- 05-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-M-LAG commands
- 04-Port isolation commands
- 05-VLAN commands
- 06-QinQ commands
- 07-Loop detection commands
- 08-Spanning tree commands
- 09-LLDP commands
- 10-PFC commands
- 11-Service loopback group commands
| 11-Service loopback group commands | 57.19 KB |
display service-loopback group
Use display service-loopback group to display service loopback group information.
display service-loopback group [ group-id ]
group-id: Specifies a service loopback group ID. The value range for the group-id argument is 1 to 1024. If you do not specify a service loopback group, this command displays information about all service loopback groups.
# Display information about service loopback group 5.
<Sysname> display service-loopback group 5
Group ID: 5 Service type: Telemetry stream
Member Status
HundredGigE1/0/1 Selected
HundredGigE1/0/2 Unselected
Group ID |
Service loopback group ID. |
Service type |
Service type of the service loopback group: · Telemetry-stream—Supports Telemetry stream traffic. |
Member |
Member ports of the service loopback group. |
Status |
Status of each member port in the service loopback group: · Selected—The port is in Selected state and can forward service packets. · Unselected—The port is in Unselected state. It cannot forward service packets. |
port service-loopback group
Use port service-loopback group to assign a port to a service loopback group.
Use undo port service-loopback group to remove a port from a service loopback group.
port service-loopback group group-id
A port does not belong to a service loopback group.
CAUTION: · When you assign a port to a service loopback group, the system removes the configuration on the port. Make sure you are fully aware of the impact of this command before using it on a live network. · If a port is the only member of a referenced service loopback group, then removing that port from the group will disrupt the functionality of the telemetry stream. |
Breakout interfaces cannot be assigned to service loopback groups.
Before assigning a port to a service loopback group, make sure the port supports the service type of the group.
A port can belong to only one service loopback group.
# Assign HundredGigE 1/0/1 to service loopback group 5.
[Sysname-HundredGigE1/0/1] port service-loopback group 5
Use service-loopback group to create a service loopback group and specify its service type.
Use undo service-loopback group to delete a service loopback group.
service-loopback group group-id type telemetry-stream
undo service-loopback group group-id
No service loopback groups exist.
type: Specifies the service type of the service loopback group.
telemetry-stream: Specifies the Telemetry stream service.
Service loopback groups must work with other features, such as GRE. A service loopback group can be used by multiple features.
To ensure correct traffic processing, do not delete a service loopback group that is being used by a feature.
# Create service loopback group 5 and specify the Telemetry stream service for the group.
[Sysname] service-loopback group 5 type telemetry-stream
