03-Layer 2—LAN Switching Configuration Guide
HomeSupportSwitchesS5590-EI SeriesConfigure & DeployConfiguration GuidesH3C S5590-HI[S5590-EI][S5500V3-HI] Switch Series Configuration Guides-R8307Pxx-6W10103-Layer 2—LAN Switching Configuration Guide
17-Cut-through Layer 2 forwarding configuration
Configuring cut-through Layer 2 forwarding
About cut-through Layer 2 forwarding
A cut-through forwarding-enabled device forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame and enhances forwarding performance.
Restrictions and guidelines for cut-through Layer 2 forwarding configuration
With cut-through forwarding, the device forwards CRC-error frames because it starts forwarding frames before their CRC field is received.
In an IRF fabric, cut-through forwarding does not take effect for traffic where the ingress and egress ports are not on the same member device.
Cut-through forwarding takes effect only for unicast packets.
2.     Enable cut-through forwarding.
cut-through enable
By default, cut-through forwarding is disabled.
