05-Layer 3—IP Services Command Reference
HomeSupportSwitchesH3C S10500 Switch SeriesReference GuidesCommand ReferencesH3C S10500 Switch Series Command References-Release7639Pxx-6W10005-Layer 3—IP Services Command Reference
13-IPv6 basics commands
13-IPv6 basics commands 914.49 KB
IPv6 basics commands· 1
display ipv6 fib· 1
display ipv6 icmp statistics· 2
display ipv6 interface· 4
display ipv6 interface prefix· 9
display ipv6 nd proxy statistics· 10
display ipv6 nd route-direct advertise· 11
display ipv6 nd snooping count vlan· 12
display ipv6 nd snooping count vsi 13
display ipv6 nd snooping vlan· 14
display ipv6 nd snooping vsi 16
display ipv6 nd user-ip-conflict record· 17
display ipv6 nd user-move record· 18
display ipv6 neighbors· 20
display ipv6 neighbors count 23
display ipv6 neighbors entry-limit 24
display ipv6 neighbors statistics· 25
display ipv6 neighbors usage· 27
display ipv6 neighbors vpn-instance· 28
display ipv6 pathmtu· 29
display ipv6 prefix· 31
display ipv6 rawip· 32
display ipv6 rawip verbose· 33
display ipv6 statistics· 37
display ipv6 tcp· 41
display ipv6 tcp verbose· 42
display ipv6 udp· 52
display ipv6 udp verbose· 53
ipv6 address· 57
ipv6 address anycast 58
ipv6 address auto· 59
ipv6 address auto link-local 59
ipv6 address duplicate-detect enable· 61
ipv6 address duplicate-detect interval 61
ipv6 address eui-64· 62
ipv6 address link-local 63
ipv6 address· 64
ipv6 extension-header drop enable· 66
ipv6 fib consistency-check enable· 66
ipv6 hop-limit 67
ipv6 hoplimit-expires enable· 68
ipv6 icmpv6 error-interval 68
ipv6 icmpv6 multicast-echo-reply enable· 69
ipv6 icmpv6 receive enable· 70
ipv6 icmpv6 reply source· 71
ipv6 icmpv6 send enable· 72
ipv6 icmpv6 source· 73
ipv6 mtu· 74
ipv6 nd autoconfig managed-address-flag· 75
ipv6 nd autoconfig other-flag· 76
ipv6 nd consistency-check enable· 76
ipv6 nd dad attempts· 77
ipv6 nd entry-limit record enable· 78
ipv6 nd fib-miss drop· 78
ipv6 nd hardware log enable· 80
ipv6 nd local-proxy dad forward enable· 80
ipv6 nd mode uni 81
ipv6 nd ns retrans-timer 82
ipv6 nd nud reachable-time· 83
ipv6 nd online-offline-log enable· 84
ipv6 nd proxy-forwarding· 84
ipv6 nd ra boot-file-url 85
ipv6 nd ra dns search-list 86
ipv6 nd ra dns search-list suppress· 87
ipv6 nd ra dns server 88
ipv6 nd ra dns server suppress· 90
ipv6 nd ra halt 91
ipv6 nd ra hop-limit unspecified· 91
ipv6 nd ra interval 92
ipv6 nd ra no-advlinkmtu· 93
ipv6 nd ra prefix· 93
ipv6 nd ra prefix default 95
ipv6 nd ra router-lifetime· 95
ipv6 nd route-direct advertise· 96
ipv6 nd route-direct advertise delay· 97
ipv6 nd route-direct prefix convert-length· 98
ipv6 nd router-preference· 100
ipv6 nd snooping dad retrans-timer 100
ipv6 nd snooping enable global 101
ipv6 nd snooping enable link-local 102
ipv6 nd snooping glean source· 102
ipv6 nd snooping lifetime· 103
ipv6 nd snooping max-learning-num·· 104
ipv6 nd snooping uplink· 104
ipv6 nd unsolicited-na-learning enable· 105
ipv6 nd user-ip-conflict record enable· 106
ipv6 nd user-move record enable· 106
ipv6 neighbor 107
ipv6 neighbor aging probe-count 110
ipv6 neighbor aging probe-interval 110
ipv6 neighbor link-local minimize· 111
ipv6 neighbor stale-aging· 112
ipv6 neighbor timer stale-aging· 113
ipv6 neighbors max-learning-num·· 114
ipv6 neighbors max-learning-number 114
ipv6 pathmtu· 115
ipv6 pathmtu age· 116
ipv6 prefer temporary-address· 117
ipv6 prefix· 118
ipv6 reassemble local enable· 118
ipv6 redirects enable· 119
ipv6 temporary-address· 120
ipv6 unreachables enable· 121
local-proxy-nd enable· 122
ping nd ipv6· 122
ping nd mac· 123
proxy-nd enable· 125
reset ipv6 nd snooping vlan· 125
reset ipv6 nd snooping vsi 126
reset ipv6 neighbors· 126
reset ipv6 pathmtu· 127
reset ipv6 statistics· 128
snmp-agent trap enable ipv6 address· 129
statistics l3-packet enable· 130
display ipv6 fib
Use display ipv6 fib to display IPv6 FIB entries.
display ipv6 fib [ vpn-instance vpn-instance-name ] [ ipv6-address [ prefix-length ] ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 FIB entries for the public network.
ipv6-address: Displays IPv6 FIB entries for a destination IPv6 address. If you do not specify an IPv6 address, this command displays all IPv6 FIB entries.
prefix-length: Specifies a prefix length for the IPv6 address, in the range of 0 to 128. If you do not specify the prefix length, this command displays the IPv6 FIB entry longest matching the IPv6 address.
# Display all IPv6 FIB entries for the public network.
<Sysname> display ipv6 fib
Flag:
  R:Relay     F:FRR
Destination: ::1                                            Prefix length: 128
Nexthop     : ::1                                            Flags: UH
Time stamp : 0x1                                            Label: Null
Interface  : InLoop0                                        Token: Invalid
Destination count
Total number of destination addresses.
FIB entry count
Total number of IPv6 FIB entries.
Destination
Destination address.
Prefix length
Prefix length of the destination address.
Nexthop
Next hop address.
Flags
Route flag:
·     U—Usable route.
·     G—Gateway route.
·     H—Host route.
·     B—Black hole route.
·     D—Dynamic route.
·     S—Static route.
·     R—Recursive route.
·     F—Fast re-route.
Time stamp
Time when the IPv6 FIB entry was generated.
Label
Inner MPLS label. For IPv6 FIB entries for the public network, this field displays Null.
Outgoing interface.
Token
Label switched path index number.
Use display ipv6 icmp statistics to display ICMPv6 packet statistics.
In standalone mode:
In IRF mode:
display ipv6 icmp statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ICMPv6 packet statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays ICMPv6 packet statistics for all cards. (In IRF mode.)
# Display ICMPv6 packet statistics.
<Sysname> display ipv6 icmp statistics
  Input: bad code                0           too short                  0
         checksum error          0           bad length                 0
         path MTU changed        0          destination unreachable  0
         too big                  0           parameter problem         0
         echo request            0           echo reply                  0
         neighbor solicit        0           neighbor advertisement   0
         router solicit          0           router advertisement      0
         redirect                 0           router renumbering         0
 output: parameter problem     0           echo request                0
         echo reply               0           unreachable no route       0
         unreachable admin       0           unreachable beyond scope 0
         unreachable address    0           unreachable no port        0
         too big                   0           time exceed transit       0
         time exceed reassembly 0           redirect                    0
         ratelimited               0           other errors               0
bad code
Number of received packets with error codes.
too short
Number of received packets with the length too short.
checksum error
Number of received packets with checksum errors.
bad length
Number of received packets with incorrect packet size.
path MTU changed
Number of received packets with path MTU changed.
Number of destination unreachable packets that have been received.
too big
Number of received or sent oversized packets.
parameter problem
Number of received or sent packets with incorrect parameters.
echo request
Number of received or sent echo request packets.
echo reply
Number of received or sent echo reply packets.
neighbor solicit
Number of received NS packets.
Number of received NA packets.
router solicit
Number of received RS packets.
Number of received RA packets.
redirect
Number of received or sent redirect packets.
router renumbering
Number of received packets with router renumbering.
Number of sent packets to report the error that no route is available to the destination.
unreachable admin
Number of sent packets to report the error that the communication with the destination is administratively prohibited.
unreachable beyondscope
Number of sent packets to report the error that the source addresses is beyond the scope.
unreachable address
Number of address unreachable packets that have been sent.
unreachable no port
Number of port unreachable packets that have been sent.
time exceed transit
Number of sent packets to report the time exceeded in transmit error.
Number of sent packets to report the fragment reassembly time exceeded error.
ratelimited
Number of packets that were not sent out because of the rate limit.
other errors
Number of sent packets with other errors.
Use display ipv6 interface to display IPv6 interface information.
display ipv6 interface [ interface-type [ interface-number ] ] [ brief [ description ] ]
interface-type: Specifies an interface by its type.
interface-number: Specifies an interface by its number.
brief: Displays brief IPv6 interface information, including physical status, link-layer protocols, and IPv6 address. If you do not specify the keyword, this command displays detailed IPv6 interface information, including IPv6 configuration and operating information, and IPv6 packet statistics.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays a maximum of 11 characters for each interface description. If the description is longer than 11 characters, the first 8 characters are displayed with an ellipsis (...) followed.
If you do not specify an interface, this command displays IPv6 information about all interfaces.
If you specify only the interface-type argument, this command displays IPv6 information about the interfaces of the specified type.
If you specify both the interface-type and the interface-number arguments, this command displays IPv6 information about the specified interface.
# Display IPv6 information about VLAN-interface 2.
<Sysname> display ipv6 interface vlan-interface 2
Vlan-interface2 current state: UP
IPv6 is enabled, link-local address is FE80::1234:56FF:FE65:4322/64 [TENTATIVE]
  Global unicast address(es):
    10::1234:56FF:FE65:4322, subnet is 10::/64 [TENTATIVE] [AUTOCFG]
      [valid lifetime 4641s/preferred lifetime 4637s]
    20::1234:56ff:fe65:4322, subnet is 20::/64 [TENTATIVE] [EUI-64]
    30::1, subnet is 30::/64 [TENTATIVE] [ANYCAST]
    40::2, subnet is 40::/64 [TENTATIVE] [DHCP]
    50::3, subnet is 50::/64 [TENTATIVE]
  Joined group address(es):
    FF02::1
    FF02::2
    FF02::1:FF00:1
    FF02::1:FF65:4322
  MTU is 1500 bytes
  ND reachable time is 1200000 milliseconds
IPv6 Packet statistics:
  InReceives:                     0
  InTooShorts:                    0
  InTruncatedPkts:               0
  InHopLimitExceeds:             0
  InBadHeaders:                   0
  InBadOptions:                   0
  ReasmReqds:                     0
  ReasmOKs:                       0
  InFragDrops:                    0
  InFragTimeouts:                0
  OutFragFails:                   0
  InDelivers:                     0
  OutRequests:                    0
  OutForwDatagrams:              0
  InNoRoutes:                     0
  OutFragOKs:                     0
  OutFragCreates:                0
  InMcastPkts:                   0
  InMcastNotMembers:            0
  OutMcastPkts:                  0
Physical state of the interface:
·     Administratively DOWN—The interface has been administratively shut down by using the shutdown command.
·     DOWN—The interface is administratively up but its physical state is down, possibly because of a connection or link failure.
·     UP—The administrative and physical states of the interface are both up.
Link layer state of the interface:
·     DOWN—The link layer protocol state of the interface is down.
·     UP—The link layer protocol state of the interface is up.
IPv6 is enabled
IPv6 is enabled on the interface. This feature is automatically enabled after an IPv6 address is configured for an interface.
link-local address
Link-local address of the interface.
Global unicast addresses of the interface.
IPv6 address states:
·     TENTATIVE—Initial state. DAD is being performed or is to be performed on the address.
·     DUPLICATE—The address is not unique on the link.
·     PREFERRED—The address is preferred and can be used as the source or destination address of a packet. If an address is in this state, the command does not display the address state.
·     DEPRECATED—The address is beyond the preferred lifetime but in the valid lifetime. It is valid, but it cannot be used as the source address for a new connection. Packets destined for the address are processed correctly.
If a global unicast address is not manually configured, the following notations indicate how the address is obtained:
·     AUTOCFG—Stateless autoconfigured.
·     DHCP—Assigned by a DHCPv6 server.
·     EUI-64—Manually configured EUI-64 IPv6 address.
·     RANDOM—Random address automatically generated.
If the address is a manually configured anycast address, it is noted with ANYCAST.
valid lifetime
Specifies how long autoconfigured global unicast addresses using a prefix are valid.
preferred lifetime
Specifies how long autoconfigured global unicast addresses using a prefix are preferred.
Addresses of the multicast groups that the interface has joined.
MTU
MTU of the interface.
DAD is enabled.
·     If DAD is enabled, this field displays the number of attempts to send an NS message for DAD (set by using the ipv6 nd dad attempts command).
·     If DAD is disabled, this field displays ND DAD is disabled. To disable DAD, set the number of attempts to 0.
ND reachable time
Time during which a neighboring device is reachable.
Interval for retransmitting an NS message.
Hosts obtained IPv6 addresses through stateless autoconfiguration.
InReceives
Received IPv6 packets, including error messages.
InTooShorts
Received IPv6 packets that are too short. For example, the received IPv6 packet is less than 40 bytes.
InTruncatedPkts
Received IPv6 packets with a length less than the payload length field specified in the packet header.
InHopLimitExceeds
Received IPv6 packets with a hop count exceeding the hop limit field specified in the packet header.
InBadHeaders
Received IPv6 packets with incorrect basic headers.
InBadOptions
Received IPv6 packets with incorrect extension headers.
ReasmReqds
Received IPv6 fragments.
ReasmOKs
Number of reassembled IPv6 packets.
InFragDrops
Received IPv6 fragments that are discarded because of certain errors.
InFragTimeouts
Received IPv6 fragments that are discarded because the amount of time they stay in the system buffer exceeds the specified interval.
OutFragFails
IPv6 packets that fail to be fragmented on the output interface.
InUnknownProtos
Received IPv6 packets with unknown or unsupported protocol type.
InDelivers
Received IPv6 packets that are delivered to user protocols (such as ICMPv6, TCP, and UDP).
OutRequests
Local IPv6 packets sent by IPv6 user protocols.
OutForwDatagrams
IPv6 packets forwarded by the interface.
InNoRoutes
Received IPv6 packets that are discarded because no matching route can be found.
InTooBigErrors
Received IPv6 packets that fail to be forwarded because they exceeded the Path MTU.
OutFragOKs
Fragmented IPv6 packets on the output interface.
OutFragCreates
Number of IPv6 fragments on the output interface.
InMcastPkts
Received IPv6 multicast packets.
InMcastNotMembers
Received IPv6 multicast packets that are discarded because the interface is not in the multicast group.
OutMcastPkts
IPv6 multicast packets sent by the interface.
InAddrErrors
Received IPv6 packets that are discarded due to invalid destination addresses.
InDiscards
Received IPv6 packets that are discarded due to resource problems rather than packet errors.
OutDiscards
IPv6 packets that fail to be sent due to resource problems rather than packet errors.
# Display brief IPv6 information about all interfaces. Each interface description contains a maximum of 11 characters.
<Sysname> display ipv6 interface brief
*down: administratively down
(s): spoofing
Interface         Physical Protocol IPv6 Address/Prefix VPN instance Description
Vlan2              down      down      1::1/64 [TENTATIVE]  --            Link to ...
Vlan3              down      down      Unassigned             vpn1         Link to ...
Vlan10             down      down      Unassigned             --            --
# Display brief IPv6 information about all interfaces. Each interface description is complete.
<Sysname> display ipv6 interface brief description
(s): spoofing
Vlan2              down      down      1::1/64 [TENTATIVE] --             Link to Cor
        eRouter
(s): spoofing
Spoofing attribute of the interface. The link protocol state of the interface is up, but the link is temporarily established on demand or does not exist.
Name of the interface.
Physical
·     *down—The interface has been administratively shut down by using the shutdown command.
·     down—The interface is administratively up but its physical state is down, possibly because of a connection or link failure.
·     up—The administrative and physical states of the interface are both up.
Protocol
Link layer protocol state of the interface:
·     down—The network layer protocol state of the interface is down.
·     up—The network layer protocol state of the interface is up.
IPv6 Address/Prefix
IPv6 address and prefix of the interface.
·     If multiple global unicast addresses are configured, this field displays the lowest address.
·     If no global unicast address is configured, this field displays the link-local address.
·     If no address is configured, this field displays Unassigned.
Available IPv6 address states include:
·     DUPLICATE—The address is not unique on the link and is not usable.
VPN instance
Name of the VPN instance to which the interface belongs. If the interface does not belong to any VPN instance, this field displays hyphens (--).
Description of the interface. If no description is configured, this field displays hyphens (--).
Use display ipv6 interface prefix to display IPv6 prefix information for an interface.
# Display IPv6 prefix information for VLAN-interface 10.
<Sysname> display ipv6 interface vlan-interface10 prefix
Prefix: 1001::/65                                          Origin: ADDRESS
Age:    -                                                     Flag:   AL
Lifetime(Valid/Preferred): 2592000/604800
Preference: -
Prefix: 2001::/64                                          Origin: STATIC
Age:    -                                                     Flag:   L
Lifetime(Valid/Preferred): 3000/2000
Preference: -
Prefix: 3001::/64                                          Origin: RA
Age:    600                                                   Flag:   A
Lifetime(Valid/Preferred): -
Preference: -
Prefix: 4001::/64                                          Origin: STATIC
Age:    -                                                     Flag:   ALP
Lifetime(Valid/Preferred): 1000/200
Preference: 200
Table 5 Command output
Filed
Prefix
IPv6 address prefix.
Origin
How the prefix is generated:
·     STATIC—Manually configured by using the ipv6 nd ra prefix command.
·     RA—Advertised in RA messages after stateless autoconfiguration is enabled.
·     ADDRESS—Generated by a manually configured address.
Age
Aging time in seconds. If the prefix does not age out, this field displays a hyphen (-).
Flag
Flags carried in RA messages. If no flags are available, this field displays a hyphen (-).
·     L—The address with the prefix is directly reachable on the link.
·     A—The prefix is used for stateless autoconfiguration.
·     N—The prefix is not advertised in RA messages.
·     P—The prefix has a preference.
Lifetime
Lifetime in seconds advertised in RA messages. If the prefix does not need to be advertised, this field displays a hyphen (-).
·     Valid—Valid lifetime of the prefix.
·     Preferred—Preferred lifetime of the prefix.
Preference
Preference of the IPv6 prefix.
ipv6 nd ra prefix
Use display ipv6 nd proxy statistics to display statistics for ND proxy reply packets.
You can view statistics for ND proxy reply packets in the most recent hour.
This command displays the ND proxy reply statistics within the most recent minute on a per-second basis and displays the statistics one minute ago on a five-minute basis.
# Display statistics for ND proxy reply packets.
<Sysname> display ipv6 nd proxy statistics
Last 1 sec proxy count: 200
Last 2 sec proxy count: 400
Last 1 min proxy count: 12000
Last 5 min proxy count: 18000
Last 10 min proxy count: 24000
Last 60 min proxy count: 182445
proxy-nd enable
Use display ipv6 nd route-direct advertise to display information about ND direct route advertisement.
display ipv6 nd route-direct advertise interface interface-type interface-number
interface interface-type interface-number: Specifies an interface by its type and number. Make sure you specify the interface where the ND direct route advertisement is enabled.
When ND direct route advertisement is enabled, the device generates direct routes based on ND entries for packet forwarding and route advertisement. You can use this command to check whether the route management module has generated direct routes for ND entries.
As a best practice, wait a period of time after you enable ND direct route advertisement and then execute this command.
# Display information about ND direct route advertisement on Ten-GigabitEthernet1/0/1.
<Sysname> display ipv6 nd route-direct advertise interface ten-gigabitethernet 1/0/1
IPv6 address             MAC address         VLAN/VSI  Interface     State Route
1::2                      6864-6839-0202 1    XGE1/0/1                  STALE YES
1::3                      6864-6839-0202 1    XGE1/0/1                  STALE NO
Table 6 Command output
IPv6 address
IPv6 address of the neighbor.
MAC address
MAC address of the neighbor.
VLAN/VSI
VLAN ID or VSI index to which the neighbor entry belongs. This field displays hyphens (--) if the neighbor entry does not belong to a VLAN or VSI.
Interface connected to the neighbor.
·     If the neighbor entry does not belong to a VSI, this field displays the interface name. If the interface name is not available, the field displays hyphens (--).
·     If the neighbor entry belongs to a VSI and the interface is a tunnel interface, the field value depends on the address resolution status.
¡     If the address is not resolved, this field displays the VSI.
¡     If the address is resolved, this field displays the tunnel ID.
·     If the neighbor entry belongs to a VSI but the interface is not a tunnel interface, the field value depends on the address resolution status.
¡     If the address is resolved, this field displays the interface.
State of a neighbor:
·     INCMP—The address is being resolved. The link layer address of the neighbor is unknown.
·     REACH—The neighbor is reachable.
·     STALE—The reachability of the neighbor is unknown. The device will not verify the reachability unless it has data to send to the neighbor.
·     DELAY—The reachability of the neighbor is unknown. The device does not send an NS message in the delay period.
·     PROBE—The reachability of the neighbor is unknown. The device sends an NS message to probe the reachability of the neighbor.
Route
Whether a direct route is generated for the ND entry in the route management module:
·     YES—A direct route is generated based on the ND entry.
·     NO—No direct route is generated based on the ND entry..
Use display ipv6 nd snooping count vlan to display the number of IPv6 ND snooping entries for VLANs.
display ipv6 nd snooping count vlan [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the total number of ND snooping entries in all VLANs.
# Display the total number of IPv6 ND snooping entries in all VLANs.
<Sysname> display ipv6 nd snooping count vlan
Total entries for VLANs: 5
# Display the total number of IPv6 ND snooping entries on Ten-GigabitEthernet 1/0/1.
<Sysname> display ipv6 nd snooping count vlan interface ten-gigabitethernet 1/0/1
Total entries on interface XGE1/0/1: 2
Table 7 Command output
Total number of ND snooping entries in all VLANs.
Total entries on interface xxx
Total number of ND snooping entries on the interface.
Use display ipv6 nd snooping count vsi to display the number of IPv6 ND snooping entries in the specified VSI.
display ipv6 nd snooping count vsi [ vsi-name ]
vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays ND snooping entries for all VSIs.
# Display the total number of IPv6 ND snooping entries in all VSIs.
<Sysname> display ipv6 nd snooping count vsi
Total entries for VSIs: 5
# Display the total number of IPv6 ND snooping entries in VSI vsi1.
<Sysname> display ipv6 nd snooping count vsi vsi1
Total entries for VSI vsi1: 2
Table 8 Command output
Total number of IPv6 ND snooping entries in all VSIs.
Total number of IPv6 ND snooping entries in VSI vsi1.
Use display ipv6 nd snooping vlan to display ND snooping entries in the specified VLAN.
display ipv6 nd snooping vlan [ [ vlan-id | interface interface-type interface-number ] [ global | link-local ] | ipv6-address ] [ verbose ]
vlan vlan-id: Displays ND snooping entries for the specified VLAN. The value range for the VLAN ID is 1 to 4094.
interface interface-type interface-number: Displays ND snooping entries for the specified interface in a VLAN. The interface-type interface-number argument specifies an interface by its type and number.
global: Displays ND snooping entries for global unicast addresses in the VLAN.
link-local: Displays ND snooping entries for link-local addresses in the VLAN.
ipv6-address: Displays the ND snooping entry for the specified IPv6 address.
verbose: Displays detailed information about ND snooping entries in the VLAN. If you do not specify the keyword, this command displays brief information about ND snooping entries.
If you do not specify any parameters, this command displays all ND snooping entries.
# Display brief information about IPv6 ND snooping entries for VLAN 1.
<Sysname> display ipv6 nd snooping vlan 1
IPv6 address              MAC address     VID  Interface     Status       Age
1::2                       0000-1234-0c01  1    XGE1/0/2       VALID        57
# Display detailed information about IPv6 ND snooping entries for VLAN 1.
<Sysname> display ipv6 nd snooping vlan 1 verbose
IPv6 address: 1::2
MAC address: 0000-1234-0c01
Interface: XGE1/0/2
First VLAN ID: 1   Second VLAN ID: N/A
Status: VALID   Age: 57
Table 9 Command output
IPv6 address
IPv6 address in the ND snooping entry.
MAC address
MAC address in the ND snooping entry.
VID
ID of the VLAN to which the ND snooping entry belongs.
First VLAN ID
ID of the SVLAN to which the ND snooping entry belongs.
Second VLAN ID
ID of the CVLAN to which the ND snooping entry belongs. If no CVLAN is configured, this field displays N/A. For more information about the SVLAN and CVLAN, see QinQ in Layer 2—LAN Switching Configuration Guide.
Input interface in the ND snooping entry.
Status
Status of the ND snooping entry:
·     TENTATIVE—The entry is ineffective.
·     VALID—The entry is effective.
·     TESTING_TPLT—The entry is being tested by DAD. The device performs DAD for the entry in the following situations:
¡     The entry ages out.
¡     An ND trusted interface in the VLAN receives an ND message from the IPv6 address in the entry.
·     TESTING_VP—The entry is being tested by DAD. The device performs DAD when an ND untrusted interface in the VLAN receives an ND message from the IPv6 address in the entry.
Age
For an ND snooping entry in VALID status, this field displays its remaining aging time in seconds.
For an ND snooping entry in other status, this field displays a pound sign (#).
Use display ipv6 nd snooping vsi to display ND snooping entries in the specified VSI.
In standalone mode:
display ipv6 nd snooping vsi [ vsi-name ] [ slot slot-number ]
In IRF mode:
display ipv6 nd snooping vsi [ vsi-name ] [ chassis chassis-number slot lot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ND snooping entries for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays ND snooping entries for the global active MPU. (In IRF mode.)
# Display ND snooping entries in VSI vsi1.
<Sysname> display ipv6 nd snooping vsi vsi1
IPv6 address            MAC address     VSI name         Link ID    Aging(min)
1::2                     0000-1234-0c01  vsi1              0x70000    5
Table 10 Command output
IPv6 address
MAC address
VSI name
Name of the VSI to which the ND snooping entry belongs.
Link ID
Link ID that uniquely identifies an AC or a VXLAN tunnel on a VSI.
Aging(min)
Remaining aging time of the ND snooping entry, in minutes.
Use display ipv6 nd user-ip-conflict record to display user IPv6 address conflict records.
In standalone mode:
display ipv6 nd user-ip-conflict record [ slot slot-number ]
In IRF mode:
display ipv6 nd user-ip-conflict record [chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays user IP address conflict records for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays user IP address conflict records for all cards. (In IRF mode.)
# Display all user IPv6 address conflict records.
<Sysname> display ipv6 nd user-ip-conflict record
IPv6 address: 10::1
System time: 2018-02-02 11:22:29
Conflict count: 1
Log suppress count: 0
Old interface: Ten-GigabitEthernet1/0/1
New interface: Ten-GigabitEthernet1/0/2
Old SVLAN/CVLAN: 100/2
New SVLAN/CVLAN: 100/2
Old MAC: 00e0-ca63-8141
New MAC: 00e0-ca63-8142
IPv6 address: 10::2
System time: 2018-02-02 10:20:30
Conflict count: 1
Old SVLAN/CVLAN: 100/--
New SVLAN/CVLAN: 100/--
Table 11 Command output
IPv6 address
IPv6 address of a user.
System time
Time when the user IPv6 address conflict occurred.
Conflict count
Number of times user IPv6 address conflicts occurred.
Log suppress count
Number of times user IPv6 address conflict log generation has been suppressed.
Old interface
Output interface in the old ND entry.
New interface
Output interface in the new ND entry.
Old SVLAN/CVLAN
ID of the outer VLAN or inner VLAN in the old ND entry. This field displays hyphens (--) if the ND entry does not belong to any outer VLAN or inner VLAN.
New SVLAN/CVLAN
ID of the outer VLAN or inner VLAN in the new ND entry. This field displays hyphens (--) if the ND entry does not belong to any outer VLAN or inner VLAN.
Old MAC
MAC address in the old ND entry.
New MAC
MAC address in the new ND entry.
Use display ipv6 nd user-move record to display user port migration records.
In standalone mode:
display ipv6 nd user-move record [ slot slot-number ]
In IRF mode:
display ipv6 nd user-move record [chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays user port migration records for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays user port migration records for all cards. (In IRF mode.)
# Display all user port migration records.
<Sysname> display ipv6 nd user-move record
IPv6 address: 10::1
MAC address: 00e0-ca63-8141
Move count: 1
Before:
  SVLAN/CVLAN: 100/2
After:
  SVLAN/CVLAN: 100/2
IPv6 address: 10::2
MAC address: 00e0-ca63-8142
Move count: 1
Before:
  SVLAN/CVLAN: 100/--
After:
  SVLAN/CVLAN: 100/--
Table 12 Command output
IPv6 address
IPv6 address of the user.
MAC address
MAC address of the user.
System time
Time when the user port migration occurred.
Move count
Number of times the user port migrated.
Log suppress count
Number of times user port migration log generation has been suppressed.
Before
Information before the user port migration.
interface
Interface information in the ND entry.
SVLAN/CVLAN
ID of the outer VLAN or inner VLAN in the ND entry. This field displays hyphens (--) if the ND entry does not belong to any outer VLAN or inner VLAN.
After
Information after the user port migration.
Use display ipv6 neighbors to display IPv6 neighbor information.
In standalone mode:
In IRF mode:
display ipv6 neighbors { { ipv6-address | all | dynamic | static } [ chassis chassis-number slot slot-number ] | interface interface-type interface-number | vlan vlan-id } [ verbose ]
ipv6-address: Specifies the IPv6 address of a neighbor whose information is displayed.
all: Displays information about all neighbors, including neighbors acquired dynamically and configured statically on the public network and all private networks.
dynamic: Displays information about all neighbors acquired dynamically.
static: Displays information about all neighbors configured statically.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 neighbor information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 neighbor information for all cards. (In IRF mode.)
vlan vlan-id: Displays information about neighbors in the specified VLAN. The value range for VLAN ID is 1 to 4094.
verbose: Displays detailed neighbor information.
# Display all neighbor information.
<Sysname> display ipv6 neighbors all
Type: S-Static    D-Dynamic    O-Openflow     R-Rule    IS-Invalid static
IPv6 address                 MAC address    VID  Interface          State T  Aging
1::2                          6864-6839-0202 1         XGE1/0/1              STALE D  136
FE80::6A64:68FF:FE39:202  6864-6839-0202 1         XGE1/0/1              STALE D  126
1::3                      6864-6839-0203 1          Tunnel1       STALE D  136
1::4                          6864-6839-0204 1          XGE1/0/2               STALE D  136
# Display detailed information about all neighbors.
<Sysname> display ipv6 neighbors all verbose
IPv6 Address      : 1::2
MAC address       : 6864-6839-0202            Type  : Dynamic
State              : STALE                       Aging : 136   seconds
Interface         : XGE1/0/1                    VLAN  : 1
VPN instance     : --
Service instance: --
Link ID           : --
VXLAN ID          : --
VSI name          : --
VSI interface    : --
Nickname          : 0x0
IPv6 Address     : FE80::6A64:68FF:FE39:202
State             : STALE                       Aging : 126   seconds
VPN instance     : --
Link ID           : --
VXLAN ID          : --
VSI name          : --
VSI interface    : --
Nickname          : 0x0
IPv6 Address     : 1::3
MAC address      : 6864-6839-0203            Type  : Static
State            : REACH                     Aging : --
Interface        : Tunnel1                   VLAN  : --
VPN instance     : --
Service instance : --
Link ID          : 0x5000001
VXLAN ID         : 10
VSI name         : vpna
VSI interface    : Vsi1
Nickname         : 0x0
IPv6 Address     : 1::4
MAC address      : 6864-6839-0204            Type  : Static
Interface        : XGE1/0/2                  VLAN  : --
VPN instance     : --
Service instance : 1
Link ID          : 0x1
VXLAN ID         : 10
VSI name         : vpna
Nickname         : 0x0
Table 13 Command output
IPv6 Address
MAC address
VLAN/VSI
Neighbor information type:
·     Static—Statically configured.
·     Dynamic—Dynamically obtained.
·     Openflow—Learned from the OpenFlow module.
·     Rule—Learned from the portal module.
·     Invalid static—Invalid static configuration.
Aging
Reachable time of the neighbor:
·     For a static neighbor entry, this field displays hyphens (--), representing the neighbor entry never expires.
·     For a dynamic neighbor entry, this field displays the elapsed time in seconds. If the neighbor is never reachable, this field displays a pound sign (#).
VPN instance
Name of a VPN instance. This field displays hyphens (--) if no VPN instance is configured.
Service instance
Ethernet service instance. If the neighbor entry does not belong to any Ethernet service instance for the related Layer 2 Ethernet interface or Layer 2 aggregate interface, this field displays hyphens (--).
Link ID
ID of the link that connects to the neighbor. The link ID is a string with a maximum of eight hexadecimal numbers.
If the neighbor entry does not belong to a VSI, the field displays hyphens (--).
VXLAN ID
ID of the VXLAN associated with the VSI in the neighbor entry. If no VXLAN is specified, the field displays hyphens (--).
VSI name
Name of the VSI where the neighbor entry belongs. If the entry does not belong to a VSI, the field displays hyphens (--).
VSI interface
VSI interface associated with the VSI. If no VSI interface is specified, the field displays hyphens (--).
Nickname
Nickname of a neighbor entry. The name is a string of four hexadecimal numbers.
ipv6 neighbor
Use display ipv6 neighbors count to display the number of neighbor entries.
In standalone mode:
In IRF mode:
display ipv6 neighbors { { all | dynamic | static } [ chassis chassis-number slot slot-number ] | interface interface-type interface-number | vlan vlan-id } count
all: Displays the total number of all neighbor entries, including neighbor entries created dynamically and configured statically.
dynamic: Displays the total number of neighbor entries created dynamically.
static: Displays the total number of neighbor entries configured statically.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the number of neighbor entries for all cards. (In standalone mode.) .
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays the number of neighbor entries for all cards. (In IRF mode.)
vlan vlan-id: Displays the total number of neighbor entries in the specified VLAN. The value range for VLAN ID is 1 to 4094.
# Display the total number of neighbor entries created dynamically.
<Sysname> display ipv6 neighbors dynamic count
 Total number of dynamic entries: 2
Use display ipv6 neighbors entry-limit to display the maximum number of ND entries that a device supports.
# Display the maximum number of ND entries that the device supports.
<Sysname> display ipv6 neighbors entry-limit
ND entries: 2048
Use display ipv6 neighbors statistics to display ND entry statistics.
In standalone mode:
display ipv6 neighbors statistics { [ by-slot ] all | interface { interface-name | interface-type interface-number } | slot slot-number }
In IRF mode:
display ipv6 neighbors statistics { [ by-slot ] all | interface { interface-name | interface-type interface-number } | chassis chassis-number slot slot-number }
all: Displays statistics about all ND entries.
by-slot: Displays statistics about all ND entries by card. (In standalone mode.)
by-slot: Displays statistics about all ND entries by card. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ND entry statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays ND entry statistics for all cards. (In IRF mode.)
Use this feature to monitor the usage of ND entry resources. When a packet forwarding error occurs, you can check ND entry statistics, and then determine whether the error is caused by excessive consumption of ND entry resources.
# Display ND entry statistics on Ten-GigabitEthernet 1/0/1.
<Sysname> display ipv6 neighbors statistics interface ten-gigabitethernet 1/0/1
State      Dynamic      Static      Rule
Incmp      0            0           0
Reach      0            2           0
Stale      1            -           -
Delay      0            -           -
Probe      0            -           -
Total      1            2           0
# Display all ND entry statistics.
<Sysname> display ipv6 neighbors statistics all
Incmp      0             4             0
Reach      1             2             0
Stale      0             -             -
Delay      0             -             -
Probe      0             -             -
Total      1             6             0
# Display all ND entry statistics by card. (In standalone mode.) (In IRF mode.)
<Sysname> display ipv6 neighbors statistics by-slot all
Slot 1:
Incmp      0            4           0
Reach      1            2           0
Stale      0            -           -
Delay      0            -           -
Probe      0            -           -
Total      1            6           0
Slot 2:
Incmp      0            4           0
Reach      1            2           0
Stale      0            -           -
Delay      0            -           -
Probe      0            -           -
Total      1            6           0
# Display all ND entry statistics on slot 1. (In standalone mode.)
<Sysname> display ipv6 neighbors statistics slot 1
Incmp      0            0           0
Reach      0            2           0
Stale      1            -           -
Delay      0            -           -
Probe      0            -           -
Total      1            2           0
Table 14 Command output
Dynamic
Number of dynamic ND entries.
Static
Number of static ND entries.
Rule
Number of ND entries learned from other modules, such as IPoE and Portal.
Incmp
Number of ND entries in Incmp state.
Reach
Number of ND entries in Reach state.
Stale
Number of ND entries in Stale state.
Delay
Number of ND entries in Delay state.
Probe
Number of ND entries in Probe state.
Use display ipv6 neighbors usage to display the ND table usage.
You can use this command to monitor the number of ND entries on the device and to determine whether ND attacks exist on the network.
The ND table usage is the ratio of the real-time ND entry count to the ND table capacity. When a network-side port is a VLAN interface, the dynamic ND learning limit might fail to reach the ND table capacity because it is restricted to the next hop hardware resources. Therefore, it might happen that the displayed ND table usage is low but the maximum number of dynamic ND entries is already reached.
The ND table usage provides statistics in the most recent hour.
# Display the ND table usage.
<Sysname> display ipv6 neighbors usage
ND table upper limit: 65000
  Time           ND entry count    Usage
  Current       52000             80%
  1 min ago     51351             79%
  2 min ago     50711             78%
  3 min ago     47748             77%
  59 min ago    13656             21%
  60 min ago    13007             20%
Table 15 Command output
Maximum number of ND entries supported by the ND table.
Time
Time when the ND table usage was recorded.
ND entry count
Number of ND entries.
Usage
Usage of ND table, which is the ratio of the real-time ND entry count to the ND table upper limit.
Use display ipv6 neighbors vpn-instance to display neighbor information about a VPN instance.
display ipv6 neighbors vpn-instance vpn-instance-name [ count ]
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The VPN instance must already exist.
count: Displays the total number of neighbor entries in the specified VPN instance.
# Display neighbor information about the VPN instance vpn1.
<Sysname> display ipv6 neighbors vpn-instance vpn1
IPv6 address                 MAC address    VLAN/VSI  Interface           State T  Aging
FE80::200:5EFF:FE32:B800  0000-5e32-b800 --   XGE1/0/1            REACH IS --
Table 16 Command output
IPv6 address
MAC address
VLAN/VSI
ID of the VLAN to which the interface connected to the neighbor belongs. This field displays hyphens (--) if the neighbor does not belong to a VLAN.
State of the neighbor:
·     STALE—Whether the neighbor is reachable is unknown. The device does not verify the reachability any longer unless data is sent to the neighbor.
·     DELAY—Whether the neighbor is reachable is unknown. The device sends an NS message after a delay.
·     PROBE—Whether the neighbor is reachable is unknown. The device sends an NS message to verify the reachability of the neighbor.
·     Rule—Learned from the IPoE or portal module.
Aging
Use the display ipv6 pathmtu command to display IPv6 Path MTU information.
display ipv6 pathmtu [ vpn-instance vpn-instance-name ] { ipv6-address | { all | dynamic | static } [ count ] }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 Path MTU information about the public network.
ipv6-address: Specifies the destination IPv6 address for which the Path MTU information is to be displayed.
all: Displays all Path MTU information for the public network.
dynamic: Displays all dynamic Path MTU information.
static: Displays all static Path MTU information.
count: Displays the total number of Path MTU entries.
# Display all Path MTU information.
<Sysname> display ipv6 pathmtu all
IPv6 destination address                PathMTU   Age    Type
1:2::3:2                                   1800       -      Static
1:2::4:2                                   1400       10     Dynamic
1:2::5:2                                   1280       10     Dynamic
# Displays the total number of Path MTU entries.
<Sysname> display ipv6 pathmtu all count
Total number of entries: 3
Table 17  Command output
PathMTU
Path MTU value on the network path to an IPv6 address.
Age
Time for a Path MTU to live. For a static Path MTU, this field displays a hyphen (-).
Path MTU type:
·     Dynamic—Dynamically negotiated.
Total number of Path MTU entries.
ipv6 pathmtu
reset ipv6 pathmtu
display ipv6 prefix
Use display ipv6 prefix to display information about IPv6 prefixes, including dynamic and static prefixes.
prefix-number: Specifies the ID of an IPv6 prefix, in the range of 1 to 1024. If you do not specify an IPv6 prefix ID, this command displays information about all IPv6 prefixes.
A static IPv6 prefix is configured by using the ipv6 prefix command.
A dynamic IPv6 prefix is obtained from the DHCPv6 server, and its prefix ID is configured by using the ipv6 dhcp client pd command. For detailed information, see Layer 3—IP Services Configuration Guide.
# Display information about all IPv6 prefixes.
<Sysname> display ipv6 prefix
Number  Prefix                                     Type
1        1::/16                                     Static
2        11:77::/32                                Dynamic
# Display information about the IPv6 prefix with prefix ID 1.
<Sysname> display ipv6 prefix 1
Number: 1
Type  : Dynamic
Prefix: ABCD:77D8::/32
Preferred lifetime 90 sec, valid lifetime 120 sec
Table 18 Command output
Number
Prefix ID.
Prefix type:
·     Static—Static IPv6 prefix.
·     Dynamic—Dynamic IPv6 prefix.
Prefix
Prefix and its length. If no prefix is obtained, this field displays Not-available.
Preferred lifetime in seconds. For a static IPv6 prefix, this field is not displayed.
Valid lifetime in seconds. For a static IPv6 prefix, this field is not displayed.
ipv6 dhcp client pd
ipv6 prefix
display ipv6 rawip
Use display ipv6 rawip to display brief information about IPv6 RawIP connections.
In standalone mode:
display ipv6 rawip [ slot slot-number ]
In IRF mode:
display ipv6 rawip [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays brief information about IPv6 RawIP connections for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays brief information about IPv6 RawIP connections for all cards. (In IRF mode.)
# (In standalone mode.) Display brief information about IPv6 RawIP connections.
<Sysname> display ipv6 rawip
Local Addr            Foreign Addr        Protocol Slot  Cpu PCB
2001:2002:2003:2     3001:3002:3003:3   58        1      0    0x0000000000000009
004:2005:2006:20     004:3005:3006:30
07:2008                07:3008
2002::100             2002::138            58        2      0    0x0000000000000008
::                     ::                     58        5      0    0x0000000000000002
Table 19 Command output
Local Addr
Local IPv6 address.
Foreign Addr
Peer IPv6 address.
Protocol
Protocol number.
PCB
PCB index.
Use display ipv6 rawip verbose to display detailed information about IPv6 RawIP connections.
In standalone mode:
In IRF mode:
display ipv6 rawip verbose [ chassis chassis-number slot slot-number [ pcb pcb-index ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays detailed information about IPv6 RawIP connections for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays detailed information about IPv6 RawIP connections for all cards. (In IRF mode.)
pcb pcb-index: Displays detailed information about IPv6 RawIP connections of the specified PCB.  The value range for the pcb-index argument is 1 to FFFFFFFFFFFFFFF.
# (In standalone mode.) Display detailed information about an IPv6 RawIP connection.
<Sysname> display ipv6 rawip verbose
Total RawIP socket number: 1
 Connection info: src = ::, dst = ::
 Creator: ping ipv6[320]
 State: N/A
 Options: N/A
 Error: 0
 Type: 3
 Protocol: 58
 Inpcb flags: N/A
 Inpcb extflag: INP_EXTRCVICMPERR INP_EXTFILTER
 Inpcb vflag: INP_IPv6
 Hop limit: 255 (minimum hop limit: 0)
 Send VRF: 0xffff
 Receive VRF: 0xffff
Table 20 Command output
Total number of IPv6 RawIP sockets.
Connection info
Connection information, including the source and destination IPv6 addresses.
Location
Socket location.
Creator
Task name of the socket. The process number is in the square brackets.
Socket state:
·     NOFDREF—The user has closed the connection.
·     ISCONNECTED—The connection has been established.
·     ISCONNECTING—The connection is being established.
·     ISDISCONNECTING—The connection is being interrupted.
·     ASYNC—Asynchronous mode.
·     ISDISCONNECTED—The connection has been terminated.
·     ISSMOOTHING—Cross-card data smoothing is in progress.
·     CANBIND—The socket supports the bind operation.
·     PROTOREF—Indicates strong protocol reference.
·     ISPCBSYNCING—Cross-card PCB synchronization is in progress.
·     N/A—None of above state.
Options
Socket options:
·     SO_DEBUG—Records socket debugging information.
·     SO_ACCEPTCONN—Enables the server to listen connection requests.
·     SO_REUSEADDR—Allows the local address reuse.
·     SO_KEEPALIVE—Requires the protocol to test whether the connection is still alive.
·     SO_DONTROUTE—Bypasses the routing table query for outgoing packets because the destination is in a directly connected network.
·     SO_BROADCAST—Supports broadcast packets.
·     SO_LINGER—Closes the socket. The system can still send remaining data in the socket send buffer.
·     SO_OOBINLINE—Stores the out-of-band data in the input queue.
·     SO_REUSEPORT—Allows the local port reuse.
·     SO_TIMESTAMP—Records the timestamps of the incoming packets, accurate to milliseconds. This option is applicable to protocols that are not connection orientated.
·     SO_NOSIGPIPE—Disables the socket from sending data. As a result, a sigpipe cannot be established when a return failure occurs.
·     SO_TIMESTAMPNS—Has a similar function with the timestamp, accurate to nanoseconds.
·     SO_KEEPALIVETIME—Sets a keepalive time. This option is supported in TCP.
·     SO_FILTER—Supports setting the packet filter criterion. This option is available for OSI Socket and RawIP.
·     SO_USCBINDEX—Obtains the user profile index from the received packets.
·     SO_SEQPACKET—Preserves the boundaries of packets sent to the socket buffer.
·     SO_FILLTWAMPTIME—Sets the timestamp for TWAMP.
·     SO_LOCAL—Local socket option.
·     SO_NBMAADDR—Obtains the remote NBMA address of the ADVPN tunnel.
·     SO_DONTDELIVER—Do not deliver the data to the application.
·     SO_UCM—Sets the IPoE enabling status. ‌
·     SO_RAWSLOT—Raw slot.
·     SO_LEASEDUSERID—Obtains a usable lease.
·     N/A—No options are set.
Error
Error code.
Displays receive buffer information in the following order:
·     cc—Used space.
·     hiwat—Maximum space.
·     lowat—Minimum space.
·     drop—Number of dropped packets.
·     state—Buffer state:
¡     CANTSENDMORE—Unable to send data to the peer.
¡     CANTRCVMORE—Unable to receive data from the peer.
¡     RCVATMARK—Receiving tag.
¡     N/A—None of the above states.
Displays send buffer information in the following order:
·     cc—Used space.
Socket type:
·     1SOCK_STREAM. This socket uses TCP to provide reliable transmission of byte streams.
·     2SOCK_DGRAM. This socket uses UDP to provide datagram transmission.
·     3SOCK_RAW. This socket allows an application to change the next upper-layer protocol header.
·     N/A—None of the above types.
Protocol
Number of protocol using the socket. 58 represents ICMP.
Inpcb flags
Flags in the Internet PCB:
·     INP_RECVOPTS—Receives IPv6 options.
·     INP_RECVRETOPTS—Receives replied IPv6 options.
·     INP_RECVDSTADDR—Receives destination IPv6 address.
·     INP_HDRINCL—Provides the entire IPv6 header.
·     INP_REUSEADDR—Reuses the IPv6 address.
·     INP_REUSEPORT—Reuses the port number.
·     INP_ANONPORT—Port number not specified.
·     INP_PROTOCOL_PACKET—Identifies a protocol packet.
·     INP_RCVVLANID—Receives the VLAN ID of the packet. Only UDP and RawIP support this flag.
·     IN6P_IPv6_V6ONLY—Only supports IPv6 protocol stack.
·     IN6P_PKTINFO—Receives the source IPv6 address and input interface of the packet.
·     IN6P_HOPLIMIT—Receives the hop limit.
·     IN6P_HOPOPTS—Receives the hop-by-hop options extension header.
·     IN6P_DSTOPTS—Receives the destination options extension header.
·     IN6P_RTHDR—Receives the routing extension header.
·     IN6P_RTHDRDSTOPTS—Receives the destination options extension header preceding the routing extension header.
·     IN6P_TCLASS—Receives the traffic class of the packet.
·     IN6P_AUTOFLOWLABEL—Attaches a flow label automatically.
·     IN6P_RFC2292—Uses the API specified in RFC 2292.
·     IN6P_MTU—Discovers differences in the MTU size of every link along a given data path. TCP does not support this flag.
·     INP_RCVMACADDR—Receives the MAC address of the frame.
·     INP_USEICMPSRC—Uses the specified IPv6 address as the source IPv6 address for outgoing ICMP packets.
·     INP_SYNCPCB—Waits until Internet PCB is synchronized.
·     INP_LOCAL—Preferentially matches the INPCB with this flag on the same card.
·     N/A—None of the above flags.
Inpcb extflag
Extension flags in the Internet PCB:
·     INP_EXTRCVPVCIDX—Records the PVC index of the received packet.
·     INP_RCVPWID—Records the PW ID of the received packet.
·     INP_EXTRCVICMPERR—Receives an ICMP error packet.
·     INP_EXTFILTER—Filters the contents in the received packet.
·     INP_EXTDONTDROP—Do not drop the received packet.
·     INP_EXLISTEN—Adds the INPCB carrying this flag to the listen hash table.
·     INP_SELECTMATCHSRCBYFIB—Uses the FIB table to select a matching source.
·     INP_EXTPRIVATESOCKET—Associates the INPCB with the NSR private socket.
·     INP_EXTNOCACHEPKT—Do not cache packets.
·     INP_EXTRCVVLANDOT1P—Obtains the Dot1p value of the VLAN tag in the received packet.
·     INP_EXTSNDDATAIF—Sets the output interface of data.
·     INP_EXTFREEBIND—The socket is not bound to an address or port.
·     INP_EXTRCVUPID—Obtains the UP ID from the received packet in the UCM control-/user-plane separated (CUPS) network.
·     INP_EXTINNERPROXY—Receives packets forwarded by the proxy.
·     INP_EXLISTENNET—Sets this flag when the connection information is added to the network segment linked list.
Inpcb vflag
IP version flag in the Internet PCB:
·     INP_IPv4—IPv4 protocol.
·     INP_IPv6—IPv6 protocol.
·     INP_IPv6PROTO—Creates an Internet PCB based on IPv6 protocol.
·     INP_TIMEWAIT—In TIMEWAIT state.
·     INP_ONESBCAST—Sends broadcast packets.
·     INP_DROPPED—Protocol dropped flag.
·     INP_SOCKREF—Strong socket reference.
·     INP_DONTBLOCK—Do not block synchronization of the Internet PCB.
Hop limit
Hop limit in the Internet PCB.
Send VRF
VRF from which packets are sent.
Receive VRF
VRF from which packets are received.
Use display ipv6 statistics to display IPv6 and ICMPv6 packet statistics.
In standalone mode:
In IRF mode:
display ipv6 statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 and ICMPv6 packet statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 and ICMPv6 packet statistics for all cards. (In IRF mode.)
# Display IPv6 and ICMPv6 packet statistics.
<Sysname> display ipv6 statistics
  IPv6 statistics:
    Sent packets:
      Total:      0
        Sent locally:         0            Forwarded:              0
        Raw packets:          0            Discarded:              0
        Fragments:             0            Fragments failed:      0
        Routing failed:       0
    Received packets:
      Total:      0
        Received locally:     0            Hop limit exceeded:  0
        Fragments:             0            Reassembled:           0
        Reassembly failures:  0            Reassembly timeout:  0
        Format errors:         0            Option errors:        0
        Protocol errors:      0
  ICMPv6 statistics:
    Sent packets:
      Total:      0
        Unreachable:           0             Too big:                0
        Hop limit exceeded:   0             Reassembly timeouts: 0
        Parameter problems:   0
        Echo requests:         0             Echo replies:          0
        Neighbor solicits:    0             Neighbor adverts:     0
        Router solicits:      0             Router adverts:        0
        Redirects:             0              Router renumbering:   0
      Send failed:
        Rate limitation:      0             Other errors:          0
    Received packets:
      Total:      0
        Checksum errors:      0             Too short:              0
        Bad codes:             0
        Parameter problems:   0             Unknown error types:   0
        Unknown info types:   0
      Deliver failed:
        Bad length:           0
Table 21 Command output
IPv6 statistics:
Sent packets:
Total:
Sent locally:
Forwarded:
Raw packets:
Discarded:
Fragments:
Fragments failed:
Routing failed:
Statistics for sent IPv6 packets:
·     Total—Total number of packets that have been locally sent and forwarded.
·     Sent locally—Number of locally sent packets.
·     Forwarded—Number of forwarded packets.
·     Raw packets—Number of packets sent by using a raw socket.
·     Discarded—Number of discarded packets.
·     Fragments—Number of sent fragments.
·     Fragments failed—Number of fragments that were failed to send.
·     Routing failed—Number of packets with routing failures.
Received packets:
Total:
Received locally:
Hop limit exceeded:
Fragments:
Reassembled:
Reassembly timeout:
Format errors:
Option errors:
Protocol errors:
Statistics for received IPv6 packets:
·     Total—Total number of received packets.
·     Received locally—Number of received packets that are destined for the device.
·     Hop limit exceeded—Number of packets with hop limit exceeded.
·     Fragments—Number of received fragments.
·     Reassembled—Number of reassembled packets.
·     Reassembly failures—Number of packets with reassembly failures.
·     Reassembly timeout—Number of packets with reassembly timed out.
·     Format errors—Number of packets with format errors.
·     Option errors—Number of packets with option errors.
·     Protocol errors—Number of packets with protocol errors.
ICMPv6 statistics:
ICMPv6 message statistics.
Sent packets:
Total:
Unreached:
Too big:
Hop limit exceeded:
Parameter problems:
Echo requests:
Echo replies:
Neighbor solicits:
Neighbor adverts:
Router solicits:
Router adverts:
Redirects:
Router renumbering
Sent failed:
Rate limitation:
Other errors:
Statistics for sent ICMPv6 messages:
·     Total—Total number of sent messages.
·     Unreached—Number of Destination Unreachable messages.
·     Too big—Number of Packet Too Big messages.
·     Hop limit exceeded—Number of Hop Limit Exceeded messages.
·     Reassembly timeouts—Number of Fragment Reassembly Time Exceeded messages.
·     Parameter problems—Number of Parameter Problem messages.
·     Echo requests—Number of Echo Requests.
·     Echo replies—Number of Echo Replies.
·     Neighbor solicits—Number of Neighbor Solicitation messages.
·     Neighbor adverts—Number of Neighbor Advertisement messages.
·     Router solicits—Number of Router Solicitation messages.
·     Router adverts—Number of Router Advertisement messages.
·     Redirects—Number of Redirect messages.
·     Router renumbering—Number of Router Renumbering messages.
·     Sent failed—Number of messages that were failed to send locally.
·     Rate limitation—Number of unsent messages because of rate limiting.
·     Other errors—Number of messages with other errors.
Received packets:
Total:
Checksum errors:
Too short:
Bad codes:
Unreachable:
Too big:
Hop limit exceeded:
Parameter problems:
Echo requests:
Echo replies:
Neighbor solicits:
Neighbor adverts:
Router solicits:
Router adverts:
Redirects:
Router renumbering:
Unknown info types:
Deliver failed:
Bad length:
Statistics for received ICMPv6 messages:
·     Total—Total number of received messages.
·     Checksum errors—Number of messages with checksum errors.
·     Too short—Number of messages with a too short length.
·     Bad codes—Number of messages with error codes.
·     Unknown error types—Number of messages with unknown error types.
·     Unknown info types—Number of messages with unknown information types.
·     Deliver failed—Number of messages with local delivery failures.
·     Bad length—Number of messages with error length.
display ipv6 tcp
Use display ipv6 tcp to display brief information about IPv6 TCP connections.
In standalone mode:
In IRF mode:
display ipv6 tcp [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays brief information about IPv6 TCP connections for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays brief information about IPv6 TCP connections for all cards. (In IRF mode.)
# (In standalone mode.) Display brief information about IPv6 TCP connections.
<Sysname> display ipv6 tcp
*: TCP connection with authentication
 LAddr->port         FAddr->port       State        Slot  CPU PCB
 LInt
*2001:2002:2003:2   3001:3002:3003:3 ESTABLISHED 1     0    0x000000000000c387
07:2008->1200        07:3008->1200
 N/A
2001::1->23          2001::5->1284     ESTABLISHED 2     0    0x0000000000000008
 N/A
2003::1->25          2001::2->1283     LISTEN       3     0    0x0000000000000009
 N/A
 2003::1->179        fe80::2->1283     LISTEN       3     0   0x000000000000000a
 XGE1/0/2
Table 22 Command output
Indicates that the TCP connection uses authentication.
LAddr->port
Local IPv6 address and port number.
FAddr->port
Peer IPv6 address and port number.
IPv6 TCP connection state:
·     CLOSED—The server receives a disconnection request's reply from the client.
·     LISTEN—The server is waiting for connection requests.
·     SYN_SENT—The client is waiting for the server to reply to the connection request.
·     SYN_RCVD—The server receives a connection request.
·     ESTABLISHED—The server and client have established connections and can transmit data bidirectionally.
·     CLOSE_WAIT—The server receives a disconnection request from the client.
·     FIN_WAIT_1—The client is waiting for the server to reply to a disconnection request.
·     CLOSING—The server and client are waiting for peer's disconnection reply when receiving disconnection requests from each other.
·     LAST_ACK—The server is waiting for the client to reply to a disconnection request.
·     FIN_WAIT_2—The client receives a disconnection reply from the server.
·     TIME_WAIT—The client receives a disconnection request from the server.
PCB
PCB index.
LInt
Local interface. If no input interface is specified for any TCP-based feature (for example, BGP peer) on the local end, this field displays N/A.
display ipv6 tcp verbose
Use display ipv6 tcp verbose to display detailed information about IPv6 TCP connections.
In standalone mode:
In IRF mode:
display ipv6 tcp verbose [ chassis chassis-number slot slot-number [ pcb pcb-index ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays detailed information about IPv6 TCP connections for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays detailed information about IPv6 TCP connections for all cards. (In IRF mode.)
pcb pcb-index: Displays detailed information about IPv6 TCP connections of the specified PCB. The value range for the pcb-index argument is 1 to FFFFFFFFFFFFFFFF.
# (In standalone mode.) Display detailed information about an IPv6 TCP connection.
<Sysname> display ipv6 tcp verbose
 Connection info: src = 2001::1->179 ,  dst = 2001::2->4181
 NSR standby: N/A
 Creator: bgpd[199]
 State: ISCONNECTED
 Options: N/A
 Error: 0
 Receiving buffer(cc/hiwat/lowat/drop/state): 0 / 65536 / 1 / 0 / N/A
 Sending buffer(cc/hiwat/lowat/state): 0 / 65536 / 512 / N/A
 Type: 1
 Protocol: 6
 Inpcb flags: N/A
 Inpcb extflag: N/A
 Connection state: ESTABLISHED
 NSR state: READY(M)
 Send VRF: 0x0
 Receive VRF: 0x0
 Local interface: N/A
 Error count in abnormal-packet-defend period: 0
 Checksum errors: 0
 Duplicate packets: 0
 Part-Duplicate packets: 0
 Out-of-order packets: 0
 Duplicate ACK packets: 0
 Out-of-order ACK packets: 0
 Packets with data out of window: 0
 MD5 authentication errors: 0
 Keychain authentication errors: 0
 Timestamp errors: 0
Maximum Segment Size (MSS): 512
 Window Scale (wscale): 0
 Retransmission Timeout (rto): 3000000.0ms
 Retransmission Count/Total: 0/0
 Round-trip Time (rtt/rtvar): 0.0ms/12000000.0ms
 Delayed Ack Timeout (ato): 100000.0ms
 Congestion Window (cwnd): 1073725440
 TCP Throughput: 0.00 Mbps
 sendpps/sendkbps/recvpps/recvkbps/: 0/0.000/0/0.000
 iss/unack/next/max/wnd: 0/0/0/0/0
 irs/undeliver/next/adv/wnd: 0/0/0/0/0
 NSR Info:
 Total Recv/Send Count(history Recv/history Send): 41/43(41/43)
 EnableMsg Recv/Send Count(history Recv/history Send): 1/2(1/2)
 DisableMsg Recv/Send Count(history Recv/history Send): 0/1(0/1)
 SlotchangeMsg Recv/Send Count(history Recv/history Send): 0/1(0/1)
 ReadyMsg Recv/Send Count(history Recv/history Send): 2/1(2/1)
 PullMsg Recv/Send Count(history Recv/history Send): 2/1(2/1)
 BriefdataMsg Recv/Send Count(history Recv/history Send): 1/2(1/2)
 PktMsg Recv/Send Count(history Recv/history Send): 35/35(35/35)
 CmdMsg Recv/Send Count(history Recv/history Send): 0/0(0/0)
 Recent Recv/Send Seq: 41/43
 Recent Recv/Send Time: 11:14:44:469624 May 23 2022/11:14:44:467624 May 23 2022
 Option Value:
 rcvsb_timeo/sndsb_timeo/pd_type/pd_len: 0/0/0/0
 so_linger: 1
 ka_idle/ka_intval/ka_count: 0/0/0
 so_accept_filter_str: filter1
 Md5 Password:123
 Tcp Key Chain: key123
 Out Interface/NextHop/Local Address: 0/0.0.0.0/0.0.0.0
 Filter Offset/Length/Value/Mask: 0/0/00 00 00 00 00 00 00 00 /00 00 0 00 00 00 00 00
 Ip Tos/McastTTL/McastLoop/ Mcast Interface Index: 192/0/0/0
 Acl Index/MacIndex: 4294967295/4294967295
 Mpls Flag/Label: 0/4294967295
 Kernel Event ID: 0
 Send Mac: 0000-0000-0000
 Bier TTL/Entropy/TunnelID: 0/0/0
Ip Option Hdr: 0x01 02 03
Table 23 Command output
TCP inpcb number
Number of IPv6 TCP Internet PCBs.
Connection info
Connection information, including source IPv6 address, source port number, destination IPv6 address, and destination port number.
Location
Socket location.
NSR standby
tcpcb number
Number of IPv6 TCP PCBs (excluding PCBs of TCP in TIME_WAIT state).
Creator
Socket state:
Options
Socket options:
Error
Error code.
·     cc—Used space.
Sending buffer(cc/hiwat/lowat/drop/state)
·     cc—Used space.
Socket type:
Protocol
Number of the protocol using the socket. 6 represents TCP.
Inpcb flags
Inpcb extflag
·     INP_EXTDONTDROP—Does not drop the received packet.
·     INP_EXLISTEN—Listening socket.
·     INP_EXTFILTER—Filters the contents in the received packets.
Inpcb vflag
IP version flags in the Internet PCB:
Hop limit
Connection state
TCP options
TCP options:
·     TF_DELACK—Delays sending ACK packets.
·     TF_SENTFIN—A FIN packet has been sent.
·     TF_RCVD_SCALE—Requests the receive window size scale factor.
·     TF_RCVD_TSTMP—A timestamp was received in the SYN packet.
·     TF_NEEDSYN—Sends a SYN packet.
·     TF_NEEDFIN—Sends a FIN packet.
·     TF_MORETOCOME—More data is to be added to the socket.
·     TF_LQ_OVERFLOW—The listening queue overflows.
·     TF_LASTIDLE—Idle connection.
·     TF_RXWIN0SENT—A reply with receive window size 0 was sent.
·     TF_FASTRECOVERY—Enters NewReno fast recovery mode.
·     TF_WASFRECOVERY—In NewReno fast recovery mode.
·     TF_SIGNATURE—MD5 signature.
·     TF_FORCEDATA—Forces to send one byte.
·     TF_TSO—TSO is enabled.
·     TF_PMTU—Supports RFC 1191.
·     TF_PMTUD—Starts Path MTU discovery.
·     TF_PASSIVE_CONN—Passive connection.
·     TF_APP_SEND—The application sends data.
·     TF_ABNORMAL_CLOSE—The application was abnormally closed.
·     TF_NODELAY—Disables the Nagle algorithm that buffers the sent data inside the TCP.
·     TF_NOOPT—No TCP options.
·     TF_NOPUSH—Forces TCP to delay sending any TCP data until a full sized segment is buffered in the TCP buffers.
·     TF_NSR—Enables TCP NSR.
·     TF_REQ_SCALE—Enables the TCP window scale option.
·     TF_REQ_TSTMP—Enables the time stamp option.
·     TF_SACK_PERMIT—Enables the TCP selective acknowledgement option.
·     TF_ENHANCED_AUTH—Enables the enhanced authentication option.
NSR state
NSR state of the TCP connection:
·     CLOSED—Closed (initial) state.
·     CLOSING—The connection is to be closed.
·     ENABLED—The connection backup is enabled.
·     OPEN—The connection synchronization has started.
·     PENDING—The connection backup is not ready.
·     READY—The connection backup is ready.
·     SMOOTH—The connection data is being smoothed.
Between the parentheses is the role of the connection:
·     M—Main connection.
·     S—Standby connection.
Send VRF
Receive VRF
Local interface
Interface on the local end. If no input interface is specified for any TCP-based feature (for example, BGP peer) on the local end, this field displays N/A.
Number of error packets received in one abnormal-packet-defend period if attack prevention is enabled for TCP connections.
Checksum errors
Number of received packets with checksum errors.
Duplicate packets
Number of received duplicate packets.
Number of received partially duplicate packets.
Number of received out-of-order packets.
Number of received duplicate ACK packets.
Number of received out-of-order ACK packets.
Number of received packets whose serial number is out of the sliding window range.
Number of packets with failed MD5 authentication.
Number of packets with failed Keychain authentication.
Timestamp errors
Number of packets with timestamp errors.
Maximum segment size.
Window scale.
Retransmission timeout in milliseconds.
Current number retransmissions/total number of retransmissions.
Average round-trip time in milliseconds.
Delayed acknowledgement timeout in milliseconds.
Sequance number of the packet at the congestion window.
TCP Throughput
TCP throughput in Mbps.
sendpps/sendbps/recvpps/recvbps
·     sendpps—Number of packets sent per second.
·     sendbps—Bytes sent per second.
·     recvpps—Number of packets received per second.
·     recvbps—Bytes received per second.
Iss/unack/next/max/wnd
·     Iss—Local initial sequence number.
·     unack—Sequence number of sent packet that has not been acknowledged.
·     next—Sequence number for next sending.
·     max—Maximum sequence number for sending.
·     wnd—Sequence number of the packet at the sending window.
Irs/undeliver/next/adv/wnd
·     Irs—Peer initial sequence number.
·     undeliver—Sequence number of the packet that has not been reported.
·     adv—Size of the receiving buffer.
·     wnd—Sequence number of the packet at the notification receiving window.
Total number of received/sent packets through the LIPC connection between TCP NSR main and standby connections.
Number of received/sent EnableMsg messages through the LIPC connection between TCP NSR main and standby connections.
Number of received/sent DisableMsg messages through the LIPC connection between TCP NSR main and standby connections.
Number of received/sent SlotchangeMsg messages through the LIPC connection between TCP NSR main and standby connections.
Number of received/sent ReadyMsg messages through the LIPC connection between TCP NSR main and standby connections.
Number of received/sent PullMsg messages through the LIPC connection between TCP NSR main and standby connections.
Number of received/sent BriefdataMsg messages through the LIPC connection between TCP NSR main and standby connections.
Number of received/sent PktMsg messages through the LIPC connection between TCP NSR main and standby connections.
Number of received/sent CmdMsg messages through the LIPC connection between TCP NSR main and standby connections.
Number of received/sent history messages through the LIPC connection between TCP NSR main and standby connections.
Sequence number of the message received/sent most recently between TCP NSR main and standby connections.
Absolute time of the most recent message receiving/sending between TCP NSR main and standby connections.
·     rcvsb_timeo—Socket receiving buffer timeout.
·     sndsb_timeo—Socket sending buffer timeout in jiffies.
·     pd_type—Socket private data type.
·     pd_len—Socket private data length in bytes.
so_linger
Socket linger value.
ka_idle/ka_interval/ka_cout
·     ka_idle—Socket keepalive idle timeout.
·     ka_interval—Socket keepalive interval.
·     ka_cout—Socket keepalive count.
Name of the socket packet receiving filter.
Md5 Password
TCP MD5 password.
Tcp Key Chain
TCP keychain name.
·     Out Interface—Outgoing interface.
·     NextHop.
·     Local Address.
Pcb filter offset, length, value, and mask.
Ip Tos/McastTTL/McastLoop/Mcast Interface Index:
·     Ip Tos—IP TOS value.
·     McastTTL—Multicast TTL.
·     McastLoop—Multicast loop.
·     Mcast Interface Index—Multicast interface index.
Acl Index/MacIndex
·     Acl Index—ACL filtering parameters.
·     MacIndex—Layer 2 ACL parameters.
Mpls Flag/Label
MPLS flag and MPLS label.
Send Mac
Peer MAC address specified for packet sending of upper-layer applications.
·     Bier TTL.
·     Entropy—BIER grouping flag.
·     TunnelID—BIER tunnel ID.
Ip Option Hdr
IP options required in a TCP packet.
display ipv6 udp
Use display ipv6 udp to display brief information about IPv6 UDP connections.
In standalone mode:
In IRF mode:
display ipv6 udp [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays brief information about IPv6 UDP connections for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays brief information about IPv6 UDP connections for all cards. (In IRF mode.)
# (In standalone mode.) Displays brief information about IPv6 UDP connections.
<Sysname> display ipv6 udp
 LAddr->port         FAddr->port         Slot  Cpu PCB
 2001:2002:2003:2   3001:3002:3003:3   1      0   0x000000000000c387
 2001::1->23         2001::5->1284       2      0   0x0000000000000008
 2003::1->25         2001::2->1283       3      0   0x0000000000000009
Table 24 Command output
LAddr->port
FAddr->port
PCB
PCB index.
display ipv6 udp verbose
Use display ipv6 udp verbose to display detailed information about IPv6 UDP connections.
In standalone mode:
In IRF mode:
display ipv6 udp verbose [ chassis chassis-number slot slot-number [ pcb pcb-index ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays detailed information about IPv6 UDP connections for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays detailed information about IPv6 UDP connections for all cards. (In IRF mode.)
pcb pcb-index: Displays detailed information about IPv6 UDP connections of the specified PCB. The value range for the pcb-index argument is 1 to FFFFFFFFFFFFFFFF.
# (In standalone mode.) Display detailed information about an IPv6 UDP connection.
<Sysname> display ipv6 udp verbose
Total UDP socket number: 1
 Connection info: src = ::->69, dst = ::->0
 Creator: sock_test_mips[250]
 State: N/A
 Options: N/A
 Error: 0
 Type: 2
 Protocol: 17
 Inpcb flags: N/A
 Inpcb extflag: N/A
 Send VRF: 0xffff
 Receive VRF: 0xffff
Table 25 Command output
Total number of IPv6 UDP sockets.
Connection info
Location
Socket location.
Creator
Task name of the socket. The progress number is in the square brackets.
Socket state:
Options
Socket options:
·     SO_OOBINLINE—Stores the out-o-band data in the input queue.
·     SO_TIMESTAMP—Records the timestamps of the input packets, accurate to milliseconds. This option is applicable to protocols that are not connection orientated.
Error
Error code.
·     cc—Used space.
·     cc—Used space.
Socket type:
Protocol
Number of the protocol using the socket. 17 represents UDP.
Inpcb flags
Inpcb extflag
Inpcb vflag
Hop limit
Send VRF
Receive VRF
ipv6 address
Use ipv6 address to configure an IPv6 global unicast address for an interface.
Use undo ipv6 address to delete an IPv6 global unicast address of the interface.
undo ipv6 address [ ipv6-address prefix-length | ipv6-address/prefix-length ]
No IPv6 global unicast address is configured for an interface.
Interface view
ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies a prefix length in the range of 1 to 128.
Like public IPv4 addresses, IPv6 global unicast addresses are assigned to ISPs. This type of address allows for prefix aggregation to reduce the number of global routing entries.
If you do not specify any parameters, the undo ipv6 address command deletes all IPv6 addresses of an interface.
# Set the IPv6 global unicast address of VLAN-interface 100 to 2001::1 with prefix length 64.
Method 1:
[Sysname-Vlan-interface100] ipv6 address 2001::1/64
Method 2:
[Sysname-Vlan-interface100] ipv6 address 2001::1 64
ipv6 address anycast
Use ipv6 address anycast to configure an IPv6 anycast address for an interface.
Use undo ipv6 address anycast to delete the IPv6 anycast address of the interface.
undo ipv6 address { ipv6-address prefix-length | ipv6-address/prefix-length } anycast
No IPv6 anycast address is configured for an interface.
Interface view
ipv6-address: Specifies an IPv6 anycast address.
# Set the IPv6 anycast address of VLAN-interface 100 to 2001::1 with prefix length 64.
Method 1:
[Sysname-Vlan-interface100] ipv6 address 2001::1/64 anycast
Method 2:
[Sysname-Vlan-interface100] ipv6 address 2001::1 64 anycast
ipv6 address auto
Use ipv6 address auto to enable the stateless address autoconfiguration feature on an interface, so that the interface can automatically generate a global unicast address.
Use undo ipv6 address auto to disable this feature.
ipv6 address auto
The stateless address autoconfiguration feature is disabled.
Interface view
After a global unicast address is generated through stateless autoconfiguration, a link-local address is generated automatically.
To delete the global unicast address and the link-local address that are automatically generated, use either of the following commands:
·     undo ipv6 address auto
·     undo ipv6 address
An interface ID is used for generating the global unicast address and the link-local address for an interface. On an IEEE 802 interface (such as an Ethernet interface or a VLAN interface), the interface ID is derived from the MAC address of the interface. If the MAC address changes, the interface ID, global unicast address, and link-local address will also change. This will cause the entry table to rebuild for some protocols, such as MLD, IPv6 PIM, and OSPFv3. If you do not want this situation to occur, use other IPv6 address configuration methods that do not use MAC addresses, for example, manually specify an IPv6 address.
# Enable stateless address autoconfiguration on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 address auto
ipv6 address auto link-local
Use ipv6 address auto link-local to automatically generate a link-local address for an interface.
Use undo ipv6 address auto link-local to restore the default.
No link-local address is configured on an interface. A link-local address is automatically generated after an IPv6 global unicast address is configured for the interface.
Interface view
Link-local addresses are used for neighbor discovery and stateless autoconfiguration on the local link. Packets using link-local addresses as the source or destination addresses cannot be forwarded to other links.
After an IPv6 global unicast address is configured for an interface, a link-local address is automatically generated. This link-local address is the same as the one generated by using the ipv6 address auto link-local command.
The undo ipv6 address auto link-local command deletes only the link-local addresses generated through the ipv6 address auto link-local command. If the undo command is executed on an interface with an IPv6 global unicast address configured, the interface still has a link-local address.
You can also manually assign an IPv6 link-local address for an interface by using the ipv6 address link-local command. Manual assignment takes precedence over automatic generation for IPv6 link-local addresses.
·     If you first use automatic generation and then manual assignment, the manually assigned link-local address overwrites the automatically generated address.
·     If you first use manual assignment and then automatic generation, both of the following occur:
¡     The automatically generated link-local address does not take effect.
¡     The link-local address of an interface is still the manually assigned address.
If you delete the manually assigned address, the automatically generated link-local address takes effect.
# Configure VLAN-interface 100 to automatically generate a link-local address.
[Sysname-Vlan-interface100] ipv6 address auto link-local
ipv6 address duplicate-detect enable
Use ipv6 address duplicate-detect enable to enable duplicate detection for duplicate addresses.
Use undo ipv6 address duplicate-detect enable to disable duplicate detection for duplicate addresses.
Duplicate detection for duplicate addresses is disabled.
If the device detects that an IPv6 address on an interface has been used on the network, the device marks that IPv6 address as duplicate. The interface cannot use the address for communication.
By default, an interface does not perform duplicate detection for duplicate addresses. Once an IPv6 address is marked as duplicate on an interface, it will be unusable even after it becomes unique on the link later.
To resolve this issue, enable duplicate detection for duplicate addresses. This feature sends NS messages to the duplicate address at random intervals until it does not receive an NA response message from that address or until duplicate detection is disabled for duplicate addresses.
You can set the maximum duplicate detection interval for duplicate addresses by using the ipv6 address duplicate-detect interval command. For more information about duplicate address detection, see IPv6 basics configuration in Layer 3—IP Services Configuration Guide.
# Enable duplicate detection for duplicate addresses.
[Sysname] ipv6 address duplicate-detect enable
Use ipv6 address duplicate-detect interval to set the maximum duplicate detection interval for duplicate addresses.
Use undo ipv6 address duplicate-detect interval to restore the default.
ipv6 address duplicate-detect interval interval
The maximum duplicate detection interval for duplicate addresses is 5 seconds.
interval: Sets the maximum duplicate detection interval for duplicate addresses in seconds. The value range for this argument is 1 to 60.
After the device marks a detected address as duplicate, it waits for a random amount of time between 1 and the maximum detection interval. Then, the device resends an NS message to the solicited-node multicast address of the duplicate address. This mechanism helps reduce the risk of congestion that results from the NS messages sent for duplicate detection. For more information about duplicate address detection, see IPv6 basics configuration in Layer 3—IP Services Configuration Guide.
# Set the maximum duplicate detection interval to 10 seconds for duplicate addresses.
[Sysname] ipv6 address duplicate-detect interval 10
ipv6 address eui-64
Use ipv6 address eui-64 to configure an EUI-64 IPv6 address for an interface.
Use undo ipv6 address eui-64 to delete an EUI-64 IPv6 address from an interface.
undo ipv6 address { ipv6-address prefix-length | ipv6-address/prefix-length } eui-64
No EUI-64 IPv6 address is configured for an interface.
Interface view
ipv6-address prefix-length: Specifies an IPv6 address and IPv6 prefix length. The ipv6-address and prefix-length arguments jointly specify the prefix of an EUI-64 IPv6 address. The value range for the prefix-length argument is 1 to 64. The IPv6 address and IPv6 prefix length support the following formats:
·     ipv6-address/prefix-length. For example: 2001::1/64.
·     ipv6-address prefix-length. For example: 2001::1 64.
An EUI-64 IPv6 address is generated based on the specified prefix and the automatically generated interface ID. To display the EUI-64 IPv6 address, use the display ipv6 interface command. The interface ID is derived from the MAC address of the interface. If the MAC address changes, the interface ID, global unicast address, and link-local address will also change. This will cause the entry table to rebuild for some protocols, such as MLD, IPv6 PIM, and OSPFv3. If you do not want this situation to occur, use other IPv6 address configuration methods that do not use MAC addresses, for example, manually specify an IPv6 address.
The prefix length of an EUI-64 IPv6 address cannot be greater than 64.
# Configure an EUI-64 IPv6 address for VLAN-interface 100. The prefix of the address is the same as that of 2001::1/64, and the interface ID is generated based on the MAC address of the device.
Method 1:
[Sysname-Vlan-interface100] ipv6 address 2001::1/64 eui-64
Method 2:
[Sysname-Vlan-interface100] ipv6 address 2001::1 64 eui-64
Use ipv6 address link-local to configure a link-local address for the interface.
Use undo ipv6 address link-local to restore the default.
ipv6 address { ipv6-address [ prefix-length ] | ipv6-address/prefix-length } link-local
undo ipv6 address { ipv6-address [ prefix-length ] | ipv6-address/prefix-length } link-local
No link-local address is configured for the interface.
Interface view
ipv6-address: Specifies an IPv6 link-local address. The first 10 bits of an address must be 1111111010 (binary). The first group of hexadecimals in the address must be FE80 to FEBF.
prefix-length: Specifies an IPv6 prefix length, in the range of 1 to 128.
Manual assignment takes precedence over automatic generation.
If you use automatic generation, and then use manual assignment, the manually assigned link-local address overwrites the one that is automatically generated.
If you use manual assignment and then use automatic generation, both of the following occur:
·     The automatically generated link-local address does not take effect.
·     The manually assigned link-local address of an interface remains.
After you delete the manually assigned address, the automatically generated link-local address takes effect. For automatic generation of an IPv6 link-local address, see the ipv6 address auto link-local command.
When you configure a link-local address, make sure the prefix length is equal to or greater than 10. Otherwise, the configuration fails.
# Configure a link-local address for VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 address fe80::1 link-local
# Configure a link-local address for VLAN-interface 100 and set the prefix length to 64.
[Sysname-Vlan-interface100] ipv6 address fe80::1 64 link-local
ipv6 address prefix-number
Use ipv6 address prefix-number to specify an IPv6 prefix for an interface to automatically generate an IPv6 global unicast address and advertise the prefix.
Use undo ipv6 address prefix-number to restore the default.
No IPv6 prefix is specified for IPv6 address autoconfiguration.
Interface view
prefix-number: Specifies an IPv6 prefix by its ID in the range of 1 to 1024. The specified IPv6 prefix can be manually configured or obtained through DHCPv6.
sub-prefix: Specifies the sub-prefix bit and host bit for the IPv6 global unicast address.
prefix-length: Specifies the sub-prefix length in the range of 1 to 128.
This command enables an interface to automatically generate an IPv6 global unicast address based on the specified IPv6 prefix, sub-prefix bit, and host bit.
An interface can generate only one IPv6 global unicast address based on the prefix specified by using the ipv6 address command. To configure the interface to generate a new IPv6 address, execute the undo ipv6 address command to delete the configuration, and then execute the ipv6 address command.
# Configure a static IPv6 prefix AAAA::/16 and assign ID 1 to the prefix. Configure VLAN-interface 100 to use this prefix to generate the IPv6 address AAAA:CCCC:DDDD::10/32 and advertise this prefix.
[Sysname] ipv6 prefix 1 AAAA::/16
[Sysname-Vlan-interface100] ipv6 address 1 BBBB:CCCC:DDDD::10/32
# Configure VLAN-interface 10 to obtain an IPv6 prefix through DHCPv6 and assign ID 2 to the obtained prefix. Configure VLAN-interface 100 to use the obtained prefix to generate the IPv6 address AAAA:CCCC:DDDD::10/32 and advertise the prefix.
[Sysname-Vlan-interface10] ipv6 dhcp client pd 2 rapid-commit option-group 1
[Sysname-Vlan-interface10] quit
[Sysname-Vlan-interface100] ipv6 address 2 BBBB:CCCC:DDDD::10/32
ipv6 prefix
ipv6 dhcp client pd
ipv6 extension-header drop enable
Use ipv6 extension-header drop enable to enable a device to discard IPv6 packets that contain extension headers.
Use undo ipv6 extension-header drop enable to disable a device from discarding IPv6 packets that contain extension headers.
A device does not discard IPv6 packets that contain extension headers.
This feature enables a device to discard a received IPv6 packet in which the extension headers cannot be processed by the device.
# Enable the device to discard IPv6 packets that contain extension headers.
[Sysname] ipv6 extension-header drop enable
ipv6 fib consistency-check enable
Use ipv6 fib consistency-check enable to enable IPv6 FIB entry consistency check.
Use undo ipv6 fib consistency-check enable to disable IPv6 FIB entry consistency check.
IPv6 FIB entry consistency check is disabled.
Packet drops or incorrect forwarding might occur when the IPv6 FIB entries in hardware are inconsistent with FIB entries configured in software. To prevent these issues, enable IPv6 FIB entry consistency check.
This feature compares all IPv6 FIB entries in software with the IPv6 FIB entries in hardware regularly. If the device detects an inconsistency, the device performs the following tasks:
·     Generates a log.
·     Updates the IPv6 FIB entry in hardware with the IPv6 FIB entry in software.
# Enable IPv6 FIB entry consistency check.
[Sysname] ipv6 fib consistency-check enable
ipv6 hop-limit
Use ipv6 hop-limit to set the Hop Limit field in the IPv6 header.
Use undo ipv6 hop-limit to restore the default.
ipv6 hop-limit value
undo ipv6 hop-limit
The hop limit is 64.
value: Specifies the number of hops, in the range of 1 to 255.
The hop limit determines the number of hops that an IPv6 packet generated by the device can travel.
The device advertises the hop limit in RA messages. All RA message receivers use the advertised value to fill in the Hop Limit field for IPv6 packets to be sent. To disable the device from advertising the hop limit, use the ipv6 nd ra hop-limit unspecified command.
# Set the maximum number of hops to 100.
[Sysname] ipv6 hop-limit 100
ipv6 hoplimit-expires enable
Use ipv6 hoplimit-expires enable to enable sending ICMPv6 time exceeded messages.
Use undo ipv6 hoplimit-expires to disable sending ICMPv6 time exceeded messages.
undo ipv6 hoplimit-expires enable
Sending ICMPv6 time exceeded messages is enabled.
ICMPv6 time exceeded messages are sent to the source of IPv6 packets after the device discards IPv6 packets because hop or reassembly times out.
To prevent too many ICMPv6 error messages from affecting device performance, disable this feature. Even with the feature disabled, the device still sends fragment reassembly time exceeded messages.
# Disable sending ICMPv6 time exceeded messages.
[Sysname] undo ipv6 hoplimit-expires enable
ipv6 icmpv6 error-interval
Use ipv6 icmpv6 error-interval to set the bucket size and the interval for tokens to arrive in the bucket for ICMPv6 error messages.
Use undo ipv6 icmpv6 error-interval to restore the default.
The bucket allows a maximum of 10 tokens, and a token is placed in the bucket every 100 milliseconds.
interval: Specifies the interval for tokens to arrive in the bucket. The value range is 0 to 2147483647 milliseconds. To disable the ICMPv6 rate limit, set the value to 0.
bucketsize: Specifies the maximum number of tokens allowed in the bucket. The value range is 1 to 200.
This command limits the rate at which ICMPv6 error messages are sent. Use this command to prevent network congestion caused by excessive ICMPv6 error messages generated within a short period. A token bucket algorithm is used with one token representing one ICMPv6 error message.
A token is placed in the bucket at intervals until the maximum number of tokens that the bucket can hold is reached.
A token is removed from the bucket when an ICMPv6 error message is sent. When the bucket is empty, ICMPv6 error messages are not sent until a new token is placed in the bucket.
# Set the bucket size to 40 tokens and the interval for tokens to arrive in the bucket to 200 milliseconds for ICMPv6 error messages.
[Sysname] ipv6 icmpv6 error-interval 200 40
Use ipv6 icmpv6 multicast-echo-reply enable to enable replying to multicast echo requests.
Use undo ipv6 icmpv6 multicast-echo-reply to restore the default.
undo ipv6 icmpv6 multicast-echo-reply enable
The device is disabled from replying to multicast echo requests.
If a host is configured to reply to multicast echo requests, an attacker can use this mechanism to attack the host. For example, the attacker can send an echo request to a multicast address with Host A as the source. All hosts in the multicast group will send echo replies to Host A.
To prevent attacks, do not enable the device to reply to multicast echo requests unless necessary.
# Enable replying to multicast echo requests.
[Sysname] ipv6 icmpv6 multicast-echo-reply enable
ipv6 icmpv6 receive enable
Use ipv6 icmpv6 receive enable to enable the device to receive a specific type of ICMPv6 messages.
Use undo ipv6 icmpv6 receive enable to disable the device from receiving a specific type of ICMPv6 messages.
ipv6 icmpv6 { name name | type type code code } receive enable
undo ipv6 icmpv6 { name name | type type code code } receive enable
The device receives all types of ICMPv6 messages.
name name: Specifies an ICMPv6 message name.
type type: Specifies an ICMPv6 message type. The value range for the type argument is 0 to 255.
code code: Specifies an ICMPv6 message code. The value range for the code argument is 0 to 255.
CAUTION
CAUTION:
Disabling receiving ICMPv6 messages of a specific type might affect network operation. Please use this feature with caution.
By default, the device receives all types of ICMPv6 messages. Such a setting might affect device performance if a large number of ICMPv6 responses are received within a short time. To resolve this issue, you can use this command to disable the device from receiving a specific type of ICMPv6 messages.
Table 26 shows common ICMPv6 messages and their meanings.
Table 26 Common ICMPv6 messages
Name
Code
echo
128
0
Echo request used to ping a target node.
echo-reply
129
0
Echo reply sent by a target node after receiving an echo request.
err-header-field
4
0
Erroneous header field was found.
frag-time-exceeded
3
1
Fragment reassembly timed out.
hop-limit-exceeded
3
0
Hop limit decreased to 0 in transit.
host-admin-prohib
1
1
Communication with the target host was prohibited by the admin policy.
host-unreachable
1
3
The target host address was unreachable.
neighbor-advertisement
136
0
Neighbor advertisement for IPv6 neighbor discovery.
neighbor-solicitation
135
0
Neighbor solicitation for IPv6 neighbor discovery.
network-unreachable
1
0
No route to destination exists.
packet-too-big
2
0
Packet forwarding failed because the packet length was longer than the MTU.
port-unreachable
1
4
The target port was unreachable.
redirect
137
0
Route redirection message.
router-advertisement
134
0
IPv6 router advertisement.
router-solicitation
133
0
IPv6 router solicitation.
unknown-ipv6-opt
4
2
Unknown IPv6 option.
unknown-next-hdr
4
1
Unknown IPv6 Next Header field.
# Disable the device from receiving ICMPv6 echo reply messages.
[Sysname] undo ipv6 icmpv6 name echo-reply receive enable
ipv6 icmpv6 reply source
Use ipv6 icmpv6 reply source to specify a source IPv6 address for outgoing ICMPv6 replies.
Use undo ipv6 icmpv6 reply source to restore the default.
ipv6 icmpv6 reply source [ vpn-instance vpn-instance-name ] { address ipv6-address | interface interface-type [ interface-number ] }
undo ipv6 icmpv6 reply source [ vpn-instance vpn-instance-name ]
No source IPv6 address is specified for outgoing ICMPv6 replies.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the specified address belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
interface interface-type [ interface-number ]: Specifies an interface. The device uses the IPv6 address of this interface as the source IPv6 address for outgoing ICMPv6 replies.
# Specify 1::1 as the source IPv6 address for outgoing ICMPv6 replies.
[Sysname] ipv6 icmpv6 reply source address 1::1
ipv6 icmpv6 source
ipv6 icmpv6 send enable
Use ipv6 icmpv6 send enable to enable the device to send a specific type of ICMPv6 messages.
Use undo ipv6 icmpv6 send enable to disable the device from sending a specific type of ICMPv6 messages.
ipv6 icmpv6 { name name | type type code code } send enable
undo ipv6 icmpv6 { name name | type type code code } send enable
The device can send all types of ICMPv6 messages except Destination Unreachable and Redirect messages.
CAUTION
CAUTION:
Disabling sending ICMPv6 messages of a specific type might affect network operation. Please use this feature with caution.
By default, the device sends all types of ICMPv6 messages except Destination Unreachable and Redirect messages. Attackers might obtain device information from specific types of ICMPv6 messages, causing security issues.
For security purposes, you can use this command to disable the device from sending specific types of ICMPv6 messages.
To enable sending Destination Unreachable, Time Exceeded, or Redirect messages, you can perform one of the following tasks:
·     Execute the ipv6 icmpv6 send enable command.
·     Execute one of the following commands as needed:
¡     ipv6 unreachables enable
¡     ipv6 hoplimit-expires enable
¡     ipv6 redirects enable
# Disable the device from sending ICMPv6 echo reply messages.
[Sysname] undo ipv6 icmpv6 name echo-reply send enable
ipv6 icmpv6 source
Use ipv6 icmpv6 source to specify a source IPv6 address for unsolicited ICMPv6 packets.
Use undo ipv6 icmpv6 source to restore the default.
undo ipv6 icmpv6 source [ vpn-instance vpn-instance-name ]
No IPv6 source address is specified for unsolicited ICMPv6 packets.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the specified address belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the ipv6-address argument specifies an IPv6 address on the public network. The specified VPN instance must already exist.
For ICMPv6 echo requests, the source IPv6 address specified in the ping ipv6 command has higher priority than the source IPv6 address specified in this command.
# Specify IPv6 address 1::1 as the source address for unsolicited ICMPv6 packets.
[Sysname] ipv6 icmpv6 source 1::1
ipv6 mtu
Use ipv6 mtu to set the interface MTU for IPv6 packets.
Use undo ipv6 mtu to restore the default.
ipv6 mtu size
undo ipv6 mtu
The interface MTU is not configured.
Interface view
size: Specifies the MTU size in bytes. The value range for this argument is 1280 to 9198.
If the size of a packet exceeds the MTU of the sending interface, the device discards the packet. If the device is an intermediate device, it also sends the source host an ICMPv6 Packet Too Big message with the MTU of the sending interface. The source host fragments the packets according to the MTU. To avoid this situation, set a proper interface MTU.
After you configure both the ipv6 mtu and ip mtu commands on an interface, the device processes the Layer 3 unicast packets received on that interface as follows:
·     When the following conditions exist, the device delivers an IPv6 Layer 3 unicast packet to the CPU for software forwarding, and then forwards that packet without fragmentation:
¡     The specified IPv6 MTU is larger than the specified IPv4 MTU.
¡     The length of the IPv6 Layer 3 unicast packet is in the range of the IPv4 MTU to the IPv6 MTU.
·     When the following conditions exist, the device delivers an IPv4 Layer 3 unicast packet to the CPU for software forwarding, and then forwards that packet after fragmentation:
¡     The specified IPv6 MTU is smaller than the specified IPv4 MTU.
¡     The length of the IPv4 Layer 3 unicast packet is in the range of the IPv6 MTU to the IPv4 MTU.
# Set the interface MTU for IPv6 packets to 1280 bytes on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 mtu 1280
# Set the interface MTU for IPv6 packets to 1280 bytes on VSI-interface 10.
[Sysname] interface vsi-interface 10
[Sysname-Vsi-interface10] ipv6 mtu 1280
Use ipv6 nd autoconfig managed-address-flag to set the managed address configuration flag (M) to 1 in RA advertisements to be sent.
Use undo ipv6 nd autoconfig managed-address-flag to restore the default.
The M flag is set to 0 in RA advertisements. Hosts receiving the advertisements will obtain IPv6 addresses through stateless autoconfiguration.
Interface view
The M flag in RA advertisements determines whether receiving hosts use stateful autoconfiguration to obtain IPv6 addresses.
·     If the M flag is set to 1 in RA advertisements, receiving hosts use stateful autoconfiguration (for example, from an DHCPv6 server) to obtain IPv6 addresses.
·     If the M flag is set to 0 in RA advertisements, receiving hosts use stateless autoconfiguration. Stateless autoconfiguration generates IPv6 addresses according to link-layer addresses and the prefix information in the RA advertisements.
# Set the M flag to 1 in RA advertisements to be sent.
[Sysname-Vlan-interface100] ipv6 nd autoconfig managed-address-flag
ipv6 nd autoconfig other-flag
Use ipv6 nd autoconfig other-flag to set the other stateful configuration flag (O) to 1 in RA advertisements to be sent.
Use undo ipv6 nd autoconfig other-flag to restore the default.
The O flag is set to 0 in RA advertisements. Hosts receiving the advertisements will acquire other information through stateless autoconfiguration.
Interface view
The O flag in RA advertisements determines whether receiving hosts use stateful autoconfiguration to obtain configuration information other than IPv6 addresses.
·     If the O flag is set to 1 in RA advertisements, receiving hosts use stateful autoconfiguration (for example, from a DHCPv6 server) to obtain configuration information other than IPv6 addresses.
·     If the O flag is set to 0 in RA advertisements, receiving hosts use stateless autoconfiguration to obtain configuration information other than IPv6 addresses.
# Set the O flag to 0 in RA advertisements to be sent.
[Sysname-Vlan-interface100] undo ipv6 nd autoconfig other-flag
ipv6 nd consistency-check enable
Use ipv6 nd consistency-check enable to enable ND entry consistency check.
Use undo ipv6 nd consistency-check enable to disable ND entry consistency check.
ND entry consistency check is disabled.
Packet drops or incorrect forwarding might occur when the ND entries in hardware are inconsistent with ND entries configured in software. To prevent these issues, enable ND entry consistency check.
This feature compares all ND entries in software with the ND entries in hardware regularly. If the device detects an inconsistency, the device performs the following tasks:
·     Generates a log.
·     Updates the ND entry in hardware with the ND entry in software.
# Enable ND entry consistency check.
[Sysname] ipv6 nd consistency-check enable
ipv6 nd dad attempts
Use ipv6 nd dad attempts to set the number of attempts to send an NS message for DAD.
Use undo ipv6 nd dad attempts to restore the default.
ipv6 nd dad attempts times
The number of attempts to send an NS message for DAD is 1.
Interface view
times: Specifies the number of attempts to send an NS message for DAD, in the range of 0 to 600. If it is set to 0, DAD is disabled.
An interface sends an NS message for DAD after obtaining an IPv6 address.
If the interface does not receive a response within the time specified by using ipv6 nd ns retrans-timer, it resends an NS message.
If the interface receives no response after making the maximum sending attempts (set by using ipv6 nd dad attempts), the interface uses the obtained address.
# Set the number of attempts to send an NS message for DAD to 20.
[Sysname-Vlan-interface100] ipv6 nd dad attempts 20
ipv6 nd entry-limit record enable
Use ipv6 nd entry-limit record enable to enable recording ND entry learning events.
Use undo ipv6 nd entry-limit record enable to disable recording ND entry learning events.
The ND module does not record ND entry learning events.
(In IRF mode.) (In standalone mode.) An ND entry learning event occurs when the number of ND entries that a card or an interface has learnt exceeds the threshold or drops below the threshold.
After you enable this feature, the ND module logs ND entry learning events and sends them to the information center. For log messages to be sent correctly, configure the information center to set log message filtering and output rules, including output destinations. For information about the log destination and output rule configuration in the information center, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable recording ND entry learning events.
[Sysname] ipv6 nd entry-limit record enable
ipv6 neighbors max-learning-num
ipv6 neighbors max-learning-number
ipv6 nd fib-miss drop
Use ipv6 nd fib-miss drop to disable the device from sending NS messages for ND entry learning when IPv6 data packets trigger ND resolution.
Use undo ipv6 nd fib-miss drop to restore the default.
The device sends NS messages for ND entry learning when IPv6 data packets trigger ND resolution.
Layer 3 aggregation interface view
Layer 3 aggregation subinterface view
VSI interface view
VLAN interface view
Application scenarios
By default, when the device receives a data packet not destined for it and cannot find a match for the next hop in the ND table, it performs the following tasks:
1.     Multicasts an NS message to obtain the MAC address of the next hop.
2.     Generates an ND entry based on the obtained MAC address.
A large number of NS messages consume too many network resources, affecting normal service operation. To resolve the issue, use this command to disable the device from sending NS messages for ND entry learning when IPv6 data packets trigger ND resolution. This suppresses ND flooding by reducing ND packets on the network.
Operating mechanism
After you configure this feature on an interface of the device, the device does not multicast an NS message for ND entry learning if one of the following conditions exists:
·     The interface receives a data packet not destined for the device and the next hop for the data packet does not match any ND entry.
·     ND resolution is triggered when the interface actively sends a data packet.
As a best practice, configure this feature only when the network is under ND flood attacks.
# Enable VLAN-interface 100 to disable the device from sending NS messages for ND entry learning when IPv6 data packets trigger ND resolution.
[Sysname-Vlan-interface100] ipv6 nd fib-miss drop
ipv6 nd hardware log enable
Use ipv6 nd hardware log enable to enable logging ND entry deployment events.
Use undo ipv6 nd hardware log enable to disable logging ND entry deployment events.
ipv6 nd hardware log enable [ count-limit count-limit-value ]
The device does not log the events that occur during ND entry deployment to hardware.
count-limit count-limit-value: Set the maximum number of log entries that the device can generate per second for ND deployment events. The value range for the count-limit-value argument is 1 to 2000. If you do not specify this option, the device can generate up to 2000 log entries per second for ND deployment events.
After learning an ND entry, the device deploys that ND entry to hardware for packet forwarding. To record the events that occur during ND entry deployment to hardware, you can use this command. This command enables the device to generate log messages for ND deployment events and deliver such log messages to the information center.
For log messages to be sent correctly, configure the information center to set log message filtering and output rules, including output destinations. For information about information center configuration, see information center configuration in Network Management and Monitoring Configuration Guide.
Log generation consumes memory resources. To save device memory, enable this feature only when you need to troubleshoot traffic forwarding issues. If the number of log messages generated by the device per second reaches the limit, the device will not generate any log message for a new ND deployment event.
# Enable logging the events that occur during ND entry deployment to hardware and set the maximum number of log entries to 100.
[Sysname] ipv6 nd hardware log enable count-limit 100
ipv6 nd local-proxy dad forward enable
Use ipv6 nd local-proxy dad forward enable to enable Duplicate Address Detection (DAD) message forwarding for a VSI.
Use undo ipv6 nd local-proxy dad forward enable to disable DAD message forwarding for a VSI.
DAD message forwarding is enabled for a VSI.
VSI view
When an access user in an authentication domain initiates an authentication request, the device looks for an available authentication server. If all authentication servers in that authentication domain are detected unavailable, the device changes to the critical state (also known as the fail-permit state). In this state, the device assigns the access user to the critical domain (also known as the fail-permit domain) so that the user can come online in the critical domain without being authenticated. If the local ND proxy feature is enabled by using the local-proxy-nd enable command, the device discards the DAD NS and NA messages received from the VSI of the critical domain instead of forwarding those messages.
Operating mechanism
With DAD message forwarding enabled, the device forwards the DAD NS and NA messages received from the VSI of the critical domain.
Recommended configuration
Enable this feature only for the VSIs associated with critical domains.
If you disable this feature for a VSI, the device directly discards the DAD NS and NA messages received from that VSI.
# Disable DAD message forwarding for VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa] undo ipv6 nd local-proxy dad forward enable
ipv6 nd mode uni
Use ipv6 nd mode uni to configure a port as a customer-side port.
Use undo ipv6 nd mode to restore the default.
ipv6 nd mode uni
undo ipv6 nd mode
A port acts as a network-side port.
VLAN interface view
VSI interface view
By default, a port operates as the network-side port. The device associates an ND entry with routing information when the interface learns an ND entry. The ND entry provides the next hop information for routing. Restricted to the hardware next hop resources on the device, the maximum number of dynamic ND entries that a network-side port can learn might be smaller than the value you set.
When the port operates as the customer-side port, the device will not associate the routing information with the learned ND entries, thus saving hardware resources.
The maximum number of dynamic ND entries that a customer-side port can learn is different than a network-side port. Select the operating mode for a port according to the port location in your live network.
# Specify VLAN-interface 2 as a customer-side port.
[Sysname-Vlan-interface2] ipv6 nd mode uni
Use ipv6 nd ns retrans-timer to set the interval for retransmitting an NS message.
Use undo ipv6 nd ns retrans-timer to restore the default.
The local interface sends NS messages at every an interval of 1000 milliseconds, and the Retrans Timer field in the RA messages sent is 0. The interval for retransmitting an NS message is determined by the receiving device.
Interface view
value: Specifies the interval value in the range of 1000 to 4294967295 milliseconds.
If a device does not receive a response from the peer within the specified interval, the device resends an NS message. The device retransmits an NS message at the specified interval and uses the interval value to fill the Retrans Timer field in RA messages to be sent.
# Specify VLAN-interface 100 to retransmit NS messages every 10000 milliseconds.
[Sysname-Vlan-interface100] ipv6 nd ns retrans-timer 10000
ipv6 nd nud reachable-time
Use ipv6 nd nud reachable-time to set the neighbor reachable time on an interface.
Use undo ipv6 nd nud reachable-time to restore the default.
The neighbor reachable time on the local interface is 1200000 milliseconds, and the value of the Reachable Time field in RA messages is 0. The reachable time is determined by the receiving device.
Interface view
time: Specifies the neighbor reachable time in the range of 1 to 3600000 milliseconds.
If the neighbor reachability detection shows that a neighbor is reachable, the device considers the neighbor reachable within the specified reachable time. If the device must send a packet to the neighbor after the specified reachable time expires, the device reconfirms whether the neighbor is reachable. The device sets the specified value as the neighbor reachable time on the local interface and uses the value to fill the Reachable Time field in RA messages to be sent.
# Set the neighbor reachable time on VLAN-interface 100 to 10000 milliseconds.
[Sysname-Vlan-interface100] ipv6 nd nud reachable-time 10000
ipv6 nd online-offline-log enable
Use ipv6 nd online-offline-log enable to enable ND logging for user online and offline events.
Use undo ipv6 nd online-offline-log enable to disable ND logging for user online and offline events.
ipv6 nd online-offline-log enable [ rate rate ]
ND logging for user online and offline events is disabled.
rate rate: Specifies the maximum number of logs that can be output per second. The value range is 3 to 500. If you do not specify this option, the maximum log output rate is 100 logs per second.
A higher log output rate consumes more CPU resources. Adjust the log output rate based the CPU performance and usage.
# Enable ND logging for user online and offline events, and set the maximum log output rate to 100 logs per second.
[Sysname] ipv6 nd online-offline-log enable rate 100
ipv6 neighbor
ipv6 nd proxy-forwarding
Use ipv6 nd proxy-forwarding to enable ND proxy forwarding.
Use undo ipv6 nd proxy-forwarding to restore the default.
ND proxy forwarding is disabled.
VLAN interface view
With this feature enabled on an interface, the device issues dynamic and static ND entries that use the interface as the output interface only to proxy service modules. When a principal service module receives a packet whose destination IPv6 address resides on the same subnet with the interface, it delivers the packet to a proxy service module based on load sharing. The proxy service module will re-encapsulate and forward the packet out of the interface.
This feature allows only proxy service modules to learn ND entries and forward packets. To ensure ND learning and packet forwarding, you must specify a proxy service module before you enable this feature. As a best practice, specify a service module with high performance as a proxy service module.
# Enable ND proxy forwarding on VLAN-interface 10.
[Sysname-Vlan-interface10] ipv6 nd proxy-forwarding
ipv6 nd ra boot-file-url
Use ipv6 nd ra boot-file-url to specify the URL of the boot file in RA messages.
Use undo ipv6 nd ra boot-file-url to restore the default.
ipv6 nd ra boot-file-url url-string
RA messages do not contain the URL of the boot file.
Interface view
url-string: Specifies the URL address of the boot file, a case-sensitive string of 1 to 127 characters. The URL address must be started with http://, https://. ftp://, or tftp://.
On some networks, a device follows the steps to implement automatic configuration:
1.     Obtains an IPv6 address through ND or DHCPv6.
2.     Obtains the URL address for downloading the boot file from the DHCPv6 server.
3.     Downloads the boot file from the FTP server and installs it.
With the boot file URL specified in RA messages, the device can use the ND protocol to obtain both the IPv6 address and the boot file URL for automatic configuration. DHCPv6 is not required in the network, simplifying the network deployment.
# Specify the boot file URL address as tftp://169.254.0.1/file/softimg.iso in RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra boot-file-url tftp://169.254.0.1/file/softimg.iso
ipv6 nd ra dns search-list
Use ipv6 nd ra dns search-list to specify DNS suffix information to be advertised in RA messages.
Use undo ipv6 nd ra dns search-list to remove a DNS suffix from RA message advertisement.
undo ipv6 nd ra dns search-list domain-name
DNS suffix information is not specified and RA messages do not contain DNS suffix options.
Interface view
domain-name: Specifies a DNS suffix. It is a dot-separated, case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.), for example, aabbcc.com. The DNS suffix can include a maximum of 253 characters, and each separated string includes no more than 63 characters.
seconds: Specifies the lifetime of the DNS suffix, in seconds. The value range is 4 to 4294967295. Value 4294967295 indicates that the lifetime of the DNS suffix is infinite.
infinite: Sets the lifetime of the DNS suffix to infinite.
seqno: Specifies the sequence number of the DNS suffix, in the range of 0 to 4294967295. The sequence number for a DNS suffix must be unique. A smaller sequence number represents a higher priority.
The DNS search list (DNSSL) option in RA messages provides DNS suffix information for hosts. The RA messages allow hosts to obtain their IPv6 addresses and the DNS suffix through stateless autoconfiguration. This method is useful in a network where DHCPv6 infrastructure is not provided.
The default lifetime of the DNS suffix is three times the maximum interval for advertising RA messages. To set the maximum interval, use the ipv6 nd ra interval command.
You can configure a maximum of eight DNS suffixes on an interface. One DNSSL option contains one DNS suffix. All DNSSL options are sorted in ascending order of the sequence number of the DNS suffix.
The sequence number uniquely identifies a DNS suffix. To modify a DNS suffix or its sequence number, you must first use the undo ipv6 nd ra dns search-list command to remove the DNS suffix from RA message advertisement.
After you execute the ipv6 nd ra dns search-list command, the device immediately sends an RA message with the existing and newly specified DNS suffix information.
After you execute the undo ipv6 nd ra dns search-list command, the device immediately sends two RA messages.
·     The first RA message contains information about all DNS suffixes, including DNS suffixes specified in the undo command with their lifetime set to 0 seconds.
·     The second RA message contains information about remaining DNS suffixes.
Each time the device sends an RA message from an interface, it immediately refreshes the RA message advertisement interval for that interface.
# Specify the DNS suffix as com, the suffix lifetime as infinite, and the sequence number as 1 for RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra dns search-list com infinite sequence 1
ipv6 nd ra dns search-list suppress
ipv6 nd ra interval
Use ipv6 nd ra dns search-list suppress to enable DNS suffix suppression in RA messages.
Use undo ipv6 nd ra dns search-list suppress to disable DNS suffix suppression in RA messages.
DNS suffix suppression in RA messages is disabled.
Interface view
This command suppresses advertising DNS suffixes in RA messages on an interface. If you specify a new DNS suffix or remove a DNS suffix on the interface, the device immediately sends an RA message without any DNSSL options.
RA messages are suppressed by default. To disable RA message suppression, use the undo ipv6 nd ra halt command.
Whether enabling this feature on an interface will trigger sending RA message immediately depends on the interface configuration:
·     If the interface has DNS suffix information configured, the device immediately sends two RA messages. In the first message, the lifetime for DNS suffixes is 0 seconds. The second RA message does not contain any DNSSL options.
·     If the interface has no DNS suffix information specified, no RA messages are triggered.
Whether disabling this feature on an interface will trigger sending RA message immediately depends on the interface configuration:
·     If the interface has DNS suffix information configured, the device immediately sends an RA message containing the configured lifetime of the DNS suffix.
# Enable DNS suffix suppression in RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra dns search-list suppress
ipv6 nd ra dns server
Use ipv6 nd ra dns server to specify DNS server information to be advertised in RA messages.
Use undo ipv6 nd ra dns server to remove a DNS server from RA message advertisement.
undo ipv6 nd ra dns server ipv6-address
DNS server information is not specified and RA messages do not contain DNS server options.
Interface view
ipv6-address: Specifies the IPv6 address of the DNS server, which must be a global unicast address or a link-local address.
seconds: Specifies the lifetime of the DNS server, in seconds. The value range is 4 to 4294967295. Value 4294967295 indicates that the lifetime of the DNS server is infinite.
infinite: Sets the lifetime of the DNS server to infinite.
sequence seqno: Specifies the sequence number of the DNS server, in the range of 0 to 4294967295. The sequence number for a DNS server must be unique. A smaller sequence number represents a higher priority.
The DNS server option in RA messages provides DNS server information for hosts. The RA messages allow hosts to obtain their IPv6 addresses and the DNS server through stateless autoconfiguration. This method is useful in a network where DHCPv6 infrastructure is not provided.
The default lifetime of the DNS server is three times the maximum interval for advertising RA messages. To set the maximum interval, use the ipv6 nd ra interval command.
You can configure a maximum of eight DNS servers on an interface. One DNS server option contains one DNS server. All DNS server options are sorted in ascending order of the DNS server sequence number.
The sequence number uniquely identifies a DNS server. To modify the IPv6 address or sequence number of a DNS server, you must first use the undo ipv6 nd ra dns server command to remove the DNS server from RA message advertisement.
After you execute the ipv6 nd ra dns server command, the device immediately sends an RA message with the existing and newly specified DNS server options.
After you execute the undo ipv6 nd ra dns server command, the device immediately sends two RA messages.
·     The first RA message contains information about all DNS servers, including the DNS servers specified in the undo command with their lifetime set to 0 seconds.
·     The second RA message contains information about remaining DNS servers.
# Specify the DNS server address as 2001:10::100, the server lifetime as infinite, and the sequence number as 1 for RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra dns server 2001:10::100 infinite sequence 1
ipv6 nd ra dns server suppress
ipv6 nd ra interval
Use ipv6 nd ra dns server suppress to enable DNS server suppression in RA messages.
Use undo ipv6 nd ra dns server suppress to disable DNS server suppression in RA messages.
DNS server suppression in RA messages is disabled.
Interface view
This command suppresses advertising DNS server addresses in RA messages on an interface. If you specify a new DNS server or remove a DNS server on the interface, the device immediately sends an RA message without any DNS server options.
·     If the interface has DNS server information configured or has obtained an AAA-authorized DNS server address, the device immediately sends two RA messages. In the first message, the lifetime for DNS server addresses is 0 seconds. The second RA message does not contain any DNS server options.
·     If the interface has no DNS server information specified or no AAA-authorized DNS server address assigned, no RA messages are triggered.
·     If the interface has DNS server information configured or has obtained an AAA-authorized DNS server address, the device immediately sends an RA message containing the DNS server information.
# Enable DNS server suppression in RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra dns server suppress
ipv6 nd ra halt
Use ipv6 nd ra halt to suppress an interface from advertising RA messages.
Use undo ipv6 nd ra halt to disable this feature.
ipv6 nd ra halt
An interface is suppressed from sending RA messages.
Interface view
# Disable RA message suppression on VLAN-interface 100.
[Sysname-Vlan-interface100] undo ipv6 nd ra halt
Use ipv6 nd ra hop-limit unspecified to specify unlimited hops in RA messages.
Use undo ipv6 nd ra hop-limit unspecified to restore the default.
The maximum number of hops in the RA messages is limited to 64.
Interface view
To set the maximum number of hops to a value rather than the default setting, use the ipv6 hop-limit command.
# Specify unlimited hops in the RA messages on VLAN-interface 100.
[Sysname-Vlan-interface10] ipv6 nd ra hop-limit unspecified
ipv6 hop-limit
ipv6 nd ra interval
Use ipv6 nd ra interval to set the maximum and minimum intervals for advertising RA messages.
Use undo ipv6 nd ra interval to restore the default.
The maximum interval between RA messages is 600 seconds, and the minimum interval is 200 seconds.
Interface view
max-interval: Specifies the maximum interval value in seconds, in the range of 4 to 1800.
min-interval: Specifies the minimum interval value in the range of 3 seconds to three-fourths of the maximum interval.
The device advertises RA messages randomly between the maximum interval and the minimum interval.
The maximum interval for sending RA messages should be less than or equal to the router lifetime in RA messages.
# Set the maximum interval for advertising RA messages to 1000 seconds and the minimum interval to 700 seconds.
[Sysname-Vlan-interface100] ipv6 nd ra interval 1000 700
ipv6 nd ra router-lifetime
ipv6 nd ra no-advlinkmtu
Use ipv6 nd ra no-advlinkmtu to turn off the MTU option in RA messages.
Use undo ipv6 nd ra no-advlinkmtu to restore the default.
RA messages contain the MTU option.
Interface view
The MTU option in the RA messages specifies the link MTU to ensure that all nodes on the link use the same MTU.
# Turn off the MTU option in RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra no-advlinkmtu
ipv6 nd ra prefix
Use ipv6 nd ra prefix to configure the prefix information in RA messages.
Use undo ipv6 nd ra prefix to restore the default.
ipv6 nd ra prefix { ipv6-prefix prefix-length | ipv6-prefix/prefix-length } [ valid-lifetime preferred-lifetime [ no-autoconfig | off-link | prefix-preference level ] * | no-advertise ]
undo ipv6 nd ra prefix { ipv6-prefix | ipv6-prefix/prefix-length }
No prefix information is configured for RA messages. Instead, the IPv6 address of the interface sending RA messages is used as the prefix information.
If the IPv6 address is manually configured, the prefix uses the fixed valid lifetime 2592000 seconds (30 days) and preferred lifetime 604800 seconds (7 days).
If the IPv6 address is automatically obtained (through DHCP, for example), the prefix uses the valid and preferred lifetime of the IPv6 address.
Interface view
ipv6-prefix: Specifies the IPv6 prefix.
prefix-length: Specifies the prefix length of the IPv6 address.
valid-lifetime: Specifies the valid lifetime of a prefix, in the range of 0 to 4294967295 seconds. The default value is 2592000 seconds (30 days).
preferred-lifetime: Specifies the preferred lifetime of a prefix used for stateless autoconfiguration, in the range of 0 to 4294967295 seconds. The preferred lifetime cannot be longer than the valid lifetime. The default value is 604800 seconds (7 days).
no-autoconfig: Specifies a prefix not to be used for stateless autoconfiguration. If you do not specify this keyword, the prefix is used for stateless autoconfiguration.
off-link: Indicates that the address with the prefix is not directly reachable on the link. If you do not specify this keyword, the address with the prefix is directly reachable on the link.
prefix-preference level: Specifies the prefix preference. The level argument specifies the preference value in the range of 0 to 255. A larger value indicates a higher preference. The client selects an IPv6 prefix with the highest preference for address generation. If you do not specify this option, the RA message does not contain the preference for the prefix.
no-advertise: Disables the device from advertising the prefix specified in this command. If you do not specify this keyword, the device advertises the prefix specified in this command.
After hosts on the same link receive RA messages, they can use the prefix information in the RA messages for stateless autoconfiguration.
A prefix specified without a parameter in this command preferentially uses the default settings configured by using the ipv6 nd ra prefix default command. If the default settings are unavailable, the prefix uses the following settings:
·     Valid lifetime of 2592000 seconds (30 days).
·     Preferred lifetime of 604800 seconds (7 days).
·     The prefix is used for stateless autoconfiguration.
·     The address with the prefix is directly reachable on the link.
·     The prefix is advertised in RA messages.
# Configure the prefix information in RA messages on VLAN-interface 100.
Method 1:
[Sysname-Vlan-interface100] ipv6 nd ra prefix 2001:10::100/64 100 10
Method 2:
[Sysname-Vlan-interface100] ipv6 nd ra prefix 2001:10::100 64 100 10
Use ipv6 nd ra prefix default to configure the default settings for prefixes advertised in RA messages.
Use undo ipv6 nd ra prefix default to restore the default.
ipv6 nd ra prefix default [ valid-lifetime preferred-lifetime [ no-autoconfig | off-link ] * | no-advertise ]
No default settings are configured for prefixes advertised in RA messages.
Interface view
This command specifies the default settings for the prefix specified by using the ipv6 nd ra prefix command. If none of the parameters (valid-lifetime, preferred-lifetime, no-autoconfig, off-link, and no-advertise) is configured in the ipv6 nd ra prefix command, the prefix uses the default settings.
# Configure the default settings for prefixes advertised in RA messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra prefix default 100 10
Use ipv6 nd ra router-lifetime to set the router lifetime in RA messages.
Use undo ipv6 nd ra router-lifetime to restore the default.
The router lifetime in RA messages is three times the maximum interval for advertising RA messages.
Interface view
time: Specifies the router lifetime in the range of 0 to 9000 seconds. If the value is set to 0, the router does not act as the default router.
The router lifetime in RA messages specifies how long the router sending the RA messages acts as the default router. Hosts receiving the RA messages check this value to determine whether to use the sending router as the default router. If the router lifetime is 0, the router cannot be used as the default router.
The router lifetime in RA messages must be greater than or equal to the advertising interval.
# Set the router lifetime in RA messages on VLAN-interface 100 to 1000 seconds.
[Sysname-Vlan-interface100] ipv6 nd ra router-lifetime 1000
ipv6 nd ra interval
ipv6 nd route-direct advertise
Use ipv6 nd route-direct advertise to enable ND direct route advertisement.
Use undo ipv6 nd route-direct advertise to disable ND direct route advertisement.
ipv6 nd route-direct advertise [ preference preference-value | tag tag-value ] *
The ND direct route advertisement feature is disabled.
Interface view
preference preference-value: Sets a preference value for ND-advertised direct routes. The value range for the preference-value argument is 1 to 255, and the default is 0. A smaller value represents a higher priority.
tag tag-value: Sets a tag value for ND-advertised direct routes. The value range for the tag-value argument is 1 to 4294967295, and the default is 0.
With ND direct route advertisement enabled, ND advertises ND entries to the route management module to generate direct routes. The route preference value determines the match order of a route. Dynamic routing protocols use the tag value as the route identifier when redistributing a direct route.
# Enable ND direct route advertisement for VLAN-interface 100, and set both the preference value and tag value to 2 for direct routes.
[Sysname-Vlan-interface100] ipv6 nd route-direct advertise preference 2 tag 2
# Enable ND direct route advertisement for VSI-interface 1, and set both the preference value and tag value to 2 for direct routes.
[Sysname-Vsi-interface1] ipv6 nd route-direct advertise preference 2 tag 2
ipv6 nd route-direct advertise delay
ipv6 nd route-direct prefix convert-length
Use ipv6 nd route-direct advertise delay to set the delay time for ND direct route generation.
Use undo ipv6 nd route-direct advertise delay to restore the default.
ipv6 nd route-direct advertise delay delay-time
The device does not delay ND direct route generation.
VLAN interface view
VSI interface view
delay-time: Specifies the delay time for ND direct route generation, in the range of 0 to 3600 seconds.
After you enable ND direct route advertisement by using the ipv6 nd route-direct advertise command, the device uses ND entries to generate direct routes and adjacency entries. If the direct routes are generated earlier than the adjacency entries, packet loss will occur due to lack of Layer 2 information during packet encapsulation. To avoid such an issue, use this command to set the delay time for ND direct route generation.
Operating mechanism
You can enable ND direct route advertisement before or after setting the delay time for ND direct route generation. If you enable ND direct route advertisement after setting the delay time, the system will generate ND direct routes after the delay time.
After you enable ND direct route advertisement and set the delay time for ND direct route generation, the device starts a timer after it has learned an ND entry. Then, it generates an ND direct route when the timer value reaches the delay time. If you edit the direct route advertisement configuration within the delay time, the device immediately advertises the direct route with the new configuration. If you set a new delay time before the timer value reaches the original delay time, the device does not reset the timer and performs one of the following tasks:
·     If the timer value is greater than the new delay time, the device immediately generates an ND direct route.
·     If the timer value is less than the new delay time, the device generates a ND direct route when the new delay time is reached.
# Set the delay time for ND direct route generation on VLAN-interface 10.
[Sysname-Vlan-interface100] ipv6 nd route-direct advertise delay 200
Use ipv6 nd route-direct prefix convert-length to specify a prefix length for generating a network route for identified ND entries.
Use undo ipv6 nd route-direct prefix to restore the default.
ipv6 nd route-direct prefix ipv6-prefix prefix-length convert-length convert-length
undo ipv6 nd route-direct prefix ipv6-prefix prefix-length
No prefix length is specified for generating a network route for identified ND entries. The device generates 128-bit host routes based on ND entries.
Interface view
ipv6-prefix: Specifies an IPv6 prefix.
prefix-length: Specifies an IPv6 prefix length in the range of 1 to 128. The ipv6-prefix prefix-length arguments identify ND entries for which the network route is generated.
convert-length: Specifies an IPv6 prefix length for the generated network route, in the range of 1 to 127. The value for this argument must be higher than the value for the prefix-length argument.
After you execute the ipv6 nd route-direct advertise command on an interface, the device generates 128-bit host routes for ND entries learned on the interface. As a result, the routing table might be populated with excessive host routes. To reduce the routing table size, execute the ipv6 nd route-direct prefix convert-length command for the device to generate network routes for identified ND entries instead of host routes.
For the configuration to take effect, the specified IPv6 prefix must be consistent with the IPv6 address prefix of the interface.
# On VLAN-interface 100, set the prefix length to 70 for generating a network route for ND entries with IPv6 prefix 2001::1/64.
[Sysname-Vlan-interface100] ipv6 nd route-direct prefix 2001::1 64 convert-length 70
# On VSI-interface 1, set the prefix length to 70 for generating a network route for ND entries with IPv6 prefix 2001::1/64.
[Sysname-Vsi-interface1] ipv6 nd route-direct prefix 2001::1 64 convert-length 70
ipv6 nd router-preference
Use ipv6 nd router-preference to set a router preference in RA messages.
Use undo ipv6 nd router-preference to restore the default.
The router preference is medium.
Interface view
high: Sets the router preference to the highest setting.
low: Sets the router preference to the lowest setting.
medium: Sets the router preference to the medium setting.
A hosts selects a router with the highest preference as the default router.
When router preferences are the same in RA messages, a host selects the router corresponding to the first received RA message as the default gateway.
# Set the router preference in RA messages to the highest on VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd router-preference high
ipv6 nd snooping dad retrans-timer
Use ipv6 nd snooping dad retrans-timer to set the DAD NS message retransmission interval for ND snooping entry creation or update.
Use undo ipv6 nd snooping dad retrans-timer to restore the default.
ipv6 nd snooping dad retrans-timer interval
The DAD NS message retransmission interval is 250 milliseconds for ND snooping entry creation or update.
interval: Specifies the DAD NS message retransmission interval for ND snooping entry creation or update, in the range of 100 to 500 milliseconds.
When creating or updating an ND snooping entry, the device sends an NS message to test the entry by DAD. When both of the following conditions exist, the device retransmits an NS message:
·     The device does not receive a reply within the retransmission interval.
·     The retransmission interval is less than or equal to the timeout time for ND snooping entries in INVALID status (TENTATIVE, TESTING_TPLT, or TESTING_VP).
For the device to send the NS message only once, set a retransmission interval longer than the timeout time for ND snooping entries in INVALID status.
Example
# Set the DAD NS message retransmission interval to 200 milliseconds for ND snooping entry creation or update.
[Sysname] ipv6 nd snooping dad retrans-timer 200
ipv6 nd snooping enable global
Use ipv6 nd snooping enable global to enable ND snooping for global unicast addresses.
Use undo ipv6 nd snooping enable global to disable ND snooping for global unicast addresses.
ND snooping is disabled for global unicast addresses.
VLAN view
VSI view
# Enable ND snooping for global unicast addresses.
[Sysname] vlan 2
[Sysname-vlan2] ipv6 nd snooping enable global
ipv6 nd snooping enable link-local
Use ipv6 nd snooping enable link-local to enable ND snooping for link-local addresses.
Use undo ipv6 nd snooping enable link-local to disable ND snooping for link-local addresses.
ND snooping is disabled for link-local addresses.
VLAN view
VSI view
# Enable ND snooping for link-local addresses.
[Sysname] vlan 2
[Sysname-vlan2] ipv6 nd snooping enable link-local
ipv6 nd snooping glean source
Use ipv6 nd snooping glean source to enable ND snooping for data packets from unknown sources.
Use undo ipv6 nd snooping glean source to disable ND snooping for data packets from unknown sources.
ND snooping is disabled for data packets from unknown sources.
VLAN view
This command enables the device to learn ND snooping entries from data packets originated by unknown sources.
For this command to take effect, execute the ipv6 nd snooping enable global command or the ipv6 nd snooping enable link-local command.
Before enabling ND snooping entries learning from data packets for a VLAN, you must configure IPv6 source guard on all untrusted interfaces in the same VLAN. This operation ensures correct forwarding of the data packets received all these interfaces.
# Enable ND snooping for data packets from unknown sources.
[Sysname] vlan 2
[Sysname-vlan2] ipv6 nd snooping glean source
ipv6 nd snooping lifetime
Use ipv6 nd snooping lifetime to set timeout timers for ND snooping entries.
Use undo ipv6 nd snooping lifetime to restore the default.
ipv6 nd snooping lifetime { invalid invalid-lifetime | valid valid-lifetime }
undo ipv6 nd snooping lifetime { invalid | valid }
The timeout timer for ND snooping entries in INVALID status (TENTATIVE, TESTING_TPLT, or TESTING_VP) is 500 milliseconds.
The timeout timer for ND snooping entries in VALID status is 300 seconds.
invalid invalid-lifetime: Sets a timeout timer for ND snooping entries in INVALID status (TENTATIVE, TESTING_TPLT, or TESTING_VP). The value range is 250 to 1000 milliseconds.
valid valid-lifetime: Sets a timeout timer for ND snooping entries in VALID status. The value range is 60 to 86400 seconds.
# Set the timeout timer to 250 seconds for ND snooping entries in VALID status.
[Sysname] ipv6 nd snooping lifetime valid 250
ipv6 nd snooping max-learning-num
Use ipv6 nd snooping max-learning-num to set the maximum number of ND snooping entries that an interface can learn.
Use undo ipv6 nd snooping max-learning-num to restore the default.
ipv6 nd snooping max-learning-num max-number
An interface can learn a maximum of 1024 ND snooping entries.
max-number: Specifies the maximum number of ND snooping entries that an interface can learn. The value range for this argument is 1 to 1024.
# Allow Ten-GigabitEthernet 1/0/1 to learn a maximum of 64 ND snooping entries.
[Sysname-Ten-GigabitEthernet1/0/1] ipv6 nd snooping max-learning-num 64
ipv6 nd snooping uplink
Use ipv6 nd snooping uplink to configure the port as an ND snooping uplink port. The ND snooping uplink port cannot learn ND snooping entries.
Use undo ipv6 nd snooping uplink to restore the default.
The port is not an ND snooping uplink port. After ND snooping is enabled, the port can learn ND snooping entries.
# Configure Ten-GigabitEthernet 1/0/1 as an ND snooping uplink port.
[Sysname-Ten-GigabitEthernet1/0/1] ipv6 nd snooping uplink
# Configure Bridge-aggregation 1 as an ND snooping uplink port.
[Sysname-Bridge-Aggregation1] ipv6 nd snooping uplink
ipv6 nd unsolicited-na-learning enable
Use ipv6 nd unsolicited-na-learning enable to enable unsolicited NA learning.
Use undo ipv6 nd unsolicited-na-learning enable to disable unsolicited NA learning.
Unsolicited NA learning is disabled.
Layer 3 interface view
To ensure that the device learns ND entries from trusted NA messages, enable this feature only on a secure network.
This feature might cause the device to learn excessive ND entries that consume too many system resources. As a best practice, execute the ipv6 neighbor stale-aging command to set a smaller aging timer before you enable this feature. The smaller aging timer accelerates the aging of ND entries in stale state.
# Enable unsolicited NA learning on VLAN-interface 2.
[Sysname-Vlan-interface2] ipv6 nd unsolicited-na-learning enable
ipv6 nd user-ip-conflict record enable
Use ipv6 nd user-ip-conflict record enable to enable recording user IPv6 address conflicts.
Use undo ipv6 nd user-ip-conflict record enable to disable recording user IPv6 address conflicts.
Recording user IPv6 address conflicts is disabled.
This feature detects and records user IPv6 address conflicts. A conflict occurs if an incoming NA packet has the same source IPv6 address as an existing ND entry but a different source MAC address. The device generates a user IPv6 address conflict record, logs the conflict, and sends the log to the information center. For information about the log destination and output rule configuration in the information center, see the information center in Network Management and Monitoring Configuration Guide.
Each card can generate a maximum of 10 user IPv6 address conflict logs per second. When this maximum number is reached, the card suppresses generating user IPv6 address conflict logs and records the suppression times. Each card can save a maximum of 200 user IPv6 address conflict records.
When the number of saved user IPv6 address conflict records reaches the upper limit, new records overwrite old ones.
# Enable recording user IPv6 address conflicts.
[Sysname] ipv6 nd user-ip-conflict record enable
display ipv6 nd user-ip-conflict record
ipv6 nd user-move record enable
Use ipv6 nd user-move record enable to enable recording user port migrations.
Use undo ipv6 nd user-move record enable to disable recording user port migrations.
Recording user port migrations is disabled.
This feature enables the device to detect and record user port migrations. A user port migrates if an incoming NA packet has the same source IPv6 address and source MAC address as an existing ND entry but a different port. The device generates a user port migration record, logs the migration event, and sends the log to the information center. For information about the log destination and output rule configuration in the information center, see the information center in Network Management and Monitoring Configuration Guide.
Each card can generate a maximum of 10 user port migration logs per second. When this maximum number is reached, the card suppresses generating user port migration logs and records the suppression times. Each card can save a maximum of 200 user port migration records.
When the number of saved user port migration records reaches the upper limit, new records overwrite old ones.
# Enable recording user port migrations.
[Sysname] ipv6 nd user-move record enable
display ipv6 nd user-move record
ipv6 neighbor
Use ipv6 neighbor to configure a static neighbor entry.
Use undo ipv6 neighbor to delete a neighbor entry.
ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number | vsi-interface vsi-interface-id tunnel number vsi vsi-name | vsi-interface vsi-interface-id interface-type interface-number service-instance instance-id vsi vsi-name } [ vpn-instance vpn-instance-name ]
undo ipv6 neighbor ipv6-address interface-type interface-number
No static neighbor entries exist.
ipv6-address: Specifies the IPv6 address of the static neighbor entry.
mac-address: Specifies the MAC address (48 bits) of the static neighbor entry, in the format of H-H-H.
vlan-id: Specifies the VLAN ID of the static neighbor entry, in the range of 1 to 4094.
port-type port-number: Specifies a Layer 2 port of the static neighbor entry by its type and number.
interface interface-type interface-number: Specifies a Layer 3 interface of the static neighbor entry by its type and number.
vsi-interface vsi-interface-id: Specifies an input VSI interface for packets received from the neighbor in the entry. The vsi-interface-id argument specifies the VSI interface number.
tunnel number: Specifies an output tunnel interface for packets sent to the neighbor in the entry. The number argument specifies the tunnel interface number.
interface-type interface-number: Specifies a Layer 2 interface by its type and number. The device determines an output interface for packets sent to the neighbor in the entry based on the specified Layer 2 interface and Ethernet service instance.
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters.
service-instance instance-id: Specifies the Ethernet service instance of the entry. The instance-id specifies the Ethernet service instance ID in the range of 1 to 4096. You must specify this option if a Layer 2 interface is specified. This option is not configurable if an interface of another type is specified.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the static neighbor entry belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command configures a static neighbor entry for the public network.
A neighbor entry stores information about a link-local node. The entry can be created dynamically through NS and NA messages, or configured statically.
The device uniquely identifies a static neighbor entry by using the neighbor's IPv6 address and the number of the Layer 3 interface that connects to the neighbor.
You can configure a static neighbor entry by using one of the following methods:
·     Method 1—Associate a neighbor IPv6 address and link-layer address with the Layer 3 interface of the local node.
·     Method 2—Associate a neighbor IPv6 address and link-layer address with a Layer 2 port in a VLAN containing the local node.
·     Method 3—Specify a neighbor IPv6 address, MAC address, input interface (VSI interface), output interface (tunnel interface), and VSI name.
·     Method 4—Specify a neighbor IPv6 address, MAC address, input interface (VSI interface), output interface (determined by a Layer 2 interface and Ethernet service instance), and VSI name.
To configure a static neighbor entry for a VLAN interface, use Method 1 or Method 2.
·     If Method 1 is used, the neighbor entry is in INCMP state. After the device obtains the corresponding Layer 2 port information, the neighbor entry goes into REACH state.
·     If Method 2 is used, the port specified by port-type port-number must belong to the VLAN specified by vlan-id and the corresponding VLAN interface must already exist. After the static neighbor entry is configured, the device associates the VLAN interface with the IPv6 address to uniquely identify the static neighbor entry. The entry will be in REACH state.
If the device and its neighbor are connected through a VSI interface, use Method 3 or Method 4 to configure the neighbor entry.
·     If Method 3 is used, the neighbor entry is in REACH state. This method is applicable to the network where VXLAN gateways are connected through tunnel interfaces. In the network, a VXLAN gateway is identified by both the VSI and VSI interface. A VSI interface is associated with multiple tunnel interfaces. To create a neighbor entry, you must specify the VSI interface, VSI, and tunnel interface.
·     If Method 4 is used, the neighbor entry is in REACH state. This method is applicable to the network where VXLAN gateways are associated with local sites. A VXLAN gateway is identified by both the VSI and VSI interface. One VXLAN gateway might have multiple local sites. Local sites access the VXLAN network through Layer 2 interfaces where Ethernet service instance and VSI mappings are configured. To create a neighbor entry, you must specify the VSI interface, Layer 2 interface connected to the local site, Ethernet service instance, and VSI.
For more information about VSI, VSI interfaces, and Ethernet service instances, see VXLAN overview in VXLAN Configuration Guide.
For more information about tunnel interfaces, see tunneling configuration in Layer 3—IP Services Configuration Guide.
To delete a static neighbor entry for a VSI interface, specify only the VSI interface.
To delete a static neighbor entry for a VLAN interface, specify only the VLAN interface.
You can use the undo ipv6 neighbor command to delete both static and dynamic neighbor entries.
# Configure a static neighbor entry for VLAN-interface 1.
[Sysname] ipv6 neighbor 2000::1 fe-e0-89 interface Vlan-interface 1
# Configure a static neighbor entry, and specify IPv6 address 2000::1, MAC address 00e0-fc01-0000, input interface (VSI-interface 1), output interface (Tunnel-interface 1), and VSI vsi1.
[Sysname] ipv6 neighbor 2000::1 00e0-fc01-0000 vsi-interface 1 tunnel 1 vsi vsi1
# Configure a static neighbor entry, and specify IPv6 address 2000::1, MAC address 00e0-fc01-0000, input interface (VSI-interface 1), output interface (Ten-GigabitEthernet 1/0/1), Ethernet service instance 1, and VSI vsi1.
[Sysname] ipv6 neighbor 2000::1 00e0-fc01-0000 vsi-interface 1 ten-gigabitethernet 1/0/1 service-instance 1 vsi vsi1
display ipv6 neighbors
reset ipv6 neighbors
ipv6 neighbor aging probe-count
Use ipv6 neighbor aging probe-count to set the maximum number of probes to test the reachability of neighbors in ND entries.
Use undo ipv6 neighbor aging probe-count to restore the default.
ipv6 neighbor aging probe-count count
The device performs a maximum of three probes to test the reachability of neighbors in ND entries.
count: Specifies the maximum number of probes. The value range for this argument is 0 to 10. To disable the device from probing ND entries, set the value to 0.
The device probes the reachability of a neighbor when the neighbor entry is in PROBE state. Neighbor entries in DELAY state will adopt this setting when they enter into the PROBE state.
This command does not apply to ND entries in PROBE state.
# Allow the device to perform a maximum of five probes to test the reachability of neighbors in ND entries.
[Sysname] ipv6 neighbor aging probe-count 5
ipv6 neighbor aging probe-interval
Use ipv6 neighbor aging probe-interval to set the interval for testing the reachability of neighbors in ND entries.
Use undo ipv6 neighbor aging probe-interval to restore the default.
ipv6 neighbor aging probe-interval interval
The interval for testing the reachability of neighbors in ND entries is the same as the interval for retransmitting an NS message.
interval: Specifies the interval in seconds. The value rang is 1 to 60.
The modification takes effect immediately after you execute the command.
To set the interval for retransmitting an NS message, use the ipv6 nd ns retrans-timer command.
# Set the interval to 10 seconds for testing the reachability of neighbors in ND entries.
[Sysname] ipv6 neighbor aging probe-interval 10
Use ipv6 neighbor link-local minimize to minimize link-local ND entries.
Use undo ipv6 neighbor link-local minimize to restore the default.
All ND entries are assigned to the driver.
Perform this command to minimize link-local ND entries assigned to the driver. Link-local ND entries refer to ND entries that contain link-local addresses.
With this feature enabled, the device does not add newly learned link-local ND entries whose link local addresses are not the next hop of any route to the driver. This saves driver resources.
This feature affects only newly learned link-local ND entries rather than existing ND entries.
# Minimize link-local ND entries.
[Sysname] ipv6 neighbor link-local minimize
Use ipv6 neighbor stale-aging to set the aging timer for ND entries in stale state.
Use undo ipv6 neighbor stale-aging to restore the default.
ipv6 neighbor stale-aging { aging-minutes | second aging-seconds }
The aging timer for ND entries in stale state is 240 minutes.
aging-minutes: Specifies the aging timer in minutes for ND entries in stale state, in the range of 1 to 1440.
second aging-seconds: Specifies the aging timer in seconds for ND entries in stale state, in the range of 60 to 86400.
This aging time applies to all ND entries in stale state. If an ND entry in stale state is not updated before the timer expires, it changes to the delay state. If it is still not updated in 5 seconds, the ND entry changes to the probe state. The device sends an NS message for detection a maximum of three attempts. If no response is received, the device deletes the ND entry.
You can set the aging timer for ND entries in stale state in system view and interface view. For ND entries in stale state on an interface, the aging timer in interface view has higher priority than the aging timer in system view.
# Set the aging timer for ND entries in stale state to 120 minutes.
[Sysname] ipv6 neighbor stale-aging 120
ipv6 neighbor timer stale-aging
Use ipv6 neighbor timer stale-aging to set the aging timer for ND entries in stale state on an interface.
Use undo ipv6 neighbor timer stale-aging to restore the default.
ipv6 neighbor timer stale-aging { aging-minutes | second aging-seconds }
The aging timer of ND entries in stale state is not configured on an interface. The aging timer is determined by the configuration of the ipv6 neighbor stale-aging command in system view.
Layer 3 Ethernet interface/subinterface view
Layer 3 aggregate interface/subinterface view
VXLAN VSI interface view
VLAN interface view
Tunnel interface view
aging-time: Specifies the aging timer in minutes for ND entries in stale state, in the range of 1 to 1440.
This aging timer applies to ND entries in stale state on the interface. If an ND entry in stale state is not updated before the timer expires, it changes to the delay state. If it is still not updated in 5 seconds, the ND entry changes to the probe state. The device sends an NS message for probe and a maximum of three attempts is allowed. If no response is received, the device deletes the ND entry.
# On VLAN-interface 2, set the aging timer to 200 minutes for ND entries in stale state.
[Sysname-Vlan-interface2] ipv6 neighbor timer stale-aging 200
Use ipv6 neighbors max-learning-num to set the maximum number of dynamic neighbor entries that an interface can learn. This prevents the interface from occupying too many neighbor table resources.
Use undo ipv6 neighbors max-learning-num to restore the default.
The maximum number of dynamic neighbor entries that an interface can learn equals the maximum free space of the neighbor table.
Layer 2/Layer 3 interface view
Layer 2/Layer 3 aggregate interface view
max-number: Specifies the maximum number of dynamic neighbor entries that an interface can learn. The value range for this argument is 1 to 131072.
The device can dynamically acquire the link-layer address of a neighboring node through NS and NA messages and add it into the neighbor table.
When the number of dynamic neighbor entries reaches the threshold, the interface stops learning neighbor information.
# Set the maximum number of dynamic neighbor entries that VLAN-interface 100 can learn to 10.
[Sysname-Vlan-interface100] ipv6 neighbors max-learning-num 10
Use ipv6 neighbors max-learning-number to set the maximum number of dynamic neighbor entries that the device can learn.
Use undo ipv6 neighbors max-learning-number to restore the default.
In standalone mode:
ipv6 neighbors max-learning-number max-number slot slot-number
undo ipv6 neighbors max-learning-number slot slot-number
In IRF mode:
ipv6 neighbors max-learning-number max-number chassis chassis-number slot slot-number
undo ipv6 neighbors max-learning-number chassis chassis-number slot slot-number
The device can learn up to 131072 dynamic neighbor entries.
max-number: Specifies the maximum number of dynamic neighbor entries that the device can learn. The value range for this argument is 0 to 131072. To disable the device from learning dynamic neighbor entries, set the value for this argument to 0.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
To avoid excessive resource consumption by neighbor entries, set the maximum number of dynamic neighbor entries that the device can learn.
When the number of dynamic neighbor entries reaches the limit, the device stops learning neighbor information.
# (In standalone mode.) On slot 1, set the maximum number of dynamic neighbor entries that the device can learn to 64.
[Sysname] ipv6 neighbors max-learning-number 64 slot 1
ipv6 pathmtu
Use ipv6 pathmtu to set a static Path MTU for an IPv6 address.
Use undo ipv6 pathmtu to delete the Path MTU configuration for an IPv6 address.
undo ipv6 pathmtu [ vpn-instance vpn-instance-name ] ipv6-address
No static Path MTU is set.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the Path MTU belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command sets the Path MTU for the public network.
ipv6-address: Specifies an IPv6 address.
value: Specifies the Path MTU of the specified IPv6 address, in the range of 1280 to 10240 bytes.
You can set a static Path MTU for a destination IPv6 address. When a source host sends a packet through an interface, it compares the interface MTU with the static Path MTU of the specified destination IPv6 address. If the packet size is larger than the smaller one of the two values, the host fragments the packet according to the smaller value.
# Set a static Path MTU for an IPv6 address.
[Sysname] ipv6 pathmtu fe80::12 1300
display ipv6 pathmtu
reset ipv6 pathmtu
ipv6 pathmtu age
Use ipv6 pathmtu age to set the aging time for a dynamic Path MTU.
Use undo ipv6 pathmtu age to restore the default.
ipv6 pathmtu age age-time
The aging time for dynamic Path MTU is 10 minutes.
age-time: Specifies the aging time for Path MTU in minutes, in the range of 10 to 100.
After the path MTU from a source host to a destination host is dynamically determined, the source host sends subsequent packets to the destination host based on this MTU. After the aging time expires, the following events occur:
·     The dynamic Path MTU is removed.
·     The source host determines a dynamic path MTU through the Path MTU mechanism again.
The aging time is invalid for a static Path MTU.
# Set the aging time for a dynamic Path MTU to 40 minutes.
[Sysname] ipv6 pathmtu age 40
ipv6 prefer temporary-address
Use ipv6 prefer temporary-address to enable the system to preferentially use the temporary IPv6 address of the sending interface as the source address of a packet.
Use undo ipv6 prefer temporary-address to disable the system to preferentially use the temporary IPv6 address of the sending interface as the source address of a packet.
The system is disabled to preferentially use the temporary IPv6 address of the sending interface as the source address of a packet.
The temporary address feature enables the system to generate and preferentially use the temporary IPv6 address of the sending interface as the source address of a packet. If the temporary IPv6 address cannot be used because of a DAD conflict, the system uses the public IPv6 address.
# Enable the system to preferentially use the temporary IPv6 address of the sending interface as the source address of the packet.
[Sysname] ipv6 prefer temporary-address
ipv6 address auto
ipv6 nd ra prefix
ipv6 temporary-address
ipv6 prefix
Use ipv6 prefix to configure a static IPv6 prefix.
Use undo ipv6 prefix to delete a static IPv6 prefix.
undo ipv6 prefix prefix-number
No static IPv6 prefix is configured.
prefix-number: Specifies a prefix ID in the range of 1 to 1024.
ipv6-prefix/prefix-length: Specifies a prefix and its length. The value range for the prefix-length argument is 1 to 128.
To modify an existing static prefix, execute the undo ipv6 prefix command to delete the existing static prefix, and then execute the ipv6 prefix command.
Dynamic IPv6 prefixes obtained from DHCPv6 servers cannot be manually removed or modified.
A static IPv6 prefix can have the same prefix ID with a dynamic IPv6 prefix, but the static one takes precedence over the dynamic one.
# Create static IPv6 prefix 2001:0410::/32 with prefix ID 1.
[Sysname] ipv6 prefix 1 2001:0410::/32
display ipv6 prefix
ipv6 reassemble local enable
Use ipv6 reassemble local enable to enable IPv6 local fragment reassembly.
Use undo ipv6 reassemble local enable to disable IPv6 local fragment reassembly.
IPv6 local fragment reassembly is disabled.
Configure this command on a device to improve fragment reassembly efficiency. An LPU performs fragment reassembly for an IPv6 packet destined for the device if it receives fragments of that packet. If this feature is disabled, all IPv6 fragments are delivered to the active MPU for reassembly.
This feature fails to reassemble an IPv6 packet if fragments of the packet are received by different LPUs.
# Enable IPv6 local fragment reassembly.
[Sysname] ipv6 reassemble local enable
ipv6 redirects enable
Use ipv6 redirects enable to enable sending ICMPv6 redirect messages.
Use undo ipv6 redirects enable to disable sending ICMPv6 redirect messages.
Sending ICMPv6 redirect messages is disabled.
The default gateway sends an ICMPv6 redirect message to the source of an IPv6 packet to inform the source of a better first hop.
Sending ICMPv6 redirect messages enables hosts that hold few routes to establish routing tables and find the best route. Because this feature adds host routes into the routing tables, host performance degrades when there are too many host routes. As a result, sending ICMPv6 redirect messages is disabled by default.
# Enable sending ICMPv6 redirect messages.
[Sysname] ipv6 redirects enable
Use ipv6 temporary-address to enable the temporary IPv6 address feature.
Use undo ipv6 temporary-address to restore the default.
The system does not generate any temporary IPv6 address.
valid-lifetime: Specifies the valid lifetime for temporary IPv6 addresses, in the range of 600 to 4294967295 seconds. The default valid lifetime is 604800 seconds (7 days).
preferred-lifetime: Specifies the preferred lifetime for temporary IPv6 addresses, in the range of 600 to 4294967295 seconds. The default preferred lifetime is 86400 seconds (1 day).
You must enable stateless autoconfiguration before enabling the temporary address feature.
The valid lifetime for temporary IPv6 addresses must be greater than or equal to the preferred lifetime for temporary IPv6 addresses.
In stateless address autoconfiguration, an interface automatically generates an IPv6 global unicast address by using the address prefix in the received RA message and the interface ID. On an IEEE 802 interface (such as an Ethernet interface or a VLAN interface), the interface ID is generated based on the interface's MAC address and is globally unique. An attacker can exploit this rule to easily identify the sending device.
To fix the vulnerability, you can enable the temporary address feature. An IEEE 802 interface generates the following addresses:
·     Public IPv6 address—Includes an address prefix in the RA message and a fixed interface ID generated based on the interface's MAC address.
·     Temporary IPv6 address—Includes an address prefix in the RA message and a random interface ID generated through MD5.
When the valid lifetime of a temporary IPv6 address expires, the system deletes the address and generates a new one. This enables the system to send packets with different source addresses through the same interface. The preferred lifetime and valid lifetime for a temporary IPv6 address are determined as follows:
·     The preferred lifetime of a temporary IPv6 address takes the smaller of the following values:
¡     The preferred lifetime of the address prefix in the RA message.
¡     The preferred lifetime configured for temporary IPv6 addresses minus DESYNC_FACTOR (a random number in the range of 0 to 600 seconds).
·     The valid lifetime of a temporary IPv6 address takes the smaller of the following values:
¡     The valid lifetime of the address prefix.
¡     The valid lifetime configured for temporary IPv6 addresses.
# Enable the system to generate a temporary IPv6 address.
[Sysname] ipv6 temporary-address
ipv6 address auto
ipv6 nd ra prefix
ipv6 unreachables enable
Use ipv6 unreachables enable to enable sending ICMPv6 destination unreachable messages.
Use undo ipv6 unreachables to disable sending ICMPv6 destination unreachable messages.
undo ipv6 unreachables enable
Sending ICMPv6 destination unreachable messages is disabled.
If the device fails to forward a received IPv6 packet because of a destination unreachable error, it performs the following operations:
·     Drops the packet.
·     Sends an ICMPv6 destination unreachable message to the source.
If the device is generating ICMPv6 destination unreachable messages incorrectly, disable sending ICMPv6 destination unreachable messages to prevent attack risks.
# Enable sending ICMPv6 destination unreachable messages.
[Sysname] ipv6 unreachables enable
local-proxy-nd enable
Use local-proxy-nd enable to enable local ND proxy.
Use undo local-proxy-nd enable to disable local ND proxy.
Local ND proxy is disabled.
VLAN interface view
# Enable local ND proxy on VLAN-interface 100.
[Sysname-Vlan-interface100] local-proxy-nd enable
proxy-nd enable
ping nd ipv6
Use ping nd ipv6 to verify the availability of an IPv6 address in the LAN.
ping nd ipv6 host [ interface interface-type interface-number [ vlan vlan-id ] ] [ timeout timeout ] [ count count ]
host: Specifies an IPv6 address or a host name. A host name is a case-insensitive string of 1 to 253 characters. The string can contain letters, digits, hyphens (-), underscores (_), and dots (.).
interface interface-type interface-number: Specifies the egress interface that sends NS packets. The interface-type and interface-number arguments represent the interface type and interface number, respectively. If you do not specify this option, the device sends NS packets out of the egress interface specified by the route entry.
vlan vlan-id: Specifies the VLAN to which the egress interface belongs. The value range for the vlan-id argument is 1 to 4094.
timeout timeout: Specifies the NS packet timeout in milliseconds. The value range is 0 to 65535 and the default value is 3000.
count count: Specifies the maximum number of NS packet transmission attempts, in the range of 1 to 4294967295. The default value is 5.
This feature allows users to verify if an IPv6 address is being used by another device in the LAN.
After you perform this task, the device sends an NS packet to the specified IPv6 address. If no NA packet is received within the timeout, the device retransmits the NS packet. If no NA packet is received after the maximum number of transmission attempts is reached, the device considers that the IPv6 address is not being used.
You can also use the ping ipv6 command to verify the IPv6 address availability. However, the test result might be inaccurate because the peer device cannot respond if a firewall is configured to forbid the device from responding to ICMPv6 packets. Compared with ping operations, ND-ping uses Layer 2 packets (ND packets), which are not blocked by firewalls in most cases, and NS packets are shorter than ICMPv6 packets and require less network resources.
To test the address availability by specifying a host name, configure DNS for the device to translate the host name to an IPv6 address. For more information about DNS, see "Configuring DNS."
If multiple devices exist in the LAN, executing this command might take a long time. To stop the command execution, press Ctrl+C.
# Verify if IPv6 address 2001::2 is being used by another device in the LAN. The test result shows that the address is being used by device 0003-0003-0003.
<Sysname> ping nd ipv6 2001::2
2001::2 is used by 0003-0003-0003.
# Verify if IPv6 address 2001::2 is being used by another device in the LAN. The test result shows that the address is not being used by any other device.
The IPv6 address is not in use on the network.
ping nd mac
Use ping nd mac to obtain the IPv6 address of the device that uses the specified MAC address in a specific subnet.
ping nd mac mac-address { interface interface-type interface-number | ipv6 ipv6-address [ vpn-instance vpn-instance-name ] } [ timeout timeout ] [ count count ]
mac-address: Specifies a MAC address in the H-H-H format. You can omit the 0s at the start of each group. For example, you can specify MAC address 000f-00e2-0001 as f-e2-1 in this command. Make sure the MAC address is not a multicast, broadcast, or virtual address.
interface interface-type interface-number: Specifies the ICMPv6 packet egress interface to search the MAC address in the interface subnet. The interface-type and interface-number arguments represent the interface type and interface number, respectively.
ipv6 ipv6-address: Specifies an IPv6 subnet.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command searches the MAC address in the public network.
timeout timeout: Specifies the ICMPv6 packet timeout in milliseconds. The value range is 0 to 65535 and the default value is 3000.
count count: Specifies the maximum number of ICMPv6 packet transmission attempts, in the range of 1 to 4294967295. The default value is 5.
Perform this task to obtain the IPv6 address of the device that uses the specified MAC address in a specific subnet.
After you perform this task, the device broadcasts a Layer 3 ICMPv6 packet. If no ICMPv6 response is received within the timeout, the device resends the broadcast packet. If no ICMPv6 response is received after the number of maximum transmission attempts is received, the device considers that the MAC address does not exist in the subnet.
If multiple devices exist in the subnet, executing this command might take a long time. To stop the command execution, press Ctrl+C.
# Obtain the IPv6 address of device 0003-0003-0003 in the subnet where interface Ten-GigabitEthernet 1/0/1 resides.
<Sysname> ping nd mac 0003-0003-0003 interface ten-gigabitethernet 1/0/1
ND-Ping MAC statistics:
  1 packet(s) transmitted
  1 packet(s) received
  IPv6 address                MAC address
  2001::2                      0003-0003-0003
# Obtain the IPv6 address of device 0003-0003-0003 in subnet 2001::0.
<Sysname> ping nd mac 0003-0003-0003 ipv6 2001::0
  5 packet(s) transmitted
  0 packet(s) received
  MAC[0003-0003-0003] not in use
proxy-nd enable
Use proxy-nd enable to enable common ND proxy.
Use undo proxy-nd enable to disable common ND proxy.
proxy-nd enable
Common ND proxy is disabled.
VLAN interface view
# Enable common ND proxy on VLAN-interface 100.
[Sysname-Vlan-interface100] proxy-nd enable
reset ipv6 nd snooping vlan
Use reset ipv6 nd snooping vlan to clear ND snooping entries in VLANs.
reset ipv6 nd snooping vlan { [ vlan-id ] [ global | link-local ] | vlan-id ipv6-address }
vlan-id: Clears ND snooping entries for the specified VLAN. The value range for the VLAN ID is 1 to 4094.
global: Clears ND snooping entries for global unicast addresses.
link-local: Clears ND snooping entries for link-local addresses.
vlan-id ipv6-address: Clears the ND snooping entry of the specified IPv6 address in the specified VLAN.
If you do not specify any parameters, this command clears ND snooping entries in all VLANs.
# Clear ND snooping entries in all VLANs.
<Sysname> reset ipv6 nd snooping vlan
display ipv6 nd snooping count vlan
display ipv6 nd snooping vlan
reset ipv6 nd snooping vsi
Use reset ipv6 nd snooping vsi to clear ND snooping entries in VSIs.
reset ipv6 nd snooping vsi [ vsi-name ]
vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clear ND snooping entries in all VSIs.
# Clear ND snooping entries in VSI vsi1.
<Sysname> reset ipv6 nd snooping vsi vsi1
display ipv6 nd snooping count vsi
display ipv6 nd snooping vsi
Use reset ipv6 neighbors to clear IPv6 neighbor information.
In standalone mode:
In IRF mode:
reset ipv6 neighbors { all | dynamic | interface interface-type interface-number | chassis chassis-number slot slot-number | static }
all: Clears static and dynamic neighbor information for all interfaces.
dynamic: Clears dynamic neighbor information for all interfaces.
interface interface-type interface-number: Clears dynamic neighbor information for the interface specified by its type and number.
slot slot-number: Specifies a card by its slot number. If you do not specify a cad, this command clears dynamic neighbor information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears dynamic neighbor information for all cards. (In IRF mode.)
static: Clears static neighbor information for all interfaces.
# Clear neighbor information for all interfaces.
<Sysname> reset ipv6 neighbors all
This will delete all the entries. Continue? [Y/N]:Y
# Clear dynamic neighbor information for all interfaces.
<Sysname> reset ipv6 neighbors dynamic
This will delete all the dynamic entries. Continue? [Y/N]:Y
# Clear all neighbor information for Ten-GigabitEthernet 1/0/1.
<Sysname> reset ipv6 neighbors interface ten-gigabitethernet 1/0/1
This will delete all the dynamic entries by the interface you specified. Continue? [Y/N]:Y
ipv6 neighbor
reset ipv6 pathmtu
Use reset ipv6 pathmtu to clear the Path MTU information.
all: Clears all Path MTUs.
dynamic: Clears all dynamic Path MTUs.
static: Clears all static Path MTUs.
# Clear all Path MTUs.
<Sysname> reset ipv6 pathmtu all
reset ipv6 statistics
Use reset ipv6 statistics to clear IPv6 and ICMPv6 packet statistics.
In standalone mode:
In IRF mode:
reset ipv6 statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a cad, this command clears IPv6 and ICMPv6 packet statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears IPv6 and ICMPv6 packet statistics for all cards. (In IRF mode.)
# Clear IPv6 and ICMPv6 packet statistics.
<Sysname> reset ipv6 statistics
display ipv6 statistics
snmp-agent trap enable ipv6 address
Use snmp-agent trap enable ipv6 address to enable SNMP notifications for the IPv6 basics module.
Use undo snmp-agent trap enable ipv6 address to disable SNMP notifications for the IPv6 basics module.
snmp-agent trap enable ipv6 address [ interface-state-change | protocol-enable-failure ] *
undo snmp-agent trap enable ipv6 address [ interface-state-change | protocol-enable-failure ] *
SNMP notifications are enabled for the IPv6 basics module.
interface-state-change: Enables SNMP notifications for IPv6 interface state changes. This keyword takes effect only on IPv6 interfaces.
protocol-enable-failure: Enables SNMP notifications for interface-level IPv6 enabling failures.
Application scenarios
This feature enables the IPv6 basics module to generate SNMP notifications for critical events.
Operating mechanism
The IPv6 basics module sends SNMP notifications to the SNMP module. For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see SNMP configuration in Network Management and Monitoring Configuration Guide.
·     If you specify the interface-state-change keyword, the IPv6 basics module will send SNMP notifications for IPv6 interface state changes. When an IPv6 interface has a state change, the device sends information about the interface and status of the interface in SNMP notifications to the SNMP module.
·     If you specify the protocol-enable-failure keyword, the IPv6 basics module will send SNMP notifications for interface-level IPv6 enabling failures. When an IPv6 interface has an IPv6 enabling failure, the device sends the name, chassis number, and slot number of the interface in SNMP notifications to the SNMP module.
To enable or disable all SNMP notifications for the IPv6 basics module, do not specify any parameters.
After you disable SNMP notifications for the IPv6 basics module, the IPv6 basics module will not send any SNMP notifications to the SNMP module. The device can report the critical events of the IPv6 basics module only by sending the IPv6 basics module's log messages to the information center. For log messages to be sent correctly, configure the information center to set log message filtering and output rules, including output destinations. For information about the log destination and output rule configuration in the information center, see information center configuration in Network Management and Monitoring Configuration Guide.
# Disable SNMP notifications for IPv6 interface state changes and interface-level IPv6 enabling failures.
[Sysname] undo snmp-agent trap enable ipv6 address interface-state-change protocol-enable-failure
statistics l3-packet enable
Use statistics l3-packet enable to enable Layer 3 packet statistics collection.
Use undo statistics l3-packet enable to disable Layer 3 packet statistics collection.
statistics l3-packet enable { inbound | outbound }
undo statistics l3-packet enable { inbound | outbound }
Layer 3 packet statistics collection is disabled.
Interface view
inbound: Enables statistics collection for incoming Layer 3 packets.
outbound: Enables statistics collection for outgoing Layer 3 packets.
With this feature enabled on an interface, the device counts incoming and outgoing IPv6 packets on the interface. To display the collected statistics, execute the display interface command.
When the interface is processing a large number of packets, enabling this feature will cause high CPU usage and degrade the forwarding performance. If the statistics are not necessary, disable this feature to ensure the device performance.
# Enable statistics collection for incoming Layer 3 packets on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] statistics l3-packet enable inbound
display ip interface
display ip statistics
