| 03-WLAN SAVI commands | 59.27 KB |
IP source guard commands
display ip source binding
Use display ip source binding to display IPv4SG bindings.
display ip source binding [ wlan-snooping ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ]
wlan-snooping: Specifies the WLAN snooping module.
ip-address ip-address: Specifies an IPv4 address.
mac-address mac-address: Specifies a MAC address in H-H-H format.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
# Display all IPSG bindings on the public network.
<Sysname> display ip source binding
Total entries found: 2
IP Address MAC Address Interface VLAN Type
10.1.0.5 040a-0000-4000 WLAN-BSS1/0/1 1 WLAN snooping
10.1.0.6 040a-0000-3000 WLAN-BSS1/0/2 1 WLAN snooping
Total entries found |
Total number of IPv4SG bindings. |
IP Address |
IPv4 address in the IPv4SG binding. If no IP address is bound in the binding, this field displays N/A. |
MAC Address |
MAC address in the IPv4SG binding. If no MAC address is bound in the binding, this field displays N/A. |
Interface of the binding. This field displays N/A for a global IPv4SG binding. |
VLAN |
VLAN information in the IPv4SG binding. If the binding contains no VLAN information, this field displays N/A. |
Type |
Type of the IPv4SG binding. WLAN snooping indicates that the IPv4SG binding is dynamically generated based on WLAN snooping. The binding is used by other modules to provide security services. |
ip verify source
display ipv6 source binding
Use display ipv6 source binding to display IPv6SG bindings.
display ipv6 source binding [ wlan-snooping ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ]
ip-address ipv6-address: Specifies an IPv6 address.
# Display all IPv6SG bindings on the public network.
<Sysname> display ipv6 source binding
Total entries found: 1
IPv6 Address MAC Address Interface VLAN Type
2012:1222:2012:1222: 000f-2202-0435 WLAN-BSS1/0/1 1 DHCPv6 snooping
2012:1222:2012:1222
Total number of IPv6SG bindings. |
IPv6 Address |
IPv6 address in the IPv6SG binding. If no IPv6 address is bound in the binding, this field displays N/A. |
MAC Address |
MAC address in the IPv6SG binding. If no MAC address is bound in the binding, this field displays N/A. |
Interface of the IPv6SG binding. This field displays N/A for a global IPv6SG binding. |
VLAN |
VLAN information in the IPv6SG binding. If the binding contains no VLAN information, this field displays N/A. |
Type |
Type of the IPv6SG binding. WLAN snooping indicates that the IPv6SG binding is dynamically generated based on WLAN snooping. The binding is used by other modules to provide security services. |
ipv6 verify source
ip verify source
Use ip verify source to enable the IPSG feature for IPv4.
Use undo ip verify source to disable the IPSG feature for IPv4.
ip verify source [ alarm-only ]
The IPSG feature is disabled for IPv4.
Service template view
alarm-only: Represents that the IPSG feature for IPv4 only generates alarms but does not block traffic.
This feature uses WLAN snooping entries to filter IPv4 packets received by an AP. It drops packets that do not match the entries. A WLAN snooping entry is an IP-MAC binding.
In an IPv4 network, IPSG uses only the WLAN snooping entries obtained through DHCP packets.
# Enable the IPSG feature for IPv4.
[Sysname] wlan service-template security
[Sysname-wlan-st-security] ip verify source
ipv6 verify source
Use ipv6 verify source to enable the IPSG feature for IPv6.
Use undo ipv6 verify source to disable the IPSG feature for IPv6.
ipv6 verify source [ alarm-only ]
The IPSG feature is disabled for IPv6.
alarm-only: Represents that the IPSG feature for IPv6 only generates alarms but does not block traffic.
This feature uses WLAN snooping entries to filter IPv6 packets received by an AP. It drops packets that do not match the entries. A WLAN snooping entry is an IP-MAC binding.
# Enable the IPSG feature for IPv6.
[Sysname-wlan-st-security] ipv6 verify source
