04-Hardware management and maintenance | 96.67 KB |
4 Hardware management and maintenance
Displaying hardware information about the device
Displaying software and hardware version information about the device
Displaying the operational statistics about the device
Displaying information about the device
Displaying electrical label information for the device
Displaying the CPU usage of the device
Displaying the memory usage of the device
Displaying the operational status of the built-in fans
Displaying the operating state of power modules
The command lines and outputs depend on the software version that runs on the device.
Use the display version command to display software and hardware version information about the device. The output includes the following information:
· Current software version.
· Current hardware version.
· Device operating time.
The output depends on the software and hardware version of the device.
<H3C> display version
H3C Comware Software, Version 7.1.064, ESS 5610
Copyright (c) 2004-2022 New H3C Technologies Co., Ltd. All rights reserved.
H3C WX2880X uptime is 4 weeks, 0 days, 0 hours, 46 minutes
Last reboot reason : User soft reboot
Boot image: flash:/boot.bin
Boot image version: 7.1.064, ESS 5610
Compiled May 20 2022 15:00:00
System image: flash:/system.bin
System image version: 7.1.064, ESS 5610
with 1 2200MHz Multi-core Processor
4096M bytes DDR4
7456M bytes EMMC Memory
Hardware Version is Ver.A
CPLD Version is 002
Basic Bootrom Version is 1.08
Extend Bootrom Version is 1.08
[Subslot 0]WX2880X Hardware Version is Ver.A
When you perform routine maintenance or the system fails, you might need to display the operational information of each feature module to locate failures. Typically, you need to run the display commands individually. However, you can use the display diagnostic-information command in any view to display or save the operational statistics of multiple feature modules of the device. This command displays the output of the display clock, display version, display device, and display current-configuration commands.
· Save the operational statistics for each feature module of the device:
<H3C>display diagnostic-information
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_H3C_20220713-091818.tar.gz]:
Diagnostic information is outputting to flash:/diag_H3C_20220713-091818.tar.gz.
Please wait...
Save successfully.
To view the contents of the default.diag file, execute the more default.diag command in user view, and then press the Page Up and Page Down keys.
· Display the operational statistics for each feature module of the device. (Details not shown.)
<H3C> display diagnostic-information
09:18:31 UTC Wed 07/13/2022
H3C WX2880X uptime is 4 weeks, 0 days, 0 hours, 47 minutes
4096M bytes DDR4
Use the display device command to display information about the device.
<H3C> display device
Slot No. Subslot No. Board Type Status Max Ports
1 0 WX2880X Normal 12
Table4-1 Command output
Board Type |
Device type. |
Status |
Device status: · Fault—The device is faulty and cannot start up correctly. · Normal—The device is operating correctly. |
Max Ports |
Maximum number of ports supported. |
An electrical label is a profile of a device. It contains the permanent configuration, including the serial number, manufacturing date, MAC address, and vendor name.
Use the display device manuinfo command to display the electrical label information for the device.
<H3C> display device manuinfo
DEVICE_NAME:WX2880X
DEVICE_SERIAL_NUMBER:219801A3TM8216E00001
MAC_ADDRESS:5CA7-21EE-F860
MANUFACTURING_DATE:2022-01-14
VENDOR_NAME:H3C
Table4-2 Command output
DEVICE_NAME |
Device model. |
DEVICE_SERIAL_NUMBER |
Serial number of the device. |
MAC_ADDRESS |
MAC address of the device. |
MANUFACTURING_DATE |
Manufacturing data of the device. |
VENDOR_NAME |
Vendor name. |
Use the display cpu-usage command to display the CPU usage statistics for the device.
<H3C> display cpu-usage
Unit CPU usage:
3% in last 5 seconds
3% in last 1 minute
3% in last 5 minutes
Table4-3 Command output
3% in last 5 seconds |
Average CPU usage in the last 5 seconds (after the device boots, the device calculates and records the average CPU usage at the interval of 5 seconds). |
3% in last 1 minute |
Average CPU usage in the last minute (after the device boots, the device calculates and records the average CPU usage at the interval of 1 minute). |
3% in last 5 minutes |
Average CPU usage in the last 5 minutes (after the device boots, the device calculates and records the average CPU usage at the interval of 5 minutes). |
Use the display memory command to display the memory usage statistics for the device.
<H3C>display memory
Memory statistics are measured in KB:
Slot 1:
Total Used Free Shared Buffers Cached FreeRatio
Mem: 4027756 712064 3315692 0 9836 287052 82.8%
-/+ Buffers/Cache: 415176 3612580
Swap: 0 0 0
Mem |
Memory usage information. |
Total |
Total size of the physical memory space that can be allocated. |
Used |
Used physical memory. |
Free |
Free physical memory. |
Shared |
Physical memory shared by processes. |
Buffers |
Physical memory used for buffers. |
Cached |
Used physical memory for cache. |
FreeRatio |
Free memory ratio. |
–/+ Buffers/Cache |
· -/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications. · -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications. |
Swap |
Swap memory. |
Use the display fan command to display the operating states of fans.
<H3C> display fan
Fan 1 State: Normal
Table4-5 Command output
Fan n |
Fan No.. |
State |
Fan state: · Normal—The fan is operating correctly. · Absent—The fan is not in position. |
Use the display power command to display the operating state of power modules.
<H3C> display power
Power 1 State: Normal
Power 2 State: Abnormal
Table4-6 Command output
Power 1,2 |
Power module No.. |
State |
Power module state: · Normal—The power module is operating correctly. · Absent—The power module is not in position. |
Rebooting the device
To reboot the device, use one of the following methods:
· Reboot the device at the CLI. You can remotely reboot the device in either of the following ways:
¡ Reboot the device immediately by using the reboot command.
¡ Schedule a reboot to occur at a specific time or date or after a delay by using the schedule reboot command.
· Power off and power on the device. This method cuts off the power of the device forcibly, which might cause data loss. It is the least-preferred method.
· Before you reboot the device, perform the following tasks:
¡ Use the save command to save the running configuration. For more information about the save command, see configuration file management commands in the command references.
¡ Use the display startup and display boot-loader commands to verify that you have specified the correct next-startup configuration files and startup software images. If the main startup software image is corrupt or does not exist, a reboot failure will occur. To avoid a reboot failure, use the boot-loader file command to specify a new startup software image. For more information about the display startup and display boot-loader commands, see software upgrade commands in the command references.
· The device will not reboot if a file is being accessed.
Configuration procedure
Rebooting the device immediately
Task |
Command |
Remarks |
Reboot the device immediately. |
reboot [ force ] |
Available in user view. |
Scheduling a reboot for the device
Task |
Command |
Remarks |
Schedule a reboot. |
· Schedule a reboot to occur at a specific time or date: · Schedule a reboot to occur after a delay: |
Use either command. By default, no reboot date or time or reboot delay time is specified. Available in user view. The most recent configuration takes effect if you execute the scheduler reboot at or scheduler reboot delay command multiple times. |
