20-Network Management and Monitoring Command Reference
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesCommand ReferencesH3C WX3800X Series Access Controllers Command References(R1411P02)-6W10020-Network Management and Monitoring Command Reference
09-UCC commands
09-UCC commands 125.74 KB
UCC commands
application enable
Use application enable to enable UCC for an audio or video application.
Use undo application enable to disable UCC for an audio or video application.
application app-name enable
undo application app-name enable
UCC is disabled for audio and video applications.
UCC profile view
app-name: Specifies an application name.
With UCC enabled for an audio or video application, the wireless service bound to the UCC profile will preferentially forward traffic from that application for wireless users that use the application to obtain higher-quality services.
# Enable UCC for FeiShu.
[Sysname] ucc profile ssidcompany
[Sysname-ucc-profile-ssidcompany] application feishu enable
ucc profile
application flow-mark
Use application flow-mark to configure priority marking for traffic from an audio or video application.
Use undo application flow-mark to restore the default.
application app-name flow-mark
undo application app-name flow-mark
Priority marking is not configured for traffic from audio and video applications.
UCC profile view
Priority marking marks the priority of uplink traffic for an audio or video application and sends the priority to other service modules for them to process the traffic as configured.
# Configure priority marking for Tencent Meeting traffic.
[Sysname-ucc-profile-ssidcompany] application tencentmeeting flow-mark
ucc profile
application-subcategory drop
Use application-subcategory drop to drop packets of an application in the specified subcategory.
Use undo application-subcategory drop to restore the default.
application-subcategory appsubcategory [ app app-name ] drop
undo application-subcategory appsubcategory [ app app-name ] drop
The device does not drop application packets.
UCC profile view
appsubcategory: Specifies the name of the application subcategory. The name is defined by the device automatically. You can obtain the name by using the application-subcategory ?command.
app app-name: Specifies the name of the application. The name is defined by the device automatically. You can obtain the name by using the application-subcategory appsubcategory app ? command. If you do not specify this option, the command drops packets of all applications in the subcategory.
With this feature configured, the device drops application packets specified by the client. In this case, the wireless service bound to the UCC profile cannot provide the corresponding application services.
After configuring the device to drop packets of all applications in the specified subcategory, you cannot configure a specific application any more.
# Configure the device to drop packets of YouKu in the Streaming_Media application subcategory.
[Sysname-ucc-profile-ssidcompany] application-subcategory streaming_media app youku drop
application-subcategory rate-limit
Use application-subcategory rate-limit to enable and specify a packet rate limit for an application in the specified subcategory.
Use undo application-subcategory rate-limit to disable packet rate limit for an application in the specified subcategory.
application-subcategory appsubcategory [ app app-name ] rate-limit rate
undo application-subcategory appsubcategory [ app app-name ] rate-limit
Rate limit for application packets is disabled.
UCC profile view
app app-name: Specifies the name of the application. The name is defined by the device automatically. You can obtain the name by using the application-subcategory appsubcategory app ? command. If you do not specify this option, the command set rate limit for all application packets in the subcategory.
rate: Specifies the rate limit, in the range of 64 to 10000000 kbps.
With this feature enabled, the wireless service bound to the UCC profile restricts the packet rate of a specified application. In a scenario featuring a large traffic volume, to ensure the service quality of key applications, you can set low rate limits for non-key application packets and high rate limits for key application packets.
After specifying a rate limit for packets of all applications in a specified subcategory, you cannot configure a specific application any more.
# Specify the rate limit as 100 kbps for packets of YouKu in the Streaming_Media subcategory.
[Sysname-ucc-profile-ssidcompany] application-subcategory streaming_media app youku rate-limit 100
application-subcategory remark
Use application-subcategory remark to specify packet priorities for an application in the specified subcategory.
Use undo application-subcategory remark to restore the default.
application-subcategory appsubcategory [ app app-name ] remark { dot1p dot1p-value | dscp dscp-value }
undo application-subcategory appsubcategory [ app app-name ] remark
DSCP and 802.1p priorities for packets of an application in the subcategory are defined by the application itself.
UCC profile view
dscp dscp-value: Specifies the DSCP priority, in the range of 0 to 63. A greater number indicates a higher priority.
dot1p dot1p-value: Specifies the 802.1p priority, in the range of 0 to 7. A greater number indicates a higher priority.
With this feature configured, the wireless service bound to the UCC profile modifies the DSCP and 802.1p priorities of packets for an application in a specified subcategory.
If you configure this feature with UCC enabled for an audio or video application for the same UCC profile, packets whose priorities are specified by this feature take precedence.
After specifying packet priorities for all applications in the specified subcategory, you cannot configure a specific application any more.
# Specify the DSCP priority as 30 for packets of YouKu in the Streaming_Media subcategory.
[Sysname-ucc-profile-ssidcompany] application-subcategory streaming_media app youku remark dscp 30
apr wlan-signature update
Use apr wlan-signature update to bulk upgrade APR signature libraries for APs on the AC.
apr wlan-signature update { file-name | default }
file-name: Specifies the name of the compressed package file containing the APR signature library file and brief application information file, a string of 1 to 255 characters with the suffix .dat.
default: Restores the APR signature library of the AP to the factory default signature library.
For the audio and video feature of the UCC module to take effect on an AP, you also need to configure the DPI application identification feature. DPI application identification depends on the APR signature library. To ensure correct audio and video operation, upgrade the APR signature library on the AP in time. In a distributed AP network environment with AC + fit AP deployed, one AC might manage multiple APs. If the audio and video feature of the UCC module is enabled for multiple APs, use this command to upgrade the APR signature library for the APs in bulk.
# Bulk upgrade APR signature libraries for APs.
[Sysname] apr wlan-signature update tmp.dat
display apr wlan-signature library
Use display apr wlan-signature library to display APR signature library version information on the AC.
In a distributed AP network environment with AC + fit AP deployed, you can execute this command to obtain the version information of the APR signature library on the AC. This allows you to check the APR signature library version information for the fit AP, or to upgrade the APR signature library for the AP on the AC.
# Display APR signature library version information on the AC.
<Sysname> display apr wlan-signature library
APR wlan-signature library information:
Type      SigVersion         ReleaseTime               Size
Current   1.0.26             Mon Jun 27 07:50:52 2022  223792
Factory   1.0.0              Tue Feb 19 08:54:52 2019  234400
APR signature library version. Options include:
·     Current—Current version.
·     Factory—Factory default version.
SigVersion
APR signature library version number.
ReleaseTime
Time when the APR signature library was released.
Size
Size of the APR signature library in bytes.
display ucc profile
Use display ucc profile to display configuration information for UCC profiles.
display ucc profile [ profile-name ]
profile-name: Specifies a UCC profile by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a UCC profile, this command displays configuration information for all UCC profiles.
# Display configuration information for all UCC profiles.
<Sysname> display ucc profile
UCC profile information:
  UCC profile name: ssidcompany1
    UCC-enabled applications: tencentmeeting
                              qq
    Traffic-marking enabled applications: tencentmeeting
                                          qq
Total UCC profiles: 1
List of applications that are already enabled with UCC.
List of applications that are already enabled with traffic priority marking.
application enable
display ucc whitelist ap
Use display ucc whitelist ap to display UCC AP whitelist.
# Display UCC AP whitelist.
<Sysname> display ucc whitelist ap
  AP Whitelist Entry Info:
    AP name: ap1, ap2, ap3
ucc whitelist ap
display ucc whitelist ap-group
Use display ucc whitelist ap-group to display UCC AP group whitelist.
# Display UCC AP group whitelist.
<Sysname> display ucc whitelist ap-group
  AP-group Whitelist Entry Info:
    Group name: apg1, apg2
ucc profile
Use ucc profile to create a UCC profile and enter its view, or enter the view of an existing UCC profile.
Use undo ucc profile to delete a UCC profile.
ucc profile profile-name
undo ucc profile profile-name
No UCC profiles exist.
profile-name: Specifies the name of a UCC profile, a case-insensitive string of 1 to 31 characters. The UCC profile name can contain hyphens (-), underscores (_), left brackets ([), right brackets (]), and slashes (/).
# Create UCC profile ssidcompany and enter its view.
display ucc profile
ucc-profile
ucc whitelist ap
Use ucc whitelist ap to configure the UCC AP whitelist.
Use undo ucc whitelist ap to delete table entries from the UCC AP whitelist.
ucc whitelist ap ap-name
undo ucc whitelist ap [ ap-name ]
The UCC AP whitelist is not specified, and the UCC information of an AC can be reported to AC.
ap-name: Specifies an AP name, a case-sensitive string of 1 to 64 characters. Only letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), slashes (/), and hyphens (-) are allowed. If you do not specify this argument, this command deletes all table entries from the UCC AP white list.
Perform this task to allow only APs that belong to the UCC AP or AP group white list to collect and report UCC statistics to AC, reducing AC pressure from too many AP reports. In this way, pressure is also released for APs that do not belong to the UCC AP or AP group white list, because they no longer collect or report UCC statistics to AC.
Only UCC APs for audio and video traffic are restricted by the whitelist.
# Add AP ap1 to the UCC AP whitelist.
[Sysname] ucc whitelist ap ap1
Use ucc whitelist ap-group to configure the UCC AP group whitelist.
Use undo ucc whitelist ap-group to delete table entries from the UCC AP group whitelist.
ucc whitelist ap-group group-name
undo ucc whitelist ap-group [ group-name ]
UCC AP group whitelist is not specified.
group-name: Specifies an AP group name, a case-insensitive string of 1 to 31 characters. If you do not specify this argument, this command deletes all table entries from the UCC AP group white list.
# Add AP group apg1 to the UCC AP group whitelist.
[Sysname] ucc whitelist ap-group apg1
ucc whitelist ap
ucc-profile
Use ucc-profile to bind a UCC profile to a service template.
Use undo ucc-profile to unbind a UCC profile from a service template.
ucc-profile profile-name
undo ucc-profile
No UCC profile is bound to a service template.
Service template view
Use this command to enable a service template to optimize and analyze audio and video traffic for wireless clients associated with the service template.
You can bind only one UCC profile to a service template. To bind a different UCC profile to the service template, first unbind the existing UCC profile from the service template.
# Bind UCC profile ssidcompany to service template service.
[Sysname-ucc-profile-ssidcompany] sip enable
[Sysname-ucc-profile-ssidcompany] quit
[Sysname] wlan service-template service
[Sysname-wlan-st-service] ucc-profile ssidcompany
sip enable
ucc profile
