- 13-Network Management and Monitoring Configuration Guides
- 02-NQA configuration
- 03-iNQA configuration
- 04-NTP configuration
- 05-PoE configuration
- 06-SNMP configuration
- 07-RMON configuration
- 08-NETCONF configuration
- 09-EAA configuration
- 10-Process monitoring and maintenance configuration
- 11-Sampler configuration
- 12-Mirroring configuration
- 13-NetStream configuration
- 14-IPv6 NetStream configuration
- 15-sFlow configuration
- 16-Information center configuration
- 17-GOLD configuration
- 18-Packet capture configuration
- 19-VCF fabric configuration
- 20-CWMP configuration
- 21-SmartMC configuration
- 22-SQA configuration
- 23-eMDI configuration
- 24-Performance management configuration
- 25-Ansible configuration
- 26-Event MIB configuration
- 27-EPS agent configuration
- 28-Cloud connection configuration
- 29-EPA configuration
- 30-KPI data collection configuration
00-Preface | 110.54 KB |
Preface
This configuration guide describes features that help you manage and monitor your network, for example, manage system events, collect traffic statistics, sample packets, assess network performance, and test network connectivity.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S10500 switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
