11-Security Configuration Guide
HomeSupportSwitchesS12500G-AF SeriesConfigure & DeployConfiguration GuidesH3C S12500G-AF Switch Series Configuration Guides-Release7639Pxx-6W10011-Security Configuration Guide
19-MFF configuration
19-MFF configuration 160.07 KB
Configuring MFF
About MFF
MAC-forced forwarding (MFF) implements Layer 2 isolation and Layer 3 communication between hosts in the same broadcast domain.
An MFF-enabled device intercepts ARP requests and returns the MAC address of a gateway (or server) to the senders. In this way, the senders are forced to send packets to the gateway for traffic monitoring and attack prevention.
MFF network model
As shown in Figure 1, hosts are connected to Switch C through Switch A and Switch B, which are called Ethernet access nodes (EANs). The MFF-enabled EANs forward packets from hosts to the gateway for further forwarding. The hosts are isolated at Layer 2, but they can communicate at Layer 3.
Figure 1 Network diagram for MFF
MFF works with any of the following features to implement traffic filtering and Layer 2 isolation on the EANs:
·     ARP snooping (see Layer 3—IP Services Configuration Guide).
·     IP source guard (see "Configuring IP source guard").
·     ARP detection (see "Configuring ARP attack protection").
·     VLAN mapping (see Layer 2—LAN Switching Configuration Guide).
Port roles
Two types of ports, user port and network port, exist in an MFF-enabled VLAN.
User port
An MFF user port is directly connected to a host and processes the following packets differently:
·     Allows multicast packets to pass.
·     Delivers ARP packets to the CPU.
·     Processes unicast packets as follows:
¡     If gateways' MAC addresses have been learned, the user port allows only the unicast packets with the gateways' MAC addresses as the destination MAC addresses to pass.
¡     If no gateways' MAC addresses have been learned, the user port discards all received unicast packets.
Network port
An MFF network port is connected to any of the following networking devices:
·     An access switch.
·     A distribution switch.
·     A gateway.
·     A server.
A network port processes the following packets differently:
·     Denies broadcast packets other than DHCP and ARP packets.
Processing of ARP packets in MFF
An MFF-enabled device implements Layer 3 communication between hosts by intercepting ARP requests from the hosts and replies with the MAC address of a gateway. This mechanism helps reduce the number of broadcast messages.
The MFF device processes ARP packets as follows:
·     After receiving an ARP request from a host, the MFF device sends the MAC address of the corresponding gateway to the host. In this way, hosts in the network have to communicate at Layer 3 through a gateway.
·     After receiving an ARP request from a gateway, the MFF device sends the requested host's MAC address to the gateway if the corresponding entry is available. If the entry is not available, the MFF device forwards the ARP request.
·     The MFF device forwards ARP replies between hosts and gateways.
·     If the source MAC addresses of ARP requests from gateways are different from those recorded, the MFF device updates and broadcasts the IP and MAC addresses of the gateways.
MFF default gateway
MFF applies to only networks where the hosts' IP addresses are manually configured. Because the hosts cannot obtain the gateway information through DHCP, the default gateway must be specified by the mac-forced-forwarding default-gateway command. MFF maintains only one default gateway for each VLAN. MFF updates the MAC address of the default gateway upon receiving an ARP packet with a different sender MAC address from the default gateway.
Protocols and standards
RFC 4562, MAC-Forced Forwarding
MFF tasks at a glance
To configure MFF, perform the following tasks:
1.     Enabling MFF
2.     Configuring a network port
3.     (Optional.) Enabling periodic gateway probe
4.     Specifying the IP addresses of servers
If servers exist in the network, you must perform this task to ensure communication between the servers and hosts.
Enabling MFF
·     An MFF-enabled device and a host cannot ping each other.
·     When MFF works with static IP source guard bindings, you must configure VLAN IDs in the static bindings. Otherwise, IP packets allowed by IP source guard are permitted even if their destination MAC addresses are not the MAC address of the gateway.
·     MFF is not supported in a network where VRRP load balancing mode is configured.
For MFF to take effect, make sure ARP snooping is enabled on the VLAN where MFF is enabled.
2.     Enter VLAN view.
vlan vlan-id
3.     Enable MFF.
mac-forced-forwarding default-gateway gateway-ip
By default, MFF is disabled.
In a VLAN with MFF enabled, you need to configure the following ports as network ports:
·     Upstream ports connected to the gateway.
·     Ports connected to other MFF devices.
Link aggregation is supported by network ports in an MFF-enabled VLAN, but it is not supported by user ports in the VLAN. You can add the network ports to link aggregation groups, but cannot add the user ports to link aggregation groups. For more information about link aggregation, see Layer 2—LAN Switching Configuration Guide.
2.     Enter interface view.
3.     Configure the port as a network port.
mac-forced-forwarding network-port
By default, the port is a user port.
You can configure the MFF device to detect gateways every 30 seconds for the change of MAC addresses by sending forged ARP packets. The ARP packets use 0.0.0.0 as the sender IP address and bridge MAC address as the sender MAC address.
2.     Enter VLAN view.
vlan vlan-id
3.     Enable periodic gateway probe.
mac-forced-forwarding gateway probe
Server IP addresses can be those of the interfaces on a router in a VRRP group and those of the servers collaborating with MFF, such as a RADIUS server.
When the MFF device receives an ARP request from a server, the device searches IP-to-MAC address entries it has stored. Then the device replies with the requested MAC address to the server.
As a result, packets from a host to a server are forwarded by the gateway. However, packets from a server to a host are not forwarded by the gateway.
MFF does not check whether the IP address of a server is on the same network segment as that of a gateway. Instead, it checks whether the IP address of a server is all-zero or all-one. An all-zero or all-one server IP address is invalid.
If the server's interface connecting to the MFF device uses secondary IP addresses to send ARP packets, include all these IP addresses in the server IP address list.
2.     Enter VLAN view.
vlan vlan-id
3.     Specify the IP addresses of servers.
mac-forced-forwarding server server-ip&<1-10>
By default, no server IP address is specified.
Display and maintenance commands for MFF
Display MFF port configuration.
display mac-forced-forwarding interface
Display the MFF configuration for a VLAN.
display mac-forced-forwarding vlan vlan-id
MFF configuration examples
Example: Configuring MFF in a tree network
As shown in Figure 2, all the devices are in VLAN 100. Hosts A, B, and C are assigned IP addresses manually.
Configure MFF to isolate the hosts at Layer 2 and allow them to communicate with each other through the gateway at Layer 3.
Figure 2 Network diagram
1.     Configure the IP addresses of the hosts and the gateway, as shown in Figure 2.
2.     Configure Switch A:
# Configure MFF on VLAN 100.
[SwitchA] vlan 100
[SwitchA-vlan100] mac-forced-forwarding default-gateway 10.1.1.100
# Specify the IP address of the server.
[SwitchA-vlan100] mac-forced-forwarding server 10.1.1.200
# Enable ARP snooping on VLAN 100.
[SwitchA-vlan100] arp snooping enable
[SwitchA-vlan100] quit
# Configure HundredGigE 3/0/1 as a network port.
[SwitchA] interface hundredgige 3/0/1
[SwitchA-HundredGigE3/0/1] mac-forced-forwarding network-port
3.     Configure Switch B:
[SwitchB] vlan 100
[SwitchB-vlan100] mac-forced-forwarding default-gateway 10.1.1.100
[SwitchB-vlan100] mac-forced-forwarding server 10.1.1.200
[SwitchB-vlan100] arp snooping enable
[SwitchB-vlan100] quit
# Configure HundredGigE 3/0/2 as a network port.
[SwitchB] interface hundredgige 3/0/2 1/0/6
[SwitchB-HundredGigE3/0/2] mac-forced-forwarding network-port
Example: Configuring MFF in a ring network
As shown in Figure 3, all the devices are in VLAN 100, and the switches form a ring. Hosts A, B, and C are assigned IP addresses manually.
Figure 3 Network diagram
1.     Configure the IP addresses of the hosts and the gateway, as in shown in Figure 3.
# Enable STP globally to make sure STP is enabled on interfaces.
[SwitchA] stp global enable
[SwitchA] vlan 100
# Configure HundredGigE 3/0/2 and HundredGigE 3/0/3 as network ports.
[SwitchA] interface hundredgige 3/0/2
[SwitchA-HundredGigE3/0/2] mac-forced-forwarding network-port
[SwitchA-HundredGigE3/0/2] quit
[SwitchA] interface hundredgige 3/0/3
[SwitchA-HundredGigE3/0/3] mac-forced-forwarding network-port
[SwitchB] stp global enable
[SwitchB] vlan 100
# Configure HundredGigE 3/0/1 and HundredGigE 3/0/3 as network ports.
[SwitchB] interface hundredgige 3/0/1
[SwitchB-HundredGigE3/0/1] mac-forced-forwarding network-port
[SwitchB-HundredGigE3/0/1] quit
[SwitchB] interface hundredgige 3/0/3
[SwitchB-HundredGigE3/0/3] mac-forced-forwarding network-port
4.     Enable STP on Switch C globally to make sure STP is enabled on interfaces.
[SwitchC] stp global enable
