| 00-Preface | 99.25 KB |
Preface
This installation guide describes the installation procedures for the WX2812X-PWR access controller, including preparing for installation, installing the access controller, and accessing the access controller.
· Audience
Audience
· Network planners.
· Network administrators working with the WX2812X-PWR access controller.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
Your comments or suggestions would be highly appreciated.
