HomeSupportRouters5G IPRAN Access RoutersConfigure & DeployConfiguration GuidesH3C RA5300 Router Configuration Guides-R7607-6W10109-Security Configuration Guide
06-IP-based attack prevention configuration
06-IP-based attack prevention configuration 41.04 KB
Configuring IP-based attack prevention
About IP-based attack prevention
Attackers can initiate attacks based on IP and upper-layer protocols. For example, an attacker can exploit the TCP connection establishment process or send a target excessive ICMP requests (such as ping packets) in a short period of time. To prevent such attacks, IP-based attack prevention provides the following features:
Configuring Naptha attack prevention
Naptha is a DDoS attack that targets operating systems. It exploits the resources consuming vulnerability in TCP/IP stack and network application process. The attacker establishes a large number of TCP connections in a short period of time and leaves them in certain states without requesting any data. These TCP connections starve the victim of system resources, resulting in a system breakdown.
After you enable Naptha attack prevention, the device periodically checks the number of TCP connections in each state (CLOSING, ESTABLISHED, FIN_WAIT_1, FIN_WAIT_2, and LAST_ACK). If the number of TCP connections in a state exceeds the limit, the device will accelerate the aging of the TCP connections in that state to mitigate the Naptha attack.
2.     Enable Naptha attack prevention.
tcp anti-naptha enable
By default, Naptha attack prevention is disabled.
3.     (Optional.) Set the maximum number of TCP connections in a state.
tcp state { closing | established | fin-wait-1 | fin-wait-2 | last-ack } connection-limit number
By default, the maximum number of TCP connections in each state (CLOSING, ESTABLISHED, FIN_WAIT_1, FIN_WAIT_2, and LAST_ACK) is 50.
To disable the device from accelerating the aging of the TCP connections in a state, set the value to 0.
4.     (Optional.) Set the interval for checking the number of TCP connections in each state.
tcp check-state interval interval
By default, the interval for checking the number of TCP connections in each state is 30 seconds.
