H3C S7500X Switch Series Hardware Information and Specifications-6W100
HomeSupportSwitchesS7500X SeriesProduct LiteratureHardware Information & SpecificationsH3C S7500X Switch Series Hardware Information and Specifications-6W100
01-Hardware Information and Technical Specifications
1 Chassis views and technical specifications· 1-1
Chassis views· 1-1
S7503X· 1-1
S7503X-PoE· 1-2
S7506X· 1-2
S7506X-PoE· 1-3
S7506X-S· 1-4
S7506X-S-MF· 1-5
S7510X· 1-6
S7510X-PoE· 1-7
Technical specifications· 1-8
Weights and dimensions· 1-8
Module power consumption· 1-11
Total power consumption· 1-13
Heat dissipation· 1-14
Noise· 1-15
2 FRUs and compatibility matrixes· 1-1
MPUs· 1-1
Service modules· 1-3
Restrictions and guidelines· 1-3
Interface modules· 1-4
OAA modules· 1-6
Power system·· 1-9
Restrictions and guidelines· 1-9
Power modules· 1-10
Power cords· 1-13
(Optional) PoE power system·· 1-14
Fan trays· 1-14
3 LEDs· 1-1
MPU LEDs· 1-1
Management Ethernet port LEDs· 1-3
Power module status LEDs· 1-3
Fan tray status LEDs· 1-4
Card status LEDs· 1-4
Active/standby state LED·· 1-5
SFP28 port LEDs· 1-6
Service module LEDs· 1-6
RJ-45 Ethernet port LEDs· 1-6
Combo interface LEDs· 1-6
SFP port LEDs· 1-7
SFP+ port LEDs· 1-7
QSFP+ port LEDs· 1-7
QSFP28 port LEDs· 1-8
EPON port LEDs· 1-8
Power module LEDs· 1-8
PSR320-A· 1-8
PSR650-A/PSR650-D/PSR1200-A/PSR1200-D·· 1-9
PSR650C-12A/PSR650C-12D/PSR1400-A/PSR1400-12A1-F/PSR2500-12AHD/PSR2500-12D·· 1-9
PSR1400-D·· 1-10
PSR1400-12D1· 1-11
PSR2800-ACV/PSR2800-A1-F· 1-12
PSR6000-ACV· 1-13
4 Cables· 1-1
Ethernet twisted pair cable· 1-1
RJ-45 connector 1-1
Cable pinouts· 1-2
Cable type· 1-2
Pin assignments· 1-3
Making an Ethernet twisted pair cable· 1-4
Optical fiber 1-5
Optical fiber 1-5
Optical fiber cable· 1-5
Patch cord· 1-5
Pigtail cord· 1-6
Fiber connector 1-6
SFP+ DAC/SFP28 DAC cable· 1-7
QSFP+ DAC/QSFP28 DAC cable· 1-7
QSFP+ to SFP+ DAC cable· 1-7
SFP28 AOC cable· 1-8
Chassis views
The S7500X switch series includes the following models:
·     S7503X
·     S7503X-PoE
·     S7506X
·     S7506X-PoE
·     S7506X-S
·     S7506X-S-MF
·     S7510X
·     S7510X-PoE
The figures in this section are for illustration only.
S7503X
Figure1-1 S7503X front panel
(1) Power module section
(2) MPU section
(3) Service module section
(4) Fan tray section
S7503X-PoE
Figure1-2 S7503X-PoE front and rear panels
(2) MPU section
(5) PoE power input terminals (reserved)
S7506X
Figure1-3 S7506X front panel
(1) Service module section
(2) MPU section
(3) Power module section
S7506X-PoE
Figure1-4 S7506X-PoE front panel
(2) MPU section
S7506X-S
Figure1-5 S7506X-S front panel
(2) MPU section
S7506X-S-MF
Figure1-6 S7506X-S-MF front panel
(2) MPU section
S7510X
Figure1-7 S7510X front panel
(2) MPU section
S7510X-PoE
Figure1-8 S7510X-PoE front panel
(2) MPU section
Table1-1 Chassis weights and dimensions
Model
Weight (fully configured)
Height
Width
Depth
S7503X
< 35 kg (77.16 lb)
216 mm (8.50 in)/5 RUs
436 mm (17.17 in)
420 mm (16.54 in)
S7503X-PoE
< 35 kg (77.16 lb)
436 mm (17.17 in)
420 mm (16.54 in)
S7506X
< 75 kg (165.34 lb)
575 mm (22.64 in)/13 RUs
436 mm (17.17 in)
420 mm (16.54 in)
S7506X-PoE
< 75 kg (165.34 lb)
436 mm (17.17 in)
420 mm (16.54 in)
S7506X-S
< 75 kg (165.34 lb)
436 mm (17.17 in)
420 mm (16.54 in)
S7506X-S-MF
< 75 kg (165.34 lb)
436 mm (17.17 in)
420 mm (16.54 in)
S7510X
< 95 kg (209.44 lb)
708 mm (27.87 in)/16 RUs
436 mm (17.17 in)
420 mm (16.54 in)
S7510X-PoE
< 95 kg (209.44 lb)
436 mm (17.17 in)
420 mm (16.54 in)
·     A rack unit (RU) is 44.45 mm (1.75 in). It is a used as a measurement for the rack height.
·     Net weight is the chassis weight, excluding the weights of cards, power modules and other removable modules.
Table1-2 Card weights and dimensions
Model
Weight
Height
Width
Depth
LSQM2SUPA0
1.35 kg (2.98 lb)
45 mm (1.77 in)
199 mm (7.83 in)
355 mm (13.98 in)
LSQM2SUPB0
1.45 kg (3.20 lb)
45 mm (1.77 in)
199 mm (7.83 in)
355 mm (13.98 in)
LSQM3SUPA0
1.35 kg (2.98 lb)
45 mm (1.77 in)
199 mm (7.83 in)
355 mm (13.98 in)
LSQM1MPUSA0
3.25 kg (7.16 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1MPUSC0
3.70 kg (7.16 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1SRP4Y06A0
2.90 kg (6.39 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1MPUS06S0
3.25 kg (7.16 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1MPUS10B0
3.40 kg (8.16 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1MPUS10C0
3.70 kg (8.16 lb)
45 mm (1.77 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGS24QSFD0
3.00 kg (6.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1CQGS12SG0
3.20 kg (7.05 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1CGS2FE0
2.82 kg (6.22 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1QGS24RSG0
3.39 kg (7.47 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GT24PTSSC0
3.21 kg (7.08 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GT24TSSC0
2.95 kg (6.50 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM3GP44TSSC0
3.00 kg (6.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1GP40TS8FD0
3.20 kg (7.05 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GP40TS8FD0
3.10 kg (6.83 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GP44TSSC0
3.00 kg (6.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GP24TSSC0
2.85 kg (6.28 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGS48RFE0
3.60 kg (7.94 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGS48RSG0
3.50 kg (7.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2TGS48SG0
3.30 kg (7.28 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGS16GPSA0
3.50 kg (7.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGS24FD0
3.00 kg (6.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGS16FD0
2.91 kg (6.42 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2TGS16SF0
3.05 kg (6.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GP24TSSA0
2.85 kg (6.28 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGS12EC0
3.30 kg (7.28 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1GP48FD0
3.10 kg (6.83 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1XPT12TSFD0
3.45 kg (7.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2XPT12TSFD0
3.45 kg (7.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1PT24TSSC0
2.90 kg (6.39 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1PT8TSSC0
2.75 kg (6.06 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GP48SA0
3.00 kg (6.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GP24SA0
2.81 kg (6.19 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1TGT24FD0
3.40 kg (7.50 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1GT48FD0
3.40 kg (7.50 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GT48SA0
3.18 kg (7.01 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2GT48SC0
3.18 kg (7.01 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM4GV48SA0
3.05 kg (6.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM4GV48SC0
3.05 kg (6.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSU1WCME0
4.00 kg (8.82 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSU3WCMD0
3.62 kg (7.98 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1WCMX20
4.00 kg (8.82 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1WCMX40
4.00 kg (8.82 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1FWDSC0
3.80 kg (8.38 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSU1FWCEA0
3.90 kg (8.60 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSU3FWCEA0
3.90 kg (8.60 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1FWCEAB0
3.90 kg (8.60 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSU1NSCEA0
3.90 kg (8.60 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1NSDSC0
3.80 kg (8.38 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSU1IPSBEA0
3.90 kg (8.60 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1IPSDSC0
3.80 kg (8.38 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1ACGDSC0
3.80 kg (8.38 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1ADEDSC0
3.80 kg (8.38 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSU1ADECEA0
3.90 kg (8.60 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM2FWDSC0
3.30 kg (7.28 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1EPSB0
3.40 kg (8.16 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1SDNB0
3.40 kg (8.16 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSQM1WBCZ720X
3.50 kg (7.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
·     Card dimensions are expressed in the H × W × D format.
¡     H—Height of the front panel of the card.
¡     W—Width of the front panel of the card.
¡     D—Depth from the front panel of the card to the connector.
·     The card models listed in Table1-2 are marked on the card panels. They might be slightly different from the card models marked on the card packages. For example, LSU1WCME0 and LSUM1WCME0 identify the same card. LSU1WCME0 is marked on the card panel. When you order the card, you refer to it as LSUM1WCME0.
Table1-3 Power module adapter weights and dimensions
Model
Weight
Height
Width
Depth
LSQM1PWRSPB
4.95 kg (10.91 lb)
128 mm (5.04 in)
196 mm (7.72 in)
380 mm (14.96 in)
Table1-4 Power module weights and dimensions
Model
Weight
Height
Width
Depth
PSR320-A
2.00 kg (4.41 lb)
40 mm (1.57 in)/1 RU
140 mm (5.51 in)
350 mm (13.78 in)
PSR650-A
1.90 kg (4.19 lb)
140 mm (5.51 in)
350 mm (13.78 in)
PSR650-D
3.20 kg (7.05 lb)
140 mm (5.51 in)
350 mm (13.78 in)
PSR650C-12A
5.15 kg (11.35 lb)
128 mm (5.04 in)/3 RUs
196 mm (7.72 in)
382 mm (15.04 in)
PSR650C-12D
4.20 kg (9.26 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR1200-A
2.56 kg (5.64 lb)
140 mm (5.51 in)
350 mm (13.78 in)
PSR1200-D
2.51 kg (5.53 lb)
140 mm (5.51 in)
350 mm (13.78 in)
PSR1400-A
8.30 kg (18.30 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR1400-12A1-F
4.30 kg (9.48 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR1400-D
4.20 kg (9.26 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR1400-12D1
6.39 kg (14.09 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR2500-12AHD
5.45 kg (12.02 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR2500-12D
5.55 kg (12.24 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR2800-ACV
8.00 kg (17.64 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR2800-A1-F
5.45 kg (12.02 lb)
196 mm (7.72 in)
382 mm (15.04 in)
PSR6000-ACV
12.16 kg (26.81 lb)
196 mm (7.72 in)
382 mm (15.04 in)
Table1-5 Fan tray weights and dimensions
Model
Weight
Height
Width
Depth
S7503X fan tray
S7503X-PoE fan tray
1.00 kg (2.20 lb)
29 mm (1.14 in)
167 mm (6.57 in)
350 mm (13.78 in)
S7506X fan tray
S7506X-PoE fan tray
S7506X-S fan tray
2.20 kg (4.85 lb)
29 mm (1.14 in)
347 mm (13.66 in)
367 mm (14.45 in)
S7506X-S-MF fan tray
0.70 kg (1.54 lb)
27 mm (1.06 in)
100 mm (3.94 in)
347 mm (13.66 in)
S7510X fan tray
S7510X-PoE fan tray
2.94 kg (6.48 lb)
28 mm (1.10 in)
497 mm (19.57 in)
351 mm (13.82 in)
Card power consumption
A card has different power consumptions in static and dynamic states.
·     Static power consumption (min)—Power consumed by the card when the following conditions exist:
¡     The card is running but all ports on the card are down.
¡     No transceiver modules are installed in the fiber ports on the card.
·     Dynamic power consumption (max)—Power consumed by the card when all the ports on the card are link up and broadcast storm occurs.
Table1-6 Card power consumption
Model
LSQM2SUPA0
9 W
18 W
LSQM2SUPB0
15 W
21 W
LSQM3SUPA0
9 W
16 W
LSQM1MPUSA0
60 W
100 W
LSQM1MPUSC0
103 W
168 W
LSQM1SRP4Y06A0
37 W
62 W
LSQM1MPUS06S0
27 W
42 W
LSQM1MPUS10B0
67 W
108 W
LSQM1MPUS10C0
93 W
182 W
LSQM1TGS24QSFD0
60 W
107 W
LSQM1CQGS12SG0
55 W
147 W
LSQM1CGS2FE0
55 W
77 W
LSQM1QGS24RSG0
65 W
198 W
LSQM2GT24PTSSC0
36 W
59 W
LSQM2GT24TSSC0
32 W
43 W
LSQM3GP44TSSC0
34 W
69 W
LSQM1GP40TS8FD0
47 W
96 W
LSQM2GP40TS8FD0
42 W
81 W
LSQM2GP44TSSC0
31 W
65 W
LSQM2GP24TSSC0
27 W
52 W
LSQM1TGS48RFE0
50 W
122 W
LSQM1TGS48RSG0
60 W
149 W
LSQM2TGS48SG0
67 W
152 W
LSQM1TGS16GPSA0
28 W
64 W
LSQM1TGS24FD0
50 W
104 W
LSQM1TGS16FD0
54 W
90 W
LSQM2TGS16SF0
52 W
75 W
LSQM2GP24TSSA0
25 W
49 W
LSQM1TGS12EC0
82 W
130 W
LSQM1GP48FD0
49 W
78 W
LSQM1XPT12TSFD0
100 W
162 W
LSQM2XPT12TSFD0
100 W
162 W
LSQM1PT24TSSC0
80 W
115 W
LSQM1PT8TSSC0
56 W
80 W
LSQM2GP48SA0
28 W
58 W
LSQM2GP24SA0
24 W
45 W
LSQM1TGT24FD0
60 W
112 W
LSQM1GT48FD0
48 W
65 W
LSQM2GT48SA0
35 W
45 W
LSQM2GT48SC0
38 W
48 W
LSQM4GV48SA0
34 W
44 W
LSQM4GV48SC0
38 W
48 W
LSU1WCME0
125 W
180 W
LSU3WCMD0
118 W
150 W
LSQM1WCMX20
125 W
180 W
LSQM1WCMX40
125 W
180 W
LSQM1FWDSC0
115 W
123 W
LSU1FWCEA0
109 W
157 W
LSU3FWCEA0
109 W
157 W
LSUM1FWCEAB0
109 W
157 W
LSU1NSCEA0
109 W
157 W
LSQM1NSDSC0
115 W
123 W
LSU1IPSBEA0
109 W
157 W
LSQM1IPSDSC0
116 W
124 W
LSQM1ACGDSC0
116 W
124 W
LSQM1ADEDSC0
116 W
124 W
LSU1ADECEA0
109 W
157 W
LSQM2FWDSC0
60 W
66 W
LSQM1EPSB0
102 W
124 W
LSQM1SDNB0
102 W
124 W
LSQM1WBCZ720X
160 W
210 W
Fan tray power consumption
The switch uses fan trays that can automatically adjust the fan speed based on the heat dissipation condition of the switch. The power consumed by a fan tray varies by fan speed. Table1-7 shows the power consumption of different fan trays.
Table1-7 Fan tray power consumption
Model
Min fan tray power consumption
Max fan tray power consumption
S7503X
S7503X-PoE
7 W
11 W
S7506X
S7506X-PoE
S7506X-S
24.5 W
42.5 W
S7506X-S-MF
7.00 W
14.00 W
S7510X
S7510X-PoE
28 W
48.5 W
For the S7503X, S7506X, S7506X-S, S7506X-S-MF, and S7510X switches, the total power consumption equals the system power consumption.
For the S7503X-PoE, S7506X-PoE, and S7510X-PoE switches, the total power consumption equals the system power consumption plus the PoE power consumption.
System power consumption
The total power consumption of the switch is the power consumptions of all operating cards and fan trays. It varies by the type and number of the operating cards and the fan tray power consumption.
·     The minimum system power consumption is the total static power consumption of all cards plus the minimum fan tray power consumption. For example, an S7506X switch is installed with two LSQM1MPUS10C0 MPUs, three LSQM1GP48FD0 interface modules, and one fan tray. The minimum system power consumption of the switch is 2 × 93 + 3 × 49 + 24.5 = 357.5 W.
·     The maximum system power consumption is the total dynamic power consumption of all cards plus the maximum fan tray power consumption. For example, an S7506X switch is installed with two LSQM1MPUS10C0 MPUs, three LSQM1GP48FD0 interface modules, and one fan tray. The maximum system power consumption of the switch is 2 × 182 + 3 × 78 + 42.5 = 640.5 W.
The power over Ethernet (PoE) power consumption refers to the power that all powered devices (PDs) receive from the switch.
The maximum PoE power consumption refers to the sum of the power consumption of all PDs when all power interfaces (PIs) are connected to PDs and the maximum PI power is reached. The maximum PoE power consumption is decided by the following items:
·     Number of the PoE cards installed on the switch.
·     Number of the PIs that each PoE card provides.
·     Maximum PoE power that each PoE card can provide.
·     Maximum PoE power that each slot on the switch can provide.
Each slot of the switch can provide a maximum PoE power of 1440 W.
Table1-8 shows the specifications for each PoE card model.
For example, an S7506X-PoE switch is installed with three LSQM4GV48SA0 PoE cards. The maximum PoE power consumption of the switch is 3 × 1440 = 4320 W.
Table1-8 PoE card specifications
Model
PI quantity
PI power
Maximum PSE power
Maximum number of PSEs for each switch model
LSQM4GV48SA0
48
0 to 30 W
1440 W
·     S7503X-PoE: 3
·     S7506X-PoE: 6
·     S7510X-PoE: 10
LSQM4GV48SC0
48
0 to 30 W
1440 W
·     The PoE power consumption is 0 if the switch does not supply PoE.
·     The maximum PoE power consumption of the S7510X switch is 10000 W.
·     For more information about PoE power supply, see H3C S7500X Switch Series Installation Guide.
Heat dissipation
Heat dissipation is measured in BTU/h, and 1 W equals 3.4121 BTU/h.
The heat dissipation of a switch depends on its power consumption. To calculate heat dissipation of the switch, assume 90% power consumption is converted to heat, and the efficiency of the power module is 90%. Heat dissipation/hour of the switch is 0.9 × (total power consumption of the cards plus power consumption of the fan tray)/0.9 × 3.4121.
Table1-9 shows the heat dissipation for each switch model.
Table1-9 Heat dissipation
Model
Heat dissipation (BTU/h)
S7503X
S7503X-PoE
2187
S7506X
S7506X-PoE
5347
S7506X-S
S7506X-S-MF
4487
S7510X
S7510X-PoE
8165
For the power consumption of the cards and fan trays available for the switch, see "Module power consumption."
Noise
The switch uses fan trays that can adjust the fan speed automatically based on the device temperature. The sound pressure levels vary by fan speed. For more information, see Table1-10.
Table1-10 Sound pressure levels
Model
Sound pressure level when the fan tray operates at low speed
Sound pressure level when the fan tray operates at middle speed
Sound pressure level when the fan tray operates at full speed
S7503X
S7503X-PoE
52.2 dBA
54.0 dBA
56.0 dBA
S7506X
S7506X-PoE
S7506X-S
S7506X-S-MF
53.6 dBA
56.2 dBA
57.7 dBA
S7510X
S7510X-PoE
53.5 dBA
55.8 dBA
56.7 dBA
For the compatibility between transceiver modules and cards, see H3C S7500X Switch Series Cards and Transceiver Modules Compatibility Matrixes.
MPUs
You can install one MPU, or two MPUs for redundancy on the switch. When you install two MPUs, make sure the two MPUs are the same model.
Table2-1 MPU specifications
Model
Specifications
Flash memory
NVRAM
SDRAM
Ports
LSQM2SUPA0
2 GB
1 MB
2 GB
·     1 × console port
·     1 × USB console port
·     2 × management Ethernet ports (one 10/100/1000BASE-T copper port and one SFP port)
·     1 × USB port
LSQM2SUPB0
4 GB
1 MB
4 GB
·     1 × console port
·     1 × USB port
·     2 × SMB coaxial clock output ports
·     2 × SMB coaxial clock input ports
·     2 × high-precision time synchronization ports (Both ports are used for input by default. When both the ports are used for input, only port 1 is valid.)
LSQM3SUPA0
4 GB
1 MB
4 GB
·     1 × console port
·     1 × USB port
LSQM1MPUSA0
2 GB
1 MB
4 GB
·     1 × console port
·     4 × management Ethernet ports (two 10/100/1000BASE-T copper ports and two SFP ports)
·     1 × USB port
LSQM1MPUSC0
2 GB
1 MB
4 GB
·     1 × console port
·     1 × USB port
LSQM1SRP4Y06A0
2 GB
1 MB
4 GB
·     1 × console port
·     2 × management Ethernet ports (one RJ-45 port and one SFP port)
·     1 × USB port
·     4 × SFP28 ports
LSQM1MPUS06S0
4 GB
1 MB
4 GB
·     1 × console port
LSQM1MPUS10B0
2 GB
1 MB
4 GB
·     1 × console port
·     1 × USB port
LSQM1MPUS10C0
2 GB
1 MB
4 GB
·     1 × console port
·     1 × USB port
·     Among the management Ethernet ports on an MPU, only port 0 is available during the startup of the switch.
·     To connect an SFP management Ethernet port on the MPUs, make sure the peer port operates at 1000 Mbps in full-duplex mode.
·     The USB ports on the MPUs do not support USB extension cables.
Table2-2 MPU and switch compatibility matrix
MPU model
Switch model
S7503X
S7503X-PoE
S7506X
S7506X-PoE
S7506X-S
S7506X-S-MF
S7510X
S7510X-PoE
LSQM2SUPA0
Yes
No
No
No
LSQM2SUPB0
Yes
No
No
No
LSQM3SUPA0
Yes
No
No
No
LSQM1MPUSA0
No
Yes
No
No
LSQM1MPUSC0
No
Yes
No
No
LSQM1SRP4Y06A0
No
Yes
Yes
No
LSQM1MPUS06S0
No
Yes
Yes
No
LSQM1MPUS10B0
No
No
No
Yes
LSQM1MPUS10C0
No
No
No
Yes
To verify compatibility of an MPU with the software version you are using, see the release notes for the device.
Service modules
Follow these restrictions and guidelines to use service modules:
·     For the switch models and system software versions that a service module is compatible with, see the service module manual.
·     A combo interface is a logical interface that contains an SFP port and an RJ-45 Ethernet port. Only one of them can be activated at a time.
·     After you convert 40G ports on an LSQM1CQGS12SG0 interface module to 100G ports, only ports 1, 4, 7, and 10 are available.
·     Follow these guidelines to use services modules on an S7503X switch:
¡     Do not use an LSQM1TGS16FD0 interface module with the following modules:
-     EC interface modules.
-     OAA modules: LSU1FWCEA0, LSU3FWCEA0, LSU3WCMD0, LSU1ADECEA0, LSU1NSCEA0, LSUM1FWCEAB0, LSU1IPSBEA0, LSU1WCME0, LSQM1WCMX40, and LSQM1WCMX20.
¡     Do not use FD interface modules (except the LSQM1TGS16FD0) with the following modules:
-     SA interface modules.
¡     Do not use an FE interface module, LSQM1EPSB0 module, or LSQM1SDNB0 module with the following modules:
Interface modules
Table2-3 Interface module specifications
Model
Port quantity
Port type
Available transceiver modules and network cables
LSQM1TGS24QSFD0
26
·     2 × 40GBASE-R-QSFP+ fiber ports or 1 × 100G QSFP28 fiber port
·     24 × 10GBASE-R-SFP+ fiber ports
·     QSFP28 transceiver module
·     QSFP28 DAC cable
·     QSFP+ transceiver module
·     QSFP+ DAC cable
·     QSFP+ to SFP+ DAC cable
·     10-GE SFP+ transceiver module
·     10-GE SFP+ DAC cable
·     GE SFP transceiver module
LSQM1CQGS12SG0
12
·     12 × 40GBASE-R QSFP+ fiber ports or 4 × 100GBASE-R QSFP28 fiber ports
·     QSFP28 DAC cable
·     QSFP+ DAC cable
LSQM1CGS2FE0
2
·     QSFP28 DAC cable
LSQM1QGS24RSG0
24
·     QSFP+ DAC cable
LSQM2GT24PTSSC0
48
·     4 × 10GBASE-R SFP+/LC fiber ports
·     20 × 1000BASE-X-SFP/LC fiber ports
·     24 × 10/100/1000BASE-T-RJ45 copper ports
·     FE/GE SFP transceiver module
·     Category 5 twisted-pair cable
LSQM2GT24TSSC0
28
LSQM3GP44TSSC0
48
·     4 × 10GBASE-R-SFP+ fiber ports (support for MACsec)
·     44 × 1000BASE-X-SFP fiber ports (support for MACsec)
LSQM1GP40TS8FD0
48
·     8 × 10GBASE-R SFP+/LC fiber ports
·     40 × 1000BASE-X-SFP/LC fiber ports
LSQM2GP40TS8FD0
48
LSQM2GP44TSSC0
48
·     44 × 1000BASE-X-SFP/LC fiber ports
LSQM2GP24TSSC0
28
·     24 × 1000BASE-X-SFP/LC fiber ports
LSQM1TGS48RFE0
48
LSQM1TGS48RSG0
48
LSQM2TGS48SG0
48
LSQM1TGS16GPSA0
40
·     16 × 10GBASE-R-SFP+/LC fiber ports
LSQM1TGS24FD0
24
LSQM1TGS16FD0
16
LSQM2TGS16SF0
16
LSQM2GP24TSSA0
28
·     4 × 10GBASE-R/ SFP+/LC fiber ports
LSQM1TGS12EC0
12
LSQM1GP48FD0
48
LSQM1XPT12TSFD0
20
·     12 × 10G EPON OLT/SC fiber ports
·     8 × 10GBASE-R-SFP+/LC fiber ports
·     XFP EPON transceiver module
LSQM2XPT12TSFD0
20
·     SFP+ EPON transceiver module
LSQM1PT24TSSC0
26
·     2 × 10GBASE-R SFP+/LC fiber ports
·     24 × 1000BASE-PX-SFP/SC fiber ports
·     SFP EPON transceiver module
LSQM1PT8TSSC0
10
·     8 × 1000BASE-PX-SFP/SC fiber ports
·     2 × 1000BASE-X-SFP/LC fiber ports
LSQM2GP48SA0
48
LSQM2GP24SA0
24
LSQM1TGT24FD0
24
10GBASE-T-RJ45 copper port
Category 6A/7 twisted-pair cable
LSQM1GT48FD0
48
LSQM2GT48SA0
48
LSQM2GT48SC0
48
LSQM4GV48SA0
48
LSQM4GV48SC0
48
OAA modules
Table2-4 OAA module specifications
Model
Ports
Compatible transceiver modules and network cables
LSU1WCME0
High-performance access controller module
·     1 × console port
·     1 ×100/1000BASE-T out-of-band management Ethernet port
Category 5 or above twisted-pair cable
LSU3WCMD0
·     1 × console port
·     1 × CF card slot (supporting 256-MB, 512-MB, and 1-GB CF cards)
·     2 × USB ports
·     2 × 10/100/1000BASE-T copper ports
·     2 × GE combo interfaces
LSQM1WCMX20
Access controller module
·     1 × console port
·     1 × 10/100/1000BASE-T out-of-band management Ethernet port
LSQM1WCMX40
·     1 × console port
LSQM1FWDSC0
Firewall module
·     1 × console port
·     1 × USB port (reserved for future use)
·     1 × GE Ethernet copper port
·     1 × hard disk slot
LSU1FWCEA0
Firewall module
·     1 × console port
·     2 × USB ports (reserved)
LSU3FWCEA0
Firewall module
·     1 × console port
·     2 × USB ports
LSUM1FWCEAB0
Firewall module
·     1 × console port
·     2 × USB ports
LSU1NSCEA0
10-GE high performance NetStream module
·     1 × console port
·     Category 5 or above twisted-pair cable
LSQM1NSDSC0
NetStream module
·     1 × console port
LSU1IPSBEA0
Intrusion prevention system module
·     1 × console port
·     2 × USB ports
LSQM1IPSDSC0
·     1 × console port
·     1 × USB port (only for supplying power to a PFC)
·     1 × 10/100/1000BASE-T copper port
LSQ1SSLSC0
SSL VPN module
·     1 × console port
·     2 × USB ports
LSQ1ACGASC0
Application control gateway module
·     1 × console port
·     2 × USB ports
LSQM1ACGDSC0
·     1 × console port
·     1 × USB port (reserved)
LSQM2ACGDSC0
·     1 × console port
LSQM1ADEDSC0
Application delivery engine module
·     1 × console port
LSU1ADECEA0
·     1 × console port
·     2 × USB ports
LSQM2FWDSC0
High-performance service module
·     1 × console port
·     2 × USB ports
·     4 × 10GBASE-R fiber ports
·     1 × hard disk
LSQM1EPSB0
EPS endpoint security module
·     3 × USB 2.0 ports (only for debugging use)
·     1 × VGA connector
·     1 × 10/100/1000BASE-T management Ethernet port
·     1 × console port (only for debugging use)
LSQM1SDNB0
SDN automation module
·     1 × VGA connector
LSQM1WBCZ720X
Multiservice access controller module
·     1 × VGA connector
·     1 × 1000BASE-T management Ethernet port
·     1 × console port
Power system
Follow these restrictions and guidelines to configure and use power modules for the switch:
·     A chassis must be configured with a minimum of one power module. To improve power supply availability, you can configure a chassis with two power modules for redundancy.
·     The power modules installed on the switch must be the same type (AC or DC) and model.
·     Make sure the maximum output power of a power module is greater than the total power consumption of the switch. As a best practice, reserve 20% of the maximum output power. For more information about the system power consumption and PoE power consumption, see "Total power consumption."
·     If you want the switch to provide PoE power for PDs, order a power module that can be used for setting up a PoE system. Make sure the maximum PoE power provided by the power module is greater than the PoE power consumption. The requirements for setting up a PoE system vary by switch model. For more information about setting up a PoE system, see H3C S7500X Switch Series Installation Guide.
Power modules
Table2-5 300 W power module specifications
Item
PSR320-A
Rated input voltage
100 VAC to 240 VAC @ 50 Hz or 60 Hz
Rated output voltage
12 VDC
Max input current
10 A
Max output current
25 A
Max system output power
300 W
Support for PoE
No
Max PoE output power
N/A
Table2-6 650 W power module specifications
Item
PSR650-A
PSR650C-12A
PSR650-D
PSR650C-12D
Rated input voltage
–48 VDC to 60 VDC
–48 VDC to 60 VDC
12 VDC
Max input current
10 A
10 A
25 A
25 A
Max output current
54 A
54 A
·     12 V: 54 A
·     3.3 V: 4 A
54 A
650 W
Support for PoE
No
N/A
Table2-7 1200 W power module specifications
Item
PSR1200-A
PSR1200-D
Rated input voltage
–48 VDC to 60 VDC
·     12 VDC
·     3.3 VDC
Max input current
16 A
42 A
Max output current
·     12 V: 100 A
·     3.3 V: 4 A
1213 W
Support for PoE
No
N/A
Table2-8 1400 W power module specifications
Item
PSR1400-A
PSR1400-12A1-F
PSR1400-D
PSR1400-12D1
Rated input voltage
–48 VDC to 60 VDC
–48 VDC to 60 VDC
12 VDC
12 VDC
·     12 VDC
·     PoE: 48 VDC
12 VDC
Max input current
16 A
16 A
190 A
50 A
Max output current
117 A
117 A
·     12 V output: 117 A
·     PoE: 140 A
117 A
1150 W (110 VAC)
1400 W (220 VAC)
1150 W (110 VAC)
1400 W (220 VAC or 270 VDC)
1400 W
1400 W
Support for PoE
No
No
Yes
No
N/A
N/A
6720 W
N/A
Table2-9 2500 W power module specifications
Item
PSR2500-12AHD
PSR2500-12D
Rated input voltage
·     100 VAC to 240 VAC @ 50 Hz or 60 Hz
·     240 VDC to 380 VDC
–48 VDC to 60 VDC
12 VDC
Max input current
16 A
85 A
Max output current
·     90 VAC to 180 VAC input: 100 A
·     180 VAC to 290 VAC or 180 VDC to 400 VDC input: 208 A
208 A
2500 W
Support for PoE
No
N/A
Table2-10 2800 W power module specifications
Item
PSR2800-ACV
PSR2800-A1-F
Rated input voltage
·     12 VDC
·     PoE: –50 VDC
Max input current
16 A
Max output current
·     PoE: 28 A
1150 W (110 VAC)
1400 W (220 VAC)
1150 W (110 VAC)
Support for PoE
Yes
1150 W (110 VAC)
1400 W (220 VAC)
1150 W (110 VAC)
Table2-11 6000 W power module specifications
Item
PSR6000-ACV
Rated input voltage
·     12 VDC
·     PoE: 48 VDC
Max input current
16 A
Max output current
110 V input:
·     12 VDC: 96 A
·     One PoE input: 23 A
·     Two PoE inputs: 46 A
·     Three PoE inputs: 69 A
220 V input:
·     12 VDC: 117 A
·     One PoE input: 34 A
·     Two PoE inputs: 68 A
·     Three PoE inputs: 100 A
1150 W (110 VAC)
1400 W (220 VAC)
Support for PoE
Yes
110 V input:
·     One PoE input: 1200 W
·     Two PoE inputs: 2400 W
·     Three PoE inputs: 3600 W
220 V input:
·     One PoE input: 1800 W
·     Two PoE inputs: 3600 W
·     Three PoE inputs: 5300 W
The maximum PoE output power is 10000 W when the switch is fully configured with PSR1400-D or PSR6000-ACV power modules.
Table2-12 shows the compatibility between power modules and switches.
Table2-12 Power module and switch compatibility matrix
Power module
S7503X
S7503X-PoE
S7506X
S7506X-S
S7506X-S-MF
S7506X-PoE
S7510X
S7510X-PoE
PSR320-A
l
PSR650-A
l
PSR650-D
l
PSR1200-A
PSR1200-D
PSR650C-12A
l
l
PSR650C-12D
l
l
PSR1400-A
l
l
l
l
PSR1400-D
l
l
l
l
PSR1400-12D1
l
l
l
l
PSR2500-12AHD
l
l
l
l
PSR2500-12D
l
l
l
l
PSR2800-ACV
l
l
PSR6000-ACV
l
l
·     "l" indicates that the power module can be directly installed on the chassis.
·     "¡" indicates that you must first install a power module adapter on the chassis and then install the power module on the power module adapter. For more information about installing a power module and a power module adapter, see H3C S7500X Switch Series Installation Guide.
·     "—" indicates that the power module cannot be installed on the chassis.
Power cords
DC power cords
A DC power cord connects a DC power module to an external DC power source.
Table2-13 DC power cords available for the power modules
DC power cord code
DC power cord length
DC power module
0404A06T
3 m (9.84 ft)
PSR650-D/PSR650C-12D
0404A01N
5 m (16.40 ft)
0404A01P
10 m (32.81 ft)
0404A073
20 m (65.62 ft)
0404A0DU
3 m (9.84 ft)
PSR1200-D
0404A07G
3 m (9.84 ft)
PSR1400-D/PSR1400-12D1/PSR2500-12D
0404A08T
10 m (32.81 ft)
0404A08U
20 m (65.62 ft)
0404A072
25 m (82.02 ft)
0404A0RL
3 m (9.84 ft)
PSR2500-12AHD (240 to 380 VDC)
AC power cords
AC power cords are used for connecting the AC power modules of the switch to the external AC power source. Before you order an AC power cord, make sure you have read the following restrictions and guidelines:
·     Select AC power cords according to the power of the power module.
·     The connector type varies by country or region. Select a compliant connector type as needed.
·     For the PSR320-A, PSR650-A, and PSR650C-12A power modules, select 10A AC power cords.
·     For the PSR1200-A, PSR1400-A, PSR1400-12A1-F, PSR2500-12AHD, PSR2800-ACV, PSR2800-A1-F, and PSR6000-ACV power modules, select 16A AC power cords.
·     For the PSR2500-12AHD power module, select the 0404A0RP or 0404A0RQ AC power cord. The 0404A0RP and 0404A0RQ AC power cords can only be used for the PSR2500-12AHD power module.
·     The type of the connector (connected to the power source) varies by country or region. Select a compliant connector type as needed. For the connector types of different countries or regions and the power cord codes, see H3C Power Cords & Cables User Guide.
PoE DC power cords
A PoE DC power cord is used to connect a PoE power module on the switch to an external DC power source.
Table2-14 PoE DC power cords available for PoE power modules
PoE power module
PoE DC power cord
Cable length
PSR2800-ACV/PSR2800-A1-F/PSR6000-ACV
0404A05U
1 m (3.28 ft)
PSR1400-D
0404A07H
3 m (9.84 ft)
PoE AC power cords
The switch uses 16A PoE AC power cords. A PoE AC power cord is used to connect a PoE power module on the switch to an external AC power source.
Fan trays
Table2-15 Fan tray specifications
Fan tray
Number of fan trays
Number of fans
Fan diameter
Maximum air flow rate
S7503X fan tray
S7503X-PoE fan tray
1
2
120 mm (4.72 in)
166 CFM (4.70 m³/min)
S7506X fan tray
S7506X-PoE fan tray
S7506X-S fan tray
1
9
92 mm (3.62 in)
495 CFM (14.02 m³/min)
3
3 (one small fan and two large fans)
·     Small fan: 80 mm (3.15 in)
·     Large fan: 92 mm (3.62 in)
130 CFM (3.68 m³/min)
S7510X fan tray S7510X-PoE fan tray
1
6
92 mm (3.62 in)
662 CFM (18.75 m³/min)
1
4
120 mm (4.72 in)
The switch comes with the fan tray installed. To replace the fan tray, make sure the new fan tray is compatible with the switch.
3 LEDs
The MPUs, service modules, and power modules available for the switch use multiple LEDs to indicate their operating status. The LED type and quantity vary by module model.
Table3-1 lists the LEDs on the MPUs, service modules, and power modules.
Unless otherwise specified, the flashing frequency of the LEDs in this section is 0.5 Hz.
Table3-1 LEDs at a glance
LEDs
MPU LEDs
·     Management Ethernet port LEDs
·     Power module status LEDs
·     Fan tray status LEDs
·     Card status LEDs
·     Active/standby state LED
·     SFP28 port LEDs
Service module LEDs
·     RJ-45 Ethernet port LEDs
·     Combo interface LEDs
·     SFP port LEDs
·     SFP+ port LEDs
·     QSFP+ port LEDs
·     QSFP28 port LEDs
·     EPON port LEDs
Power module LEDs
·     PSR320-A
·     PSR650-A/PSR650-D/PSR1200-A/PSR1200-D
·     PSR650C-12A/PSR650C-12D/PSR1400-A/PSR1400-12A1-F/PSR2500-12AHD/PSR2500-12D
·     PSR1400-D
·     PSR1400-12D1
·     PSR2800-ACV
·     PSR6000-ACV
MPU LEDs
Multiple MPUs are available for the device. These MPUs provide different types and numbers of LEDs.
Figure3-1 LSQM2SUPA0 MPU LEDs
(1) Copper management Ethernet port LEDs
(2) Fiber management Ethernet port LED
(3) Active/standby state LED
(4) Card status LEDs
(5) Power module status LED
(6) Fan tray status LED (FAN)
Figure3-1 LSQM3SUPA0 MPU LEDs
(1) Fiber management Ethernet port LED
(2) Copper management Ethernet port LED
Figure3-2 LSQM1MPUSA0 MPU LEDs
(3) Card status LEDs
(4) Active/standby state LED
(5) Fan tray status LEDs
(6) Power module status LEDs
Figure3-3 LSQM1SRP4Y06A0 MPU LEDs
(2) SFP28 port LED
(7) Fiber management Ethernet port LED
The MPUs provide a LED for each fiber management Ethernet port to indicate its link status and data forwarding status.
Table3-2 Fiber management Ethernet port LED description
LED status
Flashing green
A link is present, and the port is receiving or sending data.
Steady green
A link is present.
Off
No link is present.
The MPUs provide a pair of LEDs (LINK and ACT) for each copper management Ethernet port to indicate its link status and data forwarding status.
Table3-3 Copper management Ethernet port LED description
LINK LED status
ACT LED status
On
Flashing
On
Off
A link is present.
Off
Off
No link is present.
On the MPUs available for the device, two types of power module status LEDs exist.
·     A pair of power module status LEDs (PWR OK and FAIL). See Table3-4 for the LED description.
·     A single power module status LED (PWR). See Table3-5 for the LED description.
Table3-4 Description for the power module status LEDs
PWR OK LED status
PWR FAIL LED status
On
Off
All power modules are operating correctly.
Off
On
A power module is not outputting power because one of the following conditions exists:
·     The power module is faulty or switched off.
·     The power cord is disconnected.
·     The power source is not supplying power.
Off
Off
·     No power modules are installed in the chassis.
·     No power modules are outputting power because one of the following conditions exists:
¡     The power modules are faulty or switched off.
¡     The power cords are disconnected.
¡     The power source is not supplying power.
Table3-5 Description for the power module status LED
PWR LED status (OK/FAIL)
Steady green
Steady red
Off
On the MPUs available for the device, two types of fan tray status LEDs exist.
·     A pair of fan tray status LEDs (FAN OK and FAIL). See Table3-6 for the LED description.
·     A single fan tray status LED (FAN OK/FAIL). See Table3-7 for the LED description.
Table3-6 Description for the fan tray status LEDs
FAN OK LED status
FAN FAIL LED status
On
Off
The fan tray is operating correctly.
Off
On
A fan problem has occurred or the fan tray is not in position.
Off
Off
The switch is not powered on.
Table3-7 Description for the fan tray status LED
FAN LED status (OK/FAIL)
Steady green
Steady red
Off
Card status LEDs
On the MPUs available for the device, two types of card status LEDs exist.
·     A single card status LED (SLOT RUN/ALM). See Table3-8 for the LED description.
·     A pair of card status LEDs (RUN and ALM). See Table3-9 for the LED description.
Table3-8 Description for the card status LED
SLOT LED status (RUN/ALM)
Flashing green
The card is operating correctly.
Flashing green (4 Hz)
The card is loading software.
If the LED flashes continuously, the software versions of the switch and the card do not match.
Steady red
The card is starting up or faulty.
Flashing red
The temperature of the card has exceeded the upper warning threshold or has dropped below the lower warning threshold.
Off
No card is present.
Table3-9 Description for the card status LEDs
RUN LED status
ALM LED status
Flashing (0.5 Hz)
Off
Fast flashing (4 Hz)
On
Flashing (0.5 Hz)
Slow flashing (0.25 Hz)
On
On
Off
Off
No card is present.
The ALM LED lights for a period of time at the initial phase of the system startup.
The MPUs that support active/standby switchover provide an ACTIVE LED to indicate the active or standby state.
Table3-10 MPU active/standby state LED description
ACTIVE LED status
On
The MPU is in active state.
Off
·     The MPU is in standby state.
·     The MPU is faulty. Observe also the status LED for the MPU to determine whether the MPU is faulty.
SFP28 port LEDs
The MPUs provide a SFP28 port LED to indicate the link status and data receiving/forwarding status of the port.
Table3-11 SFP28 port LED description
LED status
Flashing
The port is receiving or sending data.
On
A link is present.
Off
No link is present.
Service module LEDs
The service modules provide a LED for each RJ-45 Ethernet port to indicate the link status and data receiving/forwarding status of the port.
Table3-12 RJ-45 Ethernet port LED description
LED status
Flashing
On
A link is present.
Off
No link is present.
A combo interface contains an SFP port and an RJ-45 Ethernet port. Only one port of a combo interface is active at a time. By default, the port with the smaller number is active.
The service modules provide a LED for each combo interface to indicate the link status and data receiving/forwarding status of the interface.
Table3-13 Combo interface LED description
LED status
Flashing
The interface is receiving or sending data.
On
A link is present.
Off
No link is present.
To use the inactive port of a combo interface, execute the undo shutdown command to activate the port. The other port of the combo interface is then automatically shut down and becomes inactive.
SFP port LEDs
The service modules provide a LED for each SFP port LED to indicate the link status and data receiving/forwarding status of the port.
Table3-14 SFP port LED description
LED status
Flashing
On
A link is present.
Off
No link is present.
SFP+ port LEDs
The service modules provide a LED for each SFP+ port LED to indicate the link status and data receiving/forwarding status of the port.
Table3-15 SFP+ port LED description
Status
Flashing green
The port is receiving or sending data at 10 Gbps.
Flashing yellow
The port is receiving or sending data at 1000 Mbps.
On
A link is present.
Off
No link is present.
QSFP+ port LEDs
The service modules provide a LED for each QSFP+ port to indicate the link status and data receiving/forwarding status of the port.
Table3-16 QSFP+ port LED description
Status
Flashing
On
A link is present.
Off
No link is present.
The color of the QSFP+ port LED indicates support of the port for 100-GE/40-GE switchover as follows:
·     Yellow—The port supports 100-GE/40-GE switchover.
·     Green—The port does not support 100-GE/40-GE switchover.
QSFP28 port LEDs
The service modules provide a LED for each QSFP28 port to indicate the link status and data receiving/forwarding status of the port.
Table3-17 QSFP28 port LED description
LED status
Flashing
On
A link is present.
Off
No link is present.
The color of the QSFP28 port LED indicates the port speed as follows:
·     Green—100 Gbps.
·     Yellow—Less than 100 Gbps.
EPON port LEDs
The service modules provide a LED for each EPON port to indicate the link status and data receiving/forwarding status of the port.
Table3-18 EPON port LED description
LED status
On
The connected ONU has been successfully registered.
Off
The connected ONU is not registered, or no ONU is connected.
Power module LEDs
The switch supports many power module models. Each power module provides LEDs to indicate its operating status. The LEDs vary by power module model.
PSR320-A
A PSR320-A power module provides a status LED to indicate its operating status.
Table3-19 PSR320-A power module LED description
LED
Status
Status LED
Green
Normal operation
Red
Abnormal operation. Possible reasons include:
·     A power module alarm (such as input undervoltage, output short-circuit, output overcurrent, output overvoltage, or overtemperature) has occurred and the power module has entered protection state.
·     A power module fan failure has occurred.
Off
Abnormal power input. Possible reasons include:
·     The power module is faulty.
·     The external power supply system is not available.
The power module is switched off.
The PSR650-A, PSR650-D, PSR1200-A, and PSR1200-D power modules each provide a status LED to indicate their operating status.
Table3-20 PSR650-A/PSR650-D/PSR1200-A/PSR1200-D power module LEDs description
LED
Status
Status LED
Green
Normal operation
Red
Off
The PSR650C-12A, PSR650C-12D, PSR1400-A, PSR1400-12A1-F, PSR2500-12AHD, and PSR2500-12D power modules each provide three LEDs INPUT, OUTPUT, and FAN to indicate their operating status.
Table3-21 PSR650C-12A/PSR650C-12D/PSR1400-A/PSR1400-12A1-F/PSR2500-12AHD/PSR2500-12D power module LEDs description
LED
Status
INPUT
Green
Normal power input
Red
Abnormal power input. The input voltage is out of the rated voltage range (input undervoltage or overvoltage).
Off
·     No power input. Possible reasons include:
¡     The power cord is disconnected.
¡     The external power supply system is not available.
OUTPUT
Green
Normal power output
Red
Abnormal power output. Possible reasons include:
·     A power module alarm (such as input undervoltage, output short-circuit, output overcurrent, output overvoltage, overtemperature, or fan failure) has occurred and the power module has entered protection state.
·     The power module is switched off.
Off
FAN
Green
Normal fan operation
Red
Abnormal fan operation. Possible reasons include:
Off
·     The power module does not have power input. Possible reasons include:
PSR1400-D
A PSR1400-D power module provides four LEDs INPUT, OUTPUT, FAN, and PoE to indicate its operating status.
Table3-22 PSR1400-D power module LED description
LED
Status
INPUT
Green
The power is being input correctly, and the system power output switch is turned on.
Red
A power input problem has occurred because the input voltage is out of the rated voltage range.
Off
One of the following conditions might exist:
·     The system power output switch is turned off.
OUTPUT
Green
The power is being output correctly.
Red
A power output problem has occurred because the power module generates an alarm and enters the protection state due to output short-circuit, output overcurrent, output overvoltage, or overtemperature.
Off
FAN
Green
The fans are operating correctly.
Red
The fans are operating incorrectly because a fan failure has occurred.
Off
PoE
Green
The PoE power is being output correctly.
Red
A PoE power output problem has occurred because the PoE output voltage is out of the rated voltage range.
Off
No PoE power is being output because one of the following conditions might exist:
·     The PoE power output switch is turned off.
PSR1400-12D1
A PSR1400-12D1 power module provides three LEDs INPUT, OUTPUT, and FAN to indicate its operating status.
Table3-23 PSR1400-12D1 power module LEDs description
LED
Status
INPUT
Green
Normal power input.
Red
Abnormal power input. The input voltage is out of the rated voltage range.
Off
OUTPUT
Green
Normal power output
Red
Abnormal power output. A power module alarm (such as output short-circuit, output overcurrent, output overvoltage, or overtemperature) has occurred and the power module has entered protection state.
Off
FAN
Green
Red
Abnormal fan operation. A power module fan failure has occurred.
Off
·     The power module does have power input. Possible reasons include:
The PSR2800-ACV and PSR2800-A1-F power modules each provide five LEDs INPUT, OUTPUT, FAN, PoE INPUT, and PoE OUTPUT to indicate the operating status.
Table3-24 PSR2800-ACV/PSR2800-A1-F power module LED description
LED
Status
INPUT
Green
Normal power input.
Red
Off
¡     The system input power cord is disconnected.
OUTPUT
Green
Normal power output
Red
·     The system power switch is turned off.
Off
FAN
Green
Red
Off
PoE INPUT
Green
Normal PoE power input
Red
Abnormal PoE power input. The PoE input voltage is out of the rated voltage range.
Off
No PoE power input. Possible reasons include:
·     The PoE input power cord is disconnected.
PoE OUTPUT
Green
Normal PoE power output
Red
Abnormal PoE power output. Possible reasons include:
·     The PoE output voltage is out of the rated voltage range.
·     The PoE power switch is turned off.
Off
No PoE power output. Possible reasons include:
PSR6000-ACV
The PSR6000-ACV power module provides LEDs SYS IN, SYS OUT, SYS FAN, PoE IN1, PoE IN2, PoE IN3, PoE OUT, and PoE FAN to indicate its operating status.
Table3-25 PSR6000-ACV power module LED description
LED
Status
SYS IN
Green
Normal system power input
Red
Abnormal system power input. The system power input voltage is out of the rated voltage range.
Off
·     No system power input. Possible reasons include:
SYS OUT
Green
Normal system power output
Red
Abnormal system power output. Possible reasons include:
·     A power module alarm (such as output short-circuit, output overcurrent, output overvoltage, or overtemperature) has occurred and the power module has entered protection state.
·     The SYS power switch is turned off.
Off
SYS FAN
Green
Normal system fan operation.
Red
Abnormal system fan operation. Possible reasons include:
·     A system fan failure has occurred.
Off
PoE IN1
Green
Normal PoE1 power input.
Red
Abnormal PoE1 power input. The PoE1 power input voltage is out of the rated voltage range.
Off
No PoE1 power input. Possible reasons include:
·     The PoE1 input power cord is disconnected.
PoE IN2
Green
Normal PoE2 power input.
Red
Abnormal PoE2 power input. The PoE2 power input voltage is out of the rated voltage range.
Off
No PoE2 power input. Possible reasons include:
·     The PoE2 input power cord is disconnected.
PoE IN3
Green
Normal PoE3 power input.
Red
Abnormal PoE3 power input. The PoE3 power input voltage is out of the rated voltage range.
Off
No PoE3 power input. Possible reasons include:
·     The PoE3 input power cord is disconnected.
PoE OUT
Green
Red
Off
·     The PoE 1, PoE 2, and PoE 3 input power cords are all disconnected.
PoE FAN
Green
Normal PoE fan operation
Red
Abnormal PoE fan operation. Possible reasons include:
·     A PoE fan failure has occurred.
Off
4 Cables
This chapter describes the cables used for connecting network ports.
Table4-1 Cable description
Cable
Port type
Application
Console cable
Console port at one end and 9-pin serial port at the other end
Enables users to perform debugging, configuration, maintenance, management, and software loading on the device.
USB console cable
USB console port at one end and USB port at the other end
RJ-45 Ethernet ports
Connects RJ-45 Ethernet ports to transmit data.
Optical fiber
XFP/SFP+/SFP/QSFP+/QSFP28/EPON ports
Connects the fiber ports to transmit data.
SFP+ DAC cable (see "SFP+ DAC/SFP28 DAC cable")
SFP+ ports
Connects SFP+ ports to transmit data.
SFP28 DAC cable (see "SFP+ DAC/SFP28 DAC cable")
SFP28 ports
Connects SFP28 ports to transmit data.
QSFP+ DAC cable (see "QSFP+ DAC/QSFP28 DAC cable")
QSFP+ ports
Connects QSFP+ ports to transmit data.
QSFP28 DAC cable (see "QSFP+ DAC/QSFP28 DAC cable")
QSFP28 ports
Connects QSFP28 ports to transmit data.
QSFP+ port at one end, and SFP+ port at the other end
Connects a QSFP+ port to an SFP+ port.
SFP28 AOC cable
SFP28 ports
An Ethernet twisted pair cable consists of four pairs of insulated wires twisted together. It mainly transmits analog signals and is advantageous in transmitting data over shorter distances. The maximum transmission distance is 100 m (328.08 ft).
RJ-45 connector
An Ethernet twisted pair cable connects network devices through the RJ-45 connectors at the two ends. Figure4-1 shows the pinouts of an RJ-45 connector.
Figure4-1 RJ-45 connector pinout diagram
Cable pinouts
EIA/TIA cabling specifications define two standards: 568A and 568B for cable pinouts.
·     Standard 568A—Pin 1: white/green stripe, pin 2: green solid, pin 3: white/orange stripe, pin 4: blue solid, pin 5: white/blue stripe, pin 6: orange solid, pin 7: white/brown stripe, pin 8: brown solid.
·     Standard 568B—Pin 1: white/orange stripe, pin 2: orange solid, pin 3: white/green stripe, pin 4: blue solid, pin 5: white/blue stripe, pin 6: green solid, pin 7: white/brown stripe, pin 8: brown solid.
Cable type
Based on performance
Ethernet cables can be classified into category 3, category 4, category 5, category 5e, category 6, and category 7 cable based on performance. In LANs, category 5, category 5e, and category 6 are commonly used.
Table4-2 Ethernet cable description
Category 5
Transmits data at a maximum speed of 100 Mbps, with a bandwidth of 100 MHz.
Category 5e
Transmits data at a maximum speed of 1000 Mbps, with a bandwidth of 100 MHz.
Category 6
Transmits data at a maximum speed of 10 Gbps, with a bandwidth of 250 MHz.
The RJ-45 Ethernet ports use category 5 or higher Ethernet twisted pair cables for connection.
Based on pinouts
Ethernet twisted pair cables can be classified into straight through and crossover cables based on their pinouts.
·     Straight-through—The pinouts at both ends comply with standard 568B, as shown in Figure4-2.
·     Crossover—The pinouts at one end comply with standard 568B, and those at the other end comply with standard 568A, as shown in Figure4-3.
Figure4-2 Straight-through cable
Figure4-3 Crossover cable
Pin assignments
Select an Ethernet twisted pair cable according to the RJ-45 Ethernet port type on your device. An RJ-45 Ethernet port can be MDI (for routers and PCs) or MDIX (for switches). For the pinouts of RJ-45 Ethernet ports, see Table4-3 and Table4-4.
Table4-3 RJ-45 MDI port pinouts
Pin
10BASE-T/100BASE-TX
1000BASE-T
Signal
Function
Signal
Function
1
Tx+
Send data
BIDA+
Bi-directional data cable A+
2
Tx-
Send data
BIDA-
Bi-directional data cable A-
3
Rx+
Receive data
BIDB+
Bi-directional data cable B+
4
Reserved
BIDC+
Bi-directional data cable C+
5
Reserved
BIDC-
6
Rx-
Receive data
BIDB-
Bi-directional data cable B-
7
Reserved
BIDD+
Bi-directional data cable D+
8
Reserved
BIDD-
Bi-directional data cable D-
Table4-4 RJ-45 MDI-X port pinouts
Pin
10BASE-T/100BASE-TX
1000BASE-T
Signal
Function
Signal
Function
1
Rx+
Receive data
BIDB+
2
Rx-
Receive data
BIDB-
3
Tx+
Send data
BIDA+
4
Reserved
BIDD+
5
Reserved
BIDD-
6
Tx-
Send data
BIDA-
7
Reserved
BIDC+
8
Reserved
BIDC-
Bi-directional data cable C-
To ensure normal communication, the pins for sending data on one port should correspond to the pins for receiving data on the peer port. When both of the ports on the two devices are MDI or MDIX, a crossover Ethernet cable is needed. A cross-over cable connects devices of the same type. When one port is MDI and the other is MDIX, a straight-through Ethernet cable is needed. A straight-through cable connects devices of different types.
If an RJ-45 Ethernet port with MDI/MDIX autosensing enabled can automatically negotiate pin roles. The RJ-45 Ethernet ports on the switch support MDI/MDIX. By default, MDI/MDIX is enabled on a port.
1.     Cut the cable to length with the crimping pliers.
2.     Strip off an appropriate length of the cable sheath. The length is typically that of the RJ-45 connector.
3.     Untwist the pairs so that they can lie flat, and arrange the colored wires based on the wiring specifications.
4.     Cut the top of the wires even with one another. Insert the wires into the RJ-45 end and make sure the wires extend to the front of the RJ-45 end and make good contact with the metal contacts in the RJ-45 end and in the correct order.
5.     Crimp the RJ-45 connector with the crimping plier until you hear a click.
6.     Repeat the above steps with the other end of the cable.
7.     Use a cable tester to verify the connectivity of the cable.
Optical fiber
CAUTION
CAUTION:
Use the same types of transceiver modules, pigtail cords, patch cords, and fiber cables. If you use single-mode optical fibers, the transceiver modules, pigtail cords, patch cords, and fiber cables must be single-mode.
Optical fiber
Optical fibers are widely used in fiber-optic communications, which are advantageous for long-distance communications.
Optical fibers can be classified into the following types:
·     Single mode fiber—It has a core size of 10 µm, and has a lower modal dispersion. It carries only a single ray of light. It is mostly used for communication over longer distances.
·     Multi-mode fiber—It has a core size of 50 µm or 62.5 µm or higher, and has a higher modal dispersion than single-mode optical fiber. It is mostly used for communication over shorter distances.
Table4-5 Allowed maximum tensile force and crush load
Period of force
Tensile load (N)
Crush load (N/mm)
Short period
150
500
Long term
80
100
Optical fiber cable
An optical fiber cable is a cable containing one or more optical fibers. The optical fiber elements are typically individually coated with plastic layers and contained in a protective tube. Optical fiber cables fall into single-mode and multi-mode.
Patch cord
A fiber that has connectors at both ends is called a patch cord. A patch cord connects one optical device to another for signal routing. Patch cords fall into single-mode and multi-mode patch cords.
·     Single-mode patch cord—The jacket is yellow. It permits transmission over longer distances.
·     Multi-mode patch cord—The jacket is orange. It permits transmission over shorter distances.
Patch cords are classified into SC, LC, and FC patch cords based on interface type. The length of a patch cord can be 0.5 m (1.64 ft), 1 m (3.28 ft), 2 m (6.56 ft), 3 m (9.84 ft), 5 m (16.40 ft), and 10 m (32.81 ft).
Pigtail cord
A pigtail cord is an optical fiber that has an optical connector on one end and a length of exposed fiber on the other. The end of the pigtail is fusion spliced to a fiber, connecting the fiber cable and transceiver.
Pigtail cords fall into single-mode (yellow) and multi-mode (orange), and can also be classified into SC, LC, and FC pigtail cords based on interface type.
Fiber connector
Fiber connectors are indispensable passive components in an optical fiber communication system. They allow the removable connection between optical channels, which makes the optical system debugging and maintenance more convenient and the transit dispatching of the system more flexible.
Figure4-4 SC connector
Figure4-5 LC connector
You can use SFP+ DAC cables to connect SFP+ ports. SFP+ DAC cables support the SFP+ standard and use 10-GE SFP+ Cu standard cables.
You can use SFP28 DAC cables to connect SFP28 ports. The SFP28 DAC cables are similar to SFP+ DAC cables in appearance.
Figure4-6 SFP+ DAC cable
(1) Connector
(2) Pull latch
You can use QSFP+ DAC cables to connect QSFP+ ports.
You can use QSFP28 DAC cables to connect QSFP28 ports. The QSFP28 DAC cables are similar to QSFP+ DAC cables in appearance.
Figure4-7 QSFP+ DAC cable
(1) Connector
(2) Pull latch
A QSFP+ to SFP+ DAC cable provides one QSFP+ connector at one end and four SFP+ connectors at the other end.
Figure4-8 QSFP+ to SFP+ DAC cable
(1) QSFP+ connector
(2) QSFP+ pull latch
(3) SFP+ connector
(4) SFP+ pull latch
SFP28 AOC cable
You can use SFP28 AOC cables to connect SFP28 ports.
Figure4-9 SFP28 AOC cable
(1) Connector
(2) Pull latch
