- 06-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-IP forwarding basics commands
- 06-Fast forwarding commands
- 07-Adjacency table commands
- 08-IRDP commands
- 09-IP performance optimization commands
- 10-UDP helper commands
- 11-IPv6 basics commands
- 12-IPv6 neighbor discovery commands
- 13-DHCPv6 commands
- 14-IPv6 fast forwarding commands
- 15-IPv6 transition technologies commands
| 06-Fast forwarding commands | 63.14 KB |
display ip fast-forwarding aging-time
display ip fast-forwarding cache
display ip fast-forwarding fragcache
ip fast-forwarding load-sharing
reset ip fast-forwarding cache
Use display ip fast-forwarding aging-time to display the aging time of fast forwarding entries.
# Display the aging time of fast forwarding entries.
<Sysname> display ip fast-forwarding aging-time
Aging time: 30
Use display ip fast-forwarding cache to display fast forwarding entries.
display ip fast-forwarding cache [ ip-address ] [ slot slot-number ]
ip-address: Specifies an IP address. If you do not specify an IP address, this command displays all fast forwarding entries.
slot slot-number: Specifies a card by the slot number. If you do not specify a card, this command displays fast forwarding entries for all cards.
# Display all fast forwarding entries.
<Sysname> display ip fast-forwarding cache
Total number of fast-forwarding entries: 1
SIP SPort DIP DPort Pro Input_If Output_If Flg
7.0.0.13 68 8.0.0.1 67 17 HGE1/0/3 HGE1/0/1 5
SIP |
Source IP address. |
SPort |
Source port number. |
DIP |
Destination IP address. |
DPort |
Destination port number. |
Pro |
Protocol number. |
Input_If |
Input interface type and number. If no interface is involved in fast forwarding, this field displays N/A. If the input interface does not exist, this field displays a hyphen (-). |
Output_If |
Output interface type and number. If no interface is involved in fast forwarding, this field displays N/A. If the output interface does not exist, this field displays a hyphen (-). |
Flg |
Internal tag, marking internal operation information, such as fragmentation. |
Use display ip fast-forwarding fragcache to display fast forwarding entries for fragmented packets.
display ip fast-forwarding fragcache [ ip-address ] [ slot slot-number ]
ip-address: Specifies an IP address. If you do not specify an IP address, this command displays fast forwarding entries for all fragmented packets.
slot slot-number: Specifies a card by the slot number. If you do not specify a card, this command displays fast forwarding entries for fragmented packets on all cards.
# Display fast forwarding entries about all fragmented packets.
<Sysname> display ip fast-forwarding fragcache
Total number of fragment fast-forwarding entries: 1
SIP SPort DIP DPort Pro Input_If ID
7.0.0.13 68 8.0.0.1 67 17 HGE1/0/3 2
SIP |
SPort |
DIP |
DPort |
Pro |
Protocol number. |
Input_If |
ID |
Fragment ID. |
Use ip fast-forwarding aging-time to configure the aging time for fast forwarding entries.
Use undo ip fast-forwarding aging-time to restore the default.
ip fast-forwarding aging-time aging-time
The aging time is 30 seconds.
aging-time: Specifies the aging time in the range of 10 to 300 seconds.
# Set the aging time to 20 seconds for fast forwarding entries.
[Sysname] ip fast-forwarding aging-time 20
Use ip fast-forwarding load-sharing to enable fast forwarding load sharing.
Use undo ip fast-forwarding load-sharing to disable fast forwarding load sharing.
Fast forwarding load sharing is enabled.
Fast forwarding load sharing enables the device to load share packets of the same flow. This feature identifies a data flow by using the packet information.
If fast forwarding load sharing is disabled, the device identifies a data flow by the packet information and the input interface. No load sharing is implemented.
# Enable fast forwarding load sharing.
<Sysname> system-Views
[Sysname] ip fast-forwarding load-sharing
Use reset ip fast-forwarding cache to clear the fast forwarding table.
reset ip fast-forwarding cache [ slot slot-number ]
Predefined use roles
slot slot-number: Specifies a card by the slot number. If you do not specify a card, this command clears the fast forwarding table for all cards.
# Clear the fast forwarding table.
<Sysname> reset ip fast-forwarding cache
