| 02-FRUs and compatibility matrixes | 7.78 MB |
2 FRUs and compatibility matrixes
SPC/CSPC LPUs (interface modules)
CSPEX-1204/CSPEX-1304S/CSPEX-1404S/CSPEX-1504S/CSPEX-1104-E
LSQM1PWRSPA power supply adapter
LSQM1PWRSPB power supply adapter
For compatibility between the cards and the software release, see the release notes.
For compatibility between the cards and transceiver modules, see the cards and transceiver modules compatibility matrixes for the device.
NOTE: This document uses the identifier printed on a card or subcard as the model name. |
MPUs
CSR07MPUA1
View
Figure2-1 CSR07MPUA1 view
(1) CF card |
(2) CF card LED. For the LED description, see Table2-1. |
(3) USB 2.0 port |
(4) Management Ethernet port LED. For the LED description, see Table2-2. |
(5) Console port |
(6) Service module status LEDs. For the LED description, see Table2-5. |
(7) MPU active/standby LED. For the LED description, see Table2-7. |
(8) Management Ethernet port (10/100/1000Base-T) |
(9) Power supply status LEDs. For the LED description, see Table2-4. |
(10) Fan tray status LEDs. For the LED description, see Table2-3. |
(11) MPU status LED. For the LED description, see Table2-6. |
(12) System reset button |
LEDs
Table2-1 CF card LED description
LED |
Status |
CF card LED |
Steady green |
The CF card is present and idle. Do not hot swap it. |
Flashing green |
The CF card is present and the system is reading/writing the card. Do not hot swap it. |
Off |
The CF card is not present, or the CF card is offline. You can hot swap it. |
Table2-2 Management Ethernet port LED description
LED mark |
Status |
LINK/ACT |
Flashing green |
The port is in sending or receiving data. |
Steady green |
A link is present on the port. |
Off |
No link is present on the port. |
Table2-3 Fan tray status LED description
LED status |
OK (green) |
FAIL (red) |
Steady on |
Off |
The fan tray is operating correctly. |
Off |
Steady on |
One or multiple fans in the fan tray are faulty or the fan tray is not present. |
Off |
Off |
The router is not powered on. |
Table2-4 Power supply status LED description
LED status |
OK (green) |
FAIL (red) |
Steady on |
Off |
All power supplies in the chassis are operating correctly. |
Off |
Steady on |
A power supply in the chassis does not have power output. Possible reasons include: · The power supply is faulty. · The power supply is not switched on. · Power cord connection failure. · Power outage of the external power supply system. |
Off |
Off |
· No power supplies are present in the chassis. · No power supply in the chassis has power output. Possible reasons include: ¡ The power supplies are faulty. ¡ The power supplies are not switched on. ¡ Power cord connection failure. ¡ Power outage of the external power supply system. |
Table2-5 Service module status LED
LED status |
RUN (green) |
ALM (red) |
Flashing |
Off |
The service modules are operating correctly. |
Fast flashing |
Steady on |
One or two service modules are loading software. If the service modules remain in this state, the current software version of the service modules is not compatible with that of the device. |
Steady on |
Steady on |
One or two service modules are starting up or are faulty. |
Off |
Off |
No service modules are present. |
Table2-6 MPU status LED description
LED mark |
Status |
RUN |
Flashing green |
The MPU is operating correctly. |
Fast flashing green |
The MPU is loading software. If the MPU remains in this state, the current software version of the MPU is not compatible with that of the device. |
Steady on |
The MPU is initiating the booting process or the MPU is faulty. |
Table2-7 MPU active/standby LED description
LED mark |
LEDs |
ACTIVE |
Steady green |
The MPU is in active state. |
Off |
· The MPU is in standby state. · The MPU is faulty. To identify the failure, see the card status LED description for the MPU. |
Ports
Console port
The console port can be connected to a computer for system debugging, configuration, maintenance, management, and host software loading.
Table2-8 Console port specifications
Item |
Connector type |
RJ-45 |
Compliant standard |
Asynchronous EIA/TIA-232 |
Transmission baud rate |
≤ 115200 bps. The default value is 9600 bps. |
Transmission medium and max transmission distance |
Common asynchronous serial interface cable, with a maximum transmission distance of 15 m (49.21 ft) |
Services |
Connects to the serial port on a local PC running a terminal emulation program. |
Connects to a computer for router program loading and router debugging, or connects to a remote NMS for remote management.
Table2-9 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
1 |
10/100/1000 Mbps |
Category-5 or above twisted pair cable, with a transmission distance of 100m (328.1 ft) |
Services |
For router software upgrade and network management |
USB port
USB ports can connect multiple types of devices and provide a higher data transfer rate than common parallel interfaces and serial interfaces. A device can be hot swapped on a USB port and can plug and play when connected to a USB port.
Table2-10 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
External storage media |
NOTE: The USB port does not support an extension cable. |
CF card slot
A CF card is a mobile storage device that features fast speed, large capacity, small size, light weight, and low power consumption.
Table2-11 External CF card specifications
Item |
CF card slots |
1 |
CF card capacity |
4 GB |
Services |
You can use a CF card to store logs, application program files, and configuration files. |
Technical specifications
Table2-12 Technical specifications
Item |
Dimensions (H × W × D) |
45 ×199 × 352 mm (1.77 × 7.83 × 13.86 in) |
Weight |
1.40 kg (3.09 lb) |
Maximum power consumption |
35 W |
Typical power consumption |
32 W |
Minimum power consumption |
28 W |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
SDRAM |
4 GB |
CSR07SRPUA1
View
Figure2-2 CSR07SRPUA1 view
(1) Console port |
(2) Management Ethernet ports (10/100/1000Base-T) |
(3) USB 2.0 port |
(4) MCC 10GE port (dedicated for IRF connection, SFP+ transceiver module supported) |
(5) System reset button |
(6) Management Ethernet port LED (ACT). For the LED description, see Table2-13. |
(7) Management Ethernet port LED (LINK). For the LED description, see Table2-13. |
(8) Power supply status LED. For the LED description, see Table2-16. |
(9) Fan tray status LED. For the LED description, see Table2-15. |
(10) Card status LEDs. For the LED description, see Table2-17. |
(11) MCC 10GE port LED. For the LED description, see Table2-14. |
(12) MPU active/standby LED. For the LED description, see Table2-18. |
LEDs
Table2-13 Management Ethernet port LED description
LED status |
LINK (green) |
ACT (yellow) |
Steady on |
Flashing |
Steady on |
Off |
Off |
Off |
Table2-14 MCC 10GE port LED description
LED mark |
Status |
LINK/ACT |
Flashing green |
The MCC 10GE port is sending or receiving data. |
Steady green |
A link is present on the MCC 10GE port. |
Off |
No link is present on the MCC 10GE port. |
Table2-15 Fan tray status LED description
LED mark |
Status |
OK/FAIL |
Steady green |
Steady red |
One or more fans in the fan tray are faulty or the fan tray is not present. |
Off |
Table2-16 Power supply status LED description
LED mark |
Status |
OK/FAIL |
Steady green |
Steady red |
Off |
Table2-17 Card status LED description
LED status |
RUN (green) |
ALM (red) |
Flashing |
Off |
The card in the corresponding slot is operating correctly. |
Fast flashing |
Steady on |
The card in the corresponding slot is loading software. If the card keeps in this state, the current software version of the card is not compatible with that of the device. |
Steady on |
Steady on |
The card in the corresponding slot is starting up or is faulty. |
Steady on |
Off |
The MPU in the corresponding slot is initiating the boot process. |
Off |
Off |
No card is available in the corresponding slot. |
NOTE: The ALM LED being on for a while at the system startup does not mean that the card is faulty. |
Table2-18 MPU active/standby LED description
LED mark |
LEDs |
ACTIVE |
Steady green |
Off |
Ports
Console port
Table2-19 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
Table2-20 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
1 |
10/100/1000 Mbps |
Services |
USB port
Table2-21 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
MCC 10GE ports
Table2-22 MCC 10GE port specifications
Item |
Connector type |
LC |
10GBASE-R |
Transmission rate |
10.3125 Gbps |
Available transceiver modules |
For transceiver modules available for the port, see Table2-23. |
Services |
Dedicated for IRF connection between devices |
Table2-23 SFP+ transceiver module specifications available for the MCC 10GE port
Model |
Central wavelength (nm) |
Transmission distance |
Data rate (Gbps) |
Fiber mode |
Fiber diameter (µm) |
Transmit power (dBM) |
Receive power (dBM) |
SFP-XG-SX-MM850-A |
850 |
33 m (108.27 ft) |
10.31 |
MMF |
62.5/125 |
–7.3 to –1 |
–7 to –1 |
300 m (984.25 ft) |
50/125 |
SFP-XG-LX-SM1310 |
1310 |
10 km (6.21 miles) |
SMF |
9/125 |
–8.2 to +0.5 |
–12.6 to –0.5 |
Table2-24 Technical specifications
Item |
46 × 399 × 352 mm (1.81 × 15.71 × 13.86 in) |
Weight |
4.35 kg (9.59 lb) |
75 W |
67 W |
49 W |
SDRAM |
4 GB or 8 GB |
CSR07SRPUB1
View
Figure2-3 CSR07SRPUB1 view
(1) CF card |
(2) CF card LED. For the LED description, see Table2-25. |
(3) Console port |
(4) Management Ethernet ports (10/100/1000Base-T) |
(5) Management Ethernet port LED. For the LED description, see Table2-26. |
(6) MCC 10GE ports (dedicated for IRF connection, SFP+ transceiver module supported) |
(7) USB 2.0 port |
(8) System reset button |
(9) MCC 10 GE port LED. For the LED description, see Table2-27. |
(10) Fan tray status LEDs. For the LED description, see Table2-28. |
(11) Power supply status LEDs. For the LED description, see Table2-29. |
(12) Card status LEDs. For the LED description, see Table2-30. |
(13) MPU active/standby LED. For the LED description, see Table2-31. |
LEDs
Table2-25 CF card LED description
LED |
Status |
CF card LED |
Steady green |
Flashing green |
Off |
Table2-26 Management Ethernet port LED description
LED status |
LINK (green) |
ACT (yellow) |
Steady on |
Flashing |
Steady on |
Off |
Off |
Off |
Table2-27 MCC 10GE port LED description
LED mark |
Status |
LINK/ACT |
Flashing green |
Steady green |
Off |
Table2-28 Fan tray status LED description
Status |
OK (green) |
FAIL (red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-29 Power supply status LED description
Status |
OK (green) |
FAIL (red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-30 Card status LED description
Status |
RUN (green) |
ALM (red) |
Flashing |
Off |
Fast flashing |
Steady on |
Steady on |
Steady on |
The card in the corresponding slot is starting or faulty. |
Steady on |
Off |
Off |
Off |
Table2-31 MPU active/standby LED description
LED mark |
LEDs |
ACTIVE |
Steady green |
Off |
Ports
Console port
Table2-32 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
Table2-33 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
1 |
10/100/1000 Mbps |
Services |
USB port
Table2-34 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
CF card slot
Table2-35 External CF card specifications
Item |
CF card slots |
1 |
CF card capacity |
4 GB |
Services |
NOTE: Before you use a CF card, insert the CF card into the card slot and fasten the card cover. |
MCC 10GE ports
Table2-36 MCC 10GE port specifications
Item |
Connector type |
LC |
10GBASE-R |
Transmission rate |
10.3125 Gbps |
Services |
Table2-37 SFP+ transceiver module specifications
Model |
Data rate (Gbps) |
Fiber mode |
SFP-XG-SX-MM850-A |
850 |
33 m (108.27 ft) |
10.31 |
MMF |
62.5/125 |
–7.3 to –1 |
–7 to –1 |
300 m (984.25 ft) |
50/125 |
SFP-XG-LX220-MM1310 |
1310 |
220 m (721.78 ft) |
62.5/125 |
–6.5 to +0.5 |
–6.5 to +1.5 |
50/125 |
SFP-XG-LX-SM1310 |
1310 |
SMF |
9/125 |
–8.2 to +0.5 |
–12.6 to –0.5 |
Table2-38 Technical specifications
Item |
Weight |
3.40 kg (10.36 lb) |
60 W |
54 W |
44 W |
SDRAM |
4 GB |
CSR07SRPUC1
View
Figure2-4 CSR07SRPUC1 view
(1) CF card |
(2) CF card LED. For the LED description, see Table2-39. |
(3) Console port |
(4) Management Ethernet port (10/100/1000Base-T) |
(5) Management Ethernet port LED. For the LED description, see Table2-40. |
(6) USB 2.0 port |
(7) MPU active/standby LED. For the LED description, see Table2-44. |
(9) Fan tray status LE. For the LED description, see Table2-41. |
(10) Power supply status LE. For the LED description, see Table2-42. |
(11) Card status LE. For the LED description, see Table2-43. |
LEDs
CF card LED
Table2-39 CF card LED description
LED |
Status |
CF card LED |
Steady green |
Flashing green |
Off |
LED |
Status |
CF card LED |
Steady green |
Flashing green |
Off |
Table2-40 Management Ethernet port LED description
Status |
LINK (green) |
ACT (yellow) |
Steady on |
Flashing |
Steady on |
Off |
Off |
Off |
Table2-41 Fan tray status LED description
Status |
OK (green) |
FAIL (red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-42 Power supply status LED description
Status |
OK (green) |
FAIL (red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-43 Card status LED description
LED status |
RUN (green) |
ALM (red) |
Flashing |
Off |
Fast flashing |
Steady on |
The card in the corresponding slot is loading software. If the card keeps in this state, the software version of the card is not compatible with that of the device. |
Steady on |
Steady on |
Steady on |
Off |
Off |
Off |
Table2-44 MPU active/standby LED description
LED mark |
LEDs |
ACTIVE |
Steady green |
Off |
Ports
Console port
Table2-45 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
The management Ethernet port connects to a computer for router program loading and router debugging, or connects to a remote NMS for remote management.
Table2-46 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
1 |
10/100/1000 Mbps |
Services |
USB port
Table2-47 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
CF card slot
Table2-48 External CF card specifications
Item |
CF card slots |
1 |
CF card capacity |
4 GB |
Services |
Table2-49 Technical specifications
Item |
Weight |
3.30 kg (7.27 lb lb) |
45 W |
40 W |
30 W |
SDRAM |
4 GB |
CSR07SRPUD3
View
Figure2-5 CSR07SRPUD3 view
(1) CF card |
(2) CF card LED. For the LED description, see Table2-50. |
(3) Console port |
(5) Management Ethernet port LED. For the LED description, see Table2-51. |
(7) USB 2.0 port |
(9) High-precision time synchronization ports (Both are input ports by default. When both ports are input ports, only port 1 takes effect.) |
(10) SMB coaxial clock ports (2 input ports and 2 output ports) |
(11) MCC 10 GE port LED. For the LED description, see Table2-52. |
(12) Fan tray status LEDs. For the LED description, see Table2-53. |
(13) Power supply status LEDs. For the LED description, see Table2-54. |
(14) Card status LEDs. For the LED description, see Table2-55. |
(15) MPU active/standby LED. For the LED description, see Table2-56. |
LEDs
Table2-50 CF card LED description
LED |
Status |
CF card LED |
Steady green |
Flashing green |
Off |
Table2-51 Management Ethernet port LED description
LED status |
LINK (green) |
ACT (yellow) |
Steady on |
Flashing |
Steady on |
Off |
Off |
Off |
Table2-52 MCC 10GE port LED description
LED mark |
Status |
LINK/ACT |
Flashing green |
Steady green |
Off |
Table2-53 Fan tray status LED description
LED status |
OK (green) |
FAIL (red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-54 Power supply status LED description
LED status |
OK (green) |
FAIL (red) |
Steady on |
Off |
Off |
Steady on |
Off |
Off |
Table2-55 Card status LED description
Status |
RUN (green) |
ALM (red) |
Flashing |
Off |
Fast flashing |
Steady on |
Steady on |
Steady on |
Steady on |
Off |
Off |
Off |
Table2-56 MPU active/standby LED description
LED mark |
LEDs |
ACTIVE |
Steady green |
Off |
Ports
Console port
Table2-57 Console port specifications
Item |
Connector type |
RJ-45 |
Services |
Table2-58 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
Port quantity |
1 |
10/100/1000 Mbps |
Services |
USB port
Table2-59 USB port specifications
Item |
Connector type |
USB A |
USB 2.0 |
Services |
CF card slot
Table2-60 External CF card specifications
Item |
CF card slots |
1 |
CF card capacity |
4 GB |
Services |
MCC 10GE ports
Table2-61 MCC 10GE port specifications
Item |
Connector type |
LC |
10GBASE-R |
Transmission rate |
10.3125 Gbps |
Services |
Table2-62 SFP+ transceiver module specifications
Model |
Data rate (Gbps) |
Fiber mode |
SFP-XG-SX-MM850-A |
850 |
33 m (108.27 ft) |
10.31 |
MMF |
62.5/125 |
–7.3 to –1 |
–7 to –1 |
300 m (984.25 ft) |
50/125 |
1310 |
220 m (721.78 ft) |
62.5/125 |
–6.5 to +0.5 |
–6.5 to +1.5 |
50/125 |
SFP-XG-LX-SM1310 |
1310 |
SMF |
9/125 |
–8.2 to +0.5 |
–12.6 to –0.5 |
SMB coaxial clock input/output port
SMB coaxial clock ports provide input or output clock references at 2.048 Mbps (2.048 MHz). You can set the data rate mode or frequency mode through the CLI. Two of them are input ports and two are output ports.
Table2-63 SMB coaxial clock input/output port specifications
Item |
Connector type |
SMB coaxial |
GJB681 |
2.048 Mbps |
Transmission medium |
75-ohm coaxial cable |
Services |
Sends and receives 2.048 MHz clocks and 2.048 Mbps signals to synchronize the clocks of the router and other devices, such as routers and the terminals. |
Table2-64 High-precision time synchronization port specifications
Item |
Connector type |
RJ-45 |
QB-B-016-2010 |
9600 bps |
Category-5 or above twisted pair cable |
Services |
You can configure the port as an input port or output port at the CLI. Synchronizes the clocks of the router and other devices, such as GPS receivers and terminals. |
Table2-65 Technical specifications
Item |
Weight |
4.15 kg (9.15 lb) |
110 W |
99 W |
80 W |
SDRAM |
8 GB or 16 GB |
Compatibility information
For the MPUs supported by each router model, see Table2-66.
The router supports dual MPUs. To install two MPUs are the router, make sure they are the same model.
Table2-66 Compatibility matrix between MPUs and routers
MPU model |
SR8803-F |
SR8805-F |
SR8808-F |
SR8812-F |
CSR07MPUA1 |
Supported |
Not supported |
Not supported |
Not supported |
CSR07SRPUA1 |
Not supported |
Supported |
Supported |
Supported |
CSR07SRPUB1 |
Not supported |
Supported |
Supported |
Supported |
CSR07SRPUC1 |
Not supported |
Supported |
Not supported |
Not supported |
CSR07SRPUD3 |
Not supported |
Supported |
Supported |
Supported |
The router supports various types of interface modules, each of which provides a different number and type of interfaces.
CAUTION: · The SR8805-F router installed with the CSR07SRPUC1 MPU and SR8803-F router do not support the CSPC-CP2LB interface module. · To install a CSPC-CP2LB interface module on an SR8812-F router, you can install it only in slot 0, 4, or 7. |
CSPC-CP2LB
View
Figure2-6 CSPC-CP2LB view
(1) 100GBASE-R-CFP fiber ports (2 in total) |
(2) CFP port LED. For the LED description, see Table2-67. |
LEDs
Table2-67 CFP port LED description
LED |
Status |
CFP port LED |
Flashing |
The CFP port is sending or receiving data. |
Steady on |
A link is present on the CFP port. |
Off |
No link is present on the CFP port. |
Ports
Table2-68 Port specifications
Card model |
Connector type |
Port quantity |
Port transmission speed |
CSPC-CP2LB |
2-port 100GBASE Ethernet optical interface module |
LC |
2 |
100 Gbps |
Table2-69 Technical specifications
Item |
40 × 399 × 352 mm (1.57 × 15.71 × 13.86 in) |
Weight |
4.06 kg (8.95 lb) |
197 W |
178 W |
150 W |
CSPC-GE16XP4L-E
View
Figure2-7 CSPC-GE16XP4L-E view
(1) 10GBASE-R-SFP+ fiber ports (4 in total) (10GE SFP+ modules supported) |
(2) Combo interfaces (16 in total) (GE SFP modules supported in 1000BASE-X-SFP fiber ports) |
(3) SFP port LED. For the LED description, see Table2-71. |
(4) RJ-45 Ethernet Interface LED. For the LED description, see Table2-70. |
(5) SFP+ port LED. For the LED description, see Table2-72. |
LEDs
Table2-70 RJ-45 Ethernet port LED description
LED |
Status |
RJ-45 Ethernet port LED |
Flashing |
The port is sending or receiving data. |
Steady on |
Off |
Table2-71 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
A link is present on the SFP port. |
Off |
Table2-72 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
NOTE: You can identify the rate of an SFP+ port by observing the color of its LED. When the LED is green, the SFP+ port is operating at 10 Gbps. When the LED is yellow, the SFP+ port is operating at 1000 Mbps. |
Ports
Table2-73 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GE16XP4L-E |
16-port 1000BASE-X Ethernet combo interface + 4-port 10GBASE-R/W Ethernet optical interface line processing unit |
RJ-45 |
16 |
10/100/1000 Mbps |
LC |
16 |
1000 Mbps |
4 |
10 Gbps |
Table2-74 Technical specifications
Item |
Weight |
4.35 kg (9.59 lb) |
127 W |
114 W |
107 W |
CSPC-GE24L-E
View
Figure2-8 CSPC-GE24L-E view
(1) Combo interfaces (24 in total) (GE SFP modules supported in 1000BASE-X-SFP fiber ports) |
(2) SFP port LED. For the LED description, see Table2-76. |
(3) RJ-45 Ethernet Interface LED. For the LED description, see Table2-75. |
Status
Table2-75 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
On |
Off |
Table2-76 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
On |
Off |
Ports
Card model |
Connector type |
Port quantity |
CSPC-GE24L-E |
24-port 1000BASE-X Ethernet combo interface line processing unit |
RJ-45 |
24 |
10/100/1000 Mbps |
LC |
24 |
100 Mbps |
1000 Mbps |
Table2-78 Technical specifications
Item |
Weight |
4.45 kg (9.81 lb) |
114 W |
110 W |
108 W |
CSPC-GP24GE8XP2L-E
View
Figure2-9 CSPC-GP24GE8XP2L-E view
(1) 10GBASE-R-SFP+ fiber ports (2 in total) (10GE SFP+ modules supported) |
(2) 1000BASE-X-SFP fiber ports (24 in total, GE SFP modules supported) |
(3) Combo interfaces (8 in total) (GE SFP modules supported in 1000BASE-X-SFP fiber ports) |
(4) RJ-45 Ethernet Interface LED. For the LED description, see Table2-79. |
(5) SFP port LED. For the LED description, see Table2-80. |
(6) SFP+ port LED. For the LED description, see Table2-81. |
LEDs
Table2-79 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
On |
Off |
Table2-80 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
On |
Off |
Table2-81 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
On |
Off |
Ports
Table2-82 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GP24GE8XP2L-E |
24-port 1000BASE-X Ethernet optical interface + 8-port 1000BASE-X Ethernet combo interface + 2-port 10GBASE-R/W Ethernet optical interface line processing unit |
RJ-45 |
8 |
10/100/1000 Mbps |
LC |
32 |
1000 Mbps |
2 |
10 Gbps |
Table2-83 Technical specifications
Item |
Weight |
4.45 kg (9.81 lb) |
126 W |
113 W |
101 W |
CSPC-GP24LA1
View
Figure2-10 CSPC-GP24LA1 view
(1) 1000BASE-X-SFP fiber ports (16 in total) |
(2) Combo interfaces (8 in total) |
(3) SFP port LED. For the LED description, see Table2-85. |
(4) RJ-45 Ethernet port LED. For the LED description, see Table2-84. |
NOTE: · A combo interface is a logical interface that contains an SFP fiber port and an RJ-45 copper port. The two ports share one forwarding channel. As a result, they cannot work simultaneously. When you activate one port, the other port is automatically disabled. You can activate the fiber or copper port as needed. By default, the copper port is activated. · Use a category 5 or above twisted pair cable to connect a 1000BASE-T RJ-45 copper port. The maximum transmission distance is 100 m (328.08 ft). |
Status
Table2-84 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Table2-85 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Ports
Table2-86 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GP24LA1 |
16-port 1000BASE-X Ethernet optical interface + 8-port combo interface module |
RJ-45 |
8 |
10/100/1000 Mbps |
LC |
24 |
155 Mbps |
1000 Mbps |
10/100/1000 Mbps |
Table2-87 Technical specifications
Item |
Weight |
3.01 kg (6.64 lb) |
75 W |
68 W |
47 W |
CSPC-GP24XP2LB
View
Figure2-11 CSPC-GP24XP2LB view
(3) 10GBASE-R-XFP fiber ports (2 in total) |
(4) SFP port LED. For the LED description, see Table2-89. |
(5) RJ-45 Ethernet port LED. For the LED description, see Table2-88. |
(6) XFP port LED. For the LED description, see Table2-90. |
LEDs
Table2-88 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Table2-89 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Table2-90 XFP port LED description
XFP port LED status |
LINK |
ACT |
Steady on |
Flashing |
A link is present, and the port is sending or receiving data. |
Steady on |
Off |
A link is present, but the port is not sending or receiving data. |
Off |
Off |
No link is present on the XFP port. |
Ports
Table2-91 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GP24XP2LB |
16-port 1000BASE-X optical interface + 8-port combo interface + 2-port 10GE optical interface module |
RJ-45 |
8 |
10/100/1000 Mbps |
LC |
24 |
155 Mbps |
1000 Mbps |
Table2-92 Technical specifications
Item |
Weight |
3.08 kg (6.79 lb) |
100 W |
90 W |
51 W |
CSPC-GP48LB
View
Figure2-12 CSPC-GP48LB view
(1) 1000BASE-X-SFP fiber ports (48 in total) |
(2) SFP port LED. For the LED description, see Table2-93. |
LEDs
Table2-93 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Ports
Table2-94 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GP48LB |
48-port enhanced 1000BASE-X Ethernet optical interface module |
LC |
48 |
100 Mbps |
155 Mbps |
1000 Mbps |
10/100/1000 Mbps |
10/100/1000 Mbps |
2 |
10 Gbps |
Table2-95 Technical specifications
Item |
Weight |
3.25 kg (7.17 lb) |
110 W |
99 W |
43 W |
CSPC-GT48LA1
View
Figure2-13 CSPC-GT48LA1 view
(1) 10/100/1000BASE-T copper ports (48 in total) |
(2) RJ-45 Ethernet port LED. For the LED description, see Table2-96. |
LEDs
Table2-96 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Ports
Table2-97 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-GT48LA1 |
48-port 10/100/1000BASE-T Ethernet interface module |
RJ-45 |
48 |
10/100/1000 Mbps |
Table2-98 Technical specifications
Item |
Weight |
3.31 kg (7.29 lb) |
95 W |
86 W |
67 W |
CSPC-XP2LA1
View
Figure2-14 CSPC-XP2LA1 view
(1) 10GBASE-R-XFP fiber ports (2 in total) |
(2) XFP port LED. For the LED description, see Table2-99. |
LEDs
Table2-99 XFP port LED description
LED status |
LINK |
ACT |
Steady on |
Flashing |
Steady on |
Off |
Off |
Off |
Ports
Table2-100 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-XP2LA1 |
2-port 10GBASE Ethernet optical interface module |
LC |
2 |
10 Gbps |
Table2-101 Technical specifications
Item |
Weight |
2.93 kg (6.46 lb) |
55 W |
50 W |
43 W |
CSPC-XP4LB
View
(2) XFP port LED. For the LED description, see Table2-102. |
LEDs
Table2-102 XFP port LED description
LED status |
LINK |
ACT |
Steady on |
Flashing |
Steady on |
Off |
Off |
Off |
Ports
Table2-103 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-XP4LB |
4-port enhanced 10GBASE Ethernet optical interface module |
LC |
4 |
10 Gbps |
Table2-104 Technical specifications
Item |
Weight |
2.93 kg (6.46 lb) |
80 W |
72 W |
53 W |
CSPC-XP8LB
View
(1) 10GBASE-R-SFP+ fiber ports (8 in total) |
(2) SFP+ port LED. For the LED description, see Table2-105. |
Status
Table2-105 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-106 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-XP8LB |
8-port enhanced 10GBASE Ethernet optical interface module |
LC |
8 |
10 Gbps |
10/100/1000 Mbps |
Table2-107 Technical specifications
Item |
Weight |
3.44 kg (7.58 lb) |
170 W |
153 W |
117 W |
SPC-CP1LC
View
Figure2-17 SPC-CP1LC view
(1) 100GBASE-R-CFP fiber port (1 in total) |
(2) CFP port LED. For the LED description, see Table2-108. |
LEDs
Table2-108 CFP port LED description
LED |
Status |
CFP port LED |
Flashing |
Steady on |
Off |
Ports
Table2-109 Port specifications
Card model |
Connector type |
Port quantity |
CSPC-CP1LCX |
1-port 100GBASE Ethernet optical interface module |
LC |
1 |
100 Gbps |
Table2-110 Technical specifications
Item |
Weight |
3.40 kg (7.50 lb) |
120 W |
108 W |
85 W |
SPC-GP44XP4LA/SPC-GP44XP4LC
View
Figure2-18 SPC-GP44XP4LC view
(1) 1000BASE-X-SFP fiber ports (44 in total) |
(2) 10GBASE-R-SFP+ fiber ports (4 in total) |
(3) SFP port LED. For the LED description, see Table2-111. |
(4) SFP+ port LED. For the LED description, see Table2-112. |
NOTE: The views of the SPC-GP44XP4LA and SPC-GP44XP4LC interface modules are similar. This figure uses the SPC-GP44XP4LC as an example. |
Status
Table2-111 SFP port LED description
LED |
Status |
SFP port LED |
Flashing |
Steady on |
Off |
Table2-112 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-113 Port specifications
Card model |
Connector type |
Port quantity |
SPC-GP44XP4LA |
44-port 1000BASE-X Ethernet optical interface module + 4-port 10GBASE Ethernet optical interface module |
LC |
44 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
LC |
4 |
10 Gbps |
SPC-GP44XP4LC |
LC |
44 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
LC |
4 |
10 Gbps |
Table2-114 Technical specifications
Item |
Weight |
· SPC-GP44XP4LA: 3.55 kg (7.83 lb) · SPC-GP44XP4LC: 3.60 kg (7.94 lb) |
· SPC-GP44XP4LA: 118 W · SPC-GP44XP4LC: 146 W |
· SPC-GP44XP4LA: 106 W · SPC-GP44XP4LC: 131 W |
· SPC-GP44XP4LA: 83 W · SPC-GP44XP4LC: 90 W |
SPC-XLP2XP4LC
View
Figure2-19 SPC-XLP2XP4LC view
(1) SFP+ port LED. For the LED description, see Table2-115. |
(3) 40GBASE-R-QSFP+ fiber ports (2 in total) |
(4) QSFP+ port LED. For the LED description, see Table2-116. |
LEDs
Table2-115 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Table2-116 QSFP+ port LED description
LED |
Status |
QSFP+ port LED |
Flashing |
The QSFP+ port is sending or receiving data. |
Steady on |
A link is present on the QSFP+ port. |
Off |
No link is present on the QSFP+ port. |
Ports
Table2-117 Port specifications
Card model |
Connector type |
Port quantity |
SPC-XLP2XP4LC |
2-port 40GBASE Ethernet optical interface module + 4-port 10GBASE Ethernet optical interface module |
LC |
4 |
10 Gbps |
10/100/1000 Mbps |
MPO/LC |
2 |
40 Gbps |
Table2-118 Technical specifications
Item |
Weight |
3.20 kg (7.05 lb) |
143 W |
128 W |
91 W |
SPC-XP12LC
View
Figure2-20 SPC-XP12LC view
(1) 10GBASE-R-SFP+ fiber ports (12 in total) |
(2) SFP+ port LED. For the LED description, see Table2-119. |
Status
Table2-119 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-120 Port specifications
Card model |
Connector type |
Port quantity |
SPC-XP12LC |
12-port 10GBASE Ethernet optical interface module |
LC |
12 |
10 Gbps |
10/100/1000 Mbps |
Table2-121 Technical specifications
Item |
Weight |
3.30 kg (7.28 lb) |
146 W |
131 W |
91 W |
SPC-XP24LC
View
Figure2-21 SPC-XP24LC view
(1) 10GBASE-R-SFP+ fiber ports (24 in total) |
(2) SFP+ port LED. For the LED description, see Table2-122. |
Status
Table2-122 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-123 Port specifications
Card model |
Connector type |
Port quantity |
SPC-XP24LC |
24-port 10GBASE Ethernet optical interface module |
LC |
24 |
10 Gbps |
10/100/1000 Mbps |
Table2-124 Technical specifications
Item |
Weight |
4.20 kg (10.36 lb) |
400 W |
267 W |
174 W |
CSPEX base cards
View
Figure2-22 CSPEX-1204 view
(1) Card status LED. For the LED description, see Table2-125. |
The views of the CSPEX-1204, CSPEX-1304S, CSPEX-1404S, CSPEX-1504S, and CSPEX-1104-E base cards are similar. This figure uses the CSPEX-1204 as an example.
LEDs
LED |
Status |
RUN (green) |
Steady on |
The card is faulty. |
Off |
The card is faulty or is not present. |
Flashing (about once per second) |
The card is operating correctly. |
Fast flashing (about eight times per second) |
The card is starting up. If the LED keeps fast flashing, card registration has failed. |
Subcard slots
Table2-126 Subcard slots
Card model |
Number of subcard slots |
CSPEX-1104-E |
4 |
CSPEX-1204 |
4 |
CSPEX-1304S |
4 |
CSPEX-1404S |
4 |
CSPEX-1504S |
4 |
Table2-127 Technical specifications
Item |
Weight |
· CSPEX-1104-E: 3.45 kg (7.61 lb) · CSPEX-1204: 3.50 kg (7.72 lb) · CSPEX-1304S: 3.75 kg (8.27 lb) · CSPEX-1404S: 3.65 kg (8.05 lb) · CSPEX-1504S: 3.85 kg (8.49 lb) |
· CSPEX-1104-E: 164 W · CSPEX-1204: 190 W · CSPEX-1304S: 184 W · CSPEX-1404S: 230 W · CSPEX-1504S: 261 W |
· CSPEX-1104-E: 88 W · CSPEX-1204: 104 W · CSPEX-1304S: 106 W · CSPEX-1404S: 148 W · CSPEX-1504S: 176 W |
· CSPEX-1104-E: 79 W · CSPEX-1204: 88 W · CSPEX-1304S: 92 W · CSPEX-1404S: 120.5 W · CSPEX-1504S: 128.3 W |
The CSPEX-1304S, CSPEX-1404S, and CSPEX-1504S base cards are not compatible with the CSR07SRPUB1 and CSR07SRPUC1 MPUs.
Do not mix CSPEX-1304S, CSPEX-1404S, or CSPEX-1504S base cards with other CSPEX cards than these three on an SR8803-F router.
A CSPEX-1104-E card supports a maximum of three MIC-XP4L1 or MIC-GP4L subcards or a maximum of three of them in combinations.
Compatibility matrix between CSPEX based cards and subcards
Table2-128 Compatibility matrix between CSPEX cards and subcards
Card model |
CSPEX card |
CSPEX-1504S/CSPEX-1404S |
CSPEX-1304S |
CSPEX-1204 |
CSPEX-1104-E |
PIC-GP10L |
Not supported |
Not supported |
Slots 1 and 2: Supported Slots 3 and 4: Not supported |
Not supported |
PIC-TCP8L |
Not supported |
Not supported |
PIC-PSP4L |
Not supported |
Not supported |
PIC-PS2G4L |
Not supported |
Not supported |
Not supported |
PIC-PUP1L |
Not supported |
Not supported |
PIC-XP1L |
Not supported |
Not supported |
Not supported |
MIC-GT20L |
Not supported |
MIC-ET16L |
Supported |
Supported |
Supported |
Supported |
MIC-CLP2L |
Supported |
Supported |
Supported |
Supported |
MIC-CLP4L |
Supported |
Supported |
Supported |
Supported |
MIC-SP4L |
Supported |
Supported |
Supported |
Supported |
MIC-SP8L |
Supported |
Supported |
Supported |
Supported |
MIC-GP4L |
Supported |
Supported |
Slots 1 and 2: Not supported Slots 3 and 4: Supported |
Supported. A maximum of three are supported |
MIC-GP8L |
Not supported |
Not supported |
Not supported |
MIC-GP10L1 |
Not supported |
Not supported |
Not supported |
MIC-GP10L-V2 |
Supported |
Slots 1, 2, and 3: Supported Slot 4: Not supported |
Not supported |
Supported |
MIC-GP20L |
Not supported |
MIC-XP2L |
Supported |
Supported |
Not supported |
Supported |
MIC-XP2L-LAN |
Supported |
Supported |
Not supported |
Supported |
MIC-XP4L1 |
Supported |
Supported |
Not supported |
MIC-XP5L |
Supported |
Supported |
Not supported |
Not supported |
MIC-XP5L1 |
Supported |
Supported |
Not supported |
Not supported |
MIC-XP5L2 |
Supported |
Supported |
Not supported |
Not supported |
MIC-QP1L |
Supported |
Supported |
Not supported |
Not supported |
MIC-CP1L |
Not supported |
Not supported |
Not supported |
MIC-CQ1L1 |
Not supported |
Not supported |
Not supported |
MIC-PSP4L |
Supported |
Supported |
Not supported |
Supported |
MIC-TCP8L |
Supported |
Not supported |
Supported |
CMPE base cards
CMPE-1104
View
Figure2-23 CMPE-1104 view
(1) Card status LED. For the LED description, see Table2-129. |
LEDs
LED |
Status |
RUN (green) |
Steady on |
Off |
Subslots
Table2-130 Subslots
Card model |
CMPE-1104 |
4 |
Table2-131 Technical specifications
Item |
Weight |
3.52 kg (7.76 lb) |
158 W |
94 W |
91 W |
The CMPE subslot restrictions depend on its subcard mode. For more information about the subcard mode, see H3C SR8800-F Routers Configuration Guides.
Compatibility matrix between CMPE based cards and subcards
Table2-132 Compatibility matrix between CMPE cards and subcards
Subcard model |
CMPE base card |
PIC-GP10L |
Not supported |
PIC-TCP8L |
Not supported |
PIC-PSP4L |
Not supported |
PIC-PS2G4L |
Not supported |
PIC-PUP1L |
Not supported |
PIC-XP1L |
Not supported |
MIC-GT20L |
Not supported |
MIC-CLP4L |
Supported |
MIC-ET16L |
Supported |
MIC-CLP2L |
Supported |
MIC-SP8L |
Only one is supported. Can be installed only slot 1 or slot 2. |
MIC-SP4L |
Supported |
MIC-GP4L |
Supported |
MIC-GP8L |
MIC-GP10L1 |
Not supported |
MIC-GP10L-V2 |
Not supported |
MIC-GP20L |
Not supported |
MIC-XP2L |
Not supported |
MIC-XP2L-LAN |
Not supported |
MIC-XP4L1 |
Not supported |
MIC-XP5L |
Not supported |
MIC-XP5L1 |
Not supported |
MIC-XP5L2 |
Not supported |
MIC-QP1L |
Not supported |
MIC-CP1L |
Not supported |
MIC-CQ1L1 |
Not supported |
MIC-PSP4L |
Not supported |
MIC-TCP8L |
Not supported |
MIC subcards
IMPORTANT: · To use a MIC interface card, you must install it on a CMPE or CSPEX base card. You cannot install it directly on the router. · For the compatibility between MIC interface cards and CMPE or CSPEX base cards, see compatibility information for the base cards. · A combo interface is a logical interface that consists of an SFP port and an RJ-45 Ethernet port. Only one of the two ports can be operational at a time. · Some MIC subcards support changing the speed. For more information, see H3C SR8800-F Routers Configuration Guides. |
MIC-CLP2L
View
Figure2-24 MIC-CLP2L view
(1) CPOS-OC3/STM1-SFP port (2 in total) |
(2) Port LED. For the LED description, see Table2-133. |
LEDs
Table2-133 WAN port LED description
LED |
Status |
WAN port LED (ACT/ALM) |
Flashing green |
The port is up and is receiving or sending data correctly. |
Steady green |
The port is up and no services are running on the port. |
Steady red |
An alarm has occurred. |
Off |
The port is down. |
Ports
Table2-134 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CLP2L |
2-port OC-3/STM-1 CPOS optical interface card |
LC |
2 |
155 Mbps (OC-3/STM-1) |
Table2-135 Technical specifications
Item |
18 × 171 × 157 mm (0.71 × 6.73 × 6.18 in) |
Weight |
0.32 kg (0.71 lb) |
10.9 W |
9.8 W |
MIC-CLP4L
View
Figure2-25 MIC-CLP4L view
(1) CPOS-OC3/STM1-SFP port (4 in total) |
(2) Port LED. For the LED description, see Table2-136. |
LEDs
Table2-136 WAN port LED description
LED |
Status |
Flashing green |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-137 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CLP4L |
4-port OC-3/STM-1 CPOS optical interface card |
LC |
4 |
Table2-138 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
12.9 W |
9.8 W |
MIC-CP1L
View
Figure2-26 MIC-CP1L view
(2) CFP port LED. For the LED description, see Table2-139. |
LEDs
Table2-139 CFP port LED description
LED |
Status |
CFP port LED |
Flashing |
Steady on |
Off |
Ports
Table2-140 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CP1L |
1-port 100G optical interface card (CFP, LC) |
LC |
1 |
100 Gbps |
Table2-141 MIC-CP1L
Item |
37 × 171 × 157 mm (1.46 × 6.74 × 6.19 in) |
Weight |
0.55 kg (1.21 lb) |
11.8 W |
3.3 W |
MIC-CQ1L1
View
Figure2-27 MIC-CQ1L1 view
(1) 100GBASE-R-QSFP28 fiber port (1 in total) |
(2) QSFP28 port LED. For the LED description, see Table2-142. |
LEDs
Table2-142 QSFP28 port LED description
LED |
Status |
QSFP28 port LED |
Flashing |
The QSFP28 port is sending or receiving data at 100 Gbps. |
On |
A 100 Gbps link is present on the QSFP28 port. |
Off |
No link is present on the QSFP28 port. |
Ports
Table2-143 Port specifications
Card model |
Connector type |
Port quantity |
MIC-CQ1L1 |
1-port 100G optical interface card |
LC |
1 |
100 Gbps |
40 Gbps |
Table2-144 Technical specifications
Item |
37 × 171 × 157 mm (1.46 × 6.74 × 6.18 in) |
Weight |
0.50 kg (1.10 lb) |
15 W |
9 W |
MIC-ET16L
View
Figure2-28 MIC-ET16L view
(1) E1-HM96 copper ports (16 in total) |
(2) Port LED. For the LED description, see Table2-145. |
LEDs
LED |
Status |
ACT/ALM |
Flashing green |
Steady green |
A link is present, but the port is not receiving or sending data. |
Red |
Off |
Ports
Table2-146 Port specifications
Card model |
Connector type |
Port quantity |
MIC-ET16L |
16-port E1 electrical interface card (HM96 male connector) |
HM96 male |
16 |
E1 |
Table2-147 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
8.7 W |
8.6 W |
MIC-GP10L1
View
Figure2-29 MIC-GP10L1 view
(1) 1000BASE-X-SFP fiber ports (10 in total) |
(2) SFP port LED. For the LED description, see Table2-148. |
LEDs
Table2-148 GE SFP port LED description
LED |
Status |
GE SFP port LED (LINK/ACT) |
Flashing green |
The SFP port is sending or receiving data. |
Steady green |
Off |
No link is present on the SFP port. |
Ports
Table2-149 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP10L1 |
10-port 1000BASE-X optical interface card (SFP, LC) |
LC |
10 |
1000 Mbps |
10/100/1000 Mbps |
Table2-150 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
7.9 W |
2.1 W |
MIC-GP10L-V2
View
Figure2-30 MIC-GP10L-V2 view
(2) SFP port LED. For the LED description, see Table2-151. |
LEDs
Table2-151 GE SFP port LED description
LED |
Status |
Flashing green |
Steady green |
Off |
Ports
Table2-152 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP10L-V2 |
10-port 1000BASE-X Ethernet optical interface card (SFP, LC) |
LC |
10 |
1000 Mbps |
10/100/1000 Mbps |
100 Mbps |
Table2-153 Technical specifications
Item |
Weight |
0.35 kg (0.77 lb) |
9.4 W |
9.3 W |
MIC-GP20L
View
Figure2-31 MIC-GP20L view
(1) 1000BASE-X-SFP fiber ports (20 in total) |
(2) SFP port LED. For the LED description, see Table2-154. |
LEDs
Table2-154 GE SFP port LED description
LED |
Status |
Flashing green |
Steady green |
Off |
Ports
Table2-155 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP20L |
20-port 1000BASE-X Ethernet optical interface card (SFP, LC) |
LC |
20 |
1000 Mbps |
10/100/1000 Mbps |
100 Mbps |
Table2-156 Technical specifications
Item |
37 × 171 × 157 mm (1.46 × 6.73 × 6.18 in) |
Weight |
0.55 kg (1.21 lb) |
23 W |
7.6 W |
MIC-GP4L
View
Figure2-32 MIC-GP4L view
(1) Combo interfaces (4 in total) |
(2) Combo fiber port LINK/ACT LED. For the LED description, see Table2-157. |
(3) Combo copper port LINK LED. For the LED description, see Table2-157. |
(4) Combo copper port ACT LED. For the LED description, see Table2-157. |
LEDs
Table2-157 Combo interface LED description
Port type |
LED |
Status |
Combo fiber port |
LINK/ACT |
Steady on |
Flashing |
The port is receiving or sending data correctly. |
Off |
Combo copper port |
LINK (green) |
Steady on |
Off |
ACT (orange) |
Flashing |
Off |
The port is not receiving or sending data. |
Ports
Table2-158 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP4L |
4-port 1000BASE-X/1000BASE-T combo interface card |
RJ-45 |
4 |
10/100/1000 Mbps |
LC |
4 |
100 Mbps |
1000 Mbps |
Table2-159 Technical specifications
Item |
Weight |
0.31 kg (0.68 lb) |
5.5 W |
0.8 W |
MIC-GP8L
View
Figure2-33 MIC-GP8L view
(1) 1000BASE-X-SFP fiber ports (8 in total) |
(2) SFP port LED. For the LED description, see Table2-160. |
LEDs
Table2-160 GE SFP port LED description
LED |
Status |
Flashing green |
Steady green |
Off |
Ports
Table2-161 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GP8L |
8-port 1000BASE-X optical interface card (SFP, LC) |
LC |
8 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
Table2-162 Technical specifications
Item |
Weight |
0.29 kg (0.64 lb) |
4.7 W |
0.6 W |
MIC-GT20L
View
Figure2-34 MIC-GT20L view
(1) 10/100/1000BASE-T copper ports (20 in total) |
(2) RJ-45 Ethernet port LED. For the LED description, see Table2-163. |
LEDs
Table2-163 RJ-45 Ethernet port LED description
LED |
Status |
Flashing |
Steady on |
Off |
Ports
Table2-164 Port specifications
Card model |
Connector type |
Port quantity |
MIC-GT20L |
20-port 1000BASE-X Ethernet electrical interface card (RJ45) |
RJ-45 |
20 |
10/100/1000 Mbps |
Table2-165 Technical specifications
Item |
Weight |
0.50 kg (1.10 lb) |
11.9 W |
9.2 W |
MIC-PSP4L
View
Figure2-35 MIC-PSP4L view
(1) OC-48c/STM-16c POS fiber ports (4 in total) |
(2) Port LED. For the LED description, see Table2-166. |
LEDs
Table2-166 WAN port LED description
LED |
Status |
Flashing green |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-167 Port specifications
Card model |
Connector type |
Port quantity |
MIC-PSP4L |
4-port OC-48c/STM-16c POS optical interface card (SFP, LC) |
LC |
4 |
2.5 Gbps |
Table2-168 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
33 W |
29 W |
MIC-QP1L
View
Figure2-36 MIC-QP1L view
(1) 40GBASE-R-QSFP+ fiber ports (1 in total) |
(2) QSFP+ port LED. For the LED description, see Table2-169. |
LEDs
Table2-169 QSFP+ port LED description
LED |
Status |
QSFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-170 Port specifications
Card model |
Connector type |
Port quantity |
MIC-QP1L |
1-port 40G Ethernet optical interface card (QSFP+, LC) |
LC |
1 |
40 Gbps |
4 |
10 Gbps |
Table2-171 Technical specifications
Item |
Weight |
0.35 kg (0.77 lb) |
7 W |
3 W |
MIC-SP4L
View
Figure2-37 MIC-SP4L view
(1) 4 × OC-3c/STM-1c POS/ATM fiber ports or 1 × OC-12c/STM-4c POS/ATM fiber ports (only port 1 supports OC-12c/STM-4c) |
(2) Port LED. For the LED description, see Table2-172. |
LEDs
Table2-172 WAN port LED description
LED |
Status |
Flashing green |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-173 Port specifications
Card model |
Connector type |
Port quantity |
MIC-SP4L |
4-port OC-3c/STM-1c POS/ATM or 1-port OC-12c/STM-4c POS/ATM optical interface card (SFP, LC) |
LC |
4 |
1 |
622 Mbps (OC-12/STM-4) |
Table2-174 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
13.5 W |
9.6 W |
MIC-SP8L
View
Figure2-38 MIC-SP8L view
(1) OC-3c/STM-1c POS fiber ports (8 in total) |
(2) Port LED. For the LED description, see Table2-175. |
LEDs
Table2-175 WAN port LED description
LED |
Status |
Flashing green |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-176 Port specifications
Card model |
Connector type |
Port quantity |
MIC-SP8L |
8-port OC-3c/STM-1c POS optical interface card (SFP, LC) |
LC |
8 |
Table2-177 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
16.3 W |
14 W |
MIC-TCP8L
View
Figure2-39 MIC-TCP8L view
(1) OC-3c/OC-12c POS/GE fiber ports (8 in total) |
(2) Port LED. For the LED description, see Table2-178. |
LEDs
Table2-178 WAN port LED description
LED |
Status |
Flashing green |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-179 Port specifications
Card model |
Connector type |
Port quantity |
MIC-TCP8L |
8-port OC-3c/OC-12c POS/GE optical interface card (SFP, LC) |
LC |
8 |
10/100/1000 Mbps |
1000 Mbps |
Table2-180 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
30 W |
28 W |
MIC-XP2L
View
Figure2-40 MIC-XP2L view
(1) 10GBASE-R/W-SFP+ fiber ports (2 in total) |
(2) SFP+ port LED. For the LED description, see Table2-181. |
LEDs
Table2-181 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-182 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP2L |
2-port 10GBASE-R Ethernet optical interface card (SFP+, LC) |
LC |
2 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
Table2-183 Technical specifications
Item |
Weight |
0.29 kg (0.64 lb) |
13 W |
10 W |
MIC-XP2L-LAN
View
Figure2-41 MIC-XP2L-LAN view
(1) 10GBASE-R-SFP+ fiber ports (2 in total) |
(2) SFP+ port LED. For the LED description, see Table2-184. |
LEDs
Table2-184 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-185 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP2L-LAN |
2-port 10GBASE-R Ethernet optical interface card (SFP+, LC)-LAN |
LC |
2 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
Table2-186 Technical specifications
Item |
Weight |
0.28 kg (0.62 lb) |
9 W |
6 W |
MIC-XP4L1
View
Figure2-42 MIC-XP4L1 view
(1) 10GBASE-R/W-SFP+ fiber ports (4 in total) |
(2) SFP+ port LED. For the LED description, see Table2-187. |
LEDs
Table2-187 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-188 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP4L1 |
4-port 10GBASE-R/W Ethernet optical interface card 1 |
LC |
4 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
Table2-189 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
13 W |
11 W |
MIC-XP5L
View
Figure2-43 MIC-XP5L view
(1) 10GBASE-R/W-SFP+ fiber ports (5 in total) |
(2) SFP+ port LED. For the LED description, see Table2-190. |
LEDs
Table2-190 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-191 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP5L |
5-port 10GBASE-R/W Ethernet optical interface card |
LC |
5 |
100 Mbps |
10/100/1000 Mbps |
1000 Mbps |
10 Gbps |
Table2-192 Technical specifications
Item |
Weight |
0.30 kg (0.66 lb) |
14.2 W |
10.4 W |
MIC-XP5L1/MIC-XP5L2
View
Figure2-44 MIC-XP5L1 view
(2) SFP+ port LED. For the LED description, see Table2-193. |
The views of the MIC-XP5L1 and MIC-XP5L2 interface cards are similar. The figure uses the MIC-XP5L1 as an example.
LEDs
Table2-193 SFP+ port LED description
LED |
Status |
SFP+ port LED |
Flashing |
Steady on |
Off |
Ports
Table2-194 Port specifications
Card model |
Connector type |
Port quantity |
MIC-XP5L1 |
LC |
5 |
10/100/1000 Mbps |
10 Gbps |
MIC-XP5L2 |
5-port 10GBASE-R Ethernet optical interface card |
LC |
5 |
10/100/1000 Mbps |
10 Gbps |
Table2-195 Technical specifications
Item |
Weight |
0.35 kg (0.77 lb) |
· MIC-XP5L1: 13 W · MIC-XP5L2: 6.4 W |
· MIC-XP5L1: 11 W · MIC-XP5L2: 2.3 W |
PIC subcards
IMPORTANT: · To use a PIC interface card, you must install it on a CMPE or CSPEX base card. You cannot install it directly on the router. · For the compatibility between PIC interface cards and CMPE or CSPEX base cards, see compatibility information for the base cards. |
PIC-GP10L
View
Figure2-45 PIC-GP10L view
(1) 1000BASE-X-SFP Ethernet fiber port (10 in total) |
(2) SFP port LED. For the LED description, see Table2-196. |
LEDs
Table2-196 GE SFP port LED description
LED |
Status |
Flashing green |
Steady green |
Off |
Ports
Table2-197 Port specifications
Card model |
Connector type |
Port quantity |
PIC-GP10L |
10-port GE optical interface module |
LC |
10 |
100 Mbps |
1000 Mbps |
10/100/1000 Mbps |
Table2-198 PIC-GP10L
Item |
Weight |
0.45 kg (0.99 lb) |
21 W |
9.5 W |
PIC-PS2G4L
View
(1) OC48c/STM16c-SFP POS fiber ports (2 in total) |
(2) 1000BASE-X-SFP GE fiber ports (4 in total) |
(3) POS port LED. For the LED description, see Table2-199. |
(4) GE port LED. For the LED description, see Table2-200. |
LEDs
Table2-199 WAN port LED description
LED |
Status |
Steady green |
The port is up and a link is present on the port. |
Steady red |
Off |
The port is down. |
Table2-200 GE SFP port LED description
LED |
Status |
Flashing green |
Steady green |
Off |
Ports
Table2-201 Port specifications
Card model |
Connector type |
Port quantity |
PIC-PS2G4L |
2-port OC-48c/STM-16c POS optical interface (SFP, LC) + 4-port 1000BASE-X optical interface card (SFP, LC) |
LC |
2 |
2.5 Gbps (OC-48/STM-16) |
4 |
1000 Mbps |
10/100/1000 Mbps |
Table2-202 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
16 W |
9.3 W |
PIC-PSP4L
View
Figure2-47 PIC-PSP4L view
(1) OC48c/STM16c-SFP POS fiber ports (4 in total) |
(2) Port LED. For the LED description, see Table2-203. |
LEDs
Table2-203 WAN port LED description
LED |
Status |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-204 Port specifications
Card model |
Connector type |
Port quantity |
PIC-PSP4L |
LC |
4 |
Table2-205 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
18 W |
9.7 W |
PIC-PUP1L
View
Figure2-48 PIC-PUP1L view
(1) OC192c/STM64c-XFP POS fiber ports (1 in total) |
(2) Port LED. For the LED description, see Table2-206. |
LEDs
Table2-206 WAN port LED description
LED |
Status |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-207 Port specifications
Card model |
Connector type |
Port quantity |
PIC-PUP1L |
1-port OC-192c/STM-64c POS optical interface card (XFP, LC) |
LC |
1 |
10 Gbps (OC-192/STM-64) |
Table2-208 Technical specifications
Item |
Weight |
0.50 kg (1.10 lb) |
19 W |
14.3 W |
PIC-TCP8L
View
Figure2-49 PIC-TCP8L view
(1) OC3c/OC12c/1000BASE-X-SFP POS/GE fiber ports (8 in total) |
(2) Port LED. For the LED description, see Table2-209. |
LEDs
Table2-209 WAN port LED description
LED |
Status |
Steady green |
Steady red |
Off |
The port is down. |
Ports
Table2-210 Port specifications
Card model |
Connector type |
Port quantity |
PIC-TCP8L |
LC |
8 |
1000 Mbps |
10/100/1000 Mbps |
Table2-211 Technical specifications
Item |
Weight |
0.40 kg (0.88 lb) |
17 W |
9.7 W |
PIC-XP1L
View
Figure2-50 PIC-XP1L view
(1) 10GBASE-R/W-XFP fiber ports (1 in total) |
(2) XFP port LED. For the LED description, see Table2-212. |
LEDs
Table2-212 10GE XFP port LED description
LED |
Status |
10 GE XFP port LED (LINK/ACT) |
Flashing green |
The XFP port is sending or receiving data. |
Steady green |
A link is present on the XFP port. |
Off |
Ports
Table2-213 Port specifications
Card model |
Connector type |
Port quantity |
PIC-XP1L |
1-port 10GBASE-R/W Ethernet optical interface card (XFP, LC) |
LC |
1 |
10 Gbps |
Table2-214 Technical specifications
Item |
Weight |
0.45 kg (0.99 lb) |
23.7 W |
12.5 W |
OAA modules
IMPORTANT: A combo interface is a logical interface that consists of an SFP port and an RJ-45 Ethernet port. Only one of the two ports can be operational at a time. |
LSU1ADECEA0
View
Figure2-51 LSU1ADECEA0 view
(1) Console port (CONSOLE) |
(2) USB port (reserved for future use) |
(3) Combo copper port (10/100/1000BASE-T) |
(4) Combo copper port LED (LINK/ACT) |
(5) Combo fiber port (1000BASE-X) |
(6) Combo fiber port LED (LINK/ACT) |
(7) Alarm LED (ALM) |
(8) Running status LED (RUN) |
(9) Ejector lever |
(10) Captive screw |
LEDs
Table2-215 LED description
LED |
Mark |
Status |
Alarm LED |
ALM |
Off |
The module is operating correctly, and no alarm is present. |
Steady red |
A critical fault is present on the module. You must view the logs and locate and resolve the issue immediately. |
RUN |
Off |
No power is present or the module is faulty. |
Steady green |
The module is running incorrectly. |
Slow flashing green (1 Hz) |
The module has started and entered a normal operating state. |
Fast flashing green (8 Hz) |
The module is loading software or has not started. |
Combo interface LED |
LINK/ACT |
Off |
No link is present. |
Steady green |
A link is present. |
Flashing green |
The interface is sending or receiving data. |
Ports
Table2-216 Port specifications
Card model |
Connector type |
Port quantity |
LSU1ADECEA0 |
Application delivery service module |
RJ-45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
Table2-217 Technical specifications
Item |
Weight |
3.90 kg (8.60 lb) |
150 W |
109 W |
LSU1FWCEA0
View
Figure2-52 LSU1FWCEA0 view
(5) Combo fiber port LED (LINK/ACT) |
(9) Ejector lever |
LEDs
Table2-218 LED description
LED |
Mark |
Status |
Alarm LED |
ALM |
Off |
Steady red |
Running status LED |
RUN |
Off |
Steady green |
LINK/ACT |
Off |
Steady green |
Flashing green |
Ports
Table2-219 Port specifications
Card model |
Connector type |
Port quantity |
LSU1FWCEA0 |
Firewall service module |
RJ-45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
Table2-220 LSU1FWCEA0
Item |
Weight |
3.90 kg (8.60 lb) |
150 W |
109 W |
LSU1IPSBEA0
View
Figure2-53 LSU1IPSBEA0 view
(2) USB port (Control power supply for the external PFC power fail safeguard module) |
(9) Ejector lever |
LEDs
Table2-221 LED description
LED |
Mark |
Status |
Alarm LED |
ALM |
Off |
Steady red |
RUN |
Off |
Steady green |
LINK/ACT |
Off |
Steady green |
Flashing green |
Ports
Table2-222 Port specifications
Card model |
Connector type |
Port quantity |
LSU1IPSBEA0 |
Intrusion prevention system module |
RJ-45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
Table2-223 Technical specifications
Item |
Weight |
3.90 kg (8.60 lb) |
150 W |
109 W |
LSU3FWCEA0
View
Figure2-54 LSU3FWCEA0 view
(9) Ejector lever |
LEDs
Table2-224 LED description
LED |
Mark |
Status |
Alarm LED |
ALM |
Off |
Steady red |
RUN |
Off |
Steady green |
LINK/ACT |
Off |
Steady green |
Flashing green |
Ports
Table2-225 Port specifications
Card model |
Connector type |
Port quantity |
LSU3FWCEA0 |
RJ-45 |
2 |
10/100/1000 Mbps |
LC |
2 |
1000 Mbps |
Table2-226 Technical specifications
Item |
Weight |
3.90 kg (8.60 lb) |
150 W |
109 W |
Power supplies
PSR320-A
View
Figure2-55 PSR320-A view
(1) Captive screw |
(2) Power input receptacle |
(3) Power supply status LED |
(4) Air inlet vent |
(5) Power switch |
(6) Power supply handle |
LEDs
LED |
Status |
Possible causes |
Green |
The power supply is operating correctly. |
N/A |
Red |
The power supply is operating incorrectly. |
· An alarm is present on the power supply and the power supply has entered self-protection state because one of the following reasons: ¡ Input undervoltage. ¡ Output short circuit. ¡ Output overcurrent. ¡ Output overvoltage. ¡ Overtemperature. · The fan of the power supply is faulty. |
Off |
Abnormal power input |
· Power supply failure. · Power cord connection failure. · External power supply system outage. · Power supply switch not turned on. |
Table2-228 Technical specifications
Item |
40 × 140 × 350 mm (1.57 × 5.51 × 13.78 in) |
Weight |
1.90 kg (4.19 lb) |
Inputs |
1 |
Rated input voltage range |
100 to 240 VAC @ 50/60 Hz |
Input voltage range |
90 to 264 VAC |
Maximum input current |
10 A |
Rated output voltage |
12 VDC |
Rated output current |
25 A |
Rated output power |
300 W |
Front-end circuit breaker/fuse |
≥ 6.3 A |
Heat dissipation |
Built-in fans |
Power cord |
Standard C13 cable (3*1.0 mm²/0.00155 in²) |
PSR650-A
View
Figure2-56 PSR650-A view
(1) Captive screw |
(5) Power switch |
LEDs
Table2-229 LED description
LED |
Status |
Possible causes |
Green |
N/A |
Red |
Off |
Figure2-57 Technical specifications
Item |
Weight |
2.50 kg (5.51 lb) |
Inputs |
1 |
90 to 264 VAC |
10 A |
12 VDC |
54 A |
650 W |
≥ 15 A |
Heat dissipation |
Built-in fans |
Power cord |
PSR650-D
View
Figure2-58 PSR650-D view
(1) Captive screw |
(2) DC input receptacle (+, -, ground) |
(5) Power switch |
LEDs
Table2-230 LED description
LED |
Status |
Possible causes |
Green |
N/A |
Red |
Off |
Table2-231 Technical specifications
Item |
Weight |
2.30 kg (5.07 lb) |
Inputs |
1 |
–48 to – 60 VDC |
–36 to –72 V |
25 A |
12 VDC |
· 12 V: 54 A · 3.3 V: 4 A |
650 W |
≥ 30 A |
Heat dissipation |
Built-in fans |
Power cord |
Standard OT-M4 cable (5.3 mm²/0.00822 in²) |
PSR1200-A
View
Figure2-59 PSR1200-A view
(1) Captive screw |
(4) Power supply handle |
(5) Power switch |
(6) Air inlet vent |
LEDs
Table2-232 LED description
LED |
Status |
Possible causes |
Green |
N/A |
Red |
Off |
Table2-233 Technical specifications
Item |
Weight |
2.60 kg (10.36 lb) |
Inputs |
1 |
90 to 264 VAC |
16 A |
Rated output voltage range |
· 12 VDC · 3.3 VDC |
· 100 A · 4 A |
1213 W |
≥ 20 A |
Heat dissipation |
Built-in fans |
Power cord |
Standard C19 cable (3*1.5 mm²/0.00232 in²) |
PSR1200-D
View
Figure2-60 PSR1200-D view
(1) Captive screw |
(2) DC input receptacle |
(5) Power switch |
LEDs
Table2-234 LED description
LED |
Status |
Possible causes |
Green |
N/A |
Red |
Off |
Table2-235 Technical specifications
Item |
Weight |
2.50 kg (10.36 lb) |
Inputs |
1 |
–48 to – 60 VDC |
–36 to–72 V |
42 A |
· 100 A · 4 A |
1213 W |
≥ 50 A |
Heat dissipation |
Built-in fans |
Power cord |
Standard EN (6 to 18 mm/0.24 to 0.71 in) cable (13 mm²/0.0201 in²) |
PSR1400-A
View
Figure2-61 PSR1400-A view
(1) Captive screw |
(2) Power switch |
(3) Power supply status LEDs |
(5) Power supply handle |
(6) Power input receptacle |
LEDs
LED |
Status |
Possible causes |
INPUT |
Green |
Normal power input |
N/A |
Red |
The input voltage is not in the rated voltage range. |
Off |
No power input |
· Power supply failure. · Power cord connection failure. · External power supply system outage. |
OUTPUT |
Green |
Normal power output |
N/A |
Red |
Abnormal power output |
· An alarm is present on the power supply and the power supply has entered self-protection state because one of the following reasons: ¡ Input undervoltage. ¡ Output short circuit. ¡ Output overcurrent. ¡ Output overvoltage. ¡ Overtemperature. · Power supply switch not turned on. |
Off |
No power output |
FAN |
Green |
The fan of the power supply is operating correctly. |
N/A |
Red |
The fan of the power supply is operating incorrectly. |
· The fan of the power supply is faulty. · Power supply switch not turned on. |
Off |
The fan of the power supply is not operating. |
Table2-237 Technical specifications
Item |
128 × 196 × 382 mm (5.04 × 7.72 × 15.04 in) |
Weight |
8.30 kg (18.30 lb) |
Inputs |
1 |
90 to 264 VAC |
16 A |
12 VDC |
117 A |
· 1150 W (110 VAC) · 1400 W (220 VAC) |
≥ 20 A |
Heat dissipation |
Built-in fans |
Power cord |
PSR1400-D
View
Figure2-62 PSR1400-D view
(1) Captive screw |
(2) External PoE power supply system monitoring port |
(4) DC input positive terminal (+) |
(5) DC input negative terminal (–) |
(7) Power supply handle |
LEDs
Table2-238 LED description
LED |
Status |
Possible causes |
INPUT |
Green |
Normal power input, and the system power output switch has been turned on. |
N/A |
Red |
Off |
No power input |
· Power supply failure. · Power cord connection failure. · External power supply system outage. · System power output switch not turned on. |
OUTPUT |
Green |
N/A |
Red |
An alarm is present on the power supply and the power supply has entered self-protection state because one of the following reasons: · Output short circuit. · Output overcurrent. · Output overvoltage. · Overtemperature. |
Off |
No power output |
FAN |
Green |
N/A |
Red |
Fan failure |
Off |
Table2-239 Technical specifications
Item |
Weight |
9.30 kg (20.50 lb) |
Inputs |
1 |
–48 to – 60 VDC |
–40 to–72 V |
190 A (including 140 A PoE output) |
12 VDC |
117 A |
1400 W |
· 60 A (Non-through module) · 150 A (Through module) |
Heat dissipation |
Built-in fans |
Power cord |
Standard JG2-M6 cable (13 mm²/0.0201 in²) |
PSR2500-12AHD
View
Figure2-63 PSR2500-12AHD view
(1) Captive screw |
(2) Power switch |
LEDs
Table2-240 LED description
LED |
Status |
Possible causes |
INPUT |
Green |
N/A |
Red |
Off |
No power input |
OUTPUT |
Green |
N/A |
Red |
Off |
No power output |
FAN |
Green |
N/A |
Red |
Off |
Table2-241 Technical specifications
Item |
Dimensions (H × W × D) |
Weight |
5.70 kg (12.57 lb) |
Inputs |
1 |
· 100 to 240 VAC @ 50/60 Hz · 240 to 380 VDC |
· 90 to 290 VAC · 180 to 400 VDC |
16 A |
12 VDC |
· 100 A (100 to 180 VAC) · 208 A (180 to 240 VAC or 240 to 380 VDC) |
· 1200 W (100 to 180 VAC) · 2500 W (180 to 240 VAC or 240 to 380 VDC) |
≥ 20 A |
Heat dissipation |
Built-in fans |
Power cord |
Standard HVDCB cable (3*1.5 mm²/0.00232 in²) |
PSR2500-12D
View
Figure2-64 PSR2500-12D view
(1) Captive screw |
(2) Power switch |
LEDs
Table2-242 LED description
LED |
Status |
Possible causes |
INPUT |
Green |
N/A |
Red |
Off |
No power input |
OUTPUT |
Green |
N/A |
Red |
Off |
No power output |
FAN |
Green |
N/A |
Red |
Off |
Table2-243 Technical specifications
Item |
Weight |
Inputs |
1 |
–48 to – 60 VDC |
–36 to–72 V |
85 A |
12 VDC |
208 A |
2500 W |
≥ 100 A |
Heat dissipation |
Built-in fans |
Power cord |
LSQM1PWRSPA power supply adapter
View
Figure2-65 LSQM1PWRSPA power supply adapter view
(1) Captive screw |
(2) Power supply slot |
Table2-244 Technical specifications
Item |
Weight |
4.42 kg (9.74 lb) |
LSQM1PWRSPB power supply adapter
View
Figure2-66 LSQM1PWRSPB power supply adapter view
(1) Captive screw |
(2) Power supply slot A |
(3) Power supply slot B |
Table2-245 Technical specifications
Item |
Weight |
4.95 kg (10.91 lb) |
· For multi-level power distribution protection, make sure the rated current of the circuit breaker for the power input line of a power supply is not less than 1.2 times the maximum input current of the power supply.
· You must install a minimum of one power supply on the router. To improve power supply availability, you can install two power supplies on the router for redundancy.
· The power supplies installed on the router must be the same type (AC or DC) and model.
· Make sure the total maximum output power of the installed power supplies is greater than the system power consumption. As a best practice, reserve 20% of the maximum output power.
· Typically, an SR8803-F router uses power supplies of 1 RU high, and the other SR8800-F routers use power supplies of 3 RU high.
· To enable flexible use of power supplies for different overall power consumptions, H3C provides power supply adapters. The power supply adapter allow for insertion of a 1 RU high power supply into a 3 RU high power supply slot.
¡ To install a PSR650-A/PSR650-D power supply in a 3 RU power supply slot, use the LSQM1PWRSPA power supply adapter.
¡ To install a PSR1200-A/PSR1200-D power supply in a 3 RU power supply slot, use the LSQM1PWRSPB power supply adapter.
Compatibility matrix between power supplies and routers
The available power supply models vary by router model. Select power supplies for the router based on the power supply conditions and power consumption requirements of the router.
Table2-246 Compatibility matrix between power supplies and routers
Power supply model |
SR8803-F |
SR8805-F |
SR8808-F |
SR8812-F |
PSR320-A |
PSR650-A |
PSR650-D |
PSR1200-A |
PSR1200-D |
PSR1400-A |
PSR1400-D |
PSR2500-12AHD |
PSR2500-12D |
Fan trays
The router uses fan trays that can automatically adjust the speed to meet the cooling requirements.
The router comes with fan trays installed on it. To replace a fan tray, make sure the new fan tray is compatible with the router.
SR8803-F fan tray
View
Figure2-67 SR8803-F fan tray view
(1) Fan tray handle |
(2) Captive screw |
(3) Fan |
Table2-247 Technical specifications
Item |
27 × 115 × 338 mm (1.06 × 4.53 × 13.31 in) |
Weight |
0.90 kg (1.98 lb) |
Maximum power consumption |
15 W |
Typical power consumption |
13 W |
Minimum power consumption |
7.5 W |
Number of fans |
3 |
Fan diameter |
92 mm (3.62 in) |
Max fan speed |
3800 RPM |
Maximum air flow rate |
165 CFM |
SR8805-F fan tray
View
Figure2-68 SR8805-F fan tray view
(1) Captive screw |
(2) Fan tray handle |
(3) Fan |
Table2-248 Technical specifications
Item |
27 × 203 × 365 mm (1.06 × 7.99 × 14.37 in) |
Weight |
1.60 kg (3.53 lb) |
28 W |
25 W |
15.5 W |
Number of fans |
6 |
Fan diameter |
92 mm (3.62 in) |
Max fan speed |
3800 RPM |
330 CFM |
SR8808-F fan tray
View
Figure2-69 SR8808-F fan tray view
(1) Captive screw |
(3) Fan |
Table2-249 Technical specifications
Item |
28 × 331 × 365 mm (1.10 × 13.03 × 14.37 in) |
Weight |
2.20 kg (10.36 lb) |
43 W |
37 W |
24.5 W |
Number of fans |
9 |
Fan diameter |
92 mm (3.62 in) |
Max fan speed |
3800 RPM |
495 CFM |
SR8812-F fan tray
View
Figure2-70 SR8812-F fan tray view
(1) Captive screw |
(3) Fan |
Table2-250 Technical specifications
Item |
28 × 497 × 380 mm (1.10 × 19.57 × 14.96 in) |
Weight |
3.00 kg (6.61 lb) |
50 W |
44 W |
28 W |
Number of fans |
· Upper half: 6 · Lower half: 4 |
Fan diameter |
· Upper half: 92 mm (3.62 in) · Lower half: 120 mm (4.72 in) |
Max fan speed |
· Upper half: 3800 RPM · Lower half: 3100 RPM |
662 CFM |
Air filters
CAUTION: Clean air filters periodically (once or more times every three months) to guarantee adequate ventilation and to avoid overtemperature. |
To prevent dusts from entering the chassis, you can configure air filters for the router as needed and install them at the air intakes.
The available air filters vary by router model. Select air filters compatible with your router.
Slide rails
Before rack-mounting the router, install slide rails on the rack.
LSXM1BSR
Figure2-71 LSXM1BSR view
(1) Positioning tongue |
(2) Slide rail installation hole |
(3) Front plate installation hole |
(4) Sign |
(5) Guide rail |
Figure2-72 Front plate
(1) Installation hole |
Table2-251 Technical specifications
Item |
Maximum loading capacity |
650 kg (1432.98 lb) |
Adjustment range |
630 to 900 mm (24.80 to 35.43 in) |
Occupied rack space |
1 RU |
LSTM1KSGD0
Figure2-73 LSTM1KSGD0 view
(2) Sign |
(3) Guide rail |
Table2-252 Technical specifications
Item |
280 kg (617.28 lb) |
Adjustment range |
300 to 500 mm (11.81 to 19.69 in) |
2 RU |
LSTM2KSGD0
Figure2-74 LSTM2KSGD0 view
(2) Sign |
(3) Guide rail |
Table2-253 Technical specifications
Item |
400 kg (881.83 lb) |
Adjustment range |
500 to 800 mm (19.69 to 31.50 in) |
2 RU |
Select slide rails for the router based on the chassis weight.
Chassis weights and applicable slide rails
Table2-254 Chassis weights and applicable slide rails
Model |
Chassis weight (fully configured) |
Applicable slide rails |
SR8803-F |
29 kg (63.93 lb) |
LSXM1BSR LSTM1KSGD0 LSTM2KSGD0 |
SR8805-F |
56 kg (123.46 lb) |
SR8808-F |
74 kg (163.14 lb) |
SR8812-F |
95 kg (209.44 lb) |
CF cards
On an MPU with a CF card slot, you can install a CF card to expand the storage space for the device. A CF card can store startup files, configuration files, and logs.
Table2-255 CF card specifications
CF card model |
Storage capacity |
CF-4G |
Storage medium-compact flash card-4G |
4 GB |
DC power cords
A DC power cord is used to connect a DC power supply of a router to the external DC power supply system.
Table2-256 DC power cords available for DC power supplies
DC power supply |
DC power cord code |
PSR650-D |
0404A06T |
3 m (9.84 ft) |
0404A01N |
5 m (16.40 ft) |
0404A01P |
10 m (32.82 ft) |
0404A073 |
20 m (65.62 ft) |
PSR1200-D |
0404A0DU |
3 m (9.84 ft) |
PSR1400-D/PSR2500-12D |
0404A07G |
3 m (9.84 ft) |
0404A08T |
10 m (32.82 ft) |
0404A08U |
20 m (65.62 ft) |
0404A072 |
25 m (82.02 ft) |
PSR2500-12AHD |
0404A0RL |
High voltage, 3 m (9.84 ft) |
AC power cords
An AC power cord is used to connect an AC power supply of a router to the external AC power supply system.
To select an AC power cord for an AC power supply, consider the following items:
· Power capacity of the power supply.
· Current-carrying capacity of the power cord.
· Region-and country-specific plug type.
The PSR320-A and PSR650-A power supplies require a 10A AC power cord. Table2-257 describes the region-and country-specific plug types for 10A AC power cords.
The PSR1200-A, PSR1400-A, and PSR2500-12AHD power supplies require a 16A AC power cord. Table2-258 describes the region-and country-specific plug types for 16A AC power cords. You need to use the 0404A0RP or 0404A0RQ AC power cord for the PSR2500-12AHD power supply. The 0404A0RP and 0404A0RQ AC power cords are available only for the PSR2500-12AHD power supply.
Table2-257 10A AC power cords used in different countries or regions
1 |
Plug type |
Code (Length) |
Countries or regions where the type of power cords conforms to local safety regulations and can be used legally |
Other countries or regions using this type of power cords |
Countries or regions seldom using this type of power cords |
I type |
04041104: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Power cord outline |
Connector outline |
2 |
Plug type |
Code (Length) |
B type |
04020728: 3 m (9.8 ft) |
Canada and U.S.A |
Mexico, Argentina, Brazil, Columbia, Venezuela, Thailand, Peru, Philippine, and A6 countries or regions |
N/A |
Plug outline |
Connector outline |
3 |
Plug type |
Code (Length) |
F type |
04041056: 3 m (9.8 ft) |
Holland, Denmark, Sweden, Finland, Norway, Germany, France, Austria, Belgium, and Italy |
Indonesia, Turkey, Russia, and CIS |
N/A |
Plug outline |
Connector outline |
4 |
Plug type |
Code (Length) |
G type |
04040890: 3 m (9.8 ft) |
U.K. |
Malaysia, Hong Kong, and Egypt |
N/A |
Plug outline |
Connector outline |
5 |
Plug type |
Code (Length) |
B type |
04040887: 3 m (9.8 ft) |
Japan |
N/A |
N/A |
Plug outline |
Connector outline |
6 |
Plug type |
Code (Length) |
I type |
04040888: 3 m (9.8 ft) |
Australia |
N/A |
N/A |
Plug outline |
Connector outline |
7 |
Plug type |
Code (Length) |
J type |
04041119: 3 m (9.8 ft) |
Switzerland |
N/A |
N/A |
Plug outline |
Connector outline |
8 |
Plug type |
Code (Length) |
L type |
04041120: 3 m (9.8 ft) |
Italy |
N/A |
N/A |
Plug outline |
Connector outline |
9 |
Plug type |
Code (Length) |
D type |
0404A0Q0: 3 m (9.8 ft) |
India |
N/A |
N/A |
Plug outline |
Connector outline |
Table2-258 16A AC power cords used in different countries or regions
1 |
Plug type |
Code (Length) |
I type |
04043396: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Connector outline |
2 |
Plug type |
Code (Length) |
B type |
0404A063: 3 m (9.8 ft) |
Canada and U.S.A |
N/A |
Plug outline |
Connector outline |
3 |
Plug type |
Code (Length) |
C20 type |
0404A0C2: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Connector outline |
4 |
Plug type |
Code (Length) |
F type |
0404A061: 3 m (9.8 ft) |
N/A |
Plug outline |
Connector outline |
5 |
Plug type |
Code (Length) |
B type |
0404A062: 3 m (9.8 ft) |
Japan |
N/A |
N/A |
Plug outline |
Connector outline |
6 |
Plug type |
Code (Length) |
I type |
0404A01A: 3 m (9.8 ft) |
Australia |
N/A |
N/A |
Plug outline |
Connector outline |
7 |
Plug type |
Code (Length) |
N/A |
0404A0RP: 3 m (9.8 ft) |
China mainland |
N/A |
N/A |
Plug outline |
Connector outline |
8 |
Plug type |
Code (Length) |
L type |
0404A0RQ: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Plug outline |
Connector outline |
