10-User Access and Authentication
HomeSupportReference GuidesMIB CompanionH3C Wireless Products MIB Reference(R54xx)-6W10010-User Access and Authentication
05-HH3C-RADIUS-MIB
05-HH3C-RADIUS-MIB 218.68 KB
HH3C-RADIUS-MIB
About this MIB
Use this MIB to obtain and configure RADIUS server settings.
MIB file name
hh3c-radius.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cRadius(13)
Scalar objects
hh3cRadiusAuthErrThreshold (1.3.6.1.4.1.25506.2.13.1.3.1)
Object (OID)
Access
Value range
Implementation
read-write
Unsigned32
Unsigned32 (1..100)
Authentication failure alarm threshold.
As per the MIB.
hh3cRadiusStatAccReq (1.3.6.1.4.1.25506.2.13.6.1)
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Standard MIB values.
Number of RADIUS accounting requests sent to the RADIUS server, including start-accounting requests and real-time accounting requests.
As per the MIB.
hh3cRadiusStatAccAck (1.3.6.1.4.1.25506.2.13.6.2)
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of RADIUS accounting responses received from the RADIUS server.
As per the MIB.
hh3cRadiusStatLogoutReq (1.3.6.1.4.1.25506.2.13.6.3)
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of logout requests sent to the RADIUS server.
As per the MIB.
hh3cRadiusStatLogoutAck (1.3.6.1.4.1.25506.2.13.6.4)
Object (OID)
Access
Value range
Implementation
read-only
Counter64
Number of logout responses received from the RADIUS server.
As per the MIB.
hh3cRadiusServerFirstTrapTime (1.3.6.1.4.1.25506.2.13.7.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
Timeticks
Time when the trap was generated.
As per the MIB.
hh3cRadiusAccCacheMaxPackets (1.3.6.1.4.1.25506.2.13.8.1.1)
Object (OID)
Access
Value range
Implementation
Integer32
256..2147483647
Maximum number of buffered accounting packets.
As per the MIB.
hh3cRadiusAccCacheUpperValue (1.3.6.1.4.1.25506.2.13.8.1.2)
Object (OID)
Access
Value range
Implementation
Integer32
1..100
Upper threshold for accounting packet buffering, in percentage.
As per the MIB.
hh3cRadiusAccCacheLowerValue (1.3.6.1.4.1.25506.2.13.8.1.3)
Object (OID)
Access
Value range
Implementation
Integer32
0..99
Lower threshold for accounting packet buffering, in percentage.
As per the MIB.
hh3cRadiusAccCacheMemoryUsage (1.3.6.1.4.1.25506.2.13.8.1.4)
Object (OID)
Access
Value range
Implementation
Integer32
0..100
Current memory usage, in percentage.
As per the MIB.
hh3cRadiusAccCachePackets (1.3.6.1.4.1.25506.2.13.8.1.5)
Object (OID)
Access
Value range
Implementation
Integer32
256..2147483647
Current number of buffered packets.
As per the MIB.
Tabular objects
hh3cRdAccInfoTable
About this table
Use this table to configure or obtain RADIUS accounting scheme settings. Each RADIUS scheme contains a primary accounting server, a secondary accounting server, and other settings.
Support for operations
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cRdAccGroupName.
Object (OID)
Access
Value range
Implementation
hh3cRdAccNasIpAddr (1.3.6.1.4.1.25506.2.13.1.2.1.30)
read-create
IpAddress
NAS IPv4 address.
As per the MIB.
hh3cRdAccNasIpv6Addr (1.3.6.1.4.1.25506.2.13.1.2.1.31)
read-create
Ipv6Address
NAS IPv6 address.
As per the MIB.
hh3cRdAccRealTimeUnit
(1.3.6.1.4.1.25506.2.13.1.2.1.32)
read-create
INTEGER
minute(0),
second(1)
Interval for sending real-time accounting packets.
As per the MIB.
hh3cRdSecondaryAuthServerTable
About this table
Use this table to configure or obtain secondary RADIUS authentication server settings.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cRdGroupName, hh3cRdSecondaryAuthIpAddrType, hh3cRdSecondaryAuthIpAddr, hh3cRdSecondaryAuthVpnNam, and hh3cRdSecondaryAuthUdpPort.
Object (OID)
Access
Value range
Implementation
hh3cRdSecondaryAuthIpAddrType (1.3.6.1.4.1.25506.2.13.1.4.1.1)
not-accessible
InetAddressType
Type of the IP address for a secondary authentication server.
As per the MIB.
hh3cRdSecondaryAuthIpAddr (1.3.6.1.4.1.25506.2.13.1.4.1.2)
not-accessible
InetAddress
OCTET STRING (0..255)
IP address of the secondary authentication server.
As per the MIB.
hh3cRdSecondaryAuthVpnName (1.3.6.1.4.1.25506.2.13.1.4.1.3)
not-accessible
DisplayString
OCTET STRING (0..31)
Name of the VPN to which the secondary authentication server belongs.
As per the MIB.
hh3cRdSecondaryAuthUdpPort (1.3.6.1.4.1.25506.2.13.1.4.1.4)
not-accessible
Integer32
Integer32 (1..65535)
Port number of the secondary authentication server.
As per the MIB.
hh3cRdSecondaryAuthState (1.3.6.1.4.1.25506.2.13.1.4.1.5)
read-create
INTEGER
active(1),
block(2)
Status of the secondary authentication server.
As per the MIB.
hh3cRdSecondaryAuthKey (1.3.6.1.4.1.25506.2.13.1.4.1.6)
read-create
DisplayString
OCTET STRING (0..64)
Shared key for communication with the secondary authentication server.
The shared key is a string of 0 to 64 characters.
In dayou OEM version, the shared key string must be nine characters long or longer and must contain digits, uppercase letters, lowercase letters, and special characters.
When read, this object returns a zero-length string.
hh3cRdSecondaryAuthRowStatus
(1.3.6.1.4.1.25506.2.13.1.4.1.7)
read-create
RowStatus
Row status.
The following values are supported:
active(1).
createAndGo(4).
destroy(6).
hh3cRdSecondaryAccServerTable
About this table
Use this table to configure or obtain secondary RADIUS accounting server settings.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cRdAccGroupName, hh3cRdSecondaryAccIpAddrType, hh3cRdSecondaryAccIpAddr, hh3cRdSecondaryAccVpnName, and hh3cRdSecondaryAccUdpPort.
Object (OID)
Access
Value range
Implementation
hh3cRdSecondaryAccIpAddrType (1.3.6.1.4.1.25506.2.13.1.5.1.1)
not-accessible
InetAddressType
Type of the IP address for a secondary accounting server.
As per the MIB.
hh3cRdSecondaryAccIpAddr (1.3.6.1.4.1.25506.2.13.1.5.1.2)
not-accessible
InetAddress
IP address of the secondary accounting server.
As per the MIB.
hh3cRdSecondaryAccVpnName (1.3.6.1.4.1.25506.2.13.1.5.1.3)
not-accessible
DisplayString
Name of the VPN to which the secondary accounting server belongs.
As per the MIB.
hh3cRdSecondaryAccUdpPort (1.3.6.1.4.1.25506.2.13.1.5.1.4)
not-accessible
Integer32
Port number of the secondary accounting server.
As per the MIB.
hh3cRdSecondaryAccState (1.3.6.1.4.1.25506.2.13.1.5.1.5)
read-create
INTEGER
active(1),
block(2)
Status of the secondary accounting server.
As per the MIB.
hh3cRdSecondaryAccKey (1.3.6.1.4.1.25506.2.13.1.5.1.6)
read-create
DisplayString
Shared key for communication with the secondary accounting server.
hh3cRdSecondaryAccRowStatus
(1.3.6.1.4.1.25506.2.13.1.5.1.7)
read-create
RowStatus
Row status.
active(1).
createAndGo(4).
destroy(6).
hh3cRadiusAccServerTable
About this table
This table collects packet statistics by RADIUS accounting server, which is not implemented by standard MIBs.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is radiusAccServerIndex.
Object (OID)
Access
Value range
Implementation
hh3cRadiusAccClientStartRequests (1.3.6.1.4.1.25506.2.13.2.1.1.1.1)
read-only
Counter32
Number of start-accounting requests sent to the RADIUS server.
As per the MIB.
hh3cRadiusAccClientStartResponses (1.3.6.1.4.1.25506.2.13.2.1.1.1.2)
read-only
Counter32
Number of start-accounting requests received from the RADIUS server.
As per the MIB.
hh3cRadiusAccClientInterimRequests (1.3.6.1.4.1.25506.2.13.2.1.1.1.3)
read-only
Counter32
Number of real-time accounting request sent to the RADIUS server.
As per the MIB.
hh3cRadiusAccClientInterimResponses (1.3.6.1.4.1.25506.2.13.2.1.1.1.4)
read-only
Counter32
Number of real-time accounting requests received from the RADIUS server.
As per the MIB.
hh3cRadiusAccClientStopRequests (1.3.6.1.4.1.25506.2.13.2.1.1.1.5)
read-only
Counter32
Number of stop-accounting request sent to the RADIUS server.
As per the MIB.
hh3cRadiusAccClientStopResponses (1.3.6.1.4.1.25506.2.13.2.1.1.1.6)
read-only
Counter32
Number of stop-accounting requests received from the RADIUS server.
As per the MIB.
hh3cRadiusAuthServerTable
About this table
This table collects authentication failure statistics by RADIUS authentication server, which is not implemented by standard MIBs.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is radiusAuthServerIndex.
Object (OID)
Access
Value range
Implementation
hh3cRadiusAuthFailureTimes (1.3.6.1.4.1.25506.2.13.4.1.1.1.1)
read-only
Counter32
Number of authentication failures.
As per the MIB.
hh3cRadiusAuthTimeoutTimes (1.3.6.1.4.1.25506.2.13.4.1.1.1.2)
read-only
Counter32
Number of authentication timeouts.
As per the MIB.
hh3cRadiusAuthRejectTimes (1.3.6.1.4.1.25506.2.13.4.1.1.1.3)
read-only
Counter32
Number of authentication rejections.
As per the MIB.
Notifications
hh3cRadiusAuthServerUpTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.13.3.0.1
Authentication server up
Recovery
Major
N/A (N/A)
OFF
Notification triggers
This notification is generated when the status of an authentication server changes from blocked to active.
This notification has issues in SNMPv2 and later versions. It has been replaced with hh3cRadiusAuthenticationServerUpTrap (1.3.6.1.4.1.25506.2.13.3.0.4) in SNMPv2 and later versions.
If the radius trap-version v1 command is used on the device and authentication server up notification is enabled, notification hh3cRadiusAuthServerUpTrap is generated. If the radius trap-version v2 command is used on the device and authentication server up notification is enabled, notification hh3cRadiusAuthenticationServerUpTrap is generated.
System impact
No negative impact on the system.
Status control
ON
CLI: Use both the snmp-agent trap enable radius authentication-server-up and radius trap-version v1 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius authentication-server-up command or the radius trap-version v2 command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.67.1.2.1.1.3.1.2 (radiusAuthServerAddress)
IP address of an authentication server.
IP Address
1.3.6.1.2.1.67.1.2.1.1.3.1.3 (radiusAuthClientServerPortNumber)
Port number of the authentication server.
INTEGER
1.. 65535
Recommended action
No action is required.
hh3cRadiusAccServerUpTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.13.3.0.2
Accounting server up
Recovery
Major
N/A (N/A)
OFF
This notification is generated when the status of an accounting server changes from blocked to active.
This notification has issues in SNMPv2 and later versions. It has been replaced with hh3cRadiusAccountingServerUpTrap (1.3.6.1.4.1.25506.2.13.3.0.5) in SNMPv2 and later versions.
If the radius trap-version v1 command is used on the device and accounting server up notification is enabled, notification hh3cRadiusAccServerUpTrap is generated. If the radius trap-version v2 command is used on the device and accounting server up notification is enabled, notification hh3cRadiusAccountingServerUpTrap is generated.
System impact
Status control
ON
CLI: Use both the snmp-agent trap enable radius accounting-server-up and radius trap-version v1 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius accounting-server-up command or the radius trap-version v2 command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.67.2.2.1.1.3.1.2 (radiusAccServerAddress)
IP address of an accounting server.
IP Address
1.3.6.1.2.1.67.2.2.1.1.3.1.3 (radiusAccClientServerPortNumber)
Port number of the accounting server.
INTEGER
1.. 65535
Recommended action
hh3cRadiusAuthErrTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.13.3.0.3
Authentication failure alarm threshold crossing.
Informational
Major
N/A (N/A)
OFF
This notification is generated when the ratio of the authentication failures to the total authentication requests reaches the authentication failure alarm threshold.
System impact
The system is might being attacked.
Status control
ON
CLI: Use the snmp-agent trap enable radius authentication-error-threshold command.
OFF
CLI: Use the undo snmp-agent trap enable radius authentication-error-threshold command.
Object
OID (object name)
Index
Value range
IP Address
INTEGER
1.. 65535
Recommended action
To resolve this issue, contact the administrator for help.
Basic information
OID
Event
Severity
Default status
Recovery
Major
N/A (N/A)
OFF
This notification replaces hh3cRadiusAuthServerUpTrap (1.3.6.1.4.1.25506.2.13.3.0.1) in SNMPv2 and later versions.
If the radius trap-version v2 command is used on the device and authentication server up notification is enabled, notification hh3cRadiusAuthenticationServerUpTrap is generated. If the radius trap-version v1 command is used on the device and authentication server up notification is enabled, notification hh3cRadiusAuthServerUpTrap is generated.
System impact
Status control
ON
CLI: Use both the snmp-agent trap enable radius authentication-server-up and radius trap-version v2 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius authentication-server-up command or the radius trap-version v1 command.
Object
OID (object name)
Index
Value range
IP Address
INTEGER
1.. 65535
Recommended action
Basic information
OID
Event
Severity
Default status
Recovery
Major
N/A (N/A)
OFF
This notification replaces hh3cRadiusAccServerUpTrap (1.3.6.1.4.1.25506.2.13.3.0.2) in SNMPv2 and later versions.
If the radius trap-version v2 command is used on the device and accounting server up notification is enabled, notification hh3cRadiusAccountingServerUpTrap is generated. If the radius trap-version v1 command is used on the device and accounting server up notification is enabled, notification hh3cRadiusAccServerUpTrap is generated.
System impact
Status control
ON
CLI: Use both the snmp-agent trap enable radius accounting-server-up and radius trap-version v2 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius accounting-server-up command or the radius trap-version v1 command.
Object
OID (object name)
Index
Value range
IP Address
INTEGER
1.. 65535
Recommended action
hh3cRadiusAuthenticationServerDownTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.13.3.0.6
Authentication server down
Error
Major
1.3.6.1.4.1.25506.2.13.3.0.4 (hh3cRadiusAuthenticationServerUpTrap)
OFF
This notification is generated when the status of an authentication server changes from active to blocked.
This notification replaces hh3cRadiusAuthServerDownTrap (1.3.6.1.4.1.25506.2.13.3.1) in SNMPv2 and later versions.
If the radius trap-version v2 command is used on the device and authentication server down notification is enabled, notification hh3cRadiusAuthenticationServerDownTrap is generated. If the radius trap-version v1 command is used on the device and authentication server down notification is enabled, notification hh3cRadiusAuthServerDownTrap is generated.
System impact
If no secondary authentication servers exist, users cannot perform authentication to come online.
Status control
ON
CLI: Use both the snmp-agent trap enable radius authentication-server-down and radius trap-version v2 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius authentication-server-down command or the radius trap-version v1 command.
Object
OID (object name)
Index
Value range
IP Address
INTEGER
1.. 65535
Recommended action
To resolve this issue:
1.Use the display interface command to view whether the interface connected to the authentication server is up:
  - If no, troubleshoot the physical links.
  - If yes, go to step 2.
2.Use the ping command to check whether the RADIUS server is reachable:
  - If no, first check the network reachability between the device and the RADIUS server, and then check whether firewalls exist in the network. Make sure the RADIUS server is reachable.
  - If yes, go to step 3.
3.Use the display current-configuration command to view whether the RADIUS server's configurations are correct:
  - If no, modify the RADIUS server's configurations. For more information about RADIUS server configurations, see AAA commands in Security Command Reference and AAA configuration in Security Configuration Guide of the device.
  - If yes, go to step 4.
4.If the issue persists, collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
hh3cRadiusAccountingServerDownTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.13.3.0.7
Accounting server down
Error
Major
1.3.6.1.4.1.25506.2.13.3.0.5 (hh3cRadiusAccountingServerUpTrap)
OFF
This notification is generated when the status of an accounting server changes from active to blocked.
This notification replaces hh3cRadiusAccServerDownTrap (1.3.6.1.4.1.25506.2.13.3.2) in SNMPv2 and later versions.
If the radius trap-version v2 command is used on the device and accounting server down notification is enabled, notification hh3cRadiusAccountingServerDownTrap is generated. If the radius trap-version v1 command is used on the device and accounting server down notification is enabled, notification hh3cRadiusAccServerDownTrap is generated.
System impact
The server is unreachable and users cannot come online.
Status control
ON
CLI: Use both the snmp-agent trap enable radius accounting-server-down and radius trap-version v2 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius accounting-server-down command or the radius trap-version v1 command.
Object
OID (object name)
Index
Value range
IP Address
Port number of an accounting server.
INTEGER
1.. 65535
Recommended action
1.Use the display interface command to view whether the interface connected to the accounting server is up:
Basic information
OID
Event
Severity
Default status
Error
Major
1.3.6.1.4.1.25506.2.13.3.0.1 (hh3cRadiusAuthServerUpTrap)
OFF
This notification has issues in SNMPv2 and later versions. It has been replaced with hh3cRadiusAuthenticationServerDownTrap (1.3.6.1.4.1.25506.2.13.3.0.6) in SNMPv2 and later versions.
If the radius trap-version v1 command is used on the device and authentication server down notification is enabled, notification hh3cRadiusAuthServerDownTrap is generated. If the radius trap-version v2 command is used on the device and authentication server down notification is enabled, notification hh3cRadiusAuthenticationServerDownTrap is generated.
System impact
Status control
ON
CLI: Use both the snmp-agent trap enable radius authentication-server-down and radius trap-version v1 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius authentication-server-down command or the radius trap-version v2 command.
Object
OID (object name)
Index
Value range
IP Address
INTEGER
1.. 65535
Recommended action
Basic information
OID
Event
Severity
Default status
Error
Major
1.3.6.1.4.1.25506.2.13.3.0.2 (hh3cRadiusAccServerUpTrap)
OFF
This notification has issues in SNMPv2 and later versions. It has been replaced with hh3cRadiusAccountingServerDownTrap (1.3.6.1.4.1.25506.2.13.3.0.7) in SNMPv2 and later versions.
If the radius trap-version v1 command is used on the device and accounting server down notification is enabled, notification hh3cRadiusAccServerDownTrap is generated. If the radius trap-version v2 command is used on the device and accounting server down notification is enabled, notification hh3cRadiusAccountingServerDownTrap is generated.
System impact
Status control
ON
CLI: Use both the snmp-agent trap enable radius accounting-server-down and radius trap-version v1 commands.
OFF
CLI: Use either the undo snmp-agent trap enable radius accounting-server-down command or the radius trap-version v2 command.
Object
OID (object name)
Index
Value range
IP Address
INTEGER
1.. 65535
Recommended action
