- 03-Typical Configuration Example
- 01-H3C_AAA_Configuration_Examples
- 02-H3C_ACL_Configuration_Examples
- 03-H3C_IGMP_Configuration_Examples
- 04-H3C_IP_Source_Guard_Configuration_Examples
- 05-H3C_Ethernet_OAM_Configuration_Examples
- 06-H3C_NQA_Configuration_Examples
- 07-H3C_QinQ_Configuration_Examples
- 08-H3C_OSPF_Configuration_Examples
- 09-H3C_MPLS_TE_Configuration_Examples
- 10-H3C_OpenFlow_Configuration_Examples
- 11-H3C_NAT_Configuration_Examples
- 12-H3C_RBAC_Configuration_Examples
- 13-H3C_POS_Interface_Configuration_Examples
- 14-H3C_CPOS_Interface_Configuration_Examples
- 15-H3C_DHCP_Relay_Redundancy_Configuration_Examples
- 16-H3C_DLDP_Configuration_Examples
- 17-H3C_IS-IS_Configuration_Examples
- 18-H3C_MPLS_L3VPN_Configuration_Examples
- 19-H3C_SSH_Configuration_Examples
- 20-H3C_Login_Management_Configuration_Examples
- 21-H3C_SNMP_Configuration_Examples
- 22-H3C_Priority_Marking_and_Queue_Scheduling_Configuration_Examples
- 23-H3C_Multicast_VPN_Configuration_Examples
- 24-H3C_BGP_Configuration_Examples
- 25-H3C_HoVPN_Configuration_Examples
- 26-H3C_L2TP_Configuration_Examples
- 27-H3C_VRRP_Configuration_Examples
- 28-H3C_Traffic_Filtering_Configuration_Examples
- 29-H3C_Samplers_and_IPv4_NetStream_Configuration_Examples
- 30-H3C_Software_Upgrade_Examples
- 31-H3C_MPLS_L2VPN_Configuration_Examples
- 32-H3C_NetStream_Configuration_Examples
- 33-H3C_Policy-Based_Routing_Configuration_Examples
- 34-H3C_Traffic_Policing_Configuration_Examples
- 35-H3C_BFD_Configuration_Examples
- 36-H3C_OSPFv3_Configuration_Examples
- 37-H3C_VPLS_Configuration_Examples
- 38-H3C_GTS_and_Rate_Limiting_Configuration_Examples
- 39-H3C_IPv6_IS-IS_Configuration_Examples
- 40-H3C_MPLS OAM_Configuration_Examples
- 41-H3C_BGP_Route_Selection_Configuration_Examples
- 42-H3C_IS-IS_Route_Summarization_Configuration_Examples
- 43-H3C_SRv6 Configuration Examples
- 44-H3C_Attack_Protection_Configuration_Examples
- 45-H3C_OSPF_Multi-Process_Configuration_Examples
- 46-H3C_OSPF_with_Multi-Instance_Configuration_Examples
- 47-H3C_ARP_Attack_Protection_Configuration_Examples
- 48-H3C_DHCPv6_Server_and_DHCPv6_Prefix_Client_Configuration_Examples
- 49-CE1 Interface Connection Configuration Examples
- 50-General QoS Configuration Examples
- 51-GRE Tunnel Establishment Using OSPF Configuration Examples
- 52-GRE Tunnel Establishment Using Static Routes Configuration Examples
- 53-QoS Configuration Examples for the Financial Industry
| 43-H3C_SRv6 Configuration Examples | 1.28 MB |
Example: Configuring IPv4 L3VPN over SRv6 BE ECMP
Example: Configuring VPN FRR for IPv4 L3VPN over SRv6 BE
Example: Configuring inter-AS IPv4 L3VPN over SRv6 BE
Example: Configuring IPv4 L3VPN over SRv6 TE policy (static configuration)
Example: Configuring inter-AS IPv4 L3VPN over SRv6 TE policy (static configuration)
Example: Configuring IPv4 EVPN L3VPN over SRv6 TE policy (static configuration)
Example: Configuring IPv6 EVPN L3VPN over SRv6 BE
Example: Configuring IPv6 EVPN L3VPN over SRv6 BE ECMP
Example: Configuring IPv6 EVPN L3VPN over SRv6 BE FRR
Example: Configuring IPv6 EVPN L3VPN over SRv6 TE policy (static configuration)
Example: Configuring connectivity between EVPN L3VPN and EVPN L3VPN over SRv6
Verifying IS-IS neighbor and BGP peer establishment
Verifying packet forwarding from EVPN L3VPN to EVPN L3VPN over SRv6
Verifying packet forwarding from EVPN L3VPN over SRv6 to EVPN L3VPN
Verifying connectivity between CEs
Example: Configuring EVPN VPWS over SRv6 BE (dual-homed single-active CE)
Example: Configuring EVPN VPWS over SRv6 TE policy (static configuration)
Example: Configuring EVPN VPLS over SRv6 TE policy (static configuration)
As shown in Figure 1, the carrier network is an IPv6 network, and the private network is an IPv4 network. PE 1, P 1, P 2, and PE 2 belong to the same AS, and they use IS-IS for communication in the IPv6 network. Establish two SRv6 tunnels with the same cost between PE 1 and PE 2 to transmit IPv4 L3VPN data.
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/1/1 |
10.1.1.1/24 |
CE 2 |
XGE3/1/1 |
20.1.1.1/24 |
PE 1 |
Loop1 |
1::1/128 |
PE 2 |
Loop1 |
4::4/128 |
XGE3/1/1 |
10.1.1.2/24 |
XGE3/1/1 |
20.1.1.2/24 |
XGE3/1/2 |
2001::1/96 |
XGE3/1/2 |
2002::1/96 |
XGE3/1/3 |
3001::1/96 |
XGE3/1/3 |
3002::1/96 |
P 1 |
Loop1 |
2::2/128 |
P 2 |
Loop1 |
3::3/128 |
XGE3/1/1 |
2001::2/96 |
XGE3/1/1 |
3001::2/96 |
XGE3/1/2 |
2002::2/96 |
XGE3/1/2 |
3002::2/96 |
SRv6 BE ECMP relies on equal-cost routes in the network. To ensure successful configuration, plan the IGP costs of links reasonably. In this example, all links use the default cost 10.
Procedures
Configuring CE 1
[Sysname] sysname CE1
[CE1] interface ten-gigabitethernet 3/1/1
[CE1-Ten-GigabitEthernet3/1/1] ip address 10.1.1.1 24
[CE1-Ten-GigabitEthernet3/1/1] quit
[CE1] bgp 200
[CE1-bgp-default] router-id 11.11.11.11
[CE1-bgp-default] peer 10.1.1.2 as-number 100
[CE1-bgp-default-ipv4] peer 10.1.1.2 enable
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
Configuring PE 1
Configure IPv6 IS-IS on the PEs and device P for network connectivity between the devices. Configure IS-IS BFD to increase the IS-IS convergence speed upon link state changes.
[Sysname] sysname PE1
[PE1] isis 1
[PE1-isis-1] cost-style wide
[PE1-isis-1] network-entity 00.0000.0000.0001.00
[PE1-isis-1] address-family ipv6 unicast
[PE1-isis-1-ipv6] quit
[PE1-isis-1] quit
[PE1] interface loopback 1
[PE1-LoopBack1] ipv6 address 1::1 128
[PE1-LoopBack1] isis ipv6 enable 1
[PE1-LoopBack1] quit
[PE1] interface ten-gigabitethernet 3/1/2
[PE1-Ten-GigabitEthernet3/1/2] ipv6 address 2001::1 96
[PE1-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[PE1-Ten-GigabitEthernet3/1/2] isis ipv6 bfd enable
[PE1-Ten-GigabitEthernet3/1/2] quit
[PE1] interface ten-gigabitethernet 3/1/3
[PE1-Ten-GigabitEthernet3/1/3] ipv6 address 3001::1 96
[PE1-Ten-GigabitEthernet3/1/3] isis ipv6 enable 1
[PE1-Ten-GigabitEthernet3/1/3] isis ipv6 bfd enable
[PE1-Ten-GigabitEthernet3/1/3] quit
# Configure a VPN instance on the PE to allow CE access.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 100:1
[PE1-vpn-instance-vpn1] quit
[PE1] interface ten-gigabitethernet 3/1/1
[PE1-Ten-GigabitEthernet3/1/1] ip binding vpn-instance vpn1
[PE1-Ten-GigabitEthernet3/1/1] ip address 10.1.1.2 24
[PE1-Ten-GigabitEthernet3/1/1] quit
# Establish EBGP peer relationship between the PE and CE, and redistribute VPN routes.
[PE1] bgp 100
[PE1-bgp-default] router-id 1.1.1.1
[PE1-bgp-default-vpn1] peer 10.1.1.1 as-number 200
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.1 enable
[PE1-bgp-default-ipv4-vpn1] import-route direct
[PE1-bgp-default-vpn1] quit
# Establish MP-IBGP peer relationship between PEs.
[PE1-bgp-default] peer 4::4 as-number 100
[PE1-bgp-default] peer 4::4 connect-interface loopback 1
[PE1-bgp-default-vpnv4] peer 4::4 enable
[PE1-bgp-default-vpnv4] quit
[PE1-bgp-default] quit
# On the PE, specify a source address for the outer IPv6 header of SRv6-encapsulated IP L3VPN packets.
[PE1] segment-routing ipv6
[PE1-segment-routing-ipv6] encapsulation source-address 1::1
# On the PE, configure the locator for the destination address End.DT4 SID of the IPv6 packet header encapsulated in IP L3VPN over SRv6.
[PE1-segment-routing-ipv6] locator abc ipv6-prefix 100:1:: 64 static 16
[PE1-segment-routing-ipv6-locator-abc] quit
[PE1-segment-routing-ipv6] quit
# Configure IS-IS on the PE to reference and advertise the locator.
[PE1] isis 1
[PE1-isis-1-ipv6] segment-routing ipv6 locator abc
[PE1-isis-1] quit
# Enable the PE to exchange End.DT4 SIDs with the IPv6 peer, and allow private network routes to be iterated to the End.DT4 SID routes.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 4::4 prefix-sid
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort
Configuring P 1
[Sysname] sysname P1
[P1] isis 1
[P1-isis-1] cost-style wide
[P1-isis-1] network-entity 00.0000.0000.0002.00
[P1-isis-1] address-family ipv6 unicast
[P1-isis-1-ipv6] quit
[P1-isis-1] quit
[P1] interface loopback 1
[P1-LoopBack1] ipv6 address 2::2 128
[P1-LoopBack1] isis ipv6 enable 1
[P1-LoopBack1] quit
[P1] interface ten-gigabitethernet 3/1/1
[P1-Ten-GigabitEthernet3/1/1] ipv6 address 2001::2 96
[P1-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[P1-Ten-GigabitEthernet3/1/1] isis ipv6 bfd enable
[P1-Ten-GigabitEthernet3/1/1] quit
[P1] interface ten-gigabitethernet 3/1/2
[P1-Ten-GigabitEthernet3/1/2] ipv6 address 2002::2 96
[P1-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[P1-Ten-GigabitEthernet3/1/2] isis ipv6 bfd enable
[P1-Ten-GigabitEthernet3/1/2] quit
Configuring P 2
[Sysname] sysname P2
[P2] isis 1
[P2-isis-1] cost-style wide
[P2-isis-1] network-entity 00.0000.0000.0003.00
[P2-isis-1] address-family ipv6 unicast
[P2-isis-1-ipv6] quit
[P2-isis-1] quit
[P2] interface loopback 1
[P2-LoopBack1] ipv6 address 3::3 128
[P2-LoopBack1] isis ipv6 enable 1
[P2-LoopBack1] quit
[P2] interface ten-gigabitethernet 3/1/1
[P2-Ten-GigabitEthernet3/1/1] ipv6 address 3001::2 96
[P2-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[P2-Ten-GigabitEthernet3/1/1] isis ipv6 bfd enable
[P2-Ten-GigabitEthernet3/1/1] quit
[P2] interface ten-gigabitethernet 3/1/2
[P2-Ten-GigabitEthernet3/1/2] ipv6 address 3002::2 96
[P2-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[P2-Ten-GigabitEthernet3/1/2] isis ipv6 bfd enable
[P2-Ten-GigabitEthernet3/1/2] quit
Configuring PE 2
[Sysname] sysname PE2
[PE2] isis 1
[PE2-isis-1] cost-style wide
[PE2-isis-1] network-entity 00.0000.0000.0004.00
[PE2-isis-1] address-family ipv6 unicast
[PE2-isis-1-ipv6] quit
[PE2-isis-1] quit
[PE2] interface loopback 1
[PE2-LoopBack1] ipv6 address 4::4 128
[PE2-LoopBack1] isis ipv6 enable 1
[PE2-LoopBack1] quit
[PE2] interface ten-gigabitethernet 3/1/2
[PE2-Ten-GigabitEthernet3/1/2] ipv6 address 2002::1 96
[PE2-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[PE2-Ten-GigabitEthernet3/1/2] isis ipv6 bfd enable
[PE2-Ten-GigabitEthernet3/1/2] quit
[PE2] interface ten-gigabitethernet 3/1/3
[PE2-Ten-GigabitEthernet3/1/3] ipv6 address 3002::1 96
[PE2-Ten-GigabitEthernet3/1/3] isis ipv6 enable 1
[PE2-Ten-GigabitEthernet3/1/3] isis ipv6 bfd enable
[PE2-Ten-GigabitEthernet3/1/3] quit
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 100:1
[PE2-vpn-instance-vpn1] vpn-target 100:1
[PE2-vpn-instance-vpn1] quit
[PE2] interface ten-gigabitethernet 3/1/1
[PE2-Ten-GigabitEthernet3/1/1] ip binding vpn-instance vpn1
[PE2-Ten-GigabitEthernet3/1/1] ip address 20.1.1.2 24
[PE2-Ten-GigabitEthernet3/1/1] quit
[PE2] bgp 100
[PE2-bgp-default] router-id 4.4.4.4
[PE2-bgp-default-vpn1] peer 20.1.1.1 as-number 300
[PE2-bgp-default-ipv6-vpn1] peer 20.1.1.1 enable
[PE2-bgp-default-ipv6-vpn1] import-route direct
[PE2-bgp-default-ipv6-vpn1] quit
[PE2-bgp-default-vpn1] quit
[PE2-bgp-default] peer 1::1 as-number 100
[PE2-bgp-default] peer 1::1 connect-interface loopback 1
[PE2-bgp-default-vpnv4] peer 1::1 enable
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default] quit
[PE2] segment-routing ipv6
[PE2-segment-routing-ipv6] encapsulation source-address 4::4
[PE2-segment-routing-ipv6] locator abc ipv6-prefix 200:1:: 64 static 16
[PE2-segment-routing-ipv6-locator-abc] quit
[PE2-segment-routing-ipv6] quit
# On the PE, configure IS-IS to reference and advertise the locator.
[PE2] isis 1
[PE2-isis-1-ipv6] segment-routing ipv6 locator abc
[PE2-isis-1] quit
[PE2] bgp 100
[PE2-bgp-default-vpnv4] peer 1::1 prefix-sid
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort
Configuring CE 2
[Sysname] sysname CE2
[CE2] interface ten-gigabitethernet 3/1/1
[CE2-Ten-GigabitEthernet3/1/1] ip address 20.1.1.1 24
[CE2-Ten-GigabitEthernet3/1/1] quit
[CE2] bgp 300
[CE2-bgp-default] router-id 22.22.22.22
[CE2-bgp-default] peer 20.1.1.2 as-number 100
[CE2-bgp-default-ipv4] peer 20.1.1.2 enable
[CE2-bgp-default-ipv4] import-route direct
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
# Execute the display ip routing-table vpn-instance command on PE 1 to view VPN route information. Verify that VPN route 20.1.1.1/24 has two egress interfaces, form ECMP routes.
[PE1] display ip routing-table vpn-instance vpn1
Destinations : 11 Routes : 11
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
10.1.1.0/24 Direct 0 0 10.1.1.2 XGE3/1/1
10.1.1.0/32 Direct 0 0 10.1.1.2 XGE3/1/1
10.1.1.2/32 Direct 0 0 127.0.0.1 InLoop0
10.1.1.255/32 Direct 0 0 10.1.1.2 XGE3/1/1
20.1.1.0/24 BGP 255 0 200:1:: XGE3/1/2
BGP 255 0 200:1:: XGE3/1/3
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# Verify that CE 1 and CE 2 can ping each other.
[CE1] ping -a 10.1.1.1 20.1.1.1
Ping 20.1.1.1 (20.1.1.1) from 10.1.1.1: 56 data bytes, press CTRL+C to break
56 bytes from 20.1.1.1: icmp_seq=0 ttl=253 time=1.000 ms
56 bytes from 20.1.1.1: icmp_seq=1 ttl=253 time=1.000 ms
56 bytes from 20.1.1.1: icmp_seq=2 ttl=253 time=1.000 ms
56 bytes from 20.1.1.1: icmp_seq=3 ttl=253 time=1.000 ms
56 bytes from 20.1.1.1: icmp_seq=4 ttl=253 time=2.000 ms
--- Ping statistics for 20.1.1.1 ---
round-trip min/avg/max/std-dev = 1.000/1.200/2.000/0.400 ms
Configuration files
· CE 1:
sysname CE1
interface Ten-GigabitEthernet3/1/1
port link-mode route
bgp 200
import-route direct
· PE 1:
sysname PE1
vpn-target 100:1 import-extcommunity
vpn-target 100:1 export-extcommunity
isis 1
non-stop-routing
cost-style wide
interface LoopBack1
isis ipv6 enable 1
ipv6 address 1::1/128
interface Ten-GigabitEthernet3/1/2
isis ipv6 enable 1
ipv6 address 2001::1/96
interface Ten-GigabitEthernet3/1/3
isis ipv6 enable 1
ipv6 address 3001::1/96
bgp 100
router-id 1.1.1.1
peer 4::4 connect-interface LoopBack1
peer 4::4 enable
import-route direct
· P 1:
sysname P1
isis 1
non-stop-routing
cost-style wide
interface LoopBack1
isis ipv6 enable 1
ipv6 address 2::2/128
isis ipv6 enable 1
ipv6 address 2001::2/96
isis ipv6 enable 1
ipv6 address 2002::2/96
· P 2:
sysname P2
isis 1
non-stop-routing
cost-style wide
interface LoopBack1
isis ipv6 enable 1
ipv6 address 3::3/128
isis ipv6 enable 1
ipv6 address 3001::2/96
isis ipv6 enable 1
ipv6 address 3002::2/96
· PE 2:
sysname PE2
isis 1
non-stop-routing
cost-style wide
interface LoopBack1
isis ipv6 enable 1
ipv6 address 4::4/128
ip address 20.1.1.2 255.255.255.0
isis ipv6 enable 1
ipv6 address 2002::1/96
isis ipv6 enable 1
ipv6 address 3002::1/96
bgp 100
router-id 4.4.4.4
peer 1::1 connect-interface LoopBack1
peer 1::1 enable
import-route direct
· CE 2:
sysname CE2
ip address 20.1.1.1 255.255.255.0
bgp 300
import-route direct
As shown in Figure 2, the core network is an IPv6 network, and the private network is an IPv4 network. PE 1, PE 2, and PE 3 belong to the same AS, and they use IS-IS for communication in the IPv6 network. Establish SRv6 tunnels between PE 1 and PE 2 and between PE 1 and PE 3 to transmit IPv4 L3VPN data. CE 2 is dual-homed to PE 2 and PE 3. To implement fast switchover of VPN routes, enable IPv4 L3VPN FRR on PE 1. When the primary path fails, the VPN services can quickly switch to the backup path.
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/1/1 |
10.1.1.1/24 |
CE 2 |
XGE3/1/1 |
20.1.1.1/24 |
Loop0 |
11.11.11.11/32 |
XGE3/1/2 |
30.1.1.1/24 |
PE 1 |
Loop1 |
1::1/128 |
Loop0 |
22.22.22.22/32 |
XGE3/1/1 |
10.1.1.2/24 |
PE 3 |
Loop1 |
3::3/128 |
XGE3/1/2 |
2001::1/96 |
XGE3/1/2 |
30.1.1.2/24 |
XGE3/1/3 |
3001::1/96 |
XGE3/1/3 |
3001::2/96 |
PE 2 |
Loop1 |
2::2/128 |
XGE3/1/1 |
20.1.1.2/24 |
XGE3/1/2 |
2001::2/96 |
VPN FRR for IPv4 L3VPN over SRv6 BE requires PE 1 to learn VPNv4 routes separately from PE 2 and PE 3, and the learned routes cannot be ECMP routes. To ensure successful configuration of VPN FRR, plan the IGP costs of the links reasonably. In this example, all links use the default cost 10.
Procedures
Configuring CE 1
<CE1> system-view
[CE1] sysname CE1
[CE1] interface loopback 0
[CE1-LoopBack0] ip address 11.11.11.11 32
[CE1-LoopBack0] quit
[CE1] bgp 200
Configuring PE 1
# Configure IPv6 IS-IS on the PEs for network connectivity between the devices.
<PE1> system-view
[PE1] sysname PE1
[PE1] isis 1
[PE1-isis-1] quit
# Configure a VPN instance for CE 1 to access PE 1.
# Establish EBGP peer relationship between PE 1 and CE 1, and redistribute VPN routes.
[PE1] bgp 100
# Establish MP-IBGP peer relationship between PE 1 and PE 2 and between PE 1 and PE 3.
[PE1-bgp-default] peer 2::2 as-number 100
[PE1-bgp-default] peer 2::2 connect-interface loopback 1
[PE1-bgp-default] peer 3::3 as-number 100
[PE1-bgp-default] peer 3::3 connect-interface loopback 1
[PE1-bgp-default-vpnv4] peer 2::2 enable
[PE1-bgp-default-vpnv4] peer 3::3 enable
# On PE 1, specify a source address for the outer IPv6 header of SRv6-encapsulated IP L3VPN packets.
# On PE 1, configure the locator for the destination address End.DT4 SID of the IPv6 packet header encapsulated in IP L3VPN over SRv6.
# On PE 1, configure IS-IS to reference and advertise the locator.
[PE1] isis 1
[PE1-isis-1] quit
# Enable PE 1 to exchange End.DT4 SIDs with the IPv6 peer, and allow private network routes to be iterated to the End.DT4 SID routes.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 2::2 prefix-sid
[PE1-bgp-default-vpnv4] peer 3::3 prefix-sid
# Enable VPN FRR on PE 1, and configure static BFD to monitor the reachability of the locator advertised from PE 1 to PE 2. If the locator is unreachable (indicating a primary path failure), VPN FRR switches the traffic to the backup path.
[PE1] bgp 100
[PE1-bgp-default] primary-path-detect bfd ctrl
[PE1-bgp-default-ipv4-vpn1] pic
[PE1] bfd static ToPE2 peer-ipv6 200:1:: source-ipv6 100:1:: discriminator local 100 remote 200
[PE1-bfd-static-session-ToPE2] quit
Configuring PE 2
<PE2> system-view
[PE2] sysname PE2
[PE2] isis 1
[PE2-isis-1] network-entity 00.0000.0000.0002.00
[PE2-isis-1] quit
[PE2-LoopBack1] ipv6 address 2::2 128
[PE2-Ten-GigabitEthernet3/1/2] ipv6 address 2001::2 96
# Configure a VPN instance for CE 2 to access PE 2.
# Establish EBGP peer relationship between PE 2 and CE 2, and redistribute VPN routes.
[PE2] bgp 100
[PE2-bgp-default] router-id 2.2.2.2
# Establish MP-IBGP peer relationship between PE 1 and PE 2.
# On PE 2, specify a source address for the outer IPv6 header of SRv6-encapsulated IP L3VPN packets.
[PE2-segment-routing-ipv6] encapsulation source-address 2::2
# On PE 2, configure the locator for the destination address End.DT4 SID of the IPv6 packet header encapsulated in IP L3VPN over SRv6.
# On PE 2, configure IS-IS to reference and advertise the locator.
[PE2] isis 1
[PE2-isis-1] quit
# Enable PE 2 to exchange End.DT4 SIDs with the IPv6 peer, and allow private network routes to be iterated to the End.DT4 SID routes.
[PE2] bgp 100
# On PE 2, configure static BFD to monitor the reachability of the locator advertised from PE 2 to PE 1.
[PE2] bfd static ToPE1 peer-ipv6 100:1:: source-ipv6 200:1:: discriminator local 200 remote 100
[PE2-bfd-static-session-ToPE1] quit
Configuring PE 3
<PE3> system-view
[PE3] sysname PE3
[PE3] isis 1
[PE3-isis-1] cost-style wide
[PE3-isis-1] network-entity 00.0000.0000.0003.00
[PE3-isis-1] address-family ipv6 unicast
[PE3-isis-1-ipv6] quit
[PE3-isis-1] quit
[PE3] interface loopback 1
[PE3-LoopBack1] ipv6 address 3::3 128
[PE3-LoopBack1] isis ipv6 enable 1
[PE3-LoopBack1] quit
[PE3] interface ten-gigabitethernet 3/1/3
[PE3-Ten-GigabitEthernet3/1/2] ipv6 address 3001::2 96
[PE3-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[PE3-Ten-GigabitEthernet3/1/2] quit
# Configure a VPN instance for CE 2 to access PE 3.
[PE3] ip vpn-instance vpn1
[PE3-vpn-instance-vpn1] route-distinguisher 100:1
[PE3-vpn-instance-vpn1] vpn-target 100:1
[PE3-vpn-instance-vpn1] quit
[PE3] interface ten-gigabitethernet 3/1/2
[PE3-Ten-GigabitEthernet3/1/1] ip binding vpn-instance vpn1
[PE3-Ten-GigabitEthernet3/1/1] ip address 30.1.1.2 24
[PE3-Ten-GigabitEthernet3/1/1] quit
# Establish EBGP peer relationship between PE 3 and CE 2.
[PE3] bgp 100
[PE3-bgp-default] router-id 3.3.3.3
[PE3-bgp-default] ip vpn-instance vpn1
[PE3-bgp-default-vpn1] peer 30.1.1.1 as-number 300
[PE3-bgp-default-vpn1] address-family ipv4 unicast
[PE3-bgp-default-ipv6-vpn1] peer 30.1.1.1 enable
[PE3-bgp-default-ipv6-vpn1] import-route direct
[PE3-bgp-default-ipv6-vpn1] quit
[PE3-bgp-default-vpn1] quit
# Establish MP-IBGP peer relationship between PE 1 and PE 3.
[PE3-bgp-default] peer 1::1 as-number 100
[PE3-bgp-default] peer 1::1 connect-interface loopback 1
[PE3-bgp-default] address-family vpnv4
[PE3-bgp-default-vpnv4] peer 1::1 enable
[PE3-bgp-default-vpnv4] quit
[PE3-bgp-default] quit
# On PE 3, specify a source address for the outer IPv6 header of SRv6-encapsulated IP L3VPN packets.
[PE3] segment-routing ipv6
[PE3-segment-routing-ipv6] encapsulation source-address 3::3
# On PE 3, configure the locator for the destination address End.DT4 SID of the IPv6 packet header encapsulated in IP L3VPN over SRv6.
[PE3-segment-routing-ipv6] locator abc ipv6-prefix 300:1:: 64 static 16
[PE3-segment-routing-ipv6-locator-abc] quit
[PE3-segment-routing-ipv6] quit
# On PE 3, configure IS-IS to reference and advertise the locator.
[PE3] isis 1
[PE3-isis-1-ipv6] segment-routing ipv6 locator abc
[PE3-isis-1] quit
# Enable PE 3 to exchange End.DT4 SIDs with the IPv6 peer, and allow private network routes to be iterated to the End.DT4 SID routes.
[PE3] bgp 100
[PE3-bgp-default-vpnv4] peer 1::1 prefix-sid
[PE3-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc
[PE3-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort
[PE3-bgp-default-ipv4-vpn1] quit
Configuring CE 2
<CE2> system-view
[CE2] sysname CE2
[CE2] interface ten-gigabitethernet 3/1/2
[CE2-Ten-GigabitEthernet3/1/2] ip address 30.1.1.1 24
[CE2-Ten-GigabitEthernet3/1/2] quit
[CE2] interface loopback 0
[CE2-LoopBack0] ip address 22.22.22.22 32
[CE2-LoopBack0] quit
[CE2] bgp 300
[CE2-bgp-default] peer 30.1.1.2 as-number 100
[CE2-bgp-default-ipv4] peer 30.1.1.2 enable
# Execute the display ip routing-table vpn-instance vpn1 22.22.22.22 verbose command on PE 1 to view VPN route information. Verify that VPN route 22.22.22.22/32 has a primary egress interface and a backup egress interface, implementing VPN FRR.
[PE1] display ip routing-table vpn-instance vpn1 22.22.22.22 verbose
Summary count : 1
Destination: 22.22.22.22/32
Protocol: BGP instance default
Process ID: 0
SubProtID: 0x1 Age: 00h32m17s
Cost: 0 Preference: 255
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active Adv
TableID: 0x102 OrigAs: 300
NibID: 0x16000003 LastAs: 300
AttrID: 0x2 Neighbor: 2::2
Flags: 0x80010060 OrigNextHop: 200:1::
Label: NULL RealNextHop: FE80::62F5:1BFF:FEE0:307
BkLabel: NULL BkNextHop: FE80::62F5:20FF:FEC4:408
SRLabel: NULL Interface: Ten-GigabitEthernet3/1/2
BkSRLabel: NULL BkInterface: Ten-GigabitEthernet3/1/3
SIDIndex: NULL InLabel: NULL
Tunnel ID: Invalid IPInterface: Ten-GigabitEthernet3/1/2
BkTunnel ID: Invalid BkIPInterface: Ten-GigabitEthernet3/1/3
FtnIndex: 0x0 ColorInterface: N/A
TrafficIndex: N/A BkColorInterface: N/A
Connector: N/A VpnPeerId: N/A
Dscp: N/A Exp: N/A
SRTunnelID: Invalid StatFlags: 0x0
SID Type: N/A SID: 200:1::1:4
BkSID: 300:1::1:4 NID: Invalid
FlushNID: Invalid BkNID: Invalid
BkFlushNID: Invalid PathID: 0x0
CommBlockLen: 0
OrigLinkID: 0x0 RealLinkID: 0x0
# Shut down the egress interface Ten-GigabitEthernet 3/1/2 of PE 1 on the primary path, and verify that CE 1 and CE 2 can ping each other.
[CE1] ping -a 11.11.11.11 22.22.22.22
Ping 22.22.22.22 (22.22.22.22) from 11.11.11.11: 56 data bytes, press CTRL_C to break
56 bytes from 22.22.22.22: icmp_seq=0 ttl=253 time=1.000 ms
56 bytes from 22.22.22.22: icmp_seq=1 ttl=253 time=2.000 ms
56 bytes from 22.22.22.22: icmp_seq=2 ttl=253 time=1.000 ms
56 bytes from 22.22.22.22: icmp_seq=3 ttl=253 time=1.000 ms
56 bytes from 22.22.22.22: icmp_seq=4 ttl=253 time=1.000 ms
--- Ping statistics for 22.22.22.22 ---
Configuration files
· CE 1:
sysname CE1
combo enable fiber
interface LoopBack0
ip address 11.11.11.11 255.255.255.255
bgp 200
import-route direct
· PE 1:
sysname PE1
isis 1
non-stop-routing
cost-style wide
interface LoopBack1
isis ipv6 enable 1
combo enable copper
combo enable copper
isis ipv6 enable 1
combo enable copper
isis ipv6 enable 1
bgp 100
router-id 1.1.1.1
peer 2::2 connect-interface LoopBack1
peer 3::3 connect-interface LoopBack1
peer 2::2 enable
peer 3::3 enable
pic
import-route direct
· PE 2:
sysname PE2
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
combo enable copper
combo enable copper
isis ipv6 enable 1
bgp 100
router-id 2.2.2.2
peer 1::1 enable
import-route direct
· PE 3:
sysname PE3
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
combo enable copper
ip address 30.1.1.2 255.255.255.0
combo enable copper
isis ipv6 enable 1
bgp 100
router-id 3.3.3.3
peer 1::1 enable
import-route direct
· CE 2:
sysname CE2
interface LoopBack0
ip address 22.22.22.22 255.255.255.255
combo enable copper
combo enable copper
ip address 30.1.1.1 255.255.255.0
bgp 300
import-route direct
As shown in Figure 3, the core network is an IPv6 network, and the private network is an IPv4 network. PE 1 and ASBR 1 belong to AS 100, and PE 2 and ASBR 2 belong to AS 200. AS 100 and AS 200 use IS-IS to implement IPv6 connectivity. Configure inter-AS SRv6 BE paths between PE 1 and PE 2 to transmit IPv4 L3VPN traffic.
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/1/1 |
10.1.1.1/24 |
CE 2 |
XGE3/1/1 |
20.1.1.1/24 |
PE 1 |
Loop1 |
1::1/128 |
PE 2 |
Loop1 |
4::4/128 |
XGE3/1/1 |
10.1.1.2/24 |
XGE3/1/1 |
20.1.1.2/24 |
XGE3/1/2 |
101::1/96 |
XGE3/1/2 |
303::2/96 |
ASBR 1 |
Loop1 |
2::2/128 |
ASBR 2 |
Loop1 |
3::3/128 |
XGE3/1/1 |
101::2/96 |
XGE3/1/1 |
303::1/96 |
XGE3/1/2 |
202::1/96 |
XGE3/1/2 |
202::2/96 |
Procedures
Configuring CE 1
[CE1] bgp 65410
Configuring PE 1
# Configure IPv6 IS-IS on the PE and ASBR for network connectivity between the devices.
[PE1] isis 1
[PE1-isis-1] quit
[PE1-Ten-GigabitEthernet3/1/2] ipv6 address 101::1 96
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10.1.1.1 as-number 65410
# Establish MP-EBGP peer relationship between PEs.
[PE1-bgp-default] peer 4::4 as-number 200
[PE1-bgp-default] peer 4::4 ebgp-max-hop 255
# Establish MP-IBGP peer relationship between the PE and ASBR.
[PE1-bgp-default] address-family ipv6
[PE1-bgp-default-ipv6] peer 2::2 enable
[PE1-bgp-default-ipv6] quit
# Establish an SRv6 BE path between the PEs.
[PE1-segment-routing-ipv6] locator abc ipv6-prefix 10:1:: 64 static 16
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
Configuring ASBR 1
[Sysname] sysname ASBR1
[ASBR1] isis 1
[ASBR1-isis-1] cost-style wide
[ASBR1-isis-1] network-entity 00.0000.0000.0002.00
[ASBR1-isis-1] address-family ipv6 unicast
[ASBR1-isis-1-ipv6] quit
[ASBR1-isis-1] quit
[ASBR1] interface loopback 1
[ASBR1-LoopBack1] ipv6 address 2::2 128
[ASBR1-LoopBack1] isis ipv6 enable 1
[ASBR1-LoopBack1] quit
[ASBR1] interface ten-gigabitethernet 3/1/1
[ASBR1-Ten-GigabitEthernet3/1/1] ipv6 address 101::2 96
[ASBR1-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[ASBR1-Ten-GigabitEthernet3/1/1] quit
[ASBR1] interface ten-gigabitethernet 3/1/2
[ASBR1-Ten-GigabitEthernet3/1/2] ipv6 address 201::1 96
[ASBR1-Ten-GigabitEthernet3/1/2] quit
[ASBR1] bgp 100
[ASBR1-bgp-default] router-id 2.2.2.2
[ASBR1-bgp-default] peer 1::1 as-number 100
[ASBR1-bgp-default] peer 1::1 connect-interface loopback 1
[ASBR1-bgp-default] address-family ipv6
[ASBR1-bgp-default-ipv6] peer 1::1 enable
[ASBR1-bgp-default-ipv6] peer 1::1 next-hop-local
[ASBR1-bgp-default-ipv6] quit
# Configure BGP to import the locator routes advertised by IS-IS, and advertise the routes to ASBR 2.
[ASBR1-bgp-default] peer 202::2 as-number 200
[ASBR1-bgp-default] peer 202::2 ebgp-max-hop 255
[ASBR1-bgp-default-ipv6] peer 202::2 enable
[ASBR1-bgp-default-ipv6] import-route isisv6 1
[ASBR1-bgp-default] quit
# Configure IS-IS to redistribute the locator routes advertised by BGP.
[ASBR1] ipv6 prefix-list as100 index 10 permit 40:: 64
[ASBR1] ipv6 prefix-list as100 index 20 permit 4::4 128
[ASBR1] route-policy as100 permit node 1
[ASBR1-route-policy-as100-1] if-match ipv6 address prefix-list as100
[ASBR1-route-policy-as100-1] quit
[ASBR1] isis 1
[ASBR1-isis-1-ipv6] import-route bgp4+ route-policy as100
[ASBR1-isis-1] quit
Configuring ASBR 2
[Sysname] sysname ASBR2
[ASBR2] isis 1
[ASBR2-isis-1] cost-style wide
[ASBR2-isis-1] network-entity 00.0000.0000.0003.00
[ASBR2-isis-1] address-family ipv6 unicast
[ASBR2-isis-1-ipv6] quit
[ASBR2-isis-1] quit
[ASBR2] interface loopback 1
[ASBR2-LoopBack1] ipv6 address 3::3 128
[ASBR2-LoopBack1] isis ipv6 enable 1
[ASBR2-LoopBack1] quit
[ASBR2] interface ten-gigabitethernet 3/1/1
[ASBR2-Ten-GigabitEthernet3/1/1] ipv6 address 303::1 96
[ASBR2-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[ASBR2-Ten-GigabitEthernet3/1/1] quit
[ASBR2] interface ten-gigabitethernet 3/1/2
[ASBR2-Ten-GigabitEthernet3/1/2] ipv6 address 202::2 96
[ASBR2-Ten-GigabitEthernet3/1/2] quit
[ASBR2] bgp 200
[ASBR2-bgp-default] router-id 3.3.3.3
[ASBR2-bgp-default] peer 4::4 as-number 200
[ASBR2-bgp-default] peer 4::4 connect-interface loopback 1
[ASBR2-bgp-default] address-family ipv6
[ASBR2-bgp-default-ipv6] peer 4::4 enable
[ASBR2-bgp-default-ipv6] peer 4::4 next-hop-local
[ASBR2-bgp-default-ipv6] quit
[ASBR2-bgp-default] peer 202::1 as-number 100
[ASBR2-bgp-default] peer 202::1 ebgp-max-hop 255
[ASBR2-bgp-default-ipv6] peer 202::1 enable
[ASBR2-bgp-default-ipv6] import-route isisv6 1
[ASBR2-bgp-default] quit
[ASBR2] ipv6 prefix-list as200 index 10 permit 10:: 64
[ASBR2] ipv6 prefix-list as200 index 20 permit 1::1 128
[ASBR2] route-policy as200 permit node 1
[ASBR2-route-policy-as200-1] if-match ipv6 address prefix-list as200
[ASBR2-route-policy-as200-1] quit
[ASBR2] isis 1
[ASBR2-isis-1-ipv6] import-route bgp4+ route-policy as200
[ASBR2-isis-1] quit
Configuring PE 2
[PE2] isis 1
[PE2-isis-1] quit
[PE2-Ten-GigabitEthernet3/1/2] ipv6 address 303::2 96
[PE2] bgp 200
[PE2-bgp-default-vpn1] peer 20.1.1.1 as-number 65420
[PE2-bgp-default] peer 1::1 ebgp-max-hop 255
[PE2-bgp-default] peer 3::3 as-number 200
[PE2-bgp-default] peer 3::3 connect-interface LoopBack1
[PE2-bgp-default] address-family ipv6
[PE2-bgp-default-ipv6] peer 3::3 enable
[PE2-bgp-default-ipv6] quit
[PE2-segment-routing-ipv6] locator abc ipv6-prefix 40:: 64 static 16
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 100
Configuring CE 2
[CE2] bgp 65420
[CE2-bgp-default] peer 20.1.1.2 as-number 200
# Execute the display bgp routing-table vpnv4 command on the PE to view detailed information of the routes sent by the remote PE. Verify that the routes from the remote PE carry SID attribute data.
Use PE 1 as an example:
[PE1] display bgp routing-table vpnv4 20.1.1.0 24
BGP local router ID: 1.1.1.1
Local AS number: 100
Route distinguisher: 100:1(vpn1)
Total number of routes: 1
Paths: 1 available, 1 best
BGP routing table information of 20.1.1.0/24:
Rely nexthop : FE80::3419:41FF:FE28:331
Original nexthop: 4::4
Out interface : Ten-GigabitEthernet3/1/2
Route age : 00h07m07s
OutLabel : 3
Ext-Community : <RT: 100:1>
RxPathID : 0x0
TxPathID : 0x0
PrefixSID : End.DT4 SID <40::1:2>
AS-path : 200
Origin : incomplete
State : valid, external, best
Source type : local
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Tunnel policy : NULL
Rely tunnel IDs : N/A
# Execute the display ip routing-table vpn-instance command on the PE to view the route destined to the peer CE. Verify that the next hop of the route is the End.DT4 SID carried by the route.
20.1.1.0/24 BGP 255 0 40:: XGE3/1/2
[CE1] ping 20.1.1.1
Ping 20.1.1.1 (20.1.1.1): 56 data bytes, press CTRL+C to break
56 bytes from 20.1.1.1: icmp_seq=0 ttl=253 time=3.000 ms
56 bytes from 20.1.1.1: icmp_seq=1 ttl=253 time=2.000 ms
56 bytes from 20.1.1.1: icmp_seq=2 ttl=253 time=3.000 ms
56 bytes from 20.1.1.1: icmp_seq=3 ttl=253 time=3.000 ms
round-trip min/avg/max/std-dev = 2.000/2.600/3.000/0.490 ms
Configuration files
· CE 1:
sysname CE1
bgp 65410
import-route direct
· PE 1:
sysname PE1
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
ipv6 address 101::1/96
bgp 100
router-id 1.1.1.1
peer 4::4 enable
peer 2::2 enable
import-route direct
locator abc ipv6-prefix 10:: 64 static 16
· ASBR 1:
sysname ASBR1
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
ipv6 address 101::2/96
ipv6 address 202::1/96
bgp 100
router-id 2.2.2.2
network 10:: 64
peer 1::1 enable
peer 202::2 enable
· ASBR 2:
sysname ASBR2
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
ipv6 address 303::1/96
ipv6 address 202::2/96
bgp 200
router-id 3.3.3.3
network 40:: 64
peer 4::4 enable
peer 202::1 enable
· PE 2:
sysname PE2
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
ipv6 address 303::2/96
bgp 200
router-id 4.4.4.4
peer 1::1 enable
peer 3::3 enable
import-route direct
· CE 2:
sysname CE2
bgp 65420
import-route direct
As shown in Figure 4, the carrier network is an IPv6 network, and the private network is an IPv4 network. PE 1, P, and PE 2 belong to the same AS, and they use IS-IS for communication in the IPv6 network. Establish two SRv6 TE policy tunnels between PE 1 and PE 2 to transmit IPv4 L3VPN traffic. On PE 1 and PE 2, configure a routing policy to set the color attribute for VPNv4 routes, directing VPN traffic to the specified SRv6 TE policy tunnel.
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/1/1 |
10.1.1.1/24 |
CE 2 |
XGE3/1/2 |
20.1.1.1/24 |
Loop0 |
11.11.11.11/32 |
Loop0 |
22.22.22.22/32 |
PE 1 |
Loop1 |
1::1/128 |
P |
Loop1 |
2::2/128 |
XGE3/1/1 |
10.1.1.2/24 |
XGE3/1/1 |
3001::2/96 |
XGE3/1/2 |
2001::1/96 |
XGE3/1/2 |
2001::2/96 |
PE 2 |
Loop1 |
3::3/128 |
XGE3/1/1 |
3001::1/96 |
XGE3/1/2 |
30.1.1.2/24 |
If multiple types of tunnels (such as SRv6 TE policy tunnels and SR-MPLS TE policy tunnels) in the network have the same color attribute value, you need to configure a routing policy to set the color attributes of the routes and configure a tunnel policy to ensure that the designated SRv6 TE policy tunnel is preferentially iterated.
Procedures
Configuring CE 1
<CE1> system-view
[CE1] sysname CE1
[CE1] bgp 200
Configuring PE 1
<PE1> system-view
[PE1] sysname PE1
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
# Iterate VPN routes to the SRv6 TE policy tunnel.
[PE1-segment-routing-ipv6-locator-abc] opcode 1 end no-flavor
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 traffic-engineering
# Configure SRv6 TE policy on PE 1.
[PE1-segment-routing-ipv6] traffic-engineering
[PE1-srv6-te] srv6-policy locator abc
[PE1-srv6-te] segment-list s1
[PE1-srv6-te-sl-s1] index 10 ipv6 200:1::1
[PE1-srv6-te-sl-s1] index 20 ipv6 300:1::1
[PE1-srv6-te-sl-s1] quit
[PE1-srv6-te] policy p1
[PE1-srv6-te-policy-p1] color 10 end-point ipv6 3::3
[PE1-srv6-te-policy-p1] candidate-paths
[PE1-srv6-te-policy-p1-path] preference 10
[PE1-srv6-te-policy-p1-path-pref-10] explicit segment-list s1
[PE1-srv6-te-policy-p1-path-pref-10] quit
[PE1-srv6-te-policy-p1-path] quit
[PE1-srv6-te-policy-p1] quit
[PE1-srv6-te] quit
# On PE 1, configure a routing policy and a tunnel policy to direct VPN traffic to the specified SRv6 TE policy tunnel and ensure that the SRv6 TE policy tunnel is the preferred tunnel.
[PE1] route-policy a permit node 10
[PE1-route-policy-a-10] apply extcommunity color 00:10
[PE1-route-policy-a-10] quit
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 3::3 route-policy a import
[PE1] tunnel-policy a
[PE1-tunnel-policy-a] select-seq srv6-policy load-balance-number 1
[PE1-tunnel-policy-a] quit
[PE1-vpn-instance-vpn1] tnl-policy a
Configuring P
<P> system-view
[P] sysname P
[P] isis 1
[P-isis-1] cost-style wide
[P-isis-1] network-entity 00.0000.0000.0002.00
[P-isis-1] address-family ipv6 unicast
[P-isis-1-ipv6] quit
[P-isis-1] quit
[P] interface loopback 1
[P-LoopBack1] ipv6 address 2::2 128
[P-LoopBack1] isis ipv6 enable 1
[P-LoopBack1] quit
[P] interface ten-gigabitethernet 3/1/2
[P-Ten-GigabitEthernet3/1/2] ipv6 address 2001::2 96
[P-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[P-Ten-GigabitEthernet3/1/2] quit
[P] interface ten-gigabitethernet 3/1/1
[P-Ten-GigabitEthernet3/1/1] ipv6 address 3001::2 96
[P-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[P-Ten-GigabitEthernet3/1/1] quit
# Configure a locator on P and advertise the locator through IS-IS.
[P] segment-routing ipv6
[P-segment-routing-ipv6] locator abc ipv6-prefix 200:1:: 64 static 16
[P-segment-routing-ipv6-locator-abc] opcode 1 end no-flavor
[P-segment-routing-ipv6-locator-abc] quit
[P-segment-routing-ipv6] quit
[P] isis 1
[P-isis-1-ipv6] segment-routing ipv6 locator abc
[P-isis-1] quit
Configuring PE 2
<PE2> system-view
[PE2] sysname PE2
[PE2] isis 1
[PE2-isis-1] network-entity 00.0000.0000.0003.00
[PE2-isis-1] quit
[PE2-LoopBack1] ipv6 address 3::3 128
[PE2-Ten-GigabitEthernet3/1/1] ipv6 address 3001::1 96
[PE2-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[PE2-Ten-GigabitEthernet3/1/2] ip binding vpn-instance vpn1
[PE2-Ten-GigabitEthernet3/1/2] ip address 20.1.1.2 24
[PE2] bgp 100
[PE2-bgp-default] router-id 3.3.3.3
[PE2-bgp-default-ipv4-vpn1] peer 20.1.1.1 enable
[PE2-bgp-default-ipv4-vpn1] import-route direct
[PE2-segment-routing-ipv6] encapsulation source-address 3::3
[PE2-segment-routing-ipv6] locator abc ipv6-prefix 300:1:: 64 static 16
[PE2-segment-routing-ipv6-locator-abc] opcode 1 end no-flavor
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 100
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 traffic-engineering
# Configure SRv6 TE policy on PE 2.
[PE2-segment-routing-ipv6] traffic-engineering
[PE2-srv6-te] srv6-policy locator abc
[PE2-srv6-te] segment-list s1
[PE2-srv6-te-sl-s1] index 10 ipv6 200:1::1
[PE2-srv6-te-sl-s1] index 20 ipv6 100:1::1
[PE2-srv6-te-sl-s1] quit
[PE2-srv6-te] policy p1
[PE2-srv6-te-policy-p1] color 10 end-point ipv6 1::1
[PE2-srv6-te-policy-p1] candidate-paths
[PE2-srv6-te-policy-p1-path] preference 10
[PE2-srv6-te-policy-p1-path-pref-10] explicit segment-list s1
[PE2-srv6-te-policy-p1-path-pref-10] quit
[PE2-srv6-te-policy-p1-path] quit
[PE2-srv6-te-policy-p1] quit
[PE2-srv6-te] quit
# On PE 2, configure a routing policy and a tunnel policy to direct VPN traffic to the specified SRv6 TE policy tunnel and ensure that the SRv6 TE policy tunnel is the preferred tunnel.
[PE2] route-policy a permit node 10
[PE2-route-policy-a-10] apply extcommunity color 00:10
[PE2-route-policy-a-10] quit
[PE2] bgp 100
[PE2-bgp-default-vpnv4] peer 1::1 route-policy a import
[PE2] tunnel-policy a
[PE2-tunnel-policy-a] select-seq srv6-policy load-balance-number 1
[PE2-tunnel-policy-a] quit
[PE2-vpn-instance-vpn1] tnl-policy a
Configuring CE 2
<CE2> system-view
[CE2] sysname CE2
[CE2-Ten-GigabitEthernet3/1/2] ip address 20.1.1.1 24
[CE2] bgp 300
# On PE 1, execute the display segment-routing ipv6 te policy command to view the detailed information of the SRv6 TE policy tunnel. Verify that the status field of the SRv6 TE policy tunnel displays Up.
[PE1] display segment-routing ipv6 te policy
Name/ID: p1/0
Color: 10
End-point: 3::3
Name from BGP:
BSID:
Mode: Dynamic Type: Type_2 Request state: Succeeded
Current BSID: 100:1::1:0 Explicit BSID: - Dynamic BSID: 100:1::1:0
Reference counts: 4
Flags: A/BS/NC
Status: Up
AdminStatus: Up
Up time: 2021-11-17 16:21:17
Down time: 2021-11-17 15:54:22
Hot backup: Not configured
Statistics: Not configured
Statistics by service class: Not configured
Drop-upon-invalid: Disabled
BFD trigger path-down: Disabled
SBFD: Not configured
BFD Echo: Not configured
Forwarding index: 2150629377
Service-class: -
Rate-limit: -
Encapsulation mode: -
Candidate paths state: Configured
Candidate paths statistics:
CLI paths: 1 BGP paths: 0 PCEP paths: 0
Candidate paths:
Preference : 10
CPathName:
Instance ID: 0 ASN: 0 Node address: 0.0.0.0
Peer address: ::
Optimal: Y Flags: V/A
Explicit SID list:
ID: 1 Name: s1
Weight: 1 Forwarding index: 2149580802
State: Up State(-): -
Active path MTU: 1428 bytes
# Execute the display ip routing-table vpn-instance vpn1 22.22.22.22 verbose command on PE 1 to view VPN route information. Verify that the egress interface of VPN route 22.22.22.22/32 is SRv6 TE policy tunnel p1.
Summary count : 1
Process ID: 0
SubProtID: 0x1 Age: 00h30m45s
AttrID: 0x5 Neighbor: 3::3
Flags: 0x80010060 OrigNextHop: 3::3
Label: NULL RealNextHop: FE80::6033:29FF:FEAE:307
BkLabel: NULL BkNextHop: N/A
SRLabel: NULL Interface: p1
BkSRLabel: NULL BkInterface: N/A
Tunnel ID: 0x80300001 IPInterface: Ten-GigabitEthernet3/1/2
BkTunnel ID: Invalid BkIPInterface: N/A
Dscp: N/A Exp: N/A
SRTunnelID: 0x80300001 StatFlags: 0x0
SID Type: N/A SID: 300:1::1:0
BkSID: N/A NID: Invalid
FlushNID: 0x80300001 BkNID: Invalid
CommBlockLen: 0
Configuration files
· CE 1:
sysname CE1
combo enable fiber
interface LoopBack0
bgp 200
import-route direct
· PE 1:
sysname PE1
isis 1
non-stop-routing
cost-style wide
tunnel-policy a
interface LoopBack1
isis ipv6 enable 1
combo enable copper
combo enable copper
isis ipv6 enable 1
bgp 100
router-id 1.1.1.1
peer 3::3 enable
import-route direct
traffic-engineering
segment-list s1
policy p1
candidate-paths
preference 10
· P:
sysname P
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
combo enable copper
isis ipv6 enable 1
combo enable copper
isis ipv6 enable 1
· PE 2:
sysname PE2
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
combo enable copper
isis ipv6 enable 1
combo enable copper
bgp 100
router-id 3.3.3.3
peer 1::1 enable
import-route direct
traffic-engineering
segment-list s1
policy p1
candidate-paths
preference 10
· CE 2:
sysname CE2
interface LoopBack0
combo enable copper
bgp 300
import-route direct
As shown in Figure 5, the core network is an IPv6 network, and the private network is an IPv4 network. PE 1 and ASBR 1 belong to AS 100, and PE 2 and ASBR 2 belong to AS 200. AS 100 and AS 200 use IS-IS to implement IPv6 connectivity. Establish a static inter-AS SRv6 TE policy tunnel between PE 1 and PE 2 to transmit IPv4 L3VPN traffic.
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/1/1 |
10.1.1.1/24 |
CE 2 |
XGE3/1/1 |
20.1.1.1/24 |
PE 1 |
Loop1 |
1::1/128 |
PE 2 |
Loop1 |
4::4/128 |
XGE3/1/1 |
10.1.1.2/24 |
XGE3/1/1 |
20.1.1.2/24 |
XGE3/1/2 |
1001::1/96 |
XGE3/1/2 |
2002::1/96 |
ASBR 1 |
Loop1 |
2::2/128 |
ASBR 2 |
Loop1 |
3::3/128 |
XGE3/1/1 |
1001::2/96 |
XGE3/1/1 |
2002::2/96 |
XGE3/1/2 |
3003::1/96 |
XGE3/1/2 |
3003::2/96 |
Procedures
Configuring CE 1
[CE1] bgp 65410
Configuring PE 1
[PE1] isis 1
[PE1-isis-1] quit
[PE1-Ten-GigabitEthernet3/1/2] ipv6 address 1001::1 96
[PE1] bgp 100
[PE1-segment-routing-ipv6-locator-abc] opcode hex ::100 end-x interface ten-gigabitethernet 3/1/2 nexthop 1001::2 no-flavor
[PE1] isis 1
[PE1-isis-1-ipv6] segment-routing ipv6 locator abc auto-sid-disable
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-srv6-te-sl-s1] index 1 ipv6 100:1::100
[PE1-srv6-te-sl-s1] index 2 ipv6 200:1::100
[PE1-srv6-te-sl-s1] index 3 ipv6 300:1::100
[PE1-srv6-te] policy policy1
[PE1-srv6-te-policy-p1] color 10 end-point ipv6 4::4
[PE1-srv6-te] quit
[PE1] route-policy as100 permit node 10
[PE1-route-policy-as100-10] apply extcommunity color 00:10
[PE1-route-policy-as100-10] quit
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 4::4 route-policy as100 import
[PE1] tunnel-policy as100
[PE1-tunnel-policy-as100] select-seq srv6-policy load-balance-number 1
[PE1-tunnel-policy-as100] quit
[PE1-vpn-instance-vpn1] tnl-policy as100
Configuring ASBR 1
[ASBR1] isis 1
[ASBR1-isis-1] quit
[ASBR1-Ten-GigabitEthernet3/1/1] ipv6 address 1001::2 96
[ASBR1-Ten-GigabitEthernet3/1/2] ipv6 address 3003::1 96
[ASBR1] bgp 100
[ASBR1-bgp-default] peer 3003::2 as-number 200
[ASBR1-bgp-default] peer 3003::2 ebgp-max-hop 255
[ASBR1-bgp-default-ipv6] peer 3003::2 enable
# Configure SRv6 BGP EPE on the ASBR and configure static End.X SIDs.
[ASBR1] segment-routing ipv6
[ASBR1-segment-routing-ipv6] locator abc ipv6-prefix 200:1:: 64 static 16
[ASBR1-segment-routing-ipv6-locator-abc] opcode hex ::200 end-x interface Ten-GigabitEthernet3/1/1 nexthop 1001::1 no-flavor
[ASBR1-segment-routing-ipv6-locator-abc] quit
[ASBR1-segment-routing-ipv6] quit
[ASBR1] bgp 100
[ASBR1-bgp-default] segment-routing ipv6 egress-engineering locator abc
[ASBR1-bgp-default] peer 3003::2 egress-engineering srv6 static-sid no-flavor 200:1::100
[ASBR1] ipv6 prefix-list as100 index 10 permit 400:1:: 64
[ASBR1] isis 1
[ASBR1-isis-1] quit
Configuring ASBR 2
[ASBR2] isis 1
[ASBR2-isis-1] quit
[ASBR2-Ten-GigabitEthernet3/1/1] ipv6 address 2002::2 96
[ASBR2-Ten-GigabitEthernet3/1/2] ipv6 address 3003::2 96
[ASBR2] bgp 200
[ASBR2-bgp-default] peer 3003::1 as-number 100
[ASBR2-bgp-default] peer 3003::1 ebgp-max-hop 255
[ASBR2-bgp-default-ipv6] peer 3003::1 enable
[ASBR2] segment-routing ipv6
[ASBR2-segment-routing-ipv6] locator abc ipv6-prefix 300:1:: 64 static 16
[ASBR2-segment-routing-ipv6-locator-abc] opcode hex ::100 end-x interface Ten-GigabitEthernet3/1/1 nexthop 2002::1 no-flavor
[ASBR2-segment-routing-ipv6-locator-abc] quit
[ASBR2-segment-routing-ipv6] quit
[ASBR2] bgp 200
[ASBR2-bgp-default] segment-routing ipv6 egress-engineering locator abc
[ASBR2-bgp-default] peer 3003::1 egress-engineering srv6 static-sid no-flavor 300:1::200
[ASBR2] ipv6 prefix-list as200 index 10 permit 100:1:: 64
[ASBR2] isis 1
[ASBR2-isis-1] quit
Configuring PE 2
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 200
[PE2-segment-routing-ipv6] locator abc ipv6-prefix 400:1:: 64 static 16
[PE1-segment-routing-ipv6-locator-abc] opcode hex ::200 end-x interface Ten-GigabitEthernet3/1/2 nexthop 2002::2 no-flavor
[PE2] isis 1
[PE2-isis-1-ipv6] segment-routing ipv6 locator abc auto-sid-disable
[PE2-isis-1] quit
[PE2] bgp 100
[PE2-srv6-te-sl-s1] index 1 ipv6 400:1::200
[PE2-srv6-te-sl-s1] index 2 ipv6 300:1::200
[PE2-srv6-te-sl-s1] index 3 ipv6 200:1::200
[PE2-srv6-te] policy policy1
[PE2-srv6-te-policy-p1] binding-sid ipv6 400:1::1
[PE2-srv6-te] quit
[PE2] route-policy as200 permit node 10
[PE2-route-policy-as200-10] apply extcommunity color 00:10
[PE2-route-policy-as200-10] quit
[PE2] bgp 200
[PE2-bgp-default-vpnv4] peer 1::1 route-policy as200 import
[PE2] tunnel-policy as200
[PE2-tunnel-policy-as200] select-seq srv6-policy load-balance-number 1
[PE2-tunnel-policy-as200] quit
[PE2-vpn-instance-vpn1] tnl-policy as200
Configuring CE 2
[CE2] bgp 65420
Name/ID: policy1/0
Color: 10
End-point: 4::4
Name from BGP:
BSID:
Mode: Explicit Type: Type_2 Request state: Succeeded
Current BSID: 100:1::1 Explicit BSID: 100:1::1 Dynamic BSID: -
Reference counts: 4
Flags: A/BS/NC
Status: Up
AdminStatus: Up
Up time: 2021-11-27 16:26:20
Down time: 2021-11-27 16:25:55
Service-class: -
Rate-limit: -
Candidate paths:
Preference : 10
CPathName:
Peer address: ::
Explicit SID list:
ID: 1 Name: s1
# Execute the display ip routing-table vpn-instance vpn1 command on PE 1 to view VPN route information. Verify that the egress interface of VPN route 20.1.1.0/24 is SRv6 TE policy tunnel p1.
20.1.1.0/24 BGP 255 0 4::4 policy1
[CE1] ping 20.1.1.1
Configuration files
· CE 1:
sysname CE1
bgp 65410
import-route direct
· PE 1:
sysname PE1
tnl-policy as100
isis 1
cost-style wide
tunnel-policy as100
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
ipv6 address 1001::1/96
bgp 100
router-id 1.1.1.1
peer 4::4 enable
peer 2::2 enable
import-route direct
opcode hex ::100 end-x interface Ten-GigabitEthernet3/1/2 nexthop 1001::2 no-flavor
traffic-engineering
segment-list s1
policy policy1
binding-sid ipv6 100:1::1
candidate-paths
preference 10
· ASBR 1:
sysname ASBR1
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
ipv6 address 1001::2/96
ipv6 address 3003::1/96
bgp 100
router-id 2.2.2.2
peer 1::1 enable
peer 3003::2 enable
· ASBR 2:
sysname ASBR2
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
ipv6 address 3003::2/96
bgp 200
router-id 3.3.3.3
peer 4::4 enable
peer 3003::1 enable
ipv6 prefix-list as200 index 30 permit 1::1 128
· PE 2:
sysname PE2
tnl-policy as200
isis 1
cost-style wide
tunnel-policy as200
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
bgp 200
router-id 4.4.4.4
peer 1::1 enable
peer 3::3 enable
import-route direct
traffic-engineering
segment-list s1
policy policy1
candidate-paths
preference 10
explicit segment-list astoas
· CE 2:
sysname CE2
bgp 65420
import-route direct
As shown in Figure 6, the core network is an IPv6 network, and the private network is an IPv4 network. PE 1, P, and PE 2 belong to the same AS, and they use IS-IS for communication in the IPv6 network. Establish two SRv6 TE policy tunnels between PE 1 and PE 2 to transmit IPv4 EVPN L3VPN traffic. On PE 1 and PE 2, configure a routing policy to set the color attribute for EVPN routes, directing VPN traffic to the specified SRv6 TE policy tunnel.
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/1/1 |
10.1.1.1/24 |
CE 2 |
XGE3/1/2 |
20.1.1.1/24 |
PE 1 |
Loop1 |
1::1/128 |
PE 2 |
Loop1 |
3::3/128 |
XGE3/1/1 |
10.1.1.2/24 |
XGE3/1/1 |
20.1.1.2/24 |
XGE3/1/2 |
1001::1/96 |
XGE3/1/2 |
2001::1/96 |
P |
Loop1 |
2::2/128 |
XGE3/1/1 |
1001::2/96 |
XGE3/1/2 |
2001::2/96 |
Procedures
Configuring CE 1
[CE1] bgp 200
Configuring PE 1
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
# Establish BGP EVPN peer relationship between PEs.
[PE1-bgp-default] address-family l2vpn evpn
[PE1-bgp-default-evpn] peer 3::3 enable
[PE1-bgp-default-evpn] quit
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-bgp-default-evpn] peer 3::3 advertise encap-type srv6
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc evpn
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 traffic-engineering evpn
[PE1-srv6-te] quit
[PE1] bgp 100
[PE1-bgp-default-evpn] peer 3::3 route-policy a import
Configuring P
[Sysname] sysname P
[P] isis 1
[P-isis-1] quit
[P-LoopBack1] quit
[P-Ten-GigabitEthernet3/1/2] ipv6 address 1001::2 96
[P-Ten-GigabitEthernet3/1/1] ipv6 address 2001::2 96
[P] isis 1
[P-isis-1] quit
Configuring PE 2
[PE2] isis 1
[PE2-isis-1] quit
[PE2-Ten-GigabitEthernet3/1/2] ipv6 address 2001::1 96
[PE2] bgp 100
[PE2-bgp-default] address-family l2vpn evpn
[PE2-bgp-default-evpn] peer 1::1 enable
[PE2-bgp-default-evpn] quit
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 100
[PE2-bgp-default-evpn] peer 1::1 advertise encap-type srv6
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc evpn
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 traffic-engineering evpn
[PE2-srv6-te] quit
[PE2] bgp 100
[PE2-bgp-default-evpn] peer 1::1 route-policy a import
Configuring CE 2
[CE2] bgp 300
Name/ID: p1/0
Color: 10
End-point: 3::3
Name from BGP:
BSID:
Current BSID: 100:1::1:3 Explicit BSID: - Dynamic BSID: 100:1::1:3
Reference counts: 4
Flags: A/BS/NC
Status: Up
AdminStatus: Up
Up time: 2021-11-23 19:31:35
Down time: 2021-11-23 19:27:37
Service-class: -
Rate-limit: -
Candidate paths:
Preference : 10
CPathName:
Peer address: ::
Explicit SID list:
ID: 1 Name: s1
# Execute the display ip routing-table vpn-instance vpn1 20.1.1.0 24 command on PE 1 to view VPN route information. Verify that the egress interface of VPN route 20.1.1.0/24 is SRv6 TE policy tunnel p1.
[PE1] display ip routing-table vpn-instance vpn1 20.1.1.0 24
Summary count : 1
20.1.1.0/24 BGP 255 0 3::3 p1
[CE1] ping 20.1.1.1
Ping 20.1.1.1 (20.1.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 20.1.1.1: icmp_seq=0 ttl=253 time=2.000 ms
round-trip min/avg/max/std-dev = 1.000/1.600/2.000/0.490 ms
Configuration files
· CE 1:
sysname CE1
bgp 200
import-route direct
· PE 1:
sysname PE1
tnl-policy a
isis 1
cost-style wide
tunnel-policy a
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
bgp 100
router-id 1.1.1.1
peer 3::3 enable
import-route direct
traffic-engineering
segment-list s1
policy p1
candidate-paths
preference 10
· P:
sysname P
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
isis ipv6 enable 1
· PE 2:
sysname PE2
tnl-policy a
isis 1
cost-style wide
tunnel-policy a
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
bgp 100
router-id 3.3.3.3
peer 1::1 enable
import-route direct
traffic-engineering
segment-list s1
policy p1
candidate-paths
preference 10
· CE 2:
sysname CE2
bgp 300
import-route direct
As shown in Figure 7, the core network is an IPv6 network, and the private network is also an IPv6 network. EVPN L3VPN over SRv6 BE is deployed between the PE devices in the core network to transmit private network data through SRv6 tunnels.
· Both CE 1 and CE 2 belong to VPN 1.
· Configure EBGP to exchange VPN routes between the CE and PE.
· Run IS-IS to implement IPv6 connectivity between the PEs in the same AS, and configure MP-IBGP to implement EVPN route exchange.
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/1/1 |
1000::1/96 |
CE 2 |
XGE3/1/1 |
3000::1/96 |
PE 1 |
Loop1 |
1::1/128 |
PE 2 |
Loop1 |
3::3/128 |
XGE3/1/1 |
1000::2/96 |
XGE3/1/1 |
3000::2/96 |
XGE3/1/2 |
2001::1/96 |
XGE3/1/2 |
2002::1/96 |
P |
Loop1 |
2::2/128 |
XGE3/1/1 |
2001::2/96 |
XGE3/1/2 |
2002::2/96 |
Procedures
Configuring CE 1
[CE1-Ten-GigabitEthernet3/1/1] ipv6 address 1000::1 96
[CE1] bgp 200
[CE1-bgp-default] peer 1000::2 as-number 100
[CE1-bgp-default] address-family ipv6 unicast
[CE1-bgp-default-ipv6] peer 1000::2 enable
[CE1-bgp-default-ipv6] import-route direct
[CE1-bgp-default-ipv6] quit
Configuring PE 1
[PE1] isis 1
[PE1-isis-1] quit
[PE1-Ten-GigabitEthernet3/1/1] ipv6 address 1000::2 96
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 1000::1 as-number 200
[PE1-bgp-default-vpn1] address-family ipv6 unicast
[PE1-bgp-default-ipv6-vpn1] peer 1000::1 enable
[PE1-bgp-default-ipv6-vpn1] import-route direct
[PE1-bgp-default-ipv6-vpn1] quit
# On the PE, specify a source address for the outer IPv6 header of SRv6-encapsulated EVPN L3VPN packets.
# On the PE, configure the locator for the destination address End.DT6 SID of the IPv6 packet header encapsulated in EVPN L3VPN over SRv6.
[PE1-segment-routing-ipv6] locator evpn ipv6-prefix 1:2:: 96 static 16
[PE1-segment-routing-ipv6-locator-evpn] quit
[PE1] isis 1
[PE1-isis-1-ipv6] segment-routing ipv6 locator evpn
[PE1-isis-1] quit
# Enable the PE to exchange End.DT6 SIDs with the IPv6 peer, and allow private network routes to be iterated to the End.DT6 SID routes.
[PE1] bgp 100
[PE1-bgp-default-ipv6-vpn1] segment-routing ipv6 locator evpn evpn
[PE1-bgp-default-ipv6-vpn1] segment-routing ipv6 best-effort evpn
Configuring P
[Sysname] sysname P
[P] isis 1
[P-isis-1] quit
[P-LoopBack1] quit
[P-Ten-GigabitEthernet3/1/2] ipv6 address 2002::2 96
Configuring PE 2
[PE2] isis 1
[PE2-isis-1] quit
[PE2-Ten-GigabitEthernet3/1/1] ipv6 address 3000::2 96
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 3000::1 as-number 300
[PE2-bgp-default-vpn1] address-family ipv6 unicast
[PE2-bgp-default-ipv6-vpn1] peer 3000::1 enable
[PE2-segment-routing-ipv6] locator evpn ipv6-prefix 3:4:: 96 static 16
[PE2-segment-routing-ipv6-locator-evpn] quit
[PE2] isis 1
[PE2-isis-1-ipv6] segment-routing ipv6 locator evpn
[PE2-isis-1] quit
[PE2] bgp 100
[PE2-bgp-default-ipv6-vpn1] segment-routing ipv6 locator evpn evpn
[PE2-bgp-default-ipv6-vpn1] segment-routing ipv6 best-effort evpn
Configuring CE 2
[CE2-Ten-GigabitEthernet3/1/1] ipv6 address 3000::1 96
[CE2] bgp 300
[CE2-bgp-default] peer 3000::2 as-number 100
[CE2-bgp-default] address-family ipv6 unicast
[CE2-bgp-default-ipv6] peer 3000::2 enable
[CE2-bgp-default-ipv6] import-route direct
[CE2-bgp-default-ipv6] quit
# Execute the display bgp l2vpn evpn command on the PE to view detailed information of the routes sent by the remote PE. Verify that the routes from the remote PE carry SID attribute data.
[PE1] display bgp l2vpn evpn [5][0][96][3000::]/176
BGP routing table information of [5][0][96][3000::]/176:
Rely nexthop : FE80::A06E:DBFF:FEFC:316
Original nexthop: 3::3
Route age : 00h00m29s
OutLabel : 3
RxPathID : 0x0
TxPathID : 0x0
PrefixSID : End.DT6 SID <3:4::1:4>
AS-path : (null)
Origin : incomplete
State : valid, internal, best
Source type : local
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : IP prefix advertisement route
ESI : 0000.0000.0000.0000.0000
Ethernet tag ID : 0
IP prefix : 3000::/96
Gateway address : ::
MPLS label : 3
Re-orignination : Disable
[CE1] ping ipv6 3000::1
Ping6(56 data bytes) 1000::1 --> 3000::1, press CTRL_C to break
56 bytes from 3000::1, icmp_seq=0 hlim=62 time=3.000 ms
56 bytes from 3000::1, icmp_seq=1 hlim=62 time=2.000 ms
56 bytes from 3000::1, icmp_seq=2 hlim=62 time=2.000 ms
56 bytes from 3000::1, icmp_seq=3 hlim=62 time=2.000 ms
56 bytes from 3000::1, icmp_seq=4 hlim=62 time=2.000 ms
--- Ping6 statistics for 3000::1 ---
round-trip min/avg/max/std-dev = 2.000/2.200/3.000/0.400 ms
Configuration files
· CE 1:
sysname CE1
ipv6 address 1000::1/96
bgp 200
import-route direct
peer 1000::2 enable
· PE 1:
sysname PE1
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
ipv6 address 1000::2/96
isis ipv6 enable 1
bgp 100
router-id 1.1.1.1
peer 3::3 enable
import-route direct
peer 1000::1 enable
· P:
sysname P
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
isis ipv6 enable 1
· PE 2:
sysname PE2
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
ipv6 address 3000::2/96
isis ipv6 enable 1
bgp 100
router-id 2.2.2.2
peer 1::1 enable
import-route direct
peer 3000::1 enable
· CE 2:
sysname CE2
ipv6 address 3000::1/96
bgp 300
import-route direct
peer 3000::2 enable
As shown in Figure 8, the core network is an IPv6 network, and the private network is an IPv6 network. PE 1, P 1, P 2, and PE 2 belong to the same AS, and they use IS-IS for communication in the IPv6 network. Establish two SRv6 BE tunnels between PE 1 and PE 2 to transmit IPv6 EVPN L3VPN traffic. To fully utilize network resources, configure ECMP on the SRv6 BE tunnels between PE 1 and PE 2.
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/1/1 |
1000::1/96 |
CE 2 |
XGE3/1/1 |
4000::1/96 |
PE 1 |
Loop1 |
1::1/128 |
PE 2 |
Loop1 |
4::4/128 |
XGE3/1/1 |
1000::2/96 |
XGE3/1/1 |
4000::2/96 |
XGE3/1/2 |
2001::1/96 |
XGE3/1/2 |
2002::1/96 |
XGE3/1/3 |
3001::1/96 |
XGE3/1/3 |
3002::1/96 |
P 1 |
Loop1 |
2::2/128 |
P 2 |
Loop1 |
2::2/128 |
XGE3/1/1 |
2001::2/96 |
XGE3/1/1 |
3001::2/96 |
XGE3/1/2 |
2002::2/96 |
XGE3/1/2 |
3002::2/96 |
Procedures
Configuring CE 1
[CE1] bgp 200
Configuring PE 1
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-bgp-default-evpn] peer 4::4 enable
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-bgp-default-evpn] peer 4::4 advertise encap-type srv6
[PE1-bgp-default-ipv6-vpn1] segment-routing ipv6 locator abc evpn
Configuring P 1
[P1] isis 1
[P1-isis-1] quit
[P1-LoopBack1] quit
Configuring P 2
[P2] isis 1
[P2-isis-1] quit
[P2-LoopBack1] ipv6 address 2::2 128
[P2-LoopBack1] quit
Configuring PE 2
[PE2] isis 1
[PE2-isis-1] quit
[PE2-Ten-GigabitEthernet3/1/1] ipv6 address 4000::2 96
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 4000::1 as-number 300
[PE2-bgp-default-ipv6-vpn1] peer 4000::1 enable
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 100
[PE2-bgp-default-ipv6-vpn1] segment-routing ipv6 locator abc evpn
Configuring CE 2
[CE2-Ten-GigabitEthernet3/1/1] ipv6 address 4000::1 96
[CE2] bgp 300
[CE2-bgp-default] peer 4000::2 as-number 100
[CE2-bgp-default-ipv6] peer 4000::2 enable
# Execute the display ipv6 routing-table vpn-instance command on to view VPN route information. Verify that VPN route 4000::1/96 has two egress interfaces, forming ECMP routes.
[PE1] display ipv6 routing-table vpn-instance vpn1 4000::1 96
Summary count : 1
Destination: 4000::/96 Protocol : BGP4+
NextHop : 200:1:: Preference: 255
Interface : XGE3/1/2 Cost : 0
Interface : XGE3/1/3 Cost : 0
[CE1] ping ipv6 4000::1
Ping6(56 data bytes) 1000::1 --> 4000::1, press CTRL_C to break
56 bytes from 4000::1, icmp_seq=0 hlim=62 time=2.000 ms
56 bytes from 4000::1, icmp_seq=1 hlim=62 time=2.000 ms
56 bytes from 4000::1, icmp_seq=2 hlim=62 time=2.000 ms
56 bytes from 4000::1, icmp_seq=3 hlim=62 time=1.000 ms
56 bytes from 4000::1, icmp_seq=4 hlim=62 time=1.000 ms
--- Ping6 statistics for 4000::1 ---
Configuration files
· CE 1:
sysname CE1
bgp 200
import-route direct
peer 1000::2 enable
· PE 1:
sysname PE1
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
isis ipv6 enable 1
bgp 100
router-id 1.1.1.1
peer 4::4 enable
import-route direct
peer 1000::1 enable
· P 1:
sysname P1
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
isis ipv6 enable 1
· P 2:
sysname P2
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
isis ipv6 enable 1
· PE 2:
sysname PE2
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
ipv6 address 4000::2/96
isis ipv6 enable 1
isis ipv6 enable 1
bgp 100
router-id 4.4.4.4
peer 1::1 enable
import-route direct
peer 4000::1 enable
· CE 2:
sysname CE2
ipv6 address 4000::1/96
bgp 300
import-route direct
peer 4000::2 enable
As shown in Figure 9, the core network is an IPv6 network, and the private network is an IPv6 network. PE 1, P 1, P 2, and PE 2 belong to the same AS, and they use IS-IS for communication in the IPv6 network. Establish two SRv6 BE tunnels between PE 1 and PE 2 to transmit IPv6 EVPN L3VPN traffic. To enhance network reliability, configure FRR on PE 1 to quickly switch traffic to the backup path when the primary path fails, reducing recovery time.
Device |
IP address |
Device |
IP address |
PE 1 |
Loop1 |
1::1/128 |
PE 2 |
Loop1 |
2::2/128 |
XGE3/1/1 |
1000::2/96 |
XGE3/1/1 |
2001::2/96 |
XGE3/1/2 |
2001::1/96 |
XGE3/1/2 |
2002::2/96 |
XGE3/1/3 |
3001::1/96 |
PE 3 |
Loop1 |
3::3/128 |
XGE3/1/1 |
3001::2/96 |
XGE3/1/2 |
3002::2/96 |
CE 1 |
Loop1 |
11::11/128 |
CE 2 |
Loop1 |
22::22/128 |
XGE3/1/1 |
1000::1/96 |
XGE3/1/1 |
2002::1/96 |
XGE3/1/2 |
3002::1/96 |
Procedures
Configuring CE 1
[CE1] interface loopback 1
[CE1-LoopBack1] ipv6 address 11::11 128
[CE1-LoopBack1] quit
[CE1] bgp 200
Configuring PE 1
# Configure IPv6 IS-IS on the PEs and device P for network connectivity between the devices.
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-bgp-default-evpn] peer 2::2 enable
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-bgp-default-evpn] peer 2::2 advertise encap-type srv6
# Configure FRR.
[PE1-bgp-default-ipv6-vpn1] pic
# Configure static BFD to detect locator routes. If the locator route is not reachable, FRR will switch the traffic to the backup path.
[PE1] bfd static test peer-ipv6 200:1:: source-ipv6 100:1:: discriminator local 10 remote 20
[PE1-bfd-static-session-test] bfd multi-hop min-transmit-interval 100
[PE1-bfd-static-session-test] bfd multi-hop min-receive-interval 100
[PE1-bfd-static-session-test] bfd multi-hop detect-multiplier 3
[PE1-bfd-static-session-test] quit
[PE1] bgp 100
Configuring PE 2
[PE2] isis 1
[PE2-isis-1] quit
[PE2-Ten-GigabitEthernet3/1/1] ipv6 address 2001::2 96
[PE2-vpn-instance-vpn1] route-distinguisher 200:1
[PE2-Ten-GigabitEthernet3/1/2] ipv6 address 2002::2 96
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 2002::1 as-number 300
[PE2-bgp-default-ipv6-vpn1] peer 2002::1 enable
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 100
[PE2] bfd static test peer-ipv6 100:1:: source-ipv6 200:1:: discriminator local 20 remote 10
[PE2-bfd-static-session-test] bfd multi-hop min-transmit-interval 100
[PE2-bfd-static-session-test] bfd multi-hop min-receive-interval 100
[PE2-bfd-static-session-test] bfd multi-hop detect-multiplier 3
[PE2-bfd-static-session-test] quit
Configuring PE 3
[Sysname] sysname PE3
[PE3] isis 1
[PE3-isis-1] quit
[PE3] interface ten-gigabitethernet 3/1/1
[PE3-Ten-GigabitEthernet3/1/1] ipv6 address 3001::2 96
[PE3-Ten-GigabitEthernet3/1/1] isis ipv6 enable 1
[PE3-vpn-instance-vpn1] route-distinguisher 300:1
[PE3-Ten-GigabitEthernet3/1/2] ip binding vpn-instance vpn1
[PE3-Ten-GigabitEthernet3/1/2] ipv6 address 3002::2 96
[PE3] bgp 100
[PE3-bgp-default-vpn1] peer 3002::1 as-number 300
[PE3-bgp-default-vpn1] address-family ipv6 unicast
[PE3-bgp-default-ipv6-vpn1] peer 3002::1 enable
[PE3-bgp-default] address-family l2vpn evpn
[PE3-bgp-default-evpn] peer 1::1 enable
[PE3-bgp-default-evpn] quit
[PE3] isis 1
[PE3-isis-1] quit
[PE3] bgp 100
[PE3-bgp-default-evpn] peer 1::1 advertise encap-type srv6
[PE3-bgp-default-ipv6-vpn1] segment-routing ipv6 locator abc evpn
[PE3-bgp-default-ipv6-vpn1] segment-routing ipv6 best-effort evpn
Configuring CE 2
[CE2] interface loopback 1
[CE2-LoopBack1] ipv6 address 22::22 128
[CE2-LoopBack1] quit
[CE2-Ten-GigabitEthernet3/1/1] ipv6 address 2002::1 96
[CE2-Ten-GigabitEthernet3/1/2] ipv6 address 3002::1 96
[CE2] bgp 300
[CE2-bgp-default] peer 2002::2 as-number 100
[CE2-bgp-default] peer 3002::2 as-number 100
[CE2-bgp-default-ipv6] peer 2002::2 enable
[CE2-bgp-default-ipv6] peer 3002::2 enable
# Execute the display ipv6 routing-table vpn-instance verbose command on to view VPN route information. Verify that VPN route 22::22/128 has a backup egress interface.
[PE1] display ipv6 routing-table vpn-instance vpn1 22::22 128 verbose
Summary count : 1
Destination: 22::22/128
Protocol: BGP4+ instance default
Process ID: 0
SubProtID: 0x8 Age: 00h27m38s
FlushedAge: 00h27m38s
TableID: 0x10a OrigAs: 300
NibID: 0x2600000a LastAs: 300
AttrID: 0x0
BkAttrID: 0x7 Neighbor: 2::2
Label: NULL RealNextHop: FE80::8099:2EFF:FE26:316
BkLabel: NULL BkNextHop: FE80::8099:32FF:FEB6:416
InLabel: 0 ColorInterface: N/A
SIDIndex: 0 BkColorInterface: N/A
FtnIndex: 0x0 TunnelInterface: N/A
TrafficIndex: N/A BkTunnelInterface: N/A
Connector: N/A PathID: 0x0
UserID: 0x0 SRTunnelID: Invalid
SID Type: N/A NID: Invalid
BkFlushNID: Invalid StatFlags: 0x0
SID: 200:1::1:4
BkSID: 300:1::1:4
CommBlockLen: 0 Priority: Low
[CE1] ping ipv6 22::22
Ping6(56 data bytes) 1000::1 --> 22::22, press CTRL_C to break
56 bytes from 22::22, icmp_seq=0 hlim=62 time=2.000 ms
56 bytes from 22::22, icmp_seq=1 hlim=62 time=2.000 ms
56 bytes from 22::22, icmp_seq=2 hlim=62 time=1.000 ms
56 bytes from 22::22, icmp_seq=3 hlim=62 time=1.000 ms
56 bytes from 22::22, icmp_seq=4 hlim=62 time=1.000 ms
--- Ping6 statistics for 22::22 ---
round-trip min/avg/max/std-dev = 1.000/1.400/2.000/0.490 ms
# Shut down interface Ten-GigabitEthernet 3/1/2 on PE 1.
[PE1] interface ten-gigabitethernet 3/1/2
[PE1-Ten-GigabitEthernet3/1/2] shutdown
[PE1-Ten-GigabitEthernet3/1/2] quit
# Execute the display ipv6 routing-table vpn-instance verbose command on PE 1 to view VPN route information. Verify that the egress interface of VPN route 22::22/128 changed to Ten-GigabitEthernet 3/1/3.
Summary count : 1
Process ID: 0
SubProtID: 0x8 Age: 01h24m03s
NibID: 0x26000007 LastAs: 300
AttrID: 0x3 Neighbor: 3::3
Flags: 0x80010060 OrigNextHop: 300:1::
Label: NULL RealNextHop: FE80::843:49FF:FE7B:506
SRLabel: NULL Interface: Ten-GigabitEthernet3/1/3
Tunnel ID: Invalid IPInterface: Ten-GigabitEthernet3/1/3
Dscp: N/A Exp: N/A
SID Type: N/A SID: 300:1::1:2
CommBlockLen: 0
Configuration files
· CE 1:
sysname CE1
bgp 200
router-id 11.11.11.11
import-route direct
peer 1000::2 enable
· PE 1:
sysname PE1
isis 1
cost-style wide
network-entity 00.0000.0000.0001.00
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
isis ipv6 enable 1
bgp 100
router-id 1.1.1.1
peer 2::2 enable
peer 3::3 enable
pic
import-route direct
peer 1000::1 enable
encapsulation source-address 1::1
locator abc ipv6-prefix 100:1:: 64 static 16
· PE 2:
sysname PE2
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
bgp 100
router-id 2.2.2.2
peer 1::1 enable
import-route direct
peer 2002::1 enable
· PE 3:
sysname PE3
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
isis ipv6 enable 1
bgp 100
router-id 3.3.3.3
peer 1::1 enable
undo advertise l2vpn evpn
import-route direct
peer 3002::1 enable
· CE 2:
sysname CE2
interface LoopBack1
ipv6 address 22::22/128
bgp 300
import-route direct
peer 2002::2 enable
peer 3002::2 enable
Example: Configuring IPv6 EVPN L3VPN over SRv6 TE policy (static configuration)
As shown in Figure 10, the core network is an IPv6 network, and the private network is an IPv6 network. PE 1, P, and PE 2 belong to the same AS, and they use IS-IS for communication in the IPv6 network. Establish two SRv6 TE policy tunnels between PE 1 and PE 2 to transmit IPv6 EVPN L3VPN traffic. Configure a routing policy on PE 1 and PE 2 to configure the color attributes of the EVPN routes to direct traffic to the specified SRv6 TE policy tunnel.
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/1/1 |
100::1/96 |
CE 2 |
XGE3/1/2 |
200::1/96 |
PE 1 |
Loop1 |
1::1/128 |
PE 2 |
Loop1 |
3::3/128 |
XGE3/1/1 |
100::2/96 |
XGE3/1/1 |
200::2/96 |
XGE3/1/2 |
1001::1/96 |
XGE3/1/2 |
2001::1/96 |
P |
Loop1 |
2::2/128 |
XGE3/1/1 |
1001::2/96 |
XGE3/1/2 |
2001::2/96 |
Procedures
Configuring CE 1
[Sysname] sysname CE1
[CE1] interface ten-gigabitethernet 3/1/1
[CE1-Ten-GigabitEthernet3/1/1] ipv6 address 100::1 96
[CE1-Ten-GigabitEthernet3/1/1] quit
[CE1] bgp 200
[CE1-bgp-default] router-id 11.11.11.11
[CE1-bgp-default] peer 100::2 as-number 100
[CE1-bgp-default-ipv6] peer 100::2 enable
[CE1-bgp-default] quit
Configuring PE 1
[Sysname] sysname PE1
[PE1] isis 1
[PE1-isis-1] cost-style wide
[PE1-isis-1] network-entity 00.0000.0000.0001.00
[PE1-isis-1] address-family ipv6 unicast
[PE1-isis-1-ipv6] quit
[PE1-isis-1] quit
[PE1] interface loopback 1
[PE1-LoopBack1] ipv6 address 1::1 128
[PE1-LoopBack1] isis ipv6 enable 1
[PE1-LoopBack1] quit
[PE1-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 100:1
[PE1-vpn-instance-vpn1] quit
[PE1] interface ten-gigabitethernet 3/1/1
[PE1-Ten-GigabitEthernet3/1/1] ip binding vpn-instance vpn1
[PE1-Ten-GigabitEthernet3/1/1] ipv6 address 100::2 96
[PE1-Ten-GigabitEthernet3/1/1] quit
[PE1] bgp 100
[PE1-bgp-default] router-id 1.1.1.1
[PE1-bgp-default-vpn1] peer 100::1 as-number 200
[PE1-bgp-default-ipv6-vpn1] peer 100::1 enable
[PE1-bgp-default-vpn1] quit
[PE1-bgp-default] quit
[PE1] segment-routing ipv6
[PE1-segment-routing-ipv6] encapsulation source-address 1::1
[PE1-segment-routing-ipv6] locator abc ipv6-prefix 100:1:: 64 static 16
[PE1-segment-routing-ipv6-locator-abc] quit
[PE1-segment-routing-ipv6] quit
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
[PE1-bgp-default-ipv6-vpn1] segment-routing ipv6 traffic-engineering evpn
[PE1-srv6-te] quit
[PE1] bgp 100
Configuring P
[Sysname] sysname P
[P] isis 1
[P-isis-1] quit
[P-LoopBack1] quit
[P] isis 1
[P-isis-1] quit
Configuring PE 2
[Sysname] sysname PE2
[PE2] isis 1
[PE2-isis-1] cost-style wide
[PE2-isis-1] address-family ipv6 unicast
[PE2-isis-1-ipv6] quit
[PE2-isis-1] quit
[PE2] interface loopback 1
[PE2-LoopBack1] isis ipv6 enable 1
[PE2-LoopBack1] quit
[PE2] interface ten-gigabitethernet 3/1/2
[PE2-Ten-GigabitEthernet3/1/2] isis ipv6 enable 1
[PE2-Ten-GigabitEthernet3/1/2] quit
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 100:1
[PE2-vpn-instance-vpn1] vpn-target 100:1
[PE2-vpn-instance-vpn1] quit
[PE2] interface ten-gigabitethernet 3/1/1
[PE2-Ten-GigabitEthernet3/1/1] ip binding vpn-instance vpn1
[PE2-Ten-GigabitEthernet3/1/1] ipv6 address 200::2 96
[PE2-Ten-GigabitEthernet3/1/1] quit
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 200::1 as-number 300
[PE2-bgp-default-ipv6-vpn1] peer 200::1 enable
[PE2-bgp-default-ipv6-vpn1] import-route direct
[PE2-bgp-default-ipv6-vpn1] quit
[PE2-bgp-default-vpn1] quit
[PE2-bgp-default] peer 1::1 as-number 100
[PE2-bgp-default] peer 1::1 connect-interface loopback 1
[PE2-bgp-default] quit
[PE2] segment-routing ipv6
[PE2-segment-routing-ipv6-locator-abc] quit
[PE2-segment-routing-ipv6] quit
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 100
[PE2-bgp-default-ipv6-vpn1] segment-routing ipv6 traffic-engineering evpn
[PE2-srv6-te] quit
[PE2] bgp 100
Configuring CE 2
[Sysname] sysname CE2
[CE2-Ten-GigabitEthernet3/1/2] ipv6 address 200::1 96
[CE2] bgp 300
[CE2-bgp-default] router-id 22.22.22.22
[CE2-bgp-default] peer 200::2 as-number 100
[CE2-bgp-default-ipv6] peer 200::2 enable
[CE2-bgp-default] quit
Name/ID: p1/0
Color: 10
End-point: 3::3
Name from BGP:
BSID:
Reference counts: 4
Flags: A/BS/NC
Status: Up
AdminStatus: Up
Service-class: -
Rate-limit: -
Candidate paths:
Preference : 10
CPathName:
Peer address: ::
Explicit SID list:
ID: 1 Name: s1
# Execute the display ip routing-table vpn-instance vpn1 200::1 96 command on PE 1 to view VPN route information. Verify that the egress interface of VPN route 200::1/96 is SRv6 TE policy tunnel p1.
[PE1] display ipv6 routing-table vpn-instance vpn1 200::1 96
Summary count : 1
Destination: 200::/96 Protocol : BGP4+
NextHop : 3::3 Preference: 255
Interface : p1 Cost : 0
# Verify that CE 1 and CE 2 can ping each other.
[CE1] >ping ipv6 200::1
Ping6(56 data bytes) 100::1 --> 200::1, press CTRL_C to break
56 bytes from 200::1, icmp_seq=0 hlim=62 time=2.000 ms
56 bytes from 200::1, icmp_seq=1 hlim=62 time=1.000 ms
56 bytes from 200::1, icmp_seq=2 hlim=62 time=2.000 ms
56 bytes from 200::1, icmp_seq=3 hlim=62 time=2.000 ms
56 bytes from 200::1, icmp_seq=4 hlim=62 time=1.000 ms
--- Ping6 statistics for 200::1 ---
round-trip min/avg/max/std-dev = 1.000/1.600/2.000/0.490 mss
Configuration files
· CE 1:
sysname CE1
port link-mode route
ipv6 address 100::1/96
bgp 200
import-route direct
peer 100::2 enable
· PE 1:
sysname PE1
tnl-policy a
vpn-target 100:1 import-extcommunity
vpn-target 100:1 export-extcommunity
isis 1
cost-style wide
tunnel-policy a
interface LoopBack1
isis ipv6 enable 1
ipv6 address 1::1/128
ipv6 address 100::2/96
isis ipv6 enable 1
bgp 100
router-id 1.1.1.1
peer 3::3 enable
import-route direct
peer 100::1 enable
traffic-engineering
segment-list s1
policy p1
candidate-paths
preference 10
· P:
sysname P
isis 1
cost-style wide
interface LoopBack1
isis ipv6 enable 1
ipv6 address 2::2/128
isis ipv6 enable 1
isis ipv6 enable 1
ipv6 address 2001::2/96
· PE 2:
sysname PE2
tnl-policy a
isis 1
cost-style wide
tunnel-policy a
interface LoopBack1
isis ipv6 enable 1
ipv6 address 3::3/128
ipv6 address 200::2/96
isis ipv6 enable 1
ipv6 address 2001::1/96
bgp 100
router-id 3.3.3.3
peer 1::1 enable
import-route direct
peer 200::1 enable
traffic-engineering
segment-list s1
policy p1
candidate-paths
preference 10
· CE 2:
sysname CE2
ipv6 address 200::1/96
bgp 300
import-route direct
peer 200::2 enable
Example: Configuring connectivity between EVPN L3VPN and EVPN L3VPN over SRv6
As shown in Figure 11, PE 1 and PE 2 belong to the EVPN L3VPN network. PE 2 and PE 3 belong to the EVPN L3VPN over SRv6 network. PE 2 is the border device of the EVPN L3VPN network and the EVPN L3VPN over SRv6 networks.
· Configure an SR-MPLS BE tunnel between PE 1 and PE 2 as the public tunnel.
· Configure an SRv6 BE tunnel between PE 2 and PE 3 as the public tunnel.
· PE 1, PE 2, and PE 3 belong to the same AS.
· EVPN L3VPN and EVPN L3VPN over SRv6 networks use Option B for intra-domain connectivity.
· CE 1 and CE 4 belong to VPN 1, and CE 2, CE 3, and CE 5 belong to VPN 2.
Configuration analysis
To enable EVPN L3VPN and EVPN L3VPN over SRv6 networks to use Option B for intra-domain connectivity, perform the following tasks:
· Configure EVPN L3VPN on PE 1 and PE 2, and configure a tunnel policy to specify the SR-MPLS BE tunnel as the public tunnel.
· Configure EVPN L3VPN over SRv6 on PE 2 and PE 3, and iterate packets encapsulating End.DT4 SID to the SRv6 BE tunnel.
· Enable connectivity between the SRv6 and MPLS networks on border node PE 2. Specify the BGP-referenced locator to allocate End.T SIDs for packets forwarded from the SRv6 network to the MPLS network. Associate End.T SIDs with MPLS labels.
After you enable connectivity between the SRv6 and MPLS networks, the device allocates labels based on a per next-hop basis when routes are advertised from the SRv6 network to the MPLS network. The label allocation mode is not affected by the label-allocation-mode or apply-label command.
When configuring the EVPN L3VPN over SRv6 network, follow these restrictions and guidelines:
· For two PEs to exchange traffic through an SRv6 tunnel, establish either an IPv4 or IPv6 peer relationship between the PEs.
· IS-IS and BGP can reference only locators that have been created.
· The SRv6 encapsulated source address cannot be a loopback address, link-local address, multicast address, or unspecified address. The source address must be a local address that has been advertised by a routing protocol. As a best practice, specify the loopback interface address of the local device as the source address.
Procedures
Configuring PE 1
1. Configuring IP addresses and unicast routing protocols
# Configure IS-IS to implement network layer connectivity, and specify the wide cost type.
[PE1] isis 1
[PE1-isis-1] quit
# Configure IP addresses for interfaces loopback 0 and Ten-GigabitEthernet 3/1/1, and enable IS-IS on the interfaces.
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.1 255.255.255.255
[PE1-LoopBack0] ipv6 address 11::11 128
[PE1-LoopBack0] isis enable 1
[PE1-LoopBack0] quit
[PE1-Ten-GigabitEthernet3/1/1] port link-mode route
[PE1-Ten-GigabitEthernet3/1/1] ip address 11.0.1.1 24
[PE1-Ten-GigabitEthernet3/1/1] isis enable 1
2. Configure the MPLS LSR ID, and enable MPLS and MPLS TE.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls te
[PE1-te] quit
[PE1-Ten-GigabitEthernet3/1/1] mpls enable
[PE1-Ten-GigabitEthernet3/1/1] mpls te enable
3. Configure VPN instances for the CE to access the PE.
# Create VPN instance vpn1, and configure its RD and RT.
[PE1-vpn-instance-vpn1] route-distinguisher 1111:1
[PE1-vpn-instance-vpn1] vpn-target 1111:1000 import-extcommunity
[PE1-vpn-instance-vpn1] vpn-target 1111:1000 export-extcommunity
# Create VPN instance vpn2, and configure its RD and RT.
[PE1] ip vpn-instance vpn2
[PE1-vpn-instance-vpn2] route-distinguisher 2222:1
[PE1-vpn-instance-vpn2] vpn-target 2222:2000 import-extcommunity
[PE1-vpn-instance-vpn2] vpn-target 2222:2000 export-extcommunity
[PE1-vpn-instance-vpn2] quit
# Bind interface Ten-GigabitEthernet 3/1/2 to VPN instance vpn1.
[PE1-Ten-GigabitEthernet3/1/2] ip binding vpn-instance vpn1
[PE1-Ten-GigabitEthernet3/1/2] ip address 10.1.1.1 24
# Bind interface Ten-GigabitEthernet 3/1/3 to VPN instance vpn2.
[PE1] interface ten-gigabitethernet 3/1/3
[PE1-Ten-GigabitEthernet3/1/3] ip binding vpn-instance vpn2
[PE1-Ten-GigabitEthernet3/1/3] ip address 20.1.1.1 24
[PE1-Ten-GigabitEthernet3/1/3] quit
4. Configure IS-IS SRGB, enable MPLS TE, and enable SR-MPLS in IS-IS IPv4 unicast address family view.
[PE1] isis 1
[PE1-isis-1] mpls te enable
[PE1-isis-1] segment-routing global-block 16000 16999
[PE1-isis-1] address-family ipv4
[PE1-isis-1-ipv4] segment-routing mpls
[PE1-isis-1-ipv4] segment-routing adjacency enable
[PE1-isis-1-ipv4] quit
[PE1-isis-1] quit
5. Configure the prefix SID for interface loopback 0.
[PE1-LoopBack0] isis prefix-sid index 10
6. Configure PE 1 and PE 2 to establish MP-IBGP peer relationship to exchange BGP EVPN routes.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.2 as-number 100
[PE1-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[PE1-bgp-default-evpn] peer 2.2.2.2 enable
[PE1-bgp-default-evpn] peer 2.2.2.2 advertise encap-type mpls
[PE1-bgp-default-evpn] peer 2.2.2.2 next-hop-local
7. Configure PE 1 to establish EBGP peer relationships with CE 1 and CE 2.
[PE1-bgp-default-vpn1] peer 10.1.1.2 as-number 65410
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.2 enable
[PE1-bgp-default] ip vpn-instance vpn2
[PE1-bgp-default-vpn2] peer 20.1.1.2 as-number 65420
[PE1-bgp-default-vpn2] address-family ipv4 unicast
[PE1-bgp-default-ipv4-vpn2] peer 20.1.1.2 enable
[PE1-bgp-default-ipv4-vpn2] quit
[PE1-bgp-default-vpn2] quit
8. Configure a tunnel policy to enable EVPN L3VPN preferentially select the SR-MPLS BE tunnel as the public tunnel.
[PE1] tunnel-policy srbe
[PE1-tunnel-policy-srbe] select-seq sr-lsp load-balance-number 1
[PE1-tunnel-policy-srbe] quit
[PE1-vpn-instance-vpn1] tnl-policy srbe
[PE1-vpn-instance-vpn2] tnl-policy srbe
9. Enable EVPN to advertise VPN routes.
[PE1-vpn-instance-vpn1] address-family ipv4
[PE1-vpn-ipv4-vpn1] evpn mpls routing-enable
[PE1-vpn-ipv4-vpn1] quit
[PE1-vpn-instance-vpn2] address-family ipv4
[PE1-vpn-ipv4-vpn2] evpn mpls routing-enable
[PE1-vpn-ipv4-vpn2] quit
Configuring PE 2
[PE2] isis 1
[PE2-isis-1] network-entity 00.0000.0000.0002.00
[PE2-isis-1] quit
# Configure IP addresses for interfaces loopback 0, Ten-GigabitEthernet 3/1/1, and Ten-GigabitEthernet 3/1/2, and enable IS-IS on the interfaces.
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.2 255.255.255.255
[PE2-LoopBack0] ipv6 address 22::22 128
[PE2-LoopBack0] isis enable 1
[PE2-LoopBack0] isis ipv6 enable 1
[PE2-LoopBack0] quit
[PE2-Ten-GigabitEthernet3/1/1] port link-mode route
[PE2-Ten-GigabitEthernet3/1/1] ip address 11.0.1.2 24
[PE2-Ten-GigabitEthernet3/1/1] isis enable 1
[PE2-Ten-GigabitEthernet3/1/2] port link-mode route
[PE2-Ten-GigabitEthernet3/1/2] ipv6 address 61::1 64
[PE2] mpls lsr-id 2.2.2.2
[PE2] mpls te
[PE2-te] quit
[PE2-Ten-GigabitEthernet3/1/1] mpls enable
[PE2-Ten-GigabitEthernet3/1/1] mpls te enable
[PE2-Ten-GigabitEthernet3/1/2] mpls enable
[PE2-Ten-GigabitEthernet3/1/2] mpls te enable
3. Configure VPN instances for the CE to access PE.
[PE2] ip vpn-instance vpn2
[PE2-vpn-instance-vpn2] route-distinguisher 2222:2
[PE2-vpn-instance-vpn2] vpn-target 2222:2000 import-extcommunity
[PE2-vpn-instance-vpn2] vpn-target 2222:2000 export-extcommunity
[PE2-vpn-instance-vpn2] quit
[PE2] interface ten-gigabitethernet 3/1/3
[PE2-Ten-GigabitEthernet3/1/3] ip binding vpn-instance vpn2
[PE2-Ten-GigabitEthernet3/1/3] ip address 30.1.1.1 24
[PE2-Ten-GigabitEthernet3/1/3] quit
4. Establish an EBGP peer relationship between PE 2 and CE 3.
[PE2] bgp 100
[PE2-bgp-default] ip vpn-instance vpn2
[PE2-bgp-default-vpn2] peer 30.1.1.2 as-number 65430
[PE2-bgp-default-vpn2] address-family ipv4 unicast
[PE2-bgp-default-ipv4-vpn2] peer 30.1.1.2 enable
[PE2-bgp-default-ipv4-vpn2] quit
[PE2-bgp-default-vpn2] quit
5. Configure EVPN L3VPN, and use the SR-MPLS BE tunnel as the public tunnel.
a. Configure IS-IS SRGB, enable MPLS TE, and enable SR-MPLS in IS-IS IPv4 unicast address family view.
[PE2] isis 1
[PE2-isis-1] mpls te enable
[PE2-isis-1] segment-routing global-block 17000 17999
[PE2-isis-1] address-family ipv4
[PE2-isis-1-ipv4] segment-routing mpls
[PE2-isis-1-ipv4] segment-routing adjacency enable
[PE2-isis-1-ipv4] quit
[PE2-isis-1] quit
b. Configure a prefix SID for interface loopback 0.
[PE2-LoopBack0] isis prefix-sid index 20
c. Configure PE 1 and PE 2 to establish an MP-IBGP peer relationship to exchange BGP EVPN routes.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.1 as-number 100
[PE2-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[PE2-bgp-default-evpn] undo policy vpn-target
[PE2-bgp-default-evpn] peer 1.1.1.1 enable
[PE2-bgp-default-evpn] peer 1.1.1.1 advertise encap-type mpls
[PE2-bgp-default-evpn] peer 1.1.1.1 next-hop-local
[PE2-bgp-default-evpn] peer 1.1.1.1 reflect-client
d. Enable EVPN to advertise VPN routes.
[PE2-vpn-instance-vpn2] address-family ipv4
[PE2-vpn-ipv4-vpn2] evpn mpls routing-enable
[PE2-vpn-ipv4-vpn2] quit
e. Configure a tunnel policy for the EVPN L3VPN to preferentially select the SR-MPLS BE tunnel as the public tunnel.
[PE2] tunnel-policy srbe
[PE2-tunnel-policy-srbe] select-seq sr-lsp load-balance-number 1
[PE2-tunnel-policy-srbe] quit
[PE2-vpn-instance-vpn2] tnl-policy srbe
6. Configure EVPN L3VPN over SRv6 to use the SRv6 BE tunnel as the public tunnel.
a. Specify a source address for the outer IPv6 header of SRv6-encapsulated EVPN L3VPN packets.
[PE2-segment-routing-ipv6] encapsulation source-address 2::2
b. Configure the destination address End.DT4 SID of the IPv6 packet headers encapsulated in EVPN L3VPN over SRv6.
[PE2-segment-routing-ipv6] locator bbb ipv6-prefix 200:: 64 static 32
[PE2-segment-routing-ipv6-locator-bbb] quit
[PE2] isis 1
[PE2-isis-1-ipv6] segment-routing ipv6 locator bbb
[PE2-isis-1] quit
c. Add End.DT4 SID for the private network route.
[PE2] bgp 100
[PE2-bgp-default-ipv4-vpn2] segment-routing ipv6 locator bbb evpn
d. Establish MP-IBGP peer relationship between PE 2 and PE 3.
[PE2-bgp-default] peer 3::3 as-number 100
[PE2-bgp-default] peer 3::3 connect-interface loopback 0
[PE2-bgp-default-evpn] peer 3::3 enable
[PE2-bgp-default-evpn] peer 3::3 nexthop-local
[PE2-bgp-default-evpn] peer 3::3 reflect-client
[PE2-bgp-default-evpn] peer 3::3 advertise encap-type srv6
e. Allow private network routes to be iterated to End.DT4 SID routes.
[PE2-bgp-default-ipv4-vpn2] segment-routing ipv6 best-effort evpn
7. Configure SRv6 and EVPN L3VPN to communicate through Option B.
a. Enable the SRv6 and MPLS network to communicate with each other.
[PE2-bgp-default-evpn] srv6-mpls-interworking enable
b. Configure BGP to reference the locator.
[PE2-bgp-default-evpn] segment-routing ipv6 locator bbb evpn
c. Configure the route iteration mode.
[PE2-bgp-default-evpn] segment-routing ipv6 best-effort evpn
Configuring PE 3
[PE3] isis 1
[PE3-isis-1] network-entity 00.0000.0000.0003.00
[PE3-isis-1] cost-style wide
[PE3-isis-1] address-family ipv6 unicast
[PE3-isis-1-ipv6] quit
[PE3-isis-1] quit
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 3.3.3.3 255.255.255.255
[PE3-LoopBack0] ipv6 address 33::33 128
[PE3-LoopBack0] isis ipv6 enable 1
[PE3-LoopBack0] quit
[PE3-Ten-GigabitEthernet3/1/1] port link-mode route
[PE3-Ten-GigabitEthernet3/1/1] ipv6 address 61::2 64
[PE3-Ten-GigabitEthernet3/1/1] quit
2. Configure VPN instances for the CE to access PE.
[PE3] ip vpn-instance vpn1
[PE3-vpn-instance-vpn1] route-distinguisher 1111:3
[PE3-vpn-instance-vpn1] vpn-target 1111:1000 import-extcommunity
[PE3-vpn-instance-vpn1] vpn-target 1111:1000 export-extcommunity
[PE3-vpn-instance-vpn1] quit
[PE3] ip vpn-instance vpn2
[PE3-vpn-instance-vpn2] route-distinguisher 2222:3
[PE3-vpn-instance-vpn2] vpn-target 2222:2000 import-extcommunity
[PE3-vpn-instance-vpn2] vpn-target 2222:2000 export-extcommunity
[PE3-vpn-instance-vpn2] quit
[PE3] interface ten-gigabitethernet 3/1/2
[PE3-Ten-GigabitEthernet3/1/2] ip address 40.1.1.1 24
[PE3-Ten-GigabitEthernet3/1/2] quit
[PE3] interface ten-gigabitethernet 3/1/3
[PE3-Ten-GigabitEthernet3/1/3] ip binding vpn-instance vpn2
[PE3-Ten-GigabitEthernet3/1/3] ip address 50.1.1.1 24
[PE3-Ten-GigabitEthernet3/1/3] quit
3. Configure PE 3 to establish EBGP peer relationships with CE 4 and CE 5.
[PE3] bgp 100
[PE3-bgp-default] ip vpn-instance vpn1
[PE3-bgp-default-vpn1] peer 40.1.1.2 as-number 65440
[PE3-bgp-default-vpn1] address-family ipv4 unicast
[PE3-bgp-default-ipv4-vpn1] peer 40.1.1.2 enable
[PE3-bgp-default-ipv4-vpn1] quit
[PE3-bgp-default-vpn1] quit
[PE3-bgp-default] ip vpn-instance vpn2
[PE3-bgp-default-vpn2] peer 50.1.1.2 as-number 65450
[PE3-bgp-default-vpn2] address-family ipv4 unicast
[PE3-bgp-default-ipv4-vpn2] peer 50.1.1.2 enable
[PE3-bgp-default-ipv4-vpn2] quit
[PE3-bgp-default-vpn2] quit
[PE3-bgp-default] quit
4. Configure the source address of IPv6 packet headers encapsulated in EVPN L3VPN over SRv6.
[PE3] segment-routing ipv6
[PE3-segment-routing-ipv6] encapsulation source-address 3::3
5. Configure the destination address End.DT4 SID of IPv6 packet headers encapsulated in EVPN L3VPN over SRv6.
[PE3-segment-routing-ipv6] locator ccc ipv6-prefix 401:: 64 static 32
[PE3-segment-routing-ipv6-locator-ccc] quit
[PE3-segment-routing-ipv6] quit
[PE3] isis 1
[PE3-isis-1-ipv6] segment-routing ipv6 locator ccc
[PE3-isis-1] quit
6. Add End.DT4 SIDs for private network routes.
[PE3] bgp 100
[PE3-bgp-default-ipv4-vpn1] segment-routing ipv6 locator ccc evpn
[PE3-bgp-default-ipv4-vpn2] segment-routing ipv6 locator ccc evpn
7. Establish MP-IBGP peer relationship between PE 2 and PE 3.
[PE3-bgp-default] peer 2::2 as-number 100
[PE3-bgp-default] peer 2::2 connect-interface loopback 0
[PE3-bgp-default-evpn] peer 2::2 enable
[PE3-bgp-default-evpn] peer 2::2 nexthop-local
[PE3-bgp-default-evpn] peer 2::2 advertise encap-type srv6
8. Allow private network routes to be iterated to End.DT4 SID routes.
[PE3-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort evpn
[PE3-bgp-default-ipv4-vpn2] segment-routing ipv6 best-effort evpn
Configuring CE 1
# Assign an IP address to the interface.
[CE1-Ten-GigabitEthernet3/1/1] port link-mode route
[CE1-Ten-GigabitEthernet3/1/1] ip address 10.1.1.2 24
# Establish EBGP peer relationship between the PE and CE, and redistribute direct routes.
[CE1] bgp 65410
[CE1-bgp-default] peer 10.1.1.1 as-number 100
[CE1-bgp-default-ipv4] peer 10.1.1.1 enable
[CE1-bgp-default-ipv4] quit
Configuring CE 2
[CE2] interface ten-gigabitethernet 3/1/1
[CE2-Ten-GigabitEthernet3/1/1] port link-mode route
[CE2-Ten-GigabitEthernet3/1/1] ip address 20.1.1.2 24
[CE2-Ten-GigabitEthernet3/1/1] quit
[CE2] bgp 65420
[CE2-bgp-default] peer 20.1.1.1 as-number 100
[CE2-bgp-default-ipv4] peer 20.1.1.1 enable
[CE2-bgp-default-ipv4] import-route direct
[CE2-bgp-default-ipv4] quit
Configuring CE 3
[Sysname] sysname CE3
[CE3] interface ten-gigabitethernet 3/1/1
[CE3-Ten-GigabitEthernet3/1/1] port link-mode route
[CE3-Ten-GigabitEthernet3/1/1] ip address 30.1.1.2 24
[CE3-Ten-GigabitEthernet3/1/1] quit
[CE3] bgp 65430
[CE3-bgp-default] peer 30.1.1.1 as-number 100
[CE3-bgp-default] address-family ipv4 unicast
[CE3-bgp-default-ipv4] peer 30.1.1.1 enable
[CE3-bgp-default-ipv4] import-route direct
[CE3-bgp-default-ipv4] quit
[CE3-bgp-default] quit
Configuring CE 4
[Sysname] sysname CE4
[CE4] interface ten-gigabitethernet 3/1/1
[CE4-Ten-GigabitEthernet3/1/1] port link-mode route
[CE4-Ten-GigabitEthernet3/1/1] ip address 40.1.1.2 24
[CE4-Ten-GigabitEthernet3/1/1] quit
[CE4] bgp 65440
[CE4-bgp-default] peer 40.1.1.1 as-number 100
[CE4-bgp-default] address-family ipv4 unicast
[CE4-bgp-default-ipv4] peer 40.1.1.1 enable
[CE4-bgp-default-ipv4] import-route direct
[CE4-bgp-default-ipv4] quit
[CE4-bgp-default] quit
Configuring CE 5
[Sysname] sysname CE5
[CE5] interface ten-gigabitethernet 3/1/1
[CE5-Ten-GigabitEthernet3/1/1] port link-mode route
[CE5-Ten-GigabitEthernet3/1/1] ip address 50.1.1.2 24
[CE5-Ten-GigabitEthernet3/1/1] quit
[CE5] bgp 65450
[CE5-bgp-default] peer 50.1.1.1 as-number 100
[CE5-bgp-default] address-family ipv4 unicast
[CE5-bgp-default-ipv4] peer 50.1.1.1 enable
[CE5-bgp-default-ipv4] import-route direct
[CE5-bgp-default-ipv4] quit
[CE5-bgp-default] quit
Verifying IS-IS neighbor and BGP peer establishment
# View IS-IS neighbor information on the PEs. Verify that IS-IS neighbor relationships have been established between PE 1 and PE 2 and between PE 2 and PE 3. This section uses PE 2 as an example.
[PE2] display isis peer
Peer information for IS-IS(1)
System ID: 0000.0000.0001
Interface: XGE3/1/1 Circuit Id: 0000.0000.0002.01
State: Up HoldTime: 25s Type: L1(L1L2) PRI: 64
State: Up HoldTime: 28s Type: L2(L1L2) PRI: 64
System ID: 0000.0000.0003
Interface: XGE3/1/2 Circuit Id: 0000.0000.0003.01
State: Up HoldTime: 7s Type: L1(L1L2) PRI: 64
State: Up HoldTime: 7s Type: L2(L1L2) PRI: 64
# View BGP L2VPN peer information on the PEs. Verify that BGP L2VPN peer relationships have been established between PE 1 and PE 2 and between PE 2 and PE 3. This section uses PE 2 as an example.
[PE2] display bgp peer l2vpn evpn
BGP local router ID: 2.2.2.2
Local AS number: 100
Total number of peers: 2 Peers in established state: 2
* - Dynamically created peer
1.1.1.1 100 23 21 0 2 00:13:02 Established
33::33 100 20 20 0 2 00:13:09 Established
# View BGP-VPN IPv4 unicast peer information on the PEs. Verify that BGP peer relationships have been established between the PEs and CEs correctly. This section uses PE 2 as an example.
[PE2] display bgp peer ipv4 vpn-instance vpn2
Total number of peers: 1 Peers in established state: 1
30.1.1.2 65430 22 24 0 1 00:16:48 Established
Verifying packet forwarding from EVPN L3VPN to EVPN L3VPN over SRv6
The following information uses traffic forwarding from CE 2 (20.1.1.2) in VPN instance 2 to CE 5 (50.1.1.2) as an example to verify packet forwarding from EVPN L3VPN to EVPN L3VPN over SRv6.
# On PE 1, display the FIB table information of VPN instance vpn2. The output shows that private network label 1279 is added to packets sent to network 50.1.1.0/24, and the NHLFE ID for the outer public tunnel is 1.
[PE1] display fib vpn-instance vpn2 50.1.1.0
FIB entry count: 1
Flag:
U:Usable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
50.1.1.0/24 2.2.2.2 UGR 1 1279
# On PE 1, display the NHLFE entry information. The output shows that the NHLFE entry with ID 1 is an SRLSP, indicating that route 50.1.1.0/24 is iterated to the SR-MPLS BE tunnel.
[PE1] display mpls forwarding nhlfe 1
Flags: T - Forwarded through a tunnel
N - Forwarded through the outgoing interface to the nexthop IP address
B - Backup forwarding information
A - Active forwarding information
M - P2MP forwarding information
NID Tnl-Type Flag OutLabel Forwarding Info
1 SRLSP NA 3 XGE3/1/1 11.0.1.2
# On PE 3, display the SRv6 local SID forwarding table information. The output shows that the End.DT4 SID that PE 3 allocates to VPN instance vpn2 (route 50.1.1.0/24 belongs to VPN instance vpn2) is 401::1:0:3.
[PE3] display segment-routing ipv6 local-sid end-dt4
Local SID forwarding table (End.DT4)
Total SIDs: 2
SID : 401::1:0:1/64
Function type : End.DT4 Flavor : PSP
VPN instance : vpn1 Allocation type: Dynamic
Network type : EVPN L3VPN
Locator name : ccc
Owner : BGP State : Active
Create Time : Apr 08 17:53:27.808 2022
SID : 401::1:0:3/64
VPN instance : vpn2 Allocation type: Dynamic
Locator name : ccc
Create Time : Apr 08 17:53:27.811 2022
# On PE 2, execute the display mpls lsp srv6-mpls-interworking and display mpls forwarding ilm commands to verify that MPLS label 1279 has been mapped to End.DT4 SID (401::1:0:3). After PE 2 receives packets carrying private network label 1279, it replaces the private network label with the End.DT4 SID.
[PE2] display mpls lsp srv6-mpls-interworking
FEC : 33::33/401::1:0:3
Protocol : BGP
In Label : 1279
Out SRv6 SID : 401::1:0:3
Path ID : 0x26000000.1
[PE2] display mpls forwarding ilm 1279
InLabel Oper VRF Flag SwapInfo Forwarding Info
1279 SWAP 0 NA 401::1:0:3
XGE3/1/2
FE80::3261:2FF:FE0A:306
# On PE 2, display the FIB table information of VPN instance vpn2. The output shows that the next hop of 50.1.1.0/24 is End.DT4 SID 401::1:0:3, the route is iterated to the SRv6 BE tunnel, and the iterated next hop address is FE80::3261:2FF:FE0A:306.
[PE2] display ip routing-table vpn-instance vpn2 50.1.1.0 verbose
Summary count : 1
Destination: 50.1.1.0/24
Protocol: BGP instance default
Process ID: 0
SubProtID: 0x8 Age: 00h10m19s
FlushedAge: 00h10m19s
Cost: 0 Preference: 255
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active Adv
TableID: 0x102 OrigAs: 65450
NibID: 0x16000000 LastAs: 100
AttrID: 0x5
BkAttrID: 0xffffffff Neighbor: 33::33
Flags: 0x80010060 OrigNextHop: 401::
Label: NULL RealNextHop: FE80::3261:2FF:FE0A:306
SRLabel: NULL Interface: Ten-GigabitEthernet3/1/2
Tunnel ID: Invalid IPInterface: Ten-GigabitEthernet3/1/2
FlushNID: Invalid BkNID: Invalid
SID: 401::1:0:3
BkSID: N/A
[PE2] display fib vpn-instance vpn2 50.1.1.0
FIB entry count: 1
Flag:
R:Relay F:FRR
50.1.1.0/24 FE80::3261:2FF: UGR XGE3/1/2 Null
FE0A:306
Verifying packet forwarding from EVPN L3VPN over SRv6 to EVPN L3VPN
The following information uses traffic forwarding from CE 5 (50.1.1.2) in VPN instance 2 to CE 2 (20.1.1.2) as an example to verify packet forwarding from EVPN L3VPN over SRv6 to EVPN L3VPN.
# On PE 3, display the FIB table information of VPN instance vpn2. The output shows that the next hop of 20.1.1.0/24 is End.T SID 200::1:0:7, the route is iterated to the SRv6 BE tunnel, and the iterated next hop address is FE80::3260:E5FF:FEA1:207.
[PE3] display ip routing-table vpn-instance vpn2 20.1.1.0 verbose
Summary count : 1
Destination: 20.1.1.0/24
Process ID: 0
SubProtID: 0x8 Age: 01h14m41s
FlushedAge: 01h14m41s
TableID: 0x202 OrigAs: 100
NibID: 0x16000002 LastAs: 100
AttrID: 0x5
BkAttrID: 0xffffffff Neighbor: 22::22
Flags: 0x80010060 OrigNextHop: 200::
Label: NULL RealNextHop: FE80::3260:E5FF:FEA1:207
SRLabel: NULL Interface: Ten-GigabitEthernet3/1/1
Tunnel ID: Invalid IPInterface: Ten-GigabitEthernet3/1/1
SID: 200::1:0:7
BkSID: N/A
[PE3] display fib vpn-instance vpn2 20.1.1.0
FIB entry count: 1
Flag:
R:Relay F:FRR
20.1.1.0/24 FE80::3260:E5FF UGR XGE3/3/1 Null
:FEA1:207
# On PE 2, display the SRv6 local SID forwarding table information. The output shows that the End.T SID that PE 2 allocates is 200::1:0:7.
[PE2] display segment-routing ipv6 local-sid end-t
Local SID forwarding table (End.T)
Total SIDs: 1
SID : 200::1:0:7/64
Function type : End.T Flavor : PSP
Interface : XGE3/1/1 Interface Index: 0x2
Nexthop : 11.0.1.1
VPN instance : public instance Allocation type: Dynamic
Locator name : bbb
Create Time : May 06 16:39:46.513 2022
# On PE 2, display the IPv6 FIB table information. The output shows that the private network label corresponding to the End.T SID is 1151, and the NHLFE ID for the outer public tunnel is 1.
[PE2] display ipv6 fib 200::1:0:7
FIB entry count: 1
Flag:
R:Relay F:FRR
Destination: 200::1:0:7 Prefix length: 128
Nexthop : 0.0.0.0 Flags: UGH
Time stamp : 0x18 Label: 1151
Interface : NULL0 Token: 1
# On PE 2, display the FIB table and routing table information of VPN instance vpn2. The output shows that route 20.1.1.0/24 is iterated to the MPLS tunnel, the inner private network label is 1151, and the NHLFE ID for the outer public tunnel is 1.
[PE2] display fib vpn-instance vpn2 20.1.1.0
FIB entry count: 1
Flag:
R:Relay F:FRR
20.1.1.0/24 1.1.1.1 UGR 1 1151
# On PE 2, display the NHLFE entry information. The output shows that the NHLFE entry with ID 1 is an SRLSP, indicating that the public tunnel is the SR-MPLS BE tunnel.
[PE2] display mpls forwarding nhlfe 1
1 SRLSP NA 3 XGE3/1/1 11.0.1.1
Verifying connectivity between CEs
# Verify that CE 1 and CE 4 in VPN instance 1 can ping each other and CE 2, CE 3, and CE 5 in VPN instance 2 can ping each other.
[CE1] ping 40.1.1.2
Ping 40.1.1.2 (40.1.1.2): 56 data bytes, press CTRL+C to break
56 bytes from 40.1.1.2: icmp_seq=0 ttl=253 time=1.000 ms
56 bytes from 40.1.1.2: icmp_seq=1 ttl=253 time=2.000 ms
56 bytes from 40.1.1.2: icmp_seq=2 ttl=253 time=1.000 ms
56 bytes from 40.1.1.2: icmp_seq=3 ttl=253 time=1.000 ms
56 bytes from 40.1.1.2: icmp_seq=4 ttl=253 time=1.000 ms
--- Ping statistics for 40.1.1.2 ---
round-trip min/avg/max/std-dev = 1.000/1.200/2.000/0.400 ms
[CE2] ping 30.1.1.2
Ping 30.1.1.2 (30.1.1.2): 56 data bytes, press CTRL+C to break
56 bytes from 30.1.1.2: icmp_seq=0 ttl=253 time=2.000 ms
56 bytes from 30.1.1.2: icmp_seq=1 ttl=253 time=1.000 ms
56 bytes from 30.1.1.2: icmp_seq=2 ttl=253 time=1.000 ms
56 bytes from 30.1.1.2: icmp_seq=3 ttl=253 time=1.000 ms
56 bytes from 30.1.1.2: icmp_seq=4 ttl=253 time=1.000 ms
--- Ping statistics for 30.1.1.2 ---
[CE2] ping 50.1.1.2
Ping 50.1.1.2 (50.1.1.2): 56 data bytes, press CTRL+C to break
56 bytes from 50.1.1.2: icmp_seq=0 ttl=253 time=2.000 ms
56 bytes from 50.1.1.2: icmp_seq=1 ttl=253 time=1.000 ms
56 bytes from 50.1.1.2: icmp_seq=2 ttl=253 time=2.000 ms
56 bytes from 50.1.1.2: icmp_seq=3 ttl=253 time=2.000 ms
56 bytes from 50.1.1.2: icmp_seq=4 ttl=253 time=1.000 ms
--- Ping statistics for 50.1.1.2 ---
# Verify that a CE in VPN 1 cannot ping a CE in VPN 2, for example, verify that CE 2 cannot ping CE 4.
[CE2] ping 40.1.1.2
Request time out
Request time out
Request time out
Request time out
Request time out
5 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss
Configuration files
· PE 1
sysname PE1
tnl-policy srbe
address-family ipv4
tnl-policy srbe
address-family ipv4
isis 1
cost-style wide
mpls te enable
mpls lsr-id 1.1.1.1
mpls te
tunnel-policy srbe
interface LoopBack0
isis enable 1
ipv6 address 11::11/128
combo enable copper
ip address 11.0.1.1 255.255.255.0
isis enable 1
mpls enable
mpls te enable
combo enable copper
interface Ten-GigabitEthernet3/1/3
combo enable copper
ip address 20.1.1.1 255.255.255.0
bgp 100
peer 2.2.2.2 connect-interface LoopBack0
peer 2.2.2.2 enable
import-route direct
return
· PE 2
sysname PE2
tnl-policy srbe
address-family ipv4
isis 1
cost-style wide
mpls te enable
mpls lsr-id 2.2.2.2
mpls te
tunnel-policy srbe
interface LoopBack0
isis enable 1
isis ipv6 enable 1
combo enable copper
ip address 11.0.1.2 255.255.255.0
isis enable 1
mpls enable
mpls te enable
combo enable copper
isis ipv6 enable 1
mpls enable
mpls te enable
ipv6 address 61::1/64
combo enable copper
ip address 30.1.1.1 255.255.255.0
bgp 100
peer 1.1.1.1 connect-interface LoopBack0
peer 33::33 as-number 100
peer 33::33 connect-interface LoopBack0
peer 1.1.1.1 enable
peer 33::33 enable
peer 33::33 next-hop-local
peer 33::33 reflect-client
peer 33::33 advertise encap-type srv6
return
· PE 3
sysname PE3
isis 1
cost-style wide
interface LoopBack0
isis ipv6 enable 1
ipv6 address 33::33/128
combo enable copper
isis ipv6 enable 1
ipv6 address 61::2/64
combo enable copper
ip address 40.1.1.1 255.255.255.0
combo enable copper
ip address 50.1.1.1 255.255.255.0
bgp 100
peer 22::22 as-number 100
peer 22::22 connect-interface LoopBack0
peer 22::22 enable
peer 22::22 next-hop-local
peer 22::22 advertise encap-type srv6
return
· CE 1
sysname CE1
combo enable copper
bgp 65410
import-route direct
return
· CE 2
sysname CE2
combo enable copper
ip address 20.1.1.2 255.255.255.0
bgp 65420
import-route direct
return
· CE 3
sysname CE3
combo enable copper
ip address 30.1.1.2 255.255.255.0
bgp 65430
import-route direct
return
· CE 4
sysname CE4
combo enable copper
ip address 40.1.1.2 255.255.255.0
bgp 65440
import-route direct
return
· CE 5
sysname CE5
combo enable copper
ip address 50.1.1.2 255.255.255.0
bgp 65450
import-route direct
return
Example: Configuring EVPN VPWS over SRv6 BE (dual-homed single-active CE)
The user network has two sites, with CE 1 and CE 2 as the edge devices, respectively. The PE devices use OSPFv3 for communication in the IPv6 network. CE 1 is multi-homed to PE 1 and PE 2 through link aggregation, and CE 2 is single-homed to PE 3. Establish an SRv6 tunnel over the backbone network between CE 1 and CE 2 to implement Layer 2 communication between the two sites.
Figure 12 Network diagram
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
1::1/128 |
CE 1 |
RAGG1 |
100::1/64 |
XGE3/1/1 |
N/A |
CE 2 |
XGE3/1/1 |
100::2/64 |
XGE3/1/2 |
10::1/64 |
PE 3 |
Loop0 |
3::3/128 |
XGE3/1/3 |
20::1/64 |
XGE3/1/1 |
N/A |
PE 2 |
Loop0 |
2::2/128 |
XGE3/1/2 |
10::3/64 |
XGE3/1/1 |
N/A |
XGE3/1/3 |
30::3/64 |
XGE3/1/2 |
30::2/64 |
XGE3/1/3 |
20::2/64 |
Procedures
Configuring CE 1
# Create Layer 3 aggregate interface 1, specify the dynamic aggregation mode, and configure the IP address and subnet mask.
[CE1] interface route-aggregation 1
[CE1-Route-Aggregation1] link-aggregation mode dynamic
[CE1-Route-Aggregation1] ipv6 address 100::1 64
[CE1-Route-Aggregation1] quit
# Assign interfaces Ten-GigabitEthernet 3/1/1 and Ten-GigabitEthernet 3/1/2 to aggregation group 1.
[CE1-Ten-GigabitEthernet3/1/1] port link-aggregation group 1
[CE1] interface ten-gigabitethernet 3/1/2
[CE1-Ten-GigabitEthernet3/1/2] port link-aggregation group 1
[CE1-Ten-GigabitEthernet3/1/2] quit
Configuring PE 1
# Run OSPFv3 on PE 1.
[PE1] ospfv3
[PE1-ospfv3-1] router-id 1.1.1.1
[PE1-ospfv3-1] segment-routing ipv6 locator aaa
[PE1-ospfv3-1] area 0
[PE1-ospfv3-1-area-0.0.0.0] quit
[PE1-ospfv3-1] quit
# Configure the loopback 0 interface.
[PE1-LoopBack0] ipv6 address 1::1 128
[PE1-LoopBack0] ospfv3 1 area 0
# Enable L2VPN.
[PE1] l2vpn enable
# Configure interface Ten-GigabitEthernet 3/1/2 that connects PE 1 to PE 3.
[PE1-Ten-GigabitEthernet3/1/2] ipv6 address 10::1/64
[PE1-Ten-GigabitEthernet3/1/2] ospfv3 1 area 0
# Configure interface Ten-GigabitEthernet 3/1/3 that connects PE 1 to PE 2.
[PE1-Ten-GigabitEthernet3/1/3] ipv6 address 20::1/64
[PE1-Ten-GigabitEthernet3/1/3] ospfv3 1 area 0
# Establish IBGP peer relationships between PE 1 and PE 2 and between PE 1 and PE 3, and configure BGP EVPN for route exchange.
[PE1] bgp 100
[PE1-bgp-default] peer 2::2 as-number 100
[PE1-bgp-default] peer 2::2 connect-interface loopback 0
[PE1-bgp-default] peer 3::3 as-number 100
[PE1-bgp-default] peer 3::3 connect-interface loopback 0
# Configure the ESI value and interface redundancy mode on Ten-GigabitEthernet 3/1/1.
[PE1-Ten-GigabitEthernet3/1/1] esi 1.1.1.1.1
[PE1-Ten-GigabitEthernet3/1/1] evpn redundancy-mode all-active
# Create cross-connect group vpna and create an EVPN instance for the cross-connect group. Configure the EVPN instance to use SRv6 encapsulation. Configure the RD and RT for the EVPN instance of the cross-connect group, and implement route iteration through SID attributes.
[PE1] xconnect-group vpna
[PE1-xcg-vpna] evpn encapsulation srv6
[PE1-xcg-vpna-evpn-srv6] route-distinguisher 1:1
[PE1-xcg-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
[PE1-xcg-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
[PE1-xcg-vpna-evpn-srv6] segment-routing ipv6 best-effort
[PE1-xcg-vpna-evpn-srv6] quit
# Create cross-connect pw1, associate interface Ten-GigabitEthernet 3/1/1 with the cross-connect, and create an SRv6 tunnel in the cross-connect to associate the AC and the SRv6 tunnel.
[PE1-xcg-vpna] connection pw1
[PE1-xcg-vpna-pw1] ac interface ten-gigabitethernet 3/1/1
[PE1-xcg-vpna-pw1-Ten-GigabitEthernet3/1/1] quit
[PE1-xcg-vpna-pw1] evpn local-service-id 1 remote-service-id 2
[PE1-xcg-vpna-pw1-1-2] quit
[PE1-xcg-vpna-pw1] segment-routing ipv6 locator aaa
[PE1-xcg-vpna-pw1] quit
[PE1-xcg-vpna] quit
# Specify the source address of SRv6-encapsulated IPv6 packet headers.
# Configure a locator to request End.DX2 SIDs.
[PE1-segment-routing-ipv6] locator aaa ipv6-prefix 111:: 64 static 32
[PE1-segment-routing-ipv6-locator-aaa] quit
Configuring PE 2
# Run OSPFv3 on PE 2.
[PE2] ospfv3
[PE2-ospfv3-1] router-id 2.2.2.2
[PE2-ospfv3-1] segment-routing ipv6 locator aaa
[PE2-ospfv3-1] area 0.0.0.0
[PE2-ospfv3-1-area-0.0.0.0] quit
[PE2-ospfv3-1] quit
[PE2-LoopBack0] ipv6 address 2::2 128
[PE2-LoopBack0] ospfv3 1 area 0
# Enable L2VPN.
[PE2] l2vpn enable
# Configure interface Ten-GigabitEthernet 3/1/3 that connects PE 2 to PE 1.
[PE2-Ten-GigabitEthernet3/1/3] ipv6 address 20::2 64
[PE2-Ten-GigabitEthernet3/1/3] ospfv3 1 area 0
# Configure interface Ten-GigabitEthernet 3/1/2 that connects PE 2 to PE 3.
[PE2-Ten-GigabitEthernet3/1/2] ipv6 address 30::2 64
[PE2-Ten-GigabitEthernet3/1/2] ospfv3 1 area 0
# Establish IBGP peer relationships between PE 1 and PE 2 and between PE 3 and PE 2, and configure BGP EVPN for route exchange.
[PE2] bgp 100
[PE2-bgp-default] router-id 2.2.2.2
[PE2-bgp-default] peer 1::1 connect-interface loopback 0
[PE2-Ten-GigabitEthernet3/1/1] esi 1.1.1.1.1
[PE2-Ten-GigabitEthernet3/1/1] evpn redundancy-mode all-active
[PE2] xconnect-group vpna
[PE2-xcg-vpna] evpn encapsulation srv6
[PE2-xcg-vpna-evpn-srv6] route-distinguisher 1:1
[PE2-xcg-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
[PE2-xcg-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
[PE2-xcg-vpna-evpn-srv6] segment-routing ipv6 best-effort
[PE2-xcg-vpna-evpn-srv6] quit
[PE2-xcg-vpna] connection pw1
[PE2-xcg-vpna-pw1] ac interface ten-gigabitethernet 3/1/1
[PE2-xcg-vpna-pw1-Ten-GigabitEthernet3/1/1] quit
[PE2-xcg-vpna-pw1] evpn local-service-id 1 remote-service-id 2
[PE2-xcg-vpna-pw1-1-2] quit
[PE2-xcg-vpna-pw1] segment-routing ipv6 locator aaa
[PE2-xcg-vpna-pw1] quit
[PE2-xcg-vpna] quit
# Specify a source address for the outer IPv6 header of SRv6-encapsulated packets.
[PE2-segment-routing-ipv6] locator aaa ipv6-prefix 222:: 64 static 32
[PE2-segment-routing-ipv6-locator-aaa] quit
Configuring PE 3
# Run OSPFv3 on PE 3.
[PE3] ospfv3
[PE3-ospfv3-1] router-id 3.3.3.3
[PE3-ospfv3-1] segment-routing ipv6 locator aaa
[PE3-ospfv3-1] area 0
[PE3-ospfv3-1-area-0.0.0.0] quit
[PE3-ospfv3-1] quit
[PE3-LoopBack0] ipv6 address 3::3 128
[PE3-LoopBack0] ospfv3 1 area 0
# Enable L2VPN.
[PE3] l2vpn enable
# Configure interface Ten-GigabitEthernet 3/1/2 that connects PE 3 to PE 1.
[PE3-Ten-GigabitEthernet3/1/2] ipv6 address 10::3 64
[PE3-Ten-GigabitEthernet3/1/2] ospfv3 1 area 0
# Configure interface Ten-GigabitEthernet 3/1/3 that connects PE 3 to PE 2.
[PE3-Ten-GigabitEthernet3/1/3] ipv6 address 30::3 64
[PE3-Ten-GigabitEthernet3/1/3] ospfv3 1 area 0
# Establish IBGP peer relationships between PE 1 and PE 3 and between PE 2 and PE 3, and configure BGP EVPN for route exchange.
[PE3] bgp 100
[PE3-bgp-default] router-id 3.3.3.3
[PE3-bgp-default] peer 1::1 as-number 100
[PE3-bgp-default] peer 1::1 connect-interface loopback 0
[PE3] xconnect-group vpna
[PE3-xcg-vpna] evpn encapsulation srv6
[PE3-xcg-vpna-evpn-srv6] route-distinguisher 1:1
[PE3-xcg-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
[PE3-xcg-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
[PE3-xcg-vpna-evpn-srv6] segment-routing ipv6 best-effort
[PE3-xcg-vpna-evpn-srv6] quit
[PE3-xcg-vpna] connection pw1
[PE3-xcg-vpna-pw1] ac interface ten-gigabitethernet 3/1/1
[PE3-xcg-vpna-pw1-Ten-GigabitEthernet3/1/1] quit
[PE3-xcg-vpna-pw1] evpn local-service-id 2 remote-service-id 1
[PE3-xcg-vpna-pw1-1-2] quit
[PE3-xcg-vpna-pw1] segment-routing ipv6 locator aaa
[PE3-xcg-vpna-pw1] quit
[PE3-xcg-vpna] quit
[PE3-segment-routing-ipv6] locator aaa ipv6-prefix 333:: 64 static 32
[PE3-segment-routing-ipv6-locator-aaa] quit
Configuring CE 2
[CE2-Ten-GigabitEthernet3/1/1] ipv6 address 100::2 64
[PE1] display l2vpn peer srv6
Total number of SRv6 Tunnels: 1
1 up, 0 blocked, 0 down
Xconnect-group Name: vpna
Peer : 3::3
Flag : Main
State : Up
Remote SrvID : 2
# Display SRv6 forwarding information on PE 1 to view the ingress and egress SIDs of the SRv6 tunnel.
[PE1] display l2vpn forwarding srv6
Total number of cross-connections: 1
Total number of SRv6 tunnels: 1, 1 up, 0 blocked, 0 down
Xconnect-group Name : vpna
Connection Name : pw1
Link ID : 0x1 Type: BE State: Up
In SID : 111::1:0:3
Out SID : 333::1:0:3
# Verify that CE 1 and CE 2 can ping each other. Verify that CE 1 and CE 2 can ping each other when the link between CE 1 and PE 1 or the link between CE 1 and PE 2 fails.
Configuration files
· CE1:
sysname CE1
interface Route-Aggregation1
ipv6 address 100::1/64
interface Ten-GigabitEthernet3/1/1
interface Ten-GigabitEthernet3/1/2
· PE1:
sysname PE1
ospfv3 1
area 0.0.0.0
interface LoopBack0
ospfv3 1 area 0.0.0.0
esi 0001.0001.0001.0001.0001
evpn redundancy-mode single-active
bgp 100
router-id 1.1.1.1
peer 2::2 connect-interface LoopBack0
peer 3::3 connect-interface LoopBack0
peer 2::2 enable
peer 3::3 enable
xconnect-group vpna
connection pw1
ac interface Ten-GigabitEthernet3/1/1
· PE2:
sysname PE2
ospfv3 1
area 0.0.0.0
interface LoopBack0
ipv6 address 30::2/64
ipv6 address 20::2/64
bgp 100
router-id 2.2.2.2
peer 1::1 connect-interface LoopBack0
peer 1::1 enable
peer 3::3 enable
xconnect-group vpna
connection pw1
· PE3:
sysname PE3
ospfv3 1
area 0.0.0.0
interface LoopBack0
ipv6 address 10::3/64
ipv6 address 30::3/64
bgp 100
router-id 3.3.3.3
peer 1::1 enable
peer 2::2 enable
xconnect-group vpna
connection pw1
· CE2:
sysname CE2
ipv6 address 100::2/64
Example: Configuring EVPN VPWS over SRv6 TE policy (static configuration)
The user network has two sites CE 1 and CE 2. CE 1 and CE 2 access PE 1 and PE 2 respectively through Ethernet interfaces and communicate with each other through an SRv6 PW tunnel established over the IPv6 backbone network. Deploy an SRv6 TE policy tunnel in the IGP network for the SRv6 PW to be iterated to the SRv6 TE policy tunnel for traffic forwarding.
Figure 13 Network diagram
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/1/1 |
10::1/64 |
P |
Loop0 |
3::3/128 |
PE 1 |
Loop0 |
1::1/128 |
XGE3/1/1 |
20::2/64 |
XGE3/1/1 |
N/A |
XGE3/1/2 |
30::1/64 |
XGE3/1/2 |
20::1/64 |
PE 2 |
Loop0 |
2::2/128 |
CE 2 |
XGE3/1/1 |
10::2/64 |
XGE3/1/1 |
N/A |
XGE3/1/2 |
30::2/64 |
Procedures
Configuring CE 1
<CE1> system-view
[CE1-Ten-GigabitEthernet3/1/1] ipv6 address 10::1 64
Configuring PE 1
# Run OSPFv3 on PE 1 to advertise SIDs.
<PE1> system-view
[PE1] ospfv3
[PE1-ospfv3-1] area 0.0.0.0
[PE1-ospfv3-1] quit
# Enable L2VPN.
[PE1] l2vpn enable
# Configure interface Ten-GigabitEthernet 3/1/2 that connects PE 1 to P.
[PE1-Ten-GigabitEthernet3/1/2] ipv6 address 20::1 64
# Establish an IBGP peer relationship between PE 1 and PE 2, and configure them to exchange route information through BGP EVPN.
[PE1] bgp 100
[PE1-bgp-default] address-family l2vpn evpn
[PE1-bgp-default-evpn] quit
# Create cross-connect group vpna and create an EVPN instance for the cross-connect group. Configure the EVPN instance to use SRv6 encapsulation. Configure the RD and RT for the EVPN instance of the cross-connect group, and implement route iteration through SR-TE.
[PE1-xcg-vpna-evpn-srv6] segment-routing ipv6 traffic-engineer
[PE1-xcg-vpna] quit
# Configure the SID list.
[PE1-segment-routing-ipv6] locator aaa ipv6-prefix 5000:: 64 static 32
[PE1-segment-routing-ipv6-locator-aaa] opcode 1 end no-flavor
[PE1-segment-routing-ipv6] traffic-engineering
[PE1-srv6-te] srv6-policy locator aaa
[PE1-srv6-te] segment-list s1
[PE1-srv6-te-sl-s1] index 10 ipv6 6000::1
[PE1-srv6-te-sl-s1] index 20 ipv6 7000::1
[PE1-srv6-te-sl-s1] quit
# Create an SRv6 TE policy and configure SRv6 TE policy attributes.
[PE1-srv6-te] policy p1
[PE1-srv6-te-policy-p1] color 10 end-point ipv6 2::2
# Configure an SRv6 TE policy candidate path, and specify an SID list for the candidate path.
[PE1-srv6-te-policy-p1] candidate-paths
[PE1-srv6-te-policy-p1-path] preference 10
[PE1-srv6-te-policy-p1-path-pref-10] explicit segment-list s1
[PE1-srv6-te-policy-p1-path-pref-10] quit
[PE1-srv6-te-policy-p1-path] quit
[PE1-srv6-te-policy-p1] quit
[PE1-srv6-te] quit
# Direct traffic to the SRv6 TE policy tunnel by configuring the color attributes.
[PE1] route-policy a permit node 10
[PE1-route-policy-a-10] apply extcommunity color 00:10
[PE1-route-policy-a-10] quit
[PE1-xcg-vpna-evpn-srv6] import route-policy a
[PE1-xcg-vpna] quit
Configuring PE 2
# Run OSPFv3 on PE 2, and advertise SIDs through OSPFv3.
<PE2> system-view
[PE2] ospfv3
[PE2-ospfv3-1] quit
# Enable L2VPN.
[PE2] l2vpn enable
# Configure interface Ten-GigabitEthernet 3/1/2 that connects PE 2 to P.
[PE2-Ten-GigabitEthernet3/1/2] ospfv3 1 area 0.0.0.0
[PE2] bgp 100
[PE2-bgp-default] address-family l2vpn evpn
[PE2-bgp-default-evpn] peer 1::1 enable
[PE2-bgp-default-evpn] peer 1::1 advertise encap-type srv6
[PE2-bgp-default-evpn] quit
[PE2-xcg-vpna-evpn-srv6] segment-routing ipv6 traffic-engineer
[PE2-xcg-vpna-pw1] evpn local-service-id 2 remote-service-id 1
[PE2-xcg-vpna-pw1-2-1] quit
[PE2-xcg-vpna] quit
[PE2-segment-routing-ipv6] locator aaa ipv6-prefix 7000:: 64 static 32
[PE2-segment-routing-ipv6-locator-aaa] opcode 1 end no-flavor
[PE2-segment-routing-ipv6] traffic-engineering
[PE2-srv6-te] srv6-policy locator aaa
[PE2-srv6-te] segment-list s1
[PE2-srv6-te-sl-s1] index 10 ipv6 6000::1
[PE2-srv6-te-sl-s1] index 20 ipv6 5000::1
[PE2-srv6-te-sl-s1] quit
# Configure SRv6 TE policy on PE 2.
[PE2-srv6-te] policy p1
[PE2-srv6-te-policy-p1] color 10 end-point ipv6 1::1
[PE2-srv6-te-policy-p1] candidate-paths
[PE2-srv6-te-policy-p1-path] preference 10
[PE2-srv6-te-policy-p1-path-pref-10] explicit segment-list s1
[PE2-srv6-te-policy-p1-path-pref-10] quit
[PE2-srv6-te-policy-p1-path] quit
[PE2-srv6-te-policy-p1] quit
[PE2-srv6-te] quit
[PE2] route-policy a permit node 10
[PE2-route-policy-a-10] apply extcommunity color 00:10
[PE2-route-policy-a-10] quit
[PE1-xcg-vpna] quit
Configuring P
# Configure the SRv6 End.SID.
<P> system-view
[P] segment-routing ipv6
[P-segment-routing-ipv6] locator b ipv6-prefix 6000:: 64 static 32
[P-segment-routing-ipv6-locator-b] opcode 1 end no-flavor
[P-segment-routing-ipv6-locator-b] quit
[P-segment-routing-ipv6] quit
# Run OSPFv3 on P.
[P] ospfv3
[P-ospfv3-1] router-id 3.3.3.3
[P-ospfv3-1] segment-routing ipv6 locator b
[P-ospfv3-1] area 0.0.0.0
[P-ospfv3-1-area-0.0.0.0] quit
[P-ospfv3-1] quit
# Configure an IPv6 address for the interface, and run OSPFv3 on the interface.
[P] interface loopback 0
[P-LoopBack0] ipv6 address 3::3 128
[P-LoopBack0] ospfv3 1 area 0
[P-LoopBack0] quit
[P] interface ten-gigabitethernet 3/1/1
[P-Ten-GigabitEthernet3/1/1] ipv6 address 20::2 64
[P-Ten-GigabitEthernet3/1/1] ospfv3 1 area 0
[P-Ten-GigabitEthernet3/1/1] quit
[P] interface ten-gigabitethernet 3/1/2
[P-Ten-GigabitEthernet3/1/2] ipv6 address 30::1 64
[P-Ten-GigabitEthernet3/1/2] ospfv3 1 area 0
[P-Ten-GigabitEthernet3/1/2] quit
Configuring CE 2
<CE2> system-view
[CE2-Ten-GigabitEthernet3/1/1] ipv6 address 10::2 64
# View L2VPN SRv6 information on PE 1 to verify that an SRv6 tunnel has been established between PE 1 and PE 2.
Peer : 2::2
Flag : Main
State : Up
Remote SrvID : 2
In SID : 100::1:0:2
Out SID : 200::1:0:2
Configuration files
· CE 1:
sysname CE1
· PE 1:
sysname PE1
ospfv3 1
router-id 1.1.1.1
area 0.0.0.0
l2vpn enable
xconnect-group vpna
connection pw1
interface LoopBack0
bgp 100
peer 2::2 enable
locator aaa ipv6-prefix 100:: 64 static 32
traffic-engineering
segment-list s1
policy p1
candidate-paths
preference 10
· P:
sysname P
ospfv3 1
router-id 3.3.3.3
area 0.0.0.0
interface LoopBack0
ipv6 address 30::1/64
· PE 2:
sysname PE2
ospfv3 1
router-id 2.2.2.2
segment-routing ipv6 locator d
area 0.0.0.0
l2vpn enable
xconnect-group vpna
connection pw1
interface LoopBack0
bgp 100
peer 1::1 enable
locator aaa ipv6-prefix 200:: 64 static 32
locator d ipv6-prefix 7000:: 64 static 32
traffic-engineering
segment-list s1
policy p1
candidate-paths
preference 10
· CE 2:
sysname CE1
ipv6 address 10::2/64
Example: Configuring EVPN VPLS over SRv6 TE policy (static configuration)
The user network has two sites CE 1 and CE 2. CE 1 and CE 2 access PE 1 and PE 2 respectively through Ethernet interfaces. Deploy an SRv6 TE policy tunnel in the IGP network for the SRv6 PW to be iterated to the SRv6 TE policy tunnel for traffic forwarding.
Figure 14 Network diagram
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/1/1 |
10::1/64 |
P |
Loop0 |
3::3/128 |
PE 1 |
Loop0 |
1::1/128 |
XGE3/1/1 |
20::2/64 |
XGE3/1/1 |
N/A |
XGE3/1/2 |
30::1/64 |
XGE3/1/2 |
20::1/64 |
PE 2 |
Loop0 |
2::2/128 |
CE 2 |
XGE3/1/1 |
10::2/64 |
XGE3/1/1 |
N/A |
XGE3/1/2 |
30::2/64 |
Procedures
Configuring CE 1
<CE1> system-view
Configuring PE 1
<PE1> system-view
[PE1] ospfv3
[PE1-ospfv3-1] quit
# Enable L2VPN.
[PE1] l2vpn enable
# Configure interface Ten-GigabitEthernet 3/1/2 that connects the PE to P.
[PE1] bgp 100
# Create a VSI and an EVPN instance, configure EVPN to use SRv6 encapsulation, configure the RD and RT of the EVPN instance, implement route iteration through SR-TE, and specify the locator used by the EVPN instance.
[PE1] vsi vpna
[PE1-vsi-vpna] evpn encapsulation srv6
[PE1-vsi-vpna-evpn-srv6] route-distinguisher 1:1
[PE1-vsi-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
[PE1-vsi-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
[PE1-vsi-vpna-evpn-srv6] segment-routing ipv6 traffic-engineer
[PE1-vsi-vpna-evpn-srv6] segment-routing ipv6 locator aaa
[PE1-vsi-vpna-evpn-srv6] quit
# Associate interface Ten-GigabitEthernet 3/1/1 with the VSI.
[PE1-Ten-GigabitEthernet3/1/1] xconnect vsi vpna
[PE1-srv6-te] quit
[PE1] vsi vpna
[PE1-vsi-vpna-evpn-srv6] import route-policy a
[PE1-vsi-vpna] quit
Configuring PE 2
<PE2> system-view
[PE2] ospfv3
[PE2-ospfv3-1] quit
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] bgp 100
[PE2] vsi vpna
[PE2-vsi-vpna] evpn encapsulation srv6
[PE2-vsi-vpna-evpn-srv6] route-distinguisher 1:1
[PE2-vsi-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
[PE2-vsi-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
[PE2-vsi-vpna-evpn-srv6] segment-routing ipv6 traffic-engineer
[PE2-vsi-vpna-evpn-srv6] segment-routing ipv6 locator aaa
[PE2-vsi-vpna-evpn-srv6] quit
# Associate interface Ten-GigabitEthernet3/1/1 to the VSI.
[PE2-Ten-GigabitEthernet3/1/1] xconnect vsi vpna
[PE2-srv6-te] quit
[PE2] vsi vpna
[PE2-vsi-vpna-evpn-srv6] import route-policy a
[PE2-vsi-vpna] quit
Configuring P
<P> system-view
# Run OSPFv3 on P.
[P] ospfv3
[P-ospfv3-1] quit
# Configure an IPv6 address for the interface and run OSPFv3 on the interface.
[P-LoopBack0] quit
Configuring CE 2
<CE2> system-view
VSI Name: vpna
Peer : 2::2
Flag : Main
State : Up
# Display SRv6 forwarding information on PE 1.
Total number of VSIs: 1
VSI Name : vpna
Link ID : 0x9000000 Type: BE State: Up
In SID : 100::1:0:1
Out SID : 200::1:0:0
Configuration files
· CE 1:
sysname CE1
· PE 1:
sysname PE1
ospfv3 1
router-id 1.1.1.1
area 0.0.0.0
l2vpn enable
vsi vpna
interface LoopBack0
xconnect vsi vpna
bgp 100
peer 2::2 enable
traffic-engineering
segment-list s1
policy p1
candidate-paths
preference 10
· P:
sysname P
ospfv3 1
router-id 3.3.3.3
area 0.0.0.0
interface LoopBack0
· PE 2:
sysname PE2
ospfv3 1
router-id 2.2.2.2
area 0.0.0.0
l2vpn enable
vsi vpna
interface LoopBack0
xconnect vsi vpna
bgp 100
peer 1::1 enable
traffic-engineering
segment-list s1
policy p1
candidate-paths
preference 10
· CE 2:
sysname CE1
Related documentation
· H3C CR16000-M Routers ACL and QoS Configuration Guide-R8385P09
· H3C CR16000-M Routers ACL and QoS Command Reference-R8385P09
