, OBW – Outbound bandwidth,
           MIBW – Max inbound bandwidth, MOBW – Max outbound bandwidth,
           HASH(SIP) - Hash address source IP,
           HASH(DIP) - Hash address destination IP,
           HASH(SIP-PORT) - Hash address source IP-port
           LT - Least time, DRR - Dynamic round robin
           CARP(SIP) - CARP address source IP
           CARP(DIP) - CARP address destination IP
           CARP(SIP-PORT) - CARP address source IP-port
           CARP(HTTP) - CARP HTTP payload
           HASH(HTTP) - Hash HTTP payload
NAT/SNAT: Y - Enabled, N - Disabled
Server farm       Predictor       NAT  SNAT  Total  Active
sf                RR              Y    N     3      3
# Display detailed information about all server farms.
Server farm: sf1
  Description:
  Predictor: Hash address
  Proximity: Disabled
  NAT: Enabled
  SNAT mode: snat-pool sp
  Failed action: Keep
  Active threshold: Enabled
    Lower: 80
    Upper: 90
  Slow-online: Enabled
  Standby time: 5s
  Ramp-up time: 10s
  Selected server: Enabled
    Min server: 100
    Max server: 600
  Busy action: Enqueue
    Queue length: 11
    Queue timeout: 12
  Probe information:
    Probe method:
    aaa
    bbb
    ccc
    External-monitor method:
    Database Probe method:
  TCP RST probe template: aaa
  TCP zero-window probe template: bbb
  HTTP passive probe template: ccc
  Auto-shutdown recovery time: 30
  All-service-down action: Forward
    Forwarded to member: rs1
  Total real server: 1
  Active real server: 1
  Reference count: 1
  Real server list: (* : waiting for manual recover)
  Name      State         VPN instance     Address/Domain name    Port  Weight Priority  LT-weight
  rs1     Inactive                   1.2.3.4              0    100    4        50
  rs2     Auto shutdown              1.2.3.4              0    100    4        50
  rs3     Active                     www.example.com      0    100    4        50
  Temporary real server list : (* : waiting for manual recover)
  Name         State         Address              Port  Real server  Domain name
  auto_1.1.1.1 Active        1.1.1.1                    rs1          www.example1.com
  auto_2.2.2.2 Inactive      2.2.2.2                    rs2          www.example2.com
Table 21 Command output
Server farm
Server farm name.
Predictor
Scheduling algorithm of the server farm:
·     RR—Weighted round robin algorithm.
·     RD—Random algorithm.
·     LC—Weighted least connection algorithm.
·     BW—Bandwidth algorithm.
·     IBW—Inbound bandwidth algorithm.
·     OBW—Outbound bandwidth algorithm.
·     MBW—Maximum bandwidth algorithm.
·     MIBW—Maximum inbound bandwidth algorithm.
·     MOBW—Maximum outbound bandwidth algorithm.
·     HASH(SIP)—Hash algorithm based on source IP address.
·     HASH(DIP)—Hash algorithm based on destination IP address.
·     HASH(SIP-PORT)—Hash algorithm based on source IP address and port number.
·     LT—Least time algorithm.
·     DRR—Dynamic round robin algorithm.
·     CARP(SIP)—CARP hash algorithm based on source IP address.
·     CARP(DIP)—CARP hash algorithm based on destination IP address.
·     CARP(SIP-PORT)—CARP hash algorithm based on source IP address and port number.
·     CARP(HTTP)—CARP hash algorithm based on HTTP content.
·     HASH(HTTP)—Hash algorithm based on HTTP content.
Manual recover
·     Disabled.
·     Enabled.
NAT
NAT state of the server farm:
·     N—Disabled.
·     Y—Enabled.
SNAT
SNAT state of the server farm:
·     N—Disabled.
·     Y—Enabled.
Total
Active
Number of active real servers.
Description for the server farm.
Proximity
Proximity state of the server farm:
·     Disabled.
·     Enabled.
NAT
·     Disabled—NAT is not configured.
·     Enabled.
SNAT mode
SNAT translation mode:
·     auto-map—Automatic mapping mode.
·     tcp-option—TCP option mode.
·     snat-pool—SNAT pool mode, which uses the SNAT address pool (specified by its name) to perform address translation.
Failed action
Fault processing method of the server farm:
·     Keep—Keeps existing connections.
·     Reschedule—Redirects connections.
·     Reset—Terminates existing connections.
Active threshold
State of the criteria to determine that the server farm is available: disabled or enabled. If the state is enabled, the following fields are displayed:
·     Lower—Lower percentage value.
·     Upper—Upper percentage value.
Slow-online
State of the slow online feature: disabled or enabled. If the state is enabled, the following fields are displayed:
·     Standby time.
·     Ramp-up time.
Selected server
State of real server limit to participate in scheduling: disabled or enabled. If the state is enabled, the following fields are displayed:
·     Min server—Minimum number of real servers that participate in scheduling.
·     Max server—Maximum number of real servers that participate in scheduling.
·     At least—Health monitoring succeeds when a specified minimum number of health monitoring methods succeed.
Busy action
Action to take when the server farm is busy:
·     Drop.
·     Enqueue.
·     Force.
Queue length
This field is displayed only if the busy action is Enqueue.
Queue timeout
Probe method
Name of the custom probe template.
Name of the database LB probe template.
Indicates how packets are processed when all server farm members are unavailable:
·     --—Drop packets.
·     Forward—Forward packets to the last selected server farm member.
Forwarded to member
Last selected server farm member to which packets are forwarded.
Total real server
Active real server
Reference count
Number of times that the resource is being referenced.
Name
Real server name.
Real server state:
Address/Domain name
IPv4 and IPv6 addresses or domain names of the real server.
Port
Weight
Priority
LT-weight
Weight calculated by using the least time algorithm. This field displays a weight value only if the least time algorithm is used. If any other algorithm is used, this field displays two hyphens (--).
Temporary real server list.
Real server
Name of the real server to which the temporary real server belongs.
Domain name
Name of the domain to which the temporary real server belongs.
TCP-RST LB probe template referenced by the server farm.
This field is displayed only if a TCP-RST LB probe template is referenced.
TCP zero-window LB probe template referenced by the server farm.
This field is displayed only if a TCP zero-window LB probe template is referenced.
HTTP passive LB probe template referenced by the server farm.
This field is displayed only if an HTTP passive LB probe template is referenced.
Automatic recovery time for intelligent monitoring, in minutes.
display sticky statistics
Use display sticky statistics to display sticky entry statistics
display sticky statistics [ dns-proxy | virtual-server ]
dns-proxy dns-proxy-name: Displays sticky entry statistics for transparent DNS proxies.
virtual-server: Displays sticky entry statistics for virtual servers.
If you do not specify the dns-proxy or virtual-server keyword, this command displays statistics for all sticky entries.
# Display sticky entry statistics for virtual servers.
<Sysname> display sticky statistics virtual-server
Virtual server:
Total sticky entries for all sticky types: 27000
  Sticky type     Sticky method     Total sticky entries     Synced sticky entries
  Address-port                      12000                    120
                  Src IP            100                      10
                  Src IPv6          100                      10
                  Dst IP            100                      10
                  Dst IPv6          100                      10
                  Both IP           100                      10
                  Both IPv6         100                      10
                  Src IP port       100                      10
                  Src IPv6 port     100                      10
                  Dst IP port       100                      10
                  Dst IPv6 port     100                      10
                  Both IP port      100                      10
                  Both IPv6 port    100                      10
  HTTP header                       5000                     50
                  HTTP version      100                      10
                  HTTP URL          100                      10
                  HTTP method       100                      10
                  HTTP host         100                      10
                  Header name       100                      10
  HTTP cookie     Cookie get        100                      10
  HTTP content    HTTP content      100                      10
  Payload         Payload           100                      10
  SSL             SSL session       100                      10
  RADIUS          Attribute ID      200                      20
  SIP             SIP Call-ID       100                      10
  HTTP passive    HTTP Passive      100                      10
  UDP passive     Payload Passive   100                      10
  TCP payload     TCP Payload       100                      10
  Diameter        Attribute ID      100                      10
# Display sticky entry statistics for transparent DNS proxies.
<Sysname> display sticky statistics dns-proxy
DNS proxy:
Total sticky entries for all sticky types: 12000
                  Src IP            100                      10
                  Src IPv6          100                      10
                  Dst IP            100                      10
                  Dst IPv6          100                      10
                  Both IP           100                      10
                  Both IPv6         100                      10
                  Src IP port       100                      10
                  Dst IP port       100                      10
                  Both IP port      100                      10
Table 22 Command output
Sticky group name
Name of the sticky group that generates the sticky entries.
Sticky type
Type of the sticky group. Options include:
·     Address-port—Address and port.
·     HTTP content—HTTP entity.
·     HTTP cookie.
·     HTTP header.
·     HTTP passive.
·     Payload—HTTP or UDP payload.
·     RADIUS.
·     SIP.
·     SSL.
·     TCP payload.
·     UDP passive.
·     Diameter.
Sticky method
Sticky method corresponding to the sticky entries:
·     Src IP—Source IPv4 address sticky method.
·     Src IPv6—Source IPv6 address sticky method.
·     Src IP and port—Source IPv4 address + source port sticky method.
·     Src IPv6 and port—Source IPv6 address + source port sticky method.
·     Dst IP—Destination IPv4 address sticky method.
·     Dst IPv6—Destination IPv6 address sticky method.
·     Dst IP and port—Destination IPv4 address + destination port sticky method.
·     Dst IPv6 and port—Destination IPv6 address + destination port sticky method.
·     Both IP—Source IPv4 address + destination IPv4 address sticky method.
·     Both IPv6—Source IPv6 address + destination IPv6 address sticky method.
·     Both IP and port—Source IPv4 address + source port + destination IPv4 address + destination port sticky method.
·     Both IPv6 and port—Source IPv6 address + source port + destination IPv6 address + destination port sticky method.
·     HTTP URL—HTTP URL based sticky method.
·     HTTP header name—HTTP header name based sticky method.
·     HTTP version—HTTP version based sticky method.
·     HTTP host—HTTP host based sticky method.
·     HTTP method—HTTP Request-Method based sticky method.
·     HTTP content—HTTP entity sticky method.
·     Cookie get—HTTP cookie get sticky method.
·     Payload—HTTP or UDP payload sticky method.
·     HTTP passive—HTTP passive sticky method.
·     Payload passive—UDP payload passive sticky method.
·     TCP payload—TCP payload sticky method.
·     RADIUS IP—Sticky method based on the Framed-IP-Address attribute of RADIUS packets.
·     RADIUS ID—Sticky method based on the specified attribute of RADIUS packets.
·     SIP Call-ID—Sticky method based on the Call-ID header field of SIP packets.
·     SSL session ID—SSL sticky method based on SSL session ID.
·     Attribute ID—Sticky method based on the specified Diameter attribute.
Number of sticky entries synchronized from other devices or other cards on the local device.
display sticky virtual-server
Use display sticky virtual-server to display sticky entry information for virtual servers.
display sticky virtual-server [ virtual-server-name virtual-server-name ] [ [ link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } } | link-group link-group-name ] * | [ real-server-addr { ipv4-address | ipv6-address } | real-server-port port-number | server-farm server-farm-name | text text ] * ] [ class { class-name | default-class } | client-addr { ipv4-address | ipv6-address } | client-port port-number | sticky-type { diameter | address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive } [ key sticky-key ] ] * [ traffic-group traffic-group-id ] [ brief ]
virtual-server virtual-server-name: Specifies a virtual server by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays sticky entry information for all virtual servers.
link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } }: Specifies a link by its IPv4 address, IPv6 address, or output interface.
link-group link-group-name: Specifies a link group by its name, a case-insensitive string of 1 to 255 characters.
real-server-addr { ipv4-address | ipv6-address }: Specifies a real server by its IPv4 or IPv6 address.
real-server-port port-number: Specifies a real server port number in the range of 0 to 65535.
server-farm server-farm-name: Specifies a server farm by its name, a case-insensitive string of 1 to 255 characters.
text text: Specifies a text string to match. The string is case sensitive and can contain 1 to 63 characters.
class { class-name | default-class }: Specifies an LB class by its name, a case-insensitive string of 1 to 255 characters, or specifies the default LB class.
client-addr { ipv4-address | ipv6-address }: Specifies a client by its IPv4 or IPv6 address.
client-port port-number: Specifies a client port number in the range of 0 to 65535.
sticky-type { diameter | address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive }: Specifies a sticky group type.
key sticky-key: Specifies a key value, a case-sensitive string of 1 to 36 characters. If you do not specify key value, this command displays sticky entries for all key values.
traffic-group traffic-group-id: Specifies a cluster traffic group by its ID, an integer in the range of 1 to 255. If you do not specify this option, the command displays sticky entry information for all cluster traffic groups.
brief: Displays brief information about sticky entries. If you do not specify this keyword, the command displays detailed information about sticky entries.
# Display detailed sticky entry information for all virtual servers.
<Sysname> display sticky virtual-server
  Virtual server name: vs
  Cluster traffic group: 1
  Server farm name: sf
  Class: cla
  Sticky type: Address-port
  Sticky method: Source IP
  Sticky key: 3.0.0.13
  Virtual server addr: 33.44.1.1:80
  Real server addr: 7.0.0.7:80
  Client addr: 3.0.0.13
  Timeout: 100 sec
  Expiration time: 58 sec
  Matching sessions: 1
  Virtual server name: vs1
  Server farm name: sf_http
  Class: Default Class
  Sticky type: HTTP header
  Sticky method: HTTP header name
  Sticky key: cb3bae31bb1c443fbf3db8889055f2fe
  Text: a1b2c3d4e5
  Virtual server addr: 33.44.1.2:80
  Timeout: 100 sec
  Virtual server name: vs2
  Link group name: lg
  Class: cl2
  Sticky key: 3.0.0.15
  Virtual server addr: 0.0.0.0:0
  link: 20.1.1.1
  Client addr: 3.0.0.15
  Timeout: 100 sec
# Display brief sticky entry information for all virtual servers.
<Sysname> display sticky virtual-server brief
Sticky type    Sticky method    Sticky key      Virtual server      Real-server/link
Address-port   Src IP           3.0.0.13        vs                  7.0.0.7:80
Address-port   Src IP           3.0.0.15        vs2                 20.1.1.1
Table 23 Command output
Sticky group name
Cluster traffic group ID.
Sticky method
·     Framed-IP-Address—Sticky method based on the Framed-IP-Address attribute of RADIUS packets.
·     User-Name—Sticky method based on the User-Name attribute of RADIUS packets.
·     Code=attribute-code—Sticky method based on the attribute (specified by attribute-code) of RADIUS packets.
Sticky key
Key value corresponding to the sticky entry.
Timeout
Configured timeout time for sticky entries, in seconds. indefinite indicates not aging.
Expiration time
Remaining lifetime of the sticky entry, in seconds.
Matching sessions
Number of sessions that match the sticky entry.
This field is not displayed for sticky entries corresponding to HTTP Cookie insert and rewrite sticky methods.
display sticky-group
Use display sticky-group to display sticky group information.
display sticky-group [ name group-name ]
name group-name: Specifies a sticky group by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays information about all sticky groups.
# Display information about all sticky groups.
<Sysname> display sticky-group
Sticky group: sg1
  Description:
  Timeout: 60
  Override limit: Disabled
  Stickiness-over-busyness: Enabled
  Matching across services: Enabled
  Matching across virtual servers: Enabled
  Sticky group type: Address-port
    Method: Both IP and port
      Mask: 32
  Reference count: 1
Sticky group: sg2
  Description:
  Timeout: 60
  Sticky group type: HTTP header
    Method: HTTP header name
      Offset: 4
      Start: gzip
      Length: 10
  Reference count: 1
Sticky group: sg3
  Description:
  Timeout: 60
  Sticky group type: RADIUS
    Method: User-Name
  Reference count: 1
Sticky group: sg4
  Description:
  Timeout: 86400
  Stickiness-over-busyness: Disabled
  Sticky group type: HTTP cookie
    Method: HTTP cookie insert
      Domain: example.com
      Path: /test1
      HttpOnly: Enabled
      Secure: Enabled
  Check all packets: Disabled
  Reference count: 1
Sticky group: sg5
  Description:
  Timeout: 60
  Sticky group type: Diameter
    Method: attribute-code
      Code: 263, Index: 0
      Code: 283, Index: 0
  Reference count: 1
Table 24 Command output
Sticky group
Sticky group name.
Description for the sticky group.
Timeout
Timeout time for sticky entries in seconds. The value Infinite indicates that sticky entries never age out.
Override limit
Whether the feature of ignoring the limits for sessions that match sticky entries is enabled: Enabled or Disabled.
Whether the stickiness-over-busyness feature is enabled: Enabled or Disabled.
Sticky group type
Sticky group type:
·     HTTP cookie.
·     HTTP header.
·     HTTP passive.
·     RADIUS.
·     SIP.
·     SSL.
·     UDP passive.
·     TCP payload.
·     Diameter.
Reference count
Table 25 Detailed information for sticky groups
Sticky group type
Address-port
Method
Sticky method:
·     Source IP—Source IPv4 address sticky method.
·     Source IPv6—Source IPv6 address sticky method.
·     Source IP and port—Source IPv4 address + source port sticky method.
·     Source IPv6 and port—Source IPv6 address + source port sticky method.
·     Destination IP—Destination IPv4 address sticky method.
·     Destination IPv6—Destination IPv6 address sticky method.
·     Destination IP and port—Destination IPv4 address + destination port sticky method.
·     Destination IPv6 and port—Destination IPv6 address + destination port sticky method.
Mask
Mask length for the sticky method. This field is displayed only for IPv4 sticky methods.
Prefix
Prefix length for the sticky method. This field is displayed only for IPv6 sticky methods.
HTTP content
Offset
Offset value of the entity based on the start of the HTTP packet.
Start
Regular expression that marks the start of the entity.
End
Regular expression that marks the end of the entity. Either this field or the Length field is displayed, but not both of them.
Length
Length of the entity. Either this field or the End field is displayed, but not both of them.
HTTP cookie
Method
Sticky method:
·     HTTP cookie insert—Cookie insert sticky method.
·     HTTP cookie rewrite—Cookie rewrite sticky method.
·     HTTP cookie get—Cookie get sticky method.
This field is displayed only for the HTTP cookie sticky method.
Name
HTTP cookie name. This field is displayed only for the HTTP cookie sticky method.
Domain
Domain scope of the cookie. This field is displayed only for the HTTP cookie insert sticky method.
Path
Path scope of the cookie. This field is displayed only for the HTTP cookie insert sticky method.
Offset
Offset value based on the start of the cookie value. This field is displayed only for the cookie insert sticky method.
Start
Regular expression that marks the start of the cookie. This field is displayed only for the cookie insert sticky method.
End
Regular expression that marks the end of the cookie. Either this field or the Length field is displayed, but not both of them. This field is displayed only for the cookie insert sticky method.
Length
Length of the cookie. Either this field or the End field is displayed, but not both of them. This field is displayed only for the cookie insert sticky method.
Cookie secondary name
Name of the secondary cookie to be searched in the URI. This field is displayed only for the cookie insert sticky method.
HttpOnly
HttpOnly attribute of the cookie. This field is displayed only for the HTTP cookie insert or cookie rewrite sticky method.
Secure
Secure attribute of the cookie. This field is displayed only for the HTTP cookie insert or cookie rewrite sticky method.
Check all packets
Whether or not to enable checking for all packets.
HTTP header
Method
Sticky method:
This field is displayed only for the HTTP header sticky method.
Name
HTTP header name. This field is displayed only for the HTTP header name based sticky method.
Offset
Offset value of the HTTP header based on the start of the HTTP packet. This field is displayed only for the HTTP host or URL based sticky method.
Start
Regular expression that marks the start of the HTTP header. This field is displayed only for the HTTP host or URL based sticky method.
End
Regular expression that marks the end of the HTTP header. Either this field or the Length field is displayed, but not both of them. This field is displayed only for the HTTP host or URL based sticky method.
Length
Length of the HTTP header. Either this field or the End field is displayed, but not both of them. This field is displayed only for the HTTP host or URL based sticky method.
Payload
Offset
Offset value of the HTTP or UDP payload based on the start of the HTTP packet.
Start
Regular expression that marks the start of the HTTP or UDP payload.
End
Regular expression that marks the end of the HTTP or UDP payload. Either this field or the Length field is displayed, but not both of them. .
Length
Length of the HTTP or UDP payload. Either this field or the End field is displayed, but not both of them.
RADIUS
Method
Sticky method:
This field is not displayed if no RADIUS attribute based sticky method is specified.
SIP
Method
Sticky method, which can only be SIP Call-ID (SIP sticky method based on the Call-ID header field of SIP packets).
SSL
Method
Sticky method, which can only be SSL session ID (SSL sticky method based on SSL session ID). This field is displayed only for the SSL sticky method based on SSL session ID.
HTTP passive
Method
Sticky method:
·     HTTP header name—HTTP header name sticky method.
·     HTTP URL—HTTP URL sticky method.
·     HTTP content—HTTP content sticky method.
Get
Obtains the specified string in HTTP responses.
Match
Matches the specified string in HTTP requests.
Name
Start
End
Length
UDP passive
Get
Obtains the specified string in UDP responses.
Match
Matches the specified string in UDP requests.
Start
Regular expression that marks the start of the UDP payload.
End
Regular expression that marks the end of the UDP payload. Either this field or the Length field is displayed, but not both of them.
Length
Length of the UDP payload. Either this field or the End field is displayed, but not both of them.
TCP payload
Offset
Offset value of the TCP payload based on the start of the TCP packet.
Start
Regular expression that marks the start of the TCP payload.
End
Regular expression that marks the end of the TCP payload. Either this field or the Length field is displayed, but not both of them.
Length
Length of the TCP payload. Either this field or the End field is displayed, but not both of them.
Diameter
Method
Sticky method, which can only be attribute-code (sticky method based on the specified Diameter attribute in Diameter messages).
Code
AVP code of the specified Diameter attribute.
Index
Index of the specified Diameter attribute in an AVP sequence.
display temporary-real-server
Use display temporary-real-server to display temporary real server information.
display temporary-real-server [ brief | name temporary-real-server-name ]
display temporary-real-server server-farm server-farm-name [ name temporary-real-server-name port port-number ]
brief: Displays brief information about temporary real servers. If you do not specify this keyword, the command displays detailed information about temporary real servers.
name temporary-real-server-name: Specifies a temporary real server by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays information about all temporary real servers.
name temporary-real-server-name port port-number: Specifies a temporary real server by its name and port number. The temporary-real-server-name argument represents the name of the temporary real server, a case-insensitive string of 1 to 1 to 255 characters. The port-number argument represents the port number of the temporary real server, in the range of 0 to 65535. If you do not specify this option, the command displays information about all temporary real servers in the specified server farm.
# Display brief information about all temporary real servers.
<Sysname> display temporary-real-server brief
Temporary real server   Address          Real server  Domain name      State
auto_1.1.1.1            1.1.1.1          rs           www.h3c.com      Active
auto_2.2.2.2            2.2.2.2          rs1          www.example.com  Busy
# Display detailed information about temporary real server auto_1.1.1.1.
<Sysname> display temporary-real-server name auto_1.1.1.1
Temporary real server: auto_1.1.1.1
  Description: auto_1.1.1.1
  State: Active
  Belong domain name: www.h3c.com
  Belong real server: rs
  VPN instance:
  IPv6 address:
  Server farm: sf
  Weight: 150
  Priority: 3
  Cost: 100
  Rate limit:
    Connections: 10000
    HTTP requests: --
  Bandwidth busy:
    Busy rate: 80
  Probe log: Enabled
  Probe information:
    Dynamic weight: 1
    Probe method                    State
    t4                              Succeeded
  Reference count: 1
# Display information about all temporary real servers in server farm sf.
<Sysname> display temporary-real-server server-farm sf
Server farm: sf
  Real server: auto_1.1.1.1
    State: Inactive
    Port: 2 (port number in original packet)
    Weight: 2
    Priority: 2
    Rate limit: --
      Connections: --
      HTTP requests: --
    Probe log: Enabled
    Probe information:
      Dynamic weight: --
      Probe method                       State
      icmp                               Failed
      ora1                               Invalid
Table 26 Command output
Name of the temporary real server.
Real server
Domain name
Address
IPv4 address of the temporary real server.
Port
Port number of the temporary real server. The value of 0 indicates using the port number carried in the original packet.
State of the temporary real server/server farm member. Options include the following:
·     Active—The temporary real server/server farm member is available.
·     Busy—The temporary real server/server farm member is busy. When the temporary real server is in Active or Ramp state and enabled with bandwidth statistics collection and link protection, this field displays Busy if the maximum expected bandwidth is reached.
·     Inactive—The temporary real server/server farm member is unavailable, because the configuration is not complete, the server is not referenced, or the virtual server is not enabled.
·     Probe-failed—Health monitoring probe failed.
·     Shutdown—The temporary real server/server farm member is shut down.
·     Unknown—The temporary real server/server farm member is not configured with health monitoring.
·     Auto shutdown—The temporary real server/server farm member is in auto shutdown state. When a server farm is bound to an LB probe template, and the probe result reaches the specified threshold or exceeds the number of busy protections, the state of the server farm members is Auto shutdown.
Belong domain name
Belong real server
VPN instance
Name of the VPN instance to which the temporary real server belongs.
Inherit VPN
State of the VPN instance inheritance feature:
·     Enabled.
·     Disabled.
Server farm
Server farm to which the temporary real server belongs.
Description of the temporary real server.
IPv4 address
IPv6 address
IPv6 address of the temporary real server.
Weight
Weight of the temporary real server.
Priority
Scheduling priority of the temporary real server.
Cost
Cost of proximity calculation.
Slow shutdown
State of the slow shutdown feature for the temporary real server:
·     Disabled.
·     Enabled.
Connection limit
Maximum number of connections supported by the temporary real server.
Maximum connection rate supported by the temporary real server.
Rate limit
Rate limit of the temporary real server.
Connections
HTTP requests
HTTP requests per second for the temporary real server.
Bandwidth
Maximum total bandwidth supported by the temporary real server, in kbps.
Inbound bandwidth
Maximum uplink bandwidth supported by the temporary real server, in kbps.
Outbound bandwidth
Maximum downlink bandwidth supported by temporary real server, in kbps.
Max bandwidth
Maximum total bandwidth allowed when the temporary real server is busy, in kbps.
Maximum uplink bandwidth allowed when the temporary real server is busy, in kbps.
Maximum downlink bandwidth allowed when the temporary real server is busy, in kbps.
Busy rate
Busy ratio of the total bandwidth allowed for the temporary real server.
Inbound busy rate
Busy ratio of the uplink bandwidth allowed for the temporary real server.
Outbound busy rate
Busy ratio of the downlink bandwidth allowed for the temporary real server.
Busy recovery rate
Busy recovery ratio of the total bandwidth allowed for the temporary real server.
Busy recovery ratio of the uplink bandwidth allowed for the temporary real server.
Busy recovery ratio of the downlink bandwidth allowed for the temporary real server.
Dynamic weight
Dynamic weight calculated by the dynamic feedback algorithm. This value is valid only after the dynamic feedback algorithm takes effect. Otherwise, this field displays two hyphens (--).
SNMPDCA busy state
Busy state of the temporary real server obtained by the dynamic feedback algorithm:
·     Normal—The temporary real server is running correctly.
·     Busy—The temporary real server is busy.
Probe log
State of health monitoring logging for the temporary real server:
·     Disabled.
·     Enabled.
Success criteria for temporary real server health monitoring probe:
·     All—Health monitoring probe succeeds only when all methods pass the probe.
·     At least X—Health monitoring probe succeeds when X or more methods pass the probe.
Probe method
Name of the NQA template used by health monitoring probe.
State of custom monitoring, database probe, or NQA health monitoring:
·     Failed—Health monitoring probe failed.
·     In progress—Health monitoring probe is in progress.
·     Invalid—Health monitoring probe is not available, because the NQA template is not completely configured or the temporary real server is not available.
·     Succeeded—Health monitoring probe succeeded.
Manual recover
State of the health monitoring manual recovery feature for the server farm members:
·     Disabled.
·     Enabled.
Probe result
Probe result of the TCP RST, TCP zero-window, or HTTP passive LB probe template. Options include the following:
Variables associated with the server farm member.
Reference count
display virtual-server
Use display virtual-server to display virtual server information.
display virtual-server [ brief | name virtual-server-name ]
brief: Displays brief virtual server information. If you do not specify this keyword, the command displays detailed virtual server information.
name virtual-server-name: Displays information about the specified virtual server. The virtual-server-name argument specifies a virtual server name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays information about all virtual servers.
# Display brief information about all virtual servers.
<Sysname> display virtual-server brief
Virtual server   State    Type      VPN instance     Virtual address     Port
vs1              Inactive IP                         192.168.21.148/32   80
                                    vpn2             192.168.21.149/32   80
                                                     1111:2222:3333:4444
                                                     :5555:6666:7777:888
vs2              Active   HTTP                       61.159.4.100/32     8080
vs3              Active   LINK-IP                    51.139.4.100/32     0
vs4              Active   MySQL                      12.139.5.132/32     3306
vs5              Active   Diameter                   13.139.5.132/32     3868
# Display detailed information about all virtual servers.
Virtual server: vs
  Description: Virtual server VS
  Type: HTTP
  State: Active
  VPN instance: vpn1
  Virtual IPv4 address: 1.1.1.1/32
                        1.1.1.2/32(vpn2)
  Virtual IPv6 address: 1001::1/128(vpn3)
                        1001::2/128(vpn4)
  Port: 0 (any port)
  Traffic group: 1
  Primary server farm: sf (in use)
  Backup server farm: sfb
  Primary sticky: sg3
  Backup sticky: sg4
  LB policy: lbp2
  LB limit-policy:
  TCP parameter profile (client-side): ptc
  TCP parameter profile (server-side): pts
  HTTP parameter profile: pp1
  HTTP2 parameter profile (client-side): h1
  HTTP2 parameter profile (server-side): h2
  HTTP-statistics parameter profile: 1
  OneConnect parameter profile: one
  DPI application profile: profile1
  UDP per-packet: Enabled
  Rate limit:
    Connections: 10000
  SSL server policies with SNI list:
      Server name indication: www.example.com
  SSL server policy: ssl-server
  SSL client policy: ssl-client
  Redirect relocation:
  Redirect return-code: 302
  Sticky: test
  Sticky synchronization: Disabled
  Bandwidth busy protection: Disabled
  Interface bandwidth statistics: Disabled
  Route advertisement: Enabled
  ARP/ND interfaces:
    GigabitEthernet1/0/1
    GigabitEthernet1/0/2
  HTTP protection policy: p1
  Customlog content: %{is};%{ps}
  Insert xff: Enabled
  External-link proxy: Enabled
  External-link inject URI: proxy
  External-link inject domain suffix: c.example.com
  External-link SNAT pool: spool1
  External-link domain name whitelist:
    a.example.com
    b.example.com
Virtual server: vstcp
  Type: TCP
  State: Active
  VPN instance:
  Port: 8080
  Traffic group: 1
  Sticky: sg3
  LB policy: lbp2
  LB limit-policy:
  TCP-Application parameter profile: ptapp
  Rate limit:
    Connections: 10000
  Application-Mode: Enabled
  Proxy protocol: Enabled
  Proxy protocol version: V1
  ARP/ND interfaces:
# Display detailed information about the virtual server lk in outbound link load balancing.
<Sysname> display virtual-server name lk
Virtual server: lk
  Description:
  Type: Link-IP
  State: Active
  VPN instance:
  Port: 0
  Traffic group: 1
  Primary link group: lg1 (in use)
  Backup link group: lg2
  Sticky: sg3
  LB policy: lbp2
  LB limit-policy:
  Rate limit:
    Connections: 10000
  Connection synchronization: Disabled
  Route advertisement: Disabled
  ARP/ND interfaces:
# Display detailed information about the virtual server vs4.
<Sysname> display virtual-server name vs4
Virtual server: vs4
  Description: Virtual server VS4
  Type: MySQL
  State: Active
  VPN instance:
  Port: 3306
  Traffic group: 1
  Sticky: sg3
  LB policy: lbp2
  LB limit-policy:
  MySQL parameter profile: my
  Rate limit:
    Connections: 10000
  ARP/ND interfaces:
  Version: 5.6
  User list:
    Username: wangping
    Username: liqiang
  Read server farm: rd
  Read sticky group: rsg
  Write server farm: wr
  Write sticky group: wsg
# Display detailed information about virtual server vs5.
<Sysname> display virtual-server name vs5
Virtual server: vs5
  Description: Virtual server VS5
  Type: Diameter
  State: Active
  VPN instance: vpn1
  Port: 3868
  Traffic group: 1
  Sticky: dia-sg
  LB policy: dia-lbp
  LB limit-policy:
  Rate limit:
    Connections: --
  SSL server policy: ssp
  Diameter-session parameter profile: Dia-para
Table 27 Command output
Virtual server
Virtual server name.
Virtual server state:
·     Active—The virtual server is available.
·     Inactive—The virtual server is unavailable.
·     Inactive (disabled)—The virtual server is unavailable because the virtual server is disabled.
Virtual server type: Fast HTTP, HTTP, IP, MySQL, RADIUS, TCP, UDP, link-IP, or Diameter.
VPN instance
Name of the VPN instance to which the virtual server belongs.
Virtual address
IPv4 address and mask of the virtual server.
Port
Port number of the virtual server. 0 means any port.
Traffic group
Number of the cluster traffic group bound to the virtual server.
Description of the virtual server.
IPv6 address and prefix of the virtual server.
Primary server farm
Default primary server farm name. (in use) indicates the server farm is in use.
Backup server farm
Default backup server farm name. (in use) indicates the server farm is in use.
Primary link group
Default primary link group name. (in use) indicates the link group is in use.
Backup link group
Default backup link group name. (in use) indicates the link group is in use.
Primary sticky
Default primary sticky group name.
Backup sticky
Backup sticky group name. This field is displayed only for HTTP and RADIUS virtual servers.
LB policy
LB policy referenced by the virtual server.
HTTP parameter profile referenced by the virtual server. This field is displayed only if an HTTP parameter profile is configured.
IP parameter profile
IP parameter profile referenced by the virtual server. This field is displayed only if an IP parameter profile is configured.
TCP parameter profile referenced by the virtual server. This field is displayed only if a TCP parameter profile is configured.
Client-side TCP parameter profile referenced by the virtual server. This field is displayed only if a client-side TCP parameter profile is configured.
Server-side TCP parameter profile referenced by the virtual server. This field is displayed only if a server-side TCP parameter profile is configured.
OneConnect parameter profile referenced by the virtual server. This field is displayed only if an OneConnect parameter profile is configured.
HTTP statistics parameter profile referenced by the virtual server. This field is displayed only if an HTTP statistics parameter profile is configured.
TCP-application parameter profile referenced by the virtual server. This field is displayed only if a TCP-application parameter profile is configured.
MySQL parameter profile referenced by the virtual server. This field is displayed only if a MySQL parameter profile is configured.
Client-side HTTP2.0 parameter profile used by the virtual server. This field is displayed only if an HTTP2.0 parameter profile is configured.
Server-side HTTP2.0 parameter profile used by the virtual server. This field is displayed only if an HTTP2.0 parameter profile is configured.
Diameter parameter profile
Diameter session parameter profile specified for the virtual server. This field is displayed only when a Diameter session parameter profile is specified.
DPI application profile referenced by the virtual server. This field is displayed only if a DPI application profile is configured.
UDP per-packet
State of the per-packet load balancing for UDP traffic:
·     Disabled.
·     Enabled.
This field is displayed only for UDP virtual servers.
Connection limit
Maximum number of connections of the virtual server.
Rate limit
Rate limit of the virtual server.
Connections
Maximum number of connections per second of the virtual server.
Bandwidth
Maximum bandwidth for the virtual server in kbps.
Inbound bandwidth
Maximum inbound bandwidth for the virtual server in kbps.
Outbound bandwidth
Maximum outbound bandwidth for the virtual server in kbps.
List of SSL server policies with SNIs. This field is displayed only for TCP-type and HTTP-type virtual servers.
Server name indication. This field is displayed only for TCP-type and HTTP-type virtual servers.
SSL server policy
SSL server policy name. This field is displayed only for HTTP-type and Diameter-type virtual servers.
SSL client policy
SSL client policy name. This field is displayed only for HTTP-type virtual servers.
Redirect relocation
Redirection URL. This field is displayed only for HTTP-type virtual servers.
Status code in the redirection packets. This field is displayed only for HTTP-type virtual servers.
Sticky
Sticky group for the virtual server. This field is displayed only for HTTP-type virtual servers.
Session extension information synchronization state: Enabled or Disabled.
This field is not displayed for HTTP-type virtual servers.
Sticky entry synchronization state: Enabled or Disabled.
Link protection state: Enabled or Disabled.
Bandwidth statistics collection by interfaces: Disabled or Enabled.
Route advertisement
IP address advertisement for the virtual server: Disabled or Enabled.
Application-Mode
Layer 7 operating mode for the virtual server: Disabled or Enabled.
This field is displayed only for a TCP virtual server.
Proxy protocol
State of the proxy protocol feature for the virtual server:
·     Disabled.
·     Enabled.
This field is displayed for only TCP virtual servers.
·     V1.
·     V2.
This field is displayed only when the proxy protocol feature is enabled.
ARP/ND interfaces
Interfaces from which gratuitous ARP packets and ND packets are sent out.
Version
MySQL database version.
This field is displayed only for a MySQL virtual server.
User list
List of users logged in to the MySQL database.
Username
Username used to log in to the MySQL database.
Read server farm
Read server farm referenced by the MySQL virtual server.
Read sticky group
Sticky group associated with the read server farm.
Write server farm
Write server farm referenced by the MySQL virtual server.
Write sticky group
Sticky group associated with the write server farm.
Customlog content
Content output by using the fast log output feature.
This field is displayed only for an HTTP virtual server.
Insert xff
Whether the X-Forwarded-for field is inserted into packets sent to the server:
·     Disabled.
·     Enabled.
This field is displayed for only HTTP virtual servers.
HTTP protection policy referenced by the virtual server.
External-link proxy
External link proxy state: Disabled or Enabled.
URI of external link proxy.
Domain name suffix of external link proxy.
SNAT address pool of external link proxy.
Whitelist of external link proxy.
display virtual-server overall-statistics
Use display virtual-server overall-statistics to display statistics information about all virtual servers on the device.
display virtual-server overall-statistics [ name virtual-server-name ]
display virtual-server overall-statistics [ name virtual-server-name ] [ slot slot-number [ cpu cpu-number ] ]
name virtual-server-name: Specifies a virtual server by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays statistics information for all virtual servers.
The virtual server statistics interval is 200 milliseconds.
# Display statistics information about virtual server vs.
<Sysname> display virtual-server overall-statistics name vs
Virtual server: vs
  Total connections: 1048341
  Active connections: 0
  Max connections: 245,
    recorded at: 17:32:04 on Tue Jul 24 2074
  Connections per second: 0
  Max connections per second: 18912,
    recorded at: 17:31:55 on Tue Jul 24 2074
  Client input: 242167623 bytes
  Client output: 339667596 bytes
  Throughput: 0 bps
  Max throughput: 79507672 bps,
    recorded at: 17:31:59 on Tue Jul 24 2074
  Max inbound throughput: 35814280 bps,
    recorded at: 17:32:01 on Tue Jul 24 2074
  Max outbound throughput: 46758144 bps,
    recorded at: 17:32:00 on Tue Jul 24 2074
  Active SSL connections: 0
  SSL connections per second: 0
  Received packets: 4193385
  Sent packets: 2096703
  Dropped packets: 0
  Received requests: 1048341
  Dropped requests: 0
  Sent responses: 1048341
  Authentication permitted requests: 0
  Authentication denied requests: 0
  Redirect requests for login: 0
  Redirect requests for re-authentication: 0
For description of the command outputs, see Table 28.
display virtual-server statistics
Use display virtual-server statistics to display virtual server statistics.
display virtual-server statistics [ name virtual-server-name ]
name virtual-server-name: Specifies a virtual server by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command displays statistics of all virtual servers.
The virtual server statistics collection interval is 200 milliseconds and is not configurable.
# Display statistics for the virtual server vs.
<Sysname> display virtual-server statistics name vs
Virtual server: vs
  Total connections: 979
  Active connections: 618
  Max connections: 661
  Connections per second: 146
  Max connections per second: 156
  Client input: 333332 bytes
  Client output: 472054 bytes
  Throughput: 4088 bps
  Outbound throughput: 2874 bps
  Max throughput: 4368 bps
  Max outbound throughput: 3154 bps
  Received packets: 979
  Sent packets: 0
  Dropped packets: 0
  Redirected requests for login: 4
  Redirected requests for re-authentication: 0
Table 28 Command output
Virtual server
Total connections
Total number of connections.
Active connections
Number of active connections.
Half Open connections
Number of half-open connections. This field is displayed for only TCP virtual servers.
Max connections
Number of connections per second.
Client input
Traffic (in bytes) received from the client.
Client output
Traffic (in bytes) sent to the client.
Throughput
Inbound throughput
Outbound throughput
Max throughput
Max throughput
Max throughput
Number of active SSL connections.
SSL connections per second.
Received packets
Number of received packets.
Sent packets
Number of packets sent by the virtual server to the client.
Dropped packets
Received requests
Number of received HTTP request packets. This field is displayed only for HTTP-type virtual servers.
Dropped requests
Number of dropped HTTP request packets. This field is displayed only for HTTP-type virtual servers.
Sent responses
Number of sent HTTP response packets. This field is displayed only for HTTP-type virtual servers.
Dropped responses
Number of dropped HTTP response packets. This field is displayed only for HTTP-type virtual servers.
Number of permitted requests after authentication.
Number of denied requests after authentication.
Number of requests redirected to the login page.
Number of requests redirected to the reauthentication page.
reset virtual-server statistics
domain-name
Use domain-name to configure a domain name for a real server.
Use undo domain-name to restore the default.
domain-name domain-name
undo domain-name
No domain name is configured for a real server.
Real server view
domain-name: Specifies a domain name, a case-insensitive string of 1 to 253 characters. Each dot-separated label (such as example.com) in the domain name can contain a maximum of 253 characters. The domain name can contain letters, digits, hyphens (-), underscores (_), and dots (.).
Operating mechanism
After you configure a domain name for a real server, the device immediately sends a domain name query request to the DNS server. It then creates a real server with name auto_ip-address and IP address ip-address based on the query result. If the real server domain name is resolved to multiple IP addresses, the device creates multiple real servers.
If you configure a domain name for a real server, you must specify the DNS server for domain name resolution by using the dns server command. For more information about the dns server command, see DNS commands in Network Connectivity Command Reference.
The domain name query result returned by the DNS server carries a TTL expiration time. When the TTL expires, the device automatically performs the next domain name query. If the resolved IP for the domain name changes, the temporary real server generated based on the old IP will be deleted, and a new temporary real server will be generated based on the new IP.
The domain name query results returned by the DNS server include TTL timeout information. When the TTL expires, the device automatically performs the next domain name query. If the resolved IP address changes, the device deletes the temporary real server created based on the old resolved IP and generates a new temporary real server based on the new resolved IP.
For a real server, the domain-name command and ip address command are mutually exclusive. If you execute both commands, the most recent configuration takes effect.
Different real servers cannot use the same domain name.
# In real server view, configure a domain name for the real server.
[Sysname] real-server rs
[Sysname-rserver-rs] domain-name www.example.com
dns server (Network Connectivity Command Reference)
ip address
dpi-app-profile
Use dpi-app-profile to specify a DPI application profile for the virtual server.
Use undo dpi-app-profile to restore the default.
dpi-app-profile app-profile-name
No DPI application profile is specified for a virtual server.
IP/TCP/UDP/HTTP virtual server view
Link IP virtual server view
app-profile-name: Specifies a DPI application profile by its name, a case-insensitive string of 1 to 63 characters. For more information about DPI application profiles, see DPI engine in DPI Configuration Guide.
Operating mechanism
By specifying a DPI application profile, you can apply DPI services to the traffic of a virtual server. For more information about DPI services, see DPI Configuration Guide.
# Specify DPI application profile profile_1 for IP-type virtual server vs.
[Sysname] virtual-server vs type ip
[Sysname-vs-ip-vs] dpi-app-profile profile_1
# In outbound link load balancing, specify DPI application profile profile_1 for link IP-type virtual server vs1.
[Sysname] virtual-server vs1 type link-ip
[Sysname-vs-link-ip-vs1] dpi-app-profile profile_1
app-profile (DPI Command Reference)
encrypt-cookie
Use encrypt-cookie to encrypt a cookie.
Use undo encrypt-cookie to remove the encryption for a cookie.
encrypt-cookie name cookie-name key { cipher | simple } string
undo encrypt-cookie name cookie-name
No cookie is encrypted.
HTTP parameter profile view
name cookie-name: Specifies a cookie by its name, a case-sensitive string of 1 to 63 characters.
key: Specifies a key used to encrypt the cookie.
cipher: Specifies a key in ciphertext form.
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in ciphertext form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 31 characters. Its ciphertext form is a case-sensitive string of 1 to 73 characters.
After you execute this command, the device encrypts the Set-Cookie field in HTTP responses to prevent personal information from being revealed. When a client request contains an encrypted cookie, the device decrypts the cookie before sending the request to the server.
# For HTTP parameter profile p1, encrypt cookie cookie1 with encryption key 123456.
[Sysname] parameter-profile p1 type http
[Sysname-para-http-p1] encrypt-cookie name cookie1 key simple 123456
env-variables
Use env-variables to configure an environment variable for custom monitoring.
Use undo env-variables to delete an environment variable for custom monitoring.
env-variables variable-name value variable-value
undo env-variables variable-name
No environment variables are configured for custom monitoring.
Custom-monitoring LB probe template view
variable-name: Specifies the environment variable name, a case-sensitive string of 1 to 63 characters. The name can contain spaces.
value variable-value: Specifies an environment variable value, a case-sensitive string of 1 to 255 characters. The name can contain spaces and cannot contain quotation marks (").
Operating mechanism
You can specify the environment to execute the custom script file by configuring an environment variable.
You can configure a maximum of 16 environment variables.
# In custom-monitoring LB probe template test_external, configure an environment variable with name env and value /var/tmp.
[Sysname] loadbalance probe-template external-monitor test_external
[Sysname-lbpt-external-monitor-test_external] env-variables env value /var/tmp
exceed-mss
Use exceed-mss to specify the action to take on the segments that exceed the MSS in the HTTP requests sent by the client.
Use undo exceed-mss to restore the default.
exceed-mss { allow | drop }
undo exceed-mss
The device allows the segments to exceed the MSS in the HTTP requests sent by the client.
TCP parameter profile view
allow: Allows the segments to exceed the MSS.
drop: Discards the segments that exceed the MSS.
# For the TCP parameter profile pp3, specify the drop action for the segments that exceed the MSS in the HTTP requests sent by the client.
[Sysname] parameter-profile pp3 type tcp
[Sysname-para-tcp-pp3] exceed-mss drop
external-link inject-domain-suffix
Use external-link inject-domain-suffix to configure the domain name suffix for external link proxy.
Use undo external-link inject-domain-suffix to delete the domain name suffix for external link proxy.
external-link inject-domain-suffix domain-suffix
No domain name suffix is configured for external link proxy.
domain-suffix: Specifies the domain name suffix for rewriting domain names of external links. This argument is a case-insensitive, dot-separated string of 1 to 254 characters. Each dot-separated label in the domain name can contain a maximum of 63 characters. The domain name can contain letters, digits, hyphens (-), underscores (_), and dots (.).
Operating mechanism
If DNS packet link selection is performed by inbound link load balancing, make sure the domain name suffixes in DNS mappings are the same as those on the external link proxy.
# Configure the domain name suffix as b.example.com for external link proxy on HTTP virtual server vs.
[Sysname] virtual-server vs type http
[Sysname-vs-http-vs] external-link inject-domain-suffix b.example.com
external-link inject-uri
external-link proxy enable
Use external-link inject-uri to configure the URI for external link proxy.
Use undo external-link inject-uri to delete the URI for external link proxy.
external-link inject-uri string
No URI is configured for external link proxy.
string: Specifies the URI for rewriting domain names of external links. This argument is a case-insensitive string of 1 to 63 characters. The URI can contain letters, digits, hyphens (-), and underscores (_), and cannot contain dots (.).
Operating mechanism
Use this command to rewrite domain names of external links. Upon receiving a response from the IPv6 site server, the LB device rewrites the IPv4 external link in the response by adding the specified parameters to the associated domain name. The parameters include the URI, domain name suffix, and virtual server port number. Suppose the domain name of the original external link is http://www.example1.com, URI is proxy, domain name suffix is example2.com, and virtual server port number is 8080. The external link domain name after rewrite is http://www.example1.com.proxy.example2.com:8080. Upon receiving a DNS request containing this modified domain name, the LB device performs the following operations:
1.     Extracts the original domain name.
2.     Requests the associated IPv4 resource on behalf of the IPv6 client.
3.     Returns the obtained IPv4 resource to the IPv6 client.
# Configure the URI as proxy for external link proxy on HTTP virtual server vs.
[Sysname-vs-http-vs] external-link inject-uri proxy
external-link proxy enable (LB action view)
Use external-link proxy enable to enable external link proxy.
Use undo external-link proxy enable to disable external link proxy.
External link proxy is disabled.
HTTP LB action view
Operating mechanism
To perform external link proxy for a traffic class instead of all traffic of a virtual server, enable external link proxy in an HTTP LB action. Additionally, configure external link proxy parameters in the view of the virtual server and specify the LB policy for the virtual server.
The external link proxy action is first taken when the following actions are also configured:
·     A forwarding LB action.
·     HTTP redirection action.
·     Specifying a response file for matching HTTP requests.
·     Specifying a response file used upon load balancing failure.
# Enable external link proxy for HTTP LB action a1.
[Sysname] loadbalance action a1 type http
[Sysname-lba-http-a1] external-link proxy enable
display loabalance action
external-link proxy enable (virtual server view)
Operating mechanism
This command enables the LB device to operate as a proxy to request IPv4 resources on behalf of IPv6 clients. External link proxy operates as follows:
1.     The LB device receives an IPv6 DNS request containing an IPv4 link, and sends the request to the IPv6 site server.
2.     Upon receiving a response from the server, the LB device returns a script file with the external link rewritten as configured to the client.
3.     The client executes the script file, modifies the external link domain name as instructed, and then sends another DNS request containing the modified domain name.
4.     Upon receiving the request, the LB device extracts the original domain name and requests the associated IPv4 resource on behalf of the client.
5.     The LB device returns the obtained IPv4 resource to the client.
# Enable external link proxy for HTTP virtual server vs.
[Sysname-vs-http-vs] external-link proxy enable
external-link snat-pool
Use external-link snat-pool to specify the SNAT address pool for external link proxy.
Use undo external-link snat-pool to restore the default.
external-link snat-pool pool-name
No SNAT address pool is specified for external link proxy.
pool-name: Specifies a SNAT address pool by its name, a case-insensitive string of 1 to 255 characters.
Operating mechanism
To request an IPv4 resource as an external link proxy, the LB device will choose an IP address from the specified SNAT pool. The LB device uses this IP address as the client IP address to initiate a request on behalf of the IPv6 client.
If you do not specify a SNAT address pool, the LB device uses the IP address of the output interface to the server as the client IP address.
# Specify the SNAT address pool as spool1 for external link proxy on HTTP virtual server vs.
[Sysname-vs-http-vs] external-link snat-pool spool1
loadbalance snat-pool
external-link whitelist domain
Use external-link whitelist domain to add a domain name to the whitelist for external link proxy.
Use undo external-link whitelist domain to delete a domain name from the whitelist for external link proxy.
external-link whitelist domain domain-name
undo external-link whitelist domain domain-name
No domain names are added to the whitelist for external link proxy.
domain-name: Specifies a domain name, a case-insensitive, dot-separated string of 1 to 254 characters. Each dot-separated label in the domain name can contain a maximum of 63 characters. The domain name can contain letters, digits, hyphens (-), underscores (_), and dots (.).
Operating mechanism
The LB device does not rewrite the external links containing any domain names in the whitelist. You can add specific domain names (for example, those of the IPv6 external links in the IPv6 site) to the whitelist.
# Add domain name a.example.com to the whitelist for external link proxy on HTTP virtual server vs.
[Sysname-vs-http-vs] external-link whitelist domain a.example.com
external-script
Use external-script to specify a script file used for custom monitoring.
Use undo external-script to restore the default.
external-script file-name
No script file is specified for custom monitoring.
file-name: Specifies a script file by its name, a case-insensitive string of 1 to 255 characters.
Operating mechanism
The device detects the state of real severs according to the detection contents in the script file.
Before specifying a script file, upload the file to the device.
The device supports specifying only script files with the .py suffix.
# In custom-monitoring LB probe template test_external, use script file test.py for custom monitoring.
[Sysname] loadbalance probe-template external-monitor test-external
[Sysname-lbpt-external-monitor-test-external] external-script test.py
fail-action
Use fail-action to specify the fault processing method for a server farm.
Use undo fail-action to restore the default.
fail-action { keep | reschedule | reset }
undo fail-action
The fault processing method is to keep existing connections.
Server farm view
keep: Keeps the connection with the failed real server. Keeping or terminating the connection depends on the timeout mechanism of the protocol.
reschedule: Redirects the connection to another available real server in the server farm.
reset: Terminates the connection with the failed real server by sending RST packets (for TCP packets) or ICMP unreachable packets (for other types of packets).
The fault processing method applies when the real server that processes packets fails.
# Specify the fault processing method for the server farm sf as reschedule.
[Sysname] server-farm sf
[Sysname-sfarm-sf] fail-action reschedule
fallback-action close
Use fallback-action close to configure the method of closing TCP connections upon failure to find a real server.
Use undo fallback-action to restore the default.
fallback-action close { fin | rst }
Packets are dropped when no real servers are available for the current LB action.
Generic/HTTP LB action view
fin: Closes TCP connections by sending FIN packets.
rst: Closes TCP connections by sending RST packets.
This command enables the device to close TCP connections matching the LB policy by sending FIN or RST packets if the device fails to find a real server according to the LB action.
# In HTTP LB action a1, configure the method of closing TCP connections by sending RST packets.
[Sysname-lba-http-a1] fallback-action close rst
fallback-action continue
Use fallback-action continue to match the next rule upon failure to find an available server.
Packets are dropped when no servers are available for the current LB action.
LB action view
Operating mechanism
This command enables packets to match the next rule in an LB policy when no servers are available for the current LB action.
This command does not apply to SIP virtual servers.
# Match the next rule upon failure to find a real server for the HTTP LB action a1.
[Sysname-lba-http-a1] fallback-action continue
# In transparent DNS proxy, match the next rule upon failure to find a DNS server for the DNS LB action a2.
[Sysname] loadbalance action a2 type dns
[Sysname-lba-dns-a2] fallback-action continue
# In outbound link load balancing, match the next rule upon failure to find a DNS server for the link-generic LB action a3.
[Sysname] loadbalance action a3 type link-generic
[Sysname-lba-link-generic-a3] fallback-action continue
fallback-action response raw-file
Use fallback-action response raw-file to specify a response file used upon load balancing failure.
fallback-action response raw-file raw-filename
Packets are discarded upon load balancing failure.
HTTP LB action view
raw-filename: Specifies a response file by its name, a case-insensitive string of 1 to 255 characters.
Compatibility information
The fallback-action response raw-file command and the fallback-action continue command are mutually exclusive.
Operating mechanism
This command enables the device to respond to client requests when the device fails to find an available real server or fails to find the response file specified in the response command. The response file specified in the fallback-action response raw-file command must contain a complete HTTP packet and cannot contain only the HTTP content.
# Specify the 301.raw file as the response file used upon load balancing failure.
[Sysname] loadbalance action a_http type http
[Sysname-lba-http-a_http] fallback-action response raw-file 301.raw
display loadbalance action
fin-wait1 timeout
Use fin-wait1 timeout to set the FIN-WAIT-1 state timeout time for TCP connections.
Use undo fin-wait1 timeout to restore the default.
fin-wait1 timeout timeout-value
The FIN-WAIT-1 state timeout time is 5 seconds for TCP connections.
timeout-value: Specifies the FIN-WAIT-1 state timeout time in the range of 1 to 65535 seconds.
# Set the FIN-WAIT-1 state timeout time for TCP connections to 10 seconds in the TCP parameter profile profile.
[Sysname] parameter-profile profile type tcp
[Sysname-para-tcp-profile] fin-wait1 timeout 10
display parameter-profile
fin-wait2 timeout
Use fin-wait2 timeout to set the FIN-WAIT-2 state timeout time for TCP connections.
Use undo fin-wait2 timeout to restore the default.
The FIN-WAIT-2 state timeout time is 5 seconds for TCP connections.
timeout-value: Specifies the FIN-WAIT-2 state timeout time in the range of 1 to 65535 seconds.
# Set the FIN-WAIT-2 state timeout time for TCP connections to 10 seconds in the TCP parameter profile profile.
[Sysname-para-tcp-profile] fin-wait2 timeout 10
forward all
Use forward all to configure the packet forwarding mode.
Use undo forward to restore the default.
forward all
undo forward
The packet forwarding mode is to discard packets.
DNS/Generic/Link-generic LB action view
In DNS LB action view, this command is mutually exclusive with the dns-server-pool or skip current-dns-proxy command. In generic LB action view, the forward all and server-farm commands are mutually exclusive. In link-generic LB action view, the forward all and link-group commands are mutually exclusive. If you configure one command, the other command (if configured) is automatically cancelled.
# In server load balancing, configure the packet forwarding mode for the generic LB action lba1.
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] forward all
# In outbound link load balancing, configure the packet forwarding mode for the link-generic LB action lba2.
[Sysname] loadbalance action lba2 type link-generic
[Sysname-lba-link-generic-lba2] forward all
# In transparent DNS proxy, configure the packet forwarding mode for the DNS LB action lba3.
[Sysname] loadbalance action lba3 type dns
[Sysname-lba-dns-lba3] forward all
dns-server-pool
link-group (LB action view)
server-farm (LB action view)
frame size
Use frame size to configure the size of a frame in an HTTP2.0 packet.
Use undo frame size to restore the default.
frame size size
undo frame size
The size of a frame in an HTTP2.0 packet is 2048.
HTTP2.0 parameter profile view
size: Specifies the size of a frame in an HTTP2.0 packet, in the range of 1024 to 16384.
Operating mechanism
A frame is the smallest unit of an HTTP2.0 packet, and an HTTP2.0 packet can be composed of multiple frames. You can configure the size of a frame in an HTTP2.0 packet. If a frame exceeds the specified size, the device will fragment the data in the frame based on the specified frame size.
This command takes effect only on HTTP 2.0 request packets.
# Create HTTP2.0 parameter profile p1, and set the size of a frame in an HTTP2.0 packet to 1024.
[Sysname] parameter-profile p1 type http2
[Sysname-para-http2-p1] frame size 1024
frequency
Use frequency to set the probe interval for an LB probe template.
Use undo frequency to restore the default.
frequency interval
undo frequency
The probe interval is 300 seconds.
Load balancing probe template view
interval: Specifies the probe interval in the range of 5 to 604800 seconds.
Operating mechanism
This command specifies the interval for sending probe packets.
# Set the probe interval to 3600 seconds for ICMP probe template icmptplt.
[Sysname] loadbalance probe-template icmp icmptplt
[Sysname-lb-pt-icmp-icmptplt] frequency 3600
header (HTTP header sticky group view)
Use header to configure the HTTP header sticky method.
Use undo header to restore the default.
header { { { host | name header-name | url } [ offset offset ] [ start start-string ] [ end end-string | length length ] } | request-method | version }
undo header
No HTTP header sticky methods exist.
host: Specifies the HTTP host based sticky method.
name header-name: Specifies the HTTP header name based sticky method. The header-name argument is a case-insensitive string of 1 to 63 characters.
url: Specifies the HTTP URL based sticky method.
offset offset: Specifies the offset value of the HTTP header based on the start of the HTTP packet, in the range of 0 to 1000 bytes. The default is 0.
start start-string: Specifies the regular expression that marks the start of the HTTP header, a case-sensitive string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the HTTP header, a case-sensitive string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the HTTP header, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
request-method: Specifies the HTTP Request-Method based sticky method.
version: Specifies the HTTP version based sticky method.
Use this command to obtain the HTTP header information used to generate sticky entries based on the offset, start-string, end-string, and length values. The start-string and end-string values are not included in the sticky entry information.
# Configure the HTTP header sticky method for the HTTP header sticky group sg4: Specify the HTTP host based sticky method.
[Sysname] sticky-group sg4 type http-header
[Sysname-sticky-http-header-sg4] header host
header (HTTP passive sticky group view)
Use header to configure the HTTP header passive sticky method.
Use undo header to delete the HTTP header passive sticky method.
header { get id name header-name | match id { name header-name | url } } start start-string { end end-string | length length }
undo { get | match } id
No HTTP header passive sticky methods exist.
get: Obtains the specified string in the HTTP response header, which is used to generate an HTTP header passive sticky entry.
match: Obtains the specified string in the HTTP request header, which is used to match an HTTP header passive sticky entry.
id: Specifies the string ID in the range of 1 to 4.
start start-string: Specifies the regular expression that marks the start of the HTTP header or URL, a case-sensitive string of 1 to 127 characters. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the HTTP header or URL, a case-sensitive string of 1 to 127 characters. The string cannot contain question marks (?).
length length: Specifies the length of the HTTP header or URL, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
Both the header get and header match commands are required for an HTTP header passive sticky method.
The device obtains the header or URL information of an incoming HTTP request based on the header match command and obtains the header information of an incoming HTTP response based on the header get command. If the header or URL information of the HTTP request matches the header information of the HTTP response, the device generates a sticky entry based on the header information of the HTTP response. Subsequent HTTP requests that match the sticky entry are forwarded according to the sticky entry.
The following rules apply to use of the header match and header get commands:
·     You can execute a maximum of four header get commands and four header match commands for one HTTP passive sticky method.
·     A number of n strings that are obtained based on n header get commands generates 2n-1 strings in ascending order of string IDs. If the string obtained based on the header match command matches any one of these generated strings, the match is successful.
·     A number of n strings that are obtained based on n header match commands combine as one string in ascending order of string IDs.
For example, three header get commands are executed with string IDs 1, 2, and 3. The device obtains three strings a, b, and c in the HTTP response header, generates seven strings a, b, c, ab, ac, bc, and abc, and generates seven sticky entries. Then, three header match commands are executed with string IDs 2, 3, and 4. The device obtains three strings a, b, and c in the HTTP request header and generates one string abc. If the string matches one of the seven strings, the device generates a sticky entry based on the string abc. Subsequent HTTP requests that match the sticky entry are forwarded according to the sticky entry.
# Configure the HTTP passive sticky method for the HTTP passive sticky group sg4: Obtain the string between callid and & in the URL of the HTTP request. If the string matches the string between phone-number and & in HTTP response header x-forward-callid, the device generates a sticky entry based on the string between phone-number and &.
[Sysname] sticky-group sg4 type http-passive
[Sysname-sticky-http-passive-sg4] header get 1 name x-forward-callid start phone-number end &
[Sysname-sticky-http-passive-sg4] header match 1 url start callid end &
content (HTTP passive sticky group view)
header call-id
Use header call-id to configure the SIP call ID sticky method.
Use undo header call-id to restore the default.
header call-id
undo header call-id
No sticky methods exist.
SIP sticky group view
The SIP call ID sticky method allows the device to generate sticky entries based on the Call-ID header field in SIP messages. Packets with the same call ID are assigned to the same real server.
# Configure the SIP call ID sticky method for the SIP sticky group sg6.
[Sysname] sticky-group sg6 type sip
[Sysname-sticky-sip-sg6] header call-id
header delete
Use header delete to delete the HTTP header.
Use undo header delete to keep the HTTP header.
header delete { both | request | response } name header-name
undo header delete { both | request | response } name header-name
The HTTP header is kept.
HTTP LB action view
both: Specifies both the HTTP request and response packets.
request: Specifies the HTTP request packets.
response: Specifies the HTTP response packets.
name header-name: Specifies the name of the HTTP packet header, including standard and user-defined headers that must match the header in the packet. The header-name argument is a case-insensitive string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127. You can enter a question mark (?) to obtain a list of standard header names. For more information about the header names, see RFC 4229.
This command deletes the specified header from HTTP packets.
# Delete the header named host from HTTP request packets for the HTTP LB action lba2.
[Sysname] loadbalance action lba2 type http
[Sysname-lba-http-lba2] header delete request name host
header delete request accept-encoding
Use header delete request accept-encoding to delete the Accept-Encoding header from HTTP requests.
Use undo header delete request accept-encoding to keep the Accept-Encoding header in HTTP requests.
The LB device deletes the Accept-Encoding header from HTTP requests.
HTTP-compression parameter profile view
This command enables the LB device to delete the Accept-Encoding header from the HTTP request before sending it to the server. If the response packet sent by the server matches the specified match rule, the LB device compresses the packet before sending it to the requesting client. If the HTTP request sent by the client does not contain the Accept-Encoding header, the LB device does not compress the response packet regardless of whether this command is executed.
By default, the LB device does not modify request packets. If the response packet sent by the server is compressed, the LB device sends the packet to the requesting client without compressing it. If the response packet sent by the server is not compressed and matches the specified match rule, the LB device compresses the packet before sending it to the requesting client.
# Create the HTTP-compression parameter profile http1, and delete the Accept-Encoding header from HTTP requests.
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] header delete request accept-encoding
header exceed-length
Use header exceed-length to specify the action to take on the HTTP requests or responses when their packet headers exceed the maximum length.
Use undo header exceed-length to restore the default.
header exceed-length { continue | drop }
The system continues to perform load balancing for HTTP requests or responses when their packet headers exceed the maximum length.
continue: Continues to perform load balancing.
drop: Stops performing load balancing, discards the packet, and terminates the connection.
Operating mechanism
When the HTTP packet header length exceeds the processing capability of load balancing, the drop method applies.
This command is not supported by virtual servers of the fast HTTP type.
# For the HTTP parameter profile pp1, specify the drop action for the HTTP requests or responses with their packet headers exceeding the maximum length.
[Sysname] parameter-profile pp1 type http
[Sysname-para-http-pp1] header exceed-length drop
header insert
Use header insert to insert the HTTP header.
Use undo header insert to remove the configuration.
header insert { both | request | response } name header-name value value [ encode { base64 | url } ]
undo header insert { both | request | response } name header-name
The HTTP header is not inserted.
HTTP LB action view
name header-name: Specifies the name of the HTTP packet header, including standard and user-defined headers. The header-name argument is a case-sensitive string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127. You can enter a question mark (?) to obtain a list of standard header names. For more information about the header names, see RFC 4229.
value value: Specifies the header content to be inserted to the HTTP packet, a string of 1 to 255 characters. You can also specify the following replacement strings:
·     %is—Source IP address in HTTP requests.
·     %ps—Source port number in HTTP requests.
·     %id—Destination IP address in HTTP requests.
·     %pd—Destination port number in HTTP requests.
·     %sps—Source port number in HTTP responses.
·     %spd—Destination port number in HTTP responses.
·     %sis—Source IP address in HTTP responses.
·     %sid—Destination IP address in HTTP responses.
·     %{x509v}—Certificate version.
·     %{x509snum}—Certificate serial number.
·     %{x509sigalgo}—Certificate signature algorithm.
·     %{x509issuer}—Certificate issuer.
·     %{x509before}—Certificate effective time.
·     %{x509after}—Certificate expiration time.
·     %{x509sub}—Certificate subject.
·     %{x509spktype}—Public key type for the certificate subject.
·     %{x509spk}—Public key for the certificate subject.
·     %{x509spkRSA}—Length of the RSA public key for the certificate subject (this field is available only for an RSA public key).
·     %{x509hash}—MD5 hash value of the client certificate.
·     %{x509cipher}—Certificate cipher.
·     %{dncn}—Issuee.
·     %{dne}—Email.
·     %{dno}—Company/Organization.
·     %{dnou}—Department.
·     %{dnc}—Country.
·     %{dns}—State/Province.
·     %{dnl}—City.
encode { base64 | url }: Specifies an encoding method for replacement strings. If you do not specify an encoding method, replacement strings are not encoded.
Operating mechanism
This command inserts the specified header to HTTP packets.
URL encoding encodes only special characters in replacement strings, for example, colons in IPv6 addresses. Base64 encoding encodes entire replacement strings.
Execute this command to insert the client source IP address into the X-Forwarded-For field in the header of an HTTP request. Then, you do not need to execute the insert-xff enable command for the virtual server to enable the insertion of source IP address in X-Forwarded-For field. If you execute both the header insert and insert-xff enable commands, the insert-xff enable command takes precedence.
# Insert the header named source with source IP address and source port number as the content to HTTP request packets for the HTTP LB action lba2.
[Sysname-lba-http-lba2] header insert request name source value %is:%ps
insert-xff enable
header insert response vary
Use header insert response vary to insert the Vary header into HTTP responses.
Use undo header insert response vary to remove the configuration.
The Vary header is inserted into HTTP responses.
This command inserts the Vary header to HTTP responses and sets the header content to Accept-Encoding before sending them to the client. The command takes effect regardless of whether the response packets contain the Vary header or whether the packets are compressed.
# Create the HTTP-compression parameter profile http1, and insert the Vary header into HTTP responses.
[Sysname-para-http-compression-http1] header insert response vary
header maxparse-length
Use header maxparse-length to set the maximum length of HTTP headers that can be parsed.
Use undo header maxparse-length to restore the default.
header maxparse-length length
The maximum length of HTTP headers that can be parsed is 4096.
length: Specifies the maximum length of HTTP headers that can be parsed, in the range of 1 to 65535 bytes.
This command is not supported by the virtual servers of the fast HTTP type.
# Set the maximum length of HTTP headers that can be parsed to 8192 for the HTTP parameter profile pp1.
[Sysname-para-http-pp1] header maxparse-length 8192
header modify per-request
Use header modify per-request to perform the insert, delete, or modify operation for the header of each HTTP request or response packet.
Use undo header modify per-request to restore the default.
The insert, delete, or modify operation is performed for the header of the first HTTP request or response  packet of a connection.
# For the HTTP parameter profile pp1, perform the insert, delete, or modify operation for the header of each HTTP request or response packet.
[Sysname-para-http-pp1] header modify per-request
header rewrite
Use header rewrite to rewrite the HTTP header.
Use undo header rewrite to remove the configuration.
header rewrite { both | request | response } name header-name value value replace replace [ encode { base64 | url } ]
undo header rewrite { both | request | response } name header-name
The HTTP header is not rewritten.
HTTP LB action view
value value: Specifies the HTTP packet header content to be rewritten, a case-sensitive string of 1 to 127 characters. The string cannot contain question marks (?).
replace replace: Specifies the content after rewrite, a case-sensitive string of 1 to 127 characters. You can also specify the following replacement strings:
·     %{dncn}—Issuee.
·     %{dne}—Email.
·     %{dnc}—Country.
·     %{dnl}—City.
This command rewrites the value setting of the specified header in HTTP packets to the replace setting.
# For the HTTP LB action lba2, rewrite the content www.hello.example.com of the header named host in HTTP request packets to www.he.example.com.cn.
[Sysname-lba-http-lba2] header rewrite request name host value www\.(he)(llo)\.example.com replace www.%1.example.com.cn encode url
header rewrite request url
Use header rewrite request url to rewrite the URL in HTTP requests.
Use undo header rewrite request url to restore the default.
header rewrite request url value value replace replace [ encode { base64 | url } ]
The URL in HTTP requests is not rewritten.
HTTP LB action view
value value: Specifies the URL to be rewritten, a case-sensitive string of 1 to 127 characters. The string cannot contain question marks (?).
replace replace: Specifies the URL after rewrite, a case-sensitive string of 1 to 127 characters. You can also specify the following replacement strings:
·     %{dncn}—Issuee.
·     %{dne}—Email.
·     %{dnc}—Country.
·     %{dnl}—City.
This command rewrites the value setting in the HTTP request URL to the replace setting.
# For the HTTP LB action lba2, rewrite the URL www.hello.example.com in HTTP requests to www.he.example.com.cn.
[Sysname-lba-http-lba2] header rewrite request url value www\.(he)(llo)\.example.com replace www.%1.example.com.cn encode url
header-table size
Use header-table size to configure the maximum number of HTTP2.0 packet header entries supported by the device.
Use undo header-table size to restore the default.
header-table size size
The maximum number of HTTP2.0 packet header entries supported by the device is 4096.
size: Specifies the maximum number of HTTP2.0 packet header entries supported by the device, in the range of 0 to 65536.
Application scenarios
HTTP2.0 maintains a header table for strings and fields that appear repeatedly in the packet headers. The header table uses small-length index numbers to represent the repeated strings and compresses header data through Huffman encoding, implementing header compression for a large number of concurrent requests and responses.
As the number of HTTP2.0 packets that barely have repeated headers sent over a TCP connection increases, the number of header table entries increases on both the client and server. These entries will consume a lot of memory and reduce the concurrent processing capability of the device or server.
Operating mechanism
To resolve this issue, you can configure the maximum number of HTTP2.0 packet header entries supported by the device. When the number of header entries reaches the limit, the device will terminate the TCP connection to release memory and ensure device or server performance. You can also execute the concurrent-streams-per-connection command to configure the maximum number of concurrent requests supported by a TCP connection to resolve this issue.
# Create HTTP2.0 parameter profile p1, and set the maximum number of HTTP2.0 packet header entries supported by the device to 1024.
[Sysname-para-http2-p1] header-table size 1024
host ip address
Use host { ip | ipv6 } address to configure the Host-IP-Address AVP to be sent in Diameter messages.
Use undo host { ip | ipv6 } address to restore the default.
host { ip | ipv6 } address ip-address
The Host-IP-Address AVP to be sent in Diameter messages is not configured.
Diameter session parameter profile view
ip-address: Specifies an IPv4 or IPv6 address. The IP address cannot be a loopback, IPv6 multicast, link-local, or unspecified address.
The IP address specified by this command must be an address configured for an available interface on the device. During Diameter capability exchange with the peer, the device sends the specified Host-IP-Address AVP as its own IP address to the peer.
# Specify the Host-IP-Address AVP as 22.2.2.6 for Diameter session parameter profile dia.
[Sysname] parameter-profile dia type diameter-session
[Sysname-para-diameter-session-dia] host ip address 22.2.2.6
parameter-profile
idle-time
Use idle-time to set the idle timeout time for TCP connections between the LB device and servers.
Use undo idle-time to restore the default.
idle-time idle-time
undo idle-time
The idle timeout time for TCP connections between the LB device and servers is 86400 seconds.
OneConnect parameter profile view
MySQL parameter profile view
idle-time: Specifies the idle timeout time in the range of 1 to 4294967295 seconds.
The idle timeout time is the amount of time that a TCP connection can stay idle before it is disconnected. After the TCP connection is disconnected, new connection requests trigger establishment of a new TCP connection.
# In OneConnect parameter profile ocp, set the idle timeout time to 10000 seconds for TCP connections between the LB device and servers.
[Sysname] parameter-profile ocp type oneconnect
[Sysname-para-oneconnect-ocp] idle-time 10000
insert-header-field
Use insert-header-field to insert header fields into HTTP2.0 requests.
Use undo insert-header-field to restore the default.
insert-header-field field-name
No header fields are inserted into HTTP2.0 requests.
field-name: Specifies a header field by its name, a case-insensitive string of 1 to 63 characters.
You can insert header fields into HTTP2.0 requests to help a real server identify HTTP2.0 requests.
# Create HTTP2.0 parameter profile p1, and configure the device to insert header field aaa into HTTP2.0 requests.
[Sysname-para-http2-p1] insert-header-field aaa
insert-xff enable
Use insert-xff enable to enable the device to insert client source IP address into the X-Forwarded-For field.
Use undo insert-xff enable to disable the device from inserting client source IP address into the X-Forwarded-For field.
insert-xff enable
The device does not insert client source IP address into the X-Forwarded-For field.
After you execute this command, when the device receives a request packet from a client, it will insert the client source IP address into the X-Forwarded-For field in the HTTP packet extended header.
# Enable the device to insert client source IP address into the X-Forwarded-For field for HTTP virtual server vs3.
[Sysname] virtual-server vs3 type http
[Sysname-vs-http-vs3] insert-xff enable
ip
Use ip to configure the IPv4 sticky method.
Use undo ip to restore the default.
ip [ port ] { both | destination | source } [ mask mask-length ]
undo ip
No IPv4 sticky method is configured.
Sticky group view
port: Specifies the sticky method as IPv4 address + port number. If you do not specify this keyword, the sticky method is IPv4 address.
both: Specifies the sticky method as source IPv4 address + destination IPv4 address (if you do not specify the port keyword), or source IPv4 address + source port number + destination IPv4 address + destination port number (if you specify the port keyword).
destination: Specifies the sticky method as destination IPv4 address if you do not specify the port keyword, or destination IPv4 address + destination port number if you specify the port keyword.
source: Specifies the sticky method as source IPv4 address if you do not specify the port keyword, or source IPv4 address + source port number if you specify the port keyword.
mask mask-length: Specifies the mask length for the sticky method.
# Configure the sticky method for the address and port-based sticky group sg1 as source IPv4 address.
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1] ip source
# Configure the sticky method for the address and port-based sticky group sg1 as source IPv4 address + source port number.
[Sysname-sticky-address-port-sg1] ip port source
sticky-group
ip address
Use ip address to configure an IPv4 address for a real server.
Use undo ip address to restore the default.
ip address ipv4-address
undo ip address
No IPv4 address is configured for a real server.
Real server view
ipv4-address: Specifies an IPv4 address, which cannot be a loopback address, multicast address, broadcast address, or an address in the format of 0.X.X.X.
# Configure the IPv4 address for the real server rs as 1.1.1.1.
[Sysname-rserver-rs] ip address 1.1.1.1
ip range
Use ip range to add an IPv4 address range to a SNAT address pool.
Use undo ip range to remove an IPv4 address range from a SNAT address pool.
ip range start start-ipv4-address end end-ipv4-address
undo ip range start start-ipv4-address end end-ipv4-address
An SNAT address pool does not contain IPv4 address ranges.
SNAT address pool view
start start-ipv4-address: Specifies the start IPv4 address.
end end-ipv4-address: Specifies the end IPv4 address, which must be greater than or equal to the start IPv4 address.
Operating mechanism
You can execute this command multiple times to add multiple IPv4 address ranges to a SNAT address pool. Each address range can have a maximum of 256 IPv4 addresses.
No overlapping IPv4 addresses are allowed in the same SNAT address pool or different SNAT address pools.
If the addresses in an SNAT address pool are in the same network segment as the IP address of the interface connect the device to the server, you must specify an interface for sending gratuitous ARP or ND packets.
# Add IPv4 address range 1.1.1.1 to 1.1.1.100 to the SNAT address pool lbsp.
[Sysname] loadbalance snat-pool lbsp
[Sysname-lbsnat-pool-lbsp] ip range start 1.1.1.1 end 1.1.1.100
arp-nd interface (SNAT address pool view)
ip source mask
Use ip source mask to specify the IPv4 mask for connection reuse.
Use undo ip source mask to restore the default.
ip source mask { mask-length | mask }
undo ip source mask
The IPv4 mask for connection reuse is the natural mask.
mask-length: Specifies the mask length in the range of 0 to 32. A value of 0 indicates the natural mask.
mask: Specifies the subnet mask in dotted decimal notation.
This command limits the network segment of clients that can reuse connections between the LB device and servers. If the client that initiates a connection request is in the same network segment as the idle TCP connection, the idle TCP connection is reused. If the client does not match this requirement, a new TCP connection is established.
# In OneConnect parameter profile ocp, set the mask length for connection reuse to 24.
[Sysname-para-oneconnect-ocp] ip source mask 24
ipv6
Use ipv6 to configure the IPv6 sticky method.
Use undo ipv6 to restore the default.
ipv6 [ port ] { both | destination | source } [ prefix prefix-length ]
undo ipv6
No IPv6 sticky method is configured.
Sticky group view
port: Specifies the sticky method as IPv6 address + port number. If you do not specify this keyword, the sticky method is IPv6 address.
both: Specifies the sticky method as source IPv6 address + destination IPv6 address if you do not specify the port keyword, or source IPv6 address + source port number + destination IPv6 address + destination port number if you specify the port keyword.
destination: Specifies the sticky method as destination IPv6 address if you do not specify the port keyword, or destination IPv6 address + destination port number if you specify the port keyword.
source: Specifies the sticky method as source IPv6 address if you do not specify the port keyword, or source IPv6 address + source port number if you specify the port keyword.
prefix prefix-length: Specifies the prefix length for the sticky method.
# Configure the sticky method for the address- and port-based sticky group sg1 as source IPv6 address.
[Sysname-sticky-address-port-sg1] ipv6 source
# Configure the sticky method for the address- and port-based sticky group sg1 as source IPv6 address + source port number.
[Sysname-sticky-address-port-sg1] ipv6 port source
sticky-group
ipv6 address
Use ipv6 address to configure an IPv6 address for a real server.
Use undo ipv6 address to restore the default.
ipv6 address ipv6-address
undo ipv6 address
No IPv6 address is configured for a real server.
Real server view
ipv6-address: Specifies an IPv6 address, which cannot be a loopback address, IPv6 multicast address, link-local address, or all-zero address.
# Configure the IPv6 address for the real server rs as 1001::1.
[Sysname-rserver-rs] ipv6 address 1001::1
ipv6 range
Use ipv6 range to add an IPv6 address range to a SNAT address pool.
Use undo ipv6 range to remove an IPv6 address range from a SNAT address pool.
An SNAT address pool does not contain IPv6 address ranges.
start start-ipv6-address: Specifies the start IPv6 address.
end end-ipv6-address: Specifies the end IPv6 address, which must be greater than or equal to the start IPv6 address.
Operating mechanism
You can execute this command multiple times to add multiple IPv6 address ranges to a SNAT address pool. Each address range can have a maximum of 10000 IPv6 addresses.
No overlapping IPv6 addresses are allowed in the same SNAT address pool or different SNAT address pools.
# Add IPv6 address range 1001::1 to 1001::100 to the SNAT address pool lbsp.
[Sysname-lbsnat-pool-lbsp] ipv6 range start 1001::1 end 1001::100
ipv6 source prefix
Use ipv6 source prefix to specify the IPv6 prefix length for connection reuse.
Use undo ipv6 source prefix to restore the default.
ipv6 source prefix prefix-length
Client IPv6 addresses with a prefix length of 0 can reuse connections.
prefix-length: Specifies the prefix length in the range of 0 to 128.
# In OneConnect parameter profile ocp, set the prefix length for connection reuse to 24.
[Sysname-para-oneconnect-ocp] ipv6 source prefix 24
keepalive idle-timeout
Use keepalive idle-timeout to set the idle timeout time for sending keepalive packets.
Use undo keepalive idle-timeout to restore the default.
keepalive idle-timeout timeout-value
The idle timeout time for sending keepalive packets is 1800 seconds.
timeout-value: Specifies the idle timeout time for sending keepalive packets, in the range of 1 to 65535 seconds.
# Set the timeout time for sending keepalive packets to 5 seconds in the TCP parameter profile profile.
[Sysname-para-tcp-profile] keepalive idle-timeout 5
keepalive retransmission interval
Use keepalive retransmission interval to set the retransmission interval and retransmission times for keepalive packets.
Use undo keepalive retransmission interval to restore the default.
keepalive retransmission interval interval count count
The retransmission interval is 10 seconds, and the retransmission times is 3.
interval: Specifies the retransmission interval for keepalive packets, in the range of 1 to 65535 seconds.
count: Specifies the retransmission times for keepalive packets, in the range of 1 to 65535.
# Set the retransmission interval and retransmission times for keepalive packets to 5 seconds and 10, respectively, in the TCP parameter profile profile.
[Sysname-para-tcp-profile] keepalive retransmission interval 5 count 10
lb-limit-policy
Use lb-limit-policy to apply an LB connection limit policy to a virtual server.
Use undo lb-limit-policy to restore the default.
lb-limit-policy policy-name
No LB connection limit policies are applied to a virtual server.
Virtual server view
policy-name: Specifies an LB connection limit policy by its name, a case-insensitive string of 1 to 255 characters.
Use this command to implement rate limit for user traffic.
This command takes effect only on new sessions and does not take effect on existing sessions.
# Apply the LB connection limit policy llp to the HTTP-type virtual server vs.
[Sysname-vs-http-vs]lb-limit-policy llp
loadbalance limit-policy
lb-policy
Use lb-policy to specify an LB policy to be referenced by the specified virtual server.
Use undo lb-policy to restore the default.
lb-policy policy-name
undo lb-policy
No LB policy is referenced by a virtual server.
Virtual server view
policy-name: Specifies an LB policy by its name, a case-insensitive string of 1 to 255 characters.
Operating mechanism
By referencing an LB policy, the virtual server implements load balancing for matching packets based on the packet contents.
A virtual server can reference the policy template of the specified type. For example, a virtual server of the fast HTTP or HTTP type can reference a policy template of the generic type or HTTP type. A virtual server of the IP, SIP, TCP, or UDP type can reference a policy template of the generic type only.
# Specify the LB policy lbp1 to be referenced by the IP-type virtual server vs3.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] lb-policy lbp1
limit
Use limit to configure an LB connection limit rule.
Use undo limit to delete an LB connection limit rule.
limit limit-id acl [ ipv6 ] { acl-number | name acl-name } [ per-destination | per-service | per-source ] * amount max-amount min-amount
undo limit limit-id
No rules are configured for an LB connection limit policy.
LB connection limit policy view
limit-id: Specifies an LB connection limit rule ID. The value range for this argument is 1 to 65535.
acl: Specifies an ACL to limit user connections of a specified user range.
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, the command uses an IPv4 ACL.
acl-number: Specifies the ACL number in the range of 2000 to 3999.
name acl-name: Specifies an ACL by its name.
per-destination: Limits user connections by destination IP address.
per-service: Limits user connections by service. Services are classified by transport layer protocol and service port number.
per-source: Limits user connections by source IP address.
max-amount: Specifies the upper limit of connections, in the range of 1 to 4294967295. When the number of connections in a specified range or for a certain type reaches the upper limit, the device does not accept new connection requests.
min-amount: Specifies the lower limit of connections, in the range of 1 to 4294967295. The min-amount must be equal to or smaller than the max-amount. The device accepts new connection requests only when the number of connections drops below the lower limit.
Operating mechanism
An LB connection limit policy can have multiple rules. You can specify an ACL, a type, and the upper and lower limits for each rule. You can specify one or more of the per-destination, per-service, and per-source keywords for the command. For example, you can specify both the per-destination and per-source keywords to limit user connections by destination address and source address of packets.
If the per-destination, per-service, and per-source keywords are not specified, the command limits all user connections matching the specified ACL.
The rules in an LB connection limit policy are matched in ascending order of the rule IDs until a match is found.
When the specified ACL changes, the device uses a new LB connection limit policy to process existing connections again.
You must specify a different ACL for each rule in an LB connection limit policy.
# Configure rule 1 for the LB connection limit policy 1. Use ACL 3000 to permit user connections sourced from the network 192.168.0.0/24, and set the upper and lower limits to 2000 and 1800 for the user connections by source and destination addresses.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit ip source 192.168.0.0 0.0.0.255
[Sysname] loadbalance limit-policy 1
[Sysname-lb-limit-policy-1] limit 1 acl 3000 per-destination per-source amount 2000 1800
loadbalance action
Use loadbalance action to create an LB action and enter its view, or enter the view of an existing LB action.
Use undo loadbalance action to delete the specified LB action.
loadbalance action action-name [ type { diameter | dns | generic | http | link-generic | radius } ]
undo loadbalance action action-name
No LB actions exist.
action-name: Specifies the LB action name, a case-insensitive string of 1 to 255 characters.
type { diameter | dns | generic | http | link-generic | radius }: Specifies an LB action type.
·     diameter: Diameter load balancing action.
·     dns: DNS load balancing action.
·     generic: Generic server load balancing action.
·     http: HTTP load balancing action.
·     link-generic: Link load balancing action.
·     radius: RADIUS load balancing action.
When you create an LB action, you must specify the LB action type. You can enter an existing LB action view without entering the type of the LB action.
# Create the LB action lba1 with the generic type, and enter LB action view.
loadbalance alg
Use loadbalance alg to enable ALG for the specified protocols.
Use undo loadbalance alg to disable ALG for the specified protocols.
loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
ALG is enabled for the DNS, FTP, PPTP, and RTSP protocols and ICMP error packets.
dns: Specifies the DNS protocol.
ftp: Specifies the FTP protocol.
h323: Specifies the H.323 protocol.
icmp-error: Specifies the ICMP error packets.
ils: Specifies the Internet Locator Service (ILS) protocol.
mgcp: Specifies the Media Gateway Control Protocol (MGCP).
nbt: Specifies the NetBIOS over TCP/IP (NBT) protocol.
pptp: Specifies the Point-to-Point Tunneling Protocol (PPTP).
rsh: Specifies the Remote Shell (RSH) protocol.
rtsp: Specifies the Real Time Streaming Protocol (RTSP).
sccp: Specifies the Skinny Client Control Protocol (SCCP).
sip: Specifies the Session Initiation Protocol (SIP).
sqlnet: Specifies the SQLNET protocol.
tftp: Specifies the TFTP protocol.
xdmcp: Specifies the X Display Manager Control Protocol (XDMCP).
Operating mechanism
The ALG feature distributes parent and child sessions to the same link.
SIP fragmented packets do not support the ALG feature.
# Enable ALG for TFTP.
[Sysname] loadbalance alg tftp
loadbalance alg all-enable
Use loadbalance alg all-enable to enable ALG for all protocols.
Use loadbalance alg all-disable to disable ALG for all protocols.
# Enable ALG for all protocols.
[Sysname] loadbalance alg all-enable
loadbalance class
Use loadbalance class to create an LB class and enter its view, or enter the view of an existing LB class.
Use undo loadbalance class to delete the specified LB class.
loadbalance class class-name [ type { diameter | dns | generic | http | link-generic | mysql | radius } [ match-all | match-any ] ]
undo loadbalance class class-name
No LB classes exist.
class-name: Specifies the LB class name, a case-insensitive string of 1 to 255 characters.
type { diameter | dns | generic | http | link-generic | mysql | radius }: Specifies an LB class type.
·     diameter: Diameter load balancing class.
·     dns: DNS load balancing class.
·     generic: Generic server load balancing class.
·     http: HTTP load balancing class.
·     link-generic: Link load balancing class.
·     mysql: MySQL load balancing class.
·     radius: RADIUS load balancing class.
[ match-all | match-any ]: Requires matching all rules or any rule of the LB class. match-all is the default match mode.
When you create an LB class, you must specify an LB class type. You can enter an existing LB class view without entering the type of the LB class.
# Create the LB class lbc1 with the generic type, and enter LB class view.
[Sysname] loadbalance class lbc1 type generic
[Sysname-lbc-generic-lbc1]
Use loadbalance limit-policy to create an LB connection limit policy and enter its view, or enter the view of an existing LB connection limit policy.
Use undo loadbalance limit-policy to delete an LB connection limit policy.
loadbalance limit-policy policy-name
undo loadbalance limit-policy policy-name
No LB connection limit policies exist.
policy-name: Specifies the LB connection limit policy name, a case-insensitive string of 1 to 255 characters.
Operating mechanism
Using an LB connection limit policy can limit the number of connections on the device. It helps prevent a large number of connections from consuming too many device system resources and server resources. In this way, internal network resources (hosts or servers) are protected, and device system resources can be used more appropriately.
# Create the LB connection limit policy llp, and enter LB connection limit policy view.
[Sysname] loadbalance limit-policy llp
[Sysname-lb-limit-policy-llp]
loadbalance log enable base
Use loadbalance log enable base to enable load balancing basic logging.
Use undo loadbalance log enable base to disable load balancing basic logging.
Load balancing basic logging is enabled.
Load balancing basic logging generates logs for the following events:
·     The state of a real server, real server group, link, or link group changes.
·     The health monitoring result of a real server or link changes.
·     The number of connections on a real server, virtual server, or link reaches or drops below the upper limit.
·     The connection establishment rate on a real server, virtual server, or link reaches or drops below the upper limit.
·     A primary/backup server farm switchover occurs between server farms specified for a virtual server.
·     A primary/backup link group switchover occurs between link groups specified for a virtual server.
·     A primary/backup server farm switchover occurs between server farms specified for an LB action.
·     A primary/backup link group switchover occurs between link groups specified for an LB action.
If the actual bandwidth of a link, real server, or virtual server exceeds the maximum bandwidth specified by using the rate-limit bandwidth command, the device does not generates LB basic logs.
# Enable load balancing basic logging.
[Sysname] loadbalance log enable base
rate-limit bandwidth (link view)
rate-limit bandwidth (real server view)
rate-limit bandwidth (virtual server view)
loadbalance log enable nat
Use loadbalance log enable nat to enable load balancing NAT logging.
Use undo loadbalance log enable nat to disable load balancing NAT logging.
Load balancing NAT logging is disabled.
Operating mechanism
Load balancing NAT logging records NAT session information, including IP address and port translation information and access information.
Load balancing NAT logs are exported as flow logs. To export load balancing NAT logs, you must also configure flow log settings. For more information about flow logs, see Network Management and Monitoring Configuration Guide.
# Enable load balancing NAT logging.
[Sysname] loadbalance log enable nat
loadbalance policy
Use loadbalance policy to create an LB policy and enter its view, or enter the view of an existing LB policy.
Use undo loadbalance policy to delete the specified LB policy.
loadbalance policy policy-name [ diameter | type { dns | generic | http | link-generic | mysql | radius } ]
undo loadbalance policy policy-name
No LB policies exist.
policy-name: Specifies the LB policy name, a case-insensitive string of 1 to 255 characters.
type { diameter | dns | generic | http | link-generic | mysql | radius }: Specifies an LB policy type.
·     diameter: Diameter load balancing policy.
·     dns: DNS load balancing policy.
·     generic: Generic server load balancing policy.
·     http: HTTP load balancing policy.
·     link-generic: Link load balancing policy.
·     mysql: MySQL load balancing policy.
·     radius: RADIUS load balancing policy.
When you create an LB policy, you must specify the LB policy type. You can enter existing LB policy view without entering the type of the LB policy.
# Create the LB policy lbp1 with the generic type, and enter LB policy view.
[Sysname] loadbalance policy lbp1 type generic
[Sysname-lbp-generic-lbp1]
loadbalance probe failed-record enable
Use loadbalance probe failed-record enable to enable recording health monitoring failures.
Use undo loadbalance probe failed-record enable to restore the default.
Recording of health monitoring failures is disabled.
After you execute this command, the device starts recording health monitoring failures of real servers and links. To display the records of health monitoring failures, execute the display loadbalance probe failed-record command.
# Enable recording of health monitoring failures.
[Sysname] loadbalance probe failed-record enable
loadbalance probe failed-record max-number
Use loadbalance probe failed-record max-number to set the maximum number of health monitoring failures that can be recorded.
Use undo loadbalance probe failed-record max-number to restore the default.
loadbalance probe failed-record max-number max-number
The maximum number of health monitoring failures that can be recorded is 50000.
max-number: Specifies the maximum number of health monitoring failures that can be recorded in the range of 100 to 50000.
# Set the maximum number of health monitoring failures that can be recorded to 10000.
[Sysname] loadbalance probe failed-record max-number 10000
Use loadbalance probe-template to create an LB probe template and enter its view, or enter the view of an existing LB probe template.
Use undo loadbalance probe-template to delete an LB probe template.
loadbalance probe-template { external-monitor | http-passive | icmp | tcp-rst | tcp-zero-window } template-name
undo loadbalance probe-template { external-monitor | http-passive | icmp | tcp-rst | tcp-zero-window } template-name
No LB probe templates exist.
external-monitor: Specifies the custom-monitoring-type template.
http-passive: Specifies the HTTP-passive-type template.
icmp: Specifies the ICMP-type template.
tcp-rst: Specifies the TCP-RST template.
tcp-zero-window: Specifies the TCP zero-window template.
template-name: Specifies a template name, a case-insensitive string of 1 to 255 characters.
A server farm, a server farm member, or a real server can use a custom-monitoring LB probe template to detect the health state of each real server.
A server farm can use an HTTP passive LB probe template to count the number of URL error times by monitoring the responses of HTTP requests to each real server.
The proximity feature can use an ICMP LB probe template to start ICMP tests and identify the reachability of hosts according to received ICMP responses.
A server farm can use a TCP-RST or TCP zero-window LB probe template to count the number of RST packets or zero-window packets sent by each server farm member.
For a back-end server acting as a database, the server farm, server farm member, or real server can use a database LB probe template to detect the availability of the database. Within the monitoring period of the LB probe template, the device can use the various probe methods to progressively obtain the health state of target database from different aspects.
# Create an LB probe template named icmptplt, and enter LB probe template view.
[Sysname-lbpt-icmp-icmptplt]
loadbalance process-limit
Use loadbalance process-limit to set the maximum number of processes allowed to be started for custom monitoring.
Use undo loadbalance process-limit to restore the default.
loadbalance process-limit number
A maximum of eight processes can be started for custom monitoring.
number: Specifies the maximum number of processes, in the range of 1 to 16.
# Set the maximum number of processes allowed to be started for custom monitoring to 2.
[Sysname] loadbalance process-limit 2
display loadbalance process-limit
loadbalance protection-policy
Use loadbalance protection-policy to create a protection policy and enter its view, or enter the view of an existing protection policy.
Use undo loadbalance protection-policy to delete a protection policy.
loadbalance protection-policy policy-name [ type http ]
undo loadbalance protection-policy policy-name
No protection policies exist.
policy-name: Specifies a protection policy name, a case-insensitive string of 1 to 255 characters.
type http: Specifies the HTTP-type protection policy. When you create a protection policy, you must specify the policy type. You can enter the view of an existing protection policy without specifying the policy type.
# Create an HTTP protection policy named p1 and enter its view.
[Sysname] loadbalance protection-policy p1 type http
[Sysname-lbpp-http-p1]
loadbalance reload external-link file
Use loadbalance reload external-link file to load an external link rewrite file.
Use undo loadbalance reload external-link file to remove the configuration.
loadbalance reload external-link file filename
No external link rewrite file is used.
filename: Specifies a file by its complete name, a case-insensitive string of 1 to 256 characters.
Operating mechanism
If the file content has changed, you must reload the external link rewrite file to ensure it is effective.
Recommended configuration
Make sure the file format is supported by the client browser. As a best practice, use the JS script file.
Make sure the name of the external link rewrite file is different from the response file for HTTP requests.
# Load external link rewrite file /sub_lb_sw.js.
[Sysname] loadbalance reload external-link file /sub_lb_sw.js
external-link inject-domain-suffix
external-link inject-uri
external-link proxy enable
external-link whitelist domain
loadbalance schedule-test ip
Use loadbalance schedule-test ip to perform an IPv4 load balancing test.
loadbalance schedule-test ip { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmp | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port
application: Specifies an application to be tested.
http: Specifies the HTTP application.
message-file file-name: Specifies the file that contains HTTP packet contents. The file name is a case-insensitive string of 1 to 255 characters. The file size cannot exceed 5000 bytes.
method: Specifies an HTTP request method.
get: Specifies the GET method.
post: Specifies the POST method.
url url: Specifies a URL for the HTTP packet, a case-insensitive string of 1 to 255 characters. A URL can contain letters, digits, hyphens (-), underscores (_), and periods (.). The URL cannot contain consecutive periods.
[ header header ]&<1-10>: Specifies a space-separated list of up to 10 HTTP packet headers. A header is a case-sensitive string of 1 to 127 characters excluding question marks (?).
content content-value: Specifies the content of the HTTP packet body, a case-sensitive string of 1 to 255 characters excluding question marks (?).
protocol { protocol-number | icmp | tcp | udp }: Specifies a protocol by its number in the range of 0 to 255 or by its name. For ICMP (1), TCP (6), and UDP (17), you can enter the protocol number or protocol name.
destination destination-address: Specifies the destination IPv4 address.
destination-port destination-port: Specifies the destination port number in the range of 0 to 65535. This option is not supported by some protocols.
source source-address: Specifies the source IPv4 address.
source-port source-port: Specifies the source port number in the range of 0 to 65535. This option is not supported by some protocols.
# Perform an IPv4 load balancing test for the TCP protocol.
<Sysname> loadbalance schedule-test ip protocol tcp destination 7.7.7.7 destination-port 4 source 2.2.2.2 source-port 5
    Matched virtual server: vs2
    Matched default server farm: sf
    Forward type: Forwarding to real server
    Selected real server: rs2
        Scheduling algorithm: Predictor
    Matched default link group: lg
    Forward type: Forwarding to link
    Selected link: link2
Table 29 Command output
Forward type
Forwarding mode:
·     The destination address is not supported. Load balancing is not performed.
·     Matching HTTP virtual server is not supported—An HTTP virtual server is matched. Load balancing is not supported.
·     Forward all—Forwards packets.
·     Forwarding to real server—Forwards packets to the real server.
·     Forwarding to link—Forwards packets to the link.
·     Drop—Drops packets.
·     Redirect—Redirects packets.
·     Waiting—Enqueues packets.
Drop reason
Packet drop reason:
·     Number of connections or bandwidth for the virtual server exceeded the limit.
·     No class matched and no valid default server farm/link group configured.
·     No valid real server/link in the server farm/link group.
·     Action is drop.
·     A sticky entry was matched but the number of connections or bandwidth for the real server/link exceeded the limit.
·     A class was matched but no valid server farm/link group exists in the action of the class.
·     The HTTP message is not valid.
·     The HTTP request line is not valid.
·     The HTTP header is not valid.
·     The chunk HTTP content is not valid.
·     The server farm is busy.
·     Queue overflow (which means the wait queue is full).
Scheduling algorithm used to select the real server or link:
·     Predictor—The real server or link is selected by using the scheduling algorithm.
·     Sticky method—The real server or link is selected by using the sticky method.
·     Proximity—The link is selected by using the proximity feature.
loadbalance schedule-test ipv6
Use loadbalance schedule-test ipv6 to perform an IPv6 load balancing test.
loadbalance schedule-test ipv6 { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmpv6 | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port
protocol { protocol-number | icmpv6 | tcp | udp }: Specifies a protocol by its number in the range of 0 to 255 or by its name. For ICMPv6 (58), TCP (6), and UDP (17), you can enter the protocol number or protocol name.
destination destination-address: Specifies the destination IPv6 address.
source source-address: Specifies the source IPv6 address.
# Schedule an IPv6 load balancing test for the ICMPv6 protocol.
<Sysname> loadbalance schedule-test ipv6 protocol icmpv6 destination 10::1 source 12::2
Table 30 Command output
Forward type
Forwarding mode:
·     Forwarding to real server/link—Forwards packets to the real server or link.
Drop reason
Packet drop reason:
·     Action is drop.
loadbalance snat-global-policy
Use loadbalance snat-global-policy to create a SNAT global policy and enter its view, or enter the view of an existing SNAT global policy.
Use undo loadbalance snat-global-policy to delete the specified SNAT global policy.
loadbalance snat-global-policy policy-name
undo loadbalance snat-global-policy policy-name
No SNAT global policies exist.
policy-name: Specifies the SNAT global policy name, a case-insensitive string of 1 to 255 characters.
# Create the SNAT global policy sn1, and enter SNAT global policy view.
[Sysname] loadbalance snat-global-policy sn1
[Sysname-lb-snat-gp-sn1]
snat-mode
snat-pool (server farm view)
Use loadbalance snat-pool to create a SNAT address pool and enter its view, or enter the view of an existing SNAT address pool.
Use undo loadbalance snat-pool to delete the specified SNAT address pool.
loadbalance snat-pool pool-name
undo loadbalance snat-pool pool-name
No SNAT address pools exist.
pool-name: Specifies the SNAT address pool name, a case-insensitive string of 1 to 255 characters.
# Create the SNAT address pool lbsp, and enter SNAT address pool view.
loadbalance ssl performance-optimize cache-value
Use loadbalance ssl performance-optimize cache-value to configure the cache limit for SSL performance optimization.
Use undo loadbalance ssl performance-optimize cache-value to restore the default.
loadbalance ssl performance-optimize cache-value cache-value
The cache limit for SSL performance optimization is 0 KB, indicating that the cache size is not limited.
cache-value: Specifies the cache limit for SSL performance optimization, in the range of 0 to 15 KB.
When the SSL caches reach the specified limit, the caches will be sent to the server.
# Set the cache limit for SSL performance optimization to 12KB.
[Sysname] loadbalance ssl performance-optimize cache-value 12
loadbalance tcp-timestamp-mode
Use loadbalance tcp-timestamp-mode to globally specify an action to take on the Timestamps option in TCP packet headers.
Use undo loadbalance tcp-timestamp-mode to restore the default.
loadbalance tcp-timestamp-mode { preserve | rewrite | remove }
The Timestamps option is preserved in TCP packet headers.
preserve: Preserves the Timestamps option in TCP packet headers.
rewrite: Rewrites the Timestamps option in TCP packet headers.
remove: Removes the Timestamps option from TCP packet headers.
Operating mechanism
This command enables the LB device to preserve, rewrite, or remove the Timestamps option in the headers of TCP packets sent to the server.
·     Preserve—Preserves the Timestamps option value in TCP packet headers.
·     Rewrite—Rewrites the Timestamps option value in TCP packet headers with the current timestamp value of the device.
·     Remove—Removes the Timestamps option field from TCP packet headers. On some networks where timestamps are unnecessary, you can remove them to reduce the packet size and enhance transmission performance. When the back-end servers do not support the timestamp mechanism, you can also remove the Timestamps option from TCP packet headers.
This command takes effect for virtual servers of the TCP, HTTP, Diameter, and MySQL types. The tcp option preserve, tcp option rewrite, or tcp option remove command executed in TCP parameter profile view takes effect only for the virtual servers that are specified with the parameter profile. If both the global setting and the setting in TCP parameter profile view are configured, the setting in TCP parameter profile view takes precedence.
# Globally preserve the Timestamps option in TCP packet headers.
[Sysname] loadbalance tcp-timestamp-mode preserve
tcp option preserve
tcp option remove
tcp option rewrite
loadbalance test pcre
Use loadbalance test pcre to perform a PCRE regular expression match test and display the match result.
loadbalance test pcre value value { string string | file file-name } [ offset offset ] [ case-insensitive ]
value value: Specifies a PCRE regular expression, a case-sensitive string of 1 to 255 characters excluding question marks (?).
string string: Specifies the string to be tested, a case-sensitive string of 1 to 255 characters.
file file-name: Specifies the file to be tested by its name, a case-insensitive string of 1 to 255 characters. The file size cannot exceed 5000 bytes.
offset offset: Specifies the offset from the content to be tested, in the range of 0 to 255 bytes. The default is 0.
case-insensitive: Enables case-insensitivity matching. If you do not specify this keyword, case-sensitivity matching applies.
Operating mechanism
If the specified string or file matches the PCRE regular expression multiple times, the device displays only the result of the first match.
For a string test, the device displays the match result in text strings. For a file test, the device displays the match result in both hexadecimal characters and text strings. Characters that cannot be displayed are represented as periods (.).
# Perform a PCRE regular expression match test for string ABCDAAaefg.
<Sysname> loadbalance test pcre value aaa string ABCDAAaefg case-insensitive
Matched string content: AAa
# Perform a PCRE regular expression match test for file 123.txt.
<Sysname> loadbalance test pcre value dzckgjlfdsfdsfsdnfsdkjgnf file 123.txt
Matched file content:
64 7a 63 6b 67 6a 6c 66 64  73 66 64 73 66 73 64   dzckgjlf dsfdsfsd
6e 66 73 64 6b 6a 67 6e 66  64                     nfsdkjgn f
loadbalance test rewrite
Use loadbalance test rewrite to perform a regular-expression-based rewrite test and display the rewrite result.
loadbalance test rewrite value value replace replace-string { string string | file file-name } [ offset offset ] [ case-insensitive ]
value value: Specifies a regular expression to match the content to be rewritten, a case-sensitive string of 1 to 255 characters excluding question marks (?). You can also specify the following character strings:
·     %is—Source IP address.
·     %ps—Source port number.
·     %id—Destination IP address.
·     %pd—Destination port number.
replace replace-string: Specifies the content after rewrite, a case-sensitive string of 1 to 255 characters.
Operating mechanism
If the string or file to be tested matches the regular expression, the device replaces the matching content with the content after rewrite.
If the string or file matches the regular expression multiple times, the device displays only the rewrite result of the first match.
For a string test, the device displays the rewrite result in text strings. For a file test, the device displays the rewrite result in both hexadecimal characters and text strings. Characters that cannot be displayed are represented as periods (.).
# Perform a rewrite test for string ABCDAAaefg.
<Sysname> loadbalance test rewrite value %id replace ip:%id,port:%pd string ABCDAAaefg case-insensitive
Rewritten string content: ABCD172.0.0.1fg
# Perform a rewrite test for file 123.txt.
<Sysname> loadbalance test rewrite value dzckgjlfdsfdsfsdnfsdkjgnf replace ip:%id,port:%pd file 123.txt
Rewritten file content:
66 67 73 2d 61 47 76 61 73  64 64 73 61 67 76 62   fgs-aGva sddsagvb
64 6a 63 78 6b 6c 63 78 76  0d 0a 0d 0a 0d 0a 0d   djcxklcx v.......
0a 69 70 3a 31 37 32 2e 30  2e 30 2e 31 2c 70 6f   .ip:172. 0.0.1,po
72 74 3a 38 30 09 6a 6b 64  67 6e 66 64 6a 6b 67   rt:80.jk dgnfdjkg
6e 66 64 6b 6a 67 6e 66 64  6b 6e 67 76 73 64 66   nfdkjgnf dkngvsdf
6c 0d 0a 0d 0a 0d 0a 0d 0a  66 67 73 2b 61 67 76   l....... .fgs+agv
61 73 64 64 73 61 67 76 62  64 6a 63 78 6b 6c 63   asddsagv bdjcxklc
78 76 0d 0a 66 67 73 64 61  67 76 61 73 64 64 73   xv..fgsd agvasdds
61 67 76 62 64 6a 63 78 6b  6c 63 78 76            agvbdjcx klcxv
location rewrite
Use location rewrite to rewrite the content in the Location header of HTTP responses from the server.
Use undo location rewrite to restore the default.
location rewrite match regex match-pattern replace replace-string
undo location rewrite match regex match-pattern replace replace-string
The content in the Location header of HTTP responses from the server is not rewritten.
HTTP LB action view
match: Matches the Location header content to be rewritten.
regex match-pattern: Specifies a regular expression, a case-sensitive string of 1 to 127 characters. Regular expression metacharacter (?) is supported.
replace replace-string: Specifies the Location header content after rewriting, a case-sensitive string of 1 to 127 characters.
Operating mechanism
If the HTTP response contains 302 redirect and matches the specified match-pattern, the system will rewrite the content in the Location header to replace-value based on the match-pattern.
You can execute this command multiple times to configure multiple rules. If you execute this command multiple times to rewrite the same Location header content, the most recent configuration takes effect.
As a best practice, configure a maximum of 16 rules for an HTTP LB action.
Redirection of the Location header is executed after SSL URL redirection rewrite. The system rewrites the Location header content after matching the SSL URL rewrite result.
# In HTTP LB action lba2, rewrite http://www.example.com:9080 to http://www.example.com:80 in the Location headers of HTTP responses sent by the server.
[Sysname-lba-http-lba2] location rewrite match regex (http://www.example.com):9080 replace %1:80
ssl url rewrite location
manual-recover enable (server farm view)
Use manual-recover enable to enable health monitoring manual recovery.
Use undo manual-recover enable to disable health monitoring manual recovery.
Health monitoring manual recovery is disabled.
Server farm view
If health monitoring manual recovery is disabled, a server farm member automatically returns to normal state after it passes the health check. If health monitoring manual recovery is enabled, when a server farm member passes the health check, it will not automatically return to normal state. You need to manually restore it to normal state by executing the recover-to-active command in server farm member view.
# Enable health monitoring manual recovery for server farm sf.
[Sysname] server-farm sf
[Sysname-sfarm-sf] manual-recover enable
recover-to-active (server farm member view)
match acl
Use match class to create an ACL match rule or modify an existing ACL match rule.
Use undo match to delete a match rule.
match [ match-id ] acl [ ipv6 ] { acl-number | name acl-name }
undo match match-id
No match rules exist.
LB class view
match-id: Specifies a match rule by its ID in the range of 1 to 65535. If you do not specify this argument, the system automatically assigns an available rule ID with the smallest number.
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, the command creates an IPv4 ACL.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter.
If the specified ACL does not exist, this rule is not matched.
You can create a maximum of 65535 match rules for an LB class.
# In server load balancing, create an ACL match rule for the generic LB class lbc1.
[Sysname-lbc-generic-lbc1] match acl 2000
# In outbound link load balancing, create an ACL match rule for the link-generic LB class lbc2.
[Sysname] loadbalance class lbc2 type link-generic
[Sysname-lbc-link-generic-lbc2] match acl 2000
# In transparent DNS proxy, create an ACL match rule for the DNS LB class lbc3.
[Sysname] loadbalance class lbc3 type dns
[Sysname-lbc-dns-lbc3] match acl 2000
match application-id
Use match application-id to create an application ID match rule or modify an existing application ID match rule.
match [ match-id ] application-id [ application-id | all ]
undo match match-id
Diameter LB class view
application-id: Specifies an application by its ID in the range of 1 to 4294967295.
all: Specifies all applications.
The specified application ID must be an application ID defined in the Diameter base protocol and its extension protocols. If the specified application ID does not exist, the rule does not take effect.
# Create an application ID match rule for Diameter LB class lbc1.
[Sysname] loadbalance class lbc1 type diameter
[Sysname-lbc-diameter-lbc1] match application-id 3
loadbalance class
match class
Use match class to create a match rule that references an LB class or modify an existing match rule that references an LB class.
match [ match-id ] class class-name
undo match match-id
An LB class does not have a match rule.
LB class view
class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 255 characters, to be referenced by the match rule. The current LB class cannot be referenced.
A match rule cannot reference an LB class that has already been referenced.
# In server load balancing, create a match rule that references the LB class lbc2 for the generic LB class lbc1.
[Sysname-lbc-generic-lbc1] match class lbc2
# In outbound link load balancing, create a match rule that references the LB class lbc3 for the link-generic LB class lbc2.
[Sysname] loadbalance class lbc3 type link-generic
[Sysname-lbc-link-generic-lbc3] match class lbc2
# In transparent DNS proxy, create a match rule that references the LB class lbc4 for the DNS LB class lbc2.
[Sysname] loadbalance class lbc4 type dns
[Sysname-lbc-dns-lbc4] match class lbc2
match content
Use match content to create an HTTP entity match rule or modify an existing HTTP entity match rule.
match [ match-id ] content content [ offset offset ]
undo match match-id
HTTP LB class view
content content: Specifies the HTTP entity regular expression, a case-sensitive string of 1 to 255 characters. The string cannot contain question marks (?).
offset offset: Specifies the offset value of the HTTP entity based on the start of the HTTP packet, in the range of 0 to 1000 bytes. The default is 0.
If the entity of an HTTP packet after the offset value matches the specified regular expression, the packet matches the rule.
# Create an HTTP entity match rule for the HTTP LB class lbc2: Specify the offset value as 10 and regular expression as abc.
[Sysname] loadbalance class lbc2 type http
[Sysname-lbc-http-lbc2] match content abc.* offset 10
match cookie
Use match cookie to create an HTTP cookie match rule or modify an existing HTTP cookie match rule.
match [ match-id ] cookie cookie-name value value
undo match match-id
HTTP LB class view
cookie cookie-name: Specifies the name of the HTTP cookie, a case-sensitive string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127.
value value: Specifies the cookie value regular expression, a case-sensitive string of 1 to 255 characters. The string cannot contain question marks (?).
If an HTTP packet contains the specified cookie with the value matching the specified regular expression, the packet matches the rule.
# Create an HTTP cookie match rule for the HTTP LB class lbc2: Specify the cookie name as JSession-id and cookie value regular expression as abc.
[Sysname-lbc-http-lbc2] match cookie JSession-id value abc.*
match destination-realm
Use match destination-realm to create a destination realm match rule or modify an existing destination realm match rule.
match [ match-id ] destination-realm realm-name
undo match  match-id
realm-name: Specifies a destination realm name for exact match, a case-sensitive string of 1 to 127 characters.
If a Diameter LB class is configured with a destination realm name match rule, the corresponding LB action will be performed for the traffic matching the specified destination realm name. If the specified destination realm name does not exist, the rule does not take effect.
# Create an destination realm name match rule for Diameter LB class lbc1.
[Sysname-lbc-diameter-lbc1] match destination-realm example.com
loadbalance class
match header
Use match header to create an HTTP header match rule or modify an existing HTTP header match rule.
match [ match-id ] header header-name value value
undo match match-id
HTTP LB class view
header header-name: Specifies the name of the HTTP packet header, a case-insensitive string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127.
value value: Specifies the header value regular expression, a case-sensitive string of 1 to 255 characters. The string cannot contain question marks (?).
If an HTTP packet contains the specified header with the value matching the specified regular expression, the packet matches the rule.
# Create an HTTP header match rule for the HTTP LB class lbc2: Specify the HTTP packet header name as user-agent and header value regular expression as abcd.
[Sysname-lbc-http-lbc2] match header user-agent value abcd
match interface
Use match interface to create an interface match rule or modify an existing interface match rule.
match [ match-id ] interface interface-type interface-number
undo match match-id
Generic/HTTP/Link-generic LB class view
interface interface-type interface-number: Specifies an interface by its type and number. The interface type can be Layer 3 Ethernet interface and Layer 3 aggregate interface.
If the specified interface does not exist, the rule does not take effect.
# In outbound link load balancing, create an interface match rule for the link-generic LB class lbc1 to match interface GigabitEthernet 1/0/0.
[Sysname] loadbalance class lbc1 type link-generic
[Sysname-lbc-link-generic-lbc1] match interface gigabitethernet 1/0/0
# In server load balancing, create an interface match rule for the generic LB class lbc2 to match interface GigabitEthernet 1/0/0.
[Sysname] loadbalance class lbc2 type generic
[Sysname-lbc-generic-lbc2] match interface gigabitethernet 1/0/0
match method
Use match method to create an HTTP method match rule or modify an existing HTTP method match rule.
match [ match-id ] method { ext ext-type | rfc rfc-type }
undo match match-id
HTTP LB class view
ext ext-type: Specifies the extended type, a case-sensitive string of 1 to 63 characters excluding brackets ({ }, ( ),[ ], < >), at sign (@), comma (,), semicolon (;), colon (:), backslash (\), quotation mark ("), slash (/), question mark (?), equal sign (=), space character (SP), and horizontal tab (HT). The character string also excludes ASCII codes that are less than or equal to 31 and greater than or equal to 127.
rfc rfc-type: Specifies the RFC type to process the resources identified by the URI in HTTP request packets:
·     CONNECT—Maintain the resources.
·     DELETE—Delete the resources.
·     GET—Request for the resources.
·     HEAD—Request for the header of the response message of the resources.
·     OPTIONS—Request to query the resources-related options and requirements supported by the server.
·     POST—Add new data to the resources.
·     PUT—Request the server to store the resource identified by the URI.
·     TRACE—Request the server to return the request message it receives for test or diagnosis.
# Create a packet matching method match rule with extended type user for the HTTP LB class lbc2.
[Sysname-lbc-http-lbc2] match method ext user
# Create a packet matching method match rule with RFC type CONNECT for the HTTP LB class lbc2.
[Sysname-lbc-http-lbc2] match method rfc CONNECT
match payload
Use match payload to create a TCP payload match rule or modify an existing TCP payload match rule.
match [ match-id ] payload payload [ case-insensitive ] [ not ]
undo match match-id
Generic LB class view
payload: Specifies the TCP payload regular expression, a case-sensitive string of 1 to 255 characters.
case-insensitive: Disables case sensitivity for matching character strings. If you do not specify this keyword, case sensitivity is enabled.
not: Negates the match rule. If you do not specify this keyword, the LB action is taken when the TCP payload regular expression is matched.
The device takes the corresponding LB action on TCP packets matching a TCP payload match rule. If you specify the not keyword for a TCP payload match rule, the device takes the corresponding LB action on TCP packets not matching the TCP payload match rule.
# Create a match rule to match the payload hello for generic LB class c1.
[Sysname] loadbalance class c1 type generic
[Sysname-lbc-generic-c1] match payload hello
match radius-attribute
Use match radius-attribute to create a RADIUS attribute match rule or modify an existing RADIUS attribute match rule.
match [ match-id ] radius-attribute { code attribute-code | user-name } value attribute-value
undo match match-id
RADIUS LB class view
code attribute-code: Specifies the code of the RADIUS attribute type, in the range of 1 to 255.
user-name: Specifies the RADIUS attribute type as user-name (code 1).
value attribute-value: Specifies the RADIUS attribute regular expression, a case-sensitive string of 1 to 255 characters.
# Create a match rule to match usernames that contain aaa for RADIUS LB class lbc1.
[Sysname] loadbalance class lbc1 type radius
[Sysname-lbc-radius-lbc1] match radius-attribute user-name value aaa*
match source
Use match source to create a source IP address match rule or modify an existing source IP address match rule.
match [ match-id ] source { ip address ipv4-address [ mask-length | mask ] | ipv6 address ipv6-address [ prefix-length ] }
undo match match-id
LB class view
source: Specifies the match rule type as source IP address.
ip address ipv4-address: Specifies an IPv4 address.
mask-length: Specifies a mask length in the range of 0 to 32. The default is 32.
mask: Specifies a subnet mask. The default is 255.255.255.255.
ipv6 address ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies a prefix length in the range of 0 to 128. The default is 128.
# In server load balancing, create a match rule that matches source IP address 1.1.1.1/32 for the generic LB class lbc1.
[Sysname-lbc-generic-lbc1] match source ip address 1.1.1.1
# In outbound link load balancing, create a match rule that matches source IP address 1.1.1.1/32 for the link-generic LB class lbc2.
[Sysname-lbc-link-generic-lbc2] match source ip address 1.1.1.1
# In transparent DNS proxy, create a match rule that matches source IP address 1.1.1.1/32 for the DNS LB class lbc3.
[Sysname-lbc-dns-lbc3] match source ip address 1.1.1.1
match sql
Use match sql to create a MySQL statement match rule or modify an existing MySQL statement match rule.
match [ match-id ] sql sql [ case-insensitive ] [ not ]
undo match match-id
MySQL LB class view
sql: Specifies a regular expression used to match MySQL statements, a case-sensitive string of 1 to 255 characters.
not: Specifies that the LB action is taken when the MySQL statement regular expression is not matched. If you do not specify this keyword, the LB action is taken when the MySQL statement regular expression is matched.
# Create a match rule that matches MySQL statement select for the MySQL LB class c1.
[Sysname] loadbalance class c1 type mysql
[Sysname-lbc-mysql-lbc1] match sql select
match url
Use match url to create an HTTP URL match rule or modify an existing HTTP URL match rule.
match [ match-id ] url url
undo match match-id
HTTP LB class view
url url: Specifies a URL regular expression, a case-sensitive string of 1 to 255 characters. The string cannot contain question marks (?).
# Create an HTTP URL match rule with regular expression .*.html for the HTTP LB class lbc2.
[Sysname-lbc-http-lbc2] match url .*.html
match user
Use match user to create a user match rule or modify an existing user match rule.
match [ match-id ] [ identity-domain domain-name ] user user-name
undo match match-id
identity-domain domain-name: Matches the user in an identity domain. The domain-name argument represents the identity domain name, a case-insensitive string of 1 to 255 characters excluding question marks (?). If you do not specify this option, the system matches the user among users that do not belong to any identity domain.
user-name: Specifies a username, a case-sensitive string of 1 to 55 characters.
If the specified user does not exist, the rule does not take effect.
# In outbound link load balancing, create a user match rule for the link-generic LB class lbc1 to match user u1 in identity domain domain1.
[Sysname-lbc-link-generic-lbc1] match identity-domain domain1 user u1
# In server load balancing, create a user match rule for the generic LB class lbc2 to match user u1 in identity domain domain1.
[Sysname-lbc-generic-lbc2] match identity-domain domain1 user u1
display loadbalance class
match user-group
Use match user-group to create a user group match rule or modify an existing user group match rule.
match [ match-id ] [ identity-domain domain-name ] user-group user-group-name
undo match match-id
identity-domain domain-name: Matches the user group in an identity domain. The domain-name argument represents the identity domain name, a case-insensitive string of 1 to 255 characters excluding question marks (?). If you do not specify this option, the system matches the user group among user groups that do not belong to any identity domain.
user-group-name: Specifies a user group by its name, a case-insensitive string of 1 to 200 characters.
If the specified user group does not exist, the rule does not take effect.
# In outbound link load balancing, create a user group match rule for the link-generic LB class lbc1 to match user group lb-group in identity domain domain1.
[Sysname-lbc-link-generic-lbc1] match identity-domain domain1 user-group lb-group
# In server load balancing, create a user group match rule for the generic LB class lbc2 to match user group lb-group in identity domain domain1.
[Sysname-lbc-generic-lbc2] match identity-domain domain1 user-group lb-group
match version
Use match version to create an HTTP version match rule or modify an existing HTTP version match rule.
match [ match-id ] version { 1.0| 1.1 | 2.0 }
undo match match-id
HTTP LB class view
1.0: Specifies HTTP 1.0.
1.1: Specifies HTTP 1.1.
2.0: Specifies HTTP 2.0.
# Create an HTTP version match rule with HTTP 1.0 for the HTTP LB class lbc1.
[Sysname] loadbalance class lbc1 type http
[Sysname-lbc-dns-lbc1] match version 1.0
match-across-service enable
Use match-across-service enable to enable sticky entry matching across services.
Use undo match-across-service enable to disable sticky entry matching across services.
Sticky entry matching across services is disabled.
Address-port sticky group view
RADIUS sticky group view
Diameter sticky group view
When the device fails to find matching a stikcy entry for traffic of a virtual server, this feature allows the device to match the sticky entries of other virtual servers with the same IP address as the current virtual server.
With this feature enabled, the device can distribute requests from the same client to different services of the same virtual server to the same server farm member.
# In address-port sticky group sg1, enable sticky entry matching across services.
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1] match-across-service enable
match-across-virtual-server enable
Use match-across-virtual-server enable to enable sticky entry matching across virtual servers.
Use undo match-across-virtual-server enable to disable sticky entry matching across virtual servers.
Sticky entry matching across virtual servers is disabled.
When the device fails to find matching a stikcy entry for traffic of a virtual server, this feature allows the device to match the sticky entries of other virtual servers.
With this feature enabled, the device can distribute requests from the same client to different virtual servers to the same server farm member.
# In address-port sticky group sg1, enable sticky entry matching across virtual servers.
[Sysname-sticky-address-port-sg1] match-across-virtual-server enable
match-buffer-end
Use match-buffer-end to configure the buffering end string for TCP payload matching.
Use undo match-buffer-end to restore the default.
match-buffer-end string
No buffering end string is configured.
TCP-application parameter profile view
string: Specifies a string that indicates the end of buffering, a case-insensitive string of 1 to 31 characters.
For the TCP payload match rule, the device buffers traffic from clients for TCP payload matching during the buffering period. The device stops buffering traffic when any of the following events occurs:
·     The device receives the buffering end string from clients.
·     The size of buffered data exceeds the specified buffering size.
·     The buffered data matches the TCP payload match rule.
This command specifies the string that indicates the end of buffering for traffic received from clients.
# In TCP-application parameter profile p1, configure the buffering end string as over.
[Sysname] parameter-profile p1 type tcp-application
[Sysname-para-tcp-application-p1] match-buffer-end over
match-buffer-size
match-buffer-time
match payload
match-buffer-size
Use match-buffer-size to set the maximum buffering size for TCP payload matching.
Use undo match-buffer-size to restore the default.
match-buffer-size size
The maximum buffering size is 4096 bytes.
size: Specifies the maximum buffering size in the range of 1 to 4096 bytes.
This command specifies the maximum size of TCP data from clients that the device can buffer.
# In TCP-application parameter profile p1, set the maximum buffering size to 2048 bytes for TCP payload matching.
[Sysname-para-tcp-application-p1] match-buffer-size 2048
match-buffer-end
match-buffer-time
match payload
match-buffer-time
Use match-buffer-time to set the buffering period for TCP payload matching.
Use undo match-buffer-time to restore the default.
match-buffer-time time
The buffering period for TCP payload matching is 3 seconds.
time: Specifies the buffering period in the range of 1 to 5 seconds.
This command specifies the amount of time for the device to buffer TCP data sent by clients.
# In TCP-application parameter profile p1, set the buffering period for TCP payload matching to 3 seconds.
[Sysname-para-tcp-application-p1] match-buffer-time 3
match-buffer-end
match-buffer-size
match payload
max-reuse (parameter profile view)
Use max-reuse to set the maximum number of times that a TCP connection can be reused.
Use undo max-reuse to restore the default.
max-reuse reuse-number
undo max-reuse
A TCP connection can be reused for a maximum of 1000 times.
OneConnect parameter profile view
MySQL parameter profile view
reuse-number: Specifies the maximum number of reuse times, in the range of 1 to 4294967295.
Operating mechanism
After connection reuse is enabled, a TCP connection is not disconnected until the maximum number of reuse times is reached. After the TCP connection is disconnected, new connection requests trigger establishment of a new TCP connection.
# In OneConnect parameter profile ocp, set the maximum number of reuse times to 10000.
[Sysname] parameter-profile ocp type oneconnect
[Sysname-para-oneconnect-ocp] max-reuse 10000
memory-size
Use memory-size to set the memory size used for compression.
Use undo memory-size to restore the default.
memory-size size
undo memory-size
The memory size used for compression is 8 KB.
HTTP-compression parameter profile view
size: Specifies the memory size in KB used for compression. The value can only be 1, 2, 4, 8, 16, 32, or 64.
# Create the HTTP-compression parameter profile pa1, and set the memory size used for compression to 32 KB.
[Sysname] parameter-profile pa1 type http-compress
[Sysname-para-http-compress-pa1] memory-size 32
monitor-interval
Use monitor-interval to set the monitoring time for an LB probe template.
Use undo monitor-interval to restore the default.
monitor-interval interval-time
The monitoring time is 10 seconds for a TCP-RST or TCP zero-window LB probe template, 1 second for an HTTP passive LB probe template, and 5 seconds for a custom-monitoring LB probe template.
HTTP passive LB probe template view
TCP-RST LB probe template view
TCP zero-window LB probe template view
Custom-monitoring LB probe template view
interval-time: Specifies the monitoring time in the range of 5 to 255 seconds for a TCP-RST or TCP zero-window LB probe template, in the range of 1 to 5 seconds for an HTTP passive LB probe template, and in the range of 1 to 86400 seconds for a custom-monitoring LB probe template.
During the monitoring time, the system counts the number of RST packets or zero-window packets sent by each server farm member in a server farm.
During the monitoring time, the system monitors the responses of matching HTTP requests and counts the number of URL error times.
After a custom-monitoring LB probe template is specified, the system executes the custom script file during the monitoring time to detect the state of real servers.
# In TCP RST LB probe template rsttplt, set the monitoring time to 60 seconds.
[Sysname] loadbalance probe-template tcp-rst rsttplt
[Sysname-lbpt-tcp-rst-rsttplt] monitor-interval 60
external-script
node
Use node to create a statistics node and enter its view, or enter the view of an existing statistics node.
Use undo node to delete the specified statistics node.
node node-name
undo node node-name
No statistics nodes exist.
HTTP statistics parameter profile view
node-name: Specifies the statistics node name, a case-insensitive string of 1 to 255 characters.
You can configure a maximum of 256 statistics nodes in one HTTP statistics parameter profile.
# In HTTP statistics parameter profile http1, create statistics node node1 and enter statistics node view.
[Sysname] parameter-profile http1 type http-statistics
[Sysname-para-http-statistics-http1] node node1
[Sysname-para-http-statistics-http1-node-node1]
origin-host
Use origin-host to configure the Origin-Host AVP to be sent in Diameter messages.
Use undo origin-host to restore the default.
origin-host host-name
undo origin-host
The Origin-Host AVP to be sent in Diameter messages is host.h3c.com.
Diameter session parameter profile view
host-name: Specifies the Origin-Host AVP to be sent in Diameter messages, a case-sensitive string of 1 to 127 characters.
Operating mechanism
During Diameter capability exchange between the device and the peer, they exchange the Origin-Host, Origin-Realm, Vendor-Id, and Product-Name AVPs through CER and CEA messages. Use this command to specify the Origin-Host AVP for the device to send to the peer during the Diameter capability exchange.
The configured Origin-Host AVP must be a fully qualified domain name (FQDN), which contains both a host name and a source domain name. The source domain name is specified by using the origin-realm command. For example, if the host name is host1 and the source domain name is example.com, the Origin-Host AVP must be configured as host1.example.com.
# Configure the Origin-Host AVP as rd.example.com for Diameter session parameter profile dia.
[Sysname] parameter-profile dia type diameter-session
[Sysname-para-diameter-session-dia] origin-host rd.example.com
origin-realm
parameter-profile
origin-realm
Use origin-realm to configure the Origin-Realm AVP to be sent in Diameter messages.
Use undo origin-realm to restore the default.
origin-realm realm-name
undo origin-realm
The Origin-Realm AVP to be sent in Diameter messages is h3c.com.
realm-name: Specifies the Origin-Realm AVP to be sent in Diameter messages, a case-sensitive string of 1 to 127 characters.
During Diameter capability exchange between the device and the peer, they exchange the Origin-Host, Origin-Realm, Vendor-Id, and Product-Name AVPs through CER and CEA messages. Use this command to specify the Origin-Realm AVP for the device to send to the peer during the Diameter capability exchange.
# Configure the Origin-Realm AVP as rd.example.com for Diameter session parameter profile dia.
[Sysname-para-diameter-session-dia] origin-realm example.com
origin-host
parameter-profile
override-limit enable
Use override-limit enable to ignore the limits for sessions that match sticky entries.
Use undo override-limit enable to remove the configuration.
The session limits apply to sessions that match sticky entries.
Sticky group view
Use this command to ignore the following limits for sessions that match sticky entries:
·     Bandwidth and connection parameters on real servers or links.
·     Bandwidth ratios and maximum expected bandwidths for real servers or links.
·     LB connection limit policies on virtual servers.
This command takes effect only on new sessions and does not take effect on existing sessions.
# Ignore the limits for sessions that match sticky entries generated in the sticky group st.
[Sysname] sticky-group st type address-port
[Sysname-sticky-address-port-st] override-limit enable
parameter (LB action view)
Use parameter to specify a parameter profile for a Diameter LB action.
Use undo parameter to restore the default.
parameter { diameter-session | tcp } profile-name [ server-side ]
undo parameter { diameter-session | tcp }
No parameter profile is specified for a Diameter LB action.
Diameter LB action view
diameter-session: Specifies a Diameter session parameter profile.
tcp: Specifies a TCP parameter profile.
profile-name: Specifies a parameter profile by its name, a case-insensitive string of 1 to 255 characters.
server-side: Specifies a server-side TCP parameter profile.
Use this command to specify a Diameter session parameter profile to process the traffic forwarded to the server farm. Use this command to specify a TCP parameter profile to process and optimize the TCP connections established between the device and the server.
# Specify Diameter session parameter profile pp2 for Diameter LB action act.
[Sysname] loadbalance action act type diameter
[Sysname-lba-diameter-act] parameter diameter-session pp2
loadbalance action
parameter (virtual server view)
Use parameter to specify a parameter profile to be referenced by a virtual server.
parameter { diameter-session | http | http-compression | http-statistics | http2 [ client-side | server-side ] | ip | mysql | oneconnect | tcp | tcp-application } profile-name [ client-side | server-side ]
undo parameter { diameter-session | http | http-compression | http-statistics | http2 [ client-side | server-side ] | ip | mysql | oneconnect | tcp | tcp-application } [ client-side | server-side ]
No parameter profile is referenced by a virtual server.
Virtual server view
{ diameter-session | http | http2 | http-compression | http-statistics | ip | mysql | oneconnect | tcp | tcp-application }: Specifies a parameter profile type, Diameter session, HTTP, HTTP2.0, HTTP-compression, HTTP statistics, IP, OneConnect, TCP, or TCP-application. The diameter-session keyword is supported only by virtual servers of the Diameter type. The http keyword is supported only by virtual servers of the fast HTTP and HTTP types. The tcp client-side option is supported only by virtual servers of the Diameter, fast HTTP, HTTP, and MySQL types. The tcp server-side option is supported only by virtual servers of the fast HTTP, HTTP, and MySQL types. The http-compression, http-statistics, http2, and oneconnect keywords are supported only by virtual servers of the HTTP type. The mysql keyword is supported only by MySQL virtual servers. The tcp-application keyword is supported only by TCP virtual servers operating at Layer 7.
client-side: Specifies a client-side parameter profile.
server-side: Specifies a server-side parameter profile.
Operating mechanism
The virtual server references the parameter profile to implement analysis, processing, and optimization for service traffic.
A client-side parameter profile optimizes and processes TCP connections between the client and the device. A server-side parameter profile optimizes and processes TCP connections between the device and the server. Only TCP parameter profiles support the client-side and server-side keywords.
If you configure the virtual server to use only the HTTP2.0 parameter profile on the client side, the system analyzes, processes, and optimizes HTTP2.0 packets sent by the client, but forwards HTTP1.0 or 1.1 packets to the real server. If you configure the virtual server to use the HTTP2.0 parameter profiles on both the client side and server side, the system processes and optimizes HTTP2.0 packets sent by the client and forwards HTTP2.0 packets to the real server. If you configure the virtual server to use only the HTTP2.0 parameter profile on the server side, the parameter profile does not take effect. If you configure the virtual server to use only an HTTP parameter profile, only HTTP 1.0 and HTTP 1.1 packets can be processed and forwarded.
The virtual servers of the RADIUS type can only reference the IP parameter profile.
# Specify the IP parameter profile pp2 to be referenced by the IP-type virtual server vs3.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] parameter ip pp2
parameter-profile
Use parameter-profile to create a parameter profile and enter its view, or enter the view of an existing parameter profile.
Use undo parameter-profile to delete the specified parameter profile.
parameter-profile profile-name [ type { diameter-session | http | http-compression | http-statistics | http2 | ip | mysql | oneconnect | tcp | tcp-application } ]
undo parameter-profile profile-name
No parameter profiles exist.
profile-name: Specifies a parameter profile name, a case-insensitive string of 1 to 255 characters.
type { diameter-session | http | http-compression | http-statistics | http2 | ip | mysql | oneconnect | tcp | tcp-application }: Specifies a parameter profile type, Diameter session, HTTP, HTTP-compression, HTTP statistics, IP, MySQL, OneConnect, TCP, or TCP-application. When you create a parameter profile, you must specify the parameter profile type. You can enter an existing parameter profile view without entering the parameter profile type.
Operating mechanism
You can configure advanced parameters through the parameter profile. The virtual server references the parameter profile to implement analysis, processing, and optimization for service traffic.
# Create the IP parameter profile pp2, and enter parameter profile view.
[Sysname] parameter-profile pp2 type ip
[Sysname-para-ip-pp2]
payload (HTTP/UDP payload sticky group view)
Use payload to configure the HTTP or UDP payload sticky method.
Use undo payload to delete the HTTP or UDP payload sticky method.
payload [ offset offset ] [ start start-string ] [ end end-string | length length ]
undo payload
No sticky methods exist.
offset offset: Specifies the offset value of the HTTP or UDP payload based on the start of the HTTP or UDP packet, in the range of 0 to 1000 bytes. The default is 0.
start start-string: Specifies the regular expression that marks the start of the HTTP or UDP payload, a case-sensitive string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the HTTP or UDP payload, a case-sensitive string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the HTTP or UDP payload, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
Operating mechanism
Use this command to obtain the HTTP or UDP payload information used to generate sticky entries based on the offset, start-string, end-string, and length values. The start-string and end-string values are not included in the sticky entry information.
This command is not supported by the virtual servers of the fast HTTP type.
# Configure the HTTP payload sticky method for the HTTP payload sticky group sg5: Starting from the 10th byte of start of the HTTP packet, use the 20-byte HTTP payload to generate sticky entries.
[Sysname] sticky-group sg5 type payload
[Sysname-sticky-payload-sg5] payload offset 10 length 20
# Configure the UDP payload sticky method for the UDP payload sticky group sg6: Starting from the 28th byte of start of the UDP packet, use the 6-byte UDP payload to generate sticky entries.
[Sysname] sticky-group sg6 type payload
[Sysname-sticky-payload-sg6] payload offset 28 length 6
payload (UDP passive sticky group view)
Use payload to configure the UDP payload passive sticky method.
Use undo payload to delete the UDP payload passive sticky method.
payload { get | match } [ offset offset ] [ start start-string ] [ end end-string | length length ]
undo payload { get | match }
No UDP payload passive sticky methods exist.
get: Obtains the specified string in the UDP response payload, which is used to generate a UDP payload passive sticky entry.
match: Obtains the specified string in the UDP request payload, which is used to match a UDP payload passive sticky entry.
offset offset: Specifies the offset value of the UDP payload based on the start of the UDP packet, in the range of 0 to 1000 bytes. The default is 0.
start start-string: Specifies the regular expression that marks the start of the UDP payload, a case-sensitive string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the UDP payload, a case-sensitive string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the UDP payload, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
Use the payload get command to obtain the UDP response payload information based on the offset, start-string, end-string, and length values. Use the payload match command to obtain the UDP request payload information based on those values.
Both the payload get and payload match commands are required for a UDP payload passive sticky method.
The device obtains the payload information of an incoming UDP request based on the payload match command and obtains the payload information of an incoming UDP response based on the payload get command. If the payload information of the UDP request matches the payload information of the UDP response, the device generates a sticky entry based on the payload information of the UDP response. Subsequent UDP requests that match the sticky entry are forwarded according to the sticky entry.
# Configure the UDP payload passive sticky method for the UDP passive sticky group sg5: Obtain the 20-byte UDP payload string starting with id in the UDP response. If the obtained string matches the 20-byte UDP payload string starting with id in the UDP request, the device generates a sticky entry based on the string obtained from the UDP response.
[Sysname] sticky-group sg5 type udp-passive
[Sysname-sticky-udp-passive-sg5] payload get start id length 20
[Sysname-sticky-udp-passive-sg5] payload match start id length 20
payload (TCP payload sticky group view)
Use payload to configure the TCP payload sticky method.
Use undo payload to delete the TCP payload sticky method.
undo payload
No TCP payload sticky methods exist.
offset offset: Specifies the offset value of the TCP payload based on the start of the TCP packet, in the range of 0 to 1000 bytes. The default is 0.
start start-string: Specifies the regular expression that marks the start of the TCP payload, a case-sensitive string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the TCP payload, a case-sensitive string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the TCP payload, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
Use this command to obtain the TCP payload information used to generate sticky entries based on the offset, start-string, end-string, and length values. The start-string and end-string values are not included in the sticky entry information.
If you do not specify any parameters in this command, the sticky entry is generated based on the whole TCP packet.
# Configure the TCP payload sticky method for the TCP payload sticky group sg: Use the whole TCP packet to generate sticky entries.
[Sysname] sticky-group sg type tcp-payload
[Sysname-sticky-payload-sg] payload
payload rewrite
Use payload rewrite to rewrite the TCP payload.
Use undo payload rewrite to remove the configuration.
payload rewrite { both | request | response } value value replace replace-string
undo payload rewrite { both | request | response } value value
The TCP payload is not rewritten.
Generic LB action view
both: Specifies both the TCP request and response packets.
request: Specifies the TCP request packets.
response: Specifies the TCP response packets.
value value: Specifies the TCP packet header content to be rewritten, a case-sensitive string of 1 to 127 characters.
replace replace-string: Specifies the content after rewrite, a case-sensitive string of 1 to 127 characters. You can also specify the following replacement strings:
·     %[variable]—Replaces the specified value with the variable associated with the server farm member. The variable is the variable name.
·     %[1-9]—Replaces the specified value with the content in the corresponding parentheses of the specified value. For example, executing the payload rewrite value (Wel)(co)(me) replace %2 command will replace the string Welcome with co in the second pair of parentheses.
You can replace the specified value with the variable associated with the server farm member by specifying the replacement string %[variable]. For example, you can replace the string QMGR.S01 in the payload with QMGR.S0_1 by executing the following commands:
·     variable var1 value _1 (in server farm member view).
·     payload rewrite request value “QMGR.S01” replace QMGR.S01%[var1] (in generic LB action view).
# In generic LB action lba1, replace QMGR.S01 in the payload of TCP requests with QMGR.S01%[var1]. var1 is the name of the variable associated with the server farm member.
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] payload rewrite request value QMGR.S01 replace QMGR.S01%[var1]
variable
pool-size
Use pool-size to set the maximum number of connections allowed in the MySQL connection pool.
Use undo pool-size to restore the default.
pool-size pool-size
undo pool-size
The maximum number of connections allowed in the MySQL connection pool is 1024.
pool-size: Specifies the maximum number of connections allowed in the MySQL connection pool, in the range of 1 to 64000.
After MySQL data transfer is completed, the TCP connection is stored in a connection pool instead of being closed. For a new connection request, the device selects an available connection from the connection pool before attempting to open a new connection.
# Set the maximum number of connections allowed in the MySQL connection pool to 2000 for the MySQL parameter profile p1.
[Sysname] parameter-profile p1 type mysql
[Sysname-para-mysql-p1] pool-size 2000
port (real server view)
Use port to configure the port number of a real server.
Use undo port to restore the default.
port port-number
undo port
The port number of a real server is 0. (The original port number is used.)
Real server view
port-number: Specifies a port number in the range of 0 to 65535. 0 means the original port number is used.
This configuration takes effect only when you enable the NAT feature for the server farm.
# Specify the port number of the real server rs as 8080.
[Sysname] real-server rs
[Sysname-rserver-rs] port 8080
transparent enable (server farm view)
port (virtual server view)
Use port to configure the port number of a virtual server.
port { port-number [ to port-number ] } &<1-n>
undo port
The port number is 0 (indicates any port) for the virtual server of the IP, RADIUS, TCP, or UDP type. The port number is 80 for the virtual server of the fast HTTP or HTTP type. The port number is 5060 for the virtual server of the SIP type.
Virtual server view
port-number [ to port-number ] &<1-n>: Specifies a space-separated list of up to n port number items. Each port number item specifies a port number or a range of port numbers in the form of start-port-number to end-port-number. For IP, RADIUS, TCP, and UDP virtual servers, the value range for the port-number argument is 0 to 65535 (0 means any port) and the value range for n is 1 to 32. For HTTP, fast HTTP, and SIP virtual servers, the value range for the port-number argument is 1 to 65535 and the value of n can only be 1.
If the virtual server has referenced an SSL policy, you must configure a non-default port number (typically 443) for the virtual server.
# Specify the port number of the IP-type virtual server vs3 as 8080.
[Sysname-vs-ip-vs3] port 8080
ssl-server-policy
predictor
Use predictor to specify a scheduling algorithm for a server farm.
Use undo predictor to restore the default.
Real server-based:
predictor { dync-round-robin | least-connection | least-time | { bandwidth | max-bandwidth } [ inbound | outbound ] }
undo predictor
Server farm member-based:
predictor hash [ carp ] address { destination | source | source-ip-port } [ mask mask-length ] [ prefix prefix-length ]
predictor hash [ carp ] http [ offset offset ] [ start start-string ] [ [ end end-string ] | [ length length ] ]
predictor { least-connection member [ slow-online ] | least-time member | random | round-robin | }
undo predictor
The scheduling algorithm for a server farm is weighted round robin.
Server farm view
hash address: Performs the hash algorithm based on IP address.
carp: Specifies the Cache Array Routing Protocol (CARP) hash algorithm. When the number of available real servers changes, this protocol makes all available real servers have the smallest load changes.
destination: Performs the hash algorithm based on destination IP address.
source: Performs the hash algorithm based on source IP address.
source-ip-port: Performs the hash algorithm based on source IP address and port number.
mask mask-length: Specifies the IPv4 address mask length, in the range of 0 to 32. The default is 32.
prefix prefix-length: Specifies the IPv6 address prefix length, in the range of 0 to 128. The default is 128.
http: Performs the hash algorithm based on the HTTP content.
offset offset: Specifies the offset value based on the start of the HTTP content, in the range of 0 to 1000 bytes. The default is 0.
start start-string: Specifies the regular expression that marks the start of the HTTP content, a case-sensitive string of 1 to 127 characters starting from the offset value. The string cannot contain question marks (?).
end end-string: Specifies the regular expression that marks the end of the HTTP content, a case-sensitive string of 1 to 127 characters starting from the start-string value. The string cannot contain question marks (?).
length length: Specifies the length of the HTTP content, in the range of 0 to 1000 bytes. The default is 0, which indicates all lengths.
dync-round-robin: Specifies the dynamic round robin algorithm, which assigns new connections to real servers based on load weight values calculated by using the memory usage, CPU usage, and disk usage of the real servers. The smaller the load, the greater the weight value. A real server with a greater weight value is assigned more connections.
least-connection: Specifies the real server-based weighted least connection algorithm, which always assigns new connections to the real server with the fewest number of weighted active connections (the total number of active connections in all server farms divided by weight). The weight value used in this algorithm is configured in real server view.
least-connection member: Specifies the server farm member-based weighted least connection algorithm, which always assigns new connections to the server farm member with the fewest number of weighted active connections (the number of active connections in the specified server farm divided by weight). The weight value used in this algorithm is configured in server farm member view.
slow-online: Optimizes the warm-up process of server farm members that use the weighted least connection algorithm. To optimize the warm-up process of server farm members by using this keyword, first enable the real server warm-up feature for the server farm.
least-time: Specifies the least time algorithm, which assigns new connections to real servers based on load weight values calculated by using the response time of the real servers. The shorter the response time, the greater the weight value. A real server with a greater weight value is assigned more connections.
least-time member: Specifies the server farm member-based least time algorithm, which assigns new connections to server farm members based on load weight values calculated by using the response time of the server farm members. The shorter the response time, the greater the weight value. A server farm member with a greater weight value is assigned more connections.
random: Specifies the random algorithm, which randomly assigns new connections to real servers.
round-robin: Specifies the weighted round robin algorithm, which assigns new connections to real servers based on the weights of real servers. A higher weight indicates more new connections will be assigned. The weight value used in this algorithm is configured in server farm member view.
bandwidth: Specifies the bandwidth algorithm, which assigns packets to real servers based on the weight of the real servers and the bandwidth ratio. The weight value used in this algorithm is configured in real server view.
max-bandwidth: Specifies the maximum bandwidth algorithm, which always assigns packets to the idle real server with the largest remaining bandwidth.
inbound: Selects a real server based on the inbound bandwidth.
outbound: Selects a real server based on the outbound bandwidth.
The dynamic round robin algorithm can take effect only if you specify an SNMP-DCA NQA template. If no SNMP-DCA NQA template is specified, the non-weighted round robin algorithm is used. For more information about NQA templates, see NQA configuration in Network Management and Monitoring Configuration Guide.
If you do not specify the inbound or outbound keyword, the total bandwidth is used to select a real server.
In the bandwidth algorithm and maximum bandwidth algorithm, the remaining bandwidth is the maximum expected bandwidth minus the current bandwidth. If the maximum expected bandwidth is not configured, the remaining bandwidth is the maximum bandwidth of the real server minus the current bandwidth.
# Specify the scheduling algorithm for the server farm sf as random.
[Sysname-sfarm-sf] predictor random
max-bandwidth (real server view)
rate-limit bandwidth (real server view)
prefer-method
Use prefer-method to specify the preferred compression algorithm.
Use undo prefer-method to restore the default.
prefer-method { deflate | gzip }
undo prefer-method
The preferred compression algorithm is gzip.
deflate: Specifies the Deflate compression algorithm.
gzip: Specifies the default GNU zip compression algorithm.
If the client request supports the configured compression algorithm, the configured compression algorithm applies. If the client request does not support the configured compression algorithm, the compression algorithm contained in the request applies.
# Create the HTTP-compression parameter profile http1, and specify the preferred compression algorithm as deflate.
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] prefer-method deflate
priority (real server view)
Use priority to set the priority of a real server.
Use undo priority to restore the default.
priority priority
undo priority
The priority of a real server is 4.
Real server view
priority: Specifies the priority value of the real server, in the range of 1 to 8. A greater value means a higher priority to be referenced.
Typically only the real servers with the highest priority participate in scheduling. If the number of such real servers is smaller than the required minimum number, more real servers are selected by priority in descending order.
# Set the priority of the real server rs to 3.
[Sysname-rserver-rs] priority 3
selected-server
priority (server farm member view)
Use priority to set the priority of a server farm member.
priority priority
undo priority
The priority of a server farm member is 4.
Server farm member view
priority: Specifies the priority value in the range of 1 to 8. A greater value means a higher priority.
Typically, only the members with the highest priority in a server farm participate in scheduling. If the number of such members is smaller than the required minimum number, more members are selected by priority in descending order. If the allowed maximum number is exceeded after members with a certain priority are added, only some of the members with that priority are added.
Use this command together with the selected-server command in server farm view.
# Set the priority of server farm member rs1 to 3.
[Sysname-sfarm-sf] real-server rs1 port 80
[Sysname-sfarm-sf-#member#-rs1-port-80] priority 3
selected-server (server farm view)
priority (SNAT global policy view)
Use priority to set the priority of a SNAT global policy.
priority priority
undo priority
The priority of a SNAT global policy is 0.
priority: Specifies the priority value in the range of 0 to 65535. A greater value means a higher priority.
You can configure multiple SNAT global policies with different priorities. They are matched in descending order of priority values.
# Set the priority of SNAT global policy sn1 to 100.
[Sysname] loadbalance snat-global-policy sn1
[Sysname-lb-snat-gp-sn1] priority 100
probe (real server view)
Use probe to specify a health monitoring method for a real server.
Use undo probe to restore the default.
probe template-name [ nqa-template-port ]
undo probe template-name
No health monitoring method is specified for a real server.
Real server view
template-name: Specifies an NQA template by its name, a case-insensitive string of 1 to 255 characters.
nqa-template-port: Uses the destination port number specified in the NQA template for detection. If you do not specify this keyword, the real server's port number is used for detection.
Use the nqa template command to create an NQA template to be referenced by the health monitoring method.
You can specify a health monitoring method by using one of the following methods:
·     Configure the parameter globally for all members in a server farm in server farm view.
·     Configure the parameter for a specific real server in real server view or server farm member view.
The health monitoring method configuration in real server view or server farm member view takes precedence over the configuration in server farm view. As a best practice, specify a health monitoring method preferentially in server farm view.
The health monitoring result for a real server affects the availability of a server farm member. The health monitoring result for a server farm member does not affect the availability of a real server.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the real server rs as t4.
[Sysname] nqa template icmp t4
[Sysname-nqatplt-icmp-t4] quit
[Sysname-rserver-rs] probe t4
nqa template (Network Management and Monitoring Command Reference)
success-criteria (real server view)
probe (server farm member view)
Use probe to specify a health monitoring method for a server farm member.
No health monitoring method is specified for a server farm member.
nqa-template-port: Uses the destination port number specified in the NQA template for detection. If you do not specify this keyword, the server farm member's port number is used for detection.
Use the nqa template command to create an NQA template to be referenced by the health monitoring method. The server farm uses the parameters defined in the NQA template to detect the availability of the server farm members.
The health monitoring method configuration in server farm member view takes precedence over the configuration in server farm view. As a best practice, specify a health monitoring method preferentially in server farm view.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the server farm member rs1 as t4.
[Sysname-sfarm-sf-#member#-rs1-port-80] probe t4
success-criteria (server farm member view)
probe (server farm view)
Use probe to specify a health monitoring method for a server farm.
Use undo probe to delete a health monitoring method from a server farm.
No health monitoring method is specified for a server farm.
Server farm view
The health monitoring method configuration in real server view takes precedence over the configuration in server farm view. As a best practice, specify a health monitoring method preferentially in server farm view.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the server farm sf as t4.
<Sysname>system-view
[Sysname-sfarm-sf] probe t4
success-criteria (server farm view)
probe log enable (real server view)
Use probe log enable to enable health monitoring logging for a real server.
Use undo probe log enable to disable health monitoring logging for a real server.
probe log enable
Health monitoring logging is enabled for a real server.
Real server view
Operating mechanism
This feature generates logs when the health of a real server changes.
# Enable health monitoring logging for real server rs.
[Sysname-rserver-rs] probe log enable
probe log enable (server farm member view)
Use probe log enable to enable health monitoring logging for a server farm member.
Use undo probe log enable to disable health monitoring logging for a server farm member.
probe log enable
Health monitoring logging is enabled for a server farm member.
Operating mechanism
This feature generates logs when the health of a server farm member changes.
# Enable health monitoring logging for server farm member rs1.
[Sysname] server-farm sf
[Sysname-sfarm-sf-#member#-rs1-port-80] probe log enable
probe-template (real server view)
Use probe-template to specify a custom-monitoring LB probe template for a real server.
Use undo probe-template to remove a custom-monitoring LB probe template from a real server.
probe-template  template-name
undo probe-template  template-name
No LB probe template is specified for a real server.
Real server view
external-monitor: Specifies a custom-type LB probe template.
template-name: Specifies a custom-monitoring template by its name, a case-insensitive string of 1 to 255 characters.
Operating mechanism
This command can monitor a real sever by referencing a custom-monitoring LB probe template.
The monitoring result of a real server affects the availability of a server farm member, but the monitoring result of a server farm member does not affect the availability of a real server.
A real server configured with a domain name do not support custom-monitoring LB probe templates.
# Specify custom-monitoring LB probe template test_external for real server rs.
[Sysname-rserver-rs] probe-template external-monitor test_external
probe-template (server farm member view)
Use probe-template to specify a custom-monitoring probe template for a server farm member.
Use undo probe-template to remove a custom-monitoring LB probe template from a server farm member.
No probe template is specified for a server farm member.
Operating mechanism
This command can monitor a sever farm member by referencing a custom-monitoring LB probe template.
You can configure this command for all server farm members in server farm view or for a single server farm member in server farm member view. If you configure this command in both server farm view and server farm member view, the configuration in server farm member view takes effect.
A server farm member configured with a domain name do not support custom-monitoring LB probe templates.
# Specify custom-monitoring LB probe template test_external for server farm member rs1.
[Sysname-sfarm-sf-#member#-rs1-port-80] probe-template external-monitor test_external
probe-template (server farm view)
Use probe-template to specify an LB probe template for a server farm.
Use undo probe-template to remove an LB probe template for a server farm.
probe-template { external-monitor | http-passive | tcp-rst | tcp-zero-window } template-name
undo probe-template { external-monitor | http-passive | tcp-rst | tcp-zero-window }
No LB probe template is specified for a server farm.
Server farm view
external-monitor: Specifies a custom-monitoring LB probe template.
http-passive: Specifies an HTTP passive LB probe template.
tcp-rst: Specifies a TCP-RST LB probe template.
tcp-zero-window: Specifies a TCP zero-window LB probe template.
template-name: Specifies the template name, a case-insensitive string of 1 to 255 characters.
This command can monitor all real severs in a server farm.
A server farm can reference only one HTTP passive LB probe template, one TCP-RST LB probe template, and one TCP zero-window LB probe template at the same time.
You can specify multiple custom-monitoring LB probe templates for a server farm. A custom-monitoring LB probe template does not take effect on a server farm member if the member is configured with a domain name.
# Specify TCP-RST LB probe template r1 for server farm sf.
[Sysname-sfarm-sf] probe-template tcp-rst r1
product-name
Use product-name to configure the Product-Name AVP to be sent in Diameter messages.
Use undo product-name to restore the default.
product-name product-name
undo product-name
The Product-Name AVP is the device name configured by the administrator. If the administrator has not edited the device name, the Product-Name AVP is H3C.
product-name: Specifies the Product-Name AVP, a case-sensitive string of 1 to 127 characters.
During Diameter capability exchange between the device and the peer, they exchange the Origin-Host, Origin-Realm, Vendor-Id, and Product-Name AVPs through CER and CEA messages. Use this command to specify the Product-Name AVP for the device to send to the peer during Diameter capability exchange.
The administrator can use the sysname command to configure the device name, which is used as the Product-Name AVP by default. For more information about the sysname command, see Fundamentals Command Reference.
# Specify the Product-Name AVP as L5080 for Diameter session parameter profile dia.
[Sysname-para-diameter-session-dia] product-name L5080
parameter-profile
sysname (Fundamentals Command Reference)
protect-action
Use protect-action to configure the protection action for an LB probe template.
Use undo protect-action to restore the default.
protect-action { auto-shutdown | busy [ probe-interval interval ] [ probe-times times ] }
undo protect-action
The protection action is to place a real server in busy state.
auto-shutdown: Automatically shuts down a real server.
busy: Places a real server in busy state.
probe-interval interval: Specifies the interval for probing the real server in busy state, in the range of 5 to 3600 seconds. The default is 30 seconds.
probe-times times: Specifies the maximum number of times for probing the real server in busy state, in the range of 0 to 255. The default is 0, which means that the number of probe times is not limited.
For the busy action, after placing a real server in busy state, the device starts probing the real server at the specified probe intervals. If the number of RST or zero-window packets sent does not reach the threshold in a probe interval, the real server is placed back in normal state. If threshold violation persists when the maximum probe times is reached, the system automatically shuts down the real server.
A real server that is shut down or placed in busy state due to packet threshold violation will be restored to normal state immediately when the referenced LB probe template is deleted.
If a real server is shut down or placed in busy state due to packet threshold violation, you can restore the real server to normal state after a period of time (by executing the auto-shutdown recovery-time command) or immediately (by executing the recover-from-auto-shutdown (real server view) command).
# In TCP-RST LB probe template rsttplt, configure the protection action as busy, set the probe interval to 30 seconds, and set the probe times to 3.
[Sysname-lbpt-tcp-rst-rsttplt] protect-action busy probe-interval 30 probe-times 3
protected-url
Use protected-url to configure the URLs to be protected.
Use undo protected-url to remove all protected URLs.
protected-url url
undo protected-url
No URLs are protected.
Protection rule view
url: Specifies a regular expression to match URLs, a case-sensitive string of 1 to 255 characters. The regular expression cannot contain question marks (?).
If the number of times that a user accesses a protected URL exceeds the request threshold during the protection period, the protection action is taken.
The device does not match the parameters in a URL and matches only the portion before the question mark (?).
# In protection rule 5, configure www.example.com/index.html as a protected URL.
[Sysname] loadbalance protection-policy p1
[Sysname-lbpp-http-p1] rule 5
[Sysname-lbpp-http-p1-rule-5] protected-url www.example.com/index.html
cookie (protection policy view)
protection-action
protection-period
source-ip
protection-action
Use protection-action to configure a protection action.
Use undo protection-action to restore the default.
protection-action { warning | { drop | verify { insert-header | js } } } *
No protection action is configured.
HTTP protection policy view
warning: Generates a log message.
drop: Drops requests.
verify: Performs client verification on subsequent requests.
insert-header: Performs cookie verification by inserting an HTTP header.
js: Performs cookie verification by inserting a JS script.
The protection action is taken when protection rules in a protection policy are matched. The device supports the following protection actions:
·     Warning—Generates a log message and sends it to the information center.
·     Drop—Drops requests.
·     Verify client—Returns a response carrying a cookie value to the client. If a subsequent request carries the returned cookie value, it passes the verification. If a subsequent request does not carry a cookie value or carries a different cookie value, it fails to pass the verification and is dropped. This protection action is useful in scenarios where attackers cannot insert cookie values into attack packets. The device supports returning a cookie value by inserting an HTTP header or a JS script.
# In HTTP protection policy p1, configure generating log messages and performing client verification by inserting an HTTP header as the protection actions.
[Sysname] loadbalance protection-policy p1 type http
[Sysname-lbpp-http-p1] protection-action warning verify insert-header
protection-period
Use protection-period to set the protection period.
Use undo protection-period to restore the default.
protection-period period
The protection period is 120 seconds.
period: Specifies a protection period in the range of 1 to 900 seconds.
# In protection rule 5, set the protection period to 5 seconds.
[Sysname-lbpp-http-p1-rule-5] protection-period 5
protected-url
protection-action
protection-policy
Use protection-policy to specify a protection policy for a virtual server.
Use undo protection-policy to restore the default.
protection-policy http policy-name
undo protection-policy http
No protection policy is specified for a virtual server.
HTTP virtual server view
policy-name: Specifies a protection policy by its name, a case-insensitive string of 1 to 255 characters.
The protection policy specified for a virtual server protects the traffic matching the virtual server.
# Specify protection policy p1 for HTTP virtual server vs.
[Sysname] virtual-server vs type http
[Sysname-vs-http-vs]protection-policy http p1
proximity enable
Use proximity enable to enable the proximity feature for a server farm.
Use undo proximity enable to disable the proximity feature for a server farm.
proximity enable
The proximity feature is disabled for a server farm.
Server farm view
Operating mechanism
The proximity feature takes precedence over the scheduling algorithm in selecting a real server. If no real server is selected according to the proximity feature, the scheduling algorithm is used.
# Enable the proximity feature for the server farm sf.
[Sysname-sfarm-sf] proximity enable
proxy-protocol enable
Use proxy-protocol enable to enable proxy protocol for a TCP virtual server
Use undo proxy-protocol enable to restore the default.
proxy-protocol enable [ v1 | v2 ]
Proxy protocol is disabled for a TCP virtual server.
TCP virtual server view
v1: Specifies proxy protocol version 1.
v2: Specifies proxy protocol version 2.
After you execute this command, the device uses the proxy protocol to transparently transmit the real source IP address information to the back-end real server.
If you do not specify a proxy protocol version when executing this command, version 1 is used by default. Before executing this command, make sure that the back-end real server supports the specified proxy protocol version. If the back-end real server does not support the specified proxy protocol version, the device and the real server cannot establish a connection.
Only Layer 7 TCP virtual servers support this command.
# In TCP virtual server view, enable the proxy protocol feature.
[Sysname] virtual-server vs type tcp
[Sysname-vs-tcp-vs] proxy-protocol enable
application-mode enable
radius-attribute
Use radius-attribute to configure the RADIUS attribute sticky method.
Use undo radius-attribute to delete the RADIUS attribute sticky method.
radius-attribute { code attribute-code | framed-ip-address | user-name }
No RADIUS sticky methods exist.
code attribute-code: Specifies the code of the RADIUS attribute type, in the range of 1 to 255.
framed-ip-address: Specifies the RADIUS attribute type as framed-ip-address (code 8).
user-name: Specifies the RADIUS attribute type as user-name (code 1).
The RADIUS attribute sticky method takes effect only on RADIUS packets.
# Configure the RADIUS attribute sticky method for sticky group s1 by specifying the RADIUS attribute type as user-name.
[Sysname] sticky-group s1 type radius
[Sysname-sticky-radius-s1] radius-attribute user-name
Use rate-limit bandwidth to set the maximum bandwidth of a real server.
Use undo rate-limit bandwidth to restore the default.
rate-limit bandwidth [ inbound | outbound ] bandwidth-value kbps
undo rate-limit bandwidth [ inbound | outbound ]
The maximum bandwidth of a real server is not limited.
Real server view
inbound: Specifies the maximum inbound bandwidth.
outbound: Specifies the maximum outbound bandwidth.
bandwidth-value: Specifies the maximum bandwidth in the range of 0 to 4294967295. The value 0 means the bandwidth is not limited.
kbps: Specifies the bandwidth unit as kbps.
If you do not specify the inbound or outbound keyword, the maximum bandwidth equals the inbound bandwidth plus the outbound bandwidth.
# Set the maximum bandwidth of the real server rs to 1 kbps.
[Sysname-rserver-rs] rate-limit bandwidth 1 kbps
# Set the maximum inbound bandwidth of the real server rs to 1 kbps.
[Sysname-rserver-rs] rate-limit bandwidth inbound 1 kbps
# Set the maximum outbound bandwidth of the real server rs to 1 kbps.
[Sysname-rserver-rs] rate-limit bandwidth outbound 1 kbps
rate-limit bandwidth (virtual server view)
Use rate-limit bandwidth to set the maximum bandwidth of a virtual server.
The maximum bandwidth of a virtual server is not limited.
Virtual server view
# Set the maximum bandwidth of the IP-type virtual server vs3 to 1 kbps.
[Sysname-vs-ip-vs3] rate-limit bandwidth 1 kbps
# In outbound link load balancing, set the maximum inbound bandwidth of the link IP-type virtual server vs3 to 1 kbps.
[Sysname] virtual-server vs3 type link-ip
[Sysname-vs-link-ip-vs3] rate-limit bandwidth inbound 1 kbps
rate-limit connection (real server view)
Use rate-limit connection to set the maximum number of connections per second of a real server.
Use undo rate-limit connection to restore the default.
rate-limit connection connection-number
The maximum number of connections per second of a real server is 0.
Real server view
connection-number: Specifies the maximum number of connections per second in the range of 0 to 4294967295. 0 means the number is not limited.
# Set the maximum number of connections per second of the real server rs to 10000.
[Sysname-rserver-rs] rate-limit connection 10000
rate-limit connection (server farm member view)
Use rate-limit connection to set the maximum number of connections per second of a server farm member.
The maximum number of connections per second of a server farm member is 0.
# Set the maximum number of connections per second of the server farm member rs1 to 1000.
[Sysname-sfarm-sf-#member#-rs1-port-80] rate-limit connection 1000
rate-limit connection (virtual server view)
Use rate-limit connection to set the maximum number of connections per second of a virtual server.
The maximum number of connections per second of a virtual server is 0.
Virtual server view
# Set the maximum number of connections per second of the IP-type virtual server vs3 to 10000.
[Sysname-vs-ip-vs3] rate-limit connection 10000
# In outbound link load balancing, set the maximum number of connections per second of the link IP-type virtual server vs2 to 10000.
[Sysname] virtual-server vs2 type link-ip
[Sysname-vs-link-ip-vs2] rate-limit connection 10000
rate-limit http-request (real server view)
Use rate-limit http-request to set the maximum number of HTTP requests per second for a real server.
Use undo rate-limit http-request to restore the default.
rate-limit http-request request-number
The maximum number of HTTP requests per second is 0 for a real server.
Real server view
request-number: Specifies the maximum number of HTTP requests per second, in the range of 0 to 4294967295. 0 means the number is not limited.
The number of HTTP requests per second is used for determining whether a real server is busy. If the number of HTTP requests received by a real server per second exceeds the specified maximum value, the real server is considered busy.
# Set the maximum number of HTTP requests per second to 10000 for real server rs.
[Sysname-rserver-rs] rate-limit http-request 10000
rate-limit http-request (server farm member view)
Use rate-limit http-request to set the maximum number of HTTP requests per second for a server farm member.
The maximum number of HTTP requests per second is 0 for a server farm member.
The number of HTTP requests per second is used for determining whether a server farm member is busy. If the number of HTTP requests received by a server farm member per second exceeds the specified maximum value, the server farm member is considered busy.
# Set the maximum number of HTTP requests per second to 10000 for server farm member rs.
[Sysname-sfarm-sf-#member#-rs1-port-80] rate-limit http-request 10000
readwrite-separation
Use readwrite-separation to enable read/write separation for the MySQL database.
Use undo readwrite-separation to disable read/write separation for the MySQL database.
readwirte-separation read-server-farm read-server-farm-name [ read-sticky-group read-sticky-group-name ] write-server-farm write-sever-farm-name [ write-sticky-group write-sticky-group-name ]
Read/write separation is disabled for the MySQL database.
MySQL virtual server view
read-server-farm read-server-farm-name: Specifies a read server farm by its name, a case-insensitive string of 1 to 63 characters.
read-sticky read-sticky-group-name: Specifies a sticky group for the read server farm by its name, a case-insensitive string of 1 to 63 characters.
write-server-farm write-server-farm-name: Specifies a write server farm by its name, a case-insensitive string of 1 to 63 characters.
write-sticky write-sticky-group-name: Specifies a sticky group for the write server farm by its name, a case-insensitive string of 1 to 63 characters.
Read/write separation allows read commands and write commands to be executed by the read server farm and write server farm, respectively, which helps reduce the impact of concurrent read/write requests on database performance.
# Enable read/write separation for the MySQL database of MySQL virtual server vs1.
[Sysname] virtual-server vs1 type mysql
[Sysname-vs-mysql-vs1] readwrite-separation read-server-farm rd write-server-farm wr
real-server (server farm view)
Use real-server to create a server farm member and enter its view, or enter the view of an existing server farm member.
Use undo real-server to delete a server farm member.
real-server real-server-name port port-number
undo real-server real-server-name port port-number
No server farm members exist.
Server farm view
real-server-name: Specifies a server farm member by its name, a case-insensitive string of 1 to 255 characters.
port-number: Specifies the port number of the server farm member, in the range of 0 to 65535.
You can use one of the following methods to add a member to a server farm:
·     Use the real-server command in server farm view. H3C recommends using this method.
·     Use the server-farm command in real server view.
You cannot use both methods to add a member with the same real server name and port number to a server farm.
If you configure a domain name on a real server and receive the domain name resolution result, the server farm will automatically reference the temporary server farm members corresponding to the domain name resolution result after referencing the real server. The name of a temporary member is in the auto_IP address form, for example, auto_1.1.1.1.
# Add server farm member rs1 and enter server farm member view.
server-farm (real server view)
real-server (system view)
Use real-server to create a real server and enter its view, or enter the view of an existing real server.
Use undo real-server to delete the specified real server.
No real servers exist.
real-server-name: Specifies the real server name, a case-insensitive string of 1 to 255 characters.
# Create real server rs and enter real server view.
rebalance per-request
Use rebalance per-request to enable load balancing for each HTTP request.
Use undo rebalance per-request to restore the default.
Load balancing applies to the first HTTP request of a connection. Other HTTP requests are processed in the same way.
HTTP parameter profile view
# Enable load balancing for each HTTP request in the HTTP parameter profile pp1.
[Sysname] parameter-profile pp1 type http
[Sysname-para-http-pp1] rebalance per-request
recover-to-active (real server view)
Use recover-to-active to manually recover a real server.
recover-to-active
Real server view
If health monitoring is not configured, a recovered real server is set to Unknown state.
If health monitoring is configured and succeeds, a recovered real server is set to Active state. If health monitoring fails, a recovered real server is set to Probe-failed state.
# Manually recover a real server.
[Sysname-rserver-rs] recover-to-active
recover-to-active (server farm member view)
Use recover-to-active to manually recover a server farm member.
recover-to-active
If health monitoring is not configured, a recovered server farm member is set to Unknown state.
If health monitoring is configured and succeeds, a recovered server farm member is set to Active state. If health monitoring fails, a recovered server farm member is set to Probe-failed state.
# Manually recover a server farm member.
[Sysname-sfarm-sf-#member#-rs1-port-80] recover-to-active
recv-window size
Use recv-window size to configure the maximum Tx window size for HTTP2.0.
Use undo recv-window size to restore the default.
recv-window size size
The maximum Tx window size for HTTP2.0 is 32KB.
HTTP2.0 parameter profile view
size: Specifies the maximum Tx window size for HTTP2.0, in the range of 16 to 128 KB.
If there are too many concurrent requests on a TCP connection, the concurrent processing capability of the device or server will be affected. To resolve this issue, you can configure the maximum number of concurrent requests supported by a TCP connection. You can also configure the maximum Tx window size for HTTP2.0 to resolve this issue. When the concurrent requests exceed the maximum Tx window size, the device will receive and process the concurrent requests in multiple batches based on the Tx window size.
This command takes effect only on HTTP 2.0 request packets.
# Create HTTP2.0 parameter profile p1, and set the maximum Tx window size for HTTP2.0 to 128KB.
[Sysname] parameter-profile p1 type http2
[Sysname-para-http2-p1] recv-window size 128
concurrent-streams-per-connection
redirect relocation (LB action view)
Use redirect relocation to enable the redirection feature and specify a redirection URL for an LB action.
Use undo redirect relocation to disable the redirection feature for an LB action.
redirect relocation relocation
The redirection feature is disabled for an LB action.
HTTP LB action view
relocation: Specifies a redirection URL, a case-sensitive string of 1 to 255 characters. You can also specify the question mark (?) or the following character strings as the redirection URL (each character string can be used only once):
·     %h: Specifies the host name and port number in the client request packet.
·     %{host}: Specifies the host name in the client request packet.
·     %{port}: Specifies the port number in the client request packet.
·     %p: Specifies the URL in the client request packet.
Compatibility information
This command redirects all HTTP request packets matching an LB action to the specified URL.
Operating mechanism
This command and the server-farm command are mutually exclusive. If you configure one command, the other command (if configured) is automatically cancelled.
# Enable the redirection feature for the HTTP LB action lba1, and specify the redirection URL as https://%h%p.
[Sysname] loadbalance action lba1 type http
[Sysname-lba-http-lba1] redirect relocation https://%h%p
redirect relocation (virtual server view)
Use redirect relocation to enable the redirection feature and specify a redirection URL for a virtual server.
Use undo redirect relocation to disable the redirection feature for a virtual server.
The redirection feature is disabled for a virtual server.
relocation: Specifies a redirection URL, a case-sensitive string of 1 to 255 characters. The redirection feature redirects all request packets matching the virtual server to the URL. You can also specify the question mark (?) or the following character strings as the redirection URL (each character string can be used only once):
# Enable the redirection feature for the HTTP-type virtual server vs2, and specify the redirection URL as https://%h%p.
[Sysname] virtual-server vs2 type http
[Sysname-vs-http-vs2] redirect relocation https://%h%p
redirect return-code (LB action view)
Use redirect return-code to specify the status code in the redirection packets that the LB device returns to clients.
Use undo redirect return-code to restore the default.
redirect return-code { 301 | 302 | 307 }
The status code in the redirection packets that the LB device returns to clients is 302.
HTTP LB action view
301: Deletes request resources permanently.
302: Deletes request resources temporarily.
307: Redirects requests to the URL in the location header temporarily.
This configuration takes effect only when the redirection feature is enabled for the HTTP LB action.
# Specify the status code in the redirection packets that the LB device returns to clients as 301 for the HTTP LB action lba1.
[Sysname-lba-http-lba1] redirect return-code 301
redirect relocation
redirect return-code (virtual server view)
This configuration takes effect only when the redirection feature is enabled for the virtual server.
# Specify the status code in the redirection packets that the LB device returns to clients as 301 for the HTTP-type virtual server vs2.
[Sysname-vs-http-vs2] redirect return-code 301
redirect relocation
reload http-response
Use reload http-response to reload a response file.
reload http-response { file filename }
file filename: Specifies a file by its name, a case-insensitive string of 1 to 255 characters.
If a response file changes, you must reload the file to make it take effect.
# Reload response file subsys_intf.js.
[Sysname] reload http-response /index/subsys_intf.js
fallback-action response raw-file
response
request-version all
Use request-version all to enable compression for responses to HTTP 1.0 requests.
Use undo request-version all to restore the default.
request-version all
Compression is disabled for responses to HTTP 1.0 requests.
HTTP-compression parameter profile view
# Create the HTTP-compression parameter profile http1, and enable compression for responses to HTTP 1.0 requests.
[Sysname-para-http-compression-http1] request-version all
reset loadbalance connections
Use reset loadbalance connections to clear application layer connections.
This command clears all application layer connections, including reused idle connections.
# Clear application layer connections.
<Sysname> reset loadbalance connection
reset loadbalance probe failed-record
Use reset loadbalance probe failed-record to clear the recorded health monitoring failures.
reset loadbalance probe failed-record { real-server | link } [ name name ]
real-server: Specifies a real server or all real servers.
link: Specifies a link or all links.
name name: Specifies a real server or a link by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this parameter, this command clears the recorded health monitoring failures for all real servers or all links.
# Clear the recorded health monitoring failures for all real servers.
<Sysname> reset loadbalance probe failed-record real-server
display loadbalance probe failed-record
reset loadbalance snat-pool statistics
Use reset loadbalance snat-pool statistics to clear SNAT address pool statistics.
reset loadbalance snat-pool statistics [ pool-name ]
pool-name: Specifies an SNAT address pool by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command clear statistics of all SNAT address pools.
# Clear statistics of all SNAT address pools and the associated SNAT IP addresses.
<Sysname> reset loadbalance snat-pool statistics
# Clear statistics of SNAT address pool sp and its members.
<Sysname> reset loadbalance snat-pool statistics sp
reset real-server statistics
Use reset real-server statistics to clear real server statistics or server farm member statistics.
reset real-server statistics [ real-server-name ]
reset real-server statistics server-farm server-farm-name [ name real-server-name port port-number ]
real-server-name: Clears statistics of the specified real server. The real-server-name argument specifies a real server name, a case-insensitive string of 1 to 255 characters. If you do not specify this argument, the command clears statistics of all real servers.
server-farm server-farm-name: Clears statistics for members of a server farm. The server-farm-name argument specifies a server farm by its name, a case-insensitive string of 1 to 255 characters.
name real-server-name port port-number: Clears statistics for a server farm member. The real-server-name argument specifies a server farm member by its name, a case-insensitive string of 1 to 255 characters. The port-number argument specifies the port number of the server farm member, in the range of 0 to 65535. If you do not specify this option, the command clears statistics for all members of a server farm.
# Clear statistics of all real servers.
<Sysname> reset real-server statistics
# Clear statistics of all members in server farm sf.
<Sysname> reset real-server statistics server-farm sf
display real-server statistics
reset sticky virtual-server
Use reset sticky virtual-server to clear sticky entry information for virtual servers.
reset sticky virtual-server [ virtual-server-name virtual-server-name ] [ [ link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } } | link-group link-group-name ] * | [ real-server-addr { ipv4-address | ipv6-address } | real-server-port port-number | server-farm server-farm-name | text text ] * ] [ class { class-name | default-class } | client-addr { ipv4-address | ipv6-address } | client-port port-number | sticky-type { diameter | address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive } [ key sticky-key ] ] * [ traffic-group traffic-group-id ]
virtual-server virtual-server-name: Specifies a virtual server by its name, a case-insensitive string of 1 to 255 characters. If you do not specify this option, the command clears sticky entry information for all virtual servers.
link { ip ipv4-address | ipv6 ipv6-address | interface { interface-type interface-number | interface-name } }: Specifies a link by its IPv4 address, IPv6 address, or output interface.
link-group link-group-name: Specifies a link group by its name, a case-insensitive string of 1 to 255 characters.
real-server-addr { ipv4-address | ipv6-address }: Specifies a real server by its IPv4 or IPv6 address.
real-server-port port-number: Specifies a real server port number in the range of 0 to 65535.
server-farm server-farm-name: Specifies a server farm by its name, a case-insensitive string of 1 to 255 characters.
text text: Specifies a text string to match.
class { class-name | default-class }: Specifies an LB class by its name, a case-insensitive string of 1 to 255 characters, or specifies the default LB class.
client-addr { ipv4-address | ipv6-address }: Specifies a client by its IPv4 or IPv6 address.
client-port port-number: Specifies a client port number in the range of 0 to 65535.
sticky-type { diameter | address-port | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive }: Specifies a sticky group type.
key sticky-key: Specifies a key value, a case-sensitive string of 1 to 36 characters. If you do not specify key value, this command clears sticky entries for all key values.
traffic-group traffic-group-id: Specifies a cluster traffic group by its ID, an integer in the range of 1 to 255. If you do not specify this option, the command clears sticky entry information of all cluster traffic groups.
# Clear sticky entry information for client address 3.0.0.1 of virtual server vs.
<Sysname> reset sticky virtual-server virtual-server-name vs client-addr 3.0.0.1
reset virtual-server statistics
Use reset virtual-server statistics to clear virtual server statistics.
reset virtual-server statistics [ virtual-server-name ]
virtual-server-name: Clears statistics of the specified virtual server. The virtual-server-name argument specifies a virtual server name, a case-insensitive string of 1 to 255 characters. If you do not specify this argument, the command clears statistics of all virtual servers.
# Clear statistics of all virtual servers.
<Sysname> reset virtual-server statistics
display virtual-server statistics
response
Use response to specify a response file for matching HTTP requests.
Use undo response to restore the default.
response { url url file filename | workpath workpath zip-file zip-filename }
undo response { url url | workpath workpath }
No response file is specified for HTTP requests.
HTTP LB action view
url url: Specifies the URL path used to match HTTP requests, a case-sensitive string of 1 to 255 characters. The specified URL path must start with a forward slash (/).
file filename: Specifies an uncompressed file by its name, a case-insensitive string of 1 to 255 characters.
workpath workpath: Specifies a working path to match the URL in HTTP requests, a case-sensitive string of 1 to 255 characters. The working path can be a single forward slash (/), or a string that starts with a forward slash and does not end with a forward slash.
zip-file zip-filename: Specifies a zip file by its name, a case-insensitive string of 1 to 255 characters. The relative path in the zip file is used to match the URL in HTTP requests.
Any two of the following commands are mutually exclusive:
·     response
·     server-farm (LB action view)
·     redirect relocation (LB action view)
Operating mechanism
If the URL path in a client request matches the specified URL path, the device responds to the request by using an uncompressed file.
If the URL path in a client request matches the specified working path plus a relative path in the zip file, the device responds to the request by using the file in the zip file. For example, if you configure the response workpath /index zip-file flash:/za/zb/test.zip command and a relative path /css/col.css exists in test.zip, the matching URL is /index/css/col.css and the response file is col.css.
URL-encoded URLs cannot be matched.
If you configure both an uncompressed file and a compressed file for the same URL path, the uncompressed file is used to respond to matching HTTP requests.
The path specified in the command must exist on the device.
For the same HTTP LB action, only one uncompressed file can be used for a URL, and one uncompressed file can be used for multiple URLs.
If you specify multiple compressed files for one or more URL paths in the same HTTP LB action, the most recent configuration takes effect.
If you specify multiple uncompressed files for one URL path in the same HTTP LB action, the most recent configuration takes effect. One uncompressed file can be used for different URL paths.
# Specify response file subsys.js for the HTTP requests with URL path /index/subsys/subsys_intf.js.
[Sysname] loadbalance action a_http type http
[Sysname-lba-http-a_http] response url /index/subsys/subsys_intf.js file subsys.js
display loadbalance action
retransmission enable
Use retransmission enable to enable Diameter message retransmission.
Use undo retransmission enable to disable Diameter message retransmission.
Diameter message retransmission is disabled.
Diameter session parameter profile view
With Diameter message retransmission enabled, if the device does not receive any response from the real server within the retransmission timeout timer, the device retransmits the message to another real server in the same server farm and restarts the timer. If the device still does not receive any response within the retransmission timeout timer, it considers the message transmission failed and notifies the client that the server is unreachable.
The device can retransmit a Diameter message only once.
# Enable Diameter message retransmission for Diameter session parameter profile dia.
[Sysname] parameter-profile dia type diameter-session
[Sysname-para-diameter-session-dia] retransmission enable
parameter-profile
Use retransmission timeout to set the timeout timer for Diameter message retransmission.
Use undo retransmission to restore the default.
retransmission timeout timeout-value
undo retransmission timeout
The timeout timer for Diameter message retransmission is 5 seconds.
timeout-value: Specifies the timeout timer in the range of 1 to 4294967295 seconds.
Before using this command, use the retransmission enable command to enable Diameter message retransmission.
Use this command to set an appropriate timeout timer for Diameter message retransmission. A long timeout timer might result in waste of resources. A short timeout timer might prevent the servers from responding to user requests in time.
# Set the timeout timer for Diameter message retransmission to 15 seconds for Diameter session parameter profile dia.
[Sysname-para-diameter-session-dia] retransmission timeout 15
parameter-profile
route-advertisement enable
Use route-advertisement enable to enable IP address advertisement for a virtual server.
Use undo route-advertisement enable to disable IP address advertisement for a virtual server.
IP address advertisement is disabled for a virtual server.
Virtual server view
After this feature is configured, the device advertises the IP address of the virtual server to OSPF for route calculation. When the service of a data center switches to another data center, the traffic to the virtual server can also be switched to that data center. For information about OSPF, see Network Connectivity Configuration Guide.
# Enable IP address advertisement for the virtual server vs.
[Sysname] virtual-server vs type ip
[Sysname-vs-ip-vs] route-advertisement enable
rst threshold
Use rst threshold to set the RST packet count threshold for a TCP-RST LB probe template.
Use undo rst threshold to restore the default.
rst threshold number
undo rst threshold
The RST packet count threshold is 1000000.
TCP-RST LB probe template view
number: Specifies the RST packet count threshold value, in the range of 1 to 4294967295.
When the number of RST packets sent by a real server reaches the threshold, the protection action specified in the protect-action command is taken.
# In TCP-RST LB probe template rsttplt, set the RST packet count threshold to 20.
[Sysname] loadbalance probe-template tcp-rst rsttplt
[Sysname-lbpt-tcp-rst-rsttplt] rst threshold 20
protect-action
rule (parameter profile view)
Use rule to configure a filtering rule for compression.
Use undo rule to restore the default.
rule [ rule-id ] { deny | permit } { content-type | url } expression
undo rule rule-id
No filtering rules are configured.
rule-id: Specifies a rule by its ID in the range of 1 to 65535. If the rule does not exist, the command creates the rule. If the rule already exists, the command modifies the rule. If you do not specify this argument, the system automatically assigns an available rule ID with the smallest number.
deny: Does not compress matching packets.
permit: Compresses matching packets.
content-type: Matches content types in the content-type header of packets.
url: Matches URLs in packets.
expression: Specifies a regular expression, a case-sensitive string of 1 to 255 characters. The string cannot contain question marks (?).
# Create the HTTP-compression parameter profile http1, and configure the device to not compress the response packets containing the string image in URLs.
[Sysname-para-http-compression-http1] rule deny url image
rule (protection policy view)
Use rule to create a protection rule and enter its view, or enter the view of an existing protection rule.
Use undo rule to delete a protection rule.
rule rule-id
undo rule rule-id
No protection rules exist.
rule-id: Specifies a rule ID in the range of 1 to 65535.
Operating mechanism
You can configure multiple protection rules in an HTTP protection policy. The device compares the URL in a packet with the URLs configured in the protection rules according to the order of the rule IDs. If a match is found and the configured protection threshold is exceeded, the device performs the associated protection action. If the URL in the packet does not match the URL configured in a specific protection rule, the device compares the URL with the next protection rule.
# In HTTP protection policy p1, create protection rule 5 and enter its view.
secondary-cookie delimiters
Use secondary-cookie delimiters to configure the delimiter that separates secondary cookies in URLs.
Use undo secondary-cookie delimiters to restore the default.
secondary-cookie delimiters text
The delimiter that separates secondary cookies in URLs can be slash (/), ampersand (&), number sign (#), or plus (+).
text: Specifies the delimiter, a string of 1 to 4 characters including exclamation mark (!), quotation mark (',"), number sign (#), semicolon (;), brackets (( ),[ ], < >), question mark (?), backslash (\), caret (^), grave accent (`), vertical bar (|), colon (:), at sign (@), ampersand (&), dollar sign ($), plus (+), asterisk (*), comma (,), and slash (/). Each character in the string is considered as a delimiter.
# For the HTTP parameter profile pp1, configure the delimiter that separates secondary cookies in URLs as slash (/), at sign (@), number sign (#), or dollar sign ($).
[Sysname-para-http-pp1] secondary-cookie delimiters !@#$
secondary-cookie start
Use secondary-cookie start to configure the start delimiter for secondary cookies in URLs.
Use undo secondary-cookie start to restore the default.
secondary-cookie start text
The start delimiter for secondary cookies in URLs is question mark (?).
text: Specifies the delimiter, a string of 1 to 2 characters including exclamation mark (!), quotation mark ("), number sign (#), semicolon (;), brackets ([ ], < >), question mark (?), backslash (\), caret (^), grave accent (`), and vertical bar (|).
# For the HTTP parameter profile pp1, configure the start delimiter for secondary cookies in URLs as question mark (?) or exclamation mark (!).
[Sysname-para-http-pp1] secondary-cookie start ?!
selected-server
Use selected-server to specify the number of real servers to participate in scheduling.
Use undo selected-server to restore the default.
selected-server min min-number max max-number
The real servers with the highest priority participate in scheduling.
Server farm view
min min-number: Specifies the minimum number of real servers to participate in scheduling, in the range of 1 to 1000.
max max-number: Specifies the maximum number of real servers to participate in scheduling, in the range of 1 to 1000. The value of the max-number argument must be greater than or equal to the value of the min-number argument.
If the number of real servers available to participate in scheduling exceeds the max-number setting, the max-number setting applies.
If the number of real servers available to participate in scheduling is less than the min-number setting, more real servers are selected by priority in descending order.
# Configure the minimum number and maximum number of real servers in the server farm sf to participate in scheduling as 20 and 30, respectively.
[Sysname-sfarm-sf] selected-server min 20 max 30
predictor (server farm view)
server-connection reuse
Use server-connection reuse to enable connection reuse between the LB device and the server.
Use undo server-connection reuse to disable connection reuse between the LB device and the server.
Connection reuse between the LB device and the server is disabled.
MySQL parameter profile view
Operating mechanism
This command allows the LB device to establish connections to the server that can be reused by clients. Because multiple clients can use the same connection, the number of connections between the clients and the server is reduced.
This command is not supported by the virtual servers of the fast HTTP type.
# Enable connection reuse between the LB device and the server for the HTTP parameter profile pp1.
[Sysname-para-http-pp1] server-connection reuse
Use server-farm to specify the primary server farm.
Use undo server-farm to restore the default.
server-farm server-farm-name [ backup backup-server-farm-name ] [ sticky sticky-name [ backup backup-sticky-name ] ]
undo server-farm
No primary server farm is specified.
LB action view
server-farm-name: Specifies a primary server farm name, a case-insensitive string of 1 to 255 characters.
backup backup-server-farm-name: Specifies a backup server farm name, a case-insensitive string of 1 to 255 characters.
sticky sticky-name: Specifies a primary sticky group by its name, a case-insensitive string of 1 to 255 characters.
backup backup-sticky-name: Specifies a backup sticky group by its name, a case-insensitive string of 1 to 255 characters. This option is supported only by HTTP virtual servers and RADIUS virtual servers.
This command is mutually exclusive with the forward all or redirect relocation command. If you configure one command, the other command (if configured) is automatically cancelled.
Operating mechanism
When the primary server farm is available (contains real servers), packets are forwarded through the primary server farm. When the primary server farm is not available, packets are forwarded through the backup server farm.
If you specify both a primary sticky group and a backup sticky group, the device generates both primary sticky entries and backup sticky entries. If packets do not match primary sticky entries, backup sticky entries will apply.
The device generates backup sticky entries for only the following sticky group combinations:
·     RADIUS-type primary sticky group and port-address-type backup sticky group.
·     HTTP cookie-type primary sticky group and port-address-type backup sticky group.
·     HTTP cookie-type primary sticky group and HTTP passive-type backup sticky group.
# Specify the primary server farm sf, the backup server farm sfb, and the sticky group sg1 for the generic LB action lba1.
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] server-farm sf backup sfb sticky sg1
forward all
Use server-farm to specify the server farm for a real server.
undo server-farm [ server-farm-name ]
A real server does not belong to any server farm.
Real server view
server-farm-name: Specifies a server farm name, a case-insensitive string of 1 to 255 characters.
You can specify a server farm that has not been created.
# Specify the server farm sf for the real server rs.
[Sysname] real-server rs
[Sysname-rserver-rs] server-farm sf
server-farm (system view)
Use server-farm to create a server farm and enter its view, or enter the view of an existing server farm.
Use undo server-farm to delete the specified server farm.
undo server-farm server-farm-name
No server farms exist.
Operating mechanism
You can add servers with common attributes to a server farm to facilitate management.
# Create the server farm sf and enter server farm view.
[Sysname-sfarm-sf]
service-down-action reset
Use service-down-action reset to enable immediate TCP connection interruption upon virtual server unavailability.
Use undo service-down-action reset to disable immediate TCP connection interruption upon virtual server unavailability.
Immediate TCP connection interruption upon virtual server unavailability is disabled.
TCP/HTTP/fast HTTP/MySQL/SIP-TCP virtual server view
After you execute this command for a virtual server, if the virtual server is unavailable, a SYN packet from a client will be immediately responded to with an RST packet.
# In TCP virtual server view, enable immediate TCP connection interruption upon virtual server unavailability.
[Sysname-vs-tcp-vs] service-down-action reset
service enable
Use service enable to enable a virtual server.
Use undo service enable to disable a virtual server.
service enable
undo service enable
A virtual server is disabled.
Virtual server view
# Enable the IP-type virtual server vs3.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] service enable
# In outbound link load balancing, enable the link IP-type virtual server vs2.
[Sysname-vs-link-ip-vs2] service enable
service object-group
Use service object-group to specify a service object group for address translation.
Use undo service object-group to restore the default.
service object-group object-group-name
All packets matching virtual servers are translated.
object-group-name: Specifies a service object group by its name, a case-insensitive string of 1 to 63 characters.
If you specify a service object group, the device performs SNAT on only packets with a matching service. For information about configuring a service object group, see object group configuration in Security Configuration Guide.
# Specify a service object group obj1 for SNAT global policy sn1.
[Sysname-lb-snat-gp-sn1] service object-group obj1
object-group (Security Command Reference)
set ip tos (LB action view)
Use set ip tos to set the ToS field value of IP packets sent to the server.
Use undo set ip tos to restore the default.
set ip tos tos-number
undo set ip tos
The ToS field of IP packets sent to the server is not changed.
LB action view
tos-number: Specifies the ToS field value in the range of 0 to 255.
# Set the ToS field value to 20 for IP packets sent to the server for the generic LB action lba1.
[Sysname-lba-generic-lba1] set ip tos 20
# In outbound link load balancing, set the ToS field value to 20 for IP packets sent to the server for the link-generic LB action lba2.
[Sysname] loadbalance action lba2 type link-generic
[Sysname-lba-link-generic-lba2] set ip tos 20
# In transparent DNS proxy, set the ToS field value to 20 for IP packets sent to the server for the DNS LB action lba3.
[Sysname] loadbalance action lba3 type dns
[Sysname-lba-dns-lba3] set ip tos 20
set ip tos (parameter profile view)
Use set ip tos to set the ToS field value of IP packets sent to the client.
undo set ip tos
The ToS field of IP packets sent to the client is not changed.
Parameter profile view
This command is available in IP parameter profile view only.
# Set the ToS field value to 20 for IP packets sent to the client for the IP parameter profile pp2.
[Sysname] parameter-profile pp2 type ip
[Sysname-para-ip-pp2] set ip tos 20
Use shutdown to shut down a real server.
Use undo shutdown to activate a real server.
shutdown
A real server is activated.
Real server view
# Shut down the real server rs.
[Sysname-rserver-rs] shutdown
shutdown (server farm member view)
Use shutdown to shut down a server farm member.
Use undo shutdown to activate a server farm member.
shutdown
A server farm member is activated.
Server farm member view
# Shut down the server farm member rs1.
[Sysname-sfarm-sf] real-server rs1 port 80
[Sysname-sfarm-sf-#member#-rs1-port-80] shutdown
slow-attack client-read timeout
Use slow-attack client-read timeout to configure the timeout timer for detecting slow read attacks.
Use undo slow-attack client-read timeout to disable slow read attack detection.
slow-attack client-read timeout timeout-value
Slow read attack detection is disabled. After you enable HTTP slow attack protection, the timeout timer for detecting slow read attacks is 30 seconds.
timeout-value: Specifies the timeout timer for the client to finish reading an HTTP response, in the range of 1 to 65535 seconds. The default value is 30.
Operating mechanism
The device takes an HTTP response as a slow read attack if a client does not finish reading an HTTP response sent by a server before the timeout timer expires.
The timeout timer for detecting slow read attacks takes effect only after you enable HTTP slow attack protection.
If you use this command to enable slow read attack detection, the configuration takes effect on only new traffic, and it does not take effect on existing traffic.
If you use this command to disable slow read attack detection or edit the timeout timer for detecting slow read attacks, the configuration takes effect on both existing traffic and new traffic.
# Configure the timeout timer for detecting slow read attacks in HTTP protection policy view.
[Sysname-lbpp-http-p1] slow-attack client-read timeout 30
display loadbalance protection-policy
slow-attack protection enable
slow-attack min-transmit-rate
Use slow-attack min-transmit-rate to configure the minimum transmission rate and the minimum transmission rate duration for detecting slow attacks.
Use undo slow-attack min-transmit-rate to disable .
slow-attack min-transmit-rate rate-value [ duration duration ]
Slow attack detection with the minimum transmission rate is disabled. After you enable HTTP slow attack protection, the minimum transmission rate is 100 bytes per second and the duration is 60 seconds for detecting slow attacks.
rate-value: Specifies the minimum transmission rate for detecting slow attacks, in the range of 1 to 65535 bytes per second. The default value is 100.
duration: Specifies the minimum transmission rate duration for detecting slow attacks, in the range of 1 to 65535 seconds. The default value is 60.
Operating mechanism
When some applications have high upload or download demands, using the timeout timer for detecting slow attacks might lead to misjudgments. To identify attacks more accurately, the device can use the minimum transmission rate and minimum transmission rate duration settings. The device takes the traffic as a slow HTTP attack if the actual transmission rate remains below the minimum rate within the specified duration.
The device then identifies the attack type based on the current transmission stage.
·     In the HTTP request header transmission stage, the device identifies that it might be a slow headers attack.
·     In the HTTP request body transmission stage, the device identifies that it might be a slow body attack.
·     In the response packet sending stage, the device identifies that it might be a slow read attack.
·     If the client request packet or the response packet returned to the client is the HTTP/2 version, the device identifies it as an HTTP/2 slow attack.
The minimum transmission rate and the minimum transmission rate duration for detecting slow attacks take effect only after you enable HTTP slow attack protection.
If you use this command to enable slow attack detection with the minimum transmission rate or edit the minimum transmission rate, the configuration takes effect on only new traffic, and it does not take effect on existing traffic.
If you use this command to disable slow attack detection with the minimum transmission rate or edit the minimum transmission rate duration, the configuration takes effect on new both existing traffic and new traffic.
# Configure the minimum transmission rate as 120 bytes per second and the duration as 50 seconds for detecting slow attacks in HTTP protection policy view.
[Sysname-lbpp-http-p1] slow-attack min-transmit-rate 120 duration 50
slow-attack request-headers timeout
slow-attack request-body timeout
Use slow-attack protection enable to enable HTTP slow attack protection for an HTTP protection policy.
Use undo slow-attack protection enable to disable HTTP slow attack protection for an HTTP protection policy.
HTTP slow attack protection is disabled for an HTTP protection policy.
Operating mechanism
You can configure HTTP slow attack protection for an HTTP protection policy. This configuration enables the device to analyze received HTTP request packets. It determines whether a slow headers, slow body, or slow read attack occurs based on the timeout timer, minimum transmission rate, and minimum transmission rate duration. If such a slow attack occurs, the device takes the associated protection actions.
HTTP slow attacks include the following types:
·     Slow headers attack—The device takes an HTTP request as a slow headers attack if the device does not completely receive the headers of the HTTP request sent by a client before the timeout timer expires.
·     Slow body attack—The device takes an HTTP request as a slow body attack if the device does not completely receive the body of the HTTP request sent by a client before the timeout timer expires.
·     Slow read attack—The device takes an HTTP response as a slow read attack if a client does not finish reading an HTTP response sent by a server before the timeout timer expires.
To have the HTTP slow attack protection feature take effect, specify the protection action as warning or drop with the protection-action { warning | drop } * command.
# Enable HTTP slow attack protection in HTTP protection policy view.
[Sysname-lbpp-http-p1] slow-attack protection enable
protection-action
slow-attack request-header timeout
Use slow-attack request-body timeout to configure the timeout timer for detecting slow body attacks.
Use undo slow-attack request-body timeout to disable slow body attack detection.
slow-attack request-body timeout timeout-value
Slow body attack detection is disabled. After you enable HTTP slow attack protection, the timeout timer for detecting slow body attacks is 20 seconds.
timeout-value: Specifies the timeout timer for the client to completely send the body of an HTTP request, in the range of 1 to 65535 seconds. The default value is 20.
Operating mechanism
The timeout timer for detecting slow body attacks takes effect only after you enable HTTP slow attack protection.
If you use this command to enable slow body attack detection, the configuration takes effect on only new traffic, and it does not take effect on existing traffic.
If you use this command to disable slow body attack detection or edit the timeout timer for detecting slow body attacks, the configuration takes effect on both existing traffic and new traffic.
# Configure the timeout timer for detecting slow body attacks in HTTP protection policy view.
[Sysname-lbpp-http-p1] slow-attack request-body timeout 20
Use slow-attack request-header timeout to configure the timeout timer for detecting slow headers attacks.
Use undo slow-attack request-header timeout to disable slow headers attack detection.
slow-attack request-header timeout timeout-value
Slow headers attack detection is disabled. After you enable HTTP slow attack protection, the timeout timer for detecting slow headers attacks is 10 seconds.
timeout-value: Specifies the timeout timer for the client to completely send the headers of an HTTP request, in the range of 1 to 65535 seconds. The default value is 10.
Operating mechanism
The timeout timer for detecting slow headers attacks takes effect only after you enable HTTP slow attack protection.
If you use this command to enable slow headers attack detection, the configuration takes effect on only new traffic, and it does not take effect on existing traffic.
If you use this command to disable slow headers attack detection or edit the timeout timer for detecting slow headers attacks, the configuration takes effect on both existing traffic and new traffic.
# Configure the timeout timer for detecting slow headers attacks in HTTP protection policy view.
[Sysname-lbpp-http-p1] slow-attack request-header timeout 10
slow-offline enable (real server view)
Use slow-offline enable to enable the slow offline feature for a real server.
Use undo slow-offline enable to disable the slow offline feature for a real server.
slow-offline enable
The slow offline feature is disabled for a real server.
Real server view
Operating mechanism
The shutdown command immediately terminates existing connections of a real server. The slow offline feature does not terminate existing connections and wait them to age out. It creates connections for traffic that matches the exiting sticky entry and continues to perform health monitoring on the server farm member.
Application scenarios
Use the slow offline feature if you want to remove a server farm member and then add it again at a later time. With the slow offline feature, you can also monitor the state of the server farm member in real time.
To enable the slow offline feature for a real server, you must execute the slow-offline enable command and then the shutdown command.
This command and the slow-shutdown enable command are mutually exclusive. A subsequently executed command overwrites the previously executed command.
# Enable the slow offline feature for the real server rs.
[Sysname-rserver-rs] slow-offline enable
slow-shutdown (real server view)
slow-offline enable (server farm member view)
Use slow-offline enable to enable the slow offline feature for a server farm member.
Use undo slow-offline enable to disable the slow offline feature for a server farm member.
slow-offline enable
The slow offline feature is disabled for a server farm member.
Operating mechanism
The shutdown command immediately terminates existing connections of a server farm member. The slow offline feature does not terminate existing connections and wait them to age out. It creates connections for traffic that matches an existing sticky entry and continues to perform health monitoring on the server farm member.
To enable the slow offline feature for a server farm member, you must execute this command and then the shutdown command.
# Enable the slow offline feature for the server farm member rs.
[Sysname] server-farm sf
[Sysname-sfarm-sf] real-server rs port 0
[Sysname-sfarm-sf-#member#-rs-port-0] slow-offline enable
[Sysname-sfarm-sf-#member#-rs-port-0] shutdown
slow-shutdown (server farm member view)
slow-online
Use slow-online to enable the slow online feature for a server farm.
Use undo slow-online to disable the slow online feature for a server farm.
slow-online [ standby-time standby-time ramp-up-time ramp-up-time ]
undo slow-online
The slow online feature is disabled for a server farm.
Server farm view
standby-time standby-time: Specifies the standby timer in the range of 0 to 600 seconds. The default is 5 seconds.
ramp-up-time ramp-up-time: Specifies the ramp-up timer in the range of 3 to 600 seconds. The default is 5 seconds.
The real servers newly added to a server farm might not be able to immediately process large numbers of services assigned by the LB device. To resolve this issue, enable the slow online feature for the server farm. The feature uses the standby timer and ramp-up timer. When a real server is added, the LB device does not assign any service to the real server until the standby timer expires.
When the standby timer expires, the ramp-up timer starts. During the ramp-up time, the LB device increases the service amount according to the processing capability of the real server, until the ramp-up timer expires.
# Enable the slow online feature for the server farm sf.
[Sysname-sfarm-sf] slow-online
slow-shutdown enable (real server view)
Use slow-shutdown enable to enable the slow shutdown feature for a real server.
Use undo slow-shutdown enable to disable the slow shutdown feature for a real server.
The slow shutdown feature is disabled for a real server.
Real server view
Operating mechanism
The shutdown command immediately terminates existing connections of a real server. The slow shutdown feature ages out the connections, and does not establish new connections.
Use the slow shutdown feature before you maintain or upgrade a real server to avoid bad user experience caused by sudden disconnections.
To enable the slow shutdown feature for a real server, you must execute the slow-shutdown enable command and then the shutdown command. If you execute the shutdown command and then the slow-shutdown enable command, the slow shutdown feature does not take effect and the real server is shut down.
This command and the slow-offline enable command are mutually exclusive. A subsequently executed command overwrites the previously executed command.
# Enable the slow shutdown feature for the real server rs.
[Sysname-rserver-rs] slow-shutdown enable
slow-shutdown enable (server farm member view)
Use slow-shutdown enable to enable the slow shutdown feature for a server farm member.
Use undo slow-shutdown enable to disable the slow shutdown feature for a server farm member.
The slow shutdown feature is disabled for a server farm member.
Operating mechanism
The shutdown command immediately terminates existing connections of a server farm member. The slow shutdown feature ages out the connections, and does not establish new connections.
Use the slow shutdown feature before you maintain or upgrade a server farm member to avoid bad user experience caused by sudden disconnections.
To enable the slow shutdown feature for a server farm member, you must execute the slow-shutdown enable command and then the shutdown command. If you execute the shutdown command and then the slow-shutdown enable command, the slow shutdown feature does not take effect and the server farm member is shut down.
# Enable the slow shutdown feature for the server farm member rs1.
[Sysname-sfarm-sf-#member#-rs1-port-80] slow-shutdown enable
snat enable
Use snat enable to enable a SNAT global policy.
Use undo snat enable to disable a SNAT global policy.
snat enable
undo snat enable
A SNAT global policy is disabled.
SNAT global policy view
# Enable SNAT global policy sn1.
[Sysname] loadbalance snat-global-policy sn1
[Sysname-lb-snat-gp-sn1] snat enable
snat-mode
Use snat-mode to specify a translation mode for a server farm.
Use undo snat-mode to restore the default.
snat-mode { auto-map | tcp-option }
undo snat-mode
No translation mode is specified for a server farm.
Server farm view
auto-map: Specifies the automatic mapping mode.
tcp-option: Specifies the TCP option mode.
You can configured only one translation mode for a server farm. This command and the snat-pool (server farm view) command are mutually exclusive.
Operating mechanism
The device supports the following translation modes for a server farm:
·     Automatic mapping—Translates the source IP address into the IP address of the interface connecting to the real servers.
·     TCP option—Translates the source IP address into the IP address carried in the TCP option field of packets.
·     SNAT address pool—Translates the source IP address into an IP address in the SNAT address pool specified by using the snat-pool (server farm view) command.
If SNAT is not configured for a server farm, the server farm uses SNAT global policies for address translation (if configured).
# Specify the automatic mapping translation mode for server farm sf.
[Sysname-sfarm-sf] snat-mode auto-map
snat-pool
Use snat-pool to specify the SNAT address pool to be referenced by a server farm.
Use undo snat-pool to restore the default.
snat-pool pool-name
undo snat-pool
No SNAT address pool is referenced by a server farm.
Server farm view
pool-name: Specifies the SNAT address pool name, a case-insensitive string of 1 to 255 characters.
After a server farm references a SNAT address pool, the LB device replaces the source address of packets it receives with an SNAT address before forwarding the packets.
# Specify the SNAT address pool lbsp to be referenced by the server farm sf.
[Sysname-sfarm-sf] snat-pool lbsp
snmp-agent trap enable loadbalance
Use snmp-agent trap enable loadbalance to enable SNMP notifications for load balancing.
Use undo snmp-agent trap enable loadbalance to disable SNMP notifications for load balancing.
All SNMP notifications are enabled for load balancing.
Operating mechanism
To report critical load balancing events to an NMS, enable SNMP notifications for load balancing. For load balancing event notifications to be sent correctly, you must also configure SNMP as described in the network management and monitoring configuration guide for the device.
# Disable SNMP notifications for load balancing.
[Sysname] undo snmp-agent trap enable loadbalance
source-ip
Use source-ip to configure a source-IP-based request threshold.
Use undo source-ip to restore the default.
source-ip request-threshold threshold
undo source-ip
The source-IP-based request threshold is not configured.
Protection rule view
request-threshold threshold: Specifies a request threshold in the range of 1 to 4294967295.
If the number of times that a user accesses a protected URL exceeds the request threshold during the protection period, the protection action is taken. The device determines whether requests belong to the same user based on the following elements:
·     Cookie—Requests with the same cookie value for a cookie (specified in the cookie command in protection rule view) belong to the same user.
·     Source IP address—Requests with the same source IP address belong to the same user.
If you configure both a cookie-based request threshold and a source-IP-based request threshold, the protection action is taken when either threshold is exceeded.
# In protection rule 5, configure a source-IP-based request threshold of 2.
[Sysname] loadbalance protection-policy p1
[Sysname-lbpp-http-p1] rule 5
[Sysname-lbpp-http-p1-rule-5] source-ip request-threshold 2
cookie (protection policy view)
protected-url
protection-action
protection-period
source-ip object-group (parameter profile view)
Use source-ip object-group to enable collection of HTTP traffic statistics by source IP address object group.
Use undo source-ip object-group to remove a source IP address object group for HTTP traffic statistics collection.
source-ip object-group object-group-name
undo source-ip object-group object-group-name
HTTP traffic statistics are collected on a per-IP address basis.
HTTP statistics parameter profile view
object-group-name: Specifies a source IP address object group by its name, a case-insensitive string of 1 to 63 characters.
Operating mechanism
If HTTP packets match the specified URL and source IP address object group, they are counted based on the source IP address object group. If HTTP packets match the specified URL but do not match the specified source IP address object group, they are counted based on the source IP address.
You can specify a maximum of 1024 source IP address object groups in one HTTP statistics parameter profile.
This command takes effect only on IP address objects configured by using the host, subnet, and range keywords in the network command. For information about configuring IP address objects, see object group configuration in Security Configuration Guide.
# In HTTP statistics parameter profile http1, enable collection of HTTP traffic statistics by source IP address object group cnc.
[Sysname] parameter-profile http1 type http-statistics
[Sysname-para-http-statistics-http1] source-ip object-group cnc
network (Security Command Reference)
source-ip object-group (SNAT global policy view)
Use source-ip object-group to specify a source IP address object group for address translation.
Use undo source-ip object-group to restore the default.
All packets are translated.
If you specify a source IP address object group, the device performs SNAT on only packets with a matching source IP address. For information about configuring an IP address object group, see object group configuration in Security Configuration Guide.
# Specify source IP address object group obj1 for SNAT global policy sn1.
[Sysname-lb-snat-gp-sn1] source-ip object-group obj1
src-addr-option
Use src-addr-option to configure the TCP option for SNAT.
Use undo src-addr-option to restore the default.
src-addr-option option-number [ encode { binary | string } ]
No TCP option is configured for SNAT.
TCP parameter profile view
option-number: Specifies a TCP option by its number. Valid numbers are 6, 7, 9 to 18, and 22 to 254.
encode { binary | string }: Specifies the bindary or string encoding mode. The default is the binary mode.
This command enables the device to parse the IP address in the TCP option by using the specified encoding mode. Then, the device translates the source IP address according to the configured translation mode.
This command takes effect only in a TCP parameter profile that is referenced as a client-side parameter profile by a virtual server.
# In TCP parameter profile pp3, specify TCP option 28 with binary encoding mode for SNAT.
[Sysname] parameter-profile pp3 type tcp
[Sysname-para-tcp-pp3] src-addr-option 28 encode binary
snat-mode
ssl session-id
Use ssl session-id to configure an SSL sticky method based on SSL session ID.
Use undo ssl session-id to restore the default.
ssl session-id
undo ssl session-id
No sticky methods exist.
SSL sticky group view
Operating mechanism
The SSL sticky method based on SSL session ID applies only to HTTPS request packets. This sticky method requires specifying an SSL server policy for the virtual server.
# Configure the SSL sticky method based on SSL session ID for the SSL sticky group sg6.
[Sysname] sticky-group sg6 type ssl
[Sysname-sticky-ssl-sg6] ssl session-id
ssl url rewrite
Use ssl url rewrite to rewrite the URL in the Location header of HTTP response packets sent by the server.
Use undo ssl url rewrite to remove the configuration.
ssl url rewrite location location [ clearport clear-port ] [ sslport ssl-port ]
undo ssl url rewrite location location [ clearport clear-port ]
The URL in the Location header of HTTP response packets sent by the server is not rewritten.
HTTP LB action view
location location: Specifies the Location header URL regular expression, a case-sensitive string of 1 to 255 characters.
clearport clear-port: Specifies the HTTP port number to be rewritten, in the range of 1 to 65535. The default is 80.
sslport ssl-port: Specifies the SSL port number after rewrite, in the range of 1 to 65535. The default is 443.
If the Location header of an HTTP response packet contains the location and clear-port values, the system rewrites HTTP in the URL to HTTPS and rewrites the clear-port value to the ssl-port value.
# For the HTTP LB action lba2, rewrite the URL http://www.ss.example.com:8080 in the Location header of HTTP response packets sent by the server to https://www.ss.example.com:443.
[Sysname] loadbalance action lba2 type http
[Sysname-lba-http-lba2] ssl url rewrite location www.ss.example.com clearport 8080 sslport 443
ssl-client-policy (LB action view)
Use ssl-client-policy to specify an SSL client policy to encrypt traffic between the LB device (SSL client) and the SSL server.
Use undo ssl-client-policy to restore the default.
ssl-client-policy policy-name
undo ssl-client-policy policy-name
No SSL client policy is referenced.
HTTP/Diameter LB action view
policy-name: Specifies an SSL policy by its name, a case-insensitive string of 1 to 31 characters.
The virtual servers of the fast HTTP type do not support this command.
The device does not support specifying an SSL client policy that uses the following cipher suites:
·     exp_rsa_des_cbc_sha.
·     exp_rsa_rc2_md5.
·     exp_rsa_rc4_md5.
·     rsa_des_cbc_sha.
# Specify the SSL client policy scp for the HTTP LB action lba2.
[Sysname-lba-http-lba2] ssl-client-policy scp
ssl-client-policy (virtual server view)
Use ssl-client-policy to specify an SSL client policy for a virtual server to encrypt traffic between the LB device (SSL client) and the SSL server.
A virtual server does not reference any SSL client policy.
HTTP virtual server view
·     exp_rsa_rc2_md5.
·     exp_rsa_rc4_md5.
·     rsa_des_cbc_sha.
# Specify the SSL client policy scp for the HTTP virtual server vs2.
[Sysname-vs-http-vs2] ssl-client-policy scp
ssl-server-policy
Use ssl-server-policy to specify an SSL server policy for a virtual server to encrypt traffic between the LB device (SSL server) and the SSL client.
Use undo ssl-server-policy to remove an SSL server policy.
ssl-server-policy policy-name [ sni server-name ]
undo ssl-server-policy policy-name [ policy-name sni ]
A virtual server does not reference any SSL server policy.
HTTP/TCP/Diameter virtual server view
policy-name: Specifies an SSL server policy by its name, a case-insensitive string of 1 to 31 characters.
sni server-name: Specifies an SSL server indication, a case-insensitive string of 1 to 253 characters.
Operating mechanism
If you execute this command multiple times without the sni server-name option, the most recent configuration takes effect.
You can specify multiple SSL server policies with SSL server indications, and each SSL server policy must have a different SSL server indication.
If you specify multiple SSL server policies, only the SSL server policy without an SSL server indication takes effect.
The device does not support specifying an SSL server policy that uses the following cipher suites:
·     exp_rsa_rc2_md5.
·     exp_rsa_rc4_md5.
·     rsa_des_cbc_sha.
# Specify the SSL server policy ssp for the HTTP virtual server vs2.
[Sysname-vs-http-vs2] ssl-server-policy ssp
statistics-match url
Use statistics-match url to configure a URL match rule.
Use undo statistics-match url to delete a URL match rule.
statistics-match [ rule-id ] url url
undo statistics-match rule-id
No URL match rules exist.
Statistics node view
rule-id: Specifies the match rule ID in the range of 1 to 256. If you do not specify a match rule ID, the system assigns the smallest available rule ID to the match rule.
url: Specifies a URL regular expression, a case-sensitive string of 1 to 255 characters. The string cannot contain question marks (?).
You can configure a maximum of 256 URL match rules for one statistics node.
# In statistics node bank, configure a string of .html to match URLs in HTTP packets.
[Sysname-para-http-statistics-http1] node bank
[Sysname-para-http-statistics-http1-node-bank] statistics-match url *.html
status-code
Use status-code to configure a response status code to check.
Use undo status-code to remove a response status code.
status-code code
undo status-code code
No response status code is configured for checking.
HTTP passive LB probe template view
code: Specifies a response status code, in the range of 100 to 599.
The device monitors the responses of HTTP requests with URLs specified in the check-url command. If the status code in an HTTP response is the same as the specified response status code, a URL error is recorded.
You can configure a maximum of 10 response status codes for one HTTP passive load balancing template.
# Configure response status code 404 in HTTP passive load balancing template tplt.
[Sysname] loadbalance probe-template http-passive tplt
[Sysname-lbpt-http-passive-tplt] status-code 404
check-url
sticky
Use sticky to specify a sticky group for a virtual server.
Use undo sticky to restore the default.
sticky sticky-name
undo sticky
No sticky group is specified for a virtual server.
sticky-name: Specifies a sticky group by its name, a case-insensitive string of 1 to 255 characters.
Operating mechanism
You can also specify a sticky group by using the default server-farm and server-farm (LB action view) commands. The sticky group specified by using the sticky command has the highest priority.
This command allows you to specify only HTTP cookie sticky groups.
# Specify the HTTP cookie sticky group test for HTTP virtual server vs.
[Sysname] virtual-server vs type http
[Sysname-vs-http-vs] sticky test
default server-farm
sticky-group
sticky-group
Use sticky-group to create a sticky group and enter its view, or enter the view of an existing sticky group.
Use undo sticky-group to delete the specified sticky group.
sticky-group group-name [ type { address-port | diameter | http-content | http-cookie | http-header | http-passive | payload | radius| sip | ssl | tcp-payload | udp-passive } ]
undo sticky-group group-name
No sticky groups exist.
group-name: Specifies a sticky group name, a case-insensitive string of 1 to 255 characters.
type { address-port | diameter | http-content | http-cookie | http-header | http-passive | payload | radius | sip | ssl | tcp-payload | udp-passive }: Specifies the sticky group type, address and port, Diameter, HTTP entity, HTTP cookie, HTTP header, HTTP passive, HTTP or UDP payload, RADIUS, SIP, SSL, TCP payload, or UDP passive. When you create a sticky group, you must specify the sticky group type. You can enter an existing sticky group view without entering the type of the sticky group.
Operating mechanism
A sticky group uses a specific sticky method to distribute similar sessions to the same real server or link. The sticky method applies to the first packet of a session. Subsequent packets of the session are distributed to the same real server or link.
# Create the address- and port-type sticky group sg1 and enter sticky group view.
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1]
sticky-over-busy enable
Use sticky-over-busy enable to enable stickiness-over-busyness.
Use undo sticky-over-busy enable to disable stickiness-over-busyness.
Stickiness-over-busyness is disabled.
Sticky group view
This command enables the device to assign client requests to real servers based on sticky entries, regardless of whether the real servers are busy.
When stickiness-over-busyness is disabled, the device assigns client requests to only the real servers in normal state.
# In address- and port-type sticky group sg1, enable stickiness-over-busyness.
[Sysname-sticky-address-port-sg1] sticky-over-busy enable
success-criteria (real server view)
Use success-criteria to specify the health monitoring success criteria for a real server.
Use undo success-criteria to restore the default.
success-criteria { all | at-least min-number }
Health monitoring succeeds only when all the specified health monitoring methods succeed.
Real server view
all: Specifies the health monitoring success criteria as all successful health monitoring methods.
at-least min-number: Specifies the health monitoring success criteria as the specified minimum number of successful health monitoring methods, in the range of 1 to 4294967295.
If the min-number setting exceeds the number of existing health monitoring methods on the device, the number of existing health monitoring methods applies.
The health monitoring success criteria configuration in real server view takes precedence over the configuration in server farm view.
# Configure the health monitoring success criteria for the real server rs as a minimum number of 2 successful health monitoring methods.
[Sysname-rserver-rs] success-criteria at-least 2
success-criteria (server farm member view)
Use success-criteria to specify the health monitoring success criteria for a server farm member.
The health monitoring success criteria configuration in server farm member view takes precedence over the configuration in server farm view.
The health monitoring result for a real server affects the availability of a server farm member. The health monitoring result for a server farm member does not affect the availability of a real server.
# Configure the health monitoring success criteria for the server farm member rs1 as a minimum number of 2 successful health monitoring methods.
[Sysname-sfarm-sf-#member#-rs1-port-80] success-criteria at-least 2
success-criteria (server farm view)
Use success-criteria to specify the health monitoring success criteria for a server farm.
Server farm view
# Configure the health monitoring success criteria for the server farm sf as a minimum number of 2 successful health monitoring methods.
[Sysname-sfarm-sf] success-criteria at-least 2
syn retransmission-timeout
Use syn retransmission-timeout to set the retransmission timeout time for SYN packets.
Use undo syn retransmission-timeout to restore the default.
syn retransmission-timeout timeout-value
The retransmission timeout time for SYN packets is 10 seconds.
timeout-value: Specifies the retransmission timeout time for SYN packets, in the range of 1 to 75 seconds.
This command sets the amount of time the device waits for a SYN ACK before closing a TCP connection.
# Set the retransmission timeout time for SYN packets to 5 seconds for TCP connections.
[Sysname] parameter-profile profile type tcp
[Sysname-para-tcp-profile] syn retransmission-timeout 5
display parameter-profile
syn-cookie threshold
Use syn-cookie threshold to configure the threshold for triggering SYN Cookie protection.
Use undo syn-cookie threshold to restore the default.
syn-cookie threshold threshold
The threshold is 0, indicating that SYN Cookie protection will never be triggered.
threshold: Specifies the number of half-open connections that triggers SYN Cookie protection, in the range of 1 to 4294967295.
Generally, the establishment of a TCP connection requires a three-way handshake. Some attackers carry out SYN Flood attacks during the establishment of a TCP connection to consume server resources, preventing the server from providing services. You can execute this command to resolve this issue.
When the number of half-open connections between the virtual server and client reaches the specified threshold, the SYN Cookie protection feature will be triggered to prevent SYN Flood attacks.
A half-open connection refers to a TCP connection that is not completely established. In a half-open connection between a virtual server and a client, the virtual server has received a TCP connection request SYN packet but has not received an ACK packet.
This command takes effect only when the TCP parameter profile is used by a Layer 4 TCP virtual server.
# In TCP parameter profile tcppara, set the threshold for triggering SYN Cookie protection to 10.
[Sysname] parameter-profile tcppara type tcp
[Sysname-para-tcp-tcppara] syn-cookie threshold 10
tcp checksum-force-verify enable
Use tcp checksum-force-verify enable to enable the device to check the TCP checksum of a received packet.
Use undo tcp checksum-force-verify enable to restore the default.
The device does not check the TCP checksum of a received packet.
After you execute this command, the device will check the TCP checksum of a received packet. If the TCP checksum is correct, the device processes the packet. If the TCP checksum is incorrect, the device discards the packet, because it determines that the packet has been tampered with during the transmission from the sender to the device.
# Enable the device to check the TCP checksum of a received packet.
[Sysname] parameter-profile pp type tcp
[Sysname-para-tcp-pp] tcp checksum-force-verify enable
tcp connection idle-timeout
Use tcp connection idle-timeout to set the idle timeout for TCP connections.
Use undo tcp connection idle-timeout to restore the default.
tcp connection idle-timeout value
The idle timeout is 0 seconds for TCP connections, which means TCP connections never time out.
value: Specifies the idle timeout in the range of 1 to 86400 seconds.
This command sets the idle timeout for TCP connections between the LB device and the clients and for TCP connections between the LB device and the servers. If no traffic is available on a TCP connection before the idle timeout expires, the LB device terminates the TCP connection.
# Set the idle timeout to 60 seconds for TCP connections.
[Sysname] parameter-profile pp1 type tcp
[Sysname-para-tcp-pp1] tcp connection idle-timeout 60
tcp mss
Use tcp mss to set the MSS for the LB device.
Use undo tcp mss to restore the default.
tcp mss value
undo tcp mss
The MSS is not set for the LB device.
value: Specifies the MSS value in the range of 128 to 1460 bytes.
Operating mechanism
When the client establishes a TCP connection to the LB device, the client sends its own MSS value to the LB device. The LB device records the MSS value and sends the configured MSS value to the client. The client and the LB device use the smaller MSS value for communication.
When the LB device establishes a TCP connection to the server, the LB device sends the configured MSS value to the server. The server records the MSS value and sends its own MSS value to the LB device. The LB device and the server use the smaller MSS value for communication.
This command takes effect only when the fast HTTP or HTTP virtual server has referenced a TCP parameter profile.
# Set the MSS to 1300 bytes for the LB device.
[Sysname] parameter-profile tcp type tcp
[Sysname-para-tcp-tcp] tcp mss 1300
tcp option preserve
Use tcp option preserve to preserve the specified TCP option in TCP packet headers.
Use undo tcp option preserve to remove the configuration.
tcp option preserve option-number
undo tcp option preserve option-number
The preserve action is not specified for the TCP option in TCP packet headers. For the Timestamps option, the global action specified in the loadbalance tcp-timestamp-mode command applies.
option-number: Specifies a TCP option by its number. In the current software version, the value for this argument only takes 8, indicating the Timestamps option in TCP packet headers.
Operating mechanism
This command enables the LB device to preserve the Timestamps option in the headers of TCP packets sent to the server. In the current software version, this command supports only the TCP Timestamps option with option number 8.
If you execute the tcp option preserve, tcp option remove, and tcp option rewrite commands multiple times for TCP option 8, the most recent configuration takes effect.
If you execute both the tcp option preserve and loadbalance tcp-timestamp-mode commands, the tcp option preserve command takes effect.
# In TCP parameter profile pp1, preserve TCP option 8 in TCP packet headers.
[Sysname-para-tcp-pp1] tcp option preserve 8
parameter-profile
tcp option remove
tcp option rewrite
tcp option insert
Use tcp option insert to insert the client information into a TCP option.
Use undo tcp option insert to remove the configuration.
tcp option insert option-number { src-addr | value value } [ encode { binary | string } ]
undo tcp option insert option-number
The client information is not inserted into any TCP options.
option-number: Specifies a TCP option by its number. Valid values are 6, 7, 9 to 18, and 22 to 254.
src-addr: Inserts the real source IP address of the client to the TCP option.
value value: Inserts the specified information to the TCP option. The information is a string of 1 to 255 characters and supports the following variables:
·     %{is}: Client source IP address.
·     %{isl}: Client source IP address length. One byte.
·     %{ps}: Client source port number.
·     %{psl}: Client source port number length. One byte.
encode { binary | string }: Specifies the binary or string encoding mode. The default is binary mode.
Operating mechanism
This command inserts the specified information into the specified option in headers of TCP packets sent to the server.
You can execute this command multiple times to insert the client IP address to a maximum of five TCP options.
When a TCP parameter profile is used by a Layer 4 TCP virtual server, the specified content is inserted only to the TCP SYN initial packet. When the profile is used by a Layer 7 TCP virtual server, the specified content is inserted to the TCP negotiation packets and all data packets.
If you execute this command multiple times for the same TCP option, the most recent configuration takes effect.
This command takes effect only on TCP parameter profiles referenced by the following virtual servers:
·     HTTP virtual servers.
·     TCP virtual servers configured with SSL server policies.
·     TCP virtual servers operating at Layer 7.
·     MySQL virtual servers.
# In TCP parameter profile para2, insert the client IP address into TCP option 28.
[Sysname] parameter-profile para2 type tcp
[Sysname-para-tcp-para2] tcp option insert 28 src-addr
parameter-profile
tcp option remove
Use tcp option remove to remove the specified TCP option from TCP packet headers.
Use undo tcp option remove to remove the configuration.
tcp option remove option-number
undo tcp option remove option-number
The remove action is not specified for the TCP option in TCP packet headers. For the Timestamps option, the global action specified in the loadbalance tcp-timestamp-mode command applies.
option-number: Specifies a TCP option by its number in the range of 3 to 254.
Operating mechanism
This command removes the specified TCP option from headers of TCP packets sent to the server.
If you execute both the tcp option remove command for TCP option 8 and the loadbalance tcp-timestamp-mode command, the tcp option remove command takes effect.
You can execute this command multiple times to remove a maximum of five TCP options.
# In TCP parameter profile para2, remove TCP option 8 from TCP packet headers.
[Sysname-para-tcp-para2] tcp option remove 8
parameter-profile
tcp option preserve
tcp option rewrite
tcp option rewrite
Use tcp option rewrite to rewrite the specified TCP option in TCP packet headers.
Use undo tcp option rewrite to remove the configuration.
tcp option rewrite option-number
undo tcp option rewrite option-number
The rewrite action is not specified for the TCP option in TCP packet headers. For the Timestamps option, the global action specified in the loadbalance tcp-timestamp-mode command applies.
Operating mechanism
This command enables the LB device to rewrite the Timestamps option in the headers of TCP packets sent to the server. In the current software version, this command supports only the TCP Timestamps option with option number 8. This command rewrites the Timestamps option value in TCP packet headers with the current timestamp value of the device
If you execute both the tcp option rewrite and loadbalance tcp-timestamp-mode commands, the tcp option rewrite command takes effect.
# In TCP parameter profile pp1, rewrite TCP option 8 in TCP packet headers.
[Sysname-para-tcp-pp1] tcp option rewrite 8
parameter-profile
tcp option preserve
tcp option remove
tcp window-size
Use tcp window-size to configure the maximum local window size for TCP connections.
Use undo tcp window-size to restore the default.
tcp window-size size
The maximum local window size for TCP connections is 65535.
size: Specifies the maximum local window size for TCP connections, in the range of 8192 to 65535.
# Set the maximum local window size for TCP connections to 8192 for the TCP parameter profile pp3.
[Sysname-para-tcp-pp3] tcp window-size 8192
tcp-close
Use tcp-close to configure the method to close TCP connections.
Use undo tcp-close to restore the default.
tcp-close { fin | rst }
undo tcp-close
FIN packets are sent to close TCP connections.
Generic/HTTP/Diameter LB action view
fin: Closes TCP connections by sending FIN packets.
rst: Closes TCP connections by sending RST packets.
# In generic LB action lba1, configure the rst method to close TCP connections.
[Sysname-lba-generic-lba1] tcp-close rst
timeout (LB probe template view)
Use timeout to set the timeout time for probe responses.
Use undo timeout to restore the default.
undo timeout
The timeout time for probe responses is 3 seconds for ICMP probe packets and custom monitoring probe packets and is 5 seconds for HTTP passive probe packets.
ICMP LB probe template view
Custom-monitoring LB probe template view
timeout-value: Specifies the timeout time for probe responses, in the range of 1 to 60 seconds for ICMP probe packets, 1 to 255 seconds for HTTP passive probe packets, and 1 to 86400 seconds for custom monitoring probe packets.
Operating mechanism
After an HTTP passive LB probe template is referenced, the device monitors the responses of HTTP requests with URLs specified in the check-url command. If the response time for an HTTP request exceeds the specified timeout time, a URL error is recorded.
Recommended configuration
As a best practice, set the timeout time for probe responses to be smaller than the monitoring time (set by using the monitor-interval command).
# Set the timeout time for probe responses to 5 seconds in the ICMP template icmptplt.
[Sysname] loadbalance probe-template icmp icmptplt
[Sysname-lbpt-icmp-icmptplt] timeout 5
check-url
monitor-interval
timeout (sticky group view)
Use timeout to set the timeout timer for sticky entries.
timeout { indefinite | timeout-value }
undo timeout
The timeout timer for sticky entries is 86400 seconds for sticky groups of the HTTP cookie, HTTP passive, and UDP passive types, 180 seconds for sticky groups of the Diameter type, and 60 seconds for sticky groups of other types.
Sticky group view
indefinite: Specifies an indefinite timeout timer for sticky entries so that the sticky entries never age out. Sticky groups of the HTTP cookie type, HTTP passive type, and UDP passive type do not support this keyword.
timeout-value: Specifies the timeout timer in the range of 0 to 31536000 seconds for sticky groups of the HTTP cookie type and in the range of 10 to 604800 seconds for sticky groups of other types.
For sticky groups of the HTTP cookie type, the following principles apply:
·     If the sticky method is cookie insert or cookie rewrite, a timeout timer of 0 indicates session persistency.
·     If the sticky method is cookie get, a timeout timer of 0 indicates the timeout time for the sticky entries is 0 seconds.
# Set the timeout timer for sticky entries to 100 seconds in the address- and port-type sticky group sg1.
[Sysname-sticky-address-port-sg1] timeout 100
time-wait timeout
Use time-wait timeout to set the TIME_WAIT state timeout time for TCP connections.
Use undo time-wait timeout to restore the default.
time-wait timeout value
The TIME_WAIT state timeout time is 2 seconds for TCP connections.
value: Specifies the TIME_WAIT state timeout time in the range of 1 to 65535 seconds.
A TCP connection cannot be released until the TIME_WAIT timer expires. To release TCP connections faster and improve load balancing efficiency, use this command to set a shorter TIME_WAIT state timeout time.
# Set the TIME_WAIT state timeout time for TCP connections to 30 seconds in the TCP parameter profile pa1.
[Sysname] parameter-profile pa1 type tcp
[Sysname-para-tcp-pa1] time-wait timeout 30
traffic-group (virtual server view)
Use traffic-group to bind a cluster traffic group to a virtual server.
Use undo traffic-group to restore the default.
traffic-group traffic-group-id
undo traffic-group
No cluster traffic group is bound to a virtual server.
Virtual server view
traffic-group-id: Specifies a cluster traffic group by its ID, an integer in the range of 1 to 255.
In a cluster, a cluster traffic group is a basic logical unit that processes services. After you associate a cluster traffic group with a virtual server, traffic that matches the virtual server is processed by the cluster traffic group.
To specify a cluster traffic group for a virtual server, make sure the current device has been added to the traffic group.
Different types of virtual servers can use the same cluster traffic group.
# Bind cluster traffic group 1 to virtual server vs1.
[Sysname] virtual-server vs1 type http
[Sysname-vs-http-vs1] traffic-group 1
cluster traffic-group (High Availability Command Reference)
traffic-group (snat pool view)
Use traffic-group to specify a cluster traffic group for an SNAT address pool.
undo traffic-group
An SNAT address pool is not bound to any cluster traffic group.
SNAT address pool view
traffic-group-id: Specifies a cluster traffic group by its number in the range of 1 to 255.
In a cluster network, a traffic group is the basic logical unit for processing services in the cluster. You can specify a cluster traffic group for an SNAT address pool to enable the cluster traffic group to process the packets matching the SNAT address pool.
To specify a cluster traffic group for an SNAT address pool, make sure the current device has been added to the traffic group.
# Bind SNAT address pool sp to cluster traffic group 1.
[Sysname] loadbalance snat-pool sp
[Sysname-lbsnat-pool-addr-sp] traffic-group 1
translation-mode
Use translation-mode to configure a translation mode for a SNAT global policy.
Use undo translation-mode to restore the default.
translation-mode { auto-map | snat-pool pool-name }
No translation mode is configured for a SNAT global policy.
snat-pool pool-name: Specifies the SNAT address pool mode. The pool-name argument specifies the SNAT address pool name, a case-insensitive string of 1 to 255 characters.
Operating mechanism
The device supports the following translation modes in a SNAT global policy:
·     SNAT address pool—Translates the source IP address into an IP address in the specified SNAT address pool.
If SNAT is not configured for a server farm, the server farm uses SNAT global policies for address translation.
# Specify SNAT address pool sp for address translation in SNAT global policy sn1.
[Sysname-lb-snat-gp-sn1] translation-mode snat-pool sp
transparent enable
Use transparent enable to disable NAT for a server farm.
Use undo transparent enable to enable NAT for a server farm.
transparent enable
NAT is enabled for a server farm.
Server farm view
If the server farm is referenced by a virtual server of the HTTP type, the NAT feature takes effect even if it is disabled.
# Disable NAT for the server farm sf.
[Sysname-sfarm-sf] transparent enable
udp per-packet
Use udp per-packet to enable per-packet load balancing for UDP traffic for a virtual server.
Use undo udp per-packet to disable per-packet load balancing for UDP traffic for a virtual server.
udp per-packet
undo udp per-packet
Per-packet load balancing for UDP traffic is disabled for a virtual server.
UDP virtual server view
UDP-based SIP virtual server view
Operating mechanism
When per-packet load balancing for UDP traffic is disabled, the LB device distributes traffic matching the virtual server according to application type. Traffic of the same application type is distributed to one real server.
When per-packet load balancing for UDP traffic is enabled, the following results apply:
·     The LB device distributes traffic matching the virtual server on a per-packet basis.
·     The LB device does not collect statistics of connections on the virtual server or real server.
·     If NAT is not enabled for the referenced server farm, the LB device does not collect statistics of packets sent by the virtual server or real server.
·     The following configurations are still effective:
¡     Scheduling algorithm configured on the server farm referenced by the virtual server.
¡     Sticky method of the sticky group when the virtual server references the server farm.
Because packets of the same session have the same quintuple, the hash scheduling algorithm or the source IP address sticky method yields the same result for the packets. For example, if a server farm uses the hash scheduling algorithm or the source IP address sticky method, the LB device distributes UDP packets of the same session to one real server. In this case, the LB device cannot distribute UDP packets on a per-packet basis.
# Enable per-packet load balancing for UDP traffic for the UDP virtual server vs5.
[Sysname] virtual-server vs5 type udp
[Sysname-vs-udp-vs5] udp per-packet
username (virtual server view)
Use username to specify the login username and password of the MySQL database.
Use undo username to remove the login username and password of the MySQL database.
username username [ password { cipher | simple } string ]
undo username username
The login username and password of the MySQL database is not specified.
MySQL virtual server view
username: Specifies the username, a case-sensitive string of 1 to 63 characters.
password: Specifies the password. If you do not specify the password, the password is null.
string: Specifies the password string. Its plaintext form is a case-sensitive string of 1 to 127 characters. Its encrypted form is a case-sensitive string of 1 to 255 characters.
You can configure a maximum of 100 login users.
The specified login username and password must be the same as the actual login username and password of the MySQL database.
# Specify the username and password as root and 123456, respectively, for the MySQL virtual server vs1.
[Sysname] virtual-server vs1 type mysql
[Sysname-vs-mysql-vs1] username root password simple 123456
variable
Use variable to associate a variable with a server farm member.
Use undo variable to disassociate a variable from a server farm member.
variable variable-name value value
undo variable variable-name
No variable is associated with a server farm member.
variable-name: Specifies a variable name, a case-sensitive string of 1 to 63 characters.
value value: Specifies the variable value, a case-sensitive string of 1 to 127 characters.
# Associate a variable with variable name var1 and variable value 1 with server farm member rs.
[Sysname-sfarm-sf] real-server rs port 5001
[Sysname-sfarm-sf-#member#-rs-port-5001] variable var1 value _1
payload rewrite
vendor-id
Use vendor-id to configure the Vendor-Id AVP to be sent in Diameter messages.
Use undo vendor-id to restore the default.
vendor-id vendor-id
vendor-id undone
The Vendor-Id AVP is 25506, which indicates that the vendor is H3C.
Diameter session parameter profile view
vendor-id: Specify the Vendor-Id AVP in the range of 1 to 4294967295. By default, the Vendor-Id AVP is 25506, which indicates that the vendor is H3C.
During the Diameter capability exchange between the device and the peer, they exchange the Origin-Host, Origin-Realm, Vendor-Id, and Product-Name AVPs through CER and CEA messages. Use this command to specify the Vendor-Id AVP for the device to send to the peer during the Diameter capability exchange.
# Specify the Vendor-Id AVP as 25506 for Diameter session parameter profile dia.
[Sysname] parameter-profile dia type diameter-session
[Sysname-para-diameter-session-dia] vendor-id 25506
parameter-profile
version
Use version to configure the MySQL database version.
Use undo version to restore the default.
version { 5.0 | 5.1 | 5.5 | 5.6 | 5.7 }
undo version
The MySQL database version is 5.6.
{ 5.0 | 5.1 | 5.5 | 5.6 | 5.7 }: Specifies the MySQL database version number.
The LB device performs authentication for clients on behalf of the MySQL server and sends database initialization packets of the specified MySQL version to clients.
# Configure the MySQL database version as 5.7 for the MySQL virtual server vs1.
[Sysname-vs-mysql-vs1] version 5.7
virtual ip address
Use virtual ip address to configure an IPv4 address (VSIP) for a virtual server.
Use undo virtual ip address to remove an IPv4 address from a virtual server.
virtual ip address ipv4-address [ mask-length | mask ]
undo virtual ip address [ ipv4-address [ all ] ]
No IPv4 address is configured for a virtual server.
Virtual server view
ipv4-address: Specifies an IPv4 address. It cannot be a loopback address, multicast address, broadcast address, or an address in the format of 0.X.X.X (with a mask length of 32).
mask-length: Specifies a mask length in the range of 0 to 32. The default is 32. This argument is not supported by virtual servers of the fast HTTP type and HTTP type.
mask: Specifies a subnet mask. The default is 255.255.255.255. This argument is not supported by virtual servers of the fast HTTP type and HTTP type.
all: Deletes the IPv4 address.
Operating mechanism
You can configure an IPv4 address range or multiple individual IPv4 addresses for a virtual server. When you configure an IPv4 address range and execute this command multiple times, the most recent configuration takes effect. A virtual server supports either IPv4 address range or individual IPv4 addresses, but not both.
When you execute the undo virtual ip address command:
·     If you do not specify any parameters, the command deletes all IPv4 addresses of the virtual server.
·     If you specify the ipv4-address all option, the command deletes the IPv4 address.
If the IP address of an interface connected to a client is in the same network segment as the VSIP, you must perform the following tasks:
·     Set the IPv4 subnet mask length to 32 for the VSIP.
·     Specify an interface for sending gratuitous ARP or ND packets.
For a UDP SIP virtual server with port number 5060, when you enable per-packet load balancing for UDP traffic by using the udp per-packet command and enable SIP load balancing ALG by using the loadbalance alg sip command, the device does not support processing multiple IP addresses. Therefore, configure only one VSIP as a best practice.
# Configure the IPv4 address for the IP-type virtual server vs3 as 1.1.1.1/24.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] virtual ip address 1.1.1.1 24
arp-nd interface (virtual server view)
virtual ipv6 address
Use virtual ipv6 address to configure an IPv6 address (VSIP) for a virtual server.
Use undo virtual ipv6 address to remove an IPv6 address from a virtual server.
virtual ipv6 address ipv6-address [ prefix-length ]
undo virtual ipv6 address [ ipv6-address [ all ] ]
No IPv6 address is configured for a virtual server.
Virtual server view
ipv6-address: Specifies an IPv6 address, which cannot be a loopback address, IPv6 multicast address, link-local address, or all-zero address (when the prefix length is not 0).
prefix-length: Specifies a prefix length in the range of 0 to 128. The default is 128. This argument is not supported by virtual servers of the fast HTTP type and HTTP type.
all: Deletes the IPv6 address.
Operating mechanism
You can configure an IPv6 address range or multiple individual IPv6 addresses for a virtual server. When you configure an IPv6 address range and execute this command multiple times, the most recent configuration takes effect. A virtual server supports either IPv6 address range or individual IPv6 addresses, but not both.
When you execute the undo virtual ipv6 address command:
·     If you do not specify any parameters, the command deletes all IPv6 addresses of the virtual server.
·     If you specify the ipv6-address all option, the command deletes the IPv6 address.
If the IPv6 address of an interface connected to a client is in the same network segment as the VSIP, you must perform the following tasks:
·     Set the IPv6 prefix length to 128 for the VSIP.
# Configure the IPv6 address for the IP-type virtual server vs3 as 1001::1/64.
[Sysname-vs-ip-vs3] virtual ipv6 address 1001::1 64
virtual-server (system view)
Use virtual-server to create a virtual server and enter its view, or enter the view of an existing virtual server.
Use undo virtual-server to delete the specified virtual server.
virtual-server virtual-server-name [ type { diameter | fast-http | http | ip | link-ip | | mysql sip-tcp | sip-udp | radius | tcp | udp } ]
undo virtual-server virtual-server-name
No virtual servers exist.
virtual-server-name: Specifies the virtual server name, a case-insensitive string of 1 to 255 characters.
type { diameter | fast-http |http | ip | link-ip | mysql | sip-tcp | sip-udp | radius | tcp | udp }: Specifies the virtual server type as Diameter, fast HTTP, HTTP, IP, link-IP, MySQL, RADIUS, TCP-based SIP, UDP-based SIP, TCP, or UDP. When you create a virtual server, you must specify a virtual server type. You can enter an existing virtual server view without entering the type of the virtual server.
# Create the virtual server vs3 with the IP type, and enter virtual server view.
[Sysname-vs-ip-vs3]
vrrp vrid (SNAT address pool view)
Use vrrp vrid to bind an SNAT address pool to a VRRP group.
Use undo vrrp to remove the configuration.
vrrp [ ipv6 ] vrid virtual-router-id interface interface-type interface-number
undo [ ipv6 ] vrrp
An SNAT address pool is not bound to any VRRP group.
ipv6: Specifies an IPv6 VRRP group. If you do not specify this keyword, the SNAT group is bound to an IPv4 VRRP group.
virtual-router-id: Specifies a VRRP group by its number in the range of 1 to 255.
An SNAT address pool can be bound to a maximum of one IPv4 VRRP group and a maximum of one IPv6 VRRP group.
# Bind SNAT address pool sp1 to VRRP group 1.
[Sysname] loadbalance snat-pool spl
[Sysname-lbsnat-pool-sp1] vrrp vrid 1 interface gigabitethernet 1/0/1
weight (real server view)
Use weight to set the weight of a real server.
Use undo weight to restore the default.
weight weight-value
undo weight
The weight of a real server is 100.
Real server view
weight-value: Specifies the weight in the range of 1 to 255.
A greater weight value means a higher priority to be referenced.
# Set the weight of the real server rs to 150.
[Sysname] real-server rs
[Sysname-rserver-rs] weight 150
weight (server farm member view)
Use weight to set the weight of a server farm member.
weight weight-value
undo weight
The weight of a server farm member is 100.
Server farm member view
A greater weight value means a higher priority in scheduling.
# Set the weight of the server farm member rs1 to 150.
[Sysname-sfarm-sf] real-server rs1 port 80
[Sysname-sfarm-sf-#member#-rs1-port-80] weight 150
window-size
Use window-size to set the window size used for compression.
Use undo window-size to restore the default.
window-size size
undo window-size
The window size used for compression is 16 KB.
HTTP-compression parameter profile view
size: Specifies the window size in KB used for compression. The value can only be 1, 2, 4, 8, 16, or 32.
# Create the HTTP-compression parameter profile pa1, and set the window size used for compression to 32 KB.
[Sysname] parameter-profile pa1 type http-compress
[Sysname-para-http-compression-pa1] window-size 32
zero-window threshold
Use zero-window threshold to set the percentage threshold of zero-window packets for a TCP zero-window LB probe template.
Use undo zero-window threshold to restore the default.
zero-window threshold percentage
undo packet-zero-window
The percentage threshold of zero-window packets  is 40%.
TCP zero-window LB probe template view
percentage: Specifies the percentage threshold of zero-window packets, in the range of 1 to 100.
When the percentage of zero-window packets sent by a real server reaches the threshold, the protection action specified in the protect-action command is taken.
# In TCP zero-window LB probe template zerotplt, set the percentage threshold of zero-window packets to 20%.
<Sysname>system-view
[Sysname] loadbalance probe-template tcp-zero-window zerotplt
[Sysname-lbpt-tcp-zwnd-zerotplt] zero-window threshold 20
protect-action
