- 12-WLAN Advanced Features Command Reference
- 01-WLAN optimization commands
- 02-Hotspot 2.0 commands
- 03-WLAN probe commands
- 04-WSA commands
- 05-Wireless location commands
- 06-WLAN process maintenance commands
- 07-Bonjour gateway commands
- 08-WLAN mesh commands
- 09-AC hierarchy commands
- 10-WLAN forwarding commands
| 00-Preface | 111.61 KB |
Preface
This command reference describes the configuration commands for the following WLAN advanced features:
· WLAN optimization.
· Hotspot 2.0.
· WLAN probe.
· WSA.
· Wireless location.
· WLAN process maintenance.
· WLAN mesh.
· Bonjour gateway.
· AC hierarchy.
· WLAN forwarding.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
