03-Typical Configuration Example
HomeSupportRoutersH3C SR8800-F Router SeriesConfigure & DeployConfiguration ExamplesH3C SR8800-F Routers Configuration Examples All-In-One-R838x-6W10203-Typical Configuration Example
Table of Contents
Related Documents
54-GRE Tunnel Establishment Using Static Routes Configuration Examples
Introduction
The following information provides an example of configuring GRE tunnels using static routes.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of GRE and static routes.
Configuration examples
As shown in Figure 1, Device A, Device B, and Device C run OSPF. Establish a directly connected link between Device A and Device B so that Host A and Host B can communicate with each other. The specific requirements are as follows:
·     Configure Device A as the default gateway for Host A, and Device B as the default gateway for Host B.
·     Establish a directly connected link between Device A and Device B. Use static routes to specify forwarding of packets to the peer ends through the corresponding tunnel interfaces.
Figure 1 Network diagram
Analysis
To meet the network requirements, perform the following tasks:
·     To establish a GRE tunnel between Device A and Device B, complete GRE-related configurations.
·     To transmit packets between Host A and Host B through the GRE tunnel, configure a directly connected route to Host B on Device A and a directly connected route to Host A on Device B.
Procedures
Configuring Device A
1.     Assign an IP address to each interface, as shown in Figure 1. (Details not shown.)
2.     Configure basic OSPF functions.
[DeviceA] ospf
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] quit
3.     Configure a GRE tunnel:
# Create tunnel interface Tunnel 0, and specify the tunnel mode as GRE/IPv4.
[DeviceA] interface tunnel 0 mode gre
# Assign an IP address to interface Tunnel 0.
[DeviceA-Tunnel0] ip address 2.2.2.1 255.255.255.0
# Configure the source address of interface Tunnel 0 (as the IP address of Ten-GigabitEthernet3/1/1 on Device A).
[DeviceA-Tunnel0] source 11.1.1.1
# Configure the destination address of interface Tunnel 0 (as the IP address of Ten-GigabitEthernet3/1/1 on Device B).
[DeviceA-Tunnel0] destination 11.2.1.2
[DeviceA-Tunnel0] quit
4.     Configure a static route to the subnet where Host B resides.
[DeviceA] ip route-static 10.2.1.0 255.255.255.0 Tunnel 0
Configuring Device B
[DeviceB] ospf
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
[DeviceB] interface tunnel 0 mode gre
[DeviceB-Tunnel0] ip address 2.2.2.2 255.255.255.0
# Configure the source address of interface Tunnel 0 (as the IP address of Ten-GigabitEthernet3/1/1 on Device B).
[DeviceB-Tunnel0] source 11.2.1.2
# Configure the destination address of interface Tunnel 0 (as the IP address of Ten-GigabitEthernet3/1/1 on Device A).
[DeviceB-Tunnel0] destination 11.1.1.1
[DeviceB-Tunnel0] quit
4.     Configure a static route to the subnet where Host A resides.
[DeviceB] ip route-static 10.1.1.0 255.255.255.0 Tunnel 0
Configuring Device C
<DeviceC> system-view
[DeviceC] ospf
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
# Execute the display ip routing-table command on Device A. Verify that Device A has learned the OSPF route to the 11.2.1.0/24 subnet.
<DeviceA>display ip routing-table
Destinations : 15       Routes : 15
2.2.2.0/24         Direct  0   0           2.2.2.1         Tun0
2.2.2.1/32         Direct  0   0           127.0.0.1       InLoop0
2.2.2.255/32       Direct  0   0           2.2.2.1         Tun0
10.1.1.0/24        Direct  0   0           10.1.1.2        XGE3/1/2
10.1.1.2/32        Direct  0   0           127.0.0.1       InLoop0
10.1.1.255/32      Direct  0   0           10.1.1.2        XGE3/1/2
10.2.1.0/24        Static  60  0           0.0.0.0         Tun0
11.1.1.0/24        Direct  0   0           11.1.1.1        XGE3/1/1
11.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
11.1.1.255/32      Direct  0   0           11.1.1.1        XGE3/1/1
11.2.1.0/24        O_INTRA 10  2           11.1.1.2        XGE3/1/1
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
# Execute the display ip routing-table command on Device B. Verify that Device B has learned the OSPF route to the 11.1.1.0/24 subnet.
<DeviceB>display ip routing-table
2.2.2.0/24         Direct  0   0           2.2.2.2         Tun0
2.2.2.2/32         Direct  0   0           127.0.0.1       InLoop0
2.2.2.255/32       Direct  0   0           2.2.2.2         Tun0
10.1.1.0/24        Static  60  0           0.0.0.0         Tun0
10.2.1.0/24        Direct  0   0           10.2.1.2        XGE3/1/2
10.2.1.2/32        Direct  0   0           127.0.0.1       InLoop0
10.2.1.255/32      Direct  0   0           10.2.1.2        XGE3/1/2
11.1.1.0/24        O_INTRA 10  2           11.2.1.1        XGE3/1/1
11.2.1.0/24        Direct  0   0           11.2.1.2        XGE3/1/1
11.2.1.2/32        Direct  0   0           127.0.0.1       InLoop0
11.2.1.255/32      Direct  0   0           11.2.1.2        XGE3/1/1
# Execute the display interface brief command on Device A. Verify that the status of interface Tunnel 0 on Device A is up.
<DeviceA>display interface brief
Protocol: (s) - spoofing
Interface                         Link Protocol Primary IP      Description
XGE3/1/1                           UP   UP       11.1.1.1
XGE3/1/2                           UP   UP       10.1.1.2
InLoop0                           UP   UP(s)    --
NULL0                             UP   UP(s)    --
Tun0                              UP   UP       2.2.2.1
# Execute the display interface brief command on Device B. Verify that the status of interface Tunnel 0 on Device B is up.
<DeviceB>display interface brief
XGE3/1/1                           UP   UP       11.2.1.2
XGE3/1/2                           UP   UP       10.2.1.2
InLoop0                           UP   UP(s)    --
NULL0                             UP   UP(s)    --
Tun0                              UP   UP       2.2.2.2
# Execute the display ip routing-table command on Device A. Verify that the static route from Device A to the subnet where Host B resides goes through interface Tunnel 0.
# Execute the display ip routing-table command on Device B. Verify that the static route from Device B to the subnet where Host A resides goes through interface Tunnel 0.
# Verify that the private IP of Device A can ping the private IP of Device B.
<DeviceA>ping -a 10.1.1.2 10.2.1.2
Ping 10.2.1.2 (10.2.1.2) from 10.1.1.2: 56 data bytes, press CTRL+C to break
56 bytes from 10.2.1.2: icmp_seq=0 ttl=255 time=26.000 ms
56 bytes from 10.2.1.2: icmp_seq=1 ttl=255 time=1.000 ms
56 bytes from 10.2.1.2: icmp_seq=2 ttl=255 time=1.000 ms
56 bytes from 10.2.1.2: icmp_seq=3 ttl=255 time=1.000 ms
56 bytes from 10.2.1.2: icmp_seq=4 ttl=255 time=2.000 ms
--- Ping statistics for 10.2.1.2 ---
round-trip min/avg/max/std-dev = 1.000/6.200/26.000/9.908 ms
# Verify that Host A can ping Host B.
<HostA>ping 10.2.1.1
Ping 10.2.1.1 (10.2.1.1): 56 data bytes, press CTRL+C to break
56 bytes from 10.2.1.1: icmp_seq=0 ttl=253 time=3.000 ms
56 bytes from 10.2.1.1: icmp_seq=1 ttl=253 time=1.000 ms
56 bytes from 10.2.1.1: icmp_seq=2 ttl=253 time=2.000 ms
56 bytes from 10.2.1.1: icmp_seq=3 ttl=253 time=2.000 ms
56 bytes from 10.2.1.1: icmp_seq=4 ttl=253 time=2.000 ms
--- Ping statistics for 10.2.1.1 ---
round-trip min/avg/max/std-dev = 1.000/2.000/3.000/0.632 ms
Configuration files
·     Device A:
ospf 1
 area 0.0.0.0
interface Ten-GigabitEthernet3/1/1
 port link-mode route
 ip address 11.1.1.1 255.255.255.0
interface Ten-GigabitEthernet3/1/2
interface Tunnel0 mode gre
 source 11.1.1.1
 ip route-static 10.2.1.0 24 Tunnel0
return
·     Device B:
ospf 1
 area 0.0.0.0
 ip address 11.2.1.2 255.255.255.0
 ip address 10.2.1.2 255.255.255.0
 source 11.2.1.2
 ip route-static 10.1.1.0 24 Tunnel0
return
·     Device C:
ospf 1
 area 0.0.0.0
 ip address 11.1.1.2 255.255.255.0
 ip address 11.2.1.1 255.255.255.0
return
Related documentation
·     Layer 3—IP Services Configuration Guide
·     Layer 3—IP Routing Configuration Guide
·     Layer 3—IP Services Command Reference
·     Layer 3—IP Routing Command Reference
