H3C SR8800-X Router Series Hardware Information and Specifications-5W100
HomeSupportRoutersH3C SR8800-X Router SeriesProduct LiteratureHardware Information & SpecificationsH3C SR8800-X Router Series Hardware Information and Specifications-5W100
03-Cables
03-Cables 330.41 KB
3 Cables
This chapter describes cables used for connecting network ports.
Table3-1 Cable description
Cable
Ports connected
Application
Reference
Console cable
Console port at one end and 9-pin serial port at the other end
Connects the console port of the router to the console terminal.
See H3C SR8800-X Router Series Installation Guide.
USB console cable
USB console port at one end and USB port at the other end
Connects the USB console port of the router to the console terminal.
Ethernet twisted pair cable
RJ-45 Ethernet ports
Connects RJ-45 Ethernet ports to transmit data.
About Ethernet twisted pair cable
E1 cable
E1-HM96 Ethernet copper ports
Connects E1-HM96 Ethernet copper ports to transmit data.
E1 cable
VGA cable
VGA connector
Connects the VGA connector to transmit video data.
VGA cable
Optical fiber
XFP/QSPF+/QSFP28/SFP28/CFP/CFP2/SFP+/SFP ports
Connects the fiber ports to transmit data.
Optical fiber
About Ethernet twisted pair cables
An Ethernet twisted pair cable consists of four pairs of insulated wires twisted together. It mainly transmits analog signals and is advantageous in transmitting data over shorter distances. The maximum transmission distance is 100 m (328.08 ft).
RJ-45 connector
An Ethernet twisted pair cable connects network devices through the RJ-45 connectors at the two ends. Figure3-1 shows the pinouts of an RJ-45 connector.
Figure3-1 RJ-45 connector pinout diagram
Cable pinouts
EIA/TIA cabling specifications define two standards: 568A and 568B for cable pinouts.
·     Standard 568A—pin 1: white/green stripe, pin 2: green solid, pin 3: white/orange stripe, pin 4: blue solid, pin 5: white/blue stripe, pin 6: orange solid, pin 7: white/brown stripe, pin 8: brown solid.
·     Standard 568B—pin 1: white/orange stripe, pin 2: orange solid, pin 3: white/green stripe, pin 4: blue solid, pin 5: white/blue stripe, pin 6: green solid, pin 7: white/brown stripe, pin 8: brown solid.
Cable type
Based on performance
Ethernet cables can be classified into category 3, category 4, category 5, category 5e, category 6, category 6A, and category 7 cable based on performance.
Table3-2 Ethernet cable description
Category 5
Transmits data at a maximum speed of 100 Mbps, with a bandwidth of 100 MHz.
Category 5e
Transmits data at a maximum speed of 1000 Mbps, with a bandwidth of 100 MHz.
Category 6
Transmits data at a speed higher than 1 Gbps, with a bandwidth of 250 MHz.
Category 6A
Transmits data at a speed higher than 10 Gbps, with a bandwidth of 500 MHz.
Category 7
Transmits data at a speed higher than 10 Gbps, with a bandwidth of 600 MHz.
The 10 Gbps RJ-45 Ethernet ports use category 6A or category 7 Ethernet twisted pair cables for connection. Other RJ-45 Ethernet ports use category 5 or higher Ethernet twisted pair cables for connection.
Based on pinouts
Ethernet twisted pair cables can be classified into straight through and crossover cables based on their pinouts.
·     Straight-through—The pinouts at both ends comply with standard 568B, as shown in Figure3-2.
·     Crossover—The pinouts at one end comply with standard 568B, and those at the other end comply with standard 568A, as shown in Figure3-3.
Figure3-2 Straight-through cable
Figure3-3 Crossover cable
Pin assignments
Select an Ethernet twisted pair cable according to the RJ-45 Ethernet interface type on your device. An RJ-45 Ethernet interface can be MDI (for routers and PCs) or MDIX (for routers). For the pinouts of RJ-45 Ethernet interfaces, see Table3-3 and Table3-4.
Table3-3 RJ-45 MDI interface pinouts
Pin
10BASE-T/100BASE-TX
1000BASE-T
Signal
Function
Signal
Function
1
Tx+
Send data
BIDA+
Bi-directional data cable A+
2
Tx-
Send data
BIDA-
Bi-directional data cable A-
3
Rx+
Receive data
BIDB+
Bi-directional data cable B+
4
Reserved
N/A
BIDC+
Bi-directional data cable C+
5
Reserved
N/A
BIDC-
Bi-directional data cable C-
6
Rx-
Receive data
BIDB-
Bi-directional data cable B-
7
Reserved
N/A
BIDD+
Bi-directional data cable D+
8
Reserved
N/A
BIDD-
Bi-directional data cable D-
Table3-4 RJ-45 MDI-X interface pinouts
Pin
10BASE-T/100BASE-TX
1000BASE-T
Signal
Function
Signal
Function
1
Rx+
Receive data
BIDB+
2
Rx-
Receive data
BIDB-
3
Tx+
Send data
BIDA+
4
Reserved
N/A
BIDD+
5
Reserved
N/A
BIDD-
6
Tx-
Send data
BIDA-
7
Reserved
N/A
BIDC+
8
Reserved
N/A
BIDC-
To ensure normal communication, the pins for sending data on one port should correspond to the pins for receiving data on the peer port. When both of the ports on the two devices are MDI or MDIX, a crossover Ethernet cable is needed. A cross-over cable connects devices of the same type. When one port is MDI and the other is MDIX, a straight-through Ethernet cable is needed. A straight-through cable connects devices of different types.
The RJ-45 Ethernet ports on the router support auto-MDI/MDIX. By default, auto-MDI/MDIX is enabled on a port.
Making an Ethernet twisted pair cable
1.     Cut the cable to length with the crimping pliers.
2.     Strip off an appropriate length of the cable sheath. The length is typically that of the RJ-45 connector.
3.     Untwist the pairs so that they can lie flat, and arrange the colored wires based on the wiring specifications.
4.     Cut the top of the wires even with one another. Insert the wires into the RJ-45 end and make sure the wires extend to the front of the RJ-45 end and make good contact with the metal contacts in the RJ-45 end and in the correct order.
5.     Crimp the RJ-45 connector with the crimping pliers until you hear a click.
6.     Repeat the above steps with the other end of the cable.
7.     Use a cable tester to verify the proper connectivity of the cable.
E1 cable
You can use an E1 cable to connect E1-HM96 Ethernet copper ports.
Figure3-4 E1 cable (1)
Figure3-5 E1 cable (2)
Figure3-6 E1 cable (3)
VGA cable
You can use a VGA cable to connect the universal open application platform and PC (or terminal).
Figure3-7 VGA cable
Table3-5 Cable connections between the universal open application platform and VGA connectors on the PC (or terminal)
VGA
Signal
1
VGA_RED
2
VGA_GREEN
3
VGA_BIUE
4
VGA_CABLE_PRSNT
5
GND
6
RED GND
7
GREEN GND
8
BIUE GND
9
P5V
10
GND
11
NC
12
VGA_SW_DATX
13
VGA_HSYNC
14
VGA_VSYNC
15
VGA_SW_CLKX
Optical fiber
CAUTION
CAUTION:
Use the same types of transceiver modules, pigtail cords, patch cords, and fiber cables. If you use single-mode optical fibers, the transceiver modules, pigtail cords, patch cords, and fiber cables must be single-mode.
About optical fibers
Optical fiber
Optical fibers are widely used in fiber-optic communications, which are advantageous for long-distance communications.
Optical fibers can be classified into the following types:
·     Single mode fiber—It has a core size of 10 µm or smaller, and has a lower modal dispersion. It carries only a single ray of light. It is mostly used for communication over longer distances.
·     Multi-mode fiber—It has a core size of 50 µm or 62.5 µm or higher, and has a higher modal dispersion than single-mode optical fiber. It is mostly used for communication over shorter distances.
Table3-6 Allowed maximum tensile force and crush load
Period of force
Tensile load (N)
Crush load (N/mm)
Short period
150
500
Long term
80
100
Optical fiber cable
An optical fiber cable is a cable containing one or more optical fibers. Typically, the optical fiber elements are individually coated with plastic layers and contained in a protective tube. Optical fiber cables contain single-mode and multi-mode optical fiber cables.
Patch cord
A fiber that has connectors at both ends is called a patch cord. A patch cord connects one optical device to another for signal routing. Patch cords contain single-mode and multi-mode patch cords.
·     Single-mode patch cord—The jacket is yellow. It permits transmission over longer distances.
·     Multi-mode patch cord—The jacket is orange. It permits transmission over shorter distances.
Patch cords are mainly classified into SC, LC, and FC based on interface type. The typical length of a patch cord can be 0.5 m (1.64 ft), 1 m (3.28 ft), 2 m (6.56 ft), 3 m (9.84 ft), 5 m (16.40 ft), and 10 m (32.81 ft).
Pigtail cord
A pigtail cord is an optical fiber that has an optical connector on one end and a length of exposed fiber on the other. The end of the pigtail is fusion spliced to a fiber, connecting the fiber cable and transceiver.
Pigtail cords contain single-mode (yellow) and multi-mode (orange) pigtail cords. Based on interface type, pigtail cords can also be classified into three main types, SC, LC, and FC.
Fiber connector
Fiber connectors are indispensable passive components in an optical fiber communication system. They allow the removable connection between optical channels, which makes the optical system debugging and maintenance more convenient and the transit dispatching of the system more flexible.
Figure3-8 SC connector
Figure3-9 LC connector
Precautions
·     Make sure the fiber connector and fiber type match the transceiver module type.
·     The fiber ports on some cards have shielded covers. Remove the shielded covers before using the fiber ports. Fiber interfaces must be installed with shielded covers when they are not in use. Keep them safely.
·     Fiber connectors must be protected under safe and reliable outer packing, and be fitted with dust caps. Fiber connectors must be installed with dust caps when they are not in use. Take care not to scratch their end face. Replace the dust cap if it is loose or polluted.
·     Before connecting a fiber, use dust free paper and absolute alcohol to clean the end face of the fiber connector. You can brush the end face only in one direction. You also need to brush the end face of the fiber port.
·     Never bend or curve a fiber when connecting it. After a fiber is installed correctly, the bend radius must be not less than 40 mm (the minimum dynamic bend radius is 20 D, and the minimum static bend radius is 10 D. D indicates the outer diameter of dust caps).
·     If the fiber has to pass through a metallic board hole, the hole must have a sleek and fully filleted surface (the filleting radius must be not less than 2 mm). When passing through a metallic board hole or bending along the acute side of mechanical parts, the fiber must wear jackets or cushions.
·     Insert and remove a plug with care. Never exert a fierce force to the fiber or plug; otherwise the plug might be damaged or the fiber might be broken. Never pull, press or extrude the fiber fiercely. For the allowed maximum tensile load and crush load, see Table3-6.
