- 06-IP Multicast Command Reference
- 01-IGMP snooping commands
- 02-PIM snooping commands
- 03-Multicast VLAN commands
- 04-Multicast routing and forwarding commands
- 05-IGMP commands
- 06-PIM commands
- 07-MSDP commands
- 08-Multicast VPN commands
- 09-MLD snooping commands
- 10-IPv6 PIM snooping commands
- 11-IPv6 multicast VLAN commands
- 12-IPv6 multicast routing and forwarding commands
- 13-MLD commands
- 14-IPv6 PIM commands
| 04-Multicast routing and forwarding commands | 363.83 KB |
acl (IPv4 multicast flow policy view)
bandwidth (IPv4 multicast flow policy view)
display multicast fast-forwarding cache
display multicast flow-policy info
display multicast forwarding df-info
display multicast forwarding event
display multicast forwarding-table
display multicast forwarding-table df-list
display multicast replication-share info
display multicast routing-table
display multicast routing-table static
flow-ucmp unicast reserve-bandwidth (MRIB view)
multicast cpu-forwarding max-copy-count
multicast flow-ucmp unicast reserve-bandwidth
multicast forwarding supervlan community
multicast forwarding-table cache-unknown per-entry
multicast forwarding-table cache-unknown total
multicast replication-share enable
reset multicast fast-forwarding cache
reset multicast forwarding event
reset multicast forwarding-table
Use acl to configure the multicast group range in which an IPv4 multicast flow policy takes effect.
Use undo acl to restore the default.
acl { ipv4-acl-number | name ipv4-acl-name }
undo acl
An IPv4 multicast flow policy does not take effect on any multicast groups.
ipv4-acl-number: Specifies an IPv4 basic or advanced ACL by its number, in the range of 2000 to 3999. If the ACL does not exist or does not have contain rules, the IPv4 multicast flow policy does not take effect on any multicast groups.
name ipv4-acl-name: Specifies an IPv4 basic or advanced ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters and must begin with an English letter. To avoid confusion, make sure the argument is not all. If the ACL does not exist or does not have contain rules, the IPv4 multicast flow policy does not take effect on any multicast groups.
This command is not supported by the default IPv4 multicast flow policy.
If a multicast group matches the ACL specified in an IPv4 multicast flow policy, the estimated bandwidth configured in the policy is used for the multicast flows of the multicast group.
In a basic ACL rule, the source parameter specifies a multicast group range. Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
In an advanced ACL rule, the source parameter specifies a multicast source range, and the destination parameter specifies a multicast group range. Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
An ACL rule containing the vpn-instance vpn-instance option does not take effect.
Example
# Configure an IPv4 multicast flow policy to take effect on the multicast group range 224.1.0.0/16.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 224.1.0.0 0.0.255.255
[Sysname] multicast routing
[Sysname-mrib] flow-policy name abc
[Sysname-mrib-flow-policy-abc] acl 2000
flow-policy (IPv4 MRIB view)
Use bandwidth to set the estimated bandwidth for multicast flows.
bandwidth bandwidth { gbps | kbps | mbps }
undo bandwidth
The estimated bandwidth for multicast flows is 0.
bandwidth: Specifies the estimated bandwidth in the range of 1 to 10000.
gbps: Specifies Gbps as the bandwidth unit.
kbps: Specifies kbps as the bandwidth unit.
Mbps: Specifies Mbps as the bandwidth unit.
The estimated bandwidth is selected for IPv4 multicast flows as follows:
1. If the multicast group of an IPv4 multicast flow matches the ACL specified in a custom IPv4 multicast flow policy, the estimated bandwidth configured in the policy is selected for the multicast flow.
2. If the multicast group of an IPv4 multicast flow does not match an ACL in any custom IPv4 multicast flow policy, the estimated bandwidth configured in the default policy is selected for the multicast flow.
3. If the default policy is not created or the estimated bandwidth is not configured in the default policy, the estimated bandwidth for the multicast flow is 0.
Example
# Set the estimated bandwidth to 200 Mbps for IPv4 multicast flow policy abc.
[Sysname-mrib-flow-policy-abc] bandwidth 200 mbps
delete ip rpf-route-static
Use delete ip rpf-route-static to delete all static multicast routes.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command deletes all static multicast routes on the public network.
This command deletes all static multicast routes. To delete a specified static multicast route, use the undo ip rpf-route-static command.
# Delete all static multicast routes on the public network.
[Sysname] delete ip rpf-route-static
This will erase all multicast static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
ip rpf-route-static
display mrib interface
Use display mrib interface to display information about interfaces maintained by the MRIB.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about interfaces maintained by the MRIB on the public network.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about all interfaces maintained by the MRIB.
# Display information about interfaces maintained by the MRIB on the public network.
<Sysname> display mrib interface
Interface: Vlan-interface1
Index: 0x00004444
Current state: up
MTU: 1500
Type: BROADCAST
Protocol: PIM-DM
PIM protocol state: Enabled
Address list:
1. Local address : 8.12.0.2/16
Remote address: 0.0.0.0
Reference : 1
State : NORMAL
Flags : 0x2
Interface name. |
Index |
Index number of the interface. |
Current state |
Current status of the interface: up or down. |
MTU |
MTU value. |
Type |
Interface type: · BROADCAST—Broadcast link interface. · LOOP—Loopback interface. · REGISTER—Register interface. · MTUNNEL—Multicast tunnel interface. This field is empty if the interface is Null 0. |
Protocol |
Protocol running on the interface: PIM-DM, PIM-SM, IGMP, PROXY, or MD. |
PIM protocol state |
Whether PIM is enabled: Enabled or Disabled. |
Address list |
Interface address list. |
Local address |
Local IP address. |
Remote address |
Remote end IP address. This field is displayed only when the interface is vlink type. |
Reference |
Number of times that the address has been referenced. |
State |
Status of the interface address: NORMAL or DEL. |
Flags |
Interface attribute. This field displays one flag or the sum of multiple flags. For example, value 0x2 means that the interface has only one flag 0x2, and value 0x14 means that the interface has flags 0x4 and 0x10. The following flags are available for an interface: · 0x0—The interface is in normal status. · 0x1—The interface address is being deleted. · 0x2—The interface address is an IPv4 primary address. · 0x4—The interface is a PMSI tunnel interface for RSVP-TE-based MVPN. · 0x8—The interface is a multicast tunnel interface for a Layer 3 VXLAN. · 0x10—The interface is a virtual multicast incoming interface for tunneled traffic. |
display multicast boundary
Use display multicast boundary to display multicast boundary information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays multicast boundary information on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.0.0 to 239.255.255.255. If you do not specify a multicast group, this command displays multicast boundary information for all multicast groups.
mask-length: Specifies an address mask length in the range of 4 to 32. The default is 32.
mask: Specifies an address mask. The default is 255.255.255.255.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays multicast boundary information for all interfaces.
# Display information about all multicast boundaries on the public network.
<Sysname> display multicast boundary
Boundary Interface
224.1.1.0/24 Vlan1
239.2.2.0/24 Vlan2
Boundary |
Multicast group associated with the multicast boundary. |
Boundary interface associated with the multicast boundary. |
multicast boundary
Use display multicast fast-forwarding cache to display multicast fast forwarding entries.
display multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache [ source-address | group-address ] * [ slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays multicast fast forwarding entries on the public network.
source-address: Specifies a multicast source address.
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays multicast fast forwarding entries for the master device.
# Display multicast fast forwarding entries on the public network.
<Sysname> display multicast fast-forwarding cache
Total 1 entries, 1 matched
(60.1.1.200, 225.0.0.2)
Status : Enabled
Source port: 2001 Destination port: 2002
Protocol : 2 Flag : 0x2
Incoming interface: Vlan-interface1
List of 1 outgoing interfaces:
Vlan-interface2
Status: Enabled Flag: 0x14
Total 1 entries, 1 matched |
Total number of (S, G) entries in the multicast fast forwarding table, and the total number of matching (S, G) entries. |
(60.1.1.200, 225.0.0.2) |
(S, G) entry. |
Protocol |
Protocol number. |
Flag of the (S, G) entry or the outgoing interface in the entry. This field displays one flag or the sum of multiple flags. For example, value 0x2 means that the entry has only one flag 0x2, and value 0x14 means that the interface has flags 0x4 and 0x10. The following flags are available for an entry: · 0x1—The entry is created because of packets passed through between cards. · 0x2—The entry is added by multicast forwarding. The following flags are available for an outgoing interface: · 0x1—The interface is added to the entry because of packets passed through between cards. · 0x2—The interface is added to an existing entry. · 0x4—The MAC address of the interface is needed for fast forwarding. · 0x8—The interface is an outgoing interface associated with the incoming VLAN or super VLAN interface. · 0x10—The interface is associated with the entry. · 0x20—The interface is to be deleted. |
Status |
Status of the (S, G) entry or the outgoing interface: · Enabled—Available. · Disabled—Unavailable. |
Incoming interface |
Incoming interface of the (S, G) entry. |
List of 1 outgoing interfaces |
Outgoing interface list of the (S, G) entry. |
reset multicast fast-forwarding cache all
Use display multicast flow-policy info to display link selection information for IPv4 multicast flow policies.
display multicast [ vpn-instance vpn-instance-name ] flow-policy info [ interface interface-type interface-number | source source-address | group group-address | policy { default | name policy-name } ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays link selection information for IPv4 multicast flow policies on the public network.
interface interface-type interface-number: Displays link selection information for IPv4 multicast flow policies on an interface.
source source-address: Displays link selection information for IPv4 multicast flow policies for a multicast source.
group group-address: Displays link selection information for IPv4 multicast flow policies for a multicast group. The value range for the group-address argument is 224.0.0.0 to 239.255.255.255.
policy default: Specifies the default IPv4 multicast flow policy.
policy name policy-name: Specifies a custom IPv4 multicast flow policy by its name, a case-insensitive string of 1 to 63 characters.
If you do not specify the source, group, or policy parameter, this command displays link selection information for all IPv4 multicast flow policies.
# Display link selection information for all IPv4 multicast flow policies on the public network.
<Sysname> display multicast flow-policy info
Total 2 interfaces, 2 matched
Vlan-interface100:
Available bandwidth: 100M
Used bandwidth: 30M (30%)
Total 4 entries, 4 matched
Flow bandwidth: 5M
Total 2 entries, 2 matched
(1.1.1.1, 225.0.0.1)
Flow policy: video1
(1.1.1.1, 225.0.0.2)
Default flow policy
Flow bandwidth: 10M
(1.1.1.1, 225.0.0.11)
Flow policy: audio1
(1.1.1.1, 225.0.0.12)
Flow policy: video2
Vlan-interface200:
Used bandwidth: 10M (10%)
Flow bandwidth: 10M
(1.1.1.1, 226.0.0.1)
Flow policy: video3
Total 2 interfaces, 2 matched |
Total number of interfaces enabled with PIM and number of matching interfaces. |
Available bandwidth |
Total available multicast bandwidth on the interface. |
Used bandwidth |
Used multicast bandwidth in percentage on the interface. |
Total 4 entries, 4 matched |
Total number of (S, G) entries that have selected the interface as an upstream interface and number of matching (S, G) entries. |
Flow bandwidth |
Estimated bandwidth configured in an IPv4 multicast flow policy. |
Total number of (S, G) entries for the IPv4 multicast flow policy and number of matching (S, G) entries. |
(1.1.1.1, 225.0.0.1) |
(S, G) entry for the IPv4 multicast flow. |
Flow policy |
Name of the custom IPv4 multicast flow policy. |
Default flow policy |
Name of the default IPv4 multicast flow policy. |
flow-ucmp unicast reserved-bandwidth
Use display multicast forwarding df-info to display DF information.
display multicast [ vpn-instance vpn-instance-name ] forwarding df-info [ rp-address ] [ verbose ] [ slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DF information on the public network.
rp-address: Specifies a BIDIR-PIM RP by its IP address.
verbose: Specifies detailed information. If you do not specify this keyword, the command displays brief information about DFs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays DF information for the master device.
In a BIDIR-PIM domain, only the DF on each subnet can forward multicast data destined for a multicast group toward the RP of the group. For more information about the DF, see IP Multicast Configuration Guide.
# Display brief information about DFs on the public network.
<Sysname> display multicast forwarding df-info
Total 1 RPs, 1 matched
00001. RP address: 7.11.0.2
Flags: 0x0
Uptime: 04:14:40
RPF interface: Vlan-interface1
List of 1 DF interfaces:
1: Vlan-interface2
# Display detailed information about DFs on the public network.
<Sysname> display multicast forwarding df-info verbose
MID: 2, Flags: 0x0
Uptime: 03:37:22
Product information: 0x7a2f762f, 0x718fee9f, 0x4b82f137, 0x71c32184
Product information: 0xa567d6fc, 0xadeb03e3
Tunnel information: 0xdfb107d4, 0x7aa5d510
1: Vlan-interface2
Product information: 0xa986152b, 0xb74a9a2f
Tunnel information: 0x297ca208, 0x76985b89
Table 5 Command output
Total 1 RPs, 1 matched |
Total number of RPs, and the total number of matching RPs. |
00001 |
Sequence number of the entry to which the RP is designated. |
RP address |
IP address of the RP. |
MID |
ID of the entry to which the RP is designated. Each entry to which the RP is designated has a unique MID. |
Flags |
Entry flag. This field displays one flag or the sum of multiple flags. For example, value 0x0 means that the entry has only one flag 0x0. The following flags are available for an entry: · 0x0—The entry is in correct state. · 0x4—The entry fails to update. · 0x8—DF interface information fails to update for the entry. · 0x40—The entry is to be deleted. · 0x100—The entry is being deleted. · 0x200—The entry is in GR state. |
Uptime |
Length of time for which the entry has been up. |
RPF interface |
RPF interface to the RP. |
List of 1 DF interfaces |
DF interface list. |
Use display multicast forwarding event to display statistics of multicast forwarding events.
display multicast [ vpn-instance vpn-instance-name ] forwarding event [ slot slot-number]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays statistics of the multicast forwarding events on the public network.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays statistics of multicast forwarding events for the master device.
# Display statistics of multicast forwarding events on the public network.
<Sysname> display multicast forwarding event
Total active events sent: 0
Total inactive events sent: 0
Total NoCache events sent: 2
Total NoCache events dropped: 0
Total WrongIF events sent: 0
Total WrongIF events dropped: 0
Total SPT switch events sent: 0
NoCache rate limit: 1024 packets/s
WrongIF rate limit: 1 packets/10s
Total timer of register suppress timeout: 0
Total active events sent |
Number of times that entry-active events have been sent. |
Total inactive events sent |
Number of times that entry-inactive events have been sent. |
Total NoCache events sent |
Number of times that NoCache events have been sent. |
Total NoCache events dropped |
Number of times that NoCache events have been dropped. |
Total WrongIF events sent |
Number of times that WrongIF events have been sent. |
Total WrongIF event dropped |
Number of times that WrongIF events have been dropped. |
Total SPT switch events sent |
Number of times that SPT-switch events have been sent. |
NoCache rate limit |
Rate limit for sending NoCache events, in pps. |
WrongIF rate limit |
Rate limit for sending WrongIF events, in packets per 10 seconds. |
Total timer of register suppress timeout |
Number of times that the registration suppression has timed out in total. |
Use display multicast forwarding-table to display multicast forwarding entries.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays multicast forwarding entries on the public network.
group-address: Specifies a multicast group address in the range of 224.0.0.0 to 239.255.255.255.
mask-length: Specifies an address mask length. The default value is 32. For a multicast group address, the value range for this argument is 4 to 32. For a multicast source address, the value range for this argument is 0 to 32.
mask: Specifies an address mask. The default value is 255.255.255.255.
incoming-interface: Specifies the multicast forwarding entries that contain the specified incoming interface.
interface-type interface-number: Specifies an incoming interface by its type and number.
outgoing-interface: Specifies the multicast forwarding entries that contain the specified outgoing interface.
exclude: Specifies the multicast forwarding entries that do not contain the specified interface in the outgoing interface list.
include: Specifies the multicast forwarding entries that contain the specified interface in the outgoing interface list.
match: Specifies the forwarding entries that contain only the specified interface in the outgoing interface list.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays multicast forwarding entries for the master device.
statistics: Displays statistics for the multicast forwarding table.
# Display multicast forwarding entries on the public network.
<Sysname> display multicast forwarding-table
00001. (172.168.0.2, 227.0.0.1)
Flags: 0x0
Incoming interface: Vlan-interface10
Incoming sub-VLAN: VLAN 11
Outgoing sub-VLAN: VLAN 12
VLAN 13
Backup incoming interface: Vlan-interface11
1: Vlan-interface20
Sub-VLAN: VLAN 21
VLAN 22
Matched 19648 packets(20512512 bytes), Wrong If 0 packet
Table 7 Command output
Total number of (S, G) entries, and the total number of matching (S, G) entries. |
00001 |
Sequence number of the (S, G) entry. |
(172.168.0.2,227.0.0.1) |
(S, G) entry. |
Flags |
Entry flag. This field displays one flag or the sum of multiple flags. For example, value 0x0 means that the entry has only one flag 0x0. The following entries are available for an entry: · 0x0—The entry is in correct state. · 0x1—The entry is in inactive state. · 0x2—The entry is null. · 0x4—The entry fails to update. · 0x8—Outgoing interface information fails to update for the entry. · 0x10—Data-group information fails to update for the entry. · 0x20—A register outgoing interface is available. · 0x40—The entry is to be deleted. · 0x80—The entry is in registration suppression state. · 0x100—The entry is being deleted. · 0x200—The entry is in GR state. · 0x400—The entry has the VLAN interface of the super VLAN. · 0x800—The entry has the associated ARP entry for the multicast source address. · 0x400000—The entry is created by the IGMP proxy. · 0x2000000—The entry is a BIDIR-PIM forwarding entry. |
Uptime |
Length of time for which the (S, G) entry has been up. |
Timeout in |
Length of time in which the (S, G) entry will expire. |
Backup incoming interface |
Backup incoming interface of the (S, G) entry. If the primary incoming interface of the (S, G) entry fails, multicast data arrived at the backup incoming interface will be forwarded to receivers. |
Incoming sub-VLAN |
Incoming sub-VLAN of the super VLAN when the incoming interface of the (S, G) entry is the VLAN interface of this super VLAN. |
Outgoing sub-VLAN |
Outgoing sub-VLAN of the super VLAN when the incoming interface of the (S, G) entry is the VLAN interface of this super VLAN. |
Sub-VLAN |
Outgoing sub-VLAN of the super VLAN when the outgoing interface of the (S, G) entry is the VLAN interface of this super VLAN. |
Matched 19648 packets(20512512 bytes), Wrong If 0 packet |
Number of packets (bytes) that match the (S, G) entry, and number of packets with incoming interface errors. The numbers are displayed as 0 if an outgoing interface of the (S, G) entry is on the specified slot. |
Forwarded 19648 packets(20512512 bytes) |
Number of packets (bytes) that have been forwarded. The numbers are displayed as 0 if an outgoing interface of the (S, G) entry is on the specified slot. |
Use display multicast forwarding-table df-list to display information about the DF list in multicast forwarding entries.
display multicast [ vpn-instance vpn-instance-name ] forwarding-table df-list [ group-address ] [ verbose ] [ slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about the DF list in multicast forwarding entries on the public network.
verbose: Specifies detailed information about the DF list in multicast forwarding entries. If you do not specify this keyword, the command displays brief information about the DF list in multicast forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about the DF list in multicast forwarding entries for the master device.
# Display brief information about the DF list in multicast forwarding entries on the public network.
<Sysname> display multicast forwarding-table df-list
00001. (0.0.0.0, 225.0.0.1)
1: Vlan-interface1
# Display detailed information about the DF list in multicast forwarding entries on the public network.
<Sysname> display multicast forwarding-table df-list verbose
1: Vlan-interface1
Product information: 0x347849f6, 0x14bd6837
Tunnel information: 0xc4857986, 0x128a9c8f
Table 8 Command output
Total number of forwarding entries, and the total number of matching entries. |
00001 |
Sequence number of the entry. |
(0.0.0.0, 225.0.0.1) |
(*, G) entry. |
Use display multicast replication-share info to display information about multicast replication resources.
display multicast replication-share info [ outgoing-interface { exclude | include | match } interface-type interface-number | replicate replicate-index ] * [ slot slot-number ]
outgoing-interface: Specifies the multicast replication resources that contain the specified outgoing interface.
exclude: Specifies the multicast replication resources that do not contain the specified interface in the outgoing interface list.
include: Specifies the multicast replication resources that contain the specified interface in the outgoing interface list.
match: Specifies the multicast replication resources that contain only the specified interface in the outgoing interface list.
interface-type interface-number: Specifies an outgoing interface by its type and number.
replicate replicate-index: Specifies a multicast replication resource by its index in the range of 0x1 to 0xFFFFFFFF.
slot slot-number: Specifies an IRF member device by its member ID. If the specified member device is the device where the output interface of multicast traffic resides, this command displays 0 resources. If you do not specify a member device, this command displays multicast replication resources for the master device.
# Display all multicast replication resources.
<Sysname> display multicast replication-share info
Total 5 entries, 5 matched
00001. Replicate index: 0x3
Drv resource index: 0x11112222, 0x33330001
Create time: 00:21:20
Flags: 0x1
Match key: 120
Reference counts: 2
1: Twenty-FiveGigE1/0/2
00002. Replicate index: 0x5
Drv resource index: 0x11112222, 0x33330002
Create time: 00:12:30
Flags: 0x3
Match key: 820
Reference counts: 3
Outgoing slots (2 in total): 1-2
List of 2 outgoing interfaces:
1: Vlan-interface10
List of 1 outgoing ports:
1: Twenty-FiveGigE1/0/1
2: Vlan-interface20
List of 2 outgoing ports:
1: GigabitEthernet2/0/1
2: GigabitEthernet2/0/2
00003.Replicate index: 0xb
Drv resource index: 0x11112222, 0x33330003
Create time: 00:11:30
Flags: 0x0
Match key: 2020
Reference counts: 1
Outgoing slots (1 in total): 2
Incoming interface: Vlan-interface100
Incoming sub-VLAN: VLAN 101
1: Vlan-interface100
Sub-VLAN: VLAN 101
1: GigabitEthernet2/0/3
Sub-VLAN: VLAN 102
1: GigabitEthernet2/0/4
00004.Replicate index: 0x20
Drv resource index: 0x11112222, 0x33330004
Create time: 00:10:30
Flags: 0x4
Match key: 2510
Reference counts: 1
Outgoing slots (1 in total): 1
Incoming interface: Vsi-interface1
1: Vsi-interface1
VSI instance: a
1: Twenty-FiveGigE1/0/3
VSI instance: b
1: Twenty-FiveGigE1/0/4
2: Vsi-interface2
VSI instance: c
1: Twenty-FiveGigE1/0/5
2: Twenty-FiveGigE1/0/6
00005.Replicate index: 0x35
Drv resource index: 0x11112222, 0x33330005
Create time: 00:09:20
Flags: 0x3
Match key: 33757175
Reference counts: 1
1: MTunnel0 (VPN: a)
Data-group: 225.2.2.1
Table 9 Command output
Total 5 entries, 5 matched |
Total number of replication entries, and the total number of matching entries. |
00001 |
Sequence number of the multicast replication resource entry. |
Replicate index |
Index of the multicast replication resource. |
Drv resource index |
Index of the hardware resource. |
Create time |
Time when the multicast replication entry was created. |
Flags |
State of the multicast replication resource entry: · 0x0—The entry is normal. · 0x1—Failed to create a multicast replication resource. · 0x2—Failed to bind a multicast replication resource. · 0x4—Failed to edit a multicast replication resource. |
Match key |
Key value used to fast match multicast replication resources that can be reused. |
Reference counts |
Number of entries that are associated with the multicast replication resource. |
Incoming interface of the entry. |
Outgoing interface list of the entry. |
Incoming sub-VLAN |
Incoming sub-VLAN of the super VLAN when the incoming interface of the entry is the VLAN interface of this super VLAN. |
Sub-VLAN |
Outgoing sub-VLAN of the super VLAN when the outgoing interface of the entry is the VLAN interface of this super VLAN. |
Outgoing slots (0 in total) |
Member IDs and total number of the member devices that have outgoing interfaces, except for the specified member device or the master device when no member device is specified. |
List of 1 outgoing ports |
Outgoing interfaces in a VLAN or VSI: · When Layer 2 multicast is configured, this field indicates the member port or router port in the VLAN or VSI. · When Layer 2 multicast is not configured, this field indicates all ports in the VLAN or VSI. |
MTunnel0 (VPN: a) |
Multicast VPN tunnel interface and the VPN instance name. |
Data-group |
Data group in the multicast VPN. |
Incoming VSI instance |
Incoming VSI instance when the incoming interface of the entry is MVXLAN-UPE type. |
Use display multicast routing-table to display multicast routing entries.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays multicast routing entries on the public network.
incoming-interface: Specifies the multicast routing entries that contain the specified incoming interface.
outgoing-interface: Specifies the multicast routing entries that contain the specified outgoing interface.
exclude: Specifies the multicast routing entries that do not contain the specified interface in the outgoing interface list.
include: Specifies the multicast routing entries that contain the specified interface in the outgoing interface list.
match: Specifies the multicast routing entries that contain only the specified interface in the outgoing interface list.
Multicast routing entries are the basis of multicast forwarding. You can use this command to view the establishment state of (S, G) entries.
# Display multicast routing entries on the public network.
<Sysname> display multicast routing-table
Total 1 entries
Uptime: 00:00:28
Upstream Interface: Vlan-interface1
Backup Upstream Interface: Vlan-interface4
List of 2 downstream interfaces
1: Vlan-interface2
2: Vlan-interface3
Table 10 Command output
Total 1 entries |
Total number of (S, G) entries. |
00001 |
(172.168.0.2, 227.0.0.1) |
(S, G) entry. |
Uptime |
Upstream Interface |
Upstream interface at which (S, G) packets should arrive. |
Backup Upstream Interface |
List of 2 downstream interfaces |
List of downstream interfaces that need to forward (S, G) packets. |
Use display multicast routing-table static to display static multicast routing entries.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays static multicast routing entries on the public network.
mask-length: Specifies an address mask length in the range of 0 to 32.
This command displays only valid static multicast routing entries.
# Display static multicast routing entries on the public network.
<Sysname> display multicast routing-table static
Destinations: 3 Routes: 4
Destination/Mask Pre RPF neighbor Interface
1.1.0.0/16 10 7.12.0.1 Vlan12
7.11.0.1 Vlan11
2.2.2.0/24 20 7.11.0.1 Vlan11
3.3.3.3/32 50 7.12.0.1 Vlan12
Table 11 Command output
Destinations |
Number of the multicast destination addresses. |
Routes |
Number of routes. |
Destination/Mask |
Destination address and its mask length. |
Pre |
Route preference. |
RPF neighbor |
IP address of the RPF neighbor to the reachable destination. |
Outgoing interface to the reachable destination. |
display multicast rpf-info
Use display multicast rpf-info to display RPF information for a multicast source.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays RPF information for a multicast source on the public network.
# Display RPF information for multicast source 192.168.1.55 on the public network.
<Sysname> display multicast rpf-info 192.168.1.55
RPF information about source 192.168.1.55:
RPF interface:Vlan-interface1, RPF neighbor: 10.1.1.1
Backup RPF interface: Vlan-interface2, backup RPF neighbor: 2.2.2.2
Referenced route/mask: 192.168.1.0/24
Referenced route type: igp
Load splitting rule: disable
Source AS: 0
C-multicast route target: 0x0000000000000000
Table 12 Command output
RPF neighbor |
IP address of the RPF neighbor. |
Referenced route/mask |
Referenced route and its mask length. |
Referenced route type |
Type of the referenced route: · igp—IGP unicast route. · egp—EGP unicast route. · unicast (direct)—Directly connected unicast route. · unicast—Other unicast routes, such as static unicast route. · multicast static—Static multicast route. · mbgp—MBGP route. |
Route selection rule |
Rule for RPF route selection: · Route preference. · Longest prefix match. |
Load splitting rule |
Status of the load splitting rule: enable or disable. |
Source AS |
AS number of the source-side PE. |
C-multicast route target |
Route target attribute value of the C-multicast route. |
flow-policy (MRIB view)
Use flow-policy to create an IPv4 multicast flow policy and enter its view, or enter the view of an existing IPv4 multicast flow policy.
Use undo flow-policy to delete IPv4 multicast flow policies.
flow-policy { default | name policy-name }
undo flow-policy { all | default | name policy-name }
No IPv4 multicast flow policies exist.
MRIB view
all: Deletes all IPv4 multicast flow policies.
Operating mechanism
The device selects the link with the smallest bandwidth usage as the optimal link if the following conditions exist:
· ECMP routes between the device and an upstream device.
· The multicast load-splitting mode is flow-ucmp.
If two links have the same bandwidth usage, the link with the higher next-hop IP address is selected.
The bandwidth usage is calculated according to the following formula: Bandwidth usage = (Used bandwidth+Estimated bandwidth)/(Total interface bandwidth x (1–Unicast reserved bandwidth)).
· The estimated bandwidth is configured by the bandwidth command in IPv4 multicast flow policy view.
· The total interface bandwidth is configured by the bandwidth command in interface view.
· The unicast reserved bandwidth is configured by the flow-ucmp unicast reserve-bandwidth or multicast flow-ucmp unicast reserve-bandwidth command.
For this command to take effect, you must configure the multicast load-splitting mode as flow-ucmp.
Adding, deleting, or modifying an IPv4 multicast flow policy does not affect the link selection results of existing multicast flows and affects link selection for only new multicast flows. Before configuring the multicast load-splitting mode as flow-ucmp, you must plan the configuration of an IPv4 multicast flow policy and the unicast reserved bandwidth configuration.
The change of link bandwidth and the change in the number of ECMP routes do not affect the route selection of existing multicast flows.
This feature does not affect multicast source-side link selection, link selection in PIM-DM, RPT link selection in PIM-SM, or local RP link selection.
If both IPv4 and IPv6 multicast flows exist in the network, increase the unicast reserved bandwidth as needed to avoid congestion.
# Create an IPv4 multicast flow policy named abc and enter its view.
# Create the default IPv4 multicast flow policy and enter its view.
[Sysname-mrib] flow-policy default
acl (IPv4 multicast flow policy)
bandwidth
Use flow-ucmp unicast reserve-bandwidth to set the global IPv4 unicast reserved bandwidth percentage.
Use undo flow-ucmp unicast reserve-bandwidth to restore the default.
flow-ucmp unicast reserve-bandwidth percentage
The global IPv4 unicast reserved bandwidth percentage is not set.
MRIB view
percentage: Specifies the global IPv4 unicast reserved bandwidth percentage in the range of 1 to 100.
Execute this command when IPv4 unicast traffic and IPv4 multicast traffic coexist in the network. The available bandwidth for multicast traffic is calculated based on the total interface bandwidth and the configured IPv4 unicast reserved bandwidth percentage. For example, if the total interface bandwidth is 100 kbps and the unicast reserved bandwidth percentage is 20% (20 kbps), the available bandwidth for multicast traffic is 80 kbps.
The flow-ucmp unicast reserve-bandwidth command takes effect on all interfaces, and the multicast flow-ucmp unicast reserve-bandwidth command takes effect only on the current interface. If you execute both commands, the latter has higher priority.
Example
# Set the global IPv4 unicast reserved bandwidth percentage to 50%.
[Sysname-mrib] flow-ucmp unicast reserve-bandwidth 50
ip rpf-route-static
Use ip rpf-route-static to configure a static multicast route.
Use undo ip rpf-route-static to delete a static multicast route.
undo ip rpf-route-static [ vpn-instance vpn-instance-name ] source-address { mask-length | mask } { rpf-nbr-address | interface-type interface-number }
No static multicast routes exist.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command configures a static multicast route on the public network.
rpf-nbr-address: Specifies an RPF neighbor by its IP address.
interface-type interface-number: Specifies an interface by its type and number. The interface connects the RPF neighbor.
preference: Sets a route preference in the range of 1 to 255. The default value is 1.
If the interface connected to an RPF neighbor is a point-to-point interface, you must specify the interface by its type and number.
If the interface connected to an RPF neighbor is not a point-to-point interface, you must specify the interface by its IP address. This type of interfaces includes Layer 3 Ethernet, Layer 3 aggregate, Loopback, and VLAN interfaces.
The configured static multicast route might not take effect when one of the following conditions exists:
· The outgoing interface iteration fails.
· The specified interface is not in the public network or the same VPN instance as the current interface.
· The specified interface is not a point-to-point interface.
· The specified interface is down.
If multiple static multicast routes within the same multicast source address range are available, only the one with the highest route preference can become active. You can use the display multicast routing-table static command to verify that the configured static multicast route has taken effect.
The undo ip rpf-route-static command deletes the specified static multicast route, but the delete ip rpf-route-static command deletes all static multicast routes.
# Configure a static multicast route to multicast source 10.1.1.0/24 and specify the interface with IP address 192.168.1.23 as the RPF neighbor on the public network.
[Sysname] ip rpf-route-static 10.1.1.0 24 192.168.1.23
load-splitting (MRIB view)
Use load-splitting to enable multicast load splitting.
Use undo load-splitting to restore the default.
load-splitting { balance-ecmp | balance-ucmp | ecmp | flow-ucmp | source | source-group | ucmp }
undo load-splitting
Multicast load splitting is disabled.
MRIB view
balance-ecmp: Enables multicast load balancing based on ECMP paths. Multicast traffic is evenly distributed among ECMP paths.
balance-ucmp: Enables multicast load balancing based on links. Multicast traffic is evenly distributed among links.
ecmp: Enables multicast load splitting based on ECMP paths.
flow-ucmp: Enables multicast load splitting based on the bandwidth usage of multicast flows.
source: Enables multicast load splitting based on multicast source.
source-group: Enables multicast load splitting based on multicast source and group.
ucmp: Enables multicast load splitting based on links.
This command does not take effect on BIDIR-PIM.
To use the flow-ucmp multicast load-splitting mode, you must first configure an IPv4 multicast flow policy and the IPv4 unicast reserved bandwidth percentage. Adding, deleting, or modifying an IPv4 multicast flow policy does not affect the link selection results of existing multicast flows and affects link selection for only new multicast flows.
On a network with ECMP routes, specify the balance-ecmp, ecmp, flow-ucmp, source, or source-group keyword. On a network with UCMP routes, specify the balance-ucmp or ucmp keyword.
· If you specify the ecmp keyword, adding or deleting ECMP routes severely affects multicast forwarding.
· If you specify the source or source-group keyword, adding or deleting ECMP routes slightly affects multicast forwarding. Specify either of the keywords on a network with unstable equal cost links.
· If you specify the balance-ecmp or balance-ucmp keyword, the device uses a polling mechanism for multicast load balancing. ECMP or UCMP-based multicast load balancing provides better stability and balance than ECMP or UCMP-based multicast load sharing.
· If you specify the flow-ucmp keyword, adding or deleting ECMP routes slightly affects multicast forwarding. Specify this keyword on a network with unstable equal-cost links. It provides better stability and balance than the ucmp multicast load-sharing mode.
# Enable multicast load splitting based on multicast source on the public network.
[Sysname-mrib] load-splitting source
longest-match (MRIB view)
Use longest-match to specify the longest prefix match principle for RPF route.
Use undo longest-match to restore the default.
longest-match
undo longest-match
Route preference is used for RPF route selection. The route with the highest preference is used as the RPF route.
MRIB view
This command enables the device to use the matching route with the longest prefix as the RPF route.
# Specify the longest prefix match principle for RPF route selection on the public network.
[Sysname-mrib] multicast longest-match
mtrace-service port
Use mtrace-service port to specify the UDP port number used by mtrace.
Use undo mtrace-service port to restore the default.
mtrace-service port number
Mtrace uses UDP port number 10240.
number: Specifies a UDP port number to be used by mtrace, in the range of 1024 to 49151.
Execute this command only when mtrace2 is used.
For successful mtrace, do not specify a UDP port number used by other modules.
You must specify the same UDP port number on all devices on the traced path. Additionally, the specified UDP port number must be the same as that specified in the mtrace v2 command.
# Specify 12345 as the UDP port number used by mtrace.
<Sysname> system-interview
[sysname] mtrace-service port 12345
mtrace v2
mtrace v1
Use mtrace v1 to trace a multicast path through mtrace1.
mtrace v1 [ vpn-instance vpn-instance-name ] { source-address | group-address } * [ destination address ] [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command traces a multicast path on the public network.
source-address: Specifies a multicast source by its IP address.
group-address: Specifies a multicast group by its IP address, in the range of 224.0.1.0 to 239.255.255.255.
destination address: Specifies the destination address of mtrace. The default destination address is 224.0.0.2.
verbose: Displays detailed information about mtrace. If you do not specify this keyword, the command displays brief information about mtrace.
To perform a non-group-specific mtrace, specify a multicast source and a destination. The mtrace starts from the destination and ends at the device directly connected to the multicast source.
To perform a non-source-specific mtrace, specify a multicast group and a destination. The mtrace starts from the destination and ends at the RP associated with the multicast group.
To perform a source-and-group-specific mtrace, specify both a multicast source and a multicast group. If you also specify a destination, the mtrace starts from the destination and ends at the device directly connected to the multicast source. If you do not specify a destination, the mtrace starts from the upstream device of the client and ends at the device directly connected to the multicast source.
An mtrace process stops if the number of traced hops reaches 255.
If the client does not receive a Reply message within 10 seconds, the client initiates a hop-by-hop mtrace to determine which device on the path encountered an error. It sends a Query message with the hops field set to 1 and waits for a Reply message. If it does not receive a Reply message within 10 seconds, the client determines that this hop encountered an error. If the client receives a Reply message within 10 seconds, it sends a Query message with the hops field value increased by 1 and waits for a Reply message. This process continues until the client does not receive a Reply message within the waiting time any more.
# Use mtrace1 to trace the path along which multicast data of group 225.2.1.1 travels from source 10.11.5.24 to destination 192.168.2.2 and display brief mtrace information.
<Sysname> mtrace v1 10.11.5.24 225.2.1.1 destination 192.168.2.2
Mtrace from 10.11.5.24 to 192.168.2.2 via group 225.2.1.1, 255 hops at most, press
CTRL_C to break.
Querying full reverse path...
Hop Incoming address Outgoing address Protocol Time Fwd code
0 5.1.1.2 192.168.2.1 PIM 50 s NO_ERROR
-1 4.1.1.2 5.1.1.1 PIM 40 s NO_ERROR
-2 3.1.1.2 4.1.1.1 PIM 60 s NO_ERROR
-3 2.1.1.2 3.1.1.1 PIM 55 s NO_ERROR
-4 10.11.5.1 2.1.1.1 PIM 30 s NO_ERROR
Table 13 Command output
Hop |
Number of the hop. 0 represents the last hop, -1 represents the hop before the last hop, and so on. |
Incoming address |
Incoming interface of the multicast data. |
Outgoing address |
Outgoing interface of the multicast data. |
Protocol |
Multicast routing protocol used between this device and the previous-hop device: · PIM. · PIM(STATIC)—PIM using a static multicast route. · PIM(MBGP)—PIM using an MBGP route. · PIM(ASSERT)—PIM in a state created by Assert processing. |
Time |
Length of time used to transmit an mtrace message between this device and the previous-hop device, in seconds. |
Fwd code |
Forwarding code or error code: · NO_ERROR—No error. · WRONG_IF—The interface on which the mtrace message arrives is not in the outgoing interface list of the multicast data. · PRUNE_SENT—This device has sent a prune message to the upstream device. · PRUNE_RCVD—This device has received a prune message from the downstream device. · SCOPED—A multicast border is configured on the incoming interface or outgoing interface of the multicast data. · NO_ROUTE—This device does not have any route for the source or the RP. · WRONG_LAST_HOP—This device is not the proper last-hop device. · REACHED_RP—This device is the RP for the (*, G) multicast data. · RPF_IF—The mtrace message arrived on the expected RPF interface for the multicast data. · NO_MULTICAST—The mtrace message arrived on an interface that is not enabled with IP multicast. · NO_SPACE—No space is available for inserting a response data block in the packet. |
# Use mtrace1 to trace the path along which multicast data of group 225.2.1.1 travels from source 10.11.5.24 to destination 192.168.2.2 and display detailed mtrace information.
<Sysname> mtrace v1 10.11.5.24 225.2.1.1 destination 192.168.2.2 verbose
Mtrace from 10.11.5.24 to 192.168.2.2 via group 225.2.1.1, 255 hops at most, use query
ID 12345, client port 50001, press CTRL_C to break.
Querying full reverse path..........
Switching to hop-by-hop mode, Current hops: 2
0: Incoming interface address: 4.1.1.2
Outgoing interface address: 5.1.1.1
Upstream router address: 4.1.1.1
Input multicast packets: 111
Output multicast packets: 111
Forwarded packets for the (S, G) pair: 22
Multicast protocol in use: PIM
Multicast TTL threshold: 1
Forwarding code: NO_ERROR
Time used (s): 50
-1: Incoming interface address: 3.1.1.2
Outgoing interface address: 4.1.1.1
Upstream router address: 3.1.1.1
Forwarded Packets for the (S, G) pair: 22
Time used (s): 50
Table 14 Command output
n |
Incoming interface address |
Outgoing interface address |
Upstream router address |
IP address of the upstream device. |
Input multicast packets |
Statistics for packets received on the incoming interface of the multicast data. |
Output multicast packets |
Statistics for packets forwarded through the outgoing interface of the multicast data. |
Forwarded packets for the (S, G) pair |
Statistics for forwarded (S, G) packets. |
Multicast protocol in use |
Multicast routing protocol used on the traced path: · PIM. · PIM(STATIC)—PIM using a static multicast route. · PIM(MBGP)—PIM using an MBGP route. · PIM(ASSERT)—PIM in a state created by Assert processing. |
Multicast TTL threshold |
Maximum number of hops to be traced on the interface. |
Forwarding code |
Time used (s) |
Length of time for transmitting the mtrace message from the previous-hop device to this device. |
mtrace v2
Use mtrace v2 to trace a multicast path through mtrace2.
mtrace v2 [ vpn-instance vpn-instance-name ] { source-address | group-address } * [ destination address | port number | wait-time time | max-hop count ] * [ verbose ]
port number: Specifies a UDP port number for mtrace2, in the range of 1024 to 49151. The default value is 10240.
wait-time time: Specifies the length of time that the client waits for a Reply message. The value range for the time argument is 1 to 65535 seconds and the default value is 10 seconds. If the client does not receive a Reply message within the waiting time, the client initiates a hop-by-hop mtrace.
max-hop count: Specifies the maximum number of the hops to be traced. The value range for the count argument is 1 to 255 and the default value is 255. If the maximum number of hops is reached on a device, the device directly sends an mtrace2 Reply message to the client and the mtrace is terminated.
To perform a non-group-specific mtrace, specify a multicast source and a destination. The mtrace starts from the destination and ends with the device directly connected to the multicast source.
An mtrace process stops if the maximum number of the hops to be traced is reached.
If the client does not receive a Reply message within the waiting time, the client initiates a hop-by-hop mtrace to determine which device on the path encountered an error. It sends a Query message with the hops field set to 1 and waits for a Reply message. If the client receives a Reply message within the waiting time, it sends a Query message with the hops field value increased by 1 and waits for a Reply message. This process continues until the client does not receive a Reply message within the waiting time any more.
# Use mtrace2 to trace the path along which multicast data of group 225.2.1.1 travels from source 10.11.5.24 to destination 192.168.2.2 and display brief mtrace information.
<Sysname> mtrace v2 10.11.5.24 225.2.1.1 destination 192.168.2.2
CTRL_C to break.
0 5.1.1.2 192.168.2.1 PIM-SM(OSPF) 50 s NO_ERROR
-1 4.1.1.2 5.1.1.1 PIM-SM(OSPF) 40 s NO_ERROR
-2 3.1.1.2 4.1.1.1 PIM-SM(OSPF) 60 s NO_ERROR
-3 2.1.1.2 3.1.1.1 PIM-SM(OSPF) 55 s NO_ERROR
-4 10.11.5.1 2.1.1.1 PIM-SM(OSPF) 30 s NO_ERROR
Table 15 Command output
Hop |
Incoming address |
Outgoing address |
Protocol |
Multicast routing protocol used between this device and the previous-hop device: · PIM-SM. · PIM-DM. Unicast routing protocol used between this device and the previous-hop device: · LOCAL—Direct route. · STATIC ROUTE—Static route. · RIP. · ISIS. · OSPF. · BGP. |
Time |
Fwd code |
# Use mtrace2 to trace the path along which multicast data of group 225.2.1.1 travels from source 10.11.5.24 to destination 192.168.2.2 and display detailed mtrace information.
<Sysname> mtrace v2 10.11.5.24 225.2.1.1 destination 192.168.2.2 verbose
Mtrace from 10.11.5.24 to 192.168.2.2 via group 225.2.1.1, 255 hops at most, use query ID 12345, client port 50001, press CTRL_C to break.
Multicast protocol in use: PIM-SM
Unicast protocol in use: OSPF
Time used (s): 50
Time used (s): 50
Table 16 Command output
n |
Statistics of packets received on the incoming interface of the multicast data. |
Statistics of packets forwarded through the outgoing interface of the multicast data. |
Statistics of forwarded (S, G) packets. |
Multicast routing protocol running on the incoming interface of the multicast data. |
Unicast protocol in use |
Unicast routing protocol running on the incoming interface of the multicast data. |
Forwarding code |
Time used (s) |
mtrace-service port
multicast boundary
Use multicast boundary to configure a multicast forwarding boundary.
Use undo multicast boundary to delete a multicast forwarding boundary.
undo multicast boundary { group-address { mask-length | mask } | all }
No multicast forwarding boundaries are configured on an interface.
Interface view
all: Specifies all forwarding boundaries configured on the interface.
A multicast forwarding boundary sets the boundary condition for the multicast groups in the specified address range. If the destination address of a multicast packet matches the set boundary condition, the packet is not forwarded.
You can configure an interface as a multicast forwarding boundary for different multicast group ranges by executing this command multiple times on the interface.
You do not need to enable IP multicast routing before you execute this command.
Assume that Set A and Set B are multicast forwarding boundary sets with different address ranges, and B is a subset of A. A takes effect on the interface no matter whether A is configured earlier or later than B.
# Configure VLAN-interface 100 as the forwarding boundary of multicast groups in the range of 239.2.0.0/16.
[Sysname-Vlan-interface100] multicast boundary 239.2.0.0 16
Use multicast cpu-forwarding max-copy-count to set the maximum number of copied multicast packets during software forwarding.
Use undo multicast cpu-forwarding max-copy-count to restore the default.
multicast cpu-forwarding max-copy-count count
The maximum number of copied multicast packets during software forwarding is 5.
count: Specifies the maximum number of copied multicast packets during software forwarding. The value range for this argument is 1 to 32.
Setting a greater limit will cause high CPU usage and degrade forwarding performance. Setting a small limit will cause multicast packets to be dropped.
CAUTION: Perform this task under the guidance of H3C Support. |
# Set the maximum number to 3 for copied multicast packets during software forwarding.
[Sysname] multicast cpu-forwarding max-copy-count 3
Use multicast flow-ucmp unicast reserve-bandwidth to set the IPv4 unicast reserved bandwidth percentage on an interface.
Use undo multicast flow-ucmp unicast reserve-bandwidth to restore the default.
multicast flow-ucmp unicast reserve-bandwidth percentage
The IPv4 unicast reserved bandwidth percentage is not set on an interface.
Interface view
percentage: Specifies the IPv4 unicast reserved bandwidth percentage in the range of 1 to 100.
For this command to take effect, you must use the load-splitting command to configure the multicast load-splitting mode.
Example
# Set the IPv4 unicast reserved bandwidth percentage to 50% on VLAN interface 100.
[Sysname-Vlan-interface100] multicast flow-ucmp unicast reserve-bandwidth 50
Use multicast forwarding supervlan community to enable multicast forwarding between sub-VLANs that are associated with a super VLAN.
Use undo multicast forwarding supervlan community to disable multicast forwarding between sub-VLANs that are associated with a super VLAN.
Multicast forwarding between sub-VLANs that are associated with a super VLAN is disabled.
VLAN interface view
For this command to take effect, you must clear all multicast forwarding entries with the super VLAN interface as the incoming interface after executing this command. To clear multicast forwarding entries, use the reset multicast forwarding-table command.
# Enable multicast forwarding between sub-VLANs that are associated with the super VLAN 2.
[Sysname-Vlan-interface2] multicast forwarding supervlan community
multicast forwarding-table cache-unknown per-entry
Use multicast forwarding-table cache-unknown per-entry to set the maximum number of unknown multicast packets that can be cached for an (S, G) entry.
Use undo multicast forwarding-table cache-unknown per-entry to restore the default.
multicast forwarding-table cache-unknown per-entry per-entry-limit
The device can cache only one unknown multicast packet for an (S, G) entry.
per-entry-limit: Specifies the maximum number of unknown multicast packets that can be cached for an (S, G) entry. The value range for this argument is 0 to 256. If you set the value to 0, the device cannot cache unknown multicast packets.
# Set the maximum number to 20 for unknown multicast packets that can be cached for an (S, G) entry.
[Sysname] multicast forwarding-table cache-unknown per-entry 20
multicast forwarding-table cache-unknown total
Use multicast forwarding-table cache-unknown total to set the maximum number of all unknown multicast packets that can be cached.
Use undo multicast forwarding-table cache-unknown total to restore the default.
multicast forwarding-table cache-unknown total total-limit
The device can cache 1024 unknown multicast packets in total.
total-limit: Specifies the maximum number of all unknown multicast packets that can be cached. The value range for this argument is 0 to 65535. If you set the value to 0, the device cannot cache unknown multicast packets.
As a best practice, set the value in this command to be far greater than the value set in the multicast forwarding-table cache-unknown per-entry command.
# Set the maximum number to 10000 for all unknown multicast packets that can be cached.
[Sysname] multicast forwarding-table cache-unknown total 10000
multicast frr mode
Use multicast frr mode to set the multicast FRR mode.
Use undo multicast frr mode to restore the default.
multicast frr mode [ by-entry | by-iif ]
The multicast FRR mode is by-entry.
by-entry: Specifies the by-entry mode. In this mode, multicast FRR periodically monitors multicast traffic on primary and backup incoming interfaces by entry.
by-iif: Specifies the by-incoming interface mode. In this mode, multicast FRR periodically monitors multicast traffic for different (S, G) entries by pair of primary and backup incoming interfaces.
With multicast FRR enabled, the device will add a primary incoming interface and a backup incoming interface for each (S, G) entry and (*, G) entry during entry creation. It will periodically monitor multicast traffic on the primary and backup incoming interfaces of all entries. If no multicast traffic is detected on the primary incoming interface, the device determines that the primary incoming interface fails and uses the backup incoming interface for multicast forwarding.
As a best practice, set the multicast FRR mode to by-incoming interface if the device has a large number of multicast entries and most entries have the same primary and backup incoming interfaces.
In the current software version, only PIM supports multicast FRR. For more information about PIM FRR, see PIM configuration in IP Multicast Configuration Guide.
# Set the multicast FRR mode to by-incoming interface.
[Sysname] multicast frr mode by-iif
rpf-frr enable
multicast frr monitor cycle
Use multicast frr monitor cycle to set the primary/backup link monitoring interval for multicast FRR.
Use undo multicast frr monitor cycle to restore the default.
multicast frr monitor cycle monitor-time
The primary/backup link monitoring interval is 200 milliseconds.
monitor-time: Specifies the primary/backup link monitoring interval in milliseconds. Valid values are 10, 20, 40, 100, 200, and 500.
Before executing this command, execute the rpf-frr enable command to enable PIM FRR.
With multicast FRR enabled, the device will add a primary incoming interface and a backup incoming interface for each (S, G) entry and (*, G) entry during entry creation. It will periodically monitor multicast traffic on the primary and backup incoming interfaces of all entries. If no multicast traffic is detected on the primary incoming interface, the device determines that the primary incoming interface fails and uses the backup incoming interface for multicast forwarding. You can set the internal at which multicast FRR monitors the states of the primary and backup links.
As a best practice to prevent the CPU from being overloaded, set the monitoring interval to a larger value if there are many multicast entries. As a best practice to prevent the device from determining link failures mistakenly when the multicast traffic rate is small, also set the monitoring interval to a larger value if there are many multicast entries.
# Set the primary/backup link monitoring interval to 20 milliseconds.
[Sysname] multicast frr monitor cycle 20
rpf-frr enable
multicast frr wtr
Use multicast frr wtr to configure traffic switchback from the backup link to the primary link for multicast FRR.
Use undo multicast frr wtr to restore the default.
multicast frr wtr { wtr-time | disable }
Traffic switchback is disabled and the wait-to-restore (WTR) time is 600 seconds.
wtr-time: Specifies the wait-to-restore (WTR) time in the range of 60 to 1800 seconds.
disable: Disables traffic switchback.
To prevent multicast traffic from being switched back before the multicast entries are created for the primary link, do not set too short a wait-to-restore (WTR) time.
Multicast packets might be lost or duplicate multicast packets might exist during a traffic switchback. As a best practice, do not configure traffic switchback for multicast services requiring high reliability.
# Set the WTR time to 800 seconds.
[Sysname] multicast frr wtr 800
rpf-frr enable
multicast permit ssdp-group
Use multicast permit ssdp-group to allow the generation of multicast entries with group address 239.255.255.250.
Use undo multicast permit ssdp-group to restore the default.
The device cannot generate multicast entries with 239.255.255.250 as the group address.
By default, the device cannot generate multicast entries with 239.255.255.250 as the group address. Perform this task to allow multicast entries with 239.255.255.250 as the group address to be generated on the device.
The generation of multicast entries with 239.255.255.250 as the group address is also affected by a multicast group policy and a multicast source policy. If 239.255.255.250 is filtered by the ACL in a multicast group policy or multicast source policy, such multicast entries cannot be generated. A multicast group policy is configured by using the igmp group-policy command, and a multicast source policy is configured by using the source-policy command.
# Allow the generation of multicast entries with group address 239.255.255.250.
[Sysname] multicast permit ssdp-group
multicast replication-share enable
Use multicast replication-share enable to enable multicast replication resource reuse.
Use undo multicast replication-share enable to disable multicast replication resource reuse.
Multicast replication resource reuse is disabled.
Multicast replication resources are hardware resources used to replicate multicast traffic. By default, multiple (S, G) entries with the same outgoing interface use multiple multicast replication resources.
This feature allows (S, G) entries with the same outgoing interface to use the same multicast replication resource.
For this command to take effect ,you must use the reboot command to reboot the device.
# Enable multicast replication resource reuse.
[Sysname] multicast replication-share enable
Configuring success. Please save the configuration first, then reboot the device to activate the function.
multicast routing
Use multicast routing to enable IP multicast routing and enter MRIB view.
Use undo multicast routing to disable IP multicast routing.
undo multicast routing [ vpn-instance vpn-instance-name ]
IP multicast routing is disabled.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command enables IP multicast routing on the public network.
Other Layer 3 multicast commands take effect only when IP multicast routing is enabled on the public network or for a VPN instance.
The device does not forward multicast packets before IP multicast routing is enabled.
# Enable IP multicast routing on the public network, and enter MRIB view.
[Sysname] multicast routing
[Sysname-mrib]
# Enable IP multicast routing for the VPN instance mvpn, and enter MRIB view.
[Sysname-mrib-mvpn]
Use reset multicast fast-forwarding cache to clear multicast fast forwarding entries.
reset multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache { { source-address | group-address } * | all } [ slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears multicast fast forwarding entries on the public network.
source-address: Specifies a multicast source address.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears multicast fast forwarding entries for the master device.
all: Specifies all multicast fast forwarding entries.
# Clear all multicast fast forwarding entries on the public network.
<Sysname> reset multicast fast-forwarding cache all
# Clear the multicast fast forwarding entry for multicast source and group (20.0.0.2, 225.0.0.2) on the public network.
<Sysname> reset multicast fast-forwarding cache 20.0.0.2 225.0.0.2
display multicast fast-forwarding cache
reset multicast forwarding event
Use reset multicast forwarding event to clear statistics for multicast forwarding events.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears statistics for the multicast forwarding events on the public network.
# Clear statistics for multicast forwarding events on the public network.
<Sysname> reset multicast forwarding event
Use reset multicast forwarding-table to clear multicast forwarding entries.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears multicast forwarding entries on the public network.
mask: Specifies an address mask. The default is 255.255.255.255.
all: Specifies all multicast forwarding entries.
When you clear a multicast forwarding entry, the associated multicast routing entry is also cleared.
# Clear multicast forwarding entries for multicast group 225.5.4.3 on the public network.
<Sysname> reset multicast forwarding-table 225.5.4.3
reset multicast routing-table
Use reset multicast routing-table to clear multicast routing entries.
reset multicast [ vpn-instance vpn-instance-name ] routing-table { { source-address [ mask { mask-length | mask } ] | group-address [ mask { mask | mask-length } ] | incoming-interface interface-type interface-number } * | all }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears multicast routing entries on the public network.
incoming-interface: Specifies the routing entries that contain the specified incoming interface.
all: Specifies all multicast routing entries.
When you clear a multicast routing entry, the associated multicast forwarding entry is also cleared.
# Clear multicast routing entries for multicast group 225.5.4.3 on the public network.
<Sysname> reset multicast routing-table 225.5.4.3
