- 05-Layer 3—IP Services Configuration Guide
- 01-ARP configuration
- 02-DHCPv6 configuration
- 03-DHCP configuration
- 04-GRE configuration
- 05-HTTP redirect configuration
- 06-IPv6 basics configuration
- 07-IPv6 fast forwarding configuration
- 08-IP addressing configuration
- 09-IP performance optimization configuration
- 10-IP forwarding basics configuration
- 11-IRDP configuration
- 12-mDNS relay configuration
- 13-mDNS gateway configuration
- 14-UDP helper configuration
- 15-DNS configuration
- 16-Fast forwarding configuration
- 17-Adjacency table configuration
- 18-Tunneling configuration
00-Preface | 110.56 KB |
Preface
This configuration guide describes IP addressing (including static and dynamic IPv4 and IPv6 address assignment), network performance optimization, ARP, and interoperation between IPv4 and IPv6.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S12500G-AF switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
