14-Network Management and Monitoring Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S9825 & S9855 Switch Series Configuration Guides-R913x-6W10114-Network Management and Monitoring Configuration Guide
11-NetAnalysis configuration
11-NetAnalysis configuration 190.42 KB
Configuring NetAnalysis
About NetAnalysis
NetAnalysis is a network traffic monitoring and analysis technology that performs in-depth analysis of service flows to obtain performance statistics about the service flows, such as packet loss rate and latency. NetAnalysis can send the analysis results to a NetAnalysis processor for analysis and display, which helps you monitor the network operation status and locate network faults.
NetAnalysis architecture
A typical NetAnalysis system consists of the following elements:
·     NetAnalysis data exporter (NDE)—Uses an ACL to match the service flows to be analyzed and replicates them to a NetAnalysis processor.
·     NetAnalysis processor (NAP)—Receives, processes, and analyzes service flows, and outputs the results to a NetAnalysis data analyzer.
·     NetAnalysis data analyzer (NDA)—Provides a Web interface for obtaining, displaying, and analyzing service flow data.
Typically, an NDE and an NAP are collocated on a device. As shown in Figure 1, when a service flow and its return traffic are forwarded along the same path, all devices on the path obtain bidirectional traffic of the service flow. You can configure NetAnalysis on these devices to analyze the flow to obtain performance statistics such as packet loss rate and latency.
Figure 1 NetAnalysis system
NetAnalysis workflow
As shown in Figure 2, NetAnalysis works as follows:
1.     The NDE uses ACLs to match the service flows monitored by NetAnalysis and replicates the service flows to the NAP.
2.     The NAP creates a flow table for each received service flow to analyze it if the service flow meets CM connection setup requirements. The NAP drops a service flow if the service flow does not meet those requirements or the NAP is overloaded. For more information about CM connection setup, see "CM connection setup."
3.     The NAP encapsulates the analysis results into packets destined for the NDA and sends the packets to the NDA for analysis and display.
Figure 2 NetAnalysis workflow
Configuring NetAnalysis for RoCEv2 traffic
About NetAnalysis for RoCEv2 traffic
Remote direct memory access (RDMA) is a direct memory access technology used in InfiniBand networks to resolve the delay of data processing on servers. RDMA transmits data directly through the network from one system to another system without involving either one's operating system. CPUs do not process the data in transmission, which increases the bandwidth and reduces latency and resource usage.
RDMA over converged Ethernet version 2 (RoCEv2) is an RDMA technology used on Ethernet networks. RoCEv2 is widely used to reduce the latency caused by CPU processing and improve application performance in TCP/IP transmission for high-performance computing, distributed storage, and AI. In these scenarios, multiple nodes might send packets simultaneously to the same node, and the burst of traffic will congest queues or even cause packet loss on the destination node. As a result, the network latency increases, and traffic throughput drops. To resolve the issues, configure NetAnalysis to monitor the status of RoCEv2 networks by analyzing RoCEv2 flow data such as packet loss, latency, throughput, and forwarding path.
RoCEv2 packet format
RoCEv2 is a network layer protocol that enables Layer 3 communication between broadcast domains. RoCEv2 encapsulates packets based on the UDP encapsulation. Figure 3 shows the format of an RoCEv2 packet.
Figure 3 RoCEv2 packet format
An RoCEv2 packet contains the following fields:
·     Ethernet header—Includes the source and destination MAC addresses.
·     IP header—Includes the source and destination IP addresses.
·     UDP header—Includes the source and destination port numbers. The destination port number is fixed at 4791.
·     InfiniBand base transport header—Includes key fields monitored by NetAnalysis.
·     IB payload.
·     ICRC and FCS.
The InfiniBand base transport header contains the following fields:
·     Opcode—RoCEv2 packet type indicating the operation mode. Available values for this field include the following:
¡     ConnectMsg—The packet is used for setting up an RoCEv2 connection. The connection is called a communication management (CM) connection. Devices in an RoCEv2 network transmit data packets through CM connections.
¡     Send—The packet is sent to the remote end without specifying where the receiver stores data.
¡     Write—The packet carries the address, key, and length of data to be written to the remote end.
¡     Read—The packet carries the address, key, and length of data to be read from the remote end. RoCEv2 packets of the Send, Write, and Read types are analyzed during throughput analysis.
¡     ACK—The packet is a response message returned by the receiver. Based on the ACK extended transport header unique to RoCEv2 ACK packets, an ACK packet can be one of the following types:
-     Common ACK packet indicating that data is received successfully.
-     NAK packet that indicates packet loss.
·     Dest QP—Destination QP that identifies an RoCEv2 flow. This field is similar to the destination port number. It is a key value used by NetAnalysis to create an RoCEv2 flow table.
·     PSN—Sequence number of the RoCEv2 packet. Packet loss is determined by checking whether the PSNs of packets are consecutive. If packet loss occurs, the receiver returns an NAK packet.
CM connection setup
RDMA sets up CM connections based on RoCE packets or TCP packets with custom fields. NetAnalysis can analyze the RoCE packets and TCP packets used for CM connection setup. The analysis process does not differ much between the packet types. The following information uses RoCE packet-based CM connection setup as an example.
Figure 4 shows the process of CM connection setup.
Figure 4 CM connection setup process
The CM connection setup procedure is as follows:
1.     The client sends a Connect Request to the server to request RoCEv2 connection setup.
2.     After receiving the Connect Request, the server replies with a Connect Reply. After receiving this packet, the client determines that an RoCEv2 connection has been set up with the server.
3.     The client sends a ReadyToUse packet to the server. After receiving this packet, the server determines that the CM connection is set up successfully.
RoCEv2 flow analysis
After NetAnalysis is enabled to collect RoCEv2 traffic statistics on the device, the NDE issues rules for matching RoCEv2 packets based on the Opcode field. The NAP creates flow entries to form an RoCEv2 flow table based on the 4-tuple information in RoCEv2 connection setup packets. The 4-tuple information is the IP address of the client, IP address of the server, QP of the client, and QP of the server.
The NAP collects statistics about key fields in the flow table that is created based on the RoCEv2 data packets sent by the NDE, and analyzes the statistics to obtain characteristics of the RoCEv2 flow. You can view the statistics in the flow table on the device, and the statistics are exported to the NDA for display and analysis after the flow ages out.
RoCEv2 flow aging
The RoCEv2 flow aging mechanism allows the device to output flow statistics to the NDA. After NetAnalysis is enabled to analyze RoCEv2 traffic, the device saves flow statistics in the RoCEv2 cache. When an RoCEv2 flow ages out, the device exports the related flow statistics to the NDA and deletes the flow statistics from the RoCEv2 cache to save cache space.
Only inactive RoCEv2 flows age out. The device starts an inactive flow aging timer after receiving a packet for a flow. If the device has not received any packet for the flow when the timer expires, the flow ages out. To save cache space, the device will delete the sessions for inactive flows and notifies the NDA of the deletion events.
RoCEv2 flow filtering
NetAnalysis can use ACLs to filter the RoCEv2 flows that traverse the device. You can use this feature to collect statistics about the RoCEv2 flows of interest. For more information about ACLs, see ACL and QoS Configuration Guide.
Restrictions and guidelines: NetAnalysis configuration
NetAnalysis is not supported for M-LAG.
An S9825 switch cannot be managed by a controller if it is enable with the NetAnalysis statistics feature for RoCEv2 traffic within a VXLAN tunnel.
NetAnalysis for RoCEv2 traffic tasks at a glance
To configure NetAnalysis to analyze RoCEv2 traffic, perform the following tasks:
1.     Setting the mode of RoCEv2 traffic analysis
2.     Enabling RoCEv2 traffic statistics collection
3.     Enabling RoCEv2 packet loss analysis globally
4.     (Optional.) Enabling AI ECN for RoCEv2 traffic statistics collection
5.     (Optional.) Setting the interval for reporting RoCEv2 traffic statistics to the NDA
6.     (Optional.) Setting the sampling rate for RoCEv2 packets
7.     (Optional.) Setting the aging timer for inactive RoCEv2 flows
8.     (Optional.) Enabling the NetAnalysis statistics feature for RoCEv2 traffic within a VXLAN tunnel
9.     (Optional.) Enabling the global packet loss analysis feature for RoCEv2 traffic within a VXLAN tunnel
As shown in Figure 5, NetAnalysis can use either of the following modes for RoCEv2 traffic analysis when multiple paths exist between an RoCEv2 client and an RoCEv2 server:
·     Bidirectional mode—NetAnalysis monitors bidirectional traffic sent between the server and the client. Based on the 4-tuple information in CM connection setup packets, NetAnalysis can collect RoCEv2 traffic statistics based on sessions and provide the session-specific RTT and lost packet count.
·     Unidirectional mode—NetAnalysis monitors the traffic sent from the client to the server to obtain the 3-tuple information used for creating RoCEv2 flow entries. In this mode, NetAnalysis collects RoCEv2 traffic statistics based on flows and provides only packet throughput information.
As a best practice to ensure correct RoCEv2 traffic analysis, configure the mode of RoCEv2 traffic analysis as follows:
·     Enable bidirectional mode on the devices attached to the server and the client (Device C and Device D).
·     Enable unidirectional mode on the intermediate devices (Device A and Device B).
Figure 5 Mode of RoCEv2 traffic analysis
For NetAnalysis features to take effect, first set the mode of RoCEv2 traffic analysis.
When you change the mode of RoCEv2 traffic analysis, all NetAnalysis configuration and the RoCEv2 cache are cleared. Make sure you are fully aware of the impact of this operation when you perform it on a live network.
In a spine-leaf network with multiple spine devices, as a best practice to ensure the successful setup of CM connections, set the mode of RoCEv2 traffic analysis to unidirectional on intermediate nodes. If you set mode of RoCEv2 traffic analysis to bidirectional, the connection requests and connections replies might be forwarding through different spine devices, causing CM connection setup failures.
2.     Set the mode of RoCEv2 traffic analysis.
netanalysis rocev2 mode { bidir | single }
By default, RoCEv2 traffic analysis is disabled, and the mode of RoCEv2 traffic analysis is not set.
Perform this task to enable NetAnalysis to analyze RoCEv2 traffic and send the analysis results to the NAP. You can use an ACL to match the RoCEv2 traffic of interest. The deny or permit action in the ACL does not take effect. NetAnalysis supports the following rules of advanced ACLs:
·     Rule 1—Matches the UDP protocol and destination IPv4 address.
·     Rule 2—Matches the UDP protocol and source IPv4 address.
·     Rule 3—Matches the UDP protocol and source and destination IPv4 addresses.
To ensure correct collection and reporting of RoCEv2 traffic statistics, use the rules supported by NetAnalysis. For more information about ACLs, see ACL and QoS Configuration Guide.
The netanalysis rocev2 statistics global command and the netanalysis rocev2 vxlan statistics acl name acl-name command are mutually exclusive on an S9825 switch. If you execute one command, the other command cannot be executed successfully.
2.     Enable RoCEv2 traffic statistics collection.
netanalysis rocev2 statistics { global | acl name acl-name }
By default, RoCEv2 traffic statistics collection is disabled.
This task enables the device to perform RoCEv2 packet loss analysis for all received RoCEv2 packets.
For RoCEv2 packet loss analysis to take effect, first enable bidirectional mode for RoCEv2 traffic analysis.
2.     Enable RoCEv2 packet loss analysis globally.
netanalysis rocev2 drop global
By default, RoCEv2 packet loss analysis is disabled globally.
AI ECN allows the device to collect RoCEv2 traffic statistics on a per-session basis on the outgoing interfaces for RoCEv2 traffic and send the RoCEv2 traffic statistics to the NDA. Based on the RoCEv2 traffic statistics, the NDA automatically adjusts the ECN threshold for lossless queues to ensure low latency and high throughput for lossless traffic. For more information about ECN, see QoS configuration in ACL and QoS Configuration Guide.
2.     Enable AI ECN for RoCEv2 traffic statistics collection.
netanalysis rocev2 ai-ecn enable
By default, AI ECN is disabled for RoCEv2 traffic statistics collection.
Perform this task to adjust the interval at which the device reports RoCEv2 traffic statistics to the NDA.
2.     Set the interval for reporting RoCEv2 traffic statistics to the NDA.
netanalysis rocev2 report-interval interval
By default, the device reports RoCEv2 traffic statistics to the NDA at an interval of 10 seconds.
A sampling rate allows the device to sample one packet from a number of RoCEv2 packets for analysis. For example, if you configure the sampling rate as 1000, the device samples one packet from 1000 RoCEv2 packets.
For the sampling rate to take effect, first set the mode of RoCEv2 traffic analysis.
2.     Set the sampling rate for RoCEv2 packets.
netanalysis rocev2 sampling-rate rate
The default is setting is 100000.
When an inactive RoCEv2 flow ages out, the device outputs the related traffic statistics to the NDA, deletes these traffic statistics from the RoCEv2 cache, and deletes the related flow entries.
2.     Set the aging timer for inactive RoCEv2 flows.
netanalysis rocev2 timeout inactive seconds
By default, the aging timer for inactive RoCEv2 flows is set to 30 seconds.
To understand and optimize network performance, and to enhance the transmission speed and reliability, you can configure the NetAnalysis statistics feature for RoCEv2 traffic within a VXLAN tunnel.
By using this feature, you can perform NetAnalysis statistical analysis on RoCEv2 traffic at the VXLAN tunnel edges or intermediate nodes. The device characterizes each traffic flow's data, including volume, bandwidth, and latency, and uploads the analysis results.
The specified RoCEv2 traffic is matched through ACL rules, but the designated deny or permit actions do not take effect. Currently, only the following advanced ACL rules are supported:
·     rule1—Configures only the UDP protocol and destination IPv4 address.
·     rule2—Configures only the UDP protocol and source IPv4 address.
·     rule3—Configures only the UDP protocol, source IPv4 address, and destination IPv4 address.
Unsupported ACL rules do not take effect, preventing NAP from receiving the matched traffic flows. For more information about ACL rule configuration, see ACL and QoS Configuration Guide.
This feature can collect staticstics for only RoCEv2 traffic within the same data center and cannot collect staticstics for VXLAN-DCI tunnel RoCEv2 traffic across data centers.
The netanalysis rocev2 vxlan statistics command and the netanalysis rocev2 vxlan-ip statistics command are mutually exclusive. If you execute one command, the other command cannot be executed successfully.
Enabling the NetAnalysis statistics feature for RoCEv2 traffic on VXLAN tunnel intermediate nodes
2.     Enable the NetAnalysis statistics feature for RoCEv2 traffic on VXLAN tunnel intermediate nodes.
netanalysis rocev2 vxlan statistics { acl name acl-name | global }
By default, the NetAnalysis statistics feature is disabled for RoCEv2 traffic on VXLAN tunnel intermediate nodes.
Enabling the NetAnalysis statistics feature for RoCEv2 traffic at the VXLAN tunnel edges
2.     Enable the NetAnalysis statistics feature for RoCEv2 traffic at the VXLAN tunnel edges.
netanalysis rocev2 vxlan-ip statistics { acl name acl-name | global }
By default, the NetAnalysis statistics feature is disabled for RoCEv2 traffic at the VXLAN tunnel edges.
In a VXLAN network with RoCEv2, ensuring zero packet loss for network traffic is crucial. You can configure this feature to analyze packet loss for decapsulated RoCEv2 traffic at both intermediate and edge nodes within the VXLAN tunnel.
For this feature to take effect, you must first set the mode of RoCEv2 traffic analysis to bidirectional.
This feature can perform packet loss analysis for only RoCEv2 traffic within the same data center and cannot perform packet loss analysis for VXLAN-DCI tunnel RoCEv2 traffic across data centers.
Enabling the global packet loss analysis feature for RoCEv2 traffic on VXLAN tunnel intermediate nodes
2.     Enable the global packet loss analysis feature for RoCEv2 traffic on VXLAN tunnel intermediate nodes.
netanalysis rocev2 vxlan drop global
By default, the global packet loss analysis feature is disabled for RoCEv2 traffic on VXLAN tunnel intermediate nodes.
Enabling the global packet loss analysis feature for RoCEv2 traffic at the VXLAN tunnel edges
2.     Enable the global packet loss analysis feature for RoCEv2 traffic at the VXLAN tunnel edges.
netanalysis rocev2 vxlan-ip drop global
By default, the global packet loss analysis feature is disabled for RoCEv2 traffic at the VXLAN tunnel edges.
Display and maintenance commands for NetAnalysis for RoCEv2 traffic
Display configuration and status of the RoCEv2 cache.
display netanalysis rocev2 cache [destination destination-ip | dstvxlan-id dstvxlan-id | source source-ip | srcvxlan-id srcxlan-id ] *
Display RoCEv2 traffic statistics.
display netanalysis rocev2 statistics
Clear RoCEv2 traffic statistics.
reset netanalysis rocev2 statistics
NetAnalysis for RoCEv2 traffic configuration examples
Example: Configuring NetAnalysis to analyze RoCEv2 traffic
As shown in Figure 6, configure NetAnalysis on the device to analyze the bidirectional RoCEv2 traffic sent between the server and the client and output the RoCEv2 traffic statistics to the NDA.
Figure 6 Network diagram
1.     Assign an IP address to each interface, as shown in Figure 6. (Details not shown.)
2.     Configure NetAnalysis to analyze RoCEv2 traffic:
# Enable bidirectional RoCEv2 traffic analysis.
[Device] netanalysis rocev2 mode bidir
# Enable global RoCEv2 traffic statistics collection.
[Device] netanalysis rocev2 statistics global
# Display configuration and status of the RoCEv2 cache after the device has been operating for a period of time.
[Device] display netanalysis rocev2 cache
S2D: source to destination              D2S: destination to source
RTT: round trip time                    RPT: packet throughput in read mode
WPT: packet throughput in write mode    SPT: packet throughput in send mode
I: input          O: output             L: local          R: remote
NetAnalysis cache information:
Flow created at        Service type
Src IP                 Src QP        S2D RTT      S2D RPT      S2D SPT/WPT
S2D NAK Pkts           S2D Interface(I)           S2D Interface(O)
S2D Src VXLAN ID       S2D Dst VXLAN ID
Dst IP                 Dst QP        D2S RTT      D2S RPT      D2S SPT/WPT
D2S NAK Pkts           D2S Interface(I)           D2S Interface(O)
D2S Src VXLAN ID       D2S Dst VXLAN ID
01/22/2019 09:08:15    RC
11.110.2.2             93309         50           11           11
2                      HGE1/0/1(L)                 HGE1/0/2(L)
10                     10
12.110.2.2             85353         50           11           11
8373                   HGE1/0/2(L)                 HGE1/0/1(L)
10                     10
# Display RoCEv2 traffic statistics.
[Device] display netanalysis rocev2 statistics
Last statistics resetting time: Never
Received packets: 1833088
         Active         Aged           Created         Reported
        (Sessions)     (Sessions)     (Sessions)      (Sessions)
RoCEv2
        2               0               2              10
