H3C UniServer R4300 G6 Server User Guide-6W101
HomeSupportServersH3C UniServer R4300 G6Install & UpgradeInstallation GuidesH3C UniServer R4300 G6 Server User Guide-6W101
02-Appendix
02-Appendix 6.91 MB
Appendix A  Server specifications· 1
Server models and chassis view· 1
Technical specifications· 1
Components· 3
Front panel 5
Front panel view of the server 5
LEDs and buttons· 5
Ports· 7
Rear panel 8
Rear panel view· 8
LEDs· 9
Ports· 10
System board· 11
System board components· 11
System maintenance switch· 13
DIMM slots· 14
Appendix B  Component specifications· 15
About component model names· 15
DIMMs· 15
DRAM DIMM rank classification label 15
HDDs and SSDs· 16
Drive numbering· 16
Drive LEDs· 17
Drive backplanes· 19
Front 24LFF drive backplane (18SAS/SATA+6UniBay) 19
Front 24LFF drive backplane (18SAS/SATA+6UniBay) 21
Front 24LFF drive backplane (18SAS/SATA+6UniBay) 22
Rear 12LFF SAS/SATA drive backplane· 23
Rear 2LFF SAS/SATA drive backplane· 24
Rear 4LFF SAS/SATA drive backplane· 24
Mid 4LFF SAS/SATA drive backplane· 25
Rear 4SFF UniBay drive backplane· 25
Rear 2SFF UniBay drive backplane· 26
Rear 2SFF SAS/SATA drive backplane· 26
Rear 8E1.S drive backplane· 27
Riser cards· 28
Riser card guidelines· 28
RC-3FHFL-2U-G6· 29
RC-3FHHL-2U-G6· 31
RC-2HHHL-R4-2U-G6· 32
RC-2FHHL-2U-G6· 33
RC-1FHHL-2U-G6· 34
Fan modules· 34
PCIe slot 35
PCIe modules· 35
Storage controllers· 36
NVMe VROC modules· 36
SATA M.2 expander module· 37
NVMe M.2 expander module· 37
2xM.2 drive cage module· 38
Server management module· 38
Serial & DSD module· 39
B/D/F information· 39
Appendix C  Managed removal of OCP network adapters· 40
Before you begin· 40
Performing a hot removal 40
Appendix D  Environment requirements· 43
About environment requirements· 43
General environment requirements· 43
Operating temperature requirements· 43
General guidelines· 43
Appendix E  Product recycling· 45
Appendix F  Glossary· 46
Appendix G  Acronyms· 48
The information in this document might differ from your product if it contains custom configuration options or features.
Figures in this document are for illustration only.
H3C UniServer R4300 G6 servers are 4U dual-processor servers independently developed by H3C based on the new-generation Eagle Stream platform of Intel. The server can be widely used in the new generation of infrastructure, including cloud computing, Internet, IDC, and enterprise markets. The strong storage performance of R4300 G6 meets the comprehensive demands for high storage density, efficient data computing, and linear expansion. It is especially suitable for distributed storage, big data, and backup and archival applications in industries such as government, security, operators, Internet, and enterprises. In addition, with efficient energy-saving technology, the server can help customers build green and low-carbon data centers.
Figure 1 Chassis view
Item
Specifications
Dimensions (H × W × D)
·     Without a security bezel: 174.8 × 447 × 781 mm (6.88 × 17.60 × 30.75 in)
·     With a security bezel: 174.8 × 447 × 809 mm (6.88 × 17.60 × 31.85 in)
Max. weight
68 kg (149.91 lb)
Power consumption
Power consumption parameters vary by configuration scheme. For more information, use the query tool for power consumption of the server at http://www.h3c.com/en/home/qr/default.htm?id=291.
Processors
·     2 × fourth-generation Intel Eagle Stream processors, that is, SPR processors or EMR processors:
¡     A maximum of 350 W power consumption per SPR processor and a maximum of 385 W power consumption per EMR processor
¡     Processor-integrated memory controller, supporting eight DIMM channels
¡     Processor-integrated PCIe controller, supporting PCIe5.0, with each processor providing 80 PCIe lanes
¡     Four-channel UPI bus interconnection
·     Supports Montage Jintide processors
For more information about processors, use the component compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
Memory
·     Up to 32 DDR5 DIMMs
·     Up to 4800MT/s for SPR processors and up to 5600 MT/s for EMR processors
·     Support RDIMMs
·     Support processing the maximum of 12 TB with two processors
Storage controllers
·     HBA and smart storage controllers in standard PCIe slots
·     NVMe RAID module
·     Network adapters in standard PCIe slots, 10G/25G/100G/200G network adapters, and 100G/200G/400G IB cards
Chipset
Intel Emmitsburg C741
Network connectors
·     1 × embedded 1 Gbps HDM dedicated management port
·     Up to two OCP 3.0 network adapters (OCP 3.0 network adapters support NCSI and hot swapping)
I/O connectors
·     Connectors at the server front:
¡     1 × USB3.0 connector (on the right chassis ear)
¡     1 × USB2.0 connector (on the left chassis ear)
¡     1 × VGA connector (on the left chassis ear)
¡     1 × HDM dedicated management port (on the left chassis ear)
·     Connectors at the server rear:
¡     2 × USB3.0 connectors
¡     1 × USB2.0 connector (on the system board)
·     1 × RJ-45 HDM dedicated network port
·     1 × VGA connector
·     1 × serial port (available only when the Serial & DSD module is used)
Expansion slots
10 × PCIe standard slots, supporting PCIe 5.0 and two dedicated OCP 3.0 slots
Optical drives
External USB optical drives
Management
·     HDM agentless management tool (with independent management port)
·     H3C iFIST/UniSystem management software
·     (Optional.) U-Center data center management platform
Security
·     Security chassis
·     TCM/TPM
·     Dual-factor authentication
Power supplies
·     (Optional.) 800W/1300W/1600W/2000W/2400W/2700W Platinum power supplies in 1+1 redundancy
·     (Optional.) –48V/336V Titanium DC power supplies in 1+1 redundancy, V-level power supplies certified by CQC31- 46128
·     Support hot swapping
·     Support 1+1 redundancy
Standards
CCC, environmental labeling
Components
Figure 2 R4300 G6 server components
Item
(1) Chassis access panel
N/A
(2) OCP network adapter
Network adapter installed onto the OCP network adapter connector on the system board.
(3) Processor heatsink
Cools the processor.
(4) Processor
Integrates memory and PCIe controllers to provide data processing capabilities for the server.
(5) Storage controller
Provides RAID capability to SAS/SATA drives, including RAID configuration and RAID scale-up. It supports online upgrade of the controller firmware and remote configuration.
(6) Standard PCIe network adapter
Installed in a standard PCIe slot to provide network ports.
(7) Riser card
Provides PCIe slots.
(8) Memory
Stores computing data and data exchanged with external storage temporarily. Both DDR5 and PMem200 are supported.
(9) Processor socket cover
Installed over an empty processor socket to protect pins in the socket.
(10) System board
One of the most important parts of a server, on which multiple components are installed, such as processor, memory, and fan. It is integrated with basic server components, including the BIOS chip and PCIe connectors.
(11) Rear drive backplane
Provides power and data channels for drives at the server rear.
(12) Riser card blank
Installed on an empty PCIe riser connector to ensure good ventilation.
(13) Rear SFF drive cage
Installed at the server rear to accommodate SFF drives.
(14) Rear LFF drive cage
Installed at the server rear to accommodate LFF drives.
(15) Power supply
Supplies power to the server. The power supplies support hot swapping and 1+1 redundancy.
(16) Chassis
Accommodate all components.
(17) Chassis ears
Attach the server to the rack. The right ear is integrated with the front I/O component, and the left ear is integrated with VGA connector, dedicated management connector, and USB 3.0 connector.
(18) Front drive backplane
Provides power and data channels for drives at the server front.
(19) E1.S drive cage
Accommodates E1.S drives.
(20) Drive
Provides data storage space. Drives support hot swapping. The server supports SSD and HDD drives, and multiple drive connectors such as SAS, SATA, M.2, and PCIe.
(21) Supercapacitor holder
Secures a supercapacitor in the chassis.
(22) Supercapacitor
Supplies power to the flash card on the power fail safeguard module, which enables the storage controller to back up data to the flash card for protection when a power outage occurs.
(23) SATA M.2 SSD
Provides data storage space for the server.
(24) NVMe VROC module
Works with Intel VMD to provide RAID capability for the server to virtualize storage resources of NVMe drives.
(25) M.2 expander module
Provides SATA M.2 SSD slots.
(26) GPU module
Provides computing services such as graphics processing and AI.
(27) Fan
Helps server ventilation. Fans support hot swapping and N+1 redundancy.
(28) Fan cage
Accommodates fan modules.
(29) Serial & DSD module
Provides one serial port and two SD card slots.
(30) Encryption module
Provides encryption services for the server to enhance data security.
(31) System battery
Supplies power to the system clock to ensure system time correctness.
(32) Chassis open-alarm module
Detects if the access panel is removed. The detection result can be displayed from the HDM Web interface.
(33) Air baffle
Provides ventilation aisles for processor heatsinks and memory modules and provides support for the supercapacitor.
Front panel
Figure 3 Front panel
Table 1 8LFF front panel description
Item
1
NVMe drives (0 to 5) (optional)
2
USB 3.0 connector
3
Serial label pull tab
4
Dedicated management connector
5
USB 2.0 connector
6
VGA connector
LEDs and buttons
Figure 4 Front panel LEDs and buttons
Table 2 LEDs and buttons on the front panel
Button/LED
Status
Power on/standby button and system power LED
·     Steady green—The system has started.
·     Flashing green (1 Hz)—The system is starting.
·     Steady amber—The system is in standby state.
·     Off—No power is present. Possible reasons:
¡     No power source is connected.
¡     No power supplies are present.
¡     The installed power supplies are faulty.
¡     The system power cords are not connected correctly.
OCP 3.0 network adapter Ethernet port LED
·     Steady green—A link is present on a port of an OCP 3.0 network adapter.
·     Flashing green (1 Hz)—A port on an OCP 3.0 network adapter is receiving or sending data.
·     Off—No link is present on any port of an OCP 3.0 network adapter.
Health LED
·     Steady green—The system is operating correctly or a minor alarm is present.
·     Flashing green (4 Hz)—HDM is initializing.
·     Flashing amber (1 Hz)—A major alarm is present.
·     Flashing red (1 Hz)—A critical alarm is present.
If a system alarm is present, log in to HDM to obtain more information about the system running status.
UID button LED
·     Steady blue—UID LED is activated. The UID LED can be activated by using the following methods:
¡     Press the UID button LED.
¡     Activate the UID LED from HDM.
·     Flashing blue:
¡     1 Hz—The firmware is being upgraded or the system is being managed from HDM. Do not power off the server.
¡     4 Hz—HDM is restarting. To restart HDM, press the UID button LED for eight seconds.
·     Off—UID LED is not activated.
Security bezel light
The security bezel provides hardened security and uses effect light to visualize operation and health status to help inspection and fault location. The default effect light is as shown in Figure 5.
Figure 5 Security bezel
Table 3 Security bezel effect light
System status
Light status
Standby
Steady white: The system is in standby state.
Startup
·     Beads turn on white from middle in turn—POST progress.
·     Beads turn on white from middle three times—POST has finished.
Running
·     Breathing white (gradient at 0.2 Hz)—Normal state, indicating the system load by the percentage of beads turning on from the middle to the two sides of the security bezel.
¡     No loadLess than 10%.
¡     Light load—10% to 50%.
¡     Middle load—50% to 80%.
¡     Heavy loadMore than 80%.
·     Breathing white (gradient at 1 Hz )—A pre-alarm is present.
UID
·     All beads flash white (1 Hz)—The firmware is being upgraded or the system is being managed from HDM. Do not power off the server.
·     Some beads flash white (1 Hz)—HDM is restarting.
Ports
Table 4 Ports on the front panel
Port
VGA connector
DB-15
Connects a display terminal, such as a monitor or KVM device.
USB connector
USB 3.0/2.0
Connects the following devices:
·     USB flash drive.
·     USB keyboard or mouse.
·     USB optical drive for operating system installation.
Type-C
Connects a Type-C to USB adapter cable, which connects to a USB Wi-Fi adapter.
The server supports only Xiaomi USB Wi-Fi adapters.
Rear panel
Rear panel view
Figure 6 Rear panel components
Table 5 Rear panel description
Item
1
PCIe riser bay 1: PCIe slots 1 through 3
2
PCIe riser bay 2: PCIe slots 4 through 6
3
PCIe riser bay 3: PCIe slots 7 and 8
4
PCIe riser bay 4: PCIe slots 9 and 10
5
Power supply 2
6
Power supply 1
7
OCP 3.0 network adapter/Serial & DSD module (in slot 17) (optional)
8
VGA connector
9
Two USB 3.0 connectors
10
HDM dedicated network port (1Gbps, RJ-45, default IP address 192.168.1.2/24)
11
OCP 3.0 network adapter (in slot 16) (optional)
12
LEDs
Figure 7 Rear panel LEDs
(1) Power supply LED for power supply 2
(2) Power supply LED for power supply 1
(3) Activity LED of the Ethernet port
(4) Link LED of the Ethernet port
(5) UID LED
Table 6 LEDs on the rear panel
LED
Status
UID LED
¡     Enable UID LED from HDM.
·     Flashing blue:
¡     4 Hz—HDM is restarting. To restart HDM, press the UID button LED for at least 8 seconds.
·     Steady green—A link is present on the port.
·     Off—No link is present on the port.
·     Flashing green (1 Hz)—The port is receiving or sending data.
·     Off—The port is not receiving or sending data.
Power supply LED
·     Steady green—The power supply is operating correctly.
·     Flashing green (0.33 Hz)—The power supply is in standby state and does not output power.
·     Flashing green (2 Hz)—The power supply is updating its firmware.
·     Steady amber—Either of the following conditions exists:
¡     The power supply is faulty.
¡     The power supply does not have power input, but another power supply has correct power input.
·     Flashing amber (1 Hz)—An alarm has occurred on the power supply.
·     Off—No power supplies have power input, which can be caused by an incorrect power cord connection or power source shutdown.
Ports
Table 7 Ports on the rear panel
Port
VGA connector
DB-15
BIOS serial port
RJ-45
The BIOS serial port is used for the following purposes:
·     Log in to the server when the remote network connection to the server has failed.
·     Establish a GSM modem or encryption lock connection.
USB connector
USB 3.0
·     USB flash drive.
RJ-45
Establishes a network connection to manage HDM from its Web interface.
Power receptacle
Standard single-phase
Connects the power supply to the power source.
System board
Figure 8 System board components
Table 8 System board components
No.
Mark
1
PCIe riser connector 1 (for processor 1)
RISER1 PCIe X16
2
Server management module slot
BMC
3
Fan connector 1 for the OCP 3.0 network adapter
OCP1 FAN
4
OCP 3.0 network adapter connector 1
OCP1
5
SlimSAS connector 1 (x4 SATA or M.2 SSD)
M.2&SATA PORT1
6
AUX connector 7 for the mid drive backplane
AUX7
7
M.2 SSD AUX connector
M.2 AUX
8
Front I/O connector
RIGHT EAR
9
Fan connector 4
J245
10
LCD smart management module connector
DIAG LCD
11
MCIO connector C1-P4A (for processor 1)
C1-P4A
12
MCIO connector C1-P4C (for processor 1)
C1-P4C
13
Fan connector 3
J104
14
MCIO connector C1-P3C (for processor 1)
C1-P3C
15
MCIO connector C1-P3A (for processor 1)
C1-P3A
16
Power connector 3 for front drive backplane
PWR3
17
Power connector 2 for front drive backplane
PWR2
18
Power connector 1 for front drive backplane
PWR1
19
Fan connector 2
J94
20
MCIO connector C2-P4A (for processor 2)
C2-P4A
21
AUX connector 3 for front drive backplane
AUX3
22
MCIO connector C2-P4C (for processor 2)
C2-P4C
23
MCIO connector C2-P3C (for processor 2)
C2-P3C
24
Fan connector 1
J96
25
AUX connector 2 for front drive backplane
AUX2
26
AUX connector 1 for front drive backplane
AUX1
27
MCIO connector C2-P3A (for processor 2)
C2-P3A
28
Power connector 7 for rear drive backplane
PWR7
29
Chassis-open alarm module connector
INTRUDER
30
Power connector 6 for rear drive backplane
PWR6
31
Front VGA and USB 2.0 connector
LEFT EAR
32
Power connector 4 for rear drive backplane
PWR4
33
Power connector 5 for rear drive backplane
PWR5
34
MCIO connector C2-P2C (for processor 2)
C2-P2C
35
AUX connector 4 for rear drive backplane
AUX4
36
MCIO connector C2-P2A (for processor 2)
C2-P2A
37
MCIO connector C2-P1C (for processor 2)
C2-P1C
38
MCIO connector C2-P1A (for processor 2)
C2-P1A
39
AUX connector 5 for rear drive backplane
AUX5
40
Riser card AUX connector 6
AUX6
41
PCIe riser connector 2 (for processor 2)
RISER2 PCIe X16
42
NVMe VROC module connector
NVMe RAID KEY
43
TPM/TCM connector
TPM
44
Fan connector 2 for OCP 3.0 network adapter
45
OCP 3.0 network adapter connector/Serial & DSD module connector
OCP2&DSD&UART CARD
46
AUX8
47
Embedded USB 2.0 connector
INTERNAL USB2.0
48
System battery
49
MCIO connector C1-P2C (for processor 1)
C1-P2C
50
MCIO connector C1-P2A (for processor 1)
C1-P2A
X
MAINTENANCE SW
Figure 9 shows the system maintenance switch. Table 9 describes how to use the maintenance switch.
Figure 9 System maintenance switch
Table 9 System maintenance switch description
Item
Remarks
1
·     Off (default)—HDM login requires the username and password of a valid HDM user account.
·     On—HDM login requires the default username and password.
For security purposes, turn off the switch after you complete tasks with the default username and password as a best practice.
5
·     Off (default)—Normal server startup.
·     On—Restores the default BIOS settings.
To restore the default BIOS settings, turn on and then turn off the switch. The server starts up with the default BIOS settings at the next startup.
CAUTION CAUTION:
The server cannot start up when the switch is turned on. To avoid service data loss, stop running services and power off the server before turning on the switch.
6
·     On—Clears all passwords from the BIOS at server startup.
If this switch is on, the server will clear all the passwords at each startup. Make sure you turn off the switch before the next server startup if you do not need to clear all the passwords.
2, 3, 4, 7, and 8
Reserved for future use.
N/A
DIMM slots
The system board provides eight DIMM channels per processor, and 16 channels in total, as shown in Figure 10. Each channel contains two DIMM slots.
Figure 10 System board DIMM slot layout
For components compatible with the server and detailed component information, use the component compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
The model name of a hardware option in this document might differ slightly from its model name label.
A model name label might add a prefix or suffix to the hardware-coded model name for purposes such as identifying the matching server brand or applicable region. For example, the DDR5-3200-16G-2Rx8-R memory model represents memory module labels including UN-DDR5-3200-16G-2Rx8-R, UN-DDR5-3200-16G-2Rx8-R-F, and UN-DDR5-3200-16G-2Rx8-R-S, which have different prefixes and suffixes.
DIMMs
The server provides eight DIMM channels per processor and each channel has two DIMM slots. If the server has one processor, the total number of DIMM slots is 16. If the server has two processors, the total number of DIMM slots is 32. For the physical layout of DIMM slots, see "DIMM slots."
A DIMM rank is a set of memory chips that the system accesses while writing or reading from the memory. On a multi-rank DIMM, only one rank is accessible at a time.
To determine the rank classification of a DIMM, use the label attached to the DIMM, as shown in Figure 11. The meaning of the DDR DIMM rank classification labels are similar and this section uses the label of a DDR5 DIMM as an example.
Figure 11 DDR DIMM rank classification label
Table 10 DIMM rank classification label description
Callout
Remarks
1
Capacity
Options include:
·     8GB.
·     16GB.
·     32GB.
·     64GB.
·     96GB.
2
Number of ranks
Options include:
·     1R—One rank (Single-Rank).
·     2R—Two ranks (Dual-Rank). A 2R DIMM is equivalent to two 1R DIMMs.
·     4R—Four ranks (Quad-Rank). A 4R DIMM is equivalent to two 2R DIMMs
·     8R—Eight ranks (8-Rank). An 8R DIMM is equivalent to two 4R DIMMs.
3
Data width
Options include:
·     ×4—4 bits.
·     ×8—8 bits.
4
DIMM generation
DDR5
5
Data rate
Options include:
·     2666V—2666 MT/s.
·     2933Y2933 MT/s.
·     3200AA3200 MT/s.
·     48004800 MT/s.
·     56005600 MT/s.
6
DIMM type
Options include:
·     L—LRDIMM.
·     R—RDIMM.
HDDs and SSDs
Drive numbering
The server provides different drive numbering schemes for different drive configurations at the server front and rear.
Figure 12 Drive numbering at the server front
Figure 13 Drive numbering at the server rear
Figure 14 Drive numbering for 8E1.S drive configuration
Drive LEDs
The server supports SAS, SATA, and NVMe (including E1.S) drives, of which SAS and SATA drives support hot swapping and NVMe drives support hot insertion and managed hot removal. You can use the LEDs on a drive to identify its status after it is connected to a storage controller.
For more information about OSs that support hot insertion and managed hot removal of NVMe drives, use the component compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
Figure 15 shows the location of the LEDs on a drive.
Figure 15 LFF&SFF drive LEDs
(1) Fault/UID LED
(2) Present/Active LED
Figure 16 E1.S drive LEDs
26-022-E1.S指示灯-1_画板 1
(1) Fault/UID LED
To identify the status of a SAS or SATA drive, use Table 11. To identify the status of an NVMe drive, use Table 12.
Table 11 SAS/SATA drive LED description
Fault/UID LED status
Present/Active LED status
Flashing amber (0.5 Hz)
Steady green/Flashing green (4.0 Hz)
A drive failure is predicted. As a best practice, replace the drive before it fails.
Steady amber
The drive is faulty. Replace the drive immediately.
Steady blue
The drive is operating correctly and is selected by the RAID controller.
Off
The drive is performing a RAID migration or rebuilding, or the system is reading or writing data to the drive.
Off
Steady green
The drive is present but no data is being read or written to the drive.
Off
Off
The drive is not securely installed.
Table 12 NVMe drive LED description
Flashing amber (4 Hz)
Off
The drive is in hot insertion process.
Steady amber
Steady blue
The drive is operating correctly and selected by the RAID controller.
Off
Off
Steady green
Off
Off
Drive backplanes
The server supports the following types of drive backplanes:
·     SAS/SATA drive backplanesSupport only SAS/SATA drives.
·     UniBay drive backplanesSupport both SAS/SATA and NVMe drives. You must connect both SAS/SATA and NVMe data cables. The number of supported drives varies by drive cabling.
·     X SAS/SATA+Y UniBay drive backplanesSupport SAS/SATA drives in all slots and support NVMe drives in certain slots.
¡     X: Number of slots supporting only SAS/SATA drives.
¡     Y: Number of slots supporting both SAS/SATA and NVMe drives.
For UniBay drive backplanes and X SAS/SATA+Y UniBay drive backplanes:
·     The two drive types are supported only when both SAS/SATA and NVMe data cables are connected.
·     The number of supported SAS/SATA drives and the number of supported NVMe drives vary by cable connection.
The UN-BP-24LFF-P36-G6 drive backplane is installed at the server front to support up to 24 3.5-inch SAS/SATA drives. The drive backplane is integrated with two PMC Expanders. It provides not only two x8 Mini-SAS-HD uplink connectors for connecting storage controllers, but also six downlink connectors for connecting other drive backplanes to support more drives.
Figure 17 24LFF drive backplane
Table 13 24LFF SAS/SATA drive backplane description
Item
Mark
1
x8 Mini-SAS-HD uplink connector 1**
SAS-PORT 1
2
x8 Mini-SAS-HD uplink connector 8*
SAS-PORT 8
3
SlimSAS connector 1 (PCIe4.0 x8), supporting NVMe drives (for drives 0 and 1)
NVMe PORT1
4
SlimSAS connector 2 (PCIe4.0 x8), supporting NVMe drives (for drives 2 and 3)
NVMe PORT2
5
SlimSAS connector 3 (PCIe4.0 x8), supporting NVMe drives (for drives 4 and 5)
NVMe PORT3
6
AUX connector 1
AUX1
7
AUX connector 2
AUX2
8
x4 Mini-SAS-HD downlink connector 3
SAS-PORT 3
9
x4 Mini-SAS-HD downlink connector 4
SAS-PORT 4
10
Power connector 1
PWR1
11
Power connector 2
PWR2
12
AUX connector 3
AUX3
13
x4 Mini-SAS-HD downlink connector 6
SAS-PORT 6
14
x4 Mini-SAS-HD downlink connector 7
SAS-PORT 7
15
x4 Mini-SAS-HD downlink connector 5
SAS-PORT 5
16
x4 Mini-SAS-HD downlink connector 2
SAS-PORT 2
·     If only one storage controller is connected, the server uses the single-version Expander firmware.
¡     *: The connector is disabled.
¡     **: The storage controller connected to this connector can manage all SAS/SATA drives connected to the backplane as well as all SAS/SATA drives connected to the other drive backplanes that are connected to the downlink connectors on this backplane.
·     If two storage controllers are connected, the server uses the dual-version Expander firmware.
¡     *: The storage controller connected to this connector can manage all SAS/SATA drives connected to the other drive backplanes that are connected to the downlink connectors on this backplane through an Expander.
¡     **: The storage controller connected to this connector can manage only all SA/SATA drives connected to this backplane.
·     For information about drive numbering, see Figure 12.
PCIe4.0 x8 description:
·     PCIe4.0: Fourth-generation signal speed.
·     x8: Bus bandwidth.
The UN-BP-24LFF-P48-G6 drive backplane is installed at the server front to support up to 24 3.5-inch SAS/SATA drives. The drive backplane is integrated with one PMC Expander. It provides not only one x8 Mini-SAS-HD uplink connector for connecting a storage controller, but also four downlink connectors for connecting other drive backplanes to support more drives.
Figure 18 24LFF drive backplane
Table 14 24LFF SAS/SATA drive backplane description
Item
Mark
1
SAS-PORT 1
2
NVMe PORT1
3
NVMe PORT2
4
NVMe PORT3
5
AUX connector 2
AUX2
6
AUX connector 1
AUX1
7
Power connector 1
PWR1
8
Power connector 2
PWR2
9
SAS-PORT 7
10
SAS-PORT 6
11
AUX connector 3
AUX3
12
SAS-PORT 5
13
SAS-PORT 2
**: The storage controller connected to this connector can manage all SAS/SATA drives connected to this backplane as well as all SAS/SATA drives connected to the other drive backplanes that are connected to the downlink connectors on this backplane.
PCIe4.0 x8PCIe4.0 x8 description:
The UN-BP-24LFF-P68-G6 drive backplane is installed at the server front to support up to 24 3.5-inch SAS/SATA drives. The drive backplane is integrated with one PMC Expander. It provides not only one x8 Mini-SAS-HD uplink connectors for connecting storage controllers, but also six downlink connectors for connecting other drive backplanes to support more drives.
Figure 19 24LFF drive backplane
Table 15 24LFF SAS/SATA drive backplane description
Item
Mark
1
SAS-PORT 1
2
NVMe PORT1
3
NVMe PORT2
4
NVMe PORT3
5
AUX connector 1
AUX1
6
AUX connector 2
AUX2
7
SAS-PORT 3
8
SAS-PORT 4
9
Power connector 1
PWR1
10
Power connector 2
PWR2
11
AUX connector 3
AUX3
12
SAS-PORT 7
13
SAS-PORT 6
14
SAS-PORT 5
15
SAS-PORT 2
The PCA-BP-12LFF-R4300G5 SAS/SATA drive backplane can be installed at the server rear to support twelve 3.5-inch SAS/SATA drives.
Figure 20 12LFF SAS/SATA drive backplane
Figure 21 12LFF SAS/SATA drive backplane description
Item
Mark
1
AUX connector
AUX
2
x8 Mini-SAS-HD connector (for SAS/SATA drives in the last eight slots connected to the backplane)
SAS PORT 2
3
x4 Mini-SAS-HD connector (for SAS/SATA drives in the first four slots connected to the backplane)
SAS PORT 1
4
Power connector
PWR
The PCA-BP-2LFF-2U-G5 2LFF SAS/SATA drive backplane is installed at the server rear to support two 3.5-inch SAS/SATA drives.
Figure 22 2LFF SAS/SATA drive backplane
Figure 23 2LFF SAS/SATA drive backplane description
Item
Mark
1
SAS PORT1
2
AUX connector
AUX1
3
Power connector
PWR1
The PCA-BP-4LFF-2U-G5 4LFF SAS/SATA drive backplane is installed at the server rear to support four 3.5-inch SAS/SATA drives.
Figure 24 4LFF SAS/SATA drive backplane
Figure 25 4LFF SAS/SATA drive backplane description
Item
Mark
1
AUX connector
AUX
2
Power connector
PWR
3
SAS PORT
The PCA-BP-4LFF-2U-M-G6 4LFF SAS/SATA drive backplane is installed to the mid 4LFF drive cage in the middle of the chassis to support up to four 3.5-inch SAS/SATA drives.
Figure 26 4LFF SAS/SATA drive backplane
Figure 27 4LFF SAS/SATA drive backplane description
Item
Mark
1
AUX connector
AUX1
2
Power connector
PWR1
3
SAS PORT1
The PCA-BP-4SFF-4UniBay-2U-G6 4SFF UniBay drive backplane is installed at the serve rear to support up to four 2.5-inch SAS/SATA/NVMe drives.
Figure 28 4SFF UniBay drive backplane
Figure 29 4SFF UniBay drive backplane description
Item
Mark
1
AUX connector
AUX
2
Power connector
PWR
3
MCIO connector B1/B2 (PCIe5.0 x8)
NVME-B1/B2
4
MCIO connector B3/B4 (PCIe5.0 x8)
NVME-B3/B4
5
SAS PORT
PCIe5.0 x8 description:
·     PCIe5.0: Fifth-generation signal speed.
The PCA-BP-2SFF-2UniBay-2U-G6 UniBay drive backplane is installed at the server rear to support two 2.5-inch SAS/SATA/NVMe drives.
Figure 30 2SFF UniBay drive backplane
Figure 31 2SFF UniBay drive backplane description
Item
Mark
1
Power connector
PWR
2
SAS PORT
3
SlimSAS connector (PCIe4.0 x8)
NVME
4
AUX connector
AUX
The PCA-BP-2SFF-2U-G6 2SFF SAS/SATA drive backplane is installed at the server rear to support up to two 2.5-inch SAS/SATA drives.
Figure 32 2SFF SAS/SATA drive backplane
Figure 33 4SFF UniBay drive backplane description
Item
Mark
1
Power connector
PWR
2
SAS PORT
4
AUX connector
AUX
The PCA-BP-8E1S-2U-G6 8E1.S drive backplane is installed at the server rear to support up to eight 15 mm E1.S drives.
Figure 34 E1.S drive backplane
Figure 35 8E1.S drive backplane description
Item
Mark
1
AUX connector
AUX
2
MCIO connector A1/A2 (PCIe5.0 x8)
EDSFF-A1/A2
3
Power connector 1
PWR 1
4
MCIO connector A3/A4 (PCIe5.0 x8)
EDSFF-A3/A4
5
EDSFF-B1/B2
6
EDSFF-B3/B4
Riser cards
To expand the server with PCIe modules, install riser cards on the PCIe riser connectors.
The server supports the following riser cards:
·     RC-3FHFL-2U-G6
·     RC-3FHHL-2U-G6
·     RC-2HHHL-R4-2U-G6
·     RC-2FHHL-2U-G6
·     RC-1FHHL-2U-G6
For more information about riser cards and installation guidelines for riser cards, see " Replacing riser cards and PCIe modules."
Each PCIe slot in a riser card can supply a maximum of 75 W of power to the PCIe module. You must connect a separate power cord to the PCIe module if it requires more than 75 W of power.
If a processor is faulty or absent, the PCIe slots connected to it are unavailable.
The slot number of a PCIe slot varies by the PCIe riser connector that holds the riser card. For example, slot 1/4 represents PCIe slot 1 if the riser card is installed on connector 1 and represents PCIe slot 4 if the riser card is installed on connector 2. For information about PCIe riser connector locations, see "Rear panel view."
RC-3FHFL-2U-G6
Figure 36 RC-3FHFL-2U-G6 (1)
(1) PCIe5.0 x16 (16,8,4,2,1) slot 2/5
(2) PCIe5.0 x16 (16,8,4,2,1) slot 3/6
(3) GPU module power connector
(4) PCIe5.0 x16 (16,8,4,2,1) slot 1/4*
PCIe5.0 x16 (16,8,4,2,1) description:
·     x16: Connector bandwidth.
·     (16,8,4,2,1): Compatible bus bandwidth, including x16, x8, x4, x2, and x1.
slot 1/4: When the riser card is installed in PCIe riser card slot 1, this slot corresponds to PCIe slot 1. When the riser card is installed in PCIe riser card slot 2, this slot corresponds to PCIe slot 4. This rule applies to all the other PCIe riser card slots. For information about PCIe slots, see "Rear panel view."
Figure 37 RC-3FHFL-2U-G6 (2)
(5) MCIO connector 2-C
(6) MCIO connector 2-A
(7) MCIO connector 1-A
(8) MCIO connector 1-C
RC-3FHHL-2U-G6
Figure 38 RC-3FHHL-2U-G6 (1)
(1) PCIe5.0 x16 (8,4,21) slot 2/5
(2) PCIe5.0 x16 (8,4,2,1) slot 3/6
(3) PCIe5.0 x16 (16,8,4,2,1) slot 1/4*
slot 1/4: When the riser card is installed in PCIe riser connector 1, this slot corresponds to PCIe slot 1. When the riser card is installed in PCIe riser connector 2, this slot corresponds to PCIe slot 4. This rule applies to all the other PCIe riser card slots. For information about PCIe slots, see "Rear panel view."
Figure 39 RC-3FHHL-2U-G6 (2)
(4) MCIO connector 1-A
(5) MCIO connector 1-C
RC-2HHHL-R4-2U-G6
Figure 40 RC-2HHHL-R4-2U-G6
(1) SLOT 2 cable
(2) AUX connector
(3) PCIe5.0 x16 (8,4,2,1) slot 8/10
(4) PCIe5.0 x16 (8,4,2,1) slot 7/9
(5) Power connector
(6) SLOT 1 cable
PCIe5.0 x16 (8,4,2,1) description:
·     (8,4,2,1): Compatible bus bandwidth, including x8, x4, x2, and x1.
slot 7/9: When the riser card is installed in PCIe riser connector 3, this slot corresponds to PCIe slot 7. When the riser card is installed in PCIe riser connector 4, this slot corresponds to PCIe slot 9. This rule applies to all the other PCIe riser card slots. For information about PCIe slots, see "Rear panel view."
RC-2FHHL-2U-G6
Figure 41 RC-2FHHL-2U-G6
(1) PCIe5.0 x16 (8,4,2,1) slot 3/6*
(2) PCIe5.0 x16 (8,4,2,1) slot 2/5
PCIe5.0 x16 (16, 8,4,2,1) description:
slot 3/6: When the riser card is installed in PCIe riser connector 1, this slot corresponds to PCIe slot 3. When the riser card is installed in PCIe riser connector 2, this slot corresponds to PCIe slot 6. This rule applies to all the other PCIe riser card slots. For information about PCIe slots, see "Rear panel view."
RC-1FHHL-2U-G6
Figure 42 RC-1FHHL-2U-G6
Fan modules
The server supports four hot swappable fan modules. The server supports N+1 fan module redundancy. Figure 43 shows the layout of the fan modules in the chassis.
The server supports variable fan speeds. That is, the system can automatically adjust fan speed based on the actual system temperature. This strategy balances system cooling and noise, optimizing both heat dissipation and noise levels.
During system POST and operation, the server will be gracefully powered off through HDM if the temperature detected by any sensor in the server reaches the critical threshold. The server will be powered off directly if the temperature of any key components such as processors exceeds the upper threshold. For more information about the thresholds and detected temperatures, access the HDM Web interface and see HDM online help.
Figure 43 Fan module layout
PCIe slot
The server supports installing riser cards and OCP network adapters. The PCIe slot numbers vary by configuration.
Figure 44 PCIe slot numbering when riser cards are installed at the server rear
PCIe modules
Typically, the PCIe modules are available in the following standard form factors:
·     LP—Low profile.
·     FHHL—Full height and half length.
·     FHFL—Full height and full length.
·     HHHL—Half height and half length.
·     HHFL—Half height and full length.
The following PCIe modules require PCIe I/O resources: Storage controllers, FC HBAs, and GPU modules. Make sure the number of such PCIe modules installed does not exceed 11.
Storage controllers
The server supports the following types of storage controllers:
·     Embedded VROC controllerEmbedded in the server and does not require installation.
·     Standard storage controllerComes in a standard PCIe form factor and typically requires a riser card for installation.
For some storage controllers, you can order a power fail safeguard module to prevent data loss from power outages. This module provides a flash card and a supercapacitor. When a system power failure occurs, the supercapacitor provides power for a minimum of 20 seconds. During this interval, the storage controller can transfer data from DDR memory to the flash card, where the data remains indefinitely or until the controller retrieves the data. If the storage controller contains a built-in flash card, you can order only a supercapacitor.
Item
Specifications
Embedded in PCH of the system board
Number of internal ports
Four internal SAS ports (compatible with SATA)
Connectors
One onboard ×4 SlimSAS connector
Drive interface
6 Gbps SATA 3.0
Supports drive hot swapping
RAID levels
0, 1, 5, 10
Built-in cache memory
N/A
Built-in flash
N/A
Power fail safeguard module
Not supported
Firmware upgrade
Upgrade with the BIOS
Platform Controller Hub (PCH) mainly manages and coordinates the operation of various hardware components, as well as communication with external devices
Standard storage controllers
For more information, use the component compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
NVMe VROC modules
Model
RAID levels
Compatible NVMe SSDs
NVMe-VROC-Key-S
0, 1, 10
All NVMe drives
NVMe-VROC-Key-P
0, 1, 5, 10
All NVMe drives
Figure 45 SATA M.2 expander module front view
(1) SATA data cable connector
(2) SATA M.2 SSD card slot 1
Figure 46 SATA M.2 expander module rear view
(1) SATA M.2 SSD card slot 2
Figure 47 NVMe M.2 expander module
(1) NVMe M.2 SSD card slot 1
(2) NVMe M.2 SSD card slot 2
Figure 48 Rear 2xM.2 drive cage module
(1) M.2 drive backplane power connector
(2) SlimSAS connector (x4 SATA)
(3) Drive cage
The server management module is installed on the system board to provide I/O connectors and HDM out-of-band features for the server.
Figure 49 Server management module
(1) VGA connector
(2) Two USB 3.0 connectors
(3) HDM dedicated management interface
(4) UID LED
(5) HDM serial port
(6) iFIST module (optional)
(7) NCSI connector
Serial & DSD module
The serial & DSD module can be installed in the slot on the server rear panel. The module provides two SD slots and forms RAID 1 by default.
Figure 50 Serial & DSD module
Table 16 Component description
Item
1
SD card slot 1
2
SD card slot 2
3
Serial port
B/D/F information
You can obtain B/D/F information by using one of the following methods:
·     BIOS log—Search the dumpiio keyword in the BIOS log.
·     UEFI shell—Execute the pci command. For information about how to execute the command, execute the help pci command.
·     Operating system—The obtaining method varies by OS.
¡     For Linux, execute the lspci command.
If Linux does not support the lspci command by default, use the software package manager supported by the operating system to obtain and install the pci-utils package.
¡     For Windows, install the pciutils package, and then execute the lspci command.
¡     For VMware, execute the lspci command.
Before you begin
Before you perform a managed removal of an OCP network adapter, perform the following tasks:
·     Use the OS compatibility query tool at http://www.h3c.com/en/home/qr/default.htm?id=66 to obtain operating systems that support managed removal of OCP network adapters.
·     Make sure the BIOS version is 6.00.15 or higher, the HDM2 version is 1.13 or higher, and the CPLD version is V001 or higher.
This section uses an OCP network adapter in slot 16 as an example.
To perform a hot removal:
1.     Access the operating system.
2.     Execute the dmidecode -t 9 command to search for the bus address of the OCP network adapter. As shown in Figure 51, the bus address of the OCP network adapter in slot 16 is 0000:31:00.0.
Figure 51 Searching for the bus address of an OCP network adapter by slot number
3.     Execute the echo 0 > /sys/bus/pci/slots/slot number/power command, where slot number represents the number of the slot where the OCP network adapter resides.
Figure 52 Executing the echo 0 > /sys/bus/pci/slots/slot number/power command
4.     Identify whether the OCP network adapter has been disconnected:
¡     Observe the OCP network adapter LED. If the LED is off, the OCP network adapter has been disconnected.
¡     Execute the lspci vvv s 0000:31:00.0 command. If no output is displayed, the OCP network adapter has been disconnected.
Figure 53 Identifying OCP network adapter status
5.     Replace the OCP network adapter.
6.     Identify whether the OCP network adapter has been connected:
¡     Observe the OCP network adapter LED. If the LED is on, the OCP network adapter has been connected.
¡     Execute the lspci vvv s 0000:31:00.0 command. If an output is displayed, the OCP network adapter has been connected.
Figure 54 Identifying OCP network adapter status
7.     Identify whether any exception exists. If any exception occurred, contact H3C Support.
The operating temperature requirements for the server vary depending on the server model and hardware configuration. When the general and component-based requirements conflict, use the component-based requirement.
Be aware that the actual maximum operating temperature of the server might be lower than what is stated because of poor site cooling performance. In a real data center, the server cooling performance might decrease because of adverse external factors, including poor cabinet cooling performance, high power density inside the cabinet, or insufficient spacing between devices.
Item
Specifications
Minimum: 5°C (41°F)
Maximum: 40°C (104°F)
CAUTION CAUTION:
The maximum temperature varies by hardware option presence. For more information, see "Operating temperature requirements."
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Operating humidity
8% to 90%, noncondensing
Storage humidity
5% to 95%, noncondensing
Operating altitude
–60 m to +3000 m (–196.85 ft to +9842.52 ft)
The allowed maximum temperature decreases by 0.33°C (32.59°F) as the altitude increases by 100 m (328.08 ft) from 900 m (2952.76 ft)
Storage altitude
–60 m to +5000 m (–196.85 ft to +16404.20 ft)
General guidelines
The cooling capability of the server depends on the power density of devices within the cabinet, the cooling capability of the cabinet, and the spacing between the server and other devices. When the server is stacked with other devices, the maximum operating temperature of the server might decrease.
When mid drives are installed, processors of 165W are not supported and smart network adapters and GPUs are not supported either.
When CRPS-195mm 2000 W Platinum AC power supplies are configured, the maximum operating temperatures are 3°C (37.4°F) lower than those described in the table.
Slot 3 does not support a GPU, a network adapter of 100G or higher, or a smart network adapter.
When a fan module fails or a single rotor of a dual-rotor fan module fails, the maximum server operating temperature decreases by 5°C (41°F). The GPU performance and performance of processors with a TDP of more than 165 W might decrease.
Table 17 Operating temperature requirements
Drive configuration
Maximum operating temperature
30°C
35°C
40°C
24LFF+12LFF
·     The server does not processors of 165W are not supported when A2/L4 GPUs are installed
·     The server does not support processors of 270W when HDD drives (excluding rear 12LFF drives), rear NVMe SSDs and E1.S drives are installed
·     The server does not support smart network adapters
·     The server does not support processors of 205W when HDD drives (excluding rear 12LFF drives), rear NVMe SSDs and E1.S drives are installed
·     The server does not support processors of 300W when SATA/SAS SSD drives (excluding rear 12LFF drives) are installed
·     The server does not support processors of 300W when network adapters of 100G or higher are installed
·     Smart network adapters are not supported
·     Mid drives are not supported
·     GPUs are not supported
·     NVMe SSDs (including U.2 and AIC) are installed
·     Mid drives and rear drives are installed
·     Processors with power consumption greater than 135W are not supported
·     Network adapters of 100G or higher, OCP network adapters of 100G or higher, and smart network adapters are not supported
New H3C Technologies Co., Ltd. provides product recycling services for its customers to ensure that hardware at the end of its life is recycled. Vendors with product recycling qualification are contracted to New H3C to process the recycled hardware in an environmentally responsible way.
For product recycling services, contact New H3C at
·     Tel: 400-810-0504
·     E-mail: [email protected]
·     Website: http://www.h3c.com
Appendix F  Glossary
Item
B
BIOS
Basic input/output system is non-volatile firmware pre-installed in a ROM chip on a server's management module. The BIOS stores basic input/output, power-on self-test, and auto startup programs to provide the most basic hardware initialization, setup and control functionality.
C
CPLD
Complex programmable logic device is an integrated circuit used to build reconfigurable digital circuits.
G
GPU module
Graphics processing unit module converts digital signals to analog signals for output to a display device and assists processors with image processing to improve overall system performance.
H
HDM
Hardware Device Management is the server management control unit with which administrators can configure server settings, view component information, monitor server health status, and remotely manage the server.
Hot swapping
A module that supports hot swapping (a hot-swappable module) can be installed or removed while the server is running without affecting the system operation.
K
KVM
KVM is a management method that allows remote users to use their local video display, keyboard, and mouse to monitor and control the server.
N
NVMe VROC module
A module that works with Intel VMD to provide RAID capability for the server to virtualize storage resources of NVMe drives.
R
RAID
Redundant array of independent disks (RAID) is a data storage virtualization technology that combines multiple physical hard drives into a single logical unit to improve storage and security performance.
Redundancy
A mechanism that ensures high availability and business continuity by providing backup modules. In redundancy mode, a backup or standby module takes over when the primary module fails.
S
Security bezel
A locking bezel mounted to the front of a server to prevent unauthorized access to modules such as hard drives.
U
U
A unit of measure defined as 44.45 mm (1.75 in) in IEC 60297-1. It is used as a measurement of the overall height of racks, as well as equipment mounted in the racks.
A UniBay drive backplane supports both SAS/SATA and NVMe drives.
UniSystem
UniSystem provided by H3C for easy and extensible server management. It can guide users to configure a server quickly with ease and provide an API interface to allow users to develop their own management tools.
V
VMD
VMD provides hot removal, management and fault-tolerance functions for NVMe drives to increase availability, reliability, and serviceability.
Appendix G  Acronyms
Acronym
Full name
B
BIOS
Basic Input/Output System
C
CMA
Cable Management Arm
CPLD
Complex Programmable Logic Device
D
DCPMM
Data Center Persistent Memory Module
DDR
Double Data Rate
DIMM
Dual In-Line Memory Module
DRAM
Dynamic Random Access Memory
DVD
Digital Versatile Disc
G
GPU
Graphics Processing Unit
H
HBA
Host Bus Adapter
HDD
Hard Disk Drive
HDM
I
IDC
Internet Data Center
iFIST
integrated Fast Intelligent Scalable Toolkit
K
KVM
Keyboard, Video, Mouse
L
LRDIMM
Load Reduced Dual Inline Memory Module
N
NCSI
Network Controller Sideband Interface
NVMe
Non-Volatile Memory Express
P
PCIe
Peripheral Component Interconnect Express
POST
Power-On Self-Test
R
RAID
Redundant Array of Independent Disks
RDIMM
Registered Dual Inline Memory Module
S
SAS
Serial Attached Small Computer System Interface
SATA
Serial ATA
SD
Secure Digital
SDS
Secure Diagnosis System
SFF
Small Form Factor
sLOM
Small form factor Local Area Network on Motherboard
SSD
Solid State Drive
T
TCM
Trusted Cryptography Module
TDP
Thermal Design Power
TPM
Trusted Platform Module
U
UID
Unit Identification
UPI
Ultra Path Interconnect
UPS
Uninterruptible Power Supply
USB
Universal Serial Bus
V
VROC
Virtual RAID on CPU
VMD
Volume Management Device
