- 16-Security Command Reference
- 01-ACL commands
- 02-Packet filter commands
- 03-Time range commands
- 04-User profile commands
- 05-Password control commands
- 06-Keychain commands
- 07-Public key management commands
- 08-PKI commands
- 09-IPsec commands
- 10-IKE commands
- 11-IKEv2 commands
- 12-SSH commands
- 13-SSL commands
- 14-SSL VPN commands
- 15-Session management commands
- 16-Connection limit commands
- 17-Attack detection and prevention commands
- 18-IP-based attack prevention commands
- 19-IP source guard commands
- 20-ARP attack protection commands
- 21-ND attack defense commands
- 22-Protocol packet rate limit commands
- 23-Security policy commands
- 24-Object group commands
- 25-ASPF commands
| 15-Session management commands | 250.81 KB |
display session aging-time application
display session aging-time state
display session relation-table
display session statistics ipv4
display session statistics ipv6
display session statistics multicast
display session table multicast ipv4
display session table multicast ipv6
reset session statistics multicast
reset session table multicast ipv4
Use display session aging-time application to display the aging time for sessions of different application layer protocols.
# Display the aging time for sessions of different application layer protocols.
<Sysname> display session aging-time application
Application Aging Time(s)
DNS 1
FTP 3600
GTP 60
H225 3600
H245 3600
RAS 300
RTSP 3600
SIP 300
TFTP 60
ILS 3600
MGCP 60
NBT 3600
PPTP 3600
RSH 60
SCCP 3600
SQLNET 600
XDMCP 3600
Application |
Application layer protocol. |
Aging Time(s) |
Aging time in seconds. |
application aging-time
Use display session aging-time stat to display the aging time for sessions in different protocol states.
# Display the aging time for sessions in different protocol states.
<Sysname> display session aging-time state
State Aging Time(s)
SYN 10
TCP-EST 3600
FIN 10
UDP-OPEN 10
UDP-READY 30
ICMP-REQUEST 30
ICMP-REPLY 10
RAWIP-OPEN 30
RAWIP-READY 60
UDPLITE-OPEN 30
UDPLITE-READY 60
DCCP-REQUEST 30
DCCP-EST 3600
DCCP-CLOSEREQ 30
SCTP-INIT 30
SCTP-EST 3600
SCTP-SHUTDOWN 30
ICMPV6-REQUEST 60
ICMPV6-REPLY 30
TCP-TIME-WAIT 2
TCP-CLOSE 2
State |
Protocol state. |
Aging Time(s) |
Use display session relation-table to display relation entries.
display session relation-table { ipv4 | ipv6 } [ slot slot-number ]
ipv4: Specifies IPv4 relation entries.
ipv6: Specifies IPv6 relation entries.
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command displays relation entries for all member devices.
# Display all IPv4 relation entries.
<Sysname> display session relation-table ipv4
Slot 1:
Source IP/port: 192.168.1.100/-
Destination IP/port: 192.168.2.100/99
DS-Lite tunnel peer: -
VPN instance/VLAN ID/VLL ID: 1/-/-
Protocol: TCP(6) TTL: 1234s App: FTP-DATA
Source IP/port: -/-
Destination IP/port: 192.168.2.200/1212
VPN instance/VLAN ID/VLL ID: -/-/-
Protocol: TCP(6) TTL: 3100s App: H225
Total entries found: 2
Source IP/port |
Source IP address and port number of the session. If the IP or port number is not specified, this field displays a hyphen (-). For an IPv6 relation entry, the source port number is not displayed. |
Destination IP/port |
Destination IP address and port number of the session. |
DS-Lite tunnel peer |
Peer tunnel interface address of the DS-Lite tunnel to which the session belongs. If no peer tunnel interface address is specified, a hyphen (-) is displayed. |
VPN instance/VLAN ID/VLL ID |
VPN instance: MPLS L3VPN instance to which the relation entry belongs. This field is not supported in the current software version. VLAN ID/VLL ID: VLAN and INLINE to which the relation entry belongs during Layer 2 forwarding. If a parameter is not specified, a hyphen (-) is displayed for the proper field. |
Protocol |
Transport layer protocol. |
TTL |
Remaining lifetime of the relation entry, in seconds. |
App |
Total entries found |
Total number of found relation entries. |
Use display session statistics to display unicast session statistics.
display session statistics [ summary ] [ slot slot-number ]
summary: Displays summary information about unicast session statistics. If you do not specify this keyword, the command displays detailed information about unicast session statistics.
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command displays unicast session statistics for all member devices.
# Display detailed information about unicast session statistics.
<Sysname> display session statistics
Current sessions: 3
TCP sessions: 0
UDP sessions: 0
ICMP sessions: 3
ICMPv6 sessions: 0
UDP-Lite sessions: 0
SCTP sessions: 0
DCCP sessions: 0
RAWIP sessions: 0
History average sessions per second:
Past hour: 1
Past 24 hours: 0
Past 30 days: 0
History average session establishment rate:
Past hour: 0/s
Past 24 hours: 0/s
Past 30 days: 0/s
Current relation-table entries: 0
Session establishment rate: 0/s
TCP: 0/s
UDP: 0/s
ICMP: 0/s
ICMPv6: 0/s
UDP-Lite: 0/s
SCTP: 0/s
DCCP: 0/s
RAWIP: 0/s
Received TCP : 0 packets 0 bytes
Received UDP : 118 packets 13568 bytes
Received ICMP : 105 packets 8652 bytes
Received ICMPv6 : 0 packets 0 bytes
Received UDP-Lite : 0 packets 0 bytes
Received SCTP : 0 packets 0 bytes
Received DCCP : 0 packets 0 bytes
Received RAWIP : 0 packets 0 bytes
Current sessions |
Total number of unicast sessions. |
TCP sessions |
Number of TCP unicast sessions. |
UDP sessions |
Number of UDP unicast sessions. |
ICMP sessions |
Number of ICMP unicast sessions. |
ICMPv6 sessions |
Number of ICMPv6 unicast sessions. |
UDP-Lite sessions |
Number of UDP-Lite unicast sessions. |
SCTP sessions |
Number of SCTP unicast sessions. |
DCCP sessions |
Number of DCCP unicast sessions. |
RAWIP sessions |
Number of Raw IP unicast sessions. |
History average sessions per second |
History statistics of average unicast sessions per second. |
Past hour |
The average number of unicast sessions per second in the most recent hour. |
Past 24 hours |
The average number of unicast sessions per second in the most recent 24 hours. |
Past 30 days |
The average number of unicast sessions per second in the most recent 30 days. |
History average session establishment rate |
History statistics of average unicast session establishment rates. |
Past hour |
The average unicast session establishment rate in the most recent hour. |
Past 24 hours |
The average unicast session establishment rate in the most recent 24 hours. |
Past 30 days |
The average unicast session establishment rate in the most recent 30 days. |
Current relation-table entries |
Total number of relation entries. |
Session establishment rate |
Unicast session establishment rate, and rates for establishing unicast sessions of different protocols. |
Received TCP |
Number of received TCP packets and bytes. |
Received UDP |
Number of received UDP packets and bytes. |
Received ICMP |
Number of received ICMP packets and bytes. |
Received ICMPv6 |
Number of received ICMPv6 packets and bytes. |
Received UDP-Lite |
Number of received UDP-Lite packets and bytes. |
Received SCTP |
Number of received SCTP packets and bytes. |
Received DCCP |
Number of received DCCP packets and bytes. |
Received RAWIP |
Number of received Raw IP packets and bytes. |
# Display summary information about unicast session statistics.
<Sysname> display session statistics summary
Slot CPU Sessions TCP UDP Rate TCP rate UDP rate
1 1 3 0 0 0/s 0/s 0/s
Table 5 Command output
CPU |
CPU number. |
Sessions |
TCP |
UDP |
Rate |
Rate of unicast session creation. |
TCP rate |
Rate of TCP unicast session creation. |
UDP rate |
Rate of UDP unicast session creation. |
Use display session statistics ipv4 to display IPv4 unicast session statistics.
display session statistics ipv4 { destination-ip destination-ip | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip source-ip | source-port source-port } * [ slot slot-number ]
destination-ip destination-ip: Specifies a destination IPv4 address for a unicast session from the initiator to the responder.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of an IPv4 unicast session from the initiator to the responder. The value range for the destination-port argument is 0 to 65535.
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv4 protocol.
source-ip source-ip: Specifies a source IPv4 address for a unicast session from the initiator to the responder.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of an IPv4 unicast session from the initiator to the responder. The value range for the source-port argument is 0 to 65535.
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command displays IPv4 unicast session statistics for all member devices.
# Display statistics for IPv4 unicast sessions from port 1024.
<Sysname> display session statistics ipv4 source-port 1024
Slot 1:
Current sessions: 1
TCP sessions: 0
UDP sessions: 1
ICMP sessions: 0
ICMPv6 sessions: 0
SCTP sessions: 0
DCCP sessions: 0
RAWIP sessions: 0
Table 6 Command output
Current sessions |
Total number of current unicast sessions. |
TCP sessions |
UDP sessions |
ICMP sessions |
ICMPv6 sessions |
UDP-Lite sessions |
SCTP sessions |
DCCP sessions |
RAWIP sessions |
Use display session statistics ipv6 to display IPv6 unicast session statistics.
display session statistics ipv6 { source-ip source-ip | destination-ip destination-ip | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-port source-port | destination-port destination-port } * [ slot slot-number ]
source-ip source-ip: Specifies a source IPv6 address for a unicast session.
destination-ip destination-ip: Specifies a destination IPv6 address for a unicast session.
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv6 protocol.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of an IPv6 unicast session. The value range for the source-port argument is 0 to 65535.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of an IPv6 unicast session. The value range for the destination-port argument is 0 to 65535.
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command displays IPv6 unicast session statistics for all member devices.
# Display statistics for unicast sessions from IPv6 address 100::2.
<Sysname> display session statistics ipv6 source-ip 100::2
CPU 1 on slot 1:
Current sessions: 1
TCP sessions: 0
UDP sessions: 0
ICMPv6 sessions: 3
SCTP sessions: 0
DCCP sessions: 0
RAWIP sessions: 0
Table 7 Command output
Current sessions |
TCP sessions |
UDP sessions |
ICMPv6 sessions |
UDP-Lite sessions |
SCTP sessions |
DCCP sessions |
RAWIP sessions |
Use display session statistic multicast to display multicast session statistics.
display session statistics multicast [ slot slot-number ]
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command displays multicast session statistics for all member devices.
# Display information about multicast session statistics.
<Sysname> display session statistics multicast
Slot 1:
Current sessions: 0
History max sessions: 0 Time: 2017-04-25 11:28:00
History max session establishment rate: 0/s Time: 2017-04-25 11:28:00
Received: 0 packets 0 bytes
Sent : 0 packets 0 bytes
Table 8 Command output
Current sessions |
Total number of multicast sessions. |
Rate of multicast session creation. |
History max sessions |
History statistics of the maximum multicast sessions. |
History max session establishment rate |
History statistics of the maximum rate at which multicast sessions were created. |
Received |
Number of received multicast packets and bytes. |
Sent |
Number of sent multicast packets and bytes. |
display session table ipv4
Use display session table ipv4 to display information about IPv4 unicast session entries that match specific criteria.
display session table ipv4 [ slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ verbose ]
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command displays information for all member devices.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv4 address or IPv4 address range for a unicast session from the initiator to the responder. The start source-ip argument specifies the start source IPv4 address. The end source-ip argument specifies the end source IPv4 address.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv4 address or IPv4 address range for a unicast session from the initiator to the responder. The start destination-ip argument specifies the start destination IPv4 address. The end destination-ip argument specifies the end destination IPv4 address.
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv4 transport layer protocol, including DCCP, ICMP, Raw IP, SCTP, TCP, UDP, and UDP-Lite.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a unicast session from the initiator to the responder. The value range for the source-port argument is 0 to 65535.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a unicast session from the initiator to the responder. The value range for the destination-port argument is 0 to 65535.
verbose: Displays detailed information about IPv4 unicast session entries. If you do not specify this keyword, the command displays brief information about IPv4 unicast session entries.
If you do not specify any parameters, this command displays all IPv4 unicast session entries.
# Display brief information about all IPv4 unicast session entries.
<Sysname> display session table ipv4
Slot 1:
Initiator:
Source IP/port: 192.168.1.18/1877
Destination IP/port: 192.168.1.55/22
Protocol: TCP(6)
Inbound interface: Vlan-interface 100
Source security zone: Trust
Total sessions found: 1
# Display detailed information about all IPv4 unicast session entries.
<Sysname> display session table ipv4 verbose
Slot 1:
Initiator:
Protocol: TCP(6)
Responder:
Source IP/port: 192.168.1.55/22
Destination IP/port: 192.168.1.18/1877
Protocol: TCP(6)
Inbound interface: Vlan-interface 101
Source security zone: Local
State: TCP_SYN_SENT
Application: SSH
Start time: 2011-07-29 19:12:36
Initiator->Responder: 1 packets 48 bytes
Responder->Initiator: 0 packets 0 bytes
Table 9 Command output
Initiator |
Information about the unicast session from the initiator to the responder. |
Responder |
Information about the unicast session from the responder to the initiator. |
Address of the DS-Lite tunnel peer. When the unicast session does not belong to any DS-Lite tunnel, this field displays a hyphen (-). |
VPN instance: MPLS L3VPN instance to which the unicast session belongs. This field is not supported in the current software version. VLAN ID/VLL ID: VLAN and INLINE to which the session belongs during Layer 2 forwarding. If a parameter is not specified, a hyphens (-) is displayed for the proper field. |
Protocol |
Transport layer protocol: · DCCP. · ICMP. · ICMPv6. · Raw IP. · SCTP. · TCP. · UDP. · UDP-Lite. The number in the brackets indicates the protocol number. |
Source security zone |
Security zone to which the inbound interface belongs. If the inbound interface does not belong to any security zone, this field displays a hyphen (-). |
State |
Unicast session state. |
Application |
Application layer protocol, FTP or DNS. If it is an unknown protocol identified by an unknown port, this field displays OTHER. |
Start time |
Unicast session establishment time. |
Initiator->Responder |
Number of packets and bytes from the initiator to the responder. |
Responder->Initiator |
Number of packets and bytes from the responder to the initiator. |
Total sessions found |
Total number of found unicast session entries. |
Use display session table multicast ipv4 to display information about IPv4 multicast session entries that match specific criteria.
display session table multicast ipv4 [ slot slot-number] [ destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port ] * [ verbose ]
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv4 address or IPv4 address range for a multicast session. The start destination-ip argument specifies the start destination IPv4 address. The end destination-ip argument specifies the end destination IPv4 address.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a multicast session. The value range for the destination-port argument is 0 to 65535.
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv4 transport layer protocol.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv4 address or IPv4 address range for a multicast session. The start source-ip argument specifies the start source IPv4 address. The end source-ip argument specifies the end source IPv4 address.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a multicast session. The value range for the source-port argument is 0 to 65535.
verbose: Displays detailed information about IPv4 multicast session entries. If you do not specify this keyword, the command displays brief information about IPv4 multicast session entries.
If you do not specify any parameters, this command displays all IPv4 multicast session entries.
# Display brief information about all IPv4 multicast session entries.
<Sysname> display session table multicast ipv4
Slot 1:
Inbound initiator:
Source IP/port: 3.3.3.4/1609
Destination IP/port: 232.0.0.1/1025
Protocol: UDP(17)
Outbound interface list:
Vlan-interface 101
Vlan-interface 102
# Display detailed information about all IPv4 multicast session entries.
<Sysname> display session table multicast ipv4 verbose
Slot 1:
Inbound initiator:
Protocol: UDP(17)
Inbound responder:
Source IP/port: 232.0.0.1/1025
Destination IP/port: 3.3.3.4/1609
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Start time: 2014-03-03 15:59:22 TTL: 18s
Initiator->Responder: 1 packets 84 bytes
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
Outbound interface: Vlan-interface 101
State: UDP_OPEN
Application: OTHER
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
Outbound interface: Vlan-interface 102
State: UDP_OPEN
Application: OTHER
Total sessions found: 3
Table 10 Command output
Inbound initiator |
Information about the multicast session from the initiator to the responder on the inbound interface. |
Inbound responder |
Information about the multicast session from the responder to the initiator on the inbound interface. |
Outbound initiator |
Information about the multicast session from the initiator to the responder on the outbound interface. |
Outbound responder |
Information about the multicast session from the responder to the initiator on the outbound interface. |
Address of the DS-Lite tunnel peer. If the multicast session is not tunneled by DS-Lite, this field displays a hyphen (-). |
VPN instance/VLAN ID/Inline ID |
MPLS L3VPN instance to which the multicast session belongs. This field is not supported in the current software version. VLAN and inline to which the multicast session belongs during Layer 2 forwarding. If a parameter is not specified, a hyphens (-) is displayed for the proper field. |
Protocol |
Transport layer protocol: · DCCP. · ICMP. · Raw IP. · SCTP. · TCP. · UDP. · UDP-Lite. The number in the brackets indicates the protocol number. |
State |
Multicast session state. |
Application |
Start time |
Time when the multicast session was created. |
TTL |
Remaining lifetime of the multicast session, in seconds. |
Inbound interface |
Inbound interface of the first packet from the initiator to responder. |
Outbound interface |
Outbound interface of the first packet from the initiator to responder. |
Outbound interface list |
Outbound interfaces of the first packet from the initiator to responder. |
Destination security zone |
Security zone to which the outbound interface belongs. If the outbound interface does not belong to any security zone, this field displays a hyphen (-). |
Total number of found multicast session entries. |
Use display session table multicast ipv6 to display information about IPv6 multicast session entries that match specific criteria.
display session table multicast ipv6 [ slot slot-number] [ destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port ] * [ verbose ]
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv6 address or IPv6 address range for a multicast session. The start destination-ip argument specifies the start destination IPv6 address. The end destination-ip argument specifies the end destination IPv6 address.
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv6 transport layer protocol.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv6 address or IPv6 address range for a multicast session. The start source-ip argument specifies the start source IPv6 address. The end source-ip argument specifies the end source IPv6 address.
verbose: Displays detailed information about IPv6 multicast session entries. If you do not specify this keyword, the command displays brief information about IPv6 multicast session entries.
If you do not specify any parameters, this command displays all IPv6 multicast session entries.
# Display brief information about all IPv6 multicast session entries.
<Sysname> display session table multicast ipv6
Slot 1:
Inbound initiator:
Source IP/port: 3::4/1617
Destination IP/port: FF0E::1/1025
Protocol: UDP(17)
Vlan-interface 101
Vlan-interface 102
# Display detailed information about all IPv6 multicast session entries.
<Sysname> display session table multicast ipv6 verbose
Slot 1:
Inbound initiator:
Protocol: UDP(17)
Inbound responder:
Source IP/port: FF0E::1/1025
Destination IP/port: 3::4/1617
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Start time: 2014-03-03 16:10:58 TTL: 23s
Initiator->Responder: 5 packets 520 bytes
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Table 11 Command output
Inbound initiator |
Inbound responder |
Protocol |
Transport layer protocol: · DCCP. · ICMPv6. · Raw IP. · SCTP. · TCP. · UDP. · UDP-Lite. The number in the brackets indicates the protocol number. |
State |
Application |
Start time |
TTL |
Inbound interface |
reset session relation-table
Use reset session relation-table to clear relation entries.
reset session relation-table [ ipv4 | ipv6 ] [ slot slot-number ]
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command clears relation entries for all member devices.
If you do not specify any parameters, this command clears all relation entries.
# Clear all IPv4 relation entries.
<Sysname> reset session relation-table ipv4
Use reset session statistics to clear unicast session statistics.
reset session statistics [ slot slot-number ]
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command clears unicast session statistics for all member devices.
# Clear all unicast session statistics.
<Sysname> reset session statistics
Use reset session statistics multicast to clear multicast session statistics.
reset session statistics multicast [ slot slot-number]
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command clears multicast session statistics for all member devices.
# Clear all multicast session statistics.
<Sysname> reset session statistics multicast
reset session table
Use reset session table to clear all unicast session entries.
reset session table [ slot slot-number ]
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command clears unicast session entries for all member devices.
# Clear all IPv4 and IPv6 unicast session entries.
<Sysname> reset session table
reset session table ipv4
Use reset session table ipv4 to clear information about IPv4 unicast session entries that match specific criteria.
reset session table ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command clears information for all member devices.
source-ip source-ip: Specifies a source IPv4 address. The source-ip argument specifies the source IPv4 address of a unicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv4 address. The destination-ip argument specifies the destination IPv4 address of a unicast session from the initiator to the responder.
If you do not specify any parameters, this command clears all IPv4 unicast session entries on the public network.
# Clear all IPv4 unicast session entries.
<Sysname> reset session table ipv4
# Clear the IPv4 unicast session entries with the source IP address of 10.10.10.10.
<Sysname> reset session table ipv4 source-ip 10.10.10.10
reset session table ipv6
Use reset session table ipv6 to clear information about IPv6 unicast session entries that match the specified criteria.
reset session table ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
source-ip source-ip: Specifies a source IPv6 address. The source-ip argument specifies the source IPv6 address of a unicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv6 address. The destination-ip argument specifies the destination IPv6 address of a unicast session from the initiator to the responder.
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv6 transport layer protocol, including DCCP, ICMPv6, Raw IP, SCTP, TCP, UDP, and UDP-Lite.
If you do not specify any parameters, this command clears all IPv6 unicast session entries on the public network.
# Clear all IPv6 unicast session entries.
<Sysname> reset session table ipv6
# Clear the IPv6 unicast session entries with the source IP address of 2011::0002.
<Sysname> reset session table ipv6 source-ip 2011::0002
display session table ipv6
Use reset session table multicast to clear IP multicast session entries.
reset session table multicast [ slot slot-number]
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command clears multicast session entries for all member devices.
# Clear all multicast session entries.
<Sysname> reset session table multicast
Use reset session table multicast ipv4 to clear information about IPv4 multicast session entries that match specific criteria.
reset session table multicast ipv4 [ slot slot-number] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
source-ip source-ip: Specifies a source IPv4 address. The source-ip argument specifies the source IPv4 address of a multicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv4 address. The destination-ip argument specifies the destination IPv4 address of a multicast session from the initiator to the responder.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a multicast session from the initiator to the responder. The value range for the source-port argument is 0 to 65535.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a multicast session from the initiator to the responder. The value range for the destination-port argument is 0 to 65535.
If you do not specify any parameters, this command clears all IPv4 multicast session entries on the public network.
# Clear all IPv4 multicast session entries.
<Sysname> reset session table multicast ipv4
# Clear the IPv4 multicast session entries with the source IP address of 10.10.10.10.
<Sysname> reset session table multicast ipv4 source-ip 10.10.10.10
Use session aging-time application to set the aging time for sessions of an application layer protocol.
Use undo session aging-time application to restore the default. If you do not specify an application layer protocol, this command restores the default aging time for all sessions of the supported application layer protocols.
session aging-time application { dns | ftp | gtp | h225 | h245 | ils | mgcp | nbt | pptp | ras | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp } time-value
undo session aging-time application [ dns | ftp | gtp | h225 | h245 | ras | rtsp | sip | tftp ]
The aging time for sessions of application layer protocols is as follows:
· DNS sessions: 1 second.
· FTP sessions: 3600 seconds.
· GTP sessions: 60 seconds.
· H.225 sessions: 3600 seconds.
· H.245 sessions: 3600 seconds.
· ILS sessions: 3600 seconds.
· MGCP sessions: 60 seconds.
· NBT sessions: 3600 second.
· PPTP sessions: 3600 seconds.
· RAS sessions: 300 seconds.
· RSH sessions: 60 seconds.
· RTSP sessions: 3600 seconds.
· SCCP sessions: 3600 seconds.
· SIP sessions: 300 seconds.
· SQLNET sessions: 600 seconds.
· TFTP sessions: 60 seconds.
· XDMCP sessions: 3600 seconds.
dns: Specifies the DNS protocol.
ftp: Specifies the FTP protocol.
gtp: Specifies the GPRS Tunneling Protocol (GTP) protocol.
h225: Specifies the H.225 protocol.
h245: Specifies the H.245 protocol.
ils: Specifies the Internet Locator Service (ILS) protocol.
mgcp: Specifies the Media Gateway Control Protocol (MGCP) protocol.
nbt: Specifies the NetBIOS over TCP/IP (NBT) protocol.
pptp: Specifies the Point-to-Point Tunneling Protocol (PPTP) protocol.
ras: Specifies the RAS protocol.
rsh: Specifies the Remote Shell (RSH) protocol.
rtsp: Specifies the Real Time Streaming Protocol (RTSP) protocol.
sccp: Specifies the Skinny Client Control Protocol (SCCP) protocol.
sip: Specifies the Session Initiation Protocol (SIP) protocol.
sqlnet: Specifies the SQLNET protocol.
tftp: Specifies the TFTP protocol.
xdmcp: Specifies the X Display Manager Control Protocol (XDMCP) protocol.
time-value: Specifies the aging time in seconds. The value range is 5 to 100000. If you specify the dns keyword, the value range is 1 to 100000.
This command sets the aging time for stable sessions of the specified application layer protocols. For TCP sessions, the stable state is ESTABLISHED. For UDP sessions, the stable state is READY.
For sessions of application layer protocols that are not supported by this command, the aging time is set by the session aging-time state command. For persistent sessions, the aging time is set by the session persistent acl command.
# Set the aging time for FTP sessions to 1800 seconds.
[Sysname] session aging-time application ftp 1800
Use session aging-time state to set the aging time for the sessions in a protocol state.
Use undo session aging-time state to restore the default for the sessions in a protocol state. If you do not specify a protocol state, this command restores all aging time for sessions in different protocol states to the default.
session aging-time state { fin | icmp-reply | icmp-request | rawip-open | rawip-ready | syn | tcp-close | tcp-est | tcp-time-wait | udp-open | udp-ready } time-value
undo session aging-time state [ fin | icmp-reply | icmp-request | rawip-open | rawip-ready | syn | tcp-close | tcp-est | tcp-time-wait | udp-open | udp-ready ]
The aging time for sessions in different protocol states is as follows:
· FIN_WAIT: 30 seconds.
· ICMP-REPLY: 30 seconds.
· ICMP-REQUEST: 60 seconds.
· RAWIP-OPEN: 30 seconds.
· RAWIP-READY: 60 seconds.
· TCP SYN-SENT and SYN-RCV: 30 seconds.
· TCP-CLOSE: 2 seconds.
· TCP ESTABLISHED: 3600 seconds.
· TCP-TIME-WAIT: 2 seconds.
· UDP-OPEN: 30 seconds.
· UDP-READY: 60 seconds.
fin: Specifies the TCP FIN_WAIT state.
icmp-reply: Specifies the ICMP REPLY state.
icmp-request: Specifies the IGMP REQUEST state.
rawip-open: Specifies the RAWIP-OPEN state.
rawip-ready: Specifies the RAWIP-READY state.
syn: Specifies the TCP SYN-SENT and SYN-RCV states.
tcp-close: Specifies the TCP CLOSE state.
tcp-est: Specifies the TCP ESTABLISHED state.
tcp-time-wait: Specifies the TCP TIME-WAIT state.
udp-open: Specifies the UDP OPEN state.
udp-ready: Specifies the UDP READY state.
time-value: Specifies the aging time in seconds. For the TCP CLOSE and TCP TIME-WAIT states, the value range is 0 to 100000. For other states, the value range is 5 to 100000.
This command sets the aging time for stable sessions of the application layer protocols that are not supported by the session aging-time application command. For persistent sessions, the aging time is set by the session persistent acl command.
# Set the aging time for TCP sessions in SYN-SENT and SYN-RCV states to 60 seconds.
[Sysname] session aging-time state syn 60
session log bytes-active
Use session log bytes-active to set the byte-based threshold for traffic-based logging.
Use undo session log bytes-active to restore the default.
session log bytes-active bytes-value
The device does not output session logs based on the byte-based threshold.
bytes-value: Specifies the byte-based threshold in the range of 1 to 1000 MB.
If you set both the traffic-based and time-based logging, the device outputs a session log when whichever is reached. After outputting a session log, the device resets the traffic counter and restarts the interval for the session.
Only one traffic-based threshold can take effect. If you set both the byte-based and packet-based thresholds, the most recent configuration takes effect.
# Configure the device to output session logs on a per-10-MB basis.
[Sysname] session log bytes-active 10
session log enable
session log time-active
session log enable
Use session log enable to enable session logging.
Use undo session log enable to disable session logging.
session log enable { ipv4 | ipv6 } [ acl acl-number ] { inbound | outbound }
undo session log enable { ipv4 | ipv6 } [ acl acl-number ] { inbound | outbound }
Session logging is disabled.
Interface view
ipv4: Logs IPv4 sessions.
ipv6: Logs IPv6 sessions.
acl acl-number: Specifies an ACL by its number in the range of 2000 to 3999. If you do not specify an ACL, this command enables session logging for all IPv4 or IPv6 sessions on the interface.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
If you do not specify the inbound or the outbound keyword, this command enables session logging on both directions.
A maximum of one IPv4 ACL and one IPv6 ACL can be applied to each direction.
If you do not set the traffic threshold or the interval but you enable session logging, the device outputs a session log when a session entry is created or removed.
# Enable IPv4 session logging in the inbound direction of VLAN-interface 100.
[Sysname-Vlan-interface 100] session log enable ipv4 inbound
# Enable session logging on VLAN-interface 101 for IPv4 sessions that match ACL 2050 in the outbound direction.
[Sysname] interface vlan-interface 101
[Sysname-Vlan-interface 101] session log enable ipv4 acl 2050 outbound
session log packets-active
Use session log packets-active to set the packet-based threshold for traffic-based logging.
Use undo session log packets-active to restore the default.
session log packets-active packets-value
The device does not output session logs based on the packet-based threshold.
packets-value: Specifies the packet-based threshold in the range of 1 to 1000 mega-packets.
# Configure the device to output session logs on a per-10-mega-packet basis.
[Sysname] session log packets-active 10
session log enable
Use session log time-active to set the time-based session logging.
Use undo session log time-active to restore the default.
session log time-active time-value
The device does not output session logs.
time-value: Specifies the interval in minutes. The value range for the time-value argument is 10 to 120 and the value must be integer times of 10.
If you set both time-based and traffic-based logging, the device outputs a session log when whichever is reached. After outputting a session log, the device resets the traffic counter and restarts the interval for the session.
# Configure the device to output session logs every 50 minutes.
<Sysname> system
[Sysname] session log time-active 50
session log enable
Use session persistent acl to specify persistent sessions.
Use undo session persistent acl to restore the default.
session persistent acl [ ipv6 ] acl-number [ aging-time time-value ]
undo session persistent acl [ ipv6 ]
No persistent sessions exist.
ipv6: Specifies an IPv6 ACL. To specify an IPv4 ACL, do not specify this keyword.
aging-time time-value: Specifies the aging time for persistent sessions in hours. The value range for the time-value argument is 0 to 360, and the default value is 24. To disable the aging for persistent sessions, set the value to 0.
This command is effective only on TCP sessions in ESTABLISHED state.
For a TCP session in ESTABLISHED state, the priority of the aging time is as follows:
· Aging time for persistent sessions.
· Aging time for sessions of application layer protocols.
· Aging time for sessions in different protocol states.
A persistent session is not removed until one of the following events occurs:
· The session entry ages out.
· The device receives a connection close request from the initiator or responder.
· You manually clear the session entries.
The configuration of persistent sessions applies only to new sessions. It has no effect on existing sessions.
# Specify IPv4 ACL 2000 for identifying persistent sessions and set the aging time to 72 hours.
[Sysname] session persistent acl 2000 aging-time 72
session statistics enable
Use session statistics enable to enable session statistics collection.
Use undo session statistics enable to disable session statistics collection.
Session statistics collection is disabled.
This command enables the device to collect the session-based outbound and inbound packets and bytes.
To display statistics per session, use the display session table command. To display statistics per packet type, use the display session statistics command.
# Enable session statistics collection.
[Sysname] session statistics enable
