03-System Management Command Reference
HomeSupportSwitchesS12500R SeriesReference GuidesCommand ReferencesH3C S12500R Switch Router Series Command References(R52xx)-6W10203-System Management Command Reference
03-Hardware resource management commands
03-Hardware resource management commands 657.52 KB
Hardware resource management commands· 1
display alarm·· 1
display alarm active· 1
display alarm history· 2
display cpu-usage· 4
display cpu-usage configuration· 5
display cpu-usage history· 6
display device· 8
display device manuinfo· 9
display device manuinfo chassis-only· 10
display device manuinfo fan· 10
display device manuinfo power 11
display environment 11
display fan· 12
display fdisk-flash· 13
display hardware-failure-detection· 14
display hardware-resource acl-hash· 15
display hardware-resource mdb· 15
display hardware-resource bfd_enhance· 16
display hardware-resource opttask-delay· 16
display hardware-resource port-speed· 17
display hardware-resource scd-port-speed· 18
display hardware-resource smartman· 18
display hardware-resource synce· 19
display hardware-resource telemetry-stream·· 19
display memory· 20
display memory dma· 22
display memory-threshold· 22
display memory-threshold dma· 24
display power 24
display resource-monitor 27
display transceiver active-control 28
display transceiver advertising· 29
display transceiver alarm·· 31
display transceiver application· 32
display transceiver diagnosis· 33
display transceiver history performance-collection· 35
display transceiver interface· 38
display transceiver itu-channel 39
display transceiver manuinfo· 40
display transceiver optics interface· 41
display transceiver status· 42
display transceiver vdm·· 44
fdisk-flash slot 45
hardware-failure-detection· 46
hardware-resource acl-hash· 47
hardware-resource mdb· 47
hardware-resource opttask-delay· 48
hardware-resource port-speed· 49
hardware-resource scd-port-speed· 50
hardware-resource smartman· 50
hardware-resource synce· 51
hardware-resource telemetry-stream·· 52
itu-channel 52
locator blink· 53
memory-threshold· 54
memory-threshold dma· 56
memory-threshold usage· 57
monitor chipblock reset 57
monitor cpu-usage enable· 58
monitor cpu-usage interval 59
monitor cpu-usage threshold· 59
monitor resend cpu-usage· 60
monitor resend cpu-usage core-interval 61
monitor resend memory-threshold dma· 62
parity-error consistency-check log enable· 63
parity-error consistency-check threshold· 64
parity-error monitor log enable· 64
parity-error monitor period· 65
parity-error monitor threshold· 66
parity-error unrecoverable log enable· 67
parity-error unrecoverable period· 68
parity-error unrecoverable reboot 68
parity-error unrecoverable threshold· 69
power-exception-monitor 70
power-monitor enable· 71
power-supply off 71
power-supply on· 72
power-supply policy enable· 72
power-supply policy redundant 73
power-supply surplus-power enable· 74
reset transceiver interface· 74
resource-monitor minor resend enable· 75
resource-monitor output 76
resource-monitor resource· 76
shutdown-interval 78
system handshake timeout 79
temperature-limit 80
transceiver diagnostic selector 81
transceiver host-fault-detect enable· 82
transceiver lane enable· 83
transceiver lane equalization· 83
transceiver lane loopback· 85
transceiver lane pattern· 86
transceiver monitor enable· 87
transceiver monitor interval 88
transceiver media-fault-detect enable· 88
transceiver optical-channel frequency· 89
transceiver optical-channel tx-power 90
transceiver performance-collection enable· 91
transceiver performance-collection interval 91
transceiver power-mode· 92
display alarm
Use display alarm to display device hardware alarm information.
display alarm [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays alarm information for all cards.
# Display device hardware alarm information.
<Sysname> display alarm
Slot CPU Level   Info
1    0   ERROR   faulty
Slot
Slot that generated the alarm. If the alarm was generated by the frame, this field displays a hyphen (-).
Level
Alarm severity. Possible values include ERROR, WARNING, NOTICE, and INFO, in descending order.
Info
Detailed alarm information:
·     faulty—The slot is starting up or faulty.
·     Fan n is absent—The specified fan is absent.
·     Power n is absent—The specified power module is absent.
·     Power n is faulty—The specified power module is faulty.
·     The temperature of sensor n exceeds the lower limit—The temperature of the specified sensor is lower than the low-temperature threshold.
·     The temperature of sensor n exceeds the upper limit—The temperature of the specified sensor is higher than the high-temperature warning threshold.
Use display alarm active to display information about active alarms.
If the device is operating abnormally, you can use the display alarm command to view alarm information. To view historical alarms that have been cleared, use the display alarm history command. To view active alarms that have not been cleared, use the display alarm active command.
# Display information about active alarms.
<Sysname>display alarm active
Seq         Level    Time                 Info
24          MINOR    2020-01-11 12:40:00  CPU usage is in minor alarm state on slot 1 cpu 0.
23           MINOR    2020-01-11 12:30:00  Memory usage is in minor alarm state on slot 1 cpu 0.
22           WARNING  2020-01-11 12:30:00  Interface GigabitEthernet2/0/2 changed to DOWN state.
Seq
Alarm sequence number, assigned when an alarm occurs.
Level
Alarm severity. The values include CRITICAL, MAJOR, MINOR, and WARNING, in descending order of severity.
Time
Time when the alarm occurred.
Info
Detailed alarm information. The values include:
·     Memory usage is in minor alarm state on slot xx cpu xx—The free memory size available to the specified CPU is below the minor alarm threshold.
·     Memory usage is in severe alarm state on slot xx cpu xx—The free memory size available to the specified CPU is below the severe alarm threshold.
·     Memory usage is in critical alarm state on slot xx cpu xx—The free memory size available to the specified CPU is below the critical alarm threshold.
·     CPU usage is in minor alarm state on slot xx cpu xx—The usage of the specified CPU has exceeded the minor alarm threshold.
·     CPU usage is in critical alarm state on slot xx cpu xx—The usage of the specified CPU has exceeded the critical alarm threshold.
·     Interface interface-name changed to DOWN state—The specified interface went down.
Use display alarm history to display information about historical alarms that have been cleared.
display alarm history [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information.
If the device is operating abnormally, use the display alarm command to view the alarm information. To view historical alarms that have been cleared, use the display alarm history command. To view active alarms that have not been cleared on the device, use the display alarm active command.
The maximum number of historical alarms that can be displayed by this command varies by device model.
# Display information about historical alarms.
<Sysname> display alarm history
Seq         Time                 Info
23          2020-01-11 12:40:00  CPU usage severe alarm cleared on slot 1 cpu 0.
22          2020-01-11 12:30:00  Memory usage severe alarm cleared on slot 1 cpu 0.
21          2020-01-11 12:30:00  Physical state of GigabitEthernet2/0/2 changed back to UP.
20          2020-01-11 12:30:00 Protocol state of GigabitEthernet2/0/2 changed back to UP.
Seq
Level
Time
Time when the alarm occurs.
Info
# Display detailed information about historical alarms.
<Sysname> display alarm history verbose
Seq 24
Alarm name: CPUUsageMajor
Alarm source: Slot 1 cpu 0
Level: MAJOR
Occurred at: 2020-01-11 12:30:00
  Info: CPU usage severe alarm occurred on state slot 1 cpu 0.
Cleared at: 2020-01-11 12:40:30
  Info: CPU usage severe alarm cleared on slot 1 cpu 0.
Seq 23
Alarm name: MemoryUsageMajor
Level: MAJOR
Alarm source: Slot 1 CPU 0
Occurred at: 2020-01-11 12:35:00
  Info: Memory usage severe alarm occurred on slot 1 cpu 0.
Cleared at: 2020-01-11 12:45:30
  Info: Memory usage severe alarm cleared on slot 1 cpu 0.
Seq
Alarm sequence number, assigned automatically by the system when an alarm occurs.
Alarm name
Name of the alarm.
AlarmPosition
Location where the alarm occurred.
Occurred at
Level
Cleared at
Time when the alarm is cleared.
Info
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
summary: Displays CPU usage statistics in table form. If you do not specify this keyword, the command displays CPU usage statistics in text form.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CPU usage statistics for all cards.
cpu cpu-number: Specifies a CPU by its number.
core core-number: Specifies a CPU core by its number.
core all: Specifies all CPU cores.
If two hyphens (--) are displayed for the CPU usage during the most recent 5-second, 1-minute, and 5-minute intervals, the command might fail to obtain data from the database on the device. Try the command later.
# Display the current CPU usage statistics in text form.
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# Display the current CPU usage statistics in table form.
Slot CPU        Last 5 sec        Last 1 min        Last 5 min
1    0          17%               29%               28%
Table 5 Command output
x% in last 5 seconds
Last 5 sec
Average CPU usage during the most recent 5-second interval. If this statistics collection feature is not supported, two hyphens (--) are displayed.
y% in last 1 minute
Last 1 min
Average CPU usage during the most recent 1-minute interval. If this statistics collection feature is not supported, two hyphens (--) are displayed.
z% in last 5 minutes
Last 5 min
Average CPU usage during the most recent 5-minute interval. If this statistics collection feature is not supported, two hyphens (--) are displayed.
Use display cpu-usage configuration to display CPU usage monitoring settings.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CPU usage monitoring settings for the active MPU.
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 99%.
Current minor alarm threshold is 79%.
Table 6 Command output
CPU usage tracking is enabled.
Sampling interval for CPU usage tracking is 60 seconds.
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
job job-id: Specifies a process by its ID. The value range for job-id is 1 to 2147483647. If you do not specify a process, this command displays the statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Command Reference.
slot slot-number: Specifies a card by its slot number. If you specify a process but do not specify a card, this command displays the statistics for the process on the active MPU. If you do not specify any options, this command displays the statistics for all processes on all cards.
cpu cpu-number: Specifies a CPU by its number. If you specify a process but do not specify a CPU, this command displays the statistics for the default CPU. If you do not specify a process or CPU, this command displays the historical statistics for all CPUs.
After CPU usage tracking is enabled, the system regularly samples CPU usage and saves the samples to a buffer. This command displays the most recent 60 samples in a coordinate system as follows:
·     The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
·     The horizontal axis represents the time.
·     Pound signs (#) indicate the CPU usage. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
# Display the historical CPU usage statistics.
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
The output shows the following items:
·     Process name. The name SYSTEM represents the entire system.
·     CPU that is holding the process: CPU 0 in slot 1.
·     Historical CPU usage statistics for the entire system during the last 60 minutes.
¡     12 minutes ago—Approximately 5%.
¡     13 minutes ago—Approximately 10%.
¡     14 minutes ago—Approximately 15%.
¡     15 minutes ago—Approximately 10%.
¡     16 and 17 minutes ago—Approximately 5%.
¡     18 minutes ago—Approximately 10%.
¡     19 minutes ago—Approximately 5%.
¡     Other time—2% or lower.
display device
Use display device to display device hardware information.
display device [ flash | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ]
flash: Displays flash memory information.
usb: Displays USB interface information.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards.
subslot subslot-number: Specifies a subcard by its subslot number. If you do not specify a subcard, this command does not display information about any subcards.
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information, and does not display firewall card information.
If you do not specify the flash and usb keywords, this command displays hardware information about cards.
# Display device hardware information.
<Sysname> display device
Slot Type             State    Subslot  Soft Ver             Patch Ver
0    LSXM1SUPER1      Master   0        S12508R-5202         None
1    LSXM1SUPER1      Standby  0        S12508R-5202         None
2    NONE             Absent   0        NONE                 None
3    LSXM1CGQ48KBR1   Normal   0        S12508R-5202         None
4    NONE             Absent   0        NONE                 None
5    NONE             Absent   0        NONE                 None
6    NONE             Absent   0        NONE                 None
7    NONE             Absent   0        NONE                 None
8    NONE             Absent   0        NONE                 None
9    NONE             Absent   0        NONE                 None
10   NONE             Absent   0        NONE                 None
11   NONE             Absent   0        NONE                 None
12   NONE             Absent   0        NONE                 None
13   NONE             Absent   0        NONE                 None
14   NONE             Absent   0        NONE                 None
15   LSXM1SFK08FR1    Normal   0        S12508R-5202         None
Table 7 Command output
Hardware type of the card.
Status
Card status:
·     Standby—The card is the standby MPU.
·     Master—The card is the active MPU.
·     Absent—The slot is not installed with a card.
·     Fault—The card is faulty and cannot start up.
·     Normal—The card is an interface module and is operating correctly.
·     Offline-OLO—The card is a switching fabric module and is isolated.
Soft Ver
Software version of the card.
Patch Ver
Most recently released patch image version that is running on the device. If no patch image is installed, this field displays None.
If both incremental and non-incremental patch images are running on the device, this field displays the most recently released incremental patch image version. For more information about patch image types, see "Upgrading software."
Use display device manuinfo to display hardware electronic label information for the device.
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays hardware electronic label information of all cards.
An electronic label contains the permanent configuration information, including the hardware serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during hardware debugging or testing. This command displays only part of the electronic label information.
# Display hardware electronic label information for the device.
<Sysname> display device manuinfo
Use display device manuinfo chassis-only to display electronic label information for the backplane.
# Display electronic label information for the backplane.
<Sysname> display device manuinfo chassis-only
Use display device manuinfo fan to display electronic label information for a fan tray.
display device manuinfo fan fan-id
fan-id: Specifies a fan tray by its ID.
# Display electronic label information for a fan tray.
<Sysname> display device manuinfo fan 1
Use display device manuinfo power to display electronic label information for a power module.
display device manuinfo power power-id
power-id: Specifies a power module by its ID.
# Display electronic label information for a power module.
<Sysname> display device manuinfo power 1
display environment
Use display environment to display temperature information.
This command displays information about all temperature sensors on the device if you do not specify a card.
# Display information about all temperature sensors on the device.
<Sysname> display environment
System temperature information (degree centigrade):
 Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 1     hotspot 1 26           0      75       90     95
 1     hotspot 2 49           0      88       96     104
 1     hotspot 3 49           0      75       90     95
 1     hotspot 4 28           0      88       96     104
 1     hotspot 5 31           0      75       90     95
 1     hotspot 6 25           0      88       96     104
 1     chip    0 38           0      60       60     90
 1     cpu     1 21           0      102      102    NA
Table 8 Command output
System Temperature information (degree centigrade)
Temperature information (°C).
sensor
Temperature sensor:
·     hotspot—Hotspot sensor.
·     cpu—CPU temperature sensor.
·     chip—Chip temperature sensor.
Slot
Sensor position. For a sensor on the chassis or fan tray, this field displays Vent.
Temperature
Current temperature.
Lower
Lower temperature limit. If the device does not support this field, this field displays NA.
Warning
Warning temperature threshold. If the device does not support this field, this field displays NA.
Alarm
Alarming temperature threshold. If the device does not support this field, this field displays NA.
Shutdown
Shutdown temperature threshold. When the sensor temperature reaches the limit, the system shuts down automatically. If the device does not support this field, this field displays NA.
display fan
Use display fan to display fan tray operating status information.
display fan [ fan-id ]
fan-id: Specifies a fan tray by its ID. If you do not specify a fan tray, this command displays operating status information for all fan trays at the specified position.
# Display the operating states of all fan trays.
<Sysname> display fan
Fan-tray 1:
 Status    : Normal
 Fan Type  : LSXM108XFAN
 Fan number: 3
 Fan mode  : Auto
 Airflow Direction: Fan-Panel-Exhaust
 Fan  Speed(rpm)
  1   4615
  2   4705
  3   4589
 Fan-tray 2:
 Status    : Normal
 Fan number: 3
 Fan mode  : Auto
 Fan  Speed(rpm)
  1   4749
  2   4649
  3   4560
---- More ----
Table 9 Command output
Fan-tray
Fan tray ID.
Status
Fan tray status:
·     Absent—No fan tray is present in the slot.
·     Normal—The fan tray is operating correctly.
·     Fault—The fan tray is faulty.
Fan Type
Fan tray model.
Fan number
Number of fan trays.
Fan mode
Operating mode of fan trays.
Airflow Direction
Actual airflow direction:
·     Fan-Panel-Exhaust—Fan panel side exhaust airflow.
·     Fan-Panel-Intake—Fan panel side intake airflow.
Fan  Speed(rpm)
Fan speed.
display fdisk-flash
Use display fdisk-flash to display disk partition information.
This command is available only in R5212P01 and later.
display fdisk-flash slot slot-id
slot slot-id: Specifies the number of the slot where the MPU resides on the modular device.
# Display disk partition information.
<sysname> display fdisk-flash slot 0
New partition mode on slot 0 size 2GB
Use display hardware-failure-detection to display the hardware failure detection settings and the latest 10 fix records for each card.
In standalone mode, the fix records are stored on the active MPU. You can use the display hardware-failure-detection command to display the records for a card even if the card is removed or replaced. The fix records are lost only when you remove or power cycle the active MPU.
# Display hardware failure detection settings and fix records.
<Sysname> display hardware-failure-detection
Current level:
    chip       : isolate
    board      : isolate
    forwarding : warning
Recent record:
--------------------------Slot  0 executed records:-----------------------------
                 There is no record.
--------------------------Slot  0 trapped records:-----------------------------
                 There is no record.
Table 10 Command output
Current level
Fix actions specified for hardware failures.
chip
Fix action for hardware failures on components of cards.
board
Fix action for hardware failures on control paths.
forwarding
Fix action for hardware failures on the forwarding plane.
Recent record
Recent failure fix records.
xxx executed records
Fix records stored on an MPU.
xxx trapped records
Trap records stored on an MPU.
Use display hardware-resource acl-hash to display information about the ACL hash mode.
# Display information about the ACL hash mode.
<Sysname> display hardware-resource acl-hash
acl-hash mode(acl-hash), all supported modes:
  disable       Disable ACL hash mode with hash result calculated by the chip
  enable        Enable ACL hash mode with hash result calculated by the ACL
  Default       Current       Next
  disable       disable       disable
Use display hardware-resource mdb to display the hardware resource allocation mode information.
display hardware-resource [ mdb ]
If you do not specify the mdb keyword, this command displays the allocation modes for all hardware resources.
# Display the allocation mode information for the MAC address table resources, ARP table resources, and routing tables.
<Sysname> display hardware-resource mdb
MDB resource(mdb), all supported modes:
  normal        The normal  mode:MAC 506K, ARP 88K, route 1.5M
  routing       The routing mode:MAC 155K, ARP 98K, route 2.5M
  routing       routing       routing
Use display hardware-resource bfd_enhance to display the status information of enhanced BFD.
display hardware-resource [ bfd_enhance ]
# Display the status information of enhanced BFD.
<Sysname> display hardware-resource bfd_enhance
bfd_enhance mode(bfd_enhance), all supported modes:
  disable       The disable bfd enhance
  enable        The enable bfd enhance
  Default       Current
  enable        enable
Use display hardware-resource opttask-delay to display information about module identification delay on MACsec-enabled interfaces.
# Display information about module identification delay on MACsec-enabled interfaces.
<Sysname> display hardware-resource opttask-delay
opt task delay mode :
 slot  2 : enable
 slot  3 : enable
 slot  4 : disable
 slot  5 : enable
 slot  6 : enable
 slot  7 : enable
 slot  8 : enable
 slot  9 : enable
Use display hardware-resource port-speed to display the port speed mode information of the LSXM1CGQ72KCR1 interface module.
display hardware-resource [ port-speed ]
# Display the port speed mode information of the LSXM1CGQ72KCR1 interface module.
<Sysname> display hardware-resource port-speed
Set card port speed module,only effect for LSXM1CGQ72KCR1 card(port-speed), all
supported modes:
  low           low speed module,72*100GB avilable ports
  high          high speed module, 36*200GB avilable ports
  mix           mix speed module, 36*100GB and 18*200GB avilable ports
  Slot Module
     2 low
     3 low
     4 low
     5 low
     6 low
     7 low
     8 low
     9 low
Use display hardware-resource scd-port-speed to display the port speed mode information of the LSXM1TGS24C1 expansion interface module.
display hardware-resource [ scd-port-speed ]
# Display the port speed mode information of the LSXM1TGS24C1 expansion interface module.
<Sysname>display hardware-resource scd-port-speed
Set subcard port speed module,only effect for LSXM1TGS24C1 subcard(scd-port-spee
d), all supported modes:
  low           subcard low speed module, 10GB avilable ports
  high          subcard high speed module, 25GB avilable ports
  Slot Module
     2 low
Use display hardware-resource smartman to display the port licensing status information.
display hardware-resource [ smartman ]
# Display the port licensing status information.
<Sysname> display hardware-resource smartman
smartman mode(smartman), all supported modes:
  disable       The disable smartman mode
  enable        The enable smartman mode
Use display hardware-resource synce to display status information of SyncE frequency synchronization.
The LSXM1CGMS48KBR1 card does not support this command.
# Display status information of SyncE frequency synchronization.
<Sysname> display hardware-resource synce
synce mode(synce),all supported modes:
disable The disable synce mode
enable The enable synce mode
Use display hardware-resource telemetry-stream to display the type of interface index to be collected by telemetry stream from packets.
This command is available only in R5212P06 and later.
# Display the type of interface index to be collected by telemetry stream from packets.
<Sysname> display hardware-resource telemetry-stream
telemetry-stream, all supported modes:
link-aggregation-memberports   The trunk members are mapped to the ifindex of th
e physical port in the telemetry stream.
link-aggregation               The trunk members are mapped to the ifindex of th
e trunk in the telemetry stream.
  Default                            Current
  link-aggregation                   link-aggregation
display memory
Use display memory to display memory usage information.
summary: Displays brief information about memory usage. If you do not specify this keyword, the command displays detailed information about memory usage.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays memory usage for all cards.
If two hyphens (--) are displayed for all the fields in a line of the command output, the command might fail to obtain data from the database on the device. Try the command later.
# Display detailed memory usage information.
<Sysname> display memory
Memory statistics are measured in KB:
Slot 0:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:      16335164   4145632  12189532         0      8596   2472508       77.5%
-/+ Buffers/Cache:   1664528  14670636
Swap:            0         0         0
Container memory statistics are measured in KB:
Slot 0:
             Total      Used      Free  UsageRatio
Mem:      16335164   2357588  12189532       14.4%
# Display brief memory usage information.
<Sysname> display memory summary
Slot CPU        Total      Used      Free  Buffers    Caches FreeRatio
   0   0     16335164   4144720  12190444     8596   2472508     77.5%
Slot CPU        Total      Used      Free  UsageRatio
   0   0     16335164   2358048  12190444       14.4%
Table 11 Command output
Memory usage information on the physical device, in KB.
Mem
Memory usage information.
Total
Total size of the physical memory space that can be allocated.
The memory space is virtually divided into two parts. Part 1 is solely used for kernel code and kernel management functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
If this field is not supported, two hyphens (--) are displayed.
Buffers
Physical memory used for buffers.
Cached
Caches
Physical memory used for caches.
FreeRatio
Free memory ratio.
-/+ Buffers/Cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Memory space for swapping.
LowMem
Low-memory usage information.
HighMem
High-memory usage information.
Container memory usage information, including:
·     Total—Total size of the physical memory space that can be allocated in the Comware container, in KB.
·     Used—Used physical memory in the Comware container, in KB.
·     Free—Free physical memory in the Comware container, in KB.
·     UsageRatio—Free physical memory usage in the Comware container.
display memory dma
Use display memory dma to display DMA memory usage information.
display memory dma [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DMA memory usage information for all cards.
This command is available only in R5212 and later.
# Display DMA memory usage information.
<System> display memory dma slot 0
DMA memory statistics measured in KB on slot 0:
Total        Used         Free         FreeRatio
4177920      2434892      1743028      42%
Table 12 Command output
Total
Total size of the DMA memory space, including the free and used DMA memory.
Used
Used DMA memory.
Free
Free DMA memory.
FreeRatio
Free DMA memory ratio.
Use display memory-threshold to display memory alarm thresholds and statistics.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the memory usage thresholds and statistics for the active MPU.
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
    Minor: 1024M
    Severe: 768M
    Critical: 512M
    Normal: 1280M
    Early-warning: 0M
    Secure: 0M
Current memory state: Normal
Event statistics:
 [Back to normal state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Enter minor low-memory state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to minor low-memory state]
 [Enter severe low-memory state]
 [Back to severe low-memory state]
 [Enter critical low-memory state]
Use display memory-threshold dma to display DMA memory alarm information.
display memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DMA memory alarm information for the active MPU.
# Display DMA memory alarm information.
<Sysname> display memory-threshold dma
Free DMA memory thresholds:
    Critical: 2048KB
    Normal: 4096KB
Current DMA memory state: Normal
Free memory event statistics:
 [Entered to critcal state]
display power
Use display power to display power module information.
display power [ power-id ]
power-id: Specifies a power module by its ID. If you do not specify a power module, this command displays information about all power modules at the specified position.
# Display brief power module information.
<Sysname> display power
 Power supply policy     : Enabled
 Surplus sleeping        : Disabled
 Power modules installed : 2
 Power modules usable    : 2
 Total power             : 4800W
 Redundant power         : 0W
 Sleeping  power         : 0W
 Available power         : 4800W
 Allocated power         : 1633W
 Remaining power         : 3167W
 PowerID State     InPower(W)  Current(A)  Voltage(V)  OutPower(W)     Type
   Input
  1      Normal      2400        4.00        53.78       215.12     PSR2400-54A
    AC
  2      Normal      2400        1.50        53.76        80.64     PSR2400-54A
    AC
  3      Absent       --          --          --           --          ---
  4      Absent       --          --          --           --          ---
  5      Absent       --          --          --           --          ---
  6      Absent       --          --          --           --          ---
  7      Absent       --          --          --           --          ---
  8      Absent       --          --          --           --          ---
 Information about reserved power:
  Slot  Status  Power(W)   Remarks
   0    Normal     55      Powered on
   1    Absent     55      Reserved for MPU
   3    Normal    577      Powered on
  14    Normal    156      Powered on
 Power information for fans:
  Fan[1]: 390W
  Fan[2]: 390W
Table 13 Command output
Power supply policy
Status of power supply management:
·     Enabled—Power supply management is enabled.
·     Disabled—Power supply management is disabled.
Surplus sleeping
Power module sleeping status:
·     Enabled—The power module sleeping feature is enabled.
·     Disabled—The power module sleeping feature is disabled.
Number of power modules installed on the device.
Number of used power modules, which are in normal or sleeping state.
Total power
Total power of power modules, in watts.
Redundant power
Power of redundant supplies, in watts.
Sleeping power
Power of sleeping supplies, in watts.
Available power
Power value (in watts) at full load, which is the total maximum power values of all modules in the system.
Allocated power
Power used by the device, in watts.
Remaining power
Remaining power of the device, in watts.
PowerID
Power module ID.
Power module status:
·     Absent—The slot is not installed with a power module.
·     Normal—The power module is operating correctly.
·     Fault—The power module is faulty.
·     Sleeping—The power module is sleeping.
InPower(W)
Device input power, in watts.
Current(A)
Output current of the power module, in amperes.
Voltage(V)
Output voltage of the power module, in volts.
OutPower(W)
Output power of the power module, in watts.
Model of the power module.
Information about reserved power of cards.
Slot
Slot number.
Status
Status of the card:
·     Normal—The card is operating correctly.
·     Fault—The card is faulty or has not started up.
Power(W)
Reserved power of a card, in watts.
Remarks
Description for reserved power of a card:
·     Reserved for MPU
·     Powered on
·     Not enough power to power it on
·     Reserved for a non-MPU card
·     Powered off
Information about reserved power for fans.
Fan[x]
Fan tray ID.
Use display resource-monitor to display resource monitoring information.
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
resource resource-name: Specifies a resource type by its name.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays resource monitoring information for all cards.
# Display ARP resource monitoring information.
<Sysname> display resource-monitor resource arp
Minor alarms resending: Enabled
Slot 1:
Resource                         Minor Severe Free/Total
                                 (%)   (%)    (absolute)
arp                              50    20     90095/90098
Table 14 Command output
Status of the minor resource depletion alarm resending feature, Enabled or Disabled.
Resource
Monitored resource type.
Minor
Minor resource depletion threshold, in percentage.
Severe
Severe resource depletion threshold, in percentage.
Free/Total
(absolute)
Numbers of available resources and total resources, in absolute values.
Use display transceiver active-control to display active control information of a 400G transceiver module.
display transceiver active-control interface [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command applies to all interfaces.
# Display active control information of the 400G transceiver module in FourHundredGigE 1/0/1.
<Sysname> display transceiver active-control interface fourhundredgige 1/0/1
<Sysname> display transceiver active-control interface interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver active-control setting information:
Current working mode     :400G-SR8
  Lane   LowestHostLane   RxPre-Cursor    RxPost-Cursor   RxAmplitude
  Lane1  Lane1            0.5 dB          1 dB            100-400 mV
  Lane2  Lane1            0.5 dB          1 dB            100-400 mV
  Lane3  Lane1            0.5 dB          1 dB            100-400 mV
  Lane4  Lane1            0.5 dB          1 dB            100-400 mV
  Lane5  Lane5            0.5 dB          1 dB            100-400 mV
  Lane6  Lane5            0.5 dB          1 dB            100-400 mV
  Lane7  Lane5            0.5 dB          1 dB            100-400 mV
  Lane8  Lane5            0.5 dB          1 dB            100-400 mV
Table 15 Command output
Current operating mode of the transceiver module.
Lane
Lane number.
LowestHostLane
Lowest-numbered host lane in the lane group to which the lane belongs.
RxPre-Cursor
Rx output equalization pre-cursor.
RxPost-Cursor
Rx output equalization post-cursor.
RxAmplitude
Rx output amplitude.
Use display transceiver advertising to display advertising information of 400G transceiver modules.
display transceiver advertising interface [ interface-type interface-number ]
# Display the advertising information of the 400G transceiver module in interface FourHundredGigE 1/0/1.
<Sysname> display transceiver advertising interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver advertising information:
  CMIS Revision                      : 3.0
  Versatile Diagnostic Monitoring    : YES
  Tx clock recovery capabilities     : Tx input lanes 1-4 and 5-8 to be in separate Tx synchronous groups
  Max Tx Input Eq(dB)                : 9
  Max Rx Output Eq Pre-cursor(dB)    : 1.5
  Max Rx Output Eq Post-cursor(dB)   : 3
  Tx disable implemented             : YES
  Tx Force Squelch implemented       : YES
  Tx Squelch implemented             : NO
  Tunable transmitter                : YES
  Tx bypass CDR implemented          : YES
  Rx bypass CDR implemented          : YES
  Tx Input Eq Adaptive               : YES
  CDB implemented                    : NO
Table 16 Command output
CMIS revision
QSFP-DD CMIS version. The value is 3.0 or 4.0.
Versatile diagnostic monitoring
Support for versatile diagnostic monitoring:
·     YES.
·     NO.
Clock recovery capabilities when the transceiver module acts as the transmitter:
·     All Tx input lanes to be in a single Tx synchronous group.
·     Tx input lanes 1-4 and 5-8 to be in separate Tx synchronous groups.
·     Tx input lanes 1-2, 3-4, 5-6, 7-8 to be in separate Tx synchronous groups.
·     Each Tx input lane to be in a separate Tx synchronous group.
Max Tx input Eq (dB)
Maximum Tx Input Equalization control value.
Max Rx output Eq pre-cursor (dB)
Maximum Rx output Eq pre-cursor control value.
Max Rx output Eq post-cursor (dB)
Maximum Rx output Eq post-cursor control value.
Support for Tx disable:
·     YES.
·     NO.
Support for Tx Force Squelch:
·     YES.
·     NO.
Support for Tx Squelch:
·     NO.
·     OMA—Implements Tx Squelch based on OMA.
·     Pave—Implements Tx Squelch based on Pave.
·     Both—Implements Tx Squelch based on OMA or Pave as needed.
Tunable transmitter
Indicates whether the transmitter is tunable:
·     YES.
·     NO.
Support for bypass CDR when the transceiver module acts as the transmitter:
·     YES.
·     NO.
Support for bypass CDR when the transceiver module acts as the receiver:
·     YES.
·     NO.
Tx input Eq adaptive
Support for the input equalization adaptive control when the transceiver module acts as the transmitter:
·     YES.
·     NO.
CDB implemented
Support for CDB:
·     NO.
·     One instance of CDB—Supports one CDB instance.
·     Two instances of CDB—Supports two CDB instances.
·     Unknown.
Use display transceiver alarm to display transceiver alarms.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
Table 17 shows the common transceiver alarm components. If no error occurs, "None" is displayed.
Table 17 Common transceiver alarm components
APD
Avalanche photo diode
PCS
Physical coding sublayer
PHY XS
PHY extended sublayer
PMA/PMD
Physical medium attachment/physical medium dependent
power
Optical power
REFCLK
Reference clock
RX
Receive
TEC
Thermoelectric cooler
Temp
Temperature
TX
Transmit
VDM
Versatile diagnostics monitoring
pre-FEC
Pre-forward error correction
BER
Bit error ratio
CFO
Carrier frequency offset
# Display the alarms present on the transceiver module in interface HundredGigE 1/0/1.
<Sysname> display transceiver alarm interface hundredgige 1/0/1
HundredGigE1/0/1 transceiver current alarm information:
  RX loss of signal
  RX power low
Table 18 Command output
Alarms present on the transceiver module.
RX loss of signal
Received signals are lost.
RX power low
Received power is low.
Use display transceiver application to display application related information for 400G transceiver modules.
display transceiver application interface [ interface-type interface-number ]
# Display application related information for the 400G transceiver module in interface FourHundredGigE 1/0/1.
<Sysname> display transceiver application interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver application information:
ApSel code: 0001b
     Host Electrical Interface code     Module Media Interface Code
     400GAUI-8 C2M                      400G-SR8
     Host Lane Count                    Media Lane Count
     8                                  8
     The Lowest host Lane               The Lowest media lane
     1                                  1
ApSel Code: 0010b
     IB EDR                             Undefined
     8                                  8
     1                                  1
Table 19 Command output
ApSel Code
Current application of the transceiver module represented by the
ApSel code.
Lowest-numbered media lane.
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters on transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on every transceiver module.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface HundredGigE 1/0/1.
<Sysname> display transceiver diagnosis interface hundredgige 1/0/1
HundredGigE1/0/1 transceiver diagnostic information:
    Temp(C)  Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    36        3.31        6.13      -35.64          -5.19
  Alarm thresholds:
           Temp(C)   Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    High   50         3.55        1.44      -10.00         5.00
    Low    30         3.01        1.01      -30.00         0.00
<Sysname> display transceiver diagnosis interface hundredgige 1/0/1:1
HundredGigE1/0/1:1 transceiver diagnostic information:
[module]  Temp.(C) Voltage(V)
          43         3.30
[channel] Bias(mA)  RX power(dBm)  TX power(dBm)
    1     7.39      -36.96         1.13
    2     7.39      -36.96         0.99
    3     7.39      -36.96         1.08
    4     7.39      -36.96         1.11
  Alarm thresholds:
          Temp.(C) Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    High  85         3.64        15.00     3.40           5.40
    Low   -15        2.97        3.00      -14.00         -12.10
# Display the current values of the digital diagnosis parameters on the transceiver module in interface FourHundredGigE 1/0/1.
<Sysname> display transceiver diagnosis interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver diagnostic information:
    [Module]   Temp(C)     Voltage(V)      TEC Current(%)   Laser Temp(C)
               40            3.34            38              53
    [Channel]   Bias(mA)     RX power(dBm)  TX power(dBm)
    1           1.13         -20.43               -1.0
    2           1.13         -20.43               -1.0
    3           1.13         -20.43               -1.0
    4           1.13         -20.43               -1.0
    5           1.13         -20.43               -1.0
    6           1.13         -20.43               -1.0
    7           1.13         -20.43               -1.0
    8           1.13         -20.43               -1.0
  Alarm thresholds:
    High  80         3.64        15.00     5.00           5.50
    Low   -10        2.97        4.50      -12.00         -3.50
          TEC Curr(%)   Laser Temp(C)
    High  N/A           N/A
    Low   N/A           N/A
  Warning thresholds:
    High  70         3.47        10.00     4.00           4.00
    Low   0          3.13        0.00      -9.50          -6.50
    High  N/A           N/A
    Low   N/A           N/A
# Display the current values of the digital diagnosis parameters on the transceiver module in interface FourHundredGigE 1/0/1. (This example is available only for a transceiver module that supports CMIS 4.0.)
<Sysname> isplay transceiver diagnosis interface fourhundredgige 1/0/1
  Alarm thresholds:
Media performance monitoring:
    Rx bits                            : 12345678901234567890
    Rx FEC corrected bits              : 12345678901234567890
    Rx frames                          : 12345678901234567890
    Rx uncorrectable frames            : 12345678901234567890
Host performance monitoring:
    Tx bits                            : 12345678901234567890
    Tx FEC corrected bits              : 12345678901234567890
    Tx frames                          : 12345678901234567890
    Tx uncorrectable frames            : 12345678901234567890
Table 20 Command output
Digital diagnosis information for the transceiver module in the interface.
Wave.er(nm)
Wavelength offset in nm, accurate to 0.001 nm. This field is supported only on the SFP-XG-LH80-Tunable transceiver module.
Freq.er(GHz)
Frequency offset in GHz, accurate to 0.1 GHz. This field is supported only on the SFP-XG-LH80-Tunable transceiver module.
[Module]
Parameters of the transceiver module.
Temp.(C)
Temperature in °C, accurate to 1°C.
Voltage(V)
Voltage in V, accurate to 0.01 V.
TEC Current(%)
TEC current in percentage, accurate to 0.01%.
Laser Temp(C)
Laser temperature in °C, accurate to 0.01°C.
[Channel]
Channel number. A channel is also referred to as a lane.
Bias(mA)
Bias current in mA, accurate to 0.01 mA.
RX power(dBm)
Receive power in dBm, accurate to 0.01 dBm.
TX power(dBm)
Transmit power in dBm, accurate to 0.01 dBm.
TEC Curr. (%)
Laser Temp(C)
Use display transceiver history performance-collection to display history performance sampling information of transceiver modules.
display transceiver history performance-collection interface [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays history performance sampling information on all transceiver modules.
This command is available only for the QSFPDD-400G-ZR transceiver module.
This command displays transceiver performance information of the most recent two sampling intervals.
# Display history performance sampling information of the transceiver module in FourHundredGigE 1/0/1.
<Sysname> display transceiver history performance interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver history performance information:
Time 2021-11-09 10:00:00 - 2021-11-09 11:00:00
VDM performance data:
Parameters                         Min            Max            Avg
CD-high granularity(Ps/nm)       : 0              0              0
DGD(Ps)                          : 0.00           0.00           0.00
PDL(dB)                          : 0.00           0.00           0.00
OSNR(dB)                         : 0.00           0.00           0.00
eSNR(dB)                         : 9.00           9.00           9.00
CFO(MHz)                         : 0              0              0
SOP ROC(krad/s)                  : 0              0              0
Tx Power(dBm)                    : -174.80        -9.39          -10.21
Rx total power(dBm)              : -30.22         -25.39         -25.59
Pre-FEC BER Media Input (Lane1)  : 1.00E00        1.00E00        1.00E00
FERC Media Input (Lane1)         : 1.00E00        1.00E00        1.00E00
Pre-FEC BER Host Input (Lane1)   : 0.00E-23       1.00E00        1.29E-07
FERC Host Input (Lane1)          : 0.00E-23       1.00E00        1.27E-04
    Rx bits                            : 3605
    Rx FEC corrected bits              : 3605
    Rx frames                          : 3605
    Rx uncorrectable frames            : 3605
    Rx Min uncorrect frames error      : 1
    Rx Max uncorrect frames error      : 1
    Rx post-FEC BER                    : 1.00E+00
    Tx bits                            : 1267250934611574
    Tx FEC corrected bits              : 164625007
    Tx frames                          : 1733738820
    Tx uncorrectable frames            : 220329
    Tx Min uncorrect frames error      : 0
    Tx Max uncorrect frames error      : 188832
    Tx post-FEC BER                    : 1.27E-04
Time 2021-11-09 09:00:00 - 2021-11-09 10:00:00
CFO(MHz)                         : 0              0              0
Tx Power(dBm)                    : -174.80        -9.39          -10.51
Rx total power(dBm)              : -30.30         -25.44         -25.59
Pre-FEC BER Host Input (Lane1)   : 0.00E-23       1.00E00        1.41E-07
FERC Host Input (Lane1)          : 0.00E-23       1.00E00        1.10E-05
    Rx bits                            : 3604
    Rx FEC corrected bits              : 3604
    Rx frames                          : 3604
    Rx uncorrectable frames            : 3604
    Tx bits                            : 1266782281942900
    Tx FEC corrected bits              : 179431912
    Tx frames                          : 1642561264
    Tx uncorrectable frames            : 18073
    Tx Max uncorrect frames error      : 9211
    Tx post-FEC BER                    : 1.10E-05
Table 21 Command output
Time yyyy-mm-dd hh:mm:ss - yyyy-mm-dd hh:mm:ss
Sampling time range.
Chromatic dispersion (high granularity), accurate to 0.01 ps/nm.
DGD(Ps)
Differential group delay in ps, accurate to 0.01 ps.
PDL(dB)
Polarization-dependent loss in dB, accurate to 0.01 dB
OSNR(dB)
Optical signal to noise ratio in dB, accurate to 0.1 dB.
eSNR(dB)
Echo signal to noise ratio in dB, accurate to 0.1 dB.
CFO(MHz)
Carrier frequency offset in MHz, accurate to 1 MHz.
SOP ROC(krad/s)
State-of-polarization rate-of-change in krad/s, accurate to 1 krad/s.
Tx Power(dBm)
Rx total power(dBm)
Total receive power in dBm, accurate to 0.01 dBm.
Use display transceiver interface to display the key parameters of transceiver modules.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface HundredGigE 1/0/1.
<Sysname> display transceiver interface hundredgige 1/0/1
HundredGigE1/0/1 transceiver information:
  Transceiver type                 : 400G_BASE_SR8_QSFPDD
  Connector type                   : MPO
  Wavelength (nm)                  : 850
  Transfer distance (m)            : 70(OM3),100(OM4)
  Max power(W)                     : 12
  Digital diagnostic monitoring    : Yes
  Vendor name                      : H3C
Table 22 Command output
Transceiver Type
Model of the transceiver module.
Connector Type
Connector type of the transceiver module:
·     Optical connectors, including SC connector developed by NTT, and 1.25mm/RJ45 LC connector developed by Lucent.
·     Other connectors, including RJ-45 and CX4.
Wavelength(nm)
For the transceiver module, this field displays central wavelength of the laser sent, in nm. If the transceiver module such as 10GBASE-LX4, supports multiple wavelengths, each wavelength value is separated by a comma.
For the electrical transceiver, this field displays N/A.
Transfer Distance(xx)
Transfer distance. For a single-mode transceiver module, the distance is measured in km. For other transceiver modules, the distance is measured in m. If the transceiver module supports multiple transfer media, the transfer distances are separated by commas. The corresponding transfer medium is enclosed in the brackets following the transfer distance value. The following are the transfer media:
·     9um—9/125 um single-mode optical fiber.
·     50um—50/125um OM 2 multi-mode optical fiber.
·     62.5um—62.5/125um OM 1 multi-mode optical fiber.
·     CX4—CX4 cable.
·     OM3—50 um OM3 multi-mode optical fiber.
·     OM4—50 um OM4 multi-mode optical fiber.
·     OM5—50 um OM5 multi-mode optical fiber.
·     STACK—Stack cable.
·     TP—Twisted pair cable.
Max power(W)
Maximum power of the transceiver module.
Digital Diagnostic Monitoring
Support for digital diagnostic monitoring:
·     Yes.
·     No.
Vendor Name
Vendor name or vendor name specified for the transceiver module.
Ordering Name
Ordering name of the transceiver module.
Use display transceiver itu-channel to display ITU channel information for transceiver modules.
display transceiver itu-channel interface [ interface-type interface-number [ supported-channel ] ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays ITU channel information for the transceiver modules on all interfaces.
supported channel: Specifies ITU channels supported on the interface. If this keyword is not specified, the command displays the ITU channel that is in use on the interface.
This command is available only for the SFP-XG-LH80-Tunable transceiver module.
# Display ITU channel information for the transceiver module on HundredGigE 1/0/1.
<Sysname> display transceiver itu-channel interface hundredgige 1/0/1
Interface                           Channel        WaveLength(nm)  Frequency(THz)
GE1/0/1                             1              1566.72         191.35
# Display ITU channels supported by the transceiver module on HundredGigE 1/0/1.
<Sysname> display transceiver itu-channel interface hundredgige 1/0/1 supported-channel
ITU channel settings supported on HundredGigE 1/0/1 :
1          1566.72           191.35
2          1566.31           191.40
3          1565.90           191.45
4          1565.50           191.50
5          1565.09           191.55
6          1564.68           191.60
7          1564.27           191.65
8          1563.86           191.70
Omitted…
Table 23 Command output
WaveLength(nm)
Wavelength of the channel in nm, accurate to 0.01 nm. This field displays a hyphen (-) in the following situations:
·     No transceiver module is installed on the interface.
·     The transceiver module does not support specifying an ITU channel number.
·     The command failed to obtain the ITU channel information.
·     The device does not support the ITU channel number stored on the transceiver module.
Frequency(THz)
Frequency of the channel in THz, accurate to 0.01 THz. This field displays a hyphen (-) in the following situations:
itu-channel
Use display transceiver manuinfo to display electronic label information for transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for the transceiver modules on all interfaces.
# Display electronic label information for the transceiver module in interface HundredGigE 1/0/1.
<Sysname> display transceiver manuinfo interface hundredgige 1/0/1
HundredGigE1/0/1 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2019-09-01
  Vendor Name          : H3C
Table 24 Command output
Manu. Serial Number
Serial number generated during debugging and testing.
Manufacturing Date
Debugging and testing date. The date takes the value of the system clock of the computer when debugging and testing is performed.
Vendor Name
The value is H3C.
Use display transceiver optics interface to display key optical parameters for transceiver modules.
display transceiver optics interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If no interface is specified, this command displays key optical parameters for all interfaces that support configuring optical parameters.
# Display key optical parameters for the transceiver module in interface FourHundredGigE 1/0/1.
<Sysname> display transceiver optics interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver optics information:
  Grid spacing                  : 50GHz,75GHz,100GHz
  Frequency                     : 194.10THz
  Configured output power       : -5.0dBm
  Configured grid spacing       : 50GHz
optics modulation-mode
optics tx-power
Use display transceiver status to display 400G transceiver module status information.
display transceiver status interface [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command applies to all interfaces.
# Display status information for the 400G transceiver module in interface FourHundredGigE 1/0/1.
<Sysname> display transceiver status interface fourhundredgige 1/0/1
FourHundredGigE1/0/1 transceiver status information:
  Module state        : ModuleReady
  Interrupt           : YES
  Host-fault-detect   : Enabled
  Media-fault-detect  : Disabled
  Lane      Data Path State     Media Lane State
  Lane1     Activated           Enable
  Lane2     Activated           Enable
  Lane3     Activated           Enable
  Lane4     Activated           Enable
  Lane5     Activated           Enable
  Lane6     Activated           Enable
  Lane7     Activated           Enable
  Lane8     Activated           Enable
  Loopback Mode       :
  Lane      Media Output   Media Input    Host Output    Host Input
  Lane1     Disable        Disable        Disable        Disable
  Lane2     Disable        Disable        Disable        Disable
  Lane3     Disable        Disable        Disable        Disable
  Lane4     Disable        Disable        Disable        Disable
  Lane5     Disable        Disable        Disable        Disable
  Lane6     Disable        Disable        Disable        Disable
  Lane7     Disable        Disable        Disable        Disable
  Lane8     Disable        Disable        Disable        Disable
# Display status information for the 400G ZR transceiver module in interface FourHundredGigE 1/0/1. (This example is available only for the QSFPDD-400G-ZR transceiver module.)
  Interrupt           : YES
  Loopback Mode       :
Table 25 Command output
Module status
Transceiver module status:
·     ModuleLowPwr—The transceiver module operates in low power.
·     ModulePwrUp—The transceiver module is powered on.
·     ModuleReady—The transceiver module is ready.
·     ModulePwrDn—The transceiver module is powered off.
·     Fault state—The transceiver module is faulty.
·     Unknown.
Interrupt alarm
Indicates whether the transceiver module is in interrupt alarm status:
·     Yes.
·     No.
Data path state
Data path status:
·     Unknown.
·     Deactivated.
·     Initial—The transceiver module is performing initialization tasks on the data path.
·     Deinit—The data path is deinitialized.
·     Activated.
·     TxTurnOn—Tx output is enabled.
·     TxTurnOff—Tx output is disabled.
·     Initialized—The data path is fully initialized.
Media Lane State
Media lane status:
·     Enabled.
·     Disabled.
Host-fault-detect
Fault detection status on the transceiver host side:
·     Enabled.
·     Disabled.
Media-fault-detect
Fault detection status on the transceiver media side:
·     Enabled.
·     Disabled.
Loopback Mode
Loopback testing mode of a lane on the transceiver module.
Media Output
Loopbacks the signal received by the receiver of the media side to the transmitter of the media side as the output signal of the media:
·     Enabled.
·     Disabled.
Media Input
Loopbacks the signal from the transmitter of the media side to the receiver of the media side as the input signal of the media:
·     Enabled.
·     Disabled.
Host Output
Loopbacks the signal received by the receiver of the host side to the transmitter of the host side as the output signal of the host:
·     Enabled.
·     Disabled.
Host Input
Loopbacks the signal from the transmitter of the host side to the receiver of the host side as the input signal of the host:
·     Enabled.
·     Disabled.
Use display transceiver vdm to display the versatile diagnostics monitoring (VDM) information of a transceiver module.
display transceiver vdm interface interface-type interface-number vdm-id vdm-id
vdm-id vdm-id: Specifies a VDM by its ID. The value range varies by transceiver module model.
This command is available only for 200G and 400G transceiver modules that support CMIS 4.0.
# Display the VDM 1 information of the transceiver module in FourHundredGigE 1/0/1.
<Sysname> display transceiver vdm interface fourhundredgige 1/0/1 vdm-id 1
VDM Description: Laser Temperature
Module/lane         VDM value(C)
Lane1               58.0
Alarm/Warning thresholds:
          Warning(C)     Alarm(C)
  High    80.0           85.0
  Low     0.0            251.0
# Display the VDM 2 information of the transceiver module in FourHundredGigE 1/0/1.
<Sysname> display transceiver vdm interface fourhundredgige 1/0/1 vdm-id 2
VDM Description: eSNR Host Input
Module/lane         VDM value(dB)
Lane1               0.0
          Warning(dB)    Alarm(dB)
  High    99.0           99.0
  Low     226.0          216.0
fdisk-flash slot
Use fdisk-flash slot to perform disk partitioning.
Use undo fdisk-flash slot to cancel disk partitioning.
fdisk-flash slot slot-id [ size size-value ]
undo fdisk-flash slot slot-id
No disk partition is performed.
Before partitioning a disk, perform the following tasks:
·     Back up files. Disk partitioning will clear all data on a disk.
·     Verify that no other users are accessing the disk during the partitioning process.
·     Make sure the disk is not write-protected.
Only the LSXM1SUP04TR1, LSXM1SUP02TR1, and LSXM2SUP02LR1 cards support disk partitioning.
For disk partitioning to take effect, restart the device and format the disk under BTW.
size size-value: Specifies the partition size in the range of 1 to 4 in GB. The default size is 2 GB.
# Perform disk partitioning.
<sysname> system-view
[Sysname] fdisk-flash slot 0
Please back up important files, if you do not back up, the data may be lost.
Whether to continue to divide [Y/N]:Y
New partition mode set successfully on slot 0!
Whether to restart immediately [Y/N]:Y
Now rebooting, please wait...
Use hardware-failure-detection to specify the action to be taken in response to hardware failures.
Use undo hardware-failure-detection to restore the default.
hardware-failure-detection { board | chip | forwarding } { isolate | off | reset | warning }
undo hardware-failure-detection { board | chip | forwarding }
The system takes the action of reset in response to hardware failures on chips, cards, and the forwarding plane.
board: Specifies failures on control paths and cards.
chip: Specifies failures on components of cards such as the chips, capacitances, resistances.
forwarding: Specifies failures on the forwarding plane (including services and other relevant items).
isolate: Takes one or more of the following actions:
·     Shuts down the relevant ports.
·     Prohibits loading software for the relevant cards.
·     Isolates the relevant cards.
·     Powers off the relevant cards to reduce impact from the failures.
off: Takes no action.
reset: Restarts the relevant components or cards to recover from failures.
warning: Sends traps to notify you of the failures.
The device automatically detects hardware failures on components, cards, and the forwarding plane. You can specify the actions to be taken in response to detected failures.
# Configure the device to send traps in response to failures on components.
[Sysname] hardware-failure-detection chip warning
Use hardware-resource acl-hash to enable or disable the ACL hash mode.
hardware-resource acl-hash { disable | enable }
The ACL hash mode is disabled.
disable: Disables the ACL hash mode. The hash result is calculated by the chip. When the chip calculates the hash result, the chip cannot differentiate between the source IP address and destination IP address in a 5-tuple. For example, if the hash option selects the source IP address, changes in the destination IP address will also affect the hash result.
enable: Enables the ACL hash mode. In this mode, the hash result is calculated by the ACL.
This command is applicable to common IPv4 packets not encapsulated packets or IPv6 packets. The configuration takes effect only after a device reboot.
# Enable the ACL hash mode.
[Sysname] hardware-resource acl-hash enable
Do you want to change the specified hardware resource working mode? [Y/N]: y
The hardware resource working mode is changed, please save the configuration and reboot the system to make it effective.
Use hardware-resource mdb to specify the allocation mode for MDB resources.
hardware-resource mdb { normal | routing }
The routing allocation mode is specified for MDB resources.
normal: Specify the normal allocation mode. In this mode, the MAC address table, ARP table, and routing table capacities are 506K, 88K, and 1.5M respectively.
routing: Specify the routing allocation mode. In this mode, the MAC address table, ARP table, and routing table capacities are 155K, 98K, and 2.5M respectively.
For this command to take effect, you must reboot the device.
# Specify the normal allocation mode for MDB resources.
[Sysname] hardware-resource mdb normal
Do you want to change the specified hardware resource working mode? [Y/N]:Y
Use hardware-resource opttask-delay to configure module identification delay on MACsec-enabled interfaces.
hardware-resource opttask-delay { enable | disable } [slot slot-number ]
Module identification delay is enabled on MACsec-enabled interfaces.
enable: Enables module identification delay on MACsec-enabled interfaces.
disable: Disables module identification delay on MACsec-enabled interfaces.
This command takes effect only on the LSXM1CDMS36KCR1, LSXM1CGQ72KCR1, and LSXM1CDQ18KCR1 interface modules.
To have a module identification delay change take efect on MACsec-enabled interfaces, restart the corresponding card.
# Enable module identification delay on MACsec-enabled interfaces a card.
[Sysname] hardware-resource opttask-delay enable slot 5
The port speed mode is changed, to make it effective please reboot the slot.
Use hardware-resource port-speed to specify the port speed mode for the LSXM1CGQ72KCR1 interface module.
hardware-resource port-speed { high | low | mix } [ slot slot-number ]
The low port speed mode is specified for the LSXM1CGQ72KCR1 interface module.
high: Specifies the high speed mode.
low: Specifies the low speed mode.
mix: Specifies the mix speed mode.
slot slot-number: Specifies an LSXM1CGQ72KCR1 interface module by its slot number. If you do not specify an LSXM1CGQ72KCR1 interface module, this command specifies the port speed mode for all LSXM1CGQ72KCR1 interface modules on the device.
This command is available only for the LSXM1CGQ72KCR1 interface module.
For a port speed mode change on an LSXM1CGQ72KCR1 interface module to take effect, you must restart the interface module.
# Specify the high port speed mode for the LSXM1CGQ72KCR1 interface module in slot 2.
[Sysname] hardware-resource port-speed high slot 2
Use hardware-resource scd-port-speed to specify the port speed mode for the LSXM1TGS24C1 interface module.
hardware-resource scd-port-speed { high | low } [ slot slot-number ]
The low port speed mode is specified for the LSXM1TGS24C1 interface module.
low: Specified the low speed mode.
slot slot-number: Specifies an LSXM1CGQ72KCR1 interface module by its slot number. If you do not specify an LSXM1TGS24C1 interface module, this command specifies the port speed mode for all LSXM1TGS24C1 interface modules on the device.
This command is available only for the LSXM1TGS24C1 interface module.
For a port speed mode change on an LSXM1TGS24C11 interface module to take effect, you must restart the interface module.
# Specify the high port speed mode for the LSXM1TGS24C1 interface module in slot 3.
[Sysname] hardware-resource scd-port-speed high slot 3
The subcard port speed mode is changed, to make it effective please insert the slot a LSXM1TGS24C1 subcard or reboot the slot if a LSXM1TGS24C1 subcard has already be inserted.
Use hardware-resource smartman to enable or disable port licensing.
hardware-resource smartman { enable | disable }
Port licensing is disabled.
enable: Enable port licensing.
disable: Disables port licensing.
To use license-based features, you need to install the licenses on the device. You can execute this command to have the installed licenses take effect as needed. If port licensing is enabled, the installed licenses on the device can take effect.
For an enabling status change to take effect, restart the device.
# Enable port licensing.
[Sysname] hardware-resource smartman enable
Use hardware-resource synce to enable or disable SyncE frequency synchronization on cards.
hardware-resource synce { enable | disable | default [ slot slot-number ] }
SyncE frequency synchronization is disabled on cards.
enable: Enables SyncE frequency synchronization.
disable: Disables SyncE frequency synchronization.
default: Specifies the default setting for a card. By default, SyncE frequency synchronization is enabled for the LSXM1CDQ36KBR1 card and SyncE frequency synchronization is disabled for a nono-LSXM1CGMS48KBR1 card. This keyword is available only in R5212 and later.
For this command to take effect, save the configuration and restart the device.
# Enable SyncE frequency synchronization on cards.
[Sysname] hardware-resource synce enable
Use hardware-resource telemetry-stream to configure the type of interface index to be collected by telemetry stream from packets.
hardware-resource telemetry-stream { link-aggregation | link-aggregation-memberports }
When a telemetry stream action is configured on an aggregation member interface, Layer 3 aggregate interface, or Layer 3 aggregate subinterface, telemetry stream collects the interface index of the aggregate interface.
link-aggregation: Configure telemetry stream to collect the interface index of the aggregate interface.
link-aggregation: Configure telemetry stream to collect the interface index of the aggregation member interface.
This command takes effect immediately.
# Configure telemetry stream to collect the interface index of the aggregate interface from packets.
[Sysname] hardware-resource telemetry-stream link-aggregation
Do you want to change the type of interface index to be collected? [Y/N]:Y
itu-channel
Use itu-channel to set the ITU channel number for a transceiver module.
Use undo itu-channel to restore the default.
itu-channel channel-number
undo itu-channel
The ITU channel number is 1.
Ethernet interface view
channel-number: Specifies the ITU channel number.
The ITU channel number is saved in a register on the transceiver module. It is not saved to the configuration file.
# Set the ITU channel number to 2 for the transceiver module on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] itu-channel 2
Changing the channel number causes the service to be down for a while. Continue? [Y/N]:Y
locator blink
Use locator blink blink-time to start LED flashing to locate devices.
Use locator blink stop to stop LED flashing.
locator blink stop
blink-time: Specifies the flash duration in seconds. The value range is 5 to 120.
stop: Stops flashing.
The device provides a LED for device locating. The locator blink blink-time command flashes the specified LEDs quickly for a period of time unless you execute the locator blink stop command. You can observe the LEDs to locate the devices.
# Start LED flashing to locate devices.
<Sysname> locator blink 30
# Stop LED flashing.
<Sysname> locator blink stop
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
Minor alarm threshold: 1024 MB.
Severe alarm threshold: 768 MB.
Critical alarm threshold: 768 MB.
Normal state threshold: 1280 MB.
Early-warning threshold: 1152 MB.
Sufficient-memory threshold: 1152 MB.
ratio: Specifies free-memory thresholds in percentage. If you do not specify this keyword, the command sets free-memory thresholds in MB.
minor minor-value: Specifies the minor alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the minor-value argument. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the severe-value argument. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the critical-value argument. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. To view the value range for this threshold, enter a question mark (?) in the place of the normal-value argument.
early-warning early-warning-value: Specifies the early-warning threshold. To view the value range for this threshold, enter a question mark (?) in the place of the early-warning-value argument. This option is available only in R5212 and later.
secure secure-value: Specifies the sufficient-memory threshold. To view the value range for this threshold, enter a question mark (?) in the place of the secure-value argument. This option is available only in R5212 and later.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets free-memory thresholds for the active MPU.
cpu cpu-number: Specifies a CPU by its number.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space decreases to or below the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules or processes.
The early warning feature warns you of an approaching insufficient-memory condition.
If a memory alarm occurs, delete unused configuration items or disable some features to increase the free memory space. Because the memory space is insufficient, some configuration items might not be able to be deleted.
By default, the severe alarm threshold and the critical alarm threshold are the same for the S12500R device. You can specify different severe and critical alarm thresholds as needed.
If the severe and critical alarm thresholds are the same, the system will restart a card if one of the following conditions is met:
·     After a severe alarm occurs, the remaining free-memory value has been smaller than the severe alarm threshold for 30 seconds.
·     The interval between two consecutive severe alarms is shorter than 30 seconds.
·     The severe alarm has occurred three times within three minutes.
·     After a severe alarm occurs, the system will periodically sample free memory space and predict if the free memory space will be exhausted within 30 seconds. If the prediction result indicates that the free memory space will be exhausted within 30 seconds, the system will restart the card.
If the severe and critical alarm thresholds are different, the system will restart a card if one of the following conditions:
·     After a critical alarm occurs, the remaining free-memory value has been smaller than the critical alarm threshold for 30 seconds.
·     The interval between two consecutive critical alarms is shorter than 30 seconds.
·     The critical alarm has occurred three times within three minutes.
·     After a critical alarm occurs, the system will periodically sample free memory space and predict if the free memory space will be exhausted within 30 seconds. If the prediction result indicates that the free memory space will be exhausted within 30 seconds, the system will restart the card.
For more information about the thresholds, see hardware resources management in System Management Configuration Guide.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 3%, 2%, 1%, and 5% of the total memory size, respectively.
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
Use memory-threshold dma to set DMA memory thresholds.
Use undo memory-threshold dma to restore the default.
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
The DMA memory alarm threshold is 2048 KB and the normal state threshold is 4096 KB.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets DMA memory thresholds for the active MPU.
ratio: Specifies DMA memory thresholds in percentage.
critical critical-value: Specifies the DMA memory alarm threshold. If the ratio keyword is specified, the value range for the critical-value argument is 1 to 100 in percentage. If the ratio keyword is not specified, the value range 0 for the critical-value argument is 1 to 4177920 in KB.
normal normal-value: Specifies the normal state threshold. If the ratio keyword is specified, the value range for the normal-value argument is 1 to 100 in percentage. If the ratio keyword is not specified, the device adjusts the value for the normal-value argument depending on the value for the critical-value argument.
To ensure correct operation of the services that require DMA memory, the system monitors the amount of free DMA memory space regularly. If the amount of free DMA memory space decreases to or below the alarm threshold, the system generates a notification and restarts the corresponding card.
# Set the DMA memory alarm threshold and the normal state threshold to 32KB and 96 KB, respectively.
[Sysname] memory-threshold dma slot 0 critical 32 normal 96
memory-threshold usage
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 100%.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the memory usage threshold for the active MPU.
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
The device samples memory usage at 1-minute intervals. If the sample is greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold usage 80
monitor chipblock reset
Use monitor chipblock reset to enable chip reset.
Use undo monitor chipblock to disable chip reset.
monitor chipblock reset [ logging ]
Chip reset is enabled.
logging: Logs the chip reset event.
When a chip is faulty, the system generates an alarm. If you use the monitor chipblock reset command to enable chip reset, the system resets a chip when an alarm indicating that the chip is faulty is generated.
# Enable chip reset.
[Sysname] monitor chipblock reset
monitor cpu-usage enable
Use monitor cpu-usage enable to enable CPU usage tracking.
Use undo monitor cpu-usage enable to disable CPU usage tracking.
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU usage tracking is enabled.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command enables CPU usage tracking for the active MPU.
After you enable CPU usage tracking, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage tracking.
[Sysname] monitor cpu-usage enable
display cpu-usage configuration
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
Use undo monitor cpu-usage interval to restore the default.
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
The system samples CPU usage every 1 minute.
interval: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec (5 seconds), 1Min (1 minute), and 5Min (5 minutes), case insensitive.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the interval for the active MPU.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage threshold
Use monitor cpu-usage threshold to set CPU usage alarm thresholds.
Use undo monitor cpu-usage threshold to restore the default.
monitor cpu-usage threshold severe-threshold [ minor-threshold minor-threshold recovery-threshold recovery-threshold ] [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ minor-threshold recovery-threshold ] [ slot slot-number [ cpu cpu-number ] ]
Severe CPU usage alarm threshold: 99%.
Minor CPU usage alarm threshold: 79%.
CPU usage recovery threshold: Not configured.
severe-threshold: Specifies the severe CPU usage alarm threshold in percentage. The value range for this argument is 2 to 100.
minor-threshold minor-threshold: Specifies the minor CPU usage alarm threshold in percentage. The value range for this argument is 1 to the severe CPU usage alarm threshold minus 1. If you do not specify this option, the minor CPU usage alarm threshold is 80 percent of the severe CPU usage alarm threshold.
recovery-threshold recovery-threshold: Specifies the CPU usage recovery threshold in percentage. The value range for this argument is 0 to the minor CPU usage alarm threshold minus 1. If you do not specify this option, the CPU usage recovery threshold is 70 percent of the severe CPU usage alarm threshold.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the CPU usage threshold for the active MPU.
CAUTION
CAUTION:
If you set the severe CPU usage alarm threshold to a too low value, the device will reach the threshold easily. Normal services will be affected.
The device samples CPU usage and CPU core usage at 1-minute intervals. If the sample is greater than the CPU usage threshold, the device sends a trap.
# Set the CPU usage alarm threshold to 90%.
[Sysname] monitor cpu-usage threshold 90
monitor resend cpu-usage
Use monitor resend cpu-usage to set CPU usage alarm resending intervals.
Use undo monitor resend cpu-usage to restore the default.
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
The minor CPU usage alarm resending interval is 300 seconds. The severe CPU usage alarm resending interval is 60 seconds.
minor-interval minor-interval: Specifies the minor CPU usage alarm resending interval in seconds, a multiple of 5 in the range of 10 to 3600.
severe-interval severe-interval: Specifies the severe CPU usage alarm resending interval in seconds, a multiple of 5 in the range of 10 to 3600.
The device samples CPU usage at intervals, and compares the samples with CPU usage thresholds to identify the CPU usage status and send alarms or notifications accordingly.
In minor alarm state, the device sends minor alarms periodically until the CPU usage increases above the severe threshold or the minor alarm is removed. In severe alarm state, the device sends severe alarms periodically until the severe alarm is removed. This command sets the alarm resending intervals.
If you do not specify a keyword for the undo monitor resend cpu-usage command, the command restores the default minor and severe CPU usage alarm resending intervals.
# Set the minor CPU usage alarm resending interval to 60 seconds for a slot.
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
monitor resend cpu-usage core-interval
Use monitor resend cpu-usage core-interval to set CPU core usage alarm resending intervals.
Use undo monitor resend cpu-usage core-interval to remove CPU core usage alarm resending interval settings.
monitor resend cpu-usage core-interval { minor-interval minor-interval | severe-interval severe-interval } * [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage core-interval [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
The resending interval is 300 seconds for minor CPU core usage alarms and 60 seconds for severe CPU core usage alarms.
minor-interval minor-interval: Specifies the resending interval for minor CPU core usage alarms in seconds, a multiple of 5 in the range of 10 to 3600.
severe-interval severe-interval: Specifies the resending interval for severe CPU core usage alarms in seconds, a multiple of 5 in the range of 10 to 3600.
The device samples CPU core usage at intervals, and compares the samples with CPU core usage thresholds to identify the CPU core usage status and send alarms or notifications accordingly.
In minor alarm state, the device sends minor alarms periodically until the CPU core usage increases above the severe threshold or the minor alarm is removed. In severe alarm state, the device sends severe alarms periodically until the severe alarm is removed. This command sets the alarm resending intervals.
# Set the resending interval for minor CPU core usage alarms to 100 seconds and the resending interval for severe CPU core usage alarms 60 seconds.
[Sysname] monitor resend cpu-usage core-interval minor-interval 100 severe-interval 60
monitor resend memory-threshold dma
Use monitor resend memory-threshold dma to set the DMA memory alarm resending interval.
Use undo monitor resend memory-threshold dma to restore the default.
monitor resend memory-threshold dma critical-interval critical-interval [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold dma critical-interval [ slot slot-number [ cpu cpu-number ] ]
The DMA memory alarm resending interval is 300 seconds.
critical-interval critical-interval: Specifies the resending interval for the DMA memory alarms in seconds, in the range of 10 to 3600.
The device samples DMA memory usage at intervals, and compares the samples with the DMA memory alarm threshold to identify the DMA memory usage status and send alarms or notifications accordingly.
# Set the resending interval for the DMA memory alarms to 100 seconds.
[Sysname] monitor resend memory-threshold dma critical-interval 100
parity-error consistency-check log enable
Use parity-error consistency-check log enable to enable consistency error logging for software and hardware forwarding entries.
Use undo parity-error consistency-check log enable to disable consistency error logging for software and hardware forwarding entries.
Consistency error logging is enabled for software and hardware forwarding entries.
To forward packets, the device generates hardware forwarding entries on forwarding chips and software forwarding entries in memory at the same time. The device automatically detects whether the hardware forwarding entries and the software forwarding entries are consistent.
After you execute this command, the device collects consistency errors periodically. If the number of consistency errors in a statistics period reaches or exceeds the logging threshold, the device generates and sends a log message to the information center module. The information center module determines how and where to send the message. For more information about the information center module, see information center configuration in System Management Configuration Guide.
# Enable consistency error logging for software and hardware forwarding entries.
[Sysname] parity-error consistency-check log enable
parity-error consistency-check threshold
Use parity-error consistency-check threshold to set the logging threshold for consistency errors between software and hardware forwarding entries.
Use undo parity-error consistency-check threshold to restore the default.
parity-error consistency-check threshold value
The logging threshold is 10.
value: Specifies the logging threshold for consistency errors between software and hardware forwarding entries, in the range of 1 to 2147483647.
After you enable consistency error logging for software and hardware forwarding entries, the device collects statistics for consistency errors periodically. If the number of consistency errors reaches or exceeds the logging threshold, the device generates a log message.
# Set the logging threshold to 20 for consistency errors between software and hardware forwarding entries.
[Sysname] parity-error consistency-check threshold 20
parity-error monitor log enable
Use parity-error monitor log enable to enable parity error and ECC error logging for entries on forwarding chips.
Use undo parity-error monitor log enable to disable parity error and ECC error logging for entries on forwarding chips.
In a version earlier than R2719P02, parity error and ECC error logging is disabled for entries on forwarding chips.
In R2719P02 and later, parity error and ECC error logging is enabled for entries on forwarding chips.
The device automatically detects parity errors and ECC errors in entries on forwarding chips.
After you execute this command, the device collects parity errors and ECC errors periodically. If the number of parity errors and ECC errors in a statistics period reaches or exceeds the logging threshold, the device generates and sends a parity error and ECC error log message to the information center module. The information center module determines how and where to send the message. For more information about the information center module, see information center configuration in System Management Configuration Guide.
# Enable parity error and ECC error logging for entries on forwarding chips.
[Sysname] parity-error monitor log enable
parity-error monitor period
parity-error monitor threshold
Use parity-error monitor period to set the parity error and ECC error statistics period for entries on forwarding chips.
Use undo parity-error monitor period to restore the default.
parity-error monitor period value
The parity error and ECC error statistics period is 60 seconds for entries on forwarding chips.
period: Specifies the parity error and ECC error statistics period in seconds, in the range of 1 to 86400.
The device automatically detects parity errors and ECC errors in entries on forwarding chips. The parity error and ECC error logging feature collects parity error and ECC error statistics periodically, and generates a log message if the number of parity error and ECC errors reaches the logging threshold.
This command determines the period for the device to collect parity error and ECC error statistics.
# Set the parity error and ECC error statistics period to 120 seconds.
[Sysname] parity-error monitor period 120
Use parity-error monitor threshold to set the parity error and ECC error logging threshold for entries on forwarding chips.
Use undo parity-error monitor threshold to restore the default.
parity-error monitor threshold value
In a version earlier than R2719P02, the parity error and ECC error logging threshold is 5000 for entries on forwarding chips.
In R2719P02 and later, The parity error and ECC error logging threshold is 20000 for entries on forwarding chips.
value: Specifies the parity error and ECC error logging threshold for entries on forwarding chips, in the range of 1 to 1000000.
The device detects parity error and ECC errors in entries on forwarding chips. The parity error and ECC error logging feature collects parity error and ECC error statistics periodically, and generates a log message if the number of parity error and ECC errors reaches the logging threshold. This command sets the logging threshold.
# Set the parity error and ECC error logging threshold to 8000 for entries on forwarding chips.
[Sysname] parity-error monitor threshold 8000
parity-error unrecoverable log enable
Use parity-error unrecoverable log enable to enable uncorrectable parity error and ECC error logging for entries on forwarding chips.
Use undo parity-error unrecoverable log enable to disable uncorrectable parity error and ECC error logging for entries on forwarding chips.
Uncorrectable parity error and ECC error logging is enabled for entries on forwarding chips
The device automatically detects parity errors and ECC errors in entries on forwarding chips and tries to correct the error when an error is detected. The uncorrectable parity error and ECC error logging feature enables the device to collect uncorrectable parity error and ECC error statistics periodically. If the number of uncorrectable parity errors and ECC errors reaches or exceeds the logging threshold, the device generates and sends an uncorrectable parity error and ECC error log message to the information center module. The information center module determines how and where to send the log message. For more information about the information center module, see information center configuration in System Management Configuration Guide.
# Enable uncorrectable parity error and ECC error logging for entries on forwarding chips
[Sysname] parity-error unrecoverable log enable
parity-error unrecoverable period
parity-error unrecoverable reboot
parity-error unrecoverable threshold
Use parity-error unrecoverable period to set the statistics period for uncorrectable parity errors and ECC errors for entries on forwarding chips.
Use undo parity-error unrecoverable period to restore the default.
parity-error unrecoverable period period
The statistics period for uncorrectable parity errors and ECC errors for entries on forwarding chips is 60 seconds.
period: Specifies the statistics period for uncorrectable parity errors and ECC errors for entries on forwarding chips. The value is in the range of 1 to 86400, in seconds.
The device automatically detects parity errors and ECC errors in entries on forwarding chips and tries to correct the error when an error is detected. The uncorrectable parity error and ECC error logging feature enables the device to collect uncorrectable parity error and ECC error statistics periodically. If the number of uncorrectable parity errors and ECC errors reaches or exceeds the logging threshold, the device generates an uncorrectable parity error and ECC error log message.
This command sets the period for the device to collect uncorrectable parity error and ECC error statistics.
# Set the statistics period for uncorrectable parity errors and ECC errors in entries on forwarding chips to 120 seconds.
[Sysname] parity-error unrecoverable period 120
Use parity-error unrecoverable reboot to enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
Use undo parity-error unrecoverable reboot to disable automatic system reboot upon generation of an uncorrectable parity error and ECC error log
The system reboots automatically upon generation of an uncorrectable parity error and ECC error log.
Uncorrectable parity errors and ECC errors in entries on forwarding chips might affect system services. To remove the errors from the entries on forwarding chips, you can execute this command to enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
# Enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
[Sysname] parity-error unrecoverable reboot
Use parity-error unrecoverable threshold to set the logging threshold for uncorrectable parity errors and ECC errors on entries on forwarding chips.
Use undo parity-error unrecoverable threshold to restore the default.
parity-error unrecoverable threshold value
The logging threshold is 1 for uncorrectable parity errors and ECC errors in entries on forwarding chips.
value: Specifies the logging threshold for uncorrectable parity errors and ECC errors in entries on forwarding chips. The value is in the range of 1 to 1000000.
# Set the logging threshold for uncorrectable parity errors and ECC errors in entries on forwarding chips to 10.
[Sysname] parity-error unrecoverable log threshold 10
power-exception-monitor
Use power-exception-monitor to configure the exception monitoring mode for power modules.
power-exception-monitor { normal | enhanced }
The normal exception monitoring mode applies to power modules.
normal: Generates alarm information when a power module exception occurs.
enhanced: Monitors power modules continuously and generates alarm information when a temperature, voltage, or current exception occurs on a power module.
The enhanced exception monitoring mode for power modules occupies lots of system resources.
# Set the exception monitoring mode for power modules to normal.
[Sysname] power-exception-monitor normal
power-monitor enable
Use power-monitor enable to enable power on/off management of cards.
Use undo power-monitor enable to disable power on/off management of cards.
Power on/off management of cards is enabled.
Disabling power on/off management of cards might result in unpredictable risks. Execute the undo power-monitor enable command with caution.
After the power-monitor enable command is executed, the system performs the following operations:
·     Check the total system power and the power distribution on the cards to determine whether to power on cards.
·     Check the card temperature and fan tray conditions to determine whether to power off cards.
If power on/off management of cards is disabled, the device will not manage the power-on and -off of the cards, and all cards are powered on by default.
# Enable power on/off management of cards.
[Sysname] power-monitor enable
power-supply off
Use power-supply off to power off a card.
power-supply off slot slot-number
slot slot-number: Specifies a card by its slot number..
A card cannot send or receive packets after you forcibly power off it. Make sure you understand its impact on the live network before executing this command.
To use this command, you must enable power supply management first.
When power is insufficient, you can power off interface modules that are idle or connected to unimportant network nodes to ensure power supply to critical interface modules.
# Power off a card.
<Sysname> power-supply off slot 2
power-supply policy enable
power-supply on
Use power-supply on to power on a card
power-supply on slot slot-number
# Power on a card.
<Sysname> power-supply on slot 2
Use power-supply policy enable to enable power supply management.
Use undo power-supply policy enable to disable power supply management.
Power supply management is enabled.
# Enable power supply management.
[Sysname] power-supply policy enable
power-supply policy redundant
Use power-supply policy redundant to specify the number of redundant power modules.
Use undo power-supply policy redundant to restore the default.
power-supply policy redundant module-count
The number of redundant power modules is 0.
module-count: Specifies the number of redundant power modules. To view the value range for this argument, enter a question mark (?) in the place of this argument. The upper limit for the value range is the maximum number of redundant power modules supported by the system. The actual number of redundant power modules that you can specify varies by the number of the interface modules and their power consumption. The actual number is smaller than or equal to the maximum number.
This command takes effect only if power supply management is enabled.
# Set the number of redundant power modules to 1.
[Sysname] power-supply policy redundant 1
power-supply surplus-power enable
Use power-supply surplus-power enable to enable power module sleeping.
Use undo power-supply surplus-power enable to disable power module sleeping.
This feature is available only for switches that are installed with the PSR2400-54A, PSR2400-54D, or PSR3000-54A power module.
This feature takes effect only when power supply management is enabled.
Power modules in sleeping state cannot act as the backup power modules. When an operating power module fails or is removed, the device might not be able to operate correctly.
To view the operating status of power modules, execute the display power command.
This feature enables the device to monitor the remaining power in real time.
·     If the remaining power is greater than the power of a power module, the device places the power module into sleeping state.
·     When the remaining power becomes insufficient, the device wakes up a sleeping power module.
# Enable power module sleeping.
[Sysname] power-supply surplus-power enable
reset transceiver interface
Use reset transceiver interface to reset a 400G transceiver module.
reset transceiver interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command applies to all interfaces.
This command is disruptive. Use this command only when you cannot troubleshoot transceiver modules by using other methods.
This command will restart the transceiver module.
# Reset the 400G transceiver module in FourHundredGigE 1/0/1.
<Sysname> reset transceiver interface fourhundredgige 1/0/1
This operation causes services on the transceiver module to be down for a while. Continue? [Y/N]: Y
resource-monitor minor resend enable
Use resource-monitor minor resend enable to enable resending of minor resource depletion alarms.
Use undo resource-monitor minor resend enable to disable resending of minor resource depletion alarms.
Resending of minor resource depletion alarms is enabled.
When a resource type enters minor alarm state, the device issues a minor alarm. If the resource type stays in minor alarm state or changes from severe alarm state to minor alarm state, the device identifies whether resending of minor resource depletion alarms is enabled. If the feature is disabled, the device does not issue additional minor alarms. If the feature is enabled, the device resends minor alarms periodically.
The resending interval of severe alarms is 24 hours and the resending interval of minor alarms is 7×24 hours.
# Enable resending of minor resource depletion alarms.
[Sysname] resource-monitor minor resend enable
display resource-monitor
resource-monitor output
resource-monitor resource
Use resource-monitor output to specify destinations for resource depletion alarms.
Use undo resource-monitor output to remove destinations for resource depletion alarms.
undo resource-monitor output [ netconf-event | snmp-notification | syslog ] *
Resource depletion alarms are sent to NETCONF, SNMP, and the information center.
netconf-event: Sends resource depletion alarms to the NETCONF feature to encapsulate the alarms in NETCONF events. For more information, see NETCONF in Network Management and Monitoring Configuration Guide.
snmp-notification: Sends resource depletion alarms to the SNMP feature to encapsulate the alarms in SNMP traps and informs. For more information, see SNMP in Network Management and Monitoring Configuration Guide.
syslog: Sends resource depletion alarms to the information center to encapsulate the alarms in log messages. For more information, see information center in System Management Configuration Guide.
If you do not specify any keywords for the undo resource-monitor output command, the command disables resource depletion alarm output.
# Specify the information center module as the output destination for resource depletion alarms.
[Sysname] resource-monitor output syslog
Use resource-monitor resource to set resource depletion thresholds.
Use undo resource-monitor resource to disable resource depletion thresholds.
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
The default settings vary by resource type. Use the display resource-monitor command to display the resource depletion thresholds.
resource-name: Specifies a resource type by its name. The values for this argument are case insensitive and cannot be abbreviated. Table 26 shows the resource types that can be monitored.
Table 26 Resource types that can be monitored
Resource type
ac
Number of Ethernet service instances.
agg_group
Aggregation group hardware resources.
arp
ARP hardware resources.
ecmp_fec_1
Level-1 ECMP FEC hardware resources.
ecmp_fec_2
Level-2 ECMP FEC hardware resources.
ecmp_fec_3
Level-3 ECMP FEC hardware resources.
local_ecmp
Local ECMP group hardware resources.
local_fec_1
Level-1 local FEC hardware resources.
local_fec_2
Level-2 local FEC hardware resources.
local_fec_3
Level-3 local FEC hardware resources.
mac
MAC address table hardware resources.
mc
Multicast hardware resources.
mqcin
Inbound MQC hardware resources.
mqcout
Outbound MQC hardware resources.
nd
ND hardware resources.
openflow
OpenFlow hardware resources.
pbr
PBR hardware resources.
pfilterin
Inbound packet filter resources.
pfilterout
Outbound packet filter resources.
route
Routing hardware resources.
rport
Layer 3 aggregate subinterface hardware resources.
subrport
Layer 3 Ethernet subinterface hardware resources.
vlan
Number of VLANs.
vlaninterface
VLAN interface hardware resources.
vrf
VPN instance hardware resources.
vsiintf
VSI interface hardware resources.
by-percent: Specifies resource depletion thresholds in percentage.
minor-threshold minor-threshold: Specifies the minor resource depletion threshold. To view the value range, enter a question mark (?) in the place of the minor-threshold argument.
severe-threshold severe-threshold: Specifies the severe resource depletion threshold. To view the value range, enter a question mark (?) in the place of the severe-threshold argument.
After you execute this command for a resource type, the device monitors the available amount of the type of resources. The device samples the available amount at intervals, compares the sample with the resource depletion thresholds to identify the resource depletion status, and sends alarms as configured.
# Set the minor resource depletion threshold to 30% and the severe resource depletion threshold to 10% for ARP entry resources on slot 1.
[Sysname] resource-monitor resource arp slot 1 cpu 0 by-percent minor-threshold 30 severe-threshold 10
shutdown-interval
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval interval
The port status detection timer setting is 30 seconds.
interval: Specifies the port status detection timer value in seconds. The value range is 0 to 300. The value of 0 indicates that port status detection is not automatically performed, and you need to execute the undo shutdown command to restore the port status manually.
The device starts a port status detection timer when a port is shut down by a protocol. If the port has been in down state before the timer expires, the device will set the port status to the port's physical status.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
If T < T1, the port will be brought up after T1 – T seconds.
If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer setting to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
system handshake timeout
Use system handshake timeout to set the handshake timeout time between an MPU and an interface module.
Use undo system handshake timeout to restore the default.
system handshake timeout timeout
The handshake timeout time is 30 seconds between an MPU and an interface module.
timeout: Specify the handshake timeout time between an MPU and an interface module, in the range of 10 to 55 seconds.
After starting up, an interface module will actively register with an MPU so that it can be managed by the MPU. During device operation, the MPU will periodically send handshake packets to the interface to identify whether the interface module is operating correctly. If the interface module does not reply to the MPU before the specified timeout time expires, the MPU considers the interface module to be faulty and will restart the interface module.
In some scenarios with handshake timeout requirements, you can execute this command to specify a handshake timeout time as needed to identify faulty interfaces as soon as possible. For example, some scenarios might require a short traffic interruption due to card restart.
# Set the handshake timeout time to 40 seconds between the MPU and an interface module.
[Sysname] system handshake timeout 40
temperature-limit
Use temperature-limit to set the temperature alarm thresholds.
Use undo temperature-limit to restore the default.
temperature-limit slot slot-number { hotspot } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot } sensor-number
The defaults vary by temperature sensor model. To view the defaults, execute the undo temperature-limit and display environment commands in turn.
hotspot: Configures temperature alarm thresholds for hotspot sensors. A hotspot sensor is typically near the chip that generates a great amount of heat and used to monitor the chip.
sensor-number: Specifies a sensor by its number. To view the value range, enter a question mark (?) in the place of this argument.
lowlimit: Specifies the low-temperature threshold in Celsius degrees. The value range varies by temperature sensor. To view the value range, enter a question mark (?) in the place of this argument.
warninglimit: Specifies the high-temperature warning threshold in Celsius degrees. This threshold must be greater than the low-temperature threshold. To view the value range, enter a question mark (?) in the place of this argument.
alarmlimit: Specifies the high-temperature alarming threshold in Celsius degrees. This threshold must be greater than the warning threshold. To view the value range, enter a question mark (?) in the place of this argument.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning or alarming threshold, the device performs the following operations:
·     Sends log messages and traps.
·     Sets LEDs on the device panel.
# Set temperature alarm thresholds for hotspot sensor 1 in a slot.
[Sysname] temperature-limit slot 1 hotspot 1 -10 50 60
display environment
transceiver diagnostic selector
Use transceiver diagnostic selector to specify a diagnostic selector for a transceiver module and display specified diagnostic information.
transceiver diagnostic selector selector-id
No diagnostic selector is specified for a transceiver module.
200-GE interface view
400-GE interface view
selector-id: Specifies a diagnostic selector. The value range varies by transceiver module model.
The command settings will be saved in a register of the transceiver module. If the transceiver module has a power loss, the command settings will be cleared. You must reconfigure the command after a power recovery.
# Specify diagnostic selector 1 for the transceiver module in FourHundredGigE1/0/1 and display  specified diagnostic information.
[Sysname] interface fourhundredgige 1/0/1
[Sysname-FourHundredGigE1/0/1] transceiver diagnostic selector 1
Lane     Host side BER     Media side BER
1        1.00E-7           1.00E-7
2        1.00E-7           1.00E-7
3        1.00E-7           1.00E-7
4        1.00E-7           1.00E-7
5        1.00E-7           1.00E-7
6        1.00E-7           1.00E-7
7        1.00E-7           1.00E-7
8        1.00E-7           1.00E-7
# Specify diagnostic selector 2 for the transceiver module in FourHundredGigE 1/0/1 and display specified diagnostic information.
[Sysname-FourHundredGigE1/0/1] transceiver diagnostic selector 2
Lane     Host error count     Host total bits
1        1234567890           1234567890123456789
2        1234567890           1234567890123456789
3        1234567890           1234567890123456789
4        1234567890           1234567890123456789
# Specify diagnostic selector 6 for the transceiver module in FourHundredGigE 1/0/1 and display specified diagnostic information.
[Sysname-FourHundredGigE1/0/1] transceiver diagnostic selector 6
Lane     Host peak detect        Host SNR        Media peak detect        Media SNR
1        12345                   18.00dB         12345                    18.00dB
2        12345                   18.00dB         12345                    18.00dB
3        12345                   18.00dB         12345                    18.00dB
4        12345                   18.00dB         12345                    18.00dB
5        12345                   18.00dB         12345                    18.00dB
6        12345                   18.00dB         12345                    18.00dB
7        12345                   18.00dB         12345                    18.00dB
8        12345                   18.00dB         12345                    18.00dB
transceiver host-fault-detect enable
Use transceiver host-fault-detect enable to enable fault detection on the transceiver host side.
Use undo transceiver host-fault-detect to disable fault detection on the transceiver host side.
Fault detection is disabled on the transceiver host side.
400-GE Ethernet interface view and its breakout interface view
This command is available only for the QSFPDD-400G-ZR transceiver module.
If a transceiver module is hot-swapped or reset, this command becomes invalid. You can execute this command again after a hot-swap or reset operation.
# Enable fault detection on the host side of the transceiver module in interface FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] transceiver host-fault-detect enable
transceiver lane enable
Use transceiver lane enable to enable a lane on a 400G transceiver module.
Use undo transceiver lane to disable a lane on a 400G transceiver module.
transceiver lane [ lane-number ] enable
undo transceiver lane [ lane-number ] enable
All lanes on a transceiver module are enabled.
lane-number: Specifies a lane by its number in the range of 1 to 8. If you do not specify a lane, this command enables all lanes on the transceiver module.
Execute this command only to verify that a transceiver module operates correctly.
Disabling a lane will stop signal transmission on the lane.
Disabling a lane will stop signal transmission on the fiber port where the lane is located.
This setting is saved in a register on the transceiver module. It is not saved to the configuration file.
# Enable lane 1 on the 400G transceiver module in FourHundredGigE 1/0/1.
display transceiver status
transceiver lane equalization
Use transceiver lane equalization to configure the pre-cursor, post-cursor, and amplitude for a 400G transceiver module.
Use undo transceiver lane equalization to restore the default.
transceiver lane [ lane-number ] equalization { precursor precursor-value | postcursor postcursor-value | amplitude amplitude-value }
undo transceiver lane [ lane-number ] equalization { precursor | postcursor | amplitude }
The default settings vary by transceiver module model.
lane-number: Specifies a lane by its number in the range of 1 to 8. If you do not specify a lane, this command configures the settings for all lanes on the transceiver module.
precursor precursor-value: Specifies the Rx output equalization pre-cursor level code. The level codes include:
·     level0—No equalization.
·     level1—0.5 dB.
·     level2—1 dB.
·     level3—1.5 dB.
·     level4—2 dB.
·     level5—2.5 dB.
·     level6—3 dB.
·     level7—3.5 dB.
postcursor postcursor-value: Specifies the Rx output equalization post-cursor level code. The level codes include:
·     level1—1 dB.
·     level2—2 dB.
·     level3—3 dB.
·     level4—4 dB.
·     level5—5 dB.
·     level6—6 dB.
·     level7—7 dB.
amplitude amplitude-value: Specifies the Rx output amplitude range code. The range codes include:
·     range0—100 to 400 mV.
·     range1—300 to 600 mV.
·     range2—400 to 800 mV.
·     Range3—600 to 1200 mV.
Use this command to adjust and optimize high speed signals of a 400G transceiver module for the optical link to work in the optimum state. Use the default setting unless required otherwise. To change the default settings, contact professional engineers to avoid transceiver module exceptions.
As a best practice, do not execute this command when the interface is transmitting traffic. During execution of this command, the device disables and then enables the transceiver module automatically and traffic transmission will be interrupted.
# Configure the pre-cursor and post-cursor equalizers, and amplitude for the 400G transceiver module in FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] transceiver lane 1 equalization pre-cursor 1 post-cursor 8 amplitude 3
This operation will shut down and then bring up the transceiver module, affecting data transmission. Continue? [Y/N]:Y
display transceiver active-control
transceiver lane loopback
Use transceiver lane loopback to enable loopback testing on a transceiver module lane and specify a loopback testing mode.
Use undo transceiver lane loopback to restore the default.
transceiver lane [ lane-number ] loopback loopback-mode
undo transceiver lane [ lane-number ] loopback loopback-mode
Loopback testing is disabled for transceiver module lanes.
lane-number: Specifies a lane by its number. The value is in the range of 1 to 4 for a 200G transceiver module and in the range of 1 to 8 for a 400G transceiver module. If you do not specify a lane, this command applies to all lanes of the transceiver module.
loopback-mode: Specifies a loopback testing mode.
·     host-input: Loopbacks the signal from the transmitter of the host side to the receiver of the host side as the input signal of the host.
·     host-output: Loopbacks the signal received by the receiver of the host side to the transmitter of the host side as the output signal of the host.
·     media-input: Loopbacks the signal from the transmitter of the media side to the receiver of the media side as the input signal of the media.
·     media-output: Loopbacks the signal received by the receiver of the media side to the transmitter of the media side as the output signal of the media.
This command is available only for 200G and 400G transceiver modules that support CMIS 4.0.
This command tests whether messages can be forwarded correctly between the designated transmitter and receiver and helps identify the point of failure when the transceiver module fails to forward messages.
# Enable loopback testing and specify a loopback testing mode for lanes of the transceiver module in FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] transceiver lane loopback media-input
This operation causes the service to be down for a while. Continue? [Y/N]:Y
transceiver lane pattern
Use transceiver lane pattern to configure the signal mode and signal transmission Pseudo Random Binary Sequence (PRBS) pattern for a transceiver module lane.
Use undo transceiver lane pattern to restore the default.
transceiver lane [ lane-number ] pattern [ host-checker | host-generator media-checker | media-generator ] prbs-pattern
undo transceiver lane [ lane-number ] pattern
host-checker: Specifies the host-side signal check mode.
host-generator: Specifies the host-side signal generation mode.
media-checker: Specifies the media-side signal check mode.
media-generator: Specifies the medial-side signal generation mode.
prbs-pattern: Specifies a signal transmission PRBS pattern. The value range varies by transceiver module model.
This command settings will be saved in a register of the transceiver module. If the transceiver module has a power loss, the command settings will be cleared. You must reconfigure the command after a power recovery.
# Specify the host-side signal generation mode and signal transmission pattern of PRBS-31Q for all lanes of the transceiver module in FourHundredGigE1/0/1.
[Sysname-FourHundredGigE1/0/1] transceiver lane pattern host-generator PRBS-31Q
transceiver monitor enable
Use transceiver monitor enable to enable transceiver monitoring.
Use undo transceiver monitor enable to disable transceiver monitoring.
transceiver monitor enable [ grey | tunable ]
Transceiver monitoring is disabled.
grey: Specifies grey transceiver modules.
tunable: Specifies tunable transceiver modules.
After transceiver monitoring is enabled, the device samples the parameters of transceiver modules periodically, including the input power and output power of transceiver modules. If a sampled value reaches the alarm threshold, the device generates a log to notify users.
If you specify the grey keyword, the system monitors only grey transceiver modules. If you specify the tunable keyword, the system monitors only tunable transceiver modules. If you do not specify the grey or tunable keyword, the system monitors all types of transceiver modules.
# Enable transceiver monitoring.
[Sysname] transceiver monitor enable
transceiver monitor interval
Use transceiver monitor interval to set a transceiver monitoring interval.
Use undo transceiver monitor interval to restore the default.
transceiver monitor interval interval
The transceiver monitoring interval is 600 seconds.
interval: Specifies the transceiver monitoring interval in seconds. The value range is 300 to 3600.
After transceiver monitoring is enabled, the device samples the parameters of transceiver modules periodically, including the input power and output power of transceiver modules. If a sampled value reaches the alarm threshold, the device generates a log entry to notify users.
This command takes effect only when the transceiver monitor enable command is used.
# Set the transceiver monitoring interval to 500 seconds.
[Sysname] transceiver monitor interval 500
transceiver media-fault-detect enable
Use transceiver media-fault-detect enable to enable fault detection on the transceiver media side.
Use undo transceiver media-fault-detect to enable fault detection on the transceiver media side.
Fault detection is disabled on the transceiver media side.
# Enable fault detection on the media side of the transceiver module in interface FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] transceiver media-fault-detect enable
transceiver optical-channel frequency
Use transceiver optical-channel frequency to set the frequency and frequency grid for a transceiver optical channel.
Use undo transceiver optical-channel frequency to restore the default.
transceiver optical-channel optical-channel-number frequency frequency-value [ grid grid-value ]
undo transceiver optical-channel optical-channel-number frequency
The default varies by transceiver module model.
optical-channel-number: Specifies an optical channel by its channel number, which is fixed at 1.
frequency-value: Specifies the operating frequency of the optical channel in the range of 191300000 to 196100000 MHz.
grid grid-value: Specifies the grid of the operating frequency. The available values for the grid-value argument vary by transceiver module model. Valid values typically include 3125 MHz, 6250 MHz, 12500 MHz, 25000 MHz, 33000 MHz, 50000 MHz, 75000 MHz, and 100000 MHz. To view the value range, enter a question mark (?) in the place of the grid-value argument.
Before executing this command, use reference frequency 193100000 MHz and the specified operating frequency grid to calculate an operating frequency value as follows:
The operating frequency of an optical channel = 193100000 MHz ± the operating frequency grid × n, where n represents an integer.
If the operating frequency value is calculated incorrectly, the configuration fails.
If you do not specify the grid grid-value option, you can use any supported value for the grid-value argument to calculate the operating frequency value.
If you specify the grid grid-value option, you must use the specified value for the grid-value argument to calculate the operating frequency value. If you fail to do so, the configuration fails.
# Specify the operating frequency of optical channel 1 on the transceiver module in interface FourHundredGigE1/0/1 .
[Sysname-FourHundredGigE1/0/1] transceiver optical-channel 1 frequency ?
  <191000000-195000000>
[Sysname-FourHundredGigE1/0/1] transceiver optical-channel 1 frequency 193200000
transceiver optical-channel tx-power
Use transceiver optical-channel tx-power to specify the transmit power of an optical channel on a transceiver module.
Use undo transceiver optical-channel tx-power to restore the default.
transceiver optical-channel optical-channel-number tx-power power-value
undo transceiver optical-channel optical-channel-number tx-power
The transmit power of an optical channel is –10 dBm.
optical-channel-number: Specifies an optical channel by its number, which is fixed at 1.
power-value: Specifies the transmit power in dBm, accurate to 0.01. The value range for this argument varies by transceiver module model.
# Specify the transmit power of optical channel 1 on the transceiver module in interface FourHundredGigE 1/0/1 as –5 dBm.
[Sysname-FourHundredGigE1/0/1] transceiver optical-channel 1 tx-power -5
transceiver performance-collection enable
Use transceiver performance-collection enable to enable transceiver performance sampling.
Use undo transceiver performance-collection enable to disable transceiver performance sampling.
Transceiver performance sampling is disabled.
If you enable transceiver performance sampling, the device samples transceiver performance information at intervals and save the samples to a buffer. You can use the display transceiver history performance-collection command to view the recent transceiver performance information.
# Enable transceiver performance sampling
[Sysname] transceiver performance-collection enable
transceiver performance-collection interval
Use transceiver performance-collection interval to specify the transceiver performance sampling interval.
Use undo transceiver performance-collection interval to restore the default.
transceiver performance-collection interval interval
The transceiver performance sampling interval is 15 minutes.
interval: Specifies the transceiver performance sampling interval. Valid values include 5min (5 minutes), 15min (15 minutes), 30min (30 minutes), and 60min (60 minutes), case insensitive. You must enter a valid value completely. If you fail to do so, the system prompts a parameter error.
# Specify the transceiver performance sampling interval as 5 minutes.
[Sysname] transceiver performance-collection interval 5min
transceiver power-mode
Use transceiver power-mode to set the power mode for a 400G transceiver module.
Use undo transceiver power-mode to restore the default.
transceiver power-mode { high | low }
A transceiver module typically operates in high power mode. If a transceiver module will be idle for a long time, you can switch it to low power mode to reduce power consumption. In low power mode, the transceiver module does not transmit signals. For a transceiver module to transmit signals, you must configure it to operate in high power mode.
# Configure the 400G transceiver module in FourHundredGigE 1/0/1 to operate in high power mode.
[Sysname-FourHundredGigE1/0/1] transceiver power-mode high
# Configure the 400G transceiver module in FourHundredGigE 1/0/1 to operate in low power mode.
[Sysname-FourHundredGigE1/0/1] transceiver power-mode low
This command will place the transceiver module in low-power-consumption mode, disabling the transceiver module from transmitting data. Continue? [Y/N]:Y
