- 13-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-NTP commands
- 05-PTP commands
- 06-Network synchronization commands
- 07-SNMP commands
- 08-RMON commands
- 09-NETCONF commands
- 10-EAA commands
- 11-Process monitoring and maintenance commands
- 12-Sampler commands
- 13-Mirroring commands
- 14-NetStream commands
- 15-IPv6 NetStream commands
- 16-sFlow commands
- 17-Information center commands
- 18-GOLD commands
- 19-Packet capture commands
- 20-VCF fabric commands
- 21-CWMP commands
- 22-SmartMC commands
- 23-SQA commands
- 24-eMDI commands
- 25-Performance management commands
- 26-Event MIB commands
- 27-EPS agent commands
- 28-Cloud connection commands
- 29-EPA commands
- 30-Packet trace commands
- 31-KPI data collection commands
00-Preface | 110.54 KB |
Preface
This command reference covers the commands that help you manage and monitor your network, for example, manage system events, collect traffic statistics, sample packets, assess network performance, and test network connectivity.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S10500X switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
