08-ACL and QoS Configuration Guide
HomeSupportRouters5G IPRAN Access RoutersConfigure & DeployConfiguration GuidesH3C RA5300 Router Configuration Guides-R7607-6W10108-ACL and QoS Configuration Guide
05-Time range configuration
05-Time range configuration 51.02 KB
Configuring time ranges
About time ranges
You can implement a service based on the time of the day by applying a time range to it. A time-based service takes effect only in time periods specified by the time range. For example, you can implement time-based ACL rules by applying a time range to them.
The following basic types of time ranges are available:
·     Periodic time range—Recurs periodically on a day or days of the week.
·     Absolute time range—Represents only a period of time and does not recur.
The active period of a time range is calculated as follows:
1.     Combining all periodic statements.
2.     Combining all absolute statements.
3.     Taking the intersection of the two statement sets as the active period of the time range.
Restrictions and guidelines: Time range configuration
When you configure the ACL hardware mode, follow these restrictions and guidelines:
·     If a time range does not exist, the service based on the time range does not take effect.
·     You can create a maximum of 1024 time ranges, each with a maximum of 32 periodic statements and 12 absolute statements.
2.     Create or edit a time range.
time-range time-range-name { start-time to end-time days [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 }
If an existing time range name is provided, this command adds a statement to the time range.
Display and maintenance commands for time ranges
Execute the display command in any view.
Display time range configuration and status.
display time-range { time-range-name | all }
