19-Telemetry Command Reference
HomeSupportSwitchesS12500R SeriesReference GuidesCommand ReferencesH3C S12500R Switch Router Series Command References(R52xx)-6W10219-Telemetry Command Reference
02-Flow group commands
02-Flow group commands 58.18 KB
Flow group commands
display telemetry flow-group
Use display telemetry flow-group to display the configuration and application status of flow groups.
display telemetry flow-group [ system-defined [ ip | vxlan ] ] [ slot slot-number ]
system-defined: Specifies a system-defined flow group.
·     ip: Specifies the system-defined IP flow group.
·     vxlan: Specifies the system-defined VXLAN flow group.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the configuration and application status on the active MPU.
# Display the configuration and application status of the system-defined VXLAN flow group.
<Sysname> display telemetry flow-group system-defined ip slot 1
Flow group named system-defined-ip (System-defined)
  Mode    : Common-MOD(Inactive), Group-MOD(Inactive)
  Template:
    destination-ip
    destination-port
    protocol
    source-ip
    source-port
Aging time: 100 minutes
Name of the flow group. Values for the application status include:
·     Successful—The flow group is applied successfully.
·     Failed—The flow group fails to be applied for some reasons other than incomplete flow group configuration.
·     Inactive—The flow group has not been administratively applied.
·     Incomplete—The flow group fails to be applied because its configuration is incomplete.
System-defined indicates a system-defined flow group.
Mode
The mode specified when a flow group is applied:
·     Common-MOD
·     Group-MOD
telemetry apply flow-group
Use telemetry apply flow-group to apply a flow group.
Use undo telemetry apply flow-group to remove the application of a flow group.
telemetry apply flow-group system-defined { ip | vxlan } [ mode group-mod ]
undo telemetry apply flow-group system-defined { ip | vxlan } [ mode group-mod ]
No flow group is applied.
mode group-mod: Specifies the group MOD mode when a system-defined flow group is applied. If you do not specify this parameter, the common MOD mode applies. For more information about the two modes, see "Configuring MOD."
The device has two system-defined flow groups: one IP flow group named system-defined-ip and one VXLAN flow group named system-defined-vxlan. The two flow groups are not configurable.
The IP flow group generates flow entries based on the 5-tuple.
The VXLAN flow group generates flow entries based on the VXLAN  ID and the inner 5-tuple.
The two flow groups take effect on all traffic.
# Apply the system-defined IP flow group.
[Sysname] telemetry apply flow-group system-defined ip
# Apply the system-defined IP flow group with the group MOD mode.
[Sysname] telemetry apply flow-group system-defined ip mode group-mod
telemetry flow-group aging-time
Use telemetry flow-group aging-time to set the aging time for flow entries.
Use undo telemetry flow-group aging-time to restore the default.
telemetry flow-group aging-time aging-time
The aging time for flow entries is 15 minutes.
aging-time: Specifies the aging time for flow entries in minutes. The value range for this argument is 1 to 100.
# Set the aging time for flow entries to 20 minutes.
[Sysname] telemetry flow-group aging-time 20
