09-Radio Resources Management
HomeSupportReference GuidesCommand ReferencesH3C WX2800X&WSG1800X Command References(R5605P11)-6W10009-Radio Resources Management
06-WLAN RRM commands
06-WLAN RRM commands 640.97 KB
WLAN RRM commands‌· 1
adjacency-factor 1
adjacency-factor radio-selection· 2
adjacent-channel interference trap threshold· 3
ap name· 4
calibrate-bandwidth mode· 5
calibrate-bandwidth monitoring time-range· 6
calibrate-bandwidth self-decisive· 7
calibrate-channel 2.4g channel-set-optimization enable· 9
calibrate-channel 2.4g channel-set-optimization neighbor-threshold· 10
calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent 11
calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent-per-set 12
calibrate-channel 2.4g channel-usage-threshold· 12
calibrate-channel 2.4g crc-error-threshold· 13
calibrate-channel 2.4g interference-threshold· 14
calibrate-channel 2.4g noise-threshold· 15
calibrate-channel 2.4g receive-service-traffic threshold· 16
calibrate-channel 2.4g retransmission-threshold· 17
calibrate-channel 2.4g tolerance-level 17
calibrate-channel 5g channel-usage-threshold· 18
calibrate-channel 5g crc-error-threshold· 19
calibrate-channel 5g interference-threshold· 20
calibrate-channel 5g noise-threshold· 21
calibrate-channel 5g receive-service-traffic threshold· 21
calibrate-channel 5g retransmission-threshold· 22
calibrate-channel 5g tolerance-level 23
calibrate-channel 6g channel-usage-threshold· 24
calibrate-channel 6g crc-error-threshold· 25
calibrate-channel 6g interference-threshold· 25
calibrate-channel 6g noise-threshold· 26
calibrate-channel 6g receive-service-traffic threshold· 27
calibrate-channel 6g retransmission-threshold· 28
calibrate-channel 6g tolerance-level 28
calibrate-channel channel-set-optimization· 29
calibrate-channel channel-set-optimization neighbor-threshold· 31
calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent 32
calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent-per-set 33
calibrate-channel interference-threshold· 34
calibrate-channel mode· 35
calibrate-channel monitoring time-range· 37
calibrate-channel pronto· 38
calibrate-channel receive-service-traffic threshold· 39
calibrate-channel self-decisive· 40
calibrate-channel self-decisive sensitivity· 42
calibrate-channel suppression· 43
calibrate-channel track spectrum-analysis· 44
calibrate-power 2.4g adjacency-factor 46
calibrate-power 2.4g coverage rssi-threshold· 47
calibrate-power 2.4g coverage weak-signal-client ratio· 47
calibrate-power 2.4g coverage weak-signal-client threshold· 48
calibrate-power 2.4g coverage weak-signal-packet ratio· 49
calibrate-power 2.4g coverage weak-signal-packet threshold· 50
calibrate-power 2.4g threshold· 51
calibrate-power 5g adjacency-factor 52
calibrate-power 5g coverage rssi-threshold· 53
calibrate-power 5g coverage weak-signal-client ratio· 53
calibrate-power 5g coverage weak-signal-client threshold· 54
calibrate-power 5g coverage weak-signal-packet ratio· 55
calibrate-power 5g coverage weak-signal-packet threshold· 56
calibrate-power 5g threshold· 57
calibrate-power 6g adjacency-factor 58
calibrate-power 6g coverage rssi-threshold· 58
calibrate-power 6g coverage weak-signal-client ratio· 59
calibrate-power 6g coverage weak-signal-client threshold· 60
calibrate-power 6g coverage weak-signal-packet ratio· 61
calibrate-power 6g coverage weak-signal-packet threshold· 62
calibrate-power 6g threshold· 63
calibrate-power coverage enable· 63
calibrate-power mode { coverage | custom | density } 66
calibrate-power mode { periodic | scheduled } 67
calibrate-power monitoring time-range· 68
calibrate-power power-range· 69
calibrate-power self-decisive· 71
calibrate-power threshold· 72
channel holddown-time· 73
channel-usage-threshold· 74
co-channel interference trap threshold· 75
crc-error-threshold· 76
description· 77
display wlan rrm baseline· 78
display wlan rrm baseline apply-history· 80
display wlan rrm-calibration-group· 81
display wlan rrm-history ap· 82
display wlan rrm-status ap· 84
interference-threshold· 87
power holddown-time· 87
rrm·· 88
scan-only· 89
snmp-agent trap enable wlan rrm·· 90
tolerance-level 90
wlan calibrate-bandwidth pronto ap· 91
wlan calibrate-bandwidth pronto use-monitoring-data ap· 92
wlan calibrate-channel pronto ap· 93
wlan calibrate-channel pronto use-monitoring-data ap· 93
wlan calibrate-power pronto ap· 94
wlan calibrate-power pronto use-monitoring-data ap· 95
wlan rrm baseline apply· 96
wlan rrm baseline remove· 96
wlan rrm baseline save· 97
wlan rrm calibration-bandwidth interval 98
wlan rrm calibration-channel ap· 98
wlan rrm calibration-channel interval 99
wlan rrm calibration-power interval 100
wlan rrm-calibration-group· 100
WLAN RRM commands‌
Support for the 6GHz band depends on the AP model and the local laws and regulations.
adjacency-factor
Use adjacency-factor to set the adjacency factor.
Use undo adjacency-factor to restore the default.
adjacency-factor neighbor
In RRM view, the configuration in an AP group's RRM view is used.
In an AP group's RRM view, the configuration in global configuration view is used.
RRM view
AP group's RRM view
neighbor: Specifies the adjacency factor in the range of 1 to 16.
Operating mechanism
The adjacency factor defines the quantity of manageable detected radios that trigger TPC and the ranking of the RSSI used for comparison with the power adjustment threshold. An AC can manage only radios associated with it.
For example, if the adjacency factor is 3, the AC performs TPC for a radio when the radio detects 3 other manageable radios. After ranking the radio's RSSIs detected by other manageable radios in descending order, the AC selects the third largest RSSI to compare with the power adjustment threshold.
The priorities of configurations in RRM view, an AP group's RRM view, and global configuration view are in descending order.
# Set the adjacency factor to 7 for radio 1 of AP ap1.
[Sysname] wlan ap ap1
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] rrm
[Sysname-wlan-ap-ap1-radio-1-rrm] adjacency-factor 7
# Set the adjacency factor to 7 for radio 1 of APs in AP group group1.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] ap-model WA6320
[Sysname-wlan-ap-group-group1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1] rrm
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] adjacency-factor 7
Use adjacency-factor radio-selection to specify the type of radios to participate in TPC calculation.
Use undo adjacency-factor radio-selection to restore the default.
adjacency-factor radio-selection { all-channel | overlapping-channel }
In an AP group's RRM view, all-channel radios participate in TPC calculation.
RRM view
AP group's RRM view
all-channel: Specifies radios detected on all channels.
overlapping-channel: Specifies radios detected on overlapping channels.
Radios that can participate in the TPC calculation for a radio include the following types:
·     All-channel radios—Include all radios that detect the radio and are managed by the same AC as the radio.
·     Overlapping-channel radios—Include radios that detect the radio on a channel overlapping with the radio's transmit channel and are managed by the same AC as the radio.
# Specify the type of radios to participate in TPC calculation as overlapping-channel for radio 1 of AP ap1.
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1-radio-1-rrm] adjacency-factor radio-selection overlapping-channel
# Specify the type of radios to participate in TPC calculation as overlapping-channel for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] adjacency-factor radio-selection overlapping-channel
Use adjacent-channel interference trap threshold to set the trap threshold for adjacent-channel interference.
Use undo adjacent-channel interference trap threshold to restore the default.
adjacent-channel interference trap threshold threshold
In an AP group's RRM view, the configuration in an AP group's global radio RRM view is used.
In an AP group's global radio RRM view, the configuration in global configuration view is used.
In global configuration view, the trap threshold for adjacent-channel interference is 60 dBm.
RRM view
AP group's RRM view
Global configuration view
threshold threshold: Specifies the trap threshold in the range of 10 to 90 dBm.
When the adjacent-channel interference exceeds the trap threshold, the system generates an SNMP notification to inform the network administrator.
# Set the trap threshold for adjacent-channel interference to 16 dBm for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] adjacent-channel interference trap threshold 16
# Set the trap threshold for adjacent-channel interference to 16 dBm for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] adjacent-channel interference trap threshold 16
# Set the trap threshold for adjacent-channel interference to 16 dBm for 5GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1] radio 5g
[Sysname-wlan-ap-group-group1-radio-5g] rrm
[Sysname-wlan-ap-group-group1-radio-5g-rrm] adjacent-channel interference trap threshold 16
# Set the trap threshold for adjacent-channel interference to 16 dBm in global configuration view.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] adjacent-channel interference trap threshold 16
ap name
Use ap name to add a radio to an RRM holddown group.
Use undo ap name to remove one or all radios from an RRM holddown group.
ap name ap-name radio radio-id
undo ap { name ap-name [ radio radio-id ] | all }
No radios exist in an RRM holddown group.
RRM holddown group view
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The name can contain letters, numbers, underlines (_), left brackets ([), right brackets (]), slashes (/), and hyphens (-). The specified AP must already exist.
radio radio-id: Specifies a radio by its ID. If you do not specify this option when executing the undo command, the command deletes all radios of the specified AP from the group.
all: Specifies all radios.
A radio can belong to only one RRM holddown group. Adding a radio to a new RRM holddown group removes the radio from the old RRM holddown group.
# Add radio 2 of AP ap1 to RRM holddown group 10.
[Sysname] wlan rrm-calibration-group 10
[Sysname-wlan-rrm-calibration-group-10] ap name ap1 radio 2
Use calibrate-bandwidth mode to set the automatic bandwidth adjustment mode.
Use undo calibrate-bandwidth mode to restore the default.
calibrate-bandwidth mode { periodic | scheduled }
In global configuration view, the automatic bandwidth adjustment mode is periodic.
RRM view
AP group's RRM view
In periodic mode, the AC examines the channel quality at the specified interval and assesses whether bandwidth adjustment is required based on the detection results.
In scheduled mode, the AC collects channel quality information during the specified period, evaluates the channel quality, and assesses whether bandwidth calibration is required.
# Set the automatic bandwidth adjustment mode to scheduled for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-bandwidth self-decisive enable
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-bandwidth mode scheduled
# Set the automatic bandwidth adjustment mode to scheduled for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-bandwidth self-decisive enable
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-bandwidth mode scheduled
# Set the automatic bandwidth adjustment mode to scheduled for 5 GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1- radio-5g-rrm] calibrate-bandwidth self-decisive enble
[Sysname-wlan-ap-group-group1-radio-5g-rrm] calibrate-bandwidth mode schedule
# Set the automatic bandwidth adjustment mode to scheduled in global configuration view.
[Sysname-wlan-global-configuration] calibrate-bandwidth mode schedule
Use calibrate-bandwidth monitoring time-range to specify a time range for bandwidth monitoring.
Use undo calibrate-bandwidth monitoring time-range to remove the specified time range for bandwidth monitoring.
calibrate-bandwidth monitoring time-range time-range-name
In global configuration view, no time range is specified for bandwidth monitoring.
RRM view
AP group's RRM view
time-range-name: Specifies the name of a time range, a case-insensitive string of 1 to 32 characters. To avoid confusion, the time range name cannot be all.
After you specify a time range, the AC gathers radio environment information within the time range and generates a channel report and a neighbor report to provide a basis for bandwidth adjustment.
# Specify time range time1 for bandwidth monitoring for radio 1 on AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-bandwidth monitoring time-range time1
# Specify time range time1 for bandwidth monitoring for radio 1 on the WA6320 AP in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-bandwidth monitoring time-range time1
# Specify time range time1 for bandwidth monitoring for 5 GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1- radio-5g-rrm] calibrate-bandwidth monitoring time-range time1
# Specify time range time1 for bandwidth monitoring in global configuration view.
[Sysname-wlan-global-configuration] calibrate-bandwidth monitoring time-range time1
Use calibrate-bandwidth self-decisive enable to enable automatic bandwidth adjustment.
Use calibrate-bandwidth self-decisive disable to disable automatic bandwidth adjustment.
Use undo calibrate-bandwidth self-decisive to restore the default.
In RRM view/AP group's RRM view/AP group's global radio RRM view:
calibrate-bandwidth self-decisive { disable | enable }
In global configuration view:
calibrate-bandwidth self-decisive enable { 5g | 6g | all }
undo calibrate-bandwidth self-decisive enable { 5g | 6g | all }
In global configuration view, automatic bandwidth adjustment is disabled.
RRM view
AP group's RRM view
5g: Specifies 5 GHz radios.
6g: Specifies 6 GHz radios.
all: Specifies both 5 GHz and 6 GHz radios.
Operating mechanism
With automatic bandwidth adjustment enabled, the AC starts channel quality detection when the automatic bandwidth adjustment interval is reached, and determines whether to perform bandwidth adjustment. It decreases the bandwidth for a radio to reduce interference if the number of neighbor radios for that radio is large, and increases the bandwidth to increase transmission rate if the number is small.
This command takes effect only on 5 GHz and 6GHz radios.
# Enable automatic bandwidth adjustment for radio 1 of AP ap1.
# Enable automatic bandwidth adjustment for radio 1 of APs in AP group group1.
# Enable automatic bandwidth adjustment for 5 GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1- radio-5g-rrm] calibrate-bandwidth self-decisive enable
# Enable automatic bandwidth adjustment for all 5GHz radios in global configuration view.
[Sysname-wlan-global-configuration] calibrate-bandwidth self-decisive enable 5g
Use calibrate-channel 2.4g channel-set-optimization enable to enable orthogonal channel optimization for 2.4 GHz radios.
Use undo calibrate-channel 2.4g channel-set-optimization enable to disable orthogonal channel optimization for 2.4 GHz radios.
Orthogonal channel optimization for 2.4 GHz radios is enabled.
Application scenarios
In high-density deployment with APs of different vendors, severe interference might occur for 2.4 GHz radios because these APs cannot be managed in a unified manner and might use different orthogonal channel groups. This greatly affects the user experience.
Operating mechanism
This feature enables the AC to adopt the orthogonal channel group most used by neighbor radios on third-party APs in auto DFS. This operation can reduce the inter-channel interference between APs of different vendors to the maximum degree.
The device supports detecting the (1, 6, 11), (1, 7, 13), (2, 7, 12), (3, 8, 13), and (4, 9, 14) orthogonal channel groups.
Neighbor radio includes the following types:
·     Managed neighbor—Detected AP radios managed by the same AC.
·     Unmanaged neighbor—Detected AP radios managed by another AC.
With this feature enabled, the device performs orthogonal channel optimization for 2.4 GHz radios during auto-DFS when all the following conditions are met:
·     The total number of neighbors reaches or exceeds the configured threshold.
·     The unmanaged neighbor ratio (unmanaged neighbors/total neighbors) reaches or exceeds the configured threshold.
·     The unmanaged neighbor ratio for a single orthogonal channel group (unmanaged neighbors/total neighbors) reaches or exceeds the configured threshold.
# Disable orthogonal channel optimization for 2.4 GHz radios.
[Sysname-wlan-global-configuration] undo calibrate-channel 2.4g channel-set-optimization enable
Use calibrate-channel 2.4g channel-set-optimization neighbor-threshold to set the neighbor quantity threshold.
Use undo calibrate-channel 2.4g channel-set-optimization neighbor-threshold to restore the default.
calibrate-channel 2.4g channel-set-optimization neighbor-threshold count
The neighbor quantity threshold is 10.
count: Sets the neighbor quantity threshold in the range of 1 to 1000.
# Set the neighbor quantity threshold to 11.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g channel-set-optimization neighbor-threshold 11
Use calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent to set the unmanaged neighbor ratio threshold.
Use undo calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent to restore the default.
calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent percent
The neighbor radio threshold is 50%.
percent: Sets the unmanaged neighbor ratio threshold in the range of 1 to 100.
# Set the unmanaged neighbor ratio threshold to 20%.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent 20
Use calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent-per-set to set the unmanaged neighbor ratio threshold for a single orthogonal channel group.
Use undo calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent-per-set to restore the default.
calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent-per-set percent
The unmanaged neighbor ratio threshold is 10% for a single orthogonal channel group.
percent: Sets the unmanaged neighbor ratio threshold for a single orthogonal channel group in the range of 1 to 100.
# Set the unmanaged neighbor ratio threshold to 20% for a single orthogonal channel group.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g channel-set-optimization neighbor-unmanaged-threshold percent-per-set 20
Use calibrate-channel 2.4g channel-usage-threshold to set the channel usage threshold for 2.4 GHz radios.
Use undo calibrate-channel 2.4g channel-usage-threshold to restore the default.
calibrate-channel 2.4g channel-usage-threshold percent percent
undo calibrate-channel 2.4g channel-usage-threshold percent
The channel usage threshold is 60 for 2.4 GHz radios.
percent percent: Specifies the channel usage threshold in percent. The value range is 1 to 100.
Operating mechanism
Auto DFS is triggered when both the channel usage threshold and interference ratio threshold are reached or exceeded, but the received service traffic fails to reach the service traffic threshold.
·     Channel usage threshold—Proportion of channel resources used for packet transmitting and receiving.
·     Interference ratio threshold—Proportion of channel resources used by interferences to the total used channel resources.
·     Service traffic threshold—Proportion of received service traffic to the total received traffic.
# Set the channel usage threshold to 40 for 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g channel-usage-threshold percent 40
Use calibrate-channel 2.4g crc-error-threshold to set the CRC error threshold for 2.4 GHz radios.
Use undo calibrate-channel 2.4g crc-error-threshold to restore the default.
calibrate-channel 2.4g crc-error-threshold percent
The CRC error threshold is 0 for 2.4 GHz radios.
percent percent: Specifies the CRC error threshold in percent. The value range is 0 to 100. Setting the threshold to 0 disables the system from using the CRC error threshold as a trigger for auto DFS.
Operating mechanism
When the AC detects that the proportion of CRC-error packets in all 802.11 packets reaches or exceeds the CRC error threshold on a 2.4 GHz radio, it performs auto DFS for the radio.
# Set the CRC error threshold to 10 for 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g crc-error-threshold 10
crc-error-threshold
Use calibrate-channel 2.4g interference-threshold to set the interference threshold for 2.4 GHz radios.
Use undo calibrate-channel 2.4g interference-threshold to restore the default.
calibrate-channel 2.4g interference-threshold percent percent
undo calibrate-channel 2.4g interference-threshold percent
The interference threshold is 70 for 2.4 GHz radios.
percent percent: Specifies the interference threshold in percent. The value range is 0 to 100.
Operating mechanism
The smaller the threshold is, the more frequent DFS will be. Set a proper interference radio threshold as needed.
# Set the interference threshold to 50 for 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g interference-threshold percent 50
Use calibrate-channel 2.4g noise-threshold to set the noise threshold for 2.4 GHz radios.
Use undo calibrate-channel 2.4g noise-threshold to restore the default.
calibrate-channel 2.4g noise-threshold value
The noise threshold is 0 for 2.4 GHz radios.
value: Specifies the noise threshold in the range of 0 to 127, which represents power 0 to –127 dBm. The larger the noise threshold, the smaller the noise. Setting the threshold to 0 disables the system from using the noise threshold as a trigger for auto DFS.
Auto DFS is triggered when the noise detected by the AC in the working channel of a 2.4 GHz radio reaches or exceeds the threshold.
# Set the noise threshold to 50 for 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g noise-threshold 50
Use calibrate-channel 2.4g receive-service-traffic threshold to set received service traffic threshold for 2.4 GHz radios.
Use undo calibrate-channel 2.4g receive-service-traffic threshold to restore the default.
calibrate-channel 2.4g receive-service-traffic threshold value
The received service traffic threshold is 10 Mbps for 2.4 GHz radios.
threshold value: Specifies the received service traffic threshold in the range of 0 to 1000 Mbps.
Operating mechanism
Received traffic includes interference and service traffic. A low service traffic ratio indicates a severe interference condition.
# Set the received service traffic threshold to 30 Mbps for 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g receive-service-traffic threshold 30
Use calibrate-channel 2.4g retransmission-threshold to set the retransmission threshold for 2.4 GHz radios.
calibrate-channel 2.4g retransmission-threshold value
undo calibrate-channel 2.4g retransmission-threshold
The retransmission threshold is 0 for 2.4 GHz radios.
value: Specifies the retransmission threshold in percent. The value range is 0 to 100. Setting the threshold to 0 disables the system from using the retransmission threshold as a trigger for auto DFS.
Auto DFS is triggered if the retransmission rate on a 2.4 GHz radio reaches or exceeds the retransmission threshold.
# Set the retransmission threshold to 50 for 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g retransmission-threshold 50
Use calibrate-channel 2.4g tolerance-level to set the tolerance level for 2.4 GHz radios.
Use undo calibrate-channel 2.4g tolerance-level to restore the default.
calibrate-channel 2.4g tolerance-level percent
The tolerance level is 1 for 2.4 GHz radios.
percent: Specifies the tolerance level in percent. The value range is 0 to 100. Setting the level to 0 disables the system from using the tolerance level as a trigger for auto DFS.
Operating mechanism
The tolerance level defines the quality gap between the optimal channel and the current channel that can trigger a channel change. The AC applies the optimal channel to a radio only when the tolerance level is reached.
# Set the tolerance level to 10 for 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g tolerance-level 10
tolerance-level
Use calibrate-channel 5g channel-usage-threshold to set the channel usage threshold for 5 GHz radios.
Use undo calibrate-channel 5g channel-usage-threshold to restore the default.
calibrate-channel 5g channel-usage-threshold percent percent
undo calibrate-channel 5g channel-usage-threshold percent
The channel usage threshold is 60 for 5 GHz radios.
Operating mechanism
Auto DFS is triggered when both the channel usage threshold and interference ratio threshold are reached or exceeded but the received service traffic does not reach the service traffic threshold.
# Set the channel usage threshold to 40 for 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 5g channel-usage-threshold percent 40
Use calibrate-channel 5g crc-error-threshold to set the CRC error threshold for 5 GHz radios.
Use undo calibrate-channel 5g crc-error-threshold to restore the default.
calibrate-channel 5g crc-error-threshold percent
The CRC error threshold is 0 for 5 GHz radios.
Operating mechanism
When the AC detects that the proportion of CRC-error packets in all 802.11 packets reaches or exceeds the CRC error threshold on a 5 GHz radio, it performs auto DFS for the radio.
# Set the CRC error threshold to 10 for 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 5g crc-error-threshold 10
crc-error-threshold
Use calibrate-channel 5g interference-threshold to set the interference threshold for 5 GHz radios.
Use undo calibrate-channel 5g interference-threshold to restore the default.
calibrate-channel 5g interference-threshold percent percent
undo calibrate-channel 5g interference-threshold percent
The interference threshold is 70 for 5 GHz radios.
Operating mechanism
# Set the interference threshold to 50 for 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 5g interference-threshold percent 50
Use calibrate-channel 5g noise-threshold to set the noise threshold for 5 GHz radios.
Use undo calibrate-channel 5g noise-threshold to restore the default.
calibrate-channel 5g noise-threshold value
The noise threshold is 0 for 5 GHz radios.
Auto DFS is triggered when the noise detected by the AC in the 5 GHz working channel reaches or exceeds the threshold.
# Set the noise threshold to 50 for 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 5g noise-threshold 50
Use calibrate-channel 5g receive-service-traffic threshold to set the received service traffic threshold for 5 GHz radios.
Use undo calibrate-channel 5g receive-service-traffic threshold to restore the default.
calibrate-channel 5g receive-service-traffic threshold value
The received service traffic threshold is 10 Mbps for 5 GHz radios.
Operating mechanism
# Set the received service traffic threshold to 30 Mbps for 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 5g receive-service-traffic threshold 30
Use calibrate-channel 5g retransmission-threshold to set the retransmission threshold for 5 GHz radios.
calibrate-channel 5g retransmission-threshold value
undo calibrate-channel 5g retransmission-threshold
The retransmission threshold for 5 GHz is 0.
Auto DFS is triggered if the retransmission rate on a 5 GHz radio reaches or exceeds the retransmission threshold.
# Set the retransmission threshold to 50 for 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 5g retransmission-threshold 50
Use calibrate-channel 5g tolerance-level to set the tolerance level for 5 GHz radios.
Use undo calibrate-channel 5g tolerance-level to restore the default.
calibrate-channel 5g tolerance-level percent
The tolerance level is 0 for 5 GHz radios.
Operating mechanism
# Set the tolerance level to 10 for 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 5g tolerance-level 10
tolerance-level
Use calibrate-channel 6g channel-usage-threshold to set the channel usage threshold for 6 GHz radios.
Use undo calibrate-channel 6g channel-usage-threshold to restore the default.
calibrate-channel 6g channel-usage-threshold percent percent
undo calibrate-channel 6g channel-usage-threshold percent
The channel usage threshold is 60 for 6 GHz radios.
Set the channel usage threshold to 40 for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 6g channel-usage-threshold percent 40
Use calibrate-channel 6g crc-error-threshold to set the CRC error threshold for 6 GHz radios.
Use undo calibrate-channel 6g crc-error-threshold to restore the default.
calibrate-channel 6g crc-error-threshold percent
The CRC error threshold is 0 for 6 GHz radios.
When the AC detects that the proportion of CRC-error packets in all 802.11 packets reaches or exceeds the CRC error threshold on a 6 GHz radio, it performs auto DFS for the radio.
# Set the CRC error threshold to 10 for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 6g crc-error-threshold 10
crc-error-threshold
Use calibrate-channel 6g interference-threshold to set the interference threshold for 6 GHz radios.
Use undo calibrate-channel 6g interference-threshold to restore the default.
calibrate-channel 6g interference-threshold percent percent
undo calibrate-channel 6g interference-threshold percent
The interference threshold is 70 for 6 GHz radios.
# Set the interference threshold to 50 for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 6g interference-threshold percent 50
Use calibrate-channel 6g noise-threshold to set the noise threshold for 6 GHz radios.
Use undo calibrate-channel 6g noise-threshold to restore the default.
calibrate-channel 6g noise-threshold value
The noise threshold is 0 for 6 GHz radios.
Auto DFS is triggered when the noise detected by the AC in the 6 GHz working channel reaches or exceeds the threshold.
# Set the noise threshold to 50 for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 6g noise-threshold 50
Use calibrate-channel 6g receive-service-traffic threshold to set the received service traffic threshold for 6 GHz radios.
Use undo calibrate-channel 6g receive-service-traffic threshold to restore the default.
calibrate-channel 6g receive-service-traffic threshold value
The received service traffic threshold is 10 Mbps for 6 GHz radios.
# Set the received service traffic threshold to 30 Mbps for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 6g receive-service-traffic threshold 30
Use calibrate-channel 6g retransmission-threshold to set the retransmission threshold for 6 GHz radios.
Use undo calibrate-channel 6g retransmission-threshold to restore the default.
calibrate-channel 6g retransmission-threshold value
The retransmission threshold for 6 GHz is 0.
Auto DFS is triggered if the retransmission rate on a 6 GHz radio reaches or exceeds the retransmission threshold.
# Set the retransmission threshold to 50 for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 6g retransmission-threshold 50
Use calibrate-channel 6g tolerance-level to set the tolerance level for 6 GHz radios.
Use undo calibrate-channel 6g tolerance-level to restore the default.
calibrate-channel 6g tolerance-level percent
The tolerance level is 0 for 6 GHz radios.
# Set the tolerance level to 10 for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 6g tolerance-level 10
tolerance-level
Use calibrate-channel channel-set-optimization enable to enable orthogonal channel optimization for 2.4 GHz radios.
Use calibrate-channel channel-set-optimization disable to disable orthogonal channel optimization for 2.4 GHz radios.
Use undo calibrate-channel channel-set-optimization to restore the default.
calibrate-channel channel-set-optimization { disable | enable }
In RRM view, the radio uses the RRM configuration in the AP group's RRM view.
In an AP group's RRM view, the radio uses the RRM configuration in global radio RRM view.
In an AP group's global radio RRM view, the radio uses the global configuration.
RRM view
AP group's RRM view
This command takes effect only on 2.4 GHz radios.
The priorities of configurations in RRM view, an AP group's RRM view, an AP group’s global radio RRM view, and global configuration view are in descending order.
# Enable orthogonal channel optimization for the 2.4 GHz radio on AP ap1.
[Sysname-wlan-ap-ap1] radio 2
[Sysname-wlan-ap-ap1-radio-2] rrm
[Sysname-wlan-ap-ap1-radio-2-rrm] calibrate-channel channel-set-optimization enable
# Enable orthogonal channel optimization for 2.4 GHz radios on WA6320 APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320] radio 2
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-2] rrm
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-2-rrm] calibrate-channel channel-set-optimization enable
# Enable orthogonal channel optimization for 2.4 GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1] radio 2.4g
[Sysname-wlan-ap-group-group1-radio-2.4g] rrm
[Sysname-wlan-ap-group-group1-radio-2.4g-rrm] calibrate-channel channel-set-optimization enable
Use calibrate-channel channel-set-optimization neighbor-threshold to set the neighbor quantity threshold.
Use undo calibrate-channel channel-set-optimization neighbor-threshold to restore the default.
calibrate-channel channel-set-optimization neighbor-threshold count
RRM view
AP group's RRM view
# Set the neighbor quantity threshold to 11 on AP ap1.
[Sysname-wlan-ap-ap1-radio-2-rrm] calibrate-channel channel-set-optimization neighbor-threshold 11
# Set the neighbor quantity threshold to 11 on WA6320 APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-2-rrm] calibrate-channel channel-set-optimization neighbor-threshold 11
Use calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent to set the unmanaged neighbor ratio threshold.
Use undo calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent to restore the default.
calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent percent
RRM view
AP group's RRM view
# Set the unmanaged neighbor ratio threshold to 20% on AP ap1.
[Sysname-wlan-ap-ap1-radio-2-rrm] calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent 20
# Set the unmanaged neighbor ratio threshold to 20% on WA6320 APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-2-rrm] calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent 20
Use calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent-per-set to set the unmanaged neighbor ratio threshold for a single orthogonal channel group.
Use undo calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent-per-set to restore the default.
calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent-per-set percent
RRM view
AP group's RRM view
# Set the unmanaged neighbor ratio threshold to 20% for a single orthogonal channel group on AP ap1.
[Sysname-wlan-ap-ap1-radio-2-rrm] calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent-per-set 20
# Set the unmanaged neighbor ratio threshold to 20% for a single orthogonal channel group on WA6320 APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-2-rrm] calibrate-channel channel-set-optimization neighbor-unmanaged-threshold percent-per-set 20
Use calibrate-channel interference-threshold to set the interference ratio threshold.
Use undo calibrate-channel interference-threshold to restore the default.
calibrate-channel interference-threshold percent percent
undo calibrate-channel interference-threshold percent
RRM view
AP group's RRM view
percent percent: Specifies the interference ratio threshold in the range of 0 to 100, in percent.
Operating mechanism
# Set the interference ratio threshold to 50 for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel interference-threshold percent 50
# Set the interference ratio threshold to 50 for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel interference-threshold percent 50
Use calibrate-channel mode to set the auto-DFS mode.
Use undo calibrate-channel mode to restore the default.
calibrate-channel mode { periodic | scheduled }
calibrate-channel { 2.4g | 5g } mode { periodic | scheduled }
undo calibrate-channel { 2.4g | 5g } mode { periodic | scheduled }
In global configuration view, the auto-DFS mode is periodic.
RRM view
AP group's RRM view
periodic: Specifies periodic auto-DFS.
scheduled: Specifies scheduled auto-DFS.
2.4g: Specifies 2.4 GHz radios.
In periodic auto-DFS mode, the AC automatically performs DFS for a radio at the channel calibration interval.
In scheduled auto-DFS mode, the AC performs DFS at the specified time in a time range. Use this mode when interference is severe to avoid affecting ongoing wireless services.
# Set the auto-DFS mode to scheduled for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel self-decisive enable
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel mode scheduled
# Set the auto-DFS mode to scheduled for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel self-decisive enable
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel mode scheduled
# Set the auto-DFS mode to scheduled for 5 GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1- radio-5g-rrm] calibrate-channel mode schedule
# Set the auto-DFS mode to scheduled for the 5GHz band in global configuration view.
[Sysname-wlan-global-configuration] calibrate-channel 5g mode scheduled
Use calibrate-channel monitoring time-range to specify a time range for channel monitoring.
Use undo calibrate-channel monitoring time-range to delete the specified time range for channel monitoring.
calibrate-channel monitoring time-range time-range-name
calibrate-channel { 2.4g | 5g } monitoring time-range time-range-name
undo calibrate-channel { 2.4g | 5g } monitoring time-range
In global configuration view, no time range is specified for channel monitoring.
RRM view
AP group's RRM view
time-range-name: Specifies the name of a time range, a case-insensitive string of 1 to 32 characters. The string cannot be all.
In scheduled auto-DFS, the AC collects statistics in the specified time range to generate channel reports and neighbor reports.
# Specify a time range for channel monitoring for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel monitoring time-range time1
# Specify a time range for channel monitoring for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel monitoring time-range time1
# Specify a time range for channel monitoring for 5 GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1-radio-2.4g-rrm] calibrate-channel monitoring time-range time1
# Specify a time range for channel monitoring in global configuration view.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g monitoring time-range time1
time-range
Use calibrate-channel pronto to execute scheduled auto-DFS.
RRM view
AP group's RRM view
# Create a job and assign commands to the job for radio 1 of AP ap1.
[Sysname] scheduler job calibration1
[Sysname-job-calibration1] command 1 system-view
[Sysname-job-calibration1] command 2 wlan ap ap1
[Sysname-job-calibration1] command 3 radio 1
[Sysname-job-calibration1] command 4 rrm
[Sysname-job-calibration1] command 5 calibrate-channel pronto
# Create a job and assign commands to the job for radio 1 of APs in AP group group1.
[Sysname] scheduler job calibration2
[Sysname-job-calibration2] command 1 system-view
[Sysname-job-calibration2] command 2 wlan ap-group g1
[Sysname-job-calibration2] command 3 ap-model WA6320
[Sysname-job-calibration2] command 4 radio 1
[Sysname-job-calibration2] command 5 rrm
[Sysname-job-calibration2] command 6 calibrate-channel pronto
Use calibrate-channel receive-service-traffic threshold to set the received service traffic threshold.
Use undo calibrate-channel receive-service-traffic threshold to restore the default.
calibrate-channel receive-service-traffic threshold value
RRM view
AP group's RRM view
threshold value: Specifies the received service traffic threshold, in the range of 0 to 1000 Mbps.
Operating mechanism
# Set the received service traffic threshold to 30 Mbps for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel receive-service-traffic threshold 30
# Set the received service traffic threshold to 30 Mbps for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel receive-service-traffic threshold 30
Use calibrate-channel self-decisive enable to enable auto-DFS.
Use calibrate-channel self-decisive disable to disable auto-DFS.
Use undo calibrate-channel self-decisive to restore the default.
calibrate-channel self-decisive { disable | enable }
calibrate-channel self-decisive enable { 2.4g | 5g | 6g | all }
undo calibrate-channel self-decisive enable { 2.4g | 5g | 6g | all }
In global configuration view, auto-DFS is disabled.
RRM view
AP group's RRM view
2.4g: Specifies the 2.4GHz frequency band.
5g: Specifies the 5GHz frequency band.
6g: Specifies the 6GHz frequency band.
all: Specifies the 2.4GHz, 5GHz, and 6GHz frequency bands.
# Enable auto-DFS for radio 1 of AP ap1.
# Enable auto-DFS for radio 1 of APs in AP group group1.
# Enable auto-DFS for 2.4 GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1-radio-2.4g-rrm] calibrate-channel self-decisive enable
# Enable auto-DFS globally for both the 2.4GHz and 5GHz frequency bands.
[Sysname-wlan-global-configuration] calibrate-channel self-decisive enable all
Use calibrate-channel self-decisive sensitivity to set the DFS sensitivity mode.
Use calibrate-channel self-decisive sensitivity to restore the default.
calibrate-channel self-decisive sensitivity { custom | high | low | medium }
undo calibrate-channel self-decisive sensitivity
In an AP group's RRM view, the DFS sensitivity mode is custom.
RRM view
AP group's RRM view
custom: Specifies the custom sensitivity mode.
high: Specifies the high sensitivity mode.
low: Specifies the low sensitivity mode.
medium: Specifies the medium sensitivity mode.
DFS configured with a higher sensitivity can be triggered more easily.
DFS trigger parameters will be restored to the default if you change the sensitivity mode. The default settings vary by sensitivity mode. You cannot edit the default settings. Record the configured DFS trigger parameters if necessary before you change the sensitivity mode from custom to low, medium, or high.
You can configure DFS trigger parameters only when the sensitivity mode is custom.
# Set the DFS sensitivity mode to low for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel self-decisive sensitivity low
# Set the DFS sensitivity mode to high for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel self-decisive sensitivity high
crc-error-threshold
tolerance-level
Use calibrate-channel suppression enable to enable DFS suppression.
Use calibrate-channel suppression disable to disable DFS suppression.
Use undo calibrate-channel suppression to restore the default.
calibrate-channel suppression { disable | enable [ client-number number ] }
calibrate-channel { 2.4g | 5g } suppression enable [ client-number number ]
undo calibrate-channel { 2.4g | 5g } suppression enable
In global configuration view, DFS suppression is disabled.
RRM view
AP group's RRM view
client-number number: Specifies the online client threshold in the range of 1 to 124. The value is 124 by default.
Operating mechanism
For wireless service stability, you can configure DFS suppression to suppress periodic auto-DFS when the online client quantity reaches the specified threshold.
This feature takes effect only when periodic auto-DFS is configured.
# Enable DFS suppression for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel mode periodic
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel suppression enable
# Disable DFS suppression for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel mode periodic
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel suppression disable
# Enable DFS suppression for 2.4 GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1-radio-2.4g-rrm] calibrate-channel suppression enable client-number 100
# Enable DFS suppression for 2.4 GHz radios in global configuration view.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g suppression enable client-number 100
Use calibrate-channel track spectrum-analysis enable to enable WSA collaboration.
Use calibrate-channel track spectrum-analysis disable to disable WSA collaboration.
Use undo calibrate-channel track spectrum-analysis to restore the default.
calibrate-channel track spectrum-analysis { disable | enable }
calibrate-channel track spectrum-analysis { disable | enable } { 2.4g | 5g | all }
undo calibrate-channel track spectrum-analysis enable { 2.4g | 5g | all }
In global configuration view, WSA collaboration is disabled.
RRM view
AP group's RRM view
When you enable Wireless Spectrum Analysis (WSA) collaboration, the system performs DFS when WSA detects that the channel quality is lower than the value of the specified quality level. For more information about WSA, see WLAN Advanced Features Configuration Guide.
# Enable WSA collaboration for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-channel track spectrum-analysis enable
# Enable WSA collaboration for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-channel track spectrum-analysis enable
# Enable WSA collaboration for 5 GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1- radio-5g-rrm] calibrate-channel track spectrum-analysis enable
# Enable WSA collaboration for 2.4 GHz radios in global configuration view.
[Sysname-wlan-global-configuration] calibrate-channel track spectrum-analysis enable 2.4g
spectrum-analysis calibrate-channel sensitivity (WLAN Advanced Features Command Reference)
Use calibrate-power 2.4g adjacency-factor to set the adjacency factor for 2.4 GHz radios.
Use undo calibrate-power 2.4g adjacency-factor to restore the default.
calibrate-power 2.4g adjacency-factor neighbor
The adjacency factor is 2 for 2.4 GHz radios.
Operating mechanism
# Set the adjacency factor to 7 for the 2.4 GHz radios of all APs.
[Sysname-wlan-global-configuration] calibrate-power 2.4g adjacency-factor 7
Use calibrate-power 2.4g coverage rssi-threshold to configure the client packet RSSI threshold for the 2.4 GHz frequency band.
Use undo calibrate-power 2.4g coverage rssi-threshold to restore the default.
calibrate-power 2.4g coverage rssi-threshold rssi
The client packet RSSI threshold for the 2.4 GHz frequency band is 20.
rssi: Specifies the RSSI threshold for 2.4 GHz clients in the range of 1 to 100.
When the RSSI strength of a client packet is lower than the configured RSSI threshold, the AC determines that the packet is a weak-signal packet.
# Set the client packet RSSI threshold for the 2.4 GHz frequency band to 80.
[Sysname-wlan-global-configuration] calibrate-power 2.4g coverage rssi-threshold 80
Use calibrate-power 2.4g coverage weak-signal-client ratio to configure the weak-signal client proportion threshold for the 2.4 GHz frequency band.
Use undo calibrate-power 2.4g coverage weak-signal-client ratio to restore the default.
calibrate-power 2.4g coverage weak-signal-client ratio percent
The weak-signal client proportion threshold for the 2.4 GHz frequency band is 25.
percent: Specifies the weak-signal client proportion threshold for the 2.4 GHz frequency band  in the range of 1 to 100 in percent.
The AC determines that a blind spot exists when the following conditions are met:
·     The number of weak-signal clients associated with a radio has reached or exceeded the threshold configured by using the calibrate-power 2.4g coverage weak-signal-client threshold command.
·     The proportion of weak-signal clients associated with a radio has reached or exceeded the threshold configured by using this command.
# Set the weak-signal client proportion threshold for the 2.4 GHz frequency band to 30%.
[Sysname-wlan-global-configuration] calibrate-power 2.4g coverage weak-signal-client ratio 30
Use calibrate-power 2.4g coverage weak-signal-client threshold to configure the weak-signal client quantity threshold for the 2.4 GHz frequency band.
Use undo calibrate-power 2.4g coverage weak-signal-client threshold to restore the default.
calibrate-power 2.4g coverage weak-signal-client threshold counts
The weak-signal client quantity threshold for the 2.4 GHz frequency band is 3.
counts: Specifies the weak-signal client quantity threshold for the 2.4 GHz frequency band in the range of 1 to 75.
·     The number of weak-signal clients associated with a radio has reached or exceeded the threshold configured by using this command.
·     The proportion of weak-signal clients associated with a radio has reached or exceeded the threshold configured by using the calibrate-power 2.4g coverage weak-signal-client ratio command.
# Set the weak-signal client quantity threshold for the 2.4 GHz frequency band to 20.
[Sysname-wlan-global-configuration] calibrate-power 2.4g coverage weak-signal-client threshold 20
Use calibrate-power 2.4g coverage weak-signal-packet ratio to configure the weak-signal packet proportion threshold for the 2.4 GHz frequency band.
Use undo calibrate-power 2.4g coverage weak-signal-packet ratio to restore the default.
calibrate-power 2.4g coverage weak-signal-packet ratio percent
The weak-signal packet proportion threshold for the 2.4 GHz frequency band is 20.
percent: Specifies the weak-signal packet proportion threshold for the 2.4 GHz frequency band in the range of 1 to 100 in percent.
The AC determines that a client is a weak-signal client when the following conditions are met:
·     The number of weak-signal packets received by the client has reached or exceeded the threshold configured by using the calibrate-power 2.4g coverage weak-signal-packet threshold command.
·     The proportion of weak-signal packets received by the client has reached or exceeded the threshold configured by using this command.
# Set weak-signal packet proportion threshold for the 2.4 GHz frequency band to 20%.
[Sysname-wlan-global-configuration] calibrate-power 2.4g coverage weak-signal-packet ratio 20
Use calibrate-power 2.4g coverage weak-signal-packet threshold to configure the weak-signal packet quantity threshold for the 2.4 GHz frequency band.
Use undo calibrate-power 2.4g coverage weak-signal-packet threshold to restore the default.
calibrate-power 2.4g coverage weak-signal-packet threshold packets
The weak-signal packet quantity threshold for the 2.4 GHz frequency band is 5.
packets: Specifies the weak-signal packet quantity threshold for the 2.4 GHz frequency band in the range of 1 to 255.
·     The number of weak-signal packets received by the client has reached or exceeded the threshold configured by using this command.
·     The proportion of weak-signal packets received by the client has reached or exceeded the threshold configured by using the calibrate-power 2.4g coverage weak-signal-packet ratio command.
# Set the weak-signal packet quantity threshold for the 2.4 GHz frequency band to 20.
[Sysname-wlan-global-configuration] calibrate-power 2.4g coverage weak-signal-packet threshold 20
Use calibrate-power 2.4g threshold to set the power adjustment threshold for 2.4 GHz radios.
Use undo calibrate-power 2.4g threshold to restore the default.
calibrate-power 2.4g threshold value
The power adjustment threshold is 65.
threshold value: Specifies the power adjustment threshold in the range of 1 to 196. The value range indicates that the power of the radio is in the range of –196 dBm to –1 dBm.
Recommended configuration
As a best practice to avoid interference among radios, set the power adjustment threshold to –80 dBm for high-density WLANs.
# Set the power adjustment threshold to 70 for the 2.4 GHz radios of all APs.
[Sysname-wlan-global-configuration] calibrate-power 2.4g threshold 70
Use calibrate-power 5g adjacency-factor to set the adjacency factor for 5 GHz radios.
Use undo calibrate-power 5g adjacency-factor to restore the default.
calibrate-power 5g adjacency-factor neighbor
The adjacency factor is 2 for 5 GHz radios.
Operating mechanism
# Set the adjacency factor to 7 for the 5 GHz radios of all APs.
[Sysname-wlan-global-configuration] calibrate-power 5g adjacency-factor 7
Use calibrate-power 5g coverage rssi-threshold to configure the client packet RSSI threshold for the 5 GHz frequency band.
Use undo calibrate-power 5g coverage rssi-threshold to restore the default.
calibrate-power 5g coverage rssi-threshold rssi
The client packet RSSI threshold for the 5 GHz frequency band is 25.
rssi: Specifies the RSSI threshold for 5 GHz clients in the range of 1 to 100.
# Set the client packet RSSI threshold for the 5 GHz frequency band to 80.
[Sysname-wlan-global-configuration] calibrate-power 5g coverage rssi-threshold 80
Use calibrate-power 5g coverage weak-signal-client ratio to configure the weak-signal client proportion threshold for the 5 GHz frequency band.
Use undo calibrate-power 5g coverage weak-signal-client ratio to restore the default.
calibrate-power 5g coverage weak-signal-client ratio percent
The weak-signal client proportion threshold for the 5 GHz frequency band is 25.
percent: Specifies the weak-signal client proportion threshold for the 5 GHz frequency band in the range of 1 to 100 in percent.
·     The number of weak-signal clients associated with a radio has reached or exceeded the threshold configured by using the calibrate-power 5g coverage weak-signal-client threshold command.
# Set the weak-signal client proportion threshold for the 5 GHz frequency band to 30%.
[Sysname-wlan-global-configuration] calibrate-power 5g coverage weak-signal-client ratio 30
Use calibrate-power 5g coverage weak-signal-client threshold to configure the weak-signal client quantity threshold for the 5 GHz frequency band.
Use undo calibrate-power 5g coverage weak-signal-client threshold to restore the default.
calibrate-power 5g coverage weak-signal-client threshold counts
The weak-signal client quantity threshold for the 5 GHz frequency band is 3.
counts: Specifies the weak-signal client quantity threshold for the 5 GHz frequency band in the range of 1 to 75.
·     The proportion of weak-signal clients associated with a radio has reached or exceeded the threshold configured by using the calibrate-power 5g coverage weak-signal-client ratio command.
# Set the weak-signal client quantity threshold for the 5 GHz frequency band to 20.
[Sysname-wlan-global-configuration] calibrate-power 5g coverage weak-signal-client threshold 20
Use calibrate-power 5g coverage weak-signal-packet ratio to configure the weak-signal packet proportion threshold for the 5 GHz frequency band.
Use undo calibrate-power 5g coverage weak-signal-packet ratio to restore the default.
calibrate-power 5g coverage weak-signal-packet ratio percent
The weak-signal packet proportion threshold for the 5 GHz frequency band is 20.
percent: Specifies the weak-signal packet proportion threshold for the 5 GHz frequency band in the range of 1 to 100 in percent.
·     The number of weak-signal packets received by the client has reached or exceeded the threshold configured by using the calibrate-power 5g coverage weak-signal-packet threshold command.
# Set weak-signal packet proportion threshold for the 5 GHz frequency band to 20%.
[Sysname-wlan-global-configuration] calibrate-power 5g coverage weak-signal-packet ratio 20
Use calibrate-power 5g coverage weak-signal-packet threshold to configure the weak-signal packet quantity threshold for the 5 GHz frequency band.
Use undo calibrate-power 5g coverage weak-signal-packet threshold to restore the default.
calibrate-power 5g coverage weak-signal-packet threshold packets
The weak-signal packet quantity threshold for the 5 GHz frequency band is 5.
packets: Specifies the weak-signal packet quantity threshold for the 5 GHz frequency band in the range of 1 to 255.
·     The proportion of weak-signal packets received by the client has reached or exceeded the threshold configured by using the calibrate-power 5g coverage weak-signal-packet ratio command.
# Set the weak-signal packet quantity threshold for the 5 GHz frequency band to 20.
[Sysname-wlan-global-configuration] calibrate-power 5g coverage weak-signal-packet threshold 20
Use calibrate-power 5g threshold to set the power adjustment threshold for 5 GHz radios.
Use undo calibrate-power 5g threshold to restore the default.
calibrate-power 5g threshold value
# Set the power adjustment threshold to 70 for the 5 GHz radios of all APs.
[Sysname-wlan-global-configuration] calibrate-power 5g threshold 70
Use calibrate-power 6g adjacency-factor to set the adjacency factor for 6 GHz radios.
Use undo calibrate-power 6g adjacency-factor to restore the default.
calibrate-power 6g adjacency-factor neighbor
The adjacency factor is 2 for 6 GHz radios.
# Set the adjacency factor to 7 for the 6 GHz radios of all APs.
[Sysname-wlan-global-configuration] calibrate-power 6g adjacency-factor 7
calibrate-power 6g coverage rssi-threshold
Use calibrate-power 6g coverage rssi-threshold to configure the client packet RSSI threshold for the 6 GHz frequency band.
Use undo calibrate-power 6g coverage rssi-threshold to restore the default.
calibrate-power 6g coverage rssi-threshold rssi
The client packet RSSI threshold for the 6 GHz frequency band is 25.
rssi: Specifies the RSSI threshold for 6 GHz clients in the range of 1 to 100.
# Set the client packet RSSI threshold for the 6 GHz frequency band to 80.
[Sysname-wlan-global-configuration] calibrate-power 6g coverage rssi-threshold 80
calibrate-power 6g coverage weak-signal-client ratio
calibrate-power 6g coverage weak-signal-client threshold
calibrate-power 6g coverage weak-signal-packet ratio
calibrate-power 6g coverage weak-signal-packet threshold
calibrate-power coverage enable
Use calibrate-power 6g coverage weak-signal-client ratio to configure the weak-signal client proportion threshold for the 6 GHz frequency band.
Use undo calibrate-power 6g coverage weak-signal-client ratio to restore the default.
calibrate-power 6g coverage weak-signal-client ratio percent
The weak-signal client proportion threshold for the 6 GHz frequency band is 25.
percent: Specifies the weak-signal client proportion threshold for the 6 GHz frequency band in the range of 1 to 100 in percent.
·     The number of weak-signal clients associated with a radio has reached or exceeded the threshold configured by using the calibrate-power 6g coverage weak-signal-client threshold command.
# Set the weak-signal client proportion threshold for the 6 GHz frequency band to 30%.
[Sysname-wlan-global-configuration] calibrate-power 6g coverage weak-signal-client ratio 30
Use calibrate-power 6g coverage weak-signal-client threshold to configure the weak-signal client quantity threshold for the 6 GHz frequency band.
Use undo calibrate-power 6g coverage weak-signal-client threshold to restore the default.
calibrate-power 6g coverage weak-signal-client threshold counts
The weak-signal client quantity threshold for the 6 GHz frequency band is 3.
counts: Specifies the weak-signal client quantity threshold for the 6 GHz frequency band in the range of 1 to 75.
·     The proportion of weak-signal clients associated with a radio has reached or exceeded the threshold configured by using the calibrate-power 6g coverage weak-signal-client ratio command.
# Set the weak-signal client quantity threshold for the 6 GHz frequency band to 20.
[Sysname-wlan-global-configuration] calibrate-power 6g coverage weak-signal-client threshold 20
Use calibrate-power 6g coverage weak-signal-packet ratio to configure the weak-signal packet proportion threshold for the 6 GHz frequency band.
Use undo calibrate-power 6g coverage weak-signal-packet ratio to restore the default.
calibrate-power 6g coverage weak-signal-packet ratio percent
The weak-signal packet proportion threshold for the 6 GHz frequency band is 20.
percent: Specifies the weak-signal packet proportion threshold for the 6 GHz frequency band in the range of 1 to 100 in percent.
·     The number of weak-signal packets received by the client has reached or exceeded the threshold configured by using the calibrate-power 6g coverage weak-signal-packet threshold command.
# Set weak-signal packet proportion threshold for the 6 GHz frequency band to 20%.
[Sysname-wlan-global-configuration] calibrate-power 6g coverage weak-signal-packet ratio 20
Use calibrate-power 6g coverage weak-signal-packet threshold to configure the weak-signal packet quantity threshold for the 6 GHz frequency band.
Use undo calibrate-power 6g coverage weak-signal-packet threshold to restore the default.
calibrate-power 6g coverage weak-signal-packet threshold packets
The weak-signal packet quantity threshold for the 6 GHz frequency band is 5.
packets: Specifies the weak-signal packet quantity threshold for the 6 GHz frequency band in the range of 1 to 255.
·     The proportion of weak-signal packets received by the client has reached or exceeded the threshold configured by using the calibrate-power 6g coverage weak-signal-packet ratio command.
# Set the weak-signal packet quantity threshold for the 6 GHz frequency band to 20.
[Sysname-wlan-global-configuration] calibrate-power 6g coverage weak-signal-packet threshold 20
calibrate-power 6g threshold
Use calibrate-power 6g threshold to set the power adjustment threshold for 6 GHz radios.
Use undo calibrate-power 6g threshold to restore the default.
calibrate-power 6g threshold value
The priorities of configurations in RRM view, an AP group's RRM view, and global configuration view are in descending order.
# Set the power adjustment threshold to 75 for the 6 GHz radios of all APs.
[Sysname-wlan-global-configuration] calibrate-power 6g threshold 75
Use calibrate-power coverage enable to enable disable blind spot detection.
Use calibrate-power coverage disable to disable blind spot detection.
Use undo calibrate-power coverage to restore the default.
Radio view/AP group's radio view/AP group's global radio view:
calibrate-power coverage { disable | enable }
Global configuration view:
calibrate-power coverage enable { 2.4g | 5g | 6g | all }
undo calibrate-power coverage enable { 2.4g | 5g | 6g | all }
In radio view, the device uses the configuration in the AP group's radio view.
In an AP group's radio view, the device uses the AP group's global radio view.
In an AP group's global radio view, the device uses the global configuration view.
In global configuration view, blind spot detection is disabled.
Radio view
2.4g: Specifies the 2.4 GHz frequency band.
5g: Specifies the 5 GHz frequency band.
6g: Specifies the 6 GHz frequency band.
all: Specifies the 2.4 GHz, 5 GHz, and 6 GHz frequency bands.
Operating mechanism
With blind spot detection enabled, the AC determines whether a blind spot (or weak signal coverage area) exists based on the signal strength of wireless clients. If a blind spot exists, the AC increases the transmit power of the corresponding AP during auto TPC.
·     The number of weak-signal clients associated with a radio has reached or exceeded the configured threshold.
·     The proportion of weak-signal clients associated with a radio has reached or exceeded the configured threshold.
·     The number of weak-signal packets received by the client has reached or exceeded the configured threshold.
·     The proportion of weak-signal packets received by the client has reached or exceeded the configured threshold.
After you enable blind spot detection, use the wlan rrm calibration-power interval command to set the auto-TPC calibration interval to a value not shorter than 11 minutes as a best practice.
# Enable blind spot detection in radio view.
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] calibrate-power coverage enable
# Enable blind spot detection in an AP group's radio view.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] ap-model WA6320
[Sysname-wlan-ap-group-group1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1] calibrate-power coverage enable
# Enable blind spot detection for 5 GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1] radio 5g
[Sysname-wlan-ap-group-group1-radio-5g] calibrate-power coverage enable
# Enable blind spot detection for all 2.4 GHz radios in global configuration view.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] calibrate-power coverage enable 2.4g
calibrate-power mode { coverage | custom | density }
Use calibrate-power mode to set the TPC scenario mode.
Use undo calibrate-power mode to restore the default.
In RRM view, the configuration in an AP group's RRM view is used.
In an AP group's RRM view, the TPC scenario mode is custom.
RRM view
AP group's RRM view
coverage: Specifies the coverage mode.
custom: Specifies the custom mode.
density: Specifies the density mode.
To avoid interference among APs, use the density mode. To increase signal coverage performance, use the coverage mode. If these two modes cannot meet your network requirements, use the custom mode to customize power adjustment settings.
In either density or coverage mode, power adjustment settings are defined by the system and cannot be changed.
# Set the TPC scenario mode to coverage for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] rrm
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power mode coverage
# Set the TPC scenario mode to density for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1] rrm
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power mode density
calibrate-power mode { periodic | scheduled }
Use calibrate-power mode to set the auto TPC mode.
In RRM view, an AP group's RRM view, or an AP group's global radio RRM view:
calibrate-power { 2.4g | 5g } mode { periodic | scheduled }
undo calibrate-power { 2.4g | 5g } mode { periodic | scheduled }
In global configuration view, the auto TPC mode is periodic.
RRM view
AP group's RRM view
periodic: Specifies the periodic mode.
scheduled: Specifies the scheduled mode.
2.4g: Specifies the mode for the 2.4GHz band.
5g: Specifies the mode for the 5GHz band.
In periodic calibration, the AC repeatedly checks the channel quality at the set intervals and evaluates whether transmit power adjustments are necessary based on the results.
In scheduled calibration, the device collects channel quality information during a specific period, evaluates the channel quality, and then decides whether to adjust the transmit power.
# Set the auto TPC mode to scheduled for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power self-decisive enable
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power mode scheduled
# Set the auto TPC mode to scheduled for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power self-decisive enble
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power mode scheduled
# Set the auto TPC mode to scheduled for 5GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1-radio-5g] rrm
[Sysname-wlan-ap-group-group1- radio-5g-rrm] calibrate-power self-decisive enble
[Sysname-wlan-ap-group-group1-radio-5g-rrm] calibrate-power mode schedule
# Set the auto TPC mode to scheduled for 2.4GHz radios in global configuration view.
[Sysname-wlan-global-configuration] calibrate-power 2.4g mode schedule
calibrate-power monitoring time-range
Use calibrate-power monitoring time-range to specify the time range for collecting the environmental information for TPC.
Use undo calibrate-power monitoring time-range to remove the time range specified for collecting the environmental information for TPC.
In RRM view, an AP group’s RRM view, or an AP group’s global radio RRM view:
calibrate-power monitoring time-range time-range-name
In global configuration view:
calibrate-power { 2.4g | 5g } monitoring time-range time-range-name
undo calibrate-power { 2.4g | 5g } monitoring time-range
In global configuration view, no time range is specified for collecting radio environmental information.
RRM view
AP group's RRM view
time-range-name: Specifies the name of a time range, a case-insensitive string of 1 to 32 characters. To avoid confusion, do not specify the time range name as all.
After you specify a time range for TPC, the AC gathers radio environment data within that period and produces channel and neighbor reports to inform power adjustments.
# Specify time range time1 for TPC for radio 1 on AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power monitoring time-range time1
# Specify time range time1 for TPC for radio 1 on APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power monitoring time-range time1
# Specify time range time1 for TPC for 2.4 GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1- radio-2.4g-rrm] calibrate-power monitoring time-range time1
# Specify time range time1 for TPC for 2.4 GHz radios in global configuration view.
[Sysname-wlan-global-configuration] calibrate-power 2.4g monitoring time-range time1
calibrate-power power-range
Use calibrate-power power-range to specify the transmit power adjustment range.
Use undo calibrate-power power-range to restore the default.
calibrate-power power-range min-power to max-power
calibrate-power { 2.4g | 5g | 6g } power-range min-power to max-power
undo calibrate-power { 2.4g | 5g | 6g } power-range
In global configuration view, the minimum transmit power is 6 dBm for 2.4GHz radios, and 11 dBm for 5GHz and 6GHz radios. The maximum transmit power for the 2.4GHz, 5GHz, and 6GHz radios is consistent with the default maximum power supported by the radio band.
RRM view
AP group's RRM view
min-power: Specifies the minimum transmit power in the range of 1 to 20 dBm.
max-power: Specifies the maximum transmit power in the range of 1 to 27 dBm.
Application scenarios
Use this command to specify the radio transmit power range in different views, ensuring that the radio transmit power remains within the normal range and does not exceed the set limit.
Before configuring this command, make sure you have a certain understanding of the relevant parameters in RRM view, AP group's RRM view, AP group's global radio RRM view, and global configuration view. At the same time, pay attention attention to the priority relationship and rationality of the configurations in each view.
# Specify the power adjustment range as 15 to 20 dBm for radio 1 on AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power power-range 15 to 20
# Specify the power adjustment range as 15 to 20 dBm for radio 1 on APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power power-range 15 to 20
# Specify the power adjustment range as 15 to 20 dBm for 5 GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1-radio-5g-rrm] calibrate-power power-range 15 to 20
# Specify the power adjustment range as 15 to 20 dBm for 2.4 GHz radios in global configuration view.
[Sysname-wlan-global-configuration] calibrate-power 2.4g power-range 15 to 20
Use calibrate-power self-decisive enable to enable auto-TPC.
Use calibrate-power self-decisive disable to disable auto-TPC.
Use undo calibrate-power self-decisive to restore the default.
In RRM view/an AP group's RRM view/an AP group's global radio RRM view:
calibrate-power self-decisive { disable | enable }
calibrate-power self-decisive enable { 2.4g | 5g | 6g | all }
undo calibrate-power self-decisive enable { 2.4g | 5g | 6g | all }
In an AP group's RRM view, the configuration in an AP group's global radio RRM view is used.
In an AP group's global radio RRM view, the configuration in global configuration view is used.
In global configuration view, auto-TPC is disabled.
RRM view
AP group's RRM view
all: Specifies the 2.4GHz, 5GHz, and 6 GHz frequency bands.
# Enable auto-TPC for radio 1 of AP ap1.
# Enable auto-TPC for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power self-decisive enable
# Enable auto-TPC for 2.4 GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1-radio-2.4g-rrm] calibrate-power self-decisive enable
# Enable auto-TPC globally for the 2.4GHz, 5GHz, and 6GHz frequency bands.
[Sysname-wlan-global-configuration] calibrate-power self-decisive enable all
calibrate-power threshold
Use calibrate-power threshold to set the power adjustment threshold.
Use undo calibrate-power threshold to restore the default.
calibrate-power threshold value
In an AP group's RRM view, the configuration in global configuration view is used.
RRM view
AP group's RRM view
As a best practice to avoid interference among radios, set the power adjustment threshold to –80 dBm for high-density WLANs. The default power adjustment threshold is –65.
# Set the power adjustment threshold to 70 for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] calibrate-power threshold 70
# Set the power adjustment threshold to 70 for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] calibrate-power threshold 70
channel holddown-time
Use channel holddown-time to set the channel holddown time.
Use undo channel holddown-time to restore the default.
channel holddown-time minutes
The channel holddown time is 720 minutes.
RRM holddown group view
minutes: Specifies the channel holddown time in the range of 10 to 1440 minutes.
Each time the channel of a radio in the RRM holddown group changes, the system starts the channel holddown timer for the radio. The channel for every radio in the RRM holddown group remains unchanged during the specified channel holddown time.
# Set the channel holddown time to 600 minutes for RRM holddown group 10.
[Sysname] wlan rrm-calibration-group 10
[Sysname-wlan-rrm-calibration-group-10] channel holddown-time 600
Use channel-usage-threshold to set the channel usage threshold.
Use undo channel-usage-threshold to restore the default.
undo channel-usage-threshold percent
RRM view
AP group's RRM view
percent percent: Specifies the channel usage threshold in the range of 1 to 100.
Operating mechanism
DFS is triggered when both the channel usage threshold and interference ratio threshold are reached or exceeded, but the received service traffic fails to reach the service traffic threshold.
·     Channel usage threshold—Proportion of channel resources used for packet transmitting and receiving.
·     Interference ratio threshold—Proportion of channel resources used by interferences to the total used channel resources.
·     Service traffic threshold—Proportion of received service traffic to the total received traffic.
# Set the channel usage threshold to 40 for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] channel-usage-threshold percent 40
# Set the channel usage threshold to 40 for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] channel-usage-threshold percent 40
co-channel interference trap threshold
Use co-channel interference trap threshold to set the trap threshold for co-channel interference.
Use undo co-channel interference trap threshold to restore the default.
co-channel interference trap threshold threshold
In global configuration view, the trap threshold for co-channel interference is 60 dBm.
RRM view
AP group's RRM view
threshold threshold: Specifies the trap threshold in the range of 10 to 90 dBm.
When the co-channel interference exceeds the trap threshold, the system generates an SNMP notification to inform the network administrator.
# Set the trap threshold for co-channel interference to 16 dBm for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] co-channel interference trap threshold 16
# Set the trap threshold for co-channel interference to 16 dBm for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] co-channel interference trap threshold 16
# Set the trap threshold for co-channel interference to 16 dBm for 5 GHz radios in AP group group1.
[Sysname-wlan-ap-group-group1-radio-5g-rrm] co-channel interference trap threshold 16
# Set the trap threshold for co-channel interference to 16 dBm in global configuration view.
[Sysname] wlan g1obal-configuration
[Sysname-wlan-global-configuration] co-channel interference trap threshold 16
adjacent-channel interference trap threshold
crc-error-threshold
Use crc-error-threshold to set the CRC error threshold.
Use undo crc-error-threshold to restore the default.
RRM view
AP group's RRM view
percent: Specifies the CRC error threshold in the range of 0 to 100. Setting the threshold to 0 disables the system from using the CRC error threshold as a trigger for auto DFS.
Operating mechanism
When the AC detects that the proportion of CRC-error packets in all 802.11 packets reaches the CRC error threshold on a radio, it performs DFS for the radio.
# Set the CRC error threshold to 50 for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] crc-error-threshold 50
# Set the CRC error threshold to 50 for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] crc-error-threshold 50
description
Use description to set a description for an RRM holddown group.
No description is set for an RRM holddown group.
text: Specifies the RRM holddown group description, a case-sensitive string of 1 to 64 characters.
# Set the description for RRM holddown group 10 to office.
[Sysname-wlan-rrm-calibration-group-10] description office
display wlan rrm baseline
Use display wlan rrm baseline to display radio baseline information.
display wlan rrm baseline { all | name baseline-name } [ verbose ]
all: Specifies all radio baselines.
name baseline-name: Specifies a radio baseline by its name, a case-insensitive string of 1 to 32 characters.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief radio baseline information.
You cannot display information about a radio baseline if you do not have the right to manage radios with the location identifier in the radio baseline.
# Display brief radio baseline information.
<Sysname> display wlan rrm baseline all
 Baseline name  : apbaseline
 Radio range    : AP
 Created at     : 2015-06-22 19:56:31
 Baseline name  : groupbaseline
 Radio range    : AP group
 Created at     : 2015-06-22 19:56:12
 Baseline name  : globalbaseline
 Radio range    : Global
 Created at     : 2015-06-22 19:55:12
Radio range
Range of radios saved in the baseline:
·     AP—Radios on an AP.
·     AP group—Radios on APs in an AP group.
·     Global—Radios on all APs associated with the AC.
Created at
Time and date when the baseline was created.
# Display detailed radio baseline information.
<Sysname> display wlan rrm baseline all verbose
 Radio range   : AP
 APName             RadioID RadioType Bandwidth Channel Power RegionCode
 ap1                2       dot11gn   20        13      20    CN
 ap1                1       dot11an   40        157     20    CN
 ap2                1       dot11an   40        149     20    CN
 ap1                1       dot11an   40        149     20    CN
 ap2                2       dot11gn   20        1       20    CN
Radio range
·     AP group—Radios on all APs in an AP group.
Created at
Power
Transmit power of the radio in dBm.
RegionCode
Region code of the AP.
display wlan rrm baseline apply-history
Use display wlan rrm baseline apply-history to display the history records of radio baseline application.
display wlan rrm baseline apply-history [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
This command displays information about the most recent ten baseline applications.
# Display the brief history records of radio baseline application.
<Sysname> display wlan rrm baseline apply-history
Applied at  : 2016-01-23   12:19:50
Applied to  : global
# Display the detailed history records of radio baseline application.
<Sysname> display wlan rrm baseline apply-history verbose
Applied to  : global
Radios      : 6
Success     : 4
Failure     : 2
Failure reason
  Radio doesn't exist           : 0
  Radio is down                 : 0
  Mismatching radio type        : 0
  Mismatching region code       : 1
  Ineffective service template  : 0
  Illegal channel               : 0
  Mismatching bandwidth         : 1
  Channel locked                : 0
  Channel fixed                 : 0
  Within channel holddown time  : 0
  Mismatching channel gap policy: 0
  Power locked                  : 0
  Within power holddown time    : 0
  Power lower than min. power   : 0
  Power greater than max. power : 0
Name
Radio baseline name.
Applied at
Time at which the radio baseline was applied.
Applied to
Radio baseline application range:
·     ap—Applied to an AP.
·     apgroup—Applied to an AP group.
·     global—Applied to all APs.
Radios
Number of radios in the radio baseline.
Success
Number of successful applications.
Failure
Number of failed applications.
The radio mode saved in the baseline does not match the actual radio mode.
The region code saved in the baseline does not match the actual region code of the AP.
No service template is bound to a radio in the baseline or the bound service template is disabled.
The channel in the baseline does not match the specified channel gap.
The transmit power in the baseline is lower than the specified minimum transmit power for the radio.
The transmit power in the baseline is higher than the specified maximum transmit power for the radio.
display wlan rrm-calibration-group
Use display wlan rrm-calibration-group to display RRM holddown group information.
display wlan rrm-calibration-group { all | group-id }
all: Specifies all RRM holddown groups.
group-id: Specifies an RRM holddown group by its IDThe value range for this argument is 1 to 128.
# Display information about RRM holddown group 10.
<Sysname> display wlan rrm-calibration-group 10
          RRM Calibration Group Information
Group ID                : 10
Description             : office
Channel holddown time   : 720 minutes
Power holddown time     : 60 minutes
Location name           : default-location
Group members           : ap4-radio2, ap3-radio2
Group ID
ID of the RRM holddown group.
Description for the RRM holddown group.
Channel holddown time.
Power holddown time
Power holddown time.
Location name
Name of the location identifier assigned to the RRM holddown group.
Group members
Radios in the RRM holddown group.
display wlan rrm-history ap
Use display wlan rrm-history ap to display historical RRM adjustment information.
display wlan rrm-history ap { all | name ap-name }
all: Specifies all APs.
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The name can include letters, numbers, underscores (_), left brackets ([), right brackets (]), slashes (/), and minus signs (-).
You can use this command to display detailed information about the most recent ten channel and power adjustments. The detailed information includes adjustment time, cause, power, bandwidth, load and interference.
# Display historical channel and power adjustment information for radios of AP ap1.
<Sysname> display wlan rrm-history ap name ap1
                         AP RRM History
 Flags : I - Interference,   P - Packets discarded,    F - Retransmission,
         R - Radar select,   C - Coverage,             B - Channelbusy
         M – Manual          D – Bandwidth             O - Others
                         AP RRM History : ap1
 Radio : 1                                Basic BSSID : 000f-e2ff-7700
        Ch  Power BW    Load Util Intf   Reason    Date         Time
            (dBm) (MHz) (%)  (%)  (%)              (yyyy-mm-dd) (hh:mm:ss)
 Before 36   20   20    24   2    21     -P------- 2014-07-07   17:31:50
 After  40   20   20    9    0    8      -         -            -
 Before 40   20   20    54   1    53     IP------- 2014-07-08   12:19:50
 After  36   20   20    10   0    10     -         -            -
 Before 36   20   20    29   1    28     -------D- 2014-07-08   12:59:50
 After  36   20   40    30   0    29     -         -            -
Table 5 Command output
Radio
Radio ID.
Basic BSSID
Basic service set identifier.
Ch
Working channel of the radio.
Power (dBm)
Transmit power of the radio.
BW (MHz)
Bandwidth of the radio.
Load (%)
Channel load in percentage.
Util (%)
Channel usage in percentage.
Intf (%)
Interference detected on the channel, in percentage.
Retry
Retransmission rate detected on the channel, in percentage.
Reason
Channel or power adjustment reason.
·     I—Interference.
·     P—Packet loss.
·     F—Retransmission.
·     R—Radar avoidance.
·     C—Signal coverage.
·     B—Channel busy.
·     M—Manually adjusted.
·     D—Bandwidth adjustment.
·     O—Other reason.
Date
Adjustment date.
Time
Adjustment time.
display wlan rrm-status ap
Use display wlan rrm-status ap to display detailed RRM information.
display wlan rrm-status ap { all | name ap-name }
If both channel adjustment and power adjustment are disabled, this command does not display channel reports or neighbor reports.
# Display detailed information about channel and power adjustments for radios of AP ap1.
<Sysname> display wlan rrm-status ap name ap1
                          AP RRM Profile : ap1
 Radio   : 1                              Basic BSSID    : 70f9-6d31-2fe0
 Channel : 157                            Tx Power (dBm) : 18
    Ch    Nbrs   Load   Util   Intf   PER   Retry   Radar     Last Detected At
    36    0      0      -      0      0     -       -         2020-04-10 09:35:01
    40    0      0      -      0      0     -       -         2020-04-10 09:35:01
    44    0      0      -      0      0     -       -         2020-04-10 09:35:01
    48    0      0      -      0      0     -       -         2020-04-10 09:35:01
    52    0      0      -      0      0     -       -         2020-04-10 09:35:01
    56    0      0      -      0      0     -       -         2020-04-10 09:35:01
    60    0      0      -      0      0     -       -         2020-04-10 09:35:01
    64    0      0      -      0      0     -       -         2020-04-10 09:35:01
    100   0      0      -      0      0     -       -         2020-04-10 09:35:01
    104   0      0      -      0      0     -       -         2020-04-10 09:35:01
    108   0      0      -      0      0     -       -         2020-04-10 09:35:01
    112   0      0      -      0      0     -       -         2020-04-10 09:35:01
    116   0      0      -      0      0     -       -         2020-04-10 09:35:01
    132   0      0      -      0      0     -       -         2020-04-10 09:35:01
    136   0      0      -      0      0     -       -         2020-04-10 09:35:01
    140   0      0      -      0      0     -       -         2020-04-10 09:35:01
    149   1      0      -      0      0     -       -         2020-04-10 09:35:01
    153   4      0      -      0      0     -       -         2020-04-10 09:35:01
    157   0      0      0      0      0     0       -         2020-04-10 09:35:01
    161   2      0      -      0      0     -       -         2020-04-10 09:35:01
    165   0      0      -      0      0     -       -         2020-04-10 09:35:01
   Nbr-MACAddress   Ch    Intf   SignalStrength  Type        Last Detected At
                           (%)    (dBm)
   000f-e212-ff01   161   0      -60             Unmanaged   2020-04-10 09:39:03
   5866-ba74-e461   153   0      -72             Unmanaged   2020-04-10 09:39:03
   70f9-6d30-9020   153   0      -40             Managed     2020-04-10 09:39:03
   70f9-6d31-3080   149   0      -54             Managed     2020-04-10 09:39:03
   70f9-6d31-34e0   161   0      -59             Managed     2020-04-10 09:39:03
   7425-8a86-bbe0   153   0      -48             Unmanaged   2020-04-10 09:39:03
   7425-8a86-c720   153   0      -63             Unmanaged   2020-04-10 09:39:03
 Radio   : 2                              Basic BSSID    : 70f9-6d31-2ff0
 Channel : 1                              Tx Power (dBm) : 19
    1    6      4      0      4      0     0       -         2020-04-10 09:33:06
    6    4      2      -      2      0     -       -         2020-04-10 09:33:06
    11   6      2      -      2      0     -       -         2020-04-10 09:33:06
                           (%)    (dBm)
   000f-e212-ff11   1     49     -77             Unmanaged   2020-04-10 09:31:05
   0023-89e1-ed00   11    0      -87             Unmanaged   2020-04-10 09:31:05
   006a-55f6-ae10   1     57     -88             Unmanaged   2020-04-10 09:31:05
   5866-ba64-aa31   1     10     -60             Unmanaged   2020-04-10 09:31:05
   5866-ba74-e471   6     0      -76             Unmanaged   2020-04-10 09:31:05
   5866-baa9-a610   11    0      -62             Unmanaged   2020-04-10 09:31:05
   70f9-6d30-9030   6     0      -63             Managed     2020-04-10 09:31:05
   70f9-6d31-3090   1     51     -86             Managed     2020-04-10 09:31:05
   70f9-6d31-34f0   6     0      -85             Managed     2020-04-10 09:33:09
   7425-8a86-bbf0   6     0      -73             Unmanaged   2020-04-10 09:33:09
   7425-8a86-c731   11    0      -93             Unmanaged   2020-04-10 09:33:09
   80f6-2ec0-3330   11    0      -76             Unmanaged   2020-04-10 09:33:09
   80f6-2ec0-3331   11    0      -73             Unmanaged   2020-04-10 09:33:09
   80f6-2edd-d2d0   1     40     -60             Unmanaged   2020-04-10 09:33:09
   80f6-2edd-d2d1   1     44     -68             Unmanaged   2020-04-10 09:33:09
   80f6-2ede-0b30   11    0      -74             Unmanaged   2020-04-10 09:33:09
Table 6 Command output
Radio
Radio ID.
Basic BSSID
Channel
Tx Power
Ch
Channels supported by the radio.
Nbrs
Number of detected radios.
Load
Load detected on the channel, in percentage. Channel load refers to the ratio between the outbound packets and the inbound packets as well as the interferences. Interferences refer to the error packets that are received by the radio.
Util
Channel usage in percentage. Channel usage refers to the ratio between the outbound packets and the inbound packets.
Intf
PER
Bit error rate detected on the channel, in percentage.
Retry
Radar
Radar detection status:
·     –: No radar signals are detected on the channel.
·     Detected: Radar signals have been detected on the channel.
Nbr-MACAddress
MAC address of the detected radio.
SignalStrength
Signal strength of the radio, in dBm.
Type of the radio:
·     Unmanaged—Radios that can be detected by the radio but are not managed by the same AC.
·     Managed—Radios that can be detected by the radio and are managed by the same AC.
Last Detected At
Last time valid channel and neighbor data was detected.
Use interference-threshold to set the channel interference threshold.
Use undo interference-threshold to restore the default.
In an AP group's RRM view, the channel interference threshold is 0.
RRM view
AP group's RRM view
percent: Specifies the channel interference threshold in the range of 0 to 100. Setting the threshold to 0 disables the system from using channel interference as a trigger for DFS.
When the AC detects that the proportion of interference packets in all data packets reaches the interference threshold on a radio, it performs DFS for the radio. Interference packets are packets sent to other radios.
# Set the channel interference threshold to 60 for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] interference-threshold 60
# Set the channel interference threshold to 60 for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] interference-threshold 60
power holddown-time
Use power holddown-time to set the power holddown time.
Use undo power holddown-time to restore the default.
power holddown-time minutes
The power holddown time is 60 minutes.
minutes: Specifies the power holddown time in the range of 10 to 1440 minutes.
Each time the power of a radio in the RRM holddown group changes, the system starts the power holddown timer for the radio. The power for every radio in the RRM holddown group remains unchanged during the specified power holddown time.
# Set the power holddown time to 600 minutes for RRM holddown group 10.
[Sysname-wlan-rrm-calibration-group-10] power holddown-time 600
rrm
Use rrm to enter Radio Resource Management (RRM) view.
rrm
No RRM view exists.
Radio view
# Enter RRM view.
# Enter an AP group's RRM view.
# Enter an AP group's global radio RRM view.
scan-only
Use scan-only enable to enable radio scanning.
Use scan-only disable to disable radio scanning.
Use undo scan-only to restore the default.
scan-only { disable | enable }
undo scan-only
In an AP group's RRM view, radio scanning is disabled.
RRM view
AP group's RRM view
Operating mechanism
This feature enables APs to scan the WLAN environment and report collected statistics to the AC at the specified interval. The AC uses the statistics to generate channel reports and neighbor reports.
To view the channel reports and neighbor reports, use the display wlan rrm-status ap command.
If you have configured periodic auto-DFS, scheduled auto-DFS, or periodic auto-TPC, you do not need to enable this feature.
# Enable radio scanning for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] scan-only enable
# Enable radio scanning for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] scan-only enable
snmp-agent trap enable wlan rrm
Use snmp-agent trap enable wlan rrm to enable SNMP notifications for WLAN RRM.
Use undo snmp-agent trap enable wlan rrm to disable SNMP notifications for WLAN RRM..
SNMP notifications are disabled for WLAN RRM.
To report critical WLAN RRM events to an NMS, enable SNMP notifications for WLAN RRM. For WLAN RRM event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for WLAN RRM.
[Sysname] snmp-agent trap enable wlan rrm
tolerance-level
Use tolerance-level to set the tolerance level.
Use undo tolerance-level to restore the default.
tolerance-level percent
RRM view
AP group's RRM view
percent: Specifies the tolerance level in the range of 0 to 100. 0 indicates that the tolerance level is not taken into consideration during DFS.
Operating mechanism
The tolerance level defines the quality gap between the optimal channel and the current channel that can trigger a channel change. The AC applies the optimal channel to a radio only when the tolerance level is reached.
# Set the tolerance level to 25 for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1-rrm] tolerance-level 25
# Set the tolerance level to 25 for radio 1 of APs in AP group group1.
[Sysname-wlan-ap-group-group1-ap-model-WA6320-radio-1-rrm] tolerance-level 25
wlan calibrate-bandwidth pronto ap
Use wlan calibrate-bandwidth pronto ap to trigger an on-demand bandwidth adjustment.
wlan calibrate-bandwidth pronto ap { all | ap-group group-name } { 5g | 6g | all }
all: Performs bandwidth adjustment on all APs.
ap-group group-name: Performs bandwidth adjustment on APs in the specified AP group. group-name: Specifies the name of an AP group, a case-insensitive string of 1 to 31 characters.
5g: Specifies 5 GHz radios.
6g: Specifies 6 GHz radios.
all: Specifies both 5 GHz and 6 GHz radios.
Executing this command might consume significant system resources. Use this feature with caution.
# Perform on-demand bandwidth adjustment for both the 5 GHz and 6 GHz radios on all APs.
[Sysname] wlan calibrate-bandwidth pronto ap all all
wlan calibrate-bandwidth pronto use-monitoring-data ap
Use wlan calibrate-bandwidth pronto use-monitoring-data ap to enable scheduled auto bandwidth adjustment for the specified AP radios.
wlan calibrate-bandwidth pronto use-monitoring-data ap { all | ap-group group-name }
ap-group group-name: Specifies APs in an AP group. group-name: Specifies the name of an AP group, a case-insensitive string of 1 to 31 characters.
In areas with severe interference, frequently adjusting the bandwidth automatically can disrupt normal network usage. To avoid this issue, you can configure scheduled auto bandwidth adjustment for the AC to collect radio environment information and generates channel and neighbor reports only during the specified time range. You can set the time range by the calibrate-bandwidth monitoring time-range command. The AC then decides whether to adjust the bandwidth based on the channel and neighbor reports.
# Enable scheduled auto bandwidth adjustment for all AP radios.
[Sysname] scheduler job rrm
[Sysname-job-rrm] command 1 system-view
[Sysname-job-rrm] command 2 wlan calibrate-bandwidth pronto use-monitoring-data ap all
calibrate-bandwidth mode
wlan calibrate-channel pronto ap
IMPORTANT
IMPORTANT:
This command consumes system resources. Use it with caution.
Use wlan calibrate-channel pronto ap to execute on-demand DFS for radios of the specified APs.
wlan calibrate-channel pronto ap { all | ap-group group-name } { 2.4g | 5g | 6g | all }
all: Performs DFS on the specified radios on all APs.
ap-group group-name: Performs DFS on the specified radios on all APs in an AP group. group-name: Specifies the name of an AP group, a case-insensitive string of 1 to 31 characters.
2.4g: Performs DFS on the 2.4 GHz band.
5g: Performs DFS on the 5GHz band.
6g: Performs DFS on the 6GHz band.
2.4g: Performs DFS on the 2.4 GHz, 5 GHz, and 6 GHz bands.
Within the 16 minutes after you execute this command, the specified radios on the specified APs periodically provide wireless service on the working channel and scan the non-working channels. Packet loss might occur when the radios scan non-working channels and stop providing services. As a best practice, execute this command during network maintenance periods.
# Execute on-demand DFS for radios of all APs.
[Sysname] wlan calibrate-channel pronto ap all all
This operation will change the working channel of all radios and might cause packet loss. Continue? [Y/N]
wlan calibrate-channel pronto use-monitoring-data ap
Use wlan calibrate-channel pronto use-monitoring-data ap to enable scheduled auto DFS for the specified AP radios.
wlan calibrate-channel pronto use-monitoring-data ap { all | ap-group group-name } { 2.4g | 5g | all }
ap-group group-name: Specifies an AP group. The group-name argument specifies the name of an AP group, a case-insensitive string of 1 to 31 characters.
2.4g: Specifies 2.4 GHz radios.
all: Specifies both the 2.4 GHz and 5 GHz radios.
In areas with severe interference, frequent auto DFS operations might affect normal network usage for users. To avoid this issue, you can configure scheduled auto DFS for the AC to collect radio environmental information and generates channel and neighbor reports during the specified time range. You can set the time range by the calibrate-channel monitoring time-range command. The AC then decides whether to adjust the working channel based on the reports.
# Enable scheduled auto DFS for both the 2.4 GHz and 5 GHz radios on all APs.
[Sysname-job-rrm] command 2 wlan calibrate-channel pronto use-moniroring-data ap all all
wlan calibrate-power pronto ap
IMPORTANT
IMPORTANT:
Use wlan calibrate-power pronto ap to execute on-demand TPC for radios of the specified APs.
wlan calibrate-power pronto ap { all | ap-group group-name } { 2.4g | 5g | 6g | all }
# Execute on-demand TPC for radios of all APs.
[Sysname] wlan calibrate-power pronto ap all all
wlan calibrate-power pronto use-monitoring-data ap
Use wlan calibrate-power pronto use-monitoring-data ap to enable scheduled auto TPC for the specified AP radios.
wlan calibrate-power pronto use-monitoring-data ap { all | ap-group group-name } { 2.4g | 5g | all }
ap-group group-name: Specifies APs in an AP group. The group-name argument specifies the name of an AP group, a case-insensitive string of 1 to 31 characters.
2.4g: Specifies 2.4GHz radios.
5g: Specifies 5GHz radios.
all: Specifies both the 2.4GHz and 5GHz radios.
In areas with severe interference, frequently adjusting the transmit power automatically can disrupt normal network usage. To avoid this issue, you can configure scheduled auto TPC for the AC to collect radio environment information and generates channel and neighbor reports only during the specified time range. You can set the time range by the calibrate-power monitoring time-range command. The AC then decides whether to adjust the transmit power based on the channel and neighbor reports.
# Enable scheduled auto TPC for both the 2.4GHz and 5GHz radios on all APs.
[Sysname-job-rrm] command 2 wlan calibrate-power pronto use-monitoring-data ap all all
Use wlan rrm baseline apply to apply a radio baseline.
wlan rrm baseline apply name baseline-name
name baseline-name: Specifies a baseline name, a case-insensitive string of 1 to 32 characters.
You cannot apply a radio baseline when one of the following conditions is met:
·     You do not have the right to manage radios with the location identifier in the radio baseline.
·     The name of the radio baseline is start_config_baseline.csv.
# Apply radio baseline bl.
[Sysname] wlan rrm baseline apply name bl
wlan rrm baseline save
wlan rrm baseline remove
Use wlan rrm baseline remove to delete a radio baseline.
wlan rrm baseline remove name baseline-name
You cannot delete a radio baseline if you do not have the right to manage radios with the location identifier in the radio baseline.
# Delete radio baseline bl.
[Sysname] wlan rrm baseline remove name bl
Use wlan rrm baseline save to create a radio baseline by saving the current radio settings.
wlan rrm baseline save name baseline-name { ap ap-name [ radio radio-id ] | ap-group group-name [ ap-model ap-model ] [ radio radio-id ] | global }
ap ap-name: Specifies an AP name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). Make sure the AP is online.
radio radio-id: Specifies a radio ID. If you do not specify this option, the command saves the current settings of all radios on the specified AP or on APs in the specified AP group.
ap-group group-name: Specifies an AP group name, a case-insensitive string of 1 to 31 characters. Make sure the AP group already exists.
ap-model ap-model: Specifies an AP model. If you do not specify this option, the command saves the current settings of radios on all APs in the specified AP group.
global: Specifies all radios.
A radio baseline saves the working channel, transmit rate, and other radio attributes for a radio or several radios. You can create a radio baseline by saving the current radio settings and apply the baseline to use these settings.
A radio baseline is saved in a .csv file in the file system on the AC.
# Save the settings of radio 1 on AP ap1 and create radio baseline ap1-1.
[Sysname] wlan rrm baseline save name ap1-1 ap ap1 radio 1
# Save the settings of radio 1 of APs in AP group group1 and create radio baseline ap1g1-1.
[Sysname] wlan rrm baseline save name ap1g1-1 ap-group group1 ap-model WA6320 radio 1
# Save the settings of all radios and create radio baseline global.
[Sysname] wlan rrm baseline save name global global
wlan rrm calibration-bandwidth interval
Use wlan rrm calibration-bandwidth interval to set the interval for automatic bandwidth adjustment.
Use undo wlan rrm calibration-bandwidth interval to restore the default.
wlan rrm calibration-bandwidth interval minutes
The interval for automatic bandwidth adjustment is 13 minutes.
minutes: Specifies the automatic bandwidth adjustment interval in the range of 3 to 1440 minutes.
# Set the interval for automatic bandwidth adjustment to 10 minutes.
[Sysname] wlan rrm calibration-bandwidth interval 10
calibrate-bandwidth self-decisive
wlan rrm calibration-channel ap
Use wlan rrm calibration-channel ap to perform on-demand DFS for radios of the specified AP.
wlan rrm calibration-channel ap name ap-name [ radio radio-id ] [ force ]
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. Valid characters include letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify this option, the command takes effect on all radios of the specified AP.
force: Changes the working channel forcibly. If you do not specify this keyword, the AC determines whether to change the working channel based on the condition of the current working channel.
Operating mechanism
If you perform on-demand DFS for multiple radios, the calibration of one radio does not affect channel calibration of the other radios.
If you specify the force keyword, the new channel might not be the optimal channel.
The system will take a few minutes to scan channels and collect channel data. This might cause packet loss. During the calibration process, do not disable the radios or change channel scanning or WLAN RRM settings.
This feature does not take effect in an AC hierarchy network or on inside APs.
# Perform forced on-demand DFS for radio 1 of AP ap1.
[Sysname] wlan rrm calibration-channel ap name ap1 radio 1 force
wlan rrm calibration-channel interval
Use wlan rrm calibration-channel interval to set the channel calibration interval.
Use undo wlan rrm calibration-channel interval to restore the default.
wlan rrm calibration-channel interval minutes
The channel calibration interval is 23 minutes.
minutes: Specifies the channel calibration interval, in the range of 3 to 1440 minutes.
# Set the channel calibration interval to 10 minutes.
[Sysname] wlan rrm calibration-channel interval 10
calibrate-channel self-decisive
Use wlan rrm calibration-power interval to set the power calibration interval.
Use undo wlan rrm calibration-power interval to restore the default.
wlan rrm calibration-power interval minutes
The power calibration interval is 11 minutes.
minutes: Specifies the power calibration interval, in the range of 3 to 180 minutes.
# Set the power calibration interval to 10 minutes.
[Sysname] wlan rrm calibration-power interval 10
Use wlan rrm-calibration-group to create an RRM holddown group and enter its view, or enter the view of an existing RRM holddown group.
Use undo wlan rrm-calibration-group to remove an RRM holddown group.
wlan rrm-calibration-group group-id
undo wlan rrm-calibration-group { all | group-id }
No RRM holddown groups exist.
group-id: Specifies an RRM holddown group ID in the range of 1 to 128.
# Create RRM holddown group 10.
