H3C S7500E Switch Series Hardware Information and Specifications-6W100
HomeSupportSwitchesS7500E SeriesProduct LiteratureHardware Information & SpecificationsH3C S7500E Switch Series Hardware Information and Specifications-6W100
01-Hardware Information and Technical Specifications
1 Chassis views and technical specifications· 1-1
Chassis views· 1-1
S7502E· 1-1
S7503E-S· 1-1
S7503E-M·· 1-2
S7503E· 1-2
S7506E-S· 1-3
S7506E· 1-4
S7506E (non-PoE) 1-5
S7506E-MF· 1-6
S7506E-MF (non-PoE) 1-7
S7506E-V· 1-8
S7510E· 1-9
Technical specifications· 1-10
Weights and dimensions· 1-10
Module power consumption· 1-15
Total power consumption· 1-19
Heat dissipation· 1-22
Noise· 1-22
2 FRUs and compatibility matrixes· 2-1
MPUs· 2-1
Service modules· 2-5
Restrictions and guidelines· 2-5
Interface modules· 2-6
OAA modules· 2-12
Power system·· 2-15
Restrictions and guidelines· 2-15
Power modules· 2-15
Power cords· 2-19
PoE power system·· 2-20
Fan trays· 2-20
3 LEDs· 3-1
MPU LEDs· 3-2
Management Ethernet port LEDs· 3-2
Power module status LEDs· 3-3
Fan tray status LEDs· 3-4
Card status LEDs· 3-4
MPU active/standby status LED·· 3-6
CF card status LED·· 3-6
RJ-45 Ethernet port LEDs· 3-6
Combo interface LEDs· 3-6
SFP port LEDs· 3-7
SFP+ port LEDs· 3-7
QSFP+ port LEDs· 3-7
QSFP28 port LEDs· 3-8
XFP port LEDs· 3-8
Service module LEDs· 3-8
RJ-45 Ethernet port LEDs· 3-8
Combo interface LEDs· 3-9
SFP port LEDs· 3-9
SFP+ port LEDs· 3-9
XFP port LEDs· 3-10
QSFP+ port LEDs· 3-10
QSFP28 port LEDs· 3-10
CFP port LEDs· 3-11
EPON port LEDs· 3-11
Power module LEDs· 3-11
PSR320-A/PSR320-D·· 3-11
PSR650-A/PSR650-D/PSR1200-A/PSR1200-D·· 3-12
PSR650C-12A/PSR650C-12D/PSR1400-A/PSR1400-12A1-F/PSR2500-12AHD/PSR2500-12D·· 3-12
PSR1400-D·· 3-13
PSR1400-12D1· 3-14
PSR2800-ACV/PSR2800-A1-F· 3-15
PSR6000-ACV· 3-16
Fan tray LEDs· 3-18
4 Cables· 4-1
Ethernet twisted pair cable· 4-1
RJ-45 connector 4-1
Cable pinouts· 4-2
Cable type· 4-2
Pin assignments· 4-3
Making an Ethernet twisted pair cable· 4-4
Optical fiber 4-5
Optical fiber 4-5
Optical fiber cable· 4-5
Patch cord· 4-5
Pigtail cord· 4-6
Fiber connector 4-6
SFP+ DAC cable· 4-6
QSFP+ DAC/QSFP28 DAC cable· 4-7
QSFP+ to SFP+ DAC cable· 4-7
Chassis views
The figures in this chapter are for illustration only.
S7502E
Figure 1-1 S7502E front and rear panels
(1) Power module section
(2) MPU section
(3) Service module section
(4) Fan tray section
(5) PoE power input port
S7503E-S
Figure 1-2 S7503E-S front and rear panels
(2) MPU section
S7503E-M
Figure 1-3 S7503E-M front panel
(2) MPU section
(3) MPU/service module section (for MPUs or service modules)
S7503E
Figure 1-4 S7503E front panel
(1) MPU section
(2) Service module section
(3) Power module section
S7506E-S
Figure 1-5 S7506E-S front panel
(1) MPU section
S7506E
Figure 1-6 S7506E front panel
(1) MPU section
S7506E (non-PoE)
Figure 1-7 S7506E (non-PoE) front panel
(1) MPU section
S7506E-MF
Figure 1-8 S7506E-MF front panel
(1) MPU section
S7506E-MF (non-PoE)
Figure 1-9 S7506E-MF (non-PoE) front panel
(1) MPU section
S7506E-V
Figure 1-10 S7506E-V front panel
(1) MPU section
(2) Power module section
S7510E
Figure 1-11 S7510E front panel
(1) Service module section
(2) MPU section
Table 1-1 Chassis weights and dimensions
Model
Weight (fully configured)
Height
Width
Depth
S7502E
< 30 kg (66.14 lb)
175 mm (6.89 in) (4 RUs)
436 mm (17.17 in)
420 mm (16.54 in)
S7503E-S
< 30 kg (66.14 lb)
436 mm (17.17 in)
420 mm (16.54 in)
S7503E-M
< 30 kg (66.14 lb)
436 mm (17.17 in)
420 mm (16.54 in)
S7503E
< 60 kg (132.28 lb)
441 mm (17.36 in) (10 RUs)
436 mm (17.17 in)
420 mm (16.54 in)
S7506E-S
< 75 kg (165.34 lb)
575 mm (22.64 in) (13 RUs)
436 mm (17.17 in)
420 mm (16.54 in)
S7506E (non-PoE)
< 75 kg (165.34 lb)
436 mm (17.17 in)
420 mm (16.54 in)
S7506E
< 75 kg (165.34 lb)
436 mm (17.17 in)
420 mm (16.54 in)
S7506E-MF (non-PoE)
< 75 kg (165.34 lb)
436 mm (17.17 in)
420 mm (16.54 in)
S7506E-MF
< 75 kg (165.34 lb)
436 mm (17.17 in)
420 mm (16.54 in)
S7506E-V
< 85 kg (187.39 lb)
930 mm (36.61 in) (21 RUs)
436 mm (17.17 in)
420 mm (16.54 in)
S7510E
< 95 kg (209.44 lb)
708 mm (27.87 in) (16 RUs)
436 mm (17.17 in)
420 mm (16.54 in)
·     Rack height is measured in RUs. One RU is 44.45 mm (1.75 in).
·     The dimensions listed in Table 1-1 are for switch chassis, excluding mounting brackets, cable management brackets, cards, and power modules.
Table 1-2 Card weights and dimensions
Model
Weight
Height
Width
Depth
LSQ1MPUA0
1.35 kg (2.98 lb)
45 mm (1.77 in)
199 mm (7.83 in)
355 mm (13.98 in)
LSQ1CGV24PSC0
2.80 kg (6.17 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1CGP24TSC0
2.86 kg (6.31 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1CTGS16SC0
3.34 kg (7.36 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1MPUB0 (Salience VI-Lite)
3.60 kg (7.94 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1SRPA0 (Salience VI-Smart)
2.61 kg (5.75 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1SRPB0 (Salience VI)
3.60 kg (7.94 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1SRPD0 (Salience VI-Plus)
3.56 kg (7.85 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1SRP1CB0 (Salience VI-Turbo)
3.60 kg (7.94 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1SRP12GB0 (Salience VI-GE)
3.59 kg (7.91 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1SRP2XB0 (Salience VI-10GE)
3.60 kg (7.94 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM3MPUA0
1.41 kg (3.11 lb)
45 mm (1.77 in)
199 mm (7.83 in)
355 mm (13.98 in)
LSQM3MPUB0
2.95 kg (6.50 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2MPUC0
4.00 kg (8.82 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2MPUD0
4.10 kg (9.04 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2MPUDS0
4.05 kg (8.93 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1SRP8X2QE0
4.40 kg (9.70 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1CGP24TSSC0
3.00 kg (6.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1CGT24TSSC0
2.85 kg (6.28 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1CTGS24QSFD0
3.15 kg (6.94 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGS24QSFD0
3.00 kg (6.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1CQGS12SG0
3.20 kg (7.05 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1CGS2FE0
2.82 kg (6.22 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1QGS24RSG0
3.39 kg (7.47 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1QGS4SC0
3.12 kg (6.88 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1QGC4SC0
3.46 kg (7.62 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GP24TXSD0
3.08 kg (6.79 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1P24XGSC0
2.95 kg (6.50 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1T24XGSC0
2.92 kg (6.43 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1TGX8SD0
3.23 kg (7.12 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1TGX4SD0
2.93 kg (6.46 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1TGX4EB0
2.93 kg (6.46 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1TGX2SC0
2.95 kg (6.50 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1TGX2SD0
2.93 kg (6.46 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1TGX2EB0
2.93 kg (6.46 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1TGX1EA0
2.80 kg (6.17 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GT24PTSSC0
3.21 kg (7.08 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GT24TSSC0
2.95 kg (6.50 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM3GP44TSSC0
3.00 kg (6.61lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GP44TSSC0
3.00 kg (6.61lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1GP40TS8FD0
3.20 kg (7.05 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GP40TS8FD0
3.10 kg (6.83 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGS48RSG0
3.50 kg (7.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2TGS48SG0
3.30 kg (7.28 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGS48RFE0
3.60 kg (7.94 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGS16GPSA0
3.50 kg (7.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGS24FD0
3.00 kg (6.61lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1TGS16SC0
3.03 kg (6.68 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGS16FD0
2.91 kg (6.42 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2TGS16SF0
3.05 kg (6.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1TGS8SC0
3.11 kg (6.86 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1TGS4SC0
2.86 kg (6.31 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GP24TSSA0
2.85 kg (6.28 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGS12EC0
3.30 kg (7.28 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1XPT12TSFD0
3.45 kg (7.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2XPT12TSFD0
3.45 kg (7.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1PT24TSSC0
2.90 kg (6.39 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1PT8TSSC0
2.75 kg (6.06 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ4PT16PSC0
2.82 kg (6.22 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1PT16PSC0
2.82 kg (6.22 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1PT8PSC0
2.70 kg (5.95 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ4PT8PSC0
2.70 kg (5.95 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1PT4PSC0
2.64 kg (5.82 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ4PT4PSC0
2.64 kg (5.82 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GV40PSC0
3.02 kg (6.66 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GV24PSC0
2.80 kg (6.17 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GV24PSA0
2.80 kg (6.17 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GP24TSA0
2.77 kg (6.11 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GP24TSC0
2.77 kg (6.11 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GP24TEB0
3.04 kg (6.70 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GP24TSD0
3.01 kg (6.64 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GP48SC0
3.04 kg (6.70 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GP48SD0
3.25 kg (7.16 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GP48EB0
3.25 kg (7.16 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GP48SA0
3.00 kg (6.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1GP48FD0
3.10 kg (6.83 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GP24SC0
2.78 kg (6.13 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GP24SA0
2.81 kg (6.19 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GP12SC0
2.66 kg (5.86 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GP12EA0
2.88 kg (6.35 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1FP48SA0
3.05 kg (6.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ2FP48SA0
2.93 kg (6.46 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGT24FD0
3.40 kg (7.50 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GV48SA0
3.09 kg (6.81 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GV48SC0
3.09 kg (6.81 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GT48SA0
3.18 kg (7.01 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GV48SD0
3.31 kg (7.30 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ3GV48SC0
3.31 kg (7.30 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GT48SC0
3.18 kg (7.01 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1GT48FD0
3.40 kg (7.50 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM4GV48SA0
3.05 kg (6.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM4GV48SC0
3.05 kg (6.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1GT24SC0
2.72 kg (6.00 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ2FT48SA0
2.74 kg (6.04 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1FV48SA0
2.89 kg (6.37 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSU1WCME0
4.00 kg (8.82 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSU3WCMD0
3.62 kg (7.98 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1WCMD0
3.40 kg (7.50 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1WCMX20
4.00 kg (8.82 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1WCMX40
4.00 kg (8.82 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1FWDSC0
3.80 kg (8.38 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSU1FWCEA0
3.90 kg (8.60 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSU3FWCEA0
3.90 kg (8.60 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1FWCEAB0
3.90 kg (8.60 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ2FWBSC0
3.23 kg (7.12 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1FWBSC0
3.23 kg (7.12 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSU1NSCEA0
3.90 kg (8.60 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1NSMSC0
3.23 kg (7.12 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1NSDSC0
3.80 kg (8.38 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSU1IPSBEA0
3.90 kg (8.60 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1IPSSC0
3.23 kg (7.12 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1IPSDSC0
3.80 kg (8.38 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1SSLSC0
3.10 kg (6.83 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1ACGASC0
3.23 kg (7.12 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1ACGDSC0
3.80 kg (8.38 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSU1ADECEA0
3.90 kg (8.60 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1ADEDSC0
3.80 kg (8.38 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQ1LBSC0
3.23 kg (7.12 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2FWDSC0
3.30 kg (7.28 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1EPSB0
3.40 kg (7.50 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1SDNB0
3.40 kg (7.50 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1WBCZ720X
3.50 kg (7.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
·     Card dimensions are expressed as follows:
¡     H—Height of the front panel of the card.
¡     W—Width of the front panel of the card.
¡     D—Depth from the front panel of the card to the connector.
·     The card models listed in Table 1-2 are marked on the card panels. They might be slightly different from the card models marked on the card packages. For example, LSQ1QGS4SC0 and LSQM1QGS4SC0 identify the same card. LSQ1QGS4SC0 is marked on the card panel. When you order the card, you refer to it as LSQM1QGS4SC0.
Table 1-3 Power module adapter weights and dimensions
Model
Weight
Height
Width
Depth
LSQM1PWRSPA
4.42 kg (9.74 lb)
128 mm (5.04 in)
196 mm (7.72 in)
382 mm (15.04 in)
LSQM1PWRSPB
4.95 kg (10.91 lb)
128 mm (5.04 in)
196 mm (7.72 in)
382 mm (15.04 in)
Table 1-4 Power module weights and dimensions
Model
Weight
Height
Width
Depth
PSR320-A
2.00 kg (4.41 lb)
40 mm (1.57 in)/1 RU
140 mm (5.51 in)
350 mm (13.78 in)
PSR320-D
1.85 kg (4.08 lb)
140 mm (5.51 in)
350 mm (13.78 in)
PSR650-A
1.90 kg (4.19 lb)
140 mm (5.51 in)
350 mm (13.78 in)
PSR650-D
3.20 kg (7.05 lb)
140 mm (5.51 in)
350 mm (13.78 in)
PSR650C-12A
5.15 kg (11.35 lb)
128 mm (5.04 in)/3 RUs
196 mm (7.72 in)
382 mm (15.04 in)
PSR650C-12D
4.20 kg (9.26 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR1200-A
2.56 kg (5.64 lb)
140 mm (5.51 in)
350 mm (13.78 in)
PSR1200-D
2.51 kg (5.53 lb)
140 mm (5.51 in)
350 mm (13.78 in)
PSR1400-A
8.30 kg (18.30 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR1400-12A1-F
4.30 kg (9.48 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR1400-D
4.20 kg (9.26 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR1400-12D1
6.39 kg (14.09 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR2500-12AHD
5.45 kg (12.02 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR2500-12D
5.55 kg (12.24 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR2800-ACV
8.00 kg (17.64 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR2800-A1-F
5.45 kg (12.02 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR6000-ACV
12.16 kg (26.81 lb)
196 mm (7.72 in)
382 mm (15.04 in)
Table 1-5 Fan tray weights and dimensions
Model
Weight
Height
Width
Depth
S7502E fan tray
0.82 kg (1.81 lb)
30 mm (1.18 in)
127 mm (5 in)
351 mm (13.82 in)
S7503E-S fan tray
0.82 kg (1.81 lb)
30 mm (1.18 in)
127 mm (5 in)
351 mm (13.82 in)
S7503E-M fan tray
0.80 kg (1.76 lb)
30 mm (1.18 in)
127 mm (5 in)
351 mm (13.82 in)
S7503E fan tray
1.58 kg (3.48 lb)
29 mm (1.14 in)
225 mm (8.86 in)
367 mm (14.45 in)
S7506E-S fan tray
2.20 kg (4.85 lb)
29 mm (1.14 in)
347 mm (13.66 in)
367 mm (14.45 in)
S7506E fan tray
2.20 kg (4.85 lb)
29 mm (1.14 in)
347 mm (13.66 in)
367 mm (14.45 in)
S7506E fan tray (non-PoE)
2.20 kg (4.85 lb)
29 mm (1.14 in)
347 mm (13.66 in)
367 mm (14.45 in)
S7506E-MF fan tray
0.70 kg (1.54 lb)
27 mm (1.06 in)
100 mm (3.94 in)
347 mm (13.66 in)
S7506E-MF fan tray (non-PoE)
0.70 kg (1.54 lb)
27 mm (1.06 in)
100 mm (3.94 in)
347 mm (13.66 in)
S7506E-V fan tray
3.14 kg (6.92 lb)
45 mm (1.77 in)
435 mm (17.13 in)
377 mm (14.84 in)
S7510E fan tray
2.94 kg (6.48 lb)
28 mm (1.10 in)
497 mm (19.57 in)
351 mm (13.82 in)
Card power consumption
The power consumption of the cards depends on the card model and state. Table 1-6 shows the power consumption for different card models.
·     Static power consumption (min)—Power consumed by the card when the following conditions exist:
¡     The card is running but all ports on the card are down.
¡     No transceiver module is available on the optical interface of the card.
·     Dynamic power consumption (max)—Power consumed by the card when all the ports on the card are link up and are sending broadcasts.
Table 1-6 Card power consumption
Model
LSQ1MPUA0
10 W
15 W
LSQ1CGV24PSC0
25 W
45 W
LSQ1CGP24TSC0
30 W
60 W
LSQ1CTGS16SC0
83 W
110 W
40 W
45 W
25 W
30 W
42 W
50 W
50 W
60 W
53 W
60 W
42 W
60 W
55 W
65 W
LSQM3MPUA0
17 W
23 W
LSQM3MPUB0
36 W
60 W
LSQM2MPUC0
38 W
63 W
LSQM2MPUD0
55 W
96 W
LSQM2MPUDS0
45 W
86 W
LSQM1SRP8X2QE0
60 W
140 W
LSQM1CGP24TSSC0
28 W
55 W
LSQM1CGT24TSSC0
30 W
46 W
LSQM1CTGS24QSFD0
60 W
110 W
LSQM1TGS24QSFD0
60 W
107 W
LSQM1CQGS12SG0
55 W
147 W
LSQM1CGS2FE0
55 W
77 W
LSQM1QGS24RSG0
65 W
198 W
LSQ1QGS4SC0
70 W
90 W
LSQ1QGC4SC0
52 W
85 W
LSQ1GP24TXSD0
54 W
95 W
LSQ1P24XGSC0
40 W
55 W
LSQ1T24XGSC0
50 W
75 W
LSQ1TGX8SD0
73 W
120 W
LSQ1TGX4SD0
53 W
80 W
LSQ1TGX4EB0
53 W
80 W
LSQ1TGX2SC0
30 W
40 W
LSQ1TGX2SD0
43 W
55 W
LSQ1TGX2EB0
46 W
65 W
LSQ1TGX1EA0
35 W
45 W
LSQM2GT24PTSSC0
36 W
59 W
LSQM2GT24TSSC0
32 W
43 W
LSQM3GP44TSSC0
34 W
69 W
LSQM2GP44TSSC0
31 W
65 W
LSQM1GP40TS8FD0
47 W
96 W
LSQM2GP40TS8FD0
42 W
81 W
LSQM1TGS48RSG0
60 W
149 W
LSQM2TGS48SG0
67 W
152 W
LSQM1TGS48RFE0
50 W
122 W
LSQM1TGS16GPSA0
28 W
64 W
LSQM1TGS24FD0
50 W
104 W
LSQ1TGS16SC0
84 W
115 W
LSQM1TGS16FD0
54 W
90 W
LSQM2TGS16SF0
52 W
75 W
LSQ1TGS8SC0
75 W
95 W
LSQ1TGS4SC0
52 W
60 W
LSQM2GP24TSSA0
25 W
49 W
LSQM1TGS12EC0
82 W
130 W
LSQM1XPT12TSFD0
100 W
162 W
LSQM2XPT12TSFD0
100 W
162 W
LSQM1PT24TSSC0
80 W
115 W
LSQM1PT8TSSC0
56 W
80 W
LSQ4PT16PSC0
55 W
65 W
LSQ1PT16PSC0
55 W
65 W
LSQ1PT8PSC0
38 W
45 W
LSQ4PT8PSC0
38 W
45 W
LSQ1PT4PSC0
33 W
40 W
LSQ4PT4PSC0
33 W
40 W
LSQ1GV40PSC0
41 W
95 W
LSQ1GV24PSC0
30 W
60 W
LSQ1GV24PSA0
30 W
60 W
LSQ1GP24TSA0
25 W
45 W
LSQ1GP24TSC0
25 W
45 W
LSQ1GP24TEB0
50 W
90 W
LSQ1GP24TSD0
47 W
75 W
LSQ1GP48SC0
43 W
85 W
LSQ1GP48SD0
44 W
95 W
LSQ1GP48EB0
43 W
110 W
LSQM2GP48SA0
28 W
58 W
LSQM1GP48FD0
49 W
78 W
LSQ1GP24SC0
38 W
55 W
LSQM2GP24SA0
24 W
45 W
LSQ1GP12SC0
26 W
35 W
LSQ1GP12EA0
40 W
50 W
LSQ1FP48SA0
34 W
85 W
LSQ2FP48SA0
30 W
75 W
LSQM1TGT24FD0
60 W
112 W
LSQ1GV48SA0
60 W
80 W
LSQ1GV48SC0
60 W
90 W
LSQM2GT48SA0
35 W
45 W
LSQ1GV48SD0
67 W
95 W
LSQ3GV48SC0
67 W
95 W
LSQM2GT48SC0
38 W
48 W
LSQM1GT48FD0
48 W
65 W
LSQM4GV48SA0
34 W
44 W
LSQM4GV48SC0
38 W
48 W
LSQ1GT24SC0
42 W
50 W
LSQ2FT48SA0
24 W
30 W
LSQ1FV48SA0
30 W
35 W
LSU1WCME0
125 W
180 W
LSU3WCMD0
118 W
150 W
LSQ1WCMD0
86 W
117 W
LSQM1WCMX20
125 W
180 W
LSQM1WCMX40
125 W
180 W
LSQM1FWDSC0
115 W
123 W
LSU1FWCEA0
109 W
157 W
LSU3FWCEA0
109 W
157 W
LSUM1FWCEAB0
109 W
157 W
LSQ2FWBSC0
80 W
104 W
LSQ1FWBSC0
80 W
104 W
LSU1NSCEA0
109 W
157 W
LSQ1NSMSC0
80 W
104 W
LSQM1NSDSC0
115 W
123 W
LSU1IPSBEA0
109 W
157 W
LSQ1IPSSC0
80 W
104 W
LSQM1IPSDSC0
116 W
124 W
LSQ1SSLSC0
80 W
89 W
LSQ1ACGASC0
80 W
104 W
LSQM1ACGDSC0
116 W
124 W
LSU1ADECEA0
109 W
157 W
LSQM1ADEDSC0
116 W
124 W
LSQ1LBSC0
80 W
104 W
LSQM2FWDSC0
60 W
66 W
LSQM1EPSB0
102 W
124 W
LSQM1SDNB0
102 W
124 W
LSQM1WBCZ720X
160 W
210 W
Fan tray power consumption
The switch uses fan trays that can automatically adjust the fan speed based on the heat dissipation condition of the switch. The power consumed by a fan tray depends on the fan speed. Table 1-7 shows the power consumption of different fan trays.
Table 1-7 Fan tray power consumption
Model
Minimum fan tray power consumption
Maximum fan tray power consumption
S7502E
7.5 W
14.5 W
S7503E-S
7.5 W
14.5 W
S7503E-M
7.5 W
14.5 W
S7503E
15.5 W
27.5 W
S7506E-S
24.5 W
42.5 W
S7506E
24.5 W
42.5 W
S7506E (non-PoE)
24.5 W
42.5 W
S7506E-MF
7.00 W
14.00 W
S7506E-MF (non-PoE)
7.00 W
14.00 W
S7506E-V
30 W
45.5 W
S7510E
28 W
48.5 W
For the S7506E-S, S7506E (non-PoE), or S7506E-MF (non-PoE), the total power consumption of the switch equals its system power consumption.
For the S7502E, S7503E-S, S7503E, S7506E, S7506E-MF, S7506E-V, or S7510E, the total power consumption of the switch equals its system power consumption plus its PoE power consumption.
System power consumption
The system power consumption of the switch depends on the type and number of the running cards and the fan tray power consumption.
·     The minimum system power consumption is the total static power consumption of all cards plus the minimum fan tray power consumption. For example, an S7503E switch is installed with two LSQM2MPUC0 MPUs, three LSQ3GV48SC0 (LSQM3GV48SC0) service modules, and one fan tray. The minimum system power consumption of the switch is 2 × 38 + 3 × 67 + 15.5 = 292.5 W.
·     The maximum system power consumption is the total dynamic power consumption of all cards plus the maximum fan tray power consumption. For example, an S7503E switch is installed with two LSQM2MPUC0 MPUs, three LSQ3GV48SC0 (LSQM3GV48SC0) service modules, and one fan tray. The maximum system power consumption of the switch is 2 × 63 + 3 × 95 +27.5 = 438.5 W.
The power over Ethernet (PoE) power consumption refers to the sum of power consumptions of all powered devices (PDs) connected to the switch.
The maximum PoE power consumption refers to the sum of the power consumption of all PDs when all power interfaces (PIs) are connected to PDs and consume the maximum power. The maximum PoE power consumption is decided by the following items:
·     Number of the PoE cards (PSEs) installed on the switch.
·     Number of the PIs that each PoE card provides.
·     Maximum power of each PoE card.
·     Maximum PoE power that each slot of the switch provides.
Each slot of the switch can provide a maximum PoE power of 800 W.
Table 1-8 shows the specifications for each PoE card model.
For example, an S7503E switch is installed with three LSQ3GV48SC0 (LSQM3GV48SC0) PoE cards. The maximum PoE power consumption of the switch is 3 × 800 = 2400 W.
Table 1-8 PoE card specifications
Model
PI quantity
PI power
Maximum PSE power
Maximum number
LSQ1GV48SD0
48
0 to 30 W
800 W
·     S7502E: 2
·     S7503E: 3
·     S7506E: 6
·     S7506E-MF: 6
·     S7506E-V: 6
·     S7510E: 10
LSQ3GV48SC0
48
0 to 30 W
800 W
·     S7502E: 2
·     S7503E: 3
·     S7506E: 6
·     S7506E-MF: 6
·     S7506E-V: 6
·     S7510E: 10
LSQM4GV48SA0
48
0 to 30 W
1440 W
·     S7502E: 2
·     S7503E: 3
·     S7506E: 6
·     S7506E-MF: 6
·     S7506E-V: 6
·     S7510E: 10
LSQM4GV48SC0
48
0 to 30 W
1440 W
·     S7502E: 2
·     S7503E: 3
·     S7506E: 6
·     S7506E-MF: 6
·     S7506E-V: 6
·     S7510E: 10
LSQ1CGV24PSC0
24
0 to 15.4 W
370 W
·     S7502E: 2
·     S7503E: 3
·     S7506E: 6
·     S7506E-MF: 6
·     S7506E-V: 6
·     S7510E: 10
LSQ1GV24PSC0
24
0 to 15.4 W
370 W
·     S7502E: 2
·     S7503E: 3
·     S7506E: 6
·     S7506E-MF: 6
·     S7506E-V: 6
·     S7510E: 10
LSQ1GV24PSA0
24
0 to 15.4 W
370 W
·     S7502E: 2
·     S7503E: 3
·     S7506E: 6
·     S7506E-MF: 6
·     S7506E-V: 6
·     S7510E: 10
LSQ1FV48SA0
48
0 to 15.4 W
740 W
·     S7502E: 2
·     S7503E: 3
·     S7506E: 6
·     S7506E-MF: 6
·     S7506E-V: 6
·     S7510E: 10
LSQ1GV48SA0
48
0 to 15.4 W
740 W
·     S7502E: 2
·     S7503E: 3
·     S7506E: 6
·     S7506E-MF: 6
·     S7506E-V: 6
·     S7510E: 10
LSQ1GV48SC0
48
0 to 15.4 W
740 W
·     S7502E: 2
·     S7503E: 3
·     S7506E: 6
·     S7506E-MF: 6
·     S7506E-V: 6
·     S7510E: 10
LSQ1GV40PSC0
40
0 to 15.4 W
616 W
·     S7502E: 2
·     S7503E: 3
·     S7506E: 6
·     S7506E-MF: 6
·     S7506E-V: 6
·     S7510E: 10
·     The PoE power consumption is 0 if the switch does not supply PoE.
·     The maximum PoE power consumption of the S7510E switch is 10000 W.
·     For more information about PoE power supply, see H3C S7500E Switch Series Installation Guide.
Heat dissipation
Heat dissipation is measured in BTU/h, and 1 W equals 3.4121BTU/h.
The heat dissipation of a switch depends on its power consumption. To calculate heat dissipation of the switch, assume 90% power consumption is converted to heat, and the efficiency of the power module is 90%. Heat dissipation/hour of the switch is 0.9 × (total power consumption of the cards plus power consumption of the fan tray)/0.9 × 3.4121.
Table 1-9 shows the heat dissipation for each switch model.
Table 1-9 Heat dissipation
Model
Heat dissipation (BTU/h)
S7502E
1223
S7503E-S
1190
S7503E-M
1441
S7503E
2574
S7506E-S
3605
S7506E
4151
S7506E (non-PoE)
3605
S7506E-MF
4151
S7506E-MF (non-PoE)
3605
S7506E-V
4161
S7510E
6195
For the power consumption of the cards and fan trays of the S7500E series switches, see "Module power consumption."
Noise
The switch uses fan trays that can adjust the fan speed automatically based on the device temperature. The sound pressure levels vary by fan speed. For more information, see Table 1-10.
Table 1-10 Sound pressure levels
Model
Sound pressure level when the fan tray operates at low speed
Sound pressure level when the fan tray operates at middle speed
Sound pressure level when the fan tray operates at full speed
S7502E
49.8 dBA
51.6 dBA
56.7 dBA
S7503E-S
49.8 dBA
51.6 dBA
56.7 dBA
S7503E-M
49.8 dBA
51.6 dBA
56.7 dBA
S7503E
51.6 dBA
54.6 dBA
56.1 dBA
S7506E-S
53.6 dBA
56.2 dBA
57.7 dBA
S7506E
53.6 dBA
56.2 dBA
57.7 dBA
S7506E (non-PoE)
53.6 dBA
56.2 dBA
56.7 dBA
S7506E-MF
53.6 dBA
56.2 dBA
57.7 dBA
S7506E-MF (non-PoE)
53.6 dBA
56.2 dBA
56.7 dBA
S7506E-V
52.1 dBA
55.1 dBA
56.2 dBA
S7510E
53.5 dBA
55.8 dBA
56.7 dBA
For the compatibility between transceiver modules and cards, see H3C S7500E Switch Series Cards and Transceiver Modules Compatibility Matrixes.
MPUs
You can install one MPU, or two MPUs for redundancy on the S7500E switches except the S7503E-S switch.
Table 2-1 MPU specifications (1)
Model
Port quantity
Console port
Network management port
CF card slot
Other ports
LSQ1MPUA0
1
1
1
N/A
LSQ1CGV24PSC0
1
1
N/A
·     20 × 10/100/1000BASE-T RJ-45 ports
·     4 x combo interfaces
LSQ1CGP24TSC0
1
1
N/A
·     16 × FE/GE SFP ports (LC)
·     8 x combo interfaces
LSQ1CTGS16SC0
1
1
N/A
16 × 10GE SFP+ ports (LC)
LSQ1MPUB0
(Salience VI-Lite)
1
1
1
N/A
LSQ1SRPA0
(Salience VI-Smart)
1
1
N/A
N/A
LSQ1SRPB0
(Salience VI)
1
1
1
N/A
LSQ1SRPD0
(Salience VI-Plus)
1
1
1
N/A
LSQ1SRP1CB0
(Salience VI-Turbo)
1
1
1
N/A
LSQ1SRP12GB0
(Salience VI-GE)
1
1
1
12 × FE/GE SFP ports (LC)
LSQ1SRP2XB0
(Salience VI-10GE)
1
1
1
2 × 10GE XFP ports (LC)
Table 2-2 MPU specifications (2)
Model
Specifications
Flash memory
NVRAM
SDRAM
Ports
LSQM3MPUA0
1 GB
1 MB
4 GB
·     1 × console port
·     1 × network management port
·     1 × USB port
LSQM3MPUB0
1 GB
1 MB
2 GB
·     1 × console port
·     1 × USB console port
·     2 × network management ports (one 10/100/1000BASE-T port and one SFP port)
·     1 × USB port
LSQM2MPUC0
1 GB
1 MB
4 GB
·     1 × console port
·     4 × network management ports (two 10/100/1000BASE-T ports and two SFP ports)
·     1 × USB port
LSQM2MPUD0
1 GB
1 MB
4 GB
·     1 × console port
·     2 × QSFP+ ports
·     1 × USB port
LSQM2MPUDS0
1 GB
1 MB
4 GB
·     1 × console port
·     1 × USB port
LSQM1SRP8X2QE0
1 GB
1 MB
4 GB
·     1 × console port
·     8 × SFP+ ports
·     2 × QSFP+ ports
·     1 × USB port
LSQM1CGP24TSSC0
2 GB
1 MB
2 GB
·     1 × console port
·     1 × 10/100/1000BASE-T network management port
·     24 × SFP ports
·     4 × SFP+ ports
·     1 × USB port
LSQM1CGT24TSSC0
2 GB
1 MB
2 GB
·     1 × console port
·     24 × RJ-45 ports
·     4 × SFP+ ports
·     1 × USB port
LSQM1CTGS24QSFD0
2 GB
1 MB
2 GB
·     1 × console port
·     2 × network management ports (One RJ-45 port and one SFP port)
·     24 × 10GBASE-R-SFP+ fiber ports
·     2 × 40GBASE-R-QSFP+ fiber ports or 1 × 100G QSFP28 fiber port
·     1 × USB port
IMPORTANT
IMPORTANT:
·     Among the network management ports on the LSQM3MPUB0, LSQM2MPUC0, LSQM2MPUD0, LSQM1CTGS24QSFD0, LSQM2MPUDS0, and LSQM1SRP8X2QE0 MPUs, only port 0 is available during the startup of the switch.
·     The two QSFP+ ports on the LSQM2MPUD0 MPU are designed only for IRF connection. They do not forward service packets.
·     To connect an SFP management Ethernet port on the MPUs, make sure the peer port operates at 1000 Mbps in full-duplex mode.
·     The USB ports on the MPUs do not support USB extension cables.
·     The switch does not support mixture of different models of MPUs, except the mixture of an LSQM1CGP24TSSC0 and an LSQM1CGT24TSSC0 MPU.
·     For an S7503E-M switch, you can install either an MPU or a service module in slot 1.
Table 2-3 MPU and chassis compatibility matrix
Power module
Chassis
S7502E
S7503E-S
S7503E-M
S7503E
S7506E-S
S7506E/S7506E-MF
S7506E (non-PoE)/S7506E-MF (non-PoE)
S7506E-V
S7510E
LSQ1MPUA0
Yes
No
No
No
No
No
No
No
No
LSQ1CGP24TSC0
No
Yes
No
No
No
No
No
No
No
LSQ1CGV24PSC0
No
Yes
No
No
No
No
No
No
No
LSQ1CTGS16SC0
No
Yes
No
No
No
No
No
No
No
No
No
No
Yes
No
Yes
No
Yes
Yes
No
No
No
No
Yes
No
No
No
No
No
No
No
Yes
No
Yes
No
Yes
Yes
No
No
No
Yes
No
Yes
No
Yes
Yes
No
No
No
Yes
No
Yes
No
Yes
Yes
No
No
No
Yes
No
Yes
No
Yes
Yes
No
No
No
Yes
No
Yes
No
Yes
Yes
LSQM3MPUA0
Yes
No
No
No
No
No
No
No
No
LSQM3MPUB0
No
No
No
No
No
No
Yes
No
No
LSQM2MPUC0
No
No
No
Yes
No
Yes
No
Yes
Yes
LSQM2MPUD0
No
No
No
Yes
No
Yes
No
Yes
Yes
LSQM2MPUDS0
No
No
No
Yes
No
Yes
No
Yes
Yes
LSQM1SRP8X2QE0
No
No
No
Yes
No
Yes
No
Yes
Yes
LSQM1CGP24TSSC0
No
No
Yes
No
No
No
No
No
No
LSQM1CGT24TSSC0
No
No
Yes
No
No
No
No
No
No
LSQM1CTGS24QSFD0
No
No
Yes
No
No
No
No
No
No
For the system software versions that an MPU is compatible with, see the MPU manual.
Service modules
Follow these restrictions and guidelines to use service modules:
·     For the switch models and system software versions that a service module is compatible with, see the service module manual.
·     The model name marked on the front panel of a module might be slightly different from the model name used for sale. For example, LSQ1QGS4SC0 and LSQM1QGS4SC0 identify the same module. LSQ1QGS4SC0 is marked on the module panel. When you order the module, you refer to it as LSQM1QGS4SC0.
·     A combo interface is a logical interface that contains an SFP port and an RJ-45 Ethernet port. Only one of them can be activated at a time.
·     Service modules supported by the S7510E switch vary by the forwarding mode of the slots. For more information, see device management configuration in H3C S7500E Switch Series Fundamentals Configuration Guide.
·     Follow these guidelines to use service modules on an S7502E switch:
¡     Do not use an LSQM1TGS16FD0 interface module with the following modules:
-     EC interface modules.
-     SD interface modules.
-     EB interface modules.
-     LSQ1TGS8SC0 interface module.
-     LSQ3GV48SC0 interface module.
-     OAA modules: LSU1FWCEA0, LSU3FWCEA0, LSU3WCMD0, LSU1ADECEA0, LSU1NSCEA0, LSUM1FWCEAB0, LSU1IPSBEA0, LSU1WCME0, LSQM1WCMX40, and LSQM1WCMX20.
¡     Do not use an FD interface module (except the LSQM1TGS16FD0), FE interface module, LSQM1EPSB0 module, or LSQM1SDNB0 module with the following modules:
-     SA interface modules.
¡     Do not use an LSQM1TGS16GPSA0 interface module with the following modules:
·     For an S7510E switch installed with an LSQM2MPUC0 MPU, support for FD and FE interface modules depends on the system version:
¡     In a version earlier than R7577P02, the S7510E switch does not support FD or FE interface modules.
¡     In a version between R7577P02 and R7577P04, the S7510E switch supports only LSQM1TGS16FD0 and LSQM1GP40TS8FD0 interface modules.
¡     In a version between R7577P05 and R7577P06, the S7510E switch supports only LSQM1TGS16FD0, LSQM1GP40TS8FD0, and LSQM1TGS48RFE0 interface modules.
¡     In R7585 or later, the S7510E switch supports all FD and FE interface modules.
·     After you convert 40G ports on an LSQM1CQGS12SG0 interface module to 100G ports, only ports 1, 4, 7, and 10 are available.
·     To avoid module damage, do not install an LSQM2TGS48SG0, LSQM1CGS2FE0, or LSQM1CQGS12SG0 interface module in slot 10 on an S7510E switch.
·     7522 and later versions do not support the LSQ2FWBSC0, LSQ1NSMSC0, LSQ1FWBSC0, LSQ1LBSC0, LSQ1SSLSC0, LSQ1ACGASC0, LSQ1IPSSC0, or LSQ1WCMD0 module.
Interface modules
Table 2-4 Interface module specifications
Model
Port quantity
Port type
Available transceiver modules and network cables
LSQM1TGS24QSFD0
26
·     QSFP28 transceiver module
·     QSFP28 DAC cable
·     QSFP+ transceiver module
·     QSFP+ DAC cable
·     QSFP+ to SFP+ DAC cable
·     10-GE SFP+ transceiver module
·     10-GE SFP+ DAC cable
·     GE SFP transceiver module
LSQM1CQGS12SG0
12
4 × 100GBASE-R QSFP28 fiber ports or 12 × 40GBASE-R QSFP+ fiber ports
·     QSFP28 DAC cable
·     QSFP+ DAC cable
LSQM1CGS2FE0
2
·     QSFP28 DAC cable
LSQM1QGS24RSG0
24
·     QSFP+ DAC cable
LSQ1QGS4SC0
4
·     QSFP+ DAC cable
LSQ1QGC4SC0
4
40GBASE-R-CFP fiber port
10-GE CFP transceiver module
LSQ1GP24TXSD0
26
·     2 × 10GBASE-R/W XFP/LC fiber ports
·     16 × 1000BASE-X-SFP/LC fiber ports
·     8 × combo interfaces
·     10-GE XFP transceiver module
·     FE/GE SFP transceiver module
·     Category 5 twisted-pair cable
LSQ1P24XGSC0
26
·     2 × 10GBASE-R XFP/LC fiber ports
·     24 × 1000BASE-X-SFP/LC fiber ports
LSQ1T24XGSC0
26
·     24 × 10/100/1000BASE-T-RJ45 copper ports
LSQ1TGX8SD0
8
LSQ1TGX4SD0
4
LSQ1TGX4EB0
4
LSQ1TGX2SC0
2
LSQ1TGX2SD0
2
LSQ1TGX2EB0
2
LSQ1TGX1EA0
1
LSQM2GT24PTSSC0
48
·     4 × 10GBASE-R SFP+/LC fiber ports
·     20 × 1000BASE-X-SFP/LC fiber ports
LSQM2GT24TSSC0
28
LSQM3GP44TSSC0
48
·     4 × 10GBASE-R-SFP+ fiber ports (support for MACsec)
·     44 × 1000BASE-X-SFP fiber ports (support for MACsec)
LSQM2GP44TSSC0
48
·     44 × 1000BASE-X-SFP/LC fiber ports
LSQM1GP40TS8FD0
48
·     8 × 10GBASE-R-SFP+/LC fiber ports
·     40 × 1000BASE-X-SFP/LC fiber ports
LSQM2GP40TS8FD0
48
LSQM1TGS48RSG0
48
LSQM2TGS48SG0
48
10GBASE-R SFP+ fiber port
LSQM1TGS48RFE0
48
LSQM1TGS16GPSA0
40
·     16 × 10GBASE-R-SFP+/LC fiber ports
LSQM1TGS24FD0
24
LSQ1TGS16SC0
16
LSQM1TGS16FD0
16
LSQM2TGS16SF0
16
LSQ1TGS8SC0
8
LSQ1TGS4SC0
4
LSQM2GP24TSSA0
28
·     4 × 10GBASE-R/ SFP+/LC fiber ports
LSQM1TGS12EC0
12
LSQM1XPT12TSFD0
20
·     12 × 10G EPON OLT/SC fiber ports
·     XFP EPON transceiver module
LSQM2XPT12TSFD0
20
·     SFP+ EPON transceiver module
LSQM1PT24TSSC0
26
·     24 × 1000BASE-PX-SFP/SC fiber ports
·     2 × 10GBASE-R SFP+/LC fiber ports
·     SFP EPON transceiver module
LSQM1PT8TSSC0
10
·     8 × 1000BASE-PX-SFP/SC fiber ports
·     2 × 10GBASE-X-SFP/LC fiber ports
LSQ4PT16PSC0
24
·     16 × 1000BASE-PX-SFP/SC fiber ports
·     8 × 1000BASE-X-SFP/LC fiber ports
·     EPON transceiver module
LSQ1PT16PSC0
24
LSQ4PT16PSC0
24
LSQ1PT8PSC0
16
LSQ4PT8PSC0
16
LSQ1PT4PSC0
12
·     4 × 1000BASE-PX-SFP/SC fiber ports
LSQ4PT4PSC0
12
LSQ1GV40PSC0
48
·     40 × 10/100/1000BASE-T-RJ45 copper ports
LSQ1GV24PSC0
24
·     20 × 10/100/1000BASE-T-RJ45 copper ports
·     4 × combo interfaces
LSQ1GV24PSA0
24
LSQ1GP24TSA0
24
LSQ1GP24TSC0
24
LSQ1GP24TEB0
24
LSQ1GP24TSD0
24
LSQ1GP48SC0
48
LSQ1GP48SD0
48
LSQ1GP48EB0
48
LSQM2GP48SA0
48
LSQM1GP48FD0
48
LSQ1GP24SC0
24
LSQM2GP24SA0
24
LSQ1GP12SC0
12
LSQ1GP12EA0
12
LSQ1FP48SA0
48
100BASE-FX-SFP/LC fiber port
FE SFP transceiver module
LSQ2FP48SA0
48
LSQM1TGT24FD0
24
10GBASE-T-RJ45 copper port
Category 6A/7 twisted-pair cable
LSQ1GV48SA0
48
LSQ1GV48SC0
48
LSQM2GT48SA0
48
LSQ1GV48SD0
48
LSQ3GV48SC0
48
LSQM2GT48SC0
48
LSQM1GT48FD0
48
LSQM4GV48SA0
48
LSQM4GV48SC0
48
LSQ1GT24SC0
24
LSQ2FT48SA0
48
10/100BASE-TX-RJ45 copper port
LSQ1FV48SA0
48
OAA modules
Table 2-5 OAA module specifications
Model
Ports
Compatible transceiver modules
LSU1WCME0
High-performance access controller module
·     1 × console port
·     1 ×100/1000BASE-T out-of-band management Ethernet port
Category 5 or above twisted pair cable
LSU3WCMD0
·     1 × console port
·     1 × CF card slot (supporting 256-MB, 512-MB, and 1-GB CF cards)
·     2 × USB ports
·     2 × 10/100/1000BASE-T copper ports
·     2 × GE combo interfaces
·     Category 5 twisted pair cable
LSQ1WCMD0
·     1 × console port
·     2 × USB ports
LSQM1WCMX20
Access controller module
·     1 × console port
·     1 × 10/100/1000BASE-T out-of-band management Ethernet port
LSQM1WCMX40
·     1 × console port
LSQM1FWDSC0
Firewall module
·     1 × console port
·     1 × USB port (reserved for future use)
·     1 × GE Ethernet copper port
·     1 × hard disk slot
LSU1FWCEA0
Firewall module
·     1 × console port
·     2 × USB ports (reserved)
LSU3FWCEA0
Firewall module
·     1 × console port
·     2 × USB ports
LSUM1FWCEAB0
Firewall module
·     1 × console port
·     2 × USB ports
LSQ2FWBSC0
Firewall module
·     1 × console port
·     2 × USB ports
LSQ1FWBSC0
Firewall module
·     1 × console port
·     2 × USB ports
LSU1NSCEA0
10-GE high performance NetStream module
·     1 × console port
·     Category 5 or above twisted pair cable
LSQ1NSMSC0
NetStream module
·     1 × console port
·     2 × USB ports
LSQM1NSDSC0
NetStream module
·     1 × console port
LSU1IPSBEA0
Intrusion prevention system module
·     1 × console port
·     2 × USB ports
LSQ1IPSSC0
·     1 × console port
·     2 × USB ports
LSQM1IPSDSC0
·     1 × console port
·     1 × USB port (only for supplying power to a PFC)
·     1 × 10/100/1000BASE-T copper port
LSQ1SSLSC0
SSL VPN module
·     1 × console port
·     2 × USB ports
LSQ1ACGASC0
Application control gateway module
·     1 × console port
·     2 × USB ports
LSQM1ACGDSC0
·     1 × console port
·     1 × USB port (reserved)
LSU1ADECEA0
Application delivery engine module
·     1 × console port
·     2 × USB ports
LSQM1ADEDSC0
·     1 × console port
LSQ1LBSC0
Load balancing module
·     1 × console port
·     1 × CF card slot (supporting a 256-MB, 512-MB, or 1-GB CF card)
·     2 USB ports
LSQM2FWDSC0
High-performance service module
·     1 × console port
·     2 × USB ports
·     4 × 10GBASE-R fiber ports
·     1 × hard disk
LSQM1EPSB0
EPS endpoint security module
·     3 × USB 2.0 ports (used by technical support for debugging only)
·     1 × VGA connector
·     1 × 10/100/1000BASE-T management Ethernet port
·     1 × console port (used by technical support for debugging only)
LSQM1SDNB0
SDN automation module
·     1 × VGA connector
LSQM1WBCZ720X
Multiservice access controller module
·     1 × VGA connector
·     1 × 1000BASE-T management Ethernet port
·     1 × console port
Power system
Before you order a power module, make sure you have read the following restrictions and guidelines:
·     A chassis must be configured with a minimum of one power module. To improve power supply availability, you can configure a chassis with two power modules for redundancy.
·     The power modules installed on an S7500E switch must be the same type (AC or DC) and model.
·     Make sure the maximum output power of a power module is greater than the total power consumption of the switch. As a best practice, reserve 20% of the maximum output power. For more information about the total power consumption, see "Module power consumption."
·     If you want the switch to provide PoE power for PDs, order a power module that can be used for setting up a PoE system. Make sure the maximum PoE power provided by the power module is greater than the PoE power consumption. The requirements for setting up a PoE system vary by switch model. For more information about setting up a PoE system, see H3C S7500E Switch Series Installation Guide.
Power modules
CAUTION
CAUTION:
·     Do not install a PSR1200-A/PSR1200-D power module on an LSQM1PWRSPA power module adapter.
·     Do not install an LSQM1PWRSPA power module adapter on an S7510E switch.
Table 2-6 300 W power module specifications
Item
PSR320-A
PSR320-D
Rated input voltage
100 VAC to 240 VAC @ 50 Hz or 60 Hz
–48 VDC to 60 VDC
Rated output voltage
12 VDC
Max input current
10 A
11 A
Max output current
25 A
Max system output power
300 W
Support for PoE
No
Max PoE output power
N/A
Table 2-7 650 W power module specifications
Item
PSR650-A
PSR650C-12A
PSR650-D
PSR650C-12D
Rated input voltage
–48 VDC to 60 VDC
–48 VDC to 60 VDC
12 VDC
Max input current
10 A
10 A
25 A
25 A
Max output current
54 A
54 A
·     12 V: 54 A
·     3.3 V: 4 A
54 A
650 W
Support for PoE
No
N/A
Table 2-8 1200 W power module specifications
Item
PSR1200-A
PSR1200-D
Rated input voltage
–48 VDC to 60 VDC
·     12 VDC
·     3.3 VDC
Max input current
16 A
42 A
Max output current
·     12 V: 100 A
·     3.3 V: 4 A
1213 W
Support for PoE
No
N/A
Table 2-9 1400 W power module specifications
Item
PSR1400-A
PSR1400-12A1-F
PSR1400-D
PSR1400-12D1
Rated input voltage
–48 VDC to 60 VDC
–48 VDC to 60 VDC
12 VDC
12 VDC
·     12 VDC
·     PoE: 48 VDC
12 VDC
Max input current
16 A
16 A
190 A
50 A
Max output current
117 A
117 A
·     12 V output: 117 A
·     PoE: 140 A
117 A
1150 W (110 VAC)
1400 W (220 VAC)
1150 W (110 VAC)
1400 W (220 VAC or 270 VDC)
1400 W
1400 W
Support for PoE
No
No
Yes
No
N/A
N/A
6720 W
N/A
Table 2-10 2500 W power module specifications
Item
PSR2500-12AHD
PSR2500-12D
Rated input voltage
·     100 VAC to 240 VAC @ 50 Hz or 60 Hz
·     240 VDC to 380 VDC
–48 VDC to 60 VDC
12 VDC
Max input current
16 A
85 A
Max output current
·     90 VAC to 180 VAC input: 100 A
·     180 VAC to 290 VAC or 180 VDC to 400 VDC input: 208 A
208 A
2500 W
Support for PoE
No
N/A
Table 2-11 2800 W power module specifications
Item
PSR2800-ACV
PSR2800-A1-F
Rated input voltage
·     12 VDC
·     PoE: –50 VDC
Max input current
16 A
Max output current
·     PoE: 28 A
1150 W (110 VAC)
1400 W (220 VAC)
1150 W (110 VAC)
Support for PoE
Yes
1150 W (110 VAC)
1400 W (220 VAC)
1150 W (110 VAC)
Table 2-12 6000 W power module specifications
Item
PSR6000-ACV
Rated input voltage
·     12 VDC
·     PoE: 48 VDC
Max input current
16 A
Max output current
110 V input:
·     12 VDC: 96 A
·     One PoE input: 23 A
·     Two PoE inputs: 46 A
·     Three PoE inputs: 69 A
220 V input:
·     12 VDC: 117 A
·     One PoE input: 34 A
·     Two PoE inputs: 68 A
·     Three PoE inputs: 100 A
1150 W (110 VAC)
1400 W (220 VAC)
Support for PoE
Yes
110 V input:
·     One PoE input: 1200 W
·     Two PoE inputs: 2400 W
·     Three PoE inputs: 3600 W
220 V input:
·     One PoE input: 1800 W
·     Two PoE inputs: 3600 W
·     Three PoE inputs: 5300 W
The maximum PoE output power is 10000 W when the device is fully configured with the PSR1400-D or PSR6000-ACV power modules.
Table 2-13 Power module and chassis compatibility matrix
Power module
Chassis
S7502E
S7503E-S
S7503E-M
S7503E
S7506E-S
S7506E/S7506E-MF
S7506E-V
S7510E
PSR320-A
l
l
l
PSR320-D
l
l
PSR650-A
l
l
l
PSR650-D
l
l
l
PSR650C-12A
l
l
l
l
PSR650C-12D
l
l
l
l
PSR1200-A
PSR1200-D
PSR1400-A
l
l
l
l
l
l
PSR1400-12A1-F
l
l
l
l
l
l
PSR1400-D
l
l
l
l
l
l
PSR1400-12D1
l
l
l
l
l
l
PSR2500-12AHD
l
l
l
l
l
PSR2500-12D
l
l
l
l
l
PSR2800-ACV
l
l
l
l
l
PSR2800-A1-F
l
l
l
l
l
PSR6000-ACV
l
l
l
l
l
·     "l" indicates that the power module can be directly installed on the chassis.
·     "¡" indicates that you must first install a power module adapter on the chassis and then install the power module on the power module adapter. For more information about installing a power module and a power module adapter, see H3C S7500E Switch Series Installation Guide.
·     "—" indicates that the power module cannot be installed on the chassis.
Power cords
DC power cords
A DC power cord connects a DC power module to an external DC power source.
Table 2-14 DC power cords available for DC power modules
DC power cord code
DC power cord length
DC power module
0404A06T
3 m (9.84 ft)
PSR320-D/PSR650-D/PSR650C-12D
0404A01N
5 m (16.40 ft)
0404A01P
10 m (32.81 ft)
0404A073
20 m (65.62 ft)
0404A0DU
3 m (9.84 ft)
PSR1200-D
0404A07G
3 m (9.84 ft)
PSR1400-D/PSR1400-12D1/PSR2500-12D
0404A08T
10 m (32.81 ft)
0404A08U
20 m (65.62 ft)
0404A072
25 m (82.02 ft)
0404A0RL
3 m (9.84 ft)
PSR2500-12AHD (240 to 380 VDC)
AC power cords
AC power cords are used for connecting the power modules of an S7500E switch to the external AC power supply system. Before you order an AC power cord, make sure you have read the following restrictions and guidelines:
·     Select AC power cords according to the power of the power module.
·     The connector type varies by country or region. Select a compliant connector type as needed.
·     For the PSR320-A, PSR650-A, and PSR650C-12A power modules, select 10A AC power cords.
·     For the PSR1200-A, PSR1400-A, PSR1400-12A1-F, PSR2500-12AHD, PSR2800-ACV, PSR2800-A1-F, and PSR6000-ACV power modules, select 16A AC power cords.
·     For the PSR2500-12AHD power module, select the 0404A0RP or 0404A0RQ AC power cord. The 0404A0RP and 0404A0RQ AC power cords can only be used for the PSR2500-12AHD power module.
·     The type of the connector (connected to the power source) varies by country or region. Select a compliant connector type as needed. For the connector types of different countries or regions and the power cord codes, see H3C Power Cords & Cables User Guide.
PoE power system
PoE DC power cords
PoE DC power cords are used to connect the PoE PEM of the switch and the PoE external power frame.
Table 2-15 PoE DC power cord specifications
DC power module
PoE DC power cord
Cable length
PSR2800-ACV/ PSR2800-A1-F/PSR6000-ACV
0404A05U
1 m (3.28 ft)
PSR1400-D
0404A07H
3 m (9.84 ft)
PoE AC power cords
The S7500E switch uses 16 A PoE AC power cords. PoE AC power cords are used to connect the PoE AC PEM held in the PoE external power frame and the external AC power source.
Fan trays
The fans trays are shipped with the S7500E switches, and have been installed in the S7500E switches. If the fan tray of a switch fails, order a compatible fan tray to replace the faulty one.
Table 2-16 shows the available fan trays for different models of S7500E switches.
Table 2-16 Fan tray specifications
Fan tray
Number of fan trays
Number of fans
Fan diameter
Maximum air flow rate
S7502E fan tray
1
3
92 mm (3.62 in)
165 CFM (4.67 m³/min)
S7503E-S fan tray
1
3
92 mm (3.62 in)
S7503E-M fan tray
1
3
92 mm (3.62 in)
S7503E fan tray
1
6
92 mm (3.62 in)
330 CFM (9.34 m³/min)
S7506E-S fan tray
1
9
92 mm (3.62 in)
495 CFM (14.02 m³/min)
S7506E fan tray
1
9
92 mm (3.62 in)
S7506E (non-PoE) fan tray
1
9
92 mm (3.62 in)
S7506E-MF fan tray
3
1 small fan + 2 large fans
·     Small fan: 80 mm (3.15 in)
·     Large fan: 92 mm (3.62 in)
150 CFM (4.25 m³/min)
S7506E-MF (non-PoE) fan tray
3
S7506E-V fan tray
1
6
120 mm (4.72 in)
546 CFM (15.46 m³/min)
S7510E fan tray
1
6
92 mm (3.62 in)
662 CFM (18.75 m³/min)
4
120 mm (4.72 in)
3 LEDs
The MPUs, service modules, and power modules available for the switch use multiple LEDs to indicate their operating status. The LED type and quantity vary by module model.
Table 3-1 lists the LEDs on the MPUs, service modules, and power modules.
Unless otherwise specified, the flashing frequency of the LEDs in this section is 0.5 Hz.
Table 3-1 LEDs at a glance
LEDs
MPU LEDs
·     Management Ethernet port LEDs
·     Power module status LEDs
·     Fan tray status LEDs
·     Card status LEDs
·     MPU active/standby status LED
·     CF card status LED
·     RJ-45 Ethernet port LEDs
·     Combo interface LEDs
·     SFP port LEDs
·     SFP+ port LEDs
·     QSFP+ port LEDs
·     QSFP28 port LEDs
·     XFP port LEDs
Service module LEDs
·     SFP port LEDs
·     SFP+ port LEDs
·     XFP port LEDs
·     QSFP+ port LEDs
·     QSFP28 port LEDs
·     CFP port LEDs
·     EPON port LEDs
Power module LEDs
·     PSR320-A/PSR320-D
·     PSR650-A/PSR650-D/PSR1200-A/PSR1200-D
·     PSR650C-12A/PSR650C-12D/PSR1400-A/PSR1400-12A1-F/PSR2500-12AHD/PSR2500-12D
·     PSR1400-D
·     PSR1400-12D1
·     PSR2800-ACV/PSR2800-A1-F
·     PSR6000-ACV
Fan tray LEDs
MPU LEDs
Multiple MPU models are available for the switch. The LED type and quality vary by MPU model. The LSQM3MPUA0 MPU and LSQM2MPUC0 MPU are used in Figure 3-1 and Figure 3-2, respectively, for illustration.
Figure 3-1 LEDs on the LSQM3MPUA0 MPU
(1) Management Ethernet port LED (LINK/ACT)
(2) Service module status LEDs (LPU RUN and ALM)
(3) MPU active/standby status LED (ACTIVE)
(4) MPU status LED (RUN)
(5) Fan tray status LEDs (FAN OK and FAIL)
(6) Power module status LEDs (PWR OK and FAIL)
Figure 3-2 LEDs on the LSQM2MPUC0 MPU
(1) Management Ethernet copper port LEDs (LINK and ACT)
(2) Management Ethernet fiber port LEDs (LINK and ACT)
(3) Card status LEDs (SLOT X)
(4) MPU active/standby status LED (ACTIVE)
(5) Fan tray status LED (FAN)
(6) Power module status LED (PWR)
For a management Ethernet port that uses a LINK/ACT LED to indicate its link status and data forwarding status, see Table 3-2 for the LED description.
For a management Ethernet port that uses two LEDs LINK and ACT to indicate its link status and data forwarding status, see Table 3-3 for the LED description.
Table 3-2 Management Ethernet port LED description (1)
LINK/ACT LED status
Flashing green
A link is present, and the port is receiving or sending data.
Steady green
A link is present.
Off
No link is present.
Table 3-3 Management Ethernet port LED description (2)
LINK LED status
ACT LED status
On
Flashing
On
Off
A link is present.
Off
Off
No link is present.
Power module status LED varies by MPU model.
·     If the MPU provides one set of LEDs (OK and FAIL) to indicate the status of the power modules, see Table 3-4 for the LED description.
·     If the MPU provides multiple LEDs with numbers (for example, PWR1 and PWR2), each LED corresponds to a pluggable power module with the same number (the power module number is marked on the chassis). See Table 3-5 for the LED description.
·     If the MPU provides only one power status LED (PWR), see Table 3-6 for the LED description.
Table 3-4 Power module status LED description (1)
OK LED status
FAIL LED status
On
Off
All power modules are operating correctly.
Off
On
A power module is not outputting power because one of the following conditions exists:
·     The power module is faulty or switched off.
·     The power cord is disconnected.
·     The external power supply system is not available.
Off
Off
·     No power module is installed.
·     No power module is outputting power because one of the following conditions exists:
¡     The power modules are faulty or switched off.
¡     The power cords are disconnected.
¡     The external power supply system is not available.
Table 3-5 Power module status LED description (2)
LEDs
OK
FAIL
On
Off
The corresponding power module is operating correctly.
Off
On
The corresponding power module is not outputting power because one of the following conditions exists:
Off
Off
No power module is installed in the corresponding slot.
Table 3-6 Power module status LED description (3)
OK/FAIL LED status
Steady green
Steady red
Off
Fan tray status LED varies by MPU model.
·     If the MPU provides one set of LEDs (OK and FAIL) to indicate the status of the fan tray, see Table 3-7 for the LED description.
·     If the MPU provides one OK/FAIL LED to indicate the status of the fan tray, see Table 3-8 for the LED description.
Table 3-7 Fan tray status LED description (1)
OK LED status
FAIL LED status
On
Off
The fan tray is operating correctly.
Off
On
A fan problem has occurred or the fan tray is not in position.
Off
Off
The switch is not powered on.
Table 3-8 Fan tray status LED description (2)
OK/FAIL LED status
Steady green
Steady red
Off
Card status LEDs
LSQM3MPUA0
Table 3-9 MPU status LED description
RUN LED status
Flashing
The card is operating correctly.
Off
The card is starting up or faulty.
Table 3-10 Service module status LED description
RUN LED status
ALM LED status
Flashing
Off
The cards are operating correctly.
Fast flashing (4 Hz)
On
The cards are loading software.
If the LED flashes continuously, the software versions of the switch and the card do not match.
On
On
The cards are starting up or faulty.
Off
Off
No card is present.
LSQM2MPUC0/LSQM2MPUD0/LSQM2MPUDS0/LSQM1SRP8X2QE0
Table 3-11 Card status LED description
RUN/ALM LED status
Flashing green
Fast flashing green (4 Hz)
The card is loading software.
Steady red
Flashing red
The temperature of the card exceeds the upper limit or drops below the lower limit.
Off
No card is present.
MPUs other than the LSQM3MPUA0, LSQM2MPUC0, LSQM2MPUD0, LSQM2MPUDS0, and LSQM1SRP8X2QE0
Table 3-12 Card status LED description
RUN LED status
ALM LED status
Flashing (0.5 Hz)
Off
On
Flashing (0.5 Hz)
Slow flashing (0.25 Hz)
On
On
Off
Off
No card is present.
·     Before the active MPU starts up, all card LEDs are off. The tables describe the card LED status after the active MPU starts up.
·     The ALM LED lights for a period of time at the initial phase of the system startup.
The MPUs provide an ACTIVE LED to indicate the active or standby operating mode of the MPU.
Table 3-13 MPU active/standby status LED description
ACTIVE LED status
On
The MPU is operating in active mode.
Off
·     The MPU is operating in standby mode.
·     The MPU is faulty. Examine also the card status LEDs to determine the fault existence.
CF card status LED
The MPUs provide a CF card status LED (CFS) to indicate the status of the CF card.
Table 3-14 CF card status LED description
LED
LED status
CFS
On
The CF card is in position.
Off
The CF card is not in position or is damaged.
The MPUs provide a LED for each RJ-45 Ethernet port to indicate their link status and data receiving/forwarding status.
Table 3-15 RJ-45 Ethernet interface LED description
LED
LED status
RJ-45 Ethernet interface status LED
Flashing
The Ethernet port is receiving or sending data.
On
A link is present.
Off
No link is present.
The MPUs provide a LED for each combo interface to indicate their link status and data receiving/forwarding status.
Table 3-16 Combo interface status LED description
LED
LED status
Flashing
The combo interface is receiving or sending data.
On
A link is present.
Off
No link is present.
·     A combo interface contains an SFP port and an RJ-45 Ethernet port. Only one port can be active at a time. The other one is inactive. By default, the port with smaller number becomes active.
·     To use the inactive port of a combo interface, execute the undo shutdown command to activate the port. The other port of the combo port is then automatically shut down and becomes inactive.
SFP port LEDs
The MPU provides a LED for each SFP port to indicate their link status and data receiving/forwarding status.
Table 3-17 SFP port LED description
LED
LED status
SFP port status LED
Flashing
The SFP port is receiving or sending data.
Steady on
A link is present.
Off
No link is present.
SFP+ port LEDs
The LSQM1SRP8X2QE0 MPU provides a LED for each SFP+ port to indicate their link status and data forwarding status.
Table 3-18 SFP+ port LED description
LED status
Flashing
The port is receiving or sending data.
On
A link is present.
Off
No link is present.
The SFP+ port LED on the LSQM1SRP8X2QE0 MPU is always green no matter the SFP+ port is receiving or sending data at 10 Gbps or 1000 Mbps.
QSFP+ port LEDs
A LED is provided for each QSFP+ port to indicate the port link status and data forwarding status.
Table 3-19 QSFP+ port LED description
LED status
Flashing
On
A link is present.
Off
No link is present.
QSFP28 port LEDs
A LED is provided for each QSFP28 port to indicate the port link status and data forwarding status.
Table 3-20 QSFP+ port LED description
LED status
Flashing
On
A link is present.
Off
No link is present.
XFP port LEDs
A LED is provided for each XFP port to indicate their link status and data forwarding status.
Table 3-21 XFP port LED description
LEDs
LINK
ACT
On
Flashing
A link is present, and the XFP port is receiving or sending data.
On
Off
A link is present, but no data is being received or sent.
Off
Off
No link is present.
Service module LEDs
The service modules provide a LED for each RJ-45 Ethernet port to indicate their link status and data receiving/forwarding status.
Table 3-22 RJ-45 Ethernet port LED description
LED status
Flashing
On
A link is present.
Off
No link is present.
A combo interface contains an SFP port and an RJ-45 Ethernet port. Only one port of a combo interface can work at a time. The service modules each provide a combo interface LED to indicate the link status and data receiving/forwarding status of the corresponding combo interface.
Table 3-23 Combo interface LED description
LED status
Flashing
On
A link is present.
Off
No link is present.
·     For the SFP port and the RJ-45 Ethernet port of a combo interface, only one port can be active at a time. The other one is inactive. By default, the port with the smaller number becomes active.
·     To use the inactive port of a combo interface, execute the undo shutdown command to activate the port. The other port of the combo interface is then automatically shut down and becomes inactive.
SFP port LEDs
The service modules provide a LED for each SFP port to indicate their link status and data receiving/forwarding status.
Table 3-24 SFP port LED description
LED status
Flashing
On
A link is present.
Off
No link is present.
SFP+ port LEDs
The service modules provide a LED for each SFP+ port to indicate their link status and data receiving/forwarding status.
Table 3-25 SFP+ port LED description for the LSQ1TGS8SC0 service module
LINK LED status
ACT LED status
On
Flashing
On
Off
Off
Off
No link is present.
Table 3-26 SFP+ port LED description for other service modules
Status
Flashing green
The port is receiving or sending data at 10 Gbps.
Flashing yellow
The port is receiving or sending data at 1000 Mbps.
On
A link is present.
Off
No link is present.
XFP port LEDs
The service modules provide a LED for each XFP port to indicate their link status and data receiving/forwarding status.
Table 3-27 XFP port LED description
LINK status LED
ACT status LED
On
Flashing
On
Off
Off
Off
No link is present.
QSFP+ port LEDs
The service modules provide a LED for each QSFP+ port to indicate their link status and data receiving/forwarding status.
Table 3-28 QSFP+ port LED description
LED status
Flashing
On
A link is present.
Off
No link is present.
The color of the QSFP+ port LED indicates support of the port for 100-GE/40-GE switchover.
·     Yellow—The port supports 100-GE/40-GE switchover.
·     Green—The port does not support 100-GE/40-GE switchover.
QSFP28 port LEDs
The service modules provide a LED for each QSFP28 port to indicate their link status and data receiving/forwarding status.
Table 3-29 QSFP28 port LED description
LED status
Flashing
On
A link is present.
Off
No link is present.
The color of the QSFP28 port LED indicates the port speed as follows:
·     Green—100 Gbps.
·     Yellow—Less than 100 Gbps.
CFP port LEDs
The service modules provide a LED for each CFP port to indicate their link status and data receiving/forwarding status.
Table 3-30 CFP port LED description
LED status
Flashing
On
A link is present.
Off
No link is present.
EPON port LEDs
The service modules provide a LED for each EPON port to indicate their link status and data receiving/forwarding status.
Table 3-31 EPON port LED description
LED status
On
The connected ONU has been successfully registered.
Off
The connected ONU is not registered, or no ONU is connected.
Power module LEDs
The S7500E switches support various power module models. Each power module provides LEDs to indicate its operating status. The power modules vary in LEDs.
PSR320-A/PSR320-D
The PSR320-A and PSR320-D power modules each provide a status LED to indicate their operating status.
Table 3-32 PSR320-A/PSR320-D power module LED description
LED
Status
Status LED
Green
Normal operation
Red
Abnormal operation. Possible reasons include:
·     A power module alarm (such as input undervoltage, output short-circuit, output overcurrent, output overvoltage, or overtemperature) has occurred and the power module has entered protection state.
·     A power module fan failure has occurred.
Off
Abnormal power input. Possible reasons include:
·     The power module is faulty.
·     The power module is switched off.
The PSR650-A, PSR650-D, PSR1200-A, and PSR1200-D power modules each provide a status LED to indicate their operating status.
Table 3-33 PSR650-A/PSR650-D/PSR1200-A/PSR1200-D power module LED description
LED
Status
Status LED
Green
Normal operation
Red
Off
The PSR650C-12A, PSR650C-12D, PSR1400-A, PSR1400-12A1-F, PSR2500-12AHD, and PSR2500-12D power modules each provide three LEDs INPUT, OUTPUT, and FAN to indicate their operating status.
Table 3-34 PSR650C-12A/PSR650C-12D/PSR1400-A/PSR1400-12A1-F/PSR2500-12AHD/PSR2500-12D power module LED description
LED
Status
INPUT
Green
Normal power input
Red
Abnormal power input. The input voltage is out of the rated voltage range (input undervoltage or overvoltage).
Off
·     No power input. Possible reasons include:
¡     The power cord is disconnected.
OUTPUT
Green
Normal power output
Red
Abnormal power output. Possible reasons include:
·     A power module alarm (such as input undervoltage, output short-circuit, output overcurrent, output overvoltage, overtemperature, or fan failure) has occurred and the power module has entered protection state.
Off
FAN
Green
Normal fan operation
Red
Abnormal fan operation. Possible reasons include:
Off
·     The power module does not have power input. Possible reasons include:
PSR1400-D
A PSR1400-D power module provides four LEDs INPUT, OUTPUT, FAN, and PoE to indicate its operating status.
Table 3-35 PSR1400-D power module LED description
LED
Status
INPUT
Green
The power is being input correctly, and the system power output switch is turned on.
Red
A power input problem has occurred because the input voltage is out of the rated voltage range.
Off
One of the following conditions might exist:
·     The power source is not supplying power.
·     The system power output switch is turned off.
OUTPUT
Green
The power is being output correctly.
Red
A power output problem has occurred because the power module generates an alarm and enters the protection state due to output short-circuit, output overcurrent, output overvoltage, or overtemperature.
Off
FAN
Green
The fans are operating correctly.
Red
The fans are operating incorrectly because a fan failure has occurred.
Off
PoE
Green
The PoE power is being output correctly.
Red
A PoE power output problem has occurred because the PoE output voltage is out of the rated voltage range.
Off
No PoE power is being output because one of the following conditions might exist:
·     The PoE power output switch is turned off.
PSR1400-12D1
A PSR1400-12D1 power module provides three LEDs INPUT, OUTPUT, and FAN to indicate its operating status.
Table 3-36 PSR1400-12D1 power module LED description
LED
Status
INPUT
Green
Normal power input.
Red
Abnormal power input. The input voltage is out of the rated voltage range.
Off
OUTPUT
Green
Normal power output
Red
Abnormal power output. A power module alarm (such as output short-circuit, output overcurrent, output overvoltage, or overtemperature) has occurred and the power module has entered protection state.
Off
FAN
Green
Red
Abnormal fan operation. A power module fan failure has occurred.
Off
·     The power module does have power input. Possible reasons include:
The PSR2800-ACV and PSR2800-A1-F power modules each provide five LEDs INPUT, OUTPUT, FAN, PoE INPUT, and PoE OUTPUT to indicate the operating status.
Table 3-37 PSR2800-ACV/PSR2800-A1-F power module LED description
LED
Status
INPUT
Green
Normal power input.
Red
Off
¡     The system input power cord is disconnected.
OUTPUT
Green
Normal power output
Red
·     The system power switch is turned off.
Off
FAN
Green
Red
Off
PoE INPUT
Green
Normal PoE power input
Red
Abnormal PoE power input. The PoE input voltage is out of the rated voltage range.
Off
No PoE power input. Possible reasons include:
·     The PoE input power cord is disconnected.
PoE OUTPUT
Green
Normal PoE power output
Red
Abnormal PoE power output. Possible reasons include:
·     The PoE output voltage is out of the rated voltage range.
·     The PoE power switch is turned off.
Off
No PoE power output. Possible reasons include:
PSR6000-ACV
The PSR6000-ACV power module provides eight LEDs SYS IN, SYS OUT, SYS FAN, PoE IN1, PoE IN2, PoE IN3, PoE OUT, and PoE FAN to indicate its operating status.
Table 3-38 PSR6000-ACV power module LED description
LED
Status
SYS IN
Green
Normal system power input
Red
Abnormal system power input. The system power input voltage is out of the rated voltage range.
Off
·     No system power input. Possible reasons include:
SYS OUT
Green
Normal system power output
Red
Abnormal system power output. Possible reasons include:
·     A power module alarm (such as output short-circuit, output overcurrent, output overvoltage, or overtemperature) has occurred and the power module has entered protection state.
·     The SYS power switch is turned off.
Off
SYS FAN
Green
Normal system fan operation.
Red
Abnormal system fan operation. Possible reasons include:
·     A system fan failure has occurred.
Off
PoE IN1
Green
Normal PoE1 power input.
Red
Abnormal PoE1 power input. The PoE1 power input voltage is out of the rated voltage range.
Off
No PoE1 power input. Possible reasons include:
·     The PoE1 input power cord is disconnected.
PoE IN2
Green
Normal PoE2 power input.
Red
Abnormal PoE2 power input. The PoE2 power input voltage is out of the rated voltage range.
Off
No PoE2 power input. Possible reasons include:
·     The PoE2 input power cord is disconnected.
PoE IN3
Green
Normal PoE3 power input.
Red
Abnormal PoE3 power input. The PoE3 power input voltage is out of the rated voltage range.
Off
No PoE3 power input. Possible reasons include:
·     The PoE3 input power cord is disconnected.
PoE OUT
Green
Red
Off
·     The PoE 1, PoE 2, and PoE 3 input power cords are all disconnected.
PoE FAN
Green
Normal PoE fan operation
Red
Abnormal PoE fan operation. Possible reasons include:
·     A PoE fan failure has occurred.
Off
Fan tray LEDs
The S7506E-MF and S7506E-MF (non-PoE) fan trays each use a fan tray LED RUN/ALM to indicate their operating status.
Table 3-39 Fan tray LED description
RUN/ALM LED status
Green
Red
The fan tray is faulty.
Off
No fan tray is present or the switch is not powered on.
4 Cables
This chapter describes the cables used for connecting network ports.
Table 4-1 Cable description
Cable
Port type
Application
Console cable
Console port at one end and 9-pin serial port at the other end
Enables users to perform debugging, configuration, maintenance, management, and software loading on the device.
USB console cable
USB console port at one end and USB port at the other end
Ethernet twisted pair cable
RJ-45 Ethernet ports
Connects RJ-45 Ethernet ports to transmit data
Optical fiber
XFP/SFP+/SFP/CFP/QSFP+/EPON ports
Connects the fiber ports to transmit data
SFP+ DAC cable
SFP+ ports
Connects SFP+ ports to transmit data
QSFP+ DAC/QSFP28 DAC cable
QSFP+ ports
Connects QSFP+ ports to transmit data
QSFP28 ports
Connects QSFP28 ports to transmit data
QSFP+ port at one end, and SFP+ port at the other end
Connects a QSFP+ port to an SFP+ port
An Ethernet twisted pair cable consists of four pairs of insulated wires twisted together. It mainly transmits analog signals and is advantageous in transmitting data over shorter distances. The maximum transmission distance is 100 m (328.08 ft).
RJ-45 connector
An Ethernet twisted pair cable connects network devices through the RJ-45 connectors at the two ends. Figure 4-1 shows the pinouts of an RJ-45 connector.
Figure 4-1 RJ-45 connector pinout diagram
Cable pinouts
EIA/TIA cabling specifications define two standards: 568A and 568B for cable pinouts.
·     Standard 568A—Pin 1: white/green stripe, pin 2: green solid, pin 3: white/orange stripe, pin 4: blue solid, pin 5: white/blue stripe, pin 6: orange solid, pin 7: white/brown stripe, pin 8: brown solid.
·     Standard 568B—Pin 1: white/orange stripe, pin 2: orange solid, pin 3: white/green stripe, pin 4: blue solid, pin 5: white/blue stripe, pin 6: green solid, pin 7: white/brown stripe, pin 8: brown solid.
Cable type
Based on performance
Ethernet cables can be classified into category 3, category 4, category 5, category 5e, category 6, and category 7 cable based on performance. In LANs, category 5, category 5e, and category 6 are commonly used.
Table 4-2 Ethernet cable description
Category 5
Transmits data at a maximum speed of 100 Mbps, with a bandwidth of 100 MHz.
Category 5e
Transmits data at a maximum speed of 1000 Mbps, with a bandwidth of 100 MHz.
Category 6
Transmits data at a maximum speed of 10 Gbps, with a bandwidth of 250 MHz.
The RJ-45 Ethernet ports use category 5 or higher Ethernet twisted pair cables for connection.
Based on pinouts
Ethernet twisted pair cables can be classified into straight through and crossover cables based on their pinouts.
·     Straight-through—The pinouts at both ends comply with standard 568B, as shown in Figure 4-2.
·     Crossover—The pinouts at one end comply with standard 568B, and those at the other end comply with standard 568A, as shown in Figure 4-3.
Figure 4-2 Straight-through cable
Figure 4-3 Crossover cable
Pin assignments
Select an Ethernet twisted pair cable according to the RJ-45 Ethernet port type on your device. An RJ-45 Ethernet port can be MDI (for routers and PCs) or MDIX (for switches). For the pinouts of RJ-45 Ethernet ports, see Table 4-3 and Table 4-4.
Table 4-3 RJ-45 MDI port pinouts
Pin
10BASE-T/100BASE-TX
1000BASE-T
Signal
Function
Signal
Function
1
Tx+
Send data
BIDA+
Bi-directional data cable A+
2
Tx-
Send data
BIDA-
Bi-directional data cable A-
3
Rx+
Receive data
BIDB+
Bi-directional data cable B+
4
Reserved
BIDC+
Bi-directional data cable C+
5
Reserved
BIDC-
6
Rx-
Receive data
BIDB-
Bi-directional data cable B-
7
Reserved
BIDD+
Bi-directional data cable D+
8
Reserved
BIDD-
Bi-directional data cable D-
Table 4-4 RJ-45 MDI-X port pinouts
Pin
10BASE-T/100BASE-TX
1000BASE-T
Signal
Function
Signal
Function
1
Rx+
Receive data
BIDB+
2
Rx-
Receive data
BIDB-
3
Tx+
Send data
BIDA+
4
Reserved
BIDD+
5
Reserved
BIDD-
6
Tx-
Send data
BIDA-
7
Reserved
BIDC+
8
Reserved
BIDC-
Bi-directional data cable C-
To ensure normal communication, the pins for sending data on one port should correspond to the pins for receiving data on the peer port. When both of the ports on the two devices are MDI or MDIX, a crossover Ethernet cable is needed. A cross-over cable connects devices of the same type. When one port is MDI and the other is MDIX, a straight-through Ethernet cable is needed. A straight-through cable connects devices of different types.
If an RJ-45 Ethernet port with MDI/MDIX autosensing enabled can automatically negotiate pin roles. The S7500E RJ-45 Ethernet ports support MDI/MDIX. By default, MDI/MDIX is enabled on a port.
Making an Ethernet twisted pair cable
1.     Cut the cable to length with the crimping pliers.
2.     Strip off an appropriate length of the cable sheath. The length is typically that of the RJ-45 connector.
3.     Untwist the pairs so that they can lie flat, and arrange the colored wires based on the wiring specifications.
4.     Cut the top of the wires even with one another. Insert the wires into the RJ-45 end and make sure the wires extend to the front of the RJ-45 end and make good contact with the metal contacts in the RJ-45 end and in the correct order.
5.     Crimp the RJ-45 connector with the crimping plier until you hear a click.
6.     Repeat the above steps with the other end of the cable.
7.     Use a cable tester to verify the connectivity of the cable.
Optical fiber
CAUTION
CAUTION:
Use the same types of transceiver modules, pigtail cords, patch cords, and fiber cables. If you use single-mode optical fibers, the transceiver modules, pigtail cords, patch cords, and fiber cables must be single-mode.
Optical fiber
Optical fibers are widely used in fiber-optic communications, which are advantageous for long-distance communications.
Optical fibers can be classified into the following types:
·     Single mode fiber—It has a core size of 10 µm, and has a lower modal dispersion. It carries only a single ray of light. It is mostly used for communication over longer distances.
·     Multi-mode fiber—It has a core size of 50 µm or 62.5 µm or higher, and has a higher modal dispersion than single-mode optical fiber. It is mostly used for communication over shorter distances.
Table 4-5 Allowed maximum tensile force and crush load
Period of force
Tensile load (N)
Crush load (N/mm)
Short period
150
500
Long term
80
100
Optical fiber cable
An optical fiber cable is a cable containing one or more optical fibers. The optical fiber elements are typically individually coated with plastic layers and contained in a protective tube. Optical fiber cables fall into single-mode and multi-mode.
Patch cord
A fiber that has connectors at both ends is called a patch cord. A patch cord connects one optical device to another for signal routing. Patch cords fall into single-mode and multi-mode patch cords.
·     Single-mode patch cord—The jacket is yellow. It permits transmission over longer distances.
·     Multi-mode patch cord—The jacket is orange. It permits transmission over shorter distances.
Patch cords are classified into SC, LC, and FC patch cords based on interface type. The length of a patch cord can be 0.5 m (1.64 ft), 1 m (3.28 ft), 2 m (6.56 ft), 3 m (9.84 ft), 5 m (16.40 ft), and 10 m (32.81 ft).
Pigtail cord
A pigtail cord is an optical fiber that has an optical connector on one end and a length of exposed fiber on the other. The end of the pigtail is fusion spliced to a fiber, connecting the fiber cable and transceiver.
Pigtail cords fall into single-mode (yellow) and multi-mode (orange), and can also be classified into SC, LC, and FC pigtail cords based on interface type.
Fiber connector
Fiber connectors are indispensable passive components in an optical fiber communication system. They allow the removable connection between optical channels, which makes the optical system debugging and maintenance more convenient and the transit dispatching of the system more flexible.
Figure 4-4 SC connector
Figure 4-5 LC connector
SFP+ DAC cable
You can use SFP+ DAC cables to connect the SFP+ ports. SFP+ DAC cables support the SFP+ standard and use 10-GE SFP+ Cu standard cables.
Figure 4-6 SFP+ DAC cable
(1) Connector
(2) Pull latch
You can use QSFP+ DAC cables to connect QSFP+ ports.
You can use QSFP28 DAC cables to connect QSFP28 ports. The QSFP28 DAC cables are similar to QSFP+ DAC cables in appearance.
Figure 4-7 QSFP+ DAC cable
(1) Connector
(2) Pull latch
A QSFP+ to SFP+ DAC cable provides one QSFP+ connector at one end and four SFP+ connectors at the other end.
Figure 4-8 QSFP+ to SFP+ DAC cable
(1) QSFP+ connector
(2) QSFP+ pull latch
(3) SFP+ connector
(4) SFP+ pull latch
